| 0004041 | FreeCAD | Bug | public | 2019-06-28 12:52 | 2021-12-29 05:12 |
| Reporter | leong | Assigned To | |||
| OS | Linux | OS Version | Mageia 6 | ||
| Summary | 0004041: Navigation cube hardcoded to use Helvetica | ||||
| Description | in the latest 17147 and in the build before it the navigation cube has lost its lettering. | ||||
| Steps To Reproduce | Happens everytime I open FreeCAD | ||||
| Additional Information | OS: Mageia 6 (KDE//usr/share/xsessions/01plasma) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.17147 (Git) AppImage Build type: Release Branch: master Hash: 251a3b1ff5517d929b4993d8836e17e01ae2623c Python version: 3.7.3 Qt version: 5.9.7 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/UnitedStates (en_US) | ||||
| Tags | #lowhangingfruit | ||||
|  | @leong as suggested by tag, could you please open a topic in the "Help on using FreeCAD" subforum ? The ticket is vague and a community discussion will probably allow to narrow down the possible cause(s). ;) Thanks |
|  | OK. It appears this may be an issue with my system and some font change, but I cannot find it. Will do as you suggest/ |
|  | Forum thread: https://forum.freecadweb.org/viewtopic.php?f=3&t=37401 |
|  | It works perfectly here in both PPA versions. I have a 10 year old laptop with an Nvidea GPU with open source drivers. We saw that "save picture" was not working with a combination of some QT versions and Intel GPU/Driver .... I wonder if this is also related to the QT version and Intel GPU/Driver? OS: Ubuntu 18.04.2 LTS (KDE/plasma) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19. Build type: Release Python version: 3.6.8 Qt version: 5.9.5 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/Australia (en_AU) OS: Ubuntu 18.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.1. Build type: Release Python version: 3.6.7 Qt version: 5.9.5 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/Australia (en_AU) |
|  | I posted answer on forum FreeCAD forum Basically the navigation cube uses Helvetica font and it is not on my system. Had to add it. Maybe the code should specify another font? that would fix the issue. |
|  | I've changed the title of the issue to reflect the actual bug here: we assume Helvetica is available on all systems, to be used as a Sans Serif font, but that is not a good assumption. |
|  | This ticket has been migrated to GitHub as issue 5959. |
| 2019-06-28 12:52 | leong | New Issue | |
| 2019-06-28 12:52 | leong | File Added: freeCAD0191747.png | |
| 2019-06-30 10:31 | Kunda1 | Tag Attached: #post-to-forum | |
| 2019-06-30 14:28 | openBrain | Note Added: 0013322 | |
| 2019-06-30 14:28 | openBrain | Assigned To | => openBrain |
| 2019-06-30 14:28 | openBrain | Status | new => feedback |
| 2019-06-30 14:29 | openBrain | Assigned To | openBrain => |
| 2019-06-30 17:25 | leong | Note Added: 0013323 | |
| 2019-06-30 17:25 | leong | Status | feedback => new |
| 2019-07-01 01:00 | Kunda1 | Tag Detached: #post-to-forum | |
| 2019-07-01 01:00 | Kunda1 | Note Added: 0013324 | |
| 2019-07-01 01:12 | jmaustpc | Note Added: 0013325 | |
| 2019-08-09 11:37 | leong | Note Added: 0013408 | |
| 2019-08-09 11:38 | leong | Note Edited: 0013408 | |
| 2021-12-29 05:09 | chennes | Tag Attached: #lowhangingfruit | |
| 2021-12-29 05:11 | chennes | Summary | Navigation cube has no words => Navigation cube hardcoded to use Helvetica |
| 2021-12-29 05:12 | chennes | Note Added: 0016159 |
