| 0004112 | PartDesign | Bug | public | 2019-09-03 07:32 | 2019-09-03 18:09 |
| Reporter | DeeJayOne | Assigned To | |||
| Priority | none | Severity | minor | Reproducibility | always |
| Summary | 0004112: Fillet segment association are "randomly" changed after inserting a new PAD/POCKET when Tip is changed to a previous state. | ||||
| Description | Fillet segment association are "randomly" changed after inserting a new PAD/POCKET when Tip is changed to a previous state. | ||||
| Steps To Reproduce | With PartDesign Tool : - Create a cube (draw a rectangle on a new sketch, then create a Pad) - Select body transparency to 50% - On the top face of the cube, add a rectangular pocket - On each top segment (x4) of the pocket, create Fillets (x4) with default value (1mm) At this step, all seems OK. - Change Tip to the first Pad (Cube) - On an other side than the top face, draw a new sketch (rectangle or circle) - Then create a new Pad or Pocket. At this step, the bug occurs : some of the previous fillets are associated to other segments of the body. | ||||
| child of | 0000922 | assigned | realthunder | FreeCAD | Topological Naming |
Please see the result of each step to reproduce the bug. |
@DeeJayOne : following required worflow (big yellow box on top of page) and posting to forum may have save you the time required for this ticket. This is a very very very well known issue, due to Topological Naming. You can find plenty of information searching for this on the forum. Notice it may greatly improve in the soon future. :) Stay tuned. In between, there are tons of tips, guidelines and godd practices in the forum & wiki to have stable models. ;) |
https://www.freecad.org/wiki/Topological_naming_problem Closing |
| 2019-09-03 07:32 | DeeJayOne | New Issue | |
| 2019-09-03 07:35 | DeeJayOne | File Added: step-1.PNG | |
| 2019-09-03 07:35 | DeeJayOne | File Added: step-2.PNG | |
| 2019-09-03 07:35 | DeeJayOne | File Added: step-3.PNG | |
| 2019-09-03 07:35 | DeeJayOne | File Added: step-4.PNG | |
| 2019-09-03 07:35 | DeeJayOne | File Added: step-4a.PNG | |
| 2019-09-03 07:35 | DeeJayOne | File Added: step-4b.PNG | |
| 2019-09-03 07:35 | DeeJayOne | File Added: step-4c.PNG | |
| 2019-09-03 07:35 | DeeJayOne | Note Added: 0013518 | |
| 2019-09-03 07:39 | DeeJayOne | File Added: test_Tip_change_v1_step_1.FCStd | |
| 2019-09-03 15:19 | openBrain | Note Added: 0013522 | |
| 2019-09-03 15:19 | openBrain | Relationship added | child of 0000922 |
| 2019-09-03 15:20 | openBrain | Priority | urgent => none |
| 2019-09-03 15:20 | openBrain | Severity | crash => minor |
| 2019-09-03 15:20 | openBrain | Status | new => resolved |
| 2019-09-03 15:20 | openBrain | Resolution | open => duplicate |
| 2019-09-03 15:21 | openBrain | Tag Attached: #tobeclosed | |
| 2019-09-03 18:09 | Kunda1 | Status | resolved => closed |
| 2019-09-03 18:09 | Kunda1 | Note Added: 0013525 | |
| 2019-09-03 18:09 | Kunda1 | Tag Detached: #tobeclosed |
