0004041FreeCADBugpublic2021-12-29 05:12
Reporterleong Assigned To
Status newResolutionopen
OSLinuxOS VersionMageia 6
Target Version0.20
Summary0004041: Navigation cube hardcoded to use Helvetica
Descriptionin the latest 17147 and in the build before it the navigation cube has lost its lettering.
Steps To ReproduceHappens everytime I open FreeCAD
Additional InformationOS: Mageia 6 (KDE//usr/share/xsessions/01plasma)
Version: 0.19.17147 (Git) AppImage
Hash: 251a3b1ff5517d929b4993d8836e17e01ae2623c
Python version: 3.7.3
Qt version: 5.9.7
Tags#lowhangingfruit
leong
2019-06-28 12:52
reporter
openBrain
2019-06-30 14:28
developer   ~0013322
@leong as suggested by tag, could you please open a topic in the "Help on using FreeCAD" subforum ?
The ticket is vague and a community discussion will probably allow to narrow down the possible cause(s). ;)
Thanks
leong
2019-06-30 17:25
reporter   ~0013323
OK. It appears this may be an issue with my system and some font change, but I cannot find it. Will do as you suggest/
2019-07-01 01:00
administrator   ~0013324
Forum thread: https://forum.freecad.org/viewtopic.php?f=3&t=37401
jmaustpc
2019-07-01 01:12
manager   ~0013325
It works perfectly here in both PPA versions. I have a 10 year old laptop with an Nvidea GPU with open source drivers. We saw that "save picture" was not working with a combination of some QT versions and Intel GPU/Driver .... I wonder if this is also related to the QT version and Intel GPU/Driver?
OS: Ubuntu 18.04.2 LTS (KDE/plasma)
Version: 0.19.
Python version: 3.6.8
Qt version: 5.9.5
Locale: English/Australia (en_AU)
Version: 0.18.1.
Python version: 3.6.7
Qt version: 5.9.5
leong
2019-08-09 11:37
reporter   ~0013408
I posted answer on forum FreeCAD forum
Basically the navigation cube uses Helvetica font and it is not on my system. Had to add it.
Maybe the code should specify another font? that would fix the issue.
chennes
2021-12-29 05:12
administrator   ~0016159
I've changed the title of the issue to reflect the actual bug here: we assume Helvetica is available on all systems, to be used as a Sans Serif font, but that is not a good assumption.
yorik
2022-03-03 13:55
administrator   ~0016793
This ticket has been migrated to GitHub as issue 5959.
2019-06-28 12:52 leong New Issue
2019-06-28 12:52 leong File Added: freeCAD0191747.png
2019-06-30 10:31 Kunda1 Tag Attached: #post-to-forum
2019-06-30 14:28 openBrain Note Added: 0013322
2019-06-30 14:28 openBrain Assigned To => openBrain
2019-06-30 14:28 openBrain Status new => feedback
2019-06-30 14:29 openBrain Assigned To openBrain =>
2019-06-30 17:25 leong Note Added: 0013323
2019-06-30 17:25 leong Status feedback => new
2019-07-01 01:00 Kunda1 Tag Detached: #post-to-forum
2019-07-01 01:00 Kunda1 Note Added: 0013324
2019-07-01 01:12 jmaustpc Note Added: 0013325
2019-08-09 11:37 leong Note Added: 0013408
2019-08-09 11:38 leong Note Edited: 0013408
2021-02-06 06:50 abdullah Target Version => 0.20
2021-12-29 05:09 chennes Tag Attached: #lowhangingfruit
2021-12-29 05:11 chennes Summary Navigation cube has no words => Navigation cube hardcoded to use Helvetica
2021-12-29 05:12 chennes Note Added: 0016159
