| 0004027 | FEM | Bug | public | 2019-06-18 09:27 | 2019-06-21 14:34 |
| Reporter | h.tsubota | Assigned To | Kunda1 | ||
| OS | Windows 10 | OS Version | 10.0.17763 | ||
| Summary | 0004027: Material settings can not be edited in FEM workbench | ||||
| Description | In FEM workbench, I click the material in model tree to edit the material. But a dialog show and say "Active Task Dialog found! Please close this one before opening a new one!", but there is no Active Task Dialog in Task tab. So I cannot edit the material. | ||||
| Steps To Reproduce | 1. Open FreeCAD 2. Press the "create a new empty document" button 3. Switch to the Part workbench 4. Press the "create a cube solid" button 5. Switch to the FEM workbench 6. Press the "Creates an analysis container with standard solver CalculiX(N, A)" button 7. Press the "Creates a FEM material for solid(M,M)" button 8. Click the "SolidMaterial" in tree of Model tab 9. Show an Error dialog and I cannot create material setting. The dialog says "Active Task Dialog found! Please close this one before opening a new one!", but there is no Active Task Dialog in Task tab. | ||||
| Additional Information | # FreeCAD version information OS: Windows 10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.16117 (Git) Build type: Release Branch: releases/FreeCAD-0-18 Hash: dbb4cc6415bac848a294f03b80f65e888d531742 Python version: 3.6.6 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.3.0 Locale: Japanese/Japan (ja_JP) # FreeCAD error messages in Report view Traceback (most recent call last): File "C:\Program Files\FreeCAD 0.18\Mod\Fem\femguiobjects\_ViewProviderFemMaterial.py", line 71, in setEdit taskd = _TaskPanelFemMaterial(self.Object) File "C:\Program Files\FreeCAD 0.18\Mod\Fem\femguiobjects\_ViewProviderFemMaterial.py", line 151, in __init__ self.import_materials() File "C:\Program Files\FreeCAD 0.18\Mod\Fem\femguiobjects\_ViewProviderFemMaterial.py", line 574, in import_materials self.import_solid_materials() File "C:\Program Files\FreeCAD 0.18\Mod\Fem\femguiobjects\_ViewProviderFemMaterial.py", line 581, in import_solid_materials self.add_cards_from_a_dir(system_mat_dir, ":/icons/freecad.svg") File "C:\Program Files\FreeCAD 0.18\Mod\Fem\femguiobjects\_ViewProviderFemMaterial.py", line 620, in add_cards_from_a_dir self.materials[a_path] = Material.importFCMat(a_path) File "C:\Program Files\FreeCAD 0.18\Mod\Material\Material.py", line 65, in importFCMat Config.read(fileName) File "C:\Program Files\FreeCAD 0.18\bin\lib\configparser.py", line 697, in read self._read(fp, filename) File "C:\Program Files\FreeCAD 0.18\bin\lib\configparser.py", line 1015, in _read for lineno, line in enumerate(fp, start=1): <class 'UnicodeDecodeError'>: 'cp932' codec can't decode byte 0x93 in position 586: illegal multibyte sequence Active Task Dialog found! Please close this one before opening a new one! Active Task Dialog found! Please close this one before opening a new one! # Comment I found non-ascii characters in FCMat files in "C:\Program Files\FreeCAD 0.18\data\Mod\Material\StandardMaterial" (like "Acrylic-Glass-Generic.FCMat" etc...). And encoding has not been set in importFCMat(fileName) function in "C:\Program Files\FreeCAD 0.18\Mod\Material\Material.py". So I tried to change "Config.read(fileName)" to "Config.read(fileName, encoding='utf-8')" on line 65 in "C:\Program Files\FreeCAD 0.18\Mod\Material\Material.py". The problem may be fixed by the editing. | ||||
| Tags | FEM, material | ||||
When it comes to FEM and Materials please always test the latest 0.19dev version. Both the FEM Workbench and Materials (IFC, BIM etc...) are very hot when it comes to development. Is this the line you're referring to? https://github.com/FreeCAD/FreeCAD/blob/master/src/Mod/Material/Material.py#L73 |
FreeCAD Pull Request 2269 |
Thank you for your response. The line that you refer is correct. I see. If I found a bug next time in FEM/Material, I will test it in latest dev version. |
I can not hardly belive this fixed your problem ... The fixed was applied in the depretiated not used importer ... https://github.com/FreeCAD/FreeCAD/blob/798a9102659d246bfda1a91f78b6032d0940fe64/src/Mod/Material/Material.py#L55-L57 |
just wanted to add a note ... Just realised he is right. In 0.18 the mat card reader from Material.py is used in FEM Material panel. Thus he had thir error. Thus we should backport the fix to 0.18. I will make a post in the forum topic. |
https://forum.freecadweb.org/viewtopic.php?f=10&t=35350&p=315694#p315694 |
this could be closed the fix is in 0.18 branch too. |
Fix committed to releases/FreeCAD-0-18 branch. |
FreeCAD: master 75b52c85 2019-06-18 13:41:14 Committer: berndhahnebach Details Diff |
[Material] Respect unicode filenames Fixes 0004027 |
Affected Issues 0004027 |
| mod - src/Mod/Material/Material.py | Diff File | ||
FreeCAD: releases/FreeCAD-0-18 90ff921e 2019-06-18 13:41:14 Committer: wmayer Details Diff |
| 2019-06-18 09:27 | h.tsubota | New Issue | |
| 2019-06-18 09:27 | h.tsubota | Tag Attached: 0.18 | |
| 2019-06-18 09:27 | h.tsubota | Tag Attached: FEM | |
| 2019-06-18 09:27 | h.tsubota | Tag Attached: material | |
| 2019-06-18 13:28 | Kunda1 | Note Added: 0013253 | |
| 2019-06-18 13:42 | Kunda1 | Tag Detached: 0.18 | |
| 2019-06-18 13:43 | Kunda1 | Note Added: 0013254 | |
| 2019-06-18 13:43 | Kunda1 | Assigned To | => Kunda1 |
| 2019-06-18 13:43 | Kunda1 | Status | new => assigned |
| 2019-06-18 14:52 | h.tsubota | Note Added: 0013255 | |
| 2019-06-18 15:01 | h.tsubota | Note Edited: 0013255 | |
| 2019-06-19 18:00 | Kunda1 | Target Version | => 0.19 |
| 2019-06-19 20:14 | berndhahnebach | Note Added: 0013261 | |
| 2019-06-19 20:14 | berndhahnebach | Note Edited: 0013261 | |
| 2019-06-19 20:16 | berndhahnebach | Changeset attached | => FreeCAD master 75b52c85 |
| 2019-06-19 20:16 | Kunda1 | Note Added: 0013262 | |
| 2019-06-19 20:16 | Kunda1 | Status | assigned => closed |
| 2019-06-19 20:16 | Kunda1 | Resolution | open => fixed |
| 2019-06-19 22:43 | Kunda1 | Fixed in Version | => 0.19 |
| 2019-06-21 05:11 | berndhahnebach | Status | closed => feedback |
| 2019-06-21 05:11 | berndhahnebach | Resolution | fixed => reopened |
| 2019-06-21 05:11 | berndhahnebach | Note Added: 0013285 | |
| 2019-06-21 05:14 | berndhahnebach | Note Added: 0013286 | |
| 2019-06-21 05:15 | berndhahnebach | Note Added: 0013287 | |
| 2019-06-21 14:34 | wmayer | Changeset attached | => FreeCAD releases/FreeCAD-0-18 90ff921e |
| 2019-06-21 14:34 | Kunda1 | Note Added: 0013288 | |
| 2019-06-21 14:34 | Kunda1 | Status | feedback => closed |
| 2019-06-21 14:34 | Kunda1 | Resolution | reopened => fixed |
