| 0004108 | Draft | Bug | public | 2019-09-01 08:12 | 2021-06-07 01:55 |
| Reporter | Roy_043 | Assigned To | |||
| Summary | 0004108: Coordinate input not always relative to current working plane | ||||
| Description | If the current working plane is not one of the main working planes, coordinates entered via the keyboard are interpreted as global coordinates. | ||||
| Steps To Reproduce | Please open the attached file and do the following:
Note that the labels for the coordinate fields for the center are confusing: In the test above: Center X Global Y Global Z If you align the working plane with one of the faces of the Extrusion the labels are: Center X Local Y Local Z If point entry is always relative to the current working plane (as it should be) using 'Local' or 'Global' is unnecessary, If global coordinates are required the user can switch to the XY-plane. | ||||
| Additional Information | Forum discussion: https://forum.freecadweb.org/viewtopic.php?f=3&t=38962 | ||||
FreeCAD info: OS: Windows 8.1 (6.3) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.17877 (Git) Build type: Release Branch: master Hash: 1e19ef5be4735f4200eaf99ce9e487d2be6f4151 Python version: 3.6.8 Qt version: 5.12.1 Coin version: 4.0.0a OCC version: 7.3.0 Locale: Dutch/Netherlands (nl_NL) |
Confirmed on the forum |
FreeCAD: master 589cec2d 2021-02-01 04:19:11 Details Diff |
Draft: Add global mode to enter points - fixes 0004108 |
Affected Issues 0004108 |
| mod - src/Mod/Draft/DraftGui.py | Diff File | ||
| mod - src/Mod/Draft/Resources/ui/preferences-draftinterface.ui | Diff File | ||
FreeCAD: master c4a49a55 2021-03-26 10:18:23 Committer: GitHub Details Diff |
Merge pull request 0004348 from marioalexis84/draft-coordinate_input [0.20] [Draft] Add global mode to enter points - Fixes 0004108 |
| mod - src/Mod/Draft/draftguitools/gui_base_original.py | Diff File | ||
| mod - src/Mod/Draft/draftguitools/gui_beziers.py | Diff File | ||
| mod - src/Mod/Draft/draftguitools/gui_dimensions.py | Diff File | ||
| mod - src/Mod/Draft/draftguitools/gui_ellipses.py | Diff File | ||
| mod - src/Mod/Draft/draftguitools/gui_lines.py | Diff File | ||
| mod - src/Mod/Draft/draftguitools/gui_mirror.py | Diff File | ||
| mod - src/Mod/Draft/draftguitools/gui_move.py | Diff File | ||
| mod - src/Mod/Draft/draftguitools/gui_points.py | Diff File | ||
| mod - src/Mod/Draft/draftguitools/gui_polygons.py | Diff File | ||
| mod - src/Mod/Draft/draftguitools/gui_rectangles.py | Diff File | ||
| mod - src/Mod/Draft/draftguitools/gui_rotate.py | Diff File | ||
| mod - src/Mod/Draft/draftguitools/gui_scale.py | Diff File | ||
| mod - src/Mod/Draft/draftguitools/gui_shapestrings.py | Diff File | ||
| mod - src/Mod/Draft/draftguitools/gui_splines.py | Diff File | ||
| mod - src/Mod/Draft/draftguitools/gui_stretch.py | Diff File | ||
| 2019-09-01 08:12 | Roy_043 | New Issue | |
| 2019-09-01 08:12 | Roy_043 | File Added: WorkPlane.FCStd | |
| 2019-09-01 08:18 | Roy_043 | Note Added: 0013501 | |
| 2019-09-01 13:05 | Kunda1 | Status | new => confirmed |
| 2019-09-01 13:05 | Kunda1 | Note Added: 0013506 | |
| 2019-09-01 13:37 | Kunda1 | Target Version | => 0.19 |
| 2021-03-26 10:30 | yorik | Changeset attached | => FreeCAD master c4a49a55 |
| 2021-03-26 10:30 | marioalexis | Changeset attached | => FreeCAD master 589cec2d |
| 2021-03-26 10:30 | marioalexis | Note Added: 0015546 | |
| 2021-06-07 01:55 | marioalexis | Status | confirmed => closed |
| 2021-06-07 01:55 | marioalexis | Resolution | open => fixed |
