| 0004129 | PartDesign | Bug | public | 2019-09-13 14:22 | 2022-01-24 18:47 |
| Reporter | uwestoehr | Assigned To | abdullah | ||
| Summary | 0004129: Crash on setting certain dimensions in a sketch (Upstream OCC bug) | ||||
| Description | - open the attached example file - open the Sketch "Sketch-Pinpad" - set for the Edge 2 a vertical constraint (e.g. 3mm) - close the sketch result: crash One out of 5 times it does not crash and I get an "access violation" in the report view. The crash could be reproduced also on Mac. @TheMarkster analyzed the problem in this post: https://forum.freecad.org/viewtopic.php?p=327107#p327139 | ||||
| Additional Information | Forum thread: https://forum.freecad.org/viewtopic.php?f=3&t=38590 OS: Windows 10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.17505 (Git) Build type: Release Branch: master Hash: 755536e9df94d2d39da1468420f1fd333c35da7a Python version: 3.6.6 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.3.0 Locale: German/Germany (de_DE) | ||||
| Tags | #ready-for-migration, OCC Bug, OCC Unscheduled, sketcher, upstream | ||||
Note: OCCT crashes in PartDesign::FeatureFillet |
I have reported the bug upstream to OpenCascade and provided a patch for a possible solution. With the patch an exception is raised, which is catched by FreeCAD and the crash is avoided: https://tracker.dev.opencascade.org/view.php?id=31585 @kunda1 I think you do something with upstream reported OCCT tickets... so I let you do your magic ;) |
@abdullah I've added this ticket and companion upstream tickets to the thread tracking upstream OCC bugs: https://forum.freecad.org/viewtopic.php?t=20264 ;) |
There is no solution other than wait for OCCT to solve the access violation: https://tracker.dev.opencascade.org/view.php?id=31585 Until them, this ticket remains as acknowledged. |
Added 'OCC bug' to the bug summary for easier Identification |
@abdullah do you mind bumping the upstream ticket? |
This ticket has been migrated to GitHub as issue 5989. |
| 2019-09-13 14:22 | uwestoehr | New Issue | |
| 2019-09-13 14:22 | uwestoehr | Tag Attached: sketcher | |
| 2019-09-13 14:22 | uwestoehr | File Added: Crashfile.FCStd | |
| 2020-05-29 13:51 | abdullah | Note Added: 0014438 | |
| 2020-05-29 13:51 | abdullah | Project | Sketcher => PartDesign |
| 2020-05-30 14:00 | abdullah | Note Added: 0014444 | |
| 2020-05-30 15:03 | Kunda1 | Tag Attached: OCC Bug | |
| 2020-05-30 15:03 | Kunda1 | Tag Attached: upstream | |
| 2020-05-30 15:04 | Kunda1 | Tag Attached: OCC Unscheduled | |
| 2020-05-30 15:15 | Kunda1 | Note Added: 0014445 | |
| 2020-05-30 15:15 | Kunda1 | Status | new => confirmed |
| 2020-06-06 17:45 | abdullah | Assigned To | => abdullah |
| 2020-06-06 17:45 | abdullah | Status | confirmed => acknowledged |
| 2020-06-06 17:45 | abdullah | Note Added: 0014487 | |
| 2020-06-06 17:45 | abdullah | Product Version | 0.19 => 0.20 |
| 2020-12-01 11:39 | Kunda1 | Summary | Crash on setting certain dimensions in a sketch => Crash on setting certain dimensions in a sketch (Upstream OCC bug) |
| 2020-12-01 11:39 | Kunda1 | Note Added: 0015041 | |
| 2022-01-24 18:40 | Kunda1 | Note Added: 0016273 | |
| 2022-01-24 18:47 | Kunda1 | Tag Attached: #ready-for-migration |
