| 0004131 | FreeCAD | Bug | public | 2019-09-16 18:49 | 2020-01-07 12:00 |
| Reporter | tbray | Assigned To | wandererfan | ||
| Platform | PC | OS | Windows 10 | OS Version | 8109 |
| Summary | 0004131: Import spreadsheet into TechDraw, looses properties | ||||
| Description | The spreadsheet has a nice feature that allows display values in inches. If you use this feature, add it to a TechDrawing, or export it, the property is lost and everything reverts back to the standard mm setting (regardless of the General "units" setting. | ||||
| Steps To Reproduce | Make a simple drawing using a sketch, constrain it and Pad it. Make a spreadsheet and import the 3 dimensions. Make a 2 copies of the 3 dimensions. Change the properties of the first set to "in". The second set divide each value by 25.4 (mm -> in). The two sets of values should pretty much agree, the last set will have more decimal places. Import the spreadsheet into a TechDraw. The values with the "in" view property will change back to mm. | ||||
| Additional Information | OS: Windows 10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.16131 (Git) Build type: Release Branch: releases/FreeCAD-0-18 Hash: 3129ae4296e40ed20e7b3d460b86e6969acbe1c3 Python version: 3.6.6 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/UnitedStates (en_US) | ||||
| Tags | spreadsheet, TechDraw | ||||
Why is this an issue: I often draw stuff that are based on metric units and if I print them it isn't an issue. If I make them on my mill which is manual and uses English/American measurements, I need to build a cut list manually. I can do it in the spreadsheet but its ugly, especially because I have to use the mm to in manually, and the spreadsheet still says mm. It would actually be better to just be able to turn off the dimensions on a cell by cell basis but I would prefer to use the "in" property. |
confirmed. |
I think this is the result you're looking for: |
Should be fixed bycommit 019198a30c. |
@wandererfan should we close this ticket then ? |
| 2019-09-16 18:49 | tbray | New Issue | |
| 2019-09-16 18:49 | tbray | File Added: SSdemo.zip | |
| 2019-09-16 18:50 | tbray | Tag Attached: spreadsheet | |
| 2019-09-16 18:50 | tbray | Tag Attached: TechDraw | |
| 2019-09-16 18:55 | tbray | Note Added: 0013610 | |
| 2019-09-19 15:20 | wandererfan | Assigned To | => wandererfan |
| 2019-09-19 15:20 | wandererfan | Status | new => confirmed |
| 2019-09-19 15:20 | wandererfan | Target Version | => 0.19 |
| 2019-09-19 15:20 | wandererfan | Steps to Reproduce Updated | |
| 2019-09-19 15:20 | wandererfan | Additional Information Updated | |
| 2019-09-19 15:20 | wandererfan | Note Added: 0013649 | |
| 2019-09-19 15:22 | wandererfan | Note Edited: 0013649 | |
| 2019-09-19 15:24 | wandererfan | File Added: SSdemo.png | |
| 2019-09-19 15:24 | wandererfan | Note Added: 0013650 | |
| 2019-09-20 23:35 | wandererfan | Note Added: 0013668 | |
| 2019-09-20 23:36 | wandererfan | Status | confirmed => resolved |
| 2019-09-20 23:36 | wandererfan | Resolution | open => fixed |
| 2019-09-20 23:36 | wandererfan | Fixed in Version | => 0.19 |
| 2020-01-06 15:50 | Kunda1 | Note Added: 0013989 | |
| 2020-01-07 12:00 | wandererfan | Status | resolved => closed |
