| 0004082 | TechDraw | Bug | public | 2019-08-08 12:35 | 2020-06-26 17:12 |
| Reporter | wandererfan | Assigned To | wandererfan | ||
| Summary | 0004082: TD Fails to Display Section of Assembly | ||||
| Description | Forum Discussion TD displays incorrect results and error messages when trying to make Section view of Assembly file from A2Plus(?). The assembly pieces are combined into a Compound before Section and Projection processing. The Compound is invalid (Part.CheckGeometry) due to many self intersection errors. The individual pieces pass CheckGeometry. | ||||
| Additional Information | Assembly file is attached. Original FCStd files for pieces have been requested. | ||||
Still would like the original files for the assembly pieces. |
Could a mod please change Project to TechDraw? Thanks. |
Component "Nut" in the example file has multiple geometric problems when projected or when used in Boolean ops. I can't tell if the problems are introduced in the assembly process or are there from the original file. If "nut" is removed from the assembly the section operation works much better, but there is still a problem with the "Spindle" component. |
Changing status of ticket from feedback to assigned |
"Changing status of ticket from feedback to assigned " Why? Still waiting for feedback. Can't tell what's wrong with the input without the original files from before import to A2+. |
This is caused by geometry errors in the assembly. See forum discussion here. |
Not fixable in TechDraw. |
Closing ticket |
| 2019-08-08 12:35 | wandererfan | New Issue | |
| 2019-08-08 12:35 | wandererfan | Status | new => assigned |
| 2019-08-08 12:35 | wandererfan | Assigned To | => wandererfan |
| 2019-08-08 12:35 | wandererfan | File Added: screwjack_assmbly_sectionViewCrash.FCStd | |
| 2019-08-08 12:38 | wandererfan | Status | assigned => feedback |
| 2019-08-08 12:38 | wandererfan | Note Added: 0013403 | |
| 2019-08-08 12:39 | wandererfan | Note Added: 0013404 | |
| 2019-08-08 12:51 | chrisb | Project | FreeCAD => TechDraw |
| 2019-10-29 17:42 | wandererfan | Note Added: 0013794 | |
| 2019-12-29 13:59 | Kunda1 | Status | feedback => assigned |
| 2019-12-29 13:59 | Kunda1 | Note Added: 0013954 | |
| 2019-12-29 15:33 | wandererfan | Note Added: 0013957 | |
| 2020-06-21 12:58 | wandererfan | Note Added: 0014578 | |
| 2020-06-21 12:59 | wandererfan | Status | assigned => resolved |
| 2020-06-21 12:59 | wandererfan | Resolution | open => not fixable |
| 2020-06-21 12:59 | wandererfan | Note Added: 0014579 | |
| 2020-06-26 17:12 | Kunda1 | Status | resolved => closed |
| 2020-06-26 17:12 | Kunda1 | Note Added: 0014591 |
