0004139PartDesignBugpublic2021-03-29 09:00
ReporterDeeJayOne Assigned Towmayer
Status closedResolutionfixed
Platformx86-64OSWindowsOS Version10
Product Version0.18
Target Version0.20
Summary0004139: v0.18-16131 - Macro - SubtractivePipe attached path object issues after macro executed.
DescriptionI have tried to capture a macro while drawing a body which is containing a SubtractivePipe object.
When, I play the generated macro file, I have 2 errors displayed (on the body -> "Tip shape is empty" and the Subtractive part -> "No spine linked")
1) I have first checked the sweep properties of the SubtractivePipe and I can see that the attached path object is void. So it explains why errors occur.
Then, if I launch the GUI guest settings for the SubtractivePipe, I can newly type the attached path object, then validate and all is done.
2) I have added a python cmd in the script to add the attached path object to the subtractivePipe.
Then, I have played the macro file but the 2 errors are always here.
I can see on the properties that the attached object (a sketch in my case) is well typed, so I can say that the macro script is now OK.
But when I newly launch the GUI guest settings, I can see that there is no attached path object. How is it possible ?
I need manually type the attached path object via the GUI guest setting of the Subtractive object to solve the problem.
In case of automatic macro usage, it is very annoying.
Steps To ReproduceStart the macro recording
1) Select the PartDesign mode
2) Draw a cube via a sketch and a pad.
3) Draw a "path" sketch with a line that throws the cube.
4) Draw a "profile" sketch with a circle at the normal of the path line.
5) Draw a subtractivePipe by selecting first the profile sketch. Select the path line as the attached path object, then valid the operation.
7) Stop the macro recording
Then create a new file, create a new body and then execute the macro file previously recorded.
Additional InformationI have also played the generated macro file with v0.19-18234 and I have also the error message "No spine linked" on the Subtractive object. (same pb. as v0.18)
But this time, I don't have the error message on the body.
Tags#pending
DeeJayOne
2019-09-20 18:38
reporter   ~0013666
The macro recorded file I have used and a modified version which includes the attached path object for the SubtractivePipe.
Test_SubtractivePipe_modified.FCMacro (10,002 bytes)
# -*- coding: utf-8 -*-
# Macro Begin: C:\Users\deeja\AppData\Roaming\FreeCAD\Macro\Test_SubtractivePipe.FCMacro +++++++++++++++++++++++++++++++++++++++++++++++++
import FreeCAD
import PartDesign
import PartDesignGui
import Sketcher
App.newDocument("Sans nom")
#App.setActiveDocument("Sans_nom")
#App.ActiveDocument=App.getDocument("Sans_nom")
#Gui.ActiveDocument=Gui.getDocument("Sans_nom")
#Gui.activeDocument().activeView().viewDefaultOrientation()
App.activeDocument().addObject('PartDesign::Body','Body')
#Gui.activateView('Gui::View3DInventor', True)
#Gui.activeView().setActiveObject('pdbody', App.activeDocument().Body)
App.activeDocument().Body.newObject('Sketcher::SketchObject','Sketch')
App.activeDocument().Sketch.Support = (App.activeDocument().XY_Plane, [''])
App.activeDocument().Sketch.MapMode = 'FlatFace'
App.ActiveDocument.recompute()
#Gui.activeDocument().setEdit('Sketch')
#Gui.activateWorkbench('SketcherWorkbench')
#ActiveSketch = App.ActiveDocument.getObject('Sketch')
#tv = Show.TempoVis(App.ActiveDocument)
#if ActiveSketch.ViewObject.HideDependent:
#  objs = tv.get_all_dependent(ActiveSketch)
#  objs = filter(lambda x: not x.TypeId.startswith("TechDraw::"), objs)
#  objs = filter(lambda x: not x.TypeId.startswith("Drawing::"), objs)
#  tv.hide(objs)
#if ActiveSketch.ViewObject.ShowSupport:
#  tv.show([ref[0] for ref in ActiveSketch.Support if not ref[0].isDerivedFrom("PartDesign::Plane")])
#if ActiveSketch.ViewObject.ShowLinks:
#  tv.show([ref[0] for ref in ActiveSketch.ExternalGeometry])
#tv.hide(ActiveSketch)
#ActiveSketch.ViewObject.TempoVis = tv
#del(tv)
#if ActiveSketch.ViewObject.RestoreCamera:
#  ActiveSketch.ViewObject.TempoVis.saveCamera()
geoList = []
geoList.append(Part.LineSegment(App.Vector(-12.439816,13.332624,0),App.Vector(13.987350,13.332624,0)))
geoList.append(Part.LineSegment(App.Vector(13.987350,13.332624,0),App.Vector(13.987350,-14.999204,0)))
geoList.append(Part.LineSegment(App.Vector(13.987350,-14.999204,0),App.Vector(-12.439816,-14.999204,0)))
geoList.append(Part.LineSegment(App.Vector(-12.439816,-14.999204,0),App.Vector(-12.439816,13.332624,0)))
App.ActiveDocument.Sketch.addGeometry(geoList,False)
conList = []
conList.append(Sketcher.Constraint('Coincident',0,2,1,1))
conList.append(Sketcher.Constraint('Coincident',1,2,2,1))
conList.append(Sketcher.Constraint('Coincident',2,2,3,1))
conList.append(Sketcher.Constraint('Coincident',3,2,0,1))
conList.append(Sketcher.Constraint('Horizontal',0))
conList.append(Sketcher.Constraint('Horizontal',2))
conList.append(Sketcher.Constraint('Vertical',1))
conList.append(Sketcher.Constraint('Vertical',3))
App.ActiveDocument.Sketch.addConstraint(conList)
#Gui.activeDocument().resetEdit()
#tv = ActiveSketch.ViewObject.TempoVis
#if tv:
#  tv.restore()
#ActiveSketch.ViewObject.TempoVis = None
#del(tv)
#Gui.activateWorkbench('PartDesignWorkbench')
#Gui.activeDocument().activeView().viewIsometric()
App.activeDocument().Body.newObject("PartDesign::Pad","Pad")
App.activeDocument().Pad.Profile = App.activeDocument().Sketch
App.activeDocument().Pad.Length = 10.0
#Gui.activeDocument().hide("Sketch")
#Gui.ActiveDocument.Pad.ShapeColor=Gui.ActiveDocument.Body.ShapeColor
#Gui.ActiveDocument.Pad.LineColor=Gui.ActiveDocument.Body.LineColor
#Gui.ActiveDocument.Pad.PointColor=Gui.ActiveDocument.Body.PointColor
#Gui.ActiveDocument.Pad.Transparency=Gui.ActiveDocument.Body.Transparency
#Gui.ActiveDocument.Pad.DisplayMode=Gui.ActiveDocument.Body.DisplayMode
#Gui.activeDocument().setEdit('Pad', 0)
#Gui.Selection.clearSelection()
App.ActiveDocument.Pad.Length = 30.000000
App.ActiveDocument.Pad.Length2 = 100.000000
App.ActiveDocument.Pad.Type = 0
App.ActiveDocument.Pad.UpToFace = None
App.ActiveDocument.Pad.Reversed = 0
App.ActiveDocument.Pad.Midplane = 0
App.ActiveDocument.Pad.Offset = 0.000000
#Gui.SendMsgToActiveView("ViewFit")
App.activeDocument().Body.newObject('Sketcher::SketchObject','Sketch001')
App.activeDocument().Sketch001.Support = (App.activeDocument().XZ_Plane, [''])
App.activeDocument().Sketch001.MapMode = 'FlatFace'
#Gui.activeDocument().setEdit('Sketch001')
#ActiveSketch = App.ActiveDocument.getObject('Sketch001')
#  tv.hide(objs)
#del(tv)
App.ActiveDocument.Sketch001.addGeometry(Part.LineSegment(App.Vector(-24.063456,8.601261,0),App.Vector(18.286116,20.472610,0)),False)
#if tv:
#  tv.restore()
#del(tv)
#  tv.hide(objs)
#del(tv)
#Gui.getDocument('Sans_nom').resetEdit()
#if tv:
#  tv.restore()
#del(tv)
App.getDocument('Sans_nom').recompute()
App.activeDocument().Body.newObject('Sketcher::SketchObject','Sketch002')
App.activeDocument().Sketch002.Support = (App.activeDocument().YZ_Plane, [''])
App.activeDocument().Sketch002.MapMode = 'FlatFace'
#Gui.activeDocument().setEdit('Sketch002')
#ActiveSketch = App.ActiveDocument.getObject('Sketch002')
#  tv.hide(objs)
#del(tv)
App.ActiveDocument.Sketch002.addGeometry(Part.Circle(App.Vector(0.493656,20.770469,0),App.Vector(0,0,1),6.841867),False)
App.ActiveDocument.Sketch002.addExternal("Sketch001","Edge1")
App.ActiveDocument.Sketch002.addConstraint(Sketcher.Constraint('Coincident',0,3,-3,2))
#if tv:
#  tv.restore()
#del(tv)
App.activeDocument().Body.newObject("PartDesign::SubtractivePipe","SubtractivePipe")
App.activeDocument().SubtractivePipe.Profile = App.activeDocument().Sketch002
#Gui.activeDocument().hide("Sketch002")
# *** Add the missing line while the macro capture process *
FreeCAD.getDocument("Sans_nom").getObject("SubtractivePipe").Sections = [App.getDocument('Sans_nom').getObject('Sketch001')]
App.activeDocument().recompute()
#Gui.ActiveDocument.SubtractivePipe.ShapeColor=Gui.ActiveDocument.Body.ShapeColor
#Gui.ActiveDocument.SubtractivePipe.LineColor=Gui.ActiveDocument.Body.LineColor
#Gui.ActiveDocument.SubtractivePipe.PointColor=Gui.ActiveDocument.Body.PointColor
#Gui.ActiveDocument.SubtractivePipe.Transparency=Gui.ActiveDocument.Body.Transparency
#Gui.ActiveDocument.SubtractivePipe.DisplayMode=Gui.ActiveDocument.Body.DisplayMode
#Gui.activeDocument().setEdit('SubtractivePipe', 0)
# Macro End: C:\Users\deeja\AppData\Roaming\FreeCAD\Macro\Test_SubtractivePipe.FCMacro +++++++++++++++++++++++++++++++++++++++++++++++++
Test_SubtractivePipe_org.FCMacro (9,781 bytes)
import FreeCAD
import PartDesign
import Sketcher
#  tv.hide(objs)
#del(tv)
geoList = []
conList = []
#if tv:
#  tv.restore()
#del(tv)
#  tv.hide(objs)
#del(tv)
#if tv:
#  tv.restore()
#del(tv)
#  tv.hide(objs)
#del(tv)
#if tv:
#  tv.restore()
#del(tv)
#  tv.hide(objs)
#del(tv)
#if tv:
#  tv.restore()
#del(tv)
DeeJayOne
2019-09-21 09:28
reporter   ~0013670
Forum associated link (french)
DeeJayOne
2019-09-21 09:42
reporter   ~0013671
OS: Windows 10
Version: 0.18.16131 (Git)
Branch: releases/FreeCAD-0-18
Hash: 3129ae4296e40ed20e7b3d460b86e6969acbe1c3
Python version: 3.6.6
Qt version: 5.6.2
Locale: French/France (fr_FR)
2020-10-22 22:01
administrator   ~0014935
@DeeJayOne can you reproduce in latest 0.19
DeeJayOne
2020-11-03 18:56
reporter   ~0014962
@Kunda1
The problem seems always not solved with FC v0.19.22756.
Please see the attached file :
The "same" Macro File but recorded with FC v0.19.22756.
FC_v0.19-22756_Test_SubtractivePipe_org.FCMacro (12,968 bytes)
# Macro Begin: C:\Users\deeja\AppData\Roaming\FreeCAD\Macro\FC_v0.19-22756_Test_SubtractivePipe_org_v2.FCMacro +++++++++++++++++++++++++++++++++++++++++++++++++
import FreeCAD
import PartDesign
import Sketcher
# Gui.runCommand('Std_DlgMacroRecord',0)
### Begin command Std_New
App.newDocument("Unnamed")
# App.setActiveDocument("Unnamed")
# App.ActiveDocument=App.getDocument("Unnamed")
# Gui.ActiveDocument=Gui.getDocument("Unnamed")
# Gui.activeDocument().activeView().viewDefaultOrientation()
### End command Std_New
# Gui.runCommand('Std_OrthographicCamera',1)
### Begin command PartDesign_NewSketch
App.getDocument('Unnamed').addObject('PartDesign::Body','Body')
# Gui.ActiveDocument.ActiveView.setActiveObject('pdbody',App.getDocument('Unnamed').getObject('Body'))
### End command PartDesign_NewSketch
# Gui.Selection.addSelection('Unnamed','Body','Origin.XY_Plane.')
App.getDocument('Unnamed').getObject('Body').newObject('Sketcher::SketchObject','Sketch')
App.getDocument('Unnamed').getObject('Sketch').Support = (App.getDocument('Unnamed').getObject('XY_Plane'),[''])
App.getDocument('Unnamed').getObject('Sketch').MapMode = 'FlatFace'
Gui.getDocument('Unnamed').setEdit(App.getDocument('Unnamed').getObject('Body'),0,'Sketch.')
# import Show
# ActiveSketch = App.getDocument('Unnamed').getObject('Sketch')
# tv = Show.TempoVis(App.ActiveDocument, tag= ActiveSketch.ViewObject.TypeId)
# ActiveSketch.ViewObject.TempoVis = tv
# if ActiveSketch.ViewObject.EditingWorkbench:
#   tv.activateWorkbench(ActiveSketch.ViewObject.EditingWorkbench)
# if ActiveSketch.ViewObject.HideDependent:
#   tv.hide(tv.get_all_dependent(App.getDocument('Unnamed').getObject('Body'), 'Sketch.'))
# if ActiveSketch.ViewObject.ShowSupport:
# if ActiveSketch.ViewObject.ShowLinks:
# tv.hide(ActiveSketch)
# del(tv)
# if ActiveSketch.ViewObject.RestoreCamera:
# Gui.Selection.clearSelection()
# Gui.runCommand('Sketcher_CreateRectangle',0)
geoList = []
geoList.append(Part.LineSegment(App.Vector(-39.800282,39.728958,0),App.Vector(40.085590,39.728958,0)))
geoList.append(Part.LineSegment(App.Vector(40.085590,39.728958,0),App.Vector(40.085590,-39.871613,0)))
geoList.append(Part.LineSegment(App.Vector(40.085590,-39.871613,0),App.Vector(-39.800282,-39.871613,0)))
geoList.append(Part.LineSegment(App.Vector(-39.800282,-39.871613,0),App.Vector(-39.800282,39.728958,0)))
App.getDocument('Unnamed').getObject('Sketch').addGeometry(geoList,False)
conList = []
App.getDocument('Unnamed').getObject('Sketch').addConstraint(conList)
# Gui.getDocument('Unnamed').resetEdit()
# tv = ActiveSketch.ViewObject.TempoVis
# if tv:
#   tv.restore()
# ActiveSketch.ViewObject.TempoVis = None
# del(tv)
# Gui.Selection.addSelection('Unnamed','Body','Sketch.')
App.getDocument('Unnamed').recompute()
### Begin command PartDesign_Pad
App.getDocument('Unnamed').getObject('Body').newObject('PartDesign::Pad','Pad')
App.getDocument('Unnamed').getObject('Pad').Profile = App.getDocument('Unnamed').getObject('Sketch')
App.getDocument('Unnamed').getObject('Pad').Length = 10.0
App.getDocument('Unnamed').getObject('Sketch').Visibility = False
# App.getDocument('Unnamed').getObject('Pad').ViewObject.ShapeColor=getattr(App.getDocument('Unnamed').getObject('Body').getLinkedObject(True).ViewObject,'ShapeColor',App.getDocument('Unnamed').getObject('Pad').ViewObject.ShapeColor)
# App.getDocument('Unnamed').getObject('Pad').ViewObject.LineColor=getattr(App.getDocument('Unnamed').getObject('Body').getLinkedObject(True).ViewObject,'LineColor',App.getDocument('Unnamed').getObject('Pad').ViewObject.LineColor)
# App.getDocument('Unnamed').getObject('Pad').ViewObject.PointColor=getattr(App.getDocument('Unnamed').getObject('Body').getLinkedObject(True).ViewObject,'PointColor',App.getDocument('Unnamed').getObject('Pad').ViewObject.PointColor)
# App.getDocument('Unnamed').getObject('Pad').ViewObject.Transparency=getattr(App.getDocument('Unnamed').getObject('Body').getLinkedObject(True).ViewObject,'Transparency',App.getDocument('Unnamed').getObject('Pad').ViewObject.Transparency)
# App.getDocument('Unnamed').getObject('Pad').ViewObject.DisplayMode=getattr(App.getDocument('Unnamed').getObject('Body').getLinkedObject(True).ViewObject,'DisplayMode',App.getDocument('Unnamed').getObject('Pad').ViewObject.DisplayMode)
Gui.getDocument('Unnamed').setEdit(App.getDocument('Unnamed').getObject('Body'),0,'Pad.')
### End command PartDesign_Pad
App.getDocument('Unnamed').getObject('Pad').Length = 100.000000
App.getDocument('Unnamed').getObject('Pad').Length2 = 100.000000
App.getDocument('Unnamed').getObject('Pad').UseCustomVector = 0
App.getDocument('Unnamed').getObject('Pad').Direction = (1, 1, 1)
App.getDocument('Unnamed').getObject('Pad').Type = 0
App.getDocument('Unnamed').getObject('Pad').UpToFace = None
App.getDocument('Unnamed').getObject('Pad').Reversed = 0
App.getDocument('Unnamed').getObject('Pad').Midplane = 0
App.getDocument('Unnamed').getObject('Pad').Offset = 0
Gui.runCommand('PartDesign_NewSketch',0)
# Gui.Selection.addSelection('Unnamed','Body','Origin.XZ_Plane.')
App.getDocument('Unnamed').getObject('Body').newObject('Sketcher::SketchObject','Sketch001')
App.getDocument('Unnamed').getObject('Sketch001').Support = (App.getDocument('Unnamed').getObject('XZ_Plane'),[''])
App.getDocument('Unnamed').getObject('Sketch001').MapMode = 'FlatFace'
Gui.getDocument('Unnamed').setEdit(App.getDocument('Unnamed').getObject('Body'),0,'Sketch001.')
# ActiveSketch = App.getDocument('Unnamed').getObject('Sketch001')
#   tv.hide(tv.get_all_dependent(App.getDocument('Unnamed').getObject('Body'), 'Sketch001.'))
# del(tv)
# Gui.runCommand('Sketcher_CreateLine',0)
App.getDocument('Unnamed').getObject('Sketch001').addGeometry(Part.LineSegment(App.Vector(-60.340603,40.030975,0),App.Vector(60.405796,79.931305,0)),False)
# if tv:
#   tv.restore()
# del(tv)
# Gui.Selection.addSelection('Unnamed','Body','Sketch001.')
# Gui.Selection.addSelection('Unnamed','Body','Origin.YZ_Plane.')
App.getDocument('Unnamed').getObject('Body').newObject('Sketcher::SketchObject','Sketch002')
App.getDocument('Unnamed').getObject('Sketch002').Support = (App.getDocument('Unnamed').getObject('YZ_Plane'),[''])
App.getDocument('Unnamed').getObject('Sketch002').MapMode = 'FlatFace'
Gui.getDocument('Unnamed').setEdit(App.getDocument('Unnamed').getObject('Body'),0,'Sketch002.')
# ActiveSketch = App.getDocument('Unnamed').getObject('Sketch002')
#   tv.hide(tv.get_all_dependent(App.getDocument('Unnamed').getObject('Body'), 'Sketch002.'))
# del(tv)
# Gui.runCommand('Std_DrawStyle',2)
# Gui.runCommand('Sketcher_CompCreateCircle',0)
App.getDocument('Unnamed').getObject('Sketch002').addGeometry(Part.Circle(App.Vector(-0.106689,85.865601,0),App.Vector(0,0,1),16.255983),False)
App.getDocument('Unnamed').getObject('Sketch002').addConstraint(Sketcher.Constraint('PointOnObject',0,3,-2))
App.getDocument('Unnamed').getObject('Sketch002').movePoint(0,3,App.Vector(2.489417,60.531879,0),0)
# if tv:
#   tv.restore()
# del(tv)
# Gui.Selection.addSelection('Unnamed','Body','Sketch002.')
### Begin command PartDesign_SubtractivePipe
App.getDocument('Unnamed').getObject('Body').newObject('PartDesign::SubtractivePipe','SubtractivePipe')
App.getDocument('Unnamed').getObject('SubtractivePipe').Profile = App.getDocument('Unnamed').getObject('Sketch002')
App.getDocument('Unnamed').getObject('Sketch002').Visibility = False
# App.getDocument('Unnamed').getObject('SubtractivePipe').ViewObject.ShapeColor=getattr(App.getDocument('Unnamed').getObject('Pad').getLinkedObject(True).ViewObject,'ShapeColor',App.getDocument('Unnamed').getObject('SubtractivePipe').ViewObject.ShapeColor)
# App.getDocument('Unnamed').getObject('SubtractivePipe').ViewObject.LineColor=getattr(App.getDocument('Unnamed').getObject('Pad').getLinkedObject(True).ViewObject,'LineColor',App.getDocument('Unnamed').getObject('SubtractivePipe').ViewObject.LineColor)
# App.getDocument('Unnamed').getObject('SubtractivePipe').ViewObject.PointColor=getattr(App.getDocument('Unnamed').getObject('Pad').getLinkedObject(True).ViewObject,'PointColor',App.getDocument('Unnamed').getObject('SubtractivePipe').ViewObject.PointColor)
# App.getDocument('Unnamed').getObject('SubtractivePipe').ViewObject.Transparency=getattr(App.getDocument('Unnamed').getObject('Pad').getLinkedObject(True).ViewObject,'Transparency',App.getDocument('Unnamed').getObject('SubtractivePipe').ViewObject.Transparency)
# App.getDocument('Unnamed').getObject('SubtractivePipe').ViewObject.DisplayMode=getattr(App.getDocument('Unnamed').getObject('Pad').getLinkedObject(True).ViewObject,'DisplayMode',App.getDocument('Unnamed').getObject('SubtractivePipe').ViewObject.DisplayMode)
Gui.getDocument('Unnamed').setEdit(App.getDocument('Unnamed').getObject('Body'),0,'SubtractivePipe.')
### End command PartDesign_SubtractivePipe
# Gui.Selection.addSelection('Unnamed','Body','Sketch001.Edge1',-36.1056,-5.72674e-06,48.0394)
# Gui.getDocument('Unnamed').getObject('SubtractivePipe').Visibility = True
# Gui.runCommand('Std_DrawStyle',6)
### Begin command Std_ViewFitAll
# Gui.SendMsgToActiveView("ViewFit")
### End command Std_ViewFitAll
# Macro End: C:\Users\deeja\AppData\Roaming\FreeCAD\Macro\FC_v0.19-22756_Test_SubtractivePipe_org_v2.FCMacro +++++++++++++++++++++++++++++++++++++++++++++++++
2020-12-06 17:52
administrator   ~0015098
Open discussion forum thread: https://forum.freecad.org/viewtopic.php?f=8&t=52968
2021-02-20 18:28
administrator   ~0015393
https://github.com/wwmayer/FreeCAD/tree/bug4139
2021-03-29 09:00
administrator   ~0015572
Fix committed to master branch.
Related Changesets
FreeCAD: master 05f16342
2021-03-29 08:43:08
Details Diff
PD: [skip ci] fixes 0004139: Macro - SubtractivePipe attached path object issues after macro executed Affected Issues
0004139
mod - src/Mod/PartDesign/Gui/TaskPipeParameters.cpp Diff File
2019-09-20 18:33 DeeJayOne New Issue
2019-09-20 18:38 DeeJayOne File Added: Test_SubtractivePipe_modified.FCMacro
2019-09-20 18:38 DeeJayOne File Added: Test_SubtractivePipe_org.FCMacro
2019-09-20 18:38 DeeJayOne Note Added: 0013666
2019-09-21 09:23 DeeJayOne Summary Macro - SubtractivePipe attached path object issues after macro executed. => v0.18-16131 - Macro - SubtractivePipe attached path object issues after macro executed.
2019-09-21 09:28 DeeJayOne Note Added: 0013670
2019-09-21 09:35 DeeJayOne Description Updated
2019-09-21 09:35 DeeJayOne Additional Information Updated
2019-09-21 09:38 DeeJayOne Additional Information Updated
2019-09-21 09:42 DeeJayOne Note Added: 0013671
2020-10-22 22:01 Kunda1 Status new => feedback
2020-10-22 22:01 Kunda1 Note Added: 0014935
2020-10-23 03:05 Kunda1 Tag Attached: #pending
2020-11-03 18:56 DeeJayOne Note Added: 0014962
2020-11-03 18:56 DeeJayOne File Added: FC_v0.19-22756_Test_SubtractivePipe_org.FCMacro
2020-11-03 18:56 DeeJayOne Status feedback => new
2020-12-06 17:52 Kunda1 Note Added: 0015098
2021-02-06 06:43 abdullah Target Version => 0.20
2021-02-20 18:28 wmayer Note Added: 0015393
2021-03-29 09:00 wmayer Changeset attached => FreeCAD master 05f16342
2021-03-29 09:00 wmayer Note Added: 0015572
2021-03-29 09:00 wmayer Assigned To => wmayer
2021-03-29 09:00 wmayer Status new => closed
2021-03-29 09:00 wmayer Resolution open => fixed
