| 0004093 | Spreadsheet | General | public | 2019-08-20 11:14 | 2022-01-25 15:57 |
| Reporter | Paja | Assigned To | |||
| Priority | normal | Severity | minor | Reproducibility | random |
| Target Version | 0.20 | Fixed in Version | 0.19 | ||
| Summary | 0004093: Spreadsheet losts Alias-values | ||||
| Description | A relation between a drawing and values in Spreadsheet-cell property Alias does not survives saving, closing and further opening the file. Sometimes the Spreadsheet is completely free of former Aliases and sometimes just few of Aliases disappears. The expected Aliases are still kept in the function description of drawings parameters. Just the spreadsheet does not offers them (white background and empty Alias). Operation icons (Sketcher/Pad/Pocked/Fillet/Chamfer...) in the Application-tree shows red exclamation points (!). After rewriting the expected Aliases in each of the white-backgrounded Spreadsheet-cell the relation to the drawing is reestablished. | ||||
| Steps To Reproduce | Create a Spreadsheet an make some Aliases. Save the drawing, close FreeCAD, start FreeCAD and load the same file. Check the Aliases. | ||||
| Additional Information | OS: Windows 8.1 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.16131 (Git) Build type: Release Branch: releases/FreeCAD-0-18 Hash: 3129ae4296e40ed20e7b3d460b86e6969acbe1c3 Python version: 3.6.6 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.3.0 Locale: Czech/CzechRepublic (cs_CZ) | ||||
| Tags | #tobeclosed, spreadsheet | ||||
@Paja : thanks for reporting. Why did you report in the GCS subproject while it seems not related ? Also did you first discuss this on the forum before reporting as required in the tracker guidelines (big yellow banner) ? If you did, please add a link to the discussion. If not, please open a topic in the Help subforum so the community can perform an analysis and confirm the bug. ;) |
@Paja please follow up |
@Paja ping |
Forum thread https://forum.freecadweb.org/viewtopic.php?f=8&t=42486 |
Can you reproduce this in 0.19? |
It is my read of the forums discussion that this has been resolved in the 0.19 release. I'm marking this #tobeclosed and will do so shortly, unless I hear otherwise from testers. |
Closing. |
| 2019-08-20 11:14 | Paja | New Issue | |
| 2019-08-20 11:14 | Paja | Tag Attached: spreadsheet | |
| 2019-08-20 15:10 | openBrain | Note Added: 0013435 | |
| 2019-08-20 15:12 | openBrain | Status | new => feedback |
| 2019-08-20 15:12 | openBrain | Tag Attached: #post-to-forum | |
| 2019-08-22 15:32 | Kunda1 | Note Added: 0013450 | |
| 2019-12-05 15:18 | Kunda1 | Note Added: 0013871 | |
| 2019-12-05 15:18 | Kunda1 | Severity | block => minor |
| 2020-01-16 13:35 | Kunda1 | Note Added: 0014087 | |
| 2020-01-16 13:35 | Kunda1 | Tag Detached: #post-to-forum | |
| 2020-01-16 13:35 | Kunda1 | Tag Attached: #pending-forum | |
| 2020-01-16 13:36 | Kunda1 | Project | GCS => Expressions |
| 2020-01-16 13:36 | Kunda1 | Category | Bug => General |
| 2020-06-07 14:30 | Kunda1 | Note Added: 0014502 | |
| 2021-11-24 15:28 | chennes | Project | Expressions => Spreadsheet |
| 2021-12-29 05:06 | chennes | Note Added: 0016158 | |
| 2021-12-29 05:06 | chennes | Tag Detached: #pending-forum | |
| 2021-12-29 05:06 | chennes | Tag Attached: #tobeclosed | |
| 2022-01-25 15:57 | Kunda1 | Status | feedback => closed |
| 2022-01-25 15:57 | Kunda1 | Resolution | open => fixed |
| 2022-01-25 15:57 | Kunda1 | Fixed in Version | => 0.19 |
| 2022-01-25 15:57 | Kunda1 | Note Added: 0016297 |
