0004009PathBugpublic2022-01-26 15:38
Reporterfreman Assigned Tomlampert
Status confirmedResolutionopen
Target Version0.20
Summary0004009: Dogbone locks up on path with two surface elements
DescriptionAs discussed here, if two sufraces are selected to for a milling path and dog-bone is applied it locks up totally. This does not seem to happen with a single geometry.
https://forum.freecad.org/viewtopic.php?f=15&t=36832
Freecad file demonstating problem.
https://forum.freecad.org/download/file.php?id=85053
Steps To Reproduceselect two surfaces
add face mill path
add dog bone dress-up
kill FreeCAD process
rince and repeat. ;)
Additional InformationOS: Linux (LXDE/LXDE)
Version: 0.19.16854 (Git)
Hash: fe0fd5512ba9a8a9c729cdc47af35bbe965050ac
Python version: 2.7.15
Qt version: 4.8.7
Locale: English/UnitedKingdom (en_GB)
Tags#tobeclosed, dogbone
sliptonic
2019-06-11 01:51
manager
negtest3.FCStd (38,370 bytes)
sliptonic
2019-06-11 01:51
manager   ~0013176
The description is not quite accurate. A dogbone dressup works fine with two separate faces. The problem is unique to this shape.
Increasing the radius of the circular middle tier so that it overlaps the lower square resolves the error. (see attached negtest3 file)
2020-01-08 18:24
administrator   ~0014022
Any conclusions on this ticket?
2022-01-22 22:09
administrator   ~0016246
@sliptonic I've tagged this #tobeclosed
Can you let me know if anything needs to happen before closing this ticket?
sliptonic
2022-01-25 15:00
manager   ~0016291
Good to close.
fremen
2022-01-26 07:09
reporter   ~0016316
What is the motivation to close this before the bug is fixed ?
Of course there a specific set of conditions which triggers the bug.That is the case with most bugs which don't get caught in initial testing.
Dogbone is fine mostly.
I cannot re-examine the FCStd file attached because the link no longer works but from the description it a work around. It is not showing that the original geometry was invalid in some way or that it will not be reproduced in the future.
The whole point of this test piece ( based on on ISO standard for testing CNC machine accuracy ) is that the circle diameter is identical to the side of the square. So the proposed "solution" negates the point of the part. Maybe the ISO standards should be changed so we don't need to fix FreeCAD ?
sliptonic
2022-01-26 15:27
manager   ~0016317
Lots of reasons to close an issue. Lack of interest is one. If the issue isn't getting attention, even by the original poster, then it's not likely to be taken seriously by a developer.
If this is still an issue for you, we can leave it open
fremen
2022-01-26 15:38
reporter   ~0016318
The bug seems legitimate and not disputed. It should stay open until it gets fixed, o/w not much point in having a bug tracker and taking the trouble to report defects.
It's unfortunate that the internal changes in FC mean the original file no longer works. But the cause seems clearly identified.
yorik
2022-03-03 13:55
administrator   ~0016778
This ticket has been migrated to GitHub as issue 5944.
2019-06-06 21:44 freman New Issue
2019-06-11 01:51 sliptonic File Added: negtest3.FCStd
2019-06-11 01:51 sliptonic Note Added: 0013176
2019-06-11 01:51 sliptonic Assigned To => mlampert
2019-06-11 01:51 sliptonic Status new => acknowledged
2019-06-11 01:54 sliptonic Note Edited: 0013176
2020-01-08 18:24 Kunda1 Note Added: 0014022
2020-01-14 17:37 Kunda1 Status acknowledged => confirmed
2020-01-14 17:38 Kunda1 Target Version => 0.19
2021-02-06 06:33 abdullah Target Version => 0.20
2021-09-06 10:16 Kunda1 Summary Dog bone locks up on path with two surface elements => Dogbone locks up on path with two surface elements
2021-09-06 10:18 Kunda1 Tag Attached: dogbone
2022-01-22 22:08 Kunda1 Tag Attached: #tobeclosed
2022-01-22 22:09 Kunda1 Note Added: 0016246
2022-01-25 15:00 sliptonic Note Added: 0016291
2022-01-26 07:09 fremen Note Added: 0016316
2022-01-26 15:27 sliptonic Note Added: 0016317
2022-01-26 15:38 fremen Note Added: 0016318
