| 0004148 | FreeCAD | Bug | public | 2019-09-27 02:28 | 2020-06-05 17:23 |
| Reporter | TC2019 | Assigned To | wmayer | ||
| Priority | low | Severity | text | Reproducibility | always |
| Summary | 0004148: Status bar displays mm unit only regardless of user setting in Preferences | ||||
| Description | The Status bar always displays values in mm even though the Unit in Preferences is set to inches. Having different units makes modeling harder by repeatedly doing unit conversions. Please note that this issue was posted in the forum at the link below and it was suggested to report it in this tracker: https://forum.freecadweb.org/viewtopic.php?f=3&t=39654#p336930 | ||||
| Steps To Reproduce | This issue is reproducible: 1). Edit --> Preferences --> Units --> User system -->Imperial decimal (in/lb) 2). Go to working space and move cursor over an object, the coordinates are in mm in Status bar instead of inches | ||||
| Additional Information | OS: Windows 10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.16117 (Git) Build type: Release Branch: releases/FreeCAD-0-18 Hash: dbb4cc6415bac848a294f03b80f65e888d531742 Python version: 3.6.6 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/Canada (en_CA) | ||||
| Tags | units | ||||
CC @uwestoehr Hi, is this an issue you're aware of? |
> Hi, is this an issue you're aware of? I think this is already fixed for FC 0.19: https://forum.freecadweb.org/viewtopic.php?f=3&t=39654&p=359703#p359703 Werner recently fixed some unit issues and obviously also this one. |
nad was backported to 0.18.4 |
Sorry, I was wrong. This is not fixed for the coordinated of the mouse position. I see there 2 issues: - the numbers have no displayed unit - the unit is in every case mm |
PR submitted |
The patch has been submitted. I can confirm the issue is fixed. Many thanks. |
FreeCAD: master b0084cd4 2020-04-14 21:23:34 0penBrain Committer: wmayer Details Diff |
[FC] Status bar preselection coordinates are aware of user unit setting ; fixes 0004148 |
Affected Issues 0004148 |
| mod - src/Gui/Selection.cpp | Diff File | ||
| mod - src/Gui/SoFCSelection.cpp | Diff File | ||
| mod - src/Gui/SoFCUnifiedSelection.cpp | Diff File | ||
| 2019-09-27 02:28 | TC2019 | New Issue | |
| 2019-09-27 02:28 | TC2019 | Tag Attached: units | |
| 2019-09-29 13:34 | openBrain | Priority | high => low |
| 2019-09-29 13:34 | openBrain | Severity | major => text |
| 2019-09-29 13:34 | openBrain | Status | new => acknowledged |
| 2020-01-11 13:10 | Kunda1 | Status | acknowledged => confirmed |
| 2020-01-11 13:10 | Kunda1 | Target Version | => 0.19 |
| 2020-01-11 13:11 | Kunda1 | Note Added: 0014052 | |
| 2020-01-11 14:11 | uwestoehr | Note Added: 0014053 | |
| 2020-01-11 17:33 | Kunda1 | Note Added: 0014058 | |
| 2020-01-11 17:33 | Kunda1 | Status | confirmed => closed |
| 2020-01-11 17:33 | Kunda1 | Resolution | open => fixed |
| 2020-01-11 17:33 | Kunda1 | Fixed in Version | => 0.19 |
| 2020-01-11 19:55 | uwestoehr | Assigned To | => uwestoehr |
| 2020-01-11 19:55 | uwestoehr | Status | closed => feedback |
| 2020-01-11 19:55 | uwestoehr | Resolution | fixed => reopened |
| 2020-01-11 19:55 | uwestoehr | Note Added: 0014060 | |
| 2020-01-11 23:08 | Kunda1 | Status | feedback => confirmed |
| 2020-01-11 23:08 | Kunda1 | Fixed in Version | 0.19 => |
| 2020-04-14 21:22 | openBrain | Assigned To | uwestoehr => openBrain |
| 2020-04-14 21:25 | openBrain | Note Added: 0014355 | |
| 2020-04-14 21:52 | openBrain | Status | confirmed => assigned |
| 2020-05-31 01:36 | uwestoehr | Note Added: 0014448 | |
| 2020-06-03 19:30 | openBrain | Status | assigned => closed |
| 2020-06-03 19:30 | openBrain | Resolution | reopened => fixed |
| 2020-06-05 17:23 | wmayer | Changeset attached | => FreeCAD master b0084cd4 |
| 2020-06-05 17:23 | wmayer | Note Added: 0014476 | |
| 2020-06-05 17:23 | wmayer | Assigned To | openBrain => wmayer |
