| 0004141 | Arch | Bug | public | 2019-09-22 17:31 | 2019-12-09 14:45 |
| Reporter | Roy_043 | Assigned To | paullee | ||
| Summary | 0004141: Multi-solid walls are not correctly exported to IFC | ||||
| Description | Sketch-based walls can be made up of multiple solids. When exporting such a wall to IFC only one of the solids is exported. Examples of sketches that produce multi-solid walls: 1. Sketches with disconnected loops. 2. Sketches with T-junctions. | ||||
| Additional Information | Forum threads: https://forum.freecadweb.org/viewtopic.php?f=39&t=39423 https://forum.freecadweb.org/viewtopic.php?f=39&t=31235 | ||||
FreeCAD info: OS: Windows 8.1 (6.3) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.18234 (Git) Build type: Release Branch: master Hash: 3af5d97e9b2a60823815f662aba25422c4bc45bb Python version: 3.6.8 Qt version: 5.12.1 Coin version: 4.0.0a OCC version: 7.3.0 Locale: Dutch/Netherlands (nl_NL) |
Test file in Arch Wall - Based on Sketch Issues... |
Latest discussion for reference - Arch Wall - Based on Sketch Issues |
Pull Request at - [Arch] - To allow exportIFC.py to work properly on sketch, which use only 1st face / wire |
I confirm that this issue has been fixed. FreeCAD info: OS: Windows 8.1 (6.3) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.18811 (Git) Build type: Release Branch: master Hash: b809867021deb37be1039dab37b9fe1cafab254e Python version: 3.6.7 Qt version: 5.12.1 Coin version: 4.0.0a OCC version: 7.3.0 Locale: Dutch/Netherlands (nl_NL) |
@paullee Thanks for the fix. FYI, next time to auto-reference or auto-close this ticket you can use the MantisBT keywords in your PR. Please read https://www.freecadweb.org/wiki/Tracker#GitHub_and_MantisBT Can we close this ticket then? If so, please do the honors ;) |
| 2019-09-22 17:31 | Roy_043 | New Issue | |
| 2019-09-22 17:31 | Roy_043 | File Added: BrepTest.FCStd | |
| 2019-09-22 17:39 | Roy_043 | Note Added: 0013674 | |
| 2019-09-23 17:44 | paullee | File Added: Test_ ArchWall_ To_ IFC_ 3c_ Pure Sketch.fcstd | |
| 2019-09-23 17:44 | paullee | Note Added: 0013676 | |
| 2019-09-23 17:45 | paullee | Note Edited: 0013676 | |
| 2019-10-22 18:26 | paullee | Note Added: 0013783 | |
| 2019-10-27 04:27 | paullee | Note Added: 0013790 | |
| 2019-10-27 04:27 | paullee | Note Edited: 0013790 | |
| 2019-10-27 10:24 | Kunda1 | Assigned To | => paullee |
| 2019-10-27 10:24 | Kunda1 | Status | new => assigned |
| 2019-10-27 10:24 | Kunda1 | Target Version | => 0.19 |
| 2019-12-09 10:07 | Roy_043 | Note Added: 0013881 | |
| 2019-12-09 13:56 | Kunda1 | Note Added: 0013882 | |
| 2019-12-09 13:56 | Kunda1 | Note Edited: 0013882 | |
| 2019-12-09 14:45 | paullee | Status | assigned => closed |
| 2019-12-09 14:45 | paullee | Resolution | open => fixed |
| 2019-12-09 14:45 | paullee | Fixed in Version | => 0.19 |
