| 0004100 | Draft | Bug | public | 2019-08-27 16:43 | 2020-06-19 18:18 |
| Reporter | cynabr | Assigned To | carlopav | ||
| Platform | x86-64 | OS | linux mint | OS Version | 18.1serena |
| Summary | 0004100: problem with bezier curves. Building curves by points | ||||
| Description | bezier curves and b-spline errors when it build by points introduced earlier (whis tool point). the problem is solved only by restarting freecad кривые безье и b-spline выдают ошибку. Для этого надо их построить по точкам ранее созданым с помощью инструмента ТОЧКА. (russian lang). | ||||
| Steps To Reproduce | 1 open workbench "draft" 2 create some points 3 create bezier curve by this points just create. 4 curve with error
5. if it didn’t work you need repeat steps 1-2-3. 6. second time the problem is always. | ||||
| Additional Information | English thread: https://forum.freecadweb.org/viewtopic.php?f=3&t=38968 Russian thread: https://forum.freecadweb.org/viewtopic.php?f=29&t=38955 | ||||
| Tags | bezier curve | ||||
link to problem |
@cynabr : thanks for reporting. However, according guidelines (big yellow banner), could you please first open a forum topic so the community can help validate and identify ? Think about at least telling what precise FC version you're using. Thanks |
>> please first open a forum topic so the community can help validate and identify I'll try. FC version OS: Linux Mint 18.1 Serena Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.1. Build type: Release Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.3.0 Locale: Russian/RussianFederation (ru_RU) Today I checked on Windows 7-64bit. Another computer ... same problem. The steps are the same. The FС version is the same. messages are the same... |
@cynabr : your version is outdated (as well as the Python & Qt libs it uses). Could you please try to reproduce with latest 0.19 dev version ? |
I'll try. it version not in the repository. |
You can find it here: https://github.com/FreeCAD/FreeCAD/releases/tag/0.19_pre However better to discuss it first in the forum: there is a section dedicated to arch and Draft. |
already found, compile... however i don't have ibpyside2-dev libshiboken2-dev pyside2-tools python3-pivy python3-pyside2.qtcore python3-pyside2.qtgui python3-pyside2.qtsvg python3-pyside2.qtwidgets python3-pyside2uic On my operating system so Python 2 and Qt4 This is not recommended for newer installations as both Python 2 and Qt4 are obsolete. https://www.freecadweb.org/wiki/CompileOnUnix |
OS: Linux Mint 18.1 Serena (KDE//usr/share/xsessions/plasma) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.Unknown Build type: Unknown Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 Locale: Russian/RussianFederation (ru_RU) all the same
need new libraries? need to update the linux distribution? need new libraries? need to update the linux distribution? I will try later and compile again ... |
@cynabr : compiling isn't really needed. You can use a Py3Qt5 AppImage that will embed every needed libs. ;) But please open a topic on the forum so you can get more advice. |
But please open a topic on the forum so you can get more advice I do it. thanks |
@cynabr please also post the forum thread to this ticket so we can track the discussion, thanks. Edit: also the link in 0004100:0013469 to demonstrate the issue is broken |
https://forum.freecadweb.org/viewtopic.php?f=29&t=38955link Lang ru Mod Edit:
Forum thread Mod Edit: Fixed broken BBCode |
I install FC ver 19pre
all the same |
@DeepSOIC says he can reproduce this but not reliably. source: https://forum.freecadweb.org/viewtopic.php?f=3&t=38968#p330651 |
I think there is a problem with Draft Points command related to the callback mechanism... |
The problem with Draft Points causing the mess with the following command has been fixed with https://github.com/FreeCAD/FreeCAD/pull/3617 Perhaps this is the solution to this issue. |
| 2019-08-27 16:43 | cynabr | New Issue | |
| 2019-08-27 16:47 | cynabr | Note Added: 0013469 | |
| 2019-08-27 16:50 | cynabr | Note Edited: 0013469 | |
| 2019-08-27 18:44 | openBrain | Status | new => feedback |
| 2019-08-27 18:44 | openBrain | Note Added: 0013471 | |
| 2019-08-27 18:45 | openBrain | Tag Attached: #post-to-forum | |
| 2019-08-28 16:51 | cynabr | Note Added: 0013475 | |
| 2019-08-28 16:51 | cynabr | Status | feedback => new |
| 2019-08-28 17:27 | openBrain | Note Added: 0013476 | |
| 2019-08-28 17:42 | cynabr | Note Added: 0013477 | |
| 2019-08-28 19:32 | carlopav | Note Added: 0013479 | |
| 2019-08-28 19:53 | cynabr | Note Added: 0013480 | |
| 2019-08-29 02:53 | cynabr | File Added: freecad19pre.png | |
| 2019-08-29 02:53 | cynabr | Note Added: 0013481 | |
| 2019-08-29 14:43 | openBrain | Note Added: 0013482 | |
| 2019-08-30 10:45 | cynabr | Note Added: 0013487 | |
| 2019-08-30 11:13 | Kunda1 | Note Added: 0013489 | |
| 2019-08-30 11:13 | Kunda1 | Note Edited: 0013469 | |
| 2019-08-30 11:14 | Kunda1 | Note Edited: 0013489 | |
| 2019-08-30 19:10 | cynabr | Note Added: 0013492 | |
| 2019-08-30 19:53 | DeepSOIC | Description Updated | |
| 2019-08-30 19:53 | DeepSOIC | Additional Information Updated | |
| 2019-08-31 04:24 | cynabr | Note Added: 0013494 | |
| 2019-08-31 18:25 | cynabr | Note Added: 0013500 | |
| 2019-09-01 16:08 | Kunda1 | Note Edited: 0013492 | |
| 2019-09-01 16:09 | Kunda1 | Note Edited: 0013492 | |
| 2019-09-01 16:10 | Kunda1 | Note Edited: 0013494 | |
| 2019-09-01 16:11 | Kunda1 | Tag Detached: #post-to-forum | |
| 2019-09-01 16:15 | Kunda1 | Note Added: 0013507 | |
| 2019-09-01 16:16 | Kunda1 | Note Edited: 0013507 | |
| 2019-09-01 19:12 | Kunda1 | Tag Attached: bezier curve | |
| 2020-06-14 20:11 | carlopav | Note Added: 0014542 | |
| 2020-06-14 20:54 | carlopav | Note Added: 0014546 | |
| 2020-06-19 18:18 | yorik | Changeset attached | => FreeCAD master 59ed7087 |
| 2020-06-19 18:18 | carlopav | Note Added: 0014571 | |
| 2020-06-19 18:18 | carlopav | Assigned To | => carlopav |
| 2020-06-19 18:18 | carlopav | Status | new => closed |
| 2020-06-19 18:18 | carlopav | Resolution | open => fixed |
