| 0004013 | Sketcher | Bug | public | 2019-06-09 14:31 | 2019-06-22 07:58 |
| Reporter | openBrain | Assigned To | abdullah | ||
| Summary | 0004013: Sketcher falsely reports line already constrained (horizontal/vertical) | ||||
| Description | Sketcher wrongly reports a line already constrained vertical (horizontal) when one of its endpoint is already set vertical (horizontal) with another endpoint of the sketch. This happens only in continuous mode. --- Forum thread | ||||
| Steps To Reproduce | To reproduce, consider the simple sketch screenshot below (also attached as FCStd file): * Select the vertical constraint and apply on the upper left line => Sketcher (wrongly) reports the line has being already constrained vertical * Select the horizontal constraint and apply on the upper left line => Sketcher (wrongly) reports the line has being already constrained horizontal The weird thing is that if you first select the line, then apply the constraint (horizontal or vertical), everything works as expected. | ||||
| Additional Information | OS: Ubuntu 18.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.1. Build type: Release Python version: 2.7.15rc1 Qt version: 5.9.5 Coin version: 4.0.0a OCC version: 7.3.0 Locale: French/France (fr_FR) | ||||
| Tags | constraints, sketcher | ||||
@Kunda1 : sorry for all the work of rewriting. I wish I could edit it myself. ;) |
@openBrain updated your permissions, I think you can edit tickets now, please check. |
@Kunda1 confirmed. Thanks. Hopefully that will save you some time. ;) BTW : Is displaying external images supported by some way in MantisBT ? |
https://github.com/FreeCAD/FreeCAD/pull/2284 |
FreeCAD: master 3810381d 2019-06-22 06:17:51 Committer: abdullahtahiriyo Details Diff |
Sketcher: fixes no horizontal/vertical on segment after horizontal/vertical alignment ===================================================================================== Selecting first the horizontal/vertical constraint and applying to a line segment with a previous horizontal/vertical alignment constraint caused FreeCAD to refuse applying it. fixes 0004013 |
Affected Issues 0004013 |
| mod - src/Mod/Sketcher/Gui/CommandConstraints.cpp | Diff File | ||
| 2019-06-09 14:31 | openBrain | New Issue | |
| 2019-06-09 14:31 | openBrain | Tag Attached: constraints | |
| 2019-06-09 14:31 | openBrain | Tag Attached: sketcher | |
| 2019-06-09 14:31 | openBrain | File Added: bug_constraint.FCStd | |
| 2019-06-10 11:49 | Kunda1 | Summary | Sketcher falsely report line already constrained (horizontal/vertical) => Sketcher falsely reports line already constrained (horizontal/vertical) |
| 2019-06-10 11:49 | Kunda1 | Description Updated | |
| 2019-06-10 11:49 | Kunda1 | Steps to Reproduce Updated | |
| 2019-06-10 11:49 | Kunda1 | Additional Information Updated | |
| 2019-06-10 11:50 | Kunda1 | Description Updated | |
| 2019-06-10 11:50 | Kunda1 | Steps to Reproduce Updated | |
| 2019-06-10 11:51 | Kunda1 | File Added: ticket-4013.png | |
| 2019-06-10 11:52 | Kunda1 | Status | new => confirmed |
| 2019-06-10 11:52 | Kunda1 | Target Version | => 0.19 |
| 2019-06-10 17:35 | openBrain | Note Added: 0013173 | |
| 2019-06-10 17:37 | openBrain | Note Edited: 0013173 | |
| 2019-06-10 17:40 | Kunda1 | Note Added: 0013174 | |
| 2019-06-10 17:41 | openBrain | Note Edited: 0013173 | |
| 2019-06-10 17:45 | openBrain | Note Edited: 0013173 | |
| 2019-06-10 17:47 | openBrain | Note Added: 0013175 | |
| 2019-06-22 06:23 | abdullah | Note Added: 0013292 | |
| 2019-06-22 07:58 | abdullah | Changeset attached | => FreeCAD master 3810381d |
| 2019-06-22 07:58 | abdullah | Note Added: 0013293 | |
| 2019-06-22 07:58 | abdullah | Assigned To | => abdullah |
| 2019-06-22 07:58 | abdullah | Status | confirmed => closed |
| 2019-06-22 07:58 | abdullah | Resolution | open => fixed |
