| 0004095 | Part | Bug | public | 2019-08-21 19:10 | 2019-10-21 00:02 |
| Reporter | keithsloan52 | Assigned To | |||
| Summary | 0004095: the "Analyze Geometry facilty" in Part and OpenSCAD workbenches has regressed and no longer works, | ||||
| Description | Regression of Analyze Geometry facilty | ||||
| Steps To Reproduce | To reproduce Open a new document switch to Part workbench Select a Cube/box Select created Cube/Box Click on "Analyze Geometry" icon No analysis window, workbench icons all go grey, have to quit document. Forum discussion https://forum.freecadweb.org/viewtopic.php?f=3&t=38679&p=327944#p327944 | ||||
| Additional Information | OS: Ubuntu 18.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.3. Build type: Release Python version: 3.6.8 Qt version: 5.9.5 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/UnitedKingdom (en_GB) And before you say this needs to be tested in 0.18.x-0.19dev THIS IS A REGRESSION This needs to be fixed in the stable version, I as a developer cannot test my code without this facility. i.e. anybody who develops code to create shapes needs this facility to be working | ||||
The same problem occurs trying to use the following tools ( i.e. icons in the Parts workbench )
Not now sure it is a regression. Think problem is caused when trying to check a null shape and instead of reporting it is null fails to check trying to check. |
closing for now. If the ticket won't re-open because of permissions or what not, @keithsloan52, just mention something on the thread and I'll re-open it. |
| 2019-08-21 19:10 | keithsloan52 | New Issue | |
| 2019-08-22 04:55 | keithsloan52 | Note Added: 0013446 | |
| 2019-09-07 16:01 | keithsloan52 | Note Added: 0013553 | |
| 2019-09-08 11:37 | openBrain | Priority | urgent => normal |
| 2019-09-08 11:37 | openBrain | Severity | major => minor |
| 2019-09-08 11:37 | openBrain | Status | new => feedback |
| 2019-09-08 11:37 | openBrain | Tag Attached: #pending-forum | |
| 2019-10-20 23:08 | Kunda1 | Tag Detached: #pending-forum | |
| 2019-10-21 00:02 | Kunda1 | Status | feedback => closed |
| 2019-10-21 00:02 | Kunda1 | Resolution | open => unable to reproduce |
| 2019-10-21 00:02 | Kunda1 | Note Added: 0013775 |
