| 0004105 | Sketcher | Bug | public | 2019-08-31 19:58 | 2020-06-05 17:23 |
| Summary | 0004105: Automated changing of coincidence+line/line tangency with auto remove redundants can remove the wrong constraints | ||||
| Description | Coincidence+line/line tangency is known to be unstable and is automatically replaced by the semantically equivalent point/point tangency. This can interfere with auto remove redundants as shown in the examples in the corresponding forum discussion. This could be repaired by first applying the replacement mechanism, and afterwards removal of further redundants. If Auto remove is off everthing works as expected. | ||||
FreeCAD: master 08854bcc 2020-05-28 17:34:15 Committer: abdullahtahiriyo Details Diff |
Sketcher: Fix for failure of constraint substitution ==================================================== fixes 0004105 When a constraint substitution is present, a solve must precede any call to the redundant removal to update the solver information. |
Affected Issues 0004105 |
| mod - src/Mod/Sketcher/Gui/CommandConstraints.cpp | Diff File | ||
| 2019-08-31 19:58 | chrisb | New Issue | |
| 2019-08-31 19:58 | chrisb | Status | new => assigned |
| 2019-08-31 19:58 | chrisb | Assigned To | => abdullah |
| 2019-08-31 21:49 | Kunda1 | Description Updated | |
| 2020-05-28 17:38 | abdullah | Note Added: 0014434 | |
| 2020-05-29 12:23 | abdullah | Status | assigned => closed |
| 2020-05-29 12:23 | abdullah | Resolution | open => fixed |
| 2020-05-29 12:23 | abdullah | Fixed in Version | => 0.19 |
| 2020-05-29 12:23 | abdullah | Note Added: 0014435 | |
| 2020-06-05 17:23 | abdullah | Changeset attached | => FreeCAD master 08854bcc |
| 2020-06-05 17:23 | abdullah | Note Added: 0014480 |
