| 0004008 | Path | Bug | public | 2019-06-06 15:47 | 2019-06-23 21:52 |
| Reporter | sliptonic | Assigned To | russ4262 | ||
| Summary | 0004008: Phantom paths are displayed when job origin is moved. | ||||
| Description | https://forum.freecadweb.org/viewtopic.php?f=15&t=36825&p=312726#p312726 | ||||
The situation presented in the FreeCAD forum link in the Description above is fixed with two things:
That is NOT to say that there is no bug. I noticed that using the if you select the head of the Job in the object tree and toggle its visibility, OR hide selection, that only the phantom paths disappear/re-appear. I think the issue is related to transformation of either the Job, the Body, or related sub-component of these. |
Thanks to @sliptonic for assistance in properly applying the fix. Source of phantom paths is that in specific use cases, the Job was the active object for transformations performed in Job->Setup->Layout, rather than a Job base being the active object. Follow-up to improve this fix is to add a selection gate limiting selection during Job model editing to bases or stock belonging to current Job being edited. Current fix is included in FreeCAD Pull Request 2276 |
FreeCAD: master 8b3c4ac0 2019-06-20 04:35:13 Details Diff |
Fixes bug 0004008: removes phantom path cause Job object was base of transformations, rather than Job base(clone). |
Affected Issues 0004008 |
| mod - src/Mod/Path/PathScripts/PathJobGui.py | Diff File | ||
FreeCAD: master 332bfb50 2019-06-20 04:35:13 Details Diff |
FreeCAD: releases/FreeCAD-0-18 43510585 2019-06-20 04:35:13 Committer: wmayer Details Diff |
| 2019-06-06 15:47 | sliptonic | New Issue | |
| 2019-06-06 21:08 | russ4262 | File Added: diamond-circ-sqr-2-nu.FCStd | |
| 2019-06-06 21:08 | russ4262 | File Added: diamond-circ-sqr-2-phantom.FCStd | |
| 2019-06-06 21:08 | russ4262 | Note Added: 0013153 | |
| 2019-06-17 08:09 | Kunda1 | Status | new => confirmed |
| 2019-06-20 04:27 | russ4262 | Assigned To | => russ4262 |
| 2019-06-20 04:27 | russ4262 | Status | confirmed => assigned |
| 2019-06-20 05:09 | russ4262 | Note Added: 0013274 | |
| 2019-06-20 12:59 | russ4262 | Changeset attached | => FreeCAD master 8b3c4ac0 |
| 2019-06-20 12:59 | russ4262 | Changeset attached | => FreeCAD master 332bfb50 |
| 2019-06-22 12:39 | wmayer | Changeset attached | => FreeCAD releases/FreeCAD-0-18 43510585 |
| 2019-06-23 21:52 | wmayer | Status | assigned => closed |
| 2019-06-23 21:52 | wmayer | Resolution | open => fixed |
| 2019-06-23 21:52 | wmayer | Fixed in Version | => 0.18 |
