| 0004049 | FreeCAD | Bug | public | 2019-07-04 19:32 | 2019-08-22 20:44 |
| Reporter | Diana | Assigned To | |||
| Summary | 0004049: Llamada a freecad 0.18 dentro de script de python3.7.3 en Fedora 29 | ||||
| Description | Hola: Cuando ejecuto freecad (version 0.18) dentro de un script escrito en Python 3.7.3 el entra bien hasta cuando intento crear un nuevo documento o abrir uno ya existente. En este momento ocurre un error de segmentación. Con la versión 0.17 no me ocurría esto. Ejecutaba perfectamente bien. Gracias de antemano por atender mi problema. ------------------------------------------------------ When I run freecad (version 0.18) inside a script written in Python 3.7.3 it goes well until I try to create a new document or open an existing one. At this time a segmentation error occurs. With version 0.17 this did not happen to me. It executed perfectly well. Thanks in advance for addressing my problem. | ||||
Please open a thread on the FreeCAD forum to discuss your problem. |
@4049 We will close this ticket unless you provide more info. Fedora 29 may be missing relevant dependencies. Please follow up with the details we ask for in the yellow banner at the top of the page. Also please use english when filing bugs thank you. |
@Diana please respond |
No response from OP |
| 2019-07-04 19:32 | Diana | New Issue | |
| 2019-07-05 02:16 | Kunda1 | Status | new => feedback |
| 2019-07-05 02:16 | Kunda1 | Note Added: 0013331 | |
| 2019-07-05 02:16 | Kunda1 | Tag Attached: #post-to-forum | |
| 2019-07-22 11:43 | Kunda1 | Description Updated | |
| 2019-07-22 11:45 | Kunda1 | Note Added: 0013374 | |
| 2019-07-23 23:41 | Kunda1 | Note Added: 0013377 | |
| 2019-08-22 20:44 | Kunda1 | Status | feedback => closed |
| 2019-08-22 20:44 | Kunda1 | Resolution | open => unable to reproduce |
| 2019-08-22 20:44 | Kunda1 | Note Added: 0013454 | |
| 2019-08-22 20:44 | Kunda1 | Tag Detached: #post-to-forum |
