| 0004069 | TechDraw | Bug | public | 2019-07-25 03:00 | 2019-12-11 11:50 |
| Reporter | bgoodr | Assigned To | wandererfan | ||
| Summary | 0004069: TechDraw/View/Lines: Enable entry and display of values in the users chosen unit system | ||||
| Description | As a user, I would like to be able to specify the specific units when entering in the values to the values of: Extra Width, Hidden Width, Iso Width, Line Width that are in the TechDraw/View tab. This should ideally work similar to how other values are allowed, such as entering in length dimensions in the Sketcher Workbench. I would also like the dimensions to be displayed as I have specified them, and not have them converted for display back into SI units: I would want to be able to type in 0.001" and have it be displayed as such, and not have it switch to 0.0254mm, that is, it should respect the preferences setting in "Preferences/General/Unit System", which for my use, is currently "US customary (in/lb)". Currently, the values are in mm but there is no indication as such, and I had to find out by asking the forum for clarification. The overall goal I have is described in https://forum.freecadweb.org/viewtopic.php?f=3&t=37891#p322484 | ||||
| Steps To Reproduce | https://forum.freecadweb.org/viewtopic.php?f=3&t=37955&p=322944#p322864 is the associated forum post where we concluded a feature request was in order. | ||||
| Additional Information | OS: Ubuntu 19.04 (ubuntu:GNOME/ubuntu) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19. Build type: Release Python version: 3.7.3 Qt version: 5.12.2 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/United States (en_US) And specific version from Ubuntu command line (I'm using freecad-daily, although I also have freecad stable installed): $ dpkg --list '*freecad*' | grep -v '^un\b' Desired=Unknown/Install/Remove/Purge/Hold | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad) ||/ Name Version Architecture Description +++-=============================-=========================================-============-=========================================================== ii freecad 2:0.18.3+dfsg1~201907190308~ubuntu19.04.1 all Extensible Open Source CAx program ii freecad-common 2:0.18.3+dfsg1~201907190308~ubuntu19.04.1 all Extensible Open Source CAx program - common files ii freecad-daily 0.19~pre1~201907241808~ubuntu19.04.1 all Extensible Open Source CAx program ii freecad-daily-common 0.19~pre1~201907241808~ubuntu19.04.1 all Extensible Open Source CAx program - common files ii freecad-daily-python3 0.19~pre1~201907241808~ubuntu19.04.1 amd64 Extensible Open Source CAx program - Python 3 binaries ii freecad-daily-runtime 0.19~pre1~201907241808~ubuntu19.04.1 all Extensible Open Source CAx program - runtime files ii freecad-python3 2:0.18.3+dfsg1~201907190308~ubuntu19.04.1 amd64 Extensible Open Source CAx program - Python 3 binaries ii freecad-runtime 2:0.18.3+dfsg1~201907190308~ubuntu19.04.1 all Extensible Open Source CAx program - runtime files ii libfreecad-daily-python3-0.19 0.19~pre1~201907241808~ubuntu19.04.1 amd64 Extensible Open Source CAx program - Python 3 library files ii libfreecad-python3-0.18 2:0.18.3+dfsg1~201907190308~ubuntu19.04.1 amd64 Extensible Open Source CAx program - Python 3 library files $ | ||||
| Tags | TechDraw | ||||
Could a mod please change the "Project" on this one from "Sketcher" to "TechDraw"? Thanks. |
It is a glaring defect in a tracking system that disallows the original user from making changes to the original issue being reported. Otherwise I would have been able to make the change myself. |
should be fixed by these commits: line width: de1be3b381 position on page: 0721f7f1e4 ceeb776fff |
closed |
FreeCAD master de1be3b3 FreeCAD master 0721f7f1 FreeCAD master ceeb776f Edit: I manually associated the commits to this ticket. @wandererfan check out https://www.freecadweb.org/wiki/Tracker#MantisBT_.3C.3D.3E_GitHub_Markup |
FreeCAD: master de1be3b3 2019-12-07 03:26:15 donovaly Committer: wandererfan Details Diff |
TD: add units for line widths - this also prevents negative values - also fix an issue in DrawViewBalloon introduced by me recently |
Affected Issues 0004069 |
| mod - src/Mod/TechDraw/App/DrawViewBalloon.cpp | Diff File | ||
| mod - src/Mod/TechDraw/Gui/ViewProviderViewPart.cpp | Diff File | ||
| mod - src/Mod/TechDraw/Gui/ViewProviderViewPart.h | Diff File | ||
FreeCAD: master ceeb776f 2019-12-07 14:35:10 Details Diff |
[TD]DrawViewBalloon OriginX/Y to PropertyDistance |
| mod - src/Mod/TechDraw/App/DrawViewBalloon.h | Diff File | ||
FreeCAD: master 0721f7f1 2019-12-08 12:29:57 donovaly Committer: wandererfan Details Diff |
TD: DrawView.cpp: add routine for PropertyDistance change X and Y were changed at first by me to PropertyLength and later by Wandererfan to PropertyDistance. For this second change there is handleChangedPropertyType() code missing. This PR adds this. - also some code formatting improvements automatically done by MSVC |
| mod - src/Mod/TechDraw/App/DrawView.cpp | Diff File | ||
| 2019-07-25 03:00 | bgoodr | New Issue | |
| 2019-07-25 03:00 | bgoodr | Tag Attached: TechDraw | |
| 2019-07-25 03:00 | bgoodr | File Added: cut.png | |
| 2019-07-25 12:29 | wandererfan | Note Added: 0013383 | |
| 2019-07-25 12:30 | wandererfan | Note Edited: 0013383 | |
| 2019-07-25 15:09 | bgoodr | Note Added: 0013384 | |
| 2019-08-08 12:52 | chrisb | Project | Sketcher => TechDraw |
| 2019-08-08 12:52 | chrisb | Category | Feature => General |
| 2019-12-09 16:29 | wandererfan | Note Added: 0013889 | |
| 2019-12-09 16:30 | wandererfan | Status | new => resolved |
| 2019-12-09 16:30 | wandererfan | Resolution | open => fixed |
| 2019-12-09 16:30 | wandererfan | Category | General => Bug |
| 2019-12-09 16:30 | wandererfan | Fixed in Version | => 0.19 |
| 2019-12-10 12:08 | wandererfan | Assigned To | => wandererfan |
| 2019-12-10 12:08 | wandererfan | Status | resolved => closed |
| 2019-12-10 12:08 | wandererfan | Note Added: 0013892 | |
| 2019-12-11 11:47 | Kunda1 | Note Added: 0013897 | |
| 2019-12-11 11:48 | Kunda1 | Changeset attached | => FreeCAD master de1be3b3 |
| 2019-12-11 11:48 | Kunda1 | Changeset attached | => FreeCAD master 0721f7f1 |
| 2019-12-11 11:48 | Kunda1 | Changeset attached | => FreeCAD master ceeb776f |
| 2019-12-11 11:50 | Kunda1 | Note Edited: 0013897 |
