| 0004058 | Sketcher | Bug | public | 2019-07-16 11:30 | 2020-06-05 17:23 |
| Reporter | uwestoehr | Assigned To | openBrain | ||
| Summary | 0004058: wrong indication of autoconstraint status in task dialog and View tab | ||||
| Description | The task dialog does not indicate the current state of autoconstraints for a sketch: - assure you have in the sketcher preferences the option "Auto constraints" enabled - create a new sketch - select the sketch in the tree view - change to the View tab and set there "Autoconstraints" to "false" - open the sketch result: the task dialog tells you that "Auto constraints" is on - close the sketch result: in the View tab "Autoconstraints" is correctly still "false" However, in this case the task dialog is right but not in the View tab: - assure you have in the sketcher preferences the option "Auto constraints" disabled - create a new sketch - select the sketch in the tree view - change to the View tab and set there "Autoconstraints" to "true" - open the sketch result: the task dialog tells you that "Auto constraints" is off and this is the case, so the View tab settings was ignored - close the sketch result: in the View tab "Autoconstraints" is now "false" | ||||
| Additional Information | Forum thread: https://forum.freecadweb.org/viewtopic.php?f=3&t=37740&p=321233#p321233 OS: Windows 10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.17331 (Git) Build type: Release Branch: master Hash: cf18161dc26267c259ac21675cb9637263bf4152 Python version: 3.6.6 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.3.0 Locale: German/Germany (de_DE) | ||||
| Tags | sketcher | ||||
FreeCAD: master 811a4464 2020-04-11 14:33:38 0penBrain Committer: abdullahtahiriyo Details Diff |
[Sketcher] Local settings are correctly restored ; fixes 0003952,0004058 |
Affected Issues 0003952, 0004058 |
| mod - src/Mod/Sketcher/Gui/CommandCreateGeo.cpp | Diff File | ||
| mod - src/Mod/Sketcher/Gui/TaskSketcherGeneral.cpp | Diff File | ||
| mod - src/Mod/Sketcher/Gui/TaskSketcherGeneral.h | Diff File | ||
| mod - src/Mod/Sketcher/Gui/ViewProviderSketch.h | Diff File | ||
| 2019-07-16 11:30 | uwestoehr | New Issue | |
| 2019-07-16 11:30 | uwestoehr | Tag Attached: sketcher | |
| 2019-07-16 17:18 | uwestoehr | Description Updated | |
| 2019-07-16 17:29 | uwestoehr | Summary | wrong indication of autoconstraint status in task dialog => wrong indication of autoconstraint status in task dialog and View tab |
| 2019-07-16 17:29 | uwestoehr | Description Updated | |
| 2020-04-13 14:18 | openBrain | Assigned To | => openBrain |
| 2020-04-13 14:18 | openBrain | Status | new => assigned |
| 2020-05-28 13:45 | abdullah | Status | assigned => closed |
| 2020-05-28 13:45 | abdullah | Resolution | open => fixed |
| 2020-05-28 13:45 | abdullah | Fixed in Version | => 0.19 |
| 2020-05-28 13:45 | abdullah | Note Added: 0014431 | |
| 2020-06-05 17:23 | Changeset attached | => FreeCAD master 811a4464 | |
| 2020-06-05 17:23 | guest | Note Added: 0014479 |
