| 0004146 | Draft | Bug | public | 2019-09-26 04:19 | 2020-01-07 16:55 |
| Reporter | mikeshemp | Assigned To | yorik | ||
| Summary | 0004146: Draft->SelectPlane fails when selecting shape face | ||||
| Description | Today I tried to construct a pyramid, then change one of its faces to be the working plane so I could place text on it. Instead I received the following error: File "C:\...\FreeCAD_0.19.18293_x64_LP_12.1.2_PY3QT5-WinVS2015\Mod\Draft\DraftSelectPlane.py", line 242, in handle FreeCAD.DraftWorkingPlane.alignToFace(sel.SubObjects[0], self.taskd.form.fieldOffset.Value) 'PySide2.QtWidgets.QLineEdit' object has no attribute 'Value' | ||||
| Steps To Reproduce | I was able to reproduce this two ways. The easiest is 1. Part -> Create Geometric Primitive 2. Select Wedge, hit Ok (all default parameters are fine) 3. Go to Draft Workbench 4. Select a face of the wedge 5. Click the Select Working Plane button I was also able to repro the same error by creating a pyramid by sketching two squares and lofting the space between them. Am I using it wrong or is this a bug in FreeCAD? I'm using the latest daily build as of 9/25/2019. | ||||
| Additional Information | OS: Windows 10 (10.0) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.18293 (Git) Build type: Release Branch: master Hash: 644fb4739df4d5ff25fbae8aa4db50331c60fe63 Python version: 3.6.8 Qt version: 5.12.1 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/United States (en_US) | ||||
Note, as instructed, I tried to post to the forum before filing a bug. However, trying to post resulted in "You cannot make another post so soon after your last." even though it was my first post. |
Which post ? |
https://forum.freecadweb.org/viewtopic.php?f=23&t=39635 |
Per the thread it seems that FreeCAD Pull Request 2554 is a temp fix for this issue |
FreeCAD master e325f2e5 |
Associated fix with ticket. Closing ticket |
FreeCAD: master e325f2e5 2019-09-24 18:49:33 Committer: yorik Details Diff |
fixes issue aligning workplane to a face this is a quick workaround for a problem introduced in the Draft select plane procedure while refactoring the code. not sure it is the best fix though. |
Affected Issues 0004146 |
| mod - src/Mod/Draft/DraftSelectPlane.py | Diff File | ||
| 2019-09-26 04:19 | mikeshemp | New Issue | |
| 2019-09-26 04:20 | mikeshemp | Note Added: 0013686 | |
| 2019-09-26 17:06 | Kunda1 | Note Added: 0013688 | |
| 2019-09-26 17:07 | Kunda1 | Tag Attached: #post-to-forum | |
| 2019-09-26 19:19 | mikeshemp | Note Added: 0013689 | |
| 2019-10-02 01:43 | Kunda1 | Tag Detached: #post-to-forum | |
| 2019-10-02 01:45 | Kunda1 | Note Added: 0013703 | |
| 2019-10-02 01:46 | Kunda1 | Tag Attached: #tobeclosed | |
| 2019-10-02 01:46 | Kunda1 | Status | new => confirmed |
| 2019-10-02 05:51 | Kunda1 | Assigned To | => yorik |
| 2019-10-02 05:51 | Kunda1 | Status | confirmed => assigned |
| 2019-10-02 05:52 | Kunda1 | Target Version | => 0.19 |
| 2019-10-02 05:52 | Kunda1 | Steps to Reproduce Updated | |
| 2019-10-02 05:52 | Kunda1 | Additional Information Updated | |
| 2020-01-07 16:50 | Kunda1 | Note Added: 0014009 | |
| 2020-01-07 16:51 | Kunda1 | Note Edited: 0014009 | |
| 2020-01-07 16:53 | Kunda1 | Note Edited: 0014009 | |
| 2020-01-07 16:54 | Kunda1 | Changeset attached | => FreeCAD master e325f2e5 |
| 2020-01-07 16:54 | Kunda1 | Tag Detached: #tobeclosed | |
| 2020-01-07 16:55 | Kunda1 | Status | assigned => closed |
| 2020-01-07 16:55 | Kunda1 | Resolution | open => fixed |
| 2020-01-07 16:55 | Kunda1 | Fixed in Version | => 0.19 |
| 2020-01-07 16:55 | Kunda1 | Note Added: 0014010 |
