| 0004055 | Sketcher | Bug | public | 2019-07-12 23:03 | 2020-06-05 17:23 |
| Reporter | uwestoehr | Assigned To | openBrain | ||
| Summary | 0004055: wrong default value for grid size | ||||
| Description | In the sketcher preferences and the sketcher dialog the default value for the grid size is "0 mm". But in effect the default grid size is 10 mm. To reproduce: - edit a sketch result: you the default value of 0 mm. but you can nevertheless see a grid of 10 mm default size. - now set a grid size of e.g. 4mm - leave the sketch - edit the sketch again result: the grid has correctly the size of 4mm but you see again the 0mm. To reproduce the bug in the preferences, if you don't already see there 0mm, press "Reset" in the preferences dialog. | ||||
| Additional Information | Forum thread: https://forum.freecadweb.org/viewtopic.php?f=3&t=37665 OS: Windows 7 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.17331 (Git) Build type: Release Branch: master Hash: cf18161dc26267c259ac21675cb9637263bf4152 Python version: 3.6.6 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.3.0 Locale: German/Germany (de_DE) | ||||
| Tags | sketcher | ||||
| 2019-07-12 23:03 | uwestoehr | New Issue | |
| 2019-07-12 23:05 | uwestoehr | Additional Information Updated | |
| 2019-07-12 23:09 | uwestoehr | Tag Attached: sketcher | |
| 2019-08-23 02:54 | Kunda1 | Target Version | => 0.19 |
| 2019-08-23 02:54 | Kunda1 | Note Added: 0013461 | |
| 2020-04-13 14:18 | openBrain | Assigned To | => openBrain |
| 2020-04-13 14:18 | openBrain | Status | new => assigned |
| 2020-05-28 13:43 | abdullah | Status | assigned => closed |
| 2020-05-28 13:43 | abdullah | Resolution | open => fixed |
| 2020-05-28 13:43 | abdullah | Fixed in Version | => 0.19 |
| 2020-05-28 13:44 | abdullah | Note Added: 0014430 | |
| 2020-06-05 17:23 | Changeset attached | => FreeCAD master 5b76419d | |
| 2020-06-05 17:23 | guest | Note Added: 0014482 |
