| 0004020 | FreeCAD | Bug | public | 2019-06-14 07:23 | 2021-02-06 06:49 |
| Reporter | freman | Assigned To | |||
| Summary | 0004020: untrapped file error on start up. | ||||
| Description | Due to manual changes to file ownerships, some file has become a problem when starting FreeCAD. However, the error does not seem to be trapped at the point where the file is accessed and just bubbles up to be caught as an untrapped error which is so general as to not be any help in identifying and resolving the problem https://forum.freecad.org/viewtopic.php?f=3&t=37021&p=314367#p314367
An error report which stated the full file path and name would allow this to be fixed immediately. It seems that whatever function is attempting this file access is not trapping any file access errors and assumes it always works. While the cause in this case is outside FreeCAD, it seems it should trap any errors in file access. | ||||
OS: Linux Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.15303 (Git) Build type: Release Branch: master Hash: 6199c95fd71eacb9cc168426e55254aa79a42034 Python version: 2.7.15 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/UnitedKingdom (en_GB) |
@freman as required in the bug submission guidelines, could you please confirm bug is still present in the latest release version (yours is outdated) ? If possible, could also provide a way to reproduce the issue ? |
yes, still present on new build of 0.19 master today. However, as discussed in thread, there are two things happening here. The file permissions problem disappeared after a reboot, so the cause will be undetermined unless it happens again. the other connection message seems to be be LVM related coming from Qt. It is probably banal. This still reflects the need for better error trapping at a lower level, though it will not be possible to work out exactly where in this case until and unless it reoccurs. It seems some file access was being attempted without the success being tested. Knowing what file it was would have enabled it being resolved in minutes instead of not detected properly after hours. If I see it again , I will report back. |
While going through https://tracker.freecad.org/view.php?id=4351#bugnotes found this error as well. Using wmayer's comments in https://forum.freecad.org/viewtopic.php?t=37021 I modified the FreeCAD/src/Gui/GuiApplication.cpp to have Base::Console().Error("Event type: %d, receiver: %s\n", (int)event->type(), receiver->metaObject()->className()); at the exception handling areas. (made no difference). starting it with QT_QPA_PLATFORMTHEME=gtk3 QT_DEBUG_PLUGINS=1 ./bin/FreeCAD --write-log produced the attached file. OS: Linux Mint 19.3 (X-Cinnamon/cinnamon) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.22108 (Git) Build type: Unknown Branch: master Hash: 886d9656f0c4ccfd016e373f74cc2dde965d88e1 Python version: 3.6.9 Qt version: 5.9.5 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/Canada (en_CA) FreeCAD.log (59,248 bytes)
Msg: FreeCAD 0.19, Libs: 0.19R22108 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2020
FreeCAD is free and open-source software licensed under the terms of LGPL2+ license.
FreeCAD wouldn't be possible without FreeCAD community.
Log: Time = Wed Jul 22 09:54:08 2020
Log: AppDataSkipVendor = true
Log: AppHomePath = /home/chris/github/freecad-source/build/
Log: AppIcon = freecad
Log: AppTempPath = /tmp/
Log: BinPath = /home/chris/github/freecad-source/build/bin/
Log: BuildRepositoryURL = git://github.com/FreeCAD/FreeCAD.git master
Log: BuildRevision = 22108 (Git)
Log: BuildRevisionBranch = master
Log: BuildRevisionDate = 2020/07/21 20:12:16
Log: BuildRevisionHash = 886d9656f0c4ccfd016e373f74cc2dde965d88e1
Log: BuildVersionMajor = 0
Log: BuildVersionMinor = 19
Log: Console = 0
Log: CopyrightInfo = © Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2020
Log: Debug = 0
Log: DocPath = /home/chris/github/freecad-source/build/doc/
Log: ExeName = FreeCAD
Log: ExeVendor = FreeCAD
Log: ExeVersion = 0.19
Log: LoggingConsole = 1
Log: LoggingFile = 1
Log: LoggingFileName = /home/chris/.FreeCAD/FreeCAD.log
Log: MaintainerUrl = http://www.freecad.org/wiki/Main_Page
Log: PATH = /home/chris/anaconda3/condabin:/home/chris/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/usr/local/bin:/home/chris/.local/bin:/usr/local/cuda/bin:/home/chris/bin/flutter/bin:/home/chris/anaconda3/bin:/home/chris/bin/STMicroelectronics/STM32Cube/STM32CubeProgrammer/bin:/home/chris/raspberrypi/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian-x64/bin:/home/chris/.composer/vendor/bin
Log: PYTHONPATH =
Log: PythonSearchPath = /usr/lib/python36.zip:/usr/lib/python3.6:/usr/lib/python3.6:/usr/lib/python3.6/lib-dynload
Log: RunMode = Gui
Log: SplashAlignment = Bottom|Left
Log: SplashInfoColor = #c8c8c8
Log: SplashScreen = freecadsplash
Log: SplashTextColor = #ffffff
Log: StartWorkbench = StartWorkbench
Log: SystemParameter = /home/chris/.FreeCAD/system.cfg
Log: UserAppData = /home/chris/.FreeCAD/
Log: UserHomePath = /home/chris
Log: UserParameter = /home/chris/.FreeCAD/user.cfg
Log: Verbose =
Log: Create Application
Log: Run App init script
Log: Init: starting App::FreeCADInit.py
Log: Init: Searching for modules...
Log: Init: Initializing /home/chris/github/freecad-source/build/Mod/Tux(Init.py not found)... ignore
Log: Init: Initializing /home/chris/github/freecad-source/build/Mod/OpenSCAD... done
Log: Drawing became obsolete in 0.17; consider using TechDraw instead.
Log: Init: Initializing /home/chris/github/freecad-source/build/Mod/Drawing... done
Log: Init: Initializing /home/chris/github/freecad-source/build/Mod/Test... done
Log: Init: Initializing /home/chris/github/freecad-source/build/Mod/Fem... done
Log: Init: Initializing /home/chris/github/freecad-source/build/Mod/MeshPart... done
Log: Init: Initializing /home/chris/github/freecad-source/build/Mod/Draft... done
Log: Init: Initializing /home/chris/github/freecad-source/build/Mod/Part... done
Log: Init: Initializing /home/chris/github/freecad-source/build/Mod/Measure... done
Log: Init: Initializing /home/chris/github/freecad-source/build/Mod/Surface... done
Log: Init: Initializing /home/chris/github/freecad-source/build/Mod/Points... done
Log: Init: Initializing /home/chris/github/freecad-source/build/Mod/Complete... done
Log: Init: Initializing /home/chris/github/freecad-source/build/Mod/ReverseEngineering... done
Log: Init: Initializing /home/chris/github/freecad-source/build/Mod/Arch... done
Log: Init: Initializing /home/chris/github/freecad-source/build/Mod/TechDraw... done
Log: Init: Initializing /home/chris/github/freecad-source/build/Mod/AddonManager... done
Log: Init: Initializing /home/chris/github/freecad-source/build/Mod/Path... done
Log: Init: Initializing /home/chris/github/freecad-source/build/Mod/Image... done
Log: Init: Initializing /home/chris/github/freecad-source/build/Mod/Import... done
Log: Init: Initializing /home/chris/github/freecad-source/build/Mod/Start... done
Log: Init: Initializing /home/chris/github/freecad-source/build/Mod/Web... done
Log: Init: Initializing /home/chris/github/freecad-source/build/Mod/PartDesign... done
Log: Init: Initializing /home/chris/github/freecad-source/build/Mod/Mesh... done
Log: Init: Initializing /home/chris/github/freecad-source/build/Mod/Sketcher... done
Log: Init: Initializing /home/chris/github/freecad-source/build/Mod/Material... done
Log: Init: Initializing /home/chris/github/freecad-source/build/Mod/Robot... done
Log: Init: Initializing /home/chris/github/freecad-source/build/Mod/Inspection... done
Log: Init: Initializing /home/chris/github/freecad-source/build/Mod/Idf... done
Log: Init: Initializing /home/chris/github/freecad-source/build/Mod/Raytracing... done
Log: Init: Initializing /home/chris/github/freecad-source/build/Mod/Show(Init.py not found)... ignore
Log: Init: Initializing /home/chris/github/freecad-source/build/Mod/Spreadsheet... done
Log: Init: Initializing /home/chris/.FreeCAD/Mod/Assembly4... done
Log: Init: Initializing /home/chris/.FreeCAD/Mod/sheetmetal... done
Log: Init: Initializing /home/chris/.FreeCAD/Mod/kicadStepUpMod... done
Log: Init: Initializing /home/chris/.FreeCAD/Mod/LCInterlocking... done
Log: Init: Initializing /home/chris/.FreeCAD/Mod/3D_Printing_Tools(Init.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/parts_library(Init.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/Mechatronic1(Init.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/gbNov8.stl(Init.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/BIM(Init.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/drivdisk.stl(Init.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/CycloidGearBox(Init.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/ExplodedAssembly(Init.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/symbols_library(Init.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/ThreadProfile... done
Log: Init: Initializing /home/chris/.FreeCAD/Mod/workfeature(Init.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/Manipulator... done
Log: Init: Initializing /home/chris/.FreeCAD/Mod/gbNov8.FCStd(Init.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/DynamicData... done
Log: Init: Initializing /home/chris/.FreeCAD/Mod/pindisk.stl(Init.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/Mechatronic... done
Log: Init: Initializing /home/chris/.FreeCAD/Mod/FCGear(Init.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/New Folder2(Init.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/A2plus... done
Log: Init: Initializing /home/chris/.FreeCAD/Mod/New Folder3(Init.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/BOLTSFC(Init.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/ose-piping-workbench(Init.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/cycdisk.stl(Init.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/fasteners... done
Log: Init: Initializing /home/chris/.FreeCAD/Mod/workfeature-macro(Init.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/Lithophane... done
Log: Init: Initializing /home/chris/.FreeCAD/Mod/FreeCAD_assembly3(Init.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/es.stl(Init.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/dummy.py(Init.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/New Folder(Init.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/RemBench(Init.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/lattice2(Init.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/PieMenu(Init.py not found)... ignore
Log: Init: Initializing freecad.asm3
Log: Init: No init module found in freecad.asm3, skipping
Log: Init: Initializing freecad.gears
Log: Init: No init module found in freecad.gears, skipping
Log: Using /home/chris/github/freecad-source/build/Mod as module path!
Log: System path after init:
Log: /home/chris/github/freecad-source/build/bin
Log: /home/chris/github/freecad-source/build/Mod/Tux
Log: /home/chris/github/freecad-source/build/Mod/OpenSCAD
Log: /home/chris/github/freecad-source/build/Mod/Drawing
Log: /home/chris/github/freecad-source/build/Mod/Test
Log: /home/chris/github/freecad-source/build/Mod/Fem
Log: /home/chris/github/freecad-source/build/Mod/MeshPart
Log: /home/chris/github/freecad-source/build/Mod/Draft
Log: /home/chris/github/freecad-source/build/Mod/Part
Log: /home/chris/github/freecad-source/build/Mod/Measure
Log: /home/chris/github/freecad-source/build/Mod/Surface
Log: /home/chris/github/freecad-source/build/Mod/Points
Log: /home/chris/github/freecad-source/build/Mod/Complete
Log: /home/chris/github/freecad-source/build/Mod/ReverseEngineering
Log: /home/chris/github/freecad-source/build/Mod/Arch
Log: /home/chris/github/freecad-source/build/Mod/TechDraw
Log: /home/chris/github/freecad-source/build/Mod/AddonManager
Log: /home/chris/github/freecad-source/build/Mod/Path
Log: /home/chris/github/freecad-source/build/Mod/Image
Log: /home/chris/github/freecad-source/build/Mod/Import
Log: /home/chris/github/freecad-source/build/Mod/Start
Log: /home/chris/github/freecad-source/build/Mod/Web
Log: /home/chris/github/freecad-source/build/Mod/PartDesign
Log: /home/chris/github/freecad-source/build/Mod/Sketcher
Log: /home/chris/github/freecad-source/build/Mod/Material
Log: /home/chris/github/freecad-source/build/Mod/Robot
Log: /home/chris/github/freecad-source/build/Mod/Inspection
Log: /home/chris/github/freecad-source/build/Mod/Idf
Log: /home/chris/github/freecad-source/build/Mod/Raytracing
Log: /home/chris/github/freecad-source/build/Mod/Show
Log: /home/chris/github/freecad-source/build/Mod/Spreadsheet
Log: /home/chris/.FreeCAD/Mod/Assembly4
Log: /home/chris/.FreeCAD/Mod/sheetmetal
Log: /home/chris/.FreeCAD/Mod/kicadStepUpMod
Log: /home/chris/.FreeCAD/Mod/LCInterlocking
Log: /home/chris/.FreeCAD/Mod/3D_Printing_Tools
Log: /home/chris/.FreeCAD/Mod/parts_library
Log: /home/chris/.FreeCAD/Mod/Mechatronic1
Log: /home/chris/.FreeCAD/Mod/gbNov8.stl
Log: /home/chris/.FreeCAD/Mod/BIM
Log: /home/chris/.FreeCAD/Mod/drivdisk.stl
Log: /home/chris/.FreeCAD/Mod/CycloidGearBox
Log: /home/chris/.FreeCAD/Mod/ExplodedAssembly
Log: /home/chris/.FreeCAD/Mod/symbols_library
Log: /home/chris/.FreeCAD/Mod/ThreadProfile
Log: /home/chris/.FreeCAD/Mod/workfeature
Log: /home/chris/.FreeCAD/Mod/Manipulator
Log: /home/chris/.FreeCAD/Mod/gbNov8.FCStd
Log: /home/chris/.FreeCAD/Mod/DynamicData
Log: /home/chris/.FreeCAD/Mod/pindisk.stl
Log: /home/chris/.FreeCAD/Mod/FCGear
Log: /home/chris/.FreeCAD/Mod/New Folder2
Log: /home/chris/.FreeCAD/Mod/A2plus
Log: /home/chris/.FreeCAD/Mod/New Folder3
Log: /home/chris/.FreeCAD/Mod/BOLTSFC
Log: /home/chris/.FreeCAD/Mod/ose-piping-workbench
Log: /home/chris/.FreeCAD/Mod/cycdisk.stl
Log: /home/chris/.FreeCAD/Mod/fasteners
Log: /home/chris/.FreeCAD/Mod/workfeature-macro
Log: /home/chris/.FreeCAD/Mod/Lithophane
Log: /home/chris/.FreeCAD/Mod/FreeCAD_assembly3
Log: /home/chris/.FreeCAD/Mod/es.stl
Log: /home/chris/.FreeCAD/Mod/dummy.py
Log: /home/chris/.FreeCAD/Mod/RemBench
Log: /home/chris/.FreeCAD/Mod/lattice2
Log: /home/chris/.FreeCAD/Mod/PieMenu
Log: /home/chris/anaconda3/condabin
Log: /home/chris/bin
Log: /usr/local/sbin
Log: /usr/local/bin
Log: /usr/sbin
Log: /usr/bin
Log: /sbin
Log: /bin
Log: /usr/games
Log: /usr/local/games
Log: /snap/bin
Log: /usr/local/bin
Log: /home/chris/.local/bin
Log: /usr/local/cuda/bin
Log: /home/chris/bin/flutter/bin
Log: /home/chris/anaconda3/bin
Log: /home/chris/bin/STMicroelectronics/STM32Cube/STM32CubeProgrammer/bin
Log: /home/chris/raspberrypi/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian-x64/bin
Log: /home/chris/.composer/vendor/bin
Log: Init: App::FreeCADInit.py done
Log: Init: Creating Gui::Application and QApplication
Log: QFactoryLoader::QFactoryLoader() checking directory path "/usr/lib/x86_64-linux-gnu/qt5/plugins/platforms" ...
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqeglfs.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqeglfs.so, metadata=
"IID": "org.qt-project.Qt.QPA.QPlatformIntegrationFactoryInterface.5.3",
"MetaData": {
"Keys": [
"eglfs"
"className": "QEglFSIntegrationPlugin",
"debug": false,
"version": 329989
Log: Got keys from plugin meta data ("eglfs")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqlinuxfb.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqlinuxfb.so, metadata=
"MetaData": {
"Keys": [
"linuxfb"
"className": "QLinuxFbIntegrationPlugin",
"debug": false,
"version": 329989
Log: Got keys from plugin meta data ("linuxfb")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqminimal.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqminimal.so, metadata=
"MetaData": {
"Keys": [
"minimal"
"className": "QMinimalIntegrationPlugin",
"debug": false,
"version": 329989
Log: Got keys from plugin meta data ("minimal")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqminimalegl.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqminimalegl.so, metadata=
"MetaData": {
"Keys": [
"minimalegl"
"className": "QMinimalEglIntegrationPlugin",
"debug": false,
"version": 329989
Log: Got keys from plugin meta data ("minimalegl")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqoffscreen.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqoffscreen.so, metadata=
"MetaData": {
"Keys": [
"offscreen"
"className": "QOffscreenIntegrationPlugin",
"debug": false,
"version": 329989
Log: Got keys from plugin meta data ("offscreen")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqvnc.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqvnc.so, metadata=
"MetaData": {
"Keys": [
"vnc"
"className": "QVncIntegrationPlugin",
"debug": false,
"version": 329989
Log: Got keys from plugin meta data ("vnc")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqwayland-egl.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqwayland-egl.so, metadata=
"MetaData": {
"Keys": [
"wayland-egl"
"className": "QWaylandEglPlatformIntegrationPlugin",
"debug": false,
"version": 329989
Log: Got keys from plugin meta data ("wayland-egl")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqwayland-generic.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqwayland-generic.so, metadata=
"MetaData": {
"Keys": [
"wayland"
"className": "QWaylandIntegrationPlugin",
"debug": false,
"version": 329989
Log: Got keys from plugin meta data ("wayland")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqwayland-xcomposite-egl.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqwayland-xcomposite-egl.so, metadata=
"MetaData": {
"Keys": [
"wayland-xcomposite-egl"
"className": "QWaylandXCompositeEglPlatformIntegrationPlugin",
"debug": false,
"version": 329989
Log: Got keys from plugin meta data ("wayland-xcomposite-egl")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqwayland-xcomposite-glx.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqwayland-xcomposite-glx.so, metadata=
"MetaData": {
"Keys": [
"wayland-xcomposite-glx"
"className": "QWaylandXCompositeGlxPlatformIntegrationPlugin",
"debug": false,
"version": 329989
Log: Got keys from plugin meta data ("wayland-xcomposite-glx")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqxcb.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqxcb.so, metadata=
"MetaData": {
"Keys": [
"xcb"
"className": "QXcbIntegrationPlugin",
"debug": false,
"version": 329989
Log: Got keys from plugin meta data ("xcb")
Log: QFactoryLoader::QFactoryLoader() checking directory path "/home/chris/github/freecad-source/build/bin/platforms" ...
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/libqxcb.so"
Log: loaded library "Xcursor"
Log: QFactoryLoader::QFactoryLoader() checking directory path "/usr/lib/x86_64-linux-gnu/qt5/plugins/xcbglintegrations" ...
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/xcbglintegrations/libqxcb-egl-integration.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/xcbglintegrations/libqxcb-egl-integration.so, metadata=
"IID": "org.qt-project.Qt.QPA.Xcb.QXcbGlIntegrationFactoryInterface.5.5",
"MetaData": {
"Keys": [
"xcb_egl"
"className": "QXcbEglIntegrationPlugin",
"debug": false,
"version": 329989
Log: Got keys from plugin meta data ("xcb_egl")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/xcbglintegrations/libqxcb-glx-integration.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/xcbglintegrations/libqxcb-glx-integration.so, metadata=
"MetaData": {
"Keys": [
"xcb_glx"
"className": "QXcbGlxIntegrationPlugin",
"debug": false,
"version": 329989
Log: Got keys from plugin meta data ("xcb_glx")
Log: QFactoryLoader::QFactoryLoader() checking directory path "/home/chris/github/freecad-source/build/bin/xcbglintegrations" ...
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/xcbglintegrations/libqxcb-glx-integration.so"
Log: QFactoryLoader::QFactoryLoader() checking directory path "/usr/lib/x86_64-linux-gnu/qt5/plugins/platformthemes" ...
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/platformthemes/KDEPlasmaPlatformTheme.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/platformthemes/KDEPlasmaPlatformTheme.so, metadata=
"IID": "org.qt-project.Qt.QPA.QPlatformThemeFactoryInterface.5.1",
"MetaData": {
"Keys": [
"kde"
"className": "KdePlatformThemePlugin",
"debug": false,
"version": 329989
Log: Got keys from plugin meta data ("kde")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/platformthemes/libqgtk3.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/platformthemes/libqgtk3.so, metadata=
"MetaData": {
"Keys": [
"gtk3"
"className": "QGtk3ThemePlugin",
"debug": false,
"version": 329989
Log: Got keys from plugin meta data ("gtk3")
Log: QFactoryLoader::QFactoryLoader() checking directory path "/home/chris/github/freecad-source/build/bin/platformthemes" ...
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/platformthemes/libqgtk3.so"
Log: QFactoryLoader::QFactoryLoader() checking directory path "/usr/lib/x86_64-linux-gnu/qt5/plugins/platforminputcontexts" ...
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/platforminputcontexts/libcomposeplatforminputcontextplugin.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/platforminputcontexts/libcomposeplatforminputcontextplugin.so, metadata=
"IID": "org.qt-project.Qt.QPlatformInputContextFactoryInterface.5.1",
"MetaData": {
"Keys": [
"compose",
"xim"
"className": "QComposePlatformInputContextPlugin",
"debug": false,
"version": 329989
Log: Got keys from plugin meta data ("compose", "xim")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/platforminputcontexts/libibusplatforminputcontextplugin.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/platforminputcontexts/libibusplatforminputcontextplugin.so, metadata=
"MetaData": {
"Keys": [
"ibus"
"className": "QIbusPlatformInputContextPlugin",
"debug": false,
"version": 329989
Log: Got keys from plugin meta data ("ibus")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/platforminputcontexts/libqtvirtualkeyboardplugin.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/platforminputcontexts/libqtvirtualkeyboardplugin.so, metadata=
"MetaData": {
"Keys": [
"qtvirtualkeyboard"
"className": "QVirtualKeyboardPlugin",
"debug": false,
"version": 329989
Log: Got keys from plugin meta data ("qtvirtualkeyboard")
Log: QFactoryLoader::QFactoryLoader() checking directory path "/home/chris/github/freecad-source/build/bin/platforminputcontexts" ...
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/platforminputcontexts/libcomposeplatforminputcontextplugin.so"
Log: QFactoryLoader::QFactoryLoader() checking directory path "/usr/lib/x86_64-linux-gnu/qt5/plugins/styles" ...
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/styles/breeze.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/styles/breeze.so, metadata=
"IID": "org.qt-project.Qt.QStyleFactoryInterface",
"MetaData": {
"Keys": [
"Breeze"
"className": "StylePlugin",
"debug": false,
"version": 329989
Log: Got keys from plugin meta data ("breeze")
Log: QFactoryLoader::QFactoryLoader() checking directory path "/home/chris/github/freecad-source/build/bin/styles" ...
Log: Local server 'FreeCAD' started
Log: QFactoryLoader::QFactoryLoader() checking directory path "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats" ...
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/kimg_eps.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/kimg_eps.so, metadata=
"IID": "org.qt-project.Qt.QImageIOHandlerFactoryInterface",
"MetaData": {
"Keys": [
"eps",
"epsi",
"epsf"
"MimeTypes": [
"image/x-eps",
"image/x-eps",
"image/x-eps"
"className": "EPSPlugin",
"debug": false,
"version": 329988
Log: Got keys from plugin meta data ("eps", "epsi", "epsf")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/kimg_exr.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/kimg_exr.so, metadata=
"MetaData": {
"Keys": [
"exr"
"MimeTypes": [
"image/x-exr"
"className": "EXRPlugin",
"debug": false,
"version": 329988
Log: Got keys from plugin meta data ("exr")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/kimg_kra.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/kimg_kra.so, metadata=
"MetaData": {
"Keys": [
"kra"
"MimeTypes": [
"application/x-krita",
"className": "KraPlugin",
"debug": false,
"version": 329988
Log: Got keys from plugin meta data ("kra")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/kimg_ora.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/kimg_ora.so, metadata=
"MetaData": {
"Keys": [
"ora"
"MimeTypes": [
"image/openraster",
"image/openraster"
"className": "OraPlugin",
"debug": false,
"version": 329988
Log: Got keys from plugin meta data ("ora")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/kimg_pcx.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/kimg_pcx.so, metadata=
"MetaData": {
"Keys": [
"pcx"
"MimeTypes": [
"image/x-pcx"
"className": "PCXPlugin",
"debug": false,
"version": 329988
Log: Got keys from plugin meta data ("pcx")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/kimg_pic.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/kimg_pic.so, metadata=
"MetaData": {
"Keys": [
"pic"
"MimeTypes": [
"image/x-pic"
"className": "SoftimagePICPlugin",
"debug": false,
"version": 329988
Log: Got keys from plugin meta data ("pic")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/kimg_psd.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/kimg_psd.so, metadata=
"MetaData": {
"Keys": [
"psd"
"MimeTypes": [
"image/vnd.adobe.photoshop"
"className": "PSDPlugin",
"debug": false,
"version": 329988
Log: Got keys from plugin meta data ("psd")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/kimg_ras.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/kimg_ras.so, metadata=
"MetaData": {
"Keys": [
"ras"
"MimeTypes": [
"image/x-sun-raster"
"className": "RASPlugin",
"debug": false,
"version": 329988
Log: Got keys from plugin meta data ("ras")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/kimg_rgb.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/kimg_rgb.so, metadata=
"MetaData": {
"Keys": [
"rgb",
"rgba",
"bw",
"sgi"
"MimeTypes": [
"image/x-rgb",
"image/x-rgb",
"image/x-rgb",
"image/x-rgb"
"className": "RGBPlugin",
"debug": false,
"version": 329988
Log: Got keys from plugin meta data ("rgb", "rgba", "bw", "sgi")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/kimg_tga.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/kimg_tga.so, metadata=
"MetaData": {
"Keys": [
"tga"
"MimeTypes": [
"image/x-tga"
"className": "TGAPlugin",
"debug": false,
"version": 329988
Log: Got keys from plugin meta data ("tga")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/kimg_xcf.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/kimg_xcf.so, metadata=
"MetaData": {
"Keys": [
"xcf"
"MimeTypes": [
"image/x-xcf"
"className": "XCFPlugin",
"debug": false,
"version": 329988
Log: Got keys from plugin meta data ("xcf")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/libqgif.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/libqgif.so, metadata=
"MetaData": {
"Keys": [
"gif"
"MimeTypes": [
"image/gif"
"className": "QGifPlugin",
"debug": false,
"version": 329989
Log: Got keys from plugin meta data ("gif")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/libqicns.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/libqicns.so, metadata=
"MetaData": {
"Keys": [
"icns"
"MimeTypes": [
"image/x-icns"
"className": "QICNSPlugin",
"debug": false,
"version": 329989
Log: Got keys from plugin meta data ("icns")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/libqico.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/libqico.so, metadata=
"MetaData": {
"Keys": [
"ico",
"cur"
"MimeTypes": [
"image/vnd.microsoft.icon"
"className": "QICOPlugin",
"debug": false,
"version": 329989
Log: Got keys from plugin meta data ("ico", "cur")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/libqjpeg.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/libqjpeg.so, metadata=
"MetaData": {
"Keys": [
"jpg",
"jpeg"
"MimeTypes": [
"image/jpeg",
"image/jpeg"
"className": "QJpegPlugin",
"debug": false,
"version": 329989
Log: Got keys from plugin meta data ("jpg", "jpeg")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/libqmng.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/libqmng.so, metadata=
"MetaData": {
"Keys": [
"mng"
"MimeTypes": [
"image/x-mng"
"className": "QMngPlugin",
"debug": false,
"version": 329989
Log: Got keys from plugin meta data ("mng")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/libqsvg.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/libqsvg.so, metadata=
"MetaData": {
"Keys": [
"svg",
"svgz"
"MimeTypes": [
"image/svg+xml",
"image/svg+xml-compressed"
"className": "QSvgPlugin",
"debug": false,
"version": 329989
Log: Got keys from plugin meta data ("svg", "svgz")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/libqtga.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/libqtga.so, metadata=
"MetaData": {
"Keys": [
"tga"
"MimeTypes": [
"image/x-tga"
"className": "QTgaPlugin",
"debug": false,
"version": 329989
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/libqtiff.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/libqtiff.so, metadata=
"MetaData": {
"Keys": [
"tiff",
"tif"
"MimeTypes": [
"image/tiff",
"image/tiff"
"className": "QTiffPlugin",
"debug": false,
"version": 329989
Log: Got keys from plugin meta data ("tiff", "tif")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/libqwbmp.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/libqwbmp.so, metadata=
"MetaData": {
"Keys": [
"wbmp"
"MimeTypes": [
"image/vnd.wap.wbmp"
"className": "QWbmpPlugin",
"debug": false,
"version": 329989
Log: Got keys from plugin meta data ("wbmp")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/libqwebp.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/libqwebp.so, metadata=
"MetaData": {
"Keys": [
"webp"
"MimeTypes": [
"image/webp"
"className": "QWebpPlugin",
"debug": false,
"version": 329989
Log: Got keys from plugin meta data ("webp")
Log: QFactoryLoader::QFactoryLoader() checking directory path "/home/chris/github/freecad-source/build/bin/imageformats" ...
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/kimg_eps.so"
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/kimg_exr.so"
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/kimg_kra.so"
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/kimg_ora.so"
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/kimg_pcx.so"
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/kimg_pic.so"
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/kimg_psd.so"
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/kimg_ras.so"
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/kimg_rgb.so"
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/kimg_tga.so"
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/kimg_xcf.so"
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/libqgif.so"
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/libqicns.so"
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/libqico.so"
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/libqjpeg.so"
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/libqmng.so"
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/libqsvg.so"
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/libqtiff.so"
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/libqwbmp.so"
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/imageformats/libqwebp.so"
Log: QFactoryLoader::QFactoryLoader() checking directory path "/usr/lib/x86_64-linux-gnu/qt5/plugins/accessible" ...
Log: QFactoryLoader::QFactoryLoader() checking directory path "/home/chris/github/freecad-source/build/bin/accessible" ...
Log: QFactoryLoader::QFactoryLoader() checking directory path "/usr/lib/x86_64-linux-gnu/qt5/plugins/iconengines" ...
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/iconengines/libqsvgicon.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/iconengines/libqsvgicon.so, metadata=
"IID": "org.qt-project.Qt.QIconEngineFactoryInterface",
"MetaData": {
"Keys": [
"svg",
"svgz",
"svg.gz"
"className": "QSvgIconPlugin",
"debug": false,
"version": 329989
Log: Got keys from plugin meta data ("svg", "svgz", "svg.gz")
Log: QFactoryLoader::QFactoryLoader() checking directory path "/home/chris/github/freecad-source/build/bin/iconengines" ...
Log: OpenGL version is: 4.6 (4.6.0 NVIDIA 440.44)
Log: Run Gui init script
Log: Init: Running FreeCADGuiInit.py start script...
Log: Init: Searching modules...
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/iconengines/libqsvgicon.so"
Log: Init: Initializing /home/chris/github/freecad-source/build/Mod/Tux... done
Log: Init: Initializing /home/chris/github/freecad-source/build/Mod/Measure(InitGui.py not found)... ignore
Log: Init: Initializing /home/chris/github/freecad-source/build/Mod/Idf(InitGui.py not found)... ignore
Log: Init: Initializing /home/chris/github/freecad-source/build/Mod/Show(InitGui.py not found)... ignore
Log: Module: Part
Log: Loading Part module... done
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/designer/kdepimakonadiwidgets.so, metadata=
"IID": "org.qt-project.Qt.QDesignerCustomWidgetInterface",
"MetaData": {
"className": "KDEPimAkonadiWidgets",
"debug": false,
"version": 329988
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/designer/kdepimakonadiwidgets.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/designer/kdepimwidgets.so, metadata=
"MetaData": {
"className": "KDEPimWidgets",
"debug": false,
"version": 329988
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/designer/kdepimwidgets.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/designer/kf5deprecatedwidgets.so, metadata=
"MetaData": {
"className": "KDELibs4SupportWidgets",
"debug": false,
"version": 329989
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/designer/kf5deprecatedwidgets.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/designer/libpyqt5.so, metadata=
"IID": "org.qt-project.Qt.QDesignerCustomWidgetCollectionInterface",
"MetaData": {
"className": "PyCustomWidgets",
"debug": false,
"version": 329989
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/designer/libpyqt5.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/designer/libqquickwidget.so, metadata=
"MetaData": {
"className": "QQuickWidgetPlugin",
"debug": false,
"version": 329989
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/designer/libqquickwidget.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/designer/libqwebview.so, metadata=
"MetaData": {
"className": "QWebViewPlugin",
"debug": false,
"version": 329989
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/designer/libqwebview.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/designer/mailcommonwidgets.so, metadata=
"MetaData": {
"className": "KDEPimMailCommonWidgets",
"debug": false,
"version": 329988
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/designer/mailcommonwidgets.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/designer/pimcommonwidgets.so, metadata=
"MetaData": {
"className": "PimCommonWidgets",
"debug": false,
"version": 329988
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/designer/pimcommonwidgets.so"
Log: Loading Sketcher module... done
Wrn: A3 available
Log: Loading Path module... done
Log: Loading PathStock... done
Log: Loading PathToolControllerGui... done
Log: Loading PathToolController... done
Log: Init: Initializing /home/chris/.FreeCAD/Mod/3D_Printing_Tools... done
Log: Init: Initializing /home/chris/.FreeCAD/Mod/parts_library(InitGui.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/Mechatronic1(InitGui.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/gbNov8.stl(InitGui.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/BIM... done
Log: Init: Initializing /home/chris/.FreeCAD/Mod/drivdisk.stl(InitGui.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/CycloidGearBox... done
Log: Init: Initializing /home/chris/.FreeCAD/Mod/ExplodedAssembly... done
Log: Init: Initializing /home/chris/.FreeCAD/Mod/symbols_library(InitGui.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/workfeature... done
Log: Init: Initializing /home/chris/.FreeCAD/Mod/gbNov8.FCStd(InitGui.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/pindisk.stl(InitGui.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/FCGear(InitGui.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/New Folder2(InitGui.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/New Folder3(InitGui.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/BOLTSFC(InitGui.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/ose-piping-workbench... done
Log: Init: Initializing /home/chris/.FreeCAD/Mod/cycdisk.stl(InitGui.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/workfeature-macro(InitGui.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/FreeCAD_assembly3(InitGui.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/es.stl(InitGui.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/dummy.py(InitGui.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/New Folder(InitGui.py not found)... ignore
Log: Init: Initializing /home/chris/.FreeCAD/Mod/RemBench... done
Log: Init: Initializing /home/chris/.FreeCAD/Mod/lattice2... done
Log: Init: Initializing /home/chris/.FreeCAD/Mod/PieMenu... done
Log: Init: Initializing freecad.asm3... done
Log: Init: Initializing freecad.gears... done
Log: Init: Loading FreeCAD GUI
Log: Init: Running FreeCADGuiInit.py start script... done
Log: Init: Activating default workbench StartWorkbench
Log: Loading GUI of Web module... done
Log: Loading GUI of Start module... done
Log: Loading Start module... done
Log: libpng warning: iCCP: known incorrect sRGB profile
Log: QFactoryLoader::QFactoryLoader() checking directory path "/usr/lib/x86_64-linux-gnu/qt5/plugins/sensors" ...
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/sensors/libqtsensors_generic.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/sensors/libqtsensors_generic.so, metadata=
"IID": "com.qt-project.Qt.QSensorPluginInterface/1.0",
"MetaData": {
"Keys": [
"generic"
"className": "genericSensorPlugin",
"debug": false,
"version": 329989
Log: Got keys from plugin meta data ("generic")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/sensors/libqtsensors_iio-sensor-proxy.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/sensors/libqtsensors_iio-sensor-proxy.so, metadata=
"MetaData": {
"Keys": [
"iio-sensor-proxy"
"className": "IIOSensorProxySensorPlugin",
"debug": false,
"version": 329989
Log: Got keys from plugin meta data ("iio-sensor-proxy")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/sensors/libqtsensors_linuxsys.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/sensors/libqtsensors_linuxsys.so, metadata=
"MetaData": {
"Keys": [
"linux"
"className": "LinuxSensorPlugin",
"debug": false,
"version": 329989
Log: Got keys from plugin meta data ("linux")
Log: QFactoryLoader::QFactoryLoader() checking directory path "/home/chris/github/freecad-source/build/bin/sensors" ...
Log: QFactoryLoader::QFactoryLoader() checking directory path "/usr/lib/x86_64-linux-gnu/qt5/plugins/bearer" ...
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/bearer/libqconnmanbearer.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/bearer/libqconnmanbearer.so, metadata=
"IID": "org.qt-project.Qt.QBearerEngineFactoryInterface",
"MetaData": {
"Keys": [
"connman"
"className": "QConnmanEnginePlugin",
"debug": false,
"version": 329989
Log: Got keys from plugin meta data ("connman")
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/bearer/libqgenericbearer.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/bearer/libqgenericbearer.so, metadata=
"MetaData": {
"Keys": [
"generic"
"className": "QGenericEnginePlugin",
"debug": false,
"version": 329989
Log: QFactoryLoader::QFactoryLoader() looking at "/usr/lib/x86_64-linux-gnu/qt5/plugins/bearer/libqnmbearer.so"
Log: Found metadata in lib /usr/lib/x86_64-linux-gnu/qt5/plugins/bearer/libqnmbearer.so, metadata=
"MetaData": {
"Keys": [
"networkmanager"
"className": "QNetworkManagerEnginePlugin",
"debug": false,
"version": 329989
Log: Got keys from plugin meta data ("networkmanager")
Log: QFactoryLoader::QFactoryLoader() checking directory path "/home/chris/github/freecad-source/build/bin/bearer" ...
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/bearer/libqconnmanbearer.so"
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/bearer/libqgenericbearer.so"
Log: loaded library "/usr/lib/x86_64-linux-gnu/qt5/plugins/bearer/libqnmbearer.so"
"MetaData": {
"Keys": [
"tga"
"MimeTypes": [
"image/x-tga"
"debug": false,
"version": 329989
Log: QImage::QImage(), XPM is not supported
Log: QPixmap::scaled: Pixmap is a null pixmap
Log: Init: Showing main window
Log: Main window restored
Log: Show main window
Log: Toolbars restored
Log: Couldn't connect to spacenav daemon
Log: Init: Entering event loop
Log: QFactoryLoader::QFactoryLoader() checking directory path "/usr/lib/x86_64-linux-gnu/qt5/plugins/accessiblebridge" ...
Log: QFactoryLoader::QFactoryLoader() checking directory path "/home/chris/github/freecad-source/build/bin/accessiblebridge" ...
Log: Init: Processing command line files
Log: Hide main window
Log: Finish: Event loop left
Log: Destruct Gui::Application
Log: QLibraryPrivate::unload succeeded on "/usr/lib/x86_64-linux-gnu/qt5/plugins/bearer/libqconnmanbearer.so"
Log: QLibraryPrivate::unload succeeded on "/usr/lib/x86_64-linux-gnu/qt5/plugins/bearer/libqgenericbearer.so"
Log: QLibraryPrivate::unload succeeded on "/usr/lib/x86_64-linux-gnu/qt5/plugins/bearer/libqnmbearer.so"
Log: Couldn't disconnect from spacenav daemon
Log: FreeCAD terminating...
Log: Saving system parameter...
Log: Saving system parameter...done
Log: Saving user parameter...
Log: Saving user parameter...done
This ticket has been migrated to GitHub as issue 5947. |
| 2019-06-14 07:23 | freman | New Issue | |
| 2019-06-14 07:26 | freman | Note Added: 0013211 | |
| 2019-06-14 16:03 | openBrain | Note Added: 0013212 | |
| 2019-06-14 17:16 | freman | Note Added: 0013214 | |
| 2020-07-22 14:05 | cbruner | Note Added: 0014677 | |
| 2020-07-22 14:05 | cbruner | File Added: FreeCAD.log | |
| 2020-07-22 14:06 | cbruner | Note Edited: 0014677 | |
