| 0004104 | FreeCAD | Bug | public | 2019-08-29 14:50 | 2021-02-23 17:00 |
| Reporter | openBrain | Assigned To | wmayer | ||
| Target Version | 0.19 | ||||
| Summary | 0004104: Void property value defaults to 1 | ||||
| Description | In any property value field (in property editor of combo view), if the value is voided (deleted, eventual unit remaining) then field is exited (eg. with Tab key), the value unexpectedly defaults to 1. --- The best solution proposal is that value should be set back to the one before deletion. --- Forum thread | ||||
| Steps To Reproduce | To reproduce, select any numerical value in the property editor (in combo view) and delete (void) the existing value (you can keep the unit if present) then hit "Tab" to switch out of the field => Value is 1 (I would expect 0). | ||||
| Additional Information | Present on every OS on every FC version for a long time (at least 0.16) | ||||
| Tags | #pending, UI, units | ||||
| 2019-08-29 14:50 | openBrain | New Issue | |
| 2019-08-30 03:31 | Kunda1 | Status | new => confirmed |
| 2019-08-30 03:31 | Kunda1 | Tag Attached: units | |
| 2019-08-30 03:32 | Kunda1 | Target Version | => 0.19 |
| 2020-10-21 15:22 | Kunda1 | Assigned To | => wmayer |
| 2020-10-21 15:22 | Kunda1 | Status | confirmed => assigned |
| 2020-10-21 15:22 | Kunda1 | Note Added: 0014916 | |
| 2020-10-21 15:23 | Kunda1 | Tag Attached: #pending | |
| 2020-10-21 15:23 | Kunda1 | Tag Attached: UI | |
| 2021-02-23 16:29 | wmayer | Target Version | 0.20 => 0.19 |
| 2021-02-23 17:00 | wmayer | Changeset attached | => FreeCAD master 1939b93f |
| 2021-02-23 17:00 | wmayer | Note Added: 0015424 | |
| 2021-02-23 17:00 | wmayer | Status | assigned => closed |
| 2021-02-23 17:00 | wmayer | Resolution | open => fixed |
