| 0004113 | Draft | Bug | public | 2019-09-03 15:14 | 2021-02-21 03:46 |
| Reporter | openBrain | Assigned To | yorik | ||
| Target Version | 0.19 | Fixed in Version | 0.19 | ||
| Summary | 0004113: When Clone is used in Draft/Scale, the cloned part placement is always set to origin whatever is the reference point | ||||
| Description | When Clone is used in Draft/Scale, the cloned part placement is always set to origin whatever is the reference point. Forum thread (from this post) | ||||
| Steps To Reproduce | On a new blank document, add a Part/Cube. Select it then in Draft WB, choose Scale. Enter or click a reference point different from 0,0,0 and validate. In next Task screen tick "Clone". Although the preview is correctly displayed, when the operation is validated the cloned part is placed back to origin. | ||||
| Tags | Draft | ||||
FreeCAD: master 7c8c5892 2021-02-07 02:35:17 Details Diff |
Draft: Correct the placement in scale_with_clone - fixes 0004113 |
Affected Issues 0004113 |
| mod - src/Mod/Draft/draftguitools/gui_scale.py | Diff File | ||
FreeCAD: master 4e3a2699 2021-02-08 15:07:35 Committer: GitHub Details Diff |
Merge pull request 0004386 from marioalexis84/draft-clone Draft: Fixes 0004113: When Clone is used in Draft/Scale, the cloned part placement is always set to origin whatever is the reference point |
| 2019-09-03 15:14 | openBrain | New Issue | |
| 2019-09-03 15:14 | openBrain | Status | new => assigned |
| 2019-09-03 15:14 | openBrain | Assigned To | => yorik |
| 2019-09-03 15:14 | openBrain | Tag Attached: Draft | |
| 2021-02-06 06:29 | abdullah | Target Version | => 0.20 |
| 2021-02-08 15:30 | yorik | Changeset attached | => FreeCAD master 4e3a2699 |
| 2021-02-08 15:30 | marioalexis | Changeset attached | => FreeCAD master 7c8c5892 |
| 2021-02-08 15:30 | marioalexis | Note Added: 0015312 | |
| 2021-02-21 03:25 | marioalexis | Note Added: 0015401 | |
| 2021-02-21 03:45 | Kunda1 | Product Version | => 0.19 |
| 2021-02-21 03:45 | Kunda1 | Target Version | 0.20 => 0.19 |
| 2021-02-21 03:46 | Kunda1 | Status | assigned => closed |
| 2021-02-21 03:46 | Kunda1 | Resolution | open => fixed |
| 2021-02-21 03:46 | Kunda1 | Fixed in Version | => 0.19 |
| 2021-02-21 03:46 | Kunda1 | Note Added: 0015404 |
