| 0004087 | Sketcher | Bug | public | 2019-08-10 08:28 | 2020-03-07 03:33 |
| Reporter | paullee | Assigned To | abdullah | ||
| Platform | Linux | OS | Fedora | OS Version | 29 / 30 |
| Summary | 0004087: [Crash FC & Function Bug] - Part:FeatureGeometrySet | ||||
| Description | FC Discussion - [ Crash FC ] [ Geometry Extension Set Information Not save in file ] | ||||
| Steps To Reproduce | Repeating Forum discussion:- [ Crash FC ]
| Tags | Geometry Extension Set | ||||
@abdullah is so kind to implement this. He have not appeared since 21.7, hope he is fine. Noting @wmayer merge the GeometryExtension, trying to assign this bug to wmayer, to avoid this being forgotten or to figure out if this worthwhile to pursue or not. Not sure this is correct move, please advise otherwise. Thanks. |
https://github.com/FreeCAD/FreeCAD/commit/b748cc688495500786f5f3a239bf0379916c915f |
FreeCAD master b748cc68 |
FreeCAD: master b748cc68 2020-03-06 15:47:42 Committer: abdullahtahiriyo Details Diff |
Part: GeometryExtensions ======================== fixes 0004087 Missing "break" in loop after finding the extension was causing segfault because of null pointer access, as the unique pointer had been std:move-d when found and was thus no longer valid. |
Affected Issues 0004087 |
| mod - src/Mod/Part/App/Geometry.cpp | Diff File | ||
| 2019-08-10 08:28 | paullee | New Issue | |
| 2019-08-10 08:28 | paullee | Tag Attached: Geometry Extension Set | |
| 2019-08-10 08:28 | paullee | File Added: Test_ GeometryExtension_ Sketcher_ 1.fcstd | |
| 2019-10-06 14:40 | paullee | Note Added: 0013716 | |
| 2019-10-06 14:41 | paullee | Note Edited: 0013716 | |
| 2019-10-06 14:41 | paullee | Assigned To | => wmayer |
| 2019-10-06 14:41 | paullee | Status | new => assigned |
| 2020-03-05 18:30 | paullee | Assigned To | wmayer => abdullah |
| 2020-03-06 16:24 | abdullah | Note Added: 0014212 | |
| 2020-03-06 16:24 | abdullah | Status | assigned => closed |
| 2020-03-06 16:24 | abdullah | Resolution | open => fixed |
| 2020-03-06 16:24 | abdullah | Fixed in Version | => 0.19 |
| 2020-03-06 17:30 | Kunda1 | Note Added: 0014213 | |
| 2020-03-07 03:33 | abdullah | Changeset attached | => FreeCAD master b748cc68 |
| 2020-03-07 03:33 | abdullah | Note Added: 0014215 |
