| 0004124 | Sketcher | Bug | public | 2019-09-11 20:43 | 2021-02-20 17:33 |
| Reporter | dimitar | Assigned To | |||
| Priority | normal | Severity | minor | Reproducibility | random |
| Platform | Windows | OS | Windows | OS Version | 10 |
| Summary | 0004124: Sketcher angle produces errors when units set in m/kg/degree | ||||
| Description | Sketcher Angle produces errors when in meters constantly when creating angle constraints. As per the forum below, it seems to be an imprecision issue. Even, as in the suggestion of the forum, creating enabling advanced solver, and enabling sketch size multiplier, the issue persists. Forum thread: https://forum.freecadweb.org/viewtopic.php?f=3&t=37716&hilit=angle | ||||
| Steps To Reproduce | 1. Create a sketch 2. Create 2 lines a good distance away from the sketch origin 3. Add angle constraint 4. Leave the sketch 5. Adjust the angle constraint in the sketch properties 6. Sometimes the sketch fails to recompute throwing an Sketcher Invalid Constraint Index 22 or just an Error or Error 3. | ||||
| Additional Information | OS: Windows 10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.16117 (Git) Build type: Release Branch: releases/FreeCAD-0-18 Hash: dbb4cc6415bac848a294f03b80f65e888d531742 Python version: 3.6.6 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/UnitedKingdom (en_GB) | ||||
| Tags | #pending-forum, units | ||||
I've started another thread with a fresh example. In the attached file, if the spreadsheet number gets changed, the angle sometimes adjusts itself, sometimes it doesn't. https://forum.freecadweb.org/viewtopic.php?f=3&t=39276 |
i've just experienced this behavior with a radius constraint. I suspect it must be a rounding issue due to the fact that I am working in meters. In the following example, if i change the radius from 70m to 50m, i get the following error, also, if i go down to what it gives me and then try to go back up I also get and invalid constraints with index 8. |
Moved to Sketcher category @abdullah care to take look? |
This ticket has been migrated to GitHub as issue 5986. |
| 2019-09-11 20:43 | dimitar | New Issue | |
| 2019-09-11 20:43 | dimitar | File Added: edgeAngleError.FCStd | |
| 2019-09-12 00:26 | dimitar | File Added: angled constraints issues.FCStd | |
| 2019-09-12 00:26 | dimitar | Note Added: 0013582 | |
| 2019-09-12 16:24 | Kunda1 | Tag Attached: units | |
| 2019-09-12 16:24 | Kunda1 | Tag Attached: #pending-forum | |
| 2019-09-13 17:05 | dimitar | File Added: FreeCAD_Dv3e0Ajbbs.png | |
| 2019-09-13 17:05 | dimitar | File Added: FreeCAD_wjaJcbFmgB.png | |
| 2019-09-13 17:05 | dimitar | File Added: constraints issue.FCStd | |
| 2019-09-13 17:05 | dimitar | Note Added: 0013592 | |
| 2021-02-20 17:32 | Kunda1 | Project | FreeCAD => Sketcher |
| 2021-02-20 17:33 | Kunda1 | Note Added: 0015391 |
