| 0004035 | Path | Bug | public | 2019-06-25 18:10 | 2020-10-16 16:47 |
| Reporter | freman | Assigned To | sliptonic | ||
| Summary | 0004035: path pocket crashing on illegal memory access. | ||||
| Description | Pocket path tool crashes on this example file. The key seems to be an illegal memory access.
.. following several trapped exceptions which produce out like:
Russ tested on windows and gets similar output but it seems that Windows is more tolerant of illegal memory access and does not crash. https://forum.freecadweb.org/viewtopic.php?f=15&t=37259&p=316881#p316610 The model file provided here is slightly changed from the one initially posted there. The bounding block is now correct and 6 holes in previous model were accidentally made as construction circles not real holes. Neither of these factors affect the bug. | ||||
| Steps To Reproduce | open attached file select upper face ( Model-body.Face14 ) select pocket path tool by icon CRASH ! If pocket op is started with no selection , it seems that the out of range errors still happen but a path is created and there is not crash. In other contexts where I have seen problems, defining the base geometry from the dialogue seems to avoid some issues. This difference probably should be looked into. | ||||
| Additional Information | OS: Linux (LXDE/LXDE) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.17119 (Git) Build type: Release Branch: master Hash: e72b48e0cfcf4773e4b6527c74f2bac11ccff1ab Python version: 2.7.15 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/UnitedKingdom (en_GB) | ||||
| Tags | #pending, #pending-forum | ||||
@freman : could you please carefully select the project linked to a ticket when you enter one ? In this case I guess it's Path. @Kunda1 : can't change this. ;) |
sorry, I thought Path was part of FreeCAD, not a separate project. |
Sorry for delay just moved this ticket to Path category. CC @sliptonic |
Confirmed by Russ on the forum thread |
@freman care to re-attach .FCStd file? It's corrupted for some reason |
Sorry France is descending to 3rd world levels of network connectivity and I have to sit on someone's doorstep to get email access. I'll try to remember to check this whenever I get proper connectivity back on the work machine. Not expecting that in the near future sadly. Ping me in a month if I forget. |
I don't see where Russ confirmed. He said he made a path _without_ error. GeneFC also can't reproduce. I've also tried and it works fine. Closing the issue. Will reopen if additional steps can be provided to duplicate the problem |
| 2019-06-25 18:10 | freman | New Issue | |
| 2019-06-25 18:10 | freman | File Added: housing-crisis.FCStd | |
| 2019-06-25 18:49 | openBrain | Note Added: 0013308 | |
| 2019-06-25 20:12 | freman | Note Added: 0013310 | |
| 2020-10-14 12:34 | Kunda1 | Project | FreeCAD => Path |
| 2020-10-14 12:35 | Kunda1 | Note Added: 0014847 | |
| 2020-10-14 12:36 | Kunda1 | Status | new => confirmed |
| 2020-10-14 12:36 | Kunda1 | Note Added: 0014848 | |
| 2020-10-14 12:38 | Kunda1 | Tag Attached: #pending | |
| 2020-10-14 12:38 | Kunda1 | Tag Attached: #pending-forum | |
| 2020-10-15 15:53 | Kunda1 | Note Added: 0014865 | |
| 2020-10-16 08:49 | freman | Note Added: 0014885 | |
| 2020-10-16 16:47 | sliptonic | Assigned To | => sliptonic |
| 2020-10-16 16:47 | sliptonic | Status | confirmed => closed |
| 2020-10-16 16:47 | sliptonic | Resolution | open => fixed |
| 2020-10-16 16:47 | sliptonic | Note Added: 0014889 |
