| 0003952 | Sketcher | Bug | public | 2019-04-30 20:01 | 2020-06-05 17:23 |
| Reporter | openBrain | Assigned To | openBrain | ||
| Summary | 0003952: Sketcher grid spacing isn't kept | ||||
| Description | The grid spacing set in Sketcher isn't kept from one sketch editing to another. The parameter is reset to default as soon as Sketcher edit mode is exited. | ||||
| Steps To Reproduce |
| Additional Information | Link to forum (FR thread) | ||||
Apparently this is not related to Qt5; problem started sometime after 0.18.15007 and affects both Qt4 and Qt5. This version is affected: OS: Windows 8.1 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.16523 (Git) Build type: Release Branch: master Hash: 9b3ec233c8b21e0df66fada487cd10f471d60cac Python version: 2.7.14 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.2.0 Locale: French/France (fr_FR) |
Confirmed in the forum thread that bug exists both with Qt4 & Qt5 versions. I removed the 'Qt5' tag but can't modify the bug info accordingly. If some superuser can do it, it could avoid further confusion. ;) |
@abdullah care to weigh in on this at your convenience? |
I cannot reproduce this. Here the grid size settings are kept. I set for different sketches in one model different grid sizes and in effect these settings were correctly stored. To use the same grid size for all sketches I set a value in the sketcher preferences and it works. I reported the issue that the dialog however always shows you the grid size would be "0 mm" as bug 0004055. OS: Windows 7 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.17331 (Git) Build type: Release Branch: master Hash: cf18161dc26267c259ac21675cb9637263bf4152 Python version: 3.6.6 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.3.0 Locale: German/Germany (de_DE) |
Still reproduced with |
git comit 811a44643cb8bba2e4c710b0c6d565ad1ec1c61b |
FreeCAD: master 811a4464 2020-04-11 14:33:38 0penBrain Committer: abdullahtahiriyo Details Diff |
[Sketcher] Local settings are correctly restored ; fixes 0003952,0004058 |
Affected Issues 0003952, 0004058 |
| mod - src/Mod/Sketcher/Gui/CommandCreateGeo.cpp | Diff File | ||
| mod - src/Mod/Sketcher/Gui/TaskSketcherGeneral.cpp | Diff File | ||
| mod - src/Mod/Sketcher/Gui/TaskSketcherGeneral.h | Diff File | ||
| mod - src/Mod/Sketcher/Gui/ViewProviderSketch.h | Diff File | ||
| 2019-04-30 20:01 | openBrain | New Issue | |
| 2019-05-01 04:31 | normandc | Project | FreeCAD => Sketcher |
| 2019-05-01 04:46 | normandc | Note Added: 0013074 | |
| 2019-05-01 08:07 | openBrain | Tag Attached: Qt5 | |
| 2019-05-12 20:37 | openBrain | Tag Detached: Qt5 | |
| 2019-05-12 20:40 | openBrain | Note Added: 0013099 | |
| 2019-05-30 13:10 | Kunda1 | Additional Information Updated | |
| 2019-05-30 13:11 | Kunda1 | Status | new => confirmed |
| 2019-05-30 13:11 | Kunda1 | Note Added: 0013131 | |
| 2019-05-30 13:12 | Kunda1 | Target Version | => 0.19 |
| 2019-07-12 23:05 | uwestoehr | Note Added: 0013340 | |
| 2019-07-13 19:17 | openBrain | Note Added: 0013341 | |
| 2020-04-09 12:12 | openBrain | Assigned To | => openBrain |
| 2020-04-09 12:12 | openBrain | Status | confirmed => assigned |
| 2020-05-28 13:46 | abdullah | Status | assigned => closed |
| 2020-05-28 13:46 | abdullah | Resolution | open => fixed |
| 2020-05-28 13:46 | abdullah | Fixed in Version | => 0.19 |
| 2020-05-28 13:46 | abdullah | Note Added: 0014432 | |
| 2020-06-05 17:23 | Changeset attached | => FreeCAD master 811a4464 | |
| 2020-06-05 17:23 | guest | Note Added: 0014478 |
