| 0004133 | FreeCAD | Bug | public | 2019-09-17 04:08 | 2021-02-06 06:50 |
| Reporter | bug_reporter_00342 | Assigned To | |||
| Platform | Linux | OS | Ubuntu | OS Version | 18.04.3 LTS |
| Summary | 0004133: Sometimes face / sketch exports to flattened svg or dxf incorrectly | ||||
| Description | I've been seeing this bug very occasionally I believe since 0.16, seemingly at random. Trying to export a particular sketch as a flattened svg or dxf truly flattens the constituent paths such that they lie on top of each other when they should not. It may be that the paths are being projected along the wrong (90deg) axis to produce the exported vector image. Trying to export a clone or facebinder of the relevant sketch then exporting produces the same results. | ||||
| Steps To Reproduce | Open attached FCStd file, try to export Sketch002 as Flattened SVG or DXF. View exported file in Inkscape or similar, visually compare to original sketch. For reference, Sketch001 exports fine. Rotating the body of Sketch002 by 90deg to lie parallel to the plane of Sketch001 does not solve the issue. Tried in 0.17, 0.18, and 0.19 Daily with the same results. | ||||
| Additional Information | OS: Ubuntu 18.04.3 LTS (ubuntu:GNOME/ubuntu) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19. Build type: Release Python version: 3.6.8 Qt version: 5.9.5 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/UnitedStates (en_US) | ||||
| Tags | #pending-forum, DXF, export, SVG | ||||
Workaround is to pad the sketch, export the pad as a STEP file, open the STEP file in a new FreeCAD document, recreate the original sketch by tracing out the face using external geometry, then export the new sketch as SVG or DXF. This workaround does not support sketches that cannot currently be padded, such as those which would produce multiple solids. |
Thanks for posting. Do you mind (per the guidelines in the yellow banner at the top of the page) to post this issue to the forum to get the attention of the community. Thank you. |
Yep, no worries, I'll make a forum post. I did see the yellow banner, but the text by the Description text field currently reads:
I was pretty confident that this is a bug, so I posted without the forum thread. Perhaps the text could be changed if a forum post is always desired. |
@bug_reporter_00342 Thanks for posting to the forum, in the future please x-post the url back to the ticket so we can track the thread from the ticket. thanks Forum thread: https://forum.freecadweb.org/viewtopic.php?f=3&t=39441 |
Apparently, similiar discussion at https://forum.freecadweb.org/viewtopic.php?f=3&t=33708 |
This ticket has been migrated to GitHub as issue 5990. |
| 2019-09-17 04:08 | bug_reporter_00342 | New Issue | |
| 2019-09-17 04:08 | bug_reporter_00342 | Tag Attached: DXF | |
| 2019-09-17 04:08 | bug_reporter_00342 | Tag Attached: export | |
| 2019-09-17 04:08 | bug_reporter_00342 | Tag Attached: SVG | |
| 2019-09-17 04:08 | bug_reporter_00342 | File Added: cant_export_Sketch002.FCStd | |
| 2019-09-17 17:21 | bug_reporter_00342 | Note Added: 0013615 | |
| 2019-09-17 20:09 | Kunda1 | Tag Attached: #post-to-forum | |
| 2019-09-17 20:13 | Kunda1 | Status | new => feedback |
| 2019-09-17 20:13 | Kunda1 | Note Added: 0013616 | |
| 2019-09-19 00:14 | bug_reporter_00342 | Note Added: 0013636 | |
| 2019-09-19 00:14 | bug_reporter_00342 | Status | feedback => new |
| 2019-09-19 00:14 | bug_reporter_00342 | Note Edited: 0013636 | |
| 2019-09-19 02:53 | Kunda1 | Note Added: 0013640 | |
| 2019-09-19 02:54 | Kunda1 | Tag Detached: #post-to-forum | |
| 2019-09-19 02:54 | Kunda1 | Tag Attached: #pending-forum | |
| 2019-09-27 10:48 | Kunda1 | Note Added: 0013690 | |
