| 0004106 | PartDesign | Bug | public | 2019-09-01 01:13 | 2020-03-21 13:32 |
| Reporter | jruiz | Assigned To | wmayer | ||
| Summary | 0004106: Impossible to assign reference values to Yaw, Pitch and Roll angles. | ||||
| Description | When creating datum line, after selecting any reference, the fields Yaw, Pitch and Roll of Attachment offsets, lack of the small button for assigning them reference values. | ||||
| Steps To Reproduce |
| Tags | #post-to-forum | ||||
| child of | 0003981 | new | Expressions | Add Expression support to certain fields |
@jruiz : Guess you talk about expressions (instead of reference)... |
@openBrain where should this ticket go ? @jruiz please open a forum thread to discuss this. x-post this ticket there and x-post the thread URL back here so we can track it. Also please familiarize yourself with out Tracker Guidelines (yellow banner at the top of this page) |
@Kunda1 : actually I'm a bit hesitating. Yaw/Pitch/Roll (YPR) was originally listed in the forum thread going with 0003981 that I set as dup. But they have been removed because DeepSOIC (truly) stated that they are a big beast because they don't match any exposed property. So if YPR support expressions, user may first use them, then bind other (conflicting) expressions in the Angle+Axis properties in the Property Editor. This is also probably an issue by itself that expressions entered in the YPR aren't visible in the Property Editor. Maybe what could be fair would be to replace the dup of this ticket with a "related" link (as there is no real overlap), and take time to carefully think what to do here. |
@openBrain thank you for the comprehensive answer. I think this merits a forum thread for further discussion on how to move forward. Do you mind doing that? ;) |
@Kunda1 I need to clarify something on the original discussion then I'll do accordingly. ;) |
@Kunda1 : My understanding of the problem was actually a bit erroneous. I corrected my note above. Do you think a thread is still needed ? |
This is because there are actually 2 dialogs to edit attachments of objects: - one is src/Mod/Part/Gui/TaskAttacher.ui and this has the ExpressionEngine f(x) icon. This is the one coming with the Part WB - the other is src/Mod/Part/AttachmentEditor/TaskAttachmentEditor.ui and this one has not. This comes with the PartDesign WB visually they're identical, and functionally they're similar but slightly different. This is actually the exact same problem as issue 0004258, because these confusions can cause crashes in some circumstances. EDIT: when a datum is created then src/Mod/Part/AttachmentEditor/TaskAttachmentEditor.ui is called, therefore the AttachmentOffset fields don't have the f(x) buttons. When the datum has been created and later its Attachment property is edited from the property panel (clicking on the tiny button in the MapMode field) then src/Mod/Part/Gui/TaskAttacher.ui is called and this one does have the f(x) buttons. |
I opened a forum thread for this: https://forum.freecadweb.org/viewtopic.php?f=10&t=44377 |
https://github.com/FreeCAD/FreeCAD/commit/1cfe6d2cc7c3ccf9bce77bf776898547996195b7 |
| 2019-09-01 01:13 | jruiz | New Issue | |
| 2019-09-01 01:22 | jruiz | Tag Attached: Datum Line; Yaw; Pitch; Roll; Referenced value | |
| 2019-09-01 09:29 | openBrain | Note Added: 0013503 | |
| 2019-09-01 09:32 | openBrain | Relationship added | duplicate of 0003981 |
| 2019-09-10 20:38 | Kunda1 | Tag Detached: Datum Line; Yaw; Pitch; Roll; Referenced value | |
| 2019-09-10 20:40 | Kunda1 | Status | new => feedback |
| 2019-09-10 20:40 | Kunda1 | Note Added: 0013568 | |
| 2019-09-10 20:40 | Kunda1 | Tag Attached: #post-to-forum | |
| 2019-09-11 09:21 | openBrain | Note Added: 0013572 | |
| 2019-09-12 16:20 | Kunda1 | Note Added: 0013584 | |
| 2019-09-13 11:53 | openBrain | Note Added: 0013591 | |
| 2019-09-16 08:40 | openBrain | Note Edited: 0013572 | |
| 2019-09-16 08:41 | openBrain | Note Added: 0013606 | |
| 2020-01-09 19:06 | Kunda1 | Relationship replaced | child of 0003981 |
| 2020-01-28 07:58 | Zolko | Note Added: 0014123 | |
| 2020-01-28 11:21 | Zolko | Note Edited: 0014123 | |
| 2020-03-21 02:45 | uwestoehr | Note Added: 0014254 | |
| 2020-03-21 13:32 | wmayer | Assigned To | => wmayer |
| 2020-03-21 13:32 | wmayer | Status | feedback => closed |
| 2020-03-21 13:32 | wmayer | Resolution | open => fixed |
| 2020-03-21 13:32 | wmayer | Fixed in Version | => 0.19 |
| 2020-03-21 13:32 | wmayer | Note Added: 0014256 |
