0004072FreeCADBugpublic2021-08-18 09:33
Reporterpoeschlr Assigned Toyorik
Status closedResolutionfixed
Product Version0.18
Target Version0.20Fixed in Version0.20
Summary0004072: Addon manager python exception and lockup (module 'git' has no attribute 'Repo')
DescriptionFresh install under fedora 30. Works well on fedora 28.
Message in report view:
  File "/usr/lib64/freecad/Mod/AddonManager/AddonManager.py", line 804, in run
    bare_repo = git.Repo.clone_from(repo[1], clonedir + os.sep + '.git', bare=True)
AttributeError: module 'git' has no attribute 'Repo'
python version reported in python console:
Python 3.7.3 (default, May 11 2019, 00:38:04)
[GCC 9.1.1 20190503 (Red Hat 9.1.1-1)] on linux
Steps To ReproduceClick on any already installed addon within the addon manager. Freecad locks up and the message detailed above is printed in the report view.
Additional InformationOS: Linux
Version: 0.18.Unknown
Build type: Unknown
Python version: 3.7.3
Qt version: 4.8.7
Coin version: 3.1.3
OCC version: 6.9.1.oce-0.18
Locale: English/UnitedKingdom (en_GB)
Tagsaddon-manager
poeschlr
2019-07-27 18:01
reporter   ~0013389
Same problem happens when one tries to install something using the addon manager. (locks up and same error message in report view)
2019-07-29 14:48
administrator   ~0013391
@poeschlr
Can you recreate this in the 0.18 appimage or 0.19 appimage ?
See https://www.freecad.org/wiki/Appimage
I ask because your version uses inferior dependencies (BTW, before you open a ticket next time, familiarize yourself with our ticket opening guidelines in the large yellow banner at the top of the page).
poeschlr
2019-07-30 16:05
reporter   ~0013395
If the package uses inferior dependencies then there is a bug in the official fedora package. (Should i open a new bug about that or will you do it? I would guess you have more details what dependencies are to be updated.)
And an exception that is not reported to the user is clearly a bug no matter why it got thrown in the first place. (The only "feedback" outside the report view is a locked up addon manager. At least spawn an error message that makes some sense.) Meaning the "if you are unsure if it is a bug then open a discussion on the forum" stuff is clearly not necessary.
io7m
2020-10-08 13:47
reporter   ~0014797
I'm running into this on Arch Linux, `FreeCAD 0.19 Revision: 22436 (Git)`, so it's not just broken in Fedora.
yorik
2021-08-18 09:32
administrator   ~0015827
I couldn't find any info anywhere about why the git module would lack its "Repo" class... I now added a case to the code so it falls back to HTML download in these cases, but it should be investigated further why this happens... https://github.com/FreeCAD/FreeCAD/commit/380d214e74c8a085293314112be0ade2295b848e
2019-07-27 17:42 poeschlr New Issue
2019-07-27 18:01 poeschlr Note Added: 0013389
2019-07-29 14:48 Kunda1 Note Added: 0013391
2019-07-29 14:48 Kunda1 Status new => feedback
2019-07-29 14:49 Kunda1 Tag Attached: addon-manager
2019-07-30 16:05 poeschlr Note Added: 0013395
2019-07-30 16:05 poeschlr Status feedback => new
2020-10-08 13:47 io7m Note Added: 0014797
2021-08-18 09:32 yorik Note Added: 0015827
2021-08-18 09:33 yorik Assigned To => yorik
2021-08-18 09:33 yorik Status new => closed
2021-08-18 09:33 yorik Resolution open => fixed
2021-08-18 09:33 yorik Fixed in Version => 0.20
