| 0004094 | Draft | General | public | 2019-08-21 11:56 | 2021-02-06 06:45 |
| Reporter | doubters | Assigned To | |||
| Summary | 0004094: Incorrect behavior of the Label tool in the Draft workspace | ||||
| Description | 1. The label parameter "Display Mode" is not saved and, after opening the file, returns to "3D text" 2. Extra characters for Custom text on the working field (fixed in version 0.19) 3. When changing the "Display Mode" from "3D text" to "2D text", "Text Alignment" has to be changed several times to correctly position the inscription. | ||||
| Tags | #post-to-forum | ||||
You didn't add you full FC version (per the guidelines in large yellow banner top of page). Also, please open forum thread to signal to community about this issue. |
In which section of the forum to post? Information about versions of FreeCADs that were checked: OS: Ubuntu 19.04 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.3. Build type: Release Python version: 3.7.3 Qt version: 5.12.2 Coin version: 4.0.0a OCC version: 7.3.0 Locale: C/Default (C) OS: Ubuntu 19.04 (ubuntu:GNOME/ubuntu) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19. Build type: Release Python version: 3.7.3 Qt version: 5.12.2 Coin version: 4.0.0a OCC version: 7.3.0 Locale: C/Default (C) |
@doubters https://forum.freecadweb.org/viewforum.php?f=3 |
@carlopav care to test this to see if in fact it's an issue ? |
@kunda1, i can confirm the behaviour with:
I never had a serious look at this part of Draft code, so I don't know what's happening, but anyway this is not an intuitive behaviour. When I'll have some time i could give it a deeper look, but not so soon... |
Thanks carlopav! I'm marking this ticket 'confirmed' and setting the target for 0.19 If you do have time that is great but no worries. |
This ticket has been migrated to GitHub as issue 5977. |
| 2019-08-21 11:56 | doubters | New Issue | |
| 2019-08-21 11:56 | doubters | File Added: label.mp4 | |
| 2019-08-21 20:03 | Kunda1 | Status | new => feedback |
| 2019-08-21 20:03 | Kunda1 | Note Added: 0013444 | |
| 2019-08-21 20:03 | Kunda1 | Tag Attached: #post-to-forum | |
| 2019-08-22 06:05 | doubters | Note Added: 0013447 | |
| 2019-08-22 06:05 | doubters | Status | feedback => new |
| 2019-08-22 15:28 | Kunda1 | Note Added: 0013448 | |
| 2019-08-22 15:29 | Kunda1 | Status | new => feedback |
| 2020-01-09 19:08 | Kunda1 | Note Added: 0014033 | |
| 2020-01-09 19:20 | carlopav | Note Added: 0014034 | |
| 2020-01-10 20:45 | Kunda1 | Status | feedback => confirmed |
| 2020-01-10 20:45 | Kunda1 | Note Added: 0014036 | |
| 2020-01-10 20:45 | Kunda1 | Target Version | => 0.19 |
