| 0004157 | Arch | Bug | public | 2019-10-09 11:17 | 2020-01-06 16:22 |
| Reporter | nikitron | Assigned To | berndhahnebach | ||
| Platform | 64 bit | OS | Windows | OS Version | 7 |
| Summary | 0004157: import ifc | ||||
| Description | C:\Program Files\FreeCAD 0.18\Mod\Arch\importIFC.py lines after 900 ptype = e.NominalValue.is_a() there is no .is_a() in e.NominalValue | ||||
| Steps To Reproduce | import ifc | ||||
| Tags | IFC, import | ||||
Угловая стойка к.А.ifc (1,491,196 bytes)
ISO-10303-21;
HEADER;
FILE_DESCRIPTION(('ViewDefinition[CoordinationView_V2.0, QuantityTakeOffAddOnView]'),'2;1');
FILE_NAME('191008_A Block Corner.ifc','2019-10-08T14:22:24',('MYEO13016\\aysin'),('Structural Designer'),'IFC Database Version:Work','Tekla structures 20.1 Service Release 7, IFC Export Version: 4.0.0.0 Jun 3 2016','');
FILE_SCHEMA(('IFC2X3'));
ENDSEC;
DATA;
#1= IFCPERSON('MYEO13016\\aysin','Undefined',$,$,$,$,$,$);
#2= IFCORGANIZATION($,'Tekla Corporation',$,$,$);
#3= IFCPERSONANDORGANIZATION(#1,#2,$);
#4= IFCAPPLICATION(#2,'20.1 Service Release 7','Tekla Structures','Multi material modeling');
#5= IFCOWNERHISTORY(#3,#4,$,.NOCHANGE.,$,$,$,1570533734);
#6= IFCCARTESIANPOINT((0.,0.,0.));
#7= IFCDIRECTION((1.,0.,0.));
#8= IFCDIRECTION((0.,1.,0.));
#9= IFCDIRECTION((0.,0.,1.));
#10= IFCAXIS2PLACEMENT3D(#6,#9,#7);
#11= IFCGEOMETRICREPRESENTATIONCONTEXT($,'Model',3,1.E-005,#10,$);
#12= IFCGEOMETRICREPRESENTATIONSUBCONTEXT('Body','Model',*,*,*,*,#11,$,.MODEL_VIEW.,$);
#13= IFCGEOMETRICREPRESENTATIONSUBCONTEXT('Axis','Model',*,*,*,*,#11,$,.GRAPH_VIEW.,$);
#14= IFCGEOMETRICREPRESENTATIONSUBCONTEXT('FootPrint','Model',*,*,*,*,#11,$,.MODEL_VIEW.,$);
#15= IFCSIUNIT(*,.LENGTHUNIT.,.MILLI.,.METRE.);
#16= IFCSIUNIT(*,.AREAUNIT.,$,.SQUARE_METRE.);
#17= IFCSIUNIT(*,.VOLUMEUNIT.,$,.CUBIC_METRE.);
#18= IFCSIUNIT(*,.MASSUNIT.,.KILO.,.GRAM.);
#19= IFCSIUNIT(*,.TIMEUNIT.,$,.SECOND.);
#20= IFCSIUNIT(*,.PLANEANGLEUNIT.,$,.RADIAN.);
#21= IFCSIUNIT(*,.SOLIDANGLEUNIT.,$,.STERADIAN.);
#22= IFCSIUNIT(*,.THERMODYNAMICTEMPERATUREUNIT.,$,.DEGREE_CELSIUS.);
#23= IFCSIUNIT(*,.LUMINOUSINTENSITYUNIT.,$,.LUMEN.);
#24= IFCUNITASSIGNMENT((#15,#16,#17,#18,#19,#20,#21,#22,#23));
#25= IFCPROJECT('3exxz1aI50bBlNCTYwCTF4',#5,$,$,$,$,$,(#11),#24);
#26= IFCLOCALPLACEMENT($,#10);
#27= IFCSITE('2PDkYboo94UguCwX__65sS',#5,'EMRE',$,$,#26,$,$,.ELEMENT.,$,$,0.,$,$);
#28= IFCLOCALPLACEMENT(#26,#10);
#29= IFCBUILDING('0fouRG4W1C79e4wXvqemxy',#5,'EMRE',$,$,#28,$,$,.ELEMENT.,$,$,$);
#30= IFCLOCALPLACEMENT(#28,#10);
#31= IFCBUILDINGSTOREY('1SKg$lZOL9teXg_hi17lc2',#5,'EMRE',$,$,#30,$,$,.ELEMENT.,0.);
#32= IFCLOCALPLACEMENT(#30,#10);
#33= IFCELEMENTASSEMBLY('1Td1iR0042X34rDp0rCJ8t',#5,'Steel Assembly',$,$,#32,$,'ANK/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#34= IFCPROPERTYSINGLEVALUE('Cast unit vertical position code',$,$,$);
#35= IFCPROPERTYSINGLEVALUE('Cast unit rebar weight',$,$,$);
#36= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(0.682906084320755),$);
#37= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' +19.900'),$);
#38= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +19.916'),$);
#39= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit name',$,IFCLABEL('ANKRAJ'),$);
#40= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit position code',$,IFCLABEL('6/N2'),$);
#41= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('ANK/0(?)'),$);
#42= IFCPROPERTYSET('0gZ7kufeH6VxfgwZPtYzD4',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#36,#37,#38,#39,#40,#41));
#43= IFCQUANTITYLENGTH('Width',$,$,16.0000000001164);
#44= IFCELEMENTQUANTITY('0B$s9beK92VveE7ek5X60e',#5,'BaseQuantities',$,$,(#43));
#45= IFCCARTESIANPOINT((48609.383465468,-324.78646140571,19908.0051533431));
#46= IFCDIRECTION((-1.82500090932436E-006,1.82508428078605E-006,-0.999999999996669));
#47= IFCDIRECTION((0.707090629999721,-0.70712293199976,-2.58099999050893E-006));
#48= IFCAXIS2PLACEMENT3D(#45,#46,#47);
#49= IFCLOCALPLACEMENT(#32,#48);
#50= IFCCOLOURRGB('Light Gray',0.6,0.6,0.6);
#51= IFCSURFACESTYLERENDERING(#50,0.,$,$,$,$,IFCNORMALISEDRATIOMEASURE(0.00390625),IFCSPECULAREXPONENT(10.),.NOTDEFINED.);
#52= IFCSURFACESTYLE('STEEL/S235JR',.POSITIVE.,(#51));
#53= IFCPRESENTATIONSTYLEASSIGNMENT((#52));
#54= IFCCARTESIANPOINT((-1.58615875989199E-009,-2.91038304567337E-011));
#55= IFCCARTESIANPOINT((49.9988632188397,-1.81922203322641E-012));
#56= IFCCARTESIANPOINT((79.9995407566345,29.9999999923636));
#57= IFCCARTESIANPOINT((80.0005569440909,74.9947204590935));
#58= IFCCARTESIANPOINT((15.0017130138507,74.9979438673567));
#59= IFCCARTESIANPOINT((0.00137041952489783,59.9986877479443));
#60= IFCPOLYLINE((#54,#55,#56,#57,#58,#59,#54));
#61= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL16*75',#60);
#62= IFCCARTESIANPOINT((-7.27595761418343E-012,-1.96387076429166E-030,-8.));
#63= IFCAXIS2PLACEMENT3D(#62,#9,#7);
#64= IFCEXTRUDEDAREASOLID(#61,#63,#9,16.);
#65= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#64));
#66= IFCSTYLEDITEM(#64,(#53),$);
#67= IFCPRODUCTDEFINITIONSHAPE($,$,(#65));
#68= IFCPLATE('1Td1iR0042Wp4rDp0rCJ8t',#5,'ANKRAJ','PL16*75','PL16*75',#49,#67,'P/227(?)');
#69= IFCPLATETYPE('2YMhoEcmP48RxufXvHfN29',#5,'PL16*75',$,$,$,$,$,$,.NOTDEFINED.);
#70= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +19.900'),$);
#71= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +19.916'),$);
#72= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/227(?)'),$);
#73= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('ANK/0(?)'),$);
#74= IFCPROPERTYSINGLEVALUE('Preliminary mark',$,IFCLABEL(''),$);
#75= IFCPROPERTYSINGLEVALUE('Control number',$,$,$);
#76= IFCPROPERTYSINGLEVALUE('Phase',$,IFCINTEGER(3),$);
#77= IFCPROPERTYSINGLEVALUE('Class',$,IFCLABEL('99'),$);
#78= IFCPROPERTYSINGLEVALUE('Grade',$,IFCLABEL('S235JR'),$);
#79= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PL16*75'),$);
#80= IFCPROPERTYSINGLEVALUE('Name',$,IFCLABEL('ANKRAJ'),$);
#81= IFCPROPERTYSET('2IQXXGlUj8swKNfluWpEU9',#5,'Tekla Common','Common Properties to Shared building elements',(#70,#71,#72,#73,#74,#75,#76,#77,#78,#79,#80));
#82= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(0.682906084320755),$);
#83= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.682906084320755),$);
#84= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(0.753584586271265),$);
#85= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.682906084320755),$);
#86= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(8.6994405645956E-005),$);
#87= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(8.6994405645956E-005),$);
#88= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(8.6994405645956E-005),$);
#89= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00543715035288648),$);
#90= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(22.5688360342344),$);
#91= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0154123954438162),$);
#92= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.00599987727922981),$);
#93= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(74.997943867842),$);
#94= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(16.0000000005457),$);
#95= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(80.0005569459681),$);
#96= IFCPROPERTYSET('3Yw0KDEL9CkhDrwIti0$kY',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#82,#83,#84,#85,#86,#87,#88,#89,#90,#91,#92,#93,#94,#95));
#97= IFCQUANTITYLENGTH('Width',$,$,74.997943867842);
#98= IFCQUANTITYAREA('NetArea',$,$,0.0154123954438162);
#99= IFCQUANTITYAREA('GrossArea',$,$,0.00599987727922981);
#100= IFCQUANTITYAREA('CrossSectionArea',$,$,0.000256);
#101= IFCQUANTITYVOLUME('NetVolume',$,$,8.6994405645956E-005);
#102= IFCQUANTITYVOLUME('GrossVolume',$,$,8.6994405645956E-005);
#103= IFCELEMENTQUANTITY('0xn77QlbPDuOvqWhg67GOM',#5,'BaseQuantities',$,$,(#97,#98,#99,#100,#101,#102));
#104= IFCMATERIAL('STEEL/S235JR');
#105= IFCLOCALPLACEMENT(#30,#10);
#106= IFCELEMENTASSEMBLY('1Td1iR0042Up4rDp0rCJ8s',#5,'Steel Assembly',$,$,#105,$,'ANK/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#107= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(0.682906084320763),$);
#108= IFCPROPERTYSET('3SAwyS1Hv6nh6lSu74gtWE',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#107,#37,#38,#39,#40,#41));
#109= IFCQUANTITYLENGTH('Width',$,$,16.0000000002583);
#110= IFCELEMENTQUANTITY('1Y1pL_g514tPZxCRUAG7Is',#5,'BaseQuantities',$,$,(#109));
#111= IFCCARTESIANPOINT((48475.0344614056,-459.13546546815,19908.0051533431));
#112= IFCDIRECTION((1.82508428078358E-006,-1.82500090932188E-006,0.999999999996669));
#113= IFCDIRECTION((0.70712293199972,-0.70709062999976,-2.58099999050542E-006));
#114= IFCAXIS2PLACEMENT3D(#111,#112,#113);
#115= IFCLOCALPLACEMENT(#105,#114);
#116= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#64));
#117= IFCPRODUCTDEFINITIONSHAPE($,$,(#116));
#118= IFCPLATE('1Td1iR0042UZ4rDp0rCJ8s',#5,'ANKRAJ','PL16*75','PL16*75',#115,#117,'P/227(?)');
#119= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(0.682906084320763),$);
#120= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.682906084320763),$);
#121= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.682906084320763),$);
#122= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(8.69944056459571E-005),$);
#123= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(8.69944056459571E-005),$);
#124= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(8.69944056459571E-005),$);
#125= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00543715035288683),$);
#126= IFCPROPERTYSET('0PWmh03Xz5qRXyjNIRRhIi',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#119,#120,#84,#121,#122,#123,#124,#125,#90,#91,#92,#93,#94,#95));
#127= IFCQUANTITYLENGTH('Width',$,$,74.9979438675437);
#128= IFCQUANTITYAREA('NetArea',$,$,0.0154123954438134);
#129= IFCQUANTITYAREA('GrossArea',$,$,0.00599987727913283);
#130= IFCQUANTITYVOLUME('NetVolume',$,$,8.6994405645957E-005);
#131= IFCQUANTITYVOLUME('GrossVolume',$,$,8.6994405645957E-005);
#132= IFCELEMENTQUANTITY('1ix4VN3jzCt9bR8xM$__u8',#5,'BaseQuantities',$,$,(#127,#128,#129,#100,#130,#131));
#133= IFCLOCALPLACEMENT(#30,#10);
#134= IFCELEMENTASSEMBLY('1Td1iR002jT34rDp0rCJ4s',#5,'Steel Assembly',$,$,#133,$,'B/115(?)',.NOTDEFINED.,.RIGID_FRAME.);
#135= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(129.952253075917),$);
#136= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +20.200'),$);
#137= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit name',$,IFCLABEL('BEAM'),$);
#138= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit position code',$,IFCLABEL('6/6-M1'),$);
#139= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('B/115(?)'),$);
#140= IFCPROPERTYSET('2s0K2zQYfCDPnb7R1kioJi',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#135,#37,#136,#137,#138,#139));
#141= IFCQUANTITYLENGTH('Width',$,$,299.998914436004);
#142= IFCELEMENTQUANTITY('1JoCS4XsbBsRZvwLxGWXLa',#5,'BaseQuantities',$,$,(#141));
#143= IFCCARTESIANPOINT((48458.0635916647,-442.164595729179,19900.0049210083));
#144= IFCDIRECTION((-0.707106781198356,0.707106781171736,-2.0605091543262E-006));
#145= IFCDIRECTION((5.00300000800501E-006,7.91699999956863E-006,0.999999999956146));
#146= IFCAXIS2PLACEMENT3D(#143,#144,#145);
#147= IFCLOCALPLACEMENT(#133,#146);
#148= IFCCARTESIANPOINT((200.00393677313,7.27595761418343E-011));
#149= IFCCARTESIANPOINT((200.005645757348,189.994720457995));
#150= IFCCARTESIANPOINT((0.0017358830991725,189.998687743151));
#151= IFCPOLYLINE((#54,#148,#149,#150,#54,#54,#54));
#152= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL16*190',#151);
#153= IFCEXTRUDEDAREASOLID(#152,#63,#9,16.);
#154= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#153));
#155= IFCSTYLEDITEM(#153,(#53),$);
#156= IFCPRODUCTDEFINITIONSHAPE($,$,(#154));
#157= IFCDISCRETEACCESSORY('1Td1iR0042Jp4rDp0rCJ8q',#5,'ANKRAJ','PL16*190','PL16*190',#147,#156,'P/227(?)');
#158= IFCDISCRETEACCESSORYTYPE('3fr5TJuwTDuxzZCJYuCqUd',#5,'ANKRAJ',$,$,$,$,$,$);
#159= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +20.100'),$);
#160= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('B/115(?)'),$);
#161= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PL16*190'),$);
#162= IFCPROPERTYSET('0GCmhMPr58IfTNOJJOmkFO',#5,'Tekla Common','Common Properties to Shared building elements',(#70,#159,#72,#160,#74,#75,#76,#77,#78,#161,#80));
#163= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(129.952253075917),$);
#164= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(4.772810831963),$);
#165= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(4.77290176543385),$);
#166= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(4.772810831963),$);
#167= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000608001379867898),$);
#168= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000608001379867898),$);
#169= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000608001379867898),$);
#170= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00303991552746489),$);
#171= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(18.5383824494531),$);
#172= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0884801925618224),$);
#173= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.038000810234346),$);
#174= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(189.998687744082),$);
#175= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(16.0000000006403),$);
#176= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(200.005645752306),$);
#177= IFCPROPERTYSET('24APUBdtbCAQP5FP45kWKi',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#163,#164,#165,#166,#167,#168,#169,#170,#171,#172,#173,#174,#175,#176));
#178= IFCQUANTITYLENGTH('Width',$,$,189.998687744082);
#179= IFCQUANTITYAREA('NetArea',$,$,0.0884801925618224);
#180= IFCQUANTITYAREA('GrossArea',$,$,0.038000810234346);
#181= IFCQUANTITYVOLUME('NetVolume',$,$,0.000608001379867898);
#182= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000608001379867898);
#183= IFCELEMENTQUANTITY('3UtykH049AieYi3k744tUt',#5,'BaseQuantities',$,$,(#178,#179,#180,#100,#181,#182));
#184= IFCCARTESIANPOINT((47524.9993581264,-554.150281216347,15839.995));
#185= IFCDIRECTION((-0.999999999999993,-1.21000000165492E-007,0.));
#186= IFCAXIS2PLACEMENT3D(#184,#8,#185);
#187= IFCLOCALPLACEMENT(#30,#186);
#188= IFCCOLOURRGB($,0.6,0.3,0.);
#189= IFCSURFACESTYLERENDERING(#188,0.,$,$,$,$,IFCNORMALISEDRATIOMEASURE(0.00390625),IFCSPECULAREXPONENT(10.),.NOTDEFINED.);
#190= IFCSURFACESTYLE('8.8',.POSITIVE.,(#189));
#191= IFCPRESENTATIONSTYLEASSIGNMENT((#190));
#192= IFCCOLOURRGB($,0.,0.,0.);
#193= IFCSURFACESTYLERENDERING(#192,0.,$,$,$,$,IFCNORMALISEDRATIOMEASURE(0.00390625),IFCSPECULAREXPONENT(10.),.NOTDEFINED.);
#194= IFCSURFACESTYLE($,.POSITIVE.,(#193));
#195= IFCPRESENTATIONSTYLEASSIGNMENT((#194));
#196= IFCDIRECTION((1.,0.));
#197= IFCAXIS2PLACEMENT2D(#54,#196);
#198= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#199= IFCCARTESIANPOINT((0.,-34.0949999999997,0.));
#200= IFCAXIS2PLACEMENT3D(#199,#8,#7);
#201= IFCEXTRUDEDAREASOLID(#198,#200,#9,16.1000000000001);
#202= IFCSTYLEDITEM(#201,(#195),$);
#203= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#204= IFCCARTESIANPOINT((0.,-49.9950000000006,0.));
#205= IFCAXIS2PLACEMENT3D(#204,#8,#7);
#206= IFCEXTRUDEDAREASOLID(#203,#205,#9,15.9999999999998);
#207= IFCSTYLEDITEM(#206,(#195),$);
#208= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#209= IFCCARTESIANPOINT((0.,-123.895000000021,0.));
#210= IFCAXIS2PLACEMENT3D(#209,#8,#7);
#211= IFCEXTRUDEDAREASOLID(#208,#210,#9,74.);
#212= IFCSTYLEDITEM(#211,(#195),$);
#213= IFCCARTESIANPOINT((22.51666049841,0.));
#214= IFCCARTESIANPOINT((11.258330249205,19.5000000000028));
#215= IFCCARTESIANPOINT((-11.258330249205,19.5000000000028));
#216= IFCCARTESIANPOINT((-22.51666049841,0.));
#217= IFCCARTESIANPOINT((-11.258330249205,-19.5000000000028));
#218= IFCCARTESIANPOINT((11.258330249205,-19.5000000000028));
#219= IFCPOLYLINE((#213,#214,#215,#216,#217,#218,#213));
#220= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#219);
#221= IFCCARTESIANPOINT((0.,-137.995000000021,0.));
#222= IFCAXIS2PLACEMENT3D(#221,#8,#7);
#223= IFCEXTRUDEDAREASOLID(#220,#222,#9,14.);
#224= IFCSTYLEDITEM(#223,(#191),$);
#225= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#226= IFCCARTESIANPOINT((0.,-123.995000000021,0.));
#227= IFCAXIS2PLACEMENT3D(#226,#8,#7);
#228= IFCEXTRUDEDAREASOLID(#225,#227,#9,100.);
#229= IFCSTYLEDITEM(#228,(#191),$);
#230= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,22.);
#231= IFCCARTESIANPOINT((0.,-17.9949999999996,0.));
#232= IFCAXIS2PLACEMENT3D(#231,#8,#7);
#233= IFCEXTRUDEDAREASOLID(#230,#232,#9,4.);
#234= IFCSTYLEDITEM(#233,(#191),$);
#235= IFCCARTESIANPOINT((20.78460969084,0.));
#236= IFCCARTESIANPOINT((10.39230484542,18.0000000000025));
#237= IFCCARTESIANPOINT((-10.39230484542,18.0000000000025));
#238= IFCCARTESIANPOINT((-20.78460969084,0.));
#239= IFCCARTESIANPOINT((-10.39230484542,-18.0000000000025));
#240= IFCCARTESIANPOINT((10.39230484542,-18.0000000000025));
#241= IFCPOLYLINE((#235,#236,#237,#238,#239,#240,#235));
#242= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#241);
#243= IFCCARTESIANPOINT((0.,-13.9949999999996,0.));
#244= IFCAXIS2PLACEMENT3D(#243,#8,#7);
#245= IFCEXTRUDEDAREASOLID(#242,#244,#9,19.);
#246= IFCSTYLEDITEM(#245,(#191),$);
#247= IFCCARTESIANTRANSFORMATIONOPERATOR3D($,$,#6,$,$);
#248= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#201,#206,#211,#223,#228,#233,#245));
#249= IFCREPRESENTATIONMAP(#10,#248);
#250= IFCMAPPEDITEM(#249,#247);
#251= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#250));
#252= IFCPRODUCTDEFINITIONSHAPE($,$,(#251));
#253= IFCMECHANICALFASTENER('1Td1iR003HKZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#187,#252,'ID5d9c1b1b-0000-d152-3135-373035313136',24.,100.);
#254= IFCMECHANICALFASTENERTYPE('1aJJUPxpTFkBW7RMjjYOw5',#5,'Bolt assembly',$,$,$,$,$,$);
#255= IFCPROPERTYSINGLEVALUE('Washer count',$,$,$);
#256= IFCPROPERTYSINGLEVALUE('Washer diameter',$,IFCLENGTHMEASURE(24.),$);
#257= IFCPROPERTYSINGLEVALUE('Washer type',$,IFCLABEL('126'),$);
#258= IFCPROPERTYSINGLEVALUE('Washer name',$,IFCLABEL('SCHEIBE24-126'),$);
#259= IFCPROPERTYSINGLEVALUE('Nut count',$,$,$);
#260= IFCPROPERTYSINGLEVALUE('Nut type',$,IFCLABEL('934'),$);
#261= IFCPROPERTYSINGLEVALUE('Nut name',$,IFCLABEL('MUN24-934'),$);
#262= IFCPROPERTYSINGLEVALUE('Slotted hole y',$,IFCLENGTHMEASURE(0.),$);
#263= IFCPROPERTYSINGLEVALUE('Slotted hole x',$,IFCLENGTHMEASURE(0.),$);
#264= IFCPROPERTYSINGLEVALUE('Bolt hole diameter',$,IFCLENGTHMEASURE(27.),$);
#265= IFCPROPERTYSINGLEVALUE('Location',$,IFCLABEL('Site'),$);
#266= IFCPROPERTYSINGLEVALUE('Bolt count',$,$,$);
#267= IFCPROPERTYSINGLEVALUE('Bolt size',$,IFCLENGTHMEASURE(24.),$);
#268= IFCPROPERTYSINGLEVALUE('Bolt length',$,IFCLENGTHMEASURE(100.),$);
#269= IFCPROPERTYSINGLEVALUE('Bolt standard',$,IFCLABEL('7991'),$);
#270= IFCPROPERTYSINGLEVALUE('Bolt Name',$,IFCLABEL('M24*100'),$);
#271= IFCPROPERTYSET('0vxqUuFef4k8J53NrYFHYE',#5,'Tekla Bolt','Bolt Properties',(#255,#256,#257,#258,#259,#260,#261,#262,#263,#264,#265,#266,#267,#268,#269,#270));
#272= IFCMATERIAL('8.8');
#273= IFCCARTESIANPOINT((47275.0012301051,-554.15030009651,15839.995));
#274= IFCAXIS2PLACEMENT3D(#273,#8,#185);
#275= IFCLOCALPLACEMENT(#30,#274);
#276= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#277= IFCEXTRUDEDAREASOLID(#276,#200,#9,16.0999999999997);
#278= IFCSTYLEDITEM(#277,(#195),$);
#279= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#280= IFCEXTRUDEDAREASOLID(#279,#205,#9,16.);
#281= IFCSTYLEDITEM(#280,(#195),$);
#282= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#283= IFCEXTRUDEDAREASOLID(#282,#210,#9,74.);
#284= IFCSTYLEDITEM(#283,(#195),$);
#285= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#219);
#286= IFCEXTRUDEDAREASOLID(#285,#222,#9,14.);
#287= IFCSTYLEDITEM(#286,(#191),$);
#288= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#289= IFCEXTRUDEDAREASOLID(#288,#227,#9,100.);
#290= IFCSTYLEDITEM(#289,(#191),$);
#291= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,22.);
#292= IFCEXTRUDEDAREASOLID(#291,#232,#9,4.);
#293= IFCSTYLEDITEM(#292,(#191),$);
#294= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#241);
#295= IFCEXTRUDEDAREASOLID(#294,#244,#9,19.);
#296= IFCSTYLEDITEM(#295,(#191),$);
#297= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#277,#280,#283,#286,#289,#292,#295));
#298= IFCREPRESENTATIONMAP(#10,#297);
#299= IFCMAPPEDITEM(#298,#247);
#300= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#299));
#301= IFCPRODUCTDEFINITIONSHAPE($,$,(#300));
#302= IFCMECHANICALFASTENER('1Td1iR003HJp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#275,#301,'ID5d9c1b1b-0000-d14f-3135-373035313136',24.,100.);
#303= IFCCARTESIANPOINT((47275.0012301051,-554.15030009651,10639.995));
#304= IFCAXIS2PLACEMENT3D(#303,#8,#185);
#305= IFCLOCALPLACEMENT(#30,#304);
#306= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#307= IFCEXTRUDEDAREASOLID(#306,#200,#9,16.0999999999993);
#308= IFCSTYLEDITEM(#307,(#195),$);
#309= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#310= IFCEXTRUDEDAREASOLID(#309,#205,#9,15.9999999999993);
#311= IFCSTYLEDITEM(#310,(#195),$);
#312= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#313= IFCEXTRUDEDAREASOLID(#312,#210,#9,74.);
#314= IFCSTYLEDITEM(#313,(#195),$);
#315= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#219);
#316= IFCEXTRUDEDAREASOLID(#315,#222,#9,14.);
#317= IFCSTYLEDITEM(#316,(#191),$);
#318= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#319= IFCEXTRUDEDAREASOLID(#318,#227,#9,100.);
#320= IFCSTYLEDITEM(#319,(#191),$);
#321= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,22.);
#322= IFCEXTRUDEDAREASOLID(#321,#232,#9,4.);
#323= IFCSTYLEDITEM(#322,(#191),$);
#324= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#241);
#325= IFCEXTRUDEDAREASOLID(#324,#244,#9,19.);
#326= IFCSTYLEDITEM(#325,(#191),$);
#327= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#307,#310,#313,#316,#319,#322,#325));
#328= IFCREPRESENTATIONMAP(#10,#327);
#329= IFCMAPPEDITEM(#328,#247);
#330= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#329));
#331= IFCPRODUCTDEFINITIONSHAPE($,$,(#330));
#332= IFCMECHANICALFASTENER('1Td1iR003HJ34rDp0rCJ4s',#5,'Bolt assembly',$,$,#305,#331,'ID5d9c1b1b-0000-d14c-3135-373035313136',24.,100.);
#333= IFCCARTESIANPOINT((47524.9993581264,-554.150281216347,10639.995));
#334= IFCAXIS2PLACEMENT3D(#333,#8,#185);
#335= IFCLOCALPLACEMENT(#30,#334);
#336= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#337= IFCEXTRUDEDAREASOLID(#336,#200,#9,16.0999999999995);
#338= IFCSTYLEDITEM(#337,(#195),$);
#339= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#340= IFCEXTRUDEDAREASOLID(#339,#205,#9,15.9999999999992);
#341= IFCSTYLEDITEM(#340,(#195),$);
#342= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#343= IFCEXTRUDEDAREASOLID(#342,#210,#9,74.);
#344= IFCSTYLEDITEM(#343,(#195),$);
#345= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#219);
#346= IFCEXTRUDEDAREASOLID(#345,#222,#9,14.);
#347= IFCSTYLEDITEM(#346,(#191),$);
#348= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#349= IFCEXTRUDEDAREASOLID(#348,#227,#9,100.);
#350= IFCSTYLEDITEM(#349,(#191),$);
#351= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,22.);
#352= IFCEXTRUDEDAREASOLID(#351,#232,#9,4.);
#353= IFCSTYLEDITEM(#352,(#191),$);
#354= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#241);
#355= IFCEXTRUDEDAREASOLID(#354,#244,#9,19.);
#356= IFCSTYLEDITEM(#355,(#191),$);
#357= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#337,#340,#343,#346,#349,#352,#355));
#358= IFCREPRESENTATIONMAP(#10,#357);
#359= IFCMAPPEDITEM(#358,#247);
#360= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#359));
#361= IFCPRODUCTDEFINITIONSHAPE($,$,(#360));
#362= IFCMECHANICALFASTENER('1Td1iR003HIJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#335,#361,'ID5d9c1b1b-0000-d149-3135-373035313136',24.,100.);
#363= IFCCARTESIANPOINT((47524.9993581264,-554.150281216347,4939.995));
#364= IFCAXIS2PLACEMENT3D(#363,#8,#185);
#365= IFCLOCALPLACEMENT(#30,#364);
#366= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#367= IFCEXTRUDEDAREASOLID(#366,#200,#9,16.1000000000001);
#368= IFCSTYLEDITEM(#367,(#195),$);
#369= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#370= IFCEXTRUDEDAREASOLID(#369,#205,#9,16.);
#371= IFCSTYLEDITEM(#370,(#195),$);
#372= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#373= IFCEXTRUDEDAREASOLID(#372,#210,#9,74.);
#374= IFCSTYLEDITEM(#373,(#195),$);
#375= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#219);
#376= IFCEXTRUDEDAREASOLID(#375,#222,#9,14.);
#377= IFCSTYLEDITEM(#376,(#191),$);
#378= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#379= IFCEXTRUDEDAREASOLID(#378,#227,#9,100.);
#380= IFCSTYLEDITEM(#379,(#191),$);
#381= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,22.);
#382= IFCEXTRUDEDAREASOLID(#381,#232,#9,4.);
#383= IFCSTYLEDITEM(#382,(#191),$);
#384= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#241);
#385= IFCEXTRUDEDAREASOLID(#384,#244,#9,19.);
#386= IFCSTYLEDITEM(#385,(#191),$);
#387= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#367,#370,#373,#376,#379,#382,#385));
#388= IFCREPRESENTATIONMAP(#10,#387);
#389= IFCMAPPEDITEM(#388,#247);
#390= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#389));
#391= IFCPRODUCTDEFINITIONSHAPE($,$,(#390));
#392= IFCMECHANICALFASTENER('1Td1iR003HGp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#365,#391,'ID5d9c1b1b-0000-d143-3135-373035313136',24.,100.);
#393= IFCCARTESIANPOINT((47275.0012301051,-554.15030009651,4939.995));
#394= IFCAXIS2PLACEMENT3D(#393,#8,#185);
#395= IFCLOCALPLACEMENT(#30,#394);
#396= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#397= IFCEXTRUDEDAREASOLID(#396,#200,#9,16.1);
#398= IFCSTYLEDITEM(#397,(#195),$);
#399= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#400= IFCEXTRUDEDAREASOLID(#399,#205,#9,16.0000000000003);
#401= IFCSTYLEDITEM(#400,(#195),$);
#402= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#403= IFCEXTRUDEDAREASOLID(#402,#210,#9,74.);
#404= IFCSTYLEDITEM(#403,(#195),$);
#405= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#219);
#406= IFCEXTRUDEDAREASOLID(#405,#222,#9,14.);
#407= IFCSTYLEDITEM(#406,(#191),$);
#408= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#409= IFCEXTRUDEDAREASOLID(#408,#227,#9,100.);
#410= IFCSTYLEDITEM(#409,(#191),$);
#411= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,22.);
#412= IFCEXTRUDEDAREASOLID(#411,#232,#9,4.);
#413= IFCSTYLEDITEM(#412,(#191),$);
#414= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#241);
#415= IFCEXTRUDEDAREASOLID(#414,#244,#9,19.);
#416= IFCSTYLEDITEM(#415,(#191),$);
#417= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#397,#400,#403,#406,#409,#412,#415));
#418= IFCREPRESENTATIONMAP(#10,#417);
#419= IFCMAPPEDITEM(#418,#247);
#420= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#419));
#421= IFCPRODUCTDEFINITIONSHAPE($,$,(#420));
#422= IFCMECHANICALFASTENER('1Td1iR003HHZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#395,#421,'ID5d9c1b1b-0000-d146-3135-373035313136',24.,100.);
#423= IFCCARTESIANPOINT((47524.9993581264,-554.150281216347,-1060.005));
#424= IFCAXIS2PLACEMENT3D(#423,#8,#185);
#425= IFCLOCALPLACEMENT(#30,#424);
#426= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#427= IFCEXTRUDEDAREASOLID(#426,#200,#9,16.1);
#428= IFCSTYLEDITEM(#427,(#195),$);
#429= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#430= IFCEXTRUDEDAREASOLID(#429,#205,#9,16.);
#431= IFCSTYLEDITEM(#430,(#195),$);
#432= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#433= IFCEXTRUDEDAREASOLID(#432,#210,#9,74.);
#434= IFCSTYLEDITEM(#433,(#195),$);
#435= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#219);
#436= IFCEXTRUDEDAREASOLID(#435,#222,#9,14.);
#437= IFCSTYLEDITEM(#436,(#191),$);
#438= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#439= IFCEXTRUDEDAREASOLID(#438,#227,#9,100.);
#440= IFCSTYLEDITEM(#439,(#191),$);
#441= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,22.);
#442= IFCEXTRUDEDAREASOLID(#441,#232,#9,4.);
#443= IFCSTYLEDITEM(#442,(#191),$);
#444= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#241);
#445= IFCEXTRUDEDAREASOLID(#444,#244,#9,19.);
#446= IFCSTYLEDITEM(#445,(#191),$);
#447= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#427,#430,#433,#436,#439,#442,#445));
#448= IFCREPRESENTATIONMAP(#10,#447);
#449= IFCMAPPEDITEM(#448,#247);
#450= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#449));
#451= IFCPRODUCTDEFINITIONSHAPE($,$,(#450));
#452= IFCMECHANICALFASTENER('1Td1iR003GvJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#425,#451,'ID5d9c1b1b-0000-d0e5-3135-373035313136',24.,100.);
#453= IFCCARTESIANPOINT((47275.0012301051,-554.15030009651,-1060.005));
#454= IFCAXIS2PLACEMENT3D(#453,#8,#185);
#455= IFCLOCALPLACEMENT(#30,#454);
#456= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#457= IFCEXTRUDEDAREASOLID(#456,#200,#9,16.1);
#458= IFCSTYLEDITEM(#457,(#195),$);
#459= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#460= IFCEXTRUDEDAREASOLID(#459,#205,#9,16.);
#461= IFCSTYLEDITEM(#460,(#195),$);
#462= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#463= IFCEXTRUDEDAREASOLID(#462,#210,#9,74.);
#464= IFCSTYLEDITEM(#463,(#195),$);
#465= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#219);
#466= IFCEXTRUDEDAREASOLID(#465,#222,#9,14.);
#467= IFCSTYLEDITEM(#466,(#191),$);
#468= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#469= IFCEXTRUDEDAREASOLID(#468,#227,#9,100.);
#470= IFCSTYLEDITEM(#469,(#191),$);
#471= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,22.);
#472= IFCEXTRUDEDAREASOLID(#471,#232,#9,4.);
#473= IFCSTYLEDITEM(#472,(#191),$);
#474= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#241);
#475= IFCEXTRUDEDAREASOLID(#474,#244,#9,19.);
#476= IFCSTYLEDITEM(#475,(#191),$);
#477= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#457,#460,#463,#466,#469,#472,#475));
#478= IFCREPRESENTATIONMAP(#10,#477);
#479= IFCMAPPEDITEM(#478,#247);
#480= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#479));
#481= IFCPRODUCTDEFINITIONSHAPE($,$,(#480));
#482= IFCMECHANICALFASTENER('1Td1iR003Gw34rDp0rCJ4s',#5,'Bolt assembly',$,$,#455,#481,'ID5d9c1b1b-0000-d0e8-3135-373035313136',24.,100.);
#483= IFCLOCALPLACEMENT(#30,#10);
#484= IFCELEMENTASSEMBLY('1Td1iR003FUJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#483,$,'ANK/63(?)',.NOTDEFINED.,.RIGID_FRAME.);
#485= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(2.82601149902374),$);
#486= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -1.094'),$);
#487= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -1.078'),$);
#488= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit position code',$,IFCLABEL('5/1-6/6-N2'),$);
#489= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('ANK/63(?)'),$);
#490= IFCPROPERTYSET('1UtndcpRHFC9k0asY15Sgc',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#485,#486,#487,#39,#488,#489));
#491= IFCQUANTITYLENGTH('Width',$,$,16.);
#492= IFCELEMENTQUANTITY('3P3e6NzpTB$wHiqeGC1P19',#5,'BaseQuantities',$,$,(#491));
#493= IFCCARTESIANPOINT((47524.9997504966,-629.151268223872,-1086.));
#494= IFCAXIS2PLACEMENT3D(#493,#7,#8);
#495= IFCLOCALPLACEMENT(#483,#494);
#496= IFCCOLOURRGB('Dark Red',0.698039215686274,0.2,0.301960784313725);
#497= IFCSURFACESTYLERENDERING(#496,0.,$,$,$,$,IFCNORMALISEDRATIOMEASURE(0.00390625),IFCSPECULAREXPONENT(10.),.NOTDEFINED.);
#498= IFCSURFACESTYLE('STEEL/S235JR',.POSITIVE.,(#497));
#499= IFCPRESENTATIONSTYLEASSIGNMENT((#498));
#500= IFCRECTANGLEPROFILEDEF(.AREA.,'PLT16*150',#197,16.,150.);
#501= IFCDIRECTION((0.,-1.,0.));
#502= IFCCARTESIANPOINT((150.000610351578,2.27373675443232E-013,0.));
#503= IFCAXIS2PLACEMENT3D(#502,#185,#501);
#504= IFCEXTRUDEDAREASOLID(#500,#503,#9,150.000610351578);
#505= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#504));
#506= IFCSTYLEDITEM(#504,(#499),$);
#507= IFCPRODUCTDEFINITIONSHAPE($,$,(#505));
#508= IFCBEAM('1Td1iR003FU34rDp0rCJ4s',#5,'ANKRAJ','PLT16*150','PLT16*150',#495,#507,'P/379(?)');
#509= IFCBEAMTYPE('3sj1Mmzgv0hA1UaYBxgdo3',#5,'PLT16*150',$,$,$,$,$,$,.NOTDEFINED.);
#510= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -1.094'),$);
#511= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -1.078'),$);
#512= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/379(?)'),$);
#513= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('ANK/63(?)'),$);
#514= IFCPROPERTYSINGLEVALUE('Phase',$,IFCINTEGER(2),$);
#515= IFCPROPERTYSINGLEVALUE('Class',$,IFCLABEL('9'),$);
#516= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PLT16*150'),$);
#517= IFCPROPERTYSET('1lndeuqsr64B1bOe2$ysPb',#5,'Tekla Common','Common Properties to Shared building elements',(#510,#511,#512,#513,#74,#75,#514,#515,#78,#516,#80));
#518= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(2.82601149902374),$);
#519= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(2.82601149902374),$);
#520= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(2.8260114990308),$);
#521= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(2.82601149902374),$);
#522= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000360001464843788),$);
#523= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000360001464843788),$);
#524= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000360001464843788),$);
#525= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.0225000915527368),$);
#526= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(19.3205875685877),$);
#527= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0546002026367241),$);
#528= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0546002026367241),$);
#529= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(150.000000000007),$);
#530= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(150.000610351946),$);
#531= IFCPROPERTYSET('30g2P0JuH9LPLsVOVlRViC',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#518,#519,#520,#521,#522,#523,#524,#525,#526,#527,#528,#529,#94,#530));
#532= IFCQUANTITYLENGTH('Length',$,$,150.000610351946);
#533= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0546002026367241);
#534= IFCQUANTITYVOLUME('NetVolume',$,$,0.000360001464843788);
#535= IFCQUANTITYWEIGHT('NetWeight',$,$,2.82601149902374);
#536= IFCELEMENTQUANTITY('3Gt68vQGHCDApZqdDso6Nz',#5,'BaseQuantities',$,$,(#532,#533,#534,#535));
#537= IFCLOCALPLACEMENT(#30,#10);
#538= IFCELEMENTASSEMBLY('1Td1iR003FTJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#537,$,'ANK/63(?)',.NOTDEFINED.,.RIGID_FRAME.);
#539= IFCCARTESIANPOINT((47275.0016158756,-629.151287104069,-1086.));
#540= IFCAXIS2PLACEMENT3D(#539,#7,#8);
#541= IFCLOCALPLACEMENT(#537,#540);
#542= IFCEXTRUDEDAREASOLID(#500,#503,#9,150.000610351577);
#543= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#542));
#544= IFCSTYLEDITEM(#542,(#499),$);
#545= IFCPRODUCTDEFINITIONSHAPE($,$,(#543));
#546= IFCBEAM('1Td1iR003FT34rDp0rCJ4s',#5,'ANKRAJ','PLT16*150','PLT16*150',#541,#545,'P/379(?)');
#547= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(19.3205875685878),$);
#548= IFCPROPERTYSET('2LRBAhSRX40ORCvXLTFwmT',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#518,#519,#520,#521,#522,#523,#524,#525,#547,#527,#528,#529,#94,#530));
#549= IFCQUANTITYLENGTH('Length',$,$,150.000610351898);
#550= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0546002026367236);
#551= IFCQUANTITYVOLUME('NetVolume',$,$,0.000360001464843785);
#552= IFCQUANTITYWEIGHT('NetWeight',$,$,2.82601149902371);
#553= IFCELEMENTQUANTITY('3mli8HIUnCuxZbUfAMC6EY',#5,'BaseQuantities',$,$,(#549,#550,#551,#552));
#554= IFCCARTESIANPOINT((47524.9997174869,-554.150674997327,15787.999));
#555= IFCAXIS2PLACEMENT3D(#554,#8,#7);
#556= IFCLOCALPLACEMENT(#30,#555);
#557= IFCSURFACESTYLE('Undefined',.POSITIVE.,(#189));
#558= IFCPRESENTATIONSTYLEASSIGNMENT((#557));
#559= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,42.5);
#560= IFCCARTESIANPOINT((0.,-18.0009999999983,0.));
#561= IFCAXIS2PLACEMENT3D(#560,#8,#7);
#562= IFCEXTRUDEDAREASOLID(#559,#561,#9,16.0999999999998);
#563= IFCSTYLEDITEM(#562,(#195),$);
#564= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#562));
#565= IFCREPRESENTATIONMAP(#10,#564);
#566= IFCMAPPEDITEM(#565,#247);
#567= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#566));
#568= IFCPRODUCTDEFINITIONSHAPE($,$,(#567));
#569= IFCMECHANICALFASTENER('1Td1iR003H434rDp0rCJ4s',#5,'Bolt assembly',$,$,#556,#568,'ID5d9c1b1b-0000-d110-3135-373035313136',30.,16.);
#570= IFCPROPERTYSINGLEVALUE('Washer diameter',$,IFCLENGTHMEASURE(30.),$);
#571= IFCPROPERTYSINGLEVALUE('Washer type',$,IFCLABEL('7989'),$);
#572= IFCPROPERTYSINGLEVALUE('Washer name',$,IFCLABEL('WASHER30-7989'),$);
#573= IFCPROPERTYSINGLEVALUE('Nut type',$,IFCLABEL('555'),$);
#574= IFCPROPERTYSINGLEVALUE('Nut name',$,IFCLABEL('NUT30-555'),$);
#575= IFCPROPERTYSINGLEVALUE('Slotted hole y',$,IFCLENGTHMEASURE(60.),$);
#576= IFCPROPERTYSINGLEVALUE('Bolt hole diameter',$,IFCLENGTHMEASURE(85.),$);
#577= IFCPROPERTYSINGLEVALUE('Bolt size',$,IFCLENGTHMEASURE(85.),$);
#578= IFCPROPERTYSINGLEVALUE('Bolt length',$,IFCLENGTHMEASURE(16.),$);
#579= IFCPROPERTYSINGLEVALUE('Bolt standard',$,IFCLABEL('7990'),$);
#580= IFCPROPERTYSINGLEVALUE('Bolt Name',$,IFCLABEL('BOLT30*80'),$);
#581= IFCPROPERTYSET('1Y6OCsHj92Yurc_66svtIM',#5,'Tekla Bolt','Bolt Properties',(#255,#570,#571,#572,#259,#573,#574,#575,#263,#576,#265,#266,#577,#578,#579,#580));
#582= IFCMATERIAL('Undefined');
#583= IFCCARTESIANPOINT((47275.0017174869,-554.150674997327,15787.999));
#584= IFCAXIS2PLACEMENT3D(#583,#8,#7);
#585= IFCLOCALPLACEMENT(#30,#584);
#586= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,42.5);
#587= IFCEXTRUDEDAREASOLID(#586,#561,#9,16.1);
#588= IFCSTYLEDITEM(#587,(#195),$);
#589= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#587));
#590= IFCREPRESENTATIONMAP(#10,#589);
#591= IFCMAPPEDITEM(#590,#247);
#592= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#591));
#593= IFCPRODUCTDEFINITIONSHAPE($,$,(#592));
#594= IFCMECHANICALFASTENER('1Td1iR003H3J4rDp0rCJ4s',#5,'Bolt assembly',$,$,#585,#593,'ID5d9c1b1b-0000-d10d-3135-373035313136',30.,16.);
#595= IFCCARTESIANPOINT((47188.4976961945,-232.33006251714,15790.));
#596= IFCDIRECTION((0.,0.,-1.));
#597= IFCDIRECTION((-0.977596462291677,0.210487902062798,0.));
#598= IFCAXIS2PLACEMENT3D(#595,#596,#597);
#599= IFCLOCALPLACEMENT(#30,#598);
#600= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#601= IFCCARTESIANPOINT((0.,-5.43048542381136,0.));
#602= IFCAXIS2PLACEMENT3D(#601,#8,#7);
#603= IFCEXTRUDEDAREASOLID(#600,#602,#9,30.1000000000098);
#604= IFCSTYLEDITEM(#603,(#195),$);
#605= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#603));
#606= IFCREPRESENTATIONMAP(#10,#605);
#607= IFCMAPPEDITEM(#606,#247);
#608= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#607));
#609= IFCPRODUCTDEFINITIONSHAPE($,$,(#608));
#610= IFCMECHANICALFASTENER('1Td1iR003H2Z4rDp0rCJ4s',#5,'Bolt assembly',$,$,#599,#609,'ID5d9c1b1b-0000-d10a-3135-373035313136',20.,30.);
#611= IFCPROPERTYSINGLEVALUE('Washer diameter',$,IFCLENGTHMEASURE(20.),$);
#612= IFCPROPERTYSINGLEVALUE('Washer name',$,IFCLABEL('WASHER20-7989'),$);
#613= IFCPROPERTYSINGLEVALUE('Nut name',$,IFCLABEL('NUT20-555'),$);
#614= IFCPROPERTYSINGLEVALUE('Bolt hole diameter',$,IFCLENGTHMEASURE(22.),$);
#615= IFCPROPERTYSINGLEVALUE('Bolt size',$,IFCLENGTHMEASURE(22.),$);
#616= IFCPROPERTYSINGLEVALUE('Bolt length',$,IFCLENGTHMEASURE(30.),$);
#617= IFCPROPERTYSINGLEVALUE('Bolt Name',$,IFCLABEL('BOLT20*40'),$);
#618= IFCPROPERTYSET('1SdUU7zVDCaR$gG8BdwawF',#5,'Tekla Bolt','Bolt Properties',(#255,#611,#571,#612,#259,#573,#613,#262,#263,#614,#265,#266,#615,#616,#579,#617));
#619= IFCCARTESIANPOINT((47605.1872659515,-203.002074025746,15790.));
#620= IFCDIRECTION((0.981604704553937,0.190924602913238,0.));
#621= IFCAXIS2PLACEMENT3D(#619,#9,#620);
#622= IFCLOCALPLACEMENT(#30,#621);
#623= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,71.);
#624= IFCCARTESIANPOINT((0.,-5.31652779962808,0.));
#625= IFCAXIS2PLACEMENT3D(#624,#8,#7);
#626= IFCEXTRUDEDAREASOLID(#623,#625,#9,30.1063464563355);
#627= IFCSTYLEDITEM(#626,(#195),$);
#628= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#626));
#629= IFCREPRESENTATIONMAP(#10,#628);
#630= IFCMAPPEDITEM(#629,#247);
#631= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#630));
#632= IFCPRODUCTDEFINITIONSHAPE($,$,(#631));
#633= IFCMECHANICALFASTENER('1Td1iR003H1p4rDp0rCJ4s',#5,'Bolt assembly',$,$,#622,#632,'ID5d9c1b1b-0000-d107-3135-373035313136',20.,30.0063457489014);
#634= IFCPROPERTYSINGLEVALUE('Slotted hole x',$,IFCLENGTHMEASURE(60.),$);
#635= IFCPROPERTYSINGLEVALUE('Bolt hole diameter',$,IFCLENGTHMEASURE(82.),$);
#636= IFCPROPERTYSINGLEVALUE('Bolt size',$,IFCLENGTHMEASURE(82.),$);
#637= IFCPROPERTYSINGLEVALUE('Bolt length',$,IFCLENGTHMEASURE(30.0063457489014),$);
#638= IFCPROPERTYSET('2a6rAipB9CyBshsZR3JmrD',#5,'Tekla Bolt','Bolt Properties',(#255,#611,#571,#612,#259,#573,#613,#575,#634,#635,#265,#266,#636,#637,#579,#617));
#639= IFCCARTESIANPOINT((47611.502262432,-232.330074783564,15790.));
#640= IFCDIRECTION((0.977596474346582,0.210487846074621,0.));
#641= IFCAXIS2PLACEMENT3D(#639,#9,#640);
#642= IFCLOCALPLACEMENT(#30,#641);
#643= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#644= IFCEXTRUDEDAREASOLID(#643,#602,#9,30.1000000000079);
#645= IFCSTYLEDITEM(#644,(#195),$);
#646= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#644));
#647= IFCREPRESENTATIONMAP(#10,#646);
#648= IFCMAPPEDITEM(#647,#247);
#649= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#648));
#650= IFCPRODUCTDEFINITIONSHAPE($,$,(#649));
#651= IFCMECHANICALFASTENER('1Td1iR003H134rDp0rCJ4s',#5,'Bolt assembly',$,$,#642,#650,'ID5d9c1b1b-0000-d104-3135-373035313136',20.,30.);
#652= IFCCARTESIANPOINT((47194.8131339993,-203.00204940281,15790.));
#653= IFCDIRECTION((-0.981604681600855,0.190924720922366,0.));
#654= IFCAXIS2PLACEMENT3D(#652,#596,#653);
#655= IFCLOCALPLACEMENT(#30,#654);
#656= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,71.);
#657= IFCCARTESIANPOINT((0.,-5.3057240801901,0.));
#658= IFCAXIS2PLACEMENT3D(#657,#8,#7);
#659= IFCEXTRUDEDAREASOLID(#656,#658,#9,30.1061745233263);
#660= IFCSTYLEDITEM(#659,(#195),$);
#661= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#659));
#662= IFCREPRESENTATIONMAP(#10,#661);
#663= IFCMAPPEDITEM(#662,#247);
#664= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#663));
#665= IFCPRODUCTDEFINITIONSHAPE($,$,(#664));
#666= IFCMECHANICALFASTENER('1Td1iR003H0J4rDp0rCJ4s',#5,'Bolt assembly',$,$,#655,#665,'ID5d9c1b1b-0000-d101-3135-373035313136',20.,30.0061740875244);
#667= IFCPROPERTYSINGLEVALUE('Bolt length',$,IFCLENGTHMEASURE(30.0061740875244),$);
#668= IFCPROPERTYSET('0okTSeAC5BuACAuzcX9PRP',#5,'Tekla Bolt','Bolt Properties',(#255,#611,#571,#612,#259,#573,#613,#575,#634,#635,#265,#266,#636,#667,#579,#617));
#669= IFCCARTESIANPOINT((47524.9997174869,-554.150674997327,10587.999));
#670= IFCAXIS2PLACEMENT3D(#669,#8,#7);
#671= IFCLOCALPLACEMENT(#30,#670);
#672= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,42.5);
#673= IFCEXTRUDEDAREASOLID(#672,#561,#9,16.0999999999992);
#674= IFCSTYLEDITEM(#673,(#195),$);
#675= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#673));
#676= IFCREPRESENTATIONMAP(#10,#675);
#677= IFCMAPPEDITEM(#676,#247);
#678= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#677));
#679= IFCPRODUCTDEFINITIONSHAPE($,$,(#678));
#680= IFCMECHANICALFASTENER('1Td1iR003G_Z4rDp0rCJ4s',#5,'Bolt assembly',$,$,#671,#679,'ID5d9c1b1b-0000-d0fa-3135-373035313136',30.,16.);
#681= IFCCARTESIANPOINT((47275.0017174869,-554.150674997327,10587.999));
#682= IFCAXIS2PLACEMENT3D(#681,#8,#7);
#683= IFCLOCALPLACEMENT(#30,#682);
#684= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,42.5);
#685= IFCEXTRUDEDAREASOLID(#684,#561,#9,16.0999999999993);
#686= IFCSTYLEDITEM(#685,(#195),$);
#687= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#685));
#688= IFCREPRESENTATIONMAP(#10,#687);
#689= IFCMAPPEDITEM(#688,#247);
#690= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#689));
#691= IFCPRODUCTDEFINITIONSHAPE($,$,(#690));
#692= IFCMECHANICALFASTENER('1Td1iR003Gzp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#683,#691,'ID5d9c1b1b-0000-d0f7-3135-373035313136',30.,16.);
#693= IFCCARTESIANPOINT((47188.4976961945,-232.33006251714,10590.));
#694= IFCAXIS2PLACEMENT3D(#693,#596,#597);
#695= IFCLOCALPLACEMENT(#30,#694);
#696= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#697= IFCEXTRUDEDAREASOLID(#696,#602,#9,30.1000000000098);
#698= IFCSTYLEDITEM(#697,(#195),$);
#699= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#697));
#700= IFCREPRESENTATIONMAP(#10,#699);
#701= IFCMAPPEDITEM(#700,#247);
#702= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#701));
#703= IFCPRODUCTDEFINITIONSHAPE($,$,(#702));
#704= IFCMECHANICALFASTENER('1Td1iR003Gz34rDp0rCJ4s',#5,'Bolt assembly',$,$,#695,#703,'ID5d9c1b1b-0000-d0f4-3135-373035313136',20.,30.);
#705= IFCCARTESIANPOINT((47605.1872659515,-203.002074025746,10590.));
#706= IFCAXIS2PLACEMENT3D(#705,#9,#620);
#707= IFCLOCALPLACEMENT(#30,#706);
#708= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,71.);
#709= IFCEXTRUDEDAREASOLID(#708,#625,#9,30.1063464563355);
#710= IFCSTYLEDITEM(#709,(#195),$);
#711= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#709));
#712= IFCREPRESENTATIONMAP(#10,#711);
#713= IFCMAPPEDITEM(#712,#247);
#714= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#713));
#715= IFCPRODUCTDEFINITIONSHAPE($,$,(#714));
#716= IFCMECHANICALFASTENER('1Td1iR003GyJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#707,#715,'ID5d9c1b1b-0000-d0f1-3135-373035313136',20.,30.0063457489014);
#717= IFCCARTESIANPOINT((47611.502262432,-232.330074783564,10590.));
#718= IFCAXIS2PLACEMENT3D(#717,#9,#640);
#719= IFCLOCALPLACEMENT(#30,#718);
#720= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#721= IFCEXTRUDEDAREASOLID(#720,#602,#9,30.1000000000079);
#722= IFCSTYLEDITEM(#721,(#195),$);
#723= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#721));
#724= IFCREPRESENTATIONMAP(#10,#723);
#725= IFCMAPPEDITEM(#724,#247);
#726= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#725));
#727= IFCPRODUCTDEFINITIONSHAPE($,$,(#726));
#728= IFCMECHANICALFASTENER('1Td1iR003GxZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#719,#727,'ID5d9c1b1b-0000-d0ee-3135-373035313136',20.,30.);
#729= IFCCARTESIANPOINT((47194.8131339993,-203.00204940281,10590.));
#730= IFCAXIS2PLACEMENT3D(#729,#596,#653);
#731= IFCLOCALPLACEMENT(#30,#730);
#732= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,71.);
#733= IFCEXTRUDEDAREASOLID(#732,#658,#9,30.1061745233263);
#734= IFCSTYLEDITEM(#733,(#195),$);
#735= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#733));
#736= IFCREPRESENTATIONMAP(#10,#735);
#737= IFCMAPPEDITEM(#736,#247);
#738= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#737));
#739= IFCPRODUCTDEFINITIONSHAPE($,$,(#738));
#740= IFCMECHANICALFASTENER('1Td1iR003Gwp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#731,#739,'ID5d9c1b1b-0000-d0eb-3135-373035313136',20.,30.0061740875244);
#741= IFCCARTESIANPOINT((47524.9997174869,-554.150674997327,4887.999));
#742= IFCAXIS2PLACEMENT3D(#741,#8,#7);
#743= IFCLOCALPLACEMENT(#30,#742);
#744= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,42.5);
#745= IFCEXTRUDEDAREASOLID(#744,#561,#9,16.1);
#746= IFCSTYLEDITEM(#745,(#195),$);
#747= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#745));
#748= IFCREPRESENTATIONMAP(#10,#747);
#749= IFCMAPPEDITEM(#748,#247);
#750= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#749));
#751= IFCPRODUCTDEFINITIONSHAPE($,$,(#750));
#752= IFCMECHANICALFASTENER('1Td1iR003GuZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#743,#751,'ID5d9c1b1b-0000-d0e2-3135-373035313136',30.,16.);
#753= IFCCARTESIANPOINT((47275.0017174869,-554.150674997327,4887.999));
#754= IFCAXIS2PLACEMENT3D(#753,#8,#7);
#755= IFCLOCALPLACEMENT(#30,#754);
#756= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,42.5);
#757= IFCEXTRUDEDAREASOLID(#756,#561,#9,16.1000000000003);
#758= IFCSTYLEDITEM(#757,(#195),$);
#759= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#757));
#760= IFCREPRESENTATIONMAP(#10,#759);
#761= IFCMAPPEDITEM(#760,#247);
#762= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#761));
#763= IFCPRODUCTDEFINITIONSHAPE($,$,(#762));
#764= IFCMECHANICALFASTENER('1Td1iR003Gtp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#755,#763,'ID5d9c1b1b-0000-d0df-3135-373035313136',30.,16.);
#765= IFCCARTESIANPOINT((47188.4976961945,-232.33006251714,4890.));
#766= IFCAXIS2PLACEMENT3D(#765,#596,#597);
#767= IFCLOCALPLACEMENT(#30,#766);
#768= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#769= IFCEXTRUDEDAREASOLID(#768,#602,#9,30.1000000000098);
#770= IFCSTYLEDITEM(#769,(#195),$);
#771= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#769));
#772= IFCREPRESENTATIONMAP(#10,#771);
#773= IFCMAPPEDITEM(#772,#247);
#774= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#773));
#775= IFCPRODUCTDEFINITIONSHAPE($,$,(#774));
#776= IFCMECHANICALFASTENER('1Td1iR003Gt34rDp0rCJ4s',#5,'Bolt assembly',$,$,#767,#775,'ID5d9c1b1b-0000-d0dc-3135-373035313136',20.,30.);
#777= IFCCARTESIANPOINT((47605.1872659515,-203.002074025746,4890.));
#778= IFCAXIS2PLACEMENT3D(#777,#9,#620);
#779= IFCLOCALPLACEMENT(#30,#778);
#780= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,71.);
#781= IFCEXTRUDEDAREASOLID(#780,#625,#9,30.1063464563355);
#782= IFCSTYLEDITEM(#781,(#195),$);
#783= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#781));
#784= IFCREPRESENTATIONMAP(#10,#783);
#785= IFCMAPPEDITEM(#784,#247);
#786= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#785));
#787= IFCPRODUCTDEFINITIONSHAPE($,$,(#786));
#788= IFCMECHANICALFASTENER('1Td1iR003GsJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#779,#787,'ID5d9c1b1b-0000-d0d9-3135-373035313136',20.,30.0063457489014);
#789= IFCCARTESIANPOINT((47611.502262432,-232.330074783564,4890.));
#790= IFCAXIS2PLACEMENT3D(#789,#9,#640);
#791= IFCLOCALPLACEMENT(#30,#790);
#792= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#793= IFCEXTRUDEDAREASOLID(#792,#602,#9,30.1000000000079);
#794= IFCSTYLEDITEM(#793,(#195),$);
#795= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#793));
#796= IFCREPRESENTATIONMAP(#10,#795);
#797= IFCMAPPEDITEM(#796,#247);
#798= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#797));
#799= IFCPRODUCTDEFINITIONSHAPE($,$,(#798));
#800= IFCMECHANICALFASTENER('1Td1iR003GrZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#791,#799,'ID5d9c1b1b-0000-d0d6-3135-373035313136',20.,30.);
#801= IFCCARTESIANPOINT((47194.8131339993,-203.00204940281,4890.));
#802= IFCAXIS2PLACEMENT3D(#801,#596,#653);
#803= IFCLOCALPLACEMENT(#30,#802);
#804= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,71.);
#805= IFCEXTRUDEDAREASOLID(#804,#658,#9,30.1061745233263);
#806= IFCSTYLEDITEM(#805,(#195),$);
#807= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#805));
#808= IFCREPRESENTATIONMAP(#10,#807);
#809= IFCMAPPEDITEM(#808,#247);
#810= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#809));
#811= IFCPRODUCTDEFINITIONSHAPE($,$,(#810));
#812= IFCMECHANICALFASTENER('1Td1iR003Gqp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#803,#811,'ID5d9c1b1b-0000-d0d3-3135-373035313136',20.,30.0061740875244);
#813= IFCCARTESIANPOINT((47524.9997174869,-554.150674997327,-1112.001));
#814= IFCAXIS2PLACEMENT3D(#813,#8,#7);
#815= IFCLOCALPLACEMENT(#30,#814);
#816= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,42.5);
#817= IFCEXTRUDEDAREASOLID(#816,#561,#9,16.1);
#818= IFCSTYLEDITEM(#817,(#195),$);
#819= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#817));
#820= IFCREPRESENTATIONMAP(#10,#819);
#821= IFCMAPPEDITEM(#820,#247);
#822= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#821));
#823= IFCPRODUCTDEFINITIONSHAPE($,$,(#822));
#824= IFCMECHANICALFASTENER('1Td1iR003Gp34rDp0rCJ4s',#5,'Bolt assembly',$,$,#815,#823,'ID5d9c1b1b-0000-d0cc-3135-373035313136',30.,16.);
#825= IFCCARTESIANPOINT((47275.0017174869,-554.150674997327,-1112.001));
#826= IFCAXIS2PLACEMENT3D(#825,#8,#7);
#827= IFCLOCALPLACEMENT(#30,#826);
#828= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,42.5);
#829= IFCEXTRUDEDAREASOLID(#828,#561,#9,16.1);
#830= IFCSTYLEDITEM(#829,(#195),$);
#831= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#829));
#832= IFCREPRESENTATIONMAP(#10,#831);
#833= IFCMAPPEDITEM(#832,#247);
#834= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#833));
#835= IFCPRODUCTDEFINITIONSHAPE($,$,(#834));
#836= IFCMECHANICALFASTENER('1Td1iR003GoJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#827,#835,'ID5d9c1b1b-0000-d0c9-3135-373035313136',30.,16.);
#837= IFCCARTESIANPOINT((47188.4976961945,-232.33006251714,-1110.));
#838= IFCAXIS2PLACEMENT3D(#837,#596,#597);
#839= IFCLOCALPLACEMENT(#30,#838);
#840= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#841= IFCEXTRUDEDAREASOLID(#840,#602,#9,30.1000000000098);
#842= IFCSTYLEDITEM(#841,(#195),$);
#843= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#841));
#844= IFCREPRESENTATIONMAP(#10,#843);
#845= IFCMAPPEDITEM(#844,#247);
#846= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#845));
#847= IFCPRODUCTDEFINITIONSHAPE($,$,(#846));
#848= IFCMECHANICALFASTENER('1Td1iR003GnZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#839,#847,'ID5d9c1b1b-0000-d0c6-3135-373035313136',20.,30.);
#849= IFCCARTESIANPOINT((47605.1872659515,-203.002074025746,-1110.));
#850= IFCAXIS2PLACEMENT3D(#849,#9,#620);
#851= IFCLOCALPLACEMENT(#30,#850);
#852= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,71.);
#853= IFCEXTRUDEDAREASOLID(#852,#625,#9,30.1063464563355);
#854= IFCSTYLEDITEM(#853,(#195),$);
#855= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#853));
#856= IFCREPRESENTATIONMAP(#10,#855);
#857= IFCMAPPEDITEM(#856,#247);
#858= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#857));
#859= IFCPRODUCTDEFINITIONSHAPE($,$,(#858));
#860= IFCMECHANICALFASTENER('1Td1iR003Gmp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#851,#859,'ID5d9c1b1b-0000-d0c3-3135-373035313136',20.,30.0063457489014);
#861= IFCCARTESIANPOINT((47611.502262432,-232.330074783564,-1110.));
#862= IFCAXIS2PLACEMENT3D(#861,#9,#640);
#863= IFCLOCALPLACEMENT(#30,#862);
#864= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#865= IFCEXTRUDEDAREASOLID(#864,#602,#9,30.1000000000079);
#866= IFCSTYLEDITEM(#865,(#195),$);
#867= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#865));
#868= IFCREPRESENTATIONMAP(#10,#867);
#869= IFCMAPPEDITEM(#868,#247);
#870= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#869));
#871= IFCPRODUCTDEFINITIONSHAPE($,$,(#870));
#872= IFCMECHANICALFASTENER('1Td1iR003Gm34rDp0rCJ4s',#5,'Bolt assembly',$,$,#863,#871,'ID5d9c1b1b-0000-d0c0-3135-373035313136',20.,30.);
#873= IFCCARTESIANPOINT((47194.8131339993,-203.00204940281,-1110.));
#874= IFCAXIS2PLACEMENT3D(#873,#596,#653);
#875= IFCLOCALPLACEMENT(#30,#874);
#876= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,71.);
#877= IFCEXTRUDEDAREASOLID(#876,#658,#9,30.1061745233263);
#878= IFCSTYLEDITEM(#877,(#195),$);
#879= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#877));
#880= IFCREPRESENTATIONMAP(#10,#879);
#881= IFCMAPPEDITEM(#880,#247);
#882= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#881));
#883= IFCPRODUCTDEFINITIONSHAPE($,$,(#882));
#884= IFCMECHANICALFASTENER('1Td1iR003GlJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#875,#883,'ID5d9c1b1b-0000-d0bd-3135-373035313136',20.,30.0061740875244);
#885= IFCLOCALPLACEMENT(#30,#10);
#886= IFCELEMENTASSEMBLY('1Td1iR001d_Z4rDp0rCJ4s',#5,'Steel Assembly',$,$,#885,$,'B/141(?)',.NOTDEFINED.,.RIGID_FRAME.);
#887= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(683.486173072009),$);
#888= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' +15.700'),$);
#889= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +15.790'),$);
#890= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit name',$,IFCLABEL('KIRIS'),$);
#891= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('B/141(?)'),$);
#892= IFCPROPERTYSET('2bM_K7YX5ECB8p4us6Zkq1',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#887,#888,#889,#890,#488,#891));
#893= IFCQUANTITYLENGTH('Width',$,$,90.);
#894= IFCELEMENTQUANTITY('2unf3iUFn06PceBqzZjGRT',#5,'BaseQuantities',$,$,(#893));
#895= IFCCARTESIANPOINT((47399.9998530384,-664.169369986517,15774.));
#896= IFCDIRECTION((0.,3.40599999947421E-006,-0.9999999999942));
#897= IFCAXIS2PLACEMENT3D(#895,#7,#896);
#898= IFCLOCALPLACEMENT(#885,#897);
#899= IFCCARTESIANPOINT((5.1111143109272E-005,14.9999999999129));
#900= IFCCARTESIANPOINT((15.,2.1725996346954E-011));
#901= IFCCARTESIANPOINT((43.0051002503642,6.22885767293202E-011));
#902= IFCCARTESIANPOINT((58.0051514475964,14.9999999999966));
#903= IFCCARTESIANPOINT((58.005697551407,175.000000000149));
#904= IFCCARTESIANPOINT((43.0057487486392,190.000000000047));
#905= IFCCARTESIANPOINT((15.0006474078127,190.000000000018));
#906= IFCCARTESIANPOINT((0.00059629666961194,175.00000000009));
#907= IFCPOLYLINE((#899,#900,#901,#902,#903,#904,#905,#906,#899));
#908= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL16*58',#907);
#909= IFCEXTRUDEDAREASOLID(#908,#63,#9,16.);
#910= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#909));
#911= IFCSTYLEDITEM(#909,(#53),$);
#912= IFCPRODUCTDEFINITIONSHAPE($,$,(#910));
#913= IFCDISCRETEACCESSORY('1Td1iR003GkZ4rDp0rCJ4s',#5,'DETAY','PL16*58','PL16*58',#898,#912,'P/429(?)');
#914= IFCDISCRETEACCESSORYTYPE('18fmZExVD7x9K$44iJFdFC',#5,'DETAY',$,$,$,$,$,$);
#915= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +15.716'),$);
#916= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +15.774'),$);
#917= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/429(?)'),$);
#918= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('B/141(?)'),$);
#919= IFCPROPERTYSINGLEVALUE('Phase',$,IFCINTEGER(1),$);
#920= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PL16*58'),$);
#921= IFCPROPERTYSINGLEVALUE('Name',$,IFCLABEL('DETAY'),$);
#922= IFCPROPERTYSET('03ZrKXqQDB99o7fhdCSHIf',#5,'Tekla Common','Common Properties to Shared building elements',(#915,#916,#917,#918,#74,#75,#919,#77,#78,#920,#921));
#923= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(683.486173072009),$);
#924= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(1.32771372538392),$);
#925= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(1.38423443155487),$);
#926= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(1.32771372538392),$);
#927= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000169135506418334),$);
#928= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000169135506418334),$);
#929= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000169135506418334),$);
#930= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00256000000001765),$);
#931= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(21.4773305438362),$);
#932= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0285157465476587),$);
#933= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.011020974773526),$);
#934= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(58.00510125439),$);
#935= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(190.000095425951),$);
#936= IFCPROPERTYSET('1lyHr1ejH0Hw$k9zuvuQrm',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#923,#924,#925,#926,#927,#928,#929,#930,#931,#932,#933,#934,#94,#935));
#937= IFCQUANTITYLENGTH('Width',$,$,58.00510125439);
#938= IFCQUANTITYAREA('NetArea',$,$,0.0285157465476587);
#939= IFCQUANTITYAREA('GrossArea',$,$,0.011020974773526);
#940= IFCQUANTITYVOLUME('NetVolume',$,$,0.000169135506418334);
#941= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000169135506418334);
#942= IFCELEMENTQUANTITY('2UrzWgccPBSgFGMcyGGcIC',#5,'BaseQuantities',$,$,(#937,#938,#939,#100,#940,#941));
#943= IFCCARTESIANPOINT((47150.0008530384,-664.169369986517,15774.));
#944= IFCAXIS2PLACEMENT3D(#943,#7,#896);
#945= IFCLOCALPLACEMENT(#885,#944);
#946= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#909));
#947= IFCPRODUCTDEFINITIONSHAPE($,$,(#946));
#948= IFCDISCRETEACCESSORY('1Td1iR003GjZ4rDp0rCJ4s',#5,'DETAY','PL16*58','PL16*58',#945,#947,'P/429(?)');
#949= IFCCARTESIANPOINT((47649.9990642585,-474.169160021327,15773.9949214892));
#950= IFCAXIS2PLACEMENT3D(#949,#185,#596);
#951= IFCLOCALPLACEMENT(#885,#950);
#952= IFCCARTESIANPOINT((43.,9.92456691541332E-011));
#953= IFCCARTESIANPOINT((58.0000048185549,15.0000000001331));
#954= IFCCARTESIANPOINT((58.000056216474,175.000000000113));
#955= IFCCARTESIANPOINT((43.0000610350289,190.000000000084));
#956= IFCCARTESIANPOINT((15.0000609015042,190.000000000031));
#957= IFCCARTESIANPOINT((5.60934906963287E-005,175.000000000004));
#958= IFCPOLYLINE((#899,#900,#952,#953,#954,#955,#956,#957,#899));
#959= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL16*58',#958);
#960= IFCEXTRUDEDAREASOLID(#959,#63,#9,16.);
#961= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#960));
#962= IFCSTYLEDITEM(#960,(#53),$);
#963= IFCPRODUCTDEFINITIONSHAPE($,$,(#961));
#964= IFCDISCRETEACCESSORY('1Td1iR003GiZ4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#951,#963,'P/431(?)');
#965= IFCDISCRETEACCESSORYTYPE('1P1RvEPuvEohMO4vWVrPP9',#5,'PLATE',$,$,$,$,$,$);
#966= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/431(?)'),$);
#967= IFCPROPERTYSINGLEVALUE('Name',$,IFCLABEL('PLATE'),$);
#968= IFCPROPERTYSET('0YVnuDr49C0uAOs0_LMxQe',#5,'Tekla Common','Common Properties to Shared building elements',(#915,#916,#966,#918,#74,#75,#919,#77,#78,#920,#967));
#969= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(1.32759200159317),$);
#970= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(1.38411206831702),$);
#971= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(1.32759200159317),$);
#972= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(21.4777168084516),$);
#973= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0285136450473835),$);
#974= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0110200005439253),$);
#975= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(58.0000001230401),$);
#976= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(190.000008974961),$);
#977= IFCPROPERTYSET('1TK0J1M250zRQQr6Q$PvL5',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#923,#969,#970,#971,#927,#928,#929,#930,#972,#973,#974,#975,#94,#976));
#978= IFCQUANTITYLENGTH('Width',$,$,58.0000001230401);
#979= IFCQUANTITYAREA('NetArea',$,$,0.0285136450473835);
#980= IFCQUANTITYAREA('GrossArea',$,$,0.0110200005439253);
#981= IFCQUANTITYVOLUME('NetVolume',$,$,0.000169120000202952);
#982= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000169120000202952);
#983= IFCELEMENTQUANTITY('21asOP7uf1BRiqrEqdUMCq',#5,'BaseQuantities',$,$,(#978,#979,#980,#100,#981,#982));
#984= IFCLOCALPLACEMENT(#30,#10);
#985= IFCELEMENTASSEMBLY('1Td1iR003F_Z4rDp0rCJ4s',#5,'Steel Assembly',$,$,#984,$,'A/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#986= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(62.9646134082424),$);
#987= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' +15.670'),$);
#988= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +15.910'),$);
#989= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit name',$,IFCLABEL('ANCHOR'),$);
#990= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('A/0(?)'),$);
#991= IFCPROPERTYSET('3n7AoCVRPEhuKopLl46$PJ',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#986,#987,#988,#989,#488,#990));
#992= IFCQUANTITYLENGTH('Width',$,$,240.);
#993= IFCELEMENTQUANTITY('3qi7lk2Xf7ludjmWvBI6DC',#5,'BaseQuantities',$,$,(#992));
#994= IFCCARTESIANPOINT((47330.0009742969,-409.152085224177,15707.));
#995= IFCAXIS2PLACEMENT3D(#994,#9,#7);
#996= IFCLOCALPLACEMENT(#984,#995);
#997= IFCCARTESIANPOINT((139.998428344727,-6.21355411567492E-010));
#998= IFCCARTESIANPOINT((139.998443604374,178.792724608685));
#999= IFCCARTESIANPOINT((-7.3110350058414E-006,178.792724609377));
#1000= IFCPOLYLINE((#54,#997,#998,#999,#54,#54));
#1001= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL16*140',#1000);
#1002= IFCEXTRUDEDAREASOLID(#1001,#63,#9,16.);
#1003= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1002));
#1004= IFCSTYLEDITEM(#1002,(#53),$);
#1005= IFCPRODUCTDEFINITIONSHAPE($,$,(#1003));
#1006= IFCDISCRETEACCESSORY('1Td1iR003Ghp4rDp0rCJ4s',#5,'PLATE','PL16*140','PL16*140',#996,#1005,'P/0(?)');
#1007= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +15.699'),$);
#1008= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +15.715'),$);
#1009= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/0(?)'),$);
#1010= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('A/0(?)'),$);
#1011= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PL16*140'),$);
#1012= IFCPROPERTYSET('1s$nMA$kH4ewyjaQtmgNoP',#5,'Tekla Common','Common Properties to Shared building elements',(#1007,#1008,#1009,#1010,#74,#75,#919,#77,#78,#1011,#967));
#1013= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(62.9646134082424),$);
#1014= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(3.14385622929193),$);
#1015= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(3.14385658338631),$);
#1016= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(3.14385622929193),$);
#1017= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000400491239400246),$);
#1018= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000400491239400246),$);
#1019= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000400491239400246),$);
#1020= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.0250307024625154),$);
#1021= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(19.1684090446669),$);
#1022= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0602627221806917),$);
#1023= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0250307052817382),$);
#1024= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(139.998450915402),$);
#1025= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(178.792730334307),$);
#1026= IFCPROPERTYSET('0R3YCbfpD5BvYapw1xhswd',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1013,#1014,#1015,#1016,#1017,#1018,#1019,#1020,#1021,#1022,#1023,#1024,#94,#1025));
#1027= IFCQUANTITYLENGTH('Width',$,$,139.998450915402);
#1028= IFCQUANTITYAREA('NetArea',$,$,0.0602627221806917);
#1029= IFCQUANTITYAREA('GrossArea',$,$,0.0250307052817382);
#1030= IFCQUANTITYVOLUME('NetVolume',$,$,0.000400491239400246);
#1031= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000400491239400246);
#1032= IFCELEMENTQUANTITY('1JTSQYXov39QQRCy1VCkAl',#5,'BaseQuantities',$,$,(#1027,#1028,#1029,#100,#1030,#1031));
#1033= IFCCARTESIANPOINT((47443.9994010579,-401.152088433781,15790.));
#1034= IFCAXIS2PLACEMENT3D(#1033,#501,#185);
#1035= IFCLOCALPLACEMENT(#984,#1034);
#1036= IFCCARTESIANPOINT((0.,10.));
#1037= IFCCARTESIANPOINT((10.,0.));
#1038= IFCCARTESIANPOINT((77.9984283447266,0.));
#1039= IFCCARTESIANPOINT((87.9984283447266,10.));
#1040= IFCCARTESIANPOINT((87.9984283447266,65.0051040649414));
#1041= IFCCARTESIANPOINT((77.9984283447266,75.0051040649414));
#1042= IFCCARTESIANPOINT((10.,75.0051040649414));
#1043= IFCCARTESIANPOINT((0.,65.0051040649414));
#1044= IFCPOLYLINE((#1036,#1037,#1038,#1039,#1040,#1041,#1042,#1043,#1036));
#1045= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL16*75',#1044);
#1046= IFCEXTRUDEDAREASOLID(#1045,#63,#9,16.);
#1047= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1046));
#1048= IFCSTYLEDITEM(#1046,(#53),$);
#1049= IFCPRODUCTDEFINITIONSHAPE($,$,(#1047));
#1050= IFCDISCRETEACCESSORY('1Td1iR003Gh34rDp0rCJ4s',#5,'PLATE','PL16*75','PL16*75',#1035,#1049,'P/0(?)');
#1051= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +15.715'),$);
#1052= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +15.790'),$);
#1053= IFCPROPERTYSET('16uqSJMur4c9h3$rrmYkin',#5,'Tekla Common','Common Properties to Shared building elements',(#1051,#1052,#1009,#1010,#74,#75,#919,#77,#78,#79,#967));
#1054= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.803881608208766),$);
#1055= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(0.829001608209384),$);
#1056= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.803881608208766),$);
#1057= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.00010240530040876),$);
#1058= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.00010240530040876),$);
#1059= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.00010240530040876),$);
#1060= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00108797485351563),$);
#1061= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(21.945858803056),$);
#1062= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0176418722681232),$);
#1063= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.00660033127555242),$);
#1064= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(75.0051040649414),$);
#1065= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(87.998428344792),$);
#1066= IFCPROPERTYSET('2DWFafYFfD_PGco0JtnoVi',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1013,#1054,#1055,#1056,#1057,#1058,#1059,#1060,#1061,#1062,#1063,#1064,#94,#1065));
#1067= IFCQUANTITYLENGTH('Width',$,$,75.0051040649414);
#1068= IFCQUANTITYAREA('NetArea',$,$,0.0176418722681232);
#1069= IFCQUANTITYAREA('GrossArea',$,$,0.00660033127555242);
#1070= IFCQUANTITYVOLUME('NetVolume',$,$,0.00010240530040876);
#1071= IFCQUANTITYVOLUME('GrossVolume',$,$,0.00010240530040876);
#1072= IFCELEMENTQUANTITY('2n$T$$GEv5VO0B5YD1ORqm',#5,'BaseQuantities',$,$,(#1067,#1068,#1069,#100,#1070,#1071));
#1073= IFCCARTESIANPOINT((47451.9994009154,-409.152092881741,15714.995));
#1074= IFCAXIS2PLACEMENT3D(#1073,#185,#9);
#1075= IFCLOCALPLACEMENT(#984,#1074);
#1076= IFCCARTESIANPOINT((75.004997253418,-1.25055521493778E-012));
#1077= IFCCARTESIANPOINT((75.004997253418,179.913116455084));
#1078= IFCCARTESIANPOINT((4.36557456851006E-010,179.912734985357));
#1079= IFCPOLYLINE((#54,#1076,#1077,#1078,#54,#54));
#1080= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL16*75',#1079);
#1081= IFCEXTRUDEDAREASOLID(#1080,#63,#9,16.);
#1082= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1081));
#1083= IFCSTYLEDITEM(#1081,(#53),$);
#1084= IFCPRODUCTDEFINITIONSHAPE($,$,(#1082));
#1085= IFCDISCRETEACCESSORY('1Td1iR003GgJ4rDp0rCJ4s',#5,'PLATE','PL16*75','PL16*75',#1075,#1084,'P/0(?)');
#1086= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(1.69489268353204),$);
#1087= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(1.69489448038088),$);
#1088= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(1.69489268353204),$);
#1089= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000215909895991343),$);
#1090= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000215909895991343),$);
#1091= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000215909895991343),$);
#1092= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00287860986328128),$);
#1093= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(20.736481356945),$);
#1094= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0351461105340847),$);
#1095= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0134943828055802),$);
#1096= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(75.004997253418),$);
#1097= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(16.0000000008731),$);
#1098= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(179.913116455254),$);
#1099= IFCPROPERTYSET('2AL_WWLgLDFxuLjv$xrYYU',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1013,#1086,#1087,#1088,#1089,#1090,#1091,#1092,#1093,#1094,#1095,#1096,#1097,#1098));
#1100= IFCQUANTITYLENGTH('Width',$,$,75.004997253418);
#1101= IFCQUANTITYAREA('NetArea',$,$,0.0351461105340847);
#1102= IFCQUANTITYAREA('GrossArea',$,$,0.0134943828055802);
#1103= IFCQUANTITYVOLUME('NetVolume',$,$,0.000215909895991343);
#1104= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000215909895991343);
#1105= IFCELEMENTQUANTITY('0iI5lTEtj5TuPxGOC9L4qC',#5,'BaseQuantities',$,$,(#1100,#1101,#1102,#100,#1103,#1104));
#1106= IFCCARTESIANPOINT((47348.0009742969,-409.152086581707,15714.995));
#1107= IFCAXIS2PLACEMENT3D(#1106,#185,#9);
#1108= IFCLOCALPLACEMENT(#984,#1107);
#1109= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1081));
#1110= IFCPRODUCTDEFINITIONSHAPE($,$,(#1109));
#1111= IFCDISCRETEACCESSORY('1Td1iR003GfZ4rDp0rCJ4s',#5,'PLATE','PL16*75','PL16*75',#1108,#1110,'P/0(?)');
#1112= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(1.69489268353216),$);
#1113= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(1.69489268353216),$);
#1114= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000215909895991358),$);
#1115= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000215909895991358),$);
#1116= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000215909895991358),$);
#1117= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(16.0000000008877),$);
#1118= IFCPROPERTYSET('2NXXwLV1j11QK912m7rxHc',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1013,#1112,#1087,#1113,#1114,#1115,#1116,#1092,#1093,#1094,#1095,#1096,#1117,#1098));
#1119= IFCQUANTITYAREA('NetArea',$,$,0.0351461105340846);
#1120= IFCQUANTITYAREA('GrossArea',$,$,0.0134943828055802);
#1121= IFCQUANTITYVOLUME('NetVolume',$,$,0.000215909895991358);
#1122= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000215909895991358);
#1123= IFCELEMENTQUANTITY('1bSm_nVPD8GgGERjFfBEUj',#5,'BaseQuantities',$,$,(#1100,#1119,#1120,#100,#1121,#1122));
#1124= IFCCARTESIANPOINT((47071.0886298035,-157.192275561196,15790.));
#1125= IFCDIRECTION((0.999999990939266,0.000134615999991816,0.));
#1126= IFCAXIS2PLACEMENT3D(#1124,#9,#1125);
#1127= IFCLOCALPLACEMENT(#984,#1126);
#1128= IFCRECTANGLEPROFILEDEF(.AREA.,'PLT30*240',#197,30.,240.);
#1129= IFCDIRECTION((0.342612104600848,-0.939476953299536,0.));
#1130= IFCDIRECTION((-0.939476953299536,-0.342612104600848,0.));
#1131= IFCCARTESIANPOINT((658.11673948567,2.8421709430404E-014,3.63797880709171E-012));
#1132= IFCAXIS2PLACEMENT3D(#1131,#1130,#1129);
#1133= IFCCARTESIANPOINT((-960.44,0.,0.));
#1134= IFCAXIS1PLACEMENT(#1133,#501);
#1135= IFCREVOLVEDAREASOLID(#1128,#1132,#1134,0.699391749414444);
#1136= IFCDIRECTION((-0.447225139926483,0.894421418693525));
#1137= IFCCARTESIANPOINT((11.8584938048189,-23.7162223353947));
#1138= IFCAXIS2PLACEMENT2D(#1137,#1136);
#1139= IFCCIRCLE(#1138,26.5157137784522);
#1140= IFCTRIMMEDCURVE(#1139,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.42863508547139)),.F.,.PARAMETER.);
#1141= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#1140);
#1142= IFCCARTESIANPOINT((37.9462547300482,-18.9715614319284));
#1143= IFCCARTESIANPOINT((28.4606113433056,9.48649501793261));
#1144= IFCPOLYLINE((#1142,#1143,#54));
#1145= IFCCOMPOSITECURVESEGMENT(.DISCONTINUOUS.,.T.,#1144);
#1146= IFCCOMPOSITECURVE((#1141,#1145),.F.);
#1147= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#1146);
#1148= IFCDIRECTION((0.297078172382073,-0.108339611433356,-0.948687033793862));
#1149= IFCDIRECTION((0.342612078871954,0.939476962682448,1.2013412348244E-009));
#1150= IFCCARTESIANPOINT((-22.2697855132165,-61.0660024333356,-90.0080000600832));
#1151= IFCAXIS2PLACEMENT3D(#1150,#1149,#1148);
#1152= IFCEXTRUDEDAREASOLID(#1147,#1151,#9,100.);
#1153= IFCBOOLEANRESULT(.DIFFERENCE.,#1135,#1152);
#1154= IFCCIRCLE(#1138,26.5157137784333);
#1155= IFCTRIMMEDCURVE(#1154,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.42863508546918)),.F.,.PARAMETER.);
#1156= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#1155);
#1157= IFCCOMPOSITECURVE((#1156,#1145),.F.);
#1158= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#1157);
#1159= IFCDIRECTION((0.297078172382051,-0.108339611433354,0.948687033793869));
#1160= IFCDIRECTION((-0.342612078871956,-0.939476962682448,1.20133590575389E-009));
#1161= IFCCARTESIANPOINT((11.9914223735861,32.8816938348147,89.999999939955));
#1162= IFCAXIS2PLACEMENT3D(#1161,#1160,#1159);
#1163= IFCEXTRUDEDAREASOLID(#1158,#1162,#9,100.);
#1164= IFCBOOLEANRESULT(.DIFFERENCE.,#1153,#1163);
#1165= IFCCIRCLE(#1138,26.515713778537);
#1166= IFCTRIMMEDCURVE(#1165,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.42863508546059)),.F.,.PARAMETER.);
#1167= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#1166);
#1168= IFCCOMPOSITECURVE((#1167,#1145),.F.);
#1169= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#1168);
#1170= IFCDIRECTION((-0.297107336120191,-0.108259607562564,-0.948687033849395));
#1171= IFCDIRECTION((0.342359074491789,-0.939569190700251,-7.96621907328543E-010));
#1172= IFCCARTESIANPOINT((646.13196261912,32.9027758611622,-90.0079999601851));
#1173= IFCAXIS2PLACEMENT3D(#1172,#1171,#1170);
#1174= IFCEXTRUDEDAREASOLID(#1169,#1173,#9,100.);
#1175= IFCBOOLEANRESULT(.DIFFERENCE.,#1164,#1174);
#1176= IFCCIRCLE(#1138,26.5157137785423);
#1177= IFCTRIMMEDCURVE(#1176,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.42863508546071)),.F.,.PARAMETER.);
#1178= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#1177);
#1179= IFCCOMPOSITECURVE((#1178,#1145),.F.);
#1180= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#1179);
#1181= IFCDIRECTION((-0.297107336120126,-0.108259607562564,0.948687033849416));
#1182= IFCDIRECTION((-0.342359074491796,0.939569190700249,-7.96600549413107E-010));
#1183= IFCCARTESIANPOINT((680.367870068692,-61.0541432089575,90.0000000398519));
#1184= IFCAXIS2PLACEMENT3D(#1183,#1182,#1181);
#1185= IFCEXTRUDEDAREASOLID(#1180,#1184,#9,100.);
#1186= IFCBOOLEANRESULT(.DIFFERENCE.,#1175,#1185);
#1187= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#1186));
#1188= IFCSTYLEDITEM(#1135,(#53),$);
#1189= IFCPRODUCTDEFINITIONSHAPE($,$,(#1187));
#1190= IFCDISCRETEACCESSORY('1Td1iR003Gbp4rDp0rCJ4s',#5,'ANKRAJ','PLT30*240','PLT30*240',#1127,#1189,'P/370(?)');
#1191= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +15.670'),$);
#1192= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +15.910'),$);
#1193= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/370(?)'),$);
#1194= IFCPROPERTYSINGLEVALUE('Class',$,IFCLABEL('1'),$);
#1195= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PLT30*240'),$);
#1196= IFCPROPERTYSET('28NgjvynD4y8ui4H173fgi',#5,'Tekla Common','Common Properties to Shared building elements',(#1191,#1192,#1193,#1010,#74,#75,#919,#1194,#78,#1195,#80));
#1197= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(37.8234884324625),$);
#1198= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(37.9658298434669),$);
#1199= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(37.8234884324625),$);
#1200= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.00481827878120541),$);
#1201= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.00483629817736627),$);
#1202= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.00481827878120541),$);
#1203= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.0183512500444),$);
#1204= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(9.90376532231764),$);
#1205= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.374594953106504),$);
#1206= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.377128026675448),$);
#1207= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(240.),$);
#1208= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(30.),$);
#1209= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(671.723811809393),$);
#1210= IFCPROPERTYSET('3Ly4tRhRX8qu7tJPYoo1$a',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1013,#1197,#1198,#1199,#1200,#1201,#1202,#1203,#1204,#1205,#1206,#1207,#1208,#1209));
#1211= IFCQUANTITYLENGTH('Length',$,$,671.723811809393);
#1212= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.374594953106504);
#1213= IFCQUANTITYVOLUME('NetVolume',$,$,0.00481827878120541);
#1214= IFCQUANTITYWEIGHT('NetWeight',$,$,37.8234884324625);
#1215= IFCELEMENTQUANTITY('3doMMFhbD0bR6NlLSFoEW3',#5,'BaseQuantities',$,$,(#1211,#1212,#1213,#1214));
#1216= IFCLOCALPLACEMENT(#30,#10);
#1217= IFCELEMENTASSEMBLY('1Td1iR002izJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#1216,$,'B/141(?)',.NOTDEFINED.,.RIGID_FRAME.);
#1218= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' +10.500'),$);
#1219= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +10.590'),$);
#1220= IFCPROPERTYSET('3SXSaSNuf4M9E63cRuI4qG',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#887,#1218,#1219,#890,#488,#891));
#1221= IFCCARTESIANPOINT((47399.9998530384,-664.169369986517,10574.));
#1222= IFCAXIS2PLACEMENT3D(#1221,#7,#896);
#1223= IFCLOCALPLACEMENT(#1216,#1222);
#1224= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#909));
#1225= IFCPRODUCTDEFINITIONSHAPE($,$,(#1224));
#1226= IFCDISCRETEACCESSORY('1Td1iR003Gap4rDp0rCJ4s',#5,'DETAY','PL16*58','PL16*58',#1223,#1225,'P/429(?)');
#1227= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +10.516'),$);
#1228= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +10.574'),$);
#1229= IFCPROPERTYSET('2HhbThCdbFbh1CGb7wCcWA',#5,'Tekla Common','Common Properties to Shared building elements',(#1227,#1228,#917,#918,#74,#75,#919,#77,#78,#920,#921));
#1230= IFCCARTESIANPOINT((47150.0008530384,-664.169369986517,10574.));
#1231= IFCAXIS2PLACEMENT3D(#1230,#7,#896);
#1232= IFCLOCALPLACEMENT(#1216,#1231);
#1233= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#909));
#1234= IFCPRODUCTDEFINITIONSHAPE($,$,(#1233));
#1235= IFCDISCRETEACCESSORY('1Td1iR003GZp4rDp0rCJ4s',#5,'DETAY','PL16*58','PL16*58',#1232,#1234,'P/429(?)');
#1236= IFCCARTESIANPOINT((47649.9990642585,-474.169160021327,10573.9949214892));
#1237= IFCAXIS2PLACEMENT3D(#1236,#185,#596);
#1238= IFCLOCALPLACEMENT(#1216,#1237);
#1239= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#960));
#1240= IFCPRODUCTDEFINITIONSHAPE($,$,(#1239));
#1241= IFCDISCRETEACCESSORY('1Td1iR003GYp4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#1238,#1240,'P/431(?)');
#1242= IFCPROPERTYSET('1qRlufYevBDQE4xTsyTemb',#5,'Tekla Common','Common Properties to Shared building elements',(#1227,#1228,#966,#918,#74,#75,#919,#77,#78,#920,#967));
#1243= IFCLOCALPLACEMENT(#30,#10);
#1244= IFCELEMENTASSEMBLY('1Td1iR003Fmp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#1243,$,'A/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#1245= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(62.9646134082425),$);
#1246= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' +10.470'),$);
#1247= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +10.710'),$);
#1248= IFCPROPERTYSET('12bVKXN8rCAf$1u976h0If',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1245,#1246,#1247,#989,#488,#990));
#1249= IFCCARTESIANPOINT((47330.0009742969,-409.152085224177,10507.));
#1250= IFCAXIS2PLACEMENT3D(#1249,#9,#7);
#1251= IFCLOCALPLACEMENT(#1243,#1250);
#1252= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1002));
#1253= IFCPRODUCTDEFINITIONSHAPE($,$,(#1252));
#1254= IFCDISCRETEACCESSORY('1Td1iR003GY34rDp0rCJ4s',#5,'PLATE','PL16*140','PL16*140',#1251,#1253,'P/0(?)');
#1255= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +10.499'),$);
#1256= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +10.515'),$);
#1257= IFCPROPERTYSET('3LahFEIIH8ZQxLDOGKaZPx',#5,'Tekla Common','Common Properties to Shared building elements',(#1255,#1256,#1009,#1010,#74,#75,#919,#77,#78,#1011,#967));
#1258= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(62.9646134082425),$);
#1259= IFCPROPERTYSET('1JiFtfIkf0RfAXf68LX8JI',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1258,#1014,#1015,#1016,#1017,#1018,#1019,#1020,#1021,#1022,#1023,#1024,#94,#1025));
#1260= IFCCARTESIANPOINT((47443.9994010579,-401.152088433781,10590.));
#1261= IFCAXIS2PLACEMENT3D(#1260,#501,#185);
#1262= IFCLOCALPLACEMENT(#1243,#1261);
#1263= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1046));
#1264= IFCPRODUCTDEFINITIONSHAPE($,$,(#1263));
#1265= IFCDISCRETEACCESSORY('1Td1iR003GXJ4rDp0rCJ4s',#5,'PLATE','PL16*75','PL16*75',#1262,#1264,'P/0(?)');
#1266= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +10.515'),$);
#1267= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +10.590'),$);
#1268= IFCPROPERTYSET('0eYl7V7O9D69du6tC0zQ5g',#5,'Tekla Common','Common Properties to Shared building elements',(#1266,#1267,#1009,#1010,#74,#75,#919,#77,#78,#79,#967));
#1269= IFCPROPERTYSET('22mxxOY2v2ivU6OC13poK7',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1258,#1054,#1055,#1056,#1057,#1058,#1059,#1060,#1061,#1062,#1063,#1064,#94,#1065));
#1270= IFCCARTESIANPOINT((47451.9994009154,-409.152092881741,10514.995));
#1271= IFCAXIS2PLACEMENT3D(#1270,#185,#9);
#1272= IFCLOCALPLACEMENT(#1243,#1271);
#1273= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1081));
#1274= IFCPRODUCTDEFINITIONSHAPE($,$,(#1273));
#1275= IFCDISCRETEACCESSORY('1Td1iR003GWZ4rDp0rCJ4s',#5,'PLATE','PL16*75','PL16*75',#1272,#1274,'P/0(?)');
#1276= IFCPROPERTYSET('3IwQCImvL0seMqNTPFE$ol',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1258,#1086,#1087,#1088,#1089,#1090,#1091,#1092,#1093,#1094,#1095,#1096,#1097,#1098));
#1277= IFCCARTESIANPOINT((47348.0009742969,-409.152086581707,10514.995));
#1278= IFCAXIS2PLACEMENT3D(#1277,#185,#9);
#1279= IFCLOCALPLACEMENT(#1243,#1278);
#1280= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1081));
#1281= IFCPRODUCTDEFINITIONSHAPE($,$,(#1280));
#1282= IFCDISCRETEACCESSORY('1Td1iR003GVp4rDp0rCJ4s',#5,'PLATE','PL16*75','PL16*75',#1279,#1281,'P/0(?)');
#1283= IFCPROPERTYSET('2gnr79OHf02QVLq7qIa4bs',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1258,#1112,#1087,#1113,#1114,#1115,#1116,#1092,#1093,#1094,#1095,#1096,#1117,#1098));
#1284= IFCCARTESIANPOINT((47071.0886298035,-157.192275561196,10590.));
#1285= IFCAXIS2PLACEMENT3D(#1284,#9,#1125);
#1286= IFCLOCALPLACEMENT(#1243,#1285);
#1287= IFCBOOLEANRESULT(.DIFFERENCE.,#1135,#1152);
#1288= IFCBOOLEANRESULT(.DIFFERENCE.,#1287,#1163);
#1289= IFCBOOLEANRESULT(.DIFFERENCE.,#1288,#1174);
#1290= IFCBOOLEANRESULT(.DIFFERENCE.,#1289,#1185);
#1291= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#1290));
#1292= IFCPRODUCTDEFINITIONSHAPE($,$,(#1291));
#1293= IFCDISCRETEACCESSORY('1Td1iR003GS34rDp0rCJ4s',#5,'ANKRAJ','PLT30*240','PLT30*240',#1286,#1292,'P/370(?)');
#1294= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +10.470'),$);
#1295= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +10.710'),$);
#1296= IFCPROPERTYSET('1YL7Sxqb5ALxz6NN9CVgYi',#5,'Tekla Common','Common Properties to Shared building elements',(#1294,#1295,#1193,#1010,#74,#75,#919,#1194,#78,#1195,#80));
#1297= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(37.8234884324625),$);
#1298= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(37.8234884324625),$);
#1299= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.00481827878120541),$);
#1300= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.00481827878120541),$);
#1301= IFCPROPERTYSET('12b5P1MPX7eB8sZS4etcQS',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1258,#1297,#1198,#1298,#1299,#1201,#1300,#1203,#1204,#1205,#1206,#1207,#1208,#1209));
#1302= IFCQUANTITYVOLUME('NetVolume',$,$,0.00481827878120541);
#1303= IFCQUANTITYWEIGHT('NetWeight',$,$,37.8234884324625);
#1304= IFCELEMENTQUANTITY('3I85m7z$r17wBxNK0JmnFN',#5,'BaseQuantities',$,$,(#1211,#1212,#1302,#1303));
#1305= IFCLOCALPLACEMENT(#30,#10);
#1306= IFCELEMENTASSEMBLY('1Td1iR002j634rDp0rCJ4s',#5,'Steel Assembly',$,$,#1305,$,'B/142(?)',.NOTDEFINED.,.RIGID_FRAME.);
#1307= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(678.742947376047),$);
#1308= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' +4.800'),$);
#1309= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +4.890'),$);
#1310= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('B/142(?)'),$);
#1311= IFCPROPERTYSET('1porixx911rxCxnGwtUXX6',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1307,#1308,#1309,#890,#488,#1310));
#1312= IFCCARTESIANPOINT((47399.9998530384,-664.169369986517,4874.));
#1313= IFCAXIS2PLACEMENT3D(#1312,#7,#896);
#1314= IFCLOCALPLACEMENT(#1305,#1313);
#1315= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#909));
#1316= IFCPRODUCTDEFINITIONSHAPE($,$,(#1315));
#1317= IFCDISCRETEACCESSORY('1Td1iR003GR34rDp0rCJ4s',#5,'DETAY','PL16*58','PL16*58',#1314,#1316,'P/429(?)');
#1318= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +4.816'),$);
#1319= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +4.874'),$);
#1320= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('B/142(?)'),$);
#1321= IFCPROPERTYSET('209lNKAhnE7B91vWYgMGgI',#5,'Tekla Common','Common Properties to Shared building elements',(#1318,#1319,#917,#1320,#74,#75,#919,#77,#78,#920,#921));
#1322= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(678.742947376047),$);
#1323= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(21.4773305438363),$);
#1324= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(190.000095426002),$);
#1325= IFCPROPERTYSET('1jGQXroyz2FuuE5fq2kGvX',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1322,#924,#925,#926,#927,#928,#929,#930,#1323,#932,#933,#934,#94,#1324));
#1326= IFCQUANTITYLENGTH('Width',$,$,58.0051012542808);
#1327= IFCQUANTITYAREA('NetArea',$,$,0.0285157465476584);
#1328= IFCQUANTITYAREA('GrossArea',$,$,0.0110209747735083);
#1329= IFCQUANTITYVOLUME('NetVolume',$,$,0.000169135506418332);
#1330= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000169135506418332);
#1331= IFCELEMENTQUANTITY('2Nny4gS0H2MABWS27tS9Lx',#5,'BaseQuantities',$,$,(#1326,#1327,#1328,#100,#1329,#1330));
#1332= IFCCARTESIANPOINT((47150.0008530384,-664.169369986517,4874.));
#1333= IFCAXIS2PLACEMENT3D(#1332,#7,#896);
#1334= IFCLOCALPLACEMENT(#1305,#1333);
#1335= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#909));
#1336= IFCPRODUCTDEFINITIONSHAPE($,$,(#1335));
#1337= IFCDISCRETEACCESSORY('1Td1iR003GQ34rDp0rCJ4s',#5,'DETAY','PL16*58','PL16*58',#1334,#1336,'P/429(?)');
#1338= IFCCARTESIANPOINT((47649.9990642585,-474.169160021327,4873.9949214892));
#1339= IFCAXIS2PLACEMENT3D(#1338,#185,#596);
#1340= IFCLOCALPLACEMENT(#1305,#1339);
#1341= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#960));
#1342= IFCPRODUCTDEFINITIONSHAPE($,$,(#1341));
#1343= IFCDISCRETEACCESSORY('1Td1iR003GP34rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#1340,#1342,'P/431(?)');
#1344= IFCPROPERTYSET('2hwHZuL5X9XQxnaZDjYMXm',#5,'Tekla Common','Common Properties to Shared building elements',(#1318,#1319,#966,#1320,#74,#75,#919,#77,#78,#920,#967));
#1345= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(1.38411206831716),$);
#1346= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(21.4777168084517),$);
#1347= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0110200005439265),$);
#1348= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(190.000008974986),$);
#1349= IFCPROPERTYSET('3hvKR0aYDAO8thaI975Jr4',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1322,#969,#1345,#971,#927,#928,#929,#930,#1346,#973,#1347,#975,#94,#1348));
#1350= IFCQUANTITYLENGTH('Width',$,$,58.0000001230383);
#1351= IFCQUANTITYAREA('NetArea',$,$,0.0285136450473827);
#1352= IFCQUANTITYAREA('GrossArea',$,$,0.0110200005439265);
#1353= IFCQUANTITYVOLUME('NetVolume',$,$,0.000169120000202946);
#1354= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000169120000202946);
#1355= IFCELEMENTQUANTITY('1yJLDldC1CPgIyQxs8Cqwg',#5,'BaseQuantities',$,$,(#1350,#1351,#1352,#100,#1353,#1354));
#1356= IFCLOCALPLACEMENT(#30,#10);
#1357= IFCELEMENTASSEMBLY('1Td1iR003FZ34rDp0rCJ4s',#5,'Steel Assembly',$,$,#1356,$,'A/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#1358= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' +4.770'),$);
#1359= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +5.010'),$);
#1360= IFCPROPERTYSET('3TxfZ3kzX0z86GlsStVzqB',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#986,#1358,#1359,#989,#488,#990));
#1361= IFCCARTESIANPOINT((47330.0009742969,-409.152085224177,4807.));
#1362= IFCAXIS2PLACEMENT3D(#1361,#9,#7);
#1363= IFCLOCALPLACEMENT(#1356,#1362);
#1364= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1002));
#1365= IFCPRODUCTDEFINITIONSHAPE($,$,(#1364));
#1366= IFCDISCRETEACCESSORY('1Td1iR003GOJ4rDp0rCJ4s',#5,'PLATE','PL16*140','PL16*140',#1363,#1365,'P/0(?)');
#1367= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +4.799'),$);
#1368= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +4.815'),$);
#1369= IFCPROPERTYSET('2P7iY1XWzEEPY5nlZmmOe5',#5,'Tekla Common','Common Properties to Shared building elements',(#1367,#1368,#1009,#1010,#74,#75,#919,#77,#78,#1011,#967));
#1370= IFCCARTESIANPOINT((47443.9994010579,-401.152088433781,4890.));
#1371= IFCAXIS2PLACEMENT3D(#1370,#501,#185);
#1372= IFCLOCALPLACEMENT(#1356,#1371);
#1373= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1046));
#1374= IFCPRODUCTDEFINITIONSHAPE($,$,(#1373));
#1375= IFCDISCRETEACCESSORY('1Td1iR003GNZ4rDp0rCJ4s',#5,'PLATE','PL16*75','PL16*75',#1372,#1374,'P/0(?)');
#1376= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +4.815'),$);
#1377= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +4.890'),$);
#1378= IFCPROPERTYSET('0syu$yLdvBLQPfoxf$MIIm',#5,'Tekla Common','Common Properties to Shared building elements',(#1376,#1377,#1009,#1010,#74,#75,#919,#77,#78,#79,#967));
#1379= IFCCARTESIANPOINT((47451.9994009154,-409.152092881741,4814.995));
#1380= IFCAXIS2PLACEMENT3D(#1379,#185,#9);
#1381= IFCLOCALPLACEMENT(#1356,#1380);
#1382= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1081));
#1383= IFCPRODUCTDEFINITIONSHAPE($,$,(#1382));
#1384= IFCDISCRETEACCESSORY('1Td1iR003GMp4rDp0rCJ4s',#5,'PLATE','PL16*75','PL16*75',#1381,#1383,'P/0(?)');
#1385= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(1.69489448038158),$);
#1386= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(20.7364813569451),$);
#1387= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0134943828055858),$);
#1388= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(75.0049972534207),$);
#1389= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(179.913116455323),$);
#1390= IFCPROPERTYSET('0KTB4vsabDC8K8hdjgdkpH',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1013,#1086,#1385,#1088,#1089,#1090,#1091,#1092,#1386,#1094,#1387,#1388,#1097,#1389));
#1391= IFCQUANTITYLENGTH('Width',$,$,75.0049972534207);
#1392= IFCQUANTITYAREA('NetArea',$,$,0.0351461105340846);
#1393= IFCQUANTITYAREA('GrossArea',$,$,0.0134943828055858);
#1394= IFCQUANTITYVOLUME('NetVolume',$,$,0.000215909895991342);
#1395= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000215909895991342);
#1396= IFCELEMENTQUANTITY('3w$m$mqrr5KOZTttx$hirP',#5,'BaseQuantities',$,$,(#1391,#1392,#1393,#100,#1394,#1395));
#1397= IFCCARTESIANPOINT((47348.0009742969,-409.152086581707,4814.995));
#1398= IFCAXIS2PLACEMENT3D(#1397,#185,#9);
#1399= IFCLOCALPLACEMENT(#1356,#1398);
#1400= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1081));
#1401= IFCPRODUCTDEFINITIONSHAPE($,$,(#1400));
#1402= IFCDISCRETEACCESSORY('1Td1iR003GM34rDp0rCJ4s',#5,'PLATE','PL16*75','PL16*75',#1399,#1401,'P/0(?)');
#1403= IFCPROPERTYSET('08HYADBIP5lBFolEOI5NAE',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1013,#1112,#1385,#1113,#1114,#1115,#1116,#1092,#1093,#1094,#1387,#1388,#1117,#1389));
#1404= IFCQUANTITYAREA('NetArea',$,$,0.0351461105340844);
#1405= IFCQUANTITYAREA('GrossArea',$,$,0.0134943828055858);
#1406= IFCQUANTITYVOLUME('NetVolume',$,$,0.000215909895991357);
#1407= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000215909895991357);
#1408= IFCELEMENTQUANTITY('0pexEHACn3H9MiY5eyPTKK',#5,'BaseQuantities',$,$,(#1391,#1404,#1405,#100,#1406,#1407));
#1409= IFCCARTESIANPOINT((47071.0886298035,-157.192275561196,4890.));
#1410= IFCAXIS2PLACEMENT3D(#1409,#9,#1125);
#1411= IFCLOCALPLACEMENT(#1356,#1410);
#1412= IFCCIRCLE(#1138,26.5157137785374);
#1413= IFCTRIMMEDCURVE(#1412,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.42863508545961)),.F.,.PARAMETER.);
#1414= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#1413);
#1415= IFCCOMPOSITECURVE((#1414,#1145),.F.);
#1416= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#1415);
#1417= IFCEXTRUDEDAREASOLID(#1416,#1151,#9,100.);
#1418= IFCBOOLEANRESULT(.DIFFERENCE.,#1135,#1417);
#1419= IFCCIRCLE(#1138,26.5157137784793);
#1420= IFCTRIMMEDCURVE(#1419,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.42863508545396)),.F.,.PARAMETER.);
#1421= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#1420);
#1422= IFCCOMPOSITECURVE((#1421,#1145),.F.);
#1423= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#1422);
#1424= IFCEXTRUDEDAREASOLID(#1423,#1162,#9,100.);
#1425= IFCBOOLEANRESULT(.DIFFERENCE.,#1418,#1424);
#1426= IFCCIRCLE(#1138,26.5157137785431);
#1427= IFCTRIMMEDCURVE(#1426,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.4286350854612)),.F.,.PARAMETER.);
#1428= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#1427);
#1429= IFCCOMPOSITECURVE((#1428,#1145),.F.);
#1430= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#1429);
#1431= IFCEXTRUDEDAREASOLID(#1430,#1173,#9,100.);
#1432= IFCBOOLEANRESULT(.DIFFERENCE.,#1425,#1431);
#1433= IFCCIRCLE(#1138,26.5157137785403);
#1434= IFCTRIMMEDCURVE(#1433,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.42863508546133)),.F.,.PARAMETER.);
#1435= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#1434);
#1436= IFCCOMPOSITECURVE((#1435,#1145),.F.);
#1437= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#1436);
#1438= IFCEXTRUDEDAREASOLID(#1437,#1184,#9,100.);
#1439= IFCBOOLEANRESULT(.DIFFERENCE.,#1432,#1438);
#1440= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#1439));
#1441= IFCPRODUCTDEFINITIONSHAPE($,$,(#1440));
#1442= IFCDISCRETEACCESSORY('1Td1iR003GIJ4rDp0rCJ4s',#5,'ANKRAJ','PLT30*240','PLT30*240',#1411,#1441,'P/370(?)');
#1443= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +4.770'),$);
#1444= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +5.010'),$);
#1445= IFCPROPERTYSET('3yDhGP5wTBaeluBMRkynkF',#5,'Tekla Common','Common Properties to Shared building elements',(#1443,#1444,#1193,#1010,#74,#75,#919,#1194,#78,#1195,#80));
#1446= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.374594953106414);
#1447= IFCQUANTITYVOLUME('NetVolume',$,$,0.00481827878120453);
#1448= IFCQUANTITYWEIGHT('NetWeight',$,$,37.8234884324556);
#1449= IFCELEMENTQUANTITY('1KFx2lpan0aemjUTOJPEYW',#5,'BaseQuantities',$,$,(#1211,#1446,#1447,#1448));
#1450= IFCLOCALPLACEMENT(#30,#10);
#1451= IFCELEMENTASSEMBLY('1Td1iR002jLZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#1450,$,'B/143(?)',.NOTDEFINED.,.RIGID_FRAME.);
#1452= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(699.859398508396),$);
#1453= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -1.200'),$);
#1454= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -1.110'),$);
#1455= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('B/143(?)'),$);
#1456= IFCPROPERTYSET('1UWZI0GD19IuzET6GKB7YA',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1452,#1453,#1454,#890,#488,#1455));
#1457= IFCCARTESIANPOINT((47399.9998530384,-664.169369986517,-1126.));
#1458= IFCAXIS2PLACEMENT3D(#1457,#7,#896);
#1459= IFCLOCALPLACEMENT(#1450,#1458);
#1460= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#909));
#1461= IFCPRODUCTDEFINITIONSHAPE($,$,(#1460));
#1462= IFCDISCRETEACCESSORY('1Td1iR003GHJ4rDp0rCJ4s',#5,'DETAY','PL16*58','PL16*58',#1459,#1461,'P/429(?)');
#1463= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -1.184'),$);
#1464= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -1.126'),$);
#1465= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('B/143(?)'),$);
#1466= IFCPROPERTYSET('0v9j6fXTLAEuMciXVfSho7',#5,'Tekla Common','Common Properties to Shared building elements',(#1463,#1464,#917,#1465,#74,#75,#919,#77,#78,#920,#921));
#1467= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(699.859398508396),$);
#1468= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(21.4773305438382),$);
#1469= IFCPROPERTYSET('32YrD6Q4v3oA14zyw5Cjas',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1467,#924,#925,#926,#927,#928,#929,#930,#1468,#932,#933,#934,#94,#1324));
#1470= IFCQUANTITYAREA('NetArea',$,$,0.0285157465476484);
#1471= IFCQUANTITYAREA('GrossArea',$,$,0.0110209747735072);
#1472= IFCQUANTITYVOLUME('NetVolume',$,$,0.000169135506418257);
#1473= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000169135506418257);
#1474= IFCELEMENTQUANTITY('07nJ0LoLD3CAYHUEvFS2o2',#5,'BaseQuantities',$,$,(#1326,#1470,#1471,#100,#1472,#1473));
#1475= IFCCARTESIANPOINT((47150.0008530384,-664.169369986517,-1126.));
#1476= IFCAXIS2PLACEMENT3D(#1475,#7,#896);
#1477= IFCLOCALPLACEMENT(#1450,#1476);
#1478= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#909));
#1479= IFCPRODUCTDEFINITIONSHAPE($,$,(#1478));
#1480= IFCDISCRETEACCESSORY('1Td1iR003GGJ4rDp0rCJ4s',#5,'DETAY','PL16*58','PL16*58',#1477,#1479,'P/429(?)');
#1481= IFCQUANTITYAREA('NetArea',$,$,0.0285157465476484);
#1482= IFCQUANTITYAREA('GrossArea',$,$,0.0110209747735072);
#1483= IFCQUANTITYVOLUME('NetVolume',$,$,0.000169135506418257);
#1484= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000169135506418257);
#1485= IFCELEMENTQUANTITY('1$vy6GtQP99BHq9Hvq7vEz',#5,'BaseQuantities',$,$,(#1326,#1481,#1482,#100,#1483,#1484));
#1486= IFCCARTESIANPOINT((47649.9990642585,-474.169160021327,-1126.0050785108));
#1487= IFCAXIS2PLACEMENT3D(#1486,#185,#596);
#1488= IFCLOCALPLACEMENT(#1450,#1487);
#1489= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#960));
#1490= IFCPRODUCTDEFINITIONSHAPE($,$,(#1489));
#1491= IFCDISCRETEACCESSORY('1Td1iR003GFJ4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#1488,#1490,'P/431(?)');
#1492= IFCPROPERTYSET('11pMfLuob9df3kkIPZ6v2l',#5,'Tekla Common','Common Properties to Shared building elements',(#1463,#1464,#966,#1465,#74,#75,#919,#77,#78,#920,#967));
#1493= IFCPROPERTYSET('24KVAfvXTFpxxJ_G2$5ja0',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1467,#969,#970,#971,#927,#928,#929,#930,#1346,#973,#974,#975,#94,#1348));
#1494= IFCQUANTITYLENGTH('Width',$,$,58.0000001230026);
#1495= IFCQUANTITYAREA('NetArea',$,$,0.0285136450473829);
#1496= IFCQUANTITYAREA('GrossArea',$,$,0.0110200005439197);
#1497= IFCQUANTITYVOLUME('NetVolume',$,$,0.000169120000202947);
#1498= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000169120000202947);
#1499= IFCELEMENTQUANTITY('33$K3E1Sf6UBle$i9br6Eo',#5,'BaseQuantities',$,$,(#1494,#1495,#1496,#100,#1497,#1498));
#1500= IFCLOCALPLACEMENT(#30,#10);
#1501= IFCELEMENTASSEMBLY('1Td1iR003FLJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#1500,$,'A/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#1502= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -1.230'),$);
#1503= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -0.990'),$);
#1504= IFCPROPERTYSET('2adRDlGyb2HAFFt4aIYYzL',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#986,#1502,#1503,#989,#488,#990));
#1505= IFCCARTESIANPOINT((47330.0009742969,-409.152085224177,-1193.));
#1506= IFCAXIS2PLACEMENT3D(#1505,#9,#7);
#1507= IFCLOCALPLACEMENT(#1500,#1506);
#1508= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1002));
#1509= IFCPRODUCTDEFINITIONSHAPE($,$,(#1508));
#1510= IFCDISCRETEACCESSORY('1Td1iR003GEZ4rDp0rCJ4s',#5,'PLATE','PL16*140','PL16*140',#1507,#1509,'P/0(?)');
#1511= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -1.201'),$);
#1512= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -1.185'),$);
#1513= IFCPROPERTYSET('2ePr5B$U5CCAn6XXcJ5f6S',#5,'Tekla Common','Common Properties to Shared building elements',(#1511,#1512,#1009,#1010,#74,#75,#919,#77,#78,#1011,#967));
#1514= IFCCARTESIANPOINT((47443.9994010579,-401.152088433781,-1110.));
#1515= IFCAXIS2PLACEMENT3D(#1514,#501,#185);
#1516= IFCLOCALPLACEMENT(#1500,#1515);
#1517= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1046));
#1518= IFCPRODUCTDEFINITIONSHAPE($,$,(#1517));
#1519= IFCDISCRETEACCESSORY('1Td1iR003GDp4rDp0rCJ4s',#5,'PLATE','PL16*75','PL16*75',#1516,#1518,'P/0(?)');
#1520= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -1.185'),$);
#1521= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -1.110'),$);
#1522= IFCPROPERTYSET('3u3IeTC3n1Del_9vhgHIy9',#5,'Tekla Common','Common Properties to Shared building elements',(#1520,#1521,#1009,#1010,#74,#75,#919,#77,#78,#79,#967));
#1523= IFCCARTESIANPOINT((47451.9994009154,-409.152092881741,-1185.005));
#1524= IFCAXIS2PLACEMENT3D(#1523,#185,#9);
#1525= IFCLOCALPLACEMENT(#1500,#1524);
#1526= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1081));
#1527= IFCPRODUCTDEFINITIONSHAPE($,$,(#1526));
#1528= IFCDISCRETEACCESSORY('1Td1iR003GD34rDp0rCJ4s',#5,'PLATE','PL16*75','PL16*75',#1525,#1527,'P/0(?)');
#1529= IFCQUANTITYLENGTH('Width',$,$,75.0049972534202);
#1530= IFCQUANTITYAREA('GrossArea',$,$,0.0134943828055845);
#1531= IFCELEMENTQUANTITY('2_P2Er58P2cgf2k7BYju0g',#5,'BaseQuantities',$,$,(#1529,#1392,#1530,#100,#1394,#1395));
#1532= IFCCARTESIANPOINT((47348.0009742969,-409.152086581707,-1185.005));
#1533= IFCAXIS2PLACEMENT3D(#1532,#185,#9);
#1534= IFCLOCALPLACEMENT(#1500,#1533);
#1535= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1081));
#1536= IFCPRODUCTDEFINITIONSHAPE($,$,(#1535));
#1537= IFCDISCRETEACCESSORY('1Td1iR003GCJ4rDp0rCJ4s',#5,'PLATE','PL16*75','PL16*75',#1534,#1536,'P/0(?)');
#1538= IFCQUANTITYAREA('GrossArea',$,$,0.0134943828055844);
#1539= IFCELEMENTQUANTITY('2$jWdK98L3XxLYiP5Wawaz',#5,'BaseQuantities',$,$,(#1529,#1404,#1538,#100,#1406,#1407));
#1540= IFCCARTESIANPOINT((47071.0886298035,-157.192275561196,-1110.));
#1541= IFCAXIS2PLACEMENT3D(#1540,#9,#1125);
#1542= IFCLOCALPLACEMENT(#1500,#1541);
#1543= IFCCIRCLE(#1138,26.5157137785189);
#1544= IFCTRIMMEDCURVE(#1543,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.42863508545703)),.F.,.PARAMETER.);
#1545= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#1544);
#1546= IFCCOMPOSITECURVE((#1545,#1145),.F.);
#1547= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#1546);
#1548= IFCEXTRUDEDAREASOLID(#1547,#1151,#9,100.);
#1549= IFCBOOLEANRESULT(.DIFFERENCE.,#1135,#1548);
#1550= IFCCIRCLE(#1138,26.5157137785397);
#1551= IFCTRIMMEDCURVE(#1550,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.42863508545912)),.F.,.PARAMETER.);
#1552= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#1551);
#1553= IFCCOMPOSITECURVE((#1552,#1145),.F.);
#1554= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#1553);
#1555= IFCEXTRUDEDAREASOLID(#1554,#1162,#9,100.);
#1556= IFCBOOLEANRESULT(.DIFFERENCE.,#1549,#1555);
#1557= IFCCIRCLE(#1138,26.515713778513);
#1558= IFCTRIMMEDCURVE(#1557,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.42863508546022)),.F.,.PARAMETER.);
#1559= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#1558);
#1560= IFCCOMPOSITECURVE((#1559,#1145),.F.);
#1561= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#1560);
#1562= IFCEXTRUDEDAREASOLID(#1561,#1173,#9,100.);
#1563= IFCBOOLEANRESULT(.DIFFERENCE.,#1556,#1562);
#1564= IFCCIRCLE(#1138,26.5157137784945);
#1565= IFCTRIMMEDCURVE(#1564,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.4286350854601)),.F.,.PARAMETER.);
#1566= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#1565);
#1567= IFCCOMPOSITECURVE((#1566,#1145),.F.);
#1568= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#1567);
#1569= IFCEXTRUDEDAREASOLID(#1568,#1184,#9,100.);
#1570= IFCBOOLEANRESULT(.DIFFERENCE.,#1563,#1569);
#1571= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#1570));
#1572= IFCPRODUCTDEFINITIONSHAPE($,$,(#1571));
#1573= IFCDISCRETEACCESSORY('1Td1iR003G8Z4rDp0rCJ4s',#5,'ANKRAJ','PLT30*240','PLT30*240',#1542,#1572,'P/370(?)');
#1574= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -1.230'),$);
#1575= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -0.990'),$);
#1576= IFCPROPERTYSET('3VSOk6hEvD8OUvnax5FhTD',#5,'Tekla Common','Common Properties to Shared building elements',(#1574,#1575,#1193,#1010,#74,#75,#919,#1194,#78,#1195,#80));
#1577= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(37.8234884324625),$);
#1578= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(37.8234884324625),$);
#1579= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.00481827878120542),$);
#1580= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.00481827878120542),$);
#1581= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.374594953106504),$);
#1582= IFCPROPERTYSET('3iCXimL_r2J93QSGMzMRx7',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1013,#1577,#1198,#1578,#1579,#1201,#1580,#1203,#1204,#1581,#1206,#1207,#1208,#1209));
#1583= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.374594953106504);
#1584= IFCQUANTITYVOLUME('NetVolume',$,$,0.00481827878120542);
#1585= IFCQUANTITYWEIGHT('NetWeight',$,$,37.8234884324625);
#1586= IFCELEMENTQUANTITY('1dHD7rJ_jAMBZlSRHpvCZJ',#5,'BaseQuantities',$,$,(#1211,#1583,#1584,#1585));
#1587= IFCLOCALPLACEMENT(#30,#10);
#1588= IFCELEMENTASSEMBLY('1Td1iR003G7J4rDp0rCJ4s',#5,'Steel Assembly',$,$,#1587,$,'ANK/63(?)',.NOTDEFINED.,.RIGID_FRAME.);
#1589= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' +15.806'),$);
#1590= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +15.822'),$);
#1591= IFCPROPERTYSET('39T7FnoCP4tAwO5gvMTNCX',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#485,#1589,#1590,#39,#488,#489));
#1592= IFCCARTESIANPOINT((47524.9997504966,-629.151268223872,15814.));
#1593= IFCAXIS2PLACEMENT3D(#1592,#7,#8);
#1594= IFCLOCALPLACEMENT(#1587,#1593);
#1595= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#504));
#1596= IFCPRODUCTDEFINITIONSHAPE($,$,(#1595));
#1597= IFCBEAM('1Td1iR003G7Z4rDp0rCJ4s',#5,'ANKRAJ','PLT16*150','PLT16*150',#1594,#1596,'P/379(?)');
#1598= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +15.806'),$);
#1599= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +15.822'),$);
#1600= IFCPROPERTYSET('3AFL3aZ8T9sPCY2V7MgKvv',#5,'Tekla Common','Common Properties to Shared building elements',(#1598,#1599,#512,#513,#74,#75,#514,#515,#78,#516,#80));
#1601= IFCLOCALPLACEMENT(#30,#10);
#1602= IFCELEMENTASSEMBLY('1Td1iR003G6J4rDp0rCJ4s',#5,'Steel Assembly',$,$,#1601,$,'ANK/63(?)',.NOTDEFINED.,.RIGID_FRAME.);
#1603= IFCCARTESIANPOINT((47275.0016158756,-629.151287104069,15814.));
#1604= IFCAXIS2PLACEMENT3D(#1603,#7,#8);
#1605= IFCLOCALPLACEMENT(#1601,#1604);
#1606= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#542));
#1607= IFCPRODUCTDEFINITIONSHAPE($,$,(#1606));
#1608= IFCBEAM('1Td1iR003G6Z4rDp0rCJ4s',#5,'ANKRAJ','PLT16*150','PLT16*150',#1605,#1607,'P/379(?)');
#1609= IFCLOCALPLACEMENT(#30,#10);
#1610= IFCELEMENTASSEMBLY('1Td1iR003G5J4rDp0rCJ4s',#5,'Steel Assembly',$,$,#1609,$,'ANK/61(?)',.NOTDEFINED.,.RIGID_FRAME.);
#1611= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(5.29879095789816),$);
#1612= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' +15.715'),$);
#1613= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +15.865'),$);
#1614= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit name',$,IFCLABEL('PUL'),$);
#1615= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit position code',$,IFCLABEL('5/1-6/N2'),$);
#1616= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('ANK/61(?)'),$);
#1617= IFCPROPERTYSET('0UW7aaN7n4TBFmyqy2R5fS',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1611,#1612,#1613,#1614,#1615,#1616));
#1618= IFCQUANTITYLENGTH('Width',$,$,30.0000000001291);
#1619= IFCELEMENTQUANTITY('3Flt4vYsv5VPNZB0NqUqRY',#5,'BaseQuantities',$,$,(#1618));
#1620= IFCCARTESIANPOINT((47263.8303183166,-238.761303583808,15790.));
#1621= IFCDIRECTION((-0.977596272838045,0.210488781965129,0.));
#1622= IFCAXIS2PLACEMENT3D(#1620,#9,#1621);
#1623= IFCLOCALPLACEMENT(#1609,#1622);
#1624= IFCCOLOURRGB('Light Red',0.898039215686275,0.,0.);
#1625= IFCSURFACESTYLERENDERING(#1624,0.,$,$,$,$,IFCNORMALISEDRATIOMEASURE(0.00390625),IFCSPECULAREXPONENT(10.),.NOTDEFINED.);
#1626= IFCSURFACESTYLE('STEEL/S235JR',.POSITIVE.,(#1625));
#1627= IFCPRESENTATIONSTYLEASSIGNMENT((#1626));
#1628= IFCRECTANGLEPROFILEDEF(.AREA.,'PLT30*150',#197,30.,150.);
#1629= IFCCARTESIANPOINT((150.001159459226,0.,0.));
#1630= IFCAXIS2PLACEMENT3D(#1629,#185,#501);
#1631= IFCEXTRUDEDAREASOLID(#1628,#1630,#9,150.001159459226);
#1632= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1631));
#1633= IFCSTYLEDITEM(#1631,(#1627),$);
#1634= IFCPRODUCTDEFINITIONSHAPE($,$,(#1632));
#1635= IFCBEAM('1Td1iR003G5Z4rDp0rCJ4s',#5,'PUL','PLT30*150','PLT30*150',#1623,#1634,'P/377(?)');
#1636= IFCBEAMTYPE('32uj8QtPr0HuYou5cNhcrL',#5,'PLT30*150',$,$,$,$,$,$,.NOTDEFINED.);
#1637= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +15.865'),$);
#1638= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/377(?)'),$);
#1639= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('ANK/61(?)'),$);
#1640= IFCPROPERTYSINGLEVALUE('Class',$,IFCLABEL('2'),$);
#1641= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PLT30*150'),$);
#1642= IFCPROPERTYSINGLEVALUE('Name',$,IFCLABEL('PUL'),$);
#1643= IFCPROPERTYSET('36K$$douD4WgUGxx7lgYLn',#5,'Tekla Common','Common Properties to Shared building elements',(#1051,#1637,#1638,#1639,#74,#75,#919,#1640,#78,#1641,#1642));
#1644= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(5.29879095789816),$);
#1645= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(5.29879095789816),$);
#1646= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(5.29879095789777),$);
#1647= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(5.29879095789816),$);
#1648= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000675005217566644),$);
#1649= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000675005217566644),$);
#1650= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000675005217566644),$);
#1651= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00450003478377665),$);
#1652= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(11.8895834740228),$);
#1653= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0630004174053272),$);
#1654= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0630004174053272),$);
#1655= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(30.0000000001291),$);
#1656= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(150.001159459243),$);
#1657= IFCPROPERTYSET('1u9AXCH_b9CPMS9hsB1JMO',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1644,#1645,#1646,#1647,#1648,#1649,#1650,#1651,#1652,#1653,#1654,#529,#1655,#1656));
#1658= IFCQUANTITYLENGTH('Length',$,$,150.001159459243);
#1659= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0630004174053272);
#1660= IFCQUANTITYVOLUME('NetVolume',$,$,0.000675005217566644);
#1661= IFCQUANTITYWEIGHT('NetWeight',$,$,5.29879095789816);
#1662= IFCELEMENTQUANTITY('3UWVQHqn576OrzirKPgCBk',#5,'BaseQuantities',$,$,(#1658,#1659,#1660,#1661));
#1663= IFCLOCALPLACEMENT(#30,#10);
#1664= IFCELEMENTASSEMBLY('1Td1iR003G4J4rDp0rCJ4s',#5,'Steel Assembly',$,$,#1663,$,'ANK/61(?)',.NOTDEFINED.,.RIGID_FRAME.);
#1665= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(5.29879095790522),$);
#1666= IFCPROPERTYSET('1ol3DjIVT1evw6kLlJYPVk',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1665,#1612,#1613,#1614,#1615,#1616));
#1667= IFCQUANTITYLENGTH('Width',$,$,30.0000000000819);
#1668= IFCELEMENTQUANTITY('2qCOCn$eP9uPB64HNCnmjx',#5,'BaseQuantities',$,$,(#1667));
#1669= IFCCARTESIANPOINT((47536.1696399369,-238.76131148119,15790.));
#1670= IFCDIRECTION((0.977596284893,0.210488725976962,0.));
#1671= IFCAXIS2PLACEMENT3D(#1669,#9,#1670);
#1672= IFCLOCALPLACEMENT(#1663,#1671);
#1673= IFCEXTRUDEDAREASOLID(#1628,#1630,#9,150.001159459233);
#1674= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1673));
#1675= IFCSTYLEDITEM(#1673,(#1627),$);
#1676= IFCPRODUCTDEFINITIONSHAPE($,$,(#1674));
#1677= IFCBEAM('1Td1iR003G4Z4rDp0rCJ4s',#5,'PUL','PLT30*150','PLT30*150',#1672,#1676,'P/377(?)');
#1678= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(5.29879095790522),$);
#1679= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(5.29879095790522),$);
#1680= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(5.29879095790497),$);
#1681= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(5.29879095790522),$);
#1682= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000675005217567545),$);
#1683= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000675005217567545),$);
#1684= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000675005217567545),$);
#1685= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00450003478377703),$);
#1686= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0630004174053992),$);
#1687= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0630004174053992),$);
#1688= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(150.001159459447),$);
#1689= IFCPROPERTYSET('2jfRZxOKj2VQqAu0i83aVR',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1678,#1679,#1680,#1681,#1682,#1683,#1684,#1685,#1652,#1686,#1687,#529,#1655,#1688));
#1690= IFCQUANTITYLENGTH('Length',$,$,150.001159459447);
#1691= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0630004174053992);
#1692= IFCQUANTITYVOLUME('NetVolume',$,$,0.000675005217567544);
#1693= IFCQUANTITYWEIGHT('NetWeight',$,$,5.29879095790522);
#1694= IFCELEMENTQUANTITY('3f0cPUNSPDnO1pXuVWqgLy',#5,'BaseQuantities',$,$,(#1690,#1691,#1692,#1693));
#1695= IFCLOCALPLACEMENT(#30,#10);
#1696= IFCELEMENTASSEMBLY('1Td1iR003G3J4rDp0rCJ4s',#5,'Steel Assembly',$,$,#1695,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#1697= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(0.),$);
#1698= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' +15.773'),$);
#1699= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +15.807'),$);
#1700= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit name',$,IFCLABEL('NUT'),$);
#1701= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('XX/0(?)'),$);
#1702= IFCPROPERTYSET('0PXiCoehD4fxesyarfYQPt',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#1698,#1699,#1700,#1615,#1701));
#1703= IFCQUANTITYLENGTH('Width',$,$,34.6410161513777);
#1704= IFCELEMENTQUANTITY('1zmbPddnr3Rhx1QNlYKksI',#5,'BaseQuantities',$,$,(#1703));
#1705= IFCCARTESIANPOINT((47616.8561910801,-257.190864719625,15790.));
#1706= IFCDIRECTION((0.977596732953257,0.210486644989936,0.));
#1707= IFCDIRECTION((0.210486644989875,-0.97759673295327,0.));
#1708= IFCAXIS2PLACEMENT3D(#1705,#1706,#1707);
#1709= IFCLOCALPLACEMENT(#1695,#1708);
#1710= IFCSURFACESTYLE('MISCELLANEOUS/Zero_weight',.POSITIVE.,(#51));
#1711= IFCPRESENTATIONSTYLEASSIGNMENT((#1710));
#1712= IFCCARTESIANPOINT((-8.66025403784442,15.0000000000582));
#1713= IFCCARTESIANPOINT((8.66025403784442,15.0000000000582));
#1714= IFCCARTESIANPOINT((17.3205080756888,2.18278728425503E-011));
#1715= IFCCARTESIANPOINT((8.66025403784442,-15.0000000000146));
#1716= IFCCARTESIANPOINT((-8.66025403784442,-15.0000000000146));
#1717= IFCCARTESIANPOINT((-17.3205080756888,2.18278728425503E-011));
#1718= IFCPOLYLINE((#1712,#1713,#1714,#1715,#1716,#1717,#1712));
#1719= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'NUT_M20',#1718);
#1720= IFCCARTESIANPOINT((16.0000409062021,1.81898940354586E-012,0.));
#1721= IFCAXIS2PLACEMENT3D(#1720,#185,#501);
#1722= IFCEXTRUDEDAREASOLID(#1719,#1721,#9,16.0000409062021);
#1723= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1722));
#1724= IFCSTYLEDITEM(#1722,(#1711),$);
#1725= IFCPRODUCTDEFINITIONSHAPE($,$,(#1723));
#1726= IFCBEAM('1Td1iR003G3Z4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#1709,#1725,'XX/0(?)');
#1727= IFCBEAMTYPE('0pgbAS$O526hPIa3fEjVKG',#5,'NUT_M20',$,$,$,$,$,$,.NOTDEFINED.);
#1728= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +15.773'),$);
#1729= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +15.807'),$);
#1730= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('XX/0(?)'),$);
#1731= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('XX/0(?)'),$);
#1732= IFCPROPERTYSINGLEVALUE('Grade',$,IFCLABEL('Zero_weight'),$);
#1733= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('NUT_M20'),$);
#1734= IFCPROPERTYSINGLEVALUE('Name',$,IFCLABEL('NUT'),$);
#1735= IFCPROPERTYSET('2CGsZqU_L6ggJRborpmlo2',#5,'Tekla Common','Common Properties to Shared building elements',(#1728,#1729,#1730,#1731,#74,#75,#919,#1194,#1732,#1733,#1734));
#1736= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(0.),$);
#1737= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.),$);
#1738= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(0.),$);
#1739= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.),$);
#1740= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(1.24707976977415E-005),$);
#1741= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(1.24707976977415E-005),$);
#1742= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(1.24707976977415E-005),$);
#1743= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.),$);
#1744= IFCPROPERTYSINGLEVALUE('Area per tons',$,$,$);
#1745= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.00322161875317875),$);
#1746= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.00322161875317875),$);
#1747= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(30.0000000000582),$);
#1748= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(34.6410161513777),$);
#1749= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(16.0000409062468),$);
#1750= IFCPROPERTYSET('2vxhkXfzPAR9U_vKm7R0wD',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#1740,#1741,#1742,#1743,#1744,#1745,#1746,#1747,#1748,#1749));
#1751= IFCQUANTITYLENGTH('Length',$,$,16.0000409062468);
#1752= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161875317875);
#1753= IFCQUANTITYVOLUME('NetVolume',$,$,1.24707976977415E-005);
#1754= IFCQUANTITYWEIGHT('NetWeight',$,$,0.);
#1755= IFCELEMENTQUANTITY('3M2ZlvpDT6CvOh5c2rFT$y',#5,'BaseQuantities',$,$,(#1751,#1752,#1753,#1754));
#1756= IFCMATERIAL('MISCELLANEOUS/Zero_weight');
#1757= IFCLOCALPLACEMENT(#30,#10);
#1758= IFCELEMENTASSEMBLY('1Td1iR003G2J4rDp0rCJ4s',#5,'Steel Assembly',$,$,#1757,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#1759= IFCCARTESIANPOINT((47613.4878455301,-241.549277321974,15790.));
#1760= IFCAXIS2PLACEMENT3D(#1759,#1706,#1707);
#1761= IFCLOCALPLACEMENT(#1757,#1760);
#1762= IFCEXTRUDEDAREASOLID(#1719,#1721,#9,16.0000409061885);
#1763= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1762));
#1764= IFCSTYLEDITEM(#1762,(#1711),$);
#1765= IFCPRODUCTDEFINITIONSHAPE($,$,(#1763));
#1766= IFCBEAM('1Td1iR003G2Z4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#1761,#1765,'XX/0(?)');
#1767= IFCQUANTITYLENGTH('Length',$,$,16.0000409062377);
#1768= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161875317731);
#1769= IFCQUANTITYVOLUME('NetVolume',$,$,1.24707976977309E-005);
#1770= IFCELEMENTQUANTITY('2GO0iw4qjCeunwVXP0PFbE',#5,'BaseQuantities',$,$,(#1767,#1768,#1769,#1754));
#1771= IFCLOCALPLACEMENT(#30,#10);
#1772= IFCELEMENTASSEMBLY('1Td1iR003G1J4rDp0rCJ4s',#5,'Steel Assembly',$,$,#1771,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#1773= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' +15.768'),$);
#1774= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +15.812'),$);
#1775= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit name',$,IFCLABEL('WASHER'),$);
#1776= IFCPROPERTYSET('3q6QxqFbfFXBIbfun7RdLY',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#1773,#1774,#1775,#1615,#1701));
#1777= IFCQUANTITYLENGTH('Width',$,$,44.);
#1778= IFCELEMENTQUANTITY('0qz72QqYH4d95cLv8xwEIX',#5,'BaseQuantities',$,$,(#1777));
#1779= IFCCARTESIANPOINT((47612.6453400033,-237.638892502491,15790.));
#1780= IFCDIRECTION((0.210488725020695,-0.977596285098896,0.));
#1781= IFCAXIS2PLACEMENT3D(#1779,#1670,#1780);
#1782= IFCLOCALPLACEMENT(#1771,#1781);
#1783= IFCCIRCLEHOLLOWPROFILEDEF(.AREA.,'EPD44*9.5',#197,22.,9.5);
#1784= IFCCARTESIANPOINT((4.00000000000001,0.,0.));
#1785= IFCAXIS2PLACEMENT3D(#1784,#185,#501);
#1786= IFCEXTRUDEDAREASOLID(#1783,#1785,#9,4.00000000000001);
#1787= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1786));
#1788= IFCSTYLEDITEM(#1786,(#1711),$);
#1789= IFCPRODUCTDEFINITIONSHAPE($,$,(#1787));
#1790= IFCBEAM('1Td1iR003G1Z4rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#1782,#1789,'XX/0(?)');
#1791= IFCBEAMTYPE('2X9_RP5a5FdvLxVIu0veaP',#5,'EPD44*9.5',$,$,$,$,$,$,.NOTDEFINED.);
#1792= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +15.768'),$);
#1793= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +15.812'),$);
#1794= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('EPD44*9.5'),$);
#1795= IFCPROPERTYSINGLEVALUE('Name',$,IFCLABEL('WASHER'),$);
#1796= IFCPROPERTYSET('3apJcXTLr9wv_p$SBQmVwO',#5,'Tekla Common','Common Properties to Shared building elements',(#1792,#1793,#1730,#1731,#74,#75,#919,#1194,#1732,#1794,#1795));
#1797= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(3.93299999999802E-006),$);
#1798= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(3.93299999999802E-006),$);
#1799= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(3.93299999999802E-006),$);
#1800= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.00180062582325545),$);
#1801= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.00180062582325545),$);
#1802= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(43.9999999999636),$);
#1803= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(44.),$);
#1804= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(4.00000000015825),$);
#1805= IFCPROPERTYSET('0MQy63EELDjvWoglhJSsbb',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#1797,#1798,#1799,#1743,#1744,#1800,#1801,#1802,#1803,#1804));
#1806= IFCQUANTITYLENGTH('Length',$,$,4.00000000015825);
#1807= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00180062582325545);
#1808= IFCQUANTITYVOLUME('NetVolume',$,$,3.93299999999802E-006);
#1809= IFCELEMENTQUANTITY('1lAixit29CLwnnOXJWxJug',#5,'BaseQuantities',$,$,(#1806,#1807,#1808,#1754));
#1810= IFCLOCALPLACEMENT(#30,#10);
#1811= IFCELEMENTASSEMBLY('1Td1iR003G0J4rDp0rCJ4s',#5,'Steel Assembly',$,$,#1810,$,'R/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#1812= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' +15.780'),$);
#1813= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +15.800'),$);
#1814= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit name',$,IFCLABEL('ROD'),$);
#1815= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('R/0(?)'),$);
#1816= IFCPROPERTYSET('2L_aySXmf0bQ$OBV8atEP8',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#1812,#1813,#1814,#1615,#1815));
#1817= IFCQUANTITYLENGTH('Width',$,$,20.);
#1818= IFCELEMENTQUANTITY('2HlscV6Zb9sfIwdRVS9RmU',#5,'BaseQuantities',$,$,(#1817));
#1819= IFCCARTESIANPOINT((47625.1344111934,-295.638490283985,15790.));
#1820= IFCDIRECTION((-0.977596285304546,-0.210488724065573,0.));
#1821= IFCDIRECTION((-0.210488724065571,0.977596285304546,0.));
#1822= IFCAXIS2PLACEMENT3D(#1819,#1820,#1821);
#1823= IFCLOCALPLACEMENT(#1810,#1822);
#1824= IFCSURFACESTYLE('STEEL/HIT-RE 500V3+HIT-V(8.8)',.POSITIVE.,(#497));
#1825= IFCPRESENTATIONSTYLEASSIGNMENT((#1824));
#1826= IFCCIRCLEPROFILEDEF(.AREA.,'ROD20',#197,10.);
#1827= IFCCARTESIANPOINT((370.000357476347,0.,-1.02695728997445E-014));
#1828= IFCAXIS2PLACEMENT3D(#1827,#185,#501);
#1829= IFCEXTRUDEDAREASOLID(#1826,#1828,#9,370.000357476349);
#1830= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1829));
#1831= IFCSTYLEDITEM(#1829,(#1825),$);
#1832= IFCPRODUCTDEFINITIONSHAPE($,$,(#1830));
#1833= IFCBEAM('1Td1iR003G0Z4rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#1823,#1832,'P/0(?)');
#1834= IFCBEAMTYPE('1C4$z$$0X8CxUWuVGS_nwO',#5,'ROD20',$,$,$,$,$,$,.NOTDEFINED.);
#1835= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +15.780'),$);
#1836= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +15.800'),$);
#1837= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('R/0(?)'),$);
#1838= IFCPROPERTYSINGLEVALUE('Grade',$,IFCLABEL('HIT-RE 500V3+HIT-V(8.8)'),$);
#1839= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('ROD20'),$);
#1840= IFCPROPERTYSINGLEVALUE('Name',$,IFCLABEL('ROD'),$);
#1841= IFCPROPERTYSET('1scK$PCa14SvoQHWmSmnkL',#5,'Tekla Common','Common Properties to Shared building elements',(#1835,#1836,#1009,#1837,#74,#75,#919,#515,#1838,#1839,#1840));
#1842= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000104651904724874),$);
#1843= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000104651904724874),$);
#1844= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000104651904724874),$);
#1845= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0232205665089674),$);
#1846= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0232205665089674),$);
#1847= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(20.0000000001528),$);
#1848= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(20.),$);
#1849= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(370.000357476261),$);
#1850= IFCPROPERTYSET('0OGQoPA6fBvvMPoaw1oVa6',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#1842,#1843,#1844,#1743,#1744,#1845,#1846,#1847,#1848,#1849));
#1851= IFCQUANTITYLENGTH('Length',$,$,370.000357476261);
#1852= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0232205665089674);
#1853= IFCQUANTITYVOLUME('NetVolume',$,$,0.000104651904724874);
#1854= IFCELEMENTQUANTITY('2XnR_i9h9AxOWK9AwH5WW7',#5,'BaseQuantities',$,$,(#1851,#1852,#1853,#1754));
#1855= IFCMATERIAL('STEEL/HIT-RE 500V3+HIT-V(8.8)');
#1856= IFCCARTESIANPOINT((47469.9999731708,-444.152091930489,15798.));
#1857= IFCAXIS2PLACEMENT3D(#1856,#9,#8);
#1858= IFCLOCALPLACEMENT(#984,#1857);
#1859= IFCDIRECTION((-1.,-1.1180037636412E-008));
#1860= IFCCARTESIANPOINT((60.0000006708023,-60.0000000002367));
#1861= IFCAXIS2PLACEMENT2D(#1860,#1859);
#1862= IFCCIRCLE(#1861,60.);
#1863= IFCTRIMMEDCURVE(#1862,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.71238896920071)),.F.,.PARAMETER.);
#1864= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#1863);
#1865= IFCCARTESIANPOINT((60.000000671039,-2.36661907861892E-010));
#1866= IFCCARTESIANPOINT((228.736114501954,-9.02218744158745E-010));
#1867= IFCCARTESIANPOINT((228.734970092496,139.999999999076));
#1868= IFCCARTESIANPOINT((59.9997653548621,139.998784331539));
#1869= IFCPOLYLINE((#1865,#1866,#1867,#1868));
#1870= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#1869);
#1871= IFCDIRECTION((7.20458744112307E-006,-0.999999999974047));
#1872= IFCCARTESIANPOINT((59.9993330796157,199.998784329982));
#1873= IFCAXIS2PLACEMENT2D(#1872,#1871);
#1874= IFCCIRCLE(#1873,60.);
#1875= IFCTRIMMEDCURVE(#1874,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.71237623145467)),.F.,.PARAMETER.);
#1876= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#1875);
#1877= IFCCARTESIANPOINT((-0.000666919462174489,199.999116990536));
#1878= IFCCARTESIANPOINT((-1.59701085067354E-006,319.999359130859));
#1879= IFCCARTESIANPOINT((-220.000244141262,319.999359131732));
#1880= IFCCARTESIANPOINT((-220.000228881478,-179.998779296002));
#1881= IFCCARTESIANPOINT((2.01239322450419E-006,-179.998779296875));
#1882= IFCCARTESIANPOINT((6.7080229817282E-007,-60.000000671039));
#1883= IFCPOLYLINE((#1877,#1878,#1879,#1880,#1881,#1882));
#1884= IFCCOMPOSITECURVESEGMENT(.DISCONTINUOUS.,.T.,#1883);
#1885= IFCCOMPOSITECURVE((#1864,#1870,#1876,#1884),.F.);
#1886= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL16*436',#1885);
#1887= IFCEXTRUDEDAREASOLID(#1886,#63,#9,16.);
#1888= IFCRECTANGLEPROFILEDEF(.AREA.,'PLT30*530',#197,30.,530.);
#1889= IFCDIRECTION((-0.999999999640156,2.68270000002862E-005,0.));
#1890= IFCCARTESIANPOINT((292.97246296253,-275.046693184499,3.63797880709171E-012));
#1891= IFCAXIS2PLACEMENT3D(#1890,#9,#1889);
#1892= IFCCARTESIANPOINT((0.,-345.0455258872,0.));
#1893= IFCAXIS1PLACEMENT(#1892,#7);
#1894= IFCREVOLVEDAREASOLID(#1888,#1891,#1893,3.14159263868863);
#1895= IFCBOOLEANRESULT(.DIFFERENCE.,#1887,#1894);
#1896= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#1895));
#1897= IFCSTYLEDITEM(#1887,(#53),$);
#1898= IFCPRODUCTDEFINITIONSHAPE($,$,(#1896));
#1899= IFCPLATE('1Td1iR003F_p4rDp0rCJ4s',#5,'ANCHOR','PL16*436','PL16*436',#1858,#1898,'P/0(?)');
#1900= IFCPLATETYPE('29y_IIOmHC0f36pyZjXIWz',#5,'PL16*436',$,$,$,$,$,$,.NOTDEFINED.);
#1901= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +15.790'),$);
#1902= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +15.806'),$);
#1903= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PL16*436'),$);
#1904= IFCPROPERTYSINGLEVALUE('Name',$,IFCLABEL('ANCHOR'),$);
#1905= IFCPROPERTYSET('0g44FfpJn3JeLRDzJWEf1i',#5,'Tekla Common','Common Properties to Shared building elements',(#1901,#1902,#1009,#1010,#74,#75,#919,#77,#78,#1903,#1904));
#1906= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(17.8036017712151),$);
#1907= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(27.4053767608832),$);
#1908= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(17.8036017712151),$);
#1909= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.00226797474792549),$);
#1910= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.00229938863240068),$);
#1911= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.00226797474792549),$);
#1912= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.141748421745333),$);
#1913= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(17.5593606468865),$);
#1914= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.312619864314312),$);
#1915= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.218195674847796),$);
#1916= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(436.392968589885),$);
#1917= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(499.998145141639),$);
#1918= IFCPROPERTYSET('2hc2g0GlT0FwMdu8$AXtxP',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1013,#1906,#1907,#1908,#1909,#1910,#1911,#1912,#1913,#1914,#1915,#1916,#94,#1917));
#1919= IFCQUANTITYLENGTH('Width',$,$,436.392968589885);
#1920= IFCQUANTITYAREA('NetArea',$,$,0.312619864314312);
#1921= IFCQUANTITYAREA('GrossArea',$,$,0.218195674847796);
#1922= IFCQUANTITYVOLUME('NetVolume',$,$,0.00226797474792549);
#1923= IFCQUANTITYVOLUME('GrossVolume',$,$,0.00229938863240068);
#1924= IFCELEMENTQUANTITY('1AZo$$EF9Dg8bfGZ1G$6XQ',#5,'BaseQuantities',$,$,(#1919,#1920,#1921,#100,#1922,#1923));
#1925= IFCLOCALPLACEMENT(#30,#10);
#1926= IFCELEMENTASSEMBLY('1Td1iR003FzZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#1925,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#1927= IFCCARTESIANPOINT((47183.1442023679,-257.190838696384,15790.));
#1928= IFCDIRECTION((-0.97759670777042,0.21048676195057,0.));
#1929= IFCDIRECTION((-0.210486761950607,-0.977596707770412,0.));
#1930= IFCAXIS2PLACEMENT3D(#1927,#1928,#1929);
#1931= IFCLOCALPLACEMENT(#1925,#1930);
#1932= IFCEXTRUDEDAREASOLID(#1719,#1721,#9,16.0000409062012);
#1933= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1932));
#1934= IFCSTYLEDITEM(#1932,(#1711),$);
#1935= IFCPRODUCTDEFINITIONSHAPE($,$,(#1933));
#1936= IFCBEAM('1Td1iR003Fzp4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#1931,#1935,'XX/0(?)');
#1937= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(1.24707976977551E-005),$);
#1938= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(1.24707976977551E-005),$);
#1939= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(1.24707976977551E-005),$);
#1940= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.00322161875318136),$);
#1941= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.00322161875318136),$);
#1942= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(30.0000000000946),$);
#1943= IFCPROPERTYSET('1b3mAtE1jDzQ8fhxpMVJh$',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#1937,#1938,#1939,#1743,#1744,#1940,#1941,#1942,#1748,#1749));
#1944= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161875318136);
#1945= IFCQUANTITYVOLUME('NetVolume',$,$,1.24707976977551E-005);
#1946= IFCELEMENTQUANTITY('2YHfly0W57_eQbO8a5Rc0$',#5,'BaseQuantities',$,$,(#1767,#1944,#1945,#1754));
#1947= IFCLOCALPLACEMENT(#30,#10);
#1948= IFCELEMENTASSEMBLY('1Td1iR003FyZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#1947,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#1949= IFCCARTESIANPOINT((47186.5125497949,-241.549251702942,15790.));
#1950= IFCAXIS2PLACEMENT3D(#1949,#1928,#1929);
#1951= IFCLOCALPLACEMENT(#1947,#1950);
#1952= IFCEXTRUDEDAREASOLID(#1719,#1721,#9,16.000040906191);
#1953= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1952));
#1954= IFCSTYLEDITEM(#1952,(#1711),$);
#1955= IFCPRODUCTDEFINITIONSHAPE($,$,(#1953));
#1956= IFCBEAM('1Td1iR003Fyp4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#1951,#1955,'XX/0(?)');
#1957= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(30.0000000001019),$);
#1958= IFCPROPERTYSET('0VlaUpGhn7vOPoAWZP3tMv',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#1937,#1938,#1939,#1743,#1744,#1940,#1941,#1957,#1748,#1749));
#1959= IFCQUANTITYLENGTH('Length',$,$,16.0000409062304);
#1960= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161875318052);
#1961= IFCQUANTITYVOLUME('NetVolume',$,$,1.24707976977481E-005);
#1962= IFCELEMENTQUANTITY('0$TfoFkgX7bOHwNYjbPxQq',#5,'BaseQuantities',$,$,(#1959,#1960,#1961,#1754));
#1963= IFCLOCALPLACEMENT(#30,#10);
#1964= IFCELEMENTASSEMBLY('1Td1iR003FxZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#1963,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#1965= IFCCARTESIANPOINT((47187.355055791,-237.638866984562,15790.));
#1966= IFCDIRECTION((-0.210488842938309,-0.97759625970975,0.));
#1967= IFCAXIS2PLACEMENT3D(#1965,#1621,#1966);
#1968= IFCLOCALPLACEMENT(#1963,#1967);
#1969= IFCEXTRUDEDAREASOLID(#1783,#1785,#9,4.00000000000369);
#1970= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1969));
#1971= IFCSTYLEDITEM(#1969,(#1711),$);
#1972= IFCPRODUCTDEFINITIONSHAPE($,$,(#1970));
#1973= IFCBEAM('1Td1iR003Fxp4rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#1968,#1972,'XX/0(?)');
#1974= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(3.93300000001284E-006),$);
#1975= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(3.93300000001284E-006),$);
#1976= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(3.93300000001284E-006),$);
#1977= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.00180062582326066),$);
#1978= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.00180062582326066),$);
#1979= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(44.0000000001091),$);
#1980= IFCPROPERTYSET('0qvStmfPjAduhZOnyn_OoQ',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#1974,#1975,#1976,#1743,#1744,#1977,#1978,#1979,#1803,#1804));
#1981= IFCQUANTITYLENGTH('Length',$,$,4.00000000001091);
#1982= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00180062582326066);
#1983= IFCQUANTITYVOLUME('NetVolume',$,$,3.93300000001284E-006);
#1984= IFCELEMENTQUANTITY('0yY3EtkFLE3uGuCM5kaRlc',#5,'BaseQuantities',$,$,(#1981,#1982,#1983,#1754));
#1985= IFCLOCALPLACEMENT(#30,#10);
#1986= IFCELEMENTASSEMBLY('1Td1iR003FwZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#1985,$,'R/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#1987= IFCCARTESIANPOINT((47174.8659776408,-295.638463267343,15790.));
#1988= IFCDIRECTION((0.977596260121461,-0.210488841026152,0.));
#1989= IFCDIRECTION((0.210488841026159,0.97759626012146,0.));
#1990= IFCAXIS2PLACEMENT3D(#1987,#1988,#1989);
#1991= IFCLOCALPLACEMENT(#1985,#1990);
#1992= IFCEXTRUDEDAREASOLID(#1826,#1828,#9,370.000357476353);
#1993= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1992));
#1994= IFCSTYLEDITEM(#1992,(#1825),$);
#1995= IFCPRODUCTDEFINITIONSHAPE($,$,(#1993));
#1996= IFCBEAM('1Td1iR003Fwp4rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#1991,#1995,'P/0(?)');
#1997= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000104651904724951),$);
#1998= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000104651904724951),$);
#1999= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000104651904724951),$);
#2000= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.023220566508977),$);
#2001= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.023220566508977),$);
#2002= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(370.000357476281),$);
#2003= IFCPROPERTYSET('2CWnhYi5jDdfuT3zKATIsZ',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#1997,#1998,#1999,#1743,#1744,#2000,#2001,#1847,#1848,#2002));
#2004= IFCQUANTITYLENGTH('Length',$,$,370.000357476281);
#2005= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.023220566508977);
#2006= IFCQUANTITYVOLUME('NetVolume',$,$,0.000104651904724951);
#2007= IFCELEMENTQUANTITY('2mUmqdhP1FUhQND0PAPava',#5,'BaseQuantities',$,$,(#2004,#2005,#2006,#1754));
#2008= IFCLOCALPLACEMENT(#30,#10);
#2009= IFCELEMENTASSEMBLY('1Td1iR003FvZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#2008,$,'ANK/63(?)',.NOTDEFINED.,.RIGID_FRAME.);
#2010= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' +10.606'),$);
#2011= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +10.622'),$);
#2012= IFCPROPERTYSET('3u$7UinUXDj8aK8puGnPRZ',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#485,#2010,#2011,#39,#488,#489));
#2013= IFCCARTESIANPOINT((47524.9997504966,-629.151268223872,10614.));
#2014= IFCAXIS2PLACEMENT3D(#2013,#7,#8);
#2015= IFCLOCALPLACEMENT(#2008,#2014);
#2016= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#504));
#2017= IFCPRODUCTDEFINITIONSHAPE($,$,(#2016));
#2018= IFCBEAM('1Td1iR003Fvp4rDp0rCJ4s',#5,'ANKRAJ','PLT16*150','PLT16*150',#2015,#2017,'P/379(?)');
#2019= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +10.606'),$);
#2020= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +10.622'),$);
#2021= IFCPROPERTYSET('2MItc1Dar3ShI4vFffMgbz',#5,'Tekla Common','Common Properties to Shared building elements',(#2019,#2020,#512,#513,#74,#75,#514,#515,#78,#516,#80));
#2022= IFCLOCALPLACEMENT(#30,#10);
#2023= IFCELEMENTASSEMBLY('1Td1iR003FuZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#2022,$,'ANK/63(?)',.NOTDEFINED.,.RIGID_FRAME.);
#2024= IFCCARTESIANPOINT((47275.0016158756,-629.151287104069,10614.));
#2025= IFCAXIS2PLACEMENT3D(#2024,#7,#8);
#2026= IFCLOCALPLACEMENT(#2022,#2025);
#2027= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#542));
#2028= IFCPRODUCTDEFINITIONSHAPE($,$,(#2027));
#2029= IFCBEAM('1Td1iR003Fup4rDp0rCJ4s',#5,'ANKRAJ','PLT16*150','PLT16*150',#2026,#2028,'P/379(?)');
#2030= IFCLOCALPLACEMENT(#30,#10);
#2031= IFCELEMENTASSEMBLY('1Td1iR003FtZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#2030,$,'ANK/61(?)',.NOTDEFINED.,.RIGID_FRAME.);
#2032= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' +10.515'),$);
#2033= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +10.665'),$);
#2034= IFCPROPERTYSET('16EwcKc2T21v2Bp1kXQnV2',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1611,#2032,#2033,#1614,#1615,#1616));
#2035= IFCCARTESIANPOINT((47263.8303183166,-238.761303583808,10590.));
#2036= IFCAXIS2PLACEMENT3D(#2035,#9,#1621);
#2037= IFCLOCALPLACEMENT(#2030,#2036);
#2038= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1631));
#2039= IFCPRODUCTDEFINITIONSHAPE($,$,(#2038));
#2040= IFCBEAM('1Td1iR003Ftp4rDp0rCJ4s',#5,'PUL','PLT30*150','PLT30*150',#2037,#2039,'P/377(?)');
#2041= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +10.665'),$);
#2042= IFCPROPERTYSET('2e8DnxUSP2o9OZh300gxd2',#5,'Tekla Common','Common Properties to Shared building elements',(#1266,#2041,#1638,#1639,#74,#75,#919,#1640,#78,#1641,#1642));
#2043= IFCLOCALPLACEMENT(#30,#10);
#2044= IFCELEMENTASSEMBLY('1Td1iR003FsZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#2043,$,'ANK/61(?)',.NOTDEFINED.,.RIGID_FRAME.);
#2045= IFCPROPERTYSET('1s0mEFQun8Ix38HChLHIUG',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1665,#2032,#2033,#1614,#1615,#1616));
#2046= IFCCARTESIANPOINT((47536.1696399369,-238.76131148119,10590.));
#2047= IFCAXIS2PLACEMENT3D(#2046,#9,#1670);
#2048= IFCLOCALPLACEMENT(#2043,#2047);
#2049= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1673));
#2050= IFCPRODUCTDEFINITIONSHAPE($,$,(#2049));
#2051= IFCBEAM('1Td1iR003Fsp4rDp0rCJ4s',#5,'PUL','PLT30*150','PLT30*150',#2048,#2050,'P/377(?)');
#2052= IFCLOCALPLACEMENT(#30,#10);
#2053= IFCELEMENTASSEMBLY('1Td1iR003FrZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#2052,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#2054= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' +10.573'),$);
#2055= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +10.607'),$);
#2056= IFCPROPERTYSET('3PDe6X3MDEluzTBSB7fTmL',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#2054,#2055,#1700,#1615,#1701));
#2057= IFCCARTESIANPOINT((47616.8561910801,-257.190864719625,10590.));
#2058= IFCAXIS2PLACEMENT3D(#2057,#1706,#1707);
#2059= IFCLOCALPLACEMENT(#2052,#2058);
#2060= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1722));
#2061= IFCPRODUCTDEFINITIONSHAPE($,$,(#2060));
#2062= IFCBEAM('1Td1iR003Frp4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#2059,#2061,'XX/0(?)');
#2063= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +10.573'),$);
#2064= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +10.607'),$);
#2065= IFCPROPERTYSET('3bRMc_bvn5FO3A8LB8izAQ',#5,'Tekla Common','Common Properties to Shared building elements',(#2063,#2064,#1730,#1731,#74,#75,#919,#1194,#1732,#1733,#1734));
#2066= IFCLOCALPLACEMENT(#30,#10);
#2067= IFCELEMENTASSEMBLY('1Td1iR003FqZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#2066,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#2068= IFCCARTESIANPOINT((47613.4878455301,-241.549277321974,10590.));
#2069= IFCAXIS2PLACEMENT3D(#2068,#1706,#1707);
#2070= IFCLOCALPLACEMENT(#2066,#2069);
#2071= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1762));
#2072= IFCPRODUCTDEFINITIONSHAPE($,$,(#2071));
#2073= IFCBEAM('1Td1iR003Fqp4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#2070,#2072,'XX/0(?)');
#2074= IFCLOCALPLACEMENT(#30,#10);
#2075= IFCELEMENTASSEMBLY('1Td1iR003FpZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#2074,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#2076= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' +10.568'),$);
#2077= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +10.612'),$);
#2078= IFCPROPERTYSET('0t_G6rL3D2AgoKKdJrarTH',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#2076,#2077,#1775,#1615,#1701));
#2079= IFCCARTESIANPOINT((47612.6453400033,-237.638892502491,10590.));
#2080= IFCAXIS2PLACEMENT3D(#2079,#1670,#1780);
#2081= IFCLOCALPLACEMENT(#2074,#2080);
#2082= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1786));
#2083= IFCPRODUCTDEFINITIONSHAPE($,$,(#2082));
#2084= IFCBEAM('1Td1iR003Fpp4rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#2081,#2083,'XX/0(?)');
#2085= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +10.568'),$);
#2086= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +10.612'),$);
#2087= IFCPROPERTYSET('3FbFcZSMj8dAKKS6W4xB2e',#5,'Tekla Common','Common Properties to Shared building elements',(#2085,#2086,#1730,#1731,#74,#75,#919,#1194,#1732,#1794,#1795));
#2088= IFCLOCALPLACEMENT(#30,#10);
#2089= IFCELEMENTASSEMBLY('1Td1iR003FoZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#2088,$,'R/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#2090= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' +10.580'),$);
#2091= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +10.600'),$);
#2092= IFCPROPERTYSET('2R$DxRiWv7TwoQO0RQOS2L',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#2090,#2091,#1814,#1615,#1815));
#2093= IFCCARTESIANPOINT((47625.1344111934,-295.638490283985,10590.));
#2094= IFCAXIS2PLACEMENT3D(#2093,#1820,#1821);
#2095= IFCLOCALPLACEMENT(#2088,#2094);
#2096= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1829));
#2097= IFCPRODUCTDEFINITIONSHAPE($,$,(#2096));
#2098= IFCBEAM('1Td1iR003Fop4rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#2095,#2097,'P/0(?)');
#2099= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +10.580'),$);
#2100= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +10.600'),$);
#2101= IFCPROPERTYSET('3d40cL3uXFIQ0QOGiqzq8M',#5,'Tekla Common','Common Properties to Shared building elements',(#2099,#2100,#1009,#1837,#74,#75,#919,#515,#1838,#1839,#1840));
#2102= IFCCARTESIANPOINT((47469.9999731708,-444.152091930489,10598.));
#2103= IFCAXIS2PLACEMENT3D(#2102,#9,#8);
#2104= IFCLOCALPLACEMENT(#1243,#2103);
#2105= IFCBOOLEANRESULT(.DIFFERENCE.,#1887,#1894);
#2106= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#2105));
#2107= IFCPRODUCTDEFINITIONSHAPE($,$,(#2106));
#2108= IFCPLATE('1Td1iR003Fn34rDp0rCJ4s',#5,'ANCHOR','PL16*436','PL16*436',#2104,#2107,'P/0(?)');
#2109= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +10.590'),$);
#2110= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +10.606'),$);
#2111= IFCPROPERTYSET('1K4IU7cAr8RwV1WlFpS2dj',#5,'Tekla Common','Common Properties to Shared building elements',(#2109,#2110,#1009,#1010,#74,#75,#919,#77,#78,#1903,#1904));
#2112= IFCPROPERTYSET('27H8SIAZzE8ulr8NT6LYIf',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1258,#1906,#1907,#1908,#1909,#1910,#1911,#1912,#1913,#1914,#1915,#1916,#94,#1917));
#2113= IFCLOCALPLACEMENT(#30,#10);
#2114= IFCELEMENTASSEMBLY('1Td1iR003Flp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#2113,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#2115= IFCCARTESIANPOINT((47183.1442023679,-257.190838696384,10590.));
#2116= IFCAXIS2PLACEMENT3D(#2115,#1928,#1929);
#2117= IFCLOCALPLACEMENT(#2113,#2116);
#2118= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1932));
#2119= IFCPRODUCTDEFINITIONSHAPE($,$,(#2118));
#2120= IFCBEAM('1Td1iR003Fm34rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#2117,#2119,'XX/0(?)');
#2121= IFCLOCALPLACEMENT(#30,#10);
#2122= IFCELEMENTASSEMBLY('1Td1iR003Fkp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#2121,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#2123= IFCCARTESIANPOINT((47186.5125497949,-241.549251702942,10590.));
#2124= IFCAXIS2PLACEMENT3D(#2123,#1928,#1929);
#2125= IFCLOCALPLACEMENT(#2121,#2124);
#2126= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1952));
#2127= IFCPRODUCTDEFINITIONSHAPE($,$,(#2126));
#2128= IFCBEAM('1Td1iR003Fl34rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#2125,#2127,'XX/0(?)');
#2129= IFCLOCALPLACEMENT(#30,#10);
#2130= IFCELEMENTASSEMBLY('1Td1iR003Fjp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#2129,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#2131= IFCCARTESIANPOINT((47187.355055791,-237.638866984562,10590.));
#2132= IFCAXIS2PLACEMENT3D(#2131,#1621,#1966);
#2133= IFCLOCALPLACEMENT(#2129,#2132);
#2134= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1969));
#2135= IFCPRODUCTDEFINITIONSHAPE($,$,(#2134));
#2136= IFCBEAM('1Td1iR003Fk34rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#2133,#2135,'XX/0(?)');
#2137= IFCLOCALPLACEMENT(#30,#10);
#2138= IFCELEMENTASSEMBLY('1Td1iR003Fip4rDp0rCJ4s',#5,'Steel Assembly',$,$,#2137,$,'R/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#2139= IFCCARTESIANPOINT((47174.8659776408,-295.638463267343,10590.));
#2140= IFCAXIS2PLACEMENT3D(#2139,#1988,#1989);
#2141= IFCLOCALPLACEMENT(#2137,#2140);
#2142= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1992));
#2143= IFCPRODUCTDEFINITIONSHAPE($,$,(#2142));
#2144= IFCBEAM('1Td1iR003Fj34rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#2141,#2143,'P/0(?)');
#2145= IFCLOCALPLACEMENT(#30,#10);
#2146= IFCELEMENTASSEMBLY('1Td1iR003Fhp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#2145,$,'ANK/63(?)',.NOTDEFINED.,.RIGID_FRAME.);
#2147= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' +4.906'),$);
#2148= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +4.922'),$);
#2149= IFCPROPERTYSET('3SO1_jreD6FRTFiEQvhFwp',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#485,#2147,#2148,#39,#488,#489));
#2150= IFCCARTESIANPOINT((47524.9997504966,-629.151268223872,4914.));
#2151= IFCAXIS2PLACEMENT3D(#2150,#7,#8);
#2152= IFCLOCALPLACEMENT(#2145,#2151);
#2153= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#504));
#2154= IFCPRODUCTDEFINITIONSHAPE($,$,(#2153));
#2155= IFCBEAM('1Td1iR003Fi34rDp0rCJ4s',#5,'ANKRAJ','PLT16*150','PLT16*150',#2152,#2154,'P/379(?)');
#2156= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +4.906'),$);
#2157= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +4.922'),$);
#2158= IFCPROPERTYSET('2T1zi9MPr7ku_2hH5aAAiI',#5,'Tekla Common','Common Properties to Shared building elements',(#2156,#2157,#512,#513,#74,#75,#514,#515,#78,#516,#80));
#2159= IFCLOCALPLACEMENT(#30,#10);
#2160= IFCELEMENTASSEMBLY('1Td1iR003Fgp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#2159,$,'ANK/63(?)',.NOTDEFINED.,.RIGID_FRAME.);
#2161= IFCCARTESIANPOINT((47275.0016158756,-629.151287104069,4914.));
#2162= IFCAXIS2PLACEMENT3D(#2161,#7,#8);
#2163= IFCLOCALPLACEMENT(#2159,#2162);
#2164= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#542));
#2165= IFCPRODUCTDEFINITIONSHAPE($,$,(#2164));
#2166= IFCBEAM('1Td1iR003Fh34rDp0rCJ4s',#5,'ANKRAJ','PLT16*150','PLT16*150',#2163,#2165,'P/379(?)');
#2167= IFCLOCALPLACEMENT(#30,#10);
#2168= IFCELEMENTASSEMBLY('1Td1iR003Ffp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#2167,$,'ANK/61(?)',.NOTDEFINED.,.RIGID_FRAME.);
#2169= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' +4.815'),$);
#2170= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +4.965'),$);
#2171= IFCPROPERTYSET('2YJp$y6KT1Q9EbWOreUCPd',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1611,#2169,#2170,#1614,#1615,#1616));
#2172= IFCCARTESIANPOINT((47263.8303183166,-238.761303583808,4890.));
#2173= IFCAXIS2PLACEMENT3D(#2172,#9,#1621);
#2174= IFCLOCALPLACEMENT(#2167,#2173);
#2175= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1631));
#2176= IFCPRODUCTDEFINITIONSHAPE($,$,(#2175));
#2177= IFCBEAM('1Td1iR003Fg34rDp0rCJ4s',#5,'PUL','PLT30*150','PLT30*150',#2174,#2176,'P/377(?)');
#2178= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +4.965'),$);
#2179= IFCPROPERTYSET('3Hi13dMbbB2hOATIJOiqgM',#5,'Tekla Common','Common Properties to Shared building elements',(#1376,#2178,#1638,#1639,#74,#75,#919,#1640,#78,#1641,#1642));
#2180= IFCLOCALPLACEMENT(#30,#10);
#2181= IFCELEMENTASSEMBLY('1Td1iR003Fep4rDp0rCJ4s',#5,'Steel Assembly',$,$,#2180,$,'ANK/61(?)',.NOTDEFINED.,.RIGID_FRAME.);
#2182= IFCPROPERTYSET('2nPpFv4w50b8VSQt_MCRdO',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1665,#2169,#2170,#1614,#1615,#1616));
#2183= IFCCARTESIANPOINT((47536.1696399369,-238.76131148119,4890.));
#2184= IFCAXIS2PLACEMENT3D(#2183,#9,#1670);
#2185= IFCLOCALPLACEMENT(#2180,#2184);
#2186= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1673));
#2187= IFCPRODUCTDEFINITIONSHAPE($,$,(#2186));
#2188= IFCBEAM('1Td1iR003Ff34rDp0rCJ4s',#5,'PUL','PLT30*150','PLT30*150',#2185,#2187,'P/377(?)');
#2189= IFCLOCALPLACEMENT(#30,#10);
#2190= IFCELEMENTASSEMBLY('1Td1iR003Fdp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#2189,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#2191= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' +4.873'),$);
#2192= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +4.907'),$);
#2193= IFCPROPERTYSET('0FrNEMLMzF9hzKvcMtu0mK',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#2191,#2192,#1700,#1615,#1701));
#2194= IFCCARTESIANPOINT((47616.8561910801,-257.190864719625,4890.));
#2195= IFCAXIS2PLACEMENT3D(#2194,#1706,#1707);
#2196= IFCLOCALPLACEMENT(#2189,#2195);
#2197= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1722));
#2198= IFCPRODUCTDEFINITIONSHAPE($,$,(#2197));
#2199= IFCBEAM('1Td1iR003Fe34rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#2196,#2198,'XX/0(?)');
#2200= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +4.873'),$);
#2201= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +4.907'),$);
#2202= IFCPROPERTYSET('37CgofZP5FdBXDzpXGyFGt',#5,'Tekla Common','Common Properties to Shared building elements',(#2200,#2201,#1730,#1731,#74,#75,#919,#1194,#1732,#1733,#1734));
#2203= IFCLOCALPLACEMENT(#30,#10);
#2204= IFCELEMENTASSEMBLY('1Td1iR003Fcp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#2203,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#2205= IFCCARTESIANPOINT((47613.4878455301,-241.549277321974,4890.));
#2206= IFCAXIS2PLACEMENT3D(#2205,#1706,#1707);
#2207= IFCLOCALPLACEMENT(#2203,#2206);
#2208= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1762));
#2209= IFCPRODUCTDEFINITIONSHAPE($,$,(#2208));
#2210= IFCBEAM('1Td1iR003Fd34rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#2207,#2209,'XX/0(?)');
#2211= IFCLOCALPLACEMENT(#30,#10);
#2212= IFCELEMENTASSEMBLY('1Td1iR003Fbp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#2211,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#2213= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' +4.868'),$);
#2214= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +4.912'),$);
#2215= IFCPROPERTYSET('2XPcOvw7T5Fe1HWGS32CSL',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#2213,#2214,#1775,#1615,#1701));
#2216= IFCCARTESIANPOINT((47612.6453400033,-237.638892502491,4890.));
#2217= IFCAXIS2PLACEMENT3D(#2216,#1670,#1780);
#2218= IFCLOCALPLACEMENT(#2211,#2217);
#2219= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1786));
#2220= IFCPRODUCTDEFINITIONSHAPE($,$,(#2219));
#2221= IFCBEAM('1Td1iR003Fc34rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#2218,#2220,'XX/0(?)');
#2222= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +4.868'),$);
#2223= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +4.912'),$);
#2224= IFCPROPERTYSET('2NagkWzOr6T86IqRkW4S6h',#5,'Tekla Common','Common Properties to Shared building elements',(#2222,#2223,#1730,#1731,#74,#75,#919,#1194,#1732,#1794,#1795));
#2225= IFCPROPERTYSET('0H3DNpL29DWhkLTuUzW0as',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#1974,#1975,#1976,#1743,#1744,#1977,#1978,#1802,#1803,#1804));
#2226= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0018006258232555);
#2227= IFCQUANTITYVOLUME('NetVolume',$,$,3.93299999999816E-006);
#2228= IFCELEMENTQUANTITY('2gmwVvaQXEGh51WJ$zPA2K',#5,'BaseQuantities',$,$,(#1806,#2226,#2227,#1754));
#2229= IFCLOCALPLACEMENT(#30,#10);
#2230= IFCELEMENTASSEMBLY('1Td1iR003Fap4rDp0rCJ4s',#5,'Steel Assembly',$,$,#2229,$,'R/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#2231= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' +4.880'),$);
#2232= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +4.900'),$);
#2233= IFCPROPERTYSET('3GtHhvbTb7PQlqcNnQzCPJ',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#2231,#2232,#1814,#1615,#1815));
#2234= IFCCARTESIANPOINT((47625.1344111934,-295.638490283985,4890.));
#2235= IFCAXIS2PLACEMENT3D(#2234,#1820,#1821);
#2236= IFCLOCALPLACEMENT(#2229,#2235);
#2237= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1829));
#2238= IFCPRODUCTDEFINITIONSHAPE($,$,(#2237));
#2239= IFCBEAM('1Td1iR003Fb34rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#2236,#2238,'P/0(?)');
#2240= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +4.880'),$);
#2241= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +4.900'),$);
#2242= IFCPROPERTYSET('2U4VPtcMz6FeQ5cv3xTg2W',#5,'Tekla Common','Common Properties to Shared building elements',(#2240,#2241,#1009,#1837,#74,#75,#919,#515,#1838,#1839,#1840));
#2243= IFCPROPERTYSET('07NwtOpJP5Cf_r1EgTdTbT',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#1997,#1998,#1999,#1743,#1744,#2000,#2001,#1847,#1848,#1849));
#2244= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0232205665089682);
#2245= IFCQUANTITYVOLUME('NetVolume',$,$,0.000104651904724881);
#2246= IFCELEMENTQUANTITY('0m9EolII14kOMGVoa_3kd2',#5,'BaseQuantities',$,$,(#1851,#2244,#2245,#1754));
#2247= IFCCARTESIANPOINT((47469.9999731708,-444.152091930489,4898.));
#2248= IFCAXIS2PLACEMENT3D(#2247,#9,#8);
#2249= IFCLOCALPLACEMENT(#1356,#2248);
#2250= IFCBOOLEANRESULT(.DIFFERENCE.,#1887,#1894);
#2251= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#2250));
#2252= IFCPRODUCTDEFINITIONSHAPE($,$,(#2251));
#2253= IFCPLATE('1Td1iR003FZJ4rDp0rCJ4s',#5,'ANCHOR','PL16*436','PL16*436',#2249,#2252,'P/0(?)');
#2254= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +4.890'),$);
#2255= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +4.906'),$);
#2256= IFCPROPERTYSET('3NFz2$Em92vByUhq4OTluL',#5,'Tekla Common','Common Properties to Shared building elements',(#2254,#2255,#1009,#1010,#74,#75,#919,#77,#78,#1903,#1904));
#2257= IFCLOCALPLACEMENT(#30,#10);
#2258= IFCELEMENTASSEMBLY('1Td1iR003FY34rDp0rCJ4s',#5,'Steel Assembly',$,$,#2257,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#2259= IFCCARTESIANPOINT((47183.1442023679,-257.190838696384,4890.));
#2260= IFCAXIS2PLACEMENT3D(#2259,#1928,#1929);
#2261= IFCLOCALPLACEMENT(#2257,#2260);
#2262= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1932));
#2263= IFCPRODUCTDEFINITIONSHAPE($,$,(#2262));
#2264= IFCBEAM('1Td1iR003FYJ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#2261,#2263,'XX/0(?)');
#2265= IFCLOCALPLACEMENT(#30,#10);
#2266= IFCELEMENTASSEMBLY('1Td1iR003FX34rDp0rCJ4s',#5,'Steel Assembly',$,$,#2265,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#2267= IFCCARTESIANPOINT((47186.5125497949,-241.549251702942,4890.));
#2268= IFCAXIS2PLACEMENT3D(#2267,#1928,#1929);
#2269= IFCLOCALPLACEMENT(#2265,#2268);
#2270= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1952));
#2271= IFCPRODUCTDEFINITIONSHAPE($,$,(#2270));
#2272= IFCBEAM('1Td1iR003FXJ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#2269,#2271,'XX/0(?)');
#2273= IFCLOCALPLACEMENT(#30,#10);
#2274= IFCELEMENTASSEMBLY('1Td1iR003FW34rDp0rCJ4s',#5,'Steel Assembly',$,$,#2273,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#2275= IFCCARTESIANPOINT((47187.355055791,-237.638866984562,4890.));
#2276= IFCAXIS2PLACEMENT3D(#2275,#1621,#1966);
#2277= IFCLOCALPLACEMENT(#2273,#2276);
#2278= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1969));
#2279= IFCPRODUCTDEFINITIONSHAPE($,$,(#2278));
#2280= IFCBEAM('1Td1iR003FWJ4rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#2277,#2279,'XX/0(?)');
#2281= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(3.93300000001298E-006),$);
#2282= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(3.93300000001298E-006),$);
#2283= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(3.93300000001298E-006),$);
#2284= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0018006258232607),$);
#2285= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0018006258232607),$);
#2286= IFCPROPERTYSET('3eUxQYbbz0OxcVnFqrDZmB',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#2281,#2282,#2283,#1743,#1744,#2284,#2285,#1979,#1803,#1804));
#2287= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0018006258232607);
#2288= IFCQUANTITYVOLUME('NetVolume',$,$,3.93300000001298E-006);
#2289= IFCELEMENTQUANTITY('1cDahUBSr8Qh8ob1Nw$Txz',#5,'BaseQuantities',$,$,(#1981,#2287,#2288,#1754));
#2290= IFCLOCALPLACEMENT(#30,#10);
#2291= IFCELEMENTASSEMBLY('1Td1iR003FV34rDp0rCJ4s',#5,'Steel Assembly',$,$,#2290,$,'R/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#2292= IFCCARTESIANPOINT((47174.8659776408,-295.638463267343,4890.));
#2293= IFCAXIS2PLACEMENT3D(#2292,#1988,#1989);
#2294= IFCLOCALPLACEMENT(#2290,#2293);
#2295= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1992));
#2296= IFCPRODUCTDEFINITIONSHAPE($,$,(#2295));
#2297= IFCBEAM('1Td1iR003FVJ4rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#2294,#2296,'P/0(?)');
#2298= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000104651904724958),$);
#2299= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000104651904724958),$);
#2300= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000104651904724958),$);
#2301= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0232205665089777),$);
#2302= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0232205665089777),$);
#2303= IFCPROPERTYSET('3XMLpEWF1358ekcxv72FVO',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#2298,#2299,#2300,#1743,#1744,#2301,#2302,#1847,#1848,#2002));
#2304= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0232205665089777);
#2305= IFCQUANTITYVOLUME('NetVolume',$,$,0.000104651904724958);
#2306= IFCELEMENTQUANTITY('1ltU5xk3n3Q9y6PCIAIqOs',#5,'BaseQuantities',$,$,(#2004,#2304,#2305,#1754));
#2307= IFCLOCALPLACEMENT(#30,#10);
#2308= IFCELEMENTASSEMBLY('1Td1iR003FS34rDp0rCJ4s',#5,'Steel Assembly',$,$,#2307,$,'ANK/61(?)',.NOTDEFINED.,.RIGID_FRAME.);
#2309= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -1.185'),$);
#2310= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -1.035'),$);
#2311= IFCPROPERTYSET('1QGf9XqOXDVBvya32EmR7b',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1611,#2309,#2310,#1614,#1615,#1616));
#2312= IFCCARTESIANPOINT((47263.8303183166,-238.761303583808,-1110.));
#2313= IFCAXIS2PLACEMENT3D(#2312,#9,#1621);
#2314= IFCLOCALPLACEMENT(#2307,#2313);
#2315= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1631));
#2316= IFCPRODUCTDEFINITIONSHAPE($,$,(#2315));
#2317= IFCBEAM('1Td1iR003FSJ4rDp0rCJ4s',#5,'PUL','PLT30*150','PLT30*150',#2314,#2316,'P/377(?)');
#2318= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -1.035'),$);
#2319= IFCPROPERTYSET('3jRUBT$EX3r9nGi2iGu_qr',#5,'Tekla Common','Common Properties to Shared building elements',(#1520,#2318,#1638,#1639,#74,#75,#919,#1640,#78,#1641,#1642));
#2320= IFCLOCALPLACEMENT(#30,#10);
#2321= IFCELEMENTASSEMBLY('1Td1iR003FR34rDp0rCJ4s',#5,'Steel Assembly',$,$,#2320,$,'ANK/61(?)',.NOTDEFINED.,.RIGID_FRAME.);
#2322= IFCPROPERTYSET('2m0Fv6_Qz60wrrJqRbX0av',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1665,#2309,#2310,#1614,#1615,#1616));
#2323= IFCCARTESIANPOINT((47536.1696399369,-238.76131148119,-1110.));
#2324= IFCAXIS2PLACEMENT3D(#2323,#9,#1670);
#2325= IFCLOCALPLACEMENT(#2320,#2324);
#2326= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1673));
#2327= IFCPRODUCTDEFINITIONSHAPE($,$,(#2326));
#2328= IFCBEAM('1Td1iR003FRJ4rDp0rCJ4s',#5,'PUL','PLT30*150','PLT30*150',#2325,#2327,'P/377(?)');
#2329= IFCLOCALPLACEMENT(#30,#10);
#2330= IFCELEMENTASSEMBLY('1Td1iR003FQ34rDp0rCJ4s',#5,'Steel Assembly',$,$,#2329,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#2331= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -1.127'),$);
#2332= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -1.093'),$);
#2333= IFCPROPERTYSET('2TMlQpPifEtQs8nqu0L9IP',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#2331,#2332,#1700,#1615,#1701));
#2334= IFCCARTESIANPOINT((47616.8561910801,-257.190864719625,-1110.));
#2335= IFCAXIS2PLACEMENT3D(#2334,#1706,#1707);
#2336= IFCLOCALPLACEMENT(#2329,#2335);
#2337= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1722));
#2338= IFCPRODUCTDEFINITIONSHAPE($,$,(#2337));
#2339= IFCBEAM('1Td1iR003FQJ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#2336,#2338,'XX/0(?)');
#2340= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -1.127'),$);
#2341= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -1.093'),$);
#2342= IFCPROPERTYSET('22qVNcUXT0_89pvL1fh1Ul',#5,'Tekla Common','Common Properties to Shared building elements',(#2340,#2341,#1730,#1731,#74,#75,#919,#1194,#1732,#1733,#1734));
#2343= IFCLOCALPLACEMENT(#30,#10);
#2344= IFCELEMENTASSEMBLY('1Td1iR003FP34rDp0rCJ4s',#5,'Steel Assembly',$,$,#2343,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#2345= IFCCARTESIANPOINT((47613.4878455301,-241.549277321974,-1110.));
#2346= IFCAXIS2PLACEMENT3D(#2345,#1706,#1707);
#2347= IFCLOCALPLACEMENT(#2343,#2346);
#2348= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1762));
#2349= IFCPRODUCTDEFINITIONSHAPE($,$,(#2348));
#2350= IFCBEAM('1Td1iR003FPJ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#2347,#2349,'XX/0(?)');
#2351= IFCLOCALPLACEMENT(#30,#10);
#2352= IFCELEMENTASSEMBLY('1Td1iR003FO34rDp0rCJ4s',#5,'Steel Assembly',$,$,#2351,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#2353= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -1.132'),$);
#2354= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -1.088'),$);
#2355= IFCPROPERTYSET('3GRnuraML9S9ATAZIfPfq4',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#2353,#2354,#1775,#1615,#1701));
#2356= IFCCARTESIANPOINT((47612.6453400033,-237.638892502491,-1110.));
#2357= IFCAXIS2PLACEMENT3D(#2356,#1670,#1780);
#2358= IFCLOCALPLACEMENT(#2351,#2357);
#2359= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1786));
#2360= IFCPRODUCTDEFINITIONSHAPE($,$,(#2359));
#2361= IFCBEAM('1Td1iR003FOJ4rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#2358,#2360,'XX/0(?)');
#2362= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -1.132'),$);
#2363= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -1.088'),$);
#2364= IFCPROPERTYSET('0cinJ2FZDDaA9f3R4l6SbC',#5,'Tekla Common','Common Properties to Shared building elements',(#2362,#2363,#1730,#1731,#74,#75,#919,#1194,#1732,#1794,#1795));
#2365= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00180062582325549);
#2366= IFCQUANTITYVOLUME('NetVolume',$,$,3.93299999999813E-006);
#2367= IFCELEMENTQUANTITY('04g6MMlEf2c9epJ5Bv1xdI',#5,'BaseQuantities',$,$,(#1806,#2365,#2366,#1754));
#2368= IFCLOCALPLACEMENT(#30,#10);
#2369= IFCELEMENTASSEMBLY('1Td1iR003FN34rDp0rCJ4s',#5,'Steel Assembly',$,$,#2368,$,'R/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#2370= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -1.120'),$);
#2371= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -1.100'),$);
#2372= IFCPROPERTYSET('3$iGSBJkL5feSoZevAMOmd',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#2370,#2371,#1814,#1615,#1815));
#2373= IFCCARTESIANPOINT((47625.1344111934,-295.638490283985,-1110.));
#2374= IFCAXIS2PLACEMENT3D(#2373,#1820,#1821);
#2375= IFCLOCALPLACEMENT(#2368,#2374);
#2376= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1829));
#2377= IFCPRODUCTDEFINITIONSHAPE($,$,(#2376));
#2378= IFCBEAM('1Td1iR003FNJ4rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#2375,#2377,'P/0(?)');
#2379= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -1.120'),$);
#2380= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -1.100'),$);
#2381= IFCPROPERTYSET('2YcYKBlzr4DxoMFtNmuKV2',#5,'Tekla Common','Common Properties to Shared building elements',(#2379,#2380,#1009,#1837,#74,#75,#919,#515,#1838,#1839,#1840));
#2382= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.023220566508968);
#2383= IFCQUANTITYVOLUME('NetVolume',$,$,0.000104651904724879);
#2384= IFCELEMENTQUANTITY('0HUJ4pvyL9HA5TW4RRG$5a',#5,'BaseQuantities',$,$,(#1851,#2382,#2383,#1754));
#2385= IFCCARTESIANPOINT((47469.9999731708,-444.152091930489,-1102.));
#2386= IFCAXIS2PLACEMENT3D(#2385,#9,#8);
#2387= IFCLOCALPLACEMENT(#1500,#2386);
#2388= IFCBOOLEANRESULT(.DIFFERENCE.,#1887,#1894);
#2389= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#2388));
#2390= IFCPRODUCTDEFINITIONSHAPE($,$,(#2389));
#2391= IFCPLATE('1Td1iR003FLZ4rDp0rCJ4s',#5,'ANCHOR','PL16*436','PL16*436',#2387,#2390,'P/0(?)');
#2392= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -1.110'),$);
#2393= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -1.094'),$);
#2394= IFCPROPERTYSET('3GnXLAIVf4i84awKqvX5JH',#5,'Tekla Common','Common Properties to Shared building elements',(#2392,#2393,#1009,#1010,#74,#75,#919,#77,#78,#1903,#1904));
#2395= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(17.5593606468869),$);
#2396= IFCPROPERTYSET('2fKNOYLqj2WO2GniIu169E',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1013,#1906,#1907,#1908,#1909,#1910,#1911,#1912,#2395,#1914,#1915,#1916,#94,#1917));
#2397= IFCQUANTITYAREA('NetArea',$,$,0.312619864314281);
#2398= IFCQUANTITYVOLUME('NetVolume',$,$,0.0022679747479252);
#2399= IFCELEMENTQUANTITY('0yn7teTMP9$RiBCtWiQJlo',#5,'BaseQuantities',$,$,(#1919,#2397,#1921,#100,#2398,#1923));
#2400= IFCLOCALPLACEMENT(#30,#10);
#2401= IFCELEMENTASSEMBLY('1Td1iR003FKJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#2400,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#2402= IFCCARTESIANPOINT((47183.1442023679,-257.190838696384,-1110.));
#2403= IFCAXIS2PLACEMENT3D(#2402,#1928,#1929);
#2404= IFCLOCALPLACEMENT(#2400,#2403);
#2405= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1932));
#2406= IFCPRODUCTDEFINITIONSHAPE($,$,(#2405));
#2407= IFCBEAM('1Td1iR003FKZ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#2404,#2406,'XX/0(?)');
#2408= IFCLOCALPLACEMENT(#30,#10);
#2409= IFCELEMENTASSEMBLY('1Td1iR003FJJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#2408,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#2410= IFCCARTESIANPOINT((47186.5125497949,-241.549251702942,-1110.));
#2411= IFCAXIS2PLACEMENT3D(#2410,#1928,#1929);
#2412= IFCLOCALPLACEMENT(#2408,#2411);
#2413= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1952));
#2414= IFCPRODUCTDEFINITIONSHAPE($,$,(#2413));
#2415= IFCBEAM('1Td1iR003FJZ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#2412,#2414,'XX/0(?)');
#2416= IFCLOCALPLACEMENT(#30,#10);
#2417= IFCELEMENTASSEMBLY('1Td1iR003FIJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#2416,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#2418= IFCCARTESIANPOINT((47187.355055791,-237.638866984562,-1110.));
#2419= IFCAXIS2PLACEMENT3D(#2418,#1621,#1966);
#2420= IFCLOCALPLACEMENT(#2416,#2419);
#2421= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1969));
#2422= IFCPRODUCTDEFINITIONSHAPE($,$,(#2421));
#2423= IFCBEAM('1Td1iR003FIZ4rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#2420,#2422,'XX/0(?)');
#2424= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00180062582326069);
#2425= IFCQUANTITYVOLUME('NetVolume',$,$,3.93300000001294E-006);
#2426= IFCELEMENTQUANTITY('3neReXhEDFMOmHjE1MPfHl',#5,'BaseQuantities',$,$,(#1981,#2424,#2425,#1754));
#2427= IFCLOCALPLACEMENT(#30,#10);
#2428= IFCELEMENTASSEMBLY('1Td1iR003FHJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#2427,$,'R/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#2429= IFCCARTESIANPOINT((47174.8659776408,-295.638463267343,-1110.));
#2430= IFCAXIS2PLACEMENT3D(#2429,#1988,#1989);
#2431= IFCLOCALPLACEMENT(#2427,#2430);
#2432= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1992));
#2433= IFCPRODUCTDEFINITIONSHAPE($,$,(#2432));
#2434= IFCBEAM('1Td1iR003FHZ4rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#2431,#2433,'P/0(?)');
#2435= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0232205665089775);
#2436= IFCQUANTITYVOLUME('NetVolume',$,$,0.000104651904724956);
#2437= IFCELEMENTQUANTITY('2B5EwM9d1AoxfdqyDdtKOs',#5,'BaseQuantities',$,$,(#2004,#2435,#2436,#1754));
#2438= IFCCARTESIANPOINT((48704.1287026321,874.976717486887,15787.999));
#2439= IFCAXIS2PLACEMENT3D(#2438,#185,#8);
#2440= IFCLOCALPLACEMENT(#30,#2439);
#2441= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,42.5);
#2442= IFCEXTRUDEDAREASOLID(#2441,#561,#9,16.1000000000012);
#2443= IFCSTYLEDITEM(#2442,(#195),$);
#2444= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#2442));
#2445= IFCREPRESENTATIONMAP(#10,#2444);
#2446= IFCMAPPEDITEM(#2445,#247);
#2447= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#2446));
#2448= IFCPRODUCTDEFINITIONSHAPE($,$,(#2447));
#2449= IFCMECHANICALFASTENER('1Td1iR003FD34rDp0rCJ4s',#5,'Bolt assembly',$,$,#2440,#2448,'ID5d9c1b1b-0000-cf34-3135-373035313136',30.,16.);
#2450= IFCCARTESIANPOINT((48704.1290775329,874.976999690607,15822.));
#2451= IFCAXIS2PLACEMENT3D(#2450,#7,#8);
#2452= IFCLOCALPLACEMENT(#30,#2451);
#2453= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#2454= IFCCARTESIANPOINT((0.,-16.0999999999982,0.));
#2455= IFCAXIS2PLACEMENT3D(#2454,#8,#7);
#2456= IFCEXTRUDEDAREASOLID(#2453,#2455,#9,16.1);
#2457= IFCSTYLEDITEM(#2456,(#195),$);
#2458= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#2459= IFCCARTESIANPOINT((0.,-32.0000000000007,0.));
#2460= IFCAXIS2PLACEMENT3D(#2459,#8,#7);
#2461= IFCEXTRUDEDAREASOLID(#2458,#2460,#9,16.0000000000012);
#2462= IFCSTYLEDITEM(#2461,(#195),$);
#2463= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#2464= IFCCARTESIANPOINT((0.,-47.900000000053,0.));
#2465= IFCAXIS2PLACEMENT3D(#2464,#8,#7);
#2466= IFCEXTRUDEDAREASOLID(#2463,#2465,#9,16.0000000000005);
#2467= IFCSTYLEDITEM(#2466,(#195),$);
#2468= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#219);
#2469= IFCCARTESIANPOINT((0.,-62.000000000053,0.));
#2470= IFCAXIS2PLACEMENT3D(#2469,#8,#7);
#2471= IFCEXTRUDEDAREASOLID(#2468,#2470,#9,14.);
#2472= IFCSTYLEDITEM(#2471,(#191),$);
#2473= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#2474= IFCCARTESIANPOINT((0.,-48.000000000053,0.));
#2475= IFCAXIS2PLACEMENT3D(#2474,#8,#7);
#2476= IFCEXTRUDEDAREASOLID(#2473,#2475,#9,80.);
#2477= IFCSTYLEDITEM(#2476,(#191),$);
#2478= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,22.);
#2479= IFCAXIS2PLACEMENT3D(#6,#8,#7);
#2480= IFCEXTRUDEDAREASOLID(#2478,#2479,#9,4.);
#2481= IFCSTYLEDITEM(#2480,(#191),$);
#2482= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#241);
#2483= IFCCARTESIANPOINT((0.,4.00000000000182,0.));
#2484= IFCAXIS2PLACEMENT3D(#2483,#8,#7);
#2485= IFCEXTRUDEDAREASOLID(#2482,#2484,#9,19.);
#2486= IFCSTYLEDITEM(#2485,(#191),$);
#2487= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#2456,#2461,#2466,#2471,#2476,#2480,#2485));
#2488= IFCREPRESENTATIONMAP(#10,#2487);
#2489= IFCMAPPEDITEM(#2488,#247);
#2490= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#2489));
#2491= IFCPRODUCTDEFINITIONSHAPE($,$,(#2490));
#2492= IFCMECHANICALFASTENER('1Td1iR003FCJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#2452,#2491,'ID5d9c1b1b-0000-cf31-3135-373035313136',24.,80.);
#2493= IFCPROPERTYSINGLEVALUE('Bolt length',$,IFCLENGTHMEASURE(80.),$);
#2494= IFCPROPERTYSINGLEVALUE('Bolt Name',$,IFCLABEL('M24*80'),$);
#2495= IFCPROPERTYSET('2RYFF7QAL3yx5LrppvlfkP',#5,'Tekla Bolt','Bolt Properties',(#255,#256,#257,#258,#259,#260,#261,#262,#263,#264,#265,#266,#267,#2493,#269,#2494));
#2496= IFCCARTESIANPOINT((48704.1286986322,624.976717486887,15787.999));
#2497= IFCAXIS2PLACEMENT3D(#2496,#185,#8);
#2498= IFCLOCALPLACEMENT(#30,#2497);
#2499= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,42.5);
#2500= IFCEXTRUDEDAREASOLID(#2499,#561,#9,16.1000000000012);
#2501= IFCSTYLEDITEM(#2500,(#195),$);
#2502= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#2500));
#2503= IFCREPRESENTATIONMAP(#10,#2502);
#2504= IFCMAPPEDITEM(#2503,#247);
#2505= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#2504));
#2506= IFCPRODUCTDEFINITIONSHAPE($,$,(#2505));
#2507= IFCMECHANICALFASTENER('1Td1iR003FBZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#2498,#2506,'ID5d9c1b1b-0000-cf2e-3135-373035313136',30.,16.);
#2508= IFCCARTESIANPOINT((48704.129073533,624.976999690607,15822.));
#2509= IFCAXIS2PLACEMENT3D(#2508,#7,#8);
#2510= IFCLOCALPLACEMENT(#30,#2509);
#2511= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#2512= IFCEXTRUDEDAREASOLID(#2511,#2455,#9,16.1);
#2513= IFCSTYLEDITEM(#2512,(#195),$);
#2514= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#2515= IFCEXTRUDEDAREASOLID(#2514,#2460,#9,16.0000000000012);
#2516= IFCSTYLEDITEM(#2515,(#195),$);
#2517= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#2518= IFCEXTRUDEDAREASOLID(#2517,#2465,#9,16.0000000000005);
#2519= IFCSTYLEDITEM(#2518,(#195),$);
#2520= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#219);
#2521= IFCEXTRUDEDAREASOLID(#2520,#2470,#9,14.);
#2522= IFCSTYLEDITEM(#2521,(#191),$);
#2523= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#2524= IFCEXTRUDEDAREASOLID(#2523,#2475,#9,80.);
#2525= IFCSTYLEDITEM(#2524,(#191),$);
#2526= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,22.);
#2527= IFCEXTRUDEDAREASOLID(#2526,#2479,#9,4.);
#2528= IFCSTYLEDITEM(#2527,(#191),$);
#2529= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#241);
#2530= IFCEXTRUDEDAREASOLID(#2529,#2484,#9,19.);
#2531= IFCSTYLEDITEM(#2530,(#191),$);
#2532= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#2512,#2515,#2518,#2521,#2524,#2527,#2530));
#2533= IFCREPRESENTATIONMAP(#10,#2532);
#2534= IFCMAPPEDITEM(#2533,#247);
#2535= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#2534));
#2536= IFCPRODUCTDEFINITIONSHAPE($,$,(#2535));
#2537= IFCMECHANICALFASTENER('1Td1iR003FAp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#2510,#2536,'ID5d9c1b1b-0000-cf2b-3135-373035313136',24.,80.);
#2538= IFCCARTESIANPOINT((48382.3060625171,538.473696194465,15790.));
#2539= IFCDIRECTION((-0.210487902062822,-0.977596462291672,0.));
#2540= IFCAXIS2PLACEMENT3D(#2538,#596,#2539);
#2541= IFCLOCALPLACEMENT(#30,#2540);
#2542= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#2543= IFCEXTRUDEDAREASOLID(#2542,#602,#9,30.0999999999412);
#2544= IFCSTYLEDITEM(#2543,(#195),$);
#2545= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#2543));
#2546= IFCREPRESENTATIONMAP(#10,#2545);
#2547= IFCMAPPEDITEM(#2546,#247);
#2548= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#2547));
#2549= IFCPRODUCTDEFINITIONSHAPE($,$,(#2548));
#2550= IFCMECHANICALFASTENER('1Td1iR003FA34rDp0rCJ4s',#5,'Bolt assembly',$,$,#2541,#2549,'ID5d9c1b1b-0000-cf28-3135-373035313136',20.,30.);
#2551= IFCCARTESIANPOINT((48352.9780740257,955.16326595148,15790.));
#2552= IFCDIRECTION((-0.190924602913222,0.98160470455394,0.));
#2553= IFCAXIS2PLACEMENT3D(#2551,#9,#2552);
#2554= IFCLOCALPLACEMENT(#30,#2553);
#2555= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,71.);
#2556= IFCEXTRUDEDAREASOLID(#2555,#625,#9,30.1063464563484);
#2557= IFCSTYLEDITEM(#2556,(#195),$);
#2558= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#2556));
#2559= IFCREPRESENTATIONMAP(#10,#2558);
#2560= IFCMAPPEDITEM(#2559,#247);
#2561= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#2560));
#2562= IFCPRODUCTDEFINITIONSHAPE($,$,(#2561));
#2563= IFCMECHANICALFASTENER('1Td1iR003F9J4rDp0rCJ4s',#5,'Bolt assembly',$,$,#2554,#2562,'ID5d9c1b1b-0000-cf25-3135-373035313136',20.,30.0063457489014);
#2564= IFCCARTESIANPOINT((48382.3060747835,961.478262432043,15790.));
#2565= IFCDIRECTION((-0.210487846074622,0.977596474346581,0.));
#2566= IFCAXIS2PLACEMENT3D(#2564,#9,#2565);
#2567= IFCLOCALPLACEMENT(#30,#2566);
#2568= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#2569= IFCEXTRUDEDAREASOLID(#2568,#602,#9,30.0999999999922);
#2570= IFCSTYLEDITEM(#2569,(#195),$);
#2571= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#2569));
#2572= IFCREPRESENTATIONMAP(#10,#2571);
#2573= IFCMAPPEDITEM(#2572,#247);
#2574= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#2573));
#2575= IFCPRODUCTDEFINITIONSHAPE($,$,(#2574));
#2576= IFCMECHANICALFASTENER('1Td1iR003F8Z4rDp0rCJ4s',#5,'Bolt assembly',$,$,#2567,#2575,'ID5d9c1b1b-0000-cf22-3135-373035313136',20.,30.);
#2577= IFCCARTESIANPOINT((48352.9780494028,544.789133999286,15790.));
#2578= IFCDIRECTION((-0.190924720922386,-0.981604681600852,0.));
#2579= IFCAXIS2PLACEMENT3D(#2577,#596,#2578);
#2580= IFCLOCALPLACEMENT(#30,#2579);
#2581= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,71.);
#2582= IFCEXTRUDEDAREASOLID(#2581,#658,#9,30.1061745232009);
#2583= IFCSTYLEDITEM(#2582,(#195),$);
#2584= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#2582));
#2585= IFCREPRESENTATIONMAP(#10,#2584);
#2586= IFCMAPPEDITEM(#2585,#247);
#2587= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#2586));
#2588= IFCPRODUCTDEFINITIONSHAPE($,$,(#2587));
#2589= IFCMECHANICALFASTENER('1Td1iR003F7p4rDp0rCJ4s',#5,'Bolt assembly',$,$,#2580,#2588,'ID5d9c1b1b-0000-cf1f-3135-373035313136',20.,30.0061740875244);
#2590= IFCCARTESIANPOINT((48704.1287026321,874.976717486887,10587.999));
#2591= IFCAXIS2PLACEMENT3D(#2590,#185,#8);
#2592= IFCLOCALPLACEMENT(#30,#2591);
#2593= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,42.5);
#2594= IFCEXTRUDEDAREASOLID(#2593,#561,#9,16.0999999999991);
#2595= IFCSTYLEDITEM(#2594,(#195),$);
#2596= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#2594));
#2597= IFCREPRESENTATIONMAP(#10,#2596);
#2598= IFCMAPPEDITEM(#2597,#247);
#2599= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#2598));
#2600= IFCPRODUCTDEFINITIONSHAPE($,$,(#2599));
#2601= IFCMECHANICALFASTENER('1Td1iR003F734rDp0rCJ4s',#5,'Bolt assembly',$,$,#2592,#2600,'ID5d9c1b1b-0000-cf1c-3135-373035313136',30.,16.);
#2602= IFCCARTESIANPOINT((48704.1290775329,874.976999690607,10622.));
#2603= IFCAXIS2PLACEMENT3D(#2602,#7,#8);
#2604= IFCLOCALPLACEMENT(#30,#2603);
#2605= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#2606= IFCEXTRUDEDAREASOLID(#2605,#2455,#9,16.1);
#2607= IFCSTYLEDITEM(#2606,(#195),$);
#2608= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#2609= IFCEXTRUDEDAREASOLID(#2608,#2460,#9,15.9999999999991);
#2610= IFCSTYLEDITEM(#2609,(#195),$);
#2611= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#2612= IFCEXTRUDEDAREASOLID(#2611,#2465,#9,15.9999999999995);
#2613= IFCSTYLEDITEM(#2612,(#195),$);
#2614= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#219);
#2615= IFCEXTRUDEDAREASOLID(#2614,#2470,#9,14.);
#2616= IFCSTYLEDITEM(#2615,(#191),$);
#2617= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#2618= IFCEXTRUDEDAREASOLID(#2617,#2475,#9,80.);
#2619= IFCSTYLEDITEM(#2618,(#191),$);
#2620= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,22.);
#2621= IFCEXTRUDEDAREASOLID(#2620,#2479,#9,4.);
#2622= IFCSTYLEDITEM(#2621,(#191),$);
#2623= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#241);
#2624= IFCEXTRUDEDAREASOLID(#2623,#2484,#9,19.);
#2625= IFCSTYLEDITEM(#2624,(#191),$);
#2626= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#2606,#2609,#2612,#2615,#2618,#2621,#2624));
#2627= IFCREPRESENTATIONMAP(#10,#2626);
#2628= IFCMAPPEDITEM(#2627,#247);
#2629= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#2628));
#2630= IFCPRODUCTDEFINITIONSHAPE($,$,(#2629));
#2631= IFCMECHANICALFASTENER('1Td1iR003F6J4rDp0rCJ4s',#5,'Bolt assembly',$,$,#2604,#2630,'ID5d9c1b1b-0000-cf19-3135-373035313136',24.,80.);
#2632= IFCCARTESIANPOINT((48704.1286986322,624.976717486887,10587.999));
#2633= IFCAXIS2PLACEMENT3D(#2632,#185,#8);
#2634= IFCLOCALPLACEMENT(#30,#2633);
#2635= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,42.5);
#2636= IFCEXTRUDEDAREASOLID(#2635,#561,#9,16.0999999999991);
#2637= IFCSTYLEDITEM(#2636,(#195),$);
#2638= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#2636));
#2639= IFCREPRESENTATIONMAP(#10,#2638);
#2640= IFCMAPPEDITEM(#2639,#247);
#2641= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#2640));
#2642= IFCPRODUCTDEFINITIONSHAPE($,$,(#2641));
#2643= IFCMECHANICALFASTENER('1Td1iR003F5Z4rDp0rCJ4s',#5,'Bolt assembly',$,$,#2634,#2642,'ID5d9c1b1b-0000-cf16-3135-373035313136',30.,16.);
#2644= IFCCARTESIANPOINT((48704.129073533,624.976999690607,10622.));
#2645= IFCAXIS2PLACEMENT3D(#2644,#7,#8);
#2646= IFCLOCALPLACEMENT(#30,#2645);
#2647= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#2648= IFCEXTRUDEDAREASOLID(#2647,#2455,#9,16.1);
#2649= IFCSTYLEDITEM(#2648,(#195),$);
#2650= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#2651= IFCEXTRUDEDAREASOLID(#2650,#2460,#9,15.9999999999991);
#2652= IFCSTYLEDITEM(#2651,(#195),$);
#2653= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#2654= IFCEXTRUDEDAREASOLID(#2653,#2465,#9,15.9999999999995);
#2655= IFCSTYLEDITEM(#2654,(#195),$);
#2656= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#219);
#2657= IFCEXTRUDEDAREASOLID(#2656,#2470,#9,14.);
#2658= IFCSTYLEDITEM(#2657,(#191),$);
#2659= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#2660= IFCEXTRUDEDAREASOLID(#2659,#2475,#9,80.);
#2661= IFCSTYLEDITEM(#2660,(#191),$);
#2662= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,22.);
#2663= IFCEXTRUDEDAREASOLID(#2662,#2479,#9,4.);
#2664= IFCSTYLEDITEM(#2663,(#191),$);
#2665= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#241);
#2666= IFCEXTRUDEDAREASOLID(#2665,#2484,#9,19.);
#2667= IFCSTYLEDITEM(#2666,(#191),$);
#2668= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#2648,#2651,#2654,#2657,#2660,#2663,#2666));
#2669= IFCREPRESENTATIONMAP(#10,#2668);
#2670= IFCMAPPEDITEM(#2669,#247);
#2671= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#2670));
#2672= IFCPRODUCTDEFINITIONSHAPE($,$,(#2671));
#2673= IFCMECHANICALFASTENER('1Td1iR003F4p4rDp0rCJ4s',#5,'Bolt assembly',$,$,#2646,#2672,'ID5d9c1b1b-0000-cf13-3135-373035313136',24.,80.);
#2674= IFCCARTESIANPOINT((48382.3060625171,538.473696194465,10590.));
#2675= IFCAXIS2PLACEMENT3D(#2674,#596,#2539);
#2676= IFCLOCALPLACEMENT(#30,#2675);
#2677= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#2678= IFCEXTRUDEDAREASOLID(#2677,#602,#9,30.0999999999412);
#2679= IFCSTYLEDITEM(#2678,(#195),$);
#2680= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#2678));
#2681= IFCREPRESENTATIONMAP(#10,#2680);
#2682= IFCMAPPEDITEM(#2681,#247);
#2683= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#2682));
#2684= IFCPRODUCTDEFINITIONSHAPE($,$,(#2683));
#2685= IFCMECHANICALFASTENER('1Td1iR003F434rDp0rCJ4s',#5,'Bolt assembly',$,$,#2676,#2684,'ID5d9c1b1b-0000-cf10-3135-373035313136',20.,30.);
#2686= IFCCARTESIANPOINT((48352.9780740257,955.16326595148,10590.));
#2687= IFCAXIS2PLACEMENT3D(#2686,#9,#2552);
#2688= IFCLOCALPLACEMENT(#30,#2687);
#2689= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,71.);
#2690= IFCEXTRUDEDAREASOLID(#2689,#625,#9,30.1063464563484);
#2691= IFCSTYLEDITEM(#2690,(#195),$);
#2692= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#2690));
#2693= IFCREPRESENTATIONMAP(#10,#2692);
#2694= IFCMAPPEDITEM(#2693,#247);
#2695= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#2694));
#2696= IFCPRODUCTDEFINITIONSHAPE($,$,(#2695));
#2697= IFCMECHANICALFASTENER('1Td1iR003F3J4rDp0rCJ4s',#5,'Bolt assembly',$,$,#2688,#2696,'ID5d9c1b1b-0000-cf0d-3135-373035313136',20.,30.0063457489014);
#2698= IFCCARTESIANPOINT((48382.3060747836,961.478262432043,10590.));
#2699= IFCAXIS2PLACEMENT3D(#2698,#9,#2565);
#2700= IFCLOCALPLACEMENT(#30,#2699);
#2701= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#2702= IFCEXTRUDEDAREASOLID(#2701,#602,#9,30.099999999992);
#2703= IFCSTYLEDITEM(#2702,(#195),$);
#2704= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#2702));
#2705= IFCREPRESENTATIONMAP(#10,#2704);
#2706= IFCMAPPEDITEM(#2705,#247);
#2707= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#2706));
#2708= IFCPRODUCTDEFINITIONSHAPE($,$,(#2707));
#2709= IFCMECHANICALFASTENER('1Td1iR003F2Z4rDp0rCJ4s',#5,'Bolt assembly',$,$,#2700,#2708,'ID5d9c1b1b-0000-cf0a-3135-373035313136',20.,30.);
#2710= IFCCARTESIANPOINT((48352.9780494028,544.789133999286,10590.));
#2711= IFCAXIS2PLACEMENT3D(#2710,#596,#2578);
#2712= IFCLOCALPLACEMENT(#30,#2711);
#2713= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,71.);
#2714= IFCEXTRUDEDAREASOLID(#2713,#658,#9,30.1061745232009);
#2715= IFCSTYLEDITEM(#2714,(#195),$);
#2716= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#2714));
#2717= IFCREPRESENTATIONMAP(#10,#2716);
#2718= IFCMAPPEDITEM(#2717,#247);
#2719= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#2718));
#2720= IFCPRODUCTDEFINITIONSHAPE($,$,(#2719));
#2721= IFCMECHANICALFASTENER('1Td1iR003F1p4rDp0rCJ4s',#5,'Bolt assembly',$,$,#2712,#2720,'ID5d9c1b1b-0000-cf07-3135-373035313136',20.,30.0061740875244);
#2722= IFCCARTESIANPOINT((48704.1287026322,874.976717486887,4887.999));
#2723= IFCAXIS2PLACEMENT3D(#2722,#185,#8);
#2724= IFCLOCALPLACEMENT(#30,#2723);
#2725= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,42.5);
#2726= IFCEXTRUDEDAREASOLID(#2725,#561,#9,16.1);
#2727= IFCSTYLEDITEM(#2726,(#195),$);
#2728= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#2726));
#2729= IFCREPRESENTATIONMAP(#10,#2728);
#2730= IFCMAPPEDITEM(#2729,#247);
#2731= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#2730));
#2732= IFCPRODUCTDEFINITIONSHAPE($,$,(#2731));
#2733= IFCMECHANICALFASTENER('1Td1iR003F134rDp0rCJ4s',#5,'Bolt assembly',$,$,#2724,#2732,'ID5d9c1b1b-0000-cf04-3135-373035313136',30.,16.);
#2734= IFCCARTESIANPOINT((48704.1290775329,874.976999690607,4922.));
#2735= IFCAXIS2PLACEMENT3D(#2734,#7,#8);
#2736= IFCLOCALPLACEMENT(#30,#2735);
#2737= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#2738= IFCEXTRUDEDAREASOLID(#2737,#2455,#9,16.1);
#2739= IFCSTYLEDITEM(#2738,(#195),$);
#2740= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#2741= IFCEXTRUDEDAREASOLID(#2740,#2460,#9,16.);
#2742= IFCSTYLEDITEM(#2741,(#195),$);
#2743= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#2744= IFCEXTRUDEDAREASOLID(#2743,#2465,#9,16.0000000000002);
#2745= IFCSTYLEDITEM(#2744,(#195),$);
#2746= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#219);
#2747= IFCEXTRUDEDAREASOLID(#2746,#2470,#9,14.);
#2748= IFCSTYLEDITEM(#2747,(#191),$);
#2749= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#2750= IFCEXTRUDEDAREASOLID(#2749,#2475,#9,80.);
#2751= IFCSTYLEDITEM(#2750,(#191),$);
#2752= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,22.);
#2753= IFCEXTRUDEDAREASOLID(#2752,#2479,#9,4.);
#2754= IFCSTYLEDITEM(#2753,(#191),$);
#2755= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#241);
#2756= IFCEXTRUDEDAREASOLID(#2755,#2484,#9,19.);
#2757= IFCSTYLEDITEM(#2756,(#191),$);
#2758= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#2738,#2741,#2744,#2747,#2750,#2753,#2756));
#2759= IFCREPRESENTATIONMAP(#10,#2758);
#2760= IFCMAPPEDITEM(#2759,#247);
#2761= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#2760));
#2762= IFCPRODUCTDEFINITIONSHAPE($,$,(#2761));
#2763= IFCMECHANICALFASTENER('1Td1iR003F0J4rDp0rCJ4s',#5,'Bolt assembly',$,$,#2736,#2762,'ID5d9c1b1b-0000-cf01-3135-373035313136',24.,80.);
#2764= IFCCARTESIANPOINT((48704.1286986322,624.976717486887,4887.999));
#2765= IFCAXIS2PLACEMENT3D(#2764,#185,#8);
#2766= IFCLOCALPLACEMENT(#30,#2765);
#2767= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,42.5);
#2768= IFCEXTRUDEDAREASOLID(#2767,#561,#9,16.1);
#2769= IFCSTYLEDITEM(#2768,(#195),$);
#2770= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#2768));
#2771= IFCREPRESENTATIONMAP(#10,#2770);
#2772= IFCMAPPEDITEM(#2771,#247);
#2773= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#2772));
#2774= IFCPRODUCTDEFINITIONSHAPE($,$,(#2773));
#2775= IFCMECHANICALFASTENER('1Td1iR003E$Z4rDp0rCJ4s',#5,'Bolt assembly',$,$,#2766,#2774,'ID5d9c1b1b-0000-cefe-3135-373035313136',30.,16.);
#2776= IFCCARTESIANPOINT((48704.129073533,624.976999690607,4922.));
#2777= IFCAXIS2PLACEMENT3D(#2776,#7,#8);
#2778= IFCLOCALPLACEMENT(#30,#2777);
#2779= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#2780= IFCEXTRUDEDAREASOLID(#2779,#2455,#9,16.1);
#2781= IFCSTYLEDITEM(#2780,(#195),$);
#2782= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#2783= IFCEXTRUDEDAREASOLID(#2782,#2460,#9,16.);
#2784= IFCSTYLEDITEM(#2783,(#195),$);
#2785= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,13.5);
#2786= IFCEXTRUDEDAREASOLID(#2785,#2465,#9,16.0000000000002);
#2787= IFCSTYLEDITEM(#2786,(#195),$);
#2788= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#219);
#2789= IFCEXTRUDEDAREASOLID(#2788,#2470,#9,14.);
#2790= IFCSTYLEDITEM(#2789,(#191),$);
#2791= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#2792= IFCEXTRUDEDAREASOLID(#2791,#2475,#9,80.);
#2793= IFCSTYLEDITEM(#2792,(#191),$);
#2794= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,22.);
#2795= IFCEXTRUDEDAREASOLID(#2794,#2479,#9,4.);
#2796= IFCSTYLEDITEM(#2795,(#191),$);
#2797= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#241);
#2798= IFCEXTRUDEDAREASOLID(#2797,#2484,#9,19.);
#2799= IFCSTYLEDITEM(#2798,(#191),$);
#2800= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#2780,#2783,#2786,#2789,#2792,#2795,#2798));
#2801= IFCREPRESENTATIONMAP(#10,#2800);
#2802= IFCMAPPEDITEM(#2801,#247);
#2803= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#2802));
#2804= IFCPRODUCTDEFINITIONSHAPE($,$,(#2803));
#2805= IFCMECHANICALFASTENER('1Td1iR003E_p4rDp0rCJ4s',#5,'Bolt assembly',$,$,#2778,#2804,'ID5d9c1b1b-0000-cefb-3135-373035313136',24.,80.);
#2806= IFCCARTESIANPOINT((48382.3060625171,538.473696194465,4890.));
#2807= IFCAXIS2PLACEMENT3D(#2806,#596,#2539);
#2808= IFCLOCALPLACEMENT(#30,#2807);
#2809= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#2810= IFCEXTRUDEDAREASOLID(#2809,#602,#9,30.0999999999412);
#2811= IFCSTYLEDITEM(#2810,(#195),$);
#2812= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#2810));
#2813= IFCREPRESENTATIONMAP(#10,#2812);
#2814= IFCMAPPEDITEM(#2813,#247);
#2815= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#2814));
#2816= IFCPRODUCTDEFINITIONSHAPE($,$,(#2815));
#2817= IFCMECHANICALFASTENER('1Td1iR003E_34rDp0rCJ4s',#5,'Bolt assembly',$,$,#2808,#2816,'ID5d9c1b1b-0000-cef8-3135-373035313136',20.,30.);
#2818= IFCCARTESIANPOINT((48352.9780740257,955.16326595148,4890.));
#2819= IFCAXIS2PLACEMENT3D(#2818,#9,#2552);
#2820= IFCLOCALPLACEMENT(#30,#2819);
#2821= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,71.);
#2822= IFCEXTRUDEDAREASOLID(#2821,#625,#9,30.1063464563484);
#2823= IFCSTYLEDITEM(#2822,(#195),$);
#2824= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#2822));
#2825= IFCREPRESENTATIONMAP(#10,#2824);
#2826= IFCMAPPEDITEM(#2825,#247);
#2827= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#2826));
#2828= IFCPRODUCTDEFINITIONSHAPE($,$,(#2827));
#2829= IFCMECHANICALFASTENER('1Td1iR003EzJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#2820,#2828,'ID5d9c1b1b-0000-cef5-3135-373035313136',20.,30.0063457489014);
#2830= IFCCARTESIANPOINT((48382.3060747836,961.478262432043,4890.));
#2831= IFCAXIS2PLACEMENT3D(#2830,#9,#2565);
#2832= IFCLOCALPLACEMENT(#30,#2831);
#2833= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#2834= IFCEXTRUDEDAREASOLID(#2833,#602,#9,30.0999999999921);
#2835= IFCSTYLEDITEM(#2834,(#195),$);
#2836= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#2834));
#2837= IFCREPRESENTATIONMAP(#10,#2836);
#2838= IFCMAPPEDITEM(#2837,#247);
#2839= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#2838));
#2840= IFCPRODUCTDEFINITIONSHAPE($,$,(#2839));
#2841= IFCMECHANICALFASTENER('1Td1iR003EyZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#2832,#2840,'ID5d9c1b1b-0000-cef2-3135-373035313136',20.,30.);
#2842= IFCCARTESIANPOINT((48352.9780494028,544.789133999286,4890.));
#2843= IFCAXIS2PLACEMENT3D(#2842,#596,#2578);
#2844= IFCLOCALPLACEMENT(#30,#2843);
#2845= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,71.);
#2846= IFCEXTRUDEDAREASOLID(#2845,#658,#9,30.1061745232009);
#2847= IFCSTYLEDITEM(#2846,(#195),$);
#2848= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#2846));
#2849= IFCREPRESENTATIONMAP(#10,#2848);
#2850= IFCMAPPEDITEM(#2849,#247);
#2851= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#2850));
#2852= IFCPRODUCTDEFINITIONSHAPE($,$,(#2851));
#2853= IFCMECHANICALFASTENER('1Td1iR003Exp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#2844,#2852,'ID5d9c1b1b-0000-ceef-3135-373035313136',20.,30.0061740875244);
#2854= IFCLOCALPLACEMENT(#30,#10);
#2855= IFCELEMENTASSEMBLY('1Td1iR003EQp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#2854,$,'A/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#2856= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(61.5028927942439),$);
#2857= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit position code',$,IFCLABEL('6/N2-M1'),$);
#2858= IFCPROPERTYSET('1j0lCdLzLE6wjTV1PS8U4s',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#2856,#987,#988,#989,#2857,#990));
#2859= IFCCARTESIANPOINT((48519.0000852242,679.976974296878,15707.));
#2860= IFCAXIS2PLACEMENT3D(#2859,#9,#8);
#2861= IFCLOCALPLACEMENT(#2854,#2860);
#2862= IFCCARTESIANPOINT((139.998443603848,138.664718628599));
#2863= IFCCARTESIANPOINT((-4.9011614464689E-006,138.66471862793));
#2864= IFCPOLYLINE((#54,#997,#2862,#2863,#54,#54));
#2865= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL16*139',#2864);
#2866= IFCEXTRUDEDAREASOLID(#2865,#63,#9,16.);
#2867= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#2866));
#2868= IFCSTYLEDITEM(#2866,(#53),$);
#2869= IFCPRODUCTDEFINITIONSHAPE($,$,(#2867));
#2870= IFCDISCRETEACCESSORY('1Td1iR003ExJ4rDp0rCJ4s',#5,'PLATE','PL16*139','PL16*139',#2861,#2869,'P/0(?)');
#2871= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PL16*139'),$);
#2872= IFCPROPERTYSET('3DNj9fLcHB8QWGH40e6Kiu',#5,'Tekla Common','Common Properties to Shared building elements',(#1007,#1008,#1009,#1010,#74,#75,#919,#77,#78,#2871,#967));
#2873= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(61.5028927942439),$);
#2874= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(2.43825321550961),$);
#2875= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(2.43825339108091),$);
#2876= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(2.43825321550961),$);
#2877= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000310605505160459),$);
#2878= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000310605505160459),$);
#2879= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000310605505160459),$);
#2880= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.0194128440725288),$);
#2881= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(19.580783844375),$);
#2882= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0477429091707458),$);
#2883= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0194128454703894),$);
#2884= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(138.664718628614),$);
#2885= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(139.998448505008),$);
#2886= IFCPROPERTYSET('2qhAsve65BU9JVElReWLYP',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#2873,#2874,#2875,#2876,#2877,#2878,#2879,#2880,#2881,#2882,#2883,#2884,#94,#2885));
#2887= IFCQUANTITYLENGTH('Width',$,$,138.664718628614);
#2888= IFCQUANTITYAREA('NetArea',$,$,0.0477429091707458);
#2889= IFCQUANTITYAREA('GrossArea',$,$,0.0194128454703894);
#2890= IFCQUANTITYVOLUME('NetVolume',$,$,0.000310605505160459);
#2891= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000310605505160459);
#2892= IFCELEMENTQUANTITY('3gup2urYD8Pg5DBOJmckLR',#5,'BaseQuantities',$,$,(#2887,#2888,#2889,#100,#2890,#2891));
#2893= IFCCARTESIANPOINT((48511.0000884338,793.975401057876,15790.));
#2894= IFCAXIS2PLACEMENT3D(#2893,#7,#501);
#2895= IFCLOCALPLACEMENT(#2854,#2894);
#2896= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1046));
#2897= IFCPRODUCTDEFINITIONSHAPE($,$,(#2896));
#2898= IFCDISCRETEACCESSORY('1Td1iR003EwZ4rDp0rCJ4s',#5,'PLATE','PL16*75','PL16*75',#2895,#2897,'P/0(?)');
#2899= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.803881608208767),$);
#2900= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.803881608208767),$);
#2901= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.00010240530040876),$);
#2902= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.00010240530040876),$);
#2903= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.00010240530040876),$);
#2904= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0176418722681232),$);
#2905= IFCPROPERTYSET('0qhcCQrSPD9QfVtq572qKd',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#2873,#2899,#1055,#2900,#2901,#2902,#2903,#1060,#1061,#2904,#1063,#1064,#94,#1065));
#2906= IFCQUANTITYAREA('NetArea',$,$,0.0176418722681232);
#2907= IFCQUANTITYAREA('GrossArea',$,$,0.0066003312755505);
#2908= IFCQUANTITYVOLUME('NetVolume',$,$,0.00010240530040876);
#2909= IFCQUANTITYVOLUME('GrossVolume',$,$,0.00010240530040876);
#2910= IFCELEMENTQUANTITY('21ztdxRhP0SvWIauB2Jh2S',#5,'BaseQuantities',$,$,(#1067,#2906,#2907,#100,#2908,#2909));
#2911= IFCCARTESIANPOINT((48519.0000928817,801.975400915399,15714.995));
#2912= IFCAXIS2PLACEMENT3D(#2911,#501,#9);
#2913= IFCLOCALPLACEMENT(#2854,#2912);
#2914= IFCCARTESIANPOINT((75.004997253418,139.785110473633));
#2915= IFCCARTESIANPOINT((4.36557456851006E-010,139.784729003906));
#2916= IFCPOLYLINE((#54,#1076,#2914,#2915,#54,#54));
#2917= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL16*75',#2916);
#2918= IFCEXTRUDEDAREASOLID(#2917,#63,#9,16.);
#2919= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#2918));
#2920= IFCSTYLEDITEM(#2918,(#53),$);
#2921= IFCPRODUCTDEFINITIONSHAPE($,$,(#2919));
#2922= IFCDISCRETEACCESSORY('1Td1iR003Evp4rDp0rCJ4s',#5,'PLATE','PL16*75','PL16*75',#2913,#2921,'P/0(?)');
#2923= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(1.31686168064324),$);
#2924= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(1.31686347749197),$);
#2925= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(1.31686168064324),$);
#2926= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000167753080336719),$);
#2927= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000167753080336719),$);
#2928= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000167753080336719),$);
#2929= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00223656176757808),$);
#2930= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(21.1430044590926),$);
#2931= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0278424123858482),$);
#2932= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0104845818271654),$);
#2933= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(139.785110473924),$);
#2934= IFCPROPERTYSET('0hYP00n0L9MB1ROSuqEQka',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#2873,#2923,#2924,#2925,#2926,#2927,#2928,#2929,#2930,#2931,#2932,#1096,#94,#2933));
#2935= IFCQUANTITYAREA('NetArea',$,$,0.0278424123858482);
#2936= IFCQUANTITYAREA('GrossArea',$,$,0.0104845818271654);
#2937= IFCQUANTITYVOLUME('NetVolume',$,$,0.000167753080336719);
#2938= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000167753080336719);
#2939= IFCELEMENTQUANTITY('27ZoyQycPEzBJu4hkGBfTl',#5,'BaseQuantities',$,$,(#1100,#2935,#2936,#100,#2937,#2938));
#2940= IFCCARTESIANPOINT((48519.0000865817,697.976974296871,15714.995));
#2941= IFCAXIS2PLACEMENT3D(#2940,#501,#9);
#2942= IFCLOCALPLACEMENT(#2854,#2941);
#2943= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#2918));
#2944= IFCPRODUCTDEFINITIONSHAPE($,$,(#2943));
#2945= IFCDISCRETEACCESSORY('1Td1iR003Ev34rDp0rCJ4s',#5,'PLATE','PL16*75','PL16*75',#2942,#2944,'P/0(?)');
#2946= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(1.31686168064327),$);
#2947= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(1.31686347749286),$);
#2948= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(1.31686168064327),$);
#2949= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000167753080336722),$);
#2950= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000167753080336722),$);
#2951= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000167753080336722),$);
#2952= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00223656176757813),$);
#2953= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(21.1430044590926),$);
#2954= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0278424123858488),$);
#2955= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0104845818271725),$);
#2956= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(139.785110474018),$);
#2957= IFCPROPERTYSET('0hFRwzWM15SvQwVWfX0UjY',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#2873,#2946,#2947,#2948,#2949,#2950,#2951,#2952,#2953,#2954,#2955,#1096,#94,#2956));
#2958= IFCQUANTITYAREA('NetArea',$,$,0.0278424123858488);
#2959= IFCQUANTITYAREA('GrossArea',$,$,0.0104845818271725);
#2960= IFCQUANTITYVOLUME('NetVolume',$,$,0.000167753080336722);
#2961= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000167753080336722);
#2962= IFCELEMENTQUANTITY('1PdaLTwOf6XQ5jBhQLmYwq',#5,'BaseQuantities',$,$,(#1100,#2958,#2959,#100,#2960,#2961));
#2963= IFCCARTESIANPOINT((48307.1682755612,421.064629803543,15790.));
#2964= IFCDIRECTION((-0.000134615999986978,0.999999990939266,0.));
#2965= IFCAXIS2PLACEMENT3D(#2963,#9,#2964);
#2966= IFCLOCALPLACEMENT(#2854,#2965);
#2967= IFCREVOLVEDAREASOLID(#1128,#1132,#1134,0.699391749414447);
#2968= IFCCIRCLE(#1138,26.5157137787085);
#2969= IFCTRIMMEDCURVE(#2968,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.42863508548059)),.F.,.PARAMETER.);
#2970= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#2969);
#2971= IFCCOMPOSITECURVE((#2970,#1145),.F.);
#2972= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#2971);
#2973= IFCEXTRUDEDAREASOLID(#2972,#1151,#9,100.);
#2974= IFCBOOLEANRESULT(.DIFFERENCE.,#2967,#2973);
#2975= IFCCIRCLE(#1138,26.5157137787323);
#2976= IFCTRIMMEDCURVE(#2975,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.42863508548222)),.F.,.PARAMETER.);
#2977= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#2976);
#2978= IFCCOMPOSITECURVE((#2977,#1145),.F.);
#2979= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#2978);
#2980= IFCEXTRUDEDAREASOLID(#2979,#1162,#9,100.);
#2981= IFCBOOLEANRESULT(.DIFFERENCE.,#2974,#2980);
#2982= IFCCIRCLE(#1138,26.5157137785287);
#2983= IFCTRIMMEDCURVE(#2982,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.42863508546845)),.F.,.PARAMETER.);
#2984= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#2983);
#2985= IFCCOMPOSITECURVE((#2984,#1145),.F.);
#2986= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#2985);
#2987= IFCEXTRUDEDAREASOLID(#2986,#1173,#9,100.);
#2988= IFCBOOLEANRESULT(.DIFFERENCE.,#2981,#2987);
#2989= IFCCIRCLE(#1138,26.515713778531);
#2990= IFCTRIMMEDCURVE(#2989,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.42863508546795)),.F.,.PARAMETER.);
#2991= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#2990);
#2992= IFCCOMPOSITECURVE((#2991,#1145),.F.);
#2993= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#2992);
#2994= IFCEXTRUDEDAREASOLID(#2993,#1184,#9,100.);
#2995= IFCBOOLEANRESULT(.DIFFERENCE.,#2988,#2994);
#2996= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#2995));
#2997= IFCSTYLEDITEM(#2967,(#53),$);
#2998= IFCPRODUCTDEFINITIONSHAPE($,$,(#2996));
#2999= IFCDISCRETEACCESSORY('1Td1iR003ErJ4rDp0rCJ4s',#5,'ANKRAJ','PLT30*240','PLT30*240',#2966,#2998,'P/370(?)');
#3000= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(37.8234884930541),$);
#3001= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(37.8234884930541),$);
#3002= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.00481827878892409),$);
#3003= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.00483629817736628),$);
#3004= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.00481827878892409),$);
#3005= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.0183512500444002),$);
#3006= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.374594953660926),$);
#3007= IFCPROPERTYSET('1dSO0KgHbFKPEXoj0gIedI',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#2873,#3000,#1198,#3001,#3002,#3003,#3004,#3005,#1204,#3006,#1206,#1207,#1208,#1209));
#3008= IFCQUANTITYLENGTH('Length',$,$,671.72381180765);
#3009= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.374594953660926);
#3010= IFCQUANTITYVOLUME('NetVolume',$,$,0.00481827878892409);
#3011= IFCQUANTITYWEIGHT('NetWeight',$,$,37.8234884930541);
#3012= IFCELEMENTQUANTITY('06Cfk9Zmv5VfxanF3rPE_L',#5,'BaseQuantities',$,$,(#3008,#3009,#3010,#3011));
#3013= IFCLOCALPLACEMENT(#30,#10);
#3014= IFCELEMENTASSEMBLY('1Td1iR003EA34rDp0rCJ4s',#5,'Steel Assembly',$,$,#3013,$,'A/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#3015= IFCPROPERTYSET('2olBPjp29DLxfTzdAqCOTD',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#2856,#1246,#1247,#989,#2857,#990));
#3016= IFCCARTESIANPOINT((48519.0000852242,679.976974296878,10507.));
#3017= IFCAXIS2PLACEMENT3D(#3016,#9,#8);
#3018= IFCLOCALPLACEMENT(#3013,#3017);
#3019= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#2866));
#3020= IFCPRODUCTDEFINITIONSHAPE($,$,(#3019));
#3021= IFCDISCRETEACCESSORY('1Td1iR003EqZ4rDp0rCJ4s',#5,'PLATE','PL16*139','PL16*139',#3018,#3020,'P/0(?)');
#3022= IFCPROPERTYSET('3QK4LSI$P44vMeSEbI0Vjr',#5,'Tekla Common','Common Properties to Shared building elements',(#1255,#1256,#1009,#1010,#74,#75,#919,#77,#78,#2871,#967));
#3023= IFCCARTESIANPOINT((48511.0000884338,793.975401057876,10590.));
#3024= IFCAXIS2PLACEMENT3D(#3023,#7,#501);
#3025= IFCLOCALPLACEMENT(#3013,#3024);
#3026= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1046));
#3027= IFCPRODUCTDEFINITIONSHAPE($,$,(#3026));
#3028= IFCDISCRETEACCESSORY('1Td1iR003Epp4rDp0rCJ4s',#5,'PLATE','PL16*75','PL16*75',#3025,#3027,'P/0(?)');
#3029= IFCCARTESIANPOINT((48519.0000928817,801.975400915399,10514.995));
#3030= IFCAXIS2PLACEMENT3D(#3029,#501,#9);
#3031= IFCLOCALPLACEMENT(#3013,#3030);
#3032= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#2918));
#3033= IFCPRODUCTDEFINITIONSHAPE($,$,(#3032));
#3034= IFCDISCRETEACCESSORY('1Td1iR003Ep34rDp0rCJ4s',#5,'PLATE','PL16*75','PL16*75',#3031,#3033,'P/0(?)');
#3035= IFCCARTESIANPOINT((48519.0000865817,697.976974296871,10514.995));
#3036= IFCAXIS2PLACEMENT3D(#3035,#501,#9);
#3037= IFCLOCALPLACEMENT(#3013,#3036);
#3038= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#2918));
#3039= IFCPRODUCTDEFINITIONSHAPE($,$,(#3038));
#3040= IFCDISCRETEACCESSORY('1Td1iR003EoJ4rDp0rCJ4s',#5,'PLATE','PL16*75','PL16*75',#3037,#3039,'P/0(?)');
#3041= IFCCARTESIANPOINT((48307.1682755612,421.064629803543,10590.));
#3042= IFCAXIS2PLACEMENT3D(#3041,#9,#2964);
#3043= IFCLOCALPLACEMENT(#3013,#3042);
#3044= IFCREVOLVEDAREASOLID(#1128,#1132,#1134,0.699391749414448);
#3045= IFCCIRCLE(#1138,26.5157137787096);
#3046= IFCTRIMMEDCURVE(#3045,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.42863508548065)),.F.,.PARAMETER.);
#3047= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#3046);
#3048= IFCCOMPOSITECURVE((#3047,#1145),.F.);
#3049= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#3048);
#3050= IFCEXTRUDEDAREASOLID(#3049,#1151,#9,100.);
#3051= IFCBOOLEANRESULT(.DIFFERENCE.,#3044,#3050);
#3052= IFCCIRCLE(#1138,26.5157137787368);
#3053= IFCTRIMMEDCURVE(#3052,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.42863508548247)),.F.,.PARAMETER.);
#3054= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#3053);
#3055= IFCCOMPOSITECURVE((#3054,#1145),.F.);
#3056= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#3055);
#3057= IFCEXTRUDEDAREASOLID(#3056,#1162,#9,100.);
#3058= IFCBOOLEANRESULT(.DIFFERENCE.,#3051,#3057);
#3059= IFCCIRCLE(#1138,26.515713778511);
#3060= IFCTRIMMEDCURVE(#3059,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.42863508546759)),.F.,.PARAMETER.);
#3061= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#3060);
#3062= IFCCOMPOSITECURVE((#3061,#1145),.F.);
#3063= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#3062);
#3064= IFCEXTRUDEDAREASOLID(#3063,#1173,#9,100.);
#3065= IFCBOOLEANRESULT(.DIFFERENCE.,#3058,#3064);
#3066= IFCCIRCLE(#1138,26.5157137785125);
#3067= IFCTRIMMEDCURVE(#3066,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.42863508546706)),.F.,.PARAMETER.);
#3068= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#3067);
#3069= IFCCOMPOSITECURVE((#3068,#1145),.F.);
#3070= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#3069);
#3071= IFCEXTRUDEDAREASOLID(#3070,#1184,#9,100.);
#3072= IFCBOOLEANRESULT(.DIFFERENCE.,#3065,#3071);
#3073= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#3072));
#3074= IFCSTYLEDITEM(#3044,(#53),$);
#3075= IFCPRODUCTDEFINITIONSHAPE($,$,(#3073));
#3076= IFCDISCRETEACCESSORY('1Td1iR003EkZ4rDp0rCJ4s',#5,'ANKRAJ','PLT30*240','PLT30*240',#3043,#3075,'P/370(?)');
#3077= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.374594953660925);
#3078= IFCQUANTITYVOLUME('NetVolume',$,$,0.00481827878892406);
#3079= IFCQUANTITYWEIGHT('NetWeight',$,$,37.8234884930539);
#3080= IFCELEMENTQUANTITY('0lvhvd$mzFHeS9TPyWJ_51',#5,'BaseQuantities',$,$,(#3008,#3077,#3078,#3079));
#3081= IFCLOCALPLACEMENT(#30,#10);
#3082= IFCELEMENTASSEMBLY('1Td1iR003DvJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#3081,$,'A/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#3083= IFCPROPERTYSET('27WOThahLAC9DiEvA7$HGJ',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#2856,#1358,#1359,#989,#2857,#990));
#3084= IFCCARTESIANPOINT((48519.0000852242,679.976974296878,4807.));
#3085= IFCAXIS2PLACEMENT3D(#3084,#9,#8);
#3086= IFCLOCALPLACEMENT(#3081,#3085);
#3087= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#2866));
#3088= IFCPRODUCTDEFINITIONSHAPE($,$,(#3087));
#3089= IFCDISCRETEACCESSORY('1Td1iR003Ejp4rDp0rCJ4s',#5,'PLATE','PL16*139','PL16*139',#3086,#3088,'P/0(?)');
#3090= IFCPROPERTYSET('2dJQn$8hL699FAeMXgqPxC',#5,'Tekla Common','Common Properties to Shared building elements',(#1367,#1368,#1009,#1010,#74,#75,#919,#77,#78,#2871,#967));
#3091= IFCCARTESIANPOINT((48511.0000884338,793.975401057876,4890.));
#3092= IFCAXIS2PLACEMENT3D(#3091,#7,#501);
#3093= IFCLOCALPLACEMENT(#3081,#3092);
#3094= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1046));
#3095= IFCPRODUCTDEFINITIONSHAPE($,$,(#3094));
#3096= IFCDISCRETEACCESSORY('1Td1iR003Ej34rDp0rCJ4s',#5,'PLATE','PL16*75','PL16*75',#3093,#3095,'P/0(?)');
#3097= IFCCARTESIANPOINT((48519.0000928817,801.975400915399,4814.995));
#3098= IFCAXIS2PLACEMENT3D(#3097,#501,#9);
#3099= IFCLOCALPLACEMENT(#3081,#3098);
#3100= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#2918));
#3101= IFCPRODUCTDEFINITIONSHAPE($,$,(#3100));
#3102= IFCDISCRETEACCESSORY('1Td1iR003EiJ4rDp0rCJ4s',#5,'PLATE','PL16*75','PL16*75',#3099,#3101,'P/0(?)');
#3103= IFCQUANTITYAREA('GrossArea',$,$,0.0104845818271599);
#3104= IFCELEMENTQUANTITY('0dSzO3yGD9485nFqc6yD11',#5,'BaseQuantities',$,$,(#1100,#2935,#3103,#100,#2937,#2938));
#3105= IFCCARTESIANPOINT((48519.0000865817,697.976974296871,4814.995));
#3106= IFCAXIS2PLACEMENT3D(#3105,#501,#9);
#3107= IFCLOCALPLACEMENT(#3081,#3106);
#3108= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#2918));
#3109= IFCPRODUCTDEFINITIONSHAPE($,$,(#3108));
#3110= IFCDISCRETEACCESSORY('1Td1iR003EhZ4rDp0rCJ4s',#5,'PLATE','PL16*75','PL16*75',#3107,#3109,'P/0(?)');
#3111= IFCQUANTITYAREA('GrossArea',$,$,0.010484581827167);
#3112= IFCELEMENTQUANTITY('3yScFgepjDffWfEFX4WVjZ',#5,'BaseQuantities',$,$,(#1100,#2958,#3111,#100,#2960,#2961));
#3113= IFCCARTESIANPOINT((48307.1682755612,421.064629803543,4890.));
#3114= IFCAXIS2PLACEMENT3D(#3113,#9,#2964);
#3115= IFCLOCALPLACEMENT(#3081,#3114);
#3116= IFCCIRCLE(#1138,26.5157137786079);
#3117= IFCTRIMMEDCURVE(#3116,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.42863508547329)),.F.,.PARAMETER.);
#3118= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#3117);
#3119= IFCCOMPOSITECURVE((#3118,#1145),.F.);
#3120= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#3119);
#3121= IFCEXTRUDEDAREASOLID(#3120,#1151,#9,100.);
#3122= IFCBOOLEANRESULT(.DIFFERENCE.,#3044,#3121);
#3123= IFCCIRCLE(#1138,26.5157137786091);
#3124= IFCTRIMMEDCURVE(#3123,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.42863508547305)),.F.,.PARAMETER.);
#3125= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#3124);
#3126= IFCCOMPOSITECURVE((#3125,#1145),.F.);
#3127= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#3126);
#3128= IFCEXTRUDEDAREASOLID(#3127,#1162,#9,100.);
#3129= IFCBOOLEANRESULT(.DIFFERENCE.,#3122,#3128);
#3130= IFCCIRCLE(#1138,26.5157137785683);
#3131= IFCTRIMMEDCURVE(#3130,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.42863508547084)),.F.,.PARAMETER.);
#3132= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#3131);
#3133= IFCCOMPOSITECURVE((#3132,#1145),.F.);
#3134= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#3133);
#3135= IFCEXTRUDEDAREASOLID(#3134,#1173,#9,100.);
#3136= IFCBOOLEANRESULT(.DIFFERENCE.,#3129,#3135);
#3137= IFCCIRCLE(#1138,26.5157137785733);
#3138= IFCTRIMMEDCURVE(#3137,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.42863508547124)),.F.,.PARAMETER.);
#3139= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#3138);
#3140= IFCCOMPOSITECURVE((#3139,#1145),.F.);
#3141= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#3140);
#3142= IFCEXTRUDEDAREASOLID(#3141,#1184,#9,100.);
#3143= IFCBOOLEANRESULT(.DIFFERENCE.,#3136,#3142);
#3144= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#3143));
#3145= IFCPRODUCTDEFINITIONSHAPE($,$,(#3144));
#3146= IFCDISCRETEACCESSORY('1Td1iR003Edp4rDp0rCJ4s',#5,'ANKRAJ','PLT30*240','PLT30*240',#3115,#3145,'P/370(?)');
#3147= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.374594953660926),$);
#3148= IFCPROPERTYSET('2iOGLUtN57D9gWb0r2isZ9',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#2873,#3000,#1198,#3001,#3002,#3003,#3004,#1203,#1204,#3147,#1206,#1207,#1208,#1209));
#3149= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.374594953660926);
#3150= IFCQUANTITYVOLUME('NetVolume',$,$,0.00481827878892408);
#3151= IFCQUANTITYWEIGHT('NetWeight',$,$,37.823488493054);
#3152= IFCELEMENTQUANTITY('2S0guB$Jj6mgFxgl9hroJ7',#5,'BaseQuantities',$,$,(#3008,#3149,#3150,#3151));
#3153= IFCLOCALPLACEMENT(#30,#10);
#3154= IFCELEMENTASSEMBLY('1Td1iR003EcZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#3153,$,'ANK/63(?)',.NOTDEFINED.,.RIGID_FRAME.);
#3155= IFCPROPERTYSET('3Ua$Z1tOTEdO6IZ6Gh6nTM',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#485,#1589,#1590,#39,#2857,#489));
#3156= IFCCARTESIANPOINT((48629.1280905254,874.976615875526,15814.));
#3157= IFCAXIS2PLACEMENT3D(#3156,#8,#7);
#3158= IFCLOCALPLACEMENT(#3153,#3157);
#3159= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#542));
#3160= IFCPRODUCTDEFINITIONSHAPE($,$,(#3159));
#3161= IFCBEAM('1Td1iR003Ecp4rDp0rCJ4s',#5,'ANKRAJ','PLT16*150','PLT16*150',#3158,#3160,'P/379(?)');
#3162= IFCPROPERTYSET('0k_h4qGvr42AM7VyWc6iwE',#5,'Tekla Common','Common Properties to Shared building elements',(#1598,#1599,#512,#513,#74,#75,#919,#515,#78,#516,#80));
#3163= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(150.00000000032),$);
#3164= IFCPROPERTYSET('08fIrVAzbE$OQfdPxjGf8H',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#518,#519,#520,#521,#522,#523,#524,#525,#547,#527,#528,#3163,#94,#530));
#3165= IFCQUANTITYLENGTH('Length',$,$,150.000610351584);
#3166= IFCQUANTITYVOLUME('NetVolume',$,$,0.000360001464843785);
#3167= IFCQUANTITYWEIGHT('NetWeight',$,$,2.82601149902371);
#3168= IFCELEMENTQUANTITY('01QFW3RLvCeQevQOaujhkZ',#5,'BaseQuantities',$,$,(#3165,#550,#3166,#3167));
#3169= IFCLOCALPLACEMENT(#30,#10);
#3170= IFCELEMENTASSEMBLY('1Td1iR003EbZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#3169,$,'ANK/63(?)',.NOTDEFINED.,.RIGID_FRAME.);
#3171= IFCCARTESIANPOINT((48629.1280865254,624.976615875526,15814.));
#3172= IFCAXIS2PLACEMENT3D(#3171,#8,#7);
#3173= IFCLOCALPLACEMENT(#3169,#3172);
#3174= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#542));
#3175= IFCPRODUCTDEFINITIONSHAPE($,$,(#3174));
#3176= IFCBEAM('1Td1iR003Ebp4rDp0rCJ4s',#5,'ANKRAJ','PLT16*150','PLT16*150',#3173,#3175,'P/379(?)');
#3177= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0546002026367236);
#3178= IFCQUANTITYVOLUME('NetVolume',$,$,0.000360001464843785);
#3179= IFCQUANTITYWEIGHT('NetWeight',$,$,2.82601149902371);
#3180= IFCELEMENTQUANTITY('3frEka0WXB$gr5iw$wj$NL',#5,'BaseQuantities',$,$,(#3165,#3177,#3178,#3179));
#3181= IFCLOCALPLACEMENT(#30,#10);
#3182= IFCELEMENTASSEMBLY('1Td1iR003EaZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#3181,$,'P/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#3183= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(1.69183009850297),$);
#3184= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' +15.716'),$);
#3185= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +15.774'),$);
#3186= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit name',$,IFCLABEL('PLATE'),$);
#3187= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('P/0(?)'),$);
#3188= IFCPROPERTYSET('3T6yAcbQzDXv6R8imPL$0A',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#3183,#3184,#3185,#3186,#2857,#3187));
#3189= IFCQUANTITYLENGTH('Width',$,$,16.0000000003409);
#3190= IFCELEMENTQUANTITY('3Jt_da8mn35AoG4eLIzFvi',#5,'BaseQuantities',$,$,(#3189));
#3191= IFCCARTESIANPOINT((48568.9996213439,499.979217037308,15774.0000000021));
#3192= IFCAXIS2PLACEMENT3D(#3191,#501,#596);
#3193= IFCLOCALPLACEMENT(#3181,#3192);
#3194= IFCCARTESIANPOINT((-8.30359980446753E-006,14.9999999999977));
#3195= IFCCARTESIANPOINT((57.9998712536127,224.999740600581));
#3196= IFCCARTESIANPOINT((42.9998626705079,239.999744546868));
#3197= IFCCARTESIANPOINT((14.9998671425378,239.999751913275));
#3198= IFCCARTESIANPOINT((-0.000124553861917402,224.999755859566));
#3199= IFCPOLYLINE((#3194,#900,#952,#953,#3195,#3196,#3197,#3198,#3194));
#3200= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL16*58',#3199);
#3201= IFCEXTRUDEDAREASOLID(#3200,#63,#9,16.);
#3202= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3201));
#3203= IFCSTYLEDITEM(#3201,(#53),$);
#3204= IFCPRODUCTDEFINITIONSHAPE($,$,(#3202));
#3205= IFCPLATE('1Td1iR003Eap4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#3193,#3204,'P/432(?)');
#3206= IFCPLATETYPE('3Gx8Usc9j7dg2nYFq147_t',#5,'PL16*58',$,$,$,$,$,$,.NOTDEFINED.);
#3207= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/432(?)'),$);
#3208= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('P/0(?)'),$);
#3209= IFCPROPERTYSET('2NdzFdUbH7YOIledObxQoR',#5,'Tekla Common','Common Properties to Shared building elements',(#915,#916,#3207,#3208,#74,#75,#514,#77,#78,#920,#967));
#3210= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(1.69183009850297),$);
#3211= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(1.69183009850297),$);
#3212= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(1.74835029722606),$);
#3213= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(1.69183009850297),$);
#3214= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000215519757771079),$);
#3215= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000215519757771079),$);
#3216= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000215519757771079),$);
#3217= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00335999609375059),$);
#3218= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(21.2276673909808),$);
#3219= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0359136066130713),$);
#3220= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0139199864428826),$);
#3221= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(57.999999720485),$);
#3222= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(16.0000000014078),$);
#3223= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(239.99976741321),$);
#3224= IFCPROPERTYSET('3TiWh2NHPDEvKEYHaZpKza',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#3210,#3211,#3212,#3213,#3214,#3215,#3216,#3217,#3218,#3219,#3220,#3221,#3222,#3223));
#3225= IFCQUANTITYLENGTH('Width',$,$,57.999999720485);
#3226= IFCQUANTITYAREA('NetArea',$,$,0.0359136066130713);
#3227= IFCQUANTITYAREA('GrossArea',$,$,0.0139199864428826);
#3228= IFCQUANTITYVOLUME('NetVolume',$,$,0.000215519757771079);
#3229= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000215519757771079);
#3230= IFCELEMENTQUANTITY('1jgmAIbrf9Yul7J66Bb1Vl',#5,'BaseQuantities',$,$,(#3225,#3226,#3227,#100,#3228,#3229));
#3231= IFCLOCALPLACEMENT(#30,#10);
#3232= IFCELEMENTASSEMBLY('1Td1iR003EZZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#3231,$,'P/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#3233= IFCQUANTITYLENGTH('Width',$,$,16.0000000003409);
#3234= IFCELEMENTQUANTITY('1ruS2bPKjCQP67dViGn64R',#5,'BaseQuantities',$,$,(#3233));
#3235= IFCCARTESIANPOINT((48568.9996218441,999.976217037307,15774.0000000021));
#3236= IFCAXIS2PLACEMENT3D(#3235,#501,#596);
#3237= IFCLOCALPLACEMENT(#3231,#3236);
#3238= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3201));
#3239= IFCPRODUCTDEFINITIONSHAPE($,$,(#3238));
#3240= IFCPLATE('1Td1iR003EZp4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#3237,#3239,'P/432(?)');
#3241= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(21.2276673909808),$);
#3242= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(16.0000000014079),$);
#3243= IFCPROPERTYSET('2U2XDi_XH9rfVfbqlbq_K4',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#3210,#3211,#3212,#3213,#3214,#3215,#3216,#3217,#3241,#3219,#3220,#3221,#3242,#3223));
#3244= IFCQUANTITYVOLUME('NetVolume',$,$,0.000215519757771079);
#3245= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000215519757771079);
#3246= IFCELEMENTQUANTITY('2O1GD$0753Yu8D7N73bReu',#5,'BaseQuantities',$,$,(#3225,#3226,#3227,#100,#3244,#3245));
#3247= IFCLOCALPLACEMENT(#30,#10);
#3248= IFCELEMENTASSEMBLY('1Td1iR003EYZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#3247,$,'P/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#3249= IFCCARTESIANPOINT((48568.9996255939,749.976217037307,15774.0000000021));
#3250= IFCAXIS2PLACEMENT3D(#3249,#501,#596);
#3251= IFCLOCALPLACEMENT(#3247,#3250);
#3252= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3201));
#3253= IFCPRODUCTDEFINITIONSHAPE($,$,(#3252));
#3254= IFCPLATE('1Td1iR003EYp4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#3251,#3253,'P/432(?)');
#3255= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(21.227667390981),$);
#3256= IFCPROPERTYSET('1GdDXroNT7SuoC9beGce4A',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#3210,#3211,#3212,#3213,#3214,#3215,#3216,#3217,#3255,#3219,#3220,#3221,#3222,#3223));
#3257= IFCQUANTITYAREA('NetArea',$,$,0.0359136066130707);
#3258= IFCQUANTITYVOLUME('NetVolume',$,$,0.000215519757771073);
#3259= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000215519757771073);
#3260= IFCELEMENTQUANTITY('1UkO83IHP1OP940x7MvNIo',#5,'BaseQuantities',$,$,(#3225,#3257,#3227,#100,#3258,#3259));
#3261= IFCLOCALPLACEMENT(#30,#10);
#3262= IFCELEMENTASSEMBLY('1Td1iR003EXZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#3261,$,'ANK/61(?)',.NOTDEFINED.,.RIGID_FRAME.);
#3263= IFCPROPERTYSET('0dk_WTG2H13gVXYdbgHICI',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1665,#1612,#1613,#1614,#2857,#1616));
#3264= IFCQUANTITYLENGTH('Width',$,$,30.0000000000218);
#3265= IFCELEMENTQUANTITY('1qRVwN37j6zvqRMXgGhYx1',#5,'BaseQuantities',$,$,(#3264));
#3266= IFCCARTESIANPOINT((48388.7373035838,613.806318316645,15790.));
#3267= IFCAXIS2PLACEMENT3D(#3266,#9,#1966);
#3268= IFCLOCALPLACEMENT(#3261,#3267);
#3269= IFCEXTRUDEDAREASOLID(#1628,#1630,#9,150.001159459221);
#3270= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3269));
#3271= IFCSTYLEDITEM(#3269,(#1627),$);
#3272= IFCPRODUCTDEFINITIONSHAPE($,$,(#3270));
#3273= IFCBEAM('1Td1iR003EXp4rDp0rCJ4s',#5,'PUL','PLT30*150','PLT30*150',#3268,#3272,'P/377(?)');
#3274= IFCQUANTITYLENGTH('Length',$,$,150.001159459267);
#3275= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0630004174053313);
#3276= IFCQUANTITYVOLUME('NetVolume',$,$,0.00067500521756675);
#3277= IFCQUANTITYWEIGHT('NetWeight',$,$,5.29879095789899);
#3278= IFCELEMENTQUANTITY('0jlHwwZCPCbuGBYC2Er_en',#5,'BaseQuantities',$,$,(#3274,#3275,#3276,#3277));
#3279= IFCLOCALPLACEMENT(#30,#10);
#3280= IFCELEMENTASSEMBLY('1Td1iR003EWZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#3279,$,'ANK/61(?)',.NOTDEFINED.,.RIGID_FRAME.);
#3281= IFCQUANTITYLENGTH('Width',$,$,30.0000000000873);
#3282= IFCELEMENTQUANTITY('013LkCX6LBpBFHf10SIofB',#5,'BaseQuantities',$,$,(#3281));
#3283= IFCCARTESIANPOINT((48388.7373114812,886.145639936869,15790.));
#3284= IFCAXIS2PLACEMENT3D(#3283,#9,#1821);
#3285= IFCLOCALPLACEMENT(#3279,#3284);
#3286= IFCEXTRUDEDAREASOLID(#1628,#1630,#9,150.001159459232);
#3287= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3286));
#3288= IFCSTYLEDITEM(#3286,(#1627),$);
#3289= IFCPRODUCTDEFINITIONSHAPE($,$,(#3287));
#3290= IFCBEAM('1Td1iR003EWp4rDp0rCJ4s',#5,'PUL','PLT30*150','PLT30*150',#3285,#3289,'P/377(?)');
#3291= IFCPROPERTYSET('0WZ7MdlS13t8S9wpi2OVGx',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1678,#1679,#1680,#1681,#1682,#1683,#1684,#1651,#1652,#1686,#1687,#529,#1655,#1688));
#3292= IFCQUANTITYLENGTH('Length',$,$,150.001159459269);
#3293= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0630004174053527);
#3294= IFCQUANTITYVOLUME('NetVolume',$,$,0.000675005217567454);
#3295= IFCQUANTITYWEIGHT('NetWeight',$,$,5.29879095790452);
#3296= IFCELEMENTQUANTITY('0tqoPC6IH8HuQDEWFdnPXy',#5,'BaseQuantities',$,$,(#3292,#3293,#3294,#3295));
#3297= IFCLOCALPLACEMENT(#30,#10);
#3298= IFCELEMENTASSEMBLY('1Td1iR003EVZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#3297,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#3299= IFCPROPERTYSET('1I$fcEFx97gf8mMl3R3tBx',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#1698,#1699,#1700,#2857,#1701));
#3300= IFCCARTESIANPOINT((48407.1668647196,966.832191080095,15790.));
#3301= IFCDIRECTION((-0.210486644989933,0.977596732953257,0.));
#3302= IFCAXIS2PLACEMENT3D(#3300,#3301,#1706);
#3303= IFCLOCALPLACEMENT(#3297,#3302);
#3304= IFCEXTRUDEDAREASOLID(#1719,#1721,#9,16.0000409061802);
#3305= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3304));
#3306= IFCSTYLEDITEM(#3304,(#1711),$);
#3307= IFCPRODUCTDEFINITIONSHAPE($,$,(#3305));
#3308= IFCBEAM('1Td1iR003EVp4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#3303,#3307,'XX/0(?)');
#3309= IFCQUANTITYLENGTH('Length',$,$,16.0000409062268);
#3310= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161875317488);
#3311= IFCQUANTITYVOLUME('NetVolume',$,$,1.24707976977233E-005);
#3312= IFCELEMENTQUANTITY('3uXhq2ox1C8OG8W_c4oL5G',#5,'BaseQuantities',$,$,(#3309,#3310,#3311,#1754));
#3313= IFCLOCALPLACEMENT(#30,#10);
#3314= IFCELEMENTASSEMBLY('1Td1iR003EUZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#3313,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#3315= IFCCARTESIANPOINT((48391.525277322,963.46384553011,15790.));
#3316= IFCAXIS2PLACEMENT3D(#3315,#3301,#1706);
#3317= IFCLOCALPLACEMENT(#3313,#3316);
#3318= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3304));
#3319= IFCPRODUCTDEFINITIONSHAPE($,$,(#3318));
#3320= IFCBEAM('1Td1iR003EUp4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#3317,#3319,'XX/0(?)');
#3321= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161875317546);
#3322= IFCQUANTITYVOLUME('NetVolume',$,$,1.24707976977281E-005);
#3323= IFCELEMENTQUANTITY('2NAC3Qhj99geJO_c5hysre',#5,'BaseQuantities',$,$,(#3309,#3321,#3322,#1754));
#3324= IFCLOCALPLACEMENT(#30,#10);
#3325= IFCELEMENTASSEMBLY('1Td1iR003ETZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#3324,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#3326= IFCPROPERTYSET('11egbFpaP1OAY3mRsmmC7M',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#1773,#1774,#1775,#2857,#1701));
#3327= IFCCARTESIANPOINT((48387.6148925025,962.621340003308,15790.));
#3328= IFCAXIS2PLACEMENT3D(#3327,#1821,#1670);
#3329= IFCLOCALPLACEMENT(#3324,#3328);
#3330= IFCEXTRUDEDAREASOLID(#1783,#1785,#9,3.99999999998244);
#3331= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3330));
#3332= IFCSTYLEDITEM(#3330,(#1711),$);
#3333= IFCPRODUCTDEFINITIONSHAPE($,$,(#3331));
#3334= IFCBEAM('1Td1iR003ETp4rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#3329,#3333,'XX/0(?)');
#3335= IFCPROPERTYSET('0qaQWvpXTBJhWaZWAWseX6',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#1797,#1798,#1799,#1743,#1744,#1800,#1801,#1979,#1803,#1804));
#3336= IFCQUANTITYLENGTH('Length',$,$,3.99999999999272);
#3337= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00180062582325488);
#3338= IFCQUANTITYVOLUME('NetVolume',$,$,3.93299999998501E-006);
#3339= IFCELEMENTQUANTITY('0rmdxQ_ID0g9aET1h8yNaY',#5,'BaseQuantities',$,$,(#3336,#3337,#3338,#1754));
#3340= IFCLOCALPLACEMENT(#30,#10);
#3341= IFCELEMENTASSEMBLY('1Td1iR003ESZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#3340,$,'R/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#3342= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit position code',$,IFCLABEL('5/1-6/N2-M1'),$);
#3343= IFCPROPERTYSET('1Uf5aUMLX6Xufon$0qp7BK',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#1812,#1813,#1814,#3342,#1815));
#3344= IFCCARTESIANPOINT((48445.614490284,975.11041119336,15790.));
#3345= IFCAXIS2PLACEMENT3D(#3344,#1780,#1820);
#3346= IFCLOCALPLACEMENT(#3340,#3345);
#3347= IFCEXTRUDEDAREASOLID(#1826,#1828,#9,370.00035747635);
#3348= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3347));
#3349= IFCSTYLEDITEM(#3347,(#1825),$);
#3350= IFCPRODUCTDEFINITIONSHAPE($,$,(#3348));
#3351= IFCBEAM('1Td1iR003ESp4rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#3346,#3350,'P/0(?)');
#3352= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(20.0000000005966),$);
#3353= IFCPROPERTYSET('37myblR3r4ERDFBHfx26Kx',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#1842,#1843,#1844,#1743,#1744,#1845,#1846,#3352,#1848,#1849));
#3354= IFCQUANTITYLENGTH('Length',$,$,370.000357475394);
#3355= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.023220566508942);
#3356= IFCQUANTITYVOLUME('NetVolume',$,$,0.000104651904724869);
#3357= IFCELEMENTQUANTITY('3$NFuEaZf73vJDEwcrbV3N',#5,'BaseQuantities',$,$,(#3354,#3355,#3356,#1754));
#3358= IFCCARTESIANPOINT((48594.1280919305,819.975973170847,15798.));
#3359= IFCAXIS2PLACEMENT3D(#3358,#9,#185);
#3360= IFCLOCALPLACEMENT(#2854,#3359);
#3361= IFCCIRCLE(#1861,60.);
#3362= IFCTRIMMEDCURVE(#3361,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.7123889701188)),.F.,.PARAMETER.);
#3363= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#3362);
#3364= IFCCIRCLE(#1873,60.);
#3365= IFCTRIMMEDCURVE(#3364,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.71237623044163)),.F.,.PARAMETER.);
#3366= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#3365);
#3367= IFCCARTESIANPOINT((-1.42929638968781E-006,319.996337890626));
#3368= IFCCARTESIANPOINT((-220.000244142815,319.996337890101));
#3369= IFCCARTESIANPOINT((-220.000228880599,-179.999786377478));
#3370= IFCCARTESIANPOINT((1.84828240890056E-006,-179.999786376953));
#3371= IFCPOLYLINE((#1877,#3367,#3368,#3369,#3370,#1882));
#3372= IFCCOMPOSITECURVESEGMENT(.DISCONTINUOUS.,.T.,#3371);
#3373= IFCCOMPOSITECURVE((#3363,#1870,#3366,#3372),.F.);
#3374= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL16*436',#3373);
#3375= IFCEXTRUDEDAREASOLID(#3374,#63,#9,16.);
#3376= IFCBOOLEANRESULT(.DIFFERENCE.,#3375,#1894);
#3377= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#3376));
#3378= IFCSTYLEDITEM(#3375,(#53),$);
#3379= IFCPRODUCTDEFINITIONSHAPE($,$,(#3377));
#3380= IFCPLATE('1Td1iR003ER34rDp0rCJ4s',#5,'ANCHOR','PL16*436','PL16*436',#3360,#3379,'P/0(?)');
#3381= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(17.8035461161849),$);
#3382= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(27.4052663628866),$);
#3383= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(17.8035461161849),$);
#3384= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.141747978632063),$);
#3385= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(17.5593621402377),$);
#3386= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.312618913634513),$);
#3387= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.218194795882855),$);
#3388= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(436.392968590095),$);
#3389= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(499.996130982134),$);
#3390= IFCPROPERTYSET('1CatFa0sH3GRf_wAeVcDyx',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#2873,#3381,#3382,#3383,#1909,#1910,#1911,#3384,#3385,#3386,#3387,#3388,#94,#3389));
#3391= IFCQUANTITYLENGTH('Width',$,$,436.392968590095);
#3392= IFCQUANTITYAREA('NetArea',$,$,0.312618913634513);
#3393= IFCQUANTITYAREA('GrossArea',$,$,0.218194795882855);
#3394= IFCQUANTITYVOLUME('NetVolume',$,$,0.00226796765811273);
#3395= IFCQUANTITYVOLUME('GrossVolume',$,$,0.00229938154258898);
#3396= IFCELEMENTQUANTITY('2Z5gQXnIr1qxAy7KGSilns',#5,'BaseQuantities',$,$,(#3391,#3392,#3393,#100,#3394,#3395));
#3397= IFCLOCALPLACEMENT(#30,#10);
#3398= IFCELEMENTASSEMBLY('1Td1iR003EPp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#3397,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#3399= IFCCARTESIANPOINT((48407.1668386964,533.120202367885,15790.));
#3400= IFCDIRECTION((0.977596707770419,-0.210486761950577,0.));
#3401= IFCAXIS2PLACEMENT3D(#3399,#1929,#3400);
#3402= IFCLOCALPLACEMENT(#3397,#3401);
#3403= IFCEXTRUDEDAREASOLID(#1719,#1721,#9,16.0000409061786);
#3404= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3403));
#3405= IFCSTYLEDITEM(#3403,(#1711),$);
#3406= IFCPRODUCTDEFINITIONSHAPE($,$,(#3404));
#3407= IFCBEAM('1Td1iR003EQ34rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#3402,#3406,'XX/0(?)');
#3408= IFCQUANTITYLENGTH('Length',$,$,16.0000409062413);
#3409= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161875317668);
#3410= IFCQUANTITYVOLUME('NetVolume',$,$,1.24707976977362E-005);
#3411= IFCELEMENTQUANTITY('0nAUDRyLTDrxrSOTsSZNUX',#5,'BaseQuantities',$,$,(#3408,#3409,#3410,#1754));
#3412= IFCLOCALPLACEMENT(#30,#10);
#3413= IFCELEMENTASSEMBLY('1Td1iR003EOp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#3412,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#3414= IFCCARTESIANPOINT((48391.5252517029,536.488549794907,15790.));
#3415= IFCAXIS2PLACEMENT3D(#3414,#1929,#3400);
#3416= IFCLOCALPLACEMENT(#3412,#3415);
#3417= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3403));
#3418= IFCPRODUCTDEFINITIONSHAPE($,$,(#3417));
#3419= IFCBEAM('1Td1iR003EP34rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#3416,#3418,'XX/0(?)');
#3420= IFCQUANTITYLENGTH('Length',$,$,16.0000409062341);
#3421= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161875317643);
#3422= IFCQUANTITYVOLUME('NetVolume',$,$,1.24707976977368E-005);
#3423= IFCELEMENTQUANTITY('2YWd9MtS55Xfv_ZcLopPHx',#5,'BaseQuantities',$,$,(#3420,#3421,#3422,#1754));
#3424= IFCLOCALPLACEMENT(#30,#10);
#3425= IFCELEMENTASSEMBLY('1Td1iR003ENp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#3424,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#3426= IFCCARTESIANPOINT((48387.6148669846,537.331055790964,15790.));
#3427= IFCAXIS2PLACEMENT3D(#3426,#1966,#1988);
#3428= IFCLOCALPLACEMENT(#3424,#3427);
#3429= IFCEXTRUDEDAREASOLID(#1783,#1785,#9,3.99999999998743);
#3430= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3429));
#3431= IFCSTYLEDITEM(#3429,(#1711),$);
#3432= IFCPRODUCTDEFINITIONSHAPE($,$,(#3430));
#3433= IFCBEAM('1Td1iR003EO34rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#3428,#3432,'XX/0(?)');
#3434= IFCQUANTITYLENGTH('Length',$,$,4.00000000001455);
#3435= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00180062582325643);
#3436= IFCQUANTITYVOLUME('NetVolume',$,$,3.933000000002E-006);
#3437= IFCELEMENTQUANTITY('0Ltf8xSsTE5O$xpQGfPTWK',#5,'BaseQuantities',$,$,(#3434,#3435,#3436,#1754));
#3438= IFCLOCALPLACEMENT(#30,#10);
#3439= IFCELEMENTASSEMBLY('1Td1iR003EMp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#3438,$,'R/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#3440= IFCCARTESIANPOINT((48445.6144632673,524.841977640812,15790.));
#3441= IFCAXIS2PLACEMENT3D(#3440,#1989,#1621);
#3442= IFCLOCALPLACEMENT(#3438,#3441);
#3443= IFCEXTRUDEDAREASOLID(#1826,#1828,#9,370.000357476349);
#3444= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3443));
#3445= IFCSTYLEDITEM(#3443,(#1825),$);
#3446= IFCPRODUCTDEFINITIONSHAPE($,$,(#3444));
#3447= IFCBEAM('1Td1iR003EN34rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#3442,#3446,'P/0(?)');
#3448= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000104651904724982),$);
#3449= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000104651904724982),$);
#3450= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000104651904724982),$);
#3451= IFCPROPERTYSET('0k8mgvPND8Wvidlk81EXo0',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#3448,#3449,#3450,#1743,#1744,#1845,#1846,#3352,#1848,#1849));
#3452= IFCQUANTITYLENGTH('Length',$,$,370.000357475743);
#3453= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0232205665089652);
#3454= IFCQUANTITYVOLUME('NetVolume',$,$,0.000104651904724982);
#3455= IFCELEMENTQUANTITY('2fKBf79mD2sxFcvcr$Uuoc',#5,'BaseQuantities',$,$,(#3452,#3453,#3454,#1754));
#3456= IFCLOCALPLACEMENT(#30,#10);
#3457= IFCELEMENTASSEMBLY('1Td1iR003ELp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#3456,$,'ANK/63(?)',.NOTDEFINED.,.RIGID_FRAME.);
#3458= IFCPROPERTYSET('0wyu_Ssb5Ea8IUClNuQwqg',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#485,#2010,#2011,#39,#2857,#489));
#3459= IFCCARTESIANPOINT((48629.1280905254,874.976615875526,10614.));
#3460= IFCAXIS2PLACEMENT3D(#3459,#8,#7);
#3461= IFCLOCALPLACEMENT(#3456,#3460);
#3462= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#542));
#3463= IFCPRODUCTDEFINITIONSHAPE($,$,(#3462));
#3464= IFCBEAM('1Td1iR003EM34rDp0rCJ4s',#5,'ANKRAJ','PLT16*150','PLT16*150',#3461,#3463,'P/379(?)');
#3465= IFCPROPERTYSET('1tPc$zXTz1jBThKVrasSsr',#5,'Tekla Common','Common Properties to Shared building elements',(#2019,#2020,#512,#513,#74,#75,#919,#515,#78,#516,#80));
#3466= IFCLOCALPLACEMENT(#30,#10);
#3467= IFCELEMENTASSEMBLY('1Td1iR003EKp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#3466,$,'ANK/63(?)',.NOTDEFINED.,.RIGID_FRAME.);
#3468= IFCCARTESIANPOINT((48629.1280865254,624.976615875526,10614.));
#3469= IFCAXIS2PLACEMENT3D(#3468,#8,#7);
#3470= IFCLOCALPLACEMENT(#3466,#3469);
#3471= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#542));
#3472= IFCPRODUCTDEFINITIONSHAPE($,$,(#3471));
#3473= IFCBEAM('1Td1iR003EL34rDp0rCJ4s',#5,'ANKRAJ','PLT16*150','PLT16*150',#3470,#3472,'P/379(?)');
#3474= IFCLOCALPLACEMENT(#30,#10);
#3475= IFCELEMENTASSEMBLY('1Td1iR003EJp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#3474,$,'P/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#3476= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' +10.516'),$);
#3477= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +10.574'),$);
#3478= IFCPROPERTYSET('1sTIY_lin0jAPgmHeJulHw',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#3183,#3476,#3477,#3186,#2857,#3187));
#3479= IFCCARTESIANPOINT((48568.9996213439,499.979217037308,10574.0000000021));
#3480= IFCAXIS2PLACEMENT3D(#3479,#501,#596);
#3481= IFCLOCALPLACEMENT(#3474,#3480);
#3482= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3201));
#3483= IFCPRODUCTDEFINITIONSHAPE($,$,(#3482));
#3484= IFCPLATE('1Td1iR003EK34rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#3481,#3483,'P/432(?)');
#3485= IFCPROPERTYSET('3D5hu4wBDAM8uYsjqaZvYd',#5,'Tekla Common','Common Properties to Shared building elements',(#1227,#1228,#3207,#3208,#74,#75,#514,#77,#78,#920,#967));
#3486= IFCLOCALPLACEMENT(#30,#10);
#3487= IFCELEMENTASSEMBLY('1Td1iR003EIp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#3486,$,'P/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#3488= IFCCARTESIANPOINT((48568.9996218441,999.976217037307,10574.0000000021));
#3489= IFCAXIS2PLACEMENT3D(#3488,#501,#596);
#3490= IFCLOCALPLACEMENT(#3486,#3489);
#3491= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3201));
#3492= IFCPRODUCTDEFINITIONSHAPE($,$,(#3491));
#3493= IFCPLATE('1Td1iR003EJ34rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#3490,#3492,'P/432(?)');
#3494= IFCLOCALPLACEMENT(#30,#10);
#3495= IFCELEMENTASSEMBLY('1Td1iR003EHp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#3494,$,'P/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#3496= IFCCARTESIANPOINT((48568.9996255939,749.976217037307,10574.0000000021));
#3497= IFCAXIS2PLACEMENT3D(#3496,#501,#596);
#3498= IFCLOCALPLACEMENT(#3494,#3497);
#3499= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3201));
#3500= IFCPRODUCTDEFINITIONSHAPE($,$,(#3499));
#3501= IFCPLATE('1Td1iR003EI34rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#3498,#3500,'P/432(?)');
#3502= IFCLOCALPLACEMENT(#30,#10);
#3503= IFCELEMENTASSEMBLY('1Td1iR003EGp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#3502,$,'ANK/61(?)',.NOTDEFINED.,.RIGID_FRAME.);
#3504= IFCPROPERTYSET('01qzN7Nl94PPW19NA2Tqjr',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1665,#2032,#2033,#1614,#2857,#1616));
#3505= IFCCARTESIANPOINT((48388.7373035838,613.806318316645,10590.));
#3506= IFCAXIS2PLACEMENT3D(#3505,#9,#1966);
#3507= IFCLOCALPLACEMENT(#3502,#3506);
#3508= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3269));
#3509= IFCPRODUCTDEFINITIONSHAPE($,$,(#3508));
#3510= IFCBEAM('1Td1iR003EH34rDp0rCJ4s',#5,'PUL','PLT30*150','PLT30*150',#3507,#3509,'P/377(?)');
#3511= IFCLOCALPLACEMENT(#30,#10);
#3512= IFCELEMENTASSEMBLY('1Td1iR003EFp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#3511,$,'ANK/61(?)',.NOTDEFINED.,.RIGID_FRAME.);
#3513= IFCCARTESIANPOINT((48388.7373114812,886.145639936869,10590.));
#3514= IFCAXIS2PLACEMENT3D(#3513,#9,#1821);
#3515= IFCLOCALPLACEMENT(#3511,#3514);
#3516= IFCEXTRUDEDAREASOLID(#1628,#1630,#9,150.001159459228);
#3517= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3516));
#3518= IFCSTYLEDITEM(#3516,(#1627),$);
#3519= IFCPRODUCTDEFINITIONSHAPE($,$,(#3517));
#3520= IFCBEAM('1Td1iR003EG34rDp0rCJ4s',#5,'PUL','PLT30*150','PLT30*150',#3515,#3519,'P/377(?)');
#3521= IFCQUANTITYLENGTH('Length',$,$,150.001159459265);
#3522= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0630004174053514);
#3523= IFCQUANTITYVOLUME('NetVolume',$,$,0.000675005217567438);
#3524= IFCQUANTITYWEIGHT('NetWeight',$,$,5.29879095790439);
#3525= IFCELEMENTQUANTITY('00uWoc4aH0CPoPcb1lvm3r',#5,'BaseQuantities',$,$,(#3521,#3522,#3523,#3524));
#3526= IFCLOCALPLACEMENT(#30,#10);
#3527= IFCELEMENTASSEMBLY('1Td1iR003EEp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#3526,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#3528= IFCPROPERTYSET('36So7t$7j2teGe9CEaWkh3',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#2054,#2055,#1700,#2857,#1701));
#3529= IFCCARTESIANPOINT((48407.1668647196,966.832191080095,10590.));
#3530= IFCAXIS2PLACEMENT3D(#3529,#3301,#1706);
#3531= IFCLOCALPLACEMENT(#3526,#3530);
#3532= IFCEXTRUDEDAREASOLID(#1719,#1721,#9,16.0000409061877);
#3533= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3532));
#3534= IFCSTYLEDITEM(#3532,(#1711),$);
#3535= IFCPRODUCTDEFINITIONSHAPE($,$,(#3533));
#3536= IFCBEAM('1Td1iR003EF34rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#3531,#3535,'XX/0(?)');
#3537= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161875317564);
#3538= IFCQUANTITYVOLUME('NetVolume',$,$,1.2470797697729E-005);
#3539= IFCELEMENTQUANTITY('31KTpKaGDC5uVBy2IgOS2U',#5,'BaseQuantities',$,$,(#3420,#3537,#3538,#1754));
#3540= IFCLOCALPLACEMENT(#30,#10);
#3541= IFCELEMENTASSEMBLY('1Td1iR003EDp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#3540,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#3542= IFCCARTESIANPOINT((48391.525277322,963.46384553011,10590.));
#3543= IFCAXIS2PLACEMENT3D(#3542,#3301,#1706);
#3544= IFCLOCALPLACEMENT(#3540,#3543);
#3545= IFCEXTRUDEDAREASOLID(#1719,#1721,#9,16.0000409061876);
#3546= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3545));
#3547= IFCSTYLEDITEM(#3545,(#1711),$);
#3548= IFCPRODUCTDEFINITIONSHAPE($,$,(#3546));
#3549= IFCBEAM('1Td1iR003EE34rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#3544,#3548,'XX/0(?)');
#3550= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161875317621);
#3551= IFCQUANTITYVOLUME('NetVolume',$,$,1.24707976977338E-005);
#3552= IFCELEMENTQUANTITY('1ihTyvXIj6QPo6pYKt$Cqz',#5,'BaseQuantities',$,$,(#3420,#3550,#3551,#1754));
#3553= IFCLOCALPLACEMENT(#30,#10);
#3554= IFCELEMENTASSEMBLY('1Td1iR003ECp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#3553,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#3555= IFCPROPERTYSET('18J8FFXsvE$vfYu_giX1Gz',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#2076,#2077,#1775,#2857,#1701));
#3556= IFCCARTESIANPOINT((48387.6148925025,962.621340003308,10590.));
#3557= IFCAXIS2PLACEMENT3D(#3556,#1821,#1670);
#3558= IFCLOCALPLACEMENT(#3553,#3557);
#3559= IFCEXTRUDEDAREASOLID(#1783,#1785,#9,3.99999999998986);
#3560= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3559));
#3561= IFCSTYLEDITEM(#3559,(#1711),$);
#3562= IFCPRODUCTDEFINITIONSHAPE($,$,(#3560));
#3563= IFCBEAM('1Td1iR003ED34rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#3558,#3562,'XX/0(?)');
#3564= IFCPROPERTYSET('0uXDqgoXPCPx4ZhpD0cebx',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#1797,#1798,#1799,#1743,#1744,#1977,#1978,#1979,#1803,#1804));
#3565= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00180062582325587);
#3566= IFCQUANTITYVOLUME('NetVolume',$,$,3.93299999999226E-006);
#3567= IFCELEMENTQUANTITY('0nzQi6h6X8VR3B5cK4cSRu',#5,'BaseQuantities',$,$,(#3336,#3565,#3566,#1754));
#3568= IFCLOCALPLACEMENT(#30,#10);
#3569= IFCELEMENTASSEMBLY('1Td1iR003EBp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#3568,$,'R/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#3570= IFCPROPERTYSET('0BMvnMnALAzRzrydGeUuvz',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#2090,#2091,#1814,#3342,#1815));
#3571= IFCCARTESIANPOINT((48445.614490284,975.11041119336,10590.));
#3572= IFCAXIS2PLACEMENT3D(#3571,#1780,#1820);
#3573= IFCLOCALPLACEMENT(#3568,#3572);
#3574= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3347));
#3575= IFCPRODUCTDEFINITIONSHAPE($,$,(#3574));
#3576= IFCBEAM('1Td1iR003EC34rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#3573,#3575,'P/0(?)');
#3577= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0232205665089416);
#3578= IFCQUANTITYVOLUME('NetVolume',$,$,0.000104651904724866);
#3579= IFCELEMENTQUANTITY('1g69ANdSjD0OlqeRlScpdN',#5,'BaseQuantities',$,$,(#3354,#3577,#3578,#1754));
#3580= IFCCARTESIANPOINT((48594.1280919305,819.975973170847,10598.));
#3581= IFCAXIS2PLACEMENT3D(#3580,#9,#185);
#3582= IFCLOCALPLACEMENT(#3013,#3581);
#3583= IFCBOOLEANRESULT(.DIFFERENCE.,#3375,#1894);
#3584= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#3583));
#3585= IFCPRODUCTDEFINITIONSHAPE($,$,(#3584));
#3586= IFCPLATE('1Td1iR003EAJ4rDp0rCJ4s',#5,'ANCHOR','PL16*436','PL16*436',#3582,#3585,'P/0(?)');
#3587= IFCQUANTITYLENGTH('Width',$,$,436.392968590088);
#3588= IFCQUANTITYAREA('NetArea',$,$,0.312618913634511);
#3589= IFCQUANTITYAREA('GrossArea',$,$,0.218194795882852);
#3590= IFCQUANTITYVOLUME('NetVolume',$,$,0.00226796765811271);
#3591= IFCELEMENTQUANTITY('2J6zp7i$91YxMTxZXwuNtf',#5,'BaseQuantities',$,$,(#3587,#3588,#3589,#100,#3590,#3395));
#3592= IFCLOCALPLACEMENT(#30,#10);
#3593= IFCELEMENTASSEMBLY('1Td1iR003E934rDp0rCJ4s',#5,'Steel Assembly',$,$,#3592,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#3594= IFCCARTESIANPOINT((48407.1668386964,533.120202367885,10590.));
#3595= IFCAXIS2PLACEMENT3D(#3594,#1929,#3400);
#3596= IFCLOCALPLACEMENT(#3592,#3595);
#3597= IFCEXTRUDEDAREASOLID(#1719,#1721,#9,16.000040906186);
#3598= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3597));
#3599= IFCSTYLEDITEM(#3597,(#1711),$);
#3600= IFCPRODUCTDEFINITIONSHAPE($,$,(#3598));
#3601= IFCBEAM('1Td1iR003E9J4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#3596,#3600,'XX/0(?)');
#3602= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(16.0000409062486),$);
#3603= IFCPROPERTYSET('1zOzz2u9v1TvBxvcw9daMZ',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#1937,#1938,#1939,#1743,#1744,#1745,#1746,#1747,#1748,#3602));
#3604= IFCQUANTITYLENGTH('Length',$,$,16.0000409062486);
#3605= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161875317744);
#3606= IFCQUANTITYVOLUME('NetVolume',$,$,1.24707976977419E-005);
#3607= IFCELEMENTQUANTITY('2789wYyl53rgobW$nGRecW',#5,'BaseQuantities',$,$,(#3604,#3605,#3606,#1754));
#3608= IFCLOCALPLACEMENT(#30,#10);
#3609= IFCELEMENTASSEMBLY('1Td1iR003E834rDp0rCJ4s',#5,'Steel Assembly',$,$,#3608,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#3610= IFCCARTESIANPOINT((48391.5252517029,536.488549794907,10590.));
#3611= IFCAXIS2PLACEMENT3D(#3610,#1929,#3400);
#3612= IFCLOCALPLACEMENT(#3608,#3611);
#3613= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3597));
#3614= IFCPRODUCTDEFINITIONSHAPE($,$,(#3613));
#3615= IFCBEAM('1Td1iR003E8J4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#3612,#3614,'XX/0(?)');
#3616= IFCPROPERTYSET('1Gl66astHFT9SVOOeOST40',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#1937,#1938,#1939,#1743,#1744,#1745,#1746,#1747,#1748,#1749));
#3617= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161875317719);
#3618= IFCQUANTITYVOLUME('NetVolume',$,$,1.24707976977425E-005);
#3619= IFCELEMENTQUANTITY('3oBwf4ycTF1QcBjh0oix9p',#5,'BaseQuantities',$,$,(#3408,#3617,#3618,#1754));
#3620= IFCLOCALPLACEMENT(#30,#10);
#3621= IFCELEMENTASSEMBLY('1Td1iR003E734rDp0rCJ4s',#5,'Steel Assembly',$,$,#3620,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#3622= IFCCARTESIANPOINT((48387.6148669846,537.331055790964,10590.));
#3623= IFCAXIS2PLACEMENT3D(#3622,#1966,#1988);
#3624= IFCLOCALPLACEMENT(#3620,#3623);
#3625= IFCEXTRUDEDAREASOLID(#1783,#1785,#9,3.99999999999488);
#3626= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3625));
#3627= IFCSTYLEDITEM(#3625,(#1711),$);
#3628= IFCPRODUCTDEFINITIONSHAPE($,$,(#3626));
#3629= IFCBEAM('1Td1iR003E7J4rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#3624,#3628,'XX/0(?)');
#3630= IFCQUANTITYLENGTH('Length',$,$,4.00000000002183);
#3631= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0018006258232573);
#3632= IFCQUANTITYVOLUME('NetVolume',$,$,3.93300000000527E-006);
#3633= IFCELEMENTQUANTITY('3d$X9aKoj45gxDyqNTkQHR',#5,'BaseQuantities',$,$,(#3630,#3631,#3632,#1754));
#3634= IFCLOCALPLACEMENT(#30,#10);
#3635= IFCELEMENTASSEMBLY('1Td1iR003E634rDp0rCJ4s',#5,'Steel Assembly',$,$,#3634,$,'R/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#3636= IFCCARTESIANPOINT((48445.6144632673,524.841977640812,10590.));
#3637= IFCAXIS2PLACEMENT3D(#3636,#1989,#1621);
#3638= IFCLOCALPLACEMENT(#3634,#3637);
#3639= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3443));
#3640= IFCPRODUCTDEFINITIONSHAPE($,$,(#3639));
#3641= IFCBEAM('1Td1iR003E6J4rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#3638,#3640,'P/0(?)');
#3642= IFCLOCALPLACEMENT(#30,#10);
#3643= IFCELEMENTASSEMBLY('1Td1iR003E534rDp0rCJ4s',#5,'Steel Assembly',$,$,#3642,$,'ANK/63(?)',.NOTDEFINED.,.RIGID_FRAME.);
#3644= IFCPROPERTYSET('1yGeKyx0L2ZOhvp2n2fnNs',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#485,#2147,#2148,#39,#2857,#489));
#3645= IFCCARTESIANPOINT((48629.1280905254,874.976615875526,4914.));
#3646= IFCAXIS2PLACEMENT3D(#3645,#8,#7);
#3647= IFCLOCALPLACEMENT(#3642,#3646);
#3648= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#542));
#3649= IFCPRODUCTDEFINITIONSHAPE($,$,(#3648));
#3650= IFCBEAM('1Td1iR003E5J4rDp0rCJ4s',#5,'ANKRAJ','PLT16*150','PLT16*150',#3647,#3649,'P/379(?)');
#3651= IFCPROPERTYSET('0dyt$lp5j25xX5RvG5WV6p',#5,'Tekla Common','Common Properties to Shared building elements',(#2156,#2157,#512,#513,#74,#75,#919,#515,#78,#516,#80));
#3652= IFCLOCALPLACEMENT(#30,#10);
#3653= IFCELEMENTASSEMBLY('1Td1iR003E434rDp0rCJ4s',#5,'Steel Assembly',$,$,#3652,$,'ANK/63(?)',.NOTDEFINED.,.RIGID_FRAME.);
#3654= IFCCARTESIANPOINT((48629.1280865254,624.976615875526,4914.));
#3655= IFCAXIS2PLACEMENT3D(#3654,#8,#7);
#3656= IFCLOCALPLACEMENT(#3652,#3655);
#3657= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#542));
#3658= IFCPRODUCTDEFINITIONSHAPE($,$,(#3657));
#3659= IFCBEAM('1Td1iR003E4J4rDp0rCJ4s',#5,'ANKRAJ','PLT16*150','PLT16*150',#3656,#3658,'P/379(?)');
#3660= IFCLOCALPLACEMENT(#30,#10);
#3661= IFCELEMENTASSEMBLY('1Td1iR003E334rDp0rCJ4s',#5,'Steel Assembly',$,$,#3660,$,'P/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#3662= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' +4.816'),$);
#3663= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +4.874'),$);
#3664= IFCPROPERTYSET('2VkTGZg7T1gOCdShYFUexW',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#3183,#3662,#3663,#3186,#2857,#3187));
#3665= IFCCARTESIANPOINT((48568.9996213439,499.979217037308,4874.00000000214));
#3666= IFCAXIS2PLACEMENT3D(#3665,#501,#596);
#3667= IFCLOCALPLACEMENT(#3660,#3666);
#3668= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3201));
#3669= IFCPRODUCTDEFINITIONSHAPE($,$,(#3668));
#3670= IFCPLATE('1Td1iR003E3J4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#3667,#3669,'P/432(?)');
#3671= IFCPROPERTYSET('2UAdJM_qv5p99Qdd$GRhmG',#5,'Tekla Common','Common Properties to Shared building elements',(#1318,#1319,#3207,#3208,#74,#75,#514,#77,#78,#920,#967));
#3672= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(1.74835029722609),$);
#3673= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0139199864428829),$);
#3674= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(57.9999997204859),$);
#3675= IFCPROPERTYSET('2bqBaqvjT8DwxL9RWxxmtM',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#3210,#3211,#3672,#3213,#3214,#3215,#3216,#3217,#3255,#3219,#3673,#3674,#3222,#3223));
#3676= IFCQUANTITYLENGTH('Width',$,$,57.9999997204859);
#3677= IFCQUANTITYAREA('NetArea',$,$,0.0359136066130712);
#3678= IFCQUANTITYAREA('GrossArea',$,$,0.0139199864428829);
#3679= IFCQUANTITYVOLUME('NetVolume',$,$,0.000215519757771078);
#3680= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000215519757771078);
#3681= IFCELEMENTQUANTITY('0IQTI5B4PDXglQ4DQ7NGI1',#5,'BaseQuantities',$,$,(#3676,#3677,#3678,#100,#3679,#3680));
#3682= IFCLOCALPLACEMENT(#30,#10);
#3683= IFCELEMENTASSEMBLY('1Td1iR003E234rDp0rCJ4s',#5,'Steel Assembly',$,$,#3682,$,'P/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#3684= IFCCARTESIANPOINT((48568.9996218441,999.976217037307,4874.00000000214));
#3685= IFCAXIS2PLACEMENT3D(#3684,#501,#596);
#3686= IFCLOCALPLACEMENT(#3682,#3685);
#3687= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3201));
#3688= IFCPRODUCTDEFINITIONSHAPE($,$,(#3687));
#3689= IFCPLATE('1Td1iR003E2J4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#3686,#3688,'P/432(?)');
#3690= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(1.74835029722612),$);
#3691= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0359136066130713),$);
#3692= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0139199864428831),$);
#3693= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(57.9999997204868),$);
#3694= IFCPROPERTYSET('3t1aQGQMf7TPXeOIAESnHn',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#3210,#3211,#3690,#3213,#3214,#3215,#3216,#3217,#3255,#3691,#3692,#3693,#3242,#3223));
#3695= IFCQUANTITYLENGTH('Width',$,$,57.9999997204868);
#3696= IFCQUANTITYAREA('NetArea',$,$,0.0359136066130713);
#3697= IFCQUANTITYAREA('GrossArea',$,$,0.0139199864428831);
#3698= IFCQUANTITYVOLUME('NetVolume',$,$,0.000215519757771078);
#3699= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000215519757771078);
#3700= IFCELEMENTQUANTITY('2OE3RH6O15c8xACekGzHkm',#5,'BaseQuantities',$,$,(#3695,#3696,#3697,#100,#3698,#3699));
#3701= IFCLOCALPLACEMENT(#30,#10);
#3702= IFCELEMENTASSEMBLY('1Td1iR003E134rDp0rCJ4s',#5,'Steel Assembly',$,$,#3701,$,'P/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#3703= IFCCARTESIANPOINT((48568.9996255939,749.976217037307,4874.00000000214));
#3704= IFCAXIS2PLACEMENT3D(#3703,#501,#596);
#3705= IFCLOCALPLACEMENT(#3701,#3704);
#3706= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3201));
#3707= IFCPRODUCTDEFINITIONSHAPE($,$,(#3706));
#3708= IFCPLATE('1Td1iR003E1J4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#3705,#3707,'P/432(?)');
#3709= IFCPROPERTYSET('1fQRPQlzrCgRkrFUXcs$8u',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#3210,#3211,#3690,#3213,#3214,#3215,#3216,#3217,#3255,#3691,#3692,#3693,#3222,#3223));
#3710= IFCQUANTITYVOLUME('NetVolume',$,$,0.000215519757771078);
#3711= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000215519757771078);
#3712= IFCELEMENTQUANTITY('2aJbmFAbL5bx7d6MkrItkv',#5,'BaseQuantities',$,$,(#3695,#3696,#3697,#100,#3710,#3711));
#3713= IFCLOCALPLACEMENT(#30,#10);
#3714= IFCELEMENTASSEMBLY('1Td1iR003E034rDp0rCJ4s',#5,'Steel Assembly',$,$,#3713,$,'ANK/61(?)',.NOTDEFINED.,.RIGID_FRAME.);
#3715= IFCPROPERTYSET('1LVsvYBNX3PfbLTP8jK$fs',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1665,#2169,#2170,#1614,#2857,#1616));
#3716= IFCCARTESIANPOINT((48388.7373035838,613.806318316645,4890.));
#3717= IFCAXIS2PLACEMENT3D(#3716,#9,#1966);
#3718= IFCLOCALPLACEMENT(#3713,#3717);
#3719= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3269));
#3720= IFCPRODUCTDEFINITIONSHAPE($,$,(#3719));
#3721= IFCBEAM('1Td1iR003E0J4rDp0rCJ4s',#5,'PUL','PLT30*150','PLT30*150',#3718,#3720,'P/377(?)');
#3722= IFCLOCALPLACEMENT(#30,#10);
#3723= IFCELEMENTASSEMBLY('1Td1iR003D$34rDp0rCJ4s',#5,'Steel Assembly',$,$,#3722,$,'ANK/61(?)',.NOTDEFINED.,.RIGID_FRAME.);
#3724= IFCCARTESIANPOINT((48388.7373114812,886.145639936869,4890.));
#3725= IFCAXIS2PLACEMENT3D(#3724,#9,#1821);
#3726= IFCLOCALPLACEMENT(#3722,#3725);
#3727= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3516));
#3728= IFCPRODUCTDEFINITIONSHAPE($,$,(#3727));
#3729= IFCBEAM('1Td1iR003D$J4rDp0rCJ4s',#5,'PUL','PLT30*150','PLT30*150',#3726,#3728,'P/377(?)');
#3730= IFCLOCALPLACEMENT(#30,#10);
#3731= IFCELEMENTASSEMBLY('1Td1iR003D_34rDp0rCJ4s',#5,'Steel Assembly',$,$,#3730,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#3732= IFCPROPERTYSET('0zeLK0fcfDdAXMrx3VkQa6',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#2191,#2192,#1700,#2857,#1701));
#3733= IFCCARTESIANPOINT((48407.1668647196,966.832191080095,4890.));
#3734= IFCAXIS2PLACEMENT3D(#3733,#3301,#1706);
#3735= IFCLOCALPLACEMENT(#3730,#3734);
#3736= IFCEXTRUDEDAREASOLID(#1719,#1721,#9,16.0000409061951);
#3737= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3736));
#3738= IFCSTYLEDITEM(#3736,(#1711),$);
#3739= IFCPRODUCTDEFINITIONSHAPE($,$,(#3737));
#3740= IFCBEAM('1Td1iR003D_J4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#3735,#3739,'XX/0(?)');
#3741= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161875317646);
#3742= IFCQUANTITYVOLUME('NetVolume',$,$,1.24707976977351E-005);
#3743= IFCELEMENTQUANTITY('0dPPIleibBifw5lCJpgLi8',#5,'BaseQuantities',$,$,(#3408,#3741,#3742,#1754));
#3744= IFCLOCALPLACEMENT(#30,#10);
#3745= IFCELEMENTASSEMBLY('1Td1iR003Dz34rDp0rCJ4s',#5,'Steel Assembly',$,$,#3744,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#3746= IFCCARTESIANPOINT((48391.525277322,963.46384553011,4890.));
#3747= IFCAXIS2PLACEMENT3D(#3746,#3301,#1706);
#3748= IFCLOCALPLACEMENT(#3744,#3747);
#3749= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3736));
#3750= IFCPRODUCTDEFINITIONSHAPE($,$,(#3749));
#3751= IFCBEAM('1Td1iR003DzJ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#3748,#3750,'XX/0(?)');
#3752= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161875317697);
#3753= IFCQUANTITYVOLUME('NetVolume',$,$,1.24707976977395E-005);
#3754= IFCELEMENTQUANTITY('2rbueL0AjCCA7K9vf47IAs',#5,'BaseQuantities',$,$,(#3408,#3752,#3753,#1754));
#3755= IFCLOCALPLACEMENT(#30,#10);
#3756= IFCELEMENTASSEMBLY('1Td1iR003Dy34rDp0rCJ4s',#5,'Steel Assembly',$,$,#3755,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#3757= IFCPROPERTYSET('3CicIFjgD36AD5D$jHhTKM',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#2213,#2214,#1775,#2857,#1701));
#3758= IFCCARTESIANPOINT((48387.6148925025,962.621340003308,4890.));
#3759= IFCAXIS2PLACEMENT3D(#3758,#1821,#1670);
#3760= IFCLOCALPLACEMENT(#3755,#3759);
#3761= IFCEXTRUDEDAREASOLID(#1783,#1785,#9,3.99999999999728);
#3762= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3761));
#3763= IFCSTYLEDITEM(#3761,(#1711),$);
#3764= IFCPRODUCTDEFINITIONSHAPE($,$,(#3762));
#3765= IFCBEAM('1Td1iR003DyJ4rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#3760,#3764,'XX/0(?)');
#3766= IFCQUANTITYLENGTH('Length',$,$,4.00000000000728);
#3767= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00180062582325699);
#3768= IFCQUANTITYVOLUME('NetVolume',$,$,3.93300000000071E-006);
#3769= IFCELEMENTQUANTITY('0NauLEWRr0vOp8SDwuuJ9w',#5,'BaseQuantities',$,$,(#3766,#3767,#3768,#1754));
#3770= IFCLOCALPLACEMENT(#30,#10);
#3771= IFCELEMENTASSEMBLY('1Td1iR003Dx34rDp0rCJ4s',#5,'Steel Assembly',$,$,#3770,$,'R/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#3772= IFCPROPERTYSET('3Me4Y4cNf7Yfp4SUuXdmi3',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#2231,#2232,#1814,#3342,#1815));
#3773= IFCCARTESIANPOINT((48445.614490284,975.11041119336,4890.));
#3774= IFCAXIS2PLACEMENT3D(#3773,#1780,#1820);
#3775= IFCLOCALPLACEMENT(#3770,#3774);
#3776= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3347));
#3777= IFCPRODUCTDEFINITIONSHAPE($,$,(#3776));
#3778= IFCBEAM('1Td1iR003DxJ4rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#3775,#3777,'P/0(?)');
#3779= IFCPROPERTYSET('37KSsUqtD4oQulCITMlbM9',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#1997,#1998,#1999,#1743,#1744,#1845,#1846,#3352,#1848,#1849));
#3780= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0232205665089427);
#3781= IFCQUANTITYVOLUME('NetVolume',$,$,0.000104651904724876);
#3782= IFCELEMENTQUANTITY('2eZefMmt15BvMsoDREMrpp',#5,'BaseQuantities',$,$,(#3354,#3780,#3781,#1754));
#3783= IFCCARTESIANPOINT((48594.1280919305,819.975973170847,4898.));
#3784= IFCAXIS2PLACEMENT3D(#3783,#9,#185);
#3785= IFCLOCALPLACEMENT(#3081,#3784);
#3786= IFCBOOLEANRESULT(.DIFFERENCE.,#3375,#1894);
#3787= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#3786));
#3788= IFCPRODUCTDEFINITIONSHAPE($,$,(#3787));
#3789= IFCPLATE('1Td1iR003DvZ4rDp0rCJ4s',#5,'ANCHOR','PL16*436','PL16*436',#3785,#3788,'P/0(?)');
#3790= IFCQUANTITYLENGTH('Width',$,$,436.39296859008);
#3791= IFCQUANTITYAREA('NetArea',$,$,0.312618913634508);
#3792= IFCQUANTITYAREA('GrossArea',$,$,0.218194795882848);
#3793= IFCQUANTITYVOLUME('NetVolume',$,$,0.0022679676581127);
#3794= IFCELEMENTQUANTITY('3_q0aeCMX1b8SXGo0e910_',#5,'BaseQuantities',$,$,(#3790,#3791,#3792,#100,#3793,#3395));
#3795= IFCLOCALPLACEMENT(#30,#10);
#3796= IFCELEMENTASSEMBLY('1Td1iR003DuJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#3795,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#3797= IFCCARTESIANPOINT((48407.1668386964,533.120202367885,4890.));
#3798= IFCAXIS2PLACEMENT3D(#3797,#1929,#3400);
#3799= IFCLOCALPLACEMENT(#3795,#3798);
#3800= IFCEXTRUDEDAREASOLID(#1719,#1721,#9,16.0000409061935);
#3801= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3800));
#3802= IFCSTYLEDITEM(#3800,(#1711),$);
#3803= IFCPRODUCTDEFINITIONSHAPE($,$,(#3801));
#3804= IFCBEAM('1Td1iR003DuZ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#3799,#3803,'XX/0(?)');
#3805= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(16.0000409062559),$);
#3806= IFCPROPERTYSET('2AdGIw3$rCQeMvYKzyaykY',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#1937,#1938,#1939,#1743,#1744,#1745,#1746,#1747,#1748,#3805));
#3807= IFCQUANTITYLENGTH('Length',$,$,16.0000409062559);
#3808= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161875317845);
#3809= IFCQUANTITYVOLUME('NetVolume',$,$,1.24707976977507E-005);
#3810= IFCELEMENTQUANTITY('0aKuw8$AD2JBjxjzLy1N7W',#5,'BaseQuantities',$,$,(#3807,#3808,#3809,#1754));
#3811= IFCLOCALPLACEMENT(#30,#10);
#3812= IFCELEMENTASSEMBLY('1Td1iR003DtJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#3811,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#3813= IFCCARTESIANPOINT((48391.5252517029,536.488549794907,4890.));
#3814= IFCAXIS2PLACEMENT3D(#3813,#1929,#3400);
#3815= IFCLOCALPLACEMENT(#3811,#3814);
#3816= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3800));
#3817= IFCPRODUCTDEFINITIONSHAPE($,$,(#3816));
#3818= IFCBEAM('1Td1iR003DtZ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#3815,#3817,'XX/0(?)');
#3819= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161875317794);
#3820= IFCQUANTITYVOLUME('NetVolume',$,$,1.24707976977482E-005);
#3821= IFCELEMENTQUANTITY('1AJxfYDJH5ovN4IWFWWEHR',#5,'BaseQuantities',$,$,(#3604,#3819,#3820,#1754));
#3822= IFCLOCALPLACEMENT(#30,#10);
#3823= IFCELEMENTASSEMBLY('1Td1iR003DsJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#3822,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#3824= IFCCARTESIANPOINT((48387.6148669846,537.331055790964,4890.));
#3825= IFCAXIS2PLACEMENT3D(#3824,#1966,#1988);
#3826= IFCLOCALPLACEMENT(#3822,#3825);
#3827= IFCEXTRUDEDAREASOLID(#1783,#1785,#9,4.0000000000023);
#3828= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3827));
#3829= IFCSTYLEDITEM(#3827,(#1711),$);
#3830= IFCPRODUCTDEFINITIONSHAPE($,$,(#3828));
#3831= IFCBEAM('1Td1iR003DsZ4rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#3826,#3830,'XX/0(?)');
#3832= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(3.93300000001412E-006),$);
#3833= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(3.93300000001412E-006),$);
#3834= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(3.93300000001412E-006),$);
#3835= IFCPROPERTYSET('1nIBzeffvDY8vdzc_J94H9',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#3832,#3833,#3834,#1743,#1744,#1977,#1978,#1979,#1803,#1804));
#3836= IFCQUANTITYLENGTH('Length',$,$,4.00000000003638);
#3837= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00180062582325852);
#3838= IFCQUANTITYVOLUME('NetVolume',$,$,3.93300000001412E-006);
#3839= IFCELEMENTQUANTITY('32L88DOR1AcAchsziZ_Nnh',#5,'BaseQuantities',$,$,(#3836,#3837,#3838,#1754));
#3840= IFCLOCALPLACEMENT(#30,#10);
#3841= IFCELEMENTASSEMBLY('1Td1iR003DrJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#3840,$,'R/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#3842= IFCCARTESIANPOINT((48445.6144632673,524.841977640812,4890.));
#3843= IFCAXIS2PLACEMENT3D(#3842,#1989,#1621);
#3844= IFCLOCALPLACEMENT(#3840,#3843);
#3845= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3443));
#3846= IFCPRODUCTDEFINITIONSHAPE($,$,(#3845));
#3847= IFCBEAM('1Td1iR003DrZ4rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#3844,#3846,'P/0(?)');
#3848= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000104651904724989),$);
#3849= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000104651904724989),$);
#3850= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000104651904724989),$);
#3851= IFCPROPERTYSET('3I4C4LTBnAgAjeUKuaT3nY',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#3848,#3849,#3850,#1743,#1744,#1845,#1846,#3352,#1848,#1849));
#3852= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.023220566508966);
#3853= IFCQUANTITYVOLUME('NetVolume',$,$,0.000104651904724989);
#3854= IFCELEMENTQUANTITY('3kZGxituHCBP9hFqZ0LARP',#5,'BaseQuantities',$,$,(#3452,#3852,#3853,#1754));
#3855= IFCCARTESIANPOINT((48696.7135889992,-435.4580230017,-40.9756299499522));
#3856= IFCDIRECTION((-3.20999999656028E-007,0.999999999390699,3.49070000136351E-005));
#3857= IFCAXIS2PLACEMENT3D(#3855,#3856,#7);
#3858= IFCLOCALPLACEMENT(#30,#3857);
#3859= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#3860= IFCCARTESIANPOINT((0.,11.1198253334071,0.));
#3861= IFCAXIS2PLACEMENT3D(#3860,#8,#7);
#3862= IFCEXTRUDEDAREASOLID(#3859,#3861,#9,5.99999999994148);
#3863= IFCSTYLEDITEM(#3862,(#195),$);
#3864= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#3865= IFCCARTESIANPOINT((0.,16.9213700615557,0.));
#3866= IFCAXIS2PLACEMENT3D(#3865,#8,#7);
#3867= IFCEXTRUDEDAREASOLID(#3864,#3866,#9,6.10000000410307);
#3868= IFCSTYLEDITEM(#3867,(#195),$);
#3869= IFCCARTESIANPOINT((10.39230484542,0.));
#3870= IFCCARTESIANPOINT((5.19615242271,9.00000000000127));
#3871= IFCCARTESIANPOINT((-5.19615242271,9.00000000000127));
#3872= IFCCARTESIANPOINT((-10.39230484542,0.));
#3873= IFCCARTESIANPOINT((-5.19615242271,-9.00000000000127));
#3874= IFCCARTESIANPOINT((5.19615242271,-9.00000000000127));
#3875= IFCPOLYLINE((#3869,#3870,#3871,#3872,#3873,#3874,#3869));
#3876= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3875);
#3877= IFCCARTESIANPOINT((0.,3.09982533340714,0.));
#3878= IFCAXIS2PLACEMENT3D(#3877,#8,#7);
#3879= IFCEXTRUDEDAREASOLID(#3876,#3878,#9,7.92);
#3880= IFCSTYLEDITEM(#3879,(#558),$);
#3881= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#3882= IFCCARTESIANPOINT((0.,11.0198253334071,0.));
#3883= IFCAXIS2PLACEMENT3D(#3882,#8,#7);
#3884= IFCEXTRUDEDAREASOLID(#3881,#3883,#9,35.);
#3885= IFCSTYLEDITEM(#3884,(#558),$);
#3886= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#3887= IFCCARTESIANPOINT((0.,23.0213700656588,0.));
#3888= IFCAXIS2PLACEMENT3D(#3887,#8,#7);
#3889= IFCEXTRUDEDAREASOLID(#3886,#3888,#9,8.);
#3890= IFCSTYLEDITEM(#3889,(#558),$);
#3891= IFCCARTESIANPOINT((10.96965511461,0.));
#3892= IFCCARTESIANPOINT((5.484827557305,9.50000000000134));
#3893= IFCCARTESIANPOINT((-5.484827557305,9.50000000000134));
#3894= IFCCARTESIANPOINT((-10.96965511461,0.));
#3895= IFCCARTESIANPOINT((-5.484827557305,-9.50000000000134));
#3896= IFCCARTESIANPOINT((5.484827557305,-9.50000000000134));
#3897= IFCPOLYLINE((#3891,#3892,#3893,#3894,#3895,#3896,#3891));
#3898= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#3899= IFCCARTESIANPOINT((0.,31.0213700656588,0.));
#3900= IFCAXIS2PLACEMENT3D(#3899,#8,#7);
#3901= IFCEXTRUDEDAREASOLID(#3898,#3900,#9,10.);
#3902= IFCSTYLEDITEM(#3901,(#558),$);
#3903= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3862,#3867,#3879,#3884,#3889,#3901));
#3904= IFCREPRESENTATIONMAP(#10,#3903);
#3905= IFCMAPPEDITEM(#3904,#247);
#3906= IFCCARTESIANPOINT((65.0000000000073,4.35072422533267E-010,-8.87325768417213E-011));
#3907= IFCCARTESIANTRANSFORMATIONOPERATOR3D($,$,#3906,$,$);
#3908= IFCMAPPEDITEM(#3904,#3907);
#3909= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#3905,#3908));
#3910= IFCPRODUCTDEFINITIONSHAPE($,$,(#3909));
#3911= IFCMECHANICALFASTENER('1Td1iR002$Kp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#3858,#3910,'ID5d9c1b1b-0000-bf53-3135-373035313136',12.,35.);
#3912= IFCPROPERTYSINGLEVALUE('Washer diameter',$,IFCLENGTHMEASURE(12.),$);
#3913= IFCPROPERTYSINGLEVALUE('Washer name',$,IFCLABEL('WASHER12-7989'),$);
#3914= IFCPROPERTYSINGLEVALUE('Nut name',$,IFCLABEL('NUT12-555'),$);
#3915= IFCPROPERTYSINGLEVALUE('Bolt hole diameter',$,IFCLENGTHMEASURE(13.),$);
#3916= IFCPROPERTYSINGLEVALUE('Bolt size',$,IFCLENGTHMEASURE(12.),$);
#3917= IFCPROPERTYSINGLEVALUE('Bolt length',$,IFCLENGTHMEASURE(35.),$);
#3918= IFCPROPERTYSINGLEVALUE('Bolt Name',$,IFCLABEL('BOLT12*35'),$);
#3919= IFCPROPERTYSET('0XbonJNSb7ufHUQ98smvM7',#5,'Tekla Bolt','Bolt Properties',(#255,#3912,#571,#3913,#259,#573,#3914,#262,#263,#3915,#265,#266,#3916,#3917,#579,#3918));
#3920= IFCLOCALPLACEMENT(#30,#10);
#3921= IFCELEMENTASSEMBLY('1Td1iR002nAJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#3920,$,'DK/77(?)',.NOTDEFINED.,.RIGID_FRAME.);
#3922= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(665.299020249749),$);
#3923= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -1.110'),$);
#3924= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +4.800'),$);
#3925= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit name',$,IFCLABEL('DIKME'),$);
#3926= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit position code',$,IFCLABEL('6/6-N2'),$);
#3927= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('DK/77(?)'),$);
#3928= IFCPROPERTYSET('14i2Sz6zb2neXCin4SKLVN',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#3922,#3923,#3924,#3925,#3926,#3927));
#3929= IFCQUANTITYLENGTH('Width',$,$,238.518192698211);
#3930= IFCELEMENTQUANTITY('2J8JoPQXP87Bl2AoyT$Lrv',#5,'BaseQuantities',$,$,(#3929));
#3931= IFCCARTESIANPOINT((48764.9475061665,-586.604252655899,-60.9970000014691));
#3932= IFCDIRECTION((0.707106781186563,0.707106781186532,0.));
#3933= IFCAXIS2PLACEMENT3D(#3931,#9,#3932);
#3934= IFCLOCALPLACEMENT(#3920,#3933);
#3935= IFCCARTESIANPOINT((44.9999999998399,3.78349795937538E-010));
#3936= IFCCARTESIANPOINT((150.589736938564,105.589782714975));
#3937= IFCCARTESIANPOINT((55.1302871714433,201.049163816686));
#3938= IFCCARTESIANPOINT((2.69210431724787E-010,145.918869017005));
#3939= IFCPOLYLINE((#54,#3935,#3936,#3937,#3938,#54,#54));
#3940= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL6*135',#3939);
#3941= IFCCARTESIANPOINT((0.,0.,-3.));
#3942= IFCAXIS2PLACEMENT3D(#3941,#9,#7);
#3943= IFCEXTRUDEDAREASOLID(#3940,#3942,#9,6.);
#3944= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3943));
#3945= IFCSTYLEDITEM(#3943,(#53),$);
#3946= IFCPRODUCTDEFINITIONSHAPE($,$,(#3944));
#3947= IFCDISCRETEACCESSORY('1Td1iR002$JZ4rDp0rCJ4s',#5,'PLATE','PL6*135','PL6*135',#3934,#3946,'P/0(?)');
#3948= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -0.064'),$);
#3949= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -0.058'),$);
#3950= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('DK/77(?)'),$);
#3951= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PL6*135'),$);
#3952= IFCPROPERTYSET('3qfC3lbgn4TP9VP6WBfxQ3',#5,'Tekla Common','Common Properties to Shared building elements',(#3948,#3949,#1009,#3950,#74,#75,#76,#77,#78,#3951,#967));
#3953= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(665.299020249749),$);
#3954= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.877257164781193),$);
#3955= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(1.15181864708906),$);
#3956= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.877257164781193),$);
#3957= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000111752505067668),$);
#3958= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000111752505067668),$);
#3959= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000111752505067668),$);
#3960= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.0186254175113224),$);
#3961= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(46.2465337632193),$);
#3962= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0405701030900795),$);
#3963= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0244547483458399),$);
#3964= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(135.000011471479),$);
#3965= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(6.),$);
#3966= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(181.146268650551),$);
#3967= IFCPROPERTYSET('1bOd9b6xP6vwlY7$02PWWV',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#3953,#3954,#3955,#3956,#3957,#3958,#3959,#3960,#3961,#3962,#3963,#3964,#3965,#3966));
#3968= IFCQUANTITYLENGTH('Width',$,$,135.000011471479);
#3969= IFCQUANTITYAREA('NetArea',$,$,0.0405701030900795);
#3970= IFCQUANTITYAREA('GrossArea',$,$,0.0244547483458399);
#3971= IFCQUANTITYAREA('CrossSectionArea',$,$,3.6E-005);
#3972= IFCQUANTITYVOLUME('NetVolume',$,$,0.000111752505067668);
#3973= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000111752505067668);
#3974= IFCELEMENTQUANTITY('2d_cUfcgT6MAbAjme$s8CR',#5,'BaseQuantities',$,$,(#3968,#3969,#3970,#3971,#3972,#3973));
#3975= IFCCARTESIANPOINT((48729.2146926559,-405.458001403582,-93.9966481098618));
#3976= IFCDIRECTION((0.999999999963909,-8.49600000040733E-006,-2.91166416300875E-010));
#3977= IFCDIRECTION((0.,-3.4271000013645E-005,0.999999999412749));
#3978= IFCAXIS2PLACEMENT3D(#3975,#3976,#3977);
#3979= IFCLOCALPLACEMENT(#3920,#3978);
#3980= IFCCARTESIANPOINT((30.0000000000003,-2.50111042987555E-012));
#3981= IFCCARTESIANPOINT((30.0006141662615,142.411254882809));
#3982= IFCCARTESIANPOINT((-29.9993858337389,142.41125488281));
#3983= IFCCARTESIANPOINT((-29.9993858337393,112.411247253416));
#3984= IFCPOLYLINE((#54,#3980,#3981,#3982,#3983,#54,#54));
#3985= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL6*60',#3984);
#3986= IFCEXTRUDEDAREASOLID(#3985,#3942,#9,6.);
#3987= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#3986));
#3988= IFCSTYLEDITEM(#3986,(#53),$);
#3989= IFCPRODUCTDEFINITIONSHAPE($,$,(#3987));
#3990= IFCDISCRETEACCESSORY('1Td1iR002$Ip4rDp0rCJ4s',#5,'DETAY','PL6*60','PL6*60',#3979,#3989,'P/400(?)');
#3991= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -0.124'),$);
#3992= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -0.064'),$);
#3993= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/400(?)'),$);
#3994= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PL6*60'),$);
#3995= IFCPROPERTYSET('37hGmNRO54HO9AXF2WAnQI',#5,'Tekla Common','Common Properties to Shared building elements',(#3991,#3992,#3993,#3950,#74,#75,#76,#77,#78,#3994,#921));
#3996= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.323035226205536),$);
#3997= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(0.402454571923221),$);
#3998= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.323035226205536),$);
#3999= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(4.11509842300046E-005),$);
#4000= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(4.11509842300046E-005),$);
#4001= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(4.11509842300046E-005),$);
#4002= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.000854467529304585),$);
#4003= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(49.497805223446),$);
#4004= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0159895347070335),$);
#4005= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.00854468305569472),$);
#4006= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(59.9999999994477),$);
#4007= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(6.00000000064756),$);
#4008= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(142.41138426289),$);
#4009= IFCPROPERTYSET('2JZ2oZ1Wj4zvHDfdH1I9Sk',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#3953,#3996,#3997,#3998,#3999,#4000,#4001,#4002,#4003,#4004,#4005,#4006,#4007,#4008));
#4010= IFCQUANTITYLENGTH('Width',$,$,59.9999999994477);
#4011= IFCQUANTITYAREA('NetArea',$,$,0.0159895347070335);
#4012= IFCQUANTITYAREA('GrossArea',$,$,0.00854468305569472);
#4013= IFCQUANTITYVOLUME('NetVolume',$,$,4.11509842300046E-005);
#4014= IFCQUANTITYVOLUME('GrossVolume',$,$,4.11509842300046E-005);
#4015= IFCELEMENTQUANTITY('1HSczYXOb2w8U$xC6FSmol',#5,'BaseQuantities',$,$,(#4010,#4011,#4012,#3971,#4013,#4014));
#4016= IFCLOCALPLACEMENT(#30,#10);
#4017= IFCELEMENTASSEMBLY('1Td1iR002$DJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#4016,$,'B/173(?)',.NOTDEFINED.,.RIGID_FRAME.);
#4018= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(52.0689801613717),$);
#4019= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -0.090'),$);
#4020= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -0.000'),$);
#4021= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('B/173(?)'),$);
#4022= IFCPROPERTYSET('2_dV_Xbdj1_egxDJZ51L0T',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#4018,#4019,#4020,#890,#138,#4021));
#4023= IFCQUANTITYLENGTH('Width',$,$,90.0000007753207);
#4024= IFCELEMENTQUANTITY('18o3cemAfE3Q0mE0OtnG3O',#5,'BaseQuantities',$,$,(#4023));
#4025= IFCCARTESIANPOINT((48645.1939458758,-387.458505631215,-44.97317313447));
#4026= IFCDIRECTION((0.999999999996861,-2.43399999993832E-006,5.949999999884E-007));
#4027= IFCAXIS2PLACEMENT3D(#4025,#3977,#4026);
#4028= IFCLOCALPLACEMENT(#4016,#4027);
#4029= IFCCOLOURRGB('Dark Blue',0.,0.301960784313725,0.898039215686275);
#4030= IFCSURFACESTYLERENDERING(#4029,0.,$,$,$,$,IFCNORMALISEDRATIOMEASURE(0.00390625),IFCSPECULAREXPONENT(10.),.NOTDEFINED.);
#4031= IFCSURFACESTYLE('STEEL/S235JR',.POSITIVE.,(#4030));
#4032= IFCPRESENTATIONSTYLEASSIGNMENT((#4031));
#4033= IFCRECTANGLEPROFILEDEF(.AREA.,'PLT6*78',#197,6.,78.);
#4034= IFCCARTESIANPOINT((188.000000344881,3.79796618529211E-020,1.42108149046534E-014));
#4035= IFCAXIS2PLACEMENT3D(#4034,#185,#501);
#4036= IFCEXTRUDEDAREASOLID(#4033,#4035,#9,188.000000344881);
#4037= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#4036));
#4038= IFCSTYLEDITEM(#4036,(#4032),$);
#4039= IFCPRODUCTDEFINITIONSHAPE($,$,(#4037));
#4040= IFCDISCRETEACCESSORY('1Td1iR002$I34rDp0rCJ4s',#5,'DIKME','PLT6*78','PLT6*78',#4028,#4039,'P/476(?)');
#4041= IFCDISCRETEACCESSORYTYPE('2PCDjVco5AGP0eOpCTKWHN',#5,'DIKME',$,$,$,$,$,$);
#4042= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -0.084'),$);
#4043= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -0.006'),$);
#4044= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/476(?)'),$);
#4045= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('B/173(?)'),$);
#4046= IFCPROPERTYSINGLEVALUE('Class',$,IFCLABEL('4'),$);
#4047= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PLT6*78'),$);
#4048= IFCPROPERTYSINGLEVALUE('Name',$,IFCLABEL('DIKME'),$);
#4049= IFCPROPERTYSET('3yKmUqfA94ORtt31Pt0RUh',#5,'Tekla Common','Common Properties to Shared building elements',(#4042,#4043,#4044,#4045,#74,#75,#919,#4046,#78,#4047,#4048));
#4050= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(52.0689801613717),$);
#4051= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.690674401269168),$);
#4052= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(0.690674401272797),$);
#4053= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.690674401269168),$);
#4054= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(8.79840001616774E-005),$);
#4055= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(8.79840001616774E-005),$);
#4056= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(8.79840001616774E-005),$);
#4057= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00112800000206928),$);
#4058= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(47.084414882441),$);
#4059= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.032520000058039),$);
#4060= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.032520000058039),$);
#4061= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(78.0000000004047),$);
#4062= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(188.000000345477),$);
#4063= IFCPROPERTYSET('27Ft$zAe1DkuiSoOnZW6Vt',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#4050,#4051,#4052,#4053,#4054,#4055,#4056,#4057,#4058,#4059,#4060,#4061,#4007,#4062));
#4064= IFCQUANTITYLENGTH('Length',$,$,188.000000345477);
#4065= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.032520000058039);
#4066= IFCQUANTITYVOLUME('NetVolume',$,$,8.79840001616774E-005);
#4067= IFCQUANTITYWEIGHT('NetWeight',$,$,0.690674401269168);
#4068= IFCELEMENTQUANTITY('3cSa7un6n9dBv1nqrBcwWV',#5,'BaseQuantities',$,$,(#4064,#4065,#4066,#4067));
#4069= IFCCARTESIANPOINT((48739.1940470763,-465.457500051038,-54.9969162456491));
#4070= IFCDIRECTION((0.999999999999354,1.13700000002763E-006,0.));
#4071= IFCDIRECTION((-1.13699998410398E-006,0.999999998813557,4.86989999909212E-005));
#4072= IFCAXIS2PLACEMENT3D(#4069,#4070,#4071);
#4073= IFCLOCALPLACEMENT(#4016,#4072);
#4074= IFCCOLOURRGB('Dark Gray',0.4,0.4,0.4);
#4075= IFCSURFACESTYLERENDERING(#4074,0.,$,$,$,$,IFCNORMALISEDRATIOMEASURE(0.00390625),IFCSPECULAREXPONENT(10.),.NOTDEFINED.);
#4076= IFCSURFACESTYLE('STEEL/S235JR',.POSITIVE.,(#4075));
#4077= IFCPRESENTATIONSTYLEASSIGNMENT((#4076));
#4078= IFCRECTANGLEPROFILEDEF(.AREA.,'PLT6*188',#197,6.,188.);
#4079= IFCCARTESIANPOINT((75.0005913333387,-7.105427357601E-015,-7.27595761677597E-012));
#4080= IFCAXIS2PLACEMENT3D(#4079,#185,#501);
#4081= IFCEXTRUDEDAREASOLID(#4078,#4080,#9,75.0005913333387);
#4082= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#4081));
#4083= IFCSTYLEDITEM(#4081,(#4077),$);
#4084= IFCPRODUCTDEFINITIONSHAPE($,$,(#4082));
#4085= IFCDISCRETEACCESSORY('1Td1iR002$HJ4rDp0rCJ4s',#5,'DIKME','PLT6*188','PLT6*188',#4073,#4084,'P/473(?)');
#4086= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -0.058'),$);
#4087= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -0.052'),$);
#4088= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/473(?)'),$);
#4089= IFCPROPERTYSINGLEVALUE('Class',$,IFCLABEL('8'),$);
#4090= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PLT6*188'),$);
#4091= IFCPROPERTYSET('3A8sZI_QDF3gEH8yXO7EfO',#5,'Tekla Common','Common Properties to Shared building elements',(#4086,#4087,#4088,#4045,#74,#75,#919,#4089,#78,#4090,#4048));
#4092= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.664115236138868),$);
#4093= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(0.664115236139954),$);
#4094= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.664115236138868),$);
#4095= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(8.46006670240596E-005),$);
#4096= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(8.46006670240596E-005),$);
#4097= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(8.46006670240596E-005),$);
#4098= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.0141001111706675),$);
#4099= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(47.2150430091897),$);
#4100= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0313562294373548),$);
#4101= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0313562294373548),$);
#4102= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(188.000000000124),$);
#4103= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(75.0005913334595),$);
#4104= IFCPROPERTYSET('3$tSjhVdHE_gSz_S90DRMy',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#4050,#4092,#4093,#4094,#4095,#4096,#4097,#4098,#4099,#4100,#4101,#4102,#4007,#4103));
#4105= IFCQUANTITYLENGTH('Length',$,$,75.0005913334595);
#4106= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0313562294373548);
#4107= IFCQUANTITYVOLUME('NetVolume',$,$,8.46006670240596E-005);
#4108= IFCQUANTITYWEIGHT('NetWeight',$,$,0.664115236138868);
#4109= IFCELEMENTQUANTITY('2yt$RL07DFVBTUs2FKNJx3',#5,'BaseQuantities',$,$,(#4105,#4106,#4107,#4108));
#4110= IFCCARTESIANPOINT((48739.1939817919,-692.851480836499,-45.0000029746143));
#4111= IFCAXIS2PLACEMENT3D(#4110,#7,#8);
#4112= IFCLOCALPLACEMENT(#4016,#4111);
#4113= IFCCOLOURRGB('Light Orange',0.898039215686275,0.4,0.);
#4114= IFCSURFACESTYLERENDERING(#4113,0.,$,$,$,$,IFCNORMALISEDRATIOMEASURE(0.00390625),IFCSPECULAREXPONENT(10.),.NOTDEFINED.);
#4115= IFCSURFACESTYLE('STEEL/S235JR',.POSITIVE.,(#4114));
#4116= IFCPRESENTATIONSTYLEASSIGNMENT((#4115));
#4117= IFCRECTANGLEHOLLOWPROFILEDEF(.AREA.,'RHS200*90*6',#197,90.,200.,6.,6.,12.);
#4118= IFCCARTESIANPOINT((2257.85339654389,0.,1.8676525553487E-021));
#4119= IFCAXIS2PLACEMENT3D(#4118,#185,#501);
#4120= IFCEXTRUDEDAREASOLID(#4117,#4119,#9,2257.85339654389);
#4121= IFCCARTESIANPOINT((29.9999999999854,42.4999999999659));
#4122= IFCCARTESIANPOINT((199.999999999985,42.4999999997726));
#4123= IFCCARTESIANPOINT((199.999999999964,60.0081443784347));
#4124= IFCCARTESIANPOINT((-4.36557456851006E-010,60.0081443786621));
#4125= IFCPOLYLINE((#54,#3980,#4121,#4122,#4123,#4124,#54,#54));
#4126= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL10*60',#4125);
#4127= IFCCARTESIANPOINT((2197.8458562609,45.0000007752996,100.000000341613));
#4128= IFCAXIS2PLACEMENT3D(#4127,#501,#596);
#4129= IFCEXTRUDEDAREASOLID(#4126,#4128,#9,10.);
#4130= IFCBOOLEANRESULT(.DIFFERENCE.,#4120,#4129);
#4131= IFCCARTESIANPOINT((194.,-2.20552465179935E-010));
#4132= IFCCARTESIANPOINT((193.999999999862,142.513000488061));
#4133= IFCCARTESIANPOINT((199.999999999862,142.513000488054));
#4134= IFCCARTESIANPOINT((199.999999999854,160.005142211687));
#4135= IFCCARTESIANPOINT((-1.45519152283669E-010,160.013000488281));
#4136= IFCPOLYLINE((#54,#4131,#4132,#4133,#4134,#4135,#54,#54));
#4137= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL80*160',#4136);
#4138= IFCCARTESIANPOINT((2097.84885625095,35.0000008752966,100.000001467946));
#4139= IFCAXIS2PLACEMENT3D(#4138,#501,#596);
#4140= IFCEXTRUDEDAREASOLID(#4137,#4139,#9,80.);
#4141= IFCBOOLEANRESULT(.DIFFERENCE.,#4130,#4140);
#4142= IFCCARTESIANPOINT((190.000213641273,2.16942908082274E-009));
#4143= IFCCARTESIANPOINT((189.997482317674,197.689895632042));
#4144= IFCCARTESIANPOINT((199.997451800213,197.690017702332));
#4145= IFCCARTESIANPOINT((199.99719240077,217.682189943544));
#4146= IFCCARTESIANPOINT((-0.00311299897293793,237.6871948268));
#4147= IFCPOLYLINE((#54,#4142,#4143,#4144,#4145,#4146,#54,#54));
#4148= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL80*200',#4147);
#4149= IFCDIRECTION((1.38949999979704E-005,-6.36000013818348E-007,-0.999999999903262));
#4150= IFCDIRECTION((-2.29019911523482E-005,0.999999999737547,-6.36318236879996E-007));
#4151= IFCCARTESIANPOINT((302.393501917731,-44.9731531331039,100.022433768001));
#4152= IFCAXIS2PLACEMENT3D(#4151,#4150,#4149);
#4153= IFCEXTRUDEDAREASOLID(#4148,#4152,#9,80.);
#4154= IFCBOOLEANRESULT(.DIFFERENCE.,#4141,#4153);
#4155= IFCCARTESIANPOINT((207.393890380859,-1.3169483281672E-009));
#4156= IFCCARTESIANPOINT((203.545272827138,3.84845518943621));
#4157= IFCCARTESIANPOINT((219.384323120061,19.6875095354189));
#4158= IFCCARTESIANPOINT((113.318298339486,125.753524779597));
#4159= IFCCARTESIANPOINT((145.111022948771,157.546356200291));
#4160= IFCCARTESIANPOINT((102.689254760174,200.022186278671));
#4161= IFCCARTESIANPOINT((-4.56087946076877E-007,200.));
#4162= IFCPOLYLINE((#54,#4155,#4156,#4157,#4158,#4159,#4160,#4161,#54,#54));
#4163= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL96*200',#4162);
#4164= IFCCARTESIANPOINT((-1.62606449237869E-006,47.9990030246436,-99.9999999994543));
#4165= IFCAXIS2PLACEMENT3D(#4164,#501,#7);
#4166= IFCEXTRUDEDAREASOLID(#4163,#4165,#9,96.);
#4167= IFCBOOLEANRESULT(.DIFFERENCE.,#4154,#4166);
#4168= IFCDIRECTION((-0.707106784722086,7.07106452449794E-010,0.707106777651009));
#4169= IFCCARTESIANPOINT((-90.2169724801345,44.9999997293313,-99.9999991637887));
#4170= IFCDIRECTION((0.707106777651009,2.29289322167241E-009,0.707106784722086));
#4171= IFCAXIS2PLACEMENT3D(#4169,#4168,#4170);
#4172= IFCPLANE(#4171);
#4173= IFCHALFSPACESOLID(#4172,.F.);
#4174= IFCBOOLEANRESULT(.DIFFERENCE.,#4167,#4173);
#4175= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#4174));
#4176= IFCSTYLEDITEM(#4120,(#4116),$);
#4177= IFCPRODUCTDEFINITIONSHAPE($,$,(#4175));
#4178= IFCBEAM('1Td1iR002$D34rDp0rCJ4s',#5,'KIRIS','RHS200*90*6','RHS200*90*6',#4112,#4177,'P/458(?)');
#4179= IFCBEAMTYPE('0TwM3GLS50PQelcFG_3zrH',#5,'RHS200*90*6',$,$,$,$,$,$,.NOTDEFINED.);
#4180= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -0.090'),$);
#4181= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -0.000'),$);
#4182= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/458(?)'),$);
#4183= IFCPROPERTYSINGLEVALUE('Class',$,IFCLABEL('13'),$);
#4184= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('RHS200*90*6'),$);
#4185= IFCPROPERTYSINGLEVALUE('Name',$,IFCLABEL('KIRIS'),$);
#4186= IFCPROPERTYSET('2RY98RJCX2aAMT$_nrfZ5V',#5,'Tekla Common','Common Properties to Shared building elements',(#4180,#4181,#4182,#4045,#74,#75,#919,#4183,#78,#4184,#4185));
#4187= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(50.7141905239636),$);
#4188= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(59.1277616073329),$);
#4189= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(50.7141905239636),$);
#4190= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.00646040643617371),$);
#4191= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.00753219893087043),$);
#4192= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.00646040643617371),$);
#4193= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.415651798673854),$);
#4194= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(21.9909812424863),$);
#4195= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(1.11525481254036),$);
#4196= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(1.29763143142104),$);
#4197= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(200.022382988522),$);
#4198= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(90.0000007753207),$);
#4199= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(2134.11688769654),$);
#4200= IFCPROPERTYSET('30NAUDKhb80P66zS_bYag$',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#4050,#4187,#4188,#4189,#4190,#4191,#4192,#4193,#4194,#4195,#4196,#4197,#4198,#4199));
#4201= IFCQUANTITYLENGTH('Length',$,$,2134.11688769654);
#4202= IFCQUANTITYAREA('OuterSurfaceArea',$,$,1.11525481254036);
#4203= IFCQUANTITYVOLUME('NetVolume',$,$,0.00646040643617371);
#4204= IFCQUANTITYWEIGHT('NetWeight',$,$,50.7141905239636);
#4205= IFCELEMENTQUANTITY('00EIRAXLPCX8PpiOK0WM8Y',#5,'BaseQuantities',$,$,(#4201,#4202,#4203,#4204));
#4206= IFCLOCALPLACEMENT(#30,#10);
#4207= IFCELEMENTASSEMBLY('1Td1iR001kSZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#4206,$,'B/134(?)',.NOTDEFINED.,.RIGID_FRAME.);
#4208= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(955.104769981965),$);
#4209= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('B/134(?)'),$);
#4210= IFCPROPERTYSET('3HtTeyuP51OQzk6KmGEP0s',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#4208,#1308,#1309,#890,#138,#4209));
#4211= IFCCARTESIANPOINT((48568.9993813414,8334.99976040911,4815.99999999996));
#4212= IFCAXIS2PLACEMENT3D(#4211,#8,#9);
#4213= IFCLOCALPLACEMENT(#4206,#4212);
#4214= IFCCARTESIANPOINT((58.,225.));
#4215= IFCCARTESIANPOINT((43.,240.));
#4216= IFCCARTESIANPOINT((15.,240.));
#4217= IFCCARTESIANPOINT((0.,225.));
#4218= IFCPOLYLINE((#3194,#900,#952,#953,#4214,#4215,#4216,#4217,#3194));
#4219= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL16*58',#4218);
#4220= IFCEXTRUDEDAREASOLID(#4219,#63,#9,16.);
#4221= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#4220));
#4222= IFCSTYLEDITEM(#4220,(#53),$);
#4223= IFCPRODUCTDEFINITIONSHAPE($,$,(#4221));
#4224= IFCDISCRETEACCESSORY('1Td1iR002$9Z4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#4213,#4223,'P/430(?)');
#4225= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/430(?)'),$);
#4226= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('B/134(?)'),$);
#4227= IFCPROPERTYSET('2YDVoWcVDCdgt2j4WS93lQ',#5,'Tekla Common','Common Properties to Shared building elements',(#1318,#1319,#4225,#4226,#74,#75,#76,#77,#78,#920,#967));
#4228= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(955.104769981965),$);
#4229= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(1.69183200000001),$);
#4230= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(1.74835200000053),$);
#4231= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(1.69183200000001),$);
#4232= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000215520000000002),$);
#4233= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000215520000000002),$);
#4234= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000215520000000002),$);
#4235= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00336),$);
#4236= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(21.2276662339274),$);
#4237= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0359136450198782),$);
#4238= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0139200000000042),$);
#4239= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(58.),$);
#4240= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(240.000000000073),$);
#4241= IFCPROPERTYSET('3vmIsqxaj00BknR4oMUaD6',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#4228,#4229,#4230,#4231,#4232,#4233,#4234,#4235,#4236,#4237,#4238,#4239,#3222,#4240));
#4242= IFCQUANTITYLENGTH('Width',$,$,58.);
#4243= IFCQUANTITYAREA('NetArea',$,$,0.0359136450198782);
#4244= IFCQUANTITYAREA('GrossArea',$,$,0.0139200000000042);
#4245= IFCQUANTITYVOLUME('NetVolume',$,$,0.000215520000000002);
#4246= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000215520000000002);
#4247= IFCELEMENTQUANTITY('3atnBihLvCNAtuM2Z2btXV',#5,'BaseQuantities',$,$,(#4242,#4243,#4244,#100,#4245,#4246));
#4248= IFCLOCALPLACEMENT(#30,#10);
#4249= IFCELEMENTASSEMBLY('1Td1iR001KDp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#4248,$,'B/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#4250= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(851.042726002103),$);
#4251= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('B/0(?)'),$);
#4252= IFCPROPERTYSET('2YJRoz4Sj81vtmoRcltGqs',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#4250,#888,#889,#890,#138,#4251));
#4253= IFCCARTESIANPOINT((48574.6565743973,-424.596789171421,15716.));
#4254= IFCDIRECTION((0.707109318181996,0.707104244181997,0.));
#4255= IFCAXIS2PLACEMENT3D(#4253,#4254,#9);
#4256= IFCLOCALPLACEMENT(#4248,#4255);
#4257= IFCCARTESIANPOINT((58.,308.411712647212));
#4258= IFCCARTESIANPOINT((43.,323.411712647212));
#4259= IFCCARTESIANPOINT((15.,323.411712647212));
#4260= IFCCARTESIANPOINT((0.,308.411712647212));
#4261= IFCPOLYLINE((#3194,#900,#952,#953,#4257,#4258,#4259,#4260,#3194));
#4262= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL16*58',#4261);
#4263= IFCEXTRUDEDAREASOLID(#4262,#63,#9,16.);
#4264= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#4263));
#4265= IFCSTYLEDITEM(#4263,(#53),$);
#4266= IFCPRODUCTDEFINITIONSHAPE($,$,(#4264));
#4267= IFCDISCRETEACCESSORY('1Td1iR002_d34rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#4256,#4266,'P/430(?)');
#4268= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('B/0(?)'),$);
#4269= IFCPROPERTYSET('062CDDpJfAFx0BDzqw30bL',#5,'Tekla Common','Common Properties to Shared building elements',(#915,#916,#4225,#4268,#74,#75,#76,#77,#78,#920,#967));
#4270= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(851.042726002103),$);
#4271= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(2.2994696442848),$);
#4272= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(2.35598964428907),$);
#4273= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(2.2994696442848),$);
#4274= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000292926069335644),$);
#4275= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000292926069335644),$);
#4276= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000292926069335644),$);
#4277= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00469458740234338),$);
#4278= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(20.9868299899026),$);
#4279= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.048258578491547),$);
#4280= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0187578793335117),$);
#4281= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(323.411712646754),$);
#4282= IFCPROPERTYSET('2o6L6aUd10OxGczj7EQPSc',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#4270,#4271,#4272,#4273,#4274,#4275,#4276,#4277,#4278,#4279,#4280,#4239,#94,#4281));
#4283= IFCQUANTITYAREA('NetArea',$,$,0.048258578491547);
#4284= IFCQUANTITYAREA('GrossArea',$,$,0.0187578793335117);
#4285= IFCQUANTITYVOLUME('NetVolume',$,$,0.000292926069335644);
#4286= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000292926069335644);
#4287= IFCELEMENTQUANTITY('1EvnslQtH3FuxVOEdGo2Z5',#5,'BaseQuantities',$,$,(#4242,#4283,#4284,#100,#4285,#4286));
#4288= IFCLOCALPLACEMENT(#30,#10);
#4289= IFCELEMENTASSEMBLY('1Td1iR001KQJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#4288,$,'B/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#4290= IFCPROPERTYSET('2oSsPKx0PEjRjSh3e$4Z5D',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#4250,#1218,#1219,#890,#138,#4251));
#4291= IFCCARTESIANPOINT((48574.6565743973,-424.596789171421,10516.));
#4292= IFCAXIS2PLACEMENT3D(#4291,#4254,#9);
#4293= IFCLOCALPLACEMENT(#4288,#4292);
#4294= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#4263));
#4295= IFCPRODUCTDEFINITIONSHAPE($,$,(#4294));
#4296= IFCDISCRETEACCESSORY('1Td1iR002_bJ4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#4293,#4295,'P/430(?)');
#4297= IFCPROPERTYSET('2CjdAguGv3F8W3PgkE$$PO',#5,'Tekla Common','Common Properties to Shared building elements',(#1227,#1228,#4225,#4268,#74,#75,#76,#77,#78,#920,#967));
#4298= IFCCARTESIANPOINT((48574.6565743973,-424.596789171421,4815.99999999996));
#4299= IFCAXIS2PLACEMENT3D(#4298,#4254,#9);
#4300= IFCLOCALPLACEMENT(#4206,#4299);
#4301= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#4263));
#4302= IFCPRODUCTDEFINITIONSHAPE($,$,(#4301));
#4303= IFCDISCRETEACCESSORY('1Td1iR002_ZJ4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#4300,#4302,'P/430(?)');
#4304= IFCPROPERTYSET('1TqfBB8KPFCAJGH6zrEmVj',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#4228,#4271,#4272,#4273,#4274,#4275,#4276,#4277,#4278,#4279,#4280,#4239,#94,#4281));
#4305= IFCLOCALPLACEMENT(#30,#10);
#4306= IFCELEMENTASSEMBLY('1Td1iR002_YZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#4305,$,'B/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#4307= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(1.32771372538332),$);
#4308= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -1.184'),$);
#4309= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -1.126'),$);
#4310= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit name',$,IFCLABEL('DETAY'),$);
#4311= IFCPROPERTYSET('3UZHjVBtn3te8NrKNT$iI6',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#4307,#4308,#4309,#4310,#3926,#4251));
#4312= IFCCARTESIANPOINT((48732.9811469616,-664.169997376989,-1126.));
#4313= IFCAXIS2PLACEMENT3D(#4312,#7,#896);
#4314= IFCLOCALPLACEMENT(#4305,#4313);
#4315= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#909));
#4316= IFCPRODUCTDEFINITIONSHAPE($,$,(#4315));
#4317= IFCPLATE('1Td1iR002_YJ4rDp0rCJ4s',#5,'DETAY','PL16*58','PL16*58',#4314,#4316,'P/429(?)');
#4318= IFCPROPERTYSET('33bv3xUMX8JAX$Mm2imDtq',#5,'Tekla Common','Common Properties to Shared building elements',(#1463,#1464,#917,#4268,#74,#75,#919,#77,#78,#920,#921));
#4319= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(1.32771372538332),$);
#4320= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(21.4773305438382),$);
#4321= IFCPROPERTYSET('0puFn2g7P6Mx_OY_dSY9Fb',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#4319,#924,#925,#926,#927,#928,#929,#930,#4320,#932,#933,#934,#94,#1324));
#4322= IFCQUANTITYAREA('NetArea',$,$,0.0285157465476483);
#4323= IFCQUANTITYVOLUME('NetVolume',$,$,0.000169135506418257);
#4324= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000169135506418257);
#4325= IFCELEMENTQUANTITY('1NLV7QvTv9GOcEWN2KJEFf',#5,'BaseQuantities',$,$,(#1326,#4322,#1471,#100,#4323,#4324));
#4326= IFCLOCALPLACEMENT(#30,#10);
#4327= IFCELEMENTASSEMBLY('1Td1iR002_XZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#4326,$,'B/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#4328= IFCCARTESIANPOINT((48832.9811469616,-664.169997376989,-1126.));
#4329= IFCAXIS2PLACEMENT3D(#4328,#7,#896);
#4330= IFCLOCALPLACEMENT(#4326,#4329);
#4331= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#909));
#4332= IFCPRODUCTDEFINITIONSHAPE($,$,(#4331));
#4333= IFCPLATE('1Td1iR002_XJ4rDp0rCJ4s',#5,'DETAY','PL16*58','PL16*58',#4330,#4332,'P/429(?)');
#4334= IFCCARTESIANPOINT((48572.2615232128,-422.01205949005,19980.0067863894));
#4335= IFCDIRECTION((-0.707106781186549,-0.707106781186546,0.));
#4336= IFCAXIS2PLACEMENT3D(#4334,#4335,#9);
#4337= IFCLOCALPLACEMENT(#30,#4336);
#4338= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,9.);
#4339= IFCCARTESIANPOINT((0.,42.6001367610351,0.));
#4340= IFCAXIS2PLACEMENT3D(#4339,#8,#7);
#4341= IFCEXTRUDEDAREASOLID(#4338,#4340,#9,15.9999999995283);
#4342= IFCSTYLEDITEM(#4341,(#195),$);
#4343= IFCCARTESIANPOINT((-25.,9.));
#4344= IFCCARTESIANPOINT((25.,9.));
#4345= IFCPOLYLINE((#4343,#4344));
#4346= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#4345);
#4347= IFCDIRECTION((0.,1.));
#4348= IFCCARTESIANPOINT((25.,0.));
#4349= IFCAXIS2PLACEMENT2D(#4348,#4347);
#4350= IFCCIRCLE(#4349,9.);
#4351= IFCTRIMMEDCURVE(#4350,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(3.14159265358979)),.F.,.PARAMETER.);
#4352= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#4351);
#4353= IFCCARTESIANPOINT((25.,-9.));
#4354= IFCCARTESIANPOINT((-25.,-9.));
#4355= IFCPOLYLINE((#4353,#4354));
#4356= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#4355);
#4357= IFCDIRECTION((0.,-1.));
#4358= IFCCARTESIANPOINT((-25.,0.));
#4359= IFCAXIS2PLACEMENT2D(#4358,#4357);
#4360= IFCCIRCLE(#4359,9.);
#4361= IFCTRIMMEDCURVE(#4360,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(3.14159265358979)),.F.,.PARAMETER.);
#4362= IFCCOMPOSITECURVESEGMENT(.DISCONTINUOUS.,.T.,#4361);
#4363= IFCCOMPOSITECURVE((#4346,#4352,#4356,#4362),.F.);
#4364= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4363);
#4365= IFCCARTESIANPOINT((0.,58.4003016098034,0.));
#4366= IFCAXIS2PLACEMENT3D(#4365,#8,#7);
#4367= IFCEXTRUDEDAREASOLID(#4364,#4366,#9,16.099999999557);
#4368= IFCSTYLEDITEM(#4367,(#195),$);
#4369= IFCCARTESIANPOINT((13.85640646056,0.));
#4370= IFCCARTESIANPOINT((6.92820323028,12.0000000000017));
#4371= IFCCARTESIANPOINT((-6.92820323028,12.0000000000017));
#4372= IFCCARTESIANPOINT((-13.85640646056,0.));
#4373= IFCCARTESIANPOINT((-6.92820323028,-12.0000000000017));
#4374= IFCCARTESIANPOINT((6.92820323028,-12.0000000000017));
#4375= IFCPOLYLINE((#4369,#4370,#4371,#4372,#4373,#4374,#4369));
#4376= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#4377= IFCCARTESIANPOINT((0.,31.940136761035,0.));
#4378= IFCAXIS2PLACEMENT3D(#4377,#8,#7);
#4379= IFCEXTRUDEDAREASOLID(#4376,#4378,#9,10.56);
#4380= IFCSTYLEDITEM(#4379,(#558),$);
#4381= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,8.);
#4382= IFCCARTESIANPOINT((0.,42.5001367610351,0.));
#4383= IFCAXIS2PLACEMENT3D(#4382,#8,#7);
#4384= IFCEXTRUDEDAREASOLID(#4381,#4383,#9,60.);
#4385= IFCSTYLEDITEM(#4384,(#558),$);
#4386= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,15.);
#4387= IFCCARTESIANPOINT((0.,74.5003016093604,0.));
#4388= IFCAXIS2PLACEMENT3D(#4387,#8,#7);
#4389= IFCEXTRUDEDAREASOLID(#4386,#4388,#9,8.);
#4390= IFCSTYLEDITEM(#4389,(#558),$);
#4391= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#4392= IFCCARTESIANPOINT((0.,82.5003016093604,0.));
#4393= IFCAXIS2PLACEMENT3D(#4392,#8,#7);
#4394= IFCEXTRUDEDAREASOLID(#4391,#4393,#9,13.);
#4395= IFCSTYLEDITEM(#4394,(#558),$);
#4396= IFCCARTESIANPOINT((0.,-1.96450855582953E-010,-54.9999999999345));
#4397= IFCCARTESIANTRANSFORMATIONOPERATOR3D($,$,#4396,$,$);
#4398= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#4341,#4367,#4379,#4384,#4389,#4394));
#4399= IFCREPRESENTATIONMAP(#10,#4398);
#4400= IFCMAPPEDITEM(#4399,#4397);
#4401= IFCCARTESIANPOINT((0.,1.96450855582953E-010,54.9999999999345));
#4402= IFCCARTESIANTRANSFORMATIONOPERATOR3D($,$,#4401,$,$);
#4403= IFCMAPPEDITEM(#4399,#4402);
#4404= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#4400,#4403));
#4405= IFCPRODUCTDEFINITIONSHAPE($,$,(#4404));
#4406= IFCMECHANICALFASTENER('1Td1iR002rbp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#4337,#4405,'ID5d9c1b1b-0000-b597-3135-373035313136',16.,60.);
#4407= IFCPROPERTYSINGLEVALUE('Washer diameter',$,IFCLENGTHMEASURE(16.),$);
#4408= IFCPROPERTYSINGLEVALUE('Washer name',$,IFCLABEL('WASHER16-7989'),$);
#4409= IFCPROPERTYSINGLEVALUE('Nut name',$,IFCLABEL('NUT16-555'),$);
#4410= IFCPROPERTYSINGLEVALUE('Slotted hole x',$,IFCLENGTHMEASURE(50.),$);
#4411= IFCPROPERTYSINGLEVALUE('Bolt hole diameter',$,IFCLENGTHMEASURE(18.),$);
#4412= IFCPROPERTYSINGLEVALUE('Bolt size',$,IFCLENGTHMEASURE(16.),$);
#4413= IFCPROPERTYSINGLEVALUE('Bolt length',$,IFCLENGTHMEASURE(60.),$);
#4414= IFCPROPERTYSINGLEVALUE('Bolt Name',$,IFCLABEL('BOLT16*60'),$);
#4415= IFCPROPERTYSET('3IhkEfbtv2D9O8sQ17RMCW',#5,'Tekla Bolt','Bolt Properties',(#255,#4407,#571,#4408,#259,#573,#4409,#262,#4410,#4411,#265,#266,#4412,#4413,#579,#4414));
#4416= IFCCARTESIANPOINT((48645.8534633802,-501.695514873256,20103.0038902755));
#4417= IFCDIRECTION((0.,-0.999999999999402,1.09399999995566E-006));
#4418= IFCDIRECTION((0.,1.09399999995566E-006,0.999999999999402));
#4419= IFCAXIS2PLACEMENT3D(#4416,#4417,#4418);
#4420= IFCLOCALPLACEMENT(#133,#4419);
#4421= IFCCARTESIANPOINT((94.0000000003383,0.));
#4422= IFCCARTESIANPOINT((94.0000000003383,294.));
#4423= IFCCARTESIANPOINT((3.63797880709171E-012,294.));
#4424= IFCPOLYLINE((#54,#4421,#4422,#4423,#54,#54));
#4425= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL3*94',#4424);
#4426= IFCCARTESIANPOINT((0.,0.,-1.5));
#4427= IFCAXIS2PLACEMENT3D(#4426,#9,#7);
#4428= IFCEXTRUDEDAREASOLID(#4425,#4427,#9,3.);
#4429= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#4428));
#4430= IFCSTYLEDITEM(#4428,(#53),$);
#4431= IFCPRODUCTDEFINITIONSHAPE($,$,(#4429));
#4432= IFCDISCRETEACCESSORY('1Td1iR002raZ4rDp0rCJ4s',#5,'Cap plate','PL3*94','PL3*94',#4420,#4431,'0(?)');
#4433= IFCDISCRETEACCESSORYTYPE('3$KTT2ovrC0AqMSP3BwoXS',#5,'Cap plate',$,$,$,$,$,$);
#4434= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +20.103'),$);
#4435= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +20.197'),$);
#4436= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('0(?)'),$);
#4437= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PL3*94'),$);
#4438= IFCPROPERTYSINGLEVALUE('Name',$,IFCLABEL('Cap plate'),$);
#4439= IFCPROPERTYSET('3IMLzjadn3iAPcH3UiLnC3',#5,'Tekla Common','Common Properties to Shared building elements',(#4434,#4435,#4436,#160,#74,#75,#76,#77,#78,#4437,#4438));
#4440= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.650827800000366),$);
#4441= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(0.650827800000403),$);
#4442= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.650827800000366),$);
#4443= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(8.29080000000466E-005),$);
#4444= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(8.29080000000466E-005),$);
#4445= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(8.29080000000466E-005),$);
#4446= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.000881999999999993),$);
#4447= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(88.5026730572988),$);
#4448= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0576000000000334),$);
#4449= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0276360000000171),$);
#4450= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(94.0000000000582),$);
#4451= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(3.000000000147),$);
#4452= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(294.),$);
#4453= IFCPROPERTYSET('3cu96YY559QuvlyUDMIXIh',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#163,#4440,#4441,#4442,#4443,#4444,#4445,#4446,#4447,#4448,#4449,#4450,#4451,#4452));
#4454= IFCQUANTITYLENGTH('Width',$,$,94.0000000000582);
#4455= IFCQUANTITYAREA('NetArea',$,$,0.0576000000000334);
#4456= IFCQUANTITYAREA('GrossArea',$,$,0.0276360000000171);
#4457= IFCQUANTITYAREA('CrossSectionArea',$,$,9.E-006);
#4458= IFCQUANTITYVOLUME('NetVolume',$,$,8.29080000000466E-005);
#4459= IFCQUANTITYVOLUME('GrossVolume',$,$,8.29080000000466E-005);
#4460= IFCELEMENTQUANTITY('0DggF$isTAyQdjR2uhbqF1',#5,'BaseQuantities',$,$,(#4454,#4455,#4456,#4457,#4458,#4459));
#4461= IFCLOCALPLACEMENT(#30,#10);
#4462= IFCELEMENTASSEMBLY('1Td1iR002jQJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#4461,$,'DK/70(?)',.NOTDEFINED.,.RIGID_FRAME.);
#4463= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(577.51554556393),$);
#4464= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' +10.590'),$);
#4465= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +15.700'),$);
#4466= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('DK/70(?)'),$);
#4467= IFCPROPERTYSET('2Uh0HwdVjF$Ay1FQvWEHVt',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#4463,#4464,#4465,#3925,#3926,#4466));
#4468= IFCQUANTITYLENGTH('Width',$,$,180.001812626389);
#4469= IFCELEMENTQUANTITY('2$PGnx1JTDO9rY0w9$Js7N',#5,'BaseQuantities',$,$,(#4468));
#4470= IFCCARTESIANPOINT((48743.128037899,-684.134420797411,13148.5));
#4471= IFCDIRECTION((0.999999999990534,4.35099999961692E-006,0.));
#4472= IFCAXIS2PLACEMENT3D(#4470,#9,#4471);
#4473= IFCLOCALPLACEMENT(#4461,#4472);
#4474= IFCCOLOURRGB('Light Green',0.301960784313725,0.898039215686275,0.301960784313725);
#4475= IFCSURFACESTYLERENDERING(#4474,0.,$,$,$,$,IFCNORMALISEDRATIOMEASURE(0.00390625),IFCSPECULAREXPONENT(10.),.NOTDEFINED.);
#4476= IFCSURFACESTYLE('STEEL/S235JR',.POSITIVE.,(#4475));
#4477= IFCPRESENTATIONSTYLEASSIGNMENT((#4476));
#4478= IFCCARTESIANPOINT((-5.0931703299284E-011,-5.00000000000011,-2547.5));
#4479= IFCCARTESIANPOINT((-5.0931703299284E-011,-5.00000000000011,2547.5));
#4480= IFCCARTESIANPOINT((5.82076609134674E-011,5.,2547.5));
#4481= IFCCARTESIANPOINT((5.82076609134674E-011,5.,-2547.5));
#4482= IFCPOLYLOOP((#4478,#4479,#4480,#4481));
#4483= IFCFACEOUTERBOUND(#4482,.T.);
#4484= IFCFACE((#4483));
#4485= IFCCARTESIANPOINT((85.7242817835358,4.99999999911404,2547.5));
#4486= IFCCARTESIANPOINT((85.7242817835358,4.99999999911404,-2547.5));
#4487= IFCPOLYLOOP((#4481,#4480,#4485,#4486));
#4488= IFCFACEOUTERBOUND(#4487,.T.);
#4489= IFCFACE((#4488));
#4490= IFCCARTESIANPOINT((95.7242813128396,-5.00000000098953,-2547.5));
#4491= IFCCARTESIANPOINT((95.7242813128396,-5.00000000098953,2547.5));
#4492= IFCPOLYLOOP((#4479,#4478,#4490,#4491));
#4493= IFCFACEOUTERBOUND(#4492,.T.);
#4494= IFCFACE((#4493));
#4495= IFCCARTESIANPOINT((85.7242858185273,90.7235372216751,2547.5));
#4496= IFCCARTESIANPOINT((85.7242858185273,90.7235372216751,-2547.5));
#4497= IFCPOLYLOOP((#4486,#4485,#4495,#4496));
#4498= IFCFACEOUTERBOUND(#4497,.T.);
#4499= IFCFACE((#4498));
#4500= IFCCARTESIANPOINT((95.7242858185273,90.7235367509771,2547.5));
#4501= IFCPOLYLOOP((#4485,#4480,#4479,#4491,#4500,#4495));
#4502= IFCFACEOUTERBOUND(#4501,.T.);
#4503= IFCFACE((#4502));
#4504= IFCCARTESIANPOINT((95.7242858185273,90.7235367509771,-2547.5));
#4505= IFCPOLYLOOP((#4491,#4490,#4504,#4500));
#4506= IFCFACEOUTERBOUND(#4505,.T.);
#4507= IFCFACE((#4506));
#4508= IFCPOLYLOOP((#4490,#4478,#4481,#4486,#4496,#4504));
#4509= IFCFACEOUTERBOUND(#4508,.T.);
#4510= IFCFACE((#4509));
#4511= IFCPOLYLOOP((#4500,#4504,#4496,#4495));
#4512= IFCFACEOUTERBOUND(#4511,.T.);
#4513= IFCFACE((#4512));
#4514= IFCCLOSEDSHELL((#4484,#4489,#4494,#4499,#4503,#4507,#4510,#4513));
#4515= IFCFACETEDBREP(#4514);
#4516= IFCSTYLEDITEM(#4515,(#4477),$);
#4517= IFCSHAPEREPRESENTATION(#12,'Body','Brep',(#4515));
#4518= IFCPRODUCTDEFINITIONSHAPE($,$,(#4517));
#4519= IFCDISCRETEACCESSORY('1Td1iR002LVJ4rDp0rCJ4s',#5,'KIRIS','PL5095*10','PL5095*10',#4473,#4518,'P/0(?)');
#4520= IFCDISCRETEACCESSORYTYPE('0S83vUpXj1CxcfCWgkt6JX',#5,'KIRIS',$,$,$,$,$,$);
#4521= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +10.601'),$);
#4522= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +15.696'),$);
#4523= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('DK/70(?)'),$);
#4524= IFCPROPERTYSINGLEVALUE('Class',$,IFCLABEL('17'),$);
#4525= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PL5095*10'),$);
#4526= IFCPROPERTYSET('0I2v4iLfvAIuANqQIhW0a9',#5,'Tekla Common','Common Properties to Shared building elements',(#4521,#4522,#1009,#4523,#74,#75,#76,#4524,#78,#4525,#4185));
#4527= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(577.51554556393),$);
#4528= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(72.5714158820549),$);
#4529= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(72.5714159460625),$);
#4530= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(72.5714158820549),$);
#4531= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.0092447663544019),$);
#4532= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.00924476635439041),$);
#4533= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.0092447663544019),$);
#4534= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00181447818535387),$);
#4535= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(26.9318464231912),$);
#4536= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(1.95448222724904),$);
#4537= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(1.95448222724691),$);
#4538= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(5095.00000003957),$);
#4539= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(10.0000001593922),$);
#4540= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(181.447818694483),$);
#4541= IFCPROPERTYSET('3eIIudi010VuvuCgn43oRA',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#4527,#4528,#4529,#4530,#4531,#4532,#4533,#4534,#4535,#4536,#4537,#4538,#4539,#4540));
#4542= IFCQUANTITYLENGTH('Length',$,$,181.447818694483);
#4543= IFCQUANTITYAREA('OuterSurfaceArea',$,$,1.95448222724904);
#4544= IFCQUANTITYVOLUME('NetVolume',$,$,0.0092447663544019);
#4545= IFCQUANTITYWEIGHT('NetWeight',$,$,72.5714158820549);
#4546= IFCELEMENTQUANTITY('0TxuAXnQj5XBtUliR2FiJY',#5,'BaseQuantities',$,$,(#4542,#4543,#4544,#4545));
#4547= IFCLOCALPLACEMENT(#30,#10);
#4548= IFCELEMENTASSEMBLY('1Td1iR001iCZ4rDp0rCJ4s',#5,'GROUT',$,$,#4547,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#4549= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -7.750'),$);
#4550= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -7.700'),$);
#4551= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit name',$,IFCLABEL('GROUT'),$);
#4552= IFCPROPERTYSET('1erNakt4L0FBlOAY_3P4nr',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#4549,#4550,#4551,#488,#1701));
#4553= IFCQUANTITYLENGTH('Width',$,$,50.0000000016662);
#4554= IFCELEMENTQUANTITY('0FVYvw2gv4nRaAlxjHcZ3_',#5,'BaseQuantities',$,$,(#4553));
#4555= IFCCARTESIANPOINT((44444.9924353684,-424.171262843957,-7724.99935244927));
#4556= IFCDIRECTION((9.80399999978721E-006,0.,-0.999999999951941));
#4557= IFCAXIS2PLACEMENT3D(#4555,#4556,#501);
#4558= IFCLOCALPLACEMENT(#4547,#4557);
#4559= IFCSURFACESTYLE('Undefined/GROUT',.POSITIVE.,(#4075));
#4560= IFCPRESENTATIONSTYLEASSIGNMENT((#4559));
#4561= IFCCARTESIANPOINT((314.998016357361,1.74622982740402E-010));
#4562= IFCCARTESIANPOINT((314.998016357361,509.999999991393));
#4563= IFCCARTESIANPOINT((-3.20028448186349E-011,509.999999991393));
#4564= IFCPOLYLINE((#54,#4561,#4562,#4563,#54,#54));
#4565= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL50*315',#4564);
#4566= IFCCARTESIANPOINT((5.6843418860808E-014,0.,-25.));
#4567= IFCAXIS2PLACEMENT3D(#4566,#9,#7);
#4568= IFCEXTRUDEDAREASOLID(#4565,#4567,#9,50.);
#4569= IFCCARTESIANPOINT((70.7079467774965,9.09494701772928E-011));
#4570= IFCCARTESIANPOINT((35.3511428834026,35.3539733887774));
#4571= IFCPOLYLINE((#54,#4569,#4570,#54,#54));
#4572= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL550*50',#4571);
#4573= IFCDIRECTION((0.,0.70712813388928,-0.707085427839002));
#4574= IFCCARTESIANPOINT((389.998999999969,-6.77986972732469E-005,25.0006100413912));
#4575= IFCAXIS2PLACEMENT3D(#4574,#185,#4573);
#4576= IFCEXTRUDEDAREASOLID(#4572,#4575,#9,550.);
#4577= IFCBOOLEANRESULT(.DIFFERENCE.,#4568,#4576);
#4578= IFCCARTESIANPOINT((70.7064437866011,-4.09272615797818E-011));
#4579= IFCCARTESIANPOINT((35.353919982871,35.3567581175921));
#4580= IFCPOLYLINE((#54,#4578,#4579,#54,#54));
#4581= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL600*50',#4580);
#4582= IFCDIRECTION((-0.707135182116166,-6.93219642870438E-006,-0.707078379082179));
#4583= IFCDIRECTION((0.,-0.999999999951941,9.80399999978721E-006));
#4584= IFCCARTESIANPOINT((314.998016357365,578.999999972144,24.9943234843972));
#4585= IFCAXIS2PLACEMENT3D(#4584,#4583,#4582);
#4586= IFCEXTRUDEDAREASOLID(#4581,#4585,#9,600.);
#4587= IFCBOOLEANRESULT(.DIFFERENCE.,#4577,#4586);
#4588= IFCCARTESIANPOINT((70.7063293458114,1.17324816528708E-010));
#4589= IFCCARTESIANPOINT((35.3539772034392,35.3566970825223));
#4590= IFCPOLYLINE((#54,#4588,#4589,#54,#54));
#4591= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL600*50',#4590);
#4592= IFCDIRECTION((0.707133987663117,-6.93220814004304E-006,-0.707079573629166));
#4593= IFCDIRECTION((0.,0.999999999951941,-9.80399999978721E-006));
#4594= IFCCARTESIANPOINT((-6.10498318565078E-011,-66.9999999968163,25.0006568680215));
#4595= IFCAXIS2PLACEMENT3D(#4594,#4593,#4592);
#4596= IFCEXTRUDEDAREASOLID(#4591,#4595,#9,600.);
#4597= IFCBOOLEANRESULT(.DIFFERENCE.,#4587,#4596);
#4598= IFCDIRECTION((0.,-0.707141998284405,-0.707071562334633));
#4599= IFCCARTESIANPOINT((-160.001000000031,510.000067784567,24.9956100000618));
#4600= IFCAXIS2PLACEMENT3D(#4599,#7,#4598);
#4601= IFCEXTRUDEDAREASOLID(#4572,#4600,#9,550.);
#4602= IFCBOOLEANRESULT(.DIFFERENCE.,#4597,#4601);
#4603= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#4602));
#4604= IFCSTYLEDITEM(#4568,(#4560),$);
#4605= IFCPRODUCTDEFINITIONSHAPE($,$,(#4603));
#4606= IFCPLATE('1Td1iR001iCJ4rDp0rCJ4s',#5,'GROUT','PL50*315','PL50*315',#4558,#4605,'XX/0(?)');
#4607= IFCPLATETYPE('1jUxh9i3P6mwLFGQFqje1y',#5,'PL50*315',$,$,$,$,$,$,.NOTDEFINED.);
#4608= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -7.750'),$);
#4609= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -7.700'),$);
#4610= IFCPROPERTYSINGLEVALUE('Class',$,IFCLABEL('92'),$);
#4611= IFCPROPERTYSINGLEVALUE('Grade',$,IFCLABEL('GROUT'),$);
#4612= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PL50*315'),$);
#4613= IFCPROPERTYSINGLEVALUE('Name',$,IFCLABEL('GROUT'),$);
#4614= IFCPROPERTYSET('2ZjL4QVHz7VP9KM58CCJ$2',#5,'Tekla Common','Common Properties to Shared building elements',(#4608,#4609,#1730,#1731,#74,#75,#919,#4610,#4611,#4612,#4613));
#4615= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.00613664384519501),$);
#4616= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.00803244941708981),$);
#4617= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.00613664384519501),$);
#4618= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.0881500626744591),$);
#4619= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.351328721197619),$);
#4620= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.160649009700202),$);
#4621= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(314.998016357483),$);
#4622= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(50.0000000023538),$);
#4623= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(510.000067803237),$);
#4624= IFCPROPERTYSET('3C1IVJ0Ff6Sx6D0yYpWwr4',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#4615,#4616,#4617,#4618,#1744,#4619,#4620,#4621,#4622,#4623));
#4625= IFCQUANTITYLENGTH('Width',$,$,314.998016357483);
#4626= IFCQUANTITYAREA('NetArea',$,$,0.351328721197619);
#4627= IFCQUANTITYAREA('GrossArea',$,$,0.160649009700202);
#4628= IFCQUANTITYAREA('CrossSectionArea',$,$,0.0025);
#4629= IFCQUANTITYVOLUME('NetVolume',$,$,0.00613664384519501);
#4630= IFCQUANTITYVOLUME('GrossVolume',$,$,0.00803244941708981);
#4631= IFCELEMENTQUANTITY('3zj1PuFOf8lRj12gNOWibu',#5,'BaseQuantities',$,$,(#4625,#4626,#4627,#4628,#4629,#4630));
#4632= IFCMATERIAL('Undefined/GROUT');
#4633= IFCCARTESIANPOINT((40634.9983581212,-554.153090053149,-1060.005));
#4634= IFCAXIS2PLACEMENT3D(#4633,#501,#185);
#4635= IFCLOCALPLACEMENT(#30,#4634);
#4636= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,16.5);
#4637= IFCCARTESIANPOINT((0.,49.8950000000226,0.));
#4638= IFCAXIS2PLACEMENT3D(#4637,#8,#7);
#4639= IFCEXTRUDEDAREASOLID(#4636,#4638,#9,16.1);
#4640= IFCSTYLEDITEM(#4639,(#195),$);
#4641= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,16.5);
#4642= IFCCARTESIANPOINT((0.,33.9950000000008,0.));
#4643= IFCAXIS2PLACEMENT3D(#4642,#8,#7);
#4644= IFCEXTRUDEDAREASOLID(#4641,#4643,#9,15.9999999999999);
#4645= IFCSTYLEDITEM(#4644,(#195),$);
#4646= IFCCARTESIANPOINT((-25.,16.5));
#4647= IFCCARTESIANPOINT((25.,16.5));
#4648= IFCPOLYLINE((#4646,#4647));
#4649= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#4648);
#4650= IFCCIRCLE(#4349,16.5);
#4651= IFCTRIMMEDCURVE(#4650,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(3.14159265358979)),.F.,.PARAMETER.);
#4652= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#4651);
#4653= IFCCARTESIANPOINT((25.,-16.5));
#4654= IFCCARTESIANPOINT((-25.,-16.5));
#4655= IFCPOLYLINE((#4653,#4654));
#4656= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#4655);
#4657= IFCCIRCLE(#4359,16.5);
#4658= IFCTRIMMEDCURVE(#4657,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(3.14159265358979)),.F.,.PARAMETER.);
#4659= IFCCOMPOSITECURVESEGMENT(.DISCONTINUOUS.,.T.,#4658);
#4660= IFCCOMPOSITECURVE((#4649,#4652,#4656,#4659),.F.);
#4661= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4660);
#4662= IFCCARTESIANPOINT((0.,18.094999999999,0.));
#4663= IFCAXIS2PLACEMENT3D(#4662,#8,#7);
#4664= IFCEXTRUDEDAREASOLID(#4661,#4663,#9,16.);
#4665= IFCSTYLEDITEM(#4664,(#195),$);
#4666= IFCCARTESIANPOINT((25.98076211355,0.));
#4667= IFCCARTESIANPOINT((12.990381056775,22.5000000000032));
#4668= IFCCARTESIANPOINT((-12.990381056775,22.5000000000032));
#4669= IFCCARTESIANPOINT((-25.98076211355,0.));
#4670= IFCCARTESIANPOINT((-12.990381056775,-22.5000000000032));
#4671= IFCCARTESIANPOINT((12.990381056775,-22.5000000000032));
#4672= IFCPOLYLINE((#4666,#4667,#4668,#4669,#4670,#4671,#4666));
#4673= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4672);
#4674= IFCCARTESIANPOINT((0.,-1.80500000000101,0.));
#4675= IFCAXIS2PLACEMENT3D(#4674,#8,#7);
#4676= IFCEXTRUDEDAREASOLID(#4673,#4675,#9,19.8);
#4677= IFCSTYLEDITEM(#4676,(#558),$);
#4678= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,15.);
#4679= IFCCARTESIANPOINT((0.,17.994999999999,0.));
#4680= IFCAXIS2PLACEMENT3D(#4679,#8,#7);
#4681= IFCEXTRUDEDAREASOLID(#4678,#4680,#9,90.);
#4682= IFCSTYLEDITEM(#4681,(#558),$);
#4683= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,28.);
#4684= IFCCARTESIANPOINT((0.,65.9950000000226,0.));
#4685= IFCAXIS2PLACEMENT3D(#4684,#8,#7);
#4686= IFCEXTRUDEDAREASOLID(#4683,#4685,#9,8.);
#4687= IFCSTYLEDITEM(#4686,(#558),$);
#4688= IFCCARTESIANPOINT((26.55811238274,0.));
#4689= IFCCARTESIANPOINT((13.27905619137,23.0000000000033));
#4690= IFCCARTESIANPOINT((-13.27905619137,23.0000000000033));
#4691= IFCCARTESIANPOINT((-26.55811238274,0.));
#4692= IFCCARTESIANPOINT((-13.27905619137,-23.0000000000033));
#4693= IFCCARTESIANPOINT((13.27905619137,-23.0000000000033));
#4694= IFCPOLYLINE((#4688,#4689,#4690,#4691,#4692,#4693,#4688));
#4695= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4694);
#4696= IFCCARTESIANPOINT((0.,73.9950000000226,0.));
#4697= IFCAXIS2PLACEMENT3D(#4696,#8,#7);
#4698= IFCEXTRUDEDAREASOLID(#4695,#4697,#9,24.);
#4699= IFCSTYLEDITEM(#4698,(#558),$);
#4700= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#4639,#4644,#4664,#4676,#4681,#4686,#4698));
#4701= IFCREPRESENTATIONMAP(#10,#4700);
#4702= IFCMAPPEDITEM(#4701,#247);
#4703= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#4702));
#4704= IFCPRODUCTDEFINITIONSHAPE($,$,(#4703));
#4705= IFCMECHANICALFASTENER('1Td1iR001i3p4rDp0rCJ4s',#5,'Bolt assembly',$,$,#4635,#4704,'ID5d9c1b1b-0000-6c0f-3135-373035313136',30.,90.);
#4706= IFCPROPERTYSINGLEVALUE('Slotted hole y',$,IFCLENGTHMEASURE(50.),$);
#4707= IFCPROPERTYSINGLEVALUE('Bolt hole diameter',$,IFCLENGTHMEASURE(33.),$);
#4708= IFCPROPERTYSINGLEVALUE('Bolt size',$,IFCLENGTHMEASURE(30.),$);
#4709= IFCPROPERTYSINGLEVALUE('Bolt length',$,IFCLENGTHMEASURE(90.),$);
#4710= IFCPROPERTYSINGLEVALUE('Bolt Name',$,IFCLABEL('BOLT30*90'),$);
#4711= IFCPROPERTYSET('27QB8qnVj8v9UpNbMp1HS2',#5,'Tekla Bolt','Bolt Properties',(#255,#570,#571,#572,#259,#573,#574,#4706,#263,#4707,#265,#266,#4708,#4709,#579,#4710));
#4712= IFCCARTESIANPOINT((40634.9983581212,-554.153090053148,15839.995));
#4713= IFCAXIS2PLACEMENT3D(#4712,#501,#185);
#4714= IFCLOCALPLACEMENT(#30,#4713);
#4715= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,16.5);
#4716= IFCEXTRUDEDAREASOLID(#4715,#4638,#9,16.1);
#4717= IFCSTYLEDITEM(#4716,(#195),$);
#4718= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,16.5);
#4719= IFCEXTRUDEDAREASOLID(#4718,#4643,#9,15.9999999999991);
#4720= IFCSTYLEDITEM(#4719,(#195),$);
#4721= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4660);
#4722= IFCEXTRUDEDAREASOLID(#4721,#4663,#9,16.);
#4723= IFCSTYLEDITEM(#4722,(#195),$);
#4724= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4672);
#4725= IFCEXTRUDEDAREASOLID(#4724,#4675,#9,19.8);
#4726= IFCSTYLEDITEM(#4725,(#558),$);
#4727= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,15.);
#4728= IFCEXTRUDEDAREASOLID(#4727,#4680,#9,90.);
#4729= IFCSTYLEDITEM(#4728,(#558),$);
#4730= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,28.);
#4731= IFCEXTRUDEDAREASOLID(#4730,#4685,#9,8.);
#4732= IFCSTYLEDITEM(#4731,(#558),$);
#4733= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4694);
#4734= IFCEXTRUDEDAREASOLID(#4733,#4697,#9,24.);
#4735= IFCSTYLEDITEM(#4734,(#558),$);
#4736= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#4716,#4719,#4722,#4725,#4728,#4731,#4734));
#4737= IFCREPRESENTATIONMAP(#10,#4736);
#4738= IFCMAPPEDITEM(#4737,#247);
#4739= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#4738));
#4740= IFCPRODUCTDEFINITIONSHAPE($,$,(#4739));
#4741= IFCMECHANICALFASTENER('1Td1iR001hIZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#4714,#4740,'ID5d9c1b1b-0000-6b4a-3135-373035313136',30.,90.);
#4742= IFCCARTESIANPOINT((46579.9926804692,-579.170000075344,15795.0000000002));
#4743= IFCAXIS2PLACEMENT3D(#4742,#8,#7);
#4744= IFCLOCALPLACEMENT(#30,#4743);
#4745= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#4746= IFCCARTESIANPOINT((0.,-10.8958909389268,0.));
#4747= IFCAXIS2PLACEMENT3D(#4746,#8,#7);
#4748= IFCEXTRUDEDAREASOLID(#4745,#4747,#9,16.0000000000195);
#4749= IFCSTYLEDITEM(#4748,(#195),$);
#4750= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#4751= IFCCARTESIANPOINT((0.,4.90000000022374,0.));
#4752= IFCAXIS2PLACEMENT3D(#4751,#8,#7);
#4753= IFCEXTRUDEDAREASOLID(#4750,#4752,#9,16.1);
#4754= IFCSTYLEDITEM(#4753,(#195),$);
#4755= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#4756= IFCCARTESIANPOINT((0.,-17.4958909389268,0.));
#4757= IFCAXIS2PLACEMENT3D(#4756,#8,#7);
#4758= IFCEXTRUDEDAREASOLID(#4755,#4757,#9,6.5);
#4759= IFCSTYLEDITEM(#4758,(#191),$);
#4760= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#4761= IFCCARTESIANPOINT((0.,-10.9958909389268,0.));
#4762= IFCAXIS2PLACEMENT3D(#4761,#8,#7);
#4763= IFCEXTRUDEDAREASOLID(#4760,#4762,#9,50.);
#4764= IFCSTYLEDITEM(#4763,(#191),$);
#4765= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#4766= IFCCARTESIANPOINT((0.,21.0000000002237,0.));
#4767= IFCAXIS2PLACEMENT3D(#4766,#8,#7);
#4768= IFCEXTRUDEDAREASOLID(#4765,#4767,#9,2.5);
#4769= IFCSTYLEDITEM(#4768,(#191),$);
#4770= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#4771= IFCCARTESIANPOINT((0.,23.5000000002237,0.));
#4772= IFCAXIS2PLACEMENT3D(#4771,#8,#7);
#4773= IFCEXTRUDEDAREASOLID(#4770,#4772,#9,10.);
#4774= IFCSTYLEDITEM(#4773,(#191),$);
#4775= IFCCARTESIANPOINT((0.,0.,40.));
#4776= IFCCARTESIANTRANSFORMATIONOPERATOR3D($,$,#4775,$,$);
#4777= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#4748,#4753,#4758,#4763,#4768,#4773));
#4778= IFCREPRESENTATIONMAP(#10,#4777);
#4779= IFCMAPPEDITEM(#4778,#4776);
#4780= IFCCARTESIANPOINT((80.,0.,40.));
#4781= IFCCARTESIANTRANSFORMATIONOPERATOR3D($,$,#4780,$,$);
#4782= IFCMAPPEDITEM(#4778,#4781);
#4783= IFCCARTESIANPOINT((0.,0.,-40.));
#4784= IFCCARTESIANTRANSFORMATIONOPERATOR3D($,$,#4783,$,$);
#4785= IFCMAPPEDITEM(#4778,#4784);
#4786= IFCCARTESIANPOINT((80.,0.,-40.));
#4787= IFCCARTESIANTRANSFORMATIONOPERATOR3D($,$,#4786,$,$);
#4788= IFCMAPPEDITEM(#4778,#4787);
#4789= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#4779,#4782,#4785,#4788));
#4790= IFCPRODUCTDEFINITIONSHAPE($,$,(#4789));
#4791= IFCMECHANICALFASTENER('1Td1iR001hHp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#4744,#4790,'ID5d9c1b1b-0000-6b47-3135-373035313136',12.,50.);
#4792= IFCPROPERTYSINGLEVALUE('Washer name',$,IFCLABEL('SCHEIBE12-126'),$);
#4793= IFCPROPERTYSINGLEVALUE('Nut name',$,IFCLABEL('MUN12-934'),$);
#4794= IFCPROPERTYSINGLEVALUE('Bolt hole diameter',$,IFCLENGTHMEASURE(14.),$);
#4795= IFCPROPERTYSINGLEVALUE('Bolt length',$,IFCLENGTHMEASURE(50.),$);
#4796= IFCPROPERTYSINGLEVALUE('Bolt Name',$,IFCLABEL('M12*50'),$);
#4797= IFCPROPERTYSET('3XrI3vDq91tOIMIgHnbNEI',#5,'Tekla Bolt','Bolt Properties',(#255,#3912,#257,#4792,#259,#260,#4793,#262,#263,#4794,#265,#266,#3916,#4795,#269,#4796));
#4798= IFCCARTESIANPOINT((44959.9926804692,-579.170000075344,15795.0000000002));
#4799= IFCAXIS2PLACEMENT3D(#4798,#8,#7);
#4800= IFCLOCALPLACEMENT(#30,#4799);
#4801= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#4802= IFCEXTRUDEDAREASOLID(#4801,#4747,#9,16.0000000000195);
#4803= IFCSTYLEDITEM(#4802,(#195),$);
#4804= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#4805= IFCEXTRUDEDAREASOLID(#4804,#4752,#9,16.1);
#4806= IFCSTYLEDITEM(#4805,(#195),$);
#4807= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#4808= IFCEXTRUDEDAREASOLID(#4807,#4757,#9,6.5);
#4809= IFCSTYLEDITEM(#4808,(#191),$);
#4810= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#4811= IFCEXTRUDEDAREASOLID(#4810,#4762,#9,50.);
#4812= IFCSTYLEDITEM(#4811,(#191),$);
#4813= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#4814= IFCEXTRUDEDAREASOLID(#4813,#4767,#9,2.5);
#4815= IFCSTYLEDITEM(#4814,(#191),$);
#4816= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#4817= IFCEXTRUDEDAREASOLID(#4816,#4772,#9,10.);
#4818= IFCSTYLEDITEM(#4817,(#191),$);
#4819= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#4802,#4805,#4808,#4811,#4814,#4817));
#4820= IFCREPRESENTATIONMAP(#10,#4819);
#4821= IFCMAPPEDITEM(#4820,#4776);
#4822= IFCMAPPEDITEM(#4820,#4781);
#4823= IFCMAPPEDITEM(#4820,#4784);
#4824= IFCMAPPEDITEM(#4820,#4787);
#4825= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#4821,#4822,#4823,#4824));
#4826= IFCPRODUCTDEFINITIONSHAPE($,$,(#4825));
#4827= IFCMECHANICALFASTENER('1Td1iR001hH34rDp0rCJ4s',#5,'Bolt assembly',$,$,#4800,#4826,'ID5d9c1b1b-0000-6b44-3135-373035313136',12.,50.);
#4828= IFCCARTESIANPOINT((44149.9926804692,-579.170000075344,15795.0000000002));
#4829= IFCAXIS2PLACEMENT3D(#4828,#8,#7);
#4830= IFCLOCALPLACEMENT(#30,#4829);
#4831= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#4832= IFCEXTRUDEDAREASOLID(#4831,#4747,#9,16.0000000000195);
#4833= IFCSTYLEDITEM(#4832,(#195),$);
#4834= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#4835= IFCEXTRUDEDAREASOLID(#4834,#4752,#9,16.1);
#4836= IFCSTYLEDITEM(#4835,(#195),$);
#4837= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#4838= IFCEXTRUDEDAREASOLID(#4837,#4757,#9,6.5);
#4839= IFCSTYLEDITEM(#4838,(#191),$);
#4840= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#4841= IFCEXTRUDEDAREASOLID(#4840,#4762,#9,50.);
#4842= IFCSTYLEDITEM(#4841,(#191),$);
#4843= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#4844= IFCEXTRUDEDAREASOLID(#4843,#4767,#9,2.5);
#4845= IFCSTYLEDITEM(#4844,(#191),$);
#4846= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#4847= IFCEXTRUDEDAREASOLID(#4846,#4772,#9,10.);
#4848= IFCSTYLEDITEM(#4847,(#191),$);
#4849= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#4832,#4835,#4838,#4841,#4844,#4847));
#4850= IFCREPRESENTATIONMAP(#10,#4849);
#4851= IFCMAPPEDITEM(#4850,#4776);
#4852= IFCMAPPEDITEM(#4850,#4781);
#4853= IFCMAPPEDITEM(#4850,#4784);
#4854= IFCMAPPEDITEM(#4850,#4787);
#4855= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#4851,#4852,#4853,#4854));
#4856= IFCPRODUCTDEFINITIONSHAPE($,$,(#4855));
#4857= IFCMECHANICALFASTENER('1Td1iR001hGJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#4830,#4856,'ID5d9c1b1b-0000-6b41-3135-373035313136',12.,50.);
#4858= IFCCARTESIANPOINT((43339.9926804692,-579.170000075344,15795.0000000002));
#4859= IFCAXIS2PLACEMENT3D(#4858,#8,#7);
#4860= IFCLOCALPLACEMENT(#30,#4859);
#4861= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#4862= IFCEXTRUDEDAREASOLID(#4861,#4747,#9,16.0000000000195);
#4863= IFCSTYLEDITEM(#4862,(#195),$);
#4864= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#4865= IFCEXTRUDEDAREASOLID(#4864,#4752,#9,16.1);
#4866= IFCSTYLEDITEM(#4865,(#195),$);
#4867= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#4868= IFCEXTRUDEDAREASOLID(#4867,#4757,#9,6.5);
#4869= IFCSTYLEDITEM(#4868,(#191),$);
#4870= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#4871= IFCEXTRUDEDAREASOLID(#4870,#4762,#9,50.);
#4872= IFCSTYLEDITEM(#4871,(#191),$);
#4873= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#4874= IFCEXTRUDEDAREASOLID(#4873,#4767,#9,2.5);
#4875= IFCSTYLEDITEM(#4874,(#191),$);
#4876= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#4877= IFCEXTRUDEDAREASOLID(#4876,#4772,#9,10.);
#4878= IFCSTYLEDITEM(#4877,(#191),$);
#4879= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#4862,#4865,#4868,#4871,#4874,#4877));
#4880= IFCREPRESENTATIONMAP(#10,#4879);
#4881= IFCMAPPEDITEM(#4880,#4776);
#4882= IFCMAPPEDITEM(#4880,#4781);
#4883= IFCMAPPEDITEM(#4880,#4784);
#4884= IFCMAPPEDITEM(#4880,#4787);
#4885= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#4881,#4882,#4883,#4884));
#4886= IFCPRODUCTDEFINITIONSHAPE($,$,(#4885));
#4887= IFCMECHANICALFASTENER('1Td1iR001hFZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#4860,#4886,'ID5d9c1b1b-0000-6b3e-3135-373035313136',12.,50.);
#4888= IFCCARTESIANPOINT((40909.9926804692,-579.170000075344,15795.0000000002));
#4889= IFCAXIS2PLACEMENT3D(#4888,#8,#7);
#4890= IFCLOCALPLACEMENT(#30,#4889);
#4891= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#4892= IFCEXTRUDEDAREASOLID(#4891,#4752,#9,16.1);
#4893= IFCSTYLEDITEM(#4892,(#195),$);
#4894= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#4895= IFCEXTRUDEDAREASOLID(#4894,#4747,#9,16.0000000000195);
#4896= IFCSTYLEDITEM(#4895,(#195),$);
#4897= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#4898= IFCEXTRUDEDAREASOLID(#4897,#4757,#9,6.5);
#4899= IFCSTYLEDITEM(#4898,(#191),$);
#4900= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#4901= IFCEXTRUDEDAREASOLID(#4900,#4762,#9,50.);
#4902= IFCSTYLEDITEM(#4901,(#191),$);
#4903= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#4904= IFCEXTRUDEDAREASOLID(#4903,#4767,#9,2.5);
#4905= IFCSTYLEDITEM(#4904,(#191),$);
#4906= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#4907= IFCEXTRUDEDAREASOLID(#4906,#4772,#9,10.);
#4908= IFCSTYLEDITEM(#4907,(#191),$);
#4909= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#4892,#4895,#4898,#4901,#4904,#4907));
#4910= IFCREPRESENTATIONMAP(#10,#4909);
#4911= IFCMAPPEDITEM(#4910,#4776);
#4912= IFCMAPPEDITEM(#4910,#4781);
#4913= IFCMAPPEDITEM(#4910,#4784);
#4914= IFCMAPPEDITEM(#4910,#4787);
#4915= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#4911,#4912,#4913,#4914));
#4916= IFCPRODUCTDEFINITIONSHAPE($,$,(#4915));
#4917= IFCMECHANICALFASTENER('1Td1iR001hDZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#4890,#4916,'ID5d9c1b1b-0000-6b36-3135-373035313136',12.,50.);
#4918= IFCCARTESIANPOINT((48532.4993425044,-679.170002432391,15790.));
#4919= IFCAXIS2PLACEMENT3D(#4918,#7,#596);
#4920= IFCLOCALPLACEMENT(#885,#4919);
#4921= IFCCARTESIANPOINT((90.,5.11590769747272E-012));
#4922= IFCCARTESIANPOINT((90.,220.000000000005));
#4923= IFCCARTESIANPOINT((0.,220.000000000005));
#4924= IFCPOLYLINE((#54,#4921,#4922,#4923,#54,#54));
#4925= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL3*90',#4924);
#4926= IFCEXTRUDEDAREASOLID(#4925,#4427,#9,3.);
#4927= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#4926));
#4928= IFCSTYLEDITEM(#4926,(#53),$);
#4929= IFCPRODUCTDEFINITIONSHAPE($,$,(#4927));
#4930= IFCDISCRETEACCESSORY('1Td1iR001hBZ4rDp0rCJ4s',#5,'Cap plate','PL3*90','PL3*90',#4920,#4929,'0(?)');
#4931= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +15.700'),$);
#4932= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PL3*90'),$);
#4933= IFCPROPERTYSET('0vpTXasm1EWPUeRNFprudM',#5,'Tekla Common','Common Properties to Shared building elements',(#4931,#1052,#4436,#918,#74,#75,#919,#77,#78,#4932,#4438));
#4934= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.46629),$);
#4935= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(0.466290000000022),$);
#4936= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.46629),$);
#4937= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(5.94E-005),$);
#4938= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(5.94E-005),$);
#4939= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(5.94E-005),$);
#4940= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00066),$);
#4941= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(88.9146239464711),$);
#4942= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.04146),$);
#4943= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0198000000000009),$);
#4944= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(90.),$);
#4945= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(3.00000000150612),$);
#4946= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(220.00000000001),$);
#4947= IFCPROPERTYSET('0Evmt$qAf2nx$XwPlr3j1t',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#923,#4934,#4935,#4936,#4937,#4938,#4939,#4940,#4941,#4942,#4943,#4944,#4945,#4946));
#4948= IFCQUANTITYAREA('NetArea',$,$,0.04146);
#4949= IFCQUANTITYAREA('GrossArea',$,$,0.0198000000000009);
#4950= IFCQUANTITYVOLUME('NetVolume',$,$,5.94E-005);
#4951= IFCQUANTITYVOLUME('GrossVolume',$,$,5.94E-005);
#4952= IFCELEMENTQUANTITY('2GE3NIcC13CgkTuPHC8XYi',#5,'BaseQuantities',$,$,(#893,#4948,#4949,#4457,#4950,#4951));
#4953= IFCCARTESIANPOINT((40365.0019996906,-554.153073853048,15839.995));
#4954= IFCAXIS2PLACEMENT3D(#4953,#8,#7);
#4955= IFCLOCALPLACEMENT(#30,#4954);
#4956= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,16.5);
#4957= IFCEXTRUDEDAREASOLID(#4956,#4663,#9,16.0000000000004);
#4958= IFCSTYLEDITEM(#4957,(#195),$);
#4959= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,16.5);
#4960= IFCEXTRUDEDAREASOLID(#4959,#4643,#9,15.9999999999976);
#4961= IFCSTYLEDITEM(#4960,(#195),$);
#4962= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,16.5);
#4963= IFCEXTRUDEDAREASOLID(#4962,#4638,#9,16.1);
#4964= IFCSTYLEDITEM(#4963,(#195),$);
#4965= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4672);
#4966= IFCEXTRUDEDAREASOLID(#4965,#4675,#9,19.8);
#4967= IFCSTYLEDITEM(#4966,(#558),$);
#4968= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,15.);
#4969= IFCEXTRUDEDAREASOLID(#4968,#4680,#9,90.);
#4970= IFCSTYLEDITEM(#4969,(#558),$);
#4971= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,28.);
#4972= IFCEXTRUDEDAREASOLID(#4971,#4685,#9,8.);
#4973= IFCSTYLEDITEM(#4972,(#558),$);
#4974= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4694);
#4975= IFCEXTRUDEDAREASOLID(#4974,#4697,#9,24.);
#4976= IFCSTYLEDITEM(#4975,(#558),$);
#4977= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#4957,#4960,#4963,#4966,#4969,#4972,#4975));
#4978= IFCREPRESENTATIONMAP(#10,#4977);
#4979= IFCMAPPEDITEM(#4978,#247);
#4980= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#4979));
#4981= IFCPRODUCTDEFINITIONSHAPE($,$,(#4980));
#4982= IFCMECHANICALFASTENER('1Td1iR001gNp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#4955,#4981,'ID5d9c1b1b-0000-6a5f-3135-373035313136',30.,90.);
#4983= IFCPROPERTYSET('3h5yjvZVTCy9LcuLh_UNvW',#5,'Tekla Bolt','Bolt Properties',(#255,#570,#571,#572,#259,#573,#574,#262,#263,#4707,#265,#266,#4708,#4709,#579,#4710));
#4984= IFCCARTESIANPOINT((32534.9983581212,-554.153090053148,15839.995));
#4985= IFCAXIS2PLACEMENT3D(#4984,#501,#185);
#4986= IFCLOCALPLACEMENT(#30,#4985);
#4987= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,16.5);
#4988= IFCEXTRUDEDAREASOLID(#4987,#4638,#9,16.1);
#4989= IFCSTYLEDITEM(#4988,(#195),$);
#4990= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,16.5);
#4991= IFCEXTRUDEDAREASOLID(#4990,#4643,#9,16.0000000000013);
#4992= IFCSTYLEDITEM(#4991,(#195),$);
#4993= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4660);
#4994= IFCEXTRUDEDAREASOLID(#4993,#4663,#9,15.9999999999999);
#4995= IFCSTYLEDITEM(#4994,(#195),$);
#4996= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4672);
#4997= IFCEXTRUDEDAREASOLID(#4996,#4675,#9,19.8);
#4998= IFCSTYLEDITEM(#4997,(#558),$);
#4999= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,15.);
#5000= IFCEXTRUDEDAREASOLID(#4999,#4680,#9,90.);
#5001= IFCSTYLEDITEM(#5000,(#558),$);
#5002= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,28.);
#5003= IFCEXTRUDEDAREASOLID(#5002,#4685,#9,8.);
#5004= IFCSTYLEDITEM(#5003,(#558),$);
#5005= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4694);
#5006= IFCEXTRUDEDAREASOLID(#5005,#4697,#9,24.);
#5007= IFCSTYLEDITEM(#5006,(#558),$);
#5008= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#4988,#4991,#4994,#4997,#5000,#5003,#5006));
#5009= IFCREPRESENTATIONMAP(#10,#5008);
#5010= IFCMAPPEDITEM(#5009,#247);
#5011= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#5010));
#5012= IFCPRODUCTDEFINITIONSHAPE($,$,(#5011));
#5013= IFCMECHANICALFASTENER('1Td1iR001gN34rDp0rCJ4s',#5,'Bolt assembly',$,$,#4986,#5012,'ID5d9c1b1b-0000-6a5c-3135-373035313136',30.,90.);
#5014= IFCCARTESIANPOINT((32809.9926804692,-579.170000075344,15795.0000000002));
#5015= IFCAXIS2PLACEMENT3D(#5014,#8,#7);
#5016= IFCLOCALPLACEMENT(#30,#5015);
#5017= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#5018= IFCEXTRUDEDAREASOLID(#5017,#4747,#9,16.0000000000195);
#5019= IFCSTYLEDITEM(#5018,(#195),$);
#5020= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#5021= IFCEXTRUDEDAREASOLID(#5020,#4752,#9,16.1);
#5022= IFCSTYLEDITEM(#5021,(#195),$);
#5023= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#5024= IFCEXTRUDEDAREASOLID(#5023,#4757,#9,6.5);
#5025= IFCSTYLEDITEM(#5024,(#191),$);
#5026= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#5027= IFCEXTRUDEDAREASOLID(#5026,#4762,#9,50.);
#5028= IFCSTYLEDITEM(#5027,(#191),$);
#5029= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#5030= IFCEXTRUDEDAREASOLID(#5029,#4767,#9,2.5);
#5031= IFCSTYLEDITEM(#5030,(#191),$);
#5032= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#5033= IFCEXTRUDEDAREASOLID(#5032,#4772,#9,10.);
#5034= IFCSTYLEDITEM(#5033,(#191),$);
#5035= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5018,#5021,#5024,#5027,#5030,#5033));
#5036= IFCREPRESENTATIONMAP(#10,#5035);
#5037= IFCMAPPEDITEM(#5036,#4776);
#5038= IFCMAPPEDITEM(#5036,#4781);
#5039= IFCMAPPEDITEM(#5036,#4784);
#5040= IFCMAPPEDITEM(#5036,#4787);
#5041= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#5037,#5038,#5039,#5040));
#5042= IFCPRODUCTDEFINITIONSHAPE($,$,(#5041));
#5043= IFCMECHANICALFASTENER('1Td1iR001gMJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#5016,#5042,'ID5d9c1b1b-0000-6a59-3135-373035313136',12.,50.);
#5044= IFCCARTESIANPOINT((35239.9926804692,-579.170000075344,15795.0000000002));
#5045= IFCAXIS2PLACEMENT3D(#5044,#8,#7);
#5046= IFCLOCALPLACEMENT(#30,#5045);
#5047= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#5048= IFCEXTRUDEDAREASOLID(#5047,#4747,#9,16.0000000000195);
#5049= IFCSTYLEDITEM(#5048,(#195),$);
#5050= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#5051= IFCEXTRUDEDAREASOLID(#5050,#4752,#9,16.1);
#5052= IFCSTYLEDITEM(#5051,(#195),$);
#5053= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#5054= IFCEXTRUDEDAREASOLID(#5053,#4757,#9,6.5);
#5055= IFCSTYLEDITEM(#5054,(#191),$);
#5056= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#5057= IFCEXTRUDEDAREASOLID(#5056,#4762,#9,50.);
#5058= IFCSTYLEDITEM(#5057,(#191),$);
#5059= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#5060= IFCEXTRUDEDAREASOLID(#5059,#4767,#9,2.5);
#5061= IFCSTYLEDITEM(#5060,(#191),$);
#5062= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#5063= IFCEXTRUDEDAREASOLID(#5062,#4772,#9,10.);
#5064= IFCSTYLEDITEM(#5063,(#191),$);
#5065= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5048,#5051,#5054,#5057,#5060,#5063));
#5066= IFCREPRESENTATIONMAP(#10,#5065);
#5067= IFCMAPPEDITEM(#5066,#4776);
#5068= IFCMAPPEDITEM(#5066,#4781);
#5069= IFCMAPPEDITEM(#5066,#4784);
#5070= IFCMAPPEDITEM(#5066,#4787);
#5071= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#5067,#5068,#5069,#5070));
#5072= IFCPRODUCTDEFINITIONSHAPE($,$,(#5071));
#5073= IFCMECHANICALFASTENER('1Td1iR001gLZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#5046,#5072,'ID5d9c1b1b-0000-6a56-3135-373035313136',12.,50.);
#5074= IFCCARTESIANPOINT((36049.9926804692,-579.170000075344,15795.0000000002));
#5075= IFCAXIS2PLACEMENT3D(#5074,#8,#7);
#5076= IFCLOCALPLACEMENT(#30,#5075);
#5077= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#5078= IFCEXTRUDEDAREASOLID(#5077,#4747,#9,16.0000000000195);
#5079= IFCSTYLEDITEM(#5078,(#195),$);
#5080= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#5081= IFCEXTRUDEDAREASOLID(#5080,#4752,#9,16.1);
#5082= IFCSTYLEDITEM(#5081,(#195),$);
#5083= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#5084= IFCEXTRUDEDAREASOLID(#5083,#4757,#9,6.5);
#5085= IFCSTYLEDITEM(#5084,(#191),$);
#5086= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#5087= IFCEXTRUDEDAREASOLID(#5086,#4762,#9,50.);
#5088= IFCSTYLEDITEM(#5087,(#191),$);
#5089= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#5090= IFCEXTRUDEDAREASOLID(#5089,#4767,#9,2.5);
#5091= IFCSTYLEDITEM(#5090,(#191),$);
#5092= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#5093= IFCEXTRUDEDAREASOLID(#5092,#4772,#9,10.);
#5094= IFCSTYLEDITEM(#5093,(#191),$);
#5095= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5078,#5081,#5084,#5087,#5090,#5093));
#5096= IFCREPRESENTATIONMAP(#10,#5095);
#5097= IFCMAPPEDITEM(#5096,#4776);
#5098= IFCMAPPEDITEM(#5096,#4781);
#5099= IFCMAPPEDITEM(#5096,#4784);
#5100= IFCMAPPEDITEM(#5096,#4787);
#5101= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#5097,#5098,#5099,#5100));
#5102= IFCPRODUCTDEFINITIONSHAPE($,$,(#5101));
#5103= IFCMECHANICALFASTENER('1Td1iR001gKp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#5076,#5102,'ID5d9c1b1b-0000-6a53-3135-373035313136',12.,50.);
#5104= IFCCARTESIANPOINT((36859.9926804692,-579.170000075344,15795.0000000002));
#5105= IFCAXIS2PLACEMENT3D(#5104,#8,#7);
#5106= IFCLOCALPLACEMENT(#30,#5105);
#5107= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#5108= IFCEXTRUDEDAREASOLID(#5107,#4747,#9,16.0000000000195);
#5109= IFCSTYLEDITEM(#5108,(#195),$);
#5110= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#5111= IFCEXTRUDEDAREASOLID(#5110,#4752,#9,16.1);
#5112= IFCSTYLEDITEM(#5111,(#195),$);
#5113= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#5114= IFCEXTRUDEDAREASOLID(#5113,#4757,#9,6.5);
#5115= IFCSTYLEDITEM(#5114,(#191),$);
#5116= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#5117= IFCEXTRUDEDAREASOLID(#5116,#4762,#9,50.);
#5118= IFCSTYLEDITEM(#5117,(#191),$);
#5119= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#5120= IFCEXTRUDEDAREASOLID(#5119,#4767,#9,2.5);
#5121= IFCSTYLEDITEM(#5120,(#191),$);
#5122= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#5123= IFCEXTRUDEDAREASOLID(#5122,#4772,#9,10.);
#5124= IFCSTYLEDITEM(#5123,(#191),$);
#5125= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5108,#5111,#5114,#5117,#5120,#5123));
#5126= IFCREPRESENTATIONMAP(#10,#5125);
#5127= IFCMAPPEDITEM(#5126,#4776);
#5128= IFCMAPPEDITEM(#5126,#4781);
#5129= IFCMAPPEDITEM(#5126,#4784);
#5130= IFCMAPPEDITEM(#5126,#4787);
#5131= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#5127,#5128,#5129,#5130));
#5132= IFCPRODUCTDEFINITIONSHAPE($,$,(#5131));
#5133= IFCMECHANICALFASTENER('1Td1iR001gK34rDp0rCJ4s',#5,'Bolt assembly',$,$,#5106,#5132,'ID5d9c1b1b-0000-6a50-3135-373035313136',12.,50.);
#5134= IFCCARTESIANPOINT((39289.9926804692,-579.170000075344,15795.0000000002));
#5135= IFCAXIS2PLACEMENT3D(#5134,#8,#7);
#5136= IFCLOCALPLACEMENT(#30,#5135);
#5137= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#5138= IFCEXTRUDEDAREASOLID(#5137,#4747,#9,16.0000000000195);
#5139= IFCSTYLEDITEM(#5138,(#195),$);
#5140= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#5141= IFCEXTRUDEDAREASOLID(#5140,#4752,#9,16.1);
#5142= IFCSTYLEDITEM(#5141,(#195),$);
#5143= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#5144= IFCEXTRUDEDAREASOLID(#5143,#4757,#9,6.5);
#5145= IFCSTYLEDITEM(#5144,(#191),$);
#5146= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#5147= IFCEXTRUDEDAREASOLID(#5146,#4762,#9,50.);
#5148= IFCSTYLEDITEM(#5147,(#191),$);
#5149= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#5150= IFCEXTRUDEDAREASOLID(#5149,#4767,#9,2.5);
#5151= IFCSTYLEDITEM(#5150,(#191),$);
#5152= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#5153= IFCEXTRUDEDAREASOLID(#5152,#4772,#9,10.);
#5154= IFCSTYLEDITEM(#5153,(#191),$);
#5155= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5138,#5141,#5144,#5147,#5150,#5153));
#5156= IFCREPRESENTATIONMAP(#10,#5155);
#5157= IFCMAPPEDITEM(#5156,#4776);
#5158= IFCMAPPEDITEM(#5156,#4781);
#5159= IFCMAPPEDITEM(#5156,#4784);
#5160= IFCMAPPEDITEM(#5156,#4787);
#5161= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#5157,#5158,#5159,#5160));
#5162= IFCPRODUCTDEFINITIONSHAPE($,$,(#5161));
#5163= IFCMECHANICALFASTENER('1Td1iR001gJJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#5136,#5162,'ID5d9c1b1b-0000-6a4d-3135-373035313136',12.,50.);
#5164= IFCCARTESIANPOINT((40099.9926804692,-579.170000075344,15795.0000000002));
#5165= IFCAXIS2PLACEMENT3D(#5164,#8,#7);
#5166= IFCLOCALPLACEMENT(#30,#5165);
#5167= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#5168= IFCEXTRUDEDAREASOLID(#5167,#4747,#9,16.0000000000195);
#5169= IFCSTYLEDITEM(#5168,(#195),$);
#5170= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#5171= IFCEXTRUDEDAREASOLID(#5170,#4752,#9,16.1);
#5172= IFCSTYLEDITEM(#5171,(#195),$);
#5173= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#5174= IFCEXTRUDEDAREASOLID(#5173,#4757,#9,6.5);
#5175= IFCSTYLEDITEM(#5174,(#191),$);
#5176= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#5177= IFCEXTRUDEDAREASOLID(#5176,#4762,#9,50.);
#5178= IFCSTYLEDITEM(#5177,(#191),$);
#5179= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#5180= IFCEXTRUDEDAREASOLID(#5179,#4767,#9,2.5);
#5181= IFCSTYLEDITEM(#5180,(#191),$);
#5182= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#5183= IFCEXTRUDEDAREASOLID(#5182,#4772,#9,10.);
#5184= IFCSTYLEDITEM(#5183,(#191),$);
#5185= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5168,#5171,#5174,#5177,#5180,#5183));
#5186= IFCREPRESENTATIONMAP(#10,#5185);
#5187= IFCMAPPEDITEM(#5186,#4776);
#5188= IFCMAPPEDITEM(#5186,#4781);
#5189= IFCMAPPEDITEM(#5186,#4784);
#5190= IFCMAPPEDITEM(#5186,#4787);
#5191= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#5187,#5188,#5189,#5190));
#5192= IFCPRODUCTDEFINITIONSHAPE($,$,(#5191));
#5193= IFCMECHANICALFASTENER('1Td1iR001gIZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#5166,#5192,'ID5d9c1b1b-0000-6a4a-3135-373035313136',12.,50.);
#5194= IFCLOCALPLACEMENT(#30,#10);
#5195= IFCELEMENTASSEMBLY('1Td1iR001dyp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#5194,$,'B/126(?)',.NOTDEFINED.,.RIGID_FRAME.);
#5196= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(691.495424100393),$);
#5197= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit position code',$,IFCLABEL('4/1-5/1/6-N2'),$);
#5198= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('B/126(?)'),$);
#5199= IFCPROPERTYSET('1K04fTDw1DZ9CsyDFEmtvy',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#5196,#888,#889,#890,#5197,#5198));
#5200= IFCCARTESIANPOINT((40276.9951469627,-664.132537913409,15773.9999999996));
#5201= IFCDIRECTION((0.99999999986511,-1.64249999992288E-005,5.34305249992129E-011));
#5202= IFCDIRECTION((0.,-3.25300000008761E-006,-0.999999999994709));
#5203= IFCAXIS2PLACEMENT3D(#5200,#5201,#5202);
#5204= IFCLOCALPLACEMENT(#5194,#5203);
#5205= IFCCARTESIANPOINT((42.993892669625,3.78292906883824E-011));
#5206= IFCCARTESIANPOINT((57.9938441731823,14.9999999999688));
#5207= IFCCARTESIANPOINT((57.9933269995478,174.962341308749));
#5208= IFCCARTESIANPOINT((42.9932785031051,189.962341308655));
#5209= IFCCARTESIANPOINT((14.99938313044,189.962341308627));
#5210= IFCCARTESIANPOINT((-0.000568159676781496,174.96234130869));
#5211= IFCPOLYLINE((#3194,#900,#5205,#5206,#5207,#5208,#5209,#5210,#3194));
#5212= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL16*58',#5211);
#5213= IFCEXTRUDEDAREASOLID(#5212,#63,#9,16.);
#5214= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5213));
#5215= IFCSTYLEDITEM(#5213,(#53),$);
#5216= IFCPRODUCTDEFINITIONSHAPE($,$,(#5214));
#5217= IFCDISCRETEACCESSORY('1Td1iR001f634rDp0rCJ4s',#5,'DETAY','PL16*58','PL16*58',#5204,#5216,'P/428(?)');
#5218= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/428(?)'),$);
#5219= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('B/126(?)'),$);
#5220= IFCPROPERTYSET('3TiDZyx6n0SQCncMunOlYy',#5,'Tekla Common','Common Properties to Shared building elements',(#915,#916,#5218,#5219,#74,#75,#919,#77,#78,#920,#921));
#5221= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(691.495424100393),$);
#5222= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(1.32717197976405),$);
#5223= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(1.38369266908194),$);
#5224= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(1.32717197976405),$);
#5225= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00255939746095426),$);
#5226= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(21.4784193494288),$);
#5227= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0285055563301839),$);
#5228= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0110166613780409),$);
#5229= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(57.9938951591139),$);
#5230= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(189.962432214896),$);
#5231= IFCPROPERTYSET('1dNLP26AL7uB1bIWs5XLuJ',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#5221,#5222,#5223,#5224,#927,#928,#929,#5225,#5226,#5227,#5228,#5229,#94,#5230));
#5232= IFCQUANTITYLENGTH('Width',$,$,57.9938951591139);
#5233= IFCQUANTITYAREA('NetArea',$,$,0.0285055563301839);
#5234= IFCQUANTITYAREA('GrossArea',$,$,0.0110166613780409);
#5235= IFCQUANTITYVOLUME('NetVolume',$,$,0.000169066494237459);
#5236= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000169066494237459);
#5237= IFCELEMENTQUANTITY('3nroxEf9L1g8QbTBI0zExO',#5,'BaseQuantities',$,$,(#5232,#5233,#5234,#100,#5235,#5236));
#5238= IFCCARTESIANPOINT((40290.0045908795,-484.156332298588,15726.0061065627));
#5239= IFCDIRECTION((0.999999999695745,2.46679999924156E-005,0.));
#5240= IFCAXIS2PLACEMENT3D(#5238,#9,#5239);
#5241= IFCLOCALPLACEMENT(#5194,#5240);
#5242= IFCCOLOURRGB('Dark Cyan',0.2,0.6,0.698039215686274);
#5243= IFCSURFACESTYLERENDERING(#5242,0.,$,$,$,$,IFCNORMALISEDRATIOMEASURE(0.00390625),IFCSPECULAREXPONENT(10.),.NOTDEFINED.);
#5244= IFCSURFACESTYLE('STEEL/S235JR',.POSITIVE.,(#5243));
#5245= IFCPRESENTATIONSTYLEASSIGNMENT((#5244));
#5246= IFCLSHAPEPROFILEDEF(.AREA.,'L20*3',#197,20.,20.,3.,3.5,2.,$,$,$);
#5247= IFCCARTESIANPOINT((164.000355763397,-5.55654818772095E-019,-1.81898940354586E-012));
#5248= IFCAXIS2PLACEMENT3D(#5247,#185,#501);
#5249= IFCEXTRUDEDAREASOLID(#5246,#5248,#9,164.000355763397);
#5250= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5249));
#5251= IFCSTYLEDITEM(#5249,(#5245),$);
#5252= IFCPRODUCTDEFINITIONSHAPE($,$,(#5250));
#5253= IFCDISCRETEACCESSORY('1Td1iR001f5J4rDp0rCJ4s',#5,'ANKRAJ','L20*3','L20*3',#5241,#5252,'P/477(?)');
#5254= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +15.736'),$);
#5255= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/477(?)'),$);
#5256= IFCPROPERTYSINGLEVALUE('Class',$,IFCLABEL('81'),$);
#5257= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('L20*3'),$);
#5258= IFCPROPERTYSET('1ls3G6gkvF7R95thxujjPO',#5,'Tekla Common','Common Properties to Shared building elements',(#915,#5254,#5255,#5219,#74,#75,#919,#5256,#78,#5257,#80));
#5259= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.142901709994232),$);
#5260= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(0.144189112786987),$);
#5261= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.144189112786987),$);
#5262= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(1.82040394897111E-005),$);
#5263= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(1.8368039845476E-005),$);
#5264= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(1.8368039845476E-005),$);
#5265= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.000492001067290195),$);
#5266= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(87.5796173566879),$);
#5267= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0133420284610538),$);
#5268= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0126280273248846),$);
#5269= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(20.0000000001226),$);
#5270= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(164.000355763179),$);
#5271= IFCPROPERTYSET('2YTLlNRgn0eRwjNy4fXjC9',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#5221,#5259,#5260,#5261,#5262,#5263,#5264,#5265,#5266,#5267,#5268,#1847,#5269,#5270));
#5272= IFCQUANTITYLENGTH('Length',$,$,164.000355763179);
#5273= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0126280273248846);
#5274= IFCQUANTITYVOLUME('NetVolume',$,$,1.82040394897111E-005);
#5275= IFCQUANTITYWEIGHT('NetWeight',$,$,0.142901709994232);
#5276= IFCELEMENTQUANTITY('2Yx6jugwP3Z8gdeGxN26M8',#5,'BaseQuantities',$,$,(#5272,#5273,#5274,#5275));
#5277= IFCCARTESIANPOINT((40290.0009714322,-654.152372447439,15726.0061065627));
#5278= IFCDIRECTION((-2.18759999936489E-005,0.99999999976072,0.));
#5279= IFCDIRECTION((0.99999999976072,2.18759999945266E-005,0.));
#5280= IFCAXIS2PLACEMENT3D(#5277,#5278,#5279);
#5281= IFCLOCALPLACEMENT(#5194,#5280);
#5282= IFCCARTESIANPOINT((164.000722752632,0.,0.));
#5283= IFCAXIS2PLACEMENT3D(#5282,#185,#501);
#5284= IFCEXTRUDEDAREASOLID(#5246,#5283,#9,164.000722752632);
#5285= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5284));
#5286= IFCSTYLEDITEM(#5284,(#5245),$);
#5287= IFCPRODUCTDEFINITIONSHAPE($,$,(#5285));
#5288= IFCDISCRETEACCESSORY('1Td1iR001f4Z4rDp0rCJ4s',#5,'ANKRAJ','L20*3','L20*3',#5281,#5287,'P/477(?)');
#5289= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.142902029770376),$);
#5290= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(0.144189435443997),$);
#5291= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.144189435443997),$);
#5292= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(1.82040802255257E-005),$);
#5293= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(1.83680809482798E-005),$);
#5294= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(1.83680809482798E-005),$);
#5295= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.0004920021682579),$);
#5296= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0133420578201993),$);
#5297= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0126280555830621),$);
#5298= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(164.000722752498),$);
#5299= IFCPROPERTYSET('0SQzF6kPb07uT5PqgSwsV6',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#5221,#5289,#5290,#5291,#5292,#5293,#5294,#5295,#5266,#5296,#5297,#3352,#1848,#5298));
#5300= IFCQUANTITYLENGTH('Length',$,$,164.000722752498);
#5301= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0126280555830621);
#5302= IFCQUANTITYVOLUME('NetVolume',$,$,1.82040802255257E-005);
#5303= IFCQUANTITYWEIGHT('NetWeight',$,$,0.142902029770376);
#5304= IFCELEMENTQUANTITY('1yrftdOXzEofN7Fjwjt56r',#5,'BaseQuantities',$,$,(#5300,#5301,#5302,#5303));
#5305= IFCCARTESIANPOINT((40467.505011749,-474.169997602407,15708.));
#5306= IFCAXIS2PLACEMENT3D(#5305,#9,#185);
#5307= IFCLOCALPLACEMENT(#5194,#5306);
#5308= IFCCARTESIANPOINT((190.001708984375,1.29097088574781E-009));
#5309= IFCCARTESIANPOINT((190.004821778559,189.982345582567));
#5310= IFCCARTESIANPOINT((0.00310380901646568,189.982345581055));
#5311= IFCPOLYLINE((#54,#5308,#5309,#5310,#54,#54));
#5312= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL16*190',#5311);
#5313= IFCEXTRUDEDAREASOLID(#5312,#63,#9,16.);
#5314= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5313));
#5315= IFCSTYLEDITEM(#5313,(#53),$);
#5316= IFCPRODUCTDEFINITIONSHAPE($,$,(#5314));
#5317= IFCDISCRETEACCESSORY('1Td1iR001f3p4rDp0rCJ4s',#5,'DETAY','PL16*190','PL16*190',#5307,#5316,'P/424(?)');
#5318= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +15.716'),$);
#5319= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/424(?)'),$);
#5320= IFCPROPERTYSET('3TypIi7rb0yuTJi94d_zsw',#5,'Tekla Common','Common Properties to Shared building elements',(#4931,#5318,#5319,#5219,#74,#75,#919,#77,#78,#161,#921));
#5321= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(4.53377958156362),$);
#5322= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(4.53385375116561),$);
#5323= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(4.53377958156362),$);
#5324= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.00057755153905269),$);
#5325= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.00057755153905269),$);
#5326= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.00057755153905269),$);
#5327= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.0360969711907931),$);
#5328= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(18.6055432900353),$);
#5329= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0843534322722599),$);
#5330= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.036097561713102),$);
#5331= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(189.982345581356),$);
#5332= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(190.004821777737),$);
#5333= IFCPROPERTYSET('2UyUdYmwz9nf_L4niZ4jkc',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#5221,#5321,#5322,#5323,#5324,#5325,#5326,#5327,#5328,#5329,#5330,#5331,#94,#5332));
#5334= IFCQUANTITYLENGTH('Width',$,$,189.982345581356);
#5335= IFCQUANTITYAREA('NetArea',$,$,0.0843534322722599);
#5336= IFCQUANTITYAREA('GrossArea',$,$,0.036097561713102);
#5337= IFCQUANTITYVOLUME('NetVolume',$,$,0.00057755153905269);
#5338= IFCQUANTITYVOLUME('GrossVolume',$,$,0.00057755153905269);
#5339= IFCELEMENTQUANTITY('1$bi3WAOnA29$n0O7ydUZ2',#5,'BaseQuantities',$,$,(#5334,#5335,#5336,#100,#5337,#5338));
#5340= IFCCARTESIANPOINT((40467.0011469627,-664.132537913409,15773.9999999996));
#5341= IFCAXIS2PLACEMENT3D(#5340,#5201,#5202);
#5342= IFCLOCALPLACEMENT(#5194,#5341);
#5343= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5213));
#5344= IFCPRODUCTDEFINITIONSHAPE($,$,(#5343));
#5345= IFCDISCRETEACCESSORY('1Td1iR001f334rDp0rCJ4s',#5,'DETAY','PL16*58','PL16*58',#5342,#5344,'P/428(?)');
#5346= IFCCARTESIANPOINT((40723.0048530373,-664.132537913409,15773.9999999996));
#5347= IFCDIRECTION((0.99999999986511,1.64249999992288E-005,-5.34305249991961E-011));
#5348= IFCAXIS2PLACEMENT3D(#5346,#5347,#5202);
#5349= IFCLOCALPLACEMENT(#885,#5348);
#5350= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5213));
#5351= IFCPRODUCTDEFINITIONSHAPE($,$,(#5350));
#5352= IFCDISCRETEACCESSORY('1Td1iR001f2J4rDp0rCJ4s',#5,'DETAY','PL16*58','PL16*58',#5349,#5351,'P/428(?)');
#5353= IFCPROPERTYSET('3qw0dKPA9E$B$mgytPZRFY',#5,'Tekla Common','Common Properties to Shared building elements',(#915,#916,#5218,#918,#74,#75,#919,#77,#78,#920,#921));
#5354= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(21.4784193494296),$);
#5355= IFCPROPERTYSET('3516Q$nwr9pA2z9GxCCHkV',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#923,#5222,#5223,#5224,#927,#928,#929,#5225,#5354,#5227,#5228,#5229,#94,#5230));
#5356= IFCQUANTITYAREA('NetArea',$,$,0.0285055563301839);
#5357= IFCQUANTITYVOLUME('NetVolume',$,$,0.000169066494237452);
#5358= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000169066494237452);
#5359= IFCELEMENTQUANTITY('1OdQ_1CsXBzPI4iaqgVfi8',#5,'BaseQuantities',$,$,(#5232,#5356,#5234,#100,#5357,#5358));
#5360= IFCCARTESIANPOINT((40545.995053407,-484.152286737816,15726.0061065627));
#5361= IFCDIRECTION((0.999999999695745,-2.46679999924167E-005,0.));
#5362= IFCAXIS2PLACEMENT3D(#5360,#9,#5361);
#5363= IFCLOCALPLACEMENT(#885,#5362);
#5364= IFCEXTRUDEDAREASOLID(#5246,#5248,#9,164.000355763389);
#5365= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5364));
#5366= IFCSTYLEDITEM(#5364,(#5245),$);
#5367= IFCPRODUCTDEFINITIONSHAPE($,$,(#5365));
#5368= IFCDISCRETEACCESSORY('1Td1iR001f1Z4rDp0rCJ4s',#5,'ANKRAJ','L20*3','L20*3',#5363,#5367,'P/477(?)');
#5369= IFCPROPERTYSET('0LFqdUjirFivZgsXoV_zIz',#5,'Tekla Common','Common Properties to Shared building elements',(#915,#5254,#5255,#918,#74,#75,#919,#5256,#78,#5257,#80));
#5370= IFCPROPERTYSET('0AqQWhctfAHgSShcLyB4VW',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#923,#5259,#5260,#5261,#5262,#5263,#5264,#5265,#5266,#5267,#5268,#1847,#5269,#5270));
#5371= IFCQUANTITYLENGTH('Length',$,$,164.000355763172);
#5372= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0126280273248841);
#5373= IFCQUANTITYVOLUME('NetVolume',$,$,1.82040394897108E-005);
#5374= IFCQUANTITYWEIGHT('NetWeight',$,$,0.142901709994229);
#5375= IFCELEMENTQUANTITY('1_aE3TAbn7oxkpvUDvy0h6',#5,'BaseQuantities',$,$,(#5371,#5372,#5373,#5374));
#5376= IFCCARTESIANPOINT((40545.9983058544,-654.148784767628,15726.0061065627));
#5377= IFCDIRECTION((2.18759999936489E-005,0.99999999976072,0.));
#5378= IFCDIRECTION((0.99999999976072,-2.18759999945266E-005,0.));
#5379= IFCAXIS2PLACEMENT3D(#5376,#5377,#5378);
#5380= IFCLOCALPLACEMENT(#885,#5379);
#5381= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5284));
#5382= IFCPRODUCTDEFINITIONSHAPE($,$,(#5381));
#5383= IFCDISCRETEACCESSORY('1Td1iR001f0p4rDp0rCJ4s',#5,'ANKRAJ','L20*3','L20*3',#5380,#5382,'P/477(?)');
#5384= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.142902029770379),$);
#5385= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(1.82040802255259E-005),$);
#5386= IFCPROPERTYSET('1sOojeiVr9MwD7Kpvp$id0',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#923,#5384,#5290,#5291,#5385,#5293,#5294,#5295,#5266,#5296,#5297,#3352,#1848,#5298));
#5387= IFCQUANTITYVOLUME('NetVolume',$,$,1.82040802255259E-005);
#5388= IFCQUANTITYWEIGHT('NetWeight',$,$,0.142902029770379);
#5389= IFCELEMENTQUANTITY('1bvITztwP0YuC$RBb46DI9',#5,'BaseQuantities',$,$,(#5300,#5301,#5387,#5388));
#5390= IFCCARTESIANPOINT((40532.494988251,-474.169997602407,15708.));
#5391= IFCAXIS2PLACEMENT3D(#5390,#596,#7);
#5392= IFCLOCALPLACEMENT(#885,#5391);
#5393= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5313));
#5394= IFCPRODUCTDEFINITIONSHAPE($,$,(#5393));
#5395= IFCDISCRETEACCESSORY('1Td1iR001f034rDp0rCJ4s',#5,'DETAY','PL16*190','PL16*190',#5392,#5394,'P/424(?)');
#5396= IFCPROPERTYSET('2mRwp_7iTEkw9aIgxXBUF4',#5,'Tekla Common','Common Properties to Shared building elements',(#4931,#5318,#5319,#918,#74,#75,#919,#77,#78,#161,#921));
#5397= IFCPROPERTYSET('0aEGmHN6j2gxaK06P2q_nk',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#923,#5321,#5322,#5323,#5324,#5325,#5326,#5327,#5328,#5329,#5330,#5331,#94,#5332));
#5398= IFCQUANTITYLENGTH('Width',$,$,189.982345581356);
#5399= IFCQUANTITYAREA('NetArea',$,$,0.0843534322722599);
#5400= IFCQUANTITYAREA('GrossArea',$,$,0.0360975617131019);
#5401= IFCQUANTITYVOLUME('NetVolume',$,$,0.00057755153905269);
#5402= IFCQUANTITYVOLUME('GrossVolume',$,$,0.00057755153905269);
#5403= IFCELEMENTQUANTITY('1TRmLRjxj98RrdFbYz$$nl',#5,'BaseQuantities',$,$,(#5398,#5399,#5400,#100,#5401,#5402));
#5404= IFCCARTESIANPOINT((40532.9988530373,-664.132537913409,15773.9999999996));
#5405= IFCAXIS2PLACEMENT3D(#5404,#5347,#5202);
#5406= IFCLOCALPLACEMENT(#885,#5405);
#5407= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5213));
#5408= IFCPRODUCTDEFINITIONSHAPE($,$,(#5407));
#5409= IFCDISCRETEACCESSORY('1Td1iR001e$J4rDp0rCJ4s',#5,'DETAY','PL16*58','PL16*58',#5406,#5408,'P/428(?)');
#5410= IFCCARTESIANPOINT((32623.0048530373,-664.132537913409,15773.9999999996));
#5411= IFCAXIS2PLACEMENT3D(#5410,#5347,#5202);
#5412= IFCLOCALPLACEMENT(#5194,#5411);
#5413= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5213));
#5414= IFCPRODUCTDEFINITIONSHAPE($,$,(#5413));
#5415= IFCDISCRETEACCESSORY('1Td1iR001ewp4rDp0rCJ4s',#5,'DETAY','PL16*58','PL16*58',#5412,#5414,'P/428(?)');
#5416= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(1.32717197976809),$);
#5417= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(1.32717197976809),$);
#5418= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.028505556330206),$);
#5419= IFCPROPERTYSET('1$zauX_sf98v1Zn2k97zCO',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#5221,#5416,#5223,#5417,#927,#928,#929,#5225,#5226,#5418,#5228,#5229,#94,#5230));
#5420= IFCQUANTITYLENGTH('Width',$,$,57.9938951590957);
#5421= IFCQUANTITYAREA('NetArea',$,$,0.028505556330206);
#5422= IFCQUANTITYAREA('GrossArea',$,$,0.0110166613780375);
#5423= IFCQUANTITYVOLUME('NetVolume',$,$,0.000169066494237973);
#5424= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000169066494237973);
#5425= IFCELEMENTQUANTITY('36BOeS8Ez2mAvi6MTsMUzT',#5,'BaseQuantities',$,$,(#5420,#5421,#5422,#100,#5423,#5424));
#5426= IFCCARTESIANPOINT((32445.995053407,-484.152286737816,15726.0061065627));
#5427= IFCAXIS2PLACEMENT3D(#5426,#9,#5361);
#5428= IFCLOCALPLACEMENT(#5194,#5427);
#5429= IFCEXTRUDEDAREASOLID(#5246,#5248,#9,164.000355763393);
#5430= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5429));
#5431= IFCSTYLEDITEM(#5429,(#5245),$);
#5432= IFCPRODUCTDEFINITIONSHAPE($,$,(#5430));
#5433= IFCDISCRETEACCESSORY('1Td1iR001ew34rDp0rCJ4s',#5,'ANKRAJ','L20*3','L20*3',#5428,#5432,'P/477(?)');
#5434= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.14290170999424),$);
#5435= IFCPROPERTYSET('11P1cH4kHEtvuWQ79jMoXP',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#5221,#5434,#5260,#5261,#5292,#5263,#5264,#5265,#5266,#5267,#5268,#1847,#5269,#5270));
#5436= IFCQUANTITYLENGTH('Length',$,$,164.000355763175);
#5437= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0126280273248844);
#5438= IFCQUANTITYVOLUME('NetVolume',$,$,1.82040394897121E-005);
#5439= IFCQUANTITYWEIGHT('NetWeight',$,$,0.14290170999424);
#5440= IFCELEMENTQUANTITY('0egV4nM5DCf9c10DWezRx9',#5,'BaseQuantities',$,$,(#5436,#5437,#5438,#5439));
#5441= IFCCARTESIANPOINT((32445.9983058544,-654.148784767628,15726.0061065627));
#5442= IFCAXIS2PLACEMENT3D(#5441,#5377,#5378);
#5443= IFCLOCALPLACEMENT(#5194,#5442);
#5444= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5284));
#5445= IFCPRODUCTDEFINITIONSHAPE($,$,(#5444));
#5446= IFCDISCRETEACCESSORY('1Td1iR001evJ4rDp0rCJ4s',#5,'ANKRAJ','L20*3','L20*3',#5443,#5445,'P/477(?)');
#5447= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.14290202977039),$);
#5448= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(1.82040802255274E-005),$);
#5449= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.0004920021682579),$);
#5450= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0133420578201996),$);
#5451= IFCPROPERTYSET('09078b0Jj6zwvIrJKyGf8l',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#5221,#5447,#5290,#5291,#5448,#5293,#5294,#5449,#5266,#5450,#5297,#1847,#1848,#5298));
#5452= IFCQUANTITYVOLUME('NetVolume',$,$,1.82040802255274E-005);
#5453= IFCQUANTITYWEIGHT('NetWeight',$,$,0.14290202977039);
#5454= IFCELEMENTQUANTITY('2hiV$Eywj3A8s$$sIRks6M',#5,'BaseQuantities',$,$,(#5300,#5301,#5452,#5453));
#5455= IFCCARTESIANPOINT((32432.494988251,-474.169997602407,15708.));
#5456= IFCAXIS2PLACEMENT3D(#5455,#596,#7);
#5457= IFCLOCALPLACEMENT(#5194,#5456);
#5458= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5313));
#5459= IFCPRODUCTDEFINITIONSHAPE($,$,(#5458));
#5460= IFCDISCRETEACCESSORY('1Td1iR001euZ4rDp0rCJ4s',#5,'DETAY','PL16*190','PL16*190',#5457,#5459,'P/424(?)');
#5461= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(4.53385375117299),$);
#5462= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0360975617131608),$);
#5463= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(189.982345581666),$);
#5464= IFCPROPERTYSET('1mVxiEnq92ZP2IudtiWXpa',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#5221,#5321,#5461,#5323,#5324,#5325,#5326,#5327,#5328,#5329,#5462,#5463,#94,#5332));
#5465= IFCQUANTITYLENGTH('Width',$,$,189.982345581666);
#5466= IFCQUANTITYAREA('GrossArea',$,$,0.0360975617131608);
#5467= IFCELEMENTQUANTITY('3h13ZjGIL2Eulm58NzLD64',#5,'BaseQuantities',$,$,(#5465,#5399,#5466,#100,#5401,#5402));
#5468= IFCCARTESIANPOINT((46619.492680469,-474.170000153068,15774.00002734));
#5469= IFCAXIS2PLACEMENT3D(#5468,#185,#596);
#5470= IFCLOCALPLACEMENT(#885,#5469);
#5471= IFCCARTESIANPOINT((58.0000562164839,175.000457763784));
#5472= IFCCARTESIANPOINT((43.0000610350271,190.000457763755));
#5473= IFCCARTESIANPOINT((15.000062687528,190.000457763703));
#5474= IFCCARTESIANPOINT((5.77385245948889E-005,175.000457763675));
#5475= IFCPOLYLINE((#899,#900,#952,#953,#5471,#5472,#5473,#5474,#899));
#5476= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL16*58',#5475);
#5477= IFCEXTRUDEDAREASOLID(#5476,#63,#9,16.);
#5478= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5477));
#5479= IFCSTYLEDITEM(#5477,(#53),$);
#5480= IFCPRODUCTDEFINITIONSHAPE($,$,(#5478));
#5481= IFCDISCRETEACCESSORY('1Td1iR001elZ4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#5470,#5480,'P/431(?)');
#5482= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(1.327595314999),$);
#5483= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(1.38411539890168),$);
#5484= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(1.327595314999),$);
#5485= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00256000732421892),$);
#5486= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(21.4777139587189),$);
#5487= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0285137124284839),$);
#5488= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0110200270613191),$);
#5489= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(57.9999998695366),$);
#5490= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(190.000467001848),$);
#5491= IFCPROPERTYSET('00GO7LLtf25BCtZEk8fmTF',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#923,#5482,#5483,#5484,#927,#928,#929,#5485,#5486,#5487,#5488,#5489,#94,#5490));
#5492= IFCQUANTITYLENGTH('Width',$,$,57.9999998695366);
#5493= IFCQUANTITYAREA('NetArea',$,$,0.0285137124284839);
#5494= IFCQUANTITYAREA('GrossArea',$,$,0.0110200270613191);
#5495= IFCQUANTITYVOLUME('NetVolume',$,$,0.000169120422292867);
#5496= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000169120422292867);
#5497= IFCELEMENTQUANTITY('1cH_oDWY91geKHz2RWSiOT',#5,'BaseQuantities',$,$,(#5492,#5493,#5494,#100,#5495,#5496));
#5498= IFCCARTESIANPOINT((40949.4926804679,-474.170000076998,15774.00002734));
#5499= IFCAXIS2PLACEMENT3D(#5498,#185,#596);
#5500= IFCLOCALPLACEMENT(#885,#5499);
#5501= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5477));
#5502= IFCPRODUCTDEFINITIONSHAPE($,$,(#5501));
#5503= IFCDISCRETEACCESSORY('1Td1iR001ekp4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#5500,#5502,'P/431(?)');
#5504= IFCCARTESIANPOINT((43379.4926804679,-474.170000076998,15774.00002734));
#5505= IFCAXIS2PLACEMENT3D(#5504,#185,#596);
#5506= IFCLOCALPLACEMENT(#885,#5505);
#5507= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5477));
#5508= IFCPRODUCTDEFINITIONSHAPE($,$,(#5507));
#5509= IFCDISCRETEACCESSORY('1Td1iR001ek34rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#5506,#5508,'P/431(?)');
#5510= IFCCARTESIANPOINT((44189.4926804679,-474.170000076998,15774.00002734));
#5511= IFCAXIS2PLACEMENT3D(#5510,#185,#596);
#5512= IFCLOCALPLACEMENT(#885,#5511);
#5513= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5477));
#5514= IFCPRODUCTDEFINITIONSHAPE($,$,(#5513));
#5515= IFCDISCRETEACCESSORY('1Td1iR001ejJ4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#5512,#5514,'P/431(?)');
#5516= IFCCARTESIANPOINT((44999.4926804679,-474.170000076998,15774.00002734));
#5517= IFCAXIS2PLACEMENT3D(#5516,#185,#596);
#5518= IFCLOCALPLACEMENT(#885,#5517);
#5519= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5477));
#5520= IFCPRODUCTDEFINITIONSHAPE($,$,(#5519));
#5521= IFCDISCRETEACCESSORY('1Td1iR001eiZ4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#5518,#5520,'P/431(?)');
#5522= IFCCARTESIANPOINT((32432.9988530373,-664.132537913409,15773.9999999996));
#5523= IFCAXIS2PLACEMENT3D(#5522,#5347,#5202);
#5524= IFCLOCALPLACEMENT(#5194,#5523);
#5525= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5213));
#5526= IFCPRODUCTDEFINITIONSHAPE($,$,(#5525));
#5527= IFCDISCRETEACCESSORY('1Td1iR001eWZ4rDp0rCJ4s',#5,'DETAY','PL16*58','PL16*58',#5524,#5526,'P/428(?)');
#5528= IFCCARTESIANPOINT((32849.492680471,-474.168995337077,15774.));
#5529= IFCAXIS2PLACEMENT3D(#5528,#185,#596);
#5530= IFCLOCALPLACEMENT(#5194,#5529);
#5531= IFCCARTESIANPOINT((58.0000105404968,175.00100708019));
#5532= IFCCARTESIANPOINT((43.0000114439626,190.001007080162));
#5533= IFCCARTESIANPOINT((15.0000136799299,190.001007080109));
#5534= IFCCARTESIANPOINT((1.25999411651312E-005,175.001007080081));
#5535= IFCPOLYLINE((#3194,#900,#952,#953,#5531,#5532,#5533,#5534,#3194));
#5536= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL16*58',#5535);
#5537= IFCEXTRUDEDAREASOLID(#5536,#63,#9,16.);
#5538= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5537));
#5539= IFCSTYLEDITEM(#5537,(#53),$);
#5540= IFCPRODUCTDEFINITIONSHAPE($,$,(#5538));
#5541= IFCDISCRETEACCESSORY('1Td1iR001eVp4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#5530,#5540,'P/430(?)');
#5542= IFCPROPERTYSET('22GeXmiqH1C8FcC7vuZp1o',#5,'Tekla Common','Common Properties to Shared building elements',(#915,#916,#4225,#5219,#74,#75,#919,#77,#78,#920,#967));
#5543= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(1.32759930969718),$);
#5544= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(1.38411934685052),$);
#5545= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(1.32759930969718),$);
#5546= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00256001611328126),$);
#5547= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(21.4777104799946),$);
#5548= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0285137936071168),$);
#5549= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0110200584940328),$);
#5550= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(190.001009096072),$);
#5551= IFCPROPERTYSET('10IQVyC0rCuwfJvdwZYh4p',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#5221,#5543,#5544,#5545,#927,#928,#929,#5546,#5547,#5548,#5549,#5489,#94,#5550));
#5552= IFCQUANTITYLENGTH('Width',$,$,57.999999823478);
#5553= IFCQUANTITYAREA('NetArea',$,$,0.0285137936071168);
#5554= IFCQUANTITYAREA('GrossArea',$,$,0.0110200584940328);
#5555= IFCQUANTITYVOLUME('NetVolume',$,$,0.000169120931171616);
#5556= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000169120931171616);
#5557= IFCELEMENTQUANTITY('1DNTyrCeL9_OHa6eWmF1UL',#5,'BaseQuantities',$,$,(#5552,#5553,#5554,#100,#5555,#5556));
#5558= IFCCARTESIANPOINT((35279.4926804679,-474.169997439216,15774.));
#5559= IFCAXIS2PLACEMENT3D(#5558,#185,#596);
#5560= IFCLOCALPLACEMENT(#5194,#5559);
#5561= IFCCARTESIANPOINT((58.000014054021,174.998977661245));
#5562= IFCCARTESIANPOINT((43.0000152586581,189.998977661216));
#5563= IFCCARTESIANPOINT((15.0000147662304,189.998977661164));
#5564= IFCCARTESIANPOINT((1.36004690763225E-005,174.998977661136));
#5565= IFCPOLYLINE((#899,#900,#952,#953,#5561,#5562,#5563,#5564,#899));
#5566= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL16*58',#5565);
#5567= IFCEXTRUDEDAREASOLID(#5566,#63,#9,16.);
#5568= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5567));
#5569= IFCSTYLEDITEM(#5567,(#53),$);
#5570= IFCPRODUCTDEFINITIONSHAPE($,$,(#5568));
#5571= IFCDISCRETEACCESSORY('1Td1iR001eV34rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#5560,#5570,'P/430(?)');
#5572= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(1.32758455834137),$);
#5573= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(1.38410457914289),$);
#5574= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(1.32758455834137),$);
#5575= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(21.4777233103612),$);
#5576= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0285134938151641),$);
#5577= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(58.0000004536068),$);
#5578= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(189.998979837205),$);
#5579= IFCPROPERTYSET('22wG6f4Dj5SBFThosYyYhF',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#5221,#5572,#5573,#5574,#927,#928,#929,#930,#5575,#5576,#974,#5577,#94,#5578));
#5580= IFCQUANTITYLENGTH('Width',$,$,58.0000004536068);
#5581= IFCQUANTITYAREA('NetArea',$,$,0.0285134938151641);
#5582= IFCQUANTITYAREA('GrossArea',$,$,0.0110199409167427);
#5583= IFCQUANTITYVOLUME('NetVolume',$,$,0.000169119052018009);
#5584= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000169119052018009);
#5585= IFCELEMENTQUANTITY('0NWwCJRVn5G9i859RY8hl$',#5,'BaseQuantities',$,$,(#5580,#5581,#5582,#100,#5583,#5584));
#5586= IFCCARTESIANPOINT((36089.4926804679,-474.169997439216,15774.));
#5587= IFCAXIS2PLACEMENT3D(#5586,#185,#596);
#5588= IFCLOCALPLACEMENT(#5194,#5587);
#5589= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5567));
#5590= IFCPRODUCTDEFINITIONSHAPE($,$,(#5589));
#5591= IFCDISCRETEACCESSORY('1Td1iR001ePp4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#5588,#5590,'P/430(?)');
#5592= IFCCARTESIANPOINT((36899.4926804679,-474.169997439216,15774.));
#5593= IFCAXIS2PLACEMENT3D(#5592,#185,#596);
#5594= IFCLOCALPLACEMENT(#5194,#5593);
#5595= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5567));
#5596= IFCPRODUCTDEFINITIONSHAPE($,$,(#5595));
#5597= IFCDISCRETEACCESSORY('1Td1iR001eP34rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#5594,#5596,'P/430(?)');
#5598= IFCCARTESIANPOINT((39329.4926804679,-474.169997439216,15774.));
#5599= IFCAXIS2PLACEMENT3D(#5598,#185,#596);
#5600= IFCLOCALPLACEMENT(#5194,#5599);
#5601= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5567));
#5602= IFCPRODUCTDEFINITIONSHAPE($,$,(#5601));
#5603= IFCDISCRETEACCESSORY('1Td1iR001eOJ4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#5600,#5602,'P/430(?)');
#5604= IFCCARTESIANPOINT((40139.4909530955,-474.168995337077,15774.));
#5605= IFCAXIS2PLACEMENT3D(#5604,#185,#596);
#5606= IFCLOCALPLACEMENT(#5194,#5605);
#5607= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5537));
#5608= IFCPRODUCTDEFINITIONSHAPE($,$,(#5607));
#5609= IFCDISCRETEACCESSORY('1Td1iR001eNZ4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#5606,#5608,'P/430(?)');
#5610= IFCCARTESIANPOINT((40524.9985336876,-569.170194612416,15745.));
#5611= IFCAXIS2PLACEMENT3D(#5610,#501,#7);
#5612= IFCLOCALPLACEMENT(#885,#5611);
#5613= IFCCARTESIANPOINT((45.,-120.000000027251));
#5614= IFCCARTESIANPOINT((-45.,-120.000000027251));
#5615= IFCCARTESIANPOINT((-45.,119.999999972749));
#5616= IFCCARTESIANPOINT((45.,119.999999972749));
#5617= IFCPOLYLINE((#5613,#5614,#5615,#5616,#5613));
#5618= IFCCARTESIANPOINT((-29.,94.9999999727489));
#5619= IFCCARTESIANPOINT((-29.,-95.0000000272512));
#5620= IFCCARTESIANPOINT((29.,-95.0000000272512));
#5621= IFCCARTESIANPOINT((29.,94.9999999727489));
#5622= IFCPOLYLINE((#5618,#5619,#5620,#5621,#5618));
#5623= IFCARBITRARYPROFILEDEFWITHVOIDS(.AREA.,'WB240-16-25*90-0',#5617,(#5622));
#5624= IFCCARTESIANPOINT((8006.00080617593,1.81898940354586E-012,-2.64896346038106E-020));
#5625= IFCAXIS2PLACEMENT3D(#5624,#185,#501);
#5626= IFCEXTRUDEDAREASOLID(#5623,#5625,#9,8006.00080617593);
#5627= IFCCARTESIANPOINT((8095.00311855631,-89.9999999999764,-180.175213562531));
#5628= IFCAXIS2PLACEMENT3D(#5627,#7,#9);
#5629= IFCPLANE(#5628);
#5630= IFCHALFSPACESOLID(#5629,.F.);
#5631= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#5626,#5630);
#5632= IFCCARTESIANPOINT((8006.00080617593,1.81898940354586E-012,-120.));
#5633= IFCAXIS2PLACEMENT3D(#5632,#185,#8);
#5634= IFCPLANE(#5633);
#5635= IFCHALFSPACESOLID(#5634,.T.);
#5636= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#5631,#5635);
#5637= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#5636));
#5638= IFCSTYLEDITEM(#5626,(#4032),$);
#5639= IFCPRODUCTDEFINITIONSHAPE($,$,(#5637));
#5640= IFCBEAM('1Td1iR001d_J4rDp0rCJ4s',#5,'KIRIS','WB240-16-25*90-0','WB240-16-25*90-0',#5612,#5639,'P/304(?)');
#5641= IFCBEAMTYPE('23JGiX07vCf9oXH4e_ndpY',#5,'WB240-16-25*90-0',$,$,$,$,$,$,.NOTDEFINED.);
#5642= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/304(?)'),$);
#5643= IFCPROPERTYSINGLEVALUE('Class',$,IFCLABEL('18'),$);
#5644= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('WB240-16-25*90-0'),$);
#5645= IFCPROPERTYSET('3xbqTDjRX9UAho4ga_lnQ4',#5,'Tekla Common','Common Properties to Shared building elements',(#4931,#1052,#5642,#918,#74,#75,#919,#5643,#78,#5644,#4185));
#5646= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(664.92238495533),$);
#5647= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(664.92238495533),$);
#5648= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(664.92238495533),$);
#5649= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.0847034885293414),$);
#5650= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.0847034885293414),$);
#5651= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.0847034885293414),$);
#5652= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(1.92144019348222),$);
#5653= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(13.9506461834076),$);
#5654= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(9.27609693193938),$);
#5655= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(9.27609693193938),$);
#5656= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(240.000000027094),$);
#5657= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(90.),$);
#5658= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(8006.00080617594),$);
#5659= IFCPROPERTYSET('0TZbKMQXf6EhXWGO_Wd9ew',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#923,#5646,#5647,#5648,#5649,#5650,#5651,#5652,#5653,#5654,#5655,#5656,#5657,#5658));
#5660= IFCQUANTITYLENGTH('Length',$,$,8006.00080617594);
#5661= IFCQUANTITYAREA('OuterSurfaceArea',$,$,9.27609693193938);
#5662= IFCQUANTITYVOLUME('NetVolume',$,$,0.0847034885293414);
#5663= IFCQUANTITYWEIGHT('NetWeight',$,$,664.92238495533);
#5664= IFCELEMENTQUANTITY('1N0sC07_PBFBUVqCejzJY0',#5,'BaseQuantities',$,$,(#5660,#5661,#5662,#5663));
#5665= IFCCARTESIANPOINT((32424.9985364744,-569.170194656646,15745.));
#5666= IFCAXIS2PLACEMENT3D(#5665,#501,#7);
#5667= IFCLOCALPLACEMENT(#5194,#5666);
#5668= IFCCARTESIANPOINT((8050.00280626804,0.,0.));
#5669= IFCAXIS2PLACEMENT3D(#5668,#185,#501);
#5670= IFCEXTRUDEDAREASOLID(#5623,#5669,#9,8050.00280626804);
#5671= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5670));
#5672= IFCSTYLEDITEM(#5670,(#4032),$);
#5673= IFCPRODUCTDEFINITIONSHAPE($,$,(#5671));
#5674= IFCBEAM('1Td1iR001dyZ4rDp0rCJ4s',#5,'KIRIS','WB240-16-25*90-0','WB240-16-25*90-0',#5667,#5673,'P/252(?)');
#5675= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/252(?)'),$);
#5676= IFCPROPERTYSET('3Hgi2gxIr2R9Y09sRppd0a',#5,'Tekla Common','Common Properties to Shared building elements',(#4931,#1052,#5675,#5219,#74,#75,#919,#5643,#78,#5644,#4185));
#5677= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(668.57688306898),$);
#5678= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(668.57688306898),$);
#5679= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(668.57688306898),$);
#5680= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.0851690296903159),$);
#5681= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.0851690296903159),$);
#5682= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.0851690296903159),$);
#5683= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(1.93200067350433),$);
#5684= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(13.9504722347446),$);
#5685= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(9.32696324404586),$);
#5686= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(9.32696324404586),$);
#5687= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(8050.00280626804),$);
#5688= IFCPROPERTYSET('3a1tx03JPEjhG_Ip$tytYG',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#5221,#5677,#5678,#5679,#5680,#5681,#5682,#5683,#5684,#5685,#5686,#1207,#5657,#5687));
#5689= IFCQUANTITYLENGTH('Length',$,$,8050.00280626804);
#5690= IFCQUANTITYAREA('OuterSurfaceArea',$,$,9.32696324404586);
#5691= IFCQUANTITYVOLUME('NetVolume',$,$,0.0851690296903159);
#5692= IFCQUANTITYWEIGHT('NetWeight',$,$,668.57688306898);
#5693= IFCELEMENTQUANTITY('30J0KTPMz7yxzIo3m3Ltjn',#5,'BaseQuantities',$,$,(#5689,#5690,#5691,#5692));
#5694= IFCCARTESIANPOINT((48715.6782258152,-565.430250853945,4899.99615590692));
#5695= IFCDIRECTION((-0.707101474166633,-0.707112088166632,0.));
#5696= IFCDIRECTION((-0.707112088166636,0.707101474166629,0.));
#5697= IFCAXIS2PLACEMENT3D(#5694,#5695,#5696);
#5698= IFCLOCALPLACEMENT(#30,#5697);
#5699= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#5700= IFCCARTESIANPOINT((0.,-5.89906520945523,0.));
#5701= IFCAXIS2PLACEMENT3D(#5700,#8,#7);
#5702= IFCEXTRUDEDAREASOLID(#5699,#5701,#9,16.0000000001215);
#5703= IFCSTYLEDITEM(#5702,(#195),$);
#5704= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#5705= IFCCARTESIANPOINT((0.,9.89615590697241,0.));
#5706= IFCAXIS2PLACEMENT3D(#5705,#8,#7);
#5707= IFCEXTRUDEDAREASOLID(#5704,#5706,#9,16.1000000000001);
#5708= IFCSTYLEDITEM(#5707,(#195),$);
#5709= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#5710= IFCCARTESIANPOINT((0.,-12.4990652094552,0.));
#5711= IFCAXIS2PLACEMENT3D(#5710,#8,#7);
#5712= IFCEXTRUDEDAREASOLID(#5709,#5711,#9,6.5);
#5713= IFCSTYLEDITEM(#5712,(#191),$);
#5714= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#5715= IFCCARTESIANPOINT((0.,-5.99906520945523,0.));
#5716= IFCAXIS2PLACEMENT3D(#5715,#8,#7);
#5717= IFCEXTRUDEDAREASOLID(#5714,#5716,#9,50.);
#5718= IFCSTYLEDITEM(#5717,(#191),$);
#5719= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#5720= IFCCARTESIANPOINT((0.,25.9961559069725,0.));
#5721= IFCAXIS2PLACEMENT3D(#5720,#8,#7);
#5722= IFCEXTRUDEDAREASOLID(#5719,#5721,#9,2.5);
#5723= IFCSTYLEDITEM(#5722,(#191),$);
#5724= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#5725= IFCCARTESIANPOINT((0.,28.4961559069725,0.));
#5726= IFCAXIS2PLACEMENT3D(#5725,#8,#7);
#5727= IFCEXTRUDEDAREASOLID(#5724,#5726,#9,10.);
#5728= IFCSTYLEDITEM(#5727,(#191),$);
#5729= IFCCARTESIANPOINT((0.,0.,-60.0000000000218));
#5730= IFCCARTESIANTRANSFORMATIONOPERATOR3D($,$,#5729,$,$);
#5731= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5702,#5707,#5712,#5717,#5722,#5727));
#5732= IFCREPRESENTATIONMAP(#10,#5731);
#5733= IFCMAPPEDITEM(#5732,#5730);
#5734= IFCCARTESIANPOINT((59.9999999999854,0.,-60.0000000000146));
#5735= IFCCARTESIANTRANSFORMATIONOPERATOR3D($,$,#5734,$,$);
#5736= IFCMAPPEDITEM(#5732,#5735);
#5737= IFCCARTESIANPOINT((0.,0.,60.0000000000218));
#5738= IFCCARTESIANTRANSFORMATIONOPERATOR3D($,$,#5737,$,$);
#5739= IFCMAPPEDITEM(#5732,#5738);
#5740= IFCCARTESIANPOINT((59.9999999999854,0.,60.0000000000218));
#5741= IFCCARTESIANTRANSFORMATIONOPERATOR3D($,$,#5740,$,$);
#5742= IFCMAPPEDITEM(#5732,#5741);
#5743= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#5733,#5736,#5739,#5742));
#5744= IFCPRODUCTDEFINITIONSHAPE($,$,(#5743));
#5745= IFCMECHANICALFASTENER('1Td1iR001OQZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#5698,#5744,'ID5d9c1b1b-0000-586a-3135-373035313136',12.,50.);
#5746= IFCLOCALPLACEMENT(#30,#10);
#5747= IFCELEMENTASSEMBLY('1Td1iR002jRJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#5746,$,'DK/76(?)',.NOTDEFINED.,.RIGID_FRAME.);
#5748= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(633.685628787593),$);
#5749= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' +4.890'),$);
#5750= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +10.500'),$);
#5751= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('DK/76(?)'),$);
#5752= IFCPROPERTYSET('08MFGK0Rv04PMG670qBP5B',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#5748,#5749,#5750,#3925,#3926,#5751));
#5753= IFCCARTESIANPOINT((48708.5693247701,-686.020643927995,4897.99554946184));
#5754= IFCDIRECTION((3.80500563884146E-006,8.57975001441303E-007,0.999999999992393));
#5755= IFCDIRECTION((0.999999999971179,-6.56999999939188E-006,-3.80500000186498E-006));
#5756= IFCAXIS2PLACEMENT3D(#5753,#5754,#5755);
#5757= IFCLOCALPLACEMENT(#5746,#5756);
#5758= IFCCARTESIANPOINT((127.447486880053,-1.62287960847607E-009));
#5759= IFCCARTESIANPOINT((127.4334945706,127.124946592863));
#5760= IFCCARTESIANPOINT((-0.175367560943414,254.729644775283));
#5761= IFCCARTESIANPOINT((-127.453842159921,127.449676514814));
#5762= IFCPOLYLINE((#54,#5758,#5759,#5760,#5761,#54,#54));
#5763= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL16*180',#5762);
#5764= IFCEXTRUDEDAREASOLID(#5763,#63,#9,16.);
#5765= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5764));
#5766= IFCSTYLEDITEM(#5764,(#53),$);
#5767= IFCPRODUCTDEFINITIONSHAPE($,$,(#5765));
#5768= IFCDISCRETEACCESSORY('1Td1iR001OPZ4rDp0rCJ4s',#5,'PLAKA','PL16*180','PL16*180',#5757,#5767,'P/423(?)');
#5769= IFCDISCRETEACCESSORYTYPE('2emaDNbn92GfzC_ak6dJTf',#5,'PLAKA',$,$,$,$,$,$);
#5770= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/423(?)'),$);
#5771= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('DK/76(?)'),$);
#5772= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PL16*180'),$);
#5773= IFCPROPERTYSINGLEVALUE('Name',$,IFCLABEL('PLAKA'),$);
#5774= IFCPROPERTYSET('3VUQxpO1D07uNTANGsyTU9',#5,'Tekla Common','Common Properties to Shared building elements',(#2254,#2255,#5770,#5771,#74,#75,#76,#1194,#78,#5772,#5773));
#5775= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(633.685628787593),$);
#5776= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(5.09490489006679),$);
#5777= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(6.11239973203746),$);
#5778= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(5.09490489006679),$);
#5779= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000649032470072202),$);
#5780= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000649032470072202),$);
#5781= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000649032470072202),$);
#5782= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.0405645293795113),$);
#5783= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(18.4210570527439),$);
#5784= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0938535336582244),$);
#5785= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0486656029620817),$);
#5786= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(180.000001149398),$);
#5787= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(270.36445917403),$);
#5788= IFCPROPERTYSET('1bciXKqJX0YRTHKNLUT0hH',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#5775,#5776,#5777,#5778,#5779,#5780,#5781,#5782,#5783,#5784,#5785,#5786,#94,#5787));
#5789= IFCQUANTITYLENGTH('Width',$,$,180.000001149398);
#5790= IFCQUANTITYAREA('NetArea',$,$,0.0938535336582244);
#5791= IFCQUANTITYAREA('GrossArea',$,$,0.0486656029620817);
#5792= IFCQUANTITYVOLUME('NetVolume',$,$,0.000649032470072202);
#5793= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000649032470072202);
#5794= IFCELEMENTQUANTITY('39gytn2Yz71QBWgdHH3PUA',#5,'BaseQuantities',$,$,(#5789,#5790,#5791,#100,#5792,#5793));
#5795= IFCCARTESIANPOINT((40288.4976961945,-232.330062517137,15790.));
#5796= IFCAXIS2PLACEMENT3D(#5795,#596,#597);
#5797= IFCLOCALPLACEMENT(#30,#5796);
#5798= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#5799= IFCEXTRUDEDAREASOLID(#5798,#602,#9,30.1000000000098);
#5800= IFCSTYLEDITEM(#5799,(#195),$);
#5801= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5799));
#5802= IFCREPRESENTATIONMAP(#10,#5801);
#5803= IFCMAPPEDITEM(#5802,#247);
#5804= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#5803));
#5805= IFCPRODUCTDEFINITIONSHAPE($,$,(#5804));
#5806= IFCMECHANICALFASTENER('1Td1iR000rRZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#5797,#5805,'ID5d9c1b1b-0000-356e-3135-373035313136',20.,30.);
#5807= IFCCARTESIANPOINT((40705.1872659515,-203.002074025752,15790.));
#5808= IFCAXIS2PLACEMENT3D(#5807,#9,#620);
#5809= IFCLOCALPLACEMENT(#30,#5808);
#5810= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,71.);
#5811= IFCEXTRUDEDAREASOLID(#5810,#625,#9,30.1063464563373);
#5812= IFCSTYLEDITEM(#5811,(#195),$);
#5813= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5811));
#5814= IFCREPRESENTATIONMAP(#10,#5813);
#5815= IFCMAPPEDITEM(#5814,#247);
#5816= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#5815));
#5817= IFCPRODUCTDEFINITIONSHAPE($,$,(#5816));
#5818= IFCMECHANICALFASTENER('1Td1iR000rSJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#5809,#5817,'ID5d9c1b1b-0000-3571-3135-373035313136',20.,30.0063457489014);
#5819= IFCCARTESIANPOINT((40711.502262432,-232.330074783567,15790.));
#5820= IFCAXIS2PLACEMENT3D(#5819,#9,#640);
#5821= IFCLOCALPLACEMENT(#30,#5820);
#5822= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#5823= IFCEXTRUDEDAREASOLID(#5822,#602,#9,30.1000000000079);
#5824= IFCSTYLEDITEM(#5823,(#195),$);
#5825= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5823));
#5826= IFCREPRESENTATIONMAP(#10,#5825);
#5827= IFCMAPPEDITEM(#5826,#247);
#5828= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#5827));
#5829= IFCPRODUCTDEFINITIONSHAPE($,$,(#5828));
#5830= IFCMECHANICALFASTENER('1Td1iR000rT34rDp0rCJ4s',#5,'Bolt assembly',$,$,#5821,#5829,'ID5d9c1b1b-0000-3574-3135-373035313136',20.,30.);
#5831= IFCCARTESIANPOINT((40294.8131339993,-203.002049402811,15790.));
#5832= IFCAXIS2PLACEMENT3D(#5831,#596,#653);
#5833= IFCLOCALPLACEMENT(#30,#5832);
#5834= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,71.);
#5835= IFCEXTRUDEDAREASOLID(#5834,#658,#9,30.1061745233263);
#5836= IFCSTYLEDITEM(#5835,(#195),$);
#5837= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5835));
#5838= IFCREPRESENTATIONMAP(#10,#5837);
#5839= IFCMAPPEDITEM(#5838,#247);
#5840= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#5839));
#5841= IFCPRODUCTDEFINITIONSHAPE($,$,(#5840));
#5842= IFCMECHANICALFASTENER('1Td1iR000rTp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#5833,#5841,'ID5d9c1b1b-0000-3577-3135-373035313136',20.,30.0061740875244);
#5843= IFCCARTESIANPOINT((40634.9988455077,-554.152715152363,15787.999));
#5844= IFCAXIS2PLACEMENT3D(#5843,#501,#185);
#5845= IFCLOCALPLACEMENT(#30,#5844);
#5846= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,40.);
#5847= IFCEXTRUDEDAREASOLID(#5846,#561,#9,16.0999999999991);
#5848= IFCSTYLEDITEM(#5847,(#195),$);
#5849= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5847));
#5850= IFCREPRESENTATIONMAP(#10,#5849);
#5851= IFCMAPPEDITEM(#5850,#247);
#5852= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#5851));
#5853= IFCPRODUCTDEFINITIONSHAPE($,$,(#5852));
#5854= IFCMECHANICALFASTENER('1Td1iR000rUZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#5845,#5853,'ID5d9c1b1b-0000-357a-3135-373035313136',30.,16.);
#5855= IFCPROPERTYSINGLEVALUE('Bolt hole diameter',$,IFCLENGTHMEASURE(80.),$);
#5856= IFCPROPERTYSINGLEVALUE('Bolt size',$,IFCLENGTHMEASURE(80.),$);
#5857= IFCPROPERTYSET('1ZgjzKEM92jO1m$RJya$zV',#5,'Tekla Bolt','Bolt Properties',(#255,#570,#571,#572,#259,#573,#574,#575,#263,#5855,#265,#266,#5856,#578,#579,#580));
#5858= IFCCARTESIANPOINT((40365.0017174869,-554.152698952219,15787.999));
#5859= IFCAXIS2PLACEMENT3D(#5858,#8,#7);
#5860= IFCLOCALPLACEMENT(#30,#5859);
#5861= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,40.);
#5862= IFCEXTRUDEDAREASOLID(#5861,#561,#9,16.0999999999976);
#5863= IFCSTYLEDITEM(#5862,(#195),$);
#5864= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5862));
#5865= IFCREPRESENTATIONMAP(#10,#5864);
#5866= IFCMAPPEDITEM(#5865,#247);
#5867= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#5866));
#5868= IFCPRODUCTDEFINITIONSHAPE($,$,(#5867));
#5869= IFCMECHANICALFASTENER('1Td1iR000rVJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#5860,#5868,'ID5d9c1b1b-0000-357d-3135-373035313136',30.,16.);
#5870= IFCLOCALPLACEMENT(#30,#10);
#5871= IFCELEMENTASSEMBLY('1Td1iR000tsZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#5870,$,'A/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#5872= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(64.069865378797),$);
#5873= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit position code',$,IFCLABEL('5/1/6-N2'),$);
#5874= IFCPROPERTYSET('2jLkhg915CcwAlwuQLO7TF',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#5872,#987,#988,#989,#5873,#990));
#5875= IFCCARTESIANPOINT((40430.0009742969,-409.152085224178,15707.));
#5876= IFCAXIS2PLACEMENT3D(#5875,#9,#7);
#5877= IFCLOCALPLACEMENT(#5870,#5876);
#5878= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1002));
#5879= IFCPRODUCTDEFINITIONSHAPE($,$,(#5878));
#5880= IFCDISCRETEACCESSORY('1Td1iR000sFJ4rDp0rCJ4s',#5,'PLATE','PL16*140','PL16*140',#5877,#5879,'P/0(?)');
#5881= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(64.069865378797),$);
#5882= IFCPROPERTYSET('2Bky_K4BLEweBefVUamGpU',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#5881,#1014,#1015,#1016,#1017,#1018,#1019,#1020,#1021,#1022,#1023,#1024,#94,#1025));
#5883= IFCCARTESIANPOINT((40543.9994010579,-401.152088433781,15790.));
#5884= IFCAXIS2PLACEMENT3D(#5883,#501,#185);
#5885= IFCLOCALPLACEMENT(#5870,#5884);
#5886= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1046));
#5887= IFCPRODUCTDEFINITIONSHAPE($,$,(#5886));
#5888= IFCDISCRETEACCESSORY('1Td1iR000sG34rDp0rCJ4s',#5,'PLATE','PL16*75','PL16*75',#5885,#5887,'P/0(?)');
#5889= IFCPROPERTYSET('0zrYqbzkH7XAdxKMFko2YB',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#5881,#1054,#1055,#1056,#1057,#1058,#1059,#1060,#1061,#1062,#1063,#1064,#94,#1065));
#5890= IFCCARTESIANPOINT((40551.9994009154,-409.152092881741,15714.995));
#5891= IFCAXIS2PLACEMENT3D(#5890,#185,#9);
#5892= IFCLOCALPLACEMENT(#5870,#5891);
#5893= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1081));
#5894= IFCPRODUCTDEFINITIONSHAPE($,$,(#5893));
#5895= IFCDISCRETEACCESSORY('1Td1iR000sGp4rDp0rCJ4s',#5,'PLATE','PL16*75','PL16*75',#5892,#5894,'P/0(?)');
#5896= IFCPROPERTYSET('1eNuezXZT2WRUgHKNfGMBe',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#5881,#1086,#1087,#1088,#1089,#1090,#1091,#1092,#1093,#1094,#1095,#1096,#1097,#1098));
#5897= IFCCARTESIANPOINT((40448.0009742969,-409.152086581707,15714.995));
#5898= IFCAXIS2PLACEMENT3D(#5897,#185,#9);
#5899= IFCLOCALPLACEMENT(#5870,#5898);
#5900= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1081));
#5901= IFCPRODUCTDEFINITIONSHAPE($,$,(#5900));
#5902= IFCDISCRETEACCESSORY('1Td1iR000sHZ4rDp0rCJ4s',#5,'PLATE','PL16*75','PL16*75',#5899,#5901,'P/0(?)');
#5903= IFCPROPERTYSET('1BF4SE4s5BeAnMp$2XYo2m',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#5881,#1112,#1087,#1113,#1114,#1115,#1116,#1092,#1093,#1094,#1095,#1096,#1117,#1098));
#5904= IFCCARTESIANPOINT((40171.0886298035,-157.192275561193,15790.));
#5905= IFCAXIS2PLACEMENT3D(#5904,#9,#1125);
#5906= IFCLOCALPLACEMENT(#5870,#5905);
#5907= IFCCIRCLE(#1138,26.5157137784545);
#5908= IFCTRIMMEDCURVE(#5907,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.42863508547151)),.F.,.PARAMETER.);
#5909= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#5908);
#5910= IFCCOMPOSITECURVE((#5909,#1145),.F.);
#5911= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#5910);
#5912= IFCEXTRUDEDAREASOLID(#5911,#1151,#9,100.);
#5913= IFCBOOLEANRESULT(.DIFFERENCE.,#1135,#5912);
#5914= IFCCIRCLE(#1138,26.5157137784325);
#5915= IFCTRIMMEDCURVE(#5914,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.428635085469)),.F.,.PARAMETER.);
#5916= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#5915);
#5917= IFCCOMPOSITECURVE((#5916,#1145),.F.);
#5918= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#5917);
#5919= IFCEXTRUDEDAREASOLID(#5918,#1162,#9,100.);
#5920= IFCBOOLEANRESULT(.DIFFERENCE.,#5913,#5919);
#5921= IFCCIRCLE(#1138,26.5157137785379);
#5922= IFCTRIMMEDCURVE(#5921,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.42863508546077)),.F.,.PARAMETER.);
#5923= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#5922);
#5924= IFCCOMPOSITECURVE((#5923,#1145),.F.);
#5925= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#5924);
#5926= IFCEXTRUDEDAREASOLID(#5925,#1173,#9,100.);
#5927= IFCBOOLEANRESULT(.DIFFERENCE.,#5920,#5926);
#5928= IFCCIRCLE(#1138,26.5157137785497);
#5929= IFCTRIMMEDCURVE(#5928,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.42863508546206)),.F.,.PARAMETER.);
#5930= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#5929);
#5931= IFCCOMPOSITECURVE((#5930,#1145),.F.);
#5932= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#5931);
#5933= IFCEXTRUDEDAREASOLID(#5932,#1184,#9,100.);
#5934= IFCBOOLEANRESULT(.DIFFERENCE.,#5927,#5933);
#5935= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#5934));
#5936= IFCPRODUCTDEFINITIONSHAPE($,$,(#5935));
#5937= IFCDISCRETEACCESSORY('1Td1iR000sLZ4rDp0rCJ4s',#5,'ANKRAJ','PLT30*240','PLT30*240',#5906,#5936,'P/370(?)');
#5938= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(9.90376532231765),$);
#5939= IFCPROPERTYSET('1$aNNPruj1Nx$17o34_mXT',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#5881,#3000,#1198,#3001,#3002,#1201,#3004,#1203,#5938,#3006,#1206,#1207,#1208,#1209));
#5940= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.374594953106507);
#5941= IFCQUANTITYVOLUME('NetVolume',$,$,0.00481827878120545);
#5942= IFCQUANTITYWEIGHT('NetWeight',$,$,37.8234884324628);
#5943= IFCELEMENTQUANTITY('1l2EwwQTb4twRzJHg7813g',#5,'BaseQuantities',$,$,(#1211,#5940,#5941,#5942));
#5944= IFCLOCALPLACEMENT(#30,#10);
#5945= IFCELEMENTASSEMBLY('1Td1iR000tlp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#5944,$,'ANK/61(?)',.NOTDEFINED.,.RIGID_FRAME.);
#5946= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(5.29879095790593),$);
#5947= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit position code',$,IFCLABEL('5/1/N2'),$);
#5948= IFCPROPERTYSET('2U2OuG02f54v56tc4hJFS6',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#5946,#1612,#1613,#1614,#5947,#1616));
#5949= IFCQUANTITYLENGTH('Width',$,$,30.0000000002347);
#5950= IFCELEMENTQUANTITY('311rIUwLfF4BIOjar4iCSn',#5,'BaseQuantities',$,$,(#5949));
#5951= IFCCARTESIANPOINT((40363.8303183166,-238.761303583805,15790.));
#5952= IFCAXIS2PLACEMENT3D(#5951,#9,#1621);
#5953= IFCLOCALPLACEMENT(#5944,#5952);
#5954= IFCEXTRUDEDAREASOLID(#1628,#1630,#9,150.001159459227);
#5955= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5954));
#5956= IFCSTYLEDITEM(#5954,(#1627),$);
#5957= IFCPRODUCTDEFINITIONSHAPE($,$,(#5955));
#5958= IFCBEAM('1Td1iR000tm34rDp0rCJ4s',#5,'PUL','PLT30*150','PLT30*150',#5953,#5957,'P/377(?)');
#5959= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(5.29879095790593),$);
#5960= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(5.29879095790593),$);
#5961= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(5.29879095790857),$);
#5962= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(5.29879095790593),$);
#5963= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000675005217567635),$);
#5964= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000675005217567635),$);
#5965= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000675005217567635),$);
#5966= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(11.889583474024),$);
#5967= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.063000417405426),$);
#5968= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.063000417405426),$);
#5969= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(30.0000000002347),$);
#5970= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(150.001159459549),$);
#5971= IFCPROPERTYSET('2ULHaadfDF1OzThoW9gqTb',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#5959,#5960,#5961,#5962,#5963,#5964,#5965,#1651,#5966,#5967,#5968,#529,#5969,#5970));
#5972= IFCQUANTITYLENGTH('Length',$,$,150.001159459549);
#5973= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0630004174054261);
#5974= IFCQUANTITYVOLUME('NetVolume',$,$,0.000675005217567634);
#5975= IFCQUANTITYWEIGHT('NetWeight',$,$,5.29879095790593);
#5976= IFCELEMENTQUANTITY('3vTw9bZ9n0bhfDKS6E$YF0',#5,'BaseQuantities',$,$,(#5972,#5973,#5974,#5975));
#5977= IFCLOCALPLACEMENT(#30,#10);
#5978= IFCELEMENTASSEMBLY('1Td1iR000tmp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#5977,$,'ANK/61(?)',.NOTDEFINED.,.RIGID_FRAME.);
#5979= IFCPROPERTYSET('3mWt1xAPH3YenyVIhQ_ULg',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1665,#1612,#1613,#1614,#5947,#1616));
#5980= IFCQUANTITYLENGTH('Width',$,$,30.00000000008);
#5981= IFCELEMENTQUANTITY('3xqF15ExnExvSV$rXNCDl6',#5,'BaseQuantities',$,$,(#5980));
#5982= IFCCARTESIANPOINT((40636.1696399369,-238.76131148119,15790.));
#5983= IFCAXIS2PLACEMENT3D(#5982,#9,#1670);
#5984= IFCLOCALPLACEMENT(#5977,#5983);
#5985= IFCEXTRUDEDAREASOLID(#1628,#1630,#9,150.001159459226);
#5986= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5985));
#5987= IFCSTYLEDITEM(#5985,(#1627),$);
#5988= IFCPRODUCTDEFINITIONSHAPE($,$,(#5986));
#5989= IFCBEAM('1Td1iR000tn34rDp0rCJ4s',#5,'PUL','PLT30*150','PLT30*150',#5984,#5988,'P/377(?)');
#5990= IFCQUANTITYLENGTH('Length',$,$,150.00115945944);
#5991= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0630004174053966);
#5992= IFCQUANTITYVOLUME('NetVolume',$,$,0.000675005217567512);
#5993= IFCQUANTITYWEIGHT('NetWeight',$,$,5.29879095790497);
#5994= IFCELEMENTQUANTITY('27VVFXm$D50eS7GIs7sTbP',#5,'BaseQuantities',$,$,(#5990,#5991,#5992,#5993));
#5995= IFCLOCALPLACEMENT(#30,#10);
#5996= IFCELEMENTASSEMBLY('1Td1iR000tnp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#5995,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#5997= IFCPROPERTYSET('2Q61VcOjL08PXgIwjDiKZH',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#1698,#1699,#1700,#5947,#1701));
#5998= IFCCARTESIANPOINT((40716.8561910801,-257.190864719634,15790.));
#5999= IFCAXIS2PLACEMENT3D(#5998,#1706,#1707);
#6000= IFCLOCALPLACEMENT(#5995,#5999);
#6001= IFCEXTRUDEDAREASOLID(#1719,#1721,#9,16.0000409062001);
#6002= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6001));
#6003= IFCSTYLEDITEM(#6001,(#1711),$);
#6004= IFCPRODUCTDEFINITIONSHAPE($,$,(#6002));
#6005= IFCBEAM('1Td1iR000to34rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#6000,#6004,'XX/0(?)');
#6006= IFCPROPERTYSET('3X9LJBfzv6QhG_MNsSmw9F',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#1740,#1741,#1742,#1743,#1744,#1940,#1941,#1942,#1748,#1749));
#6007= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161875317886);
#6008= IFCQUANTITYVOLUME('NetVolume',$,$,1.24707976977411E-005);
#6009= IFCELEMENTQUANTITY('180VGYhSTDQfs5NSwIyx1c',#5,'BaseQuantities',$,$,(#1751,#6007,#6008,#1754));
#6010= IFCLOCALPLACEMENT(#30,#10);
#6011= IFCELEMENTASSEMBLY('1Td1iR000top4rDp0rCJ4s',#5,'Steel Assembly',$,$,#6010,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#6012= IFCCARTESIANPOINT((40713.4878455301,-241.549277321979,15790.));
#6013= IFCAXIS2PLACEMENT3D(#6012,#1706,#1707);
#6014= IFCLOCALPLACEMENT(#6010,#6013);
#6015= IFCEXTRUDEDAREASOLID(#1719,#1721,#9,16.0000409061924);
#6016= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6015));
#6017= IFCSTYLEDITEM(#6015,(#1711),$);
#6018= IFCPRODUCTDEFINITIONSHAPE($,$,(#6016));
#6019= IFCBEAM('1Td1iR000tp34rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#6014,#6018,'XX/0(?)');
#6020= IFCPROPERTYSET('282i5s2DTFZQDosaUyA8H3',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#1740,#1741,#1742,#1743,#1744,#1745,#1746,#1942,#1748,#1749));
#6021= IFCQUANTITYLENGTH('Length',$,$,16.0000409062395);
#6022= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161875317797);
#6023= IFCQUANTITYVOLUME('NetVolume',$,$,1.24707976977352E-005);
#6024= IFCELEMENTQUANTITY('3sjuEn6qj9fv5CijMtknPY',#5,'BaseQuantities',$,$,(#6021,#6022,#6023,#1754));
#6025= IFCLOCALPLACEMENT(#30,#10);
#6026= IFCELEMENTASSEMBLY('1Td1iR000tpp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#6025,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#6027= IFCPROPERTYSET('3a16FNHZj4YfhTQmhkg3N4',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#1773,#1774,#1775,#5947,#1701));
#6028= IFCCARTESIANPOINT((40712.6453400033,-237.638892502498,15790.));
#6029= IFCAXIS2PLACEMENT3D(#6028,#1670,#1780);
#6030= IFCLOCALPLACEMENT(#6025,#6029);
#6031= IFCEXTRUDEDAREASOLID(#1783,#1785,#9,4.00000000000348);
#6032= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6031));
#6033= IFCSTYLEDITEM(#6031,(#1711),$);
#6034= IFCPRODUCTDEFINITIONSHAPE($,$,(#6032));
#6035= IFCBEAM('1Td1iR000tq34rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#6030,#6034,'XX/0(?)');
#6036= IFCQUANTITYLENGTH('Length',$,$,4.00000000001273);
#6037= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00180062582325924);
#6038= IFCQUANTITYVOLUME('NetVolume',$,$,3.93300000000862E-006);
#6039= IFCELEMENTQUANTITY('2HyABxo4jEggWfwIDZqLbx',#5,'BaseQuantities',$,$,(#6036,#6037,#6038,#1754));
#6040= IFCLOCALPLACEMENT(#30,#10);
#6041= IFCELEMENTASSEMBLY('1Td1iR000tqp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#6040,$,'R/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#6042= IFCPROPERTYSET('1Kx1hXqc9Eswv601ePl7PV',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#1812,#1813,#1814,#5947,#1815));
#6043= IFCCARTESIANPOINT((40725.1344111934,-295.638490283996,15790.));
#6044= IFCAXIS2PLACEMENT3D(#6043,#1820,#1821);
#6045= IFCLOCALPLACEMENT(#6040,#6044);
#6046= IFCEXTRUDEDAREASOLID(#1826,#1828,#9,370.000357476353);
#6047= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6046));
#6048= IFCSTYLEDITEM(#6046,(#1825),$);
#6049= IFCPRODUCTDEFINITIONSHAPE($,$,(#6047));
#6050= IFCBEAM('1Td1iR000tr34rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#6045,#6049,'P/0(?)');
#6051= IFCPROPERTYSET('3dcSqMLCnBzvdwZclBZy4X',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#1997,#1998,#1999,#1743,#1744,#2000,#2001,#3352,#1848,#2002));
#6052= IFCQUANTITYLENGTH('Length',$,$,370.000357476263);
#6053= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0232205665089687);
#6054= IFCQUANTITYVOLUME('NetVolume',$,$,0.000104651904724885);
#6055= IFCELEMENTQUANTITY('38PnZTvUrACeyShno8$szU',#5,'BaseQuantities',$,$,(#6052,#6053,#6054,#1754));
#6056= IFCCARTESIANPOINT((40569.9999731708,-444.15209193049,15798.));
#6057= IFCAXIS2PLACEMENT3D(#6056,#9,#8);
#6058= IFCLOCALPLACEMENT(#5870,#6057);
#6059= IFCCIRCLE(#1861,60.);
#6060= IFCTRIMMEDCURVE(#6059,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.71238896822843)),.F.,.PARAMETER.);
#6061= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#6060);
#6062= IFCCIRCLE(#1873,59.9999999999999);
#6063= IFCTRIMMEDCURVE(#6062,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.71237678795003)),.F.,.PARAMETER.);
#6064= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#6063);
#6065= IFCCARTESIANPOINT((-0.000700308378475289,199.999083600574));
#6066= IFCCARTESIANPOINT((-2.01341617867001E-006,339.998352050781));
#6067= IFCCARTESIANPOINT((-220.000244141302,339.998352051654));
#6068= IFCCARTESIANPOINT((-220.000228881439,-199.998779296002));
#6069= IFCCARTESIANPOINT((2.43044223680045E-006,-199.998779296875));
#6070= IFCPOLYLINE((#6065,#6066,#6067,#6068,#6069,#1882));
#6071= IFCCOMPOSITECURVESEGMENT(.DISCONTINUOUS.,.T.,#6070);
#6072= IFCCOMPOSITECURVE((#6061,#1870,#6064,#6071),.F.);
#6073= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL16*436',#6072);
#6074= IFCEXTRUDEDAREASOLID(#6073,#63,#9,16.);
#6075= IFCBOOLEANRESULT(.DIFFERENCE.,#6074,#1894);
#6076= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#6075));
#6077= IFCSTYLEDITEM(#6074,(#53),$);
#6078= IFCPRODUCTDEFINITIONSHAPE($,$,(#6076));
#6079= IFCPLATE('1Td1iR000tsp4rDp0rCJ4s',#5,'ANCHOR','PL16*436','PL16*436',#6058,#6078,'P/0(?)');
#6080= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(18.9088537417693),$);
#6081= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(29.5977597980171),$);
#6082= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(18.9088537417693),$);
#6083= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.00240877117729546),$);
#6084= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.00244018506177062),$);
#6085= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.00240877117729546),$);
#6086= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.150548198580968),$);
#6087= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(17.5314374329463),$);
#6088= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.331499386302562),$);
#6089= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.235650953805869),$);
#6090= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(436.392968430943),$);
#6091= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(539.997137564234),$);
#6092= IFCPROPERTYSET('1ajuRHo99E4gyTEIjJWZO9',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#5881,#6080,#6081,#6082,#6083,#6084,#6085,#6086,#6087,#6088,#6089,#6090,#94,#6091));
#6093= IFCQUANTITYLENGTH('Width',$,$,436.392968430943);
#6094= IFCQUANTITYAREA('NetArea',$,$,0.331499386302562);
#6095= IFCQUANTITYAREA('GrossArea',$,$,0.235650953805869);
#6096= IFCQUANTITYVOLUME('NetVolume',$,$,0.00240877117729546);
#6097= IFCQUANTITYVOLUME('GrossVolume',$,$,0.00244018506177062);
#6098= IFCELEMENTQUANTITY('1Emt32505C7hAZIVC9oQX9',#5,'BaseQuantities',$,$,(#6093,#6094,#6095,#100,#6096,#6097));
#6099= IFCLOCALPLACEMENT(#30,#10);
#6100= IFCELEMENTASSEMBLY('1Td1iR000ttZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#6099,$,'ANK/63(?)',.NOTDEFINED.,.RIGID_FRAME.);
#6101= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(2.46177073242223),$);
#6102= IFCPROPERTYSET('3JRqcCT3fF59YVz1L38t5O',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#6101,#1589,#1590,#39,#5873,#489));
#6103= IFCCARTESIANPOINT((40634.9987504166,-484.152103045623,15814.));
#6104= IFCAXIS2PLACEMENT3D(#6103,#7,#501);
#6105= IFCLOCALPLACEMENT(#6099,#6104);
#6106= IFCRECTANGLEPROFILEDEF(.AREA.,'PLT16*140',#197,16.,140.);
#6107= IFCCARTESIANPOINT((140.000610351578,0.,-7.27595761418343E-012));
#6108= IFCAXIS2PLACEMENT3D(#6107,#185,#501);
#6109= IFCEXTRUDEDAREASOLID(#6106,#6108,#9,140.000610351578);
#6110= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6109));
#6111= IFCSTYLEDITEM(#6109,(#499),$);
#6112= IFCPRODUCTDEFINITIONSHAPE($,$,(#6110));
#6113= IFCBEAM('1Td1iR000ttp4rDp0rCJ4s',#5,'ANKRAJ','PLT16*140','PLT16*140',#6105,#6112,'P/379(?)');
#6114= IFCBEAMTYPE('28dNdyZnT1PBJTNwuVVmg5',#5,'PLT16*140',$,$,$,$,$,$,.NOTDEFINED.);
#6115= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PLT16*140'),$);
#6116= IFCPROPERTYSET('1yiux7w1DFUh$38vCa0KpO',#5,'Tekla Common','Common Properties to Shared building elements',(#1598,#1599,#512,#513,#74,#75,#919,#515,#78,#6115,#80));
#6117= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(2.46177073242223),$);
#6118= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(2.46177073242223),$);
#6119= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(2.46177073242293),$);
#6120= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(2.46177073242223),$);
#6121= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000313601367187545),$);
#6122= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000313601367187545),$);
#6123= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000313601367187545),$);
#6124= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.0196000854492211),$);
#6125= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(19.5632313746403),$);
#6126= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0481601904296938),$);
#6127= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0481601904296938),$);
#6128= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(140.000000000007),$);
#6129= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(140.000610351615),$);
#6130= IFCPROPERTYSET('15QczDlT54FeIH5EUZRQcB',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#6117,#6118,#6119,#6120,#6121,#6122,#6123,#6124,#6125,#6126,#6127,#6128,#94,#6129));
#6131= IFCQUANTITYLENGTH('Length',$,$,140.000610351615);
#6132= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0481601904296938);
#6133= IFCQUANTITYVOLUME('NetVolume',$,$,0.000313601367187545);
#6134= IFCQUANTITYWEIGHT('NetWeight',$,$,2.46177073242223);
#6135= IFCELEMENTQUANTITY('0YN$pVP2T4aO9$Wc6hSXox',#5,'BaseQuantities',$,$,(#6131,#6132,#6133,#6134));
#6136= IFCLOCALPLACEMENT(#30,#10);
#6137= IFCELEMENTASSEMBLY('1Td1iR000tuZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#6136,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#6138= IFCCARTESIANPOINT((40283.1442023679,-257.190838696386,15790.));
#6139= IFCAXIS2PLACEMENT3D(#6138,#1928,#1929);
#6140= IFCLOCALPLACEMENT(#6136,#6139);
#6141= IFCEXTRUDEDAREASOLID(#1719,#1721,#9,16.0000409061977);
#6142= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6141));
#6143= IFCSTYLEDITEM(#6141,(#1711),$);
#6144= IFCPRODUCTDEFINITIONSHAPE($,$,(#6142));
#6145= IFCBEAM('1Td1iR000tup4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#6140,#6144,'XX/0(?)');
#6146= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(16.0000409063105),$);
#6147= IFCPROPERTYSET('2_XxScQ5P2beD0pXRqEjJr',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#1740,#1741,#1742,#1743,#1744,#1745,#1746,#1747,#1748,#6146));
#6148= IFCQUANTITYLENGTH('Length',$,$,16.0000409063105);
#6149= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161875316913);
#6150= IFCQUANTITYVOLUME('NetVolume',$,$,1.24707976976942E-005);
#6151= IFCELEMENTQUANTITY('3SbRjroS12qxiJsexUkOPN',#5,'BaseQuantities',$,$,(#6148,#6149,#6150,#1754));
#6152= IFCLOCALPLACEMENT(#30,#10);
#6153= IFCELEMENTASSEMBLY('1Td1iR000tvZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#6152,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#6154= IFCCARTESIANPOINT((40286.5125497949,-241.549251702941,15790.));
#6155= IFCAXIS2PLACEMENT3D(#6154,#1928,#1929);
#6156= IFCLOCALPLACEMENT(#6152,#6155);
#6157= IFCEXTRUDEDAREASOLID(#1719,#1721,#9,16.0000409061906);
#6158= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6157));
#6159= IFCSTYLEDITEM(#6157,(#1711),$);
#6160= IFCPRODUCTDEFINITIONSHAPE($,$,(#6158));
#6161= IFCBEAM('1Td1iR000tvp4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#6156,#6160,'XX/0(?)');
#6162= IFCQUANTITYLENGTH('Length',$,$,16.0000409063014);
#6163= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161875316837);
#6164= IFCQUANTITYVOLUME('NetVolume',$,$,1.24707976976886E-005);
#6165= IFCELEMENTQUANTITY('1o9x76ieTFDxI7TH0n2mAO',#5,'BaseQuantities',$,$,(#6162,#6163,#6164,#1754));
#6166= IFCLOCALPLACEMENT(#30,#10);
#6167= IFCELEMENTASSEMBLY('1Td1iR000twZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#6166,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#6168= IFCCARTESIANPOINT((40287.355055791,-237.638866984563,15790.));
#6169= IFCAXIS2PLACEMENT3D(#6168,#1621,#1966);
#6170= IFCLOCALPLACEMENT(#6166,#6169);
#6171= IFCEXTRUDEDAREASOLID(#1783,#1785,#9,4.00000000000661);
#6172= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6171));
#6173= IFCSTYLEDITEM(#6171,(#1711),$);
#6174= IFCPRODUCTDEFINITIONSHAPE($,$,(#6172));
#6175= IFCBEAM('1Td1iR000twp4rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#6170,#6174,'XX/0(?)');
#6176= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(3.93300000001544E-006),$);
#6177= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(3.93300000001544E-006),$);
#6178= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(3.93300000001544E-006),$);
#6179= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.00180062582326103),$);
#6180= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.00180062582326103),$);
#6181= IFCPROPERTYSET('2IJlFf_FXCRgQxsk5W1jtA',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#6176,#6177,#6178,#1743,#1744,#6179,#6180,#1979,#1803,#1804));
#6182= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00180062582326103);
#6183= IFCQUANTITYVOLUME('NetVolume',$,$,3.93300000001544E-006);
#6184= IFCELEMENTQUANTITY('1kI2_6jBv2Cfkh5qhg4tB0',#5,'BaseQuantities',$,$,(#3630,#6182,#6183,#1754));
#6185= IFCLOCALPLACEMENT(#30,#10);
#6186= IFCELEMENTASSEMBLY('1Td1iR000txZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#6185,$,'R/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#6187= IFCCARTESIANPOINT((40274.8659776408,-295.638463267341,15790.));
#6188= IFCAXIS2PLACEMENT3D(#6187,#1988,#1989);
#6189= IFCLOCALPLACEMENT(#6185,#6188);
#6190= IFCEXTRUDEDAREASOLID(#1826,#1828,#9,370.000357476348);
#6191= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6190));
#6192= IFCSTYLEDITEM(#6190,(#1825),$);
#6193= IFCPRODUCTDEFINITIONSHAPE($,$,(#6191));
#6194= IFCBEAM('1Td1iR000txp4rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#6189,#6193,'P/0(?)');
#6195= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000104651904725289),$);
#6196= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000104651904725289),$);
#6197= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000104651904725289),$);
#6198= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.023220566509026),$);
#6199= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.023220566509026),$);
#6200= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(370.00035747669),$);
#6201= IFCPROPERTYSET('27KLcLn31AEPVVeKRhovdU',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#6195,#6196,#6197,#1743,#1744,#6198,#6199,#1847,#1848,#6200));
#6202= IFCQUANTITYLENGTH('Length',$,$,370.00035747669);
#6203= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.023220566509026);
#6204= IFCQUANTITYVOLUME('NetVolume',$,$,0.000104651904725289);
#6205= IFCELEMENTQUANTITY('0zkvqeUHT0TuZx6u2XNF7c',#5,'BaseQuantities',$,$,(#6202,#6203,#6204,#1754));
#6206= IFCLOCALPLACEMENT(#30,#10);
#6207= IFCELEMENTASSEMBLY('1Td1iR000tyZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#6206,$,'ANK/63(?)',.NOTDEFINED.,.RIGID_FRAME.);
#6208= IFCCARTESIANPOINT((40365.0016157955,-484.152086845482,15814.));
#6209= IFCAXIS2PLACEMENT3D(#6208,#7,#501);
#6210= IFCLOCALPLACEMENT(#6206,#6209);
#6211= IFCEXTRUDEDAREASOLID(#6106,#6108,#9,140.000610351576);
#6212= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6211));
#6213= IFCSTYLEDITEM(#6211,(#499),$);
#6214= IFCPRODUCTDEFINITIONSHAPE($,$,(#6212));
#6215= IFCBEAM('1Td1iR000typ4rDp0rCJ4s',#5,'ANKRAJ','PLT16*140','PLT16*140',#6210,#6214,'P/379(?)');
#6216= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(2.46177073242737),$);
#6217= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(19.5632313746404),$);
#6218= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(140.000610351875),$);
#6219= IFCPROPERTYSET('3Vnr7Iqp51afNauCZGPsFD',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#6117,#6118,#6216,#6120,#6121,#6122,#6123,#6124,#6217,#6126,#6127,#6128,#94,#6218));
#6220= IFCQUANTITYLENGTH('Length',$,$,140.000610351875);
#6221= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0481601904296917);
#6222= IFCQUANTITYVOLUME('NetVolume',$,$,0.00031360136718753);
#6223= IFCQUANTITYWEIGHT('NetWeight',$,$,2.46177073242211);
#6224= IFCELEMENTQUANTITY('0iOkQZnp14de8FylUKNgvA',#5,'BaseQuantities',$,$,(#6220,#6221,#6222,#6223));
#6225= IFCCARTESIANPOINT((40288.4976961945,-232.330062517137,10590.));
#6226= IFCAXIS2PLACEMENT3D(#6225,#596,#597);
#6227= IFCLOCALPLACEMENT(#30,#6226);
#6228= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#6229= IFCEXTRUDEDAREASOLID(#6228,#602,#9,30.1000000000098);
#6230= IFCSTYLEDITEM(#6229,(#195),$);
#6231= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6229));
#6232= IFCREPRESENTATIONMAP(#10,#6231);
#6233= IFCMAPPEDITEM(#6232,#247);
#6234= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#6233));
#6235= IFCPRODUCTDEFINITIONSHAPE($,$,(#6234));
#6236= IFCMECHANICALFASTENER('1Td1iR000vYZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#6227,#6235,'ID5d9c1b1b-0000-398a-3135-373035313136',20.,30.);
#6237= IFCCARTESIANPOINT((40705.1872659515,-203.002074025752,10590.));
#6238= IFCAXIS2PLACEMENT3D(#6237,#9,#620);
#6239= IFCLOCALPLACEMENT(#30,#6238);
#6240= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,71.);
#6241= IFCEXTRUDEDAREASOLID(#6240,#625,#9,30.1063464563373);
#6242= IFCSTYLEDITEM(#6241,(#195),$);
#6243= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6241));
#6244= IFCREPRESENTATIONMAP(#10,#6243);
#6245= IFCMAPPEDITEM(#6244,#247);
#6246= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#6245));
#6247= IFCPRODUCTDEFINITIONSHAPE($,$,(#6246));
#6248= IFCMECHANICALFASTENER('1Td1iR000vZJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#6239,#6247,'ID5d9c1b1b-0000-398d-3135-373035313136',20.,30.0063457489014);
#6249= IFCCARTESIANPOINT((40711.502262432,-232.330074783567,10590.));
#6250= IFCAXIS2PLACEMENT3D(#6249,#9,#640);
#6251= IFCLOCALPLACEMENT(#30,#6250);
#6252= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#6253= IFCEXTRUDEDAREASOLID(#6252,#602,#9,30.1000000000079);
#6254= IFCSTYLEDITEM(#6253,(#195),$);
#6255= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6253));
#6256= IFCREPRESENTATIONMAP(#10,#6255);
#6257= IFCMAPPEDITEM(#6256,#247);
#6258= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#6257));
#6259= IFCPRODUCTDEFINITIONSHAPE($,$,(#6258));
#6260= IFCMECHANICALFASTENER('1Td1iR000va34rDp0rCJ4s',#5,'Bolt assembly',$,$,#6251,#6259,'ID5d9c1b1b-0000-3990-3135-373035313136',20.,30.);
#6261= IFCCARTESIANPOINT((40294.8131339993,-203.002049402811,10590.));
#6262= IFCAXIS2PLACEMENT3D(#6261,#596,#653);
#6263= IFCLOCALPLACEMENT(#30,#6262);
#6264= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,71.);
#6265= IFCEXTRUDEDAREASOLID(#6264,#658,#9,30.1061745233263);
#6266= IFCSTYLEDITEM(#6265,(#195),$);
#6267= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6265));
#6268= IFCREPRESENTATIONMAP(#10,#6267);
#6269= IFCMAPPEDITEM(#6268,#247);
#6270= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#6269));
#6271= IFCPRODUCTDEFINITIONSHAPE($,$,(#6270));
#6272= IFCMECHANICALFASTENER('1Td1iR000vap4rDp0rCJ4s',#5,'Bolt assembly',$,$,#6263,#6271,'ID5d9c1b1b-0000-3993-3135-373035313136',20.,30.0061740875244);
#6273= IFCCARTESIANPOINT((40634.9983581212,-554.153090053148,10639.995));
#6274= IFCAXIS2PLACEMENT3D(#6273,#501,#185);
#6275= IFCLOCALPLACEMENT(#30,#6274);
#6276= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,16.5);
#6277= IFCEXTRUDEDAREASOLID(#6276,#4638,#9,16.1);
#6278= IFCSTYLEDITEM(#6277,(#195),$);
#6279= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,16.5);
#6280= IFCEXTRUDEDAREASOLID(#6279,#4643,#9,15.9999999999998);
#6281= IFCSTYLEDITEM(#6280,(#195),$);
#6282= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4660);
#6283= IFCEXTRUDEDAREASOLID(#6282,#4663,#9,16.0000000000001);
#6284= IFCSTYLEDITEM(#6283,(#195),$);
#6285= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4672);
#6286= IFCEXTRUDEDAREASOLID(#6285,#4675,#9,19.8);
#6287= IFCSTYLEDITEM(#6286,(#558),$);
#6288= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,15.);
#6289= IFCEXTRUDEDAREASOLID(#6288,#4680,#9,90.);
#6290= IFCSTYLEDITEM(#6289,(#558),$);
#6291= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,28.);
#6292= IFCEXTRUDEDAREASOLID(#6291,#4685,#9,8.);
#6293= IFCSTYLEDITEM(#6292,(#558),$);
#6294= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4694);
#6295= IFCEXTRUDEDAREASOLID(#6294,#4697,#9,24.);
#6296= IFCSTYLEDITEM(#6295,(#558),$);
#6297= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6277,#6280,#6283,#6286,#6289,#6292,#6295));
#6298= IFCREPRESENTATIONMAP(#10,#6297);
#6299= IFCMAPPEDITEM(#6298,#247);
#6300= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#6299));
#6301= IFCPRODUCTDEFINITIONSHAPE($,$,(#6300));
#6302= IFCMECHANICALFASTENER('1Td1iR000vbZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#6275,#6301,'ID5d9c1b1b-0000-3996-3135-373035313136',30.,90.);
#6303= IFCCARTESIANPOINT((40634.9988455077,-554.152715152363,10587.999));
#6304= IFCAXIS2PLACEMENT3D(#6303,#501,#185);
#6305= IFCLOCALPLACEMENT(#30,#6304);
#6306= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,40.);
#6307= IFCEXTRUDEDAREASOLID(#6306,#561,#9,16.0999999999998);
#6308= IFCSTYLEDITEM(#6307,(#195),$);
#6309= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6307));
#6310= IFCREPRESENTATIONMAP(#10,#6309);
#6311= IFCMAPPEDITEM(#6310,#247);
#6312= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#6311));
#6313= IFCPRODUCTDEFINITIONSHAPE($,$,(#6312));
#6314= IFCMECHANICALFASTENER('1Td1iR000vcJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#6305,#6313,'ID5d9c1b1b-0000-3999-3135-373035313136',30.,16.);
#6315= IFCCARTESIANPOINT((40365.0017174869,-554.152698952219,10587.999));
#6316= IFCAXIS2PLACEMENT3D(#6315,#8,#7);
#6317= IFCLOCALPLACEMENT(#30,#6316);
#6318= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,40.);
#6319= IFCEXTRUDEDAREASOLID(#6318,#561,#9,16.0999999999999);
#6320= IFCSTYLEDITEM(#6319,(#195),$);
#6321= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6319));
#6322= IFCREPRESENTATIONMAP(#10,#6321);
#6323= IFCMAPPEDITEM(#6322,#247);
#6324= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#6323));
#6325= IFCPRODUCTDEFINITIONSHAPE($,$,(#6324));
#6326= IFCMECHANICALFASTENER('1Td1iR000vd34rDp0rCJ4s',#5,'Bolt assembly',$,$,#6317,#6325,'ID5d9c1b1b-0000-399c-3135-373035313136',30.,16.);
#6327= IFCCARTESIANPOINT((40365.0019996906,-554.153073853048,10639.995));
#6328= IFCAXIS2PLACEMENT3D(#6327,#8,#7);
#6329= IFCLOCALPLACEMENT(#30,#6328);
#6330= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,16.5);
#6331= IFCEXTRUDEDAREASOLID(#6330,#4663,#9,16.);
#6332= IFCSTYLEDITEM(#6331,(#195),$);
#6333= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,16.5);
#6334= IFCEXTRUDEDAREASOLID(#6333,#4643,#9,15.9999999999999);
#6335= IFCSTYLEDITEM(#6334,(#195),$);
#6336= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,16.5);
#6337= IFCEXTRUDEDAREASOLID(#6336,#4638,#9,16.1);
#6338= IFCSTYLEDITEM(#6337,(#195),$);
#6339= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4672);
#6340= IFCEXTRUDEDAREASOLID(#6339,#4675,#9,19.8);
#6341= IFCSTYLEDITEM(#6340,(#558),$);
#6342= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,15.);
#6343= IFCEXTRUDEDAREASOLID(#6342,#4680,#9,90.);
#6344= IFCSTYLEDITEM(#6343,(#558),$);
#6345= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,28.);
#6346= IFCEXTRUDEDAREASOLID(#6345,#4685,#9,8.);
#6347= IFCSTYLEDITEM(#6346,(#558),$);
#6348= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4694);
#6349= IFCEXTRUDEDAREASOLID(#6348,#4697,#9,24.);
#6350= IFCSTYLEDITEM(#6349,(#558),$);
#6351= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6331,#6334,#6337,#6340,#6343,#6346,#6349));
#6352= IFCREPRESENTATIONMAP(#10,#6351);
#6353= IFCMAPPEDITEM(#6352,#247);
#6354= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#6353));
#6355= IFCPRODUCTDEFINITIONSHAPE($,$,(#6354));
#6356= IFCMECHANICALFASTENER('1Td1iR000vdp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#6329,#6355,'ID5d9c1b1b-0000-399f-3135-373035313136',30.,90.);
#6357= IFCCARTESIANPOINT((32534.9983581212,-554.153090053148,10639.995));
#6358= IFCAXIS2PLACEMENT3D(#6357,#501,#185);
#6359= IFCLOCALPLACEMENT(#30,#6358);
#6360= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,16.5);
#6361= IFCEXTRUDEDAREASOLID(#6360,#4638,#9,16.1);
#6362= IFCSTYLEDITEM(#6361,(#195),$);
#6363= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,16.5);
#6364= IFCEXTRUDEDAREASOLID(#6363,#4643,#9,15.9999999999999);
#6365= IFCSTYLEDITEM(#6364,(#195),$);
#6366= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4660);
#6367= IFCEXTRUDEDAREASOLID(#6366,#4663,#9,15.9999999999995);
#6368= IFCSTYLEDITEM(#6367,(#195),$);
#6369= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4672);
#6370= IFCEXTRUDEDAREASOLID(#6369,#4675,#9,19.8);
#6371= IFCSTYLEDITEM(#6370,(#558),$);
#6372= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,15.);
#6373= IFCEXTRUDEDAREASOLID(#6372,#4680,#9,90.);
#6374= IFCSTYLEDITEM(#6373,(#558),$);
#6375= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,28.);
#6376= IFCEXTRUDEDAREASOLID(#6375,#4685,#9,8.);
#6377= IFCSTYLEDITEM(#6376,(#558),$);
#6378= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4694);
#6379= IFCEXTRUDEDAREASOLID(#6378,#4697,#9,24.);
#6380= IFCSTYLEDITEM(#6379,(#558),$);
#6381= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6361,#6364,#6367,#6370,#6373,#6376,#6379));
#6382= IFCREPRESENTATIONMAP(#10,#6381);
#6383= IFCMAPPEDITEM(#6382,#247);
#6384= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#6383));
#6385= IFCPRODUCTDEFINITIONSHAPE($,$,(#6384));
#6386= IFCMECHANICALFASTENER('1Td1iR000vhZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#6359,#6385,'ID5d9c1b1b-0000-39ae-3135-373035313136',30.,90.);
#6387= IFCLOCALPLACEMENT(#30,#10);
#6388= IFCELEMENTASSEMBLY('1Td1iR001xLJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#6387,$,'B/126(?)',.NOTDEFINED.,.RIGID_FRAME.);
#6389= IFCPROPERTYSET('0krWwp0T95Xh4m3$umD9X3',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#5196,#1218,#1219,#890,#5197,#5198));
#6390= IFCCARTESIANPOINT((40276.9951469627,-664.132537913409,10573.9999999996));
#6391= IFCAXIS2PLACEMENT3D(#6390,#5201,#5202);
#6392= IFCLOCALPLACEMENT(#6387,#6391);
#6393= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5213));
#6394= IFCPRODUCTDEFINITIONSHAPE($,$,(#6393));
#6395= IFCDISCRETEACCESSORY('1Td1iR000xg34rDp0rCJ4s',#5,'DETAY','PL16*58','PL16*58',#6392,#6394,'P/428(?)');
#6396= IFCPROPERTYSET('02H8tznOX9R9mBpX3exO$1',#5,'Tekla Common','Common Properties to Shared building elements',(#1227,#1228,#5218,#5219,#74,#75,#919,#77,#78,#920,#921));
#6397= IFCCARTESIANPOINT((40290.0045908795,-484.156332298588,10526.0061065627));
#6398= IFCAXIS2PLACEMENT3D(#6397,#9,#5239);
#6399= IFCLOCALPLACEMENT(#6387,#6398);
#6400= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5249));
#6401= IFCPRODUCTDEFINITIONSHAPE($,$,(#6400));
#6402= IFCDISCRETEACCESSORY('1Td1iR000xh34rDp0rCJ4s',#5,'ANKRAJ','L20*3','L20*3',#6399,#6401,'P/477(?)');
#6403= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +10.536'),$);
#6404= IFCPROPERTYSET('3HuK5E8Ub7EeBL_RMV5KN6',#5,'Tekla Common','Common Properties to Shared building elements',(#1227,#6403,#5255,#5219,#74,#75,#919,#5256,#78,#5257,#80));
#6405= IFCCARTESIANPOINT((40290.0009714322,-654.152372447439,10526.0061065627));
#6406= IFCAXIS2PLACEMENT3D(#6405,#5278,#5279);
#6407= IFCLOCALPLACEMENT(#6387,#6406);
#6408= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5284));
#6409= IFCPRODUCTDEFINITIONSHAPE($,$,(#6408));
#6410= IFCDISCRETEACCESSORY('1Td1iR000xi34rDp0rCJ4s',#5,'ANKRAJ','L20*3','L20*3',#6407,#6409,'P/477(?)');
#6411= IFCCARTESIANPOINT((40467.505011749,-474.169997602407,10508.));
#6412= IFCAXIS2PLACEMENT3D(#6411,#9,#185);
#6413= IFCLOCALPLACEMENT(#6387,#6412);
#6414= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5313));
#6415= IFCPRODUCTDEFINITIONSHAPE($,$,(#6414));
#6416= IFCDISCRETEACCESSORY('1Td1iR000xj34rDp0rCJ4s',#5,'DETAY','PL16*190','PL16*190',#6413,#6415,'P/424(?)');
#6417= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +10.500'),$);
#6418= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +10.516'),$);
#6419= IFCPROPERTYSET('3STe9SwXz4X9nqKgFpRT5X',#5,'Tekla Common','Common Properties to Shared building elements',(#6417,#6418,#5319,#5219,#74,#75,#919,#77,#78,#161,#921));
#6420= IFCCARTESIANPOINT((40467.0011469627,-664.132537913409,10573.9999999996));
#6421= IFCAXIS2PLACEMENT3D(#6420,#5201,#5202);
#6422= IFCLOCALPLACEMENT(#6387,#6421);
#6423= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5213));
#6424= IFCPRODUCTDEFINITIONSHAPE($,$,(#6423));
#6425= IFCDISCRETEACCESSORY('1Td1iR000xk34rDp0rCJ4s',#5,'DETAY','PL16*58','PL16*58',#6422,#6424,'P/428(?)');
#6426= IFCCARTESIANPOINT((40723.0048530373,-664.132537913409,10573.9999999996));
#6427= IFCAXIS2PLACEMENT3D(#6426,#5347,#5202);
#6428= IFCLOCALPLACEMENT(#1216,#6427);
#6429= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5213));
#6430= IFCPRODUCTDEFINITIONSHAPE($,$,(#6429));
#6431= IFCDISCRETEACCESSORY('1Td1iR000xl34rDp0rCJ4s',#5,'DETAY','PL16*58','PL16*58',#6428,#6430,'P/428(?)');
#6432= IFCPROPERTYSET('3ZO2LNheLBBeUIyWz9Y2IS',#5,'Tekla Common','Common Properties to Shared building elements',(#1227,#1228,#5218,#918,#74,#75,#919,#77,#78,#920,#921));
#6433= IFCCARTESIANPOINT((40545.995053407,-484.152286737816,10526.0061065627));
#6434= IFCAXIS2PLACEMENT3D(#6433,#9,#5361);
#6435= IFCLOCALPLACEMENT(#1216,#6434);
#6436= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5364));
#6437= IFCPRODUCTDEFINITIONSHAPE($,$,(#6436));
#6438= IFCDISCRETEACCESSORY('1Td1iR000xm34rDp0rCJ4s',#5,'ANKRAJ','L20*3','L20*3',#6435,#6437,'P/477(?)');
#6439= IFCPROPERTYSET('143bu12Yf1Lew7x3u0GbVe',#5,'Tekla Common','Common Properties to Shared building elements',(#1227,#6403,#5255,#918,#74,#75,#919,#5256,#78,#5257,#80));
#6440= IFCCARTESIANPOINT((40545.9983058544,-654.148784767628,10526.0061065627));
#6441= IFCAXIS2PLACEMENT3D(#6440,#5377,#5378);
#6442= IFCLOCALPLACEMENT(#1216,#6441);
#6443= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5284));
#6444= IFCPRODUCTDEFINITIONSHAPE($,$,(#6443));
#6445= IFCDISCRETEACCESSORY('1Td1iR000xn34rDp0rCJ4s',#5,'ANKRAJ','L20*3','L20*3',#6442,#6444,'P/477(?)');
#6446= IFCCARTESIANPOINT((40532.494988251,-474.169997602407,10508.));
#6447= IFCAXIS2PLACEMENT3D(#6446,#596,#7);
#6448= IFCLOCALPLACEMENT(#1216,#6447);
#6449= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5313));
#6450= IFCPRODUCTDEFINITIONSHAPE($,$,(#6449));
#6451= IFCDISCRETEACCESSORY('1Td1iR000xo34rDp0rCJ4s',#5,'DETAY','PL16*190','PL16*190',#6448,#6450,'P/424(?)');
#6452= IFCPROPERTYSET('0XAqVuM4T5RfI7mulpX0vB',#5,'Tekla Common','Common Properties to Shared building elements',(#6417,#6418,#5319,#918,#74,#75,#919,#77,#78,#161,#921));
#6453= IFCLOCALPLACEMENT(#30,#10);
#6454= IFCELEMENTASSEMBLY('1Td1iR000_2p4rDp0rCJ4s',#5,'Steel Assembly',$,$,#6453,$,'A/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#6455= IFCPROPERTYSET('12hk2Li4n4qv4JJcdYcClq',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#5872,#1246,#1247,#989,#5873,#990));
#6456= IFCCARTESIANPOINT((40430.0009742969,-409.152085224178,10507.));
#6457= IFCAXIS2PLACEMENT3D(#6456,#9,#7);
#6458= IFCLOCALPLACEMENT(#6453,#6457);
#6459= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1002));
#6460= IFCPRODUCTDEFINITIONSHAPE($,$,(#6459));
#6461= IFCDISCRETEACCESSORY('1Td1iR000xop4rDp0rCJ4s',#5,'PLATE','PL16*140','PL16*140',#6458,#6460,'P/0(?)');
#6462= IFCCARTESIANPOINT((40543.9994010579,-401.152088433781,10590.));
#6463= IFCAXIS2PLACEMENT3D(#6462,#501,#185);
#6464= IFCLOCALPLACEMENT(#6453,#6463);
#6465= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1046));
#6466= IFCPRODUCTDEFINITIONSHAPE($,$,(#6465));
#6467= IFCDISCRETEACCESSORY('1Td1iR000xpZ4rDp0rCJ4s',#5,'PLATE','PL16*75','PL16*75',#6464,#6466,'P/0(?)');
#6468= IFCCARTESIANPOINT((40551.9994009154,-409.152092881741,10514.995));
#6469= IFCAXIS2PLACEMENT3D(#6468,#185,#9);
#6470= IFCLOCALPLACEMENT(#6453,#6469);
#6471= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1081));
#6472= IFCPRODUCTDEFINITIONSHAPE($,$,(#6471));
#6473= IFCDISCRETEACCESSORY('1Td1iR000xqJ4rDp0rCJ4s',#5,'PLATE','PL16*75','PL16*75',#6470,#6472,'P/0(?)');
#6474= IFCCARTESIANPOINT((40448.0009742969,-409.152086581707,10514.995));
#6475= IFCAXIS2PLACEMENT3D(#6474,#185,#9);
#6476= IFCLOCALPLACEMENT(#6453,#6475);
#6477= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1081));
#6478= IFCPRODUCTDEFINITIONSHAPE($,$,(#6477));
#6479= IFCDISCRETEACCESSORY('1Td1iR000xr34rDp0rCJ4s',#5,'PLATE','PL16*75','PL16*75',#6476,#6478,'P/0(?)');
#6480= IFCCARTESIANPOINT((40532.9988530373,-664.132537913409,10573.9999999996));
#6481= IFCAXIS2PLACEMENT3D(#6480,#5347,#5202);
#6482= IFCLOCALPLACEMENT(#1216,#6481);
#6483= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5213));
#6484= IFCPRODUCTDEFINITIONSHAPE($,$,(#6483));
#6485= IFCDISCRETEACCESSORY('1Td1iR000xs34rDp0rCJ4s',#5,'DETAY','PL16*58','PL16*58',#6482,#6484,'P/428(?)');
#6486= IFCCARTESIANPOINT((40171.0886298035,-157.192275561193,10590.));
#6487= IFCAXIS2PLACEMENT3D(#6486,#9,#1125);
#6488= IFCLOCALPLACEMENT(#6453,#6487);
#6489= IFCBOOLEANRESULT(.DIFFERENCE.,#1135,#5912);
#6490= IFCCIRCLE(#1138,26.5157137783024);
#6491= IFCTRIMMEDCURVE(#6490,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.42863508545979)),.F.,.PARAMETER.);
#6492= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#6491);
#6493= IFCCOMPOSITECURVE((#6492,#1145),.F.);
#6494= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#6493);
#6495= IFCEXTRUDEDAREASOLID(#6494,#1162,#9,100.);
#6496= IFCBOOLEANRESULT(.DIFFERENCE.,#6489,#6495);
#6497= IFCCIRCLE(#1138,26.5157137785383);
#6498= IFCTRIMMEDCURVE(#6497,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.42863508546071)),.F.,.PARAMETER.);
#6499= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#6498);
#6500= IFCCOMPOSITECURVE((#6499,#1145),.F.);
#6501= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#6500);
#6502= IFCEXTRUDEDAREASOLID(#6501,#1173,#9,100.);
#6503= IFCBOOLEANRESULT(.DIFFERENCE.,#6496,#6502);
#6504= IFCBOOLEANRESULT(.DIFFERENCE.,#6503,#5933);
#6505= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#6504));
#6506= IFCPRODUCTDEFINITIONSHAPE($,$,(#6505));
#6507= IFCDISCRETEACCESSORY('1Td1iR000xvp4rDp0rCJ4s',#5,'ANKRAJ','PLT30*240','PLT30*240',#6488,#6506,'P/370(?)');
#6508= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(9.90376532231765),$);
#6509= IFCPROPERTYSET('2F$bncSwf9jgx10PKzAxMG',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#5881,#3000,#1198,#3001,#3002,#1201,#3004,#1203,#6508,#3006,#1206,#1207,#1208,#1209));
#6510= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.374594953106507);
#6511= IFCQUANTITYVOLUME('NetVolume',$,$,0.00481827878120545);
#6512= IFCQUANTITYWEIGHT('NetWeight',$,$,37.8234884324628);
#6513= IFCELEMENTQUANTITY('1uUSqSbvvA6hjrTROTkXFD',#5,'BaseQuantities',$,$,(#1211,#6510,#6511,#6512));
#6514= IFCCARTESIANPOINT((32623.0048530373,-664.132537913409,10573.9999999996));
#6515= IFCAXIS2PLACEMENT3D(#6514,#5347,#5202);
#6516= IFCLOCALPLACEMENT(#6387,#6515);
#6517= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5213));
#6518= IFCPRODUCTDEFINITIONSHAPE($,$,(#6517));
#6519= IFCDISCRETEACCESSORY('1Td1iR000x$p4rDp0rCJ4s',#5,'DETAY','PL16*58','PL16*58',#6516,#6518,'P/428(?)');
#6520= IFCCARTESIANPOINT((32445.995053407,-484.152286737816,10526.0061065627));
#6521= IFCAXIS2PLACEMENT3D(#6520,#9,#5361);
#6522= IFCLOCALPLACEMENT(#6387,#6521);
#6523= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5429));
#6524= IFCPRODUCTDEFINITIONSHAPE($,$,(#6523));
#6525= IFCDISCRETEACCESSORY('1Td1iR000y0p4rDp0rCJ4s',#5,'ANKRAJ','L20*3','L20*3',#6522,#6524,'P/477(?)');
#6526= IFCCARTESIANPOINT((32445.9983058544,-654.148784767628,10526.0061065627));
#6527= IFCAXIS2PLACEMENT3D(#6526,#5377,#5378);
#6528= IFCLOCALPLACEMENT(#6387,#6527);
#6529= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5284));
#6530= IFCPRODUCTDEFINITIONSHAPE($,$,(#6529));
#6531= IFCDISCRETEACCESSORY('1Td1iR000y1p4rDp0rCJ4s',#5,'ANKRAJ','L20*3','L20*3',#6528,#6530,'P/477(?)');
#6532= IFCCARTESIANPOINT((32432.494988251,-474.169997602407,10508.));
#6533= IFCAXIS2PLACEMENT3D(#6532,#596,#7);
#6534= IFCLOCALPLACEMENT(#6387,#6533);
#6535= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5313));
#6536= IFCPRODUCTDEFINITIONSHAPE($,$,(#6535));
#6537= IFCDISCRETEACCESSORY('1Td1iR000y2p4rDp0rCJ4s',#5,'DETAY','PL16*190','PL16*190',#6534,#6536,'P/424(?)');
#6538= IFCCARTESIANPOINT((46619.492680469,-474.170000153068,10574.00002734));
#6539= IFCAXIS2PLACEMENT3D(#6538,#185,#596);
#6540= IFCLOCALPLACEMENT(#1216,#6539);
#6541= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5477));
#6542= IFCPRODUCTDEFINITIONSHAPE($,$,(#6541));
#6543= IFCDISCRETEACCESSORY('1Td1iR000yC34rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#6540,#6542,'P/431(?)');
#6544= IFCCARTESIANPOINT((40949.4926804679,-474.170000076998,10574.00002734));
#6545= IFCAXIS2PLACEMENT3D(#6544,#185,#596);
#6546= IFCLOCALPLACEMENT(#1216,#6545);
#6547= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5477));
#6548= IFCPRODUCTDEFINITIONSHAPE($,$,(#6547));
#6549= IFCDISCRETEACCESSORY('1Td1iR000yD34rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#6546,#6548,'P/431(?)');
#6550= IFCCARTESIANPOINT((43379.4926804679,-474.170000076998,10574.00002734));
#6551= IFCAXIS2PLACEMENT3D(#6550,#185,#596);
#6552= IFCLOCALPLACEMENT(#1216,#6551);
#6553= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5477));
#6554= IFCPRODUCTDEFINITIONSHAPE($,$,(#6553));
#6555= IFCDISCRETEACCESSORY('1Td1iR000yE34rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#6552,#6554,'P/431(?)');
#6556= IFCCARTESIANPOINT((44189.4926804679,-474.170000076998,10574.00002734));
#6557= IFCAXIS2PLACEMENT3D(#6556,#185,#596);
#6558= IFCLOCALPLACEMENT(#1216,#6557);
#6559= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5477));
#6560= IFCPRODUCTDEFINITIONSHAPE($,$,(#6559));
#6561= IFCDISCRETEACCESSORY('1Td1iR000yF34rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#6558,#6560,'P/431(?)');
#6562= IFCCARTESIANPOINT((44999.4926804679,-474.170000076998,10574.00002734));
#6563= IFCAXIS2PLACEMENT3D(#6562,#185,#596);
#6564= IFCLOCALPLACEMENT(#1216,#6563);
#6565= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5477));
#6566= IFCPRODUCTDEFINITIONSHAPE($,$,(#6565));
#6567= IFCDISCRETEACCESSORY('1Td1iR000yG34rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#6564,#6566,'P/431(?)');
#6568= IFCCARTESIANPOINT((32432.9988530373,-664.132537913409,10573.9999999996));
#6569= IFCAXIS2PLACEMENT3D(#6568,#5347,#5202);
#6570= IFCLOCALPLACEMENT(#6387,#6569);
#6571= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5213));
#6572= IFCPRODUCTDEFINITIONSHAPE($,$,(#6571));
#6573= IFCDISCRETEACCESSORY('1Td1iR000yO34rDp0rCJ4s',#5,'DETAY','PL16*58','PL16*58',#6570,#6572,'P/428(?)');
#6574= IFCCARTESIANPOINT((32849.492680471,-474.168995337077,10574.));
#6575= IFCAXIS2PLACEMENT3D(#6574,#185,#596);
#6576= IFCLOCALPLACEMENT(#6387,#6575);
#6577= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5537));
#6578= IFCPRODUCTDEFINITIONSHAPE($,$,(#6577));
#6579= IFCDISCRETEACCESSORY('1Td1iR000yP34rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#6576,#6578,'P/430(?)');
#6580= IFCPROPERTYSET('1lr47gHfbABvdEhwkIVvPp',#5,'Tekla Common','Common Properties to Shared building elements',(#1227,#1228,#4225,#5219,#74,#75,#919,#77,#78,#920,#967));
#6581= IFCCARTESIANPOINT((35279.4926804679,-474.169997439216,10574.));
#6582= IFCAXIS2PLACEMENT3D(#6581,#185,#596);
#6583= IFCLOCALPLACEMENT(#6387,#6582);
#6584= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5567));
#6585= IFCPRODUCTDEFINITIONSHAPE($,$,(#6584));
#6586= IFCDISCRETEACCESSORY('1Td1iR000yQ34rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#6583,#6585,'P/430(?)');
#6587= IFCCARTESIANPOINT((36089.4926804679,-474.169997439216,10574.));
#6588= IFCAXIS2PLACEMENT3D(#6587,#185,#596);
#6589= IFCLOCALPLACEMENT(#6387,#6588);
#6590= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5567));
#6591= IFCPRODUCTDEFINITIONSHAPE($,$,(#6590));
#6592= IFCDISCRETEACCESSORY('1Td1iR000yR34rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#6589,#6591,'P/430(?)');
#6593= IFCCARTESIANPOINT((36899.4926804679,-474.169997439216,10574.));
#6594= IFCAXIS2PLACEMENT3D(#6593,#185,#596);
#6595= IFCLOCALPLACEMENT(#6387,#6594);
#6596= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5567));
#6597= IFCPRODUCTDEFINITIONSHAPE($,$,(#6596));
#6598= IFCDISCRETEACCESSORY('1Td1iR000yS34rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#6595,#6597,'P/430(?)');
#6599= IFCCARTESIANPOINT((39329.4926804679,-474.169997439216,10574.));
#6600= IFCAXIS2PLACEMENT3D(#6599,#185,#596);
#6601= IFCLOCALPLACEMENT(#6387,#6600);
#6602= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5567));
#6603= IFCPRODUCTDEFINITIONSHAPE($,$,(#6602));
#6604= IFCDISCRETEACCESSORY('1Td1iR000yT34rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#6601,#6603,'P/430(?)');
#6605= IFCCARTESIANPOINT((40139.4909530955,-474.168995337077,10574.));
#6606= IFCAXIS2PLACEMENT3D(#6605,#185,#596);
#6607= IFCLOCALPLACEMENT(#6387,#6606);
#6608= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5537));
#6609= IFCPRODUCTDEFINITIONSHAPE($,$,(#6608));
#6610= IFCDISCRETEACCESSORY('1Td1iR000yU34rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#6607,#6609,'P/430(?)');
#6611= IFCLOCALPLACEMENT(#30,#10);
#6612= IFCELEMENTASSEMBLY('1Td1iR000zy34rDp0rCJ4s',#5,'Steel Assembly',$,$,#6611,$,'ANK/61(?)',.NOTDEFINED.,.RIGID_FRAME.);
#6613= IFCPROPERTYSET('2WfkabCPX2yBFPH5BCAMjD',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#5946,#2032,#2033,#1614,#5947,#1616));
#6614= IFCCARTESIANPOINT((40363.8303183166,-238.761303583805,10590.));
#6615= IFCAXIS2PLACEMENT3D(#6614,#9,#1621);
#6616= IFCLOCALPLACEMENT(#6611,#6615);
#6617= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5954));
#6618= IFCPRODUCTDEFINITIONSHAPE($,$,(#6617));
#6619= IFCBEAM('1Td1iR000zyJ4rDp0rCJ4s',#5,'PUL','PLT30*150','PLT30*150',#6616,#6618,'P/377(?)');
#6620= IFCLOCALPLACEMENT(#30,#10);
#6621= IFCELEMENTASSEMBLY('1Td1iR000zz34rDp0rCJ4s',#5,'Steel Assembly',$,$,#6620,$,'ANK/61(?)',.NOTDEFINED.,.RIGID_FRAME.);
#6622= IFCPROPERTYSET('30hJsHa693FgRTHKPOzJBs',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1665,#2032,#2033,#1614,#5947,#1616));
#6623= IFCCARTESIANPOINT((40636.1696399369,-238.76131148119,10590.));
#6624= IFCAXIS2PLACEMENT3D(#6623,#9,#1670);
#6625= IFCLOCALPLACEMENT(#6620,#6624);
#6626= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5985));
#6627= IFCPRODUCTDEFINITIONSHAPE($,$,(#6626));
#6628= IFCBEAM('1Td1iR000zzJ4rDp0rCJ4s',#5,'PUL','PLT30*150','PLT30*150',#6625,#6627,'P/377(?)');
#6629= IFCLOCALPLACEMENT(#30,#10);
#6630= IFCELEMENTASSEMBLY('1Td1iR000z_34rDp0rCJ4s',#5,'Steel Assembly',$,$,#6629,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#6631= IFCPROPERTYSET('2O31NdlGLF0PouMIIqiU5s',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#2054,#2055,#1700,#5947,#1701));
#6632= IFCCARTESIANPOINT((40716.8561910801,-257.190864719634,10590.));
#6633= IFCAXIS2PLACEMENT3D(#6632,#1706,#1707);
#6634= IFCLOCALPLACEMENT(#6629,#6633);
#6635= IFCEXTRUDEDAREASOLID(#1719,#1721,#9,16.0000409062002);
#6636= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6635));
#6637= IFCSTYLEDITEM(#6635,(#1711),$);
#6638= IFCPRODUCTDEFINITIONSHAPE($,$,(#6636));
#6639= IFCBEAM('1Td1iR000z_J4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#6634,#6638,'XX/0(?)');
#6640= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161875317921);
#6641= IFCQUANTITYVOLUME('NetVolume',$,$,1.24707976977434E-005);
#6642= IFCELEMENTQUANTITY('3f8EZlsh5DF9e$X3IQEtfX',#5,'BaseQuantities',$,$,(#1751,#6640,#6641,#1754));
#6643= IFCLOCALPLACEMENT(#30,#10);
#6644= IFCELEMENTASSEMBLY('1Td1iR000z$34rDp0rCJ4s',#5,'Steel Assembly',$,$,#6643,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#6645= IFCCARTESIANPOINT((40713.4878455301,-241.549277321979,10590.));
#6646= IFCAXIS2PLACEMENT3D(#6645,#1706,#1707);
#6647= IFCLOCALPLACEMENT(#6643,#6646);
#6648= IFCEXTRUDEDAREASOLID(#1719,#1721,#9,16.0000409061921);
#6649= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6648));
#6650= IFCSTYLEDITEM(#6648,(#1711),$);
#6651= IFCPRODUCTDEFINITIONSHAPE($,$,(#6649));
#6652= IFCBEAM('1Td1iR000z$J4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#6647,#6651,'XX/0(?)');
#6653= IFCLOCALPLACEMENT(#30,#10);
#6654= IFCELEMENTASSEMBLY('1Td1iR000_034rDp0rCJ4s',#5,'Steel Assembly',$,$,#6653,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#6655= IFCPROPERTYSET('2hQglUnh58H9SA7R3cKKqe',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#2076,#2077,#1775,#5947,#1701));
#6656= IFCCARTESIANPOINT((40712.6453400033,-237.638892502498,10590.));
#6657= IFCAXIS2PLACEMENT3D(#6656,#1670,#1780);
#6658= IFCLOCALPLACEMENT(#6653,#6657);
#6659= IFCEXTRUDEDAREASOLID(#1783,#1785,#9,4.00000000000318);
#6660= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6659));
#6661= IFCSTYLEDITEM(#6659,(#1711),$);
#6662= IFCPRODUCTDEFINITIONSHAPE($,$,(#6660));
#6663= IFCBEAM('1Td1iR000_0J4rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#6658,#6662,'XX/0(?)');
#6664= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00180062582325914);
#6665= IFCQUANTITYVOLUME('NetVolume',$,$,3.93300000000781E-006);
#6666= IFCELEMENTQUANTITY('1u2ZVswevAjQXrpg3PLwFu',#5,'BaseQuantities',$,$,(#6036,#6664,#6665,#1754));
#6667= IFCLOCALPLACEMENT(#30,#10);
#6668= IFCELEMENTASSEMBLY('1Td1iR000_134rDp0rCJ4s',#5,'Steel Assembly',$,$,#6667,$,'R/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#6669= IFCPROPERTYSET('2pP5QufHfBgvTBMugpYQID',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#2090,#2091,#1814,#5947,#1815));
#6670= IFCCARTESIANPOINT((40725.1344111934,-295.638490283996,10590.));
#6671= IFCAXIS2PLACEMENT3D(#6670,#1820,#1821);
#6672= IFCLOCALPLACEMENT(#6667,#6671);
#6673= IFCEXTRUDEDAREASOLID(#1826,#1828,#9,370.000357476353);
#6674= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6673));
#6675= IFCSTYLEDITEM(#6673,(#1825),$);
#6676= IFCPRODUCTDEFINITIONSHAPE($,$,(#6674));
#6677= IFCBEAM('1Td1iR000_1J4rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#6672,#6676,'P/0(?)');
#6678= IFCCARTESIANPOINT((40569.9999731708,-444.15209193049,10598.));
#6679= IFCAXIS2PLACEMENT3D(#6678,#9,#8);
#6680= IFCLOCALPLACEMENT(#6453,#6679);
#6681= IFCBOOLEANRESULT(.DIFFERENCE.,#6074,#1894);
#6682= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#6681));
#6683= IFCPRODUCTDEFINITIONSHAPE($,$,(#6682));
#6684= IFCPLATE('1Td1iR000_334rDp0rCJ4s',#5,'ANCHOR','PL16*436','PL16*436',#6680,#6683,'P/0(?)');
#6685= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(17.5314374329463),$);
#6686= IFCPROPERTYSET('0$kGPBc4n8VhNcReln49nm',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#5881,#6080,#6081,#6082,#6083,#6084,#6085,#6086,#6685,#6088,#6089,#6090,#94,#6091));
#6687= IFCQUANTITYAREA('NetArea',$,$,0.331499386302561);
#6688= IFCQUANTITYVOLUME('NetVolume',$,$,0.00240877117729545);
#6689= IFCELEMENTQUANTITY('2tOcNO$1bEqAKWlFBfqdtO',#5,'BaseQuantities',$,$,(#6093,#6687,#6095,#100,#6688,#6097));
#6690= IFCLOCALPLACEMENT(#30,#10);
#6691= IFCELEMENTASSEMBLY('1Td1iR000_3p4rDp0rCJ4s',#5,'Steel Assembly',$,$,#6690,$,'ANK/63(?)',.NOTDEFINED.,.RIGID_FRAME.);
#6692= IFCPROPERTYSET('3bbJqKx9v2eOSlB_r1MFeJ',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#6101,#2010,#2011,#39,#5873,#489));
#6693= IFCCARTESIANPOINT((40634.9987504166,-484.152103045623,10614.));
#6694= IFCAXIS2PLACEMENT3D(#6693,#7,#501);
#6695= IFCLOCALPLACEMENT(#6690,#6694);
#6696= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6109));
#6697= IFCPRODUCTDEFINITIONSHAPE($,$,(#6696));
#6698= IFCBEAM('1Td1iR000_434rDp0rCJ4s',#5,'ANKRAJ','PLT16*140','PLT16*140',#6695,#6697,'P/379(?)');
#6699= IFCPROPERTYSET('23DP54vGD8cvCPHdlfelbC',#5,'Tekla Common','Common Properties to Shared building elements',(#2019,#2020,#512,#513,#74,#75,#919,#515,#78,#6115,#80));
#6700= IFCLOCALPLACEMENT(#30,#10);
#6701= IFCELEMENTASSEMBLY('1Td1iR000_4p4rDp0rCJ4s',#5,'Steel Assembly',$,$,#6700,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#6702= IFCCARTESIANPOINT((40283.1442023679,-257.190838696386,10590.));
#6703= IFCAXIS2PLACEMENT3D(#6702,#1928,#1929);
#6704= IFCLOCALPLACEMENT(#6700,#6703);
#6705= IFCEXTRUDEDAREASOLID(#1719,#1721,#9,16.0000409061983);
#6706= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6705));
#6707= IFCSTYLEDITEM(#6705,(#1711),$);
#6708= IFCPRODUCTDEFINITIONSHAPE($,$,(#6706));
#6709= IFCBEAM('1Td1iR000_534rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#6704,#6708,'XX/0(?)');
#6710= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(16.0000409063123),$);
#6711= IFCPROPERTYSET('02KJzvwoL70xRoLTN5LV7z',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#1740,#1741,#1742,#1743,#1744,#1745,#1746,#1747,#1748,#6710));
#6712= IFCQUANTITYLENGTH('Length',$,$,16.0000409063123);
#6713= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161875316919);
#6714= IFCQUANTITYVOLUME('NetVolume',$,$,1.24707976976945E-005);
#6715= IFCELEMENTQUANTITY('0NBYy9e8b62egNbeF5Kz_W',#5,'BaseQuantities',$,$,(#6712,#6713,#6714,#1754));
#6716= IFCLOCALPLACEMENT(#30,#10);
#6717= IFCELEMENTASSEMBLY('1Td1iR000_5p4rDp0rCJ4s',#5,'Steel Assembly',$,$,#6716,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#6718= IFCCARTESIANPOINT((40286.5125497949,-241.549251702941,10590.));
#6719= IFCAXIS2PLACEMENT3D(#6718,#1928,#1929);
#6720= IFCLOCALPLACEMENT(#6716,#6719);
#6721= IFCEXTRUDEDAREASOLID(#1719,#1721,#9,16.0000409061909);
#6722= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6721));
#6723= IFCSTYLEDITEM(#6721,(#1711),$);
#6724= IFCPRODUCTDEFINITIONSHAPE($,$,(#6722));
#6725= IFCBEAM('1Td1iR000_634rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#6720,#6724,'XX/0(?)');
#6726= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161875316843);
#6727= IFCQUANTITYVOLUME('NetVolume',$,$,1.24707976976893E-005);
#6728= IFCELEMENTQUANTITY('3RL09CKgX41uI$CxhLyt8b',#5,'BaseQuantities',$,$,(#6162,#6726,#6727,#1754));
#6729= IFCLOCALPLACEMENT(#30,#10);
#6730= IFCELEMENTASSEMBLY('1Td1iR000_6p4rDp0rCJ4s',#5,'Steel Assembly',$,$,#6729,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#6731= IFCCARTESIANPOINT((40287.355055791,-237.638866984563,10590.));
#6732= IFCAXIS2PLACEMENT3D(#6731,#1621,#1966);
#6733= IFCLOCALPLACEMENT(#6729,#6732);
#6734= IFCEXTRUDEDAREASOLID(#1783,#1785,#9,4.00000000000608);
#6735= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6734));
#6736= IFCSTYLEDITEM(#6734,(#1711),$);
#6737= IFCPRODUCTDEFINITIONSHAPE($,$,(#6735));
#6738= IFCBEAM('1Td1iR000_734rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#6733,#6737,'XX/0(?)');
#6739= IFCQUANTITYLENGTH('Length',$,$,4.00000000002001);
#6740= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00180062582326101);
#6741= IFCQUANTITYVOLUME('NetVolume',$,$,3.93300000001477E-006);
#6742= IFCELEMENTQUANTITY('2BS4HjjqzEmQtufbl_DKDJ',#5,'BaseQuantities',$,$,(#6739,#6740,#6741,#1754));
#6743= IFCLOCALPLACEMENT(#30,#10);
#6744= IFCELEMENTASSEMBLY('1Td1iR000_7p4rDp0rCJ4s',#5,'Steel Assembly',$,$,#6743,$,'R/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#6745= IFCCARTESIANPOINT((40274.8659776408,-295.638463267341,10590.));
#6746= IFCAXIS2PLACEMENT3D(#6745,#1988,#1989);
#6747= IFCLOCALPLACEMENT(#6743,#6746);
#6748= IFCEXTRUDEDAREASOLID(#1826,#1828,#9,370.000357476348);
#6749= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6748));
#6750= IFCSTYLEDITEM(#6748,(#1825),$);
#6751= IFCPRODUCTDEFINITIONSHAPE($,$,(#6749));
#6752= IFCBEAM('1Td1iR000_834rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#6747,#6751,'P/0(?)');
#6753= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.023220566509026);
#6754= IFCQUANTITYVOLUME('NetVolume',$,$,0.000104651904725289);
#6755= IFCELEMENTQUANTITY('0pF_OXQc559RJkryrC6W4A',#5,'BaseQuantities',$,$,(#6202,#6753,#6754,#1754));
#6756= IFCLOCALPLACEMENT(#30,#10);
#6757= IFCELEMENTASSEMBLY('1Td1iR000_8p4rDp0rCJ4s',#5,'Steel Assembly',$,$,#6756,$,'ANK/63(?)',.NOTDEFINED.,.RIGID_FRAME.);
#6758= IFCCARTESIANPOINT((40365.0016157955,-484.152086845482,10614.));
#6759= IFCAXIS2PLACEMENT3D(#6758,#7,#501);
#6760= IFCLOCALPLACEMENT(#6756,#6759);
#6761= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6211));
#6762= IFCPRODUCTDEFINITIONSHAPE($,$,(#6761));
#6763= IFCBEAM('1Td1iR000_934rDp0rCJ4s',#5,'ANKRAJ','PLT16*140','PLT16*140',#6760,#6762,'P/379(?)');
#6764= IFCLOCALPLACEMENT(#30,#10);
#6765= IFCELEMENTASSEMBLY('1Td1iR001OMZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#6764,$,'P/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#6766= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(1.32759531499903),$);
#6767= IFCPROPERTYSET('3i3yrZakf0zfh3AqTdgall',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#6766,#4308,#4309,#3186,#488,#3187));
#6768= IFCCARTESIANPOINT((46619.492680469,-474.170000153068,-1125.99997266001));
#6769= IFCAXIS2PLACEMENT3D(#6768,#185,#596);
#6770= IFCLOCALPLACEMENT(#6764,#6769);
#6771= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5477));
#6772= IFCPRODUCTDEFINITIONSHAPE($,$,(#6771));
#6773= IFCPLATE('1Td1iR000_RJ4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#6770,#6772,'P/431(?)');
#6774= IFCPROPERTYSET('2Hydxm_UHD481I4IhwHOC3',#5,'Tekla Common','Common Properties to Shared building elements',(#1463,#1464,#966,#3208,#74,#75,#919,#77,#78,#920,#967));
#6775= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(1.32759531499903),$);
#6776= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(1.32759531499903),$);
#6777= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(1.32759531499903),$);
#6778= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(57.9999998695384),$);
#6779= IFCPROPERTYSET('1L16H4EIrD_hbM7qD9aIfQ',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#6775,#6776,#5483,#6777,#927,#928,#929,#5485,#5486,#5548,#5488,#6778,#94,#5490));
#6780= IFCQUANTITYLENGTH('Width',$,$,57.9999998695384);
#6781= IFCQUANTITYAREA('NetArea',$,$,0.0285137124284843);
#6782= IFCQUANTITYAREA('GrossArea',$,$,0.0110200270613187);
#6783= IFCQUANTITYVOLUME('NetVolume',$,$,0.00016912042229287);
#6784= IFCQUANTITYVOLUME('GrossVolume',$,$,0.00016912042229287);
#6785= IFCELEMENTQUANTITY('2nGQYfwAT64PTMyopY4wTZ',#5,'BaseQuantities',$,$,(#6780,#6781,#6782,#100,#6783,#6784));
#6786= IFCLOCALPLACEMENT(#30,#10);
#6787= IFCELEMENTASSEMBLY('1Td1iR001OMp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#6786,$,'P/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#6788= IFCPROPERTYSET('2vzoJzE99Bxg2pvVZpKUa0',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#6766,#4308,#4309,#3186,#5873,#3187));
#6789= IFCCARTESIANPOINT((40949.4926804679,-474.170000076998,-1125.99997266001));
#6790= IFCAXIS2PLACEMENT3D(#6789,#185,#596);
#6791= IFCLOCALPLACEMENT(#6786,#6790);
#6792= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5477));
#6793= IFCPRODUCTDEFINITIONSHAPE($,$,(#6792));
#6794= IFCPLATE('1Td1iR000_S34rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#6791,#6793,'P/431(?)');
#6795= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(57.9999998695387),$);
#6796= IFCPROPERTYSET('1uLMpFSFr2TeU0ZXn8sQdp',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#6775,#6776,#5483,#6777,#927,#928,#929,#5485,#5486,#5548,#5488,#6795,#94,#5490));
#6797= IFCQUANTITYLENGTH('Width',$,$,57.9999998695387);
#6798= IFCQUANTITYAREA('GrossArea',$,$,0.0110200270613187);
#6799= IFCELEMENTQUANTITY('3KevLJfcnFtOV2h1G20Wq7',#5,'BaseQuantities',$,$,(#6797,#6781,#6798,#100,#6783,#6784));
#6800= IFCLOCALPLACEMENT(#30,#10);
#6801= IFCELEMENTASSEMBLY('1Td1iR001ON34rDp0rCJ4s',#5,'Steel Assembly',$,$,#6800,$,'P/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#6802= IFCCARTESIANPOINT((43379.4926804679,-474.170000076998,-1125.99997266001));
#6803= IFCAXIS2PLACEMENT3D(#6802,#185,#596);
#6804= IFCLOCALPLACEMENT(#6800,#6803);
#6805= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5477));
#6806= IFCPRODUCTDEFINITIONSHAPE($,$,(#6805));
#6807= IFCPLATE('1Td1iR000_Sp4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#6804,#6806,'P/431(?)');
#6808= IFCLOCALPLACEMENT(#30,#10);
#6809= IFCELEMENTASSEMBLY('1Td1iR001ONJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#6808,$,'P/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#6810= IFCCARTESIANPOINT((44189.4926804679,-474.170000076998,-1125.99997266001));
#6811= IFCAXIS2PLACEMENT3D(#6810,#185,#596);
#6812= IFCLOCALPLACEMENT(#6808,#6811);
#6813= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5477));
#6814= IFCPRODUCTDEFINITIONSHAPE($,$,(#6813));
#6815= IFCPLATE('1Td1iR000_TZ4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#6812,#6814,'P/431(?)');
#6816= IFCLOCALPLACEMENT(#30,#10);
#6817= IFCELEMENTASSEMBLY('1Td1iR001ONZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#6816,$,'P/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#6818= IFCCARTESIANPOINT((44999.4926804679,-474.170000076998,-1125.99997266001));
#6819= IFCAXIS2PLACEMENT3D(#6818,#185,#596);
#6820= IFCLOCALPLACEMENT(#6816,#6819);
#6821= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5477));
#6822= IFCPRODUCTDEFINITIONSHAPE($,$,(#6821));
#6823= IFCPLATE('1Td1iR000_UJ4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#6820,#6822,'P/431(?)');
#6824= IFCCARTESIANPOINT((32809.9926804692,-579.170000075344,-1104.9999999998));
#6825= IFCAXIS2PLACEMENT3D(#6824,#8,#7);
#6826= IFCLOCALPLACEMENT(#30,#6825);
#6827= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#6828= IFCEXTRUDEDAREASOLID(#6827,#4747,#9,16.0000000000234);
#6829= IFCSTYLEDITEM(#6828,(#195),$);
#6830= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#6831= IFCEXTRUDEDAREASOLID(#6830,#4752,#9,16.1);
#6832= IFCSTYLEDITEM(#6831,(#195),$);
#6833= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#6834= IFCEXTRUDEDAREASOLID(#6833,#4757,#9,6.5);
#6835= IFCSTYLEDITEM(#6834,(#191),$);
#6836= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#6837= IFCEXTRUDEDAREASOLID(#6836,#4762,#9,50.);
#6838= IFCSTYLEDITEM(#6837,(#191),$);
#6839= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#6840= IFCEXTRUDEDAREASOLID(#6839,#4767,#9,2.5);
#6841= IFCSTYLEDITEM(#6840,(#191),$);
#6842= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#6843= IFCEXTRUDEDAREASOLID(#6842,#4772,#9,10.);
#6844= IFCSTYLEDITEM(#6843,(#191),$);
#6845= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6828,#6831,#6834,#6837,#6840,#6843));
#6846= IFCREPRESENTATIONMAP(#10,#6845);
#6847= IFCMAPPEDITEM(#6846,#4776);
#6848= IFCMAPPEDITEM(#6846,#4781);
#6849= IFCMAPPEDITEM(#6846,#4784);
#6850= IFCMAPPEDITEM(#6846,#4787);
#6851= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#6847,#6848,#6849,#6850));
#6852= IFCPRODUCTDEFINITIONSHAPE($,$,(#6851));
#6853= IFCMECHANICALFASTENER('1Td1iR000$i34rDp0rCJ4s',#5,'Bolt assembly',$,$,#6826,#6852,'ID5d9c1b1b-0000-3fb0-3135-373035313136',12.,50.);
#6854= IFCCARTESIANPOINT((35239.9926804692,-579.170000075344,-1104.9999999998));
#6855= IFCAXIS2PLACEMENT3D(#6854,#8,#7);
#6856= IFCLOCALPLACEMENT(#30,#6855);
#6857= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#6858= IFCEXTRUDEDAREASOLID(#6857,#4747,#9,16.0000000000234);
#6859= IFCSTYLEDITEM(#6858,(#195),$);
#6860= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#6861= IFCEXTRUDEDAREASOLID(#6860,#4752,#9,16.1);
#6862= IFCSTYLEDITEM(#6861,(#195),$);
#6863= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#6864= IFCEXTRUDEDAREASOLID(#6863,#4757,#9,6.5);
#6865= IFCSTYLEDITEM(#6864,(#191),$);
#6866= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#6867= IFCEXTRUDEDAREASOLID(#6866,#4762,#9,50.);
#6868= IFCSTYLEDITEM(#6867,(#191),$);
#6869= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#6870= IFCEXTRUDEDAREASOLID(#6869,#4767,#9,2.5);
#6871= IFCSTYLEDITEM(#6870,(#191),$);
#6872= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#6873= IFCEXTRUDEDAREASOLID(#6872,#4772,#9,10.);
#6874= IFCSTYLEDITEM(#6873,(#191),$);
#6875= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6858,#6861,#6864,#6867,#6870,#6873));
#6876= IFCREPRESENTATIONMAP(#10,#6875);
#6877= IFCMAPPEDITEM(#6876,#4776);
#6878= IFCMAPPEDITEM(#6876,#4781);
#6879= IFCMAPPEDITEM(#6876,#4784);
#6880= IFCMAPPEDITEM(#6876,#4787);
#6881= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#6877,#6878,#6879,#6880));
#6882= IFCPRODUCTDEFINITIONSHAPE($,$,(#6881));
#6883= IFCMECHANICALFASTENER('1Td1iR000$ip4rDp0rCJ4s',#5,'Bolt assembly',$,$,#6856,#6882,'ID5d9c1b1b-0000-3fb3-3135-373035313136',12.,50.);
#6884= IFCCARTESIANPOINT((36049.9926804692,-579.170000075344,-1104.9999999998));
#6885= IFCAXIS2PLACEMENT3D(#6884,#8,#7);
#6886= IFCLOCALPLACEMENT(#30,#6885);
#6887= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#6888= IFCEXTRUDEDAREASOLID(#6887,#4747,#9,16.0000000000234);
#6889= IFCSTYLEDITEM(#6888,(#195),$);
#6890= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#6891= IFCEXTRUDEDAREASOLID(#6890,#4752,#9,16.1);
#6892= IFCSTYLEDITEM(#6891,(#195),$);
#6893= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#6894= IFCEXTRUDEDAREASOLID(#6893,#4757,#9,6.5);
#6895= IFCSTYLEDITEM(#6894,(#191),$);
#6896= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#6897= IFCEXTRUDEDAREASOLID(#6896,#4762,#9,50.);
#6898= IFCSTYLEDITEM(#6897,(#191),$);
#6899= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#6900= IFCEXTRUDEDAREASOLID(#6899,#4767,#9,2.5);
#6901= IFCSTYLEDITEM(#6900,(#191),$);
#6902= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#6903= IFCEXTRUDEDAREASOLID(#6902,#4772,#9,10.);
#6904= IFCSTYLEDITEM(#6903,(#191),$);
#6905= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6888,#6891,#6894,#6897,#6900,#6903));
#6906= IFCREPRESENTATIONMAP(#10,#6905);
#6907= IFCMAPPEDITEM(#6906,#4776);
#6908= IFCMAPPEDITEM(#6906,#4781);
#6909= IFCMAPPEDITEM(#6906,#4784);
#6910= IFCMAPPEDITEM(#6906,#4787);
#6911= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#6907,#6908,#6909,#6910));
#6912= IFCPRODUCTDEFINITIONSHAPE($,$,(#6911));
#6913= IFCMECHANICALFASTENER('1Td1iR000$jZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#6886,#6912,'ID5d9c1b1b-0000-3fb6-3135-373035313136',12.,50.);
#6914= IFCCARTESIANPOINT((36859.9926804692,-579.170000075344,-1104.9999999998));
#6915= IFCAXIS2PLACEMENT3D(#6914,#8,#7);
#6916= IFCLOCALPLACEMENT(#30,#6915);
#6917= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#6918= IFCEXTRUDEDAREASOLID(#6917,#4747,#9,16.0000000000234);
#6919= IFCSTYLEDITEM(#6918,(#195),$);
#6920= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#6921= IFCEXTRUDEDAREASOLID(#6920,#4752,#9,16.1);
#6922= IFCSTYLEDITEM(#6921,(#195),$);
#6923= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#6924= IFCEXTRUDEDAREASOLID(#6923,#4757,#9,6.5);
#6925= IFCSTYLEDITEM(#6924,(#191),$);
#6926= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#6927= IFCEXTRUDEDAREASOLID(#6926,#4762,#9,50.);
#6928= IFCSTYLEDITEM(#6927,(#191),$);
#6929= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#6930= IFCEXTRUDEDAREASOLID(#6929,#4767,#9,2.5);
#6931= IFCSTYLEDITEM(#6930,(#191),$);
#6932= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#6933= IFCEXTRUDEDAREASOLID(#6932,#4772,#9,10.);
#6934= IFCSTYLEDITEM(#6933,(#191),$);
#6935= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6918,#6921,#6924,#6927,#6930,#6933));
#6936= IFCREPRESENTATIONMAP(#10,#6935);
#6937= IFCMAPPEDITEM(#6936,#4776);
#6938= IFCMAPPEDITEM(#6936,#4781);
#6939= IFCMAPPEDITEM(#6936,#4784);
#6940= IFCMAPPEDITEM(#6936,#4787);
#6941= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#6937,#6938,#6939,#6940));
#6942= IFCPRODUCTDEFINITIONSHAPE($,$,(#6941));
#6943= IFCMECHANICALFASTENER('1Td1iR000$kJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#6916,#6942,'ID5d9c1b1b-0000-3fb9-3135-373035313136',12.,50.);
#6944= IFCCARTESIANPOINT((39289.9926804692,-579.170000075344,-1104.9999999998));
#6945= IFCAXIS2PLACEMENT3D(#6944,#8,#7);
#6946= IFCLOCALPLACEMENT(#30,#6945);
#6947= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#6948= IFCEXTRUDEDAREASOLID(#6947,#4747,#9,16.0000000000234);
#6949= IFCSTYLEDITEM(#6948,(#195),$);
#6950= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#6951= IFCEXTRUDEDAREASOLID(#6950,#4752,#9,16.1);
#6952= IFCSTYLEDITEM(#6951,(#195),$);
#6953= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#6954= IFCEXTRUDEDAREASOLID(#6953,#4757,#9,6.5);
#6955= IFCSTYLEDITEM(#6954,(#191),$);
#6956= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#6957= IFCEXTRUDEDAREASOLID(#6956,#4762,#9,50.);
#6958= IFCSTYLEDITEM(#6957,(#191),$);
#6959= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#6960= IFCEXTRUDEDAREASOLID(#6959,#4767,#9,2.5);
#6961= IFCSTYLEDITEM(#6960,(#191),$);
#6962= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#6963= IFCEXTRUDEDAREASOLID(#6962,#4772,#9,10.);
#6964= IFCSTYLEDITEM(#6963,(#191),$);
#6965= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6948,#6951,#6954,#6957,#6960,#6963));
#6966= IFCREPRESENTATIONMAP(#10,#6965);
#6967= IFCMAPPEDITEM(#6966,#4776);
#6968= IFCMAPPEDITEM(#6966,#4781);
#6969= IFCMAPPEDITEM(#6966,#4784);
#6970= IFCMAPPEDITEM(#6966,#4787);
#6971= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#6967,#6968,#6969,#6970));
#6972= IFCPRODUCTDEFINITIONSHAPE($,$,(#6971));
#6973= IFCMECHANICALFASTENER('1Td1iR000$l34rDp0rCJ4s',#5,'Bolt assembly',$,$,#6946,#6972,'ID5d9c1b1b-0000-3fbc-3135-373035313136',12.,50.);
#6974= IFCCARTESIANPOINT((40099.9926804692,-579.170000075344,-1104.9999999998));
#6975= IFCAXIS2PLACEMENT3D(#6974,#8,#7);
#6976= IFCLOCALPLACEMENT(#30,#6975);
#6977= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#6978= IFCEXTRUDEDAREASOLID(#6977,#4747,#9,16.0000000000234);
#6979= IFCSTYLEDITEM(#6978,(#195),$);
#6980= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#6981= IFCEXTRUDEDAREASOLID(#6980,#4752,#9,16.1);
#6982= IFCSTYLEDITEM(#6981,(#195),$);
#6983= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#6984= IFCEXTRUDEDAREASOLID(#6983,#4757,#9,6.5);
#6985= IFCSTYLEDITEM(#6984,(#191),$);
#6986= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#6987= IFCEXTRUDEDAREASOLID(#6986,#4762,#9,50.);
#6988= IFCSTYLEDITEM(#6987,(#191),$);
#6989= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#6990= IFCEXTRUDEDAREASOLID(#6989,#4767,#9,2.5);
#6991= IFCSTYLEDITEM(#6990,(#191),$);
#6992= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#6993= IFCEXTRUDEDAREASOLID(#6992,#4772,#9,10.);
#6994= IFCSTYLEDITEM(#6993,(#191),$);
#6995= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6978,#6981,#6984,#6987,#6990,#6993));
#6996= IFCREPRESENTATIONMAP(#10,#6995);
#6997= IFCMAPPEDITEM(#6996,#4776);
#6998= IFCMAPPEDITEM(#6996,#4781);
#6999= IFCMAPPEDITEM(#6996,#4784);
#7000= IFCMAPPEDITEM(#6996,#4787);
#7001= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#6997,#6998,#6999,#7000));
#7002= IFCPRODUCTDEFINITIONSHAPE($,$,(#7001));
#7003= IFCMECHANICALFASTENER('1Td1iR000$lp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#6976,#7002,'ID5d9c1b1b-0000-3fbf-3135-373035313136',12.,50.);
#7004= IFCCARTESIANPOINT((40288.4976961945,-232.330062517137,-1110.));
#7005= IFCAXIS2PLACEMENT3D(#7004,#596,#597);
#7006= IFCLOCALPLACEMENT(#30,#7005);
#7007= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#7008= IFCEXTRUDEDAREASOLID(#7007,#602,#9,30.1000000000098);
#7009= IFCSTYLEDITEM(#7008,(#195),$);
#7010= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#7008));
#7011= IFCREPRESENTATIONMAP(#10,#7010);
#7012= IFCMAPPEDITEM(#7011,#247);
#7013= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#7012));
#7014= IFCPRODUCTDEFINITIONSHAPE($,$,(#7013));
#7015= IFCMECHANICALFASTENER('1Td1iR0010g34rDp0rCJ4s',#5,'Bolt assembly',$,$,#7006,#7014,'ID5d9c1b1b-0000-40a8-3135-373035313136',20.,30.);
#7016= IFCCARTESIANPOINT((40705.1872659515,-203.002074025752,-1110.));
#7017= IFCAXIS2PLACEMENT3D(#7016,#9,#620);
#7018= IFCLOCALPLACEMENT(#30,#7017);
#7019= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,71.);
#7020= IFCEXTRUDEDAREASOLID(#7019,#625,#9,30.1063464563373);
#7021= IFCSTYLEDITEM(#7020,(#195),$);
#7022= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#7020));
#7023= IFCREPRESENTATIONMAP(#10,#7022);
#7024= IFCMAPPEDITEM(#7023,#247);
#7025= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#7024));
#7026= IFCPRODUCTDEFINITIONSHAPE($,$,(#7025));
#7027= IFCMECHANICALFASTENER('1Td1iR0010gp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#7018,#7026,'ID5d9c1b1b-0000-40ab-3135-373035313136',20.,30.0063457489014);
#7028= IFCCARTESIANPOINT((40711.502262432,-232.330074783567,-1110.));
#7029= IFCAXIS2PLACEMENT3D(#7028,#9,#640);
#7030= IFCLOCALPLACEMENT(#30,#7029);
#7031= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#7032= IFCEXTRUDEDAREASOLID(#7031,#602,#9,30.1000000000079);
#7033= IFCSTYLEDITEM(#7032,(#195),$);
#7034= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#7032));
#7035= IFCREPRESENTATIONMAP(#10,#7034);
#7036= IFCMAPPEDITEM(#7035,#247);
#7037= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#7036));
#7038= IFCPRODUCTDEFINITIONSHAPE($,$,(#7037));
#7039= IFCMECHANICALFASTENER('1Td1iR0010hZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#7030,#7038,'ID5d9c1b1b-0000-40ae-3135-373035313136',20.,30.);
#7040= IFCCARTESIANPOINT((40294.8131339993,-203.002049402811,-1110.));
#7041= IFCAXIS2PLACEMENT3D(#7040,#596,#653);
#7042= IFCLOCALPLACEMENT(#30,#7041);
#7043= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,71.);
#7044= IFCEXTRUDEDAREASOLID(#7043,#658,#9,30.1061745233263);
#7045= IFCSTYLEDITEM(#7044,(#195),$);
#7046= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#7044));
#7047= IFCREPRESENTATIONMAP(#10,#7046);
#7048= IFCMAPPEDITEM(#7047,#247);
#7049= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#7048));
#7050= IFCPRODUCTDEFINITIONSHAPE($,$,(#7049));
#7051= IFCMECHANICALFASTENER('1Td1iR0010iJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#7042,#7050,'ID5d9c1b1b-0000-40b1-3135-373035313136',20.,30.0061740875244);
#7052= IFCCARTESIANPOINT((40634.9988455077,-554.152715152363,-1112.001));
#7053= IFCAXIS2PLACEMENT3D(#7052,#501,#185);
#7054= IFCLOCALPLACEMENT(#30,#7053);
#7055= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,40.);
#7056= IFCEXTRUDEDAREASOLID(#7055,#561,#9,16.0999999999999);
#7057= IFCSTYLEDITEM(#7056,(#195),$);
#7058= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#7056));
#7059= IFCREPRESENTATIONMAP(#10,#7058);
#7060= IFCMAPPEDITEM(#7059,#247);
#7061= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#7060));
#7062= IFCPRODUCTDEFINITIONSHAPE($,$,(#7061));
#7063= IFCMECHANICALFASTENER('1Td1iR0010j34rDp0rCJ4s',#5,'Bolt assembly',$,$,#7054,#7062,'ID5d9c1b1b-0000-40b4-3135-373035313136',30.,16.);
#7064= IFCCARTESIANPOINT((40365.0017174869,-554.152698952219,-1112.001));
#7065= IFCAXIS2PLACEMENT3D(#7064,#8,#7);
#7066= IFCLOCALPLACEMENT(#30,#7065);
#7067= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,40.);
#7068= IFCEXTRUDEDAREASOLID(#7067,#561,#9,16.0999999999998);
#7069= IFCSTYLEDITEM(#7068,(#195),$);
#7070= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#7068));
#7071= IFCREPRESENTATIONMAP(#10,#7070);
#7072= IFCMAPPEDITEM(#7071,#247);
#7073= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#7072));
#7074= IFCPRODUCTDEFINITIONSHAPE($,$,(#7073));
#7075= IFCMECHANICALFASTENER('1Td1iR0010jp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#7066,#7074,'ID5d9c1b1b-0000-40b7-3135-373035313136',30.,16.);
#7076= IFCCARTESIANPOINT((40365.0019996906,-554.153073853048,-1060.005));
#7077= IFCAXIS2PLACEMENT3D(#7076,#8,#7);
#7078= IFCLOCALPLACEMENT(#30,#7077);
#7079= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,16.5);
#7080= IFCEXTRUDEDAREASOLID(#7079,#4663,#9,16.);
#7081= IFCSTYLEDITEM(#7080,(#195),$);
#7082= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,16.5);
#7083= IFCEXTRUDEDAREASOLID(#7082,#4643,#9,15.9999999999998);
#7084= IFCSTYLEDITEM(#7083,(#195),$);
#7085= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,16.5);
#7086= IFCEXTRUDEDAREASOLID(#7085,#4638,#9,16.1);
#7087= IFCSTYLEDITEM(#7086,(#195),$);
#7088= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4672);
#7089= IFCEXTRUDEDAREASOLID(#7088,#4675,#9,19.8);
#7090= IFCSTYLEDITEM(#7089,(#558),$);
#7091= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,15.);
#7092= IFCEXTRUDEDAREASOLID(#7091,#4680,#9,90.);
#7093= IFCSTYLEDITEM(#7092,(#558),$);
#7094= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,28.);
#7095= IFCEXTRUDEDAREASOLID(#7094,#4685,#9,8.);
#7096= IFCSTYLEDITEM(#7095,(#558),$);
#7097= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4694);
#7098= IFCEXTRUDEDAREASOLID(#7097,#4697,#9,24.);
#7099= IFCSTYLEDITEM(#7098,(#558),$);
#7100= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#7080,#7083,#7086,#7089,#7092,#7095,#7098));
#7101= IFCREPRESENTATIONMAP(#10,#7100);
#7102= IFCMAPPEDITEM(#7101,#247);
#7103= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#7102));
#7104= IFCPRODUCTDEFINITIONSHAPE($,$,(#7103));
#7105= IFCMECHANICALFASTENER('1Td1iR0010kZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#7078,#7104,'ID5d9c1b1b-0000-40ba-3135-373035313136',30.,90.);
#7106= IFCCARTESIANPOINT((32534.9983581212,-554.153090053148,-1060.005));
#7107= IFCAXIS2PLACEMENT3D(#7106,#501,#185);
#7108= IFCLOCALPLACEMENT(#30,#7107);
#7109= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,16.5);
#7110= IFCEXTRUDEDAREASOLID(#7109,#4638,#9,16.1);
#7111= IFCSTYLEDITEM(#7110,(#195),$);
#7112= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,16.5);
#7113= IFCEXTRUDEDAREASOLID(#7112,#4643,#9,16.);
#7114= IFCSTYLEDITEM(#7113,(#195),$);
#7115= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4660);
#7116= IFCEXTRUDEDAREASOLID(#7115,#4663,#9,15.9999999999999);
#7117= IFCSTYLEDITEM(#7116,(#195),$);
#7118= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4672);
#7119= IFCEXTRUDEDAREASOLID(#7118,#4675,#9,19.8);
#7120= IFCSTYLEDITEM(#7119,(#558),$);
#7121= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,15.);
#7122= IFCEXTRUDEDAREASOLID(#7121,#4680,#9,90.);
#7123= IFCSTYLEDITEM(#7122,(#558),$);
#7124= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,28.);
#7125= IFCEXTRUDEDAREASOLID(#7124,#4685,#9,8.);
#7126= IFCSTYLEDITEM(#7125,(#558),$);
#7127= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4694);
#7128= IFCEXTRUDEDAREASOLID(#7127,#4697,#9,24.);
#7129= IFCSTYLEDITEM(#7128,(#558),$);
#7130= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#7110,#7113,#7116,#7119,#7122,#7125,#7128));
#7131= IFCREPRESENTATIONMAP(#10,#7130);
#7132= IFCMAPPEDITEM(#7131,#247);
#7133= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#7132));
#7134= IFCPRODUCTDEFINITIONSHAPE($,$,(#7133));
#7135= IFCMECHANICALFASTENER('1Td1iR0010oJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#7108,#7134,'ID5d9c1b1b-0000-40c9-3135-373035313136',30.,90.);
#7136= IFCLOCALPLACEMENT(#30,#10);
#7137= IFCELEMENTASSEMBLY('1Td1iR0015L34rDp0rCJ4s',#5,'Steel Assembly',$,$,#7136,$,'B/126(?)',.NOTDEFINED.,.RIGID_FRAME.);
#7138= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(674.073385749351),$);
#7139= IFCPROPERTYSET('1b_3yleJz9We$_xeWRjWfo',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#7138,#1453,#1454,#890,#5197,#5198));
#7140= IFCCARTESIANPOINT((40276.9951469627,-664.132537913409,-1126.00000000042));
#7141= IFCAXIS2PLACEMENT3D(#7140,#5201,#5202);
#7142= IFCLOCALPLACEMENT(#7136,#7141);
#7143= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5213));
#7144= IFCPRODUCTDEFINITIONSHAPE($,$,(#7143));
#7145= IFCDISCRETEACCESSORY('1Td1iR0012ep4rDp0rCJ4s',#5,'DETAY','PL16*58','PL16*58',#7142,#7144,'P/428(?)');
#7146= IFCPROPERTYSET('3PdiADn6n6sxC$71HHX9tN',#5,'Tekla Common','Common Properties to Shared building elements',(#1463,#1464,#5218,#5219,#74,#75,#919,#77,#78,#920,#921));
#7147= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(674.073385749351),$);
#7148= IFCPROPERTYSET('03fFNIBevBzg3wS7OOc6$y',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#7147,#5416,#5223,#5417,#927,#928,#929,#5225,#5226,#5418,#5228,#5229,#94,#5230));
#7149= IFCQUANTITYLENGTH('Width',$,$,57.993895159017);
#7150= IFCQUANTITYAREA('NetArea',$,$,0.028505556330189);
#7151= IFCQUANTITYAREA('GrossArea',$,$,0.0110166613780214);
#7152= IFCQUANTITYVOLUME('NetVolume',$,$,0.000169066494237496);
#7153= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000169066494237496);
#7154= IFCELEMENTQUANTITY('2IABdRYpH9tAA3jiqxtgtb',#5,'BaseQuantities',$,$,(#7149,#7150,#7151,#100,#7152,#7153));
#7155= IFCCARTESIANPOINT((40290.0045908795,-484.156332298588,-1173.99389343734));
#7156= IFCAXIS2PLACEMENT3D(#7155,#9,#5239);
#7157= IFCLOCALPLACEMENT(#7136,#7156);
#7158= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5249));
#7159= IFCPRODUCTDEFINITIONSHAPE($,$,(#7158));
#7160= IFCDISCRETEACCESSORY('1Td1iR0012fZ4rDp0rCJ4s',#5,'ANKRAJ','L20*3','L20*3',#7157,#7159,'P/477(?)');
#7161= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -1.164'),$);
#7162= IFCPROPERTYSET('0JQwg8qrH7ww4iedxhHFbX',#5,'Tekla Common','Common Properties to Shared building elements',(#1463,#7161,#5255,#5219,#74,#75,#919,#5256,#78,#5257,#80));
#7163= IFCPROPERTYSET('1QSHyxzyn2xw9W8iwbDHDK',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#7147,#5259,#5260,#5261,#5262,#5263,#5264,#5265,#5266,#5267,#5268,#1847,#5269,#5270));
#7164= IFCCARTESIANPOINT((40290.0009714322,-654.152372447439,-1173.99389343734));
#7165= IFCAXIS2PLACEMENT3D(#7164,#5278,#5279);
#7166= IFCLOCALPLACEMENT(#7136,#7165);
#7167= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5284));
#7168= IFCPRODUCTDEFINITIONSHAPE($,$,(#7167));
#7169= IFCDISCRETEACCESSORY('1Td1iR0012gJ4rDp0rCJ4s',#5,'ANKRAJ','L20*3','L20*3',#7166,#7168,'P/477(?)');
#7170= IFCPROPERTYSET('2W_DlmMXf8se2oby2S04wU',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#7147,#5289,#5290,#5291,#5292,#5293,#5294,#5295,#5266,#5296,#5297,#3352,#1848,#5298));
#7171= IFCCARTESIANPOINT((40467.505011749,-474.169997602407,-1192.));
#7172= IFCAXIS2PLACEMENT3D(#7171,#9,#185);
#7173= IFCLOCALPLACEMENT(#7136,#7172);
#7174= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5313));
#7175= IFCPRODUCTDEFINITIONSHAPE($,$,(#7174));
#7176= IFCDISCRETEACCESSORY('1Td1iR0012h34rDp0rCJ4s',#5,'DETAY','PL16*190','PL16*190',#7173,#7175,'P/424(?)');
#7177= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -1.200'),$);
#7178= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -1.184'),$);
#7179= IFCPROPERTYSET('2VB$eNzSLBOwZTyR3pq5Rd',#5,'Tekla Common','Common Properties to Shared building elements',(#7177,#7178,#5319,#5219,#74,#75,#919,#77,#78,#161,#921));
#7180= IFCPROPERTYSET('2sfm21V2z4vQPbL8KwaQzT',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#7147,#5321,#5322,#5323,#5324,#5325,#5326,#5327,#5328,#5329,#5330,#5331,#94,#5332));
#7181= IFCCARTESIANPOINT((40467.0011469627,-664.132537913409,-1126.00000000042));
#7182= IFCAXIS2PLACEMENT3D(#7181,#5201,#5202);
#7183= IFCLOCALPLACEMENT(#7136,#7182);
#7184= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5213));
#7185= IFCPRODUCTDEFINITIONSHAPE($,$,(#7184));
#7186= IFCDISCRETEACCESSORY('1Td1iR0012hp4rDp0rCJ4s',#5,'DETAY','PL16*58','PL16*58',#7183,#7185,'P/428(?)');
#7187= IFCLOCALPLACEMENT(#30,#10);
#7188= IFCELEMENTASSEMBLY('1Td1iR001ONp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#7187,$,'B/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#7189= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(1.3271719797643),$);
#7190= IFCPROPERTYSET('3ECOrDPxnERglz$59C9mZS',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#7189,#4308,#4309,#4310,#5873,#4251));
#7191= IFCQUANTITYLENGTH('Width',$,$,15.9999999999563);
#7192= IFCELEMENTQUANTITY('2XB$pZPQ97OPX$mK7MMEA9',#5,'BaseQuantities',$,$,(#7191));
#7193= IFCCARTESIANPOINT((40723.0048530373,-664.132537913409,-1126.00000000043));
#7194= IFCAXIS2PLACEMENT3D(#7193,#5347,#5202);
#7195= IFCLOCALPLACEMENT(#7187,#7194);
#7196= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5213));
#7197= IFCPRODUCTDEFINITIONSHAPE($,$,(#7196));
#7198= IFCPLATE('1Td1iR0012iZ4rDp0rCJ4s',#5,'DETAY','PL16*58','PL16*58',#7195,#7197,'P/428(?)');
#7199= IFCPROPERTYSET('1mLJQ67QHBAPI3qAY9MUyK',#5,'Tekla Common','Common Properties to Shared building elements',(#1463,#1464,#5218,#4268,#74,#75,#919,#77,#78,#920,#921));
#7200= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(1.3271719797643),$);
#7201= IFCPROPERTYSET('2uuaXD1XD72RiyWOOxnlJM',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#7200,#5416,#5223,#5417,#927,#928,#929,#5225,#5226,#5418,#5228,#5229,#94,#5230));
#7202= IFCQUANTITYVOLUME('NetVolume',$,$,0.00016906649423749);
#7203= IFCQUANTITYVOLUME('GrossVolume',$,$,0.00016906649423749);
#7204= IFCELEMENTQUANTITY('3hYyV53Cn9UwE0udZRYy2n',#5,'BaseQuantities',$,$,(#7149,#7150,#7151,#100,#7202,#7203));
#7205= IFCLOCALPLACEMENT(#30,#10);
#7206= IFCELEMENTASSEMBLY('1Td1iR001OO34rDp0rCJ4s',#5,'Steel Assembly',$,$,#7205,$,'ANK/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#7207= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(0.144189112786981),$);
#7208= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -1.164'),$);
#7209= IFCPROPERTYSET('09tqP45an8g8ug4mkkf_lR',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#7207,#4308,#7208,#39,#5947,#41));
#7210= IFCQUANTITYLENGTH('Width',$,$,20.0000000001226);
#7211= IFCELEMENTQUANTITY('1$Inho9_1CGggtVIMOqjka',#5,'BaseQuantities',$,$,(#7210));
#7212= IFCCARTESIANPOINT((40545.995053407,-484.152286737816,-1173.99389343734));
#7213= IFCAXIS2PLACEMENT3D(#7212,#9,#5361);
#7214= IFCLOCALPLACEMENT(#7205,#7213);
#7215= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5364));
#7216= IFCPRODUCTDEFINITIONSHAPE($,$,(#7215));
#7217= IFCBEAM('1Td1iR0012jJ4rDp0rCJ4s',#5,'ANKRAJ','L20*3','L20*3',#7214,#7216,'P/477(?)');
#7218= IFCBEAMTYPE('2GHP0Yka14cvY6nQm01qEH',#5,'L20*3',$,$,$,$,$,$,.NOTDEFINED.);
#7219= IFCPROPERTYSET('3o8Q$ncQP95B_2dq5E645P',#5,'Tekla Common','Common Properties to Shared building elements',(#1463,#7161,#5255,#73,#74,#75,#919,#5256,#78,#5257,#80));
#7220= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(0.144189112786981),$);
#7221= IFCPROPERTYSET('0W_PDqSeL47fIkQJ9IZ_2v',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#7220,#5259,#5260,#5261,#5262,#5263,#5264,#5265,#5266,#5267,#5268,#1847,#5269,#5270));
#7222= IFCLOCALPLACEMENT(#30,#10);
#7223= IFCELEMENTASSEMBLY('1Td1iR001OOJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#7222,$,'ANK/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#7224= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(0.144189435443997),$);
#7225= IFCPROPERTYSET('3WwAzOpof2v8_O$PBq_WYq',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#7224,#4308,#7208,#39,#5873,#41));
#7226= IFCCARTESIANPOINT((40545.9983058544,-654.148784767628,-1173.99389343734));
#7227= IFCAXIS2PLACEMENT3D(#7226,#5377,#5378);
#7228= IFCLOCALPLACEMENT(#7222,#7227);
#7229= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5284));
#7230= IFCPRODUCTDEFINITIONSHAPE($,$,(#7229));
#7231= IFCBEAM('1Td1iR0012k34rDp0rCJ4s',#5,'ANKRAJ','L20*3','L20*3',#7228,#7230,'P/477(?)');
#7232= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(0.144189435443997),$);
#7233= IFCPROPERTYSET('34kHuzgar3agLGxOMXudRI',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#7232,#5384,#5290,#5291,#5385,#5293,#5294,#5295,#5266,#5296,#5297,#3352,#1848,#5298));
#7234= IFCLOCALPLACEMENT(#30,#10);
#7235= IFCELEMENTASSEMBLY('1Td1iR001OOZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#7234,$,'B/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#7236= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(4.53377958156362),$);
#7237= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -1.184'),$);
#7238= IFCPROPERTYSET('1DeQ2b6hXDp8UG7kRjKJ4u',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#7236,#1453,#7237,#4310,#5873,#4251));
#7239= IFCCARTESIANPOINT((40532.494988251,-474.169997602407,-1192.));
#7240= IFCAXIS2PLACEMENT3D(#7239,#596,#7);
#7241= IFCLOCALPLACEMENT(#7234,#7240);
#7242= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5313));
#7243= IFCPRODUCTDEFINITIONSHAPE($,$,(#7242));
#7244= IFCPLATE('1Td1iR0012kp4rDp0rCJ4s',#5,'DETAY','PL16*190','PL16*190',#7241,#7243,'P/424(?)');
#7245= IFCPLATETYPE('3MSnQO8IT6Aub8RZnHMFla',#5,'PL16*190',$,$,$,$,$,$,.NOTDEFINED.);
#7246= IFCPROPERTYSET('37O7LTvZv5bfBfujPfz5DL',#5,'Tekla Common','Common Properties to Shared building elements',(#7177,#7178,#5319,#4268,#74,#75,#919,#77,#78,#161,#921));
#7247= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(4.53377958156362),$);
#7248= IFCPROPERTYSET('1vDai$NL57Cfd5vHPJPr3h',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#7247,#5321,#5322,#5323,#5324,#5325,#5326,#5327,#5328,#5329,#5330,#5331,#94,#5332));
#7249= IFCLOCALPLACEMENT(#30,#10);
#7250= IFCELEMENTASSEMBLY('1Td1iR0014_34rDp0rCJ4s',#5,'Steel Assembly',$,$,#7249,$,'A/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#7251= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(64.069865378797),$);
#7252= IFCPROPERTYSET('1dglLHio5AOAh7nU4ie2ic',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#7251,#1502,#1503,#989,#5873,#990));
#7253= IFCCARTESIANPOINT((40430.0009742969,-409.152085224178,-1193.));
#7254= IFCAXIS2PLACEMENT3D(#7253,#9,#7);
#7255= IFCLOCALPLACEMENT(#7249,#7254);
#7256= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1002));
#7257= IFCPRODUCTDEFINITIONSHAPE($,$,(#7256));
#7258= IFCDISCRETEACCESSORY('1Td1iR0012lZ4rDp0rCJ4s',#5,'PLATE','PL16*140','PL16*140',#7255,#7257,'P/0(?)');
#7259= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(64.069865378797),$);
#7260= IFCPROPERTYSET('0JBcs93cjAYRZeT11CWvV$',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#7259,#1014,#1015,#1016,#1017,#1018,#1019,#1020,#1021,#1022,#1023,#1024,#94,#1025));
#7261= IFCCARTESIANPOINT((40543.9994010579,-401.152088433781,-1110.));
#7262= IFCAXIS2PLACEMENT3D(#7261,#501,#185);
#7263= IFCLOCALPLACEMENT(#7249,#7262);
#7264= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1046));
#7265= IFCPRODUCTDEFINITIONSHAPE($,$,(#7264));
#7266= IFCDISCRETEACCESSORY('1Td1iR0012mJ4rDp0rCJ4s',#5,'PLATE','PL16*75','PL16*75',#7263,#7265,'P/0(?)');
#7267= IFCPROPERTYSET('3E1NF3MED01vzZM0jKCM1T',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#7259,#1054,#1055,#1056,#1057,#1058,#1059,#1060,#1061,#1062,#1063,#1064,#94,#1065));
#7268= IFCCARTESIANPOINT((40551.9994009154,-409.152092881741,-1185.005));
#7269= IFCAXIS2PLACEMENT3D(#7268,#185,#9);
#7270= IFCLOCALPLACEMENT(#7249,#7269);
#7271= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1081));
#7272= IFCPRODUCTDEFINITIONSHAPE($,$,(#7271));
#7273= IFCDISCRETEACCESSORY('1Td1iR0012n34rDp0rCJ4s',#5,'PLATE','PL16*75','PL16*75',#7270,#7272,'P/0(?)');
#7274= IFCPROPERTYSET('03xLOBVrD4SRtePyG8Af$a',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#7259,#1086,#1385,#1088,#1089,#1090,#1091,#1092,#1386,#1094,#1387,#1388,#1097,#1389));
#7275= IFCCARTESIANPOINT((40448.0009742969,-409.152086581707,-1185.005));
#7276= IFCAXIS2PLACEMENT3D(#7275,#185,#9);
#7277= IFCLOCALPLACEMENT(#7249,#7276);
#7278= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1081));
#7279= IFCPRODUCTDEFINITIONSHAPE($,$,(#7278));
#7280= IFCDISCRETEACCESSORY('1Td1iR0012np4rDp0rCJ4s',#5,'PLATE','PL16*75','PL16*75',#7277,#7279,'P/0(?)');
#7281= IFCPROPERTYSET('2AAke_a5r1iPnn2eeq44ki',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#7259,#1112,#1385,#1113,#1114,#1115,#1116,#1092,#1093,#1094,#1387,#1388,#1117,#1389));
#7282= IFCLOCALPLACEMENT(#30,#10);
#7283= IFCELEMENTASSEMBLY('1Td1iR001OOp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#7282,$,'B/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#7284= IFCCARTESIANPOINT((40532.9988530373,-664.132537913409,-1126.00000000043));
#7285= IFCAXIS2PLACEMENT3D(#7284,#5347,#5202);
#7286= IFCLOCALPLACEMENT(#7282,#7285);
#7287= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5213));
#7288= IFCPRODUCTDEFINITIONSHAPE($,$,(#7287));
#7289= IFCPLATE('1Td1iR0012oZ4rDp0rCJ4s',#5,'DETAY','PL16*58','PL16*58',#7286,#7288,'P/428(?)');
#7290= IFCCARTESIANPOINT((40171.0886298035,-157.192275561193,-1110.));
#7291= IFCAXIS2PLACEMENT3D(#7290,#9,#1125);
#7292= IFCLOCALPLACEMENT(#7249,#7291);
#7293= IFCCIRCLE(#1138,26.5157137785287);
#7294= IFCTRIMMEDCURVE(#7293,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.42863508545801)),.F.,.PARAMETER.);
#7295= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#7294);
#7296= IFCCOMPOSITECURVE((#7295,#1145),.F.);
#7297= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#7296);
#7298= IFCEXTRUDEDAREASOLID(#7297,#1151,#9,100.);
#7299= IFCBOOLEANRESULT(.DIFFERENCE.,#1135,#7298);
#7300= IFCCIRCLE(#1138,26.5157137785043);
#7301= IFCTRIMMEDCURVE(#7300,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.42863508545678)),.F.,.PARAMETER.);
#7302= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#7301);
#7303= IFCCOMPOSITECURVE((#7302,#1145),.F.);
#7304= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#7303);
#7305= IFCEXTRUDEDAREASOLID(#7304,#1162,#9,100.);
#7306= IFCBOOLEANRESULT(.DIFFERENCE.,#7299,#7305);
#7307= IFCCIRCLE(#1138,26.5157137784984);
#7308= IFCTRIMMEDCURVE(#7307,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.42863508545998)),.F.,.PARAMETER.);
#7309= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#7308);
#7310= IFCCOMPOSITECURVE((#7309,#1145),.F.);
#7311= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#7310);
#7312= IFCEXTRUDEDAREASOLID(#7311,#1173,#9,100.);
#7313= IFCBOOLEANRESULT(.DIFFERENCE.,#7306,#7312);
#7314= IFCCIRCLE(#1138,26.5157137785016);
#7315= IFCTRIMMEDCURVE(#7314,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.4286350854601)),.F.,.PARAMETER.);
#7316= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#7315);
#7317= IFCCOMPOSITECURVE((#7316,#1145),.F.);
#7318= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#7317);
#7319= IFCEXTRUDEDAREASOLID(#7318,#1184,#9,100.);
#7320= IFCBOOLEANRESULT(.DIFFERENCE.,#7313,#7319);
#7321= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#7320));
#7322= IFCPRODUCTDEFINITIONSHAPE($,$,(#7321));
#7323= IFCDISCRETEACCESSORY('1Td1iR0012sJ4rDp0rCJ4s',#5,'ANKRAJ','PLT30*240','PLT30*240',#7292,#7322,'P/370(?)');
#7324= IFCPROPERTYSET('2naHTqOY54aQm2QJW0k0Am',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#7259,#3000,#1198,#3001,#3002,#1201,#3004,#1203,#1204,#3006,#1206,#1207,#1208,#1209));
#7325= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.374594953106507);
#7326= IFCQUANTITYVOLUME('NetVolume',$,$,0.00481827878120545);
#7327= IFCQUANTITYWEIGHT('NetWeight',$,$,37.8234884324628);
#7328= IFCELEMENTQUANTITY('0ul7EYcqn7cxvUa01zIIY3',#5,'BaseQuantities',$,$,(#1211,#7325,#7326,#7327));
#7329= IFCCARTESIANPOINT((32623.0048530373,-664.132537913409,-1126.00000000043));
#7330= IFCAXIS2PLACEMENT3D(#7329,#5347,#5202);
#7331= IFCLOCALPLACEMENT(#7136,#7330);
#7332= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5213));
#7333= IFCPRODUCTDEFINITIONSHAPE($,$,(#7332));
#7334= IFCDISCRETEACCESSORY('1Td1iR0012wp4rDp0rCJ4s',#5,'DETAY','PL16*58','PL16*58',#7331,#7333,'P/428(?)');
#7335= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(1.32717197976835),$);
#7336= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(1.32717197976835),$);
#7337= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.028505556330211),$);
#7338= IFCPROPERTYSET('1AAAzr8n58kef$fHIfylLW',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#7147,#7335,#5223,#7336,#927,#928,#929,#5225,#5226,#7337,#5228,#5229,#94,#5230));
#7339= IFCQUANTITYLENGTH('Width',$,$,57.9938951589982);
#7340= IFCQUANTITYAREA('NetArea',$,$,0.028505556330211);
#7341= IFCQUANTITYAREA('GrossArea',$,$,0.0110166613780178);
#7342= IFCQUANTITYVOLUME('NetVolume',$,$,0.000169066494238007);
#7343= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000169066494238007);
#7344= IFCELEMENTQUANTITY('1O3TTQoJn4chDmEDzKkF88',#5,'BaseQuantities',$,$,(#7339,#7340,#7341,#100,#7342,#7343));
#7345= IFCCARTESIANPOINT((32445.995053407,-484.152286737816,-1173.99389343734));
#7346= IFCAXIS2PLACEMENT3D(#7345,#9,#5361);
#7347= IFCLOCALPLACEMENT(#7136,#7346);
#7348= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5429));
#7349= IFCPRODUCTDEFINITIONSHAPE($,$,(#7348));
#7350= IFCDISCRETEACCESSORY('1Td1iR0012xZ4rDp0rCJ4s',#5,'ANKRAJ','L20*3','L20*3',#7347,#7349,'P/477(?)');
#7351= IFCPROPERTYSET('1glf1t3L523xSGe3vBlgD4',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#7147,#5434,#5260,#5261,#5292,#5263,#5264,#5265,#5266,#5267,#5268,#1847,#5269,#5270));
#7352= IFCCARTESIANPOINT((32445.9983058544,-654.148784767628,-1173.99389343734));
#7353= IFCAXIS2PLACEMENT3D(#7352,#5377,#5378);
#7354= IFCLOCALPLACEMENT(#7136,#7353);
#7355= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5284));
#7356= IFCPRODUCTDEFINITIONSHAPE($,$,(#7355));
#7357= IFCDISCRETEACCESSORY('1Td1iR0012yJ4rDp0rCJ4s',#5,'ANKRAJ','L20*3','L20*3',#7354,#7356,'P/477(?)');
#7358= IFCPROPERTYSET('07EARsTNH1mB2zpY_pSP1E',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#7147,#5447,#5290,#5291,#5448,#5293,#5294,#5449,#5266,#5450,#5297,#1847,#1848,#5298));
#7359= IFCCARTESIANPOINT((32432.494988251,-474.169997602407,-1192.));
#7360= IFCAXIS2PLACEMENT3D(#7359,#596,#7);
#7361= IFCLOCALPLACEMENT(#7136,#7360);
#7362= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5313));
#7363= IFCPRODUCTDEFINITIONSHAPE($,$,(#7362));
#7364= IFCDISCRETEACCESSORY('1Td1iR0012z34rDp0rCJ4s',#5,'DETAY','PL16*190','PL16*190',#7361,#7363,'P/424(?)');
#7365= IFCPROPERTYSET('0WQ38hLA59FR6mXLj1ai8c',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#7147,#5321,#5461,#5323,#5324,#5325,#5326,#5327,#5328,#5329,#5462,#5463,#94,#5332));
#7366= IFCCARTESIANPOINT((32432.9988530373,-664.132537913409,-1126.00000000043));
#7367= IFCAXIS2PLACEMENT3D(#7366,#5347,#5202);
#7368= IFCLOCALPLACEMENT(#7136,#7367);
#7369= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5213));
#7370= IFCPRODUCTDEFINITIONSHAPE($,$,(#7369));
#7371= IFCDISCRETEACCESSORY('1Td1iR00130p4rDp0rCJ4s',#5,'DETAY','PL16*58','PL16*58',#7368,#7370,'P/428(?)');
#7372= IFCLOCALPLACEMENT(#30,#10);
#7373= IFCELEMENTASSEMBLY('1Td1iR0014tJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#7372,$,'ANK/61(?)',.NOTDEFINED.,.RIGID_FRAME.);
#7374= IFCPROPERTYSET('2ihEP7sLbCZxVGIYFFOl4z',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#5946,#2309,#2310,#1614,#5947,#1616));
#7375= IFCCARTESIANPOINT((40363.8303183166,-238.761303583805,-1110.));
#7376= IFCAXIS2PLACEMENT3D(#7375,#9,#1621);
#7377= IFCLOCALPLACEMENT(#7372,#7376);
#7378= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5954));
#7379= IFCPRODUCTDEFINITIONSHAPE($,$,(#7378));
#7380= IFCBEAM('1Td1iR0014tZ4rDp0rCJ4s',#5,'PUL','PLT30*150','PLT30*150',#7377,#7379,'P/377(?)');
#7381= IFCLOCALPLACEMENT(#30,#10);
#7382= IFCELEMENTASSEMBLY('1Td1iR0014uJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#7381,$,'ANK/61(?)',.NOTDEFINED.,.RIGID_FRAME.);
#7383= IFCPROPERTYSET('03WL_5VCf5A9HI9Sd$yDmL',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1665,#2309,#2310,#1614,#5947,#1616));
#7384= IFCCARTESIANPOINT((40636.1696399369,-238.76131148119,-1110.));
#7385= IFCAXIS2PLACEMENT3D(#7384,#9,#1670);
#7386= IFCLOCALPLACEMENT(#7381,#7385);
#7387= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5985));
#7388= IFCPRODUCTDEFINITIONSHAPE($,$,(#7387));
#7389= IFCBEAM('1Td1iR0014uZ4rDp0rCJ4s',#5,'PUL','PLT30*150','PLT30*150',#7386,#7388,'P/377(?)');
#7390= IFCLOCALPLACEMENT(#30,#10);
#7391= IFCELEMENTASSEMBLY('1Td1iR0014vJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#7390,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#7392= IFCPROPERTYSET('1o9DIEcef7pPoZjETgucN7',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#2331,#2332,#1700,#5947,#1701));
#7393= IFCCARTESIANPOINT((40716.8561910801,-257.190864719634,-1110.));
#7394= IFCAXIS2PLACEMENT3D(#7393,#1706,#1707);
#7395= IFCLOCALPLACEMENT(#7390,#7394);
#7396= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6635));
#7397= IFCPRODUCTDEFINITIONSHAPE($,$,(#7396));
#7398= IFCBEAM('1Td1iR0014vZ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#7395,#7397,'XX/0(?)');
#7399= IFCLOCALPLACEMENT(#30,#10);
#7400= IFCELEMENTASSEMBLY('1Td1iR0014wJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#7399,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#7401= IFCCARTESIANPOINT((40713.4878455301,-241.549277321979,-1110.));
#7402= IFCAXIS2PLACEMENT3D(#7401,#1706,#1707);
#7403= IFCLOCALPLACEMENT(#7399,#7402);
#7404= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6648));
#7405= IFCPRODUCTDEFINITIONSHAPE($,$,(#7404));
#7406= IFCBEAM('1Td1iR0014wZ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#7403,#7405,'XX/0(?)');
#7407= IFCLOCALPLACEMENT(#30,#10);
#7408= IFCELEMENTASSEMBLY('1Td1iR0014xJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#7407,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#7409= IFCPROPERTYSET('1uMJiVxST0eOm9nrwtYZK6',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#2353,#2354,#1775,#5947,#1701));
#7410= IFCCARTESIANPOINT((40712.6453400033,-237.638892502498,-1110.));
#7411= IFCAXIS2PLACEMENT3D(#7410,#1670,#1780);
#7412= IFCLOCALPLACEMENT(#7407,#7411);
#7413= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6659));
#7414= IFCPRODUCTDEFINITIONSHAPE($,$,(#7413));
#7415= IFCBEAM('1Td1iR0014xZ4rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#7412,#7414,'XX/0(?)');
#7416= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00180062582325918);
#7417= IFCQUANTITYVOLUME('NetVolume',$,$,3.93300000000792E-006);
#7418= IFCELEMENTQUANTITY('0mBbeidCL5oAgwGPqZFyNj',#5,'BaseQuantities',$,$,(#6036,#7416,#7417,#1754));
#7419= IFCLOCALPLACEMENT(#30,#10);
#7420= IFCELEMENTASSEMBLY('1Td1iR0014yJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#7419,$,'R/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#7421= IFCPROPERTYSET('07zK4csNbAyvn9yXHLKtSx',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#2370,#2371,#1814,#5947,#1815));
#7422= IFCCARTESIANPOINT((40725.1344111934,-295.638490283996,-1110.));
#7423= IFCAXIS2PLACEMENT3D(#7422,#1820,#1821);
#7424= IFCLOCALPLACEMENT(#7419,#7423);
#7425= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6673));
#7426= IFCPRODUCTDEFINITIONSHAPE($,$,(#7425));
#7427= IFCBEAM('1Td1iR0014yZ4rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#7424,#7426,'P/0(?)');
#7428= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0232205665089693);
#7429= IFCQUANTITYVOLUME('NetVolume',$,$,0.00010465190472489);
#7430= IFCELEMENTQUANTITY('1u1CQA4x11VQDm3uWaBYAp',#5,'BaseQuantities',$,$,(#6052,#7428,#7429,#1754));
#7431= IFCCARTESIANPOINT((40569.9999731708,-444.15209193049,-1102.));
#7432= IFCAXIS2PLACEMENT3D(#7431,#9,#8);
#7433= IFCLOCALPLACEMENT(#7249,#7432);
#7434= IFCBOOLEANRESULT(.DIFFERENCE.,#6074,#1894);
#7435= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#7434));
#7436= IFCPRODUCTDEFINITIONSHAPE($,$,(#7435));
#7437= IFCPLATE('1Td1iR0014_J4rDp0rCJ4s',#5,'ANCHOR','PL16*436','PL16*436',#7433,#7436,'P/0(?)');
#7438= IFCPROPERTYSET('2VSNNwx0PCrR4iF0HcmBnu',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#7259,#6080,#6081,#6082,#6083,#6084,#6085,#6086,#6087,#6088,#6089,#6090,#94,#6091));
#7439= IFCLOCALPLACEMENT(#30,#10);
#7440= IFCELEMENTASSEMBLY('1Td1iR0014$34rDp0rCJ4s',#5,'Steel Assembly',$,$,#7439,$,'ANK/63(?)',.NOTDEFINED.,.RIGID_FRAME.);
#7441= IFCPROPERTYSET('3KAyIY5HP9uOJfdQ4kQjkb',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#6101,#486,#487,#39,#5873,#489));
#7442= IFCCARTESIANPOINT((40634.9987504166,-484.152103045623,-1086.));
#7443= IFCAXIS2PLACEMENT3D(#7442,#7,#501);
#7444= IFCLOCALPLACEMENT(#7439,#7443);
#7445= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6109));
#7446= IFCPRODUCTDEFINITIONSHAPE($,$,(#7445));
#7447= IFCBEAM('1Td1iR0014$J4rDp0rCJ4s',#5,'ANKRAJ','PLT16*140','PLT16*140',#7444,#7446,'P/379(?)');
#7448= IFCPROPERTYSET('17LGSfNC53J90UGa6sTy_g',#5,'Tekla Common','Common Properties to Shared building elements',(#510,#511,#512,#513,#74,#75,#919,#515,#78,#6115,#80));
#7449= IFCLOCALPLACEMENT(#30,#10);
#7450= IFCELEMENTASSEMBLY('1Td1iR0015034rDp0rCJ4s',#5,'Steel Assembly',$,$,#7449,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#7451= IFCCARTESIANPOINT((40283.1442023679,-257.190838696386,-1110.));
#7452= IFCAXIS2PLACEMENT3D(#7451,#1928,#1929);
#7453= IFCLOCALPLACEMENT(#7449,#7452);
#7454= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6705));
#7455= IFCPRODUCTDEFINITIONSHAPE($,$,(#7454));
#7456= IFCBEAM('1Td1iR00150J4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#7453,#7455,'XX/0(?)');
#7457= IFCLOCALPLACEMENT(#30,#10);
#7458= IFCELEMENTASSEMBLY('1Td1iR0015134rDp0rCJ4s',#5,'Steel Assembly',$,$,#7457,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#7459= IFCCARTESIANPOINT((40286.5125497949,-241.549251702941,-1110.));
#7460= IFCAXIS2PLACEMENT3D(#7459,#1928,#1929);
#7461= IFCLOCALPLACEMENT(#7457,#7460);
#7462= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6721));
#7463= IFCPRODUCTDEFINITIONSHAPE($,$,(#7462));
#7464= IFCBEAM('1Td1iR00151J4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#7461,#7463,'XX/0(?)');
#7465= IFCLOCALPLACEMENT(#30,#10);
#7466= IFCELEMENTASSEMBLY('1Td1iR0015234rDp0rCJ4s',#5,'Steel Assembly',$,$,#7465,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#7467= IFCCARTESIANPOINT((40287.355055791,-237.638866984563,-1110.));
#7468= IFCAXIS2PLACEMENT3D(#7467,#1621,#1966);
#7469= IFCLOCALPLACEMENT(#7465,#7468);
#7470= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6734));
#7471= IFCPRODUCTDEFINITIONSHAPE($,$,(#7470));
#7472= IFCBEAM('1Td1iR00152J4rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#7469,#7471,'XX/0(?)');
#7473= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.00180062582326105),$);
#7474= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.00180062582326105),$);
#7475= IFCPROPERTYSET('1WkbJ9IvHFMeQNYdP7rIwb',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#6176,#6177,#6178,#1743,#1744,#7473,#7474,#1979,#1803,#1804));
#7476= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00180062582326105);
#7477= IFCQUANTITYVOLUME('NetVolume',$,$,3.93300000001487E-006);
#7478= IFCELEMENTQUANTITY('0B2PyNZa93VhGvMmw7ta1k',#5,'BaseQuantities',$,$,(#6739,#7476,#7477,#1754));
#7479= IFCLOCALPLACEMENT(#30,#10);
#7480= IFCELEMENTASSEMBLY('1Td1iR0015334rDp0rCJ4s',#5,'Steel Assembly',$,$,#7479,$,'R/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#7481= IFCCARTESIANPOINT((40274.8659776408,-295.638463267341,-1110.));
#7482= IFCAXIS2PLACEMENT3D(#7481,#1988,#1989);
#7483= IFCLOCALPLACEMENT(#7479,#7482);
#7484= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6748));
#7485= IFCPRODUCTDEFINITIONSHAPE($,$,(#7484));
#7486= IFCBEAM('1Td1iR00153J4rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#7483,#7485,'P/0(?)');
#7487= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000104651904725294),$);
#7488= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000104651904725294),$);
#7489= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000104651904725294),$);
#7490= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0232205665090266),$);
#7491= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0232205665090266),$);
#7492= IFCPROPERTYSET('2Iv5TLGjHDhuPmTG6AxmeR',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#7487,#7488,#7489,#1743,#1744,#7490,#7491,#1847,#1848,#6200));
#7493= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0232205665090266);
#7494= IFCQUANTITYVOLUME('NetVolume',$,$,0.000104651904725294);
#7495= IFCELEMENTQUANTITY('1tqG$ADyfDnforF_hu9Q5h',#5,'BaseQuantities',$,$,(#6202,#7493,#7494,#1754));
#7496= IFCLOCALPLACEMENT(#30,#10);
#7497= IFCELEMENTASSEMBLY('1Td1iR0015434rDp0rCJ4s',#5,'Steel Assembly',$,$,#7496,$,'ANK/63(?)',.NOTDEFINED.,.RIGID_FRAME.);
#7498= IFCCARTESIANPOINT((40365.0016157955,-484.152086845482,-1086.));
#7499= IFCAXIS2PLACEMENT3D(#7498,#7,#501);
#7500= IFCLOCALPLACEMENT(#7496,#7499);
#7501= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6211));
#7502= IFCPRODUCTDEFINITIONSHAPE($,$,(#7501));
#7503= IFCBEAM('1Td1iR00154J4rDp0rCJ4s',#5,'ANKRAJ','PLT16*140','PLT16*140',#7500,#7502,'P/379(?)');
#7504= IFCCARTESIANPOINT((32424.9956594666,-569.169997411911,-1155.));
#7505= IFCDIRECTION((2.39759999935113E-005,-0.999999999712576,0.));
#7506= IFCAXIS2PLACEMENT3D(#7504,#7505,#5239);
#7507= IFCLOCALPLACEMENT(#7136,#7506);
#7508= IFCEXTRUDEDAREASOLID(#5623,#5669,#9,8050.00280824916);
#7509= IFCCARTESIANPOINT((197.500610351915,-4.1086423152592E-010));
#7510= IFCCARTESIANPOINT((197.50187683167,190.036026000188));
#7511= IFCCARTESIANPOINT((0.000971605390077457,190.036102294874));
#7512= IFCPOLYLINE((#54,#7509,#7510,#7511,#54,#54));
#7513= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL40*190',#7512);
#7514= IFCDIRECTION((-0.999999999567055,0.,-2.94259999910304E-005));
#7515= IFCCARTESIANPOINT((197.501522450293,-24.9999999999993,94.9870645226654));
#7516= IFCAXIS2PLACEMENT3D(#7515,#501,#7514);
#7517= IFCEXTRUDEDAREASOLID(#7513,#7516,#9,40.);
#7518= IFCBOOLEANRESULT(.DIFFERENCE.,#7508,#7517);
#7519= IFCCARTESIANPOINT((200.00170898201,1.32467903313227E-009));
#7520= IFCCARTESIANPOINT((200.004821776041,189.982345582485));
#7521= IFCPOLYLINE((#54,#7519,#7520,#5310,#54,#54));
#7522= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL16*190',#7521);
#7523= IFCCARTESIANPOINT((8052.50646762137,-44.9999999999993,-94.9989978505415));
#7524= IFCAXIS2PLACEMENT3D(#7523,#8,#185);
#7525= IFCEXTRUDEDAREASOLID(#7522,#7524,#9,16.);
#7526= IFCBOOLEANRESULT(.DIFFERENCE.,#7518,#7525);
#7527= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#7526));
#7528= IFCSTYLEDITEM(#7508,(#4032),$);
#7529= IFCPRODUCTDEFINITIONSHAPE($,$,(#7527));
#7530= IFCBEAM('1Td1iR0015LJ4rDp0rCJ4s',#5,'KIRIS','WB240-16-25*90-0','WB240-16-25*90-0',#7507,#7529,'P/252(?)');
#7531= IFCPROPERTYSET('1RM3CqBQv2EOyufMz9$WBg',#5,'Tekla Common','Common Properties to Shared building elements',(#7177,#1521,#5675,#5219,#74,#75,#919,#5643,#78,#5644,#4185));
#7532= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(659.120381570696),$);
#7533= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(668.576883233549),$);
#7534= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(659.120381570696),$);
#7535= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.0839643798179231),$);
#7536= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.0851690297112801),$);
#7537= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.0839643798179231),$);
#7538= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(1.9320006739798),$);
#7539= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(13.9423619814063),$);
#7540= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(9.18969494918126),$);
#7541= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(9.32696324633641),$);
#7542= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(8050.00280824942),$);
#7543= IFCPROPERTYSET('2N7845TAX5ChLLBNivYYFN',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#7147,#7532,#7533,#7534,#7535,#7536,#7537,#7538,#7539,#7540,#7541,#5656,#5657,#7542));
#7544= IFCQUANTITYLENGTH('Length',$,$,8050.00280824942);
#7545= IFCQUANTITYAREA('OuterSurfaceArea',$,$,9.18969494918126);
#7546= IFCQUANTITYVOLUME('NetVolume',$,$,0.0839643798179231);
#7547= IFCQUANTITYWEIGHT('NetWeight',$,$,659.120381570696);
#7548= IFCELEMENTQUANTITY('3e0jmBU1v8KhPNrMaIUOys',#5,'BaseQuantities',$,$,(#7544,#7545,#7546,#7547));
#7549= IFCCARTESIANPOINT((40288.4976961945,-232.330062517137,4890.));
#7550= IFCAXIS2PLACEMENT3D(#7549,#596,#597);
#7551= IFCLOCALPLACEMENT(#30,#7550);
#7552= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#7553= IFCEXTRUDEDAREASOLID(#7552,#602,#9,30.1000000000098);
#7554= IFCSTYLEDITEM(#7553,(#195),$);
#7555= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#7553));
#7556= IFCREPRESENTATIONMAP(#10,#7555);
#7557= IFCMAPPEDITEM(#7556,#247);
#7558= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#7557));
#7559= IFCPRODUCTDEFINITIONSHAPE($,$,(#7558));
#7560= IFCMECHANICALFASTENER('1Td1iR001AU34rDp0rCJ4s',#5,'Bolt assembly',$,$,#7551,#7559,'ID5d9c1b1b-0000-4a78-3135-373035313136',20.,30.);
#7561= IFCCARTESIANPOINT((40705.1872659515,-203.002074025752,4890.));
#7562= IFCAXIS2PLACEMENT3D(#7561,#9,#620);
#7563= IFCLOCALPLACEMENT(#30,#7562);
#7564= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,71.);
#7565= IFCEXTRUDEDAREASOLID(#7564,#625,#9,30.1063464563373);
#7566= IFCSTYLEDITEM(#7565,(#195),$);
#7567= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#7565));
#7568= IFCREPRESENTATIONMAP(#10,#7567);
#7569= IFCMAPPEDITEM(#7568,#247);
#7570= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#7569));
#7571= IFCPRODUCTDEFINITIONSHAPE($,$,(#7570));
#7572= IFCMECHANICALFASTENER('1Td1iR001AUp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#7563,#7571,'ID5d9c1b1b-0000-4a7b-3135-373035313136',20.,30.0063457489014);
#7573= IFCCARTESIANPOINT((40711.502262432,-232.330074783567,4890.));
#7574= IFCAXIS2PLACEMENT3D(#7573,#9,#640);
#7575= IFCLOCALPLACEMENT(#30,#7574);
#7576= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#7577= IFCEXTRUDEDAREASOLID(#7576,#602,#9,30.1000000000079);
#7578= IFCSTYLEDITEM(#7577,(#195),$);
#7579= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#7577));
#7580= IFCREPRESENTATIONMAP(#10,#7579);
#7581= IFCMAPPEDITEM(#7580,#247);
#7582= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#7581));
#7583= IFCPRODUCTDEFINITIONSHAPE($,$,(#7582));
#7584= IFCMECHANICALFASTENER('1Td1iR001AVZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#7575,#7583,'ID5d9c1b1b-0000-4a7e-3135-373035313136',20.,30.);
#7585= IFCCARTESIANPOINT((40294.8131339993,-203.002049402811,4890.));
#7586= IFCAXIS2PLACEMENT3D(#7585,#596,#653);
#7587= IFCLOCALPLACEMENT(#30,#7586);
#7588= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,71.);
#7589= IFCEXTRUDEDAREASOLID(#7588,#658,#9,30.1061745233263);
#7590= IFCSTYLEDITEM(#7589,(#195),$);
#7591= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#7589));
#7592= IFCREPRESENTATIONMAP(#10,#7591);
#7593= IFCMAPPEDITEM(#7592,#247);
#7594= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#7593));
#7595= IFCPRODUCTDEFINITIONSHAPE($,$,(#7594));
#7596= IFCMECHANICALFASTENER('1Td1iR001AWJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#7587,#7595,'ID5d9c1b1b-0000-4a81-3135-373035313136',20.,30.0061740875244);
#7597= IFCCARTESIANPOINT((40634.9983581212,-554.153090053148,4939.995));
#7598= IFCAXIS2PLACEMENT3D(#7597,#501,#185);
#7599= IFCLOCALPLACEMENT(#30,#7598);
#7600= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,16.5);
#7601= IFCEXTRUDEDAREASOLID(#7600,#4638,#9,16.1);
#7602= IFCSTYLEDITEM(#7601,(#195),$);
#7603= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,16.5);
#7604= IFCEXTRUDEDAREASOLID(#7603,#4643,#9,16.);
#7605= IFCSTYLEDITEM(#7604,(#195),$);
#7606= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4660);
#7607= IFCEXTRUDEDAREASOLID(#7606,#4663,#9,15.9999999999996);
#7608= IFCSTYLEDITEM(#7607,(#195),$);
#7609= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4672);
#7610= IFCEXTRUDEDAREASOLID(#7609,#4675,#9,19.8);
#7611= IFCSTYLEDITEM(#7610,(#558),$);
#7612= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,15.);
#7613= IFCEXTRUDEDAREASOLID(#7612,#4680,#9,90.);
#7614= IFCSTYLEDITEM(#7613,(#558),$);
#7615= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,28.);
#7616= IFCEXTRUDEDAREASOLID(#7615,#4685,#9,8.);
#7617= IFCSTYLEDITEM(#7616,(#558),$);
#7618= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4694);
#7619= IFCEXTRUDEDAREASOLID(#7618,#4697,#9,24.);
#7620= IFCSTYLEDITEM(#7619,(#558),$);
#7621= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#7601,#7604,#7607,#7610,#7613,#7616,#7619));
#7622= IFCREPRESENTATIONMAP(#10,#7621);
#7623= IFCMAPPEDITEM(#7622,#247);
#7624= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#7623));
#7625= IFCPRODUCTDEFINITIONSHAPE($,$,(#7624));
#7626= IFCMECHANICALFASTENER('1Td1iR001AX34rDp0rCJ4s',#5,'Bolt assembly',$,$,#7599,#7625,'ID5d9c1b1b-0000-4a84-3135-373035313136',30.,90.);
#7627= IFCCARTESIANPOINT((40634.9988455077,-554.152715152363,4887.999));
#7628= IFCAXIS2PLACEMENT3D(#7627,#501,#185);
#7629= IFCLOCALPLACEMENT(#30,#7628);
#7630= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,40.);
#7631= IFCEXTRUDEDAREASOLID(#7630,#561,#9,16.1);
#7632= IFCSTYLEDITEM(#7631,(#195),$);
#7633= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#7631));
#7634= IFCREPRESENTATIONMAP(#10,#7633);
#7635= IFCMAPPEDITEM(#7634,#247);
#7636= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#7635));
#7637= IFCPRODUCTDEFINITIONSHAPE($,$,(#7636));
#7638= IFCMECHANICALFASTENER('1Td1iR001AXp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#7629,#7637,'ID5d9c1b1b-0000-4a87-3135-373035313136',30.,16.);
#7639= IFCCARTESIANPOINT((40365.0017174869,-554.152698952219,4887.999));
#7640= IFCAXIS2PLACEMENT3D(#7639,#8,#7);
#7641= IFCLOCALPLACEMENT(#30,#7640);
#7642= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,40.);
#7643= IFCEXTRUDEDAREASOLID(#7642,#561,#9,16.0999999999997);
#7644= IFCSTYLEDITEM(#7643,(#195),$);
#7645= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#7643));
#7646= IFCREPRESENTATIONMAP(#10,#7645);
#7647= IFCMAPPEDITEM(#7646,#247);
#7648= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#7647));
#7649= IFCPRODUCTDEFINITIONSHAPE($,$,(#7648));
#7650= IFCMECHANICALFASTENER('1Td1iR001AYZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#7641,#7649,'ID5d9c1b1b-0000-4a8a-3135-373035313136',30.,16.);
#7651= IFCCARTESIANPOINT((40365.0019996906,-554.153073853048,4939.995));
#7652= IFCAXIS2PLACEMENT3D(#7651,#8,#7);
#7653= IFCLOCALPLACEMENT(#30,#7652);
#7654= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,16.5);
#7655= IFCEXTRUDEDAREASOLID(#7654,#4663,#9,15.9999999999999);
#7656= IFCSTYLEDITEM(#7655,(#195),$);
#7657= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,16.5);
#7658= IFCEXTRUDEDAREASOLID(#7657,#4643,#9,15.9999999999997);
#7659= IFCSTYLEDITEM(#7658,(#195),$);
#7660= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,16.5);
#7661= IFCEXTRUDEDAREASOLID(#7660,#4638,#9,16.1);
#7662= IFCSTYLEDITEM(#7661,(#195),$);
#7663= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4672);
#7664= IFCEXTRUDEDAREASOLID(#7663,#4675,#9,19.8);
#7665= IFCSTYLEDITEM(#7664,(#558),$);
#7666= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,15.);
#7667= IFCEXTRUDEDAREASOLID(#7666,#4680,#9,90.);
#7668= IFCSTYLEDITEM(#7667,(#558),$);
#7669= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,28.);
#7670= IFCEXTRUDEDAREASOLID(#7669,#4685,#9,8.);
#7671= IFCSTYLEDITEM(#7670,(#558),$);
#7672= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4694);
#7673= IFCEXTRUDEDAREASOLID(#7672,#4697,#9,24.);
#7674= IFCSTYLEDITEM(#7673,(#558),$);
#7675= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#7655,#7658,#7661,#7664,#7667,#7670,#7673));
#7676= IFCREPRESENTATIONMAP(#10,#7675);
#7677= IFCMAPPEDITEM(#7676,#247);
#7678= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#7677));
#7679= IFCPRODUCTDEFINITIONSHAPE($,$,(#7678));
#7680= IFCMECHANICALFASTENER('1Td1iR001AZJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#7653,#7679,'ID5d9c1b1b-0000-4a8d-3135-373035313136',30.,90.);
#7681= IFCLOCALPLACEMENT(#30,#10);
#7682= IFCELEMENTASSEMBLY('1Td1iR001xJZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#7681,$,'B/126(?)',.NOTDEFINED.,.RIGID_FRAME.);
#7683= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(682.038922602109),$);
#7684= IFCPROPERTYSET('2B_b7UNuj68vII01$1EjEa',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#7683,#1308,#1309,#890,#5197,#5198));
#7685= IFCCARTESIANPOINT((40276.9951469627,-664.132537913409,4873.99999999958));
#7686= IFCAXIS2PLACEMENT3D(#7685,#5201,#5202);
#7687= IFCLOCALPLACEMENT(#7681,#7686);
#7688= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5213));
#7689= IFCPRODUCTDEFINITIONSHAPE($,$,(#7688));
#7690= IFCDISCRETEACCESSORY('1Td1iR001AaJ4rDp0rCJ4s',#5,'DETAY','PL16*58','PL16*58',#7687,#7689,'P/428(?)');
#7691= IFCPROPERTYSET('1uXVZfd0r8GPNPsj4cxsr5',#5,'Tekla Common','Common Properties to Shared building elements',(#1318,#1319,#5218,#5219,#74,#75,#919,#77,#78,#920,#921));
#7692= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(682.038922602109),$);
#7693= IFCPROPERTYSET('31W1CAezP5e8jxxRzpiPx7',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#7692,#5222,#5223,#5224,#927,#928,#929,#5225,#5354,#5227,#5228,#5229,#94,#5230));
#7694= IFCQUANTITYLENGTH('Width',$,$,57.9938951590175);
#7695= IFCQUANTITYAREA('NetArea',$,$,0.0285055563301837);
#7696= IFCQUANTITYAREA('GrossArea',$,$,0.0110166613780211);
#7697= IFCQUANTITYVOLUME('NetVolume',$,$,0.000169066494237457);
#7698= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000169066494237457);
#7699= IFCELEMENTQUANTITY('2FXeo_w2DEjeCCXx4Ww8Ls',#5,'BaseQuantities',$,$,(#7694,#7695,#7696,#100,#7697,#7698));
#7700= IFCCARTESIANPOINT((40290.0045908795,-484.156332298588,4826.00610656266));
#7701= IFCAXIS2PLACEMENT3D(#7700,#9,#5239);
#7702= IFCLOCALPLACEMENT(#7681,#7701);
#7703= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5249));
#7704= IFCPRODUCTDEFINITIONSHAPE($,$,(#7703));
#7705= IFCDISCRETEACCESSORY('1Td1iR001AbJ4rDp0rCJ4s',#5,'ANKRAJ','L20*3','L20*3',#7702,#7704,'P/477(?)');
#7706= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +4.836'),$);
#7707= IFCPROPERTYSET('0wkeKVMnL4kwxRnU7csMHt',#5,'Tekla Common','Common Properties to Shared building elements',(#1318,#7706,#5255,#5219,#74,#75,#919,#5256,#78,#5257,#80));
#7708= IFCPROPERTYSET('2xNjDXKu9F5v5_fRmZUmU7',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#7692,#5259,#5260,#5261,#5262,#5263,#5264,#5265,#5266,#5267,#5268,#1847,#5269,#5270));
#7709= IFCCARTESIANPOINT((40290.0009714322,-654.152372447439,4826.00610656266));
#7710= IFCAXIS2PLACEMENT3D(#7709,#5278,#5279);
#7711= IFCLOCALPLACEMENT(#7681,#7710);
#7712= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5284));
#7713= IFCPRODUCTDEFINITIONSHAPE($,$,(#7712));
#7714= IFCDISCRETEACCESSORY('1Td1iR001AcJ4rDp0rCJ4s',#5,'ANKRAJ','L20*3','L20*3',#7711,#7713,'P/477(?)');
#7715= IFCPROPERTYSET('3AoMMXac52Jg$NDMXGpvhe',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#7692,#5289,#5290,#5291,#5292,#5293,#5294,#5295,#5266,#5296,#5297,#3352,#1848,#5298));
#7716= IFCCARTESIANPOINT((40467.505011749,-474.169997602407,4808.));
#7717= IFCAXIS2PLACEMENT3D(#7716,#9,#185);
#7718= IFCLOCALPLACEMENT(#7681,#7717);
#7719= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5313));
#7720= IFCPRODUCTDEFINITIONSHAPE($,$,(#7719));
#7721= IFCDISCRETEACCESSORY('1Td1iR001AdJ4rDp0rCJ4s',#5,'DETAY','PL16*190','PL16*190',#7718,#7720,'P/424(?)');
#7722= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +4.800'),$);
#7723= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +4.816'),$);
#7724= IFCPROPERTYSET('34h5UIIWb7H9vq$8V25jxe',#5,'Tekla Common','Common Properties to Shared building elements',(#7722,#7723,#5319,#5219,#74,#75,#919,#77,#78,#161,#921));
#7725= IFCPROPERTYSET('39hSeZiWj7juNI1BYl_WSa',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#7692,#5321,#5322,#5323,#5324,#5325,#5326,#5327,#5328,#5329,#5330,#5331,#94,#5332));
#7726= IFCCARTESIANPOINT((40467.0011469627,-664.132537913409,4873.99999999958));
#7727= IFCAXIS2PLACEMENT3D(#7726,#5201,#5202);
#7728= IFCLOCALPLACEMENT(#7681,#7727);
#7729= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5213));
#7730= IFCPRODUCTDEFINITIONSHAPE($,$,(#7729));
#7731= IFCDISCRETEACCESSORY('1Td1iR001AeJ4rDp0rCJ4s',#5,'DETAY','PL16*58','PL16*58',#7728,#7730,'P/428(?)');
#7732= IFCQUANTITYLENGTH('Width',$,$,57.9938951590166);
#7733= IFCQUANTITYAREA('GrossArea',$,$,0.011016661378021);
#7734= IFCELEMENTQUANTITY('0_F0uoEXv6lx1cbuomtD5E',#5,'BaseQuantities',$,$,(#7732,#7695,#7733,#100,#7697,#7698));
#7735= IFCCARTESIANPOINT((40723.0048530373,-664.132537913409,4873.99999999957));
#7736= IFCAXIS2PLACEMENT3D(#7735,#5347,#5202);
#7737= IFCLOCALPLACEMENT(#1305,#7736);
#7738= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5213));
#7739= IFCPRODUCTDEFINITIONSHAPE($,$,(#7738));
#7740= IFCDISCRETEACCESSORY('1Td1iR001AfJ4rDp0rCJ4s',#5,'DETAY','PL16*58','PL16*58',#7737,#7739,'P/428(?)');
#7741= IFCPROPERTYSET('2I36j7w356dO3rK72zM5iA',#5,'Tekla Common','Common Properties to Shared building elements',(#1318,#1319,#5218,#1320,#74,#75,#919,#77,#78,#920,#921));
#7742= IFCPROPERTYSET('0TmobCCmv3iw2frPFH5CiP',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1322,#5222,#5223,#5224,#927,#928,#929,#5225,#5354,#5227,#5228,#5229,#94,#5230));
#7743= IFCQUANTITYVOLUME('NetVolume',$,$,0.000169066494237451);
#7744= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000169066494237451);
#7745= IFCELEMENTQUANTITY('0Acmqh6YDCAxtQtJVyw8qr',#5,'BaseQuantities',$,$,(#7694,#7695,#7696,#100,#7743,#7744));
#7746= IFCCARTESIANPOINT((40545.995053407,-484.152286737816,4826.00610656266));
#7747= IFCAXIS2PLACEMENT3D(#7746,#9,#5361);
#7748= IFCLOCALPLACEMENT(#1305,#7747);
#7749= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5364));
#7750= IFCPRODUCTDEFINITIONSHAPE($,$,(#7749));
#7751= IFCDISCRETEACCESSORY('1Td1iR001AgJ4rDp0rCJ4s',#5,'ANKRAJ','L20*3','L20*3',#7748,#7750,'P/477(?)');
#7752= IFCPROPERTYSET('0L_AL38_D8xQQGhK29VYzx',#5,'Tekla Common','Common Properties to Shared building elements',(#1318,#7706,#5255,#1320,#74,#75,#919,#5256,#78,#5257,#80));
#7753= IFCPROPERTYSET('2V0U3QYQT62QQBZtKCDcsl',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1322,#5259,#5260,#5261,#5262,#5263,#5264,#5265,#5266,#5267,#5268,#1847,#5269,#5270));
#7754= IFCCARTESIANPOINT((40545.9983058544,-654.148784767628,4826.00610656266));
#7755= IFCAXIS2PLACEMENT3D(#7754,#5377,#5378);
#7756= IFCLOCALPLACEMENT(#1305,#7755);
#7757= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5284));
#7758= IFCPRODUCTDEFINITIONSHAPE($,$,(#7757));
#7759= IFCDISCRETEACCESSORY('1Td1iR001AhJ4rDp0rCJ4s',#5,'ANKRAJ','L20*3','L20*3',#7756,#7758,'P/477(?)');
#7760= IFCPROPERTYSET('0EuPUevdn1HxsEguZOxeqa',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1322,#5384,#5290,#5291,#5385,#5293,#5294,#5295,#5266,#5296,#5297,#3352,#1848,#5298));
#7761= IFCCARTESIANPOINT((40532.494988251,-474.169997602407,4808.));
#7762= IFCAXIS2PLACEMENT3D(#7761,#596,#7);
#7763= IFCLOCALPLACEMENT(#1305,#7762);
#7764= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5313));
#7765= IFCPRODUCTDEFINITIONSHAPE($,$,(#7764));
#7766= IFCDISCRETEACCESSORY('1Td1iR001AiJ4rDp0rCJ4s',#5,'DETAY','PL16*190','PL16*190',#7763,#7765,'P/424(?)');
#7767= IFCPROPERTYSET('3Tu0ddD5r8Ah_bSQbDMyQW',#5,'Tekla Common','Common Properties to Shared building elements',(#7722,#7723,#5319,#1320,#74,#75,#919,#77,#78,#161,#921));
#7768= IFCPROPERTYSET('1AcTSrcVb9FhLc4JqfHatW',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1322,#5321,#5322,#5323,#5324,#5325,#5326,#5327,#5328,#5329,#5330,#5331,#94,#5332));
#7769= IFCLOCALPLACEMENT(#30,#10);
#7770= IFCELEMENTASSEMBLY('1Td1iR001AxZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#7769,$,'A/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#7771= IFCPROPERTYSET('1IdN2a6gz8dw6I2Ej$DtYl',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#5872,#1358,#1359,#989,#5873,#990));
#7772= IFCCARTESIANPOINT((40430.0009742969,-409.152085224178,4807.));
#7773= IFCAXIS2PLACEMENT3D(#7772,#9,#7);
#7774= IFCLOCALPLACEMENT(#7769,#7773);
#7775= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1002));
#7776= IFCPRODUCTDEFINITIONSHAPE($,$,(#7775));
#7777= IFCDISCRETEACCESSORY('1Td1iR001Aj34rDp0rCJ4s',#5,'PLATE','PL16*140','PL16*140',#7774,#7776,'P/0(?)');
#7778= IFCCARTESIANPOINT((40543.9994010579,-401.152088433781,4890.));
#7779= IFCAXIS2PLACEMENT3D(#7778,#501,#185);
#7780= IFCLOCALPLACEMENT(#7769,#7779);
#7781= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1046));
#7782= IFCPRODUCTDEFINITIONSHAPE($,$,(#7781));
#7783= IFCDISCRETEACCESSORY('1Td1iR001Ajp4rDp0rCJ4s',#5,'PLATE','PL16*75','PL16*75',#7780,#7782,'P/0(?)');
#7784= IFCCARTESIANPOINT((40551.9994009154,-409.152092881741,4814.995));
#7785= IFCAXIS2PLACEMENT3D(#7784,#185,#9);
#7786= IFCLOCALPLACEMENT(#7769,#7785);
#7787= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1081));
#7788= IFCPRODUCTDEFINITIONSHAPE($,$,(#7787));
#7789= IFCDISCRETEACCESSORY('1Td1iR001AkZ4rDp0rCJ4s',#5,'PLATE','PL16*75','PL16*75',#7786,#7788,'P/0(?)');
#7790= IFCPROPERTYSET('20M0bE$vf0Yug8T_tGLnnk',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#5881,#1086,#1385,#1088,#1089,#1090,#1091,#1092,#1386,#1094,#1387,#1388,#1097,#1389));
#7791= IFCCARTESIANPOINT((40448.0009742969,-409.152086581707,4814.995));
#7792= IFCAXIS2PLACEMENT3D(#7791,#185,#9);
#7793= IFCLOCALPLACEMENT(#7769,#7792);
#7794= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#1081));
#7795= IFCPRODUCTDEFINITIONSHAPE($,$,(#7794));
#7796= IFCDISCRETEACCESSORY('1Td1iR001AlJ4rDp0rCJ4s',#5,'PLATE','PL16*75','PL16*75',#7793,#7795,'P/0(?)');
#7797= IFCPROPERTYSET('1Z9r$6De1Fxg3t2Jw7Pumf',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#5881,#1112,#1385,#1113,#1114,#1115,#1116,#1092,#1093,#1094,#1387,#1388,#1117,#1389));
#7798= IFCCARTESIANPOINT((40532.9988530373,-664.132537913409,4873.99999999957));
#7799= IFCAXIS2PLACEMENT3D(#7798,#5347,#5202);
#7800= IFCLOCALPLACEMENT(#1305,#7799);
#7801= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5213));
#7802= IFCPRODUCTDEFINITIONSHAPE($,$,(#7801));
#7803= IFCDISCRETEACCESSORY('1Td1iR001AmJ4rDp0rCJ4s',#5,'DETAY','PL16*58','PL16*58',#7800,#7802,'P/428(?)');
#7804= IFCELEMENTQUANTITY('3b5lX2GmP0a9R1Eug_p8oU',#5,'BaseQuantities',$,$,(#7732,#7695,#7733,#100,#7743,#7744));
#7805= IFCCARTESIANPOINT((40171.0886298035,-157.192275561193,4890.));
#7806= IFCAXIS2PLACEMENT3D(#7805,#9,#1125);
#7807= IFCLOCALPLACEMENT(#7769,#7806);
#7808= IFCCIRCLE(#1138,26.5157137785886);
#7809= IFCTRIMMEDCURVE(#7808,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.42863508546255)),.F.,.PARAMETER.);
#7810= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#7809);
#7811= IFCCOMPOSITECURVE((#7810,#1145),.F.);
#7812= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#7811);
#7813= IFCEXTRUDEDAREASOLID(#7812,#1151,#9,100.);
#7814= IFCBOOLEANRESULT(.DIFFERENCE.,#1135,#7813);
#7815= IFCCIRCLE(#1138,26.5157137785472);
#7816= IFCTRIMMEDCURVE(#7815,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.42863508545875)),.F.,.PARAMETER.);
#7817= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#7816);
#7818= IFCCOMPOSITECURVE((#7817,#1145),.F.);
#7819= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#7818);
#7820= IFCEXTRUDEDAREASOLID(#7819,#1162,#9,100.);
#7821= IFCBOOLEANRESULT(.DIFFERENCE.,#7814,#7820);
#7822= IFCCIRCLE(#1138,26.5157137785399);
#7823= IFCTRIMMEDCURVE(#7822,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.42863508546108)),.F.,.PARAMETER.);
#7824= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#7823);
#7825= IFCCOMPOSITECURVE((#7824,#1145),.F.);
#7826= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#7825);
#7827= IFCEXTRUDEDAREASOLID(#7826,#1173,#9,100.);
#7828= IFCBOOLEANRESULT(.DIFFERENCE.,#7821,#7827);
#7829= IFCCIRCLE(#1138,26.5157137785384);
#7830= IFCTRIMMEDCURVE(#7829,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(4.42863508546077)),.F.,.PARAMETER.);
#7831= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#7830);
#7832= IFCCOMPOSITECURVE((#7831,#1145),.F.);
#7833= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL100*30',#7832);
#7834= IFCEXTRUDEDAREASOLID(#7833,#1184,#9,100.);
#7835= IFCBOOLEANRESULT(.DIFFERENCE.,#7828,#7834);
#7836= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#7835));
#7837= IFCPRODUCTDEFINITIONSHAPE($,$,(#7836));
#7838= IFCDISCRETEACCESSORY('1Td1iR001Aq34rDp0rCJ4s',#5,'ANKRAJ','PLT30*240','PLT30*240',#7807,#7837,'P/370(?)');
#7839= IFCPROPERTYSET('2ajw4f5EPA5gvMy_EWWHJO',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#5881,#3000,#1198,#3001,#3002,#1201,#3004,#1203,#1204,#3006,#1206,#1207,#1208,#1209));
#7840= IFCQUANTITYVOLUME('NetVolume',$,$,0.00481827878120544);
#7841= IFCQUANTITYWEIGHT('NetWeight',$,$,37.8234884324627);
#7842= IFCELEMENTQUANTITY('3JfPbwhFn2VPDhPZr7ZkIC',#5,'BaseQuantities',$,$,(#1211,#7325,#7840,#7841));
#7843= IFCLOCALPLACEMENT(#30,#10);
#7844= IFCELEMENTASSEMBLY('1Td1iR001Aqp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#7843,$,'ANK/61(?)',.NOTDEFINED.,.RIGID_FRAME.);
#7845= IFCPROPERTYSET('211BChnVH4ffCrHNZuf20Q',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#5946,#2169,#2170,#1614,#5947,#1616));
#7846= IFCCARTESIANPOINT((40363.8303183166,-238.761303583805,4890.));
#7847= IFCAXIS2PLACEMENT3D(#7846,#9,#1621);
#7848= IFCLOCALPLACEMENT(#7843,#7847);
#7849= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5954));
#7850= IFCPRODUCTDEFINITIONSHAPE($,$,(#7849));
#7851= IFCBEAM('1Td1iR001Ar34rDp0rCJ4s',#5,'PUL','PLT30*150','PLT30*150',#7848,#7850,'P/377(?)');
#7852= IFCLOCALPLACEMENT(#30,#10);
#7853= IFCELEMENTASSEMBLY('1Td1iR001Arp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#7852,$,'ANK/61(?)',.NOTDEFINED.,.RIGID_FRAME.);
#7854= IFCPROPERTYSET('3nI8THof9FRfCpAXmxJW4z',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1665,#2169,#2170,#1614,#5947,#1616));
#7855= IFCCARTESIANPOINT((40636.1696399369,-238.76131148119,4890.));
#7856= IFCAXIS2PLACEMENT3D(#7855,#9,#1670);
#7857= IFCLOCALPLACEMENT(#7852,#7856);
#7858= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5985));
#7859= IFCPRODUCTDEFINITIONSHAPE($,$,(#7858));
#7860= IFCBEAM('1Td1iR001As34rDp0rCJ4s',#5,'PUL','PLT30*150','PLT30*150',#7857,#7859,'P/377(?)');
#7861= IFCLOCALPLACEMENT(#30,#10);
#7862= IFCELEMENTASSEMBLY('1Td1iR001Asp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#7861,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#7863= IFCPROPERTYSET('2fA1sDEzvAAgMT8c8Vscfg',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#2191,#2192,#1700,#5947,#1701));
#7864= IFCCARTESIANPOINT((40716.8561910801,-257.190864719634,4890.));
#7865= IFCAXIS2PLACEMENT3D(#7864,#1706,#1707);
#7866= IFCLOCALPLACEMENT(#7861,#7865);
#7867= IFCEXTRUDEDAREASOLID(#1719,#1721,#9,16.0000409062004);
#7868= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#7867));
#7869= IFCSTYLEDITEM(#7867,(#1711),$);
#7870= IFCPRODUCTDEFINITIONSHAPE($,$,(#7868));
#7871= IFCBEAM('1Td1iR001At34rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#7866,#7870,'XX/0(?)');
#7872= IFCLOCALPLACEMENT(#30,#10);
#7873= IFCELEMENTASSEMBLY('1Td1iR001Atp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#7872,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#7874= IFCCARTESIANPOINT((40713.4878455301,-241.549277321979,4890.));
#7875= IFCAXIS2PLACEMENT3D(#7874,#1706,#1707);
#7876= IFCLOCALPLACEMENT(#7872,#7875);
#7877= IFCEXTRUDEDAREASOLID(#1719,#1721,#9,16.0000409061919);
#7878= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#7877));
#7879= IFCSTYLEDITEM(#7877,(#1711),$);
#7880= IFCPRODUCTDEFINITIONSHAPE($,$,(#7878));
#7881= IFCBEAM('1Td1iR001Au34rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#7876,#7880,'XX/0(?)');
#7882= IFCLOCALPLACEMENT(#30,#10);
#7883= IFCELEMENTASSEMBLY('1Td1iR001Aup4rDp0rCJ4s',#5,'Steel Assembly',$,$,#7882,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#7884= IFCPROPERTYSET('3XWPKvUfP9G84GUMQi_BRN',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#2213,#2214,#1775,#5947,#1701));
#7885= IFCCARTESIANPOINT((40712.6453400033,-237.638892502498,4890.));
#7886= IFCAXIS2PLACEMENT3D(#7885,#1670,#1780);
#7887= IFCLOCALPLACEMENT(#7882,#7886);
#7888= IFCEXTRUDEDAREASOLID(#1783,#1785,#9,4.00000000000287);
#7889= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#7888));
#7890= IFCSTYLEDITEM(#7888,(#1711),$);
#7891= IFCPRODUCTDEFINITIONSHAPE($,$,(#7889));
#7892= IFCBEAM('1Td1iR001Av34rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#7887,#7891,'XX/0(?)');
#7893= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00180062582325914);
#7894= IFCQUANTITYVOLUME('NetVolume',$,$,3.93300000000779E-006);
#7895= IFCELEMENTQUANTITY('2ww5_Fj5jDOebcCYy5adem',#5,'BaseQuantities',$,$,(#1981,#7893,#7894,#1754));
#7896= IFCLOCALPLACEMENT(#30,#10);
#7897= IFCELEMENTASSEMBLY('1Td1iR001Avp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#7896,$,'R/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#7898= IFCPROPERTYSET('3tzS0Kuev0dQKv3H6$3_QW',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#2231,#2232,#1814,#5947,#1815));
#7899= IFCCARTESIANPOINT((40725.1344111934,-295.638490283996,4890.));
#7900= IFCAXIS2PLACEMENT3D(#7899,#1820,#1821);
#7901= IFCLOCALPLACEMENT(#7896,#7900);
#7902= IFCEXTRUDEDAREASOLID(#1826,#1828,#9,370.000357476353);
#7903= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#7902));
#7904= IFCSTYLEDITEM(#7902,(#1825),$);
#7905= IFCPRODUCTDEFINITIONSHAPE($,$,(#7903));
#7906= IFCBEAM('1Td1iR001Aw34rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#7901,#7905,'P/0(?)');
#7907= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0232205665089695);
#7908= IFCQUANTITYVOLUME('NetVolume',$,$,0.000104651904724891);
#7909= IFCELEMENTQUANTITY('3U5cVYPxb4fA1DCbDtZU7C',#5,'BaseQuantities',$,$,(#6052,#7907,#7908,#1754));
#7910= IFCCARTESIANPOINT((40569.9999731708,-444.15209193049,4898.));
#7911= IFCAXIS2PLACEMENT3D(#7910,#9,#8);
#7912= IFCLOCALPLACEMENT(#7769,#7911);
#7913= IFCBOOLEANRESULT(.DIFFERENCE.,#6074,#1894);
#7914= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#7913));
#7915= IFCPRODUCTDEFINITIONSHAPE($,$,(#7914));
#7916= IFCPLATE('1Td1iR001Axp4rDp0rCJ4s',#5,'ANCHOR','PL16*436','PL16*436',#7912,#7915,'P/0(?)');
#7917= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(29.5977597980171),$);
#7918= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.235650953805869),$);
#7919= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(436.392968430943),$);
#7920= IFCPROPERTYSET('2wU8Qr1Vz5WR6MhBYAqk6$',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#5881,#6080,#7917,#6082,#6083,#6084,#6085,#6086,#6685,#6088,#7918,#7919,#94,#6091));
#7921= IFCQUANTITYLENGTH('Width',$,$,436.392968430943);
#7922= IFCQUANTITYAREA('GrossArea',$,$,0.235650953805869);
#7923= IFCQUANTITYVOLUME('GrossVolume',$,$,0.00244018506177062);
#7924= IFCELEMENTQUANTITY('0Jr$o_Un15uPfbhhSrGf09',#5,'BaseQuantities',$,$,(#7921,#6687,#7922,#100,#6688,#7923));
#7925= IFCLOCALPLACEMENT(#30,#10);
#7926= IFCELEMENTASSEMBLY('1Td1iR001AyZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#7925,$,'ANK/63(?)',.NOTDEFINED.,.RIGID_FRAME.);
#7927= IFCPROPERTYSET('1y9Z6T1irBWQn2uE0uTwTS',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#6101,#2147,#2148,#39,#5873,#489));
#7928= IFCCARTESIANPOINT((40634.9987504166,-484.152103045623,4914.));
#7929= IFCAXIS2PLACEMENT3D(#7928,#7,#501);
#7930= IFCLOCALPLACEMENT(#7925,#7929);
#7931= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6109));
#7932= IFCPRODUCTDEFINITIONSHAPE($,$,(#7931));
#7933= IFCBEAM('1Td1iR001Ayp4rDp0rCJ4s',#5,'ANKRAJ','PLT16*140','PLT16*140',#7930,#7932,'P/379(?)');
#7934= IFCPROPERTYSET('0pvJ7Z3Sr4B8lSBSrMBrXT',#5,'Tekla Common','Common Properties to Shared building elements',(#2156,#2157,#512,#513,#74,#75,#919,#515,#78,#6115,#80));
#7935= IFCLOCALPLACEMENT(#30,#10);
#7936= IFCELEMENTASSEMBLY('1Td1iR001AzZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#7935,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#7937= IFCCARTESIANPOINT((40283.1442023679,-257.190838696386,4890.));
#7938= IFCAXIS2PLACEMENT3D(#7937,#1928,#1929);
#7939= IFCLOCALPLACEMENT(#7935,#7938);
#7940= IFCEXTRUDEDAREASOLID(#1719,#1721,#9,16.000040906199);
#7941= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#7940));
#7942= IFCSTYLEDITEM(#7940,(#1711),$);
#7943= IFCPRODUCTDEFINITIONSHAPE($,$,(#7941));
#7944= IFCBEAM('1Td1iR001Azp4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#7939,#7943,'XX/0(?)');
#7945= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161875316932);
#7946= IFCQUANTITYVOLUME('NetVolume',$,$,1.24707976976956E-005);
#7947= IFCELEMENTQUANTITY('1_rWOtPsXET9TLkrgNPh3N',#5,'BaseQuantities',$,$,(#6712,#7945,#7946,#1754));
#7948= IFCLOCALPLACEMENT(#30,#10);
#7949= IFCELEMENTASSEMBLY('1Td1iR001A_Z4rDp0rCJ4s',#5,'Steel Assembly',$,$,#7948,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#7950= IFCCARTESIANPOINT((40286.5125497949,-241.549251702941,4890.));
#7951= IFCAXIS2PLACEMENT3D(#7950,#1928,#1929);
#7952= IFCLOCALPLACEMENT(#7948,#7951);
#7953= IFCEXTRUDEDAREASOLID(#1719,#1721,#9,16.0000409061913);
#7954= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#7953));
#7955= IFCSTYLEDITEM(#7953,(#1711),$);
#7956= IFCPRODUCTDEFINITIONSHAPE($,$,(#7954));
#7957= IFCBEAM('1Td1iR001A_p4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#7952,#7956,'XX/0(?)');
#7958= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0032216187531685);
#7959= IFCQUANTITYVOLUME('NetVolume',$,$,1.24707976976901E-005);
#7960= IFCELEMENTQUANTITY('235D2_rWLBohrWqozDfu74',#5,'BaseQuantities',$,$,(#6162,#7958,#7959,#1754));
#7961= IFCLOCALPLACEMENT(#30,#10);
#7962= IFCELEMENTASSEMBLY('1Td1iR001A$Z4rDp0rCJ4s',#5,'Steel Assembly',$,$,#7961,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#7963= IFCCARTESIANPOINT((40287.355055791,-237.638866984563,4890.));
#7964= IFCAXIS2PLACEMENT3D(#7963,#1621,#1966);
#7965= IFCLOCALPLACEMENT(#7961,#7964);
#7966= IFCEXTRUDEDAREASOLID(#1783,#1785,#9,4.00000000000552);
#7967= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#7966));
#7968= IFCSTYLEDITEM(#7966,(#1711),$);
#7969= IFCPRODUCTDEFINITIONSHAPE($,$,(#7967));
#7970= IFCBEAM('1Td1iR001A$p4rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#7965,#7969,'XX/0(?)');
#7971= IFCQUANTITYLENGTH('Length',$,$,4.00000000001819);
#7972= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.001800625823261);
#7973= IFCQUANTITYVOLUME('NetVolume',$,$,3.9330000000147E-006);
#7974= IFCELEMENTQUANTITY('32PkzpsznB8gSNPMDR9tyU',#5,'BaseQuantities',$,$,(#7971,#7972,#7973,#1754));
#7975= IFCLOCALPLACEMENT(#30,#10);
#7976= IFCELEMENTASSEMBLY('1Td1iR001B0Z4rDp0rCJ4s',#5,'Steel Assembly',$,$,#7975,$,'R/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#7977= IFCCARTESIANPOINT((40274.8659776408,-295.638463267341,4890.));
#7978= IFCAXIS2PLACEMENT3D(#7977,#1988,#1989);
#7979= IFCLOCALPLACEMENT(#7975,#7978);
#7980= IFCEXTRUDEDAREASOLID(#1826,#1828,#9,370.000357476348);
#7981= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#7980));
#7982= IFCSTYLEDITEM(#7980,(#1825),$);
#7983= IFCPRODUCTDEFINITIONSHAPE($,$,(#7981));
#7984= IFCBEAM('1Td1iR001B0p4rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#7979,#7983,'P/0(?)');
#7985= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000104651904725296),$);
#7986= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000104651904725296),$);
#7987= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000104651904725296),$);
#7988= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0232205665090267),$);
#7989= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0232205665090267),$);
#7990= IFCPROPERTYSET('3AbvqNz1T7oOyU7pyBLtah',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#7985,#7986,#7987,#1743,#1744,#7988,#7989,#1847,#1848,#6200));
#7991= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0232205665090267);
#7992= IFCQUANTITYVOLUME('NetVolume',$,$,0.000104651904725296);
#7993= IFCELEMENTQUANTITY('1l3RdqY4X23h9PH501K7rG',#5,'BaseQuantities',$,$,(#6202,#7991,#7992,#1754));
#7994= IFCLOCALPLACEMENT(#30,#10);
#7995= IFCELEMENTASSEMBLY('1Td1iR001B1Z4rDp0rCJ4s',#5,'Steel Assembly',$,$,#7994,$,'ANK/63(?)',.NOTDEFINED.,.RIGID_FRAME.);
#7996= IFCCARTESIANPOINT((40365.0016157955,-484.152086845482,4914.));
#7997= IFCAXIS2PLACEMENT3D(#7996,#7,#501);
#7998= IFCLOCALPLACEMENT(#7994,#7997);
#7999= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#6211));
#8000= IFCPRODUCTDEFINITIONSHAPE($,$,(#7999));
#8001= IFCBEAM('1Td1iR001B1p4rDp0rCJ4s',#5,'ANKRAJ','PLT16*140','PLT16*140',#7998,#8000,'P/379(?)');
#8002= IFCCARTESIANPOINT((32623.0048530373,-664.132537913409,4873.99999999957));
#8003= IFCAXIS2PLACEMENT3D(#8002,#5347,#5202);
#8004= IFCLOCALPLACEMENT(#7681,#8003);
#8005= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5213));
#8006= IFCPRODUCTDEFINITIONSHAPE($,$,(#8005));
#8007= IFCDISCRETEACCESSORY('1Td1iR001B8p4rDp0rCJ4s',#5,'DETAY','PL16*58','PL16*58',#8004,#8006,'P/428(?)');
#8008= IFCPROPERTYSET('2bHvHUmWDFGPlPjD___q49',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#7692,#5416,#5223,#5417,#927,#928,#929,#5225,#5226,#5418,#5228,#5229,#94,#5230));
#8009= IFCQUANTITYLENGTH('Width',$,$,57.9938951589984);
#8010= IFCQUANTITYAREA('NetArea',$,$,0.0285055563302057);
#8011= IFCQUANTITYAREA('GrossArea',$,$,0.0110166613780175);
#8012= IFCQUANTITYVOLUME('NetVolume',$,$,0.000169066494237967);
#8013= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000169066494237967);
#8014= IFCELEMENTQUANTITY('3EA3xCK1j4RxMLKs0BaMiz',#5,'BaseQuantities',$,$,(#8009,#8010,#8011,#100,#8012,#8013));
#8015= IFCCARTESIANPOINT((32445.995053407,-484.152286737816,4826.00610656266));
#8016= IFCAXIS2PLACEMENT3D(#8015,#9,#5361);
#8017= IFCLOCALPLACEMENT(#7681,#8016);
#8018= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5429));
#8019= IFCPRODUCTDEFINITIONSHAPE($,$,(#8018));
#8020= IFCDISCRETEACCESSORY('1Td1iR002pDZ4rDp0rCJ4s',#5,'ANKRAJ','L20*3','L20*3',#8017,#8019,'P/477(?)');
#8021= IFCPROPERTYSET('2xxpdFACLBTubk1Pm2V2EX',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#7692,#5434,#5260,#5261,#5292,#5263,#5264,#5265,#5266,#5267,#5268,#1847,#5269,#5270));
#8022= IFCCARTESIANPOINT((32445.9983058544,-654.148784767628,4826.00610656266));
#8023= IFCAXIS2PLACEMENT3D(#8022,#5377,#5378);
#8024= IFCLOCALPLACEMENT(#7681,#8023);
#8025= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5284));
#8026= IFCPRODUCTDEFINITIONSHAPE($,$,(#8025));
#8027= IFCDISCRETEACCESSORY('1Td1iR002pCZ4rDp0rCJ4s',#5,'ANKRAJ','L20*3','L20*3',#8024,#8026,'P/477(?)');
#8028= IFCPROPERTYSET('0PrEqMSizDzQLt0fo_pDel',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#7692,#5447,#5290,#5291,#5448,#5293,#5294,#5449,#5266,#5450,#5297,#1847,#1848,#5298));
#8029= IFCCARTESIANPOINT((32432.494988251,-474.169997602407,4808.));
#8030= IFCAXIS2PLACEMENT3D(#8029,#596,#7);
#8031= IFCLOCALPLACEMENT(#7681,#8030);
#8032= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5313));
#8033= IFCPRODUCTDEFINITIONSHAPE($,$,(#8032));
#8034= IFCDISCRETEACCESSORY('1Td1iR002pBZ4rDp0rCJ4s',#5,'DETAY','PL16*190','PL16*190',#8031,#8033,'P/424(?)');
#8035= IFCPROPERTYSET('0PxcVomL1Eo9aIg7FlU_t5',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#7692,#5321,#5461,#5323,#5324,#5325,#5326,#5327,#5328,#5329,#5462,#5463,#94,#5332));
#8036= IFCCARTESIANPOINT((32534.9983581212,-554.153090053148,4939.995));
#8037= IFCAXIS2PLACEMENT3D(#8036,#501,#185);
#8038= IFCLOCALPLACEMENT(#30,#8037);
#8039= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,16.5);
#8040= IFCEXTRUDEDAREASOLID(#8039,#4638,#9,16.1);
#8041= IFCSTYLEDITEM(#8040,(#195),$);
#8042= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,16.5);
#8043= IFCEXTRUDEDAREASOLID(#8042,#4643,#9,16.0000000000005);
#8044= IFCSTYLEDITEM(#8043,(#195),$);
#8045= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4660);
#8046= IFCEXTRUDEDAREASOLID(#8045,#4663,#9,16.);
#8047= IFCSTYLEDITEM(#8046,(#195),$);
#8048= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4672);
#8049= IFCEXTRUDEDAREASOLID(#8048,#4675,#9,19.8);
#8050= IFCSTYLEDITEM(#8049,(#558),$);
#8051= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,15.);
#8052= IFCEXTRUDEDAREASOLID(#8051,#4680,#9,90.);
#8053= IFCSTYLEDITEM(#8052,(#558),$);
#8054= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,28.);
#8055= IFCEXTRUDEDAREASOLID(#8054,#4685,#9,8.);
#8056= IFCSTYLEDITEM(#8055,(#558),$);
#8057= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4694);
#8058= IFCEXTRUDEDAREASOLID(#8057,#4697,#9,24.);
#8059= IFCSTYLEDITEM(#8058,(#558),$);
#8060= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8040,#8043,#8046,#8049,#8052,#8055,#8058));
#8061= IFCREPRESENTATIONMAP(#10,#8060);
#8062= IFCMAPPEDITEM(#8061,#247);
#8063= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#8062));
#8064= IFCPRODUCTDEFINITIONSHAPE($,$,(#8063));
#8065= IFCMECHANICALFASTENER('1Td1iR002oyp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#8038,#8064,'ID5d9c1b1b-0000-b2f3-3135-373035313136',30.,90.);
#8066= IFCLOCALPLACEMENT(#30,#10);
#8067= IFCELEMENTASSEMBLY('1Td1iR002oi34rDp0rCJ4s',#5,'Steel Assembly',$,$,#8066,$,'DK/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#8068= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(495.868976936604),$);
#8069= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +20.060'),$);
#8070= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('DK/0(?)'),$);
#8071= IFCPROPERTYSET('2QUxbqODLDpwwABAIOxpgJ',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#8068,#1589,#8069,#3925,#3926,#8070));
#8072= IFCQUANTITYLENGTH('Width',$,$,129.999999999898);
#8073= IFCELEMENTQUANTITY('3nwvyf43TC4guMRp2vodKK',#5,'BaseQuantities',$,$,(#8072));
#8074= IFCCARTESIANPOINT((48621.7583829734,-471.510400713886,20060.0088386614));
#8075= IFCDIRECTION((0.707106781186549,-0.707106781186546,0.));
#8076= IFCAXIS2PLACEMENT3D(#8074,#8075,#596);
#8077= IFCLOCALPLACEMENT(#8066,#8076);
#8078= IFCCOLOURRGB('Light Yellow',0.898039215686275,0.898039215686275,0.2);
#8079= IFCSURFACESTYLERENDERING(#8078,0.,$,$,$,$,IFCNORMALISEDRATIOMEASURE(0.00390625),IFCSPECULAREXPONENT(10.),.NOTDEFINED.);
#8080= IFCSURFACESTYLE('STEEL/S235JR',.POSITIVE.,(#8079));
#8081= IFCPRESENTATIONSTYLEASSIGNMENT((#8080));
#8082= IFCTSHAPEPROFILEDEF(.AREA.,'T465-40-50-130',#197,465.,130.,40.,50.,28.,$,$,$,$,$);
#8083= IFCCARTESIANPOINT((4254.01383865489,0.,0.));
#8084= IFCAXIS2PLACEMENT3D(#8083,#185,#501);
#8085= IFCEXTRUDEDAREASOLID(#8082,#8084,#9,4254.01383865489);
#8086= IFCCARTESIANPOINT((119.863914489317,3.38332029059529E-010));
#8087= IFCCARTESIANPOINT((119.863990783539,232.229995727794));
#8088= IFCCARTESIANPOINT((264.847778324147,4294.01367187684));
#8089= IFCCARTESIANPOINT((-0.134477238025283,4295.01416015771));
#8090= IFCPOLYLINE((#54,#8086,#8087,#8088,#8089,#54,#54));
#8091= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL156*265',#8090);
#8092= IFCCARTESIANPOINT((-40.0000355759767,-77.9999999877327,-232.363917608744));
#8093= IFCAXIS2PLACEMENT3D(#8092,#8,#9);
#8094= IFCEXTRUDEDAREASOLID(#8091,#8093,#9,156.);
#8095= IFCBOOLEANRESULT(.DIFFERENCE.,#8085,#8094);
#8096= IFCCARTESIANPOINT((265.000976563497,8.36735125631094E-011));
#8097= IFCCARTESIANPOINT((265.000976563366,214.230712890068));
#8098= IFCCARTESIANPOINT((-0.000552914963918738,214.229995727146));
#8099= IFCPOLYLINE((#54,#8096,#8097,#8098,#54,#54));
#8100= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL156*214',#8099);
#8101= IFCDIRECTION((2.58099999506927E-006,-1.83186799063151E-015,-0.999999999996669));
#8102= IFCCARTESIANPOINT((192.23,-77.9999999985012,232.499999998821));
#8103= IFCAXIS2PLACEMENT3D(#8102,#8,#8101);
#8104= IFCEXTRUDEDAREASOLID(#8100,#8103,#9,156.);
#8105= IFCBOOLEANRESULT(.DIFFERENCE.,#8095,#8104);
#8106= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#8105));
#8107= IFCSTYLEDITEM(#8085,(#8081),$);
#8108= IFCPRODUCTDEFINITIONSHAPE($,$,(#8106));
#8109= IFCBEAM('1Td1iR002oiJ4rDp0rCJ4s',#5,'DIKME','T465-40-50-130','T465-40-50-130',#8077,#8108,'P/324(?)');
#8110= IFCBEAMTYPE('1OUbBUsWv8sh1T3XnKT15P',#5,'T465-40-50-130',$,$,$,$,$,$,.NOTDEFINED.);
#8111= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +20.060'),$);
#8112= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/324(?)'),$);
#8113= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('DK/0(?)'),$);
#8114= IFCPROPERTYSINGLEVALUE('Class',$,IFCLABEL('6'),$);
#8115= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('T465-40-50-130'),$);
#8116= IFCPROPERTYSET('3K1zhl03n3_fy0N$hH_4t3',#5,'Tekla Common','Common Properties to Shared building elements',(#1598,#8111,#8112,#8113,#74,#75,#76,#8114,#78,#8115,#4048));
#8117= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(495.868976936604),$);
#8118= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(495.868976936604),$);
#8119= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(771.401599430699),$);
#8120= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(495.868976936604),$);
#8121= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.0631680225396948),$);
#8122= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.0982677196727005),$);
#8123= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.0631680225396948),$);
#8124= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00319994122990903),$);
#8125= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(6.7494566035811),$);
#8126= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(3.34684614089577),$);
#8127= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(5.10847646799315),$);
#8128= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(345.000005086265),$);
#8129= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(129.999999999898),$);
#8130= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(4254.01383865489),$);
#8131= IFCPROPERTYSET('3OGqxKt$PFmg6VKlIvDBXr',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#8117,#8118,#8119,#8120,#8121,#8122,#8123,#8124,#8125,#8126,#8127,#8128,#8129,#8130));
#8132= IFCQUANTITYLENGTH('Length',$,$,4254.01383865489);
#8133= IFCQUANTITYAREA('OuterSurfaceArea',$,$,3.34684614089577);
#8134= IFCQUANTITYVOLUME('NetVolume',$,$,0.0631680225396948);
#8135= IFCQUANTITYWEIGHT('NetWeight',$,$,495.868976936604);
#8136= IFCELEMENTQUANTITY('1H6ALncNrCxejr_SgTBVux',#5,'BaseQuantities',$,$,(#8132,#8133,#8134,#8135));
#8137= IFCCARTESIANPOINT((48738.8552596716,3922.38964361321,-1314.99568023916));
#8138= IFCDIRECTION((0.999999999995776,-9.19999999947074E-007,-2.7569999999625E-006));
#8139= IFCDIRECTION((-9.19999991311038E-007,-0.999999999323781,3.67640000122375E-005));
#8140= IFCAXIS2PLACEMENT3D(#8137,#8138,#8139);
#8141= IFCLOCALPLACEMENT(#30,#8140);
#8142= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#8143= IFCEXTRUDEDAREASOLID(#8142,#2479,#9,15.0999999999802);
#8144= IFCSTYLEDITEM(#8143,(#195),$);
#8145= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8143));
#8146= IFCREPRESENTATIONMAP(#10,#8145);
#8147= IFCMAPPEDITEM(#8146,#247);
#8148= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#8147));
#8149= IFCPRODUCTDEFINITIONSHAPE($,$,(#8148));
#8150= IFCMECHANICALFASTENER('1Td1iR001FWZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#8141,#8149,'ID5d9c1b1b-0000-4f82-3135-373035313136',20.,15.);
#8151= IFCPROPERTYSINGLEVALUE('Bolt hole diameter',$,IFCLENGTHMEASURE(62.),$);
#8152= IFCPROPERTYSINGLEVALUE('Bolt size',$,IFCLENGTHMEASURE(62.),$);
#8153= IFCPROPERTYSINGLEVALUE('Bolt length',$,IFCLENGTHMEASURE(15.),$);
#8154= IFCPROPERTYSET('1iss5OUjP2OwMoX9gA7jXI',#5,'Tekla Bolt','Bolt Properties',(#255,#611,#571,#612,#259,#573,#613,#262,#263,#8151,#265,#266,#8152,#8153,#579,#617));
#8155= IFCCARTESIANPOINT((48738.8554620718,4200.00264346438,-1315.00376829561));
#8156= IFCDIRECTION((-0.999999999995776,9.20000000401822E-007,2.7569999999625E-006));
#8157= IFCDIRECTION((9.19999991311039E-007,0.999999999323781,-3.67640000122376E-005));
#8158= IFCAXIS2PLACEMENT3D(#8155,#8156,#8157);
#8159= IFCLOCALPLACEMENT(#30,#8158);
#8160= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#8161= IFCEXTRUDEDAREASOLID(#8160,#2479,#9,15.1000000000259);
#8162= IFCSTYLEDITEM(#8161,(#195),$);
#8163= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8161));
#8164= IFCREPRESENTATIONMAP(#10,#8163);
#8165= IFCMAPPEDITEM(#8164,#247);
#8166= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#8165));
#8167= IFCPRODUCTDEFINITIONSHAPE($,$,(#8166));
#8168= IFCMECHANICALFASTENER('1Td1iR001FXJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#8159,#8167,'ID5d9c1b1b-0000-4f85-3135-373035313136',20.,15.);
#8169= IFCLOCALPLACEMENT(#30,#10);
#8170= IFCELEMENTASSEMBLY('1Td1iR001FUJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#8169,$,'ANK/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#8171= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(1.17749999999595),$);
#8172= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -1.330'),$);
#8173= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -1.315'),$);
#8174= IFCPROPERTYSET('34B3RsZYr1oAEZCDcBBzCI',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#8171,#8172,#8173,#39,#2857,#41));
#8175= IFCQUANTITYLENGTH('Width',$,$,15.0000000001328);
#8176= IFCELEMENTQUANTITY('3Ye45WlyzEvQnyjD3m8cEG',#5,'BaseQuantities',$,$,(#8175));
#8177= IFCCARTESIANPOINT((48688.8552389928,3922.38941388917,-1322.49554237569));
#8178= IFCAXIS2PLACEMENT3D(#8177,#8157,#8138);
#8179= IFCLOCALPLACEMENT(#8169,#8178);
#8180= IFCRECTANGLEPROFILEDEF(.AREA.,'PLT15*100',#197,15.,100.);
#8181= IFCCARTESIANPOINT((99.999999999964,4.23516473626998E-020,4.54747332084907E-013));
#8182= IFCAXIS2PLACEMENT3D(#8181,#185,#501);
#8183= IFCEXTRUDEDAREASOLID(#8180,#8182,#9,99.999999999964);
#8184= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8183));
#8185= IFCSTYLEDITEM(#8183,(#53),$);
#8186= IFCPRODUCTDEFINITIONSHAPE($,$,(#8184));
#8187= IFCBEAM('1Td1iR001FYp4rDp0rCJ4s',#5,'ANKRAJ','PLT15*100','PLT15*100',#8179,#8186,'P/484(?)');
#8188= IFCBEAMTYPE('2hUwLzjPj6E8UN6L8fPB26',#5,'PLT15*100',$,$,$,$,$,$,.NOTDEFINED.);
#8189= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -1.330'),$);
#8190= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -1.315'),$);
#8191= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/484(?)'),$);
#8192= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PLT15*100'),$);
#8193= IFCPROPERTYSET('27AKydx6z0Vxp2RTjfsLCE',#5,'Tekla Common','Common Properties to Shared building elements',(#8189,#8190,#8191,#73,#74,#75,#76,#1194,#78,#8192,#80));
#8194= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(1.17749999999595),$);
#8195= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(1.17749999999595),$);
#8196= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(1.17749999999705),$);
#8197= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(1.17749999999595),$);
#8198= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000149999999999483),$);
#8199= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000149999999999483),$);
#8200= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000149999999999483),$);
#8201= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00999999999999641),$);
#8202= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(22.0806794055291),$);
#8203= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.025999999999921),$);
#8204= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.025999999999921),$);
#8205= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(100.00000000007),$);
#8206= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(15.0000000001328),$);
#8207= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(99.9999999996799),$);
#8208= IFCPROPERTYSET('2rJzh9M25BiBVc9Pmc4tGG',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#8194,#8195,#8196,#8197,#8198,#8199,#8200,#8201,#8202,#8203,#8204,#8205,#8206,#8207));
#8209= IFCQUANTITYLENGTH('Length',$,$,99.9999999996799);
#8210= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.025999999999921);
#8211= IFCQUANTITYVOLUME('NetVolume',$,$,0.000149999999999483);
#8212= IFCQUANTITYWEIGHT('NetWeight',$,$,1.17749999999595);
#8213= IFCELEMENTQUANTITY('31RT60izLAxhYR4TrL1YYU',#5,'BaseQuantities',$,$,(#8209,#8210,#8211,#8212));
#8214= IFCLOCALPLACEMENT(#30,#10);
#8215= IFCELEMENTASSEMBLY('1Td1iR001FW34rDp0rCJ4s',#5,'Steel Assembly',$,$,#8214,$,'ANK/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#8216= IFCQUANTITYLENGTH('Width',$,$,15.0000000001405);
#8217= IFCELEMENTQUANTITY('1ureVpejf9Cwf3bs6kcTeS',#5,'BaseQuantities',$,$,(#8216));
#8218= IFCCARTESIANPOINT((48688.8554413931,4200.00241374034,-1322.50363043214));
#8219= IFCAXIS2PLACEMENT3D(#8218,#8139,#8138);
#8220= IFCLOCALPLACEMENT(#8214,#8219);
#8221= IFCEXTRUDEDAREASOLID(#8180,#8182,#9,99.9999999999567);
#8222= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8221));
#8223= IFCSTYLEDITEM(#8221,(#53),$);
#8224= IFCPRODUCTDEFINITIONSHAPE($,$,(#8222));
#8225= IFCBEAM('1Td1iR001Fb34rDp0rCJ4s',#5,'ANKRAJ','PLT15*100','PLT15*100',#8220,#8224,'P/484(?)');
#8226= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(22.0806794055307),$);
#8227= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(15.0000000001405),$);
#8228= IFCPROPERTYSET('24ZQwId9nCK9464eBGuy$o',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#8194,#8195,#8196,#8197,#8198,#8199,#8200,#8201,#8226,#8203,#8204,#8205,#8227,#8207));
#8229= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0259999999999093);
#8230= IFCQUANTITYVOLUME('NetVolume',$,$,0.000149999999999406);
#8231= IFCQUANTITYWEIGHT('NetWeight',$,$,1.17749999999533);
#8232= IFCELEMENTQUANTITY('3izZALd3bB9u7i95wA8fgU',#5,'BaseQuantities',$,$,(#8209,#8229,#8230,#8231));
#8233= IFCLOCALPLACEMENT(#30,#10);
#8234= IFCELEMENTASSEMBLY('1Td1iR001GBp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#8233,$,'C/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#8235= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(734.223245190081),$);
#8236= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -1.350'),$);
#8237= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('C/0(?)'),$);
#8238= IFCPROPERTYSET('35JtQnC3P4ZehfEexqTzZK',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#8235,#8236,#3924,#3925,#2857,#8237));
#8239= IFCQUANTITYLENGTH('Width',$,$,745.004723773332);
#8240= IFCELEMENTQUANTITY('0$wnoz8s53hfPsN6l5nxVa',#5,'BaseQuantities',$,$,(#8239));
#8241= IFCCARTESIANPOINT((48828.8529522788,4295.00752374081,-1180.00689557948));
#8242= IFCDIRECTION((0.999999999404005,-3.43526299605852E-006,-3.43538737229474E-005));
#8243= IFCDIRECTION((-3.43400000994942E-006,-0.999999999318308,3.67640000117362E-005));
#8244= IFCAXIS2PLACEMENT3D(#8241,#8242,#8243);
#8245= IFCLOCALPLACEMENT(#8233,#8244);
#8246= IFCCARTESIANPOINT((0.00031891003571104,99.9999999994915));
#8247= IFCCARTESIANPOINT((100.,1.56428919558932E-010));
#8248= IFCCARTESIANPOINT((150.003997802347,2.34649633057415E-010));
#8249= IFCCARTESIANPOINT((150.00399780248,150.001007080333));
#8250= IFCCARTESIANPOINT((0.000478368265248719,150.001007080169));
#8251= IFCPOLYLINE((#8246,#8247,#8248,#8249,#8250,#8246));
#8252= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL10*150',#8251);
#8253= IFCCARTESIANPOINT((2.56632785044577E-021,0.,-5.));
#8254= IFCAXIS2PLACEMENT3D(#8253,#9,#7);
#8255= IFCEXTRUDEDAREASOLID(#8252,#8254,#9,10.);
#8256= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8255));
#8257= IFCSTYLEDITEM(#8255,(#53),$);
#8258= IFCPRODUCTDEFINITIONSHAPE($,$,(#8256));
#8259= IFCDISCRETEACCESSORY('1Td1iR001Fbp4rDp0rCJ4s',#5,'DETAY','PL10*150','PL10*150',#8245,#8258,'P/240(?)');
#8260= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -1.180'),$);
#8261= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/240(?)'),$);
#8262= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('C/0(?)'),$);
#8263= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PL10*150'),$);
#8264= IFCPROPERTYSET('0JWXlwgqH9CuJTi9Mn77Q2',#5,'Tekla Common','Common Properties to Shared building elements',(#8189,#8260,#8261,#8262,#74,#75,#76,#77,#78,#8263,#921));
#8265= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(734.223245190081),$);
#8266= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(1.37380611639977),$);
#8267= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(1.76630517762211),$);
#8268= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(1.37380611639977),$);
#8269= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000175007148585958),$);
#8270= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000175007148585958),$);
#8271= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000175007148585958),$);
#8272= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.000500039978027213),$);
#8273= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(29.4188065230406),$);
#8274= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0404157363385346),$);
#8275= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0225007028996447),$);
#8276= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(150.00100708014),$);
#8277= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(10.0000000011205),$);
#8278= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(150.003678892792),$);
#8279= IFCPROPERTYSET('0pZcpnxEP6hBtjmNVmaxsG',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#8265,#8266,#8267,#8268,#8269,#8270,#8271,#8272,#8273,#8274,#8275,#8276,#8277,#8278));
#8280= IFCQUANTITYLENGTH('Width',$,$,150.00100708014);
#8281= IFCQUANTITYAREA('NetArea',$,$,0.0404157363385346);
#8282= IFCQUANTITYAREA('GrossArea',$,$,0.0225007028996447);
#8283= IFCQUANTITYAREA('CrossSectionArea',$,$,0.0001);
#8284= IFCQUANTITYVOLUME('NetVolume',$,$,0.000175007148585958);
#8285= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000175007148585958);
#8286= IFCELEMENTQUANTITY('0BxIsIdqn4lwOgvcWpTSz0',#5,'BaseQuantities',$,$,(#8280,#8281,#8282,#8283,#8284,#8285));
#8287= IFCLOCALPLACEMENT(#30,#10);
#8288= IFCELEMENTASSEMBLY('1Td1iR001FhJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#8287,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#8289= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -1.315'),$);
#8290= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -1.311'),$);
#8291= IFCPROPERTYSET('23rtRKI7fEwfIqugn9nzol',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#8289,#8290,#1775,#2857,#1701));
#8292= IFCQUANTITYLENGTH('Width',$,$,44.0000000001601);
#8293= IFCELEMENTQUANTITY('14gGfosZX7r8rU01lePMaL',#5,'BaseQuantities',$,$,(#8292));
#8294= IFCCARTESIANPOINT((48738.8552785413,3922.38979067903,-1310.99540080836));
#8295= IFCDIRECTION((2.76400005436785E-005,-3.67640000022643E-005,-0.999999998942219));
#8296= IFCAXIS2PLACEMENT3D(#8294,#8139,#8295);
#8297= IFCLOCALPLACEMENT(#8287,#8296);
#8298= IFCEXTRUDEDAREASOLID(#1783,#1785,#9,4.00000000138077);
#8299= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8298));
#8300= IFCSTYLEDITEM(#8298,(#1711),$);
#8301= IFCPRODUCTDEFINITIONSHAPE($,$,(#8299));
#8302= IFCBEAM('1Td1iR001FhZ4rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#8297,#8301,'XX/0(?)');
#8303= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -1.315'),$);
#8304= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -1.311'),$);
#8305= IFCPROPERTYSET('3mv57fsj99RRIJtpIgod03',#5,'Tekla Common','Common Properties to Shared building elements',(#8303,#8304,#1730,#1731,#74,#75,#76,#1194,#1732,#1794,#1795));
#8306= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(3.93300000137264E-006),$);
#8307= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(3.93300000137264E-006),$);
#8308= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(3.93300000137264E-006),$);
#8309= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.000983250000000073),$);
#8310= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.00180062582345095),$);
#8311= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.00180062582345095),$);
#8312= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(44.0000000001601),$);
#8313= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(4.0000000014611),$);
#8314= IFCPROPERTYSET('0BruRu5Lr7ZQgrcta3mbtm',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#8306,#8307,#8308,#8309,#1744,#8310,#8311,#1979,#8312,#8313));
#8315= IFCQUANTITYLENGTH('Length',$,$,4.0000000014611);
#8316= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00180062582345095);
#8317= IFCQUANTITYVOLUME('NetVolume',$,$,3.93300000137264E-006);
#8318= IFCELEMENTQUANTITY('0C8yBdhR18hhEorVTgN1y_',#5,'BaseQuantities',$,$,(#8315,#8316,#8317,#1754));
#8319= IFCLOCALPLACEMENT(#30,#10);
#8320= IFCELEMENTASSEMBLY('1Td1iR001FiJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#8319,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#8321= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -1.366'),$);
#8322= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -1.350'),$);
#8323= IFCPROPERTYSET('3nQu4Ziw1AmuSVLCPWXrTg',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#8321,#8322,#137,#2857,#1701));
#8324= IFCQUANTITYLENGTH('Width',$,$,34.6410161513795);
#8325= IFCELEMENTQUANTITY('1EUbXPE$j76xFIXk_saEkh',#5,'BaseQuantities',$,$,(#8324));
#8326= IFCCARTESIANPOINT((48738.8521710105,3922.3883568901,-1349.99540077361));
#8327= IFCDIRECTION((0.999999999988278,0.,4.84199999999654E-006));
#8328= IFCDIRECTION((4.84200018035761E-006,-3.67640000149321E-005,-0.999999999312482));
#8329= IFCAXIS2PLACEMENT3D(#8326,#8327,#8328);
#8330= IFCLOCALPLACEMENT(#8319,#8329);
#8331= IFCEXTRUDEDAREASOLID(#1719,#1721,#9,16.00000000001);
#8332= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8331));
#8333= IFCSTYLEDITEM(#8331,(#1711),$);
#8334= IFCPRODUCTDEFINITIONSHAPE($,$,(#8332));
#8335= IFCBEAM('1Td1iR001FiZ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#8330,#8334,'XX/0(?)');
#8336= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -1.366'),$);
#8337= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -1.350'),$);
#8338= IFCPROPERTYSET('1EHHTFju12zPHX2yHvAAEY',#5,'Tekla Common','Common Properties to Shared building elements',(#8336,#8337,#1730,#1731,#74,#75,#76,#1194,#1732,#1733,#1734));
#8339= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.000779422863406058),$);
#8340= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(34.6410161513795),$);
#8341= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(16.0000000001046),$);
#8342= IFCPROPERTYSET('3u$gJBqCj0Vv0L_A54OY8O',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#1740,#1741,#1742,#8339,#1744,#1745,#1746,#1747,#8340,#8341));
#8343= IFCQUANTITYLENGTH('Length',$,$,16.0000000001046);
#8344= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161450207251);
#8345= IFCQUANTITYVOLUME('NetVolume',$,$,1.24707658144688E-005);
#8346= IFCELEMENTQUANTITY('1IXL$hdtn9BvIBVBEd7vwl',#5,'BaseQuantities',$,$,(#8343,#8344,#8345,#1754));
#8347= IFCLOCALPLACEMENT(#30,#10);
#8348= IFCELEMENTASSEMBLY('1Td1iR001FjJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#8347,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#8349= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -1.295'),$);
#8350= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -1.279'),$);
#8351= IFCPROPERTYSET('3obFEJhtL5ruSDF0s1qt$c',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#8349,#8350,#137,#2857,#1701));
#8352= IFCQUANTITYLENGTH('Width',$,$,34.6410161513791);
#8353= IFCELEMENTQUANTITY('3PlPH1uW5DBALhx7oxl5cZ',#5,'BaseQuantities',$,$,(#8352));
#8354= IFCCARTESIANPOINT((48738.8553667717,3922.3909671235,-1278.99540083009));
#8355= IFCAXIS2PLACEMENT3D(#8354,#8327,#8328);
#8356= IFCLOCALPLACEMENT(#8347,#8355);
#8357= IFCEXTRUDEDAREASOLID(#1719,#1721,#9,16.000000000009);
#8358= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8357));
#8359= IFCSTYLEDITEM(#8357,(#1711),$);
#8360= IFCPRODUCTDEFINITIONSHAPE($,$,(#8358));
#8361= IFCBEAM('1Td1iR001FjZ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#8356,#8360,'XX/0(?)');
#8362= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -1.295'),$);
#8363= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -1.279'),$);
#8364= IFCPROPERTYSET('2tyKMVPF51Y8imwDeqyMbe',#5,'Tekla Common','Common Properties to Shared building elements',(#8362,#8363,#1730,#1731,#74,#75,#76,#1194,#1732,#1733,#1734));
#8365= IFCQUANTITYLENGTH('Length',$,$,16.0000000001039);
#8366= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161450207239);
#8367= IFCQUANTITYVOLUME('NetVolume',$,$,1.2470765814468E-005);
#8368= IFCELEMENTQUANTITY('3b25o7tPzERe71lmrlug9C',#5,'BaseQuantities',$,$,(#8365,#8366,#8367,#1754));
#8369= IFCLOCALPLACEMENT(#30,#10);
#8370= IFCELEMENTASSEMBLY('1Td1iR001FkJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#8369,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#8371= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -1.311'),$);
#8372= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -1.295'),$);
#8373= IFCPROPERTYSET('1OKj27xzv2yOKXaI9AuQRJ',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#8371,#8372,#137,#2857,#1701));
#8374= IFCCARTESIANPOINT((48738.8553226565,3922.39037890127,-1294.99540081922));
#8375= IFCAXIS2PLACEMENT3D(#8374,#8327,#8328);
#8376= IFCLOCALPLACEMENT(#8369,#8375);
#8377= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8357));
#8378= IFCPRODUCTDEFINITIONSHAPE($,$,(#8377));
#8379= IFCBEAM('1Td1iR001FkZ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#8376,#8378,'XX/0(?)');
#8380= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -1.311'),$);
#8381= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -1.295'),$);
#8382= IFCPROPERTYSET('0cb5FUUXrFSQ4h5ECh8u1b',#5,'Tekla Common','Common Properties to Shared building elements',(#8380,#8381,#1730,#1731,#74,#75,#76,#1194,#1732,#1733,#1734));
#8383= IFCQUANTITYLENGTH('Length',$,$,16.0000000001037);
#8384= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161450207238);
#8385= IFCQUANTITYVOLUME('NetVolume',$,$,1.2470765814468E-005);
#8386= IFCELEMENTQUANTITY('1W8fJ3esjAwudeZuvruRJh',#5,'BaseQuantities',$,$,(#8383,#8384,#8385,#1754));
#8387= IFCLOCALPLACEMENT(#30,#10);
#8388= IFCELEMENTASSEMBLY('1Td1iR001FlJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#8387,$,'R/1(?)',.NOTDEFINED.,.RIGID_FRAME.);
#8389= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -1.605'),$);
#8390= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -1.265'),$);
#8391= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('R/1(?)'),$);
#8392= IFCPROPERTYSET('1RhY0Dzmz3W8I1YPXLAFaf',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#8389,#8390,#137,#2857,#8391));
#8393= IFCQUANTITYLENGTH('Width',$,$,20.0000000000023);
#8394= IFCELEMENTQUANTITY('2OnWgqNMvAkQCpAzdM9fKo',#5,'BaseQuantities',$,$,(#8393));
#8395= IFCCARTESIANPOINT((48738.8554220314,3922.39148180489,-1264.99575615487));
#8396= IFCDIRECTION((-2.75700000240554E-006,-3.67640000122823E-005,-0.999999999320404));
#8397= IFCAXIS2PLACEMENT3D(#8395,#8138,#8396);
#8398= IFCLOCALPLACEMENT(#8387,#8397);
#8399= IFCCARTESIANPOINT((340.000057220663,2.30393000427399E-018,1.43995625267124E-019));
#8400= IFCAXIS2PLACEMENT3D(#8399,#185,#501);
#8401= IFCEXTRUDEDAREASOLID(#1826,#8400,#9,340.000057220663);
#8402= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8401));
#8403= IFCSTYLEDITEM(#8401,(#1825),$);
#8404= IFCPRODUCTDEFINITIONSHAPE($,$,(#8402));
#8405= IFCBEAM('1Td1iR001FlZ4rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#8398,#8404,'P/487(?)');
#8406= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -1.605'),$);
#8407= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -1.265'),$);
#8408= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/487(?)'),$);
#8409= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('R/1(?)'),$);
#8410= IFCPROPERTYSET('3V8xdaln9BTOctT_8SBg8e',#5,'Tekla Common','Common Properties to Shared building elements',(#8406,#8407,#8408,#8409,#74,#75,#76,#515,#1838,#1839,#1840));
#8411= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(9.61665384254837E-005),$);
#8412= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(9.61665384254837E-005),$);
#8413= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(9.61665384254837E-005),$);
#8414= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.000282842712474619),$);
#8415= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0213836676491558),$);
#8416= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0213836676491558),$);
#8417= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(340.000057220683),$);
#8418= IFCPROPERTYSET('290irK$wr4_Bf$fls7zl6r',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#8411,#8412,#8413,#8414,#1744,#8415,#8416,#1847,#5269,#8417));
#8419= IFCQUANTITYLENGTH('Length',$,$,340.000057220683);
#8420= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0213836676491558);
#8421= IFCQUANTITYVOLUME('NetVolume',$,$,9.61665384254837E-005);
#8422= IFCELEMENTQUANTITY('01DLAO_PX61RJzYTY8VocM',#5,'BaseQuantities',$,$,(#8419,#8420,#8421,#1754));
#8423= IFCLOCALPLACEMENT(#30,#10);
#8424= IFCELEMENTASSEMBLY('1Td1iR001FmJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#8423,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#8425= IFCCARTESIANPOINT((48738.8554809416,4200.0027905302,-1311.00348886481));
#8426= IFCAXIS2PLACEMENT3D(#8425,#8139,#8295);
#8427= IFCLOCALPLACEMENT(#8423,#8426);
#8428= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8298));
#8429= IFCPRODUCTDEFINITIONSHAPE($,$,(#8428));
#8430= IFCBEAM('1Td1iR001FmZ4rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#8427,#8429,'XX/0(?)');
#8431= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.00180062582345096),$);
#8432= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.00180062582345096),$);
#8433= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(4.00000000146133),$);
#8434= IFCPROPERTYSET('3vY3sKWMn8xxd8c_lVhobm',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#8306,#8307,#8308,#8309,#1744,#8431,#8432,#1979,#8312,#8433));
#8435= IFCQUANTITYLENGTH('Length',$,$,4.00000000146133);
#8436= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00180062582345096);
#8437= IFCQUANTITYVOLUME('NetVolume',$,$,3.9330000013726E-006);
#8438= IFCELEMENTQUANTITY('2Tv00_pm1Cr8srMsuKhRZg',#5,'BaseQuantities',$,$,(#8435,#8436,#8437,#1754));
#8439= IFCLOCALPLACEMENT(#30,#10);
#8440= IFCELEMENTASSEMBLY('1Td1iR001FnJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#8439,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#8441= IFCCARTESIANPOINT((48738.8523734108,4200.00135674126,-1350.00348883006));
#8442= IFCAXIS2PLACEMENT3D(#8441,#8327,#8328);
#8443= IFCLOCALPLACEMENT(#8439,#8442);
#8444= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8331));
#8445= IFCPRODUCTDEFINITIONSHAPE($,$,(#8444));
#8446= IFCBEAM('1Td1iR001FnZ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#8443,#8445,'XX/0(?)');
#8447= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(16.0000000001126),$);
#8448= IFCPROPERTYSET('2CGRYNnkTDt86oLbHAzGUg',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#1740,#1741,#1742,#8339,#1744,#1745,#1746,#1747,#8340,#8447));
#8449= IFCQUANTITYLENGTH('Length',$,$,16.0000000001126);
#8450= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161450207274);
#8451= IFCQUANTITYVOLUME('NetVolume',$,$,1.247076581447E-005);
#8452= IFCELEMENTQUANTITY('2a5Thod6r3TBaa1kyfny7q',#5,'BaseQuantities',$,$,(#8449,#8450,#8451,#1754));
#8453= IFCLOCALPLACEMENT(#30,#10);
#8454= IFCELEMENTASSEMBLY('1Td1iR001FoJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#8453,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#8455= IFCCARTESIANPOINT((48738.855569172,4200.00396697467,-1279.00348888654));
#8456= IFCAXIS2PLACEMENT3D(#8455,#8327,#8328);
#8457= IFCLOCALPLACEMENT(#8453,#8456);
#8458= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8357));
#8459= IFCPRODUCTDEFINITIONSHAPE($,$,(#8458));
#8460= IFCBEAM('1Td1iR001FoZ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#8457,#8459,'XX/0(?)');
#8461= IFCQUANTITYLENGTH('Length',$,$,16.0000000001114);
#8462= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161450207264);
#8463= IFCQUANTITYVOLUME('NetVolume',$,$,1.24707658144693E-005);
#8464= IFCELEMENTQUANTITY('2ZLDGdNTf9fPFyO5nRFMby',#5,'BaseQuantities',$,$,(#8461,#8462,#8463,#1754));
#8465= IFCLOCALPLACEMENT(#30,#10);
#8466= IFCELEMENTASSEMBLY('1Td1iR001FpJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#8465,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#8467= IFCCARTESIANPOINT((48738.8555250568,4200.00337875244,-1295.00348887568));
#8468= IFCAXIS2PLACEMENT3D(#8467,#8327,#8328);
#8469= IFCLOCALPLACEMENT(#8465,#8468);
#8470= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8357));
#8471= IFCPRODUCTDEFINITIONSHAPE($,$,(#8470));
#8472= IFCBEAM('1Td1iR001FpZ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#8469,#8471,'XX/0(?)');
#8473= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161450207266);
#8474= IFCQUANTITYVOLUME('NetVolume',$,$,1.24707658144694E-005);
#8475= IFCELEMENTQUANTITY('3EQABMPOH9Xvj1IBbVr_v2',#5,'BaseQuantities',$,$,(#8461,#8473,#8474,#1754));
#8476= IFCLOCALPLACEMENT(#30,#10);
#8477= IFCELEMENTASSEMBLY('1Td1iR001FqJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#8476,$,'R/1(?)',.NOTDEFINED.,.RIGID_FRAME.);
#8478= IFCQUANTITYLENGTH('Width',$,$,20.0000000000018);
#8479= IFCELEMENTQUANTITY('18xHaEs7b7A8Vh8MeIOIld',#5,'BaseQuantities',$,$,(#8478));
#8480= IFCCARTESIANPOINT((48738.8556244317,4200.00448165605,-1265.00384421133));
#8481= IFCAXIS2PLACEMENT3D(#8480,#8138,#8396);
#8482= IFCLOCALPLACEMENT(#8476,#8481);
#8483= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8401));
#8484= IFCPRODUCTDEFINITIONSHAPE($,$,(#8483));
#8485= IFCBEAM('1Td1iR001FqZ4rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#8482,#8484,'P/487(?)');
#8486= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(9.61665384255014E-005),$);
#8487= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(9.61665384255014E-005),$);
#8488= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(9.61665384255014E-005),$);
#8489= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.000282842712474635),$);
#8490= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0213836676491577),$);
#8491= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0213836676491577),$);
#8492= IFCPROPERTYSET('0pBDffz19EbAHSfNg3LN3U',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#8486,#8487,#8488,#8489,#1744,#8490,#8491,#1847,#5269,#8417));
#8493= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0213836676491577);
#8494= IFCQUANTITYVOLUME('NetVolume',$,$,9.61665384255014E-005);
#8495= IFCELEMENTQUANTITY('3epbkVRp1EIfgRbHdg2unB',#5,'BaseQuantities',$,$,(#8419,#8493,#8494,#1754));
#8496= IFCCARTESIANPOINT((48738.8552596716,3645.00264361321,-1314.99568023916));
#8497= IFCAXIS2PLACEMENT3D(#8496,#8138,#8139);
#8498= IFCLOCALPLACEMENT(#30,#8497);
#8499= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#8500= IFCEXTRUDEDAREASOLID(#8499,#2479,#9,15.0999999999802);
#8501= IFCSTYLEDITEM(#8500,(#195),$);
#8502= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8500));
#8503= IFCREPRESENTATIONMAP(#10,#8502);
#8504= IFCMAPPEDITEM(#8503,#247);
#8505= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#8504));
#8506= IFCPRODUCTDEFINITIONSHAPE($,$,(#8505));
#8507= IFCMECHANICALFASTENER('1Td1iR001FtJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#8498,#8506,'ID5d9c1b1b-0000-4fdd-3135-373035313136',20.,15.);
#8508= IFCCARTESIANPOINT((48738.855210997,3645.00209237423,-1329.98952226088));
#8509= IFCDIRECTION((-0.999999999999577,9.19999999950571E-007,0.));
#8510= IFCAXIS2PLACEMENT3D(#8508,#8509,#8157);
#8511= IFCLOCALPLACEMENT(#30,#8510);
#8512= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,29.);
#8513= IFCCARTESIANPOINT((0.,0.000466319708024798,0.));
#8514= IFCAXIS2PLACEMENT3D(#8513,#8,#7);
#8515= IFCEXTRUDEDAREASOLID(#8512,#8514,#9,20.1000000001408);
#8516= IFCSTYLEDITEM(#8515,(#195),$);
#8517= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8515));
#8518= IFCREPRESENTATIONMAP(#10,#8517);
#8519= IFCMAPPEDITEM(#8518,#247);
#8520= IFCCARTESIANPOINT((277.380004882818,0.,-3.78349795937538E-010));
#8521= IFCCARTESIANTRANSFORMATIONOPERATOR3D($,$,#8520,$,$);
#8522= IFCMAPPEDITEM(#8518,#8521);
#8523= IFCCARTESIANPOINT((554.760009765636,0.,-7.56699591875076E-010));
#8524= IFCCARTESIANTRANSFORMATIONOPERATOR3D($,$,#8523,$,$);
#8525= IFCMAPPEDITEM(#8518,#8524);
#8526= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#8519,#8522,#8525));
#8527= IFCPRODUCTDEFINITIONSHAPE($,$,(#8526));
#8528= IFCMECHANICALFASTENER('1Td1iR001Fup4rDp0rCJ4s',#5,'Bolt assembly',$,$,#8511,#8527,'ID5d9c1b1b-0000-4fe3-3135-373035313136',30.,20.);
#8529= IFCPROPERTYSINGLEVALUE('Bolt hole diameter',$,IFCLENGTHMEASURE(58.),$);
#8530= IFCPROPERTYSINGLEVALUE('Bolt size',$,IFCLENGTHMEASURE(58.),$);
#8531= IFCPROPERTYSINGLEVALUE('Bolt length',$,IFCLENGTHMEASURE(20.),$);
#8532= IFCPROPERTYSET('0Rx8j9RAP8Ke03KiL9AO$3',#5,'Tekla Bolt','Bolt Properties',(#255,#570,#571,#572,#259,#573,#574,#262,#263,#8529,#265,#266,#8530,#8531,#579,#580));
#8533= IFCCARTESIANPOINT((48688.8552389928,3645.00241388917,-1322.49554237569));
#8534= IFCAXIS2PLACEMENT3D(#8533,#8157,#8138);
#8535= IFCLOCALPLACEMENT(#8233,#8534);
#8536= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8183));
#8537= IFCPRODUCTDEFINITIONSHAPE($,$,(#8536));
#8538= IFCDISCRETEACCESSORY('1Td1iR001FvZ4rDp0rCJ4s',#5,'ANKRAJ','PLT15*100','PLT15*100',#8535,#8537,'P/484(?)');
#8539= IFCPROPERTYSET('25vQim_551nfk_FrzmedO6',#5,'Tekla Common','Common Properties to Shared building elements',(#8189,#8190,#8191,#8262,#74,#75,#76,#1194,#78,#8192,#80));
#8540= IFCPROPERTYSET('05pBc5hJPDgO66WOpqmAay',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#8265,#8195,#8196,#8197,#8198,#8199,#8200,#8201,#8226,#8203,#8204,#8205,#8206,#8207));
#8541= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0259999999999206);
#8542= IFCQUANTITYVOLUME('NetVolume',$,$,0.00014999999999948);
#8543= IFCQUANTITYWEIGHT('NetWeight',$,$,1.17749999999592);
#8544= IFCELEMENTQUANTITY('2uj$lXrDjDkQ9uszVEavep',#5,'BaseQuantities',$,$,(#8209,#8541,#8542,#8543));
#8545= IFCCARTESIANPOINT((48633.8565750792,3550.00770343543,-1179.99128474671));
#8546= IFCDIRECTION((-0.999999999409901,6.95050128058986E-010,3.43540000030966E-005));
#8547= IFCDIRECTION((0.,0.999999999795333,-2.02319999957525E-005));
#8548= IFCAXIS2PLACEMENT3D(#8545,#8546,#8547);
#8549= IFCLOCALPLACEMENT(#8233,#8548);
#8550= IFCCARTESIANPOINT((-0.00133424707336415,99.9999999910989));
#8551= IFCCARTESIANPOINT((645.002014160292,4.28944433513258E-010));
#8552= IFCCARTESIANPOINT((745.000345877218,99.9999999865796));
#8553= IFCCARTESIANPOINT((744.99951171888,150.001007080645));
#8554= IFCCARTESIANPOINT((-0.00200138404716199,150.001007080164));
#8555= IFCPOLYLINE((#8550,#8247,#8551,#8552,#8553,#8554,#8550));
#8556= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL10*150',#8555);
#8557= IFCEXTRUDEDAREASOLID(#8556,#8254,#9,10.);
#8558= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8557));
#8559= IFCSTYLEDITEM(#8557,(#53),$);
#8560= IFCPRODUCTDEFINITIONSHAPE($,$,(#8558));
#8561= IFCDISCRETEACCESSORY('1Td1iR001FwJ4rDp0rCJ4s',#5,'DETAY','PL10*150','PL10*150',#8549,#8560,'P/222(?)');
#8562= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/222(?)'),$);
#8563= IFCPROPERTYSET('1sjPiOF4D6sOoocsxDhF2I',#5,'Tekla Common','Common Properties to Shared building elements',(#8189,#8260,#8562,#8262,#74,#75,#76,#77,#78,#8263,#921));
#8564= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(7.98745466355548),$);
#8565= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(8.77246153575608),$);
#8566= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(7.98745466355548),$);
#8567= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.00101751014822363),$);
#8568= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.00101751014822363),$);
#8569= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.00101751014822363),$);
#8570= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.0054500201415977),$);
#8571= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(27.5720513102521),$);
#8572= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.220230509821864),$);
#8573= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.111751102366319),$);
#8574= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(150.00100708025),$);
#8575= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(745.002347261128),$);
#8576= IFCPROPERTYSET('120l_8JqrBOP$dqzI57Atj',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#8265,#8564,#8565,#8566,#8567,#8568,#8569,#8570,#8571,#8572,#8573,#8574,#8277,#8575));
#8577= IFCQUANTITYLENGTH('Width',$,$,150.00100708025);
#8578= IFCQUANTITYAREA('NetArea',$,$,0.220230509821864);
#8579= IFCQUANTITYAREA('GrossArea',$,$,0.111751102366319);
#8580= IFCQUANTITYVOLUME('NetVolume',$,$,0.00101751014822363);
#8581= IFCQUANTITYVOLUME('GrossVolume',$,$,0.00101751014822363);
#8582= IFCELEMENTQUANTITY('2U1PbDEf13OB9poOccUKCG',#5,'BaseQuantities',$,$,(#8577,#8578,#8579,#8283,#8580,#8581));
#8583= IFCCARTESIANPOINT((48828.8525750783,3550.00752401911,-1179.99182238336));
#8584= IFCDIRECTION((-0.999999999408631,-1.59273700335863E-006,3.43540585724984E-005));
#8585= IFCDIRECTION((-1.59399999583265E-006,0.999999999322934,-3.6764000011737E-005));
#8586= IFCAXIS2PLACEMENT3D(#8583,#8584,#8585);
#8587= IFCLOCALPLACEMENT(#8233,#8586);
#8588= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8255));
#8589= IFCPRODUCTDEFINITIONSHAPE($,$,(#8588));
#8590= IFCDISCRETEACCESSORY('1Td1iR001Fx34rDp0rCJ4s',#5,'DETAY','PL10*150','PL10*150',#8587,#8589,'P/240(?)');
#8591= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(1.37380611640358),$);
#8592= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(1.76630517762284),$);
#8593= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(1.37380611640358),$);
#8594= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000175007148586443),$);
#8595= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000175007148586443),$);
#8596= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000175007148586443),$);
#8597= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.000500039978027261),$);
#8598= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0404157363385634),$);
#8599= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.022500702899654),$);
#8600= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(150.003678892845),$);
#8601= IFCPROPERTYSET('0OE6$3S5v6_9Tj2G5NEzrv',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#8265,#8591,#8592,#8593,#8594,#8595,#8596,#8597,#8273,#8598,#8599,#8574,#8277,#8600));
#8602= IFCQUANTITYLENGTH('Width',$,$,150.001007080149);
#8603= IFCQUANTITYAREA('NetArea',$,$,0.0404157363385634);
#8604= IFCQUANTITYAREA('GrossArea',$,$,0.022500702899654);
#8605= IFCQUANTITYVOLUME('NetVolume',$,$,0.000175007148586443);
#8606= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000175007148586443);
#8607= IFCELEMENTQUANTITY('3LNXMPYPnAHxOMY9Gx8AC1',#5,'BaseQuantities',$,$,(#8602,#8603,#8604,#8283,#8605,#8606));
#8608= IFCCARTESIANPOINT((48828.8529522788,4035.00752374081,-1180.00689557948));
#8609= IFCDIRECTION((0.999999999407282,-2.28984196746312E-006,-3.4353943895332E-005));
#8610= IFCDIRECTION((-2.28899998731542E-006,-0.999999999697035,2.45089999930647E-005));
#8611= IFCAXIS2PLACEMENT3D(#8608,#8609,#8610);
#8612= IFCLOCALPLACEMENT(#8233,#8611);
#8613= IFCCARTESIANPOINT((225.003997802872,1.81898940354586E-012));
#8614= IFCCARTESIANPOINT((225.005828857551,150.001007080106));
#8615= IFCCARTESIANPOINT((0.00231654196022646,150.00100708012));
#8616= IFCPOLYLINE((#54,#8613,#8614,#8615,#54,#54));
#8617= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL10*150',#8616);
#8618= IFCEXTRUDEDAREASOLID(#8617,#8254,#9,10.);
#8619= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8618));
#8620= IFCSTYLEDITEM(#8618,(#53),$);
#8621= IFCPRODUCTDEFINITIONSHAPE($,$,(#8619));
#8622= IFCDISCRETEACCESSORY('1Td1iR001FyZ4rDp0rCJ4s',#5,'DETAY','PL10*150','PL10*150',#8612,#8621,'P/240(?)');
#8623= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(2.6494370036785),$);
#8624= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(2.64946142280965),$);
#8625= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(2.6494370036785),$);
#8626= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000337507898557771),$);
#8627= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000337507898557771),$);
#8628= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000337507898557771),$);
#8629= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00225003997802755),$);
#8630= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(28.3085330393964),$);
#8631= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0750016749544323),$);
#8632= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0337511009275115),$);
#8633= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(225.00582885746),$);
#8634= IFCPROPERTYSET('3MXRKvHan5n9mJDOxO4dNU',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#8265,#8623,#8624,#8625,#8626,#8627,#8628,#8629,#8630,#8631,#8632,#8276,#8277,#8633));
#8635= IFCQUANTITYLENGTH('Width',$,$,150.0010070801);
#8636= IFCQUANTITYAREA('NetArea',$,$,0.0750016749544323);
#8637= IFCQUANTITYAREA('GrossArea',$,$,0.0337511009275115);
#8638= IFCQUANTITYVOLUME('NetVolume',$,$,0.000337507898557771);
#8639= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000337507898557771);
#8640= IFCELEMENTQUANTITY('2Gds_8zpnCHe2DN6CXgeyY',#5,'BaseQuantities',$,$,(#8635,#8636,#8637,#8283,#8638,#8639));
#8641= IFCCARTESIANPOINT((48623.855318347,3922.50184883027,-1339.99930186128));
#8642= IFCDIRECTION((-9.19999998945819E-007,-0.999999999390327,3.49070000136008E-005));
#8643= IFCAXIS2PLACEMENT3D(#8641,#8642,#8138);
#8644= IFCLOCALPLACEMENT(#8233,#8643);
#8645= IFCRECTANGLEPROFILEDEF(.AREA.,'PLT20*745',#197,20.,745.);
#8646= IFCCARTESIANPOINT((214.996968696951,2.2737376649799E-013,7.55547751051962E-021));
#8647= IFCAXIS2PLACEMENT3D(#8646,#185,#501);
#8648= IFCEXTRUDEDAREASOLID(#8645,#8647,#9,214.996968696958);
#8649= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8648));
#8650= IFCSTYLEDITEM(#8648,(#53),$);
#8651= IFCPRODUCTDEFINITIONSHAPE($,$,(#8649));
#8652= IFCDISCRETEACCESSORY('1Td1iR001FzJ4rDp0rCJ4s',#5,'ANKRAJ','PLT20*745','PLT20*745',#8644,#8651,'P/380(?)');
#8653= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -1.350'),$);
#8654= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -1.330'),$);
#8655= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/380(?)'),$);
#8656= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PLT20*745'),$);
#8657= IFCPROPERTYSET('1rqj_IYW90TRnXdRRVPaUP',#5,'Tekla Common','Common Properties to Shared building elements',(#8653,#8654,#8655,#8262,#74,#75,#76,#1194,#78,#8656,#80));
#8658= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(25.1471204435943),$);
#8659= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(25.1471204436266),$);
#8660= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(25.1471204435943),$);
#8661= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.00320345483357889),$);
#8662= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.00320345483357889),$);
#8663= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.00320345483357889),$);
#8664= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.160172741679234),$);
#8665= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(14.2658624835574),$);
#8666= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.358745362105772),$);
#8667= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.358745362105772),$);
#8668= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(745.0000000003),$);
#8669= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(20.0000000005571),$);
#8670= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(214.99696869676),$);
#8671= IFCPROPERTYSET('0zTu9WKGHDi8IbSf3BfBXL',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#8265,#8658,#8659,#8660,#8661,#8662,#8663,#8664,#8665,#8666,#8667,#8668,#8669,#8670));
#8672= IFCQUANTITYLENGTH('Length',$,$,214.99696869676);
#8673= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.358745362105772);
#8674= IFCQUANTITYVOLUME('NetVolume',$,$,0.00320345483357889);
#8675= IFCQUANTITYWEIGHT('NetWeight',$,$,25.1471204435943);
#8676= IFCELEMENTQUANTITY('08Rf6bRjPDovlsULBbev_3',#5,'BaseQuantities',$,$,(#8672,#8673,#8674,#8675));
#8677= IFCLOCALPLACEMENT(#30,#10);
#8678= IFCELEMENTASSEMBLY('1Td1iR001G134rDp0rCJ4s',#5,'GROUT',$,$,#8677,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#8679= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -1.400'),$);
#8680= IFCPROPERTYSET('04JFbgt0v0Fuj31Lc5oLYg',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#8679,#8322,#4551,#2857,#1701));
#8681= IFCQUANTITYLENGTH('Width',$,$,50.0000002290526);
#8682= IFCELEMENTQUANTITY('3DedfQwZn4aghUr6FcQqmK',#5,'BaseQuantities',$,$,(#8681));
#8683= IFCCARTESIANPOINT((48573.8566139395,4345.0000772215,-1375.00399652448));
#8684= IFCDIRECTION((-2.75701496974052E-006,-1.62719974614019E-005,-0.999999999863811));
#8685= IFCAXIS2PLACEMENT3D(#8683,#8684,#8138);
#8686= IFCLOCALPLACEMENT(#8677,#8685);
#8687= IFCCARTESIANPOINT((314.998321532403,844.999999998684));
#8688= IFCCARTESIANPOINT((0.000308202077576425,845.000000000112));
#8689= IFCPOLYLINE((#54,#4561,#8687,#8688,#54,#54));
#8690= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL50*315',#8689);
#8691= IFCEXTRUDEDAREASOLID(#8690,#4567,#9,50.);
#8692= IFCDIRECTION((5.32775036479406E-011,0.707120576591423,-0.707092985512523));
#8693= IFCAXIS2PLACEMENT3D(#4574,#185,#8692);
#8694= IFCEXTRUDEDAREASOLID(#4572,#8693,#9,550.);
#8695= IFCBOOLEANRESULT(.DIFFERENCE.,#8691,#8694);
#8696= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL1200*50',#4580);
#8697= IFCDIRECTION((-0.707135182382729,-1.44898580504266E-005,-0.707078378701109));
#8698= IFCDIRECTION((7.15466400002681E-010,-0.999999999790042,2.04918613726215E-005));
#8699= IFCCARTESIANPOINT((314.998015674284,1178.99999978473,24.9758403227125));
#8700= IFCAXIS2PLACEMENT3D(#8699,#8698,#8697);
#8701= IFCEXTRUDEDAREASOLID(#8696,#8700,#9,1200.);
#8702= IFCBOOLEANRESULT(.DIFFERENCE.,#8695,#8701);
#8703= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL1200*50',#4590);
#8704= IFCDIRECTION((0.707133987419035,-1.44889662369072E-005,-0.7070795737588));
#8705= IFCCARTESIANPOINT((0.000308776262941353,-331.999999904641,25.0191194141474));
#8706= IFCAXIS2PLACEMENT3D(#8705,#8547,#8704);
#8707= IFCEXTRUDEDAREASOLID(#8703,#8706,#9,1200.);
#8708= IFCBOOLEANRESULT(.DIFFERENCE.,#8702,#8707);
#8709= IFCDIRECTION((6.81159991933814E-011,-0.707149555350884,-0.707064004434568));
#8710= IFCCARTESIANPOINT((-160.00069185211,845.000067632321,24.9956103291407));
#8711= IFCAXIS2PLACEMENT3D(#8710,#7,#8709);
#8712= IFCEXTRUDEDAREASOLID(#4572,#8711,#9,550.);
#8713= IFCBOOLEANRESULT(.DIFFERENCE.,#8708,#8712);
#8714= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#8713));
#8715= IFCSTYLEDITEM(#8691,(#4560),$);
#8716= IFCPRODUCTDEFINITIONSHAPE($,$,(#8714));
#8717= IFCPLATE('1Td1iR001G1J4rDp0rCJ4s',#5,'GROUT','PL50*315','PL50*315',#8686,#8716,'XX/0(?)');
#8718= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -1.400'),$);
#8719= IFCPROPERTYSET('27M6u8fJLB89aMSoDiwRvD',#5,'Tekla Common','Common Properties to Shared building elements',(#8718,#8337,#1730,#1731,#74,#75,#76,#4610,#4611,#4612,#4613));
#8720= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.010574287266399),$);
#8721= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.0133086661272272),$);
#8722= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.010574287266399),$);
#8723= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.160174884477382),$);
#8724= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.576245569711857),$);
#8725= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.266173381476605),$);
#8726= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(314.998016519079),$);
#8727= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(50.0000002287027),$);
#8728= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(845.000182597922),$);
#8729= IFCPROPERTYSET('3euyoiI0D0ERnvgBGo9E_e',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#8720,#8721,#8722,#8723,#1744,#8724,#8725,#8726,#8727,#8728));
#8730= IFCQUANTITYLENGTH('Width',$,$,314.998016519079);
#8731= IFCQUANTITYAREA('NetArea',$,$,0.576245569711857);
#8732= IFCQUANTITYAREA('GrossArea',$,$,0.266173381476605);
#8733= IFCQUANTITYVOLUME('NetVolume',$,$,0.010574287266399);
#8734= IFCQUANTITYVOLUME('GrossVolume',$,$,0.0133086661272272);
#8735= IFCELEMENTQUANTITY('0sN9Y4CI99xvYIfGjIzp$C',#5,'BaseQuantities',$,$,(#8730,#8731,#8732,#4628,#8733,#8734));
#8736= IFCLOCALPLACEMENT(#30,#10);
#8737= IFCELEMENTASSEMBLY('1Td1iR001G234rDp0rCJ4s',#5,'Steel Assembly',$,$,#8736,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#8738= IFCCARTESIANPOINT((48738.8552785413,3645.00279067903,-1310.99540080836));
#8739= IFCAXIS2PLACEMENT3D(#8738,#8139,#8295);
#8740= IFCLOCALPLACEMENT(#8736,#8739);
#8741= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8298));
#8742= IFCPRODUCTDEFINITIONSHAPE($,$,(#8741));
#8743= IFCBEAM('1Td1iR001G2J4rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#8740,#8742,'XX/0(?)');
#8744= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00180062582345094);
#8745= IFCQUANTITYVOLUME('NetVolume',$,$,3.93300000137249E-006);
#8746= IFCELEMENTQUANTITY('0SaZWcy0nBaBOHn9jcWf6y',#5,'BaseQuantities',$,$,(#8315,#8744,#8745,#1754));
#8747= IFCLOCALPLACEMENT(#30,#10);
#8748= IFCELEMENTASSEMBLY('1Td1iR001G334rDp0rCJ4s',#5,'Steel Assembly',$,$,#8747,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#8749= IFCCARTESIANPOINT((48738.8521710105,3645.0013568901,-1349.99540077361));
#8750= IFCAXIS2PLACEMENT3D(#8749,#8327,#8328);
#8751= IFCLOCALPLACEMENT(#8747,#8750);
#8752= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8331));
#8753= IFCPRODUCTDEFINITIONSHAPE($,$,(#8752));
#8754= IFCBEAM('1Td1iR001G3J4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#8751,#8753,'XX/0(?)');
#8755= IFCQUANTITYLENGTH('Length',$,$,16.0000000001048);
#8756= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161450207252);
#8757= IFCQUANTITYVOLUME('NetVolume',$,$,1.24707658144689E-005);
#8758= IFCELEMENTQUANTITY('2MmsRozBz1pOcbOb_dK_L1',#5,'BaseQuantities',$,$,(#8755,#8756,#8757,#1754));
#8759= IFCLOCALPLACEMENT(#30,#10);
#8760= IFCELEMENTASSEMBLY('1Td1iR001G434rDp0rCJ4s',#5,'Steel Assembly',$,$,#8759,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#8761= IFCCARTESIANPOINT((48738.8553667717,3645.0039671235,-1278.99540083009));
#8762= IFCAXIS2PLACEMENT3D(#8761,#8327,#8328);
#8763= IFCLOCALPLACEMENT(#8759,#8762);
#8764= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8357));
#8765= IFCPRODUCTDEFINITIONSHAPE($,$,(#8764));
#8766= IFCBEAM('1Td1iR001G4J4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#8763,#8765,'XX/0(?)');
#8767= IFCQUANTITYVOLUME('NetVolume',$,$,1.2470765814468E-005);
#8768= IFCELEMENTQUANTITY('3WAIb5N9zBxgxJlLCHR_gd',#5,'BaseQuantities',$,$,(#8365,#8366,#8767,#1754));
#8769= IFCLOCALPLACEMENT(#30,#10);
#8770= IFCELEMENTASSEMBLY('1Td1iR001G534rDp0rCJ4s',#5,'Steel Assembly',$,$,#8769,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#8771= IFCCARTESIANPOINT((48738.8553226565,3645.00337890127,-1294.99540081922));
#8772= IFCAXIS2PLACEMENT3D(#8771,#8327,#8328);
#8773= IFCLOCALPLACEMENT(#8769,#8772);
#8774= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8357));
#8775= IFCPRODUCTDEFINITIONSHAPE($,$,(#8774));
#8776= IFCBEAM('1Td1iR001G5J4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#8773,#8775,'XX/0(?)');
#8777= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0032216145020724);
#8778= IFCQUANTITYVOLUME('NetVolume',$,$,1.2470765814468E-005);
#8779= IFCELEMENTQUANTITY('2HodRBgxP3QP$AD7Qov2Xx',#5,'BaseQuantities',$,$,(#8365,#8777,#8778,#1754));
#8780= IFCLOCALPLACEMENT(#30,#10);
#8781= IFCELEMENTASSEMBLY('1Td1iR001G634rDp0rCJ4s',#5,'Steel Assembly',$,$,#8780,$,'R/1(?)',.NOTDEFINED.,.RIGID_FRAME.);
#8782= IFCCARTESIANPOINT((48738.8554220314,3645.00448180489,-1264.99575615487));
#8783= IFCAXIS2PLACEMENT3D(#8782,#8138,#8396);
#8784= IFCLOCALPLACEMENT(#8780,#8783);
#8785= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8401));
#8786= IFCPRODUCTDEFINITIONSHAPE($,$,(#8785));
#8787= IFCBEAM('1Td1iR001G6J4rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#8784,#8786,'P/487(?)');
#8788= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0213836676491557);
#8789= IFCQUANTITYVOLUME('NetVolume',$,$,9.61665384254829E-005);
#8790= IFCELEMENTQUANTITY('0nOonvMAbAyvaY9VeTfIIr',#5,'BaseQuantities',$,$,(#8419,#8788,#8789,#1754));
#8791= IFCCARTESIANPOINT((48747.1501910091,-544.169499915104,-7141.00517822094));
#8792= IFCAXIS2PLACEMENT3D(#8791,#7,#501);
#8793= IFCLOCALPLACEMENT(#30,#8792);
#8794= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#8795= IFCCARTESIANPOINT((0.,8.10000000012733,0.));
#8796= IFCAXIS2PLACEMENT3D(#8795,#8,#7);
#8797= IFCEXTRUDEDAREASOLID(#8794,#8796,#9,6.);
#8798= IFCSTYLEDITEM(#8797,(#195),$);
#8799= IFCCARTESIANPOINT((6.5,16.));
#8800= IFCCARTESIANPOINT((6.5,-16.));
#8801= IFCPOLYLINE((#8799,#8800));
#8802= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#8801);
#8803= IFCCARTESIANPOINT((0.,-16.));
#8804= IFCAXIS2PLACEMENT2D(#8803,#196);
#8805= IFCCIRCLE(#8804,6.5);
#8806= IFCTRIMMEDCURVE(#8805,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(3.14159265358979)),.F.,.PARAMETER.);
#8807= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#8806);
#8808= IFCCARTESIANPOINT((-6.5,-16.));
#8809= IFCCARTESIANPOINT((-6.5,16.));
#8810= IFCPOLYLINE((#8808,#8809));
#8811= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#8810);
#8812= IFCCARTESIANPOINT((0.,16.));
#8813= IFCAXIS2PLACEMENT2D(#8812,#1859);
#8814= IFCCIRCLE(#8813,6.5);
#8815= IFCTRIMMEDCURVE(#8814,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(3.14159265358979)),.F.,.PARAMETER.);
#8816= IFCCOMPOSITECURVESEGMENT(.DISCONTINUOUS.,.T.,#8815);
#8817= IFCCOMPOSITECURVE((#8802,#8807,#8811,#8816),.F.);
#8818= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#8817);
#8819= IFCCARTESIANPOINT((0.,13.9000000002437,0.));
#8820= IFCAXIS2PLACEMENT3D(#8819,#8,#7);
#8821= IFCEXTRUDEDAREASOLID(#8818,#8820,#9,6.1);
#8822= IFCSTYLEDITEM(#8821,(#195),$);
#8823= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3875);
#8824= IFCCARTESIANPOINT((0.,0.0800000001273293,0.));
#8825= IFCAXIS2PLACEMENT3D(#8824,#8,#7);
#8826= IFCEXTRUDEDAREASOLID(#8823,#8825,#9,7.92);
#8827= IFCSTYLEDITEM(#8826,(#558),$);
#8828= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#8829= IFCCARTESIANPOINT((0.,8.00000000012733,0.));
#8830= IFCAXIS2PLACEMENT3D(#8829,#8,#7);
#8831= IFCEXTRUDEDAREASOLID(#8828,#8830,#9,35.);
#8832= IFCSTYLEDITEM(#8831,(#558),$);
#8833= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#8834= IFCCARTESIANPOINT((0.,20.0000000002437,0.));
#8835= IFCAXIS2PLACEMENT3D(#8834,#8,#7);
#8836= IFCEXTRUDEDAREASOLID(#8833,#8835,#9,8.);
#8837= IFCSTYLEDITEM(#8836,(#558),$);
#8838= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#8839= IFCCARTESIANPOINT((0.,28.0000000002437,0.));
#8840= IFCAXIS2PLACEMENT3D(#8839,#8,#7);
#8841= IFCEXTRUDEDAREASOLID(#8838,#8840,#9,10.);
#8842= IFCSTYLEDITEM(#8841,(#558),$);
#8843= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8797,#8821,#8826,#8831,#8836,#8841));
#8844= IFCREPRESENTATIONMAP(#10,#8843);
#8845= IFCMAPPEDITEM(#8844,#247);
#8846= IFCCARTESIANPOINT((70.,0.,0.));
#8847= IFCCARTESIANTRANSFORMATIONOPERATOR3D($,$,#8846,$,$);
#8848= IFCMAPPEDITEM(#8844,#8847);
#8849= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#8845,#8848));
#8850= IFCPRODUCTDEFINITIONSHAPE($,$,(#8849));
#8851= IFCMECHANICALFASTENER('1Td1iR001GJp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#8793,#8850,'ID5d9c1b1b-0000-504f-3135-373035313136',12.,35.);
#8852= IFCPROPERTYSINGLEVALUE('Slotted hole y',$,IFCLENGTHMEASURE(32.),$);
#8853= IFCPROPERTYSET('3T2nmVGFjAaBtgGi95GMKK',#5,'Tekla Bolt','Bolt Properties',(#255,#3912,#571,#3913,#259,#573,#3914,#8852,#263,#3915,#265,#266,#3916,#3917,#579,#3918));
#8854= IFCLOCALPLACEMENT(#30,#10);
#8855= IFCELEMENTASSEMBLY('1Td1iR001WvZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#8854,$,'B/175(?)',.NOTDEFINED.,.RIGID_FRAME.);
#8856= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(56.3565645278347),$);
#8857= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -7.190'),$);
#8858= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -7.100'),$);
#8859= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('B/175(?)'),$);
#8860= IFCPROPERTYSET('0UB7zyY3vDXxFjL_OsssMM',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#8856,#8857,#8858,#890,#488,#8859));
#8861= IFCQUANTITYLENGTH('Width',$,$,90.0051669316799);
#8862= IFCELEMENTQUANTITY('3fhk0DsiT1kwhr0ACrzbKW',#5,'BaseQuantities',$,$,(#8861));
#8863= IFCCARTESIANPOINT((48674.1328858331,-495.170126624211,-7145.00517822062));
#8864= IFCAXIS2PLACEMENT3D(#8863,#9,#501);
#8865= IFCLOCALPLACEMENT(#8854,#8864);
#8866= IFCCARTESIANPOINT((187.997,0.,0.));
#8867= IFCAXIS2PLACEMENT3D(#8866,#185,#501);
#8868= IFCEXTRUDEDAREASOLID(#4033,#8867,#9,187.997);
#8869= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8868));
#8870= IFCSTYLEDITEM(#8868,(#4032),$);
#8871= IFCPRODUCTDEFINITIONSHAPE($,$,(#8869));
#8872= IFCDISCRETEACCESSORY('1Td1iR001GKp4rDp0rCJ4s',#5,'DIKME','PLT6*78','PLT6*78',#8865,#8871,'P/474(?)');
#8873= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -7.184'),$);
#8874= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -7.106'),$);
#8875= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/474(?)'),$);
#8876= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('B/175(?)'),$);
#8877= IFCPROPERTYSET('0JRfuDhQTAXOfrzTC4aFrh',#5,'Tekla Common','Common Properties to Shared building elements',(#8873,#8874,#8875,#8876,#74,#75,#919,#4046,#78,#4047,#4048));
#8878= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(56.3565645278347),$);
#8879= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.6906633786),$);
#8880= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(0.6906633786),$);
#8881= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.6906633786),$);
#8882= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(47.0844365107619),$);
#8883= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.032519496),$);
#8884= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.032519496),$);
#8885= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(187.997),$);
#8886= IFCPROPERTYSET('3Lek$idFb2XRORuH7wy8Ps',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#8878,#8879,#8880,#8881,#4054,#4055,#4056,#4057,#8882,#8883,#8884,#4061,#3965,#8885));
#8887= IFCQUANTITYLENGTH('Length',$,$,187.997);
#8888= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.032519496);
#8889= IFCQUANTITYVOLUME('NetVolume',$,$,8.7982596E-005);
#8890= IFCQUANTITYWEIGHT('NetWeight',$,$,0.6906633786);
#8891= IFCELEMENTQUANTITY('0iWOwOWurFQQc8DgxX81oQ',#5,'BaseQuantities',$,$,(#8887,#8888,#8889,#8890));
#8892= IFCCARTESIANPOINT((48787.1434756826,-572.169963585371,-7152.00517822106));
#8893= IFCAXIS2PLACEMENT3D(#8892,#501,#185);
#8894= IFCLOCALPLACEMENT(#8854,#8893);
#8895= IFCRECTANGLEPROFILEDEF(.AREA.,'PLT6*154',#197,6.,154.);
#8896= IFCCARTESIANPOINT((110.010591309212,0.,0.));
#8897= IFCAXIS2PLACEMENT3D(#8896,#185,#501);
#8898= IFCEXTRUDEDAREASOLID(#8895,#8897,#9,110.010591309212);
#8899= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8898));
#8900= IFCSTYLEDITEM(#8898,(#4077),$);
#8901= IFCPRODUCTDEFINITIONSHAPE($,$,(#8899));
#8902= IFCDISCRETEACCESSORY('1Td1iR001GLZ4rDp0rCJ4s',#5,'DIKME','PLT6*154','PLT6*154',#8894,#8901,'P/471(?)');
#8903= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -7.155'),$);
#8904= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -7.149'),$);
#8905= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/471(?)'),$);
#8906= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PLT6*154'),$);
#8907= IFCPROPERTYSET('2lcH9lJozDhQe7ymmmSdW3',#5,'Tekla Common','Common Properties to Shared building elements',(#8903,#8904,#8905,#8876,#74,#75,#919,#4089,#78,#8906,#4048));
#8908= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.797950823002239),$);
#8909= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(0.797950823002239),$);
#8910= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.797950823002239),$);
#8911= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000101649786369712),$);
#8912= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000101649786369712),$);
#8913= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000101649786369712),$);
#8914= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.0169416310616187),$);
#8915= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(46.4331737631956),$);
#8916= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0370513892189479),$);
#8917= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0370513892189479),$);
#8918= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(154.),$);
#8919= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(110.010591309212),$);
#8920= IFCPROPERTYSET('0M9WeahefEu842j0bHE8KT',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#8878,#8908,#8909,#8910,#8911,#8912,#8913,#8914,#8915,#8916,#8917,#8918,#3965,#8919));
#8921= IFCQUANTITYLENGTH('Length',$,$,110.010591309212);
#8922= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0370513892189479);
#8923= IFCQUANTITYVOLUME('NetVolume',$,$,0.000101649786369712);
#8924= IFCQUANTITYWEIGHT('NetWeight',$,$,0.797950823002239);
#8925= IFCELEMENTQUANTITY('3sF_cWELj2GhFaVNAgnEr4',#5,'BaseQuantities',$,$,(#8921,#8922,#8923,#8924));
#8926= IFCLOCALPLACEMENT(#30,#10);
#8927= IFCELEMENTASSEMBLY('1Td1iR001GMJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#8926,$,'B/164(?)',.NOTDEFINED.,.RIGID_FRAME.);
#8928= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(0.282636178803339),$);
#8929= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -7.221'),$);
#8930= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -7.161'),$);
#8931= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('B/164(?)'),$);
#8932= IFCPROPERTYSET('1kXIeBJGb1EvkFf8BYOIbB',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#8928,#8929,#8930,#4310,#3926,#8931));
#8933= IFCQUANTITYLENGTH('Width',$,$,6.00000000013847);
#8934= IFCELEMENTQUANTITY('3rkf2jIN97ne4MXcaAChp5',#5,'BaseQuantities',$,$,(#8933));
#8935= IFCCARTESIANPOINT((48697.1372754816,-579.169652503085,-7191.00517822067));
#8936= IFCDIRECTION((-1.76529999972451E-005,0.999999999844186,0.));
#8937= IFCAXIS2PLACEMENT3D(#8935,#8936,#9);
#8938= IFCLOCALPLACEMENT(#8926,#8937);
#8939= IFCCARTESIANPOINT((30.,123.35040283428));
#8940= IFCCARTESIANPOINT((-30.,123.35040283428));
#8941= IFCCARTESIANPOINT((-30.,93.3504028337411));
#8942= IFCPOLYLINE((#54,#3980,#8939,#8940,#8941,#54,#54));
#8943= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL6*60',#8942);
#8944= IFCEXTRUDEDAREASOLID(#8943,#3942,#9,6.);
#8945= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8944));
#8946= IFCSTYLEDITEM(#8944,(#53),$);
#8947= IFCPRODUCTDEFINITIONSHAPE($,$,(#8945));
#8948= IFCPLATE('1Td1iR001GMZ4rDp0rCJ4s',#5,'DETAY','PL6*60','PL6*60',#8938,#8947,'P/396(?)');
#8949= IFCPLATETYPE('2tFVcZSS15TuGeOGSPYvHD',#5,'PL6*60',$,$,$,$,$,$,.NOTDEFINED.);
#8950= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -7.221'),$);
#8951= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -7.161'),$);
#8952= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/396(?)'),$);
#8953= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('B/164(?)'),$);
#8954= IFCPROPERTYSET('2_OI4BbJH2mwMYQIvBccMU',#5,'Tekla Common','Common Properties to Shared building elements',(#8950,#8951,#8952,#8953,#74,#75,#919,#77,#78,#3994,#921));
#8955= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(0.282636178803339),$);
#8956= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.282636178803339),$);
#8957= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(0.348588238404451),$);
#8958= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.282636178803339),$);
#8959= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(3.60046087647565E-005),$);
#8960= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(3.60046087647565E-005),$);
#8961= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(3.60046087647565E-005),$);
#8962= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00074010241699218),$);
#8963= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(49.7103869820673),$);
#8964= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0140499538234467),$);
#8965= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.00740102416994589),$);
#8966= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(60.),$);
#8967= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(6.00000000075818),$);
#8968= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(123.350402832431),$);
#8969= IFCPROPERTYSET('179fgD0_98P9xXX7LkQR4B',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#8955,#8956,#8957,#8958,#8959,#8960,#8961,#8962,#8963,#8964,#8965,#8966,#8967,#8968));
#8970= IFCQUANTITYLENGTH('Width',$,$,60.);
#8971= IFCQUANTITYAREA('NetArea',$,$,0.0140499538234467);
#8972= IFCQUANTITYAREA('GrossArea',$,$,0.00740102416994589);
#8973= IFCQUANTITYVOLUME('NetVolume',$,$,3.60046087647565E-005);
#8974= IFCQUANTITYVOLUME('GrossVolume',$,$,3.60046087647565E-005);
#8975= IFCELEMENTQUANTITY('2Bt7iSbtbD1vKTm3pco$nh',#5,'BaseQuantities',$,$,(#8970,#8971,#8972,#3971,#8973,#8974));
#8976= IFCLOCALPLACEMENT(#30,#10);
#8977= IFCELEMENTASSEMBLY('1Td1iR001GNJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#8976,$,'DK/90(?)',.NOTDEFINED.,.RIGID_FRAME.);
#8978= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(0.871486525616915),$);
#8979= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -7.161'),$);
#8980= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -7.155'),$);
#8981= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('DK/90(?)'),$);
#8982= IFCPROPERTYSET('27wq7BrBvFigdOH1IBKlBP',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#8978,#8979,#8980,#3925,#3926,#8981));
#8983= IFCQUANTITYLENGTH('Width',$,$,6.);
#8984= IFCELEMENTQUANTITY('3mdrr_uNP1Xw19Y$WjRQx9',#5,'BaseQuantities',$,$,(#8983));
#8985= IFCCARTESIANPOINT((48820.4899330352,-584.170000087515,-7158.00517822118));
#8986= IFCAXIS2PLACEMENT3D(#8985,#501,#185);
#8987= IFCLOCALPLACEMENT(#8976,#8986);
#8988= IFCRECTANGLEPROFILEDEF(.AREA.,'PLT6*150',#197,6.,150.);
#8989= IFCCARTESIANPOINT((123.352657553703,0.,0.));
#8990= IFCAXIS2PLACEMENT3D(#8989,#185,#501);
#8991= IFCEXTRUDEDAREASOLID(#8988,#8990,#9,123.352657553703);
#8992= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8991));
#8993= IFCSTYLEDITEM(#8991,(#4032),$);
#8994= IFCPRODUCTDEFINITIONSHAPE($,$,(#8992));
#8995= IFCBEAM('1Td1iR001GNZ4rDp0rCJ4s',#5,'DIKME','PLT6*150','PLT6*150',#8987,#8994,'P/465(?)');
#8996= IFCBEAMTYPE('35e03_WuP9lA6NqOSnANwz',#5,'PLT6*150',$,$,$,$,$,$,.NOTDEFINED.);
#8997= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -7.161'),$);
#8998= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -7.155'),$);
#8999= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/465(?)'),$);
#9000= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('DK/90(?)'),$);
#9001= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PLT6*150'),$);
#9002= IFCPROPERTYSET('3bYpeziTnFFwcMIdOQCrBG',#5,'Tekla Common','Common Properties to Shared building elements',(#8997,#8998,#8999,#9000,#74,#75,#919,#4046,#78,#9001,#4048));
#9003= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(0.871486525616915),$);
#9004= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.871486525616915),$);
#9005= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(0.871486525616915),$);
#9006= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.871486525616915),$);
#9007= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000111017391798333),$);
#9008= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000111017391798333),$);
#9009= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000111017391798333),$);
#9010= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.0185028986330555),$);
#9011= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(46.2267952200838),$);
#9012= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0402860291567555),$);
#9013= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0402860291567555),$);
#9014= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(123.352657553703),$);
#9015= IFCPROPERTYSET('1KqXV$5XnC$RY6JOJt7Zn1',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#9003,#9004,#9005,#9006,#9007,#9008,#9009,#9010,#9011,#9012,#9013,#529,#3965,#9014));
#9016= IFCQUANTITYLENGTH('Length',$,$,123.352657553703);
#9017= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0402860291567555);
#9018= IFCQUANTITYVOLUME('NetVolume',$,$,0.000111017391798333);
#9019= IFCQUANTITYWEIGHT('NetWeight',$,$,0.871486525616915);
#9020= IFCELEMENTQUANTITY('09N1Aby8LEHh98_lsJ0ohm',#5,'BaseQuantities',$,$,(#9016,#9017,#9018,#9019));
#9021= IFCCARTESIANPOINT((48722.9876821691,-581.666077083508,-7665.004));
#9022= IFCAXIS2PLACEMENT3D(#9021,#501,#185);
#9023= IFCLOCALPLACEMENT(#30,#9022);
#9024= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#9025= IFCEXTRUDEDAREASOLID(#9024,#2479,#9,15.1000000000004);
#9026= IFCSTYLEDITEM(#9025,(#195),$);
#9027= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9025));
#9028= IFCREPRESENTATIONMAP(#10,#9027);
#9029= IFCMAPPEDITEM(#9028,#247);
#9030= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#9029));
#9031= IFCPRODUCTDEFINITIONSHAPE($,$,(#9030));
#9032= IFCMECHANICALFASTENER('1Td1iR001H5Z4rDp0rCJ4s',#5,'Bolt assembly',$,$,#9023,#9031,'ID5d9c1b1b-0000-5116-3135-373035313136',20.,15.);
#9033= IFCCARTESIANPOINT((48942.9876821691,-581.666080822769,-7665.004));
#9034= IFCAXIS2PLACEMENT3D(#9033,#8,#7);
#9035= IFCLOCALPLACEMENT(#30,#9034);
#9036= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#9037= IFCEXTRUDEDAREASOLID(#9036,#2479,#9,15.1000000000004);
#9038= IFCSTYLEDITEM(#9037,(#195),$);
#9039= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9037));
#9040= IFCREPRESENTATIONMAP(#10,#9039);
#9041= IFCMAPPEDITEM(#9040,#247);
#9042= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#9041));
#9043= IFCPRODUCTDEFINITIONSHAPE($,$,(#9042));
#9044= IFCMECHANICALFASTENER('1Td1iR001H6J4rDp0rCJ4s',#5,'Bolt assembly',$,$,#9035,#9043,'ID5d9c1b1b-0000-5119-3135-373035313136',20.,15.);
#9045= IFCCARTESIANPOINT((48722.9876821692,-581.663077083508,-7680.004));
#9046= IFCAXIS2PLACEMENT3D(#9045,#8,#7);
#9047= IFCLOCALPLACEMENT(#30,#9046);
#9048= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,29.);
#9049= IFCCARTESIANPOINT((0.,-5.26440377939252E-005,0.));
#9050= IFCAXIS2PLACEMENT3D(#9049,#8,#7);
#9051= IFCEXTRUDEDAREASOLID(#9048,#9050,#9,20.1000000000034);
#9052= IFCSTYLEDITEM(#9051,(#195),$);
#9053= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9051));
#9054= IFCREPRESENTATIONMAP(#10,#9053);
#9055= IFCMAPPEDITEM(#9054,#247);
#9056= IFCCARTESIANPOINT((220.,0.,-1.50066625792533E-009));
#9057= IFCCARTESIANTRANSFORMATIONOPERATOR3D($,$,#9056,$,$);
#9058= IFCMAPPEDITEM(#9054,#9057);
#9059= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#9055,#9058));
#9060= IFCPRODUCTDEFINITIONSHAPE($,$,(#9059));
#9061= IFCMECHANICALFASTENER('1Td1iR001H734rDp0rCJ4s',#5,'Bolt assembly',$,$,#9047,#9060,'ID5d9c1b1b-0000-511c-3135-373035313136',30.,20.);
#9062= IFCLOCALPLACEMENT(#30,#10);
#9063= IFCELEMENTASSEMBLY('1Td1iR0021j34rDp0rCJ4s',#5,'Steel Assembly',$,$,#9062,$,'ANK/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#9064= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(1.1775),$);
#9065= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -7.680'),$);
#9066= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -7.665'),$);
#9067= IFCPROPERTYSET('0SpXipBRv6nuWtk1l73P_A',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#9064,#9065,#9066,#39,#3926,#41));
#9068= IFCQUANTITYLENGTH('Width',$,$,15.);
#9069= IFCELEMENTQUANTITY('23eTdU7fnD8e2ehMcv70Uo',#5,'BaseQuantities',$,$,(#9068));
#9070= IFCCARTESIANPOINT((48722.9876830191,-531.666077083508,-7672.504));
#9071= IFCAXIS2PLACEMENT3D(#9070,#7,#501);
#9072= IFCLOCALPLACEMENT(#9062,#9071);
#9073= IFCEXTRUDEDAREASOLID(#8180,#8182,#9,100.);
#9074= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9073));
#9075= IFCSTYLEDITEM(#9073,(#53),$);
#9076= IFCPRODUCTDEFINITIONSHAPE($,$,(#9074));
#9077= IFCBEAM('1Td1iR001H7p4rDp0rCJ4s',#5,'ANKRAJ','PLT15*100','PLT15*100',#9072,#9076,'P/484(?)');
#9078= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -7.680'),$);
#9079= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -7.665'),$);
#9080= IFCPROPERTYSET('1gbaQ21sTCEBDsgKedzInY',#5,'Tekla Common','Common Properties to Shared building elements',(#9078,#9079,#8191,#73,#74,#75,#919,#1194,#78,#8192,#80));
#9081= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(1.1775),$);
#9082= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(1.1775),$);
#9083= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(1.17750000000403),$);
#9084= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(1.1775),$);
#9085= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.00015),$);
#9086= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.00015),$);
#9087= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.00015),$);
#9088= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.01),$);
#9089= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0260000000000001),$);
#9090= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0260000000000001),$);
#9091= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(100.000000000335),$);
#9092= IFCPROPERTYSET('1grIhJAPL8whq6RiJE4jS7',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#9081,#9082,#9083,#9084,#9085,#9086,#9087,#9088,#8202,#9089,#9090,#8205,#8206,#9091));
#9093= IFCQUANTITYLENGTH('Length',$,$,100.000000000335);
#9094= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0260000000000001);
#9095= IFCQUANTITYVOLUME('NetVolume',$,$,0.00015);
#9096= IFCQUANTITYWEIGHT('NetWeight',$,$,1.1775);
#9097= IFCELEMENTQUANTITY('18bV1ZNAnEdundxyzY73sP',#5,'BaseQuantities',$,$,(#9093,#9094,#9095,#9096));
#9098= IFCLOCALPLACEMENT(#30,#10);
#9099= IFCELEMENTASSEMBLY('1Td1iR001HPJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#9098,$,'ANK/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#9100= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(383.064470429353),$);
#9101= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -7.700'),$);
#9102= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -1.200'),$);
#9103= IFCPROPERTYSET('16Po85CjnEPA8Q4ew_RZ4K',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#9100,#9101,#9102,#39,#3926,#41));
#9104= IFCQUANTITYLENGTH('Width',$,$,6500.00400003436);
#9105= IFCELEMENTQUANTITY('0lIhaSuRb6PP5EKxmlovpt',#5,'BaseQuantities',$,$,(#9104));
#9106= IFCCARTESIANPOINT((48627.9876839546,-484.171106052319,-7530.00338648548));
#9107= IFCDIRECTION((-9.02999999500773E-007,0.999999999500407,3.15969999841909E-005));
#9108= IFCAXIS2PLACEMENT3D(#9106,#9107,#7);
#9109= IFCLOCALPLACEMENT(#9098,#9108);
#9110= IFCCARTESIANPOINT((310.000000001004,-1.13671309763383E-009));
#9111= IFCCARTESIANPOINT((410.000000000742,99.9999999984966));
#9112= IFCCARTESIANPOINT((410.000000000611,150.001007078514));
#9113= IFCPOLYLINE((#8246,#8247,#9110,#9111,#9112,#8250,#8246));
#9114= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL10*150',#9113);
#9115= IFCEXTRUDEDAREASOLID(#9114,#8254,#9,10.);
#9116= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9115));
#9117= IFCSTYLEDITEM(#9115,(#53),$);
#9118= IFCPRODUCTDEFINITIONSHAPE($,$,(#9116));
#9119= IFCDISCRETEACCESSORY('1Td1iR001H8Z4rDp0rCJ4s',#5,'DETAY','PL10*150','PL10*150',#9109,#9118,'P/222(?)');
#9120= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -7.530'),$);
#9121= IFCPROPERTYSET('0KVqRQoZbB$Ar0F28H0gCD',#5,'Tekla Common','Common Properties to Shared building elements',(#9078,#9120,#8562,#73,#74,#75,#919,#77,#78,#8263,#921));
#9122= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(383.064470429353),$);
#9123= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(4.04277959651064),$);
#9124= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(4.82777865775232),$);
#9125= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(4.04277959651064),$);
#9126= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000515003770256133),$);
#9127= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000515003770256133),$);
#9128= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000515003770256133),$);
#9129= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00210000000000002),$);
#9130= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(27.9582875050964),$);
#9131= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.113029194278982),$);
#9132= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0615003650669085),$);
#9133= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(150.001007080277),$);
#9134= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(10.0000000018699),$);
#9135= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(409.99968109544),$);
#9136= IFCPROPERTYSET('0Kfdo9aBb9AQ9g0hRt9hO8',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#9122,#9123,#9124,#9125,#9126,#9127,#9128,#9129,#9130,#9131,#9132,#9133,#9134,#9135));
#9137= IFCQUANTITYLENGTH('Width',$,$,150.001007080277);
#9138= IFCQUANTITYAREA('NetArea',$,$,0.113029194278982);
#9139= IFCQUANTITYAREA('GrossArea',$,$,0.0615003650669085);
#9140= IFCQUANTITYVOLUME('NetVolume',$,$,0.000515003770256133);
#9141= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000515003770256133);
#9142= IFCELEMENTQUANTITY('25x7A1TLb7Yh$ql3Q8PyF0',#5,'BaseQuantities',$,$,(#9137,#9138,#9139,#8283,#9140,#9141));
#9143= IFCCARTESIANPOINT((48627.9876806396,-679.167106052318,-7530.00338648548));
#9144= IFCDIRECTION((-2.49699999887076E-006,0.999999999497697,3.15969999841621E-005));
#9145= IFCDIRECTION((0.999999999996882,2.49700000011722E-006,0.));
#9146= IFCAXIS2PLACEMENT3D(#9143,#9144,#9145);
#9147= IFCLOCALPLACEMENT(#9098,#9146);
#9148= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8255));
#9149= IFCPRODUCTDEFINITIONSHAPE($,$,(#9148));
#9150= IFCDISCRETEACCESSORY('1Td1iR001H9J4rDp0rCJ4s',#5,'DETAY','PL10*150','PL10*150',#9147,#9149,'P/240(?)');
#9151= IFCPROPERTYSET('3ZvRlolrX1HfKxegEkiLPO',#5,'Tekla Common','Common Properties to Shared building elements',(#9078,#9120,#8261,#73,#74,#75,#919,#77,#78,#8263,#921));
#9152= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(1.37380611640559),$);
#9153= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(1.76630517762994),$);
#9154= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(1.37380611640559),$);
#9155= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000175007148586699),$);
#9156= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000175007148586699),$);
#9157= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000175007148586699),$);
#9158= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.000500039978027338),$);
#9159= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0404157363386667),$);
#9160= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0225007028997444),$);
#9161= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(150.003678893438),$);
#9162= IFCPROPERTYSET('305HXoG4T32ueXMiUZS8Dm',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#9122,#9152,#9153,#9154,#9155,#9156,#9157,#9158,#8273,#9159,#9160,#8574,#8277,#9161));
#9163= IFCQUANTITYLENGTH('Width',$,$,150.001007080159);
#9164= IFCQUANTITYAREA('NetArea',$,$,0.0404157363386667);
#9165= IFCQUANTITYAREA('GrossArea',$,$,0.0225007028997444);
#9166= IFCQUANTITYVOLUME('NetVolume',$,$,0.000175007148586699);
#9167= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000175007148586699);
#9168= IFCELEMENTQUANTITY('2570KDEtvB3f$MOHbrd29N',#5,'BaseQuantities',$,$,(#9163,#9164,#9165,#8283,#9166,#9167));
#9169= IFCLOCALPLACEMENT(#30,#10);
#9170= IFCELEMENTASSEMBLY('1Td1iR0021jJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#9169,$,'ANK/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#9171= IFCCARTESIANPOINT((48942.9876830191,-531.666080822769,-7672.504));
#9172= IFCAXIS2PLACEMENT3D(#9171,#185,#501);
#9173= IFCLOCALPLACEMENT(#9169,#9172);
#9174= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9073));
#9175= IFCPRODUCTDEFINITIONSHAPE($,$,(#9174));
#9176= IFCBEAM('1Td1iR001HA34rDp0rCJ4s',#5,'ANKRAJ','PLT15*100','PLT15*100',#9173,#9175,'P/484(?)');
#9177= IFCCARTESIANPOINT((49037.9876806387,-679.16711302094,-7530.00338648548));
#9178= IFCDIRECTION((-2.53099999909464E-006,-0.999999999497612,-3.15969999841594E-005));
#9179= IFCDIRECTION((-0.999999999996797,2.53100000035808E-006,0.));
#9180= IFCAXIS2PLACEMENT3D(#9177,#9178,#9179);
#9181= IFCLOCALPLACEMENT(#9098,#9180);
#9182= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8255));
#9183= IFCPRODUCTDEFINITIONSHAPE($,$,(#9182));
#9184= IFCDISCRETEACCESSORY('1Td1iR001HAp4rDp0rCJ4s',#5,'DETAY','PL10*150','PL10*150',#9181,#9183,'P/240(?)');
#9185= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(1.37380611640565),$);
#9186= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(1.37380611640565),$);
#9187= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000175007148586707),$);
#9188= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000175007148586707),$);
#9189= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000175007148586707),$);
#9190= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.000500039978027345),$);
#9191= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0404157363386687),$);
#9192= IFCPROPERTYSET('1jfp2Raqr4H8rpK64vRnji',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#9122,#9185,#9153,#9186,#9187,#9188,#9189,#9190,#8273,#9191,#9160,#8276,#8277,#9161));
#9193= IFCQUANTITYLENGTH('Width',$,$,150.001007080019);
#9194= IFCQUANTITYAREA('NetArea',$,$,0.0404157363386687);
#9195= IFCQUANTITYAREA('GrossArea',$,$,0.0225007028996983);
#9196= IFCQUANTITYVOLUME('NetVolume',$,$,0.000175007148586707);
#9197= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000175007148586707);
#9198= IFCELEMENTQUANTITY('0p2M6kmcL9JPSWBizKkxid',#5,'BaseQuantities',$,$,(#9193,#9194,#9195,#8283,#9196,#9197));
#9199= IFCLOCALPLACEMENT(#30,#10);
#9200= IFCELEMENTASSEMBLY('1Td1iR001HEZ4rDp0rCJ4s',#5,'GROUT',$,$,#9199,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#9201= IFCPROPERTYSET('3GYghBV9T9T9jF9pCbHZ9I',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#4549,#4550,#4551,#3926,#1701));
#9202= IFCQUANTITYLENGTH('Width',$,$,50.0000000016671);
#9203= IFCELEMENTQUANTITY('07yBxkd1b598YmGS_F5M3O',#5,'BaseQuantities',$,$,(#9202));
#9204= IFCCARTESIANPOINT((49087.9874398733,-424.171267178093,-7724.99935244928));
#9205= IFCAXIS2PLACEMENT3D(#9204,#4556,#501);
#9206= IFCLOCALPLACEMENT(#9199,#9205);
#9207= IFCBOOLEANRESULT(.DIFFERENCE.,#4568,#4576);
#9208= IFCBOOLEANRESULT(.DIFFERENCE.,#9207,#4586);
#9209= IFCBOOLEANRESULT(.DIFFERENCE.,#9208,#4596);
#9210= IFCBOOLEANRESULT(.DIFFERENCE.,#9209,#4601);
#9211= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#9210));
#9212= IFCPRODUCTDEFINITIONSHAPE($,$,(#9211));
#9213= IFCPLATE('1Td1iR001HEp4rDp0rCJ4s',#5,'GROUT','PL50*315','PL50*315',#9206,#9212,'XX/0(?)');
#9214= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.00613664384520589),$);
#9215= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.00613664384520589),$);
#9216= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.160649009701353),$);
#9217= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(314.998016361844),$);
#9218= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(50.0000000024929),$);
#9219= IFCPROPERTYSET('38TOSwYZ9EH93RmI6DCr5H',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#9214,#4616,#9215,#4618,#1744,#4619,#9216,#9217,#9218,#4623));
#9220= IFCQUANTITYLENGTH('Width',$,$,314.998016361844);
#9221= IFCQUANTITYAREA('NetArea',$,$,0.351328721195872);
#9222= IFCQUANTITYAREA('GrossArea',$,$,0.160649009701353);
#9223= IFCQUANTITYVOLUME('NetVolume',$,$,0.00613664384520589);
#9224= IFCQUANTITYVOLUME('GrossVolume',$,$,0.00803244941708979);
#9225= IFCELEMENTQUANTITY('1zMj$xHtf8VgDk99Cy1zQs',#5,'BaseQuantities',$,$,(#9220,#9221,#9222,#4628,#9223,#9224));
#9226= IFCLOCALPLACEMENT(#30,#10);
#9227= IFCELEMENTASSEMBLY('1Td1iR001HFZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#9226,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#9228= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -7.665'),$);
#9229= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -7.661'),$);
#9230= IFCPROPERTYSET('08WNcD3frAPwUQHOfEXe9n',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#9228,#9229,#1775,#3926,#1701));
#9231= IFCCARTESIANPOINT((48722.9876821691,-581.666084923669,-7661.00372056646));
#9232= IFCDIRECTION((0.,-0.999999999537981,3.03979999858329E-005));
#9233= IFCDIRECTION((0.,-3.03979999964479E-005,-0.999999999537981));
#9234= IFCAXIS2PLACEMENT3D(#9231,#9232,#9233);
#9235= IFCLOCALPLACEMENT(#9226,#9234);
#9236= IFCEXTRUDEDAREASOLID(#1783,#1785,#9,4.00000000137878);
#9237= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9236));
#9238= IFCSTYLEDITEM(#9236,(#1711),$);
#9239= IFCPRODUCTDEFINITIONSHAPE($,$,(#9237));
#9240= IFCBEAM('1Td1iR001HFp4rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#9235,#9239,'XX/0(?)');
#9241= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -7.665'),$);
#9242= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -7.661'),$);
#9243= IFCPROPERTYSET('3bra6XsBHDnBMLhpiSLHSe',#5,'Tekla Common','Common Properties to Shared building elements',(#9241,#9242,#1730,#1731,#74,#75,#919,#1194,#1732,#1794,#1795));
#9244= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.000983250000000076),$);
#9245= IFCPROPERTYSET('33ELERHBf0CwmqvJF0d_Gt',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#8306,#8307,#8308,#9244,#1744,#8310,#8311,#1979,#1803,#8313));
#9246= IFCQUANTITYLENGTH('Length',$,$,4.0000000013797);
#9247= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00180062582344505);
#9248= IFCQUANTITYVOLUME('NetVolume',$,$,3.93300000135586E-006);
#9249= IFCELEMENTQUANTITY('3j2byf4993RR38MwnNGsys',#5,'BaseQuantities',$,$,(#9246,#9247,#9248,#1754));
#9250= IFCLOCALPLACEMENT(#30,#10);
#9251= IFCELEMENTASSEMBLY('1Td1iR001HGZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#9250,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#9252= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -7.716'),$);
#9253= IFCPROPERTYSET('0y9s11I69A5OcXH5_jU9pL',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#9252,#4550,#137,#3926,#1701));
#9254= IFCCARTESIANPOINT((48722.9876821692,-581.663084923669,-7700.00372056646));
#9255= IFCDIRECTION((0.,-0.999999999971128,7.5989999993533E-006));
#9256= IFCDIRECTION((0.,-7.59899999991379E-006,-0.999999999971128));
#9257= IFCAXIS2PLACEMENT3D(#9254,#9255,#9256);
#9258= IFCLOCALPLACEMENT(#9250,#9257);
#9259= IFCEXTRUDEDAREASOLID(#1719,#1721,#9,15.9999999999999);
#9260= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#9261= IFCSTYLEDITEM(#9259,(#1711),$);
#9262= IFCPRODUCTDEFINITIONSHAPE($,$,(#9260));
#9263= IFCBEAM('1Td1iR001HGp4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#9258,#9262,'XX/0(?)');
#9264= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -7.716'),$);
#9265= IFCPROPERTYSET('1YqGuRENbAaewsRXNaWGjo',#5,'Tekla Common','Common Properties to Shared building elements',(#9264,#4609,#1730,#1731,#74,#75,#919,#1194,#1732,#1733,#1734));
#9266= IFCPROPERTYSET('1hX0zu4FHASepqmntrdShn',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#1740,#1741,#1742,#8339,#1744,#1745,#1746,#1747,#1748,#8341));
#9267= IFCQUANTITYLENGTH('Length',$,$,15.9999999999964);
#9268= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161450207774);
#9269= IFCQUANTITYVOLUME('NetVolume',$,$,1.24707658144931E-005);
#9270= IFCELEMENTQUANTITY('1XUie3n6fEhuGgWVycs6wX',#5,'BaseQuantities',$,$,(#9267,#9268,#9269,#1754));
#9271= IFCLOCALPLACEMENT(#30,#10);
#9272= IFCELEMENTASSEMBLY('1Td1iR001HHZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#9271,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#9273= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -7.645'),$);
#9274= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -7.629'),$);
#9275= IFCPROPERTYSET('3BE3IVZ3171BY_wds4v84f',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#9273,#9274,#137,#3926,#1701));
#9276= IFCCARTESIANPOINT((48722.9876821691,-581.666084923669,-7629.00372056646));
#9277= IFCAXIS2PLACEMENT3D(#9276,#9255,#9256);
#9278= IFCLOCALPLACEMENT(#9271,#9277);
#9279= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#9280= IFCPRODUCTDEFINITIONSHAPE($,$,(#9279));
#9281= IFCBEAM('1Td1iR001HHp4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#9278,#9280,'XX/0(?)');
#9282= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -7.645'),$);
#9283= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -7.629'),$);
#9284= IFCPROPERTYSET('0AmKDdMVzEcwTwPDE8GNrp',#5,'Tekla Common','Common Properties to Shared building elements',(#9282,#9283,#1730,#1731,#74,#75,#919,#1194,#1732,#1733,#1734));
#9285= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161450207771);
#9286= IFCQUANTITYVOLUME('NetVolume',$,$,1.2470765814493E-005);
#9287= IFCELEMENTQUANTITY('2IRdUlLQ5BjBi1GXnqzIyv',#5,'BaseQuantities',$,$,(#9267,#9285,#9286,#1754));
#9288= IFCLOCALPLACEMENT(#30,#10);
#9289= IFCELEMENTASSEMBLY('1Td1iR001HIZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#9288,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#9290= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -7.661'),$);
#9291= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -7.645'),$);
#9292= IFCPROPERTYSET('3f3ysenDX4ivKj793Mtb55',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#9290,#9291,#137,#3926,#1701));
#9293= IFCCARTESIANPOINT((48722.9876821691,-581.666084923669,-7645.00372056646));
#9294= IFCAXIS2PLACEMENT3D(#9293,#9255,#9256);
#9295= IFCLOCALPLACEMENT(#9288,#9294);
#9296= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#9297= IFCPRODUCTDEFINITIONSHAPE($,$,(#9296));
#9298= IFCBEAM('1Td1iR001HIp4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#9295,#9297,'XX/0(?)');
#9299= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -7.661'),$);
#9300= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -7.645'),$);
#9301= IFCPROPERTYSET('0VtOB9QUD1GAMkgyhh$hgI',#5,'Tekla Common','Common Properties to Shared building elements',(#9299,#9300,#1730,#1731,#74,#75,#919,#1194,#1732,#1733,#1734));
#9302= IFCLOCALPLACEMENT(#30,#10);
#9303= IFCELEMENTASSEMBLY('1Td1iR001HJZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#9302,$,'R/1(?)',.NOTDEFINED.,.RIGID_FRAME.);
#9304= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -7.955'),$);
#9305= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -7.615'),$);
#9306= IFCPROPERTYSET('3aASzg4Jv61hq$jLjwD0Rm',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#9304,#9305,#137,#3926,#8391));
#9307= IFCCARTESIANPOINT((48722.9876821691,-581.666101583531,-7615.0040758817));
#9308= IFCAXIS2PLACEMENT3D(#9307,#501,#596);
#9309= IFCLOCALPLACEMENT(#9302,#9308);
#9310= IFCEXTRUDEDAREASOLID(#1826,#8400,#9,340.000057220459);
#9311= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9310));
#9312= IFCSTYLEDITEM(#9310,(#1825),$);
#9313= IFCPRODUCTDEFINITIONSHAPE($,$,(#9311));
#9314= IFCBEAM('1Td1iR001HJp4rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#9309,#9313,'P/487(?)');
#9315= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -7.955'),$);
#9316= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -7.615'),$);
#9317= IFCPROPERTYSET('22abWhtrv2HAYkUrcsO$aW',#5,'Tekla Common','Common Properties to Shared building elements',(#9315,#9316,#8408,#8409,#74,#75,#919,#515,#1838,#1839,#1840));
#9318= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(9.61665384257434E-005),$);
#9319= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(9.61665384257434E-005),$);
#9320= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(9.61665384257434E-005),$);
#9321= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0213836676491797),$);
#9322= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0213836676491797),$);
#9323= IFCPROPERTYSET('24mB0_QPX1nA4WPWyqGdAC',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#9318,#9319,#9320,#8414,#1744,#9321,#9322,#1847,#1848,#8417));
#9324= IFCQUANTITYLENGTH('Length',$,$,340.000057220459);
#9325= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0213836676491797);
#9326= IFCQUANTITYVOLUME('NetVolume',$,$,9.61665384257434E-005);
#9327= IFCELEMENTQUANTITY('3fg2koFVP4MfcrNCXDp2fI',#5,'BaseQuantities',$,$,(#9324,#9325,#9326,#1754));
#9328= IFCLOCALPLACEMENT(#30,#10);
#9329= IFCELEMENTASSEMBLY('1Td1iR001HKZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#9328,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#9330= IFCCARTESIANPOINT((48942.9876821691,-581.666088662929,-7661.00372056646));
#9331= IFCAXIS2PLACEMENT3D(#9330,#9232,#9233);
#9332= IFCLOCALPLACEMENT(#9328,#9331);
#9333= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9236));
#9334= IFCPRODUCTDEFINITIONSHAPE($,$,(#9333));
#9335= IFCBEAM('1Td1iR001HKp4rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#9332,#9334,'XX/0(?)');
#9336= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00180062582344505);
#9337= IFCQUANTITYVOLUME('NetVolume',$,$,3.9330000013559E-006);
#9338= IFCELEMENTQUANTITY('0Sbhi56mX8KP3SiP$43qaq',#5,'BaseQuantities',$,$,(#9246,#9336,#9337,#1754));
#9339= IFCLOCALPLACEMENT(#30,#10);
#9340= IFCELEMENTASSEMBLY('1Td1iR001HLZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#9339,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#9341= IFCCARTESIANPOINT((48942.9876821692,-581.663088662929,-7700.00372056646));
#9342= IFCAXIS2PLACEMENT3D(#9341,#9255,#9256);
#9343= IFCLOCALPLACEMENT(#9339,#9342);
#9344= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#9345= IFCPRODUCTDEFINITIONSHAPE($,$,(#9344));
#9346= IFCBEAM('1Td1iR001HLp4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#9343,#9345,'XX/0(?)');
#9347= IFCLOCALPLACEMENT(#30,#10);
#9348= IFCELEMENTASSEMBLY('1Td1iR001HMZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#9347,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#9349= IFCCARTESIANPOINT((48942.9876821691,-581.666088662929,-7629.00372056646));
#9350= IFCAXIS2PLACEMENT3D(#9349,#9255,#9256);
#9351= IFCLOCALPLACEMENT(#9347,#9350);
#9352= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#9353= IFCPRODUCTDEFINITIONSHAPE($,$,(#9352));
#9354= IFCBEAM('1Td1iR001HMp4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#9351,#9353,'XX/0(?)');
#9355= IFCLOCALPLACEMENT(#30,#10);
#9356= IFCELEMENTASSEMBLY('1Td1iR001HNZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#9355,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#9357= IFCCARTESIANPOINT((48942.9876821691,-581.666088662929,-7645.00372056646));
#9358= IFCAXIS2PLACEMENT3D(#9357,#9255,#9256);
#9359= IFCLOCALPLACEMENT(#9355,#9358);
#9360= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#9361= IFCPRODUCTDEFINITIONSHAPE($,$,(#9360));
#9362= IFCBEAM('1Td1iR001HNp4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#9359,#9361,'XX/0(?)');
#9363= IFCLOCALPLACEMENT(#30,#10);
#9364= IFCELEMENTASSEMBLY('1Td1iR001HOZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#9363,$,'R/1(?)',.NOTDEFINED.,.RIGID_FRAME.);
#9365= IFCCARTESIANPOINT((48942.9876821691,-581.666105322791,-7615.0040758817));
#9366= IFCAXIS2PLACEMENT3D(#9365,#501,#596);
#9367= IFCLOCALPLACEMENT(#9363,#9366);
#9368= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9310));
#9369= IFCPRODUCTDEFINITIONSHAPE($,$,(#9368));
#9370= IFCBEAM('1Td1iR001HOp4rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#9367,#9369,'P/487(?)');
#9371= IFCCARTESIANPOINT((48832.9876841242,-474.170105357643,-7690.00389468441));
#9372= IFCAXIS2PLACEMENT3D(#9371,#185,#501);
#9373= IFCLOCALPLACEMENT(#9098,#9372);
#9374= IFCRECTANGLEPROFILEDEF(.AREA.,'PLT20*410',#197,20.,410.);
#9375= IFCEXTRUDEDAREASOLID(#9374,#8647,#9,214.996968697051);
#9376= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9375));
#9377= IFCSTYLEDITEM(#9375,(#53),$);
#9378= IFCPRODUCTDEFINITIONSHAPE($,$,(#9376));
#9379= IFCBEAM('1Td1iR001HPZ4rDp0rCJ4s',#5,'ANKRAJ','PLT20*410','PLT20*410',#9373,#9378,'P/380(?)');
#9380= IFCBEAMTYPE('0w3BEzlgvCdvD7xP2YK2fJ',#5,'PLT20*410',$,$,$,$,$,$,.NOTDEFINED.);
#9381= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -7.700'),$);
#9382= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -7.680'),$);
#9383= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PLT20*410'),$);
#9384= IFCPROPERTYSET('1auUZ$cZv5wB8HddY9Apvd',#5,'Tekla Common','Common Properties to Shared building elements',(#9381,#9382,#8655,#73,#74,#75,#919,#1194,#78,#9383,#80));
#9385= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(13.8393548750313),$);
#9386= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(13.8393548751181),$);
#9387= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(13.8393548750313),$);
#9388= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.00176297514331608),$);
#9389= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.00176297514331608),$);
#9390= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.00176297514331608),$);
#9391= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.088148757165791),$);
#9392= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(14.5452873271316),$);
#9393= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.201297393079469),$);
#9394= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.201297393079469),$);
#9395= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(410.),$);
#9396= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(214.996968698433),$);
#9397= IFCPROPERTYSET('1YC4XdTm15HwiO3KdrZX1h',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#9122,#9385,#9386,#9387,#9388,#9389,#9390,#9391,#9392,#9393,#9394,#9395,#5269,#9396));
#9398= IFCQUANTITYLENGTH('Length',$,$,214.996968698433);
#9399= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.201297393079469);
#9400= IFCQUANTITYVOLUME('NetVolume',$,$,0.00176297514331608);
#9401= IFCQUANTITYWEIGHT('NetWeight',$,$,13.8393548750313);
#9402= IFCELEMENTQUANTITY('1eR2qY$Dv2kQDId2YyVhA5',#5,'BaseQuantities',$,$,(#9398,#9399,#9400,#9401));
#9403= IFCCARTESIANPOINT((48738.8552596716,1455.00264361321,-1314.99568023915));
#9404= IFCAXIS2PLACEMENT3D(#9403,#8138,#8139);
#9405= IFCLOCALPLACEMENT(#30,#9404);
#9406= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#9407= IFCEXTRUDEDAREASOLID(#9406,#2479,#9,15.1000000000031);
#9408= IFCSTYLEDITEM(#9407,(#195),$);
#9409= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9407));
#9410= IFCREPRESENTATIONMAP(#10,#9409);
#9411= IFCMAPPEDITEM(#9410,#247);
#9412= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#9411));
#9413= IFCPRODUCTDEFINITIONSHAPE($,$,(#9412));
#9414= IFCMECHANICALFASTENER('1Td1iR001HUJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#9405,#9413,'ID5d9c1b1b-0000-5179-3135-373035313136',20.,15.);
#9415= IFCCARTESIANPOINT((48738.8554620718,1675.00264346438,-1315.00376829561));
#9416= IFCAXIS2PLACEMENT3D(#9415,#8156,#8157);
#9417= IFCLOCALPLACEMENT(#30,#9416);
#9418= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#9419= IFCEXTRUDEDAREASOLID(#9418,#2479,#9,15.1000000000031);
#9420= IFCSTYLEDITEM(#9419,(#195),$);
#9421= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9419));
#9422= IFCREPRESENTATIONMAP(#10,#9421);
#9423= IFCMAPPEDITEM(#9422,#247);
#9424= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#9423));
#9425= IFCPRODUCTDEFINITIONSHAPE($,$,(#9424));
#9426= IFCMECHANICALFASTENER('1Td1iR001HV34rDp0rCJ4s',#5,'Bolt assembly',$,$,#9417,#9425,'ID5d9c1b1b-0000-517c-3135-373035313136',20.,15.);
#9427= IFCCARTESIANPOINT((48738.8522183136,1455.00209215763,-1329.9956802207));
#9428= IFCAXIS2PLACEMENT3D(#9427,#8156,#8157);
#9429= IFCLOCALPLACEMENT(#30,#9428);
#9430= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,29.);
#9431= IFCEXTRUDEDAREASOLID(#9430,#2479,#9,20.1000000000163);
#9432= IFCSTYLEDITEM(#9431,(#195),$);
#9433= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9431));
#9434= IFCREPRESENTATIONMAP(#10,#9433);
#9435= IFCMAPPEDITEM(#9434,#247);
#9436= IFCMAPPEDITEM(#9434,#9057);
#9437= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#9435,#9436));
#9438= IFCPRODUCTDEFINITIONSHAPE($,$,(#9437));
#9439= IFCMECHANICALFASTENER('1Td1iR001HVp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#9429,#9438,'ID5d9c1b1b-0000-517f-3135-373035313136',30.,20.);
#9440= IFCLOCALPLACEMENT(#30,#10);
#9441= IFCELEMENTASSEMBLY('1Td1iR002igJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#9440,$,'C/18(?)',.NOTDEFINED.,.RIGID_FRAME.);
#9442= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(368.227684146375),$);
#9443= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('C/18(?)'),$);
#9444= IFCPROPERTYSET('3wgJWwiGnFiQ3TNZrVESSH',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#9442,#8236,#3924,#3925,#2857,#9443));
#9445= IFCQUANTITYLENGTH('Width',$,$,410.002761806031);
#9446= IFCELEMENTQUANTITY('313dShoZz68xELGZuAwhq2',#5,'BaseQuantities',$,$,(#9445));
#9447= IFCCARTESIANPOINT((48688.8552389928,1455.00241388917,-1322.49554237568));
#9448= IFCAXIS2PLACEMENT3D(#9447,#8157,#8138);
#9449= IFCLOCALPLACEMENT(#9440,#9448);
#9450= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8183));
#9451= IFCPRODUCTDEFINITIONSHAPE($,$,(#9450));
#9452= IFCDISCRETEACCESSORY('1Td1iR001HWZ4rDp0rCJ4s',#5,'ANKRAJ','PLT15*100','PLT15*100',#9449,#9451,'P/484(?)');
#9453= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('C/18(?)'),$);
#9454= IFCPROPERTYSET('0FQnZ5mub1ZQiAE1O5f67S',#5,'Tekla Common','Common Properties to Shared building elements',(#8189,#8190,#8191,#9453,#74,#75,#76,#1194,#78,#8192,#80));
#9455= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(368.227684146375),$);
#9456= IFCPROPERTYSET('0LoSox12PCrAGd2Re1oWFK',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#9455,#8195,#8196,#8197,#8198,#8199,#8200,#8201,#8226,#9089,#9090,#8205,#8206,#8207));
#9457= IFCQUANTITYLENGTH('Length',$,$,99.9999999996653);
#9458= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.025999999999921);
#9459= IFCQUANTITYVOLUME('NetVolume',$,$,0.000149999999999483);
#9460= IFCQUANTITYWEIGHT('NetWeight',$,$,1.17749999999594);
#9461= IFCELEMENTQUANTITY('0DupmAn2TBsvEY5cys7Y5a',#5,'BaseQuantities',$,$,(#9457,#9458,#9459,#9460));
#9462= IFCCARTESIANPOINT((48633.8565750792,1360.00770343543,-1179.99128474671));
#9463= IFCAXIS2PLACEMENT3D(#9462,#8546,#8157);
#9464= IFCLOCALPLACEMENT(#9440,#9463);
#9465= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9115));
#9466= IFCPRODUCTDEFINITIONSHAPE($,$,(#9465));
#9467= IFCDISCRETEACCESSORY('1Td1iR001HXJ4rDp0rCJ4s',#5,'DETAY','PL10*150','PL10*150',#9464,#9466,'P/222(?)');
#9468= IFCPROPERTYSET('3P6D2WHVH7ZAYbLUEt50rh',#5,'Tekla Common','Common Properties to Shared building elements',(#8189,#8260,#8562,#9453,#74,#75,#76,#77,#78,#8263,#921));
#9469= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(4.04277959651249),$);
#9470= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(4.04277959651249),$);
#9471= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000515003770256368),$);
#9472= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000515003770256368),$);
#9473= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000515003770256368),$);
#9474= IFCPROPERTYSET('20CTLxQv99vOoDvR8L4sej',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#9455,#9469,#9124,#9470,#9471,#9472,#9473,#9129,#9130,#9131,#9132,#8574,#8277,#9135));
#9475= IFCQUANTITYLENGTH('Width',$,$,150.001007080184);
#9476= IFCQUANTITYAREA('NetArea',$,$,0.113029194278969);
#9477= IFCQUANTITYAREA('GrossArea',$,$,0.0615003650668385);
#9478= IFCQUANTITYVOLUME('NetVolume',$,$,0.000515003770256368);
#9479= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000515003770256368);
#9480= IFCELEMENTQUANTITY('3fHJyKTA132POhD87l3RDF',#5,'BaseQuantities',$,$,(#9475,#9476,#9477,#8283,#9478,#9479));
#9481= IFCCARTESIANPOINT((48828.8525750783,1360.00752401911,-1179.99182238336));
#9482= IFCAXIS2PLACEMENT3D(#9481,#8584,#8585);
#9483= IFCLOCALPLACEMENT(#9440,#9482);
#9484= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8255));
#9485= IFCPRODUCTDEFINITIONSHAPE($,$,(#9484));
#9486= IFCDISCRETEACCESSORY('1Td1iR001HY34rDp0rCJ4s',#5,'DETAY','PL10*150','PL10*150',#9483,#9485,'P/240(?)');
#9487= IFCPROPERTYSET('1Q4HbLCovD6eeOfCzqzax_',#5,'Tekla Common','Common Properties to Shared building elements',(#8189,#8260,#8261,#9453,#74,#75,#76,#77,#78,#8263,#921));
#9488= IFCPROPERTYSET('29xyDwaF55UwofTI8giDWY',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#9455,#9152,#8592,#9154,#9155,#9156,#9157,#8597,#8273,#9159,#8599,#8276,#8277,#8600));
#9489= IFCQUANTITYLENGTH('Width',$,$,150.001007080115);
#9490= IFCQUANTITYAREA('NetArea',$,$,0.0404157363385643);
#9491= IFCQUANTITYAREA('GrossArea',$,$,0.0225007028996455);
#9492= IFCQUANTITYVOLUME('NetVolume',$,$,0.000175007148586483);
#9493= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000175007148586483);
#9494= IFCELEMENTQUANTITY('2Kw5CuyeXAnQghMYoch3nV',#5,'BaseQuantities',$,$,(#9489,#9490,#9491,#8283,#9492,#9493));
#9495= IFCCARTESIANPOINT((48688.8554413931,1675.00241374034,-1322.50363043214));
#9496= IFCAXIS2PLACEMENT3D(#9495,#8139,#8138);
#9497= IFCLOCALPLACEMENT(#9440,#9496);
#9498= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8221));
#9499= IFCPRODUCTDEFINITIONSHAPE($,$,(#9498));
#9500= IFCDISCRETEACCESSORY('1Td1iR001HYp4rDp0rCJ4s',#5,'ANKRAJ','PLT15*100','PLT15*100',#9497,#9499,'P/484(?)');
#9501= IFCPROPERTYSET('1T7$PKKMH1N88lLAHzVA1H',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#9455,#8195,#8196,#8197,#8198,#8199,#8200,#8201,#8226,#8203,#8204,#8205,#8206,#8207));
#9502= IFCQUANTITYLENGTH('Length',$,$,99.999999999658);
#9503= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0259999999999194);
#9504= IFCQUANTITYVOLUME('NetVolume',$,$,0.000149999999999472);
#9505= IFCQUANTITYWEIGHT('NetWeight',$,$,1.17749999999586);
#9506= IFCELEMENTQUANTITY('2xmoPnJOH00wnF1eq0AtCh',#5,'BaseQuantities',$,$,(#9502,#9503,#9504,#9505));
#9507= IFCCARTESIANPOINT((48828.8529522788,1770.00752374081,-1180.00689557948));
#9508= IFCAXIS2PLACEMENT3D(#9507,#8242,#8243);
#9509= IFCLOCALPLACEMENT(#9440,#9508);
#9510= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8255));
#9511= IFCPRODUCTDEFINITIONSHAPE($,$,(#9510));
#9512= IFCDISCRETEACCESSORY('1Td1iR001HZZ4rDp0rCJ4s',#5,'DETAY','PL10*150','PL10*150',#9509,#9511,'P/240(?)');
#9513= IFCPROPERTYSET('3dE$Q9vVf3DP3MMnti2ydP',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#9455,#8591,#8592,#8593,#8594,#8595,#8596,#8272,#8273,#8598,#8599,#8276,#8277,#8600));
#9514= IFCQUANTITYLENGTH('Width',$,$,150.001007080107);
#9515= IFCQUANTITYAREA('NetArea',$,$,0.0404157363385526);
#9516= IFCQUANTITYAREA('GrossArea',$,$,0.0225007028996466);
#9517= IFCQUANTITYVOLUME('NetVolume',$,$,0.000175007148586044);
#9518= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000175007148586044);
#9519= IFCELEMENTQUANTITY('35XkiflCXDev8jEs5XAHBc',#5,'BaseQuantities',$,$,(#9514,#9515,#9516,#8283,#9517,#9518));
#9520= IFCLOCALPLACEMENT(#30,#10);
#9521= IFCELEMENTASSEMBLY('1Td1iR001HdJ4rDp0rCJ4s',#5,'GROUT',$,$,#9520,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#9522= IFCQUANTITYLENGTH('Width',$,$,50.0000000447756);
#9523= IFCELEMENTQUANTITY('3yfaOSUFH4rfZxLOlssRlj',#5,'BaseQuantities',$,$,(#9522));
#9524= IFCCARTESIANPOINT((48573.8566139441,1820.00034442149,-1375.00399653026));
#9525= IFCDIRECTION((-2.757024801989E-006,-2.69599974535542E-005,-0.999999999632779));
#9526= IFCAXIS2PLACEMENT3D(#9524,#9525,#8138);
#9527= IFCLOCALPLACEMENT(#9520,#9526);
#9528= IFCBOOLEANRESULT(.DIFFERENCE.,#4568,#4576);
#9529= IFCBOOLEANRESULT(.DIFFERENCE.,#9528,#4586);
#9530= IFCBOOLEANRESULT(.DIFFERENCE.,#9529,#4596);
#9531= IFCBOOLEANRESULT(.DIFFERENCE.,#9530,#4601);
#9532= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#9531));
#9533= IFCPRODUCTDEFINITIONSHAPE($,$,(#9532));
#9534= IFCPLATE('1Td1iR001HdZ4rDp0rCJ4s',#5,'GROUT','PL50*315','PL50*315',#9527,#9533,'XX/0(?)');
#9535= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.00613632104494309),$);
#9536= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.00803244941708986),$);
#9537= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.00613632104494309),$);
#9538= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.0881500626750131),$);
#9539= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.351326342295792),$);
#9540= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.160649031151445),$);
#9541= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(314.998016524012),$);
#9542= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(50.0000000447301),$);
#9543= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(510.000135633232),$);
#9544= IFCPROPERTYSET('07_7Vq_8P8rh$biBNLwxXB',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#9535,#9536,#9537,#9538,#1744,#9539,#9540,#9541,#9542,#9543));
#9545= IFCQUANTITYLENGTH('Width',$,$,314.998016524012);
#9546= IFCQUANTITYAREA('NetArea',$,$,0.351326342295792);
#9547= IFCQUANTITYAREA('GrossArea',$,$,0.160649031151445);
#9548= IFCQUANTITYVOLUME('NetVolume',$,$,0.00613632104494309);
#9549= IFCQUANTITYVOLUME('GrossVolume',$,$,0.00803244941708985);
#9550= IFCELEMENTQUANTITY('1PUQAi3dPF9eSijU0eGTNg',#5,'BaseQuantities',$,$,(#9545,#9546,#9547,#4628,#9548,#9549));
#9551= IFCLOCALPLACEMENT(#30,#10);
#9552= IFCELEMENTASSEMBLY('1Td1iR001HeJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#9551,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#9553= IFCCARTESIANPOINT((48738.8552785413,1455.00279067903,-1310.99540080836));
#9554= IFCAXIS2PLACEMENT3D(#9553,#8139,#8295);
#9555= IFCLOCALPLACEMENT(#9551,#9554);
#9556= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8298));
#9557= IFCPRODUCTDEFINITIONSHAPE($,$,(#9556));
#9558= IFCBEAM('1Td1iR001HeZ4rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#9555,#9557,'XX/0(?)');
#9559= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.000983250000000077),$);
#9560= IFCPROPERTYSET('0P5eTVn2b8_QcLbH9_BvSK',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#8306,#8307,#8308,#9559,#1744,#8310,#8311,#1979,#8312,#8313));
#9561= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00180062582345095);
#9562= IFCQUANTITYVOLUME('NetVolume',$,$,3.93300000137252E-006);
#9563= IFCELEMENTQUANTITY('0gv9dE9sf8DBor9rmHfegG',#5,'BaseQuantities',$,$,(#8315,#9561,#9562,#1754));
#9564= IFCLOCALPLACEMENT(#30,#10);
#9565= IFCELEMENTASSEMBLY('1Td1iR001HfJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#9564,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#9566= IFCCARTESIANPOINT((48738.8521710105,1455.0013568901,-1349.99540077361));
#9567= IFCAXIS2PLACEMENT3D(#9566,#8327,#8328);
#9568= IFCLOCALPLACEMENT(#9564,#9567);
#9569= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8331));
#9570= IFCPRODUCTDEFINITIONSHAPE($,$,(#9569));
#9571= IFCBEAM('1Td1iR001HfZ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#9568,#9570,'XX/0(?)');
#9572= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161450207248);
#9573= IFCQUANTITYVOLUME('NetVolume',$,$,1.24707658144687E-005);
#9574= IFCELEMENTQUANTITY('1YWFIKOOD7mAjRUv5gzsQu',#5,'BaseQuantities',$,$,(#8755,#9572,#9573,#1754));
#9575= IFCLOCALPLACEMENT(#30,#10);
#9576= IFCELEMENTASSEMBLY('1Td1iR001HgJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#9575,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#9577= IFCCARTESIANPOINT((48738.8553667717,1455.0039671235,-1278.99540083009));
#9578= IFCAXIS2PLACEMENT3D(#9577,#8327,#8328);
#9579= IFCLOCALPLACEMENT(#9575,#9578);
#9580= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8357));
#9581= IFCPRODUCTDEFINITIONSHAPE($,$,(#9580));
#9582= IFCBEAM('1Td1iR001HgZ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#9579,#9581,'XX/0(?)');
#9583= IFCQUANTITYVOLUME('NetVolume',$,$,1.2470765814468E-005);
#9584= IFCELEMENTQUANTITY('2R_E1Dp2r0M903a4E2T7Cl',#5,'BaseQuantities',$,$,(#8365,#8366,#9583,#1754));
#9585= IFCLOCALPLACEMENT(#30,#10);
#9586= IFCELEMENTASSEMBLY('1Td1iR001HhJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#9585,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#9587= IFCCARTESIANPOINT((48738.8553226565,1455.00337890127,-1294.99540081922));
#9588= IFCAXIS2PLACEMENT3D(#9587,#8327,#8328);
#9589= IFCLOCALPLACEMENT(#9585,#9588);
#9590= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8357));
#9591= IFCPRODUCTDEFINITIONSHAPE($,$,(#9590));
#9592= IFCBEAM('1Td1iR001HhZ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#9589,#9591,'XX/0(?)');
#9593= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161450207239);
#9594= IFCQUANTITYVOLUME('NetVolume',$,$,1.24707658144679E-005);
#9595= IFCELEMENTQUANTITY('3sOzDt40XFE8X062Rwgx_L',#5,'BaseQuantities',$,$,(#8365,#9593,#9594,#1754));
#9596= IFCLOCALPLACEMENT(#30,#10);
#9597= IFCELEMENTASSEMBLY('1Td1iR001HiJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#9596,$,'R/1(?)',.NOTDEFINED.,.RIGID_FRAME.);
#9598= IFCCARTESIANPOINT((48738.8554220314,1455.00448180489,-1264.99575615487));
#9599= IFCAXIS2PLACEMENT3D(#9598,#8138,#8396);
#9600= IFCLOCALPLACEMENT(#9596,#9599);
#9601= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8401));
#9602= IFCPRODUCTDEFINITIONSHAPE($,$,(#9601));
#9603= IFCBEAM('1Td1iR001HiZ4rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#9600,#9602,'P/487(?)');
#9604= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0213836676491557);
#9605= IFCQUANTITYVOLUME('NetVolume',$,$,9.61665384254827E-005);
#9606= IFCELEMENTQUANTITY('334kWH0093HO_afIA60dCV',#5,'BaseQuantities',$,$,(#8419,#9604,#9605,#1754));
#9607= IFCLOCALPLACEMENT(#30,#10);
#9608= IFCELEMENTASSEMBLY('1Td1iR001HjJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#9607,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#9609= IFCCARTESIANPOINT((48738.8554809416,1675.0027905302,-1311.00348886481));
#9610= IFCAXIS2PLACEMENT3D(#9609,#8139,#8295);
#9611= IFCLOCALPLACEMENT(#9607,#9610);
#9612= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8298));
#9613= IFCPRODUCTDEFINITIONSHAPE($,$,(#9612));
#9614= IFCBEAM('1Td1iR001HjZ4rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#9611,#9613,'XX/0(?)');
#9615= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.00180062582345096),$);
#9616= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.00180062582345096),$);
#9617= IFCPROPERTYSET('2i5dg2hPz4fBk6yIw3zTl8',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#8306,#8307,#8308,#9559,#1744,#9615,#9616,#1979,#8312,#8433));
#9618= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00180062582345096);
#9619= IFCQUANTITYVOLUME('NetVolume',$,$,3.93300000137263E-006);
#9620= IFCELEMENTQUANTITY('01jZYro5bE8fgXNnx0Irrx',#5,'BaseQuantities',$,$,(#8435,#9618,#9619,#1754));
#9621= IFCLOCALPLACEMENT(#30,#10);
#9622= IFCELEMENTASSEMBLY('1Td1iR001HkJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#9621,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#9623= IFCCARTESIANPOINT((48738.8523734108,1675.00135674126,-1350.00348883006));
#9624= IFCAXIS2PLACEMENT3D(#9623,#8327,#8328);
#9625= IFCLOCALPLACEMENT(#9621,#9624);
#9626= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8331));
#9627= IFCPRODUCTDEFINITIONSHAPE($,$,(#9626));
#9628= IFCBEAM('1Td1iR001HkZ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#9625,#9627,'XX/0(?)');
#9629= IFCQUANTITYLENGTH('Length',$,$,16.0000000001044);
#9630= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161450207276);
#9631= IFCQUANTITYVOLUME('NetVolume',$,$,1.24707658144702E-005);
#9632= IFCELEMENTQUANTITY('1QRPWasAb8VfVi9hpWJktu',#5,'BaseQuantities',$,$,(#9629,#9630,#9631,#1754));
#9633= IFCLOCALPLACEMENT(#30,#10);
#9634= IFCELEMENTASSEMBLY('1Td1iR001HlJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#9633,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#9635= IFCCARTESIANPOINT((48738.855569172,1675.00396697467,-1279.00348888654));
#9636= IFCAXIS2PLACEMENT3D(#9635,#8327,#8328);
#9637= IFCLOCALPLACEMENT(#9633,#9636);
#9638= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8357));
#9639= IFCPRODUCTDEFINITIONSHAPE($,$,(#9638));
#9640= IFCBEAM('1Td1iR001HlZ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#9637,#9639,'XX/0(?)');
#9641= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161450207269);
#9642= IFCQUANTITYVOLUME('NetVolume',$,$,1.24707658144696E-005);
#9643= IFCELEMENTQUANTITY('2dDPiTblHC1wS0FiOoM1nZ',#5,'BaseQuantities',$,$,(#8383,#9641,#9642,#1754));
#9644= IFCLOCALPLACEMENT(#30,#10);
#9645= IFCELEMENTASSEMBLY('1Td1iR001HmJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#9644,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#9646= IFCCARTESIANPOINT((48738.8555250568,1675.00337875244,-1295.00348887568));
#9647= IFCAXIS2PLACEMENT3D(#9646,#8327,#8328);
#9648= IFCLOCALPLACEMENT(#9644,#9647);
#9649= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8357));
#9650= IFCPRODUCTDEFINITIONSHAPE($,$,(#9649));
#9651= IFCBEAM('1Td1iR001HmZ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#9648,#9650,'XX/0(?)');
#9652= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.00322161450207268);
#9653= IFCQUANTITYVOLUME('NetVolume',$,$,1.24707658144695E-005);
#9654= IFCELEMENTQUANTITY('006iK56Af4jQdl61wDYkcu',#5,'BaseQuantities',$,$,(#8383,#9652,#9653,#1754));
#9655= IFCLOCALPLACEMENT(#30,#10);
#9656= IFCELEMENTASSEMBLY('1Td1iR001HnJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#9655,$,'R/1(?)',.NOTDEFINED.,.RIGID_FRAME.);
#9657= IFCCARTESIANPOINT((48738.8556244317,1675.00448165605,-1265.00384421133));
#9658= IFCAXIS2PLACEMENT3D(#9657,#8138,#8396);
#9659= IFCLOCALPLACEMENT(#9655,#9658);
#9660= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8401));
#9661= IFCPRODUCTDEFINITIONSHAPE($,$,(#9660));
#9662= IFCBEAM('1Td1iR001HnZ4rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#9659,#9661,'P/487(?)');
#9663= IFCPROPERTYSET('1G1lZqr_TDgRjlMlJgPSUy',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#8486,#8487,#8488,#8414,#1744,#8490,#8491,#1847,#5269,#8417));
#9664= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0213836676491571);
#9665= IFCQUANTITYVOLUME('NetVolume',$,$,9.61665384254963E-005);
#9666= IFCELEMENTQUANTITY('1mVGoeraH8HfkgKGaA30SZ',#5,'BaseQuantities',$,$,(#8419,#9664,#9665,#1754));
#9667= IFCCARTESIANPOINT((48623.855318347,1565.0018302572,-1339.99930186062));
#9668= IFCAXIS2PLACEMENT3D(#9667,#8139,#8138);
#9669= IFCLOCALPLACEMENT(#9440,#9668);
#9670= IFCEXTRUDEDAREASOLID(#9374,#8647,#9,214.996968696965);
#9671= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9670));
#9672= IFCSTYLEDITEM(#9670,(#53),$);
#9673= IFCPRODUCTDEFINITIONSHAPE($,$,(#9671));
#9674= IFCDISCRETEACCESSORY('1Td1iR001HoJ4rDp0rCJ4s',#5,'ANKRAJ','PLT20*410','PLT20*410',#9669,#9673,'P/380(?)');
#9675= IFCPROPERTYSET('1WsCknG498zQo8TuZ0t7Zl',#5,'Tekla Common','Common Properties to Shared building elements',(#8653,#8654,#8655,#9453,#74,#75,#76,#1194,#78,#9383,#80));
#9676= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(14.5452873271348),$);
#9677= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(410.000000000678),$);
#9678= IFCPROPERTYSET('2rc1e$cMXEXfzVZ6LsYOUH',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#9455,#9385,#9386,#9387,#9388,#9389,#9390,#9391,#9676,#9393,#9394,#9677,#8669,#8670));
#9679= IFCQUANTITYLENGTH('Length',$,$,214.996968696651);
#9680= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.201297393079101);
#9681= IFCQUANTITYVOLUME('NetVolume',$,$,0.00176297514331248);
#9682= IFCQUANTITYWEIGHT('NetWeight',$,$,13.839354875003);
#9683= IFCELEMENTQUANTITY('3AzZqGxzvB$O5umRQ4H0ZS',#5,'BaseQuantities',$,$,(#9679,#9680,#9681,#9682));
#9684= IFCLOCALPLACEMENT(#30,#10);
#9685= IFCELEMENTASSEMBLY('1Td1iR001HrJ4rDp0rCJ4s',#5,'SLAB',$,$,#9684,$,'XX/126(?)',.NOTDEFINED.,.REINFORCEMENT_UNIT.);
#9686= IFCPROPERTYSINGLEVALUE('Cast unit vertical position code',$,IFCLABEL('-7.55--0.65'),$);
#9687= IFCPROPERTYSINGLEVALUE('Cast unit rebar weight',$,IFCMASSMEASURE(0.),$);
#9688= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(8242.52518605529),$);
#9689= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -2.000'),$);
#9690= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -1.400'),$);
#9691= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit name',$,IFCLABEL('SLAB'),$);
#9692= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit position code',$,IFCLABEL('6/N2-P1'),$);
#9693= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('XX/126(?)'),$);
#9694= IFCPROPERTYSET('022yts9Y51Th2COf6pzqaV',#5,'Tekla Assembly','Assembly Properties',(#9686,#9687,#9688,#9689,#9690,#9691,#9692,#9693));
#9695= IFCQUANTITYLENGTH('Width',$,$,21600.0000000012);
#9696= IFCELEMENTQUANTITY('0_f46Me8X6BR8zl0FaRIUp',#5,'BaseQuantities',$,$,(#9695));
#9697= IFCCARTESIANPOINT((48350.0092221272,10799.9968562015,-2000.00126614393));
#9698= IFCDIRECTION((0.999999999855313,-1.09999995584946E-008,1.70109999973268E-005));
#9699= IFCAXIS2PLACEMENT3D(#9697,#501,#9698);
#9700= IFCLOCALPLACEMENT(#9684,#9699);
#9701= IFCSURFACESTYLE('CONCRETE/C20/25',.POSITIVE.,(#5243));
#9702= IFCPRESENTATIONSTYLEASSIGNMENT((#9701));
#9703= IFCCARTESIANPOINT((264.999328611964,8.07176547823474E-011));
#9704= IFCCARTESIANPOINT((265.009887694527,599.99645996161));
#9705= IFCCARTESIANPOINT((0.0102688219267293,600.000854492556));
#9706= IFCPOLYLINE((#54,#9703,#9704,#9705,#54,#54));
#9707= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'21600*265',#9706);
#9708= IFCCARTESIANPOINT((6.11564353663717E-021,0.,-10800.));
#9709= IFCAXIS2PLACEMENT3D(#9708,#9,#7);
#9710= IFCEXTRUDEDAREASOLID(#9707,#9709,#9,21600.);
#9711= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9710));
#9712= IFCSTYLEDITEM(#9710,(#9702),$);
#9713= IFCPRODUCTDEFINITIONSHAPE($,$,(#9711));
#9714= IFCSLAB('1Td1iR001HrZ4rDp0rCJ4s',#5,'SLAB','21600*265','21600*265',#9700,#9713,'XX/126(?)',.FLOOR.);
#9715= IFCSLABTYPE('0b1Y8H$br5Bh$dFkkWemI0',#5,'21600*265',$,$,$,$,$,$,.NOTDEFINED.);
#9716= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -2.000'),$);
#9717= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -1.400'),$);
#9718= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('XX/126(?)'),$);
#9719= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('XX/126(?)'),$);
#9720= IFCPROPERTYSINGLEVALUE('Phase',$,IFCINTEGER(82),$);
#9721= IFCPROPERTYSINGLEVALUE('Class',$,IFCLABEL('11'),$);
#9722= IFCPROPERTYSINGLEVALUE('Grade',$,IFCLABEL('C20/25'),$);
#9723= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('21600*265'),$);
#9724= IFCPROPERTYSINGLEVALUE('Name',$,IFCLABEL('SLAB'),$);
#9725= IFCPROPERTYSET('1Zb4G9X$zDlR4api8jXqhS',#5,'Tekla Common','Common Properties to Shared building elements',(#9716,#9717,#9718,#9719,#74,#75,#9720,#9721,#9722,#9723,#9724));
#9726= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(8242.52518605529),$);
#9727= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(8242.52518605529),$);
#9728= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(8242.56182187369),$);
#9729= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(8242.52518605529),$);
#9730= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(3.4343854941897),$);
#9731= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(3.4343854941897),$);
#9732= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(3.4343854941897),$);
#9733= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(5.72399176846388),$);
#9734= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(4.57213257694725),$);
#9735= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(37.6859179194716),$);
#9736= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.159000035144168),$);
#9737= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(264.999618918424),$);
#9738= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(21600.0000000018),$);
#9739= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(600.000995447145),$);
#9740= IFCPROPERTYSET('2KKSQn14T2hOLnDP4Dr$Z1',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#9726,#9727,#9728,#9729,#9730,#9731,#9732,#9733,#9734,#9735,#9736,#9737,#9738,#9739));
#9741= IFCQUANTITYLENGTH('Width',$,$,21600.0000000018);
#9742= IFCQUANTITYVOLUME('NetVolume',$,$,3.4343854941897);
#9743= IFCQUANTITYAREA('NetArea',$,$,5.72399176846388);
#9744= IFCQUANTITYWEIGHT('NetWeight',$,$,8242.52518605529);
#9745= IFCELEMENTQUANTITY('37FZjuagv3UxfitZsQPZIW',#5,'BaseQuantities',$,$,(#9741,#9742,#9743,#9744));
#9746= IFCMATERIAL('CONCRETE/C20/25');
#9747= IFCCARTESIANPOINT((48715.6782258155,-565.430250853125,15799.9961559069));
#9748= IFCAXIS2PLACEMENT3D(#9747,#5695,#5696);
#9749= IFCLOCALPLACEMENT(#30,#9748);
#9750= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#9751= IFCEXTRUDEDAREASOLID(#9750,#5701,#9,16.0000000001209);
#9752= IFCSTYLEDITEM(#9751,(#195),$);
#9753= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#9754= IFCEXTRUDEDAREASOLID(#9753,#5706,#9,16.1000000000005);
#9755= IFCSTYLEDITEM(#9754,(#195),$);
#9756= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#9757= IFCEXTRUDEDAREASOLID(#9756,#5711,#9,6.5);
#9758= IFCSTYLEDITEM(#9757,(#191),$);
#9759= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#9760= IFCEXTRUDEDAREASOLID(#9759,#5716,#9,50.);
#9761= IFCSTYLEDITEM(#9760,(#191),$);
#9762= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#9763= IFCEXTRUDEDAREASOLID(#9762,#5721,#9,2.5);
#9764= IFCSTYLEDITEM(#9763,(#191),$);
#9765= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#9766= IFCEXTRUDEDAREASOLID(#9765,#5726,#9,10.);
#9767= IFCSTYLEDITEM(#9766,(#191),$);
#9768= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9751,#9754,#9757,#9760,#9763,#9766));
#9769= IFCREPRESENTATIONMAP(#10,#9768);
#9770= IFCMAPPEDITEM(#9769,#5730);
#9771= IFCMAPPEDITEM(#9769,#5735);
#9772= IFCMAPPEDITEM(#9769,#5738);
#9773= IFCMAPPEDITEM(#9769,#5741);
#9774= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#9770,#9771,#9772,#9773));
#9775= IFCPRODUCTDEFINITIONSHAPE($,$,(#9774));
#9776= IFCMECHANICALFASTENER('1Td1iR001I3J4rDp0rCJ4s',#5,'Bolt assembly',$,$,#9749,#9775,'ID5d9c1b1b-0000-520d-3135-373035313136',12.,50.);
#9777= IFCLOCALPLACEMENT(#30,#10);
#9778= IFCELEMENTASSEMBLY('1Td1iR002oh34rDp0rCJ4s',#5,'Steel Assembly',$,$,#9777,$,'ANK/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#9779= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(5.09490489006697),$);
#9780= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' +15.790'),$);
#9781= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +15.806'),$);
#9782= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit name',$,IFCLABEL('PLAKA'),$);
#9783= IFCPROPERTYSET('2LXvptzn590PZUC2vbUnE$',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#9779,#9780,#9781,#9782,#3926,#41));
#9784= IFCQUANTITYLENGTH('Width',$,$,16.0000000000218);
#9785= IFCELEMENTQUANTITY('1yTiLB9bHFcxh0BHAUUX_w',#5,'BaseQuantities',$,$,(#9784));
#9786= IFCCARTESIANPOINT((48708.5693247701,-686.020643927995,15797.9955494618));
#9787= IFCAXIS2PLACEMENT3D(#9786,#5754,#5755);
#9788= IFCLOCALPLACEMENT(#9777,#9787);
#9789= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5764));
#9790= IFCPRODUCTDEFINITIONSHAPE($,$,(#9789));
#9791= IFCPLATE('1Td1iR001I434rDp0rCJ4s',#5,'PLAKA','PL16*180','PL16*180',#9788,#9790,'P/423(?)');
#9792= IFCPLATETYPE('3bbnRDZyv9O953Nrj0C22M',#5,'PL16*180',$,$,$,$,$,$,.NOTDEFINED.);
#9793= IFCPROPERTYSET('02RxgpwWLEIP$wpAeDUTrY',#5,'Tekla Common','Common Properties to Shared building elements',(#1901,#1902,#5770,#73,#74,#75,#76,#1194,#78,#5772,#5773));
#9794= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(5.09490489006697),$);
#9795= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(5.09490489006697),$);
#9796= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(6.11239973203845),$);
#9797= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(5.09490489006697),$);
#9798= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000649032470072225),$);
#9799= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000649032470072225),$);
#9800= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000649032470072225),$);
#9801= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.040564529379512),$);
#9802= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0938535336582262),$);
#9803= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0486656029620896),$);
#9804= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(180.000001149412),$);
#9805= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(270.364459174052),$);
#9806= IFCPROPERTYSET('0RnfmlUADEiOt_UNPFnzG0',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#9794,#9795,#9796,#9797,#9798,#9799,#9800,#9801,#5783,#9802,#9803,#9804,#175,#9805));
#9807= IFCQUANTITYLENGTH('Width',$,$,180.000001149412);
#9808= IFCQUANTITYAREA('NetArea',$,$,0.0938535336582262);
#9809= IFCQUANTITYAREA('GrossArea',$,$,0.0486656029620896);
#9810= IFCQUANTITYVOLUME('NetVolume',$,$,0.000649032470072225);
#9811= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000649032470072225);
#9812= IFCELEMENTQUANTITY('1WVMHALXDA6e0vhj9v0ua9',#5,'BaseQuantities',$,$,(#9807,#9808,#9809,#100,#9810,#9811));
#9813= IFCCARTESIANPOINT((48832.9876804683,-589.170000077094,-1155.));
#9814= IFCAXIS2PLACEMENT3D(#9813,#501,#596);
#9815= IFCLOCALPLACEMENT(#9098,#9814);
#9816= IFCTSHAPEPROFILEDEF(.AREA.,'T200-25-25-110',#197,200.,110.,25.,25.,17.5,$,$,$,$,$);
#9817= IFCCARTESIANPOINT((6525.004,0.,0.));
#9818= IFCAXIS2PLACEMENT3D(#9817,#185,#501);
#9819= IFCEXTRUDEDAREASOLID(#9816,#9818,#9,6525.004);
#9820= IFCCARTESIANPOINT((45.,-60.0000000000073,-220.000000000004));
#9821= IFCAXIS2PLACEMENT3D(#9820,#185,#8);
#9822= IFCPLANE(#9821);
#9823= IFCHALFSPACESOLID(#9822,.F.);
#9824= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#9819,#9823);
#9825= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#9824));
#9826= IFCSTYLEDITEM(#9819,(#4116),$);
#9827= IFCPRODUCTDEFINITIONSHAPE($,$,(#9825));
#9828= IFCDISCRETEACCESSORY('1Td1iR001I534rDp0rCJ4s',#5,'DIKME','T200-25-25-110','T200-25-25-110',#9815,#9827,'P/386(?)');
#9829= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -1.200'),$);
#9830= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/386(?)'),$);
#9831= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('T200-25-25-110'),$);
#9832= IFCPROPERTYSET('3S$MWPMhv7UBtDGm31iQAU',#5,'Tekla Common','Common Properties to Shared building elements',(#9078,#9829,#9830,#73,#74,#75,#919,#4183,#78,#9831,#4048));
#9833= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(362.434723725),$);
#9834= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(364.951629975),$);
#9835= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(362.434723725),$);
#9836= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.0461700285),$);
#9837= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.0464906535),$);
#9838= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.0461700285),$);
#9839= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.007125),$);
#9840= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(11.1243548591641),$);
#9841= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(4.03185248),$);
#9842= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(4.05975248),$);
#9843= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(200.),$);
#9844= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(110.),$);
#9845= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(6480.004),$);
#9846= IFCPROPERTYSET('0U5DQaBsPFewXrVR5fLbwK',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#9122,#9833,#9834,#9835,#9836,#9837,#9838,#9839,#9840,#9841,#9842,#9843,#9844,#9845));
#9847= IFCQUANTITYLENGTH('Length',$,$,6480.004);
#9848= IFCQUANTITYAREA('OuterSurfaceArea',$,$,4.03185248);
#9849= IFCQUANTITYVOLUME('NetVolume',$,$,0.0461700285);
#9850= IFCQUANTITYWEIGHT('NetWeight',$,$,362.434723725);
#9851= IFCELEMENTQUANTITY('39ySMI23LCWOpk9DEOIHO3',#5,'BaseQuantities',$,$,(#9847,#9848,#9849,#9850));
#9852= IFCLOCALPLACEMENT(#30,#10);
#9853= IFCELEMENTASSEMBLY('1Td1iR002ohJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#9852,$,'B/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#9854= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(57.857721553073),$);
#9855= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +19.868'),$);
#9856= IFCPROPERTYSET('3GKOHOdajD3x96uUoDPxUm',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#9854,#1589,#9855,#890,#3926,#4251));
#9857= IFCQUANTITYLENGTH('Width',$,$,95.7235372226758);
#9858= IFCELEMENTQUANTITY('1UyQLEE_HBtfOwbiJARAlK',#5,'BaseQuantities',$,$,(#9857));
#9859= IFCCARTESIANPOINT((48743.128037899,-684.134420797411,17836.85));
#9860= IFCAXIS2PLACEMENT3D(#9859,#9,#4471);
#9861= IFCLOCALPLACEMENT(#9852,#9860);
#9862= IFCCARTESIANPOINT((-5.0931703299284E-011,-5.00000000000011,-2031.));
#9863= IFCCARTESIANPOINT((-5.0931703299284E-011,-5.00000000000011,2031.));
#9864= IFCCARTESIANPOINT((5.82076609134674E-011,5.,2031.));
#9865= IFCCARTESIANPOINT((5.82076609134674E-011,5.,-2031.));
#9866= IFCPOLYLOOP((#9862,#9863,#9864,#9865));
#9867= IFCFACEOUTERBOUND(#9866,.T.);
#9868= IFCFACE((#9867));
#9869= IFCCARTESIANPOINT((85.7242817835358,4.99999999911404,2031.));
#9870= IFCCARTESIANPOINT((85.7242817835358,4.99999999911404,-2031.));
#9871= IFCPOLYLOOP((#9865,#9864,#9869,#9870));
#9872= IFCFACEOUTERBOUND(#9871,.T.);
#9873= IFCFACE((#9872));
#9874= IFCCARTESIANPOINT((95.7242813128396,-5.00000000098953,-2031.));
#9875= IFCCARTESIANPOINT((95.7242813128396,-5.00000000098953,2031.));
#9876= IFCPOLYLOOP((#9863,#9862,#9874,#9875));
#9877= IFCFACEOUTERBOUND(#9876,.T.);
#9878= IFCFACE((#9877));
#9879= IFCCARTESIANPOINT((85.7242858185273,90.7235372216751,2031.));
#9880= IFCCARTESIANPOINT((85.7242858185273,90.7235372216751,-2031.));
#9881= IFCPOLYLOOP((#9870,#9869,#9879,#9880));
#9882= IFCFACEOUTERBOUND(#9881,.T.);
#9883= IFCFACE((#9882));
#9884= IFCCARTESIANPOINT((95.7242858185273,90.7235367509771,2031.));
#9885= IFCPOLYLOOP((#9869,#9864,#9863,#9875,#9884,#9879));
#9886= IFCFACEOUTERBOUND(#9885,.T.);
#9887= IFCFACE((#9886));
#9888= IFCCARTESIANPOINT((95.7242858185273,90.7235367509771,-2031.));
#9889= IFCPOLYLOOP((#9875,#9874,#9888,#9884));
#9890= IFCFACEOUTERBOUND(#9889,.T.);
#9891= IFCFACE((#9890));
#9892= IFCPOLYLOOP((#9874,#9862,#9865,#9870,#9880,#9888));
#9893= IFCFACEOUTERBOUND(#9892,.T.);
#9894= IFCFACE((#9893));
#9895= IFCPOLYLOOP((#9884,#9888,#9880,#9879));
#9896= IFCFACEOUTERBOUND(#9895,.T.);
#9897= IFCFACE((#9896));
#9898= IFCCLOSEDSHELL((#9868,#9873,#9878,#9883,#9887,#9891,#9894,#9897));
#9899= IFCFACETEDBREP(#9898);
#9900= IFCSTYLEDITEM(#9899,(#4477),$);
#9901= IFCSHAPEREPRESENTATION(#12,'Body','Brep',(#9899));
#9902= IFCPRODUCTDEFINITIONSHAPE($,$,(#9901));
#9903= IFCBEAM('1Td1iR001I634rDp0rCJ4s',#5,'KIRIS','PL4062*10','PL4062*10',#9861,#9902,'P/0(?)');
#9904= IFCBEAMTYPE('1WbZ_Wbh11IhPBpbojnO0W',#5,'PL4062*10',$,$,$,$,$,$,.NOTDEFINED.);
#9905= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +19.868'),$);
#9906= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PL4062*10'),$);
#9907= IFCPROPERTYSET('3SKIYhqG19auNa_dQSP7Bh',#5,'Tekla Common','Common Properties to Shared building elements',(#1598,#9905,#1009,#4268,#74,#75,#76,#4524,#78,#9906,#4185));
#9908= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(57.857721553073),$);
#9909= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(57.857721553073),$);
#9910= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(57.8577216050363),$);
#9911= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(57.857721553073),$);
#9912= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.0073704103889265),$);
#9913= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.00737041038891734),$);
#9914= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.0073704103889265),$);
#9915= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(26.9445631854747),$);
#9916= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(1.55895103415438),$);
#9917= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(1.55895103415267),$);
#9918= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(4062.00000003989),$);
#9919= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(10.0000001619674),$);
#9920= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(181.447818697037),$);
#9921= IFCPROPERTYSET('3j5DHLcU96cxsglhuYfgra',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#9908,#9909,#9910,#9911,#9912,#9913,#9914,#4534,#9915,#9916,#9917,#9918,#9919,#9920));
#9922= IFCQUANTITYLENGTH('Length',$,$,181.447818697037);
#9923= IFCQUANTITYAREA('OuterSurfaceArea',$,$,1.55895103415438);
#9924= IFCQUANTITYVOLUME('NetVolume',$,$,0.0073704103889265);
#9925= IFCQUANTITYWEIGHT('NetWeight',$,$,57.857721553073);
#9926= IFCELEMENTQUANTITY('18y3LmjPXA9vmFH2avWfca',#5,'BaseQuantities',$,$,(#9922,#9923,#9924,#9925));
#9927= IFCCARTESIANPOINT((48743.128037899,-684.134420797411,7702.99999999997));
#9928= IFCAXIS2PLACEMENT3D(#9927,#9,#4471);
#9929= IFCLOCALPLACEMENT(#5746,#9928);
#9930= IFCCARTESIANPOINT((-5.0931703299284E-011,-5.00000000000011,-2797.));
#9931= IFCCARTESIANPOINT((-5.0931703299284E-011,-5.00000000000011,2797.));
#9932= IFCCARTESIANPOINT((5.82076609134674E-011,5.,2797.));
#9933= IFCCARTESIANPOINT((5.82076609134674E-011,5.,-2797.));
#9934= IFCPOLYLOOP((#9930,#9931,#9932,#9933));
#9935= IFCFACEOUTERBOUND(#9934,.T.);
#9936= IFCFACE((#9935));
#9937= IFCCARTESIANPOINT((85.7242817835358,4.99999999911404,2797.));
#9938= IFCCARTESIANPOINT((85.7242817835358,4.99999999911404,-2797.));
#9939= IFCPOLYLOOP((#9933,#9932,#9937,#9938));
#9940= IFCFACEOUTERBOUND(#9939,.T.);
#9941= IFCFACE((#9940));
#9942= IFCCARTESIANPOINT((95.7242813128396,-5.00000000098953,-2797.));
#9943= IFCCARTESIANPOINT((95.7242813128396,-5.00000000098953,2797.));
#9944= IFCPOLYLOOP((#9931,#9930,#9942,#9943));
#9945= IFCFACEOUTERBOUND(#9944,.T.);
#9946= IFCFACE((#9945));
#9947= IFCCARTESIANPOINT((85.7242858185273,90.7235372216751,2797.));
#9948= IFCCARTESIANPOINT((85.7242858185273,90.7235372216751,-2797.));
#9949= IFCPOLYLOOP((#9938,#9937,#9947,#9948));
#9950= IFCFACEOUTERBOUND(#9949,.T.);
#9951= IFCFACE((#9950));
#9952= IFCCARTESIANPOINT((95.7242858185273,90.7235367509771,2797.));
#9953= IFCPOLYLOOP((#9937,#9932,#9931,#9943,#9952,#9947));
#9954= IFCFACEOUTERBOUND(#9953,.T.);
#9955= IFCFACE((#9954));
#9956= IFCCARTESIANPOINT((95.7242858185273,90.7235367509771,-2797.));
#9957= IFCPOLYLOOP((#9943,#9942,#9956,#9952));
#9958= IFCFACEOUTERBOUND(#9957,.T.);
#9959= IFCFACE((#9958));
#9960= IFCPOLYLOOP((#9942,#9930,#9933,#9938,#9948,#9956));
#9961= IFCFACEOUTERBOUND(#9960,.T.);
#9962= IFCFACE((#9961));
#9963= IFCPOLYLOOP((#9952,#9956,#9948,#9947));
#9964= IFCFACEOUTERBOUND(#9963,.T.);
#9965= IFCFACE((#9964));
#9966= IFCCLOSEDSHELL((#9936,#9941,#9946,#9951,#9955,#9959,#9962,#9965));
#9967= IFCFACETEDBREP(#9966);
#9968= IFCSTYLEDITEM(#9967,(#4477),$);
#9969= IFCSHAPEREPRESENTATION(#12,'Body','Brep',(#9967));
#9970= IFCPRODUCTDEFINITIONSHAPE($,$,(#9969));
#9971= IFCDISCRETEACCESSORY('1Td1iR001I7J4rDp0rCJ4s',#5,'KIRIS','PL5594*10','PL5594*10',#9929,#9970,'P/0(?)');
#9972= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +10.500'),$);
#9973= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PL5594*10'),$);
#9974= IFCPROPERTYSET('2FvQqUanf4Ox29or_GBGbg',#5,'Tekla Common','Common Properties to Shared building elements',(#2156,#9972,#1009,#5771,#74,#75,#76,#4524,#78,#9973,#4185));
#9975= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(79.6789991058323),$);
#9976= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(79.6789991746846),$);
#9977= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(79.6789991058323),$);
#9978= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.0101501909688958),$);
#9979= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.0101501909688832),$);
#9980= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.0101501909688958),$);
#9981= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(26.9273858133915),$);
#9982= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(2.14554715014762),$);
#9983= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(2.14554715014528),$);
#9984= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(5594.00000003925),$);
#9985= IFCPROPERTYSET('1tFdmEWKXDjRO_hfrS6mzb',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#5775,#9975,#9976,#9977,#9978,#9979,#9980,#4534,#9981,#9982,#9983,#9984,#4539,#4540));
#9986= IFCQUANTITYLENGTH('Length',$,$,181.447818691377);
#9987= IFCQUANTITYAREA('OuterSurfaceArea',$,$,2.14554715014762);
#9988= IFCQUANTITYVOLUME('NetVolume',$,$,0.0101501909688958);
#9989= IFCQUANTITYWEIGHT('NetWeight',$,$,79.6789991058323);
#9990= IFCELEMENTQUANTITY('2rdLk7zh56MwlBw3juhZnE',#5,'BaseQuantities',$,$,(#9986,#9987,#9988,#9989));
#9991= IFCCARTESIANPOINT((48743.128037899,-684.134420797411,1844.99999999998));
#9992= IFCAXIS2PLACEMENT3D(#9991,#9,#4471);
#9993= IFCLOCALPLACEMENT(#3920,#9992);
#9994= IFCCARTESIANPOINT((-5.0931703299284E-011,-5.00000000000011,-2955.));
#9995= IFCCARTESIANPOINT((-5.0931703299284E-011,-5.00000000000011,2955.));
#9996= IFCCARTESIANPOINT((5.82076609134674E-011,5.,2955.));
#9997= IFCCARTESIANPOINT((5.82076609134674E-011,5.,-2955.));
#9998= IFCPOLYLOOP((#9994,#9995,#9996,#9997));
#9999= IFCFACEOUTERBOUND(#9998,.T.);
#10000= IFCFACE((#9999));
#10001= IFCCARTESIANPOINT((85.7242817835358,4.99999999911404,2955.));
#10002= IFCCARTESIANPOINT((85.7242817835358,4.99999999911404,-2955.));
#10003= IFCPOLYLOOP((#9997,#9996,#10001,#10002));
#10004= IFCFACEOUTERBOUND(#10003,.T.);
#10005= IFCFACE((#10004));
#10006= IFCCARTESIANPOINT((95.7242813128396,-5.00000000098953,-2955.));
#10007= IFCCARTESIANPOINT((95.7242813128396,-5.00000000098953,2955.));
#10008= IFCPOLYLOOP((#9995,#9994,#10006,#10007));
#10009= IFCFACEOUTERBOUND(#10008,.T.);
#10010= IFCFACE((#10009));
#10011= IFCCARTESIANPOINT((85.7242858185273,90.7235372216751,2955.));
#10012= IFCCARTESIANPOINT((85.7242858185273,90.7235372216751,-2955.));
#10013= IFCPOLYLOOP((#10002,#10001,#10011,#10012));
#10014= IFCFACEOUTERBOUND(#10013,.T.);
#10015= IFCFACE((#10014));
#10016= IFCCARTESIANPOINT((95.7242858185273,90.7235367509771,2955.));
#10017= IFCPOLYLOOP((#10001,#9996,#9995,#10007,#10016,#10011));
#10018= IFCFACEOUTERBOUND(#10017,.T.);
#10019= IFCFACE((#10018));
#10020= IFCCARTESIANPOINT((95.7242858185273,90.7235367509771,-2955.));
#10021= IFCPOLYLOOP((#10007,#10006,#10020,#10016));
#10022= IFCFACEOUTERBOUND(#10021,.T.);
#10023= IFCFACE((#10022));
#10024= IFCPOLYLOOP((#10006,#9994,#9997,#10002,#10012,#10020));
#10025= IFCFACEOUTERBOUND(#10024,.T.);
#10026= IFCFACE((#10025));
#10027= IFCPOLYLOOP((#10016,#10020,#10012,#10011));
#10028= IFCFACEOUTERBOUND(#10027,.T.);
#10029= IFCFACE((#10028));
#10030= IFCCLOSEDSHELL((#10000,#10005,#10010,#10015,#10019,#10023,#10026,#10029));
#10031= IFCFACETEDBREP(#10030);
#10032= IFCSTYLEDITEM(#10031,(#4477),$);
#10033= IFCSHAPEREPRESENTATION(#12,'Body','Brep',(#10031));
#10034= IFCPRODUCTDEFINITIONSHAPE($,$,(#10033));
#10035= IFCDISCRETEACCESSORY('1Td1iR001I834rDp0rCJ4s',#5,'KIRIS','PL5910*10','PL5910*10',#9993,#10034,'P/0(?)');
#10036= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +4.800'),$);
#10037= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PL5910*10'),$);
#10038= IFCPROPERTYSET('3k8m44MFj66uUDnk3D96DY',#5,'Tekla Common','Common Properties to Shared building elements',(#2392,#10036,#1009,#3950,#74,#75,#76,#4524,#78,#10037,#4185));
#10039= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(84.1799936924327),$);
#10040= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(84.1799937636124),$);
#10041= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(84.1799936924327),$);
#10042= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.0107235660754691),$);
#10043= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.0107235660754558),$);
#10044= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.0107235660754691),$);
#10045= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(26.924950597447),$);
#10046= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(2.26654217146216),$);
#10047= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(2.26654217145968),$);
#10048= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(5910.00000003892),$);
#10049= IFCPROPERTYSET('2fstDGyF15Oee_hd007X7r',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#3953,#10039,#10040,#10041,#10042,#10043,#10044,#4534,#10045,#10046,#10047,#10048,#4539,#4540));
#10050= IFCQUANTITYLENGTH('Length',$,$,181.447818688088);
#10051= IFCQUANTITYAREA('OuterSurfaceArea',$,$,2.26654217146216);
#10052= IFCQUANTITYVOLUME('NetVolume',$,$,0.0107235660754691);
#10053= IFCQUANTITYWEIGHT('NetWeight',$,$,84.1799936924327);
#10054= IFCELEMENTQUANTITY('3HUIGLkBn0vRWMLGtfRkua',#5,'BaseQuantities',$,$,(#10050,#10051,#10052,#10053));
#10055= IFCCARTESIANPOINT((48728.8520000746,1525.00168046917,15794.9999999996));
#10056= IFCAXIS2PLACEMENT3D(#10055,#185,#8);
#10057= IFCLOCALPLACEMENT(#30,#10056);
#10058= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#10059= IFCEXTRUDEDAREASOLID(#10058,#4747,#9,16.0000000000193);
#10060= IFCSTYLEDITEM(#10059,(#195),$);
#10061= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#10062= IFCEXTRUDEDAREASOLID(#10061,#4752,#9,16.1000000000006);
#10063= IFCSTYLEDITEM(#10062,(#195),$);
#10064= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#10065= IFCEXTRUDEDAREASOLID(#10064,#4757,#9,6.5);
#10066= IFCSTYLEDITEM(#10065,(#191),$);
#10067= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#10068= IFCEXTRUDEDAREASOLID(#10067,#4762,#9,50.);
#10069= IFCSTYLEDITEM(#10068,(#191),$);
#10070= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#10071= IFCEXTRUDEDAREASOLID(#10070,#4767,#9,2.5);
#10072= IFCSTYLEDITEM(#10071,(#191),$);
#10073= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#10074= IFCEXTRUDEDAREASOLID(#10073,#4772,#9,10.);
#10075= IFCSTYLEDITEM(#10074,(#191),$);
#10076= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#10059,#10062,#10065,#10068,#10071,#10074));
#10077= IFCREPRESENTATIONMAP(#10,#10076);
#10078= IFCMAPPEDITEM(#10077,#4776);
#10079= IFCMAPPEDITEM(#10077,#4781);
#10080= IFCMAPPEDITEM(#10077,#4784);
#10081= IFCMAPPEDITEM(#10077,#4787);
#10082= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#10078,#10079,#10080,#10081));
#10083= IFCPRODUCTDEFINITIONSHAPE($,$,(#10082));
#10084= IFCMECHANICALFASTENER('1Td1iR001KN34rDp0rCJ4s',#5,'Bolt assembly',$,$,#10057,#10083,'ID5d9c1b1b-0000-545c-3135-373035313136',12.,50.);
#10085= IFCCARTESIANPOINT((48728.8520000746,3715.00168046917,15794.9999999996));
#10086= IFCAXIS2PLACEMENT3D(#10085,#185,#8);
#10087= IFCLOCALPLACEMENT(#30,#10086);
#10088= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#10089= IFCEXTRUDEDAREASOLID(#10088,#4747,#9,16.0000000000193);
#10090= IFCSTYLEDITEM(#10089,(#195),$);
#10091= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#10092= IFCEXTRUDEDAREASOLID(#10091,#4752,#9,16.1000000000006);
#10093= IFCSTYLEDITEM(#10092,(#195),$);
#10094= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#10095= IFCEXTRUDEDAREASOLID(#10094,#4757,#9,6.5);
#10096= IFCSTYLEDITEM(#10095,(#191),$);
#10097= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#10098= IFCEXTRUDEDAREASOLID(#10097,#4762,#9,50.);
#10099= IFCSTYLEDITEM(#10098,(#191),$);
#10100= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#10101= IFCEXTRUDEDAREASOLID(#10100,#4767,#9,2.5);
#10102= IFCSTYLEDITEM(#10101,(#191),$);
#10103= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#10104= IFCEXTRUDEDAREASOLID(#10103,#4772,#9,10.);
#10105= IFCSTYLEDITEM(#10104,(#191),$);
#10106= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#10089,#10092,#10095,#10098,#10101,#10104));
#10107= IFCREPRESENTATIONMAP(#10,#10106);
#10108= IFCMAPPEDITEM(#10107,#4776);
#10109= IFCMAPPEDITEM(#10107,#4781);
#10110= IFCMAPPEDITEM(#10107,#4784);
#10111= IFCMAPPEDITEM(#10107,#4787);
#10112= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#10108,#10109,#10110,#10111));
#10113= IFCPRODUCTDEFINITIONSHAPE($,$,(#10112));
#10114= IFCMECHANICALFASTENER('1Td1iR001KOp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#10087,#10113,'ID5d9c1b1b-0000-5463-3135-373035313136',12.,50.);
#10115= IFCCARTESIANPOINT((48728.8520000746,4050.00168046917,15794.9999999996));
#10116= IFCAXIS2PLACEMENT3D(#10115,#185,#8);
#10117= IFCLOCALPLACEMENT(#30,#10116);
#10118= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#10119= IFCEXTRUDEDAREASOLID(#10118,#4747,#9,16.0000000000193);
#10120= IFCSTYLEDITEM(#10119,(#195),$);
#10121= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#10122= IFCEXTRUDEDAREASOLID(#10121,#4752,#9,16.1000000000006);
#10123= IFCSTYLEDITEM(#10122,(#195),$);
#10124= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#10125= IFCEXTRUDEDAREASOLID(#10124,#4757,#9,6.5);
#10126= IFCSTYLEDITEM(#10125,(#191),$);
#10127= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#10128= IFCEXTRUDEDAREASOLID(#10127,#4762,#9,50.);
#10129= IFCSTYLEDITEM(#10128,(#191),$);
#10130= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#10131= IFCEXTRUDEDAREASOLID(#10130,#4767,#9,2.5);
#10132= IFCSTYLEDITEM(#10131,(#191),$);
#10133= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#10134= IFCEXTRUDEDAREASOLID(#10133,#4772,#9,10.);
#10135= IFCSTYLEDITEM(#10134,(#191),$);
#10136= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#10119,#10122,#10125,#10128,#10131,#10134));
#10137= IFCREPRESENTATIONMAP(#10,#10136);
#10138= IFCMAPPEDITEM(#10137,#4776);
#10139= IFCMAPPEDITEM(#10137,#4781);
#10140= IFCMAPPEDITEM(#10137,#4784);
#10141= IFCMAPPEDITEM(#10137,#4787);
#10142= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#10138,#10139,#10140,#10141));
#10143= IFCPRODUCTDEFINITIONSHAPE($,$,(#10142));
#10144= IFCMECHANICALFASTENER('1Td1iR001KxZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#10117,#10143,'ID5d9c1b1b-0000-54ee-3135-373035313136',12.,50.);
#10145= IFCCARTESIANPOINT((48728.8520000746,5320.00168046917,15794.9999999996));
#10146= IFCAXIS2PLACEMENT3D(#10145,#185,#8);
#10147= IFCLOCALPLACEMENT(#30,#10146);
#10148= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#10149= IFCEXTRUDEDAREASOLID(#10148,#4747,#9,16.0000000000193);
#10150= IFCSTYLEDITEM(#10149,(#195),$);
#10151= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#10152= IFCEXTRUDEDAREASOLID(#10151,#4752,#9,16.1000000000006);
#10153= IFCSTYLEDITEM(#10152,(#195),$);
#10154= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#10155= IFCEXTRUDEDAREASOLID(#10154,#4757,#9,6.5);
#10156= IFCSTYLEDITEM(#10155,(#191),$);
#10157= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#10158= IFCEXTRUDEDAREASOLID(#10157,#4762,#9,50.);
#10159= IFCSTYLEDITEM(#10158,(#191),$);
#10160= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#10161= IFCEXTRUDEDAREASOLID(#10160,#4767,#9,2.5);
#10162= IFCSTYLEDITEM(#10161,(#191),$);
#10163= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#10164= IFCEXTRUDEDAREASOLID(#10163,#4772,#9,10.);
#10165= IFCSTYLEDITEM(#10164,(#191),$);
#10166= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#10149,#10152,#10155,#10158,#10161,#10164));
#10167= IFCREPRESENTATIONMAP(#10,#10166);
#10168= IFCMAPPEDITEM(#10167,#4776);
#10169= IFCMAPPEDITEM(#10167,#4781);
#10170= IFCMAPPEDITEM(#10167,#4784);
#10171= IFCMAPPEDITEM(#10167,#4787);
#10172= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#10168,#10169,#10170,#10171));
#10173= IFCPRODUCTDEFINITIONSHAPE($,$,(#10172));
#10174= IFCMECHANICALFASTENER('1Td1iR001Ktp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#10147,#10173,'ID5d9c1b1b-0000-54df-3135-373035313136',12.,50.);
#10175= IFCCARTESIANPOINT((48728.8520000746,5655.00168046917,15794.9999999996));
#10176= IFCAXIS2PLACEMENT3D(#10175,#185,#8);
#10177= IFCLOCALPLACEMENT(#30,#10176);
#10178= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#10179= IFCEXTRUDEDAREASOLID(#10178,#4747,#9,16.0000000000193);
#10180= IFCSTYLEDITEM(#10179,(#195),$);
#10181= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#10182= IFCEXTRUDEDAREASOLID(#10181,#4752,#9,16.1000000000006);
#10183= IFCSTYLEDITEM(#10182,(#195),$);
#10184= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#10185= IFCEXTRUDEDAREASOLID(#10184,#4757,#9,6.5);
#10186= IFCSTYLEDITEM(#10185,(#191),$);
#10187= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#10188= IFCEXTRUDEDAREASOLID(#10187,#4762,#9,50.);
#10189= IFCSTYLEDITEM(#10188,(#191),$);
#10190= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#10191= IFCEXTRUDEDAREASOLID(#10190,#4767,#9,2.5);
#10192= IFCSTYLEDITEM(#10191,(#191),$);
#10193= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#10194= IFCEXTRUDEDAREASOLID(#10193,#4772,#9,10.);
#10195= IFCSTYLEDITEM(#10194,(#191),$);
#10196= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#10179,#10182,#10185,#10188,#10191,#10194));
#10197= IFCREPRESENTATIONMAP(#10,#10196);
#10198= IFCMAPPEDITEM(#10197,#4776);
#10199= IFCMAPPEDITEM(#10197,#4781);
#10200= IFCMAPPEDITEM(#10197,#4784);
#10201= IFCMAPPEDITEM(#10197,#4787);
#10202= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#10198,#10199,#10200,#10201));
#10203= IFCPRODUCTDEFINITIONSHAPE($,$,(#10202));
#10204= IFCMECHANICALFASTENER('1Td1iR001Ks34rDp0rCJ4s',#5,'Bolt assembly',$,$,#10177,#10203,'ID5d9c1b1b-0000-54d8-3135-373035313136',12.,50.);
#10205= IFCCARTESIANPOINT((48828.9996544548,-687.66991453126,15699.9999999999));
#10206= IFCAXIS2PLACEMENT3D(#10205,#501,#9);
#10207= IFCLOCALPLACEMENT(#4248,#10206);
#10208= IFCCARTESIANPOINT((90.,279.999999999993));
#10209= IFCCARTESIANPOINT((0.,279.999999999993));
#10210= IFCPOLYLINE((#54,#4921,#10208,#10209,#54,#54));
#10211= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL3*90',#10210);
#10212= IFCEXTRUDEDAREASOLID(#10211,#4427,#9,3.);
#10213= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#10212));
#10214= IFCSTYLEDITEM(#10212,(#53),$);
#10215= IFCPRODUCTDEFINITIONSHAPE($,$,(#10213));
#10216= IFCDISCRETEACCESSORY('1Td1iR001KTJ4rDp0rCJ4s',#5,'Cap plate','PL3*90','PL3*90',#10207,#10215,'0(?)');
#10217= IFCPROPERTYSET('0nP18OKpb2TB62decDYRYC',#5,'Tekla Common','Common Properties to Shared building elements',(#4931,#1052,#4436,#4268,#74,#75,#76,#77,#78,#4932,#4438));
#10218= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.59346),$);
#10219= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(0.593460000000016),$);
#10220= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.59346),$);
#10221= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(7.56E-005),$);
#10222= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(7.56E-005),$);
#10223= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(7.56E-005),$);
#10224= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00084),$);
#10225= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(88.6664644626428),$);
#10226= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.05262),$);
#10227= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0252000000000007),$);
#10228= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(280.000000000007),$);
#10229= IFCPROPERTYSET('3OganxCDb1R8MtSwNn22b$',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#4270,#10218,#10219,#10220,#10221,#10222,#10223,#10224,#10225,#10226,#10227,#4944,#4451,#10228));
#10230= IFCQUANTITYAREA('NetArea',$,$,0.05262);
#10231= IFCQUANTITYAREA('GrossArea',$,$,0.0252000000000007);
#10232= IFCQUANTITYVOLUME('NetVolume',$,$,7.56E-005);
#10233= IFCQUANTITYVOLUME('GrossVolume',$,$,7.56E-005);
#10234= IFCELEMENTQUANTITY('3qDnh72AL4URWrhd$gHXf6',#5,'BaseQuantities',$,$,(#893,#10230,#10231,#4457,#10232,#10233));
#10235= IFCCARTESIANPOINT((48688.999523492,7497.50289578092,15744.9999999999));
#10236= IFCAXIS2PLACEMENT3D(#10235,#7,#501);
#10237= IFCLOCALPLACEMENT(#4248,#10236);
#10238= IFCCOLOURRGB('Light Magenta',0.8,0.4,0.898039215686275);
#10239= IFCSURFACESTYLERENDERING(#10238,0.,$,$,$,$,IFCNORMALISEDRATIOMEASURE(0.00390625),IFCSPECULAREXPONENT(10.),.NOTDEFINED.);
#10240= IFCSURFACESTYLE('STEEL/S235JR',.POSITIVE.,(#10239));
#10241= IFCPRESENTATIONSTYLEASSIGNMENT((#10240));
#10242= IFCCARTESIANPOINT((-45.,150.000000000007));
#10243= IFCCARTESIANPOINT((45.,150.000000000007));
#10244= IFCCARTESIANPOINT((45.,-149.999999999993));
#10245= IFCCARTESIANPOINT((-45.,-149.999999999993));
#10246= IFCPOLYLINE((#10242,#10243,#10244,#10245,#10242));
#10247= IFCCARTESIANPOINT((29.,-119.999999999993));
#10248= IFCCARTESIANPOINT((29.,120.000000000007));
#10249= IFCCARTESIANPOINT((-29.,120.000000000007));
#10250= IFCCARTESIANPOINT((-29.,-119.999999999993));
#10251= IFCPOLYLINE((#10247,#10248,#10249,#10250,#10247));
#10252= IFCARBITRARYPROFILEDEFWITHVOIDS(.AREA.,'WB300-16-30*90-0',#10246,(#10251));
#10253= IFCCARTESIANPOINT((8183.67281255218,0.,0.));
#10254= IFCAXIS2PLACEMENT3D(#10253,#185,#501);
#10255= IFCEXTRUDEDAREASOLID(#10252,#10254,#9,8183.67281255218);
#10256= IFCDIRECTION((-0.707106803500258,0.,-0.707106758872837));
#10257= IFCCARTESIANPOINT((21.3844749238569,44.9999999999854,-149.999050978382));
#10258= IFCAXIS2PLACEMENT3D(#10257,#10256,#4168);
#10259= IFCPLANE(#10258);
#10260= IFCHALFSPACESOLID(#10259,.F.);
#10261= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#10255,#10260);
#10262= IFCCARTESIANPOINT((21.3844797238417,44.9999999999854,150.000003309993));
#10263= IFCAXIS2PLACEMENT3D(#10262,#4168,#501);
#10264= IFCPLANE(#10263);
#10265= IFCHALFSPACESOLID(#10264,.F.);
#10266= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#10261,#10265);
#10267= IFCCARTESIANPOINT((21.3844797237871,44.9999999999854,-169.999999050589));
#10268= IFCAXIS2PLACEMENT3D(#10267,#10256,#4168);
#10269= IFCPLANE(#10268);
#10270= IFCHALFSPACESOLID(#10269,.F.);
#10271= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#10266,#10270);
#10272= IFCDIRECTION((-0.707112527163203,-0.7071010351632,0.));
#10273= IFCCARTESIANPOINT((11.3843171963363,-45.0000000000946,-169.999999050589));
#10274= IFCDIRECTION((-0.7071010351632,0.707112527163203,3.13622877074147E-010));
#10275= IFCAXIS2PLACEMENT3D(#10273,#10272,#10274);
#10276= IFCPLANE(#10275);
#10277= IFCHALFSPACESOLID(#10276,.F.);
#10278= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#10271,#10277);
#10279= IFCCARTESIANPOINT((11.3843171963363,44.9999999999854,-169.999999050589));
#10280= IFCAXIS2PLACEMENT3D(#10279,#5696,#9);
#10281= IFCPLANE(#10280);
#10282= IFCHALFSPACESOLID(#10281,.F.);
#10283= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#10278,#10282);
#10284= IFCCARTESIANPOINT((8183.67281255218,0.,-150.));
#10285= IFCAXIS2PLACEMENT3D(#10284,#185,#8);
#10286= IFCPLANE(#10285);
#10287= IFCHALFSPACESOLID(#10286,.T.);
#10288= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#10283,#10287);
#10289= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#10288));
#10290= IFCSTYLEDITEM(#10255,(#10241),$);
#10291= IFCPRODUCTDEFINITIONSHAPE($,$,(#10289));
#10292= IFCBEAM('1Td1iR001KQp4rDp0rCJ4s',#5,'KIRIS','WB300-16-30*90-0','WB300-16-30*90-0',#10237,#10291,'P/514(?)');
#10293= IFCBEAMTYPE('3EmrzH_7T40QusJKAG20Qk',#5,'WB300-16-30*90-0',$,$,$,$,$,$,.NOTDEFINED.);
#10294= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/514(?)'),$);
#10295= IFCPROPERTYSINGLEVALUE('Class',$,IFCLABEL('12'),$);
#10296= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('WB300-16-30*90-0'),$);
#10297= IFCPROPERTYSET('1CdFcEHuP9wfDXhEA5Rnqs',#5,'Tekla Common','Common Properties to Shared building elements',(#4931,#1052,#10294,#4268,#74,#75,#76,#10295,#78,#10296,#4185));
#10298= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(839.690636358212),$);
#10299= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(840.283157047233),$);
#10300= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(839.690636358212),$);
#10301= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.106966960045632),$);
#10302= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.107042440388183),$);
#10303= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.106966960045632),$);
#10304= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(2.45158653594338),$);
#10305= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(13.4335596343987),$);
#10306= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(11.2800342379643),$);
#10307= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(11.2868937900718),$);
#10308= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(300.000000001382),$);
#10309= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(8183.67281255223),$);
#10310= IFCPROPERTYSET('1zXjsG5bf4DPXayoO3RwJ4',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#4270,#10298,#10299,#10300,#10301,#10302,#10303,#10304,#10305,#10306,#10307,#10308,#5657,#10309));
#10311= IFCQUANTITYLENGTH('Length',$,$,8183.67281255223);
#10312= IFCQUANTITYAREA('OuterSurfaceArea',$,$,11.2800342379643);
#10313= IFCQUANTITYVOLUME('NetVolume',$,$,0.106966960045632);
#10314= IFCQUANTITYWEIGHT('NetWeight',$,$,839.690636358212);
#10315= IFCELEMENTQUANTITY('0yxrEfo$bF7PN8TZSV$bCo',#5,'BaseQuantities',$,$,(#10311,#10312,#10313,#10314));
#10316= IFCCARTESIANPOINT((48715.6782258153,-565.430250853508,10599.9961559069));
#10317= IFCAXIS2PLACEMENT3D(#10316,#5695,#5696);
#10318= IFCLOCALPLACEMENT(#30,#10317);
#10319= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#10320= IFCEXTRUDEDAREASOLID(#10319,#5701,#9,16.0000000001208);
#10321= IFCSTYLEDITEM(#10320,(#195),$);
#10322= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#10323= IFCEXTRUDEDAREASOLID(#10322,#5706,#9,16.0999999999994);
#10324= IFCSTYLEDITEM(#10323,(#195),$);
#10325= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#10326= IFCEXTRUDEDAREASOLID(#10325,#5711,#9,6.5);
#10327= IFCSTYLEDITEM(#10326,(#191),$);
#10328= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#10329= IFCEXTRUDEDAREASOLID(#10328,#5716,#9,50.);
#10330= IFCSTYLEDITEM(#10329,(#191),$);
#10331= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#10332= IFCEXTRUDEDAREASOLID(#10331,#5721,#9,2.5);
#10333= IFCSTYLEDITEM(#10332,(#191),$);
#10334= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#10335= IFCEXTRUDEDAREASOLID(#10334,#5726,#9,10.);
#10336= IFCSTYLEDITEM(#10335,(#191),$);
#10337= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#10320,#10323,#10326,#10329,#10332,#10335));
#10338= IFCREPRESENTATIONMAP(#10,#10337);
#10339= IFCMAPPEDITEM(#10338,#5730);
#10340= IFCMAPPEDITEM(#10338,#5735);
#10341= IFCMAPPEDITEM(#10338,#5738);
#10342= IFCMAPPEDITEM(#10338,#5741);
#10343= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#10339,#10340,#10341,#10342));
#10344= IFCPRODUCTDEFINITIONSHAPE($,$,(#10343));
#10345= IFCMECHANICALFASTENER('1Td1iR001KWZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#10318,#10344,'ID5d9c1b1b-0000-5482-3135-373035313136',12.,50.);
#10346= IFCCARTESIANPOINT((48728.8520000746,1525.00168046917,10594.9999999996));
#10347= IFCAXIS2PLACEMENT3D(#10346,#185,#8);
#10348= IFCLOCALPLACEMENT(#30,#10347);
#10349= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#10350= IFCEXTRUDEDAREASOLID(#10349,#4747,#9,16.000000000024);
#10351= IFCSTYLEDITEM(#10350,(#195),$);
#10352= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#10353= IFCEXTRUDEDAREASOLID(#10352,#4752,#9,16.0999999999995);
#10354= IFCSTYLEDITEM(#10353,(#195),$);
#10355= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#10356= IFCEXTRUDEDAREASOLID(#10355,#4757,#9,6.5);
#10357= IFCSTYLEDITEM(#10356,(#191),$);
#10358= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#10359= IFCEXTRUDEDAREASOLID(#10358,#4762,#9,50.);
#10360= IFCSTYLEDITEM(#10359,(#191),$);
#10361= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#10362= IFCEXTRUDEDAREASOLID(#10361,#4767,#9,2.5);
#10363= IFCSTYLEDITEM(#10362,(#191),$);
#10364= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#10365= IFCEXTRUDEDAREASOLID(#10364,#4772,#9,10.);
#10366= IFCSTYLEDITEM(#10365,(#191),$);
#10367= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#10350,#10353,#10356,#10359,#10362,#10365));
#10368= IFCREPRESENTATIONMAP(#10,#10367);
#10369= IFCMAPPEDITEM(#10368,#4776);
#10370= IFCMAPPEDITEM(#10368,#4781);
#10371= IFCMAPPEDITEM(#10368,#4784);
#10372= IFCMAPPEDITEM(#10368,#4787);
#10373= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#10369,#10370,#10371,#10372));
#10374= IFCPRODUCTDEFINITIONSHAPE($,$,(#10373));
#10375= IFCMECHANICALFASTENER('1Td1iR001KYJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#10348,#10374,'ID5d9c1b1b-0000-5489-3135-373035313136',12.,50.);
#10376= IFCCARTESIANPOINT((48728.8520000746,3715.00168046917,10594.9999999996));
#10377= IFCAXIS2PLACEMENT3D(#10376,#185,#8);
#10378= IFCLOCALPLACEMENT(#30,#10377);
#10379= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#10380= IFCEXTRUDEDAREASOLID(#10379,#4747,#9,16.000000000024);
#10381= IFCSTYLEDITEM(#10380,(#195),$);
#10382= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#10383= IFCEXTRUDEDAREASOLID(#10382,#4752,#9,16.0999999999995);
#10384= IFCSTYLEDITEM(#10383,(#195),$);
#10385= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#10386= IFCEXTRUDEDAREASOLID(#10385,#4757,#9,6.5);
#10387= IFCSTYLEDITEM(#10386,(#191),$);
#10388= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#10389= IFCEXTRUDEDAREASOLID(#10388,#4762,#9,50.);
#10390= IFCSTYLEDITEM(#10389,(#191),$);
#10391= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#10392= IFCEXTRUDEDAREASOLID(#10391,#4767,#9,2.5);
#10393= IFCSTYLEDITEM(#10392,(#191),$);
#10394= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#10395= IFCEXTRUDEDAREASOLID(#10394,#4772,#9,10.);
#10396= IFCSTYLEDITEM(#10395,(#191),$);
#10397= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#10380,#10383,#10386,#10389,#10392,#10395));
#10398= IFCREPRESENTATIONMAP(#10,#10397);
#10399= IFCMAPPEDITEM(#10398,#4776);
#10400= IFCMAPPEDITEM(#10398,#4781);
#10401= IFCMAPPEDITEM(#10398,#4784);
#10402= IFCMAPPEDITEM(#10398,#4787);
#10403= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#10399,#10400,#10401,#10402));
#10404= IFCPRODUCTDEFINITIONSHAPE($,$,(#10403));
#10405= IFCMECHANICALFASTENER('1Td1iR001Ka34rDp0rCJ4s',#5,'Bolt assembly',$,$,#10378,#10404,'ID5d9c1b1b-0000-5490-3135-373035313136',12.,50.);
#10406= IFCCARTESIANPOINT((48728.8520000746,4050.00168046917,10594.9999999996));
#10407= IFCAXIS2PLACEMENT3D(#10406,#185,#8);
#10408= IFCLOCALPLACEMENT(#30,#10407);
#10409= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#10410= IFCEXTRUDEDAREASOLID(#10409,#4747,#9,16.000000000024);
#10411= IFCSTYLEDITEM(#10410,(#195),$);
#10412= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#10413= IFCEXTRUDEDAREASOLID(#10412,#4752,#9,16.0999999999995);
#10414= IFCSTYLEDITEM(#10413,(#195),$);
#10415= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#10416= IFCEXTRUDEDAREASOLID(#10415,#4757,#9,6.5);
#10417= IFCSTYLEDITEM(#10416,(#191),$);
#10418= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#10419= IFCEXTRUDEDAREASOLID(#10418,#4762,#9,50.);
#10420= IFCSTYLEDITEM(#10419,(#191),$);
#10421= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#10422= IFCEXTRUDEDAREASOLID(#10421,#4767,#9,2.5);
#10423= IFCSTYLEDITEM(#10422,(#191),$);
#10424= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#10425= IFCEXTRUDEDAREASOLID(#10424,#4772,#9,10.);
#10426= IFCSTYLEDITEM(#10425,(#191),$);
#10427= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#10410,#10413,#10416,#10419,#10422,#10425));
#10428= IFCREPRESENTATIONMAP(#10,#10427);
#10429= IFCMAPPEDITEM(#10428,#4776);
#10430= IFCMAPPEDITEM(#10428,#4781);
#10431= IFCMAPPEDITEM(#10428,#4784);
#10432= IFCMAPPEDITEM(#10428,#4787);
#10433= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#10429,#10430,#10431,#10432));
#10434= IFCPRODUCTDEFINITIONSHAPE($,$,(#10433));
#10435= IFCMECHANICALFASTENER('1Td1iR001Kbp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#10408,#10434,'ID5d9c1b1b-0000-5497-3135-373035313136',12.,50.);
#10436= IFCCARTESIANPOINT((48728.8520000746,5320.00168046917,10594.9999999996));
#10437= IFCAXIS2PLACEMENT3D(#10436,#185,#8);
#10438= IFCLOCALPLACEMENT(#30,#10437);
#10439= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#10440= IFCEXTRUDEDAREASOLID(#10439,#4747,#9,16.000000000024);
#10441= IFCSTYLEDITEM(#10440,(#195),$);
#10442= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#10443= IFCEXTRUDEDAREASOLID(#10442,#4752,#9,16.0999999999995);
#10444= IFCSTYLEDITEM(#10443,(#195),$);
#10445= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#10446= IFCEXTRUDEDAREASOLID(#10445,#4757,#9,6.5);
#10447= IFCSTYLEDITEM(#10446,(#191),$);
#10448= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#10449= IFCEXTRUDEDAREASOLID(#10448,#4762,#9,50.);
#10450= IFCSTYLEDITEM(#10449,(#191),$);
#10451= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#10452= IFCEXTRUDEDAREASOLID(#10451,#4767,#9,2.5);
#10453= IFCSTYLEDITEM(#10452,(#191),$);
#10454= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#10455= IFCEXTRUDEDAREASOLID(#10454,#4772,#9,10.);
#10456= IFCSTYLEDITEM(#10455,(#191),$);
#10457= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#10440,#10443,#10446,#10449,#10452,#10455));
#10458= IFCREPRESENTATIONMAP(#10,#10457);
#10459= IFCMAPPEDITEM(#10458,#4776);
#10460= IFCMAPPEDITEM(#10458,#4781);
#10461= IFCMAPPEDITEM(#10458,#4784);
#10462= IFCMAPPEDITEM(#10458,#4787);
#10463= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#10459,#10460,#10461,#10462));
#10464= IFCPRODUCTDEFINITIONSHAPE($,$,(#10463));
#10465= IFCMECHANICALFASTENER('1Td1iR001KdZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#10438,#10464,'ID5d9c1b1b-0000-549e-3135-373035313136',12.,50.);
#10466= IFCCARTESIANPOINT((48728.8520000746,5655.00168046917,10594.9999999996));
#10467= IFCAXIS2PLACEMENT3D(#10466,#185,#8);
#10468= IFCLOCALPLACEMENT(#30,#10467);
#10469= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#10470= IFCEXTRUDEDAREASOLID(#10469,#4747,#9,16.000000000024);
#10471= IFCSTYLEDITEM(#10470,(#195),$);
#10472= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#10473= IFCEXTRUDEDAREASOLID(#10472,#4752,#9,16.0999999999995);
#10474= IFCSTYLEDITEM(#10473,(#195),$);
#10475= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#10476= IFCEXTRUDEDAREASOLID(#10475,#4757,#9,6.5);
#10477= IFCSTYLEDITEM(#10476,(#191),$);
#10478= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#10479= IFCEXTRUDEDAREASOLID(#10478,#4762,#9,50.);
#10480= IFCSTYLEDITEM(#10479,(#191),$);
#10481= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#10482= IFCEXTRUDEDAREASOLID(#10481,#4767,#9,2.5);
#10483= IFCSTYLEDITEM(#10482,(#191),$);
#10484= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#10485= IFCEXTRUDEDAREASOLID(#10484,#4772,#9,10.);
#10486= IFCSTYLEDITEM(#10485,(#191),$);
#10487= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#10470,#10473,#10476,#10479,#10482,#10485));
#10488= IFCREPRESENTATIONMAP(#10,#10487);
#10489= IFCMAPPEDITEM(#10488,#4776);
#10490= IFCMAPPEDITEM(#10488,#4781);
#10491= IFCMAPPEDITEM(#10488,#4784);
#10492= IFCMAPPEDITEM(#10488,#4787);
#10493= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#10489,#10490,#10491,#10492));
#10494= IFCPRODUCTDEFINITIONSHAPE($,$,(#10493));
#10495= IFCMECHANICALFASTENER('1Td1iR001KfJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#10468,#10494,'ID5d9c1b1b-0000-54a5-3135-373035313136',12.,50.);
#10496= IFCCARTESIANPOINT((48828.9996544548,-687.66991453126,10499.9999999999));
#10497= IFCAXIS2PLACEMENT3D(#10496,#501,#9);
#10498= IFCLOCALPLACEMENT(#4288,#10497);
#10499= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#10212));
#10500= IFCPRODUCTDEFINITIONSHAPE($,$,(#10499));
#10501= IFCDISCRETEACCESSORY('1Td1iR001KvZ4rDp0rCJ4s',#5,'Cap plate','PL3*90','PL3*90',#10498,#10500,'0(?)');
#10502= IFCPROPERTYSET('0XEhre_jzEQhuzfQ64CPxm',#5,'Tekla Common','Common Properties to Shared building elements',(#6417,#1267,#4436,#4268,#74,#75,#76,#77,#78,#4932,#4438));
#10503= IFCCARTESIANPOINT((48688.999523492,7497.50289578092,10544.9999999999));
#10504= IFCAXIS2PLACEMENT3D(#10503,#7,#501);
#10505= IFCLOCALPLACEMENT(#4288,#10504);
#10506= IFCEXTRUDEDAREASOLID(#10252,#10254,#9,8183.67281255218);
#10507= IFCPLANE(#10258);
#10508= IFCHALFSPACESOLID(#10507,.F.);
#10509= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#10506,#10508);
#10510= IFCPLANE(#10263);
#10511= IFCHALFSPACESOLID(#10510,.F.);
#10512= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#10509,#10511);
#10513= IFCPLANE(#10268);
#10514= IFCHALFSPACESOLID(#10513,.F.);
#10515= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#10512,#10514);
#10516= IFCPLANE(#10275);
#10517= IFCHALFSPACESOLID(#10516,.F.);
#10518= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#10515,#10517);
#10519= IFCPLANE(#10280);
#10520= IFCHALFSPACESOLID(#10519,.F.);
#10521= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#10518,#10520);
#10522= IFCPLANE(#10285);
#10523= IFCHALFSPACESOLID(#10522,.T.);
#10524= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#10521,#10523);
#10525= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#10524));
#10526= IFCSTYLEDITEM(#10506,(#10241),$);
#10527= IFCPRODUCTDEFINITIONSHAPE($,$,(#10525));
#10528= IFCBEAM('1Td1iR001KzJ4rDp0rCJ4s',#5,'KIRIS','WB300-16-30*90-0','WB300-16-30*90-0',#10505,#10527,'P/515(?)');
#10529= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/515(?)'),$);
#10530= IFCPROPERTYSET('0KAPJX6gj6uQMNgPwfV4xY',#5,'Tekla Common','Common Properties to Shared building elements',(#6417,#1267,#10529,#4268,#74,#75,#76,#10295,#78,#10296,#4185));
#10531= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(839.690636358212),$);
#10532= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(839.690636358212),$);
#10533= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.106966960045632),$);
#10534= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.106966960045632),$);
#10535= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(11.2800342379643),$);
#10536= IFCPROPERTYSET('37aaBVvk9DrAwGVi$nTZcU',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#4270,#10531,#10299,#10532,#10533,#10302,#10534,#10304,#10305,#10535,#10307,#10308,#5657,#10309));
#10537= IFCQUANTITYLENGTH('Length',$,$,8183.67281255223);
#10538= IFCQUANTITYAREA('OuterSurfaceArea',$,$,11.2800342379643);
#10539= IFCQUANTITYVOLUME('NetVolume',$,$,0.106966960045632);
#10540= IFCQUANTITYWEIGHT('NetWeight',$,$,839.690636358212);
#10541= IFCELEMENTQUANTITY('1vc4AVGGL9RuN$SAD6_wFd',#5,'BaseQuantities',$,$,(#10537,#10538,#10539,#10540));
#10542= IFCLOCALPLACEMENT(#30,#10);
#10543= IFCELEMENTASSEMBLY('1Td1iR001RI34rDp0rCJ4s',#5,'GROUT',$,$,#10542,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#10544= IFCCARTESIANPOINT((46874.9924353684,-424.171262843948,-7724.99935244928));
#10545= IFCAXIS2PLACEMENT3D(#10544,#4556,#501);
#10546= IFCLOCALPLACEMENT(#10542,#10545);
#10547= IFCBOOLEANRESULT(.DIFFERENCE.,#4568,#4576);
#10548= IFCBOOLEANRESULT(.DIFFERENCE.,#10547,#4586);
#10549= IFCBOOLEANRESULT(.DIFFERENCE.,#10548,#4596);
#10550= IFCBOOLEANRESULT(.DIFFERENCE.,#10549,#4601);
#10551= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#10550));
#10552= IFCPRODUCTDEFINITIONSHAPE($,$,(#10551));
#10553= IFCPLATE('1Td1iR001RHp4rDp0rCJ4s',#5,'GROUT','PL50*315','PL50*315',#10546,#10552,'XX/0(?)');
#10554= IFCPROPERTYSET('0LkQT4_erDwO1cH6zcEMXR',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#4615,#9536,#4617,#4618,#1744,#4619,#9216,#9217,#4622,#4623));
#10555= IFCQUANTITYLENGTH('Width',$,$,314.99801635749);
#10556= IFCQUANTITYAREA('NetArea',$,$,0.351328721197601);
#10557= IFCQUANTITYAREA('GrossArea',$,$,0.160649009700205);
#10558= IFCQUANTITYVOLUME('NetVolume',$,$,0.00613664384519452);
#10559= IFCQUANTITYVOLUME('GrossVolume',$,$,0.00803244941708981);
#10560= IFCELEMENTQUANTITY('1E0Jl6DnDF3PThQJZ2h0Lz',#5,'BaseQuantities',$,$,(#10555,#10556,#10557,#4628,#10558,#10559));
#10561= IFCLOCALPLACEMENT(#30,#10);
#10562= IFCELEMENTASSEMBLY('1Td1iR001RM34rDp0rCJ4s',#5,'GROUT',$,$,#10561,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#10563= IFCCARTESIANPOINT((45254.9924353684,-424.171262843948,-7724.99935244928));
#10564= IFCAXIS2PLACEMENT3D(#10563,#4556,#501);
#10565= IFCLOCALPLACEMENT(#10561,#10564);
#10566= IFCBOOLEANRESULT(.DIFFERENCE.,#4568,#4576);
#10567= IFCBOOLEANRESULT(.DIFFERENCE.,#10566,#4586);
#10568= IFCBOOLEANRESULT(.DIFFERENCE.,#10567,#4596);
#10569= IFCBOOLEANRESULT(.DIFFERENCE.,#10568,#4601);
#10570= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#10569));
#10571= IFCPRODUCTDEFINITIONSHAPE($,$,(#10570));
#10572= IFCPLATE('1Td1iR001RLp4rDp0rCJ4s',#5,'GROUT','PL50*315','PL50*315',#10565,#10571,'XX/0(?)');
#10573= IFCLOCALPLACEMENT(#30,#10);
#10574= IFCELEMENTASSEMBLY('1Td1iR001RQ34rDp0rCJ4s',#5,'GROUT',$,$,#10573,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#10575= IFCCARTESIANPOINT((43634.9924353684,-424.171262843948,-7724.99935244928));
#10576= IFCAXIS2PLACEMENT3D(#10575,#4556,#501);
#10577= IFCLOCALPLACEMENT(#10573,#10576);
#10578= IFCBOOLEANRESULT(.DIFFERENCE.,#4568,#4576);
#10579= IFCBOOLEANRESULT(.DIFFERENCE.,#10578,#4586);
#10580= IFCBOOLEANRESULT(.DIFFERENCE.,#10579,#4596);
#10581= IFCBOOLEANRESULT(.DIFFERENCE.,#10580,#4601);
#10582= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#10581));
#10583= IFCPRODUCTDEFINITIONSHAPE($,$,(#10582));
#10584= IFCPLATE('1Td1iR001RPp4rDp0rCJ4s',#5,'GROUT','PL50*315','PL50*315',#10577,#10583,'XX/0(?)');
#10585= IFCLOCALPLACEMENT(#30,#10);
#10586= IFCELEMENTASSEMBLY('1Td1iR001RU34rDp0rCJ4s',#5,'GROUT',$,$,#10585,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#10587= IFCCARTESIANPOINT((41204.9924353684,-424.171262843948,-7724.99935244928));
#10588= IFCAXIS2PLACEMENT3D(#10587,#4556,#501);
#10589= IFCLOCALPLACEMENT(#10585,#10588);
#10590= IFCBOOLEANRESULT(.DIFFERENCE.,#4568,#4576);
#10591= IFCBOOLEANRESULT(.DIFFERENCE.,#10590,#4586);
#10592= IFCBOOLEANRESULT(.DIFFERENCE.,#10591,#4596);
#10593= IFCBOOLEANRESULT(.DIFFERENCE.,#10592,#4601);
#10594= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#10593));
#10595= IFCPRODUCTDEFINITIONSHAPE($,$,(#10594));
#10596= IFCPLATE('1Td1iR001RTp4rDp0rCJ4s',#5,'GROUT','PL50*315','PL50*315',#10589,#10595,'XX/0(?)');
#10597= IFCLOCALPLACEMENT(#30,#10);
#10598= IFCELEMENTASSEMBLY('1Td1iR001Ro34rDp0rCJ4s',#5,'GROUT',$,$,#10597,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#10599= IFCPROPERTYSET('1RIVGGoVHB4BTdii3R$sM$',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#4549,#4550,#4551,#5197,#1701));
#10600= IFCCARTESIANPOINT((39584.9924353684,-424.171262843948,-7724.99935244928));
#10601= IFCAXIS2PLACEMENT3D(#10600,#4556,#501);
#10602= IFCLOCALPLACEMENT(#10597,#10601);
#10603= IFCBOOLEANRESULT(.DIFFERENCE.,#4568,#4576);
#10604= IFCBOOLEANRESULT(.DIFFERENCE.,#10603,#4586);
#10605= IFCBOOLEANRESULT(.DIFFERENCE.,#10604,#4596);
#10606= IFCBOOLEANRESULT(.DIFFERENCE.,#10605,#4601);
#10607= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#10606));
#10608= IFCPRODUCTDEFINITIONSHAPE($,$,(#10607));
#10609= IFCPLATE('1Td1iR001Rnp4rDp0rCJ4s',#5,'GROUT','PL50*315','PL50*315',#10602,#10608,'XX/0(?)');
#10610= IFCLOCALPLACEMENT(#30,#10);
#10611= IFCELEMENTASSEMBLY('1Td1iR001Rs34rDp0rCJ4s',#5,'GROUT',$,$,#10610,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#10612= IFCCARTESIANPOINT((40394.9924353684,-424.171262843948,-7724.99935244928));
#10613= IFCAXIS2PLACEMENT3D(#10612,#4556,#501);
#10614= IFCLOCALPLACEMENT(#10610,#10613);
#10615= IFCBOOLEANRESULT(.DIFFERENCE.,#4568,#4576);
#10616= IFCBOOLEANRESULT(.DIFFERENCE.,#10615,#4586);
#10617= IFCBOOLEANRESULT(.DIFFERENCE.,#10616,#4596);
#10618= IFCBOOLEANRESULT(.DIFFERENCE.,#10617,#4601);
#10619= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#10618));
#10620= IFCPRODUCTDEFINITIONSHAPE($,$,(#10619));
#10621= IFCPLATE('1Td1iR001Rrp4rDp0rCJ4s',#5,'GROUT','PL50*315','PL50*315',#10614,#10620,'XX/0(?)');
#10622= IFCCARTESIANPOINT((48693.9990985793,5270.00265207478,-41.0000000000628));
#10623= IFCAXIS2PLACEMENT3D(#10622,#8,#7);
#10624= IFCLOCALPLACEMENT(#30,#10623);
#10625= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#10626= IFCEXTRUDEDAREASOLID(#10625,#8796,#9,6.);
#10627= IFCSTYLEDITEM(#10626,(#195),$);
#10628= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#8817);
#10629= IFCEXTRUDEDAREASOLID(#10628,#8820,#9,6.1);
#10630= IFCSTYLEDITEM(#10629,(#195),$);
#10631= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3875);
#10632= IFCEXTRUDEDAREASOLID(#10631,#8825,#9,7.92);
#10633= IFCSTYLEDITEM(#10632,(#558),$);
#10634= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#10635= IFCEXTRUDEDAREASOLID(#10634,#8830,#9,35.);
#10636= IFCSTYLEDITEM(#10635,(#558),$);
#10637= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#10638= IFCEXTRUDEDAREASOLID(#10637,#8835,#9,8.);
#10639= IFCSTYLEDITEM(#10638,(#558),$);
#10640= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#10641= IFCEXTRUDEDAREASOLID(#10640,#8840,#9,10.);
#10642= IFCSTYLEDITEM(#10641,(#558),$);
#10643= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#10626,#10629,#10632,#10635,#10638,#10641));
#10644= IFCREPRESENTATIONMAP(#10,#10643);
#10645= IFCMAPPEDITEM(#10644,#247);
#10646= IFCMAPPEDITEM(#10644,#8847);
#10647= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#10645,#10646));
#10648= IFCPRODUCTDEFINITIONSHAPE($,$,(#10647));
#10649= IFCMECHANICALFASTENER('1Td1iR001U434rDp0rCJ4s',#5,'Bolt assembly',$,$,#10624,#10648,'ID5d9c1b1b-0000-5e10-3135-373035313136',12.,35.);
#10650= IFCLOCALPLACEMENT(#30,#10);
#10651= IFCELEMENTASSEMBLY('1Td1iR002jh34rDp0rCJ4s',#5,'Steel Assembly',$,$,#10650,$,'B/196(?)',.NOTDEFINED.,.RIGID_FRAME.);
#10652= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(31.3929115965641),$);
#10653= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('B/196(?)'),$);
#10654= IFCPROPERTYSET('1cYibRDr91w8qwYG3vv7yX',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#10652,#4019,#4020,#890,#2857,#10653));
#10655= IFCQUANTITYLENGTH('Width',$,$,90.0000000000036);
#10656= IFCELEMENTQUANTITY('0wBKxqfEPFrx55bago2FhG',#5,'BaseQuantities',$,$,(#10655));
#10657= IFCCARTESIANPOINT((48648.9997264565,5196.98534617901,-45.0000000000628));
#10658= IFCAXIS2PLACEMENT3D(#10657,#9,#7);
#10659= IFCLOCALPLACEMENT(#10650,#10658);
#10660= IFCRECTANGLEPROFILEDEF(.AREA.,'PLT6*70',#197,6.,70.);
#10661= IFCCARTESIANPOINT((180.,0.,0.));
#10662= IFCAXIS2PLACEMENT3D(#10661,#185,#501);
#10663= IFCEXTRUDEDAREASOLID(#10660,#10662,#9,180.);
#10664= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#10663));
#10665= IFCSTYLEDITEM(#10663,(#4032),$);
#10666= IFCPRODUCTDEFINITIONSHAPE($,$,(#10664));
#10667= IFCDISCRETEACCESSORY('1Td1iR001U6J4rDp0rCJ4s',#5,'DIKME','PLT6*70','PLT6*70',#10659,#10666,'P/474(?)');
#10668= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -0.080'),$);
#10669= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -0.010'),$);
#10670= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('B/196(?)'),$);
#10671= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PLT6*70'),$);
#10672= IFCPROPERTYSET('02JbMTbgH8mxOrnyEqNTXz',#5,'Tekla Common','Common Properties to Shared building elements',(#10668,#10669,#8875,#10670,#74,#75,#76,#4046,#78,#10671,#4048));
#10673= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(31.3929115965641),$);
#10674= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00108),$);
#10675= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(47.5179456071176),$);
#10676= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0282),$);
#10677= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0282),$);
#10678= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(70.),$);
#10679= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(180.),$);
#10680= IFCPROPERTYSET('0DgEF$MJX3wvaJujgLMLqv',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#10673,#10218,#10219,#10220,#10221,#10222,#10223,#10674,#10675,#10676,#10677,#10678,#4007,#10679));
#10681= IFCQUANTITYLENGTH('Length',$,$,180.);
#10682= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0282);
#10683= IFCQUANTITYWEIGHT('NetWeight',$,$,0.59346);
#10684= IFCELEMENTQUANTITY('1cMttnIlP9uuAcuFuV399e',#5,'BaseQuantities',$,$,(#10681,#10682,#10232,#10683));
#10685= IFCCARTESIANPOINT((48723.9989453515,5309.99593868759,-52.0000000000628));
#10686= IFCAXIS2PLACEMENT3D(#10685,#7,#501);
#10687= IFCLOCALPLACEMENT(#10650,#10686);
#10688= IFCEXTRUDEDAREASOLID(#8988,#8897,#9,110.010591308601);
#10689= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#10688));
#10690= IFCSTYLEDITEM(#10688,(#4077),$);
#10691= IFCPRODUCTDEFINITIONSHAPE($,$,(#10689));
#10692= IFCDISCRETEACCESSORY('1Td1iR001U7J4rDp0rCJ4s',#5,'DIKME','PLT6*150','PLT6*150',#10687,#10691,'P/471(?)');
#10693= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -0.055'),$);
#10694= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -0.049'),$);
#10695= IFCPROPERTYSET('2leFcvHRz5DvOdse$aUw5d',#5,'Tekla Common','Common Properties to Shared building elements',(#10693,#10694,#8905,#10670,#74,#75,#76,#4089,#78,#9001,#4048));
#10696= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.777224827595265),$);
#10697= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(0.777224827595571),$);
#10698= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.777224827595265),$);
#10699= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(9.90095321777408E-005),$);
#10700= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(9.90095321777408E-005),$);
#10701= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(9.90095321777408E-005),$);
#10702= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.0165015886962901),$);
#10703= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(46.4772910047779),$);
#10704= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0361233044882835),$);
#10705= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0361233044882835),$);
#10706= IFCPROPERTYSET('08a0XToDD4_QlbmBtLYtdo',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#10673,#10696,#10697,#10698,#10699,#10700,#10701,#10702,#10703,#10704,#10705,#3163,#3965,#8919));
#10707= IFCQUANTITYLENGTH('Length',$,$,110.010591308628);
#10708= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0361233044882835);
#10709= IFCQUANTITYVOLUME('NetVolume',$,$,9.90095321777408E-005);
#10710= IFCQUANTITYWEIGHT('NetWeight',$,$,0.777224827595265);
#10711= IFCELEMENTQUANTITY('3sXKr3BMn4DxPenIrwZYFP',#5,'BaseQuantities',$,$,(#10707,#10708,#10709,#10710));
#10712= IFCCARTESIANPOINT((48693.9991160191,4180.00134344404,-41.0000000000628));
#10713= IFCAXIS2PLACEMENT3D(#10712,#8,#7);
#10714= IFCLOCALPLACEMENT(#30,#10713);
#10715= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#10716= IFCEXTRUDEDAREASOLID(#10715,#8796,#9,6.);
#10717= IFCSTYLEDITEM(#10716,(#195),$);
#10718= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#10719= IFCEXTRUDEDAREASOLID(#10718,#8820,#9,6.1);
#10720= IFCSTYLEDITEM(#10719,(#195),$);
#10721= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3875);
#10722= IFCEXTRUDEDAREASOLID(#10721,#8825,#9,7.92);
#10723= IFCSTYLEDITEM(#10722,(#558),$);
#10724= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#10725= IFCEXTRUDEDAREASOLID(#10724,#8830,#9,35.);
#10726= IFCSTYLEDITEM(#10725,(#558),$);
#10727= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#10728= IFCEXTRUDEDAREASOLID(#10727,#8835,#9,8.);
#10729= IFCSTYLEDITEM(#10728,(#558),$);
#10730= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#10731= IFCEXTRUDEDAREASOLID(#10730,#8840,#9,10.);
#10732= IFCSTYLEDITEM(#10731,(#558),$);
#10733= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#10716,#10719,#10722,#10725,#10728,#10731));
#10734= IFCREPRESENTATIONMAP(#10,#10733);
#10735= IFCMAPPEDITEM(#10734,#247);
#10736= IFCMAPPEDITEM(#10734,#8847);
#10737= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#10735,#10736));
#10738= IFCPRODUCTDEFINITIONSHAPE($,$,(#10737));
#10739= IFCMECHANICALFASTENER('1Td1iR001UAZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#10714,#10738,'ID5d9c1b1b-0000-5e2a-3135-373035313136',12.,35.);
#10740= IFCCARTESIANPOINT((48648.9997415598,4253.01864789984,-45.0000000000628));
#10741= IFCAXIS2PLACEMENT3D(#10740,#9,#7);
#10742= IFCLOCALPLACEMENT(#10650,#10741);
#10743= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#10663));
#10744= IFCPRODUCTDEFINITIONSHAPE($,$,(#10743));
#10745= IFCDISCRETEACCESSORY('1Td1iR001UD34rDp0rCJ4s',#5,'DIKME','PLT6*70','PLT6*70',#10742,#10744,'P/474(?)');
#10746= IFCCARTESIANPOINT((48723.9989640711,4140.00805779121,-52.0000000000628));
#10747= IFCAXIS2PLACEMENT3D(#10746,#7,#8);
#10748= IFCLOCALPLACEMENT(#10650,#10747);
#10749= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#10688));
#10750= IFCPRODUCTDEFINITIONSHAPE($,$,(#10749));
#10751= IFCDISCRETEACCESSORY('1Td1iR001UE34rDp0rCJ4s',#5,'DIKME','PLT6*150','PLT6*150',#10748,#10750,'P/471(?)');
#10752= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(46.4772910047779),$);
#10753= IFCPROPERTYSET('39lCP6uEX9EO6fvSa1D2P3',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#10673,#10696,#10697,#10698,#10699,#10700,#10701,#10702,#10752,#10704,#10705,#3163,#3965,#8919));
#10754= IFCQUANTITYVOLUME('NetVolume',$,$,9.90095321777407E-005);
#10755= IFCQUANTITYWEIGHT('NetWeight',$,$,0.777224827595265);
#10756= IFCELEMENTQUANTITY('3cC3jLFnP2QRzJqpwFVTAG',#5,'BaseQuantities',$,$,(#10707,#10708,#10754,#10755));
#10757= IFCCARTESIANPOINT((48728.9992678068,4230.01425953138,-91.0000000000628));
#10758= IFCAXIS2PLACEMENT3D(#10757,#5201,#9);
#10759= IFCLOCALPLACEMENT(#8233,#10758);
#10760= IFCCARTESIANPOINT((30.,127.512260436818));
#10761= IFCCARTESIANPOINT((-30.,127.512260436818));
#10762= IFCCARTESIANPOINT((-30.,97.5122604368644));
#10763= IFCPOLYLINE((#54,#3980,#10760,#10761,#10762,#54,#54));
#10764= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL6*60',#10763);
#10765= IFCEXTRUDEDAREASOLID(#10764,#3942,#9,6.);
#10766= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#10765));
#10767= IFCSTYLEDITEM(#10765,(#53),$);
#10768= IFCPRODUCTDEFINITIONSHAPE($,$,(#10766));
#10769= IFCDISCRETEACCESSORY('1Td1iR001UEp4rDp0rCJ4s',#5,'DETAY','PL6*60','PL6*60',#10759,#10768,'P/396(?)');
#10770= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -0.121'),$);
#10771= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -0.061'),$);
#10772= IFCPROPERTYSET('2jTbkxOTD4GAuBjnoq85RZ',#5,'Tekla Common','Common Properties to Shared building elements',(#10770,#10771,#8952,#8262,#74,#75,#76,#77,#78,#3994,#921));
#10773= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.291457235995296),$);
#10774= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(0.360349647994939),$);
#10775= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.291457235995296),$);
#10776= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(3.71283103178721E-005),$);
#10777= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(3.71283103178721E-005),$);
#10778= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(3.71283103178721E-005),$);
#10779= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.000765073562621643),$);
#10780= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(49.6584462396482),$);
#10781= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0144733134848289),$);
#10782= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0076507356262195),$);
#10783= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(127.512260436992),$);
#10784= IFCPROPERTYSET('1GLWwxMqLCpRUht1VXteek',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#8265,#10773,#10774,#10775,#10776,#10777,#10778,#10779,#10780,#10781,#10782,#8966,#4007,#10783));
#10785= IFCQUANTITYAREA('NetArea',$,$,0.0144733134848289);
#10786= IFCQUANTITYAREA('GrossArea',$,$,0.0076507356262195);
#10787= IFCQUANTITYVOLUME('NetVolume',$,$,3.71283103178721E-005);
#10788= IFCQUANTITYVOLUME('GrossVolume',$,$,3.71283103178721E-005);
#10789= IFCELEMENTQUANTITY('0RRnjZVr96Oxtq5Y__RXaE',#5,'BaseQuantities',$,$,(#8970,#10785,#10786,#3971,#10787,#10788));
#10790= IFCCARTESIANPOINT((48733.9996173916,4102.49974759179,-58.0000000000628));
#10791= IFCAXIS2PLACEMENT3D(#10790,#7,#8);
#10792= IFCLOCALPLACEMENT(#8233,#10791);
#10793= IFCCARTESIANPOINT((127.514512019592,0.,0.));
#10794= IFCAXIS2PLACEMENT3D(#10793,#185,#501);
#10795= IFCEXTRUDEDAREASOLID(#8988,#10794,#9,127.514512019592);
#10796= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#10795));
#10797= IFCSTYLEDITEM(#10795,(#4032),$);
#10798= IFCPRODUCTDEFINITIONSHAPE($,$,(#10796));
#10799= IFCDISCRETEACCESSORY('1Td1iR001UFp4rDp0rCJ4s',#5,'DIKME','PLT6*150','PLT6*150',#10792,#10798,'P/465(?)');
#10800= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -0.061'),$);
#10801= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -0.055'),$);
#10802= IFCPROPERTYSET('2wE9MYgdr6g9Bad3IyfKer',#5,'Tekla Common','Common Properties to Shared building elements',(#10800,#10801,#8999,#8262,#74,#75,#76,#4046,#78,#9001,#4048));
#10803= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.900890027418418),$);
#10804= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(0.900890027418703),$);
#10805= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.900890027418418),$);
#10806= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000114763060817633),$);
#10807= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000114763060817633),$);
#10808= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000114763060817633),$);
#10809= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.0191271768029388),$);
#10810= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(46.1593829263234),$);
#10811= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0415845277501127),$);
#10812= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0415845277501127),$);
#10813= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(127.514512019614),$);
#10814= IFCPROPERTYSET('24LG2n9WH6zwT19ww0WOHF',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#8265,#10803,#10804,#10805,#10806,#10807,#10808,#10809,#10810,#10811,#10812,#3163,#3965,#10813));
#10815= IFCQUANTITYLENGTH('Length',$,$,127.514512019614);
#10816= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0415845277501127);
#10817= IFCQUANTITYVOLUME('NetVolume',$,$,0.000114763060817633);
#10818= IFCQUANTITYWEIGHT('NetWeight',$,$,0.900890027418418);
#10819= IFCELEMENTQUANTITY('1XAAqziB18yxJHCQH1E3bu',#5,'BaseQuantities',$,$,(#10815,#10816,#10817,#10818));
#10820= IFCCARTESIANPOINT((48728.9992678068,1425.0168347701,-90.9951132627654));
#10821= IFCDIRECTION((-0.999999999857381,-1.68889999925288E-005,5.89544323368093E-010));
#10822= IFCDIRECTION((0.,3.49070000159696E-005,0.999999999390751));
#10823= IFCAXIS2PLACEMENT3D(#10820,#10821,#10822);
#10824= IFCLOCALPLACEMENT(#9440,#10823);
#10825= IFCCARTESIANPOINT((30.0000858306977,127.485862731896));
#10826= IFCCARTESIANPOINT((-29.9999141693028,127.485862731886));
#10827= IFCCARTESIANPOINT((-29.9999141693049,97.4858627318961));
#10828= IFCPOLYLINE((#54,#3980,#10825,#10826,#10827,#54,#54));
#10829= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL6*60',#10828);
#10830= IFCEXTRUDEDAREASOLID(#10829,#3942,#9,6.);
#10831= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#10830));
#10832= IFCSTYLEDITEM(#10830,(#53),$);
#10833= IFCPRODUCTDEFINITIONSHAPE($,$,(#10831));
#10834= IFCDISCRETEACCESSORY('1Td1iR001UH34rDp0rCJ4s',#5,'DETAY','PL6*60','PL6*60',#10824,#10833,'P/396(?)');
#10835= IFCPROPERTYSET('1_oysoU1z8XBqHSQqAOXQ8',#5,'Tekla Common','Common Properties to Shared building elements',(#10770,#10771,#8952,#9453,#74,#75,#76,#77,#78,#3994,#921));
#10836= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.291401225420058),$);
#10837= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(0.360275105159484),$);
#10838= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.291401225420058),$);
#10839= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.000764915176391875),$);
#10840= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(49.6587657645775),$);
#10841= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0144706251966455),$);
#10842= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.00764915297578523),$);
#10843= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(60.0000000000094),$);
#10844= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(6.00000000093132),$);
#10845= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(127.485882929734),$);
#10846= IFCPROPERTYSET('2t1UZYZyf9GuidmY3YmY36',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#9455,#10836,#10837,#10838,#10776,#10777,#10778,#10839,#10840,#10841,#10842,#10843,#10844,#10845));
#10847= IFCQUANTITYLENGTH('Width',$,$,60.0000000000094);
#10848= IFCQUANTITYAREA('NetArea',$,$,0.0144706251966455);
#10849= IFCQUANTITYAREA('GrossArea',$,$,0.00764915297578523);
#10850= IFCQUANTITYVOLUME('NetVolume',$,$,3.71211752127462E-005);
#10851= IFCQUANTITYVOLUME('GrossVolume',$,$,3.71211752127462E-005);
#10852= IFCELEMENTQUANTITY('2RTrUtJs93$hs9Gl$d6Wh2',#5,'BaseQuantities',$,$,(#10847,#10848,#10849,#3971,#10850,#10851));
#10853= IFCCARTESIANPOINT((48693.9991160191,1475.03149615615,-40.9968590733656));
#10854= IFCDIRECTION((1.59999981468665E-008,0.999999999390751,-3.49070000136368E-005));
#10855= IFCAXIS2PLACEMENT3D(#10853,#10854,#7);
#10856= IFCLOCALPLACEMENT(#30,#10855);
#10857= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#10858= IFCEXTRUDEDAREASOLID(#10857,#8796,#9,5.99999999991621);
#10859= IFCSTYLEDITEM(#10858,(#195),$);
#10860= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#8817);
#10861= IFCEXTRUDEDAREASOLID(#10860,#8820,#9,6.09999999991761);
#10862= IFCSTYLEDITEM(#10861,(#195),$);
#10863= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3875);
#10864= IFCEXTRUDEDAREASOLID(#10863,#8825,#9,7.92);
#10865= IFCSTYLEDITEM(#10864,(#558),$);
#10866= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#10867= IFCEXTRUDEDAREASOLID(#10866,#8830,#9,35.);
#10868= IFCSTYLEDITEM(#10867,(#558),$);
#10869= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#10870= IFCEXTRUDEDAREASOLID(#10869,#8835,#9,8.);
#10871= IFCSTYLEDITEM(#10870,(#558),$);
#10872= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#10873= IFCEXTRUDEDAREASOLID(#10872,#8840,#9,10.);
#10874= IFCSTYLEDITEM(#10873,(#558),$);
#10875= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#10858,#10861,#10864,#10867,#10870,#10873));
#10876= IFCREPRESENTATIONMAP(#10,#10875);
#10877= IFCMAPPEDITEM(#10876,#247);
#10878= IFCMAPPEDITEM(#10876,#8847);
#10879= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#10877,#10878));
#10880= IFCPRODUCTDEFINITIONSHAPE($,$,(#10879));
#10881= IFCMECHANICALFASTENER('1Td1iR001UHp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#10856,#10880,'ID5d9c1b1b-0000-5e47-3135-373035313136',12.,35.);
#10882= IFCLOCALPLACEMENT(#30,#10);
#10883= IFCELEMENTASSEMBLY('1Td1iR002$MZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#10882,$,'DK/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#10884= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(0.593459999999933),$);
#10885= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -0.080'),$);
#10886= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -0.010'),$);
#10887= IFCPROPERTYSET('0RT1H9wHHBChaFcbs88khg',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#10884,#10885,#10886,#3925,#2857,#8070));
#10888= IFCQUANTITYLENGTH('Width',$,$,6.00000000003001);
#10889= IFCELEMENTQUANTITY('1_4Kwz7EX6Aw5pVulwTgMa',#5,'BaseQuantities',$,$,(#10888));
#10890= IFCCARTESIANPOINT((48648.9997415598,1402.01405211867,-44.9943102862794));
#10891= IFCAXIS2PLACEMENT3D(#10890,#10822,#7);
#10892= IFCLOCALPLACEMENT(#10882,#10891);
#10893= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#10663));
#10894= IFCPRODUCTDEFINITIONSHAPE($,$,(#10893));
#10895= IFCBEAM('1Td1iR001UIZ4rDp0rCJ4s',#5,'DIKME','PLT6*70','PLT6*70',#10892,#10894,'P/474(?)');
#10896= IFCBEAMTYPE('2HJCbzMA12PBQiKgzFUdta',#5,'PLT6*70',$,$,$,$,$,$,.NOTDEFINED.);
#10897= IFCPROPERTYSET('1Zvt8p$oX9_RXcbuZQlY1Q',#5,'Tekla Common','Common Properties to Shared building elements',(#10668,#10669,#8875,#8113,#74,#75,#919,#4046,#78,#10671,#4048));
#10898= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(0.593459999999933),$);
#10899= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(0.593460000000882),$);
#10900= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00108),$);
#10901= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(47.5179456071224),$);
#10902= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(70.0000000001012),$);
#10903= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(180.000000000007),$);
#10904= IFCPROPERTYSET('1HV5Tw7nHC498S5VIyQV9M',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#10898,#10218,#10899,#10220,#10221,#10222,#10223,#10900,#10901,#10676,#10677,#10902,#4007,#10903));
#10905= IFCQUANTITYLENGTH('Length',$,$,180.000000000007);
#10906= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0281999999999997);
#10907= IFCQUANTITYVOLUME('NetVolume',$,$,7.55999999999915E-005);
#10908= IFCQUANTITYWEIGHT('NetWeight',$,$,0.593459999999933);
#10909= IFCELEMENTQUANTITY('0JbrlkO3D3O9gBgRQWli81',#5,'BaseQuantities',$,$,(#10905,#10906,#10907,#10908));
#10910= IFCLOCALPLACEMENT(#30,#10);
#10911= IFCELEMENTASSEMBLY('1Td1iR002$MJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#10910,$,'DK/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#10912= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(0.777224827594989),$);
#10913= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -0.055'),$);
#10914= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -0.049'),$);
#10915= IFCPROPERTYSET('30rbLW_GH7UuLWb0ecVi6h',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#10912,#10913,#10914,#3925,#2857,#8070));
#10916= IFCQUANTITYLENGTH('Width',$,$,6.00000000009321);
#10917= IFCELEMENTQUANTITY('1dW44DHUf1MuPdQD$702Fm',#5,'BaseQuantities',$,$,(#10916));
#10918= IFCCARTESIANPOINT((48723.9989640711,1515.02439781231,-51.9982550957787));
#10919= IFCAXIS2PLACEMENT3D(#10918,#7,#8642);
#10920= IFCLOCALPLACEMENT(#10910,#10919);
#10921= IFCEXTRUDEDAREASOLID(#8988,#8897,#9,110.010591308573);
#10922= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#10921));
#10923= IFCSTYLEDITEM(#10921,(#4077),$);
#10924= IFCPRODUCTDEFINITIONSHAPE($,$,(#10922));
#10925= IFCBEAM('1Td1iR001UJJ4rDp0rCJ4s',#5,'DIKME','PLT6*150','PLT6*150',#10920,#10924,'P/471(?)');
#10926= IFCPROPERTYSET('3T0RX9XeX97gdDtC20mijW',#5,'Tekla Common','Common Properties to Shared building elements',(#10693,#10694,#8905,#8113,#74,#75,#919,#4089,#78,#9001,#4048));
#10927= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(0.777224827594989),$);
#10928= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(46.4772910047789),$);
#10929= IFCPROPERTYSET('1wKT9IhxP77wjrt5ChKN4M',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#10927,#10696,#10697,#10698,#10699,#10700,#10701,#10702,#10928,#10704,#10705,#529,#4007,#8919));
#10930= IFCQUANTITYLENGTH('Length',$,$,110.010591308588);
#10931= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0361233044882714);
#10932= IFCQUANTITYVOLUME('NetVolume',$,$,9.90095321777056E-005);
#10933= IFCQUANTITYWEIGHT('NetWeight',$,$,0.777224827594989);
#10934= IFCELEMENTQUANTITY('18c02DUmX5nAXVhrNARRh$',#5,'BaseQuantities',$,$,(#10930,#10931,#10932,#10933));
#10935= IFCCARTESIANPOINT((48733.9996173916,1552.50610388485,-57.9994770290077));
#10936= IFCDIRECTION((-1.59999808887568E-008,-0.999999999414188,3.42290000141635E-005));
#10937= IFCAXIS2PLACEMENT3D(#10935,#7,#10936);
#10938= IFCLOCALPLACEMENT(#9440,#10937);
#10939= IFCCARTESIANPOINT((127.488117352195,-7.10715514377349E-015,-3.16241182605579E-022));
#10940= IFCAXIS2PLACEMENT3D(#10939,#185,#501);
#10941= IFCEXTRUDEDAREASOLID(#8988,#10940,#9,127.488117352195);
#10942= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#10941));
#10943= IFCSTYLEDITEM(#10941,(#4032),$);
#10944= IFCPRODUCTDEFINITIONSHAPE($,$,(#10942));
#10945= IFCDISCRETEACCESSORY('1Td1iR001UKJ4rDp0rCJ4s',#5,'DIKME','PLT6*150','PLT6*150',#10938,#10944,'P/465(?)');
#10946= IFCPROPERTYSET('2CJpaDD4j5mQgddCMER1FD',#5,'Tekla Common','Common Properties to Shared building elements',(#10800,#10801,#8999,#9453,#74,#75,#76,#4046,#78,#9001,#4048));
#10947= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.900703549093351),$);
#10948= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(0.900703549093592),$);
#10949= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.900703549093351),$);
#10950= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.0191232176028292),$);
#10951= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(46.1597965898318),$);
#10952= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0415762926138887),$);
#10953= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0415762926138887),$);
#10954= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(127.48811735223),$);
#10955= IFCPROPERTYSET('3DXhl4zqX4WRe5IMLgqaRC',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#9455,#10947,#10948,#10949,#10806,#10807,#10808,#10950,#10951,#10952,#10953,#3163,#4007,#10954));
#10956= IFCQUANTITYLENGTH('Length',$,$,127.48811735223);
#10957= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0415762926138887);
#10958= IFCQUANTITYVOLUME('NetVolume',$,$,0.000114739305616987);
#10959= IFCQUANTITYWEIGHT('NetWeight',$,$,0.900703549093351);
#10960= IFCELEMENTQUANTITY('3_vC1PQ6LCgO$oCl_BxZ49',#5,'BaseQuantities',$,$,(#10956,#10957,#10958,#10959));
#10961= IFCCARTESIANPOINT((48693.9991160191,3665.01065655597,-41.0000000000628));
#10962= IFCAXIS2PLACEMENT3D(#10961,#8,#7);
#10963= IFCLOCALPLACEMENT(#30,#10962);
#10964= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#10965= IFCEXTRUDEDAREASOLID(#10964,#8796,#9,6.);
#10966= IFCSTYLEDITEM(#10965,(#195),$);
#10967= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#8817);
#10968= IFCEXTRUDEDAREASOLID(#10967,#8820,#9,6.1);
#10969= IFCSTYLEDITEM(#10968,(#195),$);
#10970= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3875);
#10971= IFCEXTRUDEDAREASOLID(#10970,#8825,#9,7.92);
#10972= IFCSTYLEDITEM(#10971,(#558),$);
#10973= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#10974= IFCEXTRUDEDAREASOLID(#10973,#8830,#9,35.);
#10975= IFCSTYLEDITEM(#10974,(#558),$);
#10976= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#10977= IFCEXTRUDEDAREASOLID(#10976,#8835,#9,8.);
#10978= IFCSTYLEDITEM(#10977,(#558),$);
#10979= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#10980= IFCEXTRUDEDAREASOLID(#10979,#8840,#9,10.);
#10981= IFCSTYLEDITEM(#10980,(#558),$);
#10982= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#10965,#10968,#10971,#10974,#10977,#10980));
#10983= IFCREPRESENTATIONMAP(#10,#10982);
#10984= IFCMAPPEDITEM(#10983,#247);
#10985= IFCMAPPEDITEM(#10983,#8847);
#10986= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#10984,#10985));
#10987= IFCPRODUCTDEFINITIONSHAPE($,$,(#10986));
#10988= IFCMECHANICALFASTENER('1Td1iR001ULJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#10963,#10987,'ID5d9c1b1b-0000-5e55-3135-373035313136',12.,35.);
#10989= IFCLOCALPLACEMENT(#30,#10);
#10990= IFCELEMENTASSEMBLY('1Td1iR002jip4rDp0rCJ4s',#5,'Steel Assembly',$,$,#10989,$,'B/197(?)',.NOTDEFINED.,.RIGID_FRAME.);
#10991= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(55.4953155921612),$);
#10992= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('B/197(?)'),$);
#10993= IFCPROPERTYSET('0Cmea3H2L3NPIFNEaGrTTj',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#10991,#4019,#4020,#890,#2857,#10992));
#10994= IFCCARTESIANPOINT((48648.9997415598,3591.99335210016,-45.0000000000628));
#10995= IFCAXIS2PLACEMENT3D(#10994,#9,#7);
#10996= IFCLOCALPLACEMENT(#10989,#10995);
#10997= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#10663));
#10998= IFCPRODUCTDEFINITIONSHAPE($,$,(#10997));
#10999= IFCDISCRETEACCESSORY('1Td1iR001UNZ4rDp0rCJ4s',#5,'DIKME','PLT6*70','PLT6*70',#10996,#10998,'P/474(?)');
#11000= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('B/197(?)'),$);
#11001= IFCPROPERTYSET('2b7qGZgmj7M9s0eFOknyq6',#5,'Tekla Common','Common Properties to Shared building elements',(#10668,#10669,#8875,#11000,#74,#75,#76,#4046,#78,#10671,#4048));
#11002= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(55.4953155921612),$);
#11003= IFCPROPERTYSET('1FFrJrvoLD_gQ8aoTKetPD',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#11002,#10218,#10219,#10220,#10221,#10222,#10223,#10674,#10901,#10676,#10677,#10678,#4007,#10679));
#11004= IFCQUANTITYVOLUME('NetVolume',$,$,7.56E-005);
#11005= IFCQUANTITYWEIGHT('NetWeight',$,$,0.59346);
#11006= IFCELEMENTQUANTITY('15QsTCSbvBEB0zQJHGKMoz',#5,'BaseQuantities',$,$,(#10681,#10682,#11004,#11005));
#11007= IFCCARTESIANPOINT((48723.9989640711,3705.00394220879,-52.0000000000628));
#11008= IFCAXIS2PLACEMENT3D(#11007,#7,#501);
#11009= IFCLOCALPLACEMENT(#10989,#11008);
#11010= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#10688));
#11011= IFCPRODUCTDEFINITIONSHAPE($,$,(#11010));
#11012= IFCDISCRETEACCESSORY('1Td1iR001UOZ4rDp0rCJ4s',#5,'DIKME','PLT6*150','PLT6*150',#11009,#11011,'P/471(?)');
#11013= IFCPROPERTYSET('0FNulHWarDVegn5e9zcODX',#5,'Tekla Common','Common Properties to Shared building elements',(#10693,#10694,#8905,#11000,#74,#75,#76,#4089,#78,#9001,#4048));
#11014= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.777224827595268),$);
#11015= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.777224827595268),$);
#11016= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(9.90095321777412E-005),$);
#11017= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(9.90095321777412E-005),$);
#11018= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(9.90095321777412E-005),$);
#11019= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.0165015886962901),$);
#11020= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0361233044882836),$);
#11021= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0361233044882836),$);
#11022= IFCPROPERTYSET('2gRJJn55r43x_Q1M$hu3AL',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#11002,#11014,#10697,#11015,#11016,#11017,#11018,#11019,#10752,#11020,#11021,#3163,#3965,#8919));
#11023= IFCQUANTITYLENGTH('Length',$,$,110.010591308629);
#11024= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0361233044882836);
#11025= IFCQUANTITYVOLUME('NetVolume',$,$,9.90095321777411E-005);
#11026= IFCQUANTITYWEIGHT('NetWeight',$,$,0.777224827595268);
#11027= IFCELEMENTQUANTITY('1Ts_FsW9D4zwdbWLy9LyoF',#5,'BaseQuantities',$,$,(#11023,#11024,#11025,#11026));
#11028= IFCLOCALPLACEMENT(#30,#10);
#11029= IFCELEMENTASSEMBLY('1Td1iR001UPp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#11028,$,'B/164(?)',.NOTDEFINED.,.RIGID_FRAME.);
#11030= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(0.291435195601502),$);
#11031= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -0.121'),$);
#11032= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -0.061'),$);
#11033= IFCPROPERTYSET('3bpZNfWPnEIRR66yS$R58T',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#11030,#11031,#11032,#4310,#2857,#8931));
#11034= IFCQUANTITYLENGTH('Width',$,$,6.00000000000728);
#11035= IFCELEMENTQUANTITY('2B0HJkkB9319M1tA7_Z$JU',#5,'BaseQuantities',$,$,(#11034));
#11036= IFCCARTESIANPOINT((48728.9992678068,3614.99774046863,-91.0000000000628));
#11037= IFCAXIS2PLACEMENT3D(#11036,#10821,#9);
#11038= IFCLOCALPLACEMENT(#11028,#11037);
#11039= IFCCARTESIANPOINT((30.,127.501861572095));
#11040= IFCCARTESIANPOINT((-30.,127.501861572095));
#11041= IFCCARTESIANPOINT((-30.,97.5018615721347));
#11042= IFCPOLYLINE((#54,#3980,#11039,#11040,#11041,#54,#54));
#11043= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL6*60',#11042);
#11044= IFCEXTRUDEDAREASOLID(#11043,#3942,#9,6.);
#11045= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#11044));
#11046= IFCSTYLEDITEM(#11044,(#53),$);
#11047= IFCPRODUCTDEFINITIONSHAPE($,$,(#11045));
#11048= IFCPLATE('1Td1iR001UPZ4rDp0rCJ4s',#5,'DETAY','PL6*60','PL6*60',#11038,#11047,'P/396(?)');
#11049= IFCPROPERTYSET('02LvJxP3L6euQUTT_AS6xh',#5,'Tekla Common','Common Properties to Shared building elements',(#10770,#10771,#8952,#8953,#74,#75,#76,#77,#78,#3994,#921));
#11050= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(0.291435195601502),$);
#11051= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.291435195601502),$);
#11052= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(0.360320260803164),$);
#11053= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.291435195601502),$);
#11054= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(49.658571709126),$);
#11055= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0144722555593404),$);
#11056= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.00765011169433468),$);
#11057= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(127.501861572245),$);
#11058= IFCPROPERTYSET('1JM45vCFbC$vGzUJucTaW2',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#11050,#11051,#11052,#11053,#10776,#10777,#10778,#10779,#11054,#11055,#11056,#8966,#4007,#11057));
#11059= IFCQUANTITYAREA('NetArea',$,$,0.0144722555593404);
#11060= IFCQUANTITYAREA('GrossArea',$,$,0.00765011169433468);
#11061= IFCQUANTITYVOLUME('NetVolume',$,$,3.71255026243952E-005);
#11062= IFCQUANTITYVOLUME('GrossVolume',$,$,3.71255026243952E-005);
#11063= IFCELEMENTQUANTITY('3oz9BE5eb9Mviwqu1h7i99',#5,'BaseQuantities',$,$,(#8970,#11059,#11060,#3971,#11061,#11062));
#11064= IFCLOCALPLACEMENT(#30,#10);
#11065= IFCELEMENTASSEMBLY('1Td1iR001UQp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#11064,$,'DK/90(?)',.NOTDEFINED.,.RIGID_FRAME.);
#11066= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(0.900816589103824),$);
#11067= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -0.061'),$);
#11068= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -0.055'),$);
#11069= IFCPROPERTYSET('36ELzFcIXBgRwMRGSgOJRE',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#11066,#11067,#11068,#3925,#2857,#8981));
#11070= IFCCARTESIANPOINT((48733.9996173916,3742.50185774231,-58.0000000000628));
#11071= IFCAXIS2PLACEMENT3D(#11070,#7,#501);
#11072= IFCLOCALPLACEMENT(#11064,#11071);
#11073= IFCCARTESIANPOINT((127.50411735369,0.,-4.21875735582634E-022));
#11074= IFCAXIS2PLACEMENT3D(#11073,#185,#501);
#11075= IFCEXTRUDEDAREASOLID(#8988,#11074,#9,127.50411735369);
#11076= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#11075));
#11077= IFCSTYLEDITEM(#11075,(#4032),$);
#11078= IFCPRODUCTDEFINITIONSHAPE($,$,(#11076));
#11079= IFCBEAM('1Td1iR001UQZ4rDp0rCJ4s',#5,'DIKME','PLT6*150','PLT6*150',#11072,#11078,'P/465(?)');
#11080= IFCPROPERTYSET('2yBa0FInP0OREspCT6reiY',#5,'Tekla Common','Common Properties to Shared building elements',(#10800,#10801,#8999,#9000,#74,#75,#76,#4046,#78,#9001,#4048));
#11081= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(0.900816589103824),$);
#11082= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.900816589103824),$);
#11083= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(0.900816589104161),$);
#11084= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.900816589103824),$);
#11085= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.0191256176030535),$);
#11086= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(46.1595458135585),$);
#11087= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0415812846143515),$);
#11088= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0415812846143515),$);
#11089= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(127.50411735372),$);
#11090= IFCPROPERTYSET('1DhRZVnP14SwCukcFzEN81',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#11081,#11082,#11083,#11084,#10806,#10807,#10808,#11085,#11086,#11087,#11088,#3163,#3965,#11089));
#11091= IFCQUANTITYLENGTH('Length',$,$,127.50411735372);
#11092= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0415812846143515);
#11093= IFCQUANTITYVOLUME('NetVolume',$,$,0.000114753705618322);
#11094= IFCQUANTITYWEIGHT('NetWeight',$,$,0.900816589103824);
#11095= IFCELEMENTQUANTITY('38$QXRczH4tOt9XPU9X3wr',#5,'BaseQuantities',$,$,(#11091,#11092,#11093,#11094));
#11096= IFCCARTESIANPOINT((48693.9991160191,1654.99334344404,-41.0000000000628));
#11097= IFCAXIS2PLACEMENT3D(#11096,#8,#7);
#11098= IFCLOCALPLACEMENT(#30,#11097);
#11099= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#11100= IFCEXTRUDEDAREASOLID(#11099,#8796,#9,6.);
#11101= IFCSTYLEDITEM(#11100,(#195),$);
#11102= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#11103= IFCEXTRUDEDAREASOLID(#11102,#8820,#9,6.1);
#11104= IFCSTYLEDITEM(#11103,(#195),$);
#11105= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3875);
#11106= IFCEXTRUDEDAREASOLID(#11105,#8825,#9,7.92);
#11107= IFCSTYLEDITEM(#11106,(#558),$);
#11108= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#11109= IFCEXTRUDEDAREASOLID(#11108,#8830,#9,35.);
#11110= IFCSTYLEDITEM(#11109,(#558),$);
#11111= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#11112= IFCEXTRUDEDAREASOLID(#11111,#8835,#9,8.);
#11113= IFCSTYLEDITEM(#11112,(#558),$);
#11114= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#11115= IFCEXTRUDEDAREASOLID(#11114,#8840,#9,10.);
#11116= IFCSTYLEDITEM(#11115,(#558),$);
#11117= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#11100,#11103,#11106,#11109,#11112,#11115));
#11118= IFCREPRESENTATIONMAP(#10,#11117);
#11119= IFCMAPPEDITEM(#11118,#247);
#11120= IFCMAPPEDITEM(#11118,#8847);
#11121= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#11119,#11120));
#11122= IFCPRODUCTDEFINITIONSHAPE($,$,(#11121));
#11123= IFCMECHANICALFASTENER('1Td1iR001US34rDp0rCJ4s',#5,'Bolt assembly',$,$,#11098,#11122,'ID5d9c1b1b-0000-5e70-3135-373035313136',12.,35.);
#11124= IFCCARTESIANPOINT((48648.9997415598,1728.01064789984,-45.0000000000628));
#11125= IFCAXIS2PLACEMENT3D(#11124,#9,#7);
#11126= IFCLOCALPLACEMENT(#10989,#11125);
#11127= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#10663));
#11128= IFCPRODUCTDEFINITIONSHAPE($,$,(#11127));
#11129= IFCDISCRETEACCESSORY('1Td1iR001UUJ4rDp0rCJ4s',#5,'DIKME','PLT6*70','PLT6*70',#11126,#11128,'P/474(?)');
#11130= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.59346),$);
#11131= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.59346),$);
#11132= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(7.56E-005),$);
#11133= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(7.56E-005),$);
#11134= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(7.56E-005),$);
#11135= IFCPROPERTYSET('2C$rJkUOHDsuKC3dxqojeL',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#11002,#11130,#10899,#11131,#11132,#11133,#11134,#10674,#10675,#10676,#10677,#10678,#4007,#10903));
#11136= IFCQUANTITYVOLUME('NetVolume',$,$,7.56E-005);
#11137= IFCQUANTITYWEIGHT('NetWeight',$,$,0.59346);
#11138= IFCELEMENTQUANTITY('2LPkUTwiD6YvOGkRl0lQl0',#5,'BaseQuantities',$,$,(#10905,#10682,#11136,#11137));
#11139= IFCCARTESIANPOINT((48723.9989640711,1615.00005779121,-52.0000000000628));
#11140= IFCAXIS2PLACEMENT3D(#11139,#7,#8);
#11141= IFCLOCALPLACEMENT(#10989,#11140);
#11142= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#10688));
#11143= IFCPRODUCTDEFINITIONSHAPE($,$,(#11142));
#11144= IFCDISCRETEACCESSORY('1Td1iR001UV34rDp0rCJ4s',#5,'DIKME','PLT6*150','PLT6*150',#11141,#11143,'P/471(?)');
#11145= IFCPROPERTYSET('19JgkIRuX3pfZAQxQJA9Y4',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#11002,#10696,#10697,#10698,#10699,#10700,#10701,#10702,#10752,#10704,#10705,#529,#3965,#8919));
#11146= IFCQUANTITYLENGTH('Length',$,$,110.010591308628);
#11147= IFCELEMENTQUANTITY('1lMxmzxHjB8woVDlvTMAqZ',#5,'BaseQuantities',$,$,(#11146,#10708,#10754,#10755));
#11148= IFCCARTESIANPOINT((48728.9992678068,1705.00625953138,-91.0000000000628));
#11149= IFCAXIS2PLACEMENT3D(#11148,#5201,#9);
#11150= IFCLOCALPLACEMENT(#9440,#11149);
#11151= IFCCARTESIANPOINT((30.,127.503868103031));
#11152= IFCCARTESIANPOINT((-30.,127.503868103031));
#11153= IFCCARTESIANPOINT((-30.,97.5038681030301));
#11154= IFCPOLYLINE((#54,#3980,#11151,#11152,#11153,#54,#54));
#11155= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL6*60',#11154);
#11156= IFCEXTRUDEDAREASOLID(#11155,#3942,#9,6.);
#11157= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#11156));
#11158= IFCSTYLEDITEM(#11156,(#53),$);
#11159= IFCPRODUCTDEFINITIONSHAPE($,$,(#11157));
#11160= IFCDISCRETEACCESSORY('1Td1iR001UVp4rDp0rCJ4s',#5,'DETAY','PL6*60','PL6*60',#11150,#11159,'P/396(?)');
#11161= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.291439448443498),$);
#11162= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(0.360325931259177),$);
#11163= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.291439448443498),$);
#11164= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(49.6585474973254),$);
#11165= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0144724596931257),$);
#11166= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0076502320861821),$);
#11167= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(127.503868103035),$);
#11168= IFCPROPERTYSET('0_ZF9VVRnE_fr93qIhcg8W',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#9455,#11161,#11162,#11163,#10776,#10777,#10778,#10779,#11164,#11165,#11166,#8966,#4007,#11167));
#11169= IFCQUANTITYAREA('NetArea',$,$,0.0144724596931257);
#11170= IFCQUANTITYAREA('GrossArea',$,$,0.0076502320861821);
#11171= IFCQUANTITYVOLUME('NetVolume',$,$,3.71260443877067E-005);
#11172= IFCQUANTITYVOLUME('GrossVolume',$,$,3.71260443877067E-005);
#11173= IFCELEMENTQUANTITY('3kJwbaQJnA09YDP1UiPVLy',#5,'BaseQuantities',$,$,(#8970,#11169,#11170,#3971,#11171,#11172));
#11174= IFCCARTESIANPOINT((48733.9996173916,1577.5001422577,-58.0000000000628));
#11175= IFCAXIS2PLACEMENT3D(#11174,#7,#8);
#11176= IFCLOCALPLACEMENT(#9440,#11175);
#11177= IFCCARTESIANPOINT((127.50611735369,0.,0.));
#11178= IFCAXIS2PLACEMENT3D(#11177,#185,#501);
#11179= IFCEXTRUDEDAREASOLID(#8988,#11178,#9,127.50611735369);
#11180= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#11179));
#11181= IFCSTYLEDITEM(#11179,(#4032),$);
#11182= IFCPRODUCTDEFINITIONSHAPE($,$,(#11180));
#11183= IFCDISCRETEACCESSORY('1Td1iR001UWZ4rDp0rCJ4s',#5,'DIKME','PLT6*150','PLT6*150',#11176,#11182,'P/465(?)');
#11184= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.900830719103819),$);
#11185= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(0.900830719104046),$);
#11186= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.900830719103819),$);
#11187= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.0191259176030535),$);
#11188= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(46.1595144709525),$);
#11189= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0415819086143512),$);
#11190= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0415819086143512),$);
#11191= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(127.506117353716),$);
#11192= IFCPROPERTYSET('06flw$yDn0DxDKBbkxqeAL',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#9455,#11184,#11185,#11186,#10806,#10807,#10808,#11187,#11188,#11189,#11190,#529,#3965,#11191));
#11193= IFCQUANTITYLENGTH('Length',$,$,127.506117353716);
#11194= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0415819086143512);
#11195= IFCQUANTITYVOLUME('NetVolume',$,$,0.000114755505618321);
#11196= IFCQUANTITYWEIGHT('NetWeight',$,$,0.900830719103819);
#11197= IFCELEMENTQUANTITY('0SQDsXOxXEiBdVigBK40J2',#5,'BaseQuantities',$,$,(#11193,#11194,#11195,#11196));
#11198= IFCCARTESIANPOINT((48753.9994348061,8334.99912161408,4875.));
#11199= IFCAXIS2PLACEMENT3D(#11198,#501,#185);
#11200= IFCLOCALPLACEMENT(#30,#11199);
#11201= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#11202= IFCCARTESIANPOINT((0.,-34.8999999999781,0.));
#11203= IFCAXIS2PLACEMENT3D(#11202,#8,#7);
#11204= IFCEXTRUDEDAREASOLID(#11201,#11203,#9,20.);
#11205= IFCSTYLEDITEM(#11204,(#195),$);
#11206= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#11207= IFCCARTESIANPOINT((0.,-15.0999999999491,0.));
#11208= IFCAXIS2PLACEMENT3D(#11207,#8,#7);
#11209= IFCEXTRUDEDAREASOLID(#11206,#11208,#9,74.1000000000001);
#11210= IFCSTYLEDITEM(#11209,(#195),$);
#11211= IFCPOLYLINE((#1714,#1713,#1712,#1717,#1716,#1715,#1714));
#11212= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#11211);
#11213= IFCCARTESIANPOINT((0.,-48.1999999999781,0.));
#11214= IFCAXIS2PLACEMENT3D(#11213,#8,#7);
#11215= IFCEXTRUDEDAREASOLID(#11212,#11214,#9,13.2);
#11216= IFCSTYLEDITEM(#11215,(#558),$);
#11217= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,10.);
#11218= IFCCARTESIANPOINT((0.,-34.9999999999781,0.));
#11219= IFCAXIS2PLACEMENT3D(#11218,#8,#7);
#11220= IFCEXTRUDEDAREASOLID(#11217,#11219,#9,125.);
#11221= IFCSTYLEDITEM(#11220,(#558),$);
#11222= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,18.);
#11223= IFCCARTESIANPOINT((0.,59.0000000000509,0.));
#11224= IFCAXIS2PLACEMENT3D(#11223,#8,#7);
#11225= IFCEXTRUDEDAREASOLID(#11222,#11224,#9,8.);
#11226= IFCSTYLEDITEM(#11225,(#558),$);
#11227= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#11211);
#11228= IFCCARTESIANPOINT((0.,67.0000000000509,0.));
#11229= IFCAXIS2PLACEMENT3D(#11228,#8,#7);
#11230= IFCEXTRUDEDAREASOLID(#11227,#11229,#9,16.);
#11231= IFCSTYLEDITEM(#11230,(#558),$);
#11232= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#11204,#11209,#11215,#11220,#11225,#11230));
#11233= IFCREPRESENTATIONMAP(#10,#11232);
#11234= IFCMAPPEDITEM(#11233,#5738);
#11235= IFCCARTESIANPOINT((100.,0.,60.));
#11236= IFCCARTESIANTRANSFORMATIONOPERATOR3D($,$,#11235,$,$);
#11237= IFCMAPPEDITEM(#11233,#11236);
#11238= IFCMAPPEDITEM(#11233,#5730);
#11239= IFCCARTESIANPOINT((100.,0.,-60.));
#11240= IFCCARTESIANTRANSFORMATIONOPERATOR3D($,$,#11239,$,$);
#11241= IFCMAPPEDITEM(#11233,#11240);
#11242= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#11234,#11237,#11238,#11241));
#11243= IFCPRODUCTDEFINITIONSHAPE($,$,(#11242));
#11244= IFCMECHANICALFASTENER('1Td1iR002nip4rDp0rCJ4s',#5,'Bolt assembly',$,$,#11200,#11243,'ID5d9c1b1b-0000-b1b3-3135-373035313136',20.,125.);
#11245= IFCPROPERTYSINGLEVALUE('Bolt size',$,IFCLENGTHMEASURE(20.),$);
#11246= IFCPROPERTYSINGLEVALUE('Bolt length',$,IFCLENGTHMEASURE(125.),$);
#11247= IFCPROPERTYSINGLEVALUE('Bolt Name',$,IFCLABEL('BOLT20*125'),$);
#11248= IFCPROPERTYSET('1LQ4hP$bbCp9qA4t31hOec',#5,'Tekla Bolt','Bolt Properties',(#255,#611,#571,#612,#259,#573,#613,#262,#263,#614,#265,#266,#11245,#11246,#579,#11247));
#11249= IFCCARTESIANPOINT((48899.487295951,-679.133991697426,-1110.00000000002));
#11250= IFCAXIS2PLACEMENT3D(#11249,#4471,#596);
#11251= IFCLOCALPLACEMENT(#1450,#11250);
#11252= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#4926));
#11253= IFCPRODUCTDEFINITIONSHAPE($,$,(#11252));
#11254= IFCDISCRETEACCESSORY('1Td1iR002nC34rDp0rCJ4s',#5,'Cap plate','PL3*90','PL3*90',#11251,#11253,'0(?)');
#11255= IFCPROPERTYSET('0CeLsYQUr9rOcQwMmwGU3d',#5,'Tekla Common','Common Properties to Shared building elements',(#7177,#1521,#4436,#1465,#74,#75,#919,#77,#78,#4932,#4438));
#11256= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.466290000000576),$);
#11257= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(0.466290000000029),$);
#11258= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.466290000000576),$);
#11259= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(5.94000000000733E-005),$);
#11260= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(5.94000000000733E-005),$);
#11261= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(5.94000000000733E-005),$);
#11262= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0414600000000032),$);
#11263= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0198000000000012),$);
#11264= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(220.000000000014),$);
#11265= IFCPROPERTYSET('1nhnLIy7zCael1Ul1wZ6r5',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1467,#11256,#11257,#11258,#11259,#11260,#11261,#4940,#4941,#11262,#11263,#4944,#4945,#11264));
#11266= IFCQUANTITYAREA('NetArea',$,$,0.0414600000000032);
#11267= IFCQUANTITYAREA('GrossArea',$,$,0.0198000000000012);
#11268= IFCQUANTITYVOLUME('NetVolume',$,$,5.94000000000733E-005);
#11269= IFCQUANTITYVOLUME('GrossVolume',$,$,5.94000000000733E-005);
#11270= IFCELEMENTQUANTITY('2Yl09hRhH3YwIYTOr_Lao9',#5,'BaseQuantities',$,$,(#893,#11266,#11267,#4457,#11268,#11269));
#11271= IFCCARTESIANPOINT((46709.9908824261,-544.167860465528,-7145.00381020165));
#11272= IFCAXIS2PLACEMENT3D(#11271,#7,#501);
#11273= IFCLOCALPLACEMENT(#30,#11272);
#11274= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#11275= IFCCARTESIANPOINT((0.,10.0999999998181,0.));
#11276= IFCAXIS2PLACEMENT3D(#11275,#8,#7);
#11277= IFCEXTRUDEDAREASOLID(#11274,#11276,#9,6.);
#11278= IFCSTYLEDITEM(#11277,(#195),$);
#11279= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#11280= IFCCARTESIANPOINT((0.,15.8999999996726,0.));
#11281= IFCAXIS2PLACEMENT3D(#11280,#8,#7);
#11282= IFCEXTRUDEDAREASOLID(#11279,#11281,#9,6.1);
#11283= IFCSTYLEDITEM(#11282,(#195),$);
#11284= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3875);
#11285= IFCCARTESIANPOINT((0.,2.0799999998181,0.));
#11286= IFCAXIS2PLACEMENT3D(#11285,#8,#7);
#11287= IFCEXTRUDEDAREASOLID(#11284,#11286,#9,7.92);
#11288= IFCSTYLEDITEM(#11287,(#558),$);
#11289= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#11290= IFCCARTESIANPOINT((0.,9.9999999998181,0.));
#11291= IFCAXIS2PLACEMENT3D(#11290,#8,#7);
#11292= IFCEXTRUDEDAREASOLID(#11289,#11291,#9,35.);
#11293= IFCSTYLEDITEM(#11292,(#558),$);
#11294= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#11295= IFCCARTESIANPOINT((0.,21.9999999996726,0.));
#11296= IFCAXIS2PLACEMENT3D(#11295,#8,#7);
#11297= IFCEXTRUDEDAREASOLID(#11294,#11296,#9,8.);
#11298= IFCSTYLEDITEM(#11297,(#558),$);
#11299= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#11300= IFCCARTESIANPOINT((0.,29.9999999996726,0.));
#11301= IFCAXIS2PLACEMENT3D(#11300,#8,#7);
#11302= IFCEXTRUDEDAREASOLID(#11299,#11301,#9,10.);
#11303= IFCSTYLEDITEM(#11302,(#558),$);
#11304= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#11277,#11282,#11287,#11292,#11297,#11302));
#11305= IFCREPRESENTATIONMAP(#10,#11304);
#11306= IFCMAPPEDITEM(#11305,#247);
#11307= IFCMAPPEDITEM(#11305,#8847);
#11308= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#11306,#11307));
#11309= IFCPRODUCTDEFINITIONSHAPE($,$,(#11308));
#11310= IFCMECHANICALFASTENER('1Td1iR002DoJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#11273,#11309,'ID5d9c1b1b-0000-8dc9-3135-373035313136',12.,35.);
#11311= IFCLOCALPLACEMENT(#30,#10);
#11312= IFCELEMENTASSEMBLY('1Td1iR001wSZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#11311,$,'ANK/11(?)',.NOTDEFINED.,.RIGID_FRAME.);
#11313= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(384.164849664058),$);
#11314= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('ANK/11(?)'),$);
#11315= IFCPROPERTYSET('0kr9xwFgD0ROw4NMVWnukn',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#11313,#9101,#9102,#39,#488,#11314));
#11316= IFCQUANTITYLENGTH('Width',$,$,6500.00400003436);
#11317= IFCELEMENTQUANTITY('1l9GFJCkr2$eUCJt50PfvX',#5,'BaseQuantities',$,$,(#11316));
#11318= IFCCARTESIANPOINT((46749.9917979539,-579.168013053426,-7197.00381020169));
#11319= IFCDIRECTION((-1.88339999966294E-005,-0.99999999982264,0.));
#11320= IFCAXIS2PLACEMENT3D(#11318,#11319,#9);
#11321= IFCLOCALPLACEMENT(#11311,#11320);
#11322= IFCCARTESIANPOINT((30.,117.498863222158));
#11323= IFCCARTESIANPOINT((-30.,117.498863222158));
#11324= IFCCARTESIANPOINT((-30.,87.4988632216555));
#11325= IFCPOLYLINE((#54,#3980,#11322,#11323,#11324,#54,#54));
#11326= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL6*60',#11325);
#11327= IFCEXTRUDEDAREASOLID(#11326,#3942,#9,6.);
#11328= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#11327));
#11329= IFCSTYLEDITEM(#11327,(#53),$);
#11330= IFCPRODUCTDEFINITIONSHAPE($,$,(#11328));
#11331= IFCDISCRETEACCESSORY('1Td1iR002DnZ4rDp0rCJ4s',#5,'DETAY','PL6*60','PL6*60',#11321,#11330,'P/395(?)');
#11332= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -7.227'),$);
#11333= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -7.167'),$);
#11334= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/395(?)'),$);
#11335= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('ANK/11(?)'),$);
#11336= IFCPROPERTYSET('3Er$acrR54s9iKw0s3DHfc',#5,'Tekla Common','Common Properties to Shared building elements',(#11332,#11333,#11334,#11335,#74,#75,#919,#77,#78,#3994,#921));
#11337= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(384.164849664058),$);
#11338= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.270233840595995),$);
#11339= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(0.332051787461294),$);
#11340= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.270233840595995),$);
#11341= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(3.44246930695535E-005),$);
#11342= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(3.44246930695535E-005),$);
#11343= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(3.44246930695535E-005),$);
#11344= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.000704993179321302),$);
#11345= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(49.7897834982942),$);
#11346= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0134548844171871),$);
#11347= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.00704993179323341),$);
#11348= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(117.498863220557),$);
#11349= IFCPROPERTYSET('0rYCCa8vX8qxno$dCw5tDW',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#11337,#11338,#11339,#11340,#11341,#11342,#11343,#11344,#11345,#11346,#11347,#8966,#4007,#11348));
#11350= IFCQUANTITYAREA('NetArea',$,$,0.0134548844171871);
#11351= IFCQUANTITYAREA('GrossArea',$,$,0.00704993179323341);
#11352= IFCQUANTITYVOLUME('NetVolume',$,$,3.44246930695535E-005);
#11353= IFCQUANTITYVOLUME('GrossVolume',$,$,3.44246930695535E-005);
#11354= IFCELEMENTQUANTITY('0nVBlVU_1FNR_9hf_3JG81',#5,'BaseQuantities',$,$,(#8970,#11350,#11351,#3971,#11352,#11353));
#11355= IFCCARTESIANPOINT((46767.9911876024,-495.168487174424,-7145.00381020182));
#11356= IFCAXIS2PLACEMENT3D(#11355,#9,#501);
#11357= IFCLOCALPLACEMENT(#8854,#11356);
#11358= IFCEXTRUDEDAREASOLID(#4033,#8867,#9,187.997000000187);
#11359= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#11358));
#11360= IFCSTYLEDITEM(#11358,(#4032),$);
#11361= IFCPRODUCTDEFINITIONSHAPE($,$,(#11359));
#11362= IFCDISCRETEACCESSORY('1Td1iR002Dmp4rDp0rCJ4s',#5,'DIKME','PLT6*78','PLT6*78',#11357,#11361,'P/474(?)');
#11363= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.690663378600688),$);
#11364= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(0.690663378600689),$);
#11365= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.690663378600688),$);
#11366= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0325194960000315),$);
#11367= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0325194960000315),$);
#11368= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(187.997000000187),$);
#11369= IFCPROPERTYSET('2xKRlVvn97oAWReWCKM7h0',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#8878,#11363,#11364,#11365,#4054,#4055,#4056,#4057,#8882,#11366,#11367,#4061,#3965,#11368));
#11370= IFCQUANTITYLENGTH('Length',$,$,187.997000000187);
#11371= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0325194960000315);
#11372= IFCQUANTITYVOLUME('NetVolume',$,$,8.79825960000877E-005);
#11373= IFCQUANTITYWEIGHT('NetWeight',$,$,0.690663378600688);
#11374= IFCELEMENTQUANTITY('0IyHGlXGb3PeAZKZna5o5r',#5,'BaseQuantities',$,$,(#11370,#11371,#11372,#11373));
#11375= IFCCARTESIANPOINT((46669.9975948335,-572.168324135891,-7158.00381020147));
#11376= IFCAXIS2PLACEMENT3D(#11375,#501,#7);
#11377= IFCLOCALPLACEMENT(#8854,#11376);
#11378= IFCCARTESIANPOINT((94.9935913092122,0.,0.));
#11379= IFCAXIS2PLACEMENT3D(#11378,#185,#501);
#11380= IFCEXTRUDEDAREASOLID(#8895,#11379,#9,94.9935913092122);
#11381= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#11380));
#11382= IFCSTYLEDITEM(#11380,(#4077),$);
#11383= IFCPRODUCTDEFINITIONSHAPE($,$,(#11381));
#11384= IFCDISCRETEACCESSORY('1Td1iR001wI34rDp0rCJ4s',#5,'DIKME','PLT6*154','PLT6*154',#11377,#11383,'P/469(?)');
#11385= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/469(?)'),$);
#11386= IFCPROPERTYSET('2HN27zWhX3bPUshME4IoIe',#5,'Tekla Common','Common Properties to Shared building elements',(#8997,#8998,#11385,#8876,#74,#75,#919,#4089,#78,#8906,#4048));
#11387= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.68902651520224),$);
#11388= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(0.68902651520224),$);
#11389= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.68902651520224),$);
#11390= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(8.77740783697121E-005),$);
#11391= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(8.77740783697121E-005),$);
#11392= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(8.77740783697121E-005),$);
#11393= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.0146290130616187),$);
#11394= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(46.7992863953621),$);
#11395= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0322459492189479),$);
#11396= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0322459492189479),$);
#11397= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(94.9935913092122),$);
#11398= IFCPROPERTYSET('3bRi15Y_19Fx7yjqVKhMwr',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#8878,#11387,#11388,#11389,#11390,#11391,#11392,#11393,#11394,#11395,#11396,#8918,#3965,#11397));
#11399= IFCQUANTITYLENGTH('Length',$,$,94.9935913092122);
#11400= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0322459492189479);
#11401= IFCQUANTITYVOLUME('NetVolume',$,$,8.77740783697121E-005);
#11402= IFCQUANTITYWEIGHT('NetWeight',$,$,0.68902651520224);
#11403= IFCELEMENTQUANTITY('1hZtW6iK58HvrjZyeKwE7j',#5,'BaseQuantities',$,$,(#11399,#11400,#11401,#11402));
#11404= IFCCARTESIANPOINT((46632.4906805993,-584.168360638106,-7164.00381020132));
#11405= IFCAXIS2PLACEMENT3D(#11404,#501,#7);
#11406= IFCLOCALPLACEMENT(#11311,#11405);
#11407= IFCCARTESIANPOINT((117.501117354441,0.,0.));
#11408= IFCAXIS2PLACEMENT3D(#11407,#185,#501);
#11409= IFCEXTRUDEDAREASOLID(#8988,#11408,#9,117.501117354441);
#11410= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#11409));
#11411= IFCSTYLEDITEM(#11409,(#4032),$);
#11412= IFCPRODUCTDEFINITIONSHAPE($,$,(#11410));
#11413= IFCDISCRETEACCESSORY('1Td1iR001wH34rDp0rCJ4s',#5,'DIKME','PLT6*150','PLT6*150',#11406,#11412,'P/470(?)');
#11414= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -7.167'),$);
#11415= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/470(?)'),$);
#11416= IFCPROPERTYSET('047mfERXH5PhaKQOFTxxbf',#5,'Tekla Common','Common Properties to Shared building elements',(#11414,#8951,#11415,#11335,#74,#75,#919,#4046,#78,#9001,#4048));
#11417= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.830145394109124),$);
#11418= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(0.830145394109124),$);
#11419= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.830145394109124),$);
#11420= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000105751005618997),$);
#11421= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000105751005618997),$);
#11422= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000105751005618997),$);
#11423= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.0176251676031661),$);
#11424= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(46.329653681762),$);
#11425= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0384603486145855),$);
#11426= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0384603486145855),$);
#11427= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(117.501117354441),$);
#11428= IFCPROPERTYSET('3HbnamjEbFs8038VNwqgrj',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#11337,#11417,#11418,#11419,#11420,#11421,#11422,#11423,#11424,#11425,#11426,#529,#3965,#11427));
#11429= IFCQUANTITYLENGTH('Length',$,$,117.501117354441);
#11430= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0384603486145855);
#11431= IFCQUANTITYVOLUME('NetVolume',$,$,0.000105751005618997);
#11432= IFCQUANTITYWEIGHT('NetWeight',$,$,0.830145394109124);
#11433= IFCELEMENTQUANTITY('1AkTBo7CDA3vAXfi4v$fWW',#5,'BaseQuantities',$,$,(#11429,#11430,#11431,#11432));
#11434= IFCCARTESIANPOINT((46619.9994643383,-589.168360634551,-7145.00381012539));
#11435= IFCDIRECTION((0.999999999999546,7.26000000003089E-007,-6.17999999855305E-007));
#11436= IFCAXIS2PLACEMENT3D(#11434,#501,#11435);
#11437= IFCLOCALPLACEMENT(#8854,#11436);
#11438= IFCCARTESIANPOINT((2212.9883970408,2.3430926052313E-019,-4.68617161114059E-019));
#11439= IFCAXIS2PLACEMENT3D(#11438,#185,#501);
#11440= IFCEXTRUDEDAREASOLID(#4117,#11439,#9,2212.9883970408);
#11441= IFCCARTESIANPOINT((200.,59.9921455383301));
#11442= IFCCARTESIANPOINT((-4.00177668780088E-010,59.9921455383301));
#11443= IFCPOLYLINE((#54,#3980,#4121,#4122,#11441,#11442,#54,#54));
#11444= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL10*60',#11443);
#11445= IFCCARTESIANPOINT((59.9846617726243,35.0038471959197,100.001682991846));
#11446= IFCAXIS2PLACEMENT3D(#11445,#8,#596);
#11447= IFCEXTRUDEDAREASOLID(#11444,#11446,#9,10.);
#11448= IFCBOOLEANRESULT(.DIFFERENCE.,#11440,#11447);
#11449= IFCCARTESIANPOINT((194.,127.5));
#11450= IFCCARTESIANPOINT((200.,127.5));
#11451= IFCCARTESIANPOINT((200.,144.992141723633));
#11452= IFCCARTESIANPOINT((0.,145.));
#11453= IFCPOLYLINE((#54,#4131,#11449,#11450,#11451,#11452,#54,#54));
#11454= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL80*145',#11453);
#11455= IFCCARTESIANPOINT((144.984711212593,-44.9961002740652,100.001744701846));
#11456= IFCAXIS2PLACEMENT3D(#11455,#8,#596);
#11457= IFCEXTRUDEDAREASOLID(#11454,#11456,#9,80.);
#11458= IFCBOOLEANRESULT(.DIFFERENCE.,#11448,#11457);
#11459= IFCCARTESIANPOINT((2152.97936787743,45.0051406666498,100.003202506007));
#11460= IFCAXIS2PLACEMENT3D(#11459,#501,#596);
#11461= IFCEXTRUDEDAREASOLID(#4126,#11460,#9,10.);
#11462= IFCBOOLEANRESULT(.DIFFERENCE.,#11458,#11461);
#11463= IFCCARTESIANPOINT((2052.98237405748,35.0050788685054,100.003129908185));
#11464= IFCAXIS2PLACEMENT3D(#11463,#501,#596);
#11465= IFCEXTRUDEDAREASOLID(#4137,#11464,#9,80.);
#11466= IFCBOOLEANRESULT(.DIFFERENCE.,#11462,#11465);
#11467= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#11466));
#11468= IFCSTYLEDITEM(#11440,(#4116),$);
#11469= IFCPRODUCTDEFINITIONSHAPE($,$,(#11467));
#11470= IFCBEAM('1Td1iR001WkZ4rDp0rCJ4s',#5,'KIRIS','RHS200*90*6','RHS200*90*6',#11437,#11469,'P/460(?)');
#11471= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -7.190'),$);
#11472= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -7.100'),$);
#11473= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/460(?)'),$);
#11474= IFCPROPERTYSET('1lG8ji6Uf5XBSICNWVLrma',#5,'Tekla Common','Common Properties to Shared building elements',(#11471,#11472,#11473,#8876,#74,#75,#919,#4183,#78,#4184,#4185));
#11475= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(53.4882604324295),$);
#11476= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(57.9528549463868),$);
#11477= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(53.4882604324295),$);
#11478= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.00681379113788911),$);
#11479= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.00738252929253335),$);
#11480= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.00681379113788911),$);
#11481= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.433049150090917),$);
#11482= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(21.9851986621704),$);
#11483= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(1.17595003170087),$);
#11484= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(1.27191499871685),$);
#11485= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(200.003202510983),$);
#11486= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(90.0051669316799),$);
#11487= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(2178.01089181404),$);
#11488= IFCPROPERTYSET('1zLQIRk554sQr1Y$TxSk0b',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#8878,#11475,#11476,#11477,#11478,#11479,#11480,#11481,#11482,#11483,#11484,#11485,#11486,#11487));
#11489= IFCQUANTITYLENGTH('Length',$,$,2178.01089181404);
#11490= IFCQUANTITYAREA('OuterSurfaceArea',$,$,1.17595003170087);
#11491= IFCQUANTITYVOLUME('NetVolume',$,$,0.00681379113788911);
#11492= IFCQUANTITYWEIGHT('NetWeight',$,$,53.4882604324295);
#11493= IFCELEMENTQUANTITY('1nhoIOxy956usgovIdtHbE',#5,'BaseQuantities',$,$,(#11489,#11490,#11491,#11492));
#11494= IFCCARTESIANPOINT((48828.9995056681,8451.5006803155,4889.99999999995));
#11495= IFCAXIS2PLACEMENT3D(#11494,#8,#596);
#11496= IFCLOCALPLACEMENT(#4206,#11495);
#11497= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#10212));
#11498= IFCPRODUCTDEFINITIONSHAPE($,$,(#11497));
#11499= IFCDISCRETEACCESSORY('1Td1iR001Xbp4rDp0rCJ4s',#5,'Cap plate','PL3*90','PL3*90',#11496,#11498,'0(?)');
#11500= IFCPROPERTYSET('1FD3jrRm58mR4Zt1IypjKh',#5,'Tekla Common','Common Properties to Shared building elements',(#7722,#1377,#4436,#4226,#74,#75,#76,#77,#78,#4932,#4438));
#11501= IFCPROPERTYSET('3OQ7yMxFP4T9$jR3NCiU34',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#4228,#10218,#10219,#10220,#10221,#10222,#10223,#10224,#10225,#10226,#10227,#4944,#4451,#10228));
#11502= IFCCARTESIANPOINT((48728.8520000746,1525.00168046917,4894.99999999961));
#11503= IFCAXIS2PLACEMENT3D(#11502,#185,#8);
#11504= IFCLOCALPLACEMENT(#30,#11503);
#11505= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#11506= IFCEXTRUDEDAREASOLID(#11505,#4747,#9,16.0000000000242);
#11507= IFCSTYLEDITEM(#11506,(#195),$);
#11508= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#11509= IFCEXTRUDEDAREASOLID(#11508,#4752,#9,16.1000000000002);
#11510= IFCSTYLEDITEM(#11509,(#195),$);
#11511= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#11512= IFCEXTRUDEDAREASOLID(#11511,#4757,#9,6.5);
#11513= IFCSTYLEDITEM(#11512,(#191),$);
#11514= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#11515= IFCEXTRUDEDAREASOLID(#11514,#4762,#9,50.);
#11516= IFCSTYLEDITEM(#11515,(#191),$);
#11517= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#11518= IFCEXTRUDEDAREASOLID(#11517,#4767,#9,2.5);
#11519= IFCSTYLEDITEM(#11518,(#191),$);
#11520= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#11521= IFCEXTRUDEDAREASOLID(#11520,#4772,#9,10.);
#11522= IFCSTYLEDITEM(#11521,(#191),$);
#11523= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#11506,#11509,#11512,#11515,#11518,#11521));
#11524= IFCREPRESENTATIONMAP(#10,#11523);
#11525= IFCMAPPEDITEM(#11524,#4776);
#11526= IFCMAPPEDITEM(#11524,#4781);
#11527= IFCMAPPEDITEM(#11524,#4784);
#11528= IFCMAPPEDITEM(#11524,#4787);
#11529= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#11525,#11526,#11527,#11528));
#11530= IFCPRODUCTDEFINITIONSHAPE($,$,(#11529));
#11531= IFCMECHANICALFASTENER('1Td1iR001kGZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#11504,#11530,'ID5d9c1b1b-0000-6e42-3135-373035313136',12.,50.);
#11532= IFCCARTESIANPOINT((48728.8520000746,3715.00168046917,4894.99999999961));
#11533= IFCAXIS2PLACEMENT3D(#11532,#185,#8);
#11534= IFCLOCALPLACEMENT(#30,#11533);
#11535= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#11536= IFCEXTRUDEDAREASOLID(#11535,#4747,#9,16.0000000000242);
#11537= IFCSTYLEDITEM(#11536,(#195),$);
#11538= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#11539= IFCEXTRUDEDAREASOLID(#11538,#4752,#9,16.1000000000002);
#11540= IFCSTYLEDITEM(#11539,(#195),$);
#11541= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#11542= IFCEXTRUDEDAREASOLID(#11541,#4757,#9,6.5);
#11543= IFCSTYLEDITEM(#11542,(#191),$);
#11544= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#11545= IFCEXTRUDEDAREASOLID(#11544,#4762,#9,50.);
#11546= IFCSTYLEDITEM(#11545,(#191),$);
#11547= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#11548= IFCEXTRUDEDAREASOLID(#11547,#4767,#9,2.5);
#11549= IFCSTYLEDITEM(#11548,(#191),$);
#11550= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#11551= IFCEXTRUDEDAREASOLID(#11550,#4772,#9,10.);
#11552= IFCSTYLEDITEM(#11551,(#191),$);
#11553= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#11536,#11539,#11542,#11545,#11548,#11551));
#11554= IFCREPRESENTATIONMAP(#10,#11553);
#11555= IFCMAPPEDITEM(#11554,#4776);
#11556= IFCMAPPEDITEM(#11554,#4781);
#11557= IFCMAPPEDITEM(#11554,#4784);
#11558= IFCMAPPEDITEM(#11554,#4787);
#11559= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#11555,#11556,#11557,#11558));
#11560= IFCPRODUCTDEFINITIONSHAPE($,$,(#11559));
#11561= IFCMECHANICALFASTENER('1Td1iR001kIJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#11534,#11560,'ID5d9c1b1b-0000-6e49-3135-373035313136',12.,50.);
#11562= IFCCARTESIANPOINT((48728.8520000746,4050.00168046917,4894.99999999961));
#11563= IFCAXIS2PLACEMENT3D(#11562,#185,#8);
#11564= IFCLOCALPLACEMENT(#30,#11563);
#11565= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#11566= IFCEXTRUDEDAREASOLID(#11565,#4747,#9,16.0000000000242);
#11567= IFCSTYLEDITEM(#11566,(#195),$);
#11568= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#11569= IFCEXTRUDEDAREASOLID(#11568,#4752,#9,16.1000000000002);
#11570= IFCSTYLEDITEM(#11569,(#195),$);
#11571= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#11572= IFCEXTRUDEDAREASOLID(#11571,#4757,#9,6.5);
#11573= IFCSTYLEDITEM(#11572,(#191),$);
#11574= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#11575= IFCEXTRUDEDAREASOLID(#11574,#4762,#9,50.);
#11576= IFCSTYLEDITEM(#11575,(#191),$);
#11577= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#11578= IFCEXTRUDEDAREASOLID(#11577,#4767,#9,2.5);
#11579= IFCSTYLEDITEM(#11578,(#191),$);
#11580= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#11581= IFCEXTRUDEDAREASOLID(#11580,#4772,#9,10.);
#11582= IFCSTYLEDITEM(#11581,(#191),$);
#11583= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#11566,#11569,#11572,#11575,#11578,#11581));
#11584= IFCREPRESENTATIONMAP(#10,#11583);
#11585= IFCMAPPEDITEM(#11584,#4776);
#11586= IFCMAPPEDITEM(#11584,#4781);
#11587= IFCMAPPEDITEM(#11584,#4784);
#11588= IFCMAPPEDITEM(#11584,#4787);
#11589= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#11585,#11586,#11587,#11588));
#11590= IFCPRODUCTDEFINITIONSHAPE($,$,(#11589));
#11591= IFCMECHANICALFASTENER('1Td1iR001kK34rDp0rCJ4s',#5,'Bolt assembly',$,$,#11564,#11590,'ID5d9c1b1b-0000-6e50-3135-373035313136',12.,50.);
#11592= IFCCARTESIANPOINT((48728.8520000746,5320.00168046917,4894.99999999961));
#11593= IFCAXIS2PLACEMENT3D(#11592,#185,#8);
#11594= IFCLOCALPLACEMENT(#30,#11593);
#11595= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#11596= IFCEXTRUDEDAREASOLID(#11595,#4747,#9,16.0000000000242);
#11597= IFCSTYLEDITEM(#11596,(#195),$);
#11598= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#11599= IFCEXTRUDEDAREASOLID(#11598,#4752,#9,16.1000000000002);
#11600= IFCSTYLEDITEM(#11599,(#195),$);
#11601= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#11602= IFCEXTRUDEDAREASOLID(#11601,#4757,#9,6.5);
#11603= IFCSTYLEDITEM(#11602,(#191),$);
#11604= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#11605= IFCEXTRUDEDAREASOLID(#11604,#4762,#9,50.);
#11606= IFCSTYLEDITEM(#11605,(#191),$);
#11607= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#11608= IFCEXTRUDEDAREASOLID(#11607,#4767,#9,2.5);
#11609= IFCSTYLEDITEM(#11608,(#191),$);
#11610= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#11611= IFCEXTRUDEDAREASOLID(#11610,#4772,#9,10.);
#11612= IFCSTYLEDITEM(#11611,(#191),$);
#11613= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#11596,#11599,#11602,#11605,#11608,#11611));
#11614= IFCREPRESENTATIONMAP(#10,#11613);
#11615= IFCMAPPEDITEM(#11614,#4776);
#11616= IFCMAPPEDITEM(#11614,#4781);
#11617= IFCMAPPEDITEM(#11614,#4784);
#11618= IFCMAPPEDITEM(#11614,#4787);
#11619= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#11615,#11616,#11617,#11618));
#11620= IFCPRODUCTDEFINITIONSHAPE($,$,(#11619));
#11621= IFCMECHANICALFASTENER('1Td1iR001kLp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#11594,#11620,'ID5d9c1b1b-0000-6e57-3135-373035313136',12.,50.);
#11622= IFCCARTESIANPOINT((48728.8520000746,5655.00168046917,4894.99999999961));
#11623= IFCAXIS2PLACEMENT3D(#11622,#185,#8);
#11624= IFCLOCALPLACEMENT(#30,#11623);
#11625= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#11626= IFCEXTRUDEDAREASOLID(#11625,#4747,#9,16.0000000000242);
#11627= IFCSTYLEDITEM(#11626,(#195),$);
#11628= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#11629= IFCEXTRUDEDAREASOLID(#11628,#4752,#9,16.1000000000002);
#11630= IFCSTYLEDITEM(#11629,(#195),$);
#11631= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#11632= IFCEXTRUDEDAREASOLID(#11631,#4757,#9,6.5);
#11633= IFCSTYLEDITEM(#11632,(#191),$);
#11634= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#11635= IFCEXTRUDEDAREASOLID(#11634,#4762,#9,50.);
#11636= IFCSTYLEDITEM(#11635,(#191),$);
#11637= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#11638= IFCEXTRUDEDAREASOLID(#11637,#4767,#9,2.5);
#11639= IFCSTYLEDITEM(#11638,(#191),$);
#11640= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#11641= IFCEXTRUDEDAREASOLID(#11640,#4772,#9,10.);
#11642= IFCSTYLEDITEM(#11641,(#191),$);
#11643= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#11626,#11629,#11632,#11635,#11638,#11641));
#11644= IFCREPRESENTATIONMAP(#10,#11643);
#11645= IFCMAPPEDITEM(#11644,#4776);
#11646= IFCMAPPEDITEM(#11644,#4781);
#11647= IFCMAPPEDITEM(#11644,#4784);
#11648= IFCMAPPEDITEM(#11644,#4787);
#11649= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#11645,#11646,#11647,#11648));
#11650= IFCPRODUCTDEFINITIONSHAPE($,$,(#11649));
#11651= IFCMECHANICALFASTENER('1Td1iR001kNZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#11624,#11650,'ID5d9c1b1b-0000-6e5e-3135-373035313136',12.,50.);
#11652= IFCCARTESIANPOINT((48728.8520000746,7765.00168046917,4894.99999999961));
#11653= IFCAXIS2PLACEMENT3D(#11652,#185,#8);
#11654= IFCLOCALPLACEMENT(#30,#11653);
#11655= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#11656= IFCEXTRUDEDAREASOLID(#11655,#4747,#9,16.0000000000242);
#11657= IFCSTYLEDITEM(#11656,(#195),$);
#11658= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#11659= IFCEXTRUDEDAREASOLID(#11658,#4752,#9,16.1000000000002);
#11660= IFCSTYLEDITEM(#11659,(#195),$);
#11661= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#11662= IFCEXTRUDEDAREASOLID(#11661,#4757,#9,6.5);
#11663= IFCSTYLEDITEM(#11662,(#191),$);
#11664= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#11665= IFCEXTRUDEDAREASOLID(#11664,#4762,#9,50.);
#11666= IFCSTYLEDITEM(#11665,(#191),$);
#11667= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#11668= IFCEXTRUDEDAREASOLID(#11667,#4767,#9,2.5);
#11669= IFCSTYLEDITEM(#11668,(#191),$);
#11670= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#11671= IFCEXTRUDEDAREASOLID(#11670,#4772,#9,10.);
#11672= IFCSTYLEDITEM(#11671,(#191),$);
#11673= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#11656,#11659,#11662,#11665,#11668,#11671));
#11674= IFCREPRESENTATIONMAP(#10,#11673);
#11675= IFCMAPPEDITEM(#11674,#4776);
#11676= IFCMAPPEDITEM(#11674,#4781);
#11677= IFCMAPPEDITEM(#11674,#4784);
#11678= IFCMAPPEDITEM(#11674,#4787);
#11679= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#11675,#11676,#11677,#11678));
#11680= IFCPRODUCTDEFINITIONSHAPE($,$,(#11679));
#11681= IFCMECHANICALFASTENER('1Td1iR001kPJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#11654,#11680,'ID5d9c1b1b-0000-6e65-3135-373035313136',12.,50.);
#11682= IFCCARTESIANPOINT((48728.8520000746,8100.00168046917,4894.99999999961));
#11683= IFCAXIS2PLACEMENT3D(#11682,#185,#8);
#11684= IFCLOCALPLACEMENT(#30,#11683);
#11685= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#11686= IFCEXTRUDEDAREASOLID(#11685,#4747,#9,16.0000000000242);
#11687= IFCSTYLEDITEM(#11686,(#195),$);
#11688= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#11689= IFCEXTRUDEDAREASOLID(#11688,#4752,#9,16.1000000000002);
#11690= IFCSTYLEDITEM(#11689,(#195),$);
#11691= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#11692= IFCEXTRUDEDAREASOLID(#11691,#4757,#9,6.5);
#11693= IFCSTYLEDITEM(#11692,(#191),$);
#11694= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#11695= IFCEXTRUDEDAREASOLID(#11694,#4762,#9,50.);
#11696= IFCSTYLEDITEM(#11695,(#191),$);
#11697= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#11698= IFCEXTRUDEDAREASOLID(#11697,#4767,#9,2.5);
#11699= IFCSTYLEDITEM(#11698,(#191),$);
#11700= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#11701= IFCEXTRUDEDAREASOLID(#11700,#4772,#9,10.);
#11702= IFCSTYLEDITEM(#11701,(#191),$);
#11703= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#11686,#11689,#11692,#11695,#11698,#11701));
#11704= IFCREPRESENTATIONMAP(#10,#11703);
#11705= IFCMAPPEDITEM(#11704,#4776);
#11706= IFCMAPPEDITEM(#11704,#4781);
#11707= IFCMAPPEDITEM(#11704,#4784);
#11708= IFCMAPPEDITEM(#11704,#4787);
#11709= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#11705,#11706,#11707,#11708));
#11710= IFCPRODUCTDEFINITIONSHAPE($,$,(#11709));
#11711= IFCMECHANICALFASTENER('1Td1iR001kR34rDp0rCJ4s',#5,'Bolt assembly',$,$,#11684,#11710,'ID5d9c1b1b-0000-6e6c-3135-373035313136',12.,50.);
#11712= IFCCARTESIANPOINT((48828.9996546148,-687.66991453126,4799.99999999995));
#11713= IFCAXIS2PLACEMENT3D(#11712,#501,#9);
#11714= IFCLOCALPLACEMENT(#4206,#11713);
#11715= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#10212));
#11716= IFCPRODUCTDEFINITIONSHAPE($,$,(#11715));
#11717= IFCDISCRETEACCESSORY('1Td1iR001wFJ4rDp0rCJ4s',#5,'Cap plate','PL3*90','PL3*90',#11714,#11716,'0(?)');
#11718= IFCCARTESIANPOINT((48688.9995058521,8450.00067803607,4844.99999999995));
#11719= IFCAXIS2PLACEMENT3D(#11718,#7,#501);
#11720= IFCLOCALPLACEMENT(#4206,#11719);
#11721= IFCCARTESIANPOINT((9136.17059480733,-9.09494701772928E-013,0.));
#11722= IFCAXIS2PLACEMENT3D(#11721,#185,#501);
#11723= IFCEXTRUDEDAREASOLID(#10252,#11722,#9,9136.17059484681);
#11724= IFCCARTESIANPOINT((9136.17059480733,-9.09494701772928E-013,-150.));
#11725= IFCAXIS2PLACEMENT3D(#11724,#185,#8);
#11726= IFCPLANE(#11725);
#11727= IFCHALFSPACESOLID(#11726,.T.);
#11728= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#11723,#11727);
#11729= IFCCARTESIANPOINT((-3.94848029827699E-008,-9.09494701772928E-013,-150.));
#11730= IFCAXIS2PLACEMENT3D(#11729,#7,#501);
#11731= IFCPLANE(#11730);
#11732= IFCHALFSPACESOLID(#11731,.T.);
#11733= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#11728,#11732);
#11734= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#11733));
#11735= IFCSTYLEDITEM(#11723,(#10241),$);
#11736= IFCPRODUCTDEFINITIONSHAPE($,$,(#11734));
#11737= IFCBEAM('1Td1iR002Pn34rDp0rCJ4s',#5,'KIRIS','WB300-16-30*90-0','WB300-16-30*90-0',#11720,#11736,'P/297(?)');
#11738= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/297(?)'),$);
#11739= IFCPROPERTYSET('1qJLchfdn4BxTwPfW0EM5g',#5,'Tekla Common','Common Properties to Shared building elements',(#7722,#1377,#11738,#4226,#74,#75,#76,#10295,#78,#10296,#4185));
#11740= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(938.083724337681),$);
#11741= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(938.083724337681),$);
#11742= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(938.083724337681),$);
#11743= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.119501111380596),$);
#11744= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.119501111380596),$);
#11745= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.119501111380596),$);
#11746= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(2.74085117845404),$);
#11747= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(13.4290046950804),$);
#11748= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(12.5975307385092),$);
#11749= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(12.5975307385092),$);
#11750= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(300.00000000155),$);
#11751= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(9136.17059484686),$);
#11752= IFCPROPERTYSET('1k0r0oHH98CBHJIuH4slMS',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#4228,#11740,#11741,#11742,#11743,#11744,#11745,#11746,#11747,#11748,#11749,#11750,#5657,#11751));
#11753= IFCQUANTITYLENGTH('Length',$,$,9136.17059484686);
#11754= IFCQUANTITYAREA('OuterSurfaceArea',$,$,12.5975307385092);
#11755= IFCQUANTITYVOLUME('NetVolume',$,$,0.119501111380596);
#11756= IFCQUANTITYWEIGHT('NetWeight',$,$,938.083724337681);
#11757= IFCELEMENTQUANTITY('1GP71uYm9ADOC7$6ZaEV4e',#5,'BaseQuantities',$,$,(#11753,#11754,#11755,#11756));
#11758= IFCCARTESIANPOINT((48738.9995828323,3755.00199847941,-45.0000000000628));
#11759= IFCAXIS2PLACEMENT3D(#11758,#7,#501);
#11760= IFCLOCALPLACEMENT(#10989,#11759);
#11761= IFCCARTESIANPOINT((2190.,0.,0.));
#11762= IFCAXIS2PLACEMENT3D(#11761,#185,#501);
#11763= IFCEXTRUDEDAREASOLID(#4117,#11762,#9,2190.);
#11764= IFCCARTESIANPOINT((29.9999999998035,42.4920005799909));
#11765= IFCCARTESIANPOINT((199.999999999804,42.4920005808799));
#11766= IFCPOLYLINE((#54,#3980,#11764,#11765,#11441,#11442,#54,#54));
#11767= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL10*60',#11766);
#11768= IFCCARTESIANPOINT((2130.00785614173,-35.,99.9999997592313));
#11769= IFCAXIS2PLACEMENT3D(#11768,#501,#596);
#11770= IFCEXTRUDEDAREASOLID(#11767,#11769,#9,10.);
#11771= IFCBOOLEANRESULT(.DIFFERENCE.,#11763,#11770);
#11772= IFCCARTESIANPOINT((190.,3.88808985007927E-010));
#11773= IFCCARTESIANPOINT((190.000000000124,142.505004883029));
#11774= IFCCARTESIANPOINT((200.000000000124,142.50500488304));
#11775= IFCPOLYLINE((#54,#11772,#11773,#11774,#4134,#4135,#54,#54));
#11776= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL80*160',#11775);
#11777= IFCCARTESIANPOINT((2029.99485614173,45.,99.9999997592677));
#11778= IFCAXIS2PLACEMENT3D(#11777,#501,#596);
#11779= IFCEXTRUDEDAREASOLID(#11776,#11778,#9,80.);
#11780= IFCBOOLEANRESULT(.DIFFERENCE.,#11771,#11779);
#11781= IFCCARTESIANPOINT((30.1469993591309,-1.31421984406188E-010));
#11782= IFCCARTESIANPOINT((30.1469993589635,42.4920005796967));
#11783= IFCPOLYLINE((#54,#11781,#11782,#11765,#11441,#11442,#54,#54));
#11784= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL10*60',#11783);
#11785= IFCCARTESIANPOINT((59.9921440170838,-45.,100.000032879485));
#11786= IFCAXIS2PLACEMENT3D(#11785,#8,#596);
#11787= IFCEXTRUDEDAREASOLID(#11784,#11786,#9,10.);
#11788= IFCBOOLEANRESULT(.DIFFERENCE.,#11780,#11787);
#11789= IFCCARTESIANPOINT((160.005144017083,-35.,100.000029679104));
#11790= IFCAXIS2PLACEMENT3D(#11789,#8,#596);
#11791= IFCEXTRUDEDAREASOLID(#11776,#11790,#9,80.);
#11792= IFCBOOLEANRESULT(.DIFFERENCE.,#11788,#11791);
#11793= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#11792));
#11794= IFCSTYLEDITEM(#11763,(#4116),$);
#11795= IFCPRODUCTDEFINITIONSHAPE($,$,(#11793));
#11796= IFCBEAM('1Td1iR002jiZ4rDp0rCJ4s',#5,'KIRIS','RHS200*90*6','RHS200*90*6',#11760,#11795,'P/456(?)');
#11797= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/456(?)'),$);
#11798= IFCPROPERTYSET('0dE$ulWWX4TwW7Qh0RV$6a',#5,'Tekla Common','Common Properties to Shared building elements',(#4180,#4181,#11797,#11000,#74,#75,#76,#4183,#78,#4184,#4185));
#11799= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(52.7539459369707),$);
#11800= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(57.350844),$);
#11801= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(52.7539459369707),$);
#11802= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.00672024789005996),$);
#11803= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.00730584),$);
#11804= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.00672024789005996),$);
#11805= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.428444178229293),$);
#11806= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(21.9866792839755),$);
#11807= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(1.15988409028036),$);
#11808= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(1.2587381443299),$);
#11809= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(200.000032992459),$);
#11810= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(2154.99972829028),$);
#11811= IFCPROPERTYSET('2Cm4ZdZ1TCrexudDQMe9eQ',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#11002,#11799,#11800,#11801,#11802,#11803,#11804,#11805,#11806,#11807,#11808,#11809,#5657,#11810));
#11812= IFCQUANTITYLENGTH('Length',$,$,2154.99972829028);
#11813= IFCQUANTITYAREA('OuterSurfaceArea',$,$,1.15988409028036);
#11814= IFCQUANTITYVOLUME('NetVolume',$,$,0.00672024789005996);
#11815= IFCQUANTITYWEIGHT('NetWeight',$,$,52.7539459369707);
#11816= IFCELEMENTQUANTITY('3cBOjIpOLFf9L0GQQasQ89',#5,'BaseQuantities',$,$,(#11812,#11813,#11814,#11815));
#11817= IFCCARTESIANPOINT((48738.9995775206,4090.00199847941,-45.0000000000618));
#11818= IFCAXIS2PLACEMENT3D(#11817,#7,#501);
#11819= IFCLOCALPLACEMENT(#8233,#11818);
#11820= IFCCARTESIANPOINT((335.,0.,0.));
#11821= IFCAXIS2PLACEMENT3D(#11820,#185,#501);
#11822= IFCEXTRUDEDAREASOLID(#4117,#11821,#9,335.);
#11823= IFCCARTESIANPOINT((25.1470012664649,-1.18234311230481E-011));
#11824= IFCCARTESIANPOINT((25.1334819795811,42.5019989012389));
#11825= IFCCARTESIANPOINT((199.986465454218,42.5656166068225));
#11826= IFCCARTESIANPOINT((199.98249816912,55.061763762576));
#11827= IFCCARTESIANPOINT((-0.0174957957788138,54.9981422423984));
#11828= IFCPOLYLINE((#54,#11823,#11824,#11825,#11826,#11827,#54,#54));
#11829= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL90*55',#11828);
#11830= IFCDIRECTION((-0.000318080000137334,0.,-0.999999949412556));
#11831= IFCCARTESIANPOINT((280.00185598295,45.0000000000009,100.000032815318));
#11832= IFCAXIS2PLACEMENT3D(#11831,#501,#11830);
#11833= IFCEXTRUDEDAREASOLID(#11829,#11832,#9,90.);
#11834= IFCBOOLEANRESULT(.DIFFERENCE.,#11822,#11833);
#11835= IFCCARTESIANPOINT((25.1334819792392,42.5041427613178));
#11836= IFCCARTESIANPOINT((199.986465451941,42.5677642831079));
#11837= IFCCARTESIANPOINT((199.982498166821,55.0597648629337));
#11838= IFCCARTESIANPOINT((-0.0174955462862272,54.9961433410276));
#11839= IFCPOLYLINE((#54,#11823,#11835,#11836,#11837,#11838,#54,#54));
#11840= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL90*55',#11839);
#11841= IFCDIRECTION((0.000318088000128933,0.,-0.999999949410011));
#11842= IFCCARTESIANPOINT((54.996144017081,-44.9999999999991,100.000032847194));
#11843= IFCAXIS2PLACEMENT3D(#11842,#8,#11841);
#11844= IFCEXTRUDEDAREASOLID(#11840,#11843,#9,90.);
#11845= IFCBOOLEANRESULT(.DIFFERENCE.,#11834,#11844);
#11846= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#11845));
#11847= IFCSTYLEDITEM(#11822,(#4116),$);
#11848= IFCPRODUCTDEFINITIONSHAPE($,$,(#11846));
#11849= IFCDISCRETEACCESSORY('1Td1iR002jhp4rDp0rCJ4s',#5,'KIRIS','RHS200*90*6','RHS200*90*6',#11819,#11848,'P/446(?)');
#11850= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/446(?)'),$);
#11851= IFCPROPERTYSET('2byQa9QR9E_93noGGmpo5u',#5,'Tekla Common','Common Properties to Shared building elements',(#4180,#4181,#11850,#8262,#74,#75,#76,#4183,#78,#4184,#4185));
#11852= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(7.60464858303541),$);
#11853= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(8.772846),$);
#11854= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(7.60464858303541),$);
#11855= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000968745042424893),$);
#11856= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.00111756),$);
#11857= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000968745042424893),$);
#11858= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.0598631329209395),$);
#11859= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(22.4094492460543),$);
#11860= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.170415986455611),$);
#11861= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.195459793814433),$);
#11862= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(200.000032847209),$);
#11863= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(90.0000000000009),$);
#11864= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(310.011863559164),$);
#11865= IFCPROPERTYSET('0xR5ktsdf5ywe8YcfxDb6w',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#8265,#11852,#11853,#11854,#11855,#11856,#11857,#11858,#11859,#11860,#11861,#11862,#11863,#11864));
#11866= IFCQUANTITYLENGTH('Length',$,$,310.011863559164);
#11867= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.170415986455611);
#11868= IFCQUANTITYVOLUME('NetVolume',$,$,0.000968745042424893);
#11869= IFCQUANTITYWEIGHT('NetWeight',$,$,7.60464858303541);
#11870= IFCELEMENTQUANTITY('3v9XHoPS1DteRl2XazlgWg',#5,'BaseQuantities',$,$,(#11866,#11867,#11868,#11869));
#11871= IFCCARTESIANPOINT((48738.9995573836,5360.00199847941,-45.0000000000591));
#11872= IFCAXIS2PLACEMENT3D(#11871,#7,#501);
#11873= IFCLOCALPLACEMENT(#10650,#11872);
#11874= IFCCARTESIANPOINT((1270.,0.,-4.20207751176938E-021));
#11875= IFCAXIS2PLACEMENT3D(#11874,#185,#501);
#11876= IFCEXTRUDEDAREASOLID(#4117,#11875,#9,1270.);
#11877= IFCCARTESIANPOINT((1209.99985614173,-34.9999999999964,100.000039928025));
#11878= IFCAXIS2PLACEMENT3D(#11877,#501,#596);
#11879= IFCEXTRUDEDAREASOLID(#11444,#11878,#9,10.);
#11880= IFCBOOLEANRESULT(.DIFFERENCE.,#11876,#11879);
#11881= IFCCARTESIANPOINT((189.999999999978,140.013000488281));
#11882= IFCCARTESIANPOINT((199.999999999978,140.013000488281));
#11883= IFCPOLYLINE((#54,#11772,#11881,#11882,#4134,#4135,#54,#54));
#11884= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL80*160',#11883);
#11885= IFCCARTESIANPOINT((1109.98685614173,45.0000000000036,100.000039928062));
#11886= IFCAXIS2PLACEMENT3D(#11885,#501,#596);
#11887= IFCEXTRUDEDAREASOLID(#11884,#11886,#9,80.);
#11888= IFCBOOLEANRESULT(.DIFFERENCE.,#11880,#11887);
#11889= IFCCARTESIANPOINT((60.0001438583013,-44.9999999999964,100.000039928222));
#11890= IFCAXIS2PLACEMENT3D(#11889,#8,#596);
#11891= IFCEXTRUDEDAREASOLID(#11444,#11890,#9,10.);
#11892= IFCBOOLEANRESULT(.DIFFERENCE.,#11888,#11891);
#11893= IFCCARTESIANPOINT((189.999999999978,142.513000488281));
#11894= IFCPOLYLINE((#54,#11772,#11893,#4133,#4134,#4135,#54,#54));
#11895= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL80*160',#11894);
#11896= IFCCARTESIANPOINT((160.0131438583,-34.9999999999964,100.000039928222));
#11897= IFCAXIS2PLACEMENT3D(#11896,#8,#596);
#11898= IFCEXTRUDEDAREASOLID(#11895,#11897,#9,80.);
#11899= IFCBOOLEANRESULT(.DIFFERENCE.,#11892,#11898);
#11900= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#11899));
#11901= IFCSTYLEDITEM(#11876,(#4116),$);
#11902= IFCPRODUCTDEFINITIONSHAPE($,$,(#11900));
#11903= IFCBEAM('1Td1iR002jgp4rDp0rCJ4s',#5,'KIRIS','RHS200*90*6','RHS200*90*6',#11873,#11902,'P/455(?)');
#11904= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/455(?)'),$);
#11905= IFCPROPERTYSET('0kNAVzSIP9Zey2CY6$VZUf',#5,'Tekla Common','Common Properties to Shared building elements',(#4180,#4181,#11904,#10670,#74,#75,#76,#4183,#78,#4184,#4185));
#11906= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(28.6515419413735),$);
#11907= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(33.258252),$);
#11908= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(28.6515419413735),$);
#11909= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.0036498779543151),$);
#11910= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.00423672),$);
#11911= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.0036498779543151),$);
#11912= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.244449969947629),$);
#11913= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(22.069633639853),$);
#11914= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.632329033862995),$);
#11915= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.73139793814433),$);
#11916= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(200.000039928244),$);
#11917= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(90.0000000000036),$);
#11918= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(1234.99971337172),$);
#11919= IFCPROPERTYSET('1cOnAo2urDUvP5lbITDcqB',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#10673,#11906,#11907,#11908,#11909,#11910,#11911,#11912,#11913,#11914,#11915,#11916,#11917,#11918));
#11920= IFCQUANTITYLENGTH('Length',$,$,1234.99971337172);
#11921= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.632329033862995);
#11922= IFCQUANTITYVOLUME('NetVolume',$,$,0.0036498779543151);
#11923= IFCQUANTITYWEIGHT('NetWeight',$,$,28.6515419413735);
#11924= IFCELEMENTQUANTITY('2nnl959hD7xQVtUfxT74KJ',#5,'BaseQuantities',$,$,(#11920,#11921,#11922,#11923));
#11925= IFCCARTESIANPOINT((48532.499342744,-679.169997376989,4889.99999999998));
#11926= IFCAXIS2PLACEMENT3D(#11925,#7,#596);
#11927= IFCLOCALPLACEMENT(#1305,#11926);
#11928= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#4926));
#11929= IFCPRODUCTDEFINITIONSHAPE($,$,(#11928));
#11930= IFCDISCRETEACCESSORY('1Td1iR002jBZ4rDp0rCJ4s',#5,'Cap plate','PL3*90','PL3*90',#11927,#11929,'0(?)');
#11931= IFCPROPERTYSET('1QrK17RELD0Od7mUJDu50M',#5,'Tekla Common','Common Properties to Shared building elements',(#7722,#1377,#4436,#1320,#74,#75,#919,#77,#78,#4932,#4438));
#11932= IFCPROPERTYSET('2pwcvw6pf4WATYixtdYOfM',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1322,#4934,#4935,#4936,#4937,#4938,#4939,#4940,#4941,#4942,#4943,#4944,#4451,#4946));
#11933= IFCQUANTITYAREA('NetArea',$,$,0.04146);
#11934= IFCQUANTITYAREA('GrossArea',$,$,0.0198);
#11935= IFCQUANTITYVOLUME('NetVolume',$,$,5.94E-005);
#11936= IFCQUANTITYVOLUME('GrossVolume',$,$,5.94E-005);
#11937= IFCELEMENTQUANTITY('1thoi3h3L2Af4RROyEzoQG',#5,'BaseQuantities',$,$,(#893,#11933,#11934,#4457,#11935,#11936));
#11938= IFCCARTESIANPOINT((48532.4993425044,-679.170002432391,10590.));
#11939= IFCAXIS2PLACEMENT3D(#11938,#7,#596);
#11940= IFCLOCALPLACEMENT(#1216,#11939);
#11941= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#4926));
#11942= IFCPRODUCTDEFINITIONSHAPE($,$,(#11941));
#11943= IFCDISCRETEACCESSORY('1Td1iR002i$Z4rDp0rCJ4s',#5,'Cap plate','PL3*90','PL3*90',#11940,#11942,'0(?)');
#11944= IFCPROPERTYSET('0GBH12UqX9VPhwIAMEnvbl',#5,'Tekla Common','Common Properties to Shared building elements',(#6417,#1267,#4436,#918,#74,#75,#919,#77,#78,#4932,#4438));
#11945= IFCCARTESIANPOINT((48645.8534633802,1461.30499612099,20197.0017431284));
#11946= IFCDIRECTION((0.,0.999999999999165,-1.29200000076086E-006));
#11947= IFCDIRECTION((0.,-1.29200000076086E-006,-0.999999999999165));
#11948= IFCAXIS2PLACEMENT3D(#11945,#11946,#11947);
#11949= IFCLOCALPLACEMENT(#133,#11948);
#11950= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#4428));
#11951= IFCPRODUCTDEFINITIONSHAPE($,$,(#11950));
#11952= IFCDISCRETEACCESSORY('1Td1iR002jZ34rDp0rCJ4s',#5,'Cap plate','PL3*94','PL3*94',#11949,#11951,'0(?)');
#11953= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.650827800000443),$);
#11954= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(0.650827800000554),$);
#11955= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.650827800000443),$);
#11956= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(8.29080000000564E-005),$);
#11957= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(8.29080000000564E-005),$);
#11958= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(8.29080000000564E-005),$);
#11959= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(88.5026730573078),$);
#11960= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0576000000000461),$);
#11961= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0276360000000235),$);
#11962= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(94.00000000008),$);
#11963= IFCPROPERTYSET('2FOcQUaiX9r9QadMxBTY0t',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#163,#11953,#11954,#11955,#11956,#11957,#11958,#4446,#11959,#11960,#11961,#11962,#4451,#4452));
#11964= IFCQUANTITYLENGTH('Width',$,$,94.00000000008);
#11965= IFCQUANTITYAREA('NetArea',$,$,0.0576000000000461);
#11966= IFCQUANTITYAREA('GrossArea',$,$,0.0276360000000235);
#11967= IFCQUANTITYVOLUME('NetVolume',$,$,8.29080000000564E-005);
#11968= IFCQUANTITYVOLUME('GrossVolume',$,$,8.29080000000564E-005);
#11969= IFCELEMENTQUANTITY('1o63bgWpn32xhM54hnRrw_',#5,'BaseQuantities',$,$,(#11964,#11965,#11966,#4457,#11967,#11968));
#11970= IFCCARTESIANPOINT((48469.3773001649,-453.478304228937,19900.0049374798));
#11971= IFCDIRECTION((-0.707106781186546,0.707106781186549,7.5360860130394E-016));
#11972= IFCDIRECTION((8.07500000052385E-006,8.07499999945806E-006,0.999999999934794));
#11973= IFCAXIS2PLACEMENT3D(#11970,#11971,#11972);
#11974= IFCLOCALPLACEMENT(#133,#11973);
#11975= IFCCARTESIANPOINT((160.003936767371,1.89174897968769E-010));
#11976= IFCCARTESIANPOINT((160.006088257262,189.994720460178));
#11977= IFCCARTESIANPOINT((0.00216983700011042,189.998687744883));
#11978= IFCPOLYLINE((#54,#11975,#11976,#11977,#54,#54,#54));
#11979= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL16*160',#11978);
#11980= IFCEXTRUDEDAREASOLID(#11979,#63,#9,16.);
#11981= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#11980));
#11982= IFCSTYLEDITEM(#11980,(#53),$);
#11983= IFCPRODUCTDEFINITIONSHAPE($,$,(#11981));
#11984= IFCDISCRETEACCESSORY('1Td1iR002jVp4rDp0rCJ4s',#5,'ANKRAJ','PL16*160','PL16*160',#11974,#11983,'P/227(?)');
#11985= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PL16*160'),$);
#11986= IFCPROPERTYSET('11uav46Tj2TvxF0yA9UCMz',#5,'Tekla Common','Common Properties to Shared building elements',(#70,#8111,#72,#160,#74,#75,#76,#77,#78,#11985,#80));
#11987= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(3.81826749264115),$);
#11988= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(3.81830757529422),$);
#11989= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(3.81826749264115),$);
#11990= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.00048640350224728),$);
#11991= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.00048640350224728),$);
#11992= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.00048640350224728),$);
#11993= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00303991552754183),$);
#11994= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(18.8568396884629),$);
#11995= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0720004579964033),$);
#11996= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0304005380198584),$);
#11997= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(160.003936757774),$);
#11998= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(189.998687756546),$);
#11999= IFCPROPERTYSET('1GvSTvLyX5_Q_QcJYmqZRB',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#163,#11987,#11988,#11989,#11990,#11991,#11992,#11993,#11994,#11995,#11996,#11997,#175,#11998));
#12000= IFCQUANTITYLENGTH('Width',$,$,160.003936757774);
#12001= IFCQUANTITYAREA('NetArea',$,$,0.0720004579964034);
#12002= IFCQUANTITYAREA('GrossArea',$,$,0.0304005380198584);
#12003= IFCQUANTITYVOLUME('NetVolume',$,$,0.00048640350224728);
#12004= IFCQUANTITYVOLUME('GrossVolume',$,$,0.00048640350224728);
#12005= IFCELEMENTQUANTITY('2xtvLIWtjDS9EBkfS3UYLE',#5,'BaseQuantities',$,$,(#12000,#12001,#12002,#100,#12003,#12004));
#12006= IFCCARTESIANPOINT((48413.5150544141,-263.267390108315,19900.0049044597));
#12007= IFCDIRECTION((4.5339999922507E-006,-4.53399999992441E-006,0.999999999979443));
#12008= IFCAXIS2PLACEMENT3D(#12006,#3932,#12007);
#12009= IFCLOCALPLACEMENT(#133,#12008);
#12010= IFCCARTESIANPOINT((0.000641226957657669,99.9999999979441));
#12011= IFCCARTESIANPOINT((200.004818721654,134.996032714858));
#12012= IFCCARTESIANPOINT((185.00491333161,149.996330255049));
#12013= IFCCARTESIANPOINT((0.000961840436502825,149.999999999462));
#12014= IFCPOLYLINE((#12010,#8247,#148,#12011,#12012,#12013,#12010));
#12015= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL16*150',#12014);
#12016= IFCEXTRUDEDAREASOLID(#12015,#63,#9,16.);
#12017= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12016));
#12018= IFCSTYLEDITEM(#12016,(#53),$);
#12019= IFCPRODUCTDEFINITIONSHAPE($,$,(#12017));
#12020= IFCDISCRETEACCESSORY('1Td1iR002jV34rDp0rCJ4s',#5,'ANKRAJ','PL16*150','PL16*150',#12009,#12019,'P/227(?)');
#12021= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PL16*150'),$);
#12022= IFCPROPERTYSET('3VeZHqN8v6pQ8LdeDmVTQg',#5,'Tekla Common','Common Properties to Shared building elements',(#70,#159,#72,#160,#74,#75,#76,#77,#78,#12021,#80));
#12023= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(3.12589476501049),$);
#12024= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(3.76807870401904),$);
#12025= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(3.12589476501049),$);
#12026= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000398203154778406),$);
#12027= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000398203154778406),$);
#12028= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000398203154778406),$);
#12029= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00215993652348356),$);
#12030= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(19.1617472982071),$);
#12031= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0598976055679192),$);
#12032= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0300006266243554),$);
#12033= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(200.004177496023),$);
#12034= IFCPROPERTYSET('1uBTNs71n3AfoSptBqUsYD',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#163,#12023,#12024,#12025,#12026,#12027,#12028,#12029,#12030,#12031,#12032,#529,#1097,#12033));
#12035= IFCQUANTITYLENGTH('Width',$,$,149.99999999976);
#12036= IFCQUANTITYAREA('NetArea',$,$,0.0598976055679192);
#12037= IFCQUANTITYAREA('GrossArea',$,$,0.0300006266243554);
#12038= IFCQUANTITYVOLUME('NetVolume',$,$,0.000398203154778406);
#12039= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000398203154778406);
#12040= IFCELEMENTQUANTITY('07yBPVo_jDH9AVM5IVNfi$',#5,'BaseQuantities',$,$,(#12035,#12036,#12037,#100,#12038,#12039));
#12041= IFCCARTESIANPOINT((48708.5693247701,-686.020643927995,10597.9955494618));
#12042= IFCAXIS2PLACEMENT3D(#12041,#5754,#5755);
#12043= IFCLOCALPLACEMENT(#4461,#12042);
#12044= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5764));
#12045= IFCPRODUCTDEFINITIONSHAPE($,$,(#12044));
#12046= IFCDISCRETEACCESSORY('1Td1iR002jU34rDp0rCJ4s',#5,'PLAKA','PL16*180','PL16*180',#12043,#12045,'P/423(?)');
#12047= IFCPROPERTYSET('3kjBDms6972Oe2uQe1YlHO',#5,'Tekla Common','Common Properties to Shared building elements',(#2109,#2110,#5770,#4523,#74,#75,#76,#1194,#78,#5772,#5773));
#12048= IFCPROPERTYSET('1F8Y4ouqbCQg5yIqleJEer',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#4527,#9795,#9796,#9797,#9798,#9799,#9800,#9801,#5783,#9802,#9803,#9804,#175,#9805));
#12049= IFCCARTESIANPOINT((48498.8534633802,1463.19994527932,20150.00174068));
#12050= IFCAXIS2PLACEMENT3D(#12049,#7,#4417);
#12051= IFCLOCALPLACEMENT(#133,#12050);
#12052= IFCRECTANGLEHOLLOWPROFILEDEF(.AREA.,'RHS300*100*10',#197,100.,300.,10.,10.,20.);
#12053= IFCCARTESIANPOINT((1963.39540873568,4.15765149921736E-019,0.));
#12054= IFCAXIS2PLACEMENT3D(#12053,#185,#501);
#12055= IFCEXTRUDEDAREASOLID(#12052,#12054,#9,1960.0004087533);
#12056= IFCCARTESIANPOINT((1963.39540873568,-3.63797880709171E-012,-150.));
#12057= IFCAXIS2PLACEMENT3D(#12056,#185,#8);
#12058= IFCPLANE(#12057);
#12059= IFCHALFSPACESOLID(#12058,.T.);
#12060= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#12055,#12059);
#12061= IFCCARTESIANPOINT((3.39499998237852,0.,-150.));
#12062= IFCAXIS2PLACEMENT3D(#12061,#7,#501);
#12063= IFCPLANE(#12062);
#12064= IFCHALFSPACESOLID(#12063,.T.);
#12065= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#12060,#12064);
#12066= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#12065));
#12067= IFCSTYLEDITEM(#12055,(#10241),$);
#12068= IFCPRODUCTDEFINITIONSHAPE($,$,(#12066));
#12069= IFCBEAM('1Td1iR002jTJ4rDp0rCJ4s',#5,'BEAM','RHS300*100*10','RHS300*100*10',#12051,#12068,'P/322(?)');
#12070= IFCBEAMTYPE('0mG0jsa_b8DxY$xdAeEbfC',#5,'RHS300*100*10',$,$,$,$,$,$,.NOTDEFINED.);
#12071= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +20.100'),$);
#12072= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +20.200'),$);
#12073= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/322(?)'),$);
#12074= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('RHS300*100*10'),$);
#12075= IFCPROPERTYSINGLEVALUE('Name',$,IFCLABEL('BEAM'),$);
#12076= IFCPROPERTYSET('0aJ8FInQ91XwTtf0q4yvtV',#5,'Tekla Common','Common Properties to Shared building elements',(#12071,#12072,#12073,#160,#74,#75,#76,#10295,#78,#12074,#12075));
#12077= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(116.933624386302),$);
#12078= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(116.933624386302),$);
#12079= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(116.933624386302),$);
#12080= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.0148960031065353),$);
#12081= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.0148960031065353),$);
#12082= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.0148960031065353),$);
#12083= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.58800012262599),$);
#12084= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(13.2453596277402),$);
#12085= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(1.54882790757166),$);
#12086= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(1.54882790757166),$);
#12087= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(100.000000000109),$);
#12088= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(1960.00040875329),$);
#12089= IFCPROPERTYSET('16GRVfjIf9ne30LoKYdG4Z',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#163,#12077,#12078,#12079,#12080,#12081,#12082,#12083,#12084,#12085,#12086,#10308,#12087,#12088));
#12090= IFCQUANTITYLENGTH('Length',$,$,1960.00040875329);
#12091= IFCQUANTITYAREA('OuterSurfaceArea',$,$,1.54882790757166);
#12092= IFCQUANTITYVOLUME('NetVolume',$,$,0.0148960031065353);
#12093= IFCQUANTITYWEIGHT('NetWeight',$,$,116.933624386302);
#12094= IFCELEMENTQUANTITY('13D1wzg15CQxtrY0Kss$KY',#5,'BaseQuantities',$,$,(#12090,#12091,#12092,#12093));
#12095= IFCCARTESIANPOINT((48715.4500314836,-565.391049220312,4799.99983865138));
#12096= IFCAXIS2PLACEMENT3D(#12095,#8075,#596);
#12097= IFCLOCALPLACEMENT(#3920,#12096);
#12098= IFCCOLOURRGB('Dark Green',0.4,0.698039215686274,0.2);
#12099= IFCSURFACESTYLERENDERING(#12098,0.,$,$,$,$,IFCNORMALISEDRATIOMEASURE(0.00390625),IFCSPECULAREXPONENT(10.),.NOTDEFINED.);
#12100= IFCSURFACESTYLE('STEEL/S235JR',.POSITIVE.,(#12099));
#12101= IFCPRESENTATIONSTYLEASSIGNMENT((#12100));
#12102= IFCTSHAPEPROFILEDEF(.AREA.,'T200-40-50-130',#197,200.,130.,40.,50.,28.,$,$,$,$,$);
#12103= IFCCARTESIANPOINT((5909.99983865167,0.,0.));
#12104= IFCAXIS2PLACEMENT3D(#12103,#185,#501);
#12105= IFCEXTRUDEDAREASOLID(#12102,#12104,#9,5909.99983865167);
#12106= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12105));
#12107= IFCSTYLEDITEM(#12105,(#12101),$);
#12108= IFCPRODUCTDEFINITIONSHAPE($,$,(#12106));
#12109= IFCBEAM('1Td1iR002jSJ4rDp0rCJ4s',#5,'DIKME','T200-40-50-130','T200-40-50-130',#12097,#12108,'P/329(?)');
#12110= IFCBEAMTYPE('3b6frRE1v0yRRpqXi1i9RM',#5,'T200-40-50-130',$,$,$,$,$,$,.NOTDEFINED.);
#12111= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/329(?)'),$);
#12112= IFCPROPERTYSINGLEVALUE('Class',$,IFCLABEL('80'),$);
#12113= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('T200-40-50-130'),$);
#12114= IFCPROPERTYSET('1Dj433mxz7AQsSSQ0O_vKN',#5,'Tekla Common','Common Properties to Shared building elements',(#2392,#10036,#12111,#3950,#74,#75,#76,#12112,#78,#12113,#4048));
#12115= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(579.918734166329),$);
#12116= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(579.918734166329),$);
#12117= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(579.918734166329),$);
#12118= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.0738749979829719),$);
#12119= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.0738749979829719),$);
#12120= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.0738749979829719),$);
#12121= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.0124999999999999),$);
#12122= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(6.76922413818686),$);
#12123= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(3.92559989350549),$);
#12124= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(3.92559989350549),$);
#12125= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(129.999999999905),$);
#12126= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(5909.99983865167),$);
#12127= IFCPROPERTYSET('3cLMcPt1j4M8TlOEwnnRDu',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#3953,#12115,#12116,#12117,#12118,#12119,#12120,#12121,#12122,#12123,#12124,#9843,#12125,#12126));
#12128= IFCQUANTITYLENGTH('Length',$,$,5909.99983865167);
#12129= IFCQUANTITYAREA('OuterSurfaceArea',$,$,3.92559989350549);
#12130= IFCQUANTITYVOLUME('NetVolume',$,$,0.0738749979829719);
#12131= IFCQUANTITYWEIGHT('NetWeight',$,$,579.918734166329);
#12132= IFCELEMENTQUANTITY('3nCFJJaq54BuqRQXFtG_sn',#5,'BaseQuantities',$,$,(#12128,#12129,#12130,#12131));
#12133= IFCCARTESIANPOINT((48715.4500314835,-565.391049220043,10499.9998386596));
#12134= IFCAXIS2PLACEMENT3D(#12133,#8075,#596);
#12135= IFCLOCALPLACEMENT(#5746,#12134);
#12136= IFCCARTESIANPOINT((5594.0048386551,0.,0.));
#12137= IFCAXIS2PLACEMENT3D(#12136,#185,#501);
#12138= IFCEXTRUDEDAREASOLID(#12102,#12137,#9,5594.0048386551);
#12139= IFCCARTESIANPOINT((140.,2.08101970293575E-010));
#12140= IFCCARTESIANPOINT((320.002746585575,4.75665729027241E-010));
#12141= IFCCARTESIANPOINT((320.002777103342,151.001007080708));
#12142= IFCCARTESIANPOINT((0.000499242516525555,151.001007079869));
#12143= IFCPOLYLINE((#8246,#12139,#12140,#12141,#12142,#8246));
#12144= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL11*151',#12143);
#12145= IFCDIRECTION((-3.12456341914857E-005,-1.17804630095364E-006,-0.999999999511161));
#12146= IFCCARTESIANPOINT((18029.0034589153,-245.10789621139,5.39843049770192));
#12147= IFCAXIS2PLACEMENT3D(#12146,#12145,#11946);
#12148= IFCEXTRUDEDAREASOLID(#12144,#12147,#9,11.);
#12149= IFCBOOLEANRESULT(.DIFFERENCE.,#12138,#12148);
#12150= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#12149));
#12151= IFCSTYLEDITEM(#12138,(#12101),$);
#12152= IFCPRODUCTDEFINITIONSHAPE($,$,(#12150));
#12153= IFCBEAM('1Td1iR002jRZ4rDp0rCJ4s',#5,'DIKME','T200-40-50-130','T200-40-50-130',#12135,#12152,'P/328(?)');
#12154= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/328(?)'),$);
#12155= IFCPROPERTYSET('0eXbB$qSLBhxYs8UFuhbaq',#5,'Tekla Common','Common Properties to Shared building elements',(#2156,#9972,#12154,#5771,#74,#75,#76,#12112,#78,#12113,#4048));
#12156= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(548.911724791694),$);
#12157= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(548.911724791694),$);
#12158= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(548.911724791694),$);
#12159= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.0699250604830183),$);
#12160= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.0699250604830183),$);
#12161= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.0699250604830183),$);
#12162= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(6.77165931355977),$);
#12163= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(3.71704319350783),$);
#12164= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(3.71704319350783),$);
#12165= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(5594.0048386551),$);
#12166= IFCPROPERTYSET('1hCrHwi7b23vWTlwEknbYA',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#5775,#12156,#12157,#12158,#12159,#12160,#12161,#12121,#12162,#12163,#12164,#9843,#12125,#12165));
#12167= IFCQUANTITYLENGTH('Length',$,$,5594.0048386551);
#12168= IFCQUANTITYAREA('OuterSurfaceArea',$,$,3.71704319350783);
#12169= IFCQUANTITYVOLUME('NetVolume',$,$,0.0699250604830183);
#12170= IFCQUANTITYWEIGHT('NetWeight',$,$,548.911724791694);
#12171= IFCELEMENTQUANTITY('1iZs4y0AvDWQAEzEhSH$Ky',#5,'BaseQuantities',$,$,(#12167,#12168,#12169,#12170));
#12172= IFCCARTESIANPOINT((48715.4500314834,-565.391049220284,15699.9998386617));
#12173= IFCAXIS2PLACEMENT3D(#12172,#8075,#596);
#12174= IFCLOCALPLACEMENT(#4461,#12173);
#12175= IFCCARTESIANPOINT((5094.00483865489,0.,0.));
#12176= IFCAXIS2PLACEMENT3D(#12175,#185,#501);
#12177= IFCEXTRUDEDAREASOLID(#12102,#12176,#9,5094.00483865489);
#12178= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12177));
#12179= IFCSTYLEDITEM(#12177,(#12101),$);
#12180= IFCPRODUCTDEFINITIONSHAPE($,$,(#12178));
#12181= IFCBEAM('1Td1iR002jQZ4rDp0rCJ4s',#5,'DIKME','T200-40-50-130','T200-40-50-130',#12174,#12180,'P/324(?)');
#12182= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +15.700'),$);
#12183= IFCPROPERTYSET('2UnHpaCaDAOvreRCXF$l6P',#5,'Tekla Common','Common Properties to Shared building elements',(#2019,#12182,#8112,#4523,#74,#75,#76,#12112,#78,#12113,#4048));
#12184= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(499.849224791808),$);
#12185= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(499.849224791808),$);
#12186= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(499.849224791808),$);
#12187= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.0636750604830329),$);
#12188= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.0636750604830329),$);
#12189= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.0636750604830329),$);
#12190= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(6.77612973175826),$);
#12191= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(3.38704319350809),$);
#12192= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(3.38704319350809),$);
#12193= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(5094.00483865489),$);
#12194= IFCPROPERTYSET('0T4Yt83LHAYftc$wHUsmQx',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#4527,#12184,#12185,#12186,#12187,#12188,#12189,#12121,#12190,#12191,#12192,#9843,#12125,#12193));
#12195= IFCQUANTITYLENGTH('Length',$,$,5094.00483865489);
#12196= IFCQUANTITYAREA('OuterSurfaceArea',$,$,3.38704319350809);
#12197= IFCQUANTITYVOLUME('NetVolume',$,$,0.0636750604830329);
#12198= IFCQUANTITYWEIGHT('NetWeight',$,$,499.849224791808);
#12199= IFCELEMENTQUANTITY('3LG8yO8bH2Iuz9269pUQ7I',#5,'BaseQuantities',$,$,(#12195,#12196,#12197,#12198));
#12200= IFCCARTESIANPOINT((46579.9926804692,-579.170000075344,-1104.9999999998));
#12201= IFCAXIS2PLACEMENT3D(#12200,#8,#7);
#12202= IFCLOCALPLACEMENT(#30,#12201);
#12203= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#12204= IFCEXTRUDEDAREASOLID(#12203,#4747,#9,16.0000000000234);
#12205= IFCSTYLEDITEM(#12204,(#195),$);
#12206= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#12207= IFCEXTRUDEDAREASOLID(#12206,#4752,#9,16.1);
#12208= IFCSTYLEDITEM(#12207,(#195),$);
#12209= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#12210= IFCEXTRUDEDAREASOLID(#12209,#4757,#9,6.5);
#12211= IFCSTYLEDITEM(#12210,(#191),$);
#12212= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#12213= IFCEXTRUDEDAREASOLID(#12212,#4762,#9,50.);
#12214= IFCSTYLEDITEM(#12213,(#191),$);
#12215= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#12216= IFCEXTRUDEDAREASOLID(#12215,#4767,#9,2.5);
#12217= IFCSTYLEDITEM(#12216,(#191),$);
#12218= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#12219= IFCEXTRUDEDAREASOLID(#12218,#4772,#9,10.);
#12220= IFCSTYLEDITEM(#12219,(#191),$);
#12221= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12204,#12207,#12210,#12213,#12216,#12219));
#12222= IFCREPRESENTATIONMAP(#10,#12221);
#12223= IFCMAPPEDITEM(#12222,#4776);
#12224= IFCMAPPEDITEM(#12222,#4781);
#12225= IFCMAPPEDITEM(#12222,#4784);
#12226= IFCMAPPEDITEM(#12222,#4787);
#12227= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#12223,#12224,#12225,#12226));
#12228= IFCPRODUCTDEFINITIONSHAPE($,$,(#12227));
#12229= IFCMECHANICALFASTENER('1Td1iR002jOZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#12202,#12228,'ID5d9c1b1b-0000-ad62-3135-373035313136',12.,50.);
#12230= IFCCARTESIANPOINT((44959.9926804692,-579.170000075344,-1104.9999999998));
#12231= IFCAXIS2PLACEMENT3D(#12230,#8,#7);
#12232= IFCLOCALPLACEMENT(#30,#12231);
#12233= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#12234= IFCEXTRUDEDAREASOLID(#12233,#4747,#9,16.0000000000234);
#12235= IFCSTYLEDITEM(#12234,(#195),$);
#12236= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#12237= IFCEXTRUDEDAREASOLID(#12236,#4752,#9,16.1);
#12238= IFCSTYLEDITEM(#12237,(#195),$);
#12239= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#12240= IFCEXTRUDEDAREASOLID(#12239,#4757,#9,6.5);
#12241= IFCSTYLEDITEM(#12240,(#191),$);
#12242= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#12243= IFCEXTRUDEDAREASOLID(#12242,#4762,#9,50.);
#12244= IFCSTYLEDITEM(#12243,(#191),$);
#12245= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#12246= IFCEXTRUDEDAREASOLID(#12245,#4767,#9,2.5);
#12247= IFCSTYLEDITEM(#12246,(#191),$);
#12248= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#12249= IFCEXTRUDEDAREASOLID(#12248,#4772,#9,10.);
#12250= IFCSTYLEDITEM(#12249,(#191),$);
#12251= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12234,#12237,#12240,#12243,#12246,#12249));
#12252= IFCREPRESENTATIONMAP(#10,#12251);
#12253= IFCMAPPEDITEM(#12252,#4776);
#12254= IFCMAPPEDITEM(#12252,#4781);
#12255= IFCMAPPEDITEM(#12252,#4784);
#12256= IFCMAPPEDITEM(#12252,#4787);
#12257= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#12253,#12254,#12255,#12256));
#12258= IFCPRODUCTDEFINITIONSHAPE($,$,(#12257));
#12259= IFCMECHANICALFASTENER('1Td1iR002jNp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#12232,#12258,'ID5d9c1b1b-0000-ad5f-3135-373035313136',12.,50.);
#12260= IFCCARTESIANPOINT((44149.9926804692,-579.170000075344,-1104.9999999998));
#12261= IFCAXIS2PLACEMENT3D(#12260,#8,#7);
#12262= IFCLOCALPLACEMENT(#30,#12261);
#12263= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#12264= IFCEXTRUDEDAREASOLID(#12263,#4747,#9,16.0000000000234);
#12265= IFCSTYLEDITEM(#12264,(#195),$);
#12266= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#12267= IFCEXTRUDEDAREASOLID(#12266,#4752,#9,16.1);
#12268= IFCSTYLEDITEM(#12267,(#195),$);
#12269= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#12270= IFCEXTRUDEDAREASOLID(#12269,#4757,#9,6.5);
#12271= IFCSTYLEDITEM(#12270,(#191),$);
#12272= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#12273= IFCEXTRUDEDAREASOLID(#12272,#4762,#9,50.);
#12274= IFCSTYLEDITEM(#12273,(#191),$);
#12275= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#12276= IFCEXTRUDEDAREASOLID(#12275,#4767,#9,2.5);
#12277= IFCSTYLEDITEM(#12276,(#191),$);
#12278= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#12279= IFCEXTRUDEDAREASOLID(#12278,#4772,#9,10.);
#12280= IFCSTYLEDITEM(#12279,(#191),$);
#12281= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12264,#12267,#12270,#12273,#12276,#12279));
#12282= IFCREPRESENTATIONMAP(#10,#12281);
#12283= IFCMAPPEDITEM(#12282,#4776);
#12284= IFCMAPPEDITEM(#12282,#4781);
#12285= IFCMAPPEDITEM(#12282,#4784);
#12286= IFCMAPPEDITEM(#12282,#4787);
#12287= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#12283,#12284,#12285,#12286));
#12288= IFCPRODUCTDEFINITIONSHAPE($,$,(#12287));
#12289= IFCMECHANICALFASTENER('1Td1iR002jN34rDp0rCJ4s',#5,'Bolt assembly',$,$,#12262,#12288,'ID5d9c1b1b-0000-ad5c-3135-373035313136',12.,50.);
#12290= IFCCARTESIANPOINT((43339.9926804692,-579.170000075344,-1104.9999999998));
#12291= IFCAXIS2PLACEMENT3D(#12290,#8,#7);
#12292= IFCLOCALPLACEMENT(#30,#12291);
#12293= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#12294= IFCEXTRUDEDAREASOLID(#12293,#4747,#9,16.0000000000234);
#12295= IFCSTYLEDITEM(#12294,(#195),$);
#12296= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#12297= IFCEXTRUDEDAREASOLID(#12296,#4752,#9,16.1);
#12298= IFCSTYLEDITEM(#12297,(#195),$);
#12299= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#12300= IFCEXTRUDEDAREASOLID(#12299,#4757,#9,6.5);
#12301= IFCSTYLEDITEM(#12300,(#191),$);
#12302= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#12303= IFCEXTRUDEDAREASOLID(#12302,#4762,#9,50.);
#12304= IFCSTYLEDITEM(#12303,(#191),$);
#12305= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#12306= IFCEXTRUDEDAREASOLID(#12305,#4767,#9,2.5);
#12307= IFCSTYLEDITEM(#12306,(#191),$);
#12308= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#12309= IFCEXTRUDEDAREASOLID(#12308,#4772,#9,10.);
#12310= IFCSTYLEDITEM(#12309,(#191),$);
#12311= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12294,#12297,#12300,#12303,#12306,#12309));
#12312= IFCREPRESENTATIONMAP(#10,#12311);
#12313= IFCMAPPEDITEM(#12312,#4776);
#12314= IFCMAPPEDITEM(#12312,#4781);
#12315= IFCMAPPEDITEM(#12312,#4784);
#12316= IFCMAPPEDITEM(#12312,#4787);
#12317= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#12313,#12314,#12315,#12316));
#12318= IFCPRODUCTDEFINITIONSHAPE($,$,(#12317));
#12319= IFCMECHANICALFASTENER('1Td1iR002jMJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#12292,#12318,'ID5d9c1b1b-0000-ad59-3135-373035313136',12.,50.);
#12320= IFCCARTESIANPOINT((40524.8986833503,-569.170195042968,-1155.00000000002));
#12321= IFCDIRECTION((4.3230000009822E-006,-0.999999999990656,0.));
#12322= IFCAXIS2PLACEMENT3D(#12320,#12321,#4471);
#12323= IFCLOCALPLACEMENT(#1450,#12322);
#12324= IFCCARTESIANPOINT((8373.08813714835,0.,0.));
#12325= IFCAXIS2PLACEMENT3D(#12324,#185,#501);
#12326= IFCEXTRUDEDAREASOLID(#5623,#12325,#9,8373.08813714835);
#12327= IFCCARTESIANPOINT((8373.08813714835,0.,-120.000000000003));
#12328= IFCAXIS2PLACEMENT3D(#12327,#185,#8);
#12329= IFCPLANE(#12328);
#12330= IFCHALFSPACESOLID(#12329,.T.);
#12331= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#12326,#12330);
#12332= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#12331));
#12333= IFCSTYLEDITEM(#12326,(#4032),$);
#12334= IFCPRODUCTDEFINITIONSHAPE($,$,(#12332));
#12335= IFCBEAM('1Td1iR002jLJ4rDp0rCJ4s',#5,'KIRIS','WB240-16-25*90-0','WB240-16-25*90-0',#12323,#12334,'P/306(?)');
#12336= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/306(?)'),$);
#12337= IFCPROPERTYSET('194WL0UhH2bffcGnMNBc$e',#5,'Tekla Common','Common Properties to Shared building elements',(#7177,#1521,#12336,#1465,#74,#75,#919,#5643,#78,#5644,#4185));
#12338= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(695.410089056036),$);
#12339= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(695.410089056036),$);
#12340= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(695.410089056036),$);
#12341= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.0885872724912147),$);
#12342= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.0885872724912147),$);
#12343= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.0885872724912147),$);
#12344= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(2.0095411529156),$);
#12345= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(13.9492510091869),$);
#12346= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(9.70044988656367),$);
#12347= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(9.70044988656367),$);
#12348= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(8373.08813716568),$);
#12349= IFCPROPERTYSET('1LWg7mChb5NO0gv2DbbpD0',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1467,#12338,#12339,#12340,#12341,#12342,#12343,#12344,#12345,#12346,#12347,#5656,#5657,#12348));
#12350= IFCQUANTITYLENGTH('Length',$,$,8373.08813716568);
#12351= IFCQUANTITYAREA('OuterSurfaceArea',$,$,9.70044988656367);
#12352= IFCQUANTITYVOLUME('NetVolume',$,$,0.0885872724912147);
#12353= IFCQUANTITYWEIGHT('NetWeight',$,$,695.410089056036);
#12354= IFCELEMENTQUANTITY('2XbYMafavDmOixFdghmxkf',#5,'BaseQuantities',$,$,(#12350,#12351,#12352,#12353));
#12355= IFCCARTESIANPOINT((46579.9926804692,-579.170000075344,4895.0000000002));
#12356= IFCAXIS2PLACEMENT3D(#12355,#8,#7);
#12357= IFCLOCALPLACEMENT(#30,#12356);
#12358= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#12359= IFCEXTRUDEDAREASOLID(#12358,#4747,#9,16.000000000024);
#12360= IFCSTYLEDITEM(#12359,(#195),$);
#12361= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#12362= IFCEXTRUDEDAREASOLID(#12361,#4752,#9,16.1);
#12363= IFCSTYLEDITEM(#12362,(#195),$);
#12364= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#12365= IFCEXTRUDEDAREASOLID(#12364,#4757,#9,6.5);
#12366= IFCSTYLEDITEM(#12365,(#191),$);
#12367= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#12368= IFCEXTRUDEDAREASOLID(#12367,#4762,#9,50.);
#12369= IFCSTYLEDITEM(#12368,(#191),$);
#12370= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#12371= IFCEXTRUDEDAREASOLID(#12370,#4767,#9,2.5);
#12372= IFCSTYLEDITEM(#12371,(#191),$);
#12373= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#12374= IFCEXTRUDEDAREASOLID(#12373,#4772,#9,10.);
#12375= IFCSTYLEDITEM(#12374,(#191),$);
#12376= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12359,#12362,#12365,#12368,#12371,#12374));
#12377= IFCREPRESENTATIONMAP(#10,#12376);
#12378= IFCMAPPEDITEM(#12377,#4776);
#12379= IFCMAPPEDITEM(#12377,#4781);
#12380= IFCMAPPEDITEM(#12377,#4784);
#12381= IFCMAPPEDITEM(#12377,#4787);
#12382= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#12378,#12379,#12380,#12381));
#12383= IFCPRODUCTDEFINITIONSHAPE($,$,(#12382));
#12384= IFCMECHANICALFASTENER('1Td1iR002jFJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#12357,#12383,'ID5d9c1b1b-0000-ad3d-3135-373035313136',12.,50.);
#12385= IFCCARTESIANPOINT((44959.9926804692,-579.170000075344,4895.0000000002));
#12386= IFCAXIS2PLACEMENT3D(#12385,#8,#7);
#12387= IFCLOCALPLACEMENT(#30,#12386);
#12388= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#12389= IFCEXTRUDEDAREASOLID(#12388,#4747,#9,16.000000000024);
#12390= IFCSTYLEDITEM(#12389,(#195),$);
#12391= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#12392= IFCEXTRUDEDAREASOLID(#12391,#4752,#9,16.1);
#12393= IFCSTYLEDITEM(#12392,(#195),$);
#12394= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#12395= IFCEXTRUDEDAREASOLID(#12394,#4757,#9,6.5);
#12396= IFCSTYLEDITEM(#12395,(#191),$);
#12397= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#12398= IFCEXTRUDEDAREASOLID(#12397,#4762,#9,50.);
#12399= IFCSTYLEDITEM(#12398,(#191),$);
#12400= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#12401= IFCEXTRUDEDAREASOLID(#12400,#4767,#9,2.5);
#12402= IFCSTYLEDITEM(#12401,(#191),$);
#12403= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#12404= IFCEXTRUDEDAREASOLID(#12403,#4772,#9,10.);
#12405= IFCSTYLEDITEM(#12404,(#191),$);
#12406= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12389,#12392,#12395,#12398,#12401,#12404));
#12407= IFCREPRESENTATIONMAP(#10,#12406);
#12408= IFCMAPPEDITEM(#12407,#4776);
#12409= IFCMAPPEDITEM(#12407,#4781);
#12410= IFCMAPPEDITEM(#12407,#4784);
#12411= IFCMAPPEDITEM(#12407,#4787);
#12412= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#12408,#12409,#12410,#12411));
#12413= IFCPRODUCTDEFINITIONSHAPE($,$,(#12412));
#12414= IFCMECHANICALFASTENER('1Td1iR002jEZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#12387,#12413,'ID5d9c1b1b-0000-ad3a-3135-373035313136',12.,50.);
#12415= IFCCARTESIANPOINT((44149.9926804692,-579.170000075344,4895.0000000002));
#12416= IFCAXIS2PLACEMENT3D(#12415,#8,#7);
#12417= IFCLOCALPLACEMENT(#30,#12416);
#12418= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#12419= IFCEXTRUDEDAREASOLID(#12418,#4747,#9,16.000000000024);
#12420= IFCSTYLEDITEM(#12419,(#195),$);
#12421= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#12422= IFCEXTRUDEDAREASOLID(#12421,#4752,#9,16.1);
#12423= IFCSTYLEDITEM(#12422,(#195),$);
#12424= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#12425= IFCEXTRUDEDAREASOLID(#12424,#4757,#9,6.5);
#12426= IFCSTYLEDITEM(#12425,(#191),$);
#12427= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#12428= IFCEXTRUDEDAREASOLID(#12427,#4762,#9,50.);
#12429= IFCSTYLEDITEM(#12428,(#191),$);
#12430= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#12431= IFCEXTRUDEDAREASOLID(#12430,#4767,#9,2.5);
#12432= IFCSTYLEDITEM(#12431,(#191),$);
#12433= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#12434= IFCEXTRUDEDAREASOLID(#12433,#4772,#9,10.);
#12435= IFCSTYLEDITEM(#12434,(#191),$);
#12436= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12419,#12422,#12425,#12428,#12431,#12434));
#12437= IFCREPRESENTATIONMAP(#10,#12436);
#12438= IFCMAPPEDITEM(#12437,#4776);
#12439= IFCMAPPEDITEM(#12437,#4781);
#12440= IFCMAPPEDITEM(#12437,#4784);
#12441= IFCMAPPEDITEM(#12437,#4787);
#12442= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#12438,#12439,#12440,#12441));
#12443= IFCPRODUCTDEFINITIONSHAPE($,$,(#12442));
#12444= IFCMECHANICALFASTENER('1Td1iR002jDp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#12417,#12443,'ID5d9c1b1b-0000-ad37-3135-373035313136',12.,50.);
#12445= IFCCARTESIANPOINT((43339.9926804692,-579.170000075344,4895.0000000002));
#12446= IFCAXIS2PLACEMENT3D(#12445,#8,#7);
#12447= IFCLOCALPLACEMENT(#30,#12446);
#12448= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#12449= IFCEXTRUDEDAREASOLID(#12448,#4747,#9,16.000000000024);
#12450= IFCSTYLEDITEM(#12449,(#195),$);
#12451= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#12452= IFCEXTRUDEDAREASOLID(#12451,#4752,#9,16.1);
#12453= IFCSTYLEDITEM(#12452,(#195),$);
#12454= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#12455= IFCEXTRUDEDAREASOLID(#12454,#4757,#9,6.5);
#12456= IFCSTYLEDITEM(#12455,(#191),$);
#12457= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#12458= IFCEXTRUDEDAREASOLID(#12457,#4762,#9,50.);
#12459= IFCSTYLEDITEM(#12458,(#191),$);
#12460= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#12461= IFCEXTRUDEDAREASOLID(#12460,#4767,#9,2.5);
#12462= IFCSTYLEDITEM(#12461,(#191),$);
#12463= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#12464= IFCEXTRUDEDAREASOLID(#12463,#4772,#9,10.);
#12465= IFCSTYLEDITEM(#12464,(#191),$);
#12466= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12449,#12452,#12455,#12458,#12461,#12464));
#12467= IFCREPRESENTATIONMAP(#10,#12466);
#12468= IFCMAPPEDITEM(#12467,#4776);
#12469= IFCMAPPEDITEM(#12467,#4781);
#12470= IFCMAPPEDITEM(#12467,#4784);
#12471= IFCMAPPEDITEM(#12467,#4787);
#12472= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#12468,#12469,#12470,#12471));
#12473= IFCPRODUCTDEFINITIONSHAPE($,$,(#12472));
#12474= IFCMECHANICALFASTENER('1Td1iR002jD34rDp0rCJ4s',#5,'Bolt assembly',$,$,#12447,#12473,'ID5d9c1b1b-0000-ad34-3135-373035313136',12.,50.);
#12475= IFCCARTESIANPOINT((46619.492680469,-474.170000153068,4874.00002733999));
#12476= IFCAXIS2PLACEMENT3D(#12475,#185,#596);
#12477= IFCLOCALPLACEMENT(#1305,#12476);
#12478= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5477));
#12479= IFCPRODUCTDEFINITIONSHAPE($,$,(#12478));
#12480= IFCDISCRETEACCESSORY('1Td1iR002jA34rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#12477,#12479,'P/431(?)');
#12481= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(1.32759531499904),$);
#12482= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(1.32759531499904),$);
#12483= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(57.9999998695394),$);
#12484= IFCPROPERTYSET('1T6s8wY_P0rxxHe2fBPx3j',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1322,#12481,#5483,#12482,#927,#928,#929,#5485,#5486,#5548,#5488,#12483,#94,#5490));
#12485= IFCQUANTITYLENGTH('Width',$,$,57.9999998695394);
#12486= IFCQUANTITYAREA('NetArea',$,$,0.0285137124284846);
#12487= IFCQUANTITYAREA('GrossArea',$,$,0.0110200270613181);
#12488= IFCQUANTITYVOLUME('NetVolume',$,$,0.000169120422292872);
#12489= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000169120422292872);
#12490= IFCELEMENTQUANTITY('2B$4gqqPPCge4$1vdKjdgY',#5,'BaseQuantities',$,$,(#12485,#12486,#12487,#100,#12488,#12489));
#12491= IFCCARTESIANPOINT((40949.4926804679,-474.170000076998,4874.00002733999));
#12492= IFCAXIS2PLACEMENT3D(#12491,#185,#596);
#12493= IFCLOCALPLACEMENT(#1305,#12492);
#12494= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5477));
#12495= IFCPRODUCTDEFINITIONSHAPE($,$,(#12494));
#12496= IFCDISCRETEACCESSORY('1Td1iR002j9J4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#12493,#12495,'P/431(?)');
#12497= IFCCARTESIANPOINT((43379.4926804679,-474.170000076998,4874.00002733999));
#12498= IFCAXIS2PLACEMENT3D(#12497,#185,#596);
#12499= IFCLOCALPLACEMENT(#1305,#12498);
#12500= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5477));
#12501= IFCPRODUCTDEFINITIONSHAPE($,$,(#12500));
#12502= IFCDISCRETEACCESSORY('1Td1iR002j8Z4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#12499,#12501,'P/431(?)');
#12503= IFCCARTESIANPOINT((44189.4926804679,-474.170000076998,4874.00002733999));
#12504= IFCAXIS2PLACEMENT3D(#12503,#185,#596);
#12505= IFCLOCALPLACEMENT(#1305,#12504);
#12506= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5477));
#12507= IFCPRODUCTDEFINITIONSHAPE($,$,(#12506));
#12508= IFCDISCRETEACCESSORY('1Td1iR002j7p4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#12505,#12507,'P/431(?)');
#12509= IFCCARTESIANPOINT((44999.4926804679,-474.170000076998,4874.00002733999));
#12510= IFCAXIS2PLACEMENT3D(#12509,#185,#596);
#12511= IFCLOCALPLACEMENT(#1305,#12510);
#12512= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5477));
#12513= IFCPRODUCTDEFINITIONSHAPE($,$,(#12512));
#12514= IFCDISCRETEACCESSORY('1Td1iR002j734rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#12511,#12513,'P/431(?)');
#12515= IFCCARTESIANPOINT((40524.9985366215,-569.169997376989,4844.99999999998));
#12516= IFCAXIS2PLACEMENT3D(#12515,#501,#7);
#12517= IFCLOCALPLACEMENT(#1305,#12516);
#12518= IFCEXTRUDEDAREASOLID(#5623,#5625,#9,8006.00080612245);
#12519= IFCBOOLEANRESULT(.DIFFERENCE.,#12518,#7517);
#12520= IFCPLANE(#5628);
#12521= IFCHALFSPACESOLID(#12520,.F.);
#12522= IFCBOOLEANRESULT(.DIFFERENCE.,#12519,#12521);
#12523= IFCPLANE(#5633);
#12524= IFCHALFSPACESOLID(#12523,.T.);
#12525= IFCBOOLEANRESULT(.DIFFERENCE.,#12522,#12524);
#12526= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#12525));
#12527= IFCSTYLEDITEM(#12518,(#4032),$);
#12528= IFCPRODUCTDEFINITIONSHAPE($,$,(#12526));
#12529= IFCBEAM('1Td1iR002j5p4rDp0rCJ4s',#5,'KIRIS','WB240-16-25*90-0','WB240-16-25*90-0',#12517,#12528,'P/305(?)');
#12530= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/305(?)'),$);
#12531= IFCPROPERTYSET('2VDZttIyb1Gxy2NK63gMMb',#5,'Tekla Common','Common Properties to Shared building elements',(#7722,#1377,#12530,#1320,#74,#75,#919,#5643,#78,#5644,#4185));
#12532= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(660.179159259368),$);
#12533= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(660.179159259368),$);
#12534= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.0840992559566074),$);
#12535= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.0840992559566074),$);
#12536= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(13.9470587067131),$);
#12537= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(9.20755749113893),$);
#12538= IFCPROPERTYSET('05L8rH9qz7VA_hH$SHNDys',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1322,#12532,#5647,#12533,#12534,#5650,#12535,#5652,#12536,#12537,#5655,#1207,#5657,#5658));
#12539= IFCQUANTITYLENGTH('Length',$,$,8006.00080612245);
#12540= IFCQUANTITYAREA('OuterSurfaceArea',$,$,9.20755749113893);
#12541= IFCQUANTITYVOLUME('NetVolume',$,$,0.0840992559566074);
#12542= IFCQUANTITYWEIGHT('NetWeight',$,$,660.179159259368);
#12543= IFCELEMENTQUANTITY('28TXI_9Mb6IvfFnx2soViu',#5,'BaseQuantities',$,$,(#12539,#12540,#12541,#12542));
#12544= IFCCARTESIANPOINT((46579.9926804692,-579.170000075344,10595.0000000002));
#12545= IFCAXIS2PLACEMENT3D(#12544,#8,#7);
#12546= IFCLOCALPLACEMENT(#30,#12545);
#12547= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#12548= IFCEXTRUDEDAREASOLID(#12547,#4747,#9,16.0000000000234);
#12549= IFCSTYLEDITEM(#12548,(#195),$);
#12550= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#12551= IFCEXTRUDEDAREASOLID(#12550,#4752,#9,16.1);
#12552= IFCSTYLEDITEM(#12551,(#195),$);
#12553= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#12554= IFCEXTRUDEDAREASOLID(#12553,#4757,#9,6.5);
#12555= IFCSTYLEDITEM(#12554,(#191),$);
#12556= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#12557= IFCEXTRUDEDAREASOLID(#12556,#4762,#9,50.);
#12558= IFCSTYLEDITEM(#12557,(#191),$);
#12559= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#12560= IFCEXTRUDEDAREASOLID(#12559,#4767,#9,2.5);
#12561= IFCSTYLEDITEM(#12560,(#191),$);
#12562= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#12563= IFCEXTRUDEDAREASOLID(#12562,#4772,#9,10.);
#12564= IFCSTYLEDITEM(#12563,(#191),$);
#12565= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12548,#12551,#12554,#12557,#12560,#12563));
#12566= IFCREPRESENTATIONMAP(#10,#12565);
#12567= IFCMAPPEDITEM(#12566,#4776);
#12568= IFCMAPPEDITEM(#12566,#4781);
#12569= IFCMAPPEDITEM(#12566,#4784);
#12570= IFCMAPPEDITEM(#12566,#4787);
#12571= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#12567,#12568,#12569,#12570));
#12572= IFCPRODUCTDEFINITIONSHAPE($,$,(#12571));
#12573= IFCMECHANICALFASTENER('1Td1iR002j234rDp0rCJ4s',#5,'Bolt assembly',$,$,#12546,#12572,'ID5d9c1b1b-0000-ad08-3135-373035313136',12.,50.);
#12574= IFCCARTESIANPOINT((44959.9926804692,-579.170000075344,10595.0000000002));
#12575= IFCAXIS2PLACEMENT3D(#12574,#8,#7);
#12576= IFCLOCALPLACEMENT(#30,#12575);
#12577= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#12578= IFCEXTRUDEDAREASOLID(#12577,#4747,#9,16.0000000000234);
#12579= IFCSTYLEDITEM(#12578,(#195),$);
#12580= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#12581= IFCEXTRUDEDAREASOLID(#12580,#4752,#9,16.1);
#12582= IFCSTYLEDITEM(#12581,(#195),$);
#12583= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#12584= IFCEXTRUDEDAREASOLID(#12583,#4757,#9,6.5);
#12585= IFCSTYLEDITEM(#12584,(#191),$);
#12586= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#12587= IFCEXTRUDEDAREASOLID(#12586,#4762,#9,50.);
#12588= IFCSTYLEDITEM(#12587,(#191),$);
#12589= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#12590= IFCEXTRUDEDAREASOLID(#12589,#4767,#9,2.5);
#12591= IFCSTYLEDITEM(#12590,(#191),$);
#12592= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#12593= IFCEXTRUDEDAREASOLID(#12592,#4772,#9,10.);
#12594= IFCSTYLEDITEM(#12593,(#191),$);
#12595= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12578,#12581,#12584,#12587,#12590,#12593));
#12596= IFCREPRESENTATIONMAP(#10,#12595);
#12597= IFCMAPPEDITEM(#12596,#4776);
#12598= IFCMAPPEDITEM(#12596,#4781);
#12599= IFCMAPPEDITEM(#12596,#4784);
#12600= IFCMAPPEDITEM(#12596,#4787);
#12601= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#12597,#12598,#12599,#12600));
#12602= IFCPRODUCTDEFINITIONSHAPE($,$,(#12601));
#12603= IFCMECHANICALFASTENER('1Td1iR002j4p4rDp0rCJ4s',#5,'Bolt assembly',$,$,#12576,#12602,'ID5d9c1b1b-0000-ad13-3135-373035313136',12.,50.);
#12604= IFCCARTESIANPOINT((44149.9926804692,-579.170000075344,10595.0000000002));
#12605= IFCAXIS2PLACEMENT3D(#12604,#8,#7);
#12606= IFCLOCALPLACEMENT(#30,#12605);
#12607= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#12608= IFCEXTRUDEDAREASOLID(#12607,#4747,#9,16.0000000000234);
#12609= IFCSTYLEDITEM(#12608,(#195),$);
#12610= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#12611= IFCEXTRUDEDAREASOLID(#12610,#4752,#9,16.1);
#12612= IFCSTYLEDITEM(#12611,(#195),$);
#12613= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#12614= IFCEXTRUDEDAREASOLID(#12613,#4757,#9,6.5);
#12615= IFCSTYLEDITEM(#12614,(#191),$);
#12616= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#12617= IFCEXTRUDEDAREASOLID(#12616,#4762,#9,50.);
#12618= IFCSTYLEDITEM(#12617,(#191),$);
#12619= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#12620= IFCEXTRUDEDAREASOLID(#12619,#4767,#9,2.5);
#12621= IFCSTYLEDITEM(#12620,(#191),$);
#12622= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#12623= IFCEXTRUDEDAREASOLID(#12622,#4772,#9,10.);
#12624= IFCSTYLEDITEM(#12623,(#191),$);
#12625= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12608,#12611,#12614,#12617,#12620,#12623));
#12626= IFCREPRESENTATIONMAP(#10,#12625);
#12627= IFCMAPPEDITEM(#12626,#4776);
#12628= IFCMAPPEDITEM(#12626,#4781);
#12629= IFCMAPPEDITEM(#12626,#4784);
#12630= IFCMAPPEDITEM(#12626,#4787);
#12631= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#12627,#12628,#12629,#12630));
#12632= IFCPRODUCTDEFINITIONSHAPE($,$,(#12631));
#12633= IFCMECHANICALFASTENER('1Td1iR002j0p4rDp0rCJ4s',#5,'Bolt assembly',$,$,#12606,#12632,'ID5d9c1b1b-0000-ad03-3135-373035313136',12.,50.);
#12634= IFCCARTESIANPOINT((43339.9926804692,-579.170000075344,10595.0000000002));
#12635= IFCAXIS2PLACEMENT3D(#12634,#8,#7);
#12636= IFCLOCALPLACEMENT(#30,#12635);
#12637= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#12638= IFCEXTRUDEDAREASOLID(#12637,#4747,#9,16.0000000000234);
#12639= IFCSTYLEDITEM(#12638,(#195),$);
#12640= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#12641= IFCEXTRUDEDAREASOLID(#12640,#4752,#9,16.1);
#12642= IFCSTYLEDITEM(#12641,(#195),$);
#12643= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#12644= IFCEXTRUDEDAREASOLID(#12643,#4757,#9,6.5);
#12645= IFCSTYLEDITEM(#12644,(#191),$);
#12646= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#12647= IFCEXTRUDEDAREASOLID(#12646,#4762,#9,50.);
#12648= IFCSTYLEDITEM(#12647,(#191),$);
#12649= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#12650= IFCEXTRUDEDAREASOLID(#12649,#4767,#9,2.5);
#12651= IFCSTYLEDITEM(#12650,(#191),$);
#12652= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#12653= IFCEXTRUDEDAREASOLID(#12652,#4772,#9,10.);
#12654= IFCSTYLEDITEM(#12653,(#191),$);
#12655= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12638,#12641,#12644,#12647,#12650,#12653));
#12656= IFCREPRESENTATIONMAP(#10,#12655);
#12657= IFCMAPPEDITEM(#12656,#4776);
#12658= IFCMAPPEDITEM(#12656,#4781);
#12659= IFCMAPPEDITEM(#12656,#4784);
#12660= IFCMAPPEDITEM(#12656,#4787);
#12661= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#12657,#12658,#12659,#12660));
#12662= IFCPRODUCTDEFINITIONSHAPE($,$,(#12661));
#12663= IFCMECHANICALFASTENER('1Td1iR002j3p4rDp0rCJ4s',#5,'Bolt assembly',$,$,#12636,#12662,'ID5d9c1b1b-0000-ad0f-3135-373035313136',12.,50.);
#12664= IFCCARTESIANPOINT((40524.9985336876,-569.170194612416,10545.));
#12665= IFCAXIS2PLACEMENT3D(#12664,#501,#7);
#12666= IFCLOCALPLACEMENT(#1216,#12665);
#12667= IFCPLANE(#5628);
#12668= IFCHALFSPACESOLID(#12667,.F.);
#12669= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#5626,#12668);
#12670= IFCPLANE(#5633);
#12671= IFCHALFSPACESOLID(#12670,.T.);
#12672= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#12669,#12671);
#12673= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#12672));
#12674= IFCPRODUCTDEFINITIONSHAPE($,$,(#12673));
#12675= IFCBEAM('1Td1iR002izZ4rDp0rCJ4s',#5,'KIRIS','WB240-16-25*90-0','WB240-16-25*90-0',#12666,#12674,'P/304(?)');
#12676= IFCPROPERTYSET('3$4yp9zln7LQ06Xa$yyy7W',#5,'Tekla Common','Common Properties to Shared building elements',(#6417,#1267,#5642,#918,#74,#75,#919,#5643,#78,#5644,#4185));
#12677= IFCCARTESIANPOINT((48608.8530789533,1555.00899999999,20104.9956931453));
#12678= IFCAXIS2PLACEMENT3D(#12677,#7,#596);
#12679= IFCLOCALPLACEMENT(#30,#12678);
#12680= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#12681= IFCCARTESIANPOINT((0.,1.89300007749116,0.));
#12682= IFCAXIS2PLACEMENT3D(#12681,#8,#7);
#12683= IFCEXTRUDEDAREASOLID(#12680,#12682,#9,16.1);
#12684= IFCSTYLEDITEM(#12683,(#195),$);
#12685= IFCCARTESIANPOINT((-25.,6.5));
#12686= IFCCARTESIANPOINT((25.,6.5));
#12687= IFCPOLYLINE((#12685,#12686));
#12688= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#12687);
#12689= IFCCIRCLE(#4349,6.5);
#12690= IFCTRIMMEDCURVE(#12689,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(3.14159265358979)),.F.,.PARAMETER.);
#12691= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#12690);
#12692= IFCCARTESIANPOINT((25.,-6.5));
#12693= IFCCARTESIANPOINT((-25.,-6.5));
#12694= IFCPOLYLINE((#12692,#12693));
#12695= IFCCOMPOSITECURVESEGMENT(.CONTINUOUS.,.T.,#12694);
#12696= IFCCIRCLE(#4359,6.5);
#12697= IFCTRIMMEDCURVE(#12696,(IFCPARAMETERVALUE(0.)),(IFCPARAMETERVALUE(3.14159265358979)),.F.,.PARAMETER.);
#12698= IFCCOMPOSITECURVESEGMENT(.DISCONTINUOUS.,.T.,#12697);
#12699= IFCCOMPOSITECURVE((#12688,#12691,#12695,#12698),.F.);
#12700= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#12699);
#12701= IFCCARTESIANPOINT((0.,-9.9,0.));
#12702= IFCAXIS2PLACEMENT3D(#12701,#8,#7);
#12703= IFCEXTRUDEDAREASOLID(#12700,#12702,#9,10.);
#12704= IFCSTYLEDITEM(#12703,(#195),$);
#12705= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3875);
#12706= IFCCARTESIANPOINT((0.,-17.92,0.));
#12707= IFCAXIS2PLACEMENT3D(#12706,#8,#7);
#12708= IFCEXTRUDEDAREASOLID(#12705,#12707,#9,7.92);
#12709= IFCSTYLEDITEM(#12708,(#558),$);
#12710= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#12711= IFCCARTESIANPOINT((0.,-10.,0.));
#12712= IFCAXIS2PLACEMENT3D(#12711,#8,#7);
#12713= IFCEXTRUDEDAREASOLID(#12710,#12712,#9,50.);
#12714= IFCSTYLEDITEM(#12713,(#558),$);
#12715= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#12716= IFCCARTESIANPOINT((0.,17.9930000774912,0.));
#12717= IFCAXIS2PLACEMENT3D(#12716,#8,#7);
#12718= IFCEXTRUDEDAREASOLID(#12715,#12717,#9,8.);
#12719= IFCSTYLEDITEM(#12718,(#558),$);
#12720= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#12721= IFCCARTESIANPOINT((0.,25.9930000774912,0.));
#12722= IFCAXIS2PLACEMENT3D(#12721,#8,#7);
#12723= IFCEXTRUDEDAREASOLID(#12720,#12722,#9,10.);
#12724= IFCSTYLEDITEM(#12723,(#558),$);
#12725= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12683,#12703,#12708,#12713,#12718,#12723));
#12726= IFCREPRESENTATIONMAP(#10,#12725);
#12727= IFCMAPPEDITEM(#12726,#247);
#12728= IFCCARTESIANPOINT((90.,0.,0.));
#12729= IFCCARTESIANTRANSFORMATIONOPERATOR3D($,$,#12728,$,$);
#12730= IFCMAPPEDITEM(#12726,#12729);
#12731= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#12727,#12730));
#12732= IFCPRODUCTDEFINITIONSHAPE($,$,(#12731));
#12733= IFCMECHANICALFASTENER('1Td1iR002iup4rDp0rCJ4s',#5,'Bolt assembly',$,$,#12679,#12732,'ID5d9c1b1b-0000-ace3-3135-373035313136',12.,50.);
#12734= IFCPROPERTYSINGLEVALUE('Bolt Name',$,IFCLABEL('BOLT12*50'),$);
#12735= IFCPROPERTYSET('3YBHYVsKz3HOnWJwuxYEtg',#5,'Tekla Bolt','Bolt Properties',(#255,#3912,#571,#3913,#259,#573,#3914,#262,#4410,#3915,#265,#266,#3916,#4795,#579,#12734));
#12736= IFCCARTESIANPOINT((48568.9993813414,1565.00176040911,4815.99999999996));
#12737= IFCAXIS2PLACEMENT3D(#12736,#8,#9);
#12738= IFCLOCALPLACEMENT(#4206,#12737);
#12739= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#4220));
#12740= IFCPRODUCTDEFINITIONSHAPE($,$,(#12739));
#12741= IFCDISCRETEACCESSORY('1Td1iR002iu34rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#12738,#12740,'P/430(?)');
#12742= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(1.74835200000101),$);
#12743= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(21.2276662339276),$);
#12744= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.013920000000008),$);
#12745= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(16.0000000028122),$);
#12746= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(240.000000000138),$);
#12747= IFCPROPERTYSET('3vYf22zbv5Vuhn7v6PeD$G',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#4228,#4229,#12742,#4231,#4232,#4233,#4234,#4235,#12743,#4237,#12744,#4239,#12745,#12746));
#12748= IFCQUANTITYAREA('GrossArea',$,$,0.013920000000008);
#12749= IFCQUANTITYVOLUME('NetVolume',$,$,0.00021552);
#12750= IFCQUANTITYVOLUME('GrossVolume',$,$,0.00021552);
#12751= IFCELEMENTQUANTITY('2oyOnSdH99th$vzPCuQQ9O',#5,'BaseQuantities',$,$,(#4242,#4243,#12748,#100,#12749,#12750));
#12752= IFCCARTESIANPOINT((48568.9994304303,1565.00176040944,10516.));
#12753= IFCAXIS2PLACEMENT3D(#12752,#8,#9);
#12754= IFCLOCALPLACEMENT(#4288,#12753);
#12755= IFCPOLYLINE((#899,#900,#952,#953,#4214,#4215,#4216,#4217,#899));
#12756= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL16*58',#12755);
#12757= IFCEXTRUDEDAREASOLID(#12756,#63,#9,16.);
#12758= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12757));
#12759= IFCSTYLEDITEM(#12757,(#53),$);
#12760= IFCPRODUCTDEFINITIONSHAPE($,$,(#12758));
#12761= IFCDISCRETEACCESSORY('1Td1iR002itJ4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#12754,#12760,'P/432(?)');
#12762= IFCPROPERTYSET('1y8ea7kN9BKhgwFnfXbbVZ',#5,'Tekla Common','Common Properties to Shared building elements',(#1227,#1228,#3207,#4268,#74,#75,#76,#77,#78,#920,#967));
#12763= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(1.74835204207447),$);
#12764= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.0033600000000007),$);
#12765= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(21.2276662368192),$);
#12766= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0139200003349878),$);
#12767= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(240.000005794733),$);
#12768= IFCPROPERTYSET('1s9uRe$gr74ucYpEYiSKNC',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#4270,#4229,#12763,#4231,#4232,#4233,#4234,#12764,#12765,#4237,#12766,#4239,#12745,#12767));
#12769= IFCQUANTITYLENGTH('Width',$,$,57.9999999953889);
#12770= IFCQUANTITYAREA('NetArea',$,$,0.0359136450002958);
#12771= IFCQUANTITYAREA('GrossArea',$,$,0.0139200003349878);
#12772= IFCQUANTITYVOLUME('NetVolume',$,$,0.000215519999853126);
#12773= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000215519999853126);
#12774= IFCELEMENTQUANTITY('1LppHyqoHAlACpfjwz1HIY',#5,'BaseQuantities',$,$,(#12769,#12770,#12771,#100,#12772,#12773));
#12775= IFCCARTESIANPOINT((48568.9995453605,1565.00176040944,15716.));
#12776= IFCAXIS2PLACEMENT3D(#12775,#8,#9);
#12777= IFCLOCALPLACEMENT(#4248,#12776);
#12778= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#4220));
#12779= IFCPRODUCTDEFINITIONSHAPE($,$,(#12778));
#12780= IFCDISCRETEACCESSORY('1Td1iR002isZ4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#12777,#12779,'P/432(?)');
#12781= IFCPROPERTYSET('1gFAIQ9oz22f1BpHY8B1vb',#5,'Tekla Common','Common Properties to Shared building elements',(#915,#916,#3207,#4268,#74,#75,#76,#77,#78,#920,#967));
#12782= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(240.000000000764),$);
#12783= IFCPROPERTYSET('1VThQFhNj9UeHnaoa7MUFo',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#4270,#4229,#4230,#4231,#4232,#4233,#4234,#12764,#12765,#4237,#4238,#4239,#12745,#12782));
#12784= IFCQUANTITYLENGTH('Width',$,$,57.9999999996726);
#12785= IFCQUANTITYAREA('NetArea',$,$,0.0359136450185403);
#12786= IFCQUANTITYAREA('GrossArea',$,$,0.0139199999999657);
#12787= IFCQUANTITYVOLUME('NetVolume',$,$,0.000215519999989962);
#12788= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000215519999989962);
#12789= IFCELEMENTQUANTITY('33rMclNQz8qB9IWwnv_fBa',#5,'BaseQuantities',$,$,(#12784,#12785,#12786,#100,#12787,#12788));
#12790= IFCLOCALPLACEMENT(#30,#10);
#12791= IFCELEMENTASSEMBLY('1Td1iR002imp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#12790,$,'C/6(?)',.NOTDEFINED.,.RIGID_FRAME.);
#12792= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(257.960476939402),$);
#12793= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('C/6(?)'),$);
#12794= IFCPROPERTYSET('1tfnnlr9H1f9O1r4PsUcLQ',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#12792,#5749,#5750,#3925,#2857,#12793));
#12795= IFCQUANTITYLENGTH('Width',$,$,130.004196166992);
#12796= IFCELEMENTQUANTITY('25sJQX7wT1keLX2AhFTJ5M',#5,'BaseQuantities',$,$,(#12795));
#12797= IFCCARTESIANPOINT((48838.8522765619,1630.00168047317,4897.99565708869));
#12798= IFCDIRECTION((-1.71500000032868E-006,0.,-0.999999999998529));
#12799= IFCAXIS2PLACEMENT3D(#12797,#12798,#501);
#12800= IFCLOCALPLACEMENT(#12790,#12799);
#12801= IFCCARTESIANPOINT((130.004196166992,1.45519152283669E-010));
#12802= IFCCARTESIANPOINT((130.,200.00025940124));
#12803= IFCCARTESIANPOINT((0.,200.00025940124));
#12804= IFCPOLYLINE((#54,#12801,#12802,#12803,#54,#54));
#12805= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL16*130',#12804);
#12806= IFCEXTRUDEDAREASOLID(#12805,#63,#9,16.);
#12807= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12806));
#12808= IFCSTYLEDITEM(#12806,(#53),$);
#12809= IFCPRODUCTDEFINITIONSHAPE($,$,(#12807));
#12810= IFCDISCRETEACCESSORY('1Td1iR002irp4rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#12800,#12809,'P/418(?)');
#12811= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/418(?)'),$);
#12812= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('C/6(?)'),$);
#12813= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PL16*130'),$);
#12814= IFCPROPERTYSET('1upPAP7djC2hwZlRVoJUhV',#5,'Tekla Common','Common Properties to Shared building elements',(#2254,#2255,#12811,#12812,#74,#75,#76,#1194,#78,#12813,#5773));
#12815= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(257.960476939402),$);
#12816= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(3.26565693940245),$);
#12817= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(3.26570964333101),$);
#12818= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(3.26565693940245),$);
#12819= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000416007253427064),$);
#12820= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000416007253427064),$);
#12821= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000416007253427064),$);
#12822= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.0260004533391611),$);
#12823= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(19.1572425638833),$);
#12824= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0625609821185615),$);
#12825= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0260008729564571),$);
#12826= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(130.004196166992),$);
#12827= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(200.000259399771),$);
#12828= IFCPROPERTYSET('34sq6Mwt56dxHadYaG$QOu',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#12815,#12816,#12817,#12818,#12819,#12820,#12821,#12822,#12823,#12824,#12825,#12826,#3222,#12827));
#12829= IFCQUANTITYAREA('NetArea',$,$,0.0625609821185615);
#12830= IFCQUANTITYAREA('GrossArea',$,$,0.0260008729564571);
#12831= IFCQUANTITYVOLUME('NetVolume',$,$,0.000416007253427064);
#12832= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000416007253427064);
#12833= IFCELEMENTQUANTITY('3mLVe88tj0C9HszymlJ5_E',#5,'BaseQuantities',$,$,(#12795,#12829,#12830,#100,#12831,#12832));
#12834= IFCLOCALPLACEMENT(#30,#10);
#12835= IFCELEMENTASSEMBLY('1Td1iR002ilJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#12834,$,'C/10(?)',.NOTDEFINED.,.RIGID_FRAME.);
#12836= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(206.404188939403),$);
#12837= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('C/10(?)'),$);
#12838= IFCPROPERTYSET('3t16U2S_b7f9dgyo98b_XA',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#12836,#4464,#4465,#3925,#2857,#12837));
#12839= IFCCARTESIANPOINT((48838.8522765619,1630.00168047317,10597.9956570887));
#12840= IFCAXIS2PLACEMENT3D(#12839,#12798,#501);
#12841= IFCLOCALPLACEMENT(#12834,#12840);
#12842= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12806));
#12843= IFCPRODUCTDEFINITIONSHAPE($,$,(#12842));
#12844= IFCDISCRETEACCESSORY('1Td1iR002ir34rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#12841,#12843,'P/418(?)');
#12845= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('C/10(?)'),$);
#12846= IFCPROPERTYSET('1jczWjPpv6h8$cmnYxTjG4',#5,'Tekla Common','Common Properties to Shared building elements',(#2109,#2110,#12811,#12845,#74,#75,#76,#1194,#78,#12813,#5773));
#12847= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(206.404188939403),$);
#12848= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(3.26565693940254),$);
#12849= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(3.26565693940254),$);
#12850= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000416007253427075),$);
#12851= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000416007253427075),$);
#12852= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000416007253427075),$);
#12853= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0625609821185618),$);
#12854= IFCPROPERTYSET('2zpaVeb3z0ROSJO_YY0EVP',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#12847,#12848,#12817,#12849,#12850,#12851,#12852,#12822,#12823,#12853,#12825,#12826,#3222,#12827));
#12855= IFCQUANTITYAREA('NetArea',$,$,0.0625609821185618);
#12856= IFCQUANTITYVOLUME('NetVolume',$,$,0.000416007253427075);
#12857= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000416007253427075);
#12858= IFCELEMENTQUANTITY('1kz4wqYp90LfizK9_rDEM4',#5,'BaseQuantities',$,$,(#12795,#12855,#12830,#100,#12856,#12857));
#12859= IFCLOCALPLACEMENT(#30,#10);
#12860= IFCELEMENTASSEMBLY('1Td1iR002ii34rDp0rCJ4s',#5,'Steel Assembly',$,$,#12859,$,'C/14(?)',.NOTDEFINED.,.RIGID_FRAME.);
#12861= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(179.432117348211),$);
#12862= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +20.150'),$);
#12863= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('C/14(?)'),$);
#12864= IFCPROPERTYSET('206HIrSt574w5DOI7xQzr4',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#12861,#9780,#12862,#3925,#2857,#12863));
#12865= IFCCARTESIANPOINT((48838.8522753139,1630.00168047317,15797.9956570887));
#12866= IFCAXIS2PLACEMENT3D(#12865,#12798,#501);
#12867= IFCLOCALPLACEMENT(#12859,#12866);
#12868= IFCCARTESIANPOINT((130.,220.000259401015));
#12869= IFCCARTESIANPOINT((0.,220.000259401015));
#12870= IFCPOLYLINE((#54,#12801,#12868,#12869,#54,#54));
#12871= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL16*130',#12870);
#12872= IFCEXTRUDEDAREASOLID(#12871,#63,#9,16.);
#12873= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12872));
#12874= IFCSTYLEDITEM(#12872,(#53),$);
#12875= IFCPRODUCTDEFINITIONSHAPE($,$,(#12873));
#12876= IFCDISCRETEACCESSORY('1Td1iR002iqJ4rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#12867,#12875,'P/417(?)');
#12877= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/417(?)'),$);
#12878= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('C/14(?)'),$);
#12879= IFCPROPERTYSET('2Konjz$_nA4xvoeHKHTUoi',#5,'Tekla Common','Common Properties to Shared building elements',(#1901,#1902,#12877,#12878,#74,#75,#76,#1194,#78,#12813,#5773));
#12880= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(179.432117348211),$);
#12881= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(3.59222220978672),$);
#12882= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(3.59228018410143),$);
#12883= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(3.59222220978672),$);
#12884= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000457607924813594),$);
#12885= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000457607924813594),$);
#12886= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000457607924813594),$);
#12887= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.0286004953008318),$);
#12888= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(19.0414350914798),$);
#12889= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0684010660418257),$);
#12890= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0286009568797884),$);
#12891= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(220.000259399705),$);
#12892= IFCPROPERTYSET('1Pjra6BiDDBBbMEZiHkzGQ',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#12880,#12881,#12882,#12883,#12884,#12885,#12886,#12887,#12888,#12889,#12890,#12826,#94,#12891));
#12893= IFCQUANTITYAREA('NetArea',$,$,0.0684010660418257);
#12894= IFCQUANTITYAREA('GrossArea',$,$,0.0286009568797884);
#12895= IFCQUANTITYVOLUME('NetVolume',$,$,0.000457607924813594);
#12896= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000457607924813594);
#12897= IFCELEMENTQUANTITY('3ml4SUquLAI9a4r1Mf70$E',#5,'BaseQuantities',$,$,(#12795,#12893,#12894,#100,#12895,#12896));
#12898= IFCLOCALPLACEMENT(#30,#10);
#12899= IFCELEMENTASSEMBLY('1Td1iR002ikJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#12898,$,'ANK/16(?)',.NOTDEFINED.,.RIGID_FRAME.);
#12900= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(8.06356284307981),$);
#12901= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' +19.950'),$);
#12902= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('ANK/16(?)'),$);
#12903= IFCPROPERTYSET('1$Ye50rov4_x6MtEb24zXm',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#12900,#12901,#136,#39,#2857,#12902));
#12904= IFCQUANTITYLENGTH('Width',$,$,150.);
#12905= IFCELEMENTQUANTITY('2Up7HhIGzD2ufBgZD5_Icg',#5,'BaseQuantities',$,$,(#12904));
#12906= IFCCARTESIANPOINT((48504.845143608,1625.00899999999,20200.001693145));
#12907= IFCAXIS2PLACEMENT3D(#12906,#7,#501);
#12908= IFCLOCALPLACEMENT(#12898,#12907);
#12909= IFCCARTESIANPOINT((55.,2.85841191985777E-012));
#12910= IFCCARTESIANPOINT((70.,15.0000000000036));
#12911= IFCCARTESIANPOINT((70.,150.));
#12912= IFCCARTESIANPOINT((3.63797880709171E-012,150.));
#12913= IFCPOLYLINE((#54,#12909,#12910,#12911,#12912,#54));
#12914= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL8*70',#12913);
#12915= IFCCARTESIANPOINT((0.,0.,-4.));
#12916= IFCAXIS2PLACEMENT3D(#12915,#9,#7);
#12917= IFCEXTRUDEDAREASOLID(#12914,#12916,#9,8.);
#12918= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12917));
#12919= IFCSTYLEDITEM(#12917,(#53),$);
#12920= IFCPRODUCTDEFINITIONSHAPE($,$,(#12918));
#12921= IFCDISCRETEACCESSORY('1Td1iR002ipZ4rDp0rCJ4s',#5,'DETAY','PL8*70','PL8*70',#12908,#12920,'P/389(?)');
#12922= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +20.050'),$);
#12923= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/389(?)'),$);
#12924= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('ANK/16(?)'),$);
#12925= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PL8*70'),$);
#12926= IFCPROPERTYSET('1K2UIH5crE1vwdpQYeTVn0',#5,'Tekla Common','Common Properties to Shared building elements',(#12922,#12072,#12923,#12924,#74,#75,#76,#77,#78,#12925,#921));
#12927= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(8.06356284307981),$);
#12928= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.652334999999973),$);
#12929= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(0.6594),$);
#12930= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.652334999999973),$);
#12931= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(8.30999999999966E-005),$);
#12932= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(8.30999999999966E-005),$);
#12933= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(8.30999999999966E-005),$);
#12934= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00044),$);
#12935= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(37.135376190891),$);
#12936= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0242247056274839),$);
#12937= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0105),$);
#12938= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(8.),$);
#12939= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(150.),$);
#12940= IFCPROPERTYSET('1AFC0sBgr2h99zQoInaEoS',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#12927,#12928,#12929,#12930,#12931,#12932,#12933,#12934,#12935,#12936,#12937,#10678,#12938,#12939));
#12941= IFCQUANTITYLENGTH('Width',$,$,70.);
#12942= IFCQUANTITYAREA('NetArea',$,$,0.0242247056274839);
#12943= IFCQUANTITYAREA('GrossArea',$,$,0.0105);
#12944= IFCQUANTITYAREA('CrossSectionArea',$,$,6.4E-005);
#12945= IFCQUANTITYVOLUME('NetVolume',$,$,8.30999999999966E-005);
#12946= IFCQUANTITYVOLUME('GrossVolume',$,$,8.30999999999966E-005);
#12947= IFCELEMENTQUANTITY('2v_qwBJeXBw9Lnzo5Fv7sr',#5,'BaseQuantities',$,$,(#12941,#12942,#12943,#12944,#12945,#12946));
#12948= IFCCARTESIANPOINT((48504.845143608,1475.00899999999,20200.001693145));
#12949= IFCAXIS2PLACEMENT3D(#12948,#185,#8);
#12950= IFCLOCALPLACEMENT(#12898,#12949);
#12951= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12917));
#12952= IFCPRODUCTDEFINITIONSHAPE($,$,(#12951));
#12953= IFCDISCRETEACCESSORY('1Td1iR002iop4rDp0rCJ4s',#5,'DETAY','PL8*70','PL8*70',#12950,#12952,'P/389(?)');
#12954= IFCCARTESIANPOINT((48373.8472798384,1625.00899999999,20125.001693145));
#12955= IFCAXIS2PLACEMENT3D(#12954,#9,#501);
#12956= IFCLOCALPLACEMENT(#12898,#12955);
#12957= IFCRECTANGLEPROFILEDEF(.AREA.,'PLT10*150',#197,10.,150.);
#12958= IFCCARTESIANPOINT((150.,0.,0.));
#12959= IFCAXIS2PLACEMENT3D(#12958,#185,#501);
#12960= IFCEXTRUDEDAREASOLID(#12957,#12959,#9,150.);
#12961= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12960));
#12962= IFCSTYLEDITEM(#12960,(#4477),$);
#12963= IFCPRODUCTDEFINITIONSHAPE($,$,(#12961));
#12964= IFCDISCRETEACCESSORY('1Td1iR002io34rDp0rCJ4s',#5,'ANKRAJ','PLT10*150','PLT10*150',#12956,#12963,'P/337(?)');
#12965= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/337(?)'),$);
#12966= IFCPROPERTYSINGLEVALUE('Class',$,IFCLABEL('3'),$);
#12967= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PLT10*150'),$);
#12968= IFCPROPERTYSET('0CmFXvPg51$wdGCblCzljD',#5,'Tekla Common','Common Properties to Shared building elements',(#12922,#12072,#12965,#12924,#74,#75,#76,#12966,#78,#12967,#80));
#12969= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(1.76625),$);
#12970= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(1.76625),$);
#12971= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(1.76625),$);
#12972= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.000225),$);
#12973= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.000225),$);
#12974= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.000225),$);
#12975= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.0015),$);
#12976= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(28.8747346072187),$);
#12977= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.051),$);
#12978= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.051),$);
#12979= IFCPROPERTYSET('3qPNUiF1H328Srb8FJrkCi',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#12927,#12969,#12970,#12971,#12972,#12973,#12974,#12975,#12976,#12977,#12978,#529,#8277,#12939));
#12980= IFCQUANTITYLENGTH('Length',$,$,150.);
#12981= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.051);
#12982= IFCQUANTITYVOLUME('NetVolume',$,$,0.000225);
#12983= IFCQUANTITYWEIGHT('NetWeight',$,$,1.76625);
#12984= IFCELEMENTQUANTITY('2l_3SyVFrB8fK04bXkZFOS',#5,'BaseQuantities',$,$,(#12980,#12981,#12982,#12983));
#12985= IFCCARTESIANPOINT((48738.8523195308,1565.00200007748,10545.));
#12986= IFCAXIS2PLACEMENT3D(#12985,#7,#596);
#12987= IFCLOCALPLACEMENT(#12790,#12986);
#12988= IFCTSHAPEPROFILEDEF(.AREA.,'T200-20-20-110',#197,200.,110.,20.,20.,14.,$,$,$,$,$);
#12989= IFCCARTESIANPOINT((5700.,0.,0.));
#12990= IFCAXIS2PLACEMENT3D(#12989,#185,#501);
#12991= IFCEXTRUDEDAREASOLID(#12988,#12990,#9,5700.);
#12992= IFCCARTESIANPOINT((5639.004,119.999680391687,-220.000319453342));
#12993= IFCAXIS2PLACEMENT3D(#12992,#7,#501);
#12994= IFCPLANE(#12993);
#12995= IFCHALFSPACESOLID(#12994,.F.);
#12996= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#12991,#12995);
#12997= IFCCARTESIANPOINT((45.0040000000008,-60.0003196083126,-220.000319453342));
#12998= IFCAXIS2PLACEMENT3D(#12997,#185,#8);
#12999= IFCPLANE(#12998);
#13000= IFCHALFSPACESOLID(#12999,.F.);
#13001= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#12996,#13000);
#13002= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#13001));
#13003= IFCSTYLEDITEM(#12991,(#499),$);
#13004= IFCPRODUCTDEFINITIONSHAPE($,$,(#13002));
#13005= IFCBEAM('1Td1iR002imZ4rDp0rCJ4s',#5,'DIKME','T200-20-20-110','T200-20-20-110',#12987,#13004,'P/286(?)');
#13006= IFCBEAMTYPE('1GjHN0zF93AO6tuftgycay',#5,'T200-20-20-110',$,$,$,$,$,$,.NOTDEFINED.);
#13007= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/286(?)'),$);
#13008= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('T200-20-20-110'),$);
#13009= IFCPROPERTYSET('1wUoxMEOT84wpMyMouBBKT',#5,'Tekla Common','Common Properties to Shared building elements',(#2156,#9972,#13007,#12812,#74,#75,#76,#515,#78,#13008,#4048));
#13010= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(254.69482),$);
#13011= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(259.521),$);
#13012= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(254.69482),$);
#13013= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.0324452),$);
#13014= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.03306),$);
#13015= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.0324452),$);
#13016= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.0058),$);
#13017= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(13.6629398273589),$);
#13018= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(3.47988),$);
#13019= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(3.5456),$);
#13020= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(5594.),$);
#13021= IFCPROPERTYSET('2WkVyXQNPFMvqzFhiqW_TE',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#12815,#13010,#13011,#13012,#13013,#13014,#13015,#13016,#13017,#13018,#13019,#9843,#9844,#13020));
#13022= IFCQUANTITYLENGTH('Length',$,$,5594.);
#13023= IFCQUANTITYAREA('OuterSurfaceArea',$,$,3.47988);
#13024= IFCQUANTITYVOLUME('NetVolume',$,$,0.0324452);
#13025= IFCQUANTITYWEIGHT('NetWeight',$,$,254.69482);
#13026= IFCELEMENTQUANTITY('0osUuJlSrF8h9mAwMiQAER',#5,'BaseQuantities',$,$,(#13022,#13023,#13024,#13025));
#13027= IFCCARTESIANPOINT((48738.8523195308,1565.00200007748,15745.));
#13028= IFCAXIS2PLACEMENT3D(#13027,#7,#596);
#13029= IFCLOCALPLACEMENT(#12834,#13028);
#13030= IFCTSHAPEPROFILEDEF(.AREA.,'T200-16-20-110',#197,200.,110.,16.,20.,11.2,$,$,$,$,$);
#13031= IFCCARTESIANPOINT((5200.,0.,0.));
#13032= IFCAXIS2PLACEMENT3D(#13031,#185,#501);
#13033= IFCEXTRUDEDAREASOLID(#13030,#13032,#9,5200.);
#13034= IFCCARTESIANPOINT((5139.004,119.999680391687,-220.000319453342));
#13035= IFCAXIS2PLACEMENT3D(#13034,#7,#501);
#13036= IFCPLANE(#13035);
#13037= IFCHALFSPACESOLID(#13036,.F.);
#13038= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#13033,#13037);
#13039= IFCPLANE(#12998);
#13040= IFCHALFSPACESOLID(#13039,.F.);
#13041= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#13038,#13040);
#13042= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#13041));
#13043= IFCSTYLEDITEM(#13033,(#5245),$);
#13044= IFCPRODUCTDEFINITIONSHAPE($,$,(#13042));
#13045= IFCBEAM('1Td1iR002il34rDp0rCJ4s',#5,'DIKME','T200-16-20-110','T200-16-20-110',#13029,#13044,'P/316(?)');
#13046= IFCBEAMTYPE('23xYt$Awn5rwJH_1nt6z5U',#5,'T200-16-20-110',$,$,$,$,$,$,.NOTDEFINED.);
#13047= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/316(?)'),$);
#13048= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('T200-16-20-110'),$);
#13049= IFCPROPERTYSET('0xSIXvTVjFO8BJH266zk6W',#5,'Tekla Common','Common Properties to Shared building elements',(#2019,#12182,#13047,#12845,#74,#75,#76,#5256,#78,#13048,#4048));
#13050= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(203.138532),$);
#13051= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(207.3656),$);
#13052= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(203.138532),$);
#13053= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.02587752),$);
#13054= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.026416),$);
#13055= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.02587752),$);
#13056= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00508),$);
#13057= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(15.5974347594478),$);
#13058= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(3.16844),$);
#13059= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(3.23416),$);
#13060= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(5094.),$);
#13061= IFCPROPERTYSET('1f2T97CvnAEQAKC8kHuttB',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#12847,#13050,#13051,#13052,#13053,#13054,#13055,#13056,#13057,#13058,#13059,#9843,#9844,#13060));
#13062= IFCQUANTITYLENGTH('Length',$,$,5094.);
#13063= IFCQUANTITYAREA('OuterSurfaceArea',$,$,3.16844);
#13064= IFCQUANTITYVOLUME('NetVolume',$,$,0.02587752);
#13065= IFCQUANTITYWEIGHT('NetWeight',$,$,203.138532);
#13066= IFCELEMENTQUANTITY('2oRyy2DUXAhRN3i3vk5HD$',#5,'BaseQuantities',$,$,(#13062,#13063,#13064,#13065));
#13067= IFCCARTESIANPOINT((48378.8531783713,1550.00899999999,20199.9974118494));
#13068= IFCAXIS2PLACEMENT3D(#13067,#501,#596);
#13069= IFCLOCALPLACEMENT(#12898,#13068);
#13070= IFCCARTESIANPOINT((250.001907348633,-1.16415321826935E-010));
#13071= IFCCARTESIANPOINT((250.001892089844,270.000427246094));
#13072= IFCCARTESIANPOINT((30.0025939941406,270.000457763672));
#13073= IFCCARTESIANPOINT((30.0025939941406,139.999374389648));
#13074= IFCCARTESIANPOINT((-0.00428182445466518,139.998825073242));
#13075= IFCPOLYLINE((#54,#13070,#13071,#13072,#13073,#13074,#54,#54));
#13076= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL10*250',#13075);
#13077= IFCEXTRUDEDAREASOLID(#13076,#8254,#9,10.);
#13078= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#13077));
#13079= IFCSTYLEDITEM(#13077,(#4477),$);
#13080= IFCPRODUCTDEFINITIONSHAPE($,$,(#13078));
#13081= IFCPLATE('1Td1iR002ik34rDp0rCJ4s',#5,'ANKRAJ','PL10*250','PL10*250',#13069,#13080,'P/224(?)');
#13082= IFCPLATETYPE('1aoOMrRaXBjRlFj6K$JlYq',#5,'PL10*250',$,$,$,$,$,$,.NOTDEFINED.);
#13083= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +19.950'),$);
#13084= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/224(?)'),$);
#13085= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PL10*250'),$);
#13086= IFCPROPERTYSET('3lFNSmmZ9FnfqOxYfYuRgq',#5,'Tekla Common','Common Properties to Shared building elements',(#13083,#12072,#13084,#12924,#74,#75,#76,#12966,#78,#13085,#80));
#13087= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(4.99264284307986),$);
#13088= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(5.29889023966975),$);
#13089= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(4.99264284307986),$);
#13090= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.00063600545771718),$);
#13091= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.00063600545771718),$);
#13092= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.00063600545771718),$);
#13093= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00139998825138721),$);
#13094= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(27.5607889525744),$);
#13095= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.137601175713705),$);
#13096= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0675017864926083),$);
#13097= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(250.006181261422),$);
#13098= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(270.000470196472),$);
#13099= IFCPROPERTYSET('1IaU_ftGz4Yv0KW35S$QbH',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#12927,#13087,#13088,#13089,#13090,#13091,#13092,#13093,#13094,#13095,#13096,#13097,#8277,#13098));
#13100= IFCQUANTITYLENGTH('Width',$,$,250.006181261422);
#13101= IFCQUANTITYAREA('NetArea',$,$,0.137601175713705);
#13102= IFCQUANTITYAREA('GrossArea',$,$,0.0675017864926083);
#13103= IFCQUANTITYVOLUME('NetVolume',$,$,0.00063600545771718);
#13104= IFCQUANTITYVOLUME('GrossVolume',$,$,0.00063600545771718);
#13105= IFCELEMENTQUANTITY('085KjqyJ95kPBwHocQyufX',#5,'BaseQuantities',$,$,(#13100,#13101,#13102,#8283,#13103,#13104));
#13106= IFCCARTESIANPOINT((48703.8523195308,1565.00200007748,20200.));
#13107= IFCAXIS2PLACEMENT3D(#13106,#7,#596);
#13108= IFCLOCALPLACEMENT(#12859,#13107);
#13109= IFCTSHAPEPROFILEDEF(.AREA.,'T270-16-16-110',#197,270.,110.,16.,16.,11.2,$,$,$,$,$);
#13110= IFCCARTESIANPOINT((4455.,0.,0.));
#13111= IFCAXIS2PLACEMENT3D(#13110,#185,#501);
#13112= IFCEXTRUDEDAREASOLID(#13109,#13111,#9,4455.);
#13113= IFCCARTESIANPOINT((110.004554748535,0.));
#13114= IFCCARTESIANPOINT((110.004554748535,-280.002288818359));
#13115= IFCCARTESIANPOINT((300.003173828125,-280.002288818359));
#13116= IFCCARTESIANPOINT((300.0029296875,49.9983062744141));
#13117= IFCCARTESIANPOINT((0.0029211244545877,49.9983062744141));
#13118= IFCPOLYLINE((#54,#13113,#13114,#13115,#13116,#13117,#54,#54));
#13119= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL130*300',#13118);
#13120= IFCCARTESIANPOINT((49.9983068549809,64.9969901568838,-165.003240577695));
#13121= IFCAXIS2PLACEMENT3D(#13120,#501,#9);
#13122= IFCEXTRUDEDAREASOLID(#13119,#13121,#9,130.);
#13123= IFCBOOLEANRESULT(.DIFFERENCE.,#13112,#13122);
#13124= IFCDIRECTION((0.0121940170025714,0.,-0.999925650210725));
#13125= IFCCARTESIANPOINT((0.,-55.0003196083126,-138.780942490324));
#13126= IFCDIRECTION((0.999925650210725,0.,0.0121940170025714));
#13127= IFCAXIS2PLACEMENT3D(#13125,#13124,#13126);
#13128= IFCPLANE(#13127);
#13129= IFCHALFSPACESOLID(#13128,.F.);
#13130= IFCBOOLEANRESULT(.DIFFERENCE.,#13123,#13129);
#13131= IFCCARTESIANPOINT((4394.004,59.9996803916874,-185.000319530831));
#13132= IFCAXIS2PLACEMENT3D(#13131,#7,#501);
#13133= IFCPLANE(#13132);
#13134= IFCHALFSPACESOLID(#13133,.F.);
#13135= IFCBOOLEANRESULT(.DIFFERENCE.,#13130,#13134);
#13136= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#13135));
#13137= IFCSTYLEDITEM(#13112,(#1627),$);
#13138= IFCPRODUCTDEFINITIONSHAPE($,$,(#13136));
#13139= IFCBEAM('1Td1iR002ihp4rDp0rCJ4s',#5,'DIKME','T270-16-16-110','T270-16-16-110',#13108,#13138,'P/319(?)');
#13140= IFCBEAMTYPE('1jmLL37UDFH8aEoxNh9C30',#5,'T270-16-16-110',$,$,$,$,$,$,.NOTDEFINED.);
#13141= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +20.150'),$);
#13142= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/319(?)'),$);
#13143= IFCPROPERTYSINGLEVALUE('Class',$,IFCLABEL('86'),$);
#13144= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('T270-16-16-110'),$);
#13145= IFCPROPERTYSET('3MxT05FYPFMAqb96DDKTP2',#5,'Tekla Common','Common Properties to Shared building elements',(#1598,#13141,#13142,#12878,#74,#75,#76,#13143,#78,#13144,#4048));
#13146= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(175.839895138424),$);
#13147= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(203.675472),$);
#13148= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(175.839895138424),$);
#13149= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.0223999866418374),$);
#13150= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.02594592),$);
#13151= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.0223999866418374),$);
#13152= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00128002102673345),$);
#13153= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(16.7758495434135),$);
#13154= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(2.94986362457181),$);
#13155= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(3.397448),$);
#13156= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(270.),$);
#13157= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(4344.00569314502),$);
#13158= IFCPROPERTYSET('33Sofup_X8LBB1NqOtHNRZ',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#12880,#13146,#13147,#13148,#13149,#13150,#13151,#13152,#13153,#13154,#13155,#13156,#9844,#13157));
#13159= IFCQUANTITYLENGTH('Length',$,$,4344.00569314502);
#13160= IFCQUANTITYAREA('OuterSurfaceArea',$,$,2.94986362457181);
#13161= IFCQUANTITYVOLUME('NetVolume',$,$,0.0223999866418374);
#13162= IFCQUANTITYWEIGHT('NetWeight',$,$,175.839895138424);
#13163= IFCELEMENTQUANTITY('2d1jFM1aTEdwY5BQPbLrM5',#5,'BaseQuantities',$,$,(#13159,#13160,#13161,#13162));
#13164= IFCCARTESIANPOINT((48738.8523195316,1565.00200007709,4845.));
#13165= IFCAXIS2PLACEMENT3D(#13164,#7,#596);
#13166= IFCLOCALPLACEMENT(#9440,#13165);
#13167= IFCCARTESIANPOINT((6175.00000000004,0.,0.));
#13168= IFCAXIS2PLACEMENT3D(#13167,#185,#501);
#13169= IFCEXTRUDEDAREASOLID(#9816,#13168,#9,6175.00000000004);
#13170= IFCCARTESIANPOINT((45.,-60.0003196086755,-220.000319454492));
#13171= IFCAXIS2PLACEMENT3D(#13170,#185,#8);
#13172= IFCPLANE(#13171);
#13173= IFCHALFSPACESOLID(#13172,.F.);
#13174= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#13169,#13173);
#13175= IFCPLANE(#13171);
#13176= IFCHALFSPACESOLID(#13175,.F.);
#13177= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#13174,#13176);
#13178= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#13177));
#13179= IFCSTYLEDITEM(#13169,(#4116),$);
#13180= IFCPRODUCTDEFINITIONSHAPE($,$,(#13178));
#13181= IFCBEAM('1Td1iR002ig34rDp0rCJ4s',#5,'DIKME','T200-25-25-110','T200-25-25-110',#13166,#13180,'P/387(?)');
#13182= IFCBEAMTYPE('2xzwOwmzX1_e41mIWuKDAi',#5,'T200-25-25-110',$,$,$,$,$,$,.NOTDEFINED.);
#13183= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/387(?)'),$);
#13184= IFCPROPERTYSET('2wpZQzmBT02e58Z$zx$Ggn',#5,'Tekla Common','Common Properties to Shared building elements',(#8189,#10036,#13183,#9453,#74,#75,#76,#4183,#78,#9831,#4048));
#13185= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(342.858562500002),$);
#13186= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(345.375468750002),$);
#13187= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(342.858562500002),$);
#13188= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.0436762500000003),$);
#13189= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.0439968750000003),$);
#13190= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.0436762500000003),$);
#13191= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(11.1265997622562),$);
#13192= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(3.81485000000003),$);
#13193= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(3.84275000000003),$);
#13194= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(6130.00000000004),$);
#13195= IFCPROPERTYSET('0HPqpv4kH9a8TcEZaj2V_l',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#9455,#13185,#13186,#13187,#13188,#13189,#13190,#9839,#13191,#13192,#13193,#9843,#9844,#13194));
#13196= IFCQUANTITYLENGTH('Length',$,$,6130.00000000004);
#13197= IFCQUANTITYAREA('OuterSurfaceArea',$,$,3.81485000000003);
#13198= IFCQUANTITYVOLUME('NetVolume',$,$,0.0436762500000003);
#13199= IFCQUANTITYWEIGHT('NetWeight',$,$,342.858562500002);
#13200= IFCELEMENTQUANTITY('1wbrdzo0D6eehOcAVLyAUg',#5,'BaseQuantities',$,$,(#13196,#13197,#13198,#13199));
#13201= IFCCARTESIANPOINT((48608.8530789533,3745.00899999999,20104.9956931453));
#13202= IFCAXIS2PLACEMENT3D(#13201,#7,#596);
#13203= IFCLOCALPLACEMENT(#30,#13202);
#13204= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#13205= IFCEXTRUDEDAREASOLID(#13204,#12682,#9,16.1);
#13206= IFCSTYLEDITEM(#13205,(#195),$);
#13207= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#12699);
#13208= IFCEXTRUDEDAREASOLID(#13207,#12702,#9,10.0000000000001);
#13209= IFCSTYLEDITEM(#13208,(#195),$);
#13210= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3875);
#13211= IFCEXTRUDEDAREASOLID(#13210,#12707,#9,7.92);
#13212= IFCSTYLEDITEM(#13211,(#558),$);
#13213= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#13214= IFCEXTRUDEDAREASOLID(#13213,#12712,#9,50.);
#13215= IFCSTYLEDITEM(#13214,(#558),$);
#13216= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#13217= IFCEXTRUDEDAREASOLID(#13216,#12717,#9,8.);
#13218= IFCSTYLEDITEM(#13217,(#558),$);
#13219= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#13220= IFCEXTRUDEDAREASOLID(#13219,#12722,#9,10.);
#13221= IFCSTYLEDITEM(#13220,(#558),$);
#13222= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#13205,#13208,#13211,#13214,#13217,#13220));
#13223= IFCREPRESENTATIONMAP(#10,#13222);
#13224= IFCMAPPEDITEM(#13223,#247);
#13225= IFCMAPPEDITEM(#13223,#12729);
#13226= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#13224,#13225));
#13227= IFCPRODUCTDEFINITIONSHAPE($,$,(#13226));
#13228= IFCMECHANICALFASTENER('1Td1iR002idp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#13203,#13227,'ID5d9c1b1b-0000-ac9f-3135-373035313136',12.,50.);
#13229= IFCCARTESIANPOINT((48568.9993813414,3755.00176040911,4815.99999999996));
#13230= IFCAXIS2PLACEMENT3D(#13229,#8,#9);
#13231= IFCLOCALPLACEMENT(#4206,#13230);
#13232= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#4220));
#13233= IFCPRODUCTDEFINITIONSHAPE($,$,(#13232));
#13234= IFCDISCRETEACCESSORY('1Td1iR002id34rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#13231,#13233,'P/430(?)');
#13235= IFCQUANTITYVOLUME('NetVolume',$,$,0.00021552);
#13236= IFCQUANTITYVOLUME('GrossVolume',$,$,0.00021552);
#13237= IFCELEMENTQUANTITY('1QpuvR62H0SheBAR0Cu$BJ',#5,'BaseQuantities',$,$,(#4242,#4243,#12748,#100,#13235,#13236));
#13238= IFCCARTESIANPOINT((48568.9994304303,3755.00176040944,10516.));
#13239= IFCAXIS2PLACEMENT3D(#13238,#8,#9);
#13240= IFCLOCALPLACEMENT(#4288,#13239);
#13241= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12757));
#13242= IFCPRODUCTDEFINITIONSHAPE($,$,(#13241));
#13243= IFCDISCRETEACCESSORY('1Td1iR002icJ4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#13240,#13242,'P/432(?)');
#13244= IFCQUANTITYVOLUME('NetVolume',$,$,0.000215519999853126);
#13245= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000215519999853126);
#13246= IFCELEMENTQUANTITY('1w_4t2zxH1hOyrVcHYqPq3',#5,'BaseQuantities',$,$,(#12769,#12770,#12771,#100,#13244,#13245));
#13247= IFCCARTESIANPOINT((48568.9995453605,3755.00176040944,15716.));
#13248= IFCAXIS2PLACEMENT3D(#13247,#8,#9);
#13249= IFCLOCALPLACEMENT(#4248,#13248);
#13250= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#4220));
#13251= IFCPRODUCTDEFINITIONSHAPE($,$,(#13250));
#13252= IFCDISCRETEACCESSORY('1Td1iR002ibZ4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#13249,#13251,'P/432(?)');
#13253= IFCQUANTITYVOLUME('NetVolume',$,$,0.000215519999989962);
#13254= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000215519999989962);
#13255= IFCELEMENTQUANTITY('2lnGhW5Fz07AKxw184e$$m',#5,'BaseQuantities',$,$,(#12784,#12785,#12786,#100,#13253,#13254));
#13256= IFCLOCALPLACEMENT(#30,#10);
#13257= IFCELEMENTASSEMBLY('1Td1iR002iVp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#13256,$,'C/6(?)',.NOTDEFINED.,.RIGID_FRAME.);
#13258= IFCCARTESIANPOINT((48838.8522765619,3820.00168047317,4897.99565708869));
#13259= IFCAXIS2PLACEMENT3D(#13258,#12798,#501);
#13260= IFCLOCALPLACEMENT(#13256,#13259);
#13261= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12806));
#13262= IFCPRODUCTDEFINITIONSHAPE($,$,(#13261));
#13263= IFCDISCRETEACCESSORY('1Td1iR002iap4rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#13260,#13262,'P/418(?)');
#13264= IFCLOCALPLACEMENT(#30,#10);
#13265= IFCELEMENTASSEMBLY('1Td1iR002iUJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#13264,$,'C/10(?)',.NOTDEFINED.,.RIGID_FRAME.);
#13266= IFCCARTESIANPOINT((48838.8522765619,3820.00168047317,10597.9956570887));
#13267= IFCAXIS2PLACEMENT3D(#13266,#12798,#501);
#13268= IFCLOCALPLACEMENT(#13264,#13267);
#13269= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12806));
#13270= IFCPRODUCTDEFINITIONSHAPE($,$,(#13269));
#13271= IFCDISCRETEACCESSORY('1Td1iR002ia34rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#13268,#13270,'P/418(?)');
#13272= IFCLOCALPLACEMENT(#30,#10);
#13273= IFCELEMENTASSEMBLY('1Td1iR002iR34rDp0rCJ4s',#5,'Steel Assembly',$,$,#13272,$,'C/14(?)',.NOTDEFINED.,.RIGID_FRAME.);
#13274= IFCCARTESIANPOINT((48838.8522753139,3820.00168047317,15797.9956570887));
#13275= IFCAXIS2PLACEMENT3D(#13274,#12798,#501);
#13276= IFCLOCALPLACEMENT(#13272,#13275);
#13277= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12872));
#13278= IFCPRODUCTDEFINITIONSHAPE($,$,(#13277));
#13279= IFCDISCRETEACCESSORY('1Td1iR002iZJ4rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#13276,#13278,'P/417(?)');
#13280= IFCLOCALPLACEMENT(#30,#10);
#13281= IFCELEMENTASSEMBLY('1Td1iR002iTJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#13280,$,'ANK/16(?)',.NOTDEFINED.,.RIGID_FRAME.);
#13282= IFCCARTESIANPOINT((48504.845143608,3815.00899999999,20200.001693145));
#13283= IFCAXIS2PLACEMENT3D(#13282,#7,#501);
#13284= IFCLOCALPLACEMENT(#13280,#13283);
#13285= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12917));
#13286= IFCPRODUCTDEFINITIONSHAPE($,$,(#13285));
#13287= IFCDISCRETEACCESSORY('1Td1iR002iYZ4rDp0rCJ4s',#5,'DETAY','PL8*70','PL8*70',#13284,#13286,'P/389(?)');
#13288= IFCCARTESIANPOINT((48504.845143608,3665.00899999999,20200.001693145));
#13289= IFCAXIS2PLACEMENT3D(#13288,#185,#8);
#13290= IFCLOCALPLACEMENT(#13280,#13289);
#13291= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12917));
#13292= IFCPRODUCTDEFINITIONSHAPE($,$,(#13291));
#13293= IFCDISCRETEACCESSORY('1Td1iR002iXp4rDp0rCJ4s',#5,'DETAY','PL8*70','PL8*70',#13290,#13292,'P/389(?)');
#13294= IFCCARTESIANPOINT((48373.8472798384,3815.00899999999,20125.001693145));
#13295= IFCAXIS2PLACEMENT3D(#13294,#9,#501);
#13296= IFCLOCALPLACEMENT(#13280,#13295);
#13297= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12960));
#13298= IFCPRODUCTDEFINITIONSHAPE($,$,(#13297));
#13299= IFCDISCRETEACCESSORY('1Td1iR002iX34rDp0rCJ4s',#5,'ANKRAJ','PLT10*150','PLT10*150',#13296,#13298,'P/337(?)');
#13300= IFCCARTESIANPOINT((48738.8523195308,3755.00200007748,10545.));
#13301= IFCAXIS2PLACEMENT3D(#13300,#7,#596);
#13302= IFCLOCALPLACEMENT(#13256,#13301);
#13303= IFCPLANE(#12993);
#13304= IFCHALFSPACESOLID(#13303,.F.);
#13305= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#12991,#13304);
#13306= IFCPLANE(#12998);
#13307= IFCHALFSPACESOLID(#13306,.F.);
#13308= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#13305,#13307);
#13309= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#13308));
#13310= IFCPRODUCTDEFINITIONSHAPE($,$,(#13309));
#13311= IFCBEAM('1Td1iR002iVZ4rDp0rCJ4s',#5,'DIKME','T200-20-20-110','T200-20-20-110',#13302,#13310,'P/286(?)');
#13312= IFCCARTESIANPOINT((48738.8523195308,3755.00200007748,15745.));
#13313= IFCAXIS2PLACEMENT3D(#13312,#7,#596);
#13314= IFCLOCALPLACEMENT(#13264,#13313);
#13315= IFCPLANE(#13035);
#13316= IFCHALFSPACESOLID(#13315,.F.);
#13317= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#13033,#13316);
#13318= IFCPLANE(#12998);
#13319= IFCHALFSPACESOLID(#13318,.F.);
#13320= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#13317,#13319);
#13321= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#13320));
#13322= IFCPRODUCTDEFINITIONSHAPE($,$,(#13321));
#13323= IFCBEAM('1Td1iR002iU34rDp0rCJ4s',#5,'DIKME','T200-16-20-110','T200-16-20-110',#13314,#13322,'P/316(?)');
#13324= IFCCARTESIANPOINT((48378.8531783713,3740.00899999999,20199.9974118494));
#13325= IFCAXIS2PLACEMENT3D(#13324,#501,#596);
#13326= IFCLOCALPLACEMENT(#13280,#13325);
#13327= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#13077));
#13328= IFCPRODUCTDEFINITIONSHAPE($,$,(#13327));
#13329= IFCPLATE('1Td1iR002iT34rDp0rCJ4s',#5,'ANKRAJ','PL10*250','PL10*250',#13326,#13328,'P/224(?)');
#13330= IFCCARTESIANPOINT((48703.8523195308,3755.00200007748,20200.));
#13331= IFCAXIS2PLACEMENT3D(#13330,#7,#596);
#13332= IFCLOCALPLACEMENT(#13272,#13331);
#13333= IFCBOOLEANRESULT(.DIFFERENCE.,#13112,#13122);
#13334= IFCPLANE(#13127);
#13335= IFCHALFSPACESOLID(#13334,.F.);
#13336= IFCBOOLEANRESULT(.DIFFERENCE.,#13333,#13335);
#13337= IFCPLANE(#13132);
#13338= IFCHALFSPACESOLID(#13337,.F.);
#13339= IFCBOOLEANRESULT(.DIFFERENCE.,#13336,#13338);
#13340= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#13339));
#13341= IFCPRODUCTDEFINITIONSHAPE($,$,(#13340));
#13342= IFCBEAM('1Td1iR002iQp4rDp0rCJ4s',#5,'DIKME','T270-16-16-110','T270-16-16-110',#13332,#13341,'P/319(?)');
#13343= IFCCARTESIANPOINT((48738.8523195316,3755.00200007709,4845.));
#13344= IFCAXIS2PLACEMENT3D(#13343,#7,#596);
#13345= IFCLOCALPLACEMENT(#8233,#13344);
#13346= IFCPLANE(#13171);
#13347= IFCHALFSPACESOLID(#13346,.F.);
#13348= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#13169,#13347);
#13349= IFCPLANE(#13171);
#13350= IFCHALFSPACESOLID(#13349,.F.);
#13351= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#13348,#13350);
#13352= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#13351));
#13353= IFCPRODUCTDEFINITIONSHAPE($,$,(#13352));
#13354= IFCBEAM('1Td1iR002iPJ4rDp0rCJ4s',#5,'DIKME','T200-25-25-110','T200-25-25-110',#13345,#13353,'P/387(?)');
#13355= IFCPROPERTYSET('0RGMMGdhzDXR3BCC$AeZpu',#5,'Tekla Common','Common Properties to Shared building elements',(#8189,#10036,#13183,#8262,#74,#75,#76,#4183,#78,#9831,#4048));
#13356= IFCPROPERTYSET('3T4CDCd5L9yxhIa7Dn3PtD',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#8265,#13185,#13186,#13187,#13188,#13189,#13190,#9839,#13191,#13192,#13193,#9843,#9844,#13194));
#13357= IFCCARTESIANPOINT((48608.8530789533,4080.00899999999,20104.9956931453));
#13358= IFCAXIS2PLACEMENT3D(#13357,#7,#596);
#13359= IFCLOCALPLACEMENT(#30,#13358);
#13360= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#13361= IFCEXTRUDEDAREASOLID(#13360,#12682,#9,16.1);
#13362= IFCSTYLEDITEM(#13361,(#195),$);
#13363= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#12699);
#13364= IFCEXTRUDEDAREASOLID(#13363,#12702,#9,10.0000000000006);
#13365= IFCSTYLEDITEM(#13364,(#195),$);
#13366= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3875);
#13367= IFCEXTRUDEDAREASOLID(#13366,#12707,#9,7.92);
#13368= IFCSTYLEDITEM(#13367,(#558),$);
#13369= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#13370= IFCEXTRUDEDAREASOLID(#13369,#12712,#9,50.);
#13371= IFCSTYLEDITEM(#13370,(#558),$);
#13372= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#13373= IFCEXTRUDEDAREASOLID(#13372,#12717,#9,8.);
#13374= IFCSTYLEDITEM(#13373,(#558),$);
#13375= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#13376= IFCEXTRUDEDAREASOLID(#13375,#12722,#9,10.);
#13377= IFCSTYLEDITEM(#13376,(#558),$);
#13378= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#13361,#13364,#13367,#13370,#13373,#13376));
#13379= IFCREPRESENTATIONMAP(#10,#13378);
#13380= IFCMAPPEDITEM(#13379,#247);
#13381= IFCMAPPEDITEM(#13379,#12729);
#13382= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#13380,#13381));
#13383= IFCPRODUCTDEFINITIONSHAPE($,$,(#13382));
#13384= IFCMECHANICALFASTENER('1Td1iR002iN34rDp0rCJ4s',#5,'Bolt assembly',$,$,#13359,#13383,'ID5d9c1b1b-0000-ac5c-3135-373035313136',12.,50.);
#13385= IFCCARTESIANPOINT((48568.9993813414,4090.00176040911,4815.99999999996));
#13386= IFCAXIS2PLACEMENT3D(#13385,#8,#9);
#13387= IFCLOCALPLACEMENT(#4206,#13386);
#13388= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#4220));
#13389= IFCPRODUCTDEFINITIONSHAPE($,$,(#13388));
#13390= IFCDISCRETEACCESSORY('1Td1iR002iMJ4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#13387,#13389,'P/430(?)');
#13391= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0359136450198783),$);
#13392= IFCPROPERTYSET('0c$DKI65z2QAY4k3JTIiPO',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#4228,#4229,#12742,#4231,#4232,#4233,#4234,#12764,#12743,#13391,#12744,#4239,#12745,#12746));
#13393= IFCQUANTITYAREA('NetArea',$,$,0.0359136450198783);
#13394= IFCQUANTITYVOLUME('NetVolume',$,$,0.000215520000000001);
#13395= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000215520000000001);
#13396= IFCELEMENTQUANTITY('3dm5hZxFzAzx9ZXPm_Ezsn',#5,'BaseQuantities',$,$,(#4242,#13393,#12748,#100,#13394,#13395));
#13397= IFCCARTESIANPOINT((48568.9994304303,4090.00176040944,10516.));
#13398= IFCAXIS2PLACEMENT3D(#13397,#8,#9);
#13399= IFCLOCALPLACEMENT(#4288,#13398);
#13400= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12757));
#13401= IFCPRODUCTDEFINITIONSHAPE($,$,(#13400));
#13402= IFCDISCRETEACCESSORY('1Td1iR002iLZ4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#13399,#13401,'P/432(?)');
#13403= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00336000000000075),$);
#13404= IFCPROPERTYSET('1YVjBm8Nz7rAgzGBl0FKY4',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#4270,#4229,#12763,#4231,#4232,#4233,#4234,#13403,#12765,#4237,#12766,#4239,#12745,#12767));
#13405= IFCQUANTITYVOLUME('NetVolume',$,$,0.000215519999853127);
#13406= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000215519999853127);
#13407= IFCELEMENTQUANTITY('2C3GZKNN99F8XbXFaiBUoc',#5,'BaseQuantities',$,$,(#12769,#12770,#12771,#100,#13405,#13406));
#13408= IFCCARTESIANPOINT((48568.9995453605,4090.00176040944,15716.));
#13409= IFCAXIS2PLACEMENT3D(#13408,#8,#9);
#13410= IFCLOCALPLACEMENT(#4248,#13409);
#13411= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#4220));
#13412= IFCPRODUCTDEFINITIONSHAPE($,$,(#13411));
#13413= IFCDISCRETEACCESSORY('1Td1iR002iKp4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#13410,#13412,'P/432(?)');
#13414= IFCPROPERTYSET('0SWZ2PqvPA_Pb2rHmYRbt0',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#4270,#4229,#4230,#4231,#4232,#4233,#4234,#13403,#12765,#4237,#4238,#4239,#12745,#12782));
#13415= IFCQUANTITYAREA('NetArea',$,$,0.0359136450185404);
#13416= IFCQUANTITYVOLUME('NetVolume',$,$,0.00021551999998996);
#13417= IFCQUANTITYVOLUME('GrossVolume',$,$,0.00021551999998996);
#13418= IFCELEMENTQUANTITY('2Q4JDBmkr2fumN1sVicwbZ',#5,'BaseQuantities',$,$,(#12784,#13415,#12786,#100,#13416,#13417));
#13419= IFCLOCALPLACEMENT(#30,#10);
#13420= IFCELEMENTASSEMBLY('1Td1iR002iF34rDp0rCJ4s',#5,'Steel Assembly',$,$,#13419,$,'C/6(?)',.NOTDEFINED.,.RIGID_FRAME.);
#13421= IFCCARTESIANPOINT((48838.8522765619,4155.00168047317,4897.99565708869));
#13422= IFCAXIS2PLACEMENT3D(#13421,#12798,#501);
#13423= IFCLOCALPLACEMENT(#13419,#13422);
#13424= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12806));
#13425= IFCPRODUCTDEFINITIONSHAPE($,$,(#13424));
#13426= IFCDISCRETEACCESSORY('1Td1iR002iK34rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#13423,#13425,'P/418(?)');
#13427= IFCLOCALPLACEMENT(#30,#10);
#13428= IFCELEMENTASSEMBLY('1Td1iR002iDZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#13427,$,'C/10(?)',.NOTDEFINED.,.RIGID_FRAME.);
#13429= IFCCARTESIANPOINT((48838.8522765619,4155.00168047317,10597.9956570887));
#13430= IFCAXIS2PLACEMENT3D(#13429,#12798,#501);
#13431= IFCLOCALPLACEMENT(#13427,#13430);
#13432= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12806));
#13433= IFCPRODUCTDEFINITIONSHAPE($,$,(#13432));
#13434= IFCDISCRETEACCESSORY('1Td1iR002iJJ4rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#13431,#13433,'P/418(?)');
#13435= IFCLOCALPLACEMENT(#30,#10);
#13436= IFCELEMENTASSEMBLY('1Td1iR002iAJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#13435,$,'C/14(?)',.NOTDEFINED.,.RIGID_FRAME.);
#13437= IFCCARTESIANPOINT((48838.8522753139,4155.00168047317,15797.9956570887));
#13438= IFCAXIS2PLACEMENT3D(#13437,#12798,#501);
#13439= IFCLOCALPLACEMENT(#13435,#13438);
#13440= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12872));
#13441= IFCPRODUCTDEFINITIONSHAPE($,$,(#13440));
#13442= IFCDISCRETEACCESSORY('1Td1iR002iIZ4rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#13439,#13441,'P/417(?)');
#13443= IFCLOCALPLACEMENT(#30,#10);
#13444= IFCELEMENTASSEMBLY('1Td1iR002iCZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#13443,$,'ANK/16(?)',.NOTDEFINED.,.RIGID_FRAME.);
#13445= IFCCARTESIANPOINT((48504.845143608,4150.00899999999,20200.001693145));
#13446= IFCAXIS2PLACEMENT3D(#13445,#7,#501);
#13447= IFCLOCALPLACEMENT(#13443,#13446);
#13448= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12917));
#13449= IFCPRODUCTDEFINITIONSHAPE($,$,(#13448));
#13450= IFCDISCRETEACCESSORY('1Td1iR002iHp4rDp0rCJ4s',#5,'DETAY','PL8*70','PL8*70',#13447,#13449,'P/389(?)');
#13451= IFCCARTESIANPOINT((48504.845143608,4000.00899999999,20200.001693145));
#13452= IFCAXIS2PLACEMENT3D(#13451,#185,#8);
#13453= IFCLOCALPLACEMENT(#13443,#13452);
#13454= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12917));
#13455= IFCPRODUCTDEFINITIONSHAPE($,$,(#13454));
#13456= IFCDISCRETEACCESSORY('1Td1iR002iH34rDp0rCJ4s',#5,'DETAY','PL8*70','PL8*70',#13453,#13455,'P/389(?)');
#13457= IFCCARTESIANPOINT((48373.8472798384,4150.00899999999,20125.001693145));
#13458= IFCAXIS2PLACEMENT3D(#13457,#9,#501);
#13459= IFCLOCALPLACEMENT(#13443,#13458);
#13460= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12960));
#13461= IFCPRODUCTDEFINITIONSHAPE($,$,(#13460));
#13462= IFCDISCRETEACCESSORY('1Td1iR002iGJ4rDp0rCJ4s',#5,'ANKRAJ','PLT10*150','PLT10*150',#13459,#13461,'P/337(?)');
#13463= IFCCARTESIANPOINT((48738.8523195308,4090.00200007748,10545.));
#13464= IFCAXIS2PLACEMENT3D(#13463,#7,#596);
#13465= IFCLOCALPLACEMENT(#13419,#13464);
#13466= IFCPLANE(#12993);
#13467= IFCHALFSPACESOLID(#13466,.F.);
#13468= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#12991,#13467);
#13469= IFCPLANE(#12998);
#13470= IFCHALFSPACESOLID(#13469,.F.);
#13471= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#13468,#13470);
#13472= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#13471));
#13473= IFCPRODUCTDEFINITIONSHAPE($,$,(#13472));
#13474= IFCBEAM('1Td1iR002iEp4rDp0rCJ4s',#5,'DIKME','T200-20-20-110','T200-20-20-110',#13465,#13473,'P/286(?)');
#13475= IFCCARTESIANPOINT((48738.8523195308,4090.00200007748,15745.));
#13476= IFCAXIS2PLACEMENT3D(#13475,#7,#596);
#13477= IFCLOCALPLACEMENT(#13427,#13476);
#13478= IFCPLANE(#13035);
#13479= IFCHALFSPACESOLID(#13478,.F.);
#13480= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#13033,#13479);
#13481= IFCPLANE(#12998);
#13482= IFCHALFSPACESOLID(#13481,.F.);
#13483= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#13480,#13482);
#13484= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#13483));
#13485= IFCPRODUCTDEFINITIONSHAPE($,$,(#13484));
#13486= IFCBEAM('1Td1iR002iDJ4rDp0rCJ4s',#5,'DIKME','T200-16-20-110','T200-16-20-110',#13477,#13485,'P/316(?)');
#13487= IFCCARTESIANPOINT((48378.8531783713,4075.00899999999,20199.9974118494));
#13488= IFCAXIS2PLACEMENT3D(#13487,#501,#596);
#13489= IFCLOCALPLACEMENT(#13443,#13488);
#13490= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#13077));
#13491= IFCPRODUCTDEFINITIONSHAPE($,$,(#13490));
#13492= IFCPLATE('1Td1iR002iCJ4rDp0rCJ4s',#5,'ANKRAJ','PL10*250','PL10*250',#13489,#13491,'P/224(?)');
#13493= IFCCARTESIANPOINT((48703.8523195308,4090.00200007748,20200.));
#13494= IFCAXIS2PLACEMENT3D(#13493,#7,#596);
#13495= IFCLOCALPLACEMENT(#13435,#13494);
#13496= IFCBOOLEANRESULT(.DIFFERENCE.,#13112,#13122);
#13497= IFCPLANE(#13127);
#13498= IFCHALFSPACESOLID(#13497,.F.);
#13499= IFCBOOLEANRESULT(.DIFFERENCE.,#13496,#13498);
#13500= IFCPLANE(#13132);
#13501= IFCHALFSPACESOLID(#13500,.F.);
#13502= IFCBOOLEANRESULT(.DIFFERENCE.,#13499,#13501);
#13503= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#13502));
#13504= IFCPRODUCTDEFINITIONSHAPE($,$,(#13503));
#13505= IFCBEAM('1Td1iR002iA34rDp0rCJ4s',#5,'DIKME','T270-16-16-110','T270-16-16-110',#13495,#13504,'P/319(?)');
#13506= IFCCARTESIANPOINT((48738.8523195316,4090.00200007709,4845.));
#13507= IFCAXIS2PLACEMENT3D(#13506,#7,#596);
#13508= IFCLOCALPLACEMENT(#8233,#13507);
#13509= IFCPLANE(#13171);
#13510= IFCHALFSPACESOLID(#13509,.F.);
#13511= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#13169,#13510);
#13512= IFCPLANE(#13171);
#13513= IFCHALFSPACESOLID(#13512,.F.);
#13514= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#13511,#13513);
#13515= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#13514));
#13516= IFCPRODUCTDEFINITIONSHAPE($,$,(#13515));
#13517= IFCDISCRETEACCESSORY('1Td1iR002i8Z4rDp0rCJ4s',#5,'DIKME','T200-25-25-110','T200-25-25-110',#13508,#13516,'P/387(?)');
#13518= IFCCARTESIANPOINT((48568.9993813414,5360.00176040911,4815.99999999996));
#13519= IFCAXIS2PLACEMENT3D(#13518,#8,#9);
#13520= IFCLOCALPLACEMENT(#4206,#13519);
#13521= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#4220));
#13522= IFCPRODUCTDEFINITIONSHAPE($,$,(#13521));
#13523= IFCDISCRETEACCESSORY('1Td1iR002i5Z4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#13520,#13522,'P/430(?)');
#13524= IFCPROPERTYSET('19yirW1cf1AvTZ$zf1nvq5',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#4228,#4229,#4230,#4231,#4232,#4233,#4234,#4235,#12765,#4237,#4238,#4239,#3222,#4240));
#13525= IFCQUANTITYAREA('GrossArea',$,$,0.0139200000000017);
#13526= IFCQUANTITYVOLUME('NetVolume',$,$,0.000215519999999999);
#13527= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000215519999999999);
#13528= IFCELEMENTQUANTITY('2oaA$hSrH9Uf3R5GFmRDcW',#5,'BaseQuantities',$,$,(#4242,#4243,#13525,#100,#13526,#13527));
#13529= IFCCARTESIANPOINT((48568.9994304303,5360.00176040944,10516.));
#13530= IFCAXIS2PLACEMENT3D(#13529,#8,#9);
#13531= IFCLOCALPLACEMENT(#4288,#13530);
#13532= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12757));
#13533= IFCPRODUCTDEFINITIONSHAPE($,$,(#13532));
#13534= IFCDISCRETEACCESSORY('1Td1iR002i4p4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#13531,#13533,'P/432(?)');
#13535= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(21.2276662368193),$);
#13536= IFCPROPERTYSET('3l2rKscID6Oek5gKHDceoR',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#4270,#4229,#12763,#4231,#4232,#4233,#4234,#12764,#13535,#4237,#12766,#4239,#12745,#12767));
#13537= IFCQUANTITYVOLUME('NetVolume',$,$,0.000215519999853126);
#13538= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000215519999853126);
#13539= IFCELEMENTQUANTITY('25Xl4hgrzBuOyIGXOgVizc',#5,'BaseQuantities',$,$,(#12769,#12770,#12771,#100,#13537,#13538));
#13540= IFCCARTESIANPOINT((48568.9995453605,5360.00176040944,15716.));
#13541= IFCAXIS2PLACEMENT3D(#13540,#8,#9);
#13542= IFCLOCALPLACEMENT(#4248,#13541);
#13543= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#4220));
#13544= IFCPRODUCTDEFINITIONSHAPE($,$,(#13543));
#13545= IFCDISCRETEACCESSORY('1Td1iR002i434rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#13542,#13544,'P/432(?)');
#13546= IFCQUANTITYVOLUME('NetVolume',$,$,0.000215519999989961);
#13547= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000215519999989961);
#13548= IFCELEMENTQUANTITY('28gsWNkZ98hg8fthVcoZSA',#5,'BaseQuantities',$,$,(#12784,#12785,#12786,#100,#13546,#13547));
#13549= IFCCARTESIANPOINT((48568.9993813414,5695.00176040911,4815.99999999996));
#13550= IFCAXIS2PLACEMENT3D(#13549,#8,#9);
#13551= IFCLOCALPLACEMENT(#4206,#13550);
#13552= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#4220));
#13553= IFCPRODUCTDEFINITIONSHAPE($,$,(#13552));
#13554= IFCDISCRETEACCESSORY('1Td1iR002hqZ4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#13551,#13553,'P/430(?)');
#13555= IFCCARTESIANPOINT((48568.9994304303,5695.00176040944,10516.));
#13556= IFCAXIS2PLACEMENT3D(#13555,#8,#9);
#13557= IFCLOCALPLACEMENT(#4288,#13556);
#13558= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12757));
#13559= IFCPRODUCTDEFINITIONSHAPE($,$,(#13558));
#13560= IFCDISCRETEACCESSORY('1Td1iR002hpp4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#13557,#13559,'P/432(?)');
#13561= IFCCARTESIANPOINT((48568.9995453605,5695.00176040944,15716.));
#13562= IFCAXIS2PLACEMENT3D(#13561,#8,#9);
#13563= IFCLOCALPLACEMENT(#4248,#13562);
#13564= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#4220));
#13565= IFCPRODUCTDEFINITIONSHAPE($,$,(#13564));
#13566= IFCDISCRETEACCESSORY('1Td1iR002hp34rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#13563,#13565,'P/432(?)');
#13567= IFCCARTESIANPOINT((48568.9993813414,7805.00176040911,4815.99999999996));
#13568= IFCAXIS2PLACEMENT3D(#13567,#8,#9);
#13569= IFCLOCALPLACEMENT(#4206,#13568);
#13570= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#4220));
#13571= IFCPRODUCTDEFINITIONSHAPE($,$,(#13570));
#13572= IFCDISCRETEACCESSORY('1Td1iR002hjZ4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#13569,#13571,'P/430(?)');
#13573= IFCCARTESIANPOINT((48568.9993813414,8140.00176040911,4815.99999999996));
#13574= IFCAXIS2PLACEMENT3D(#13573,#8,#9);
#13575= IFCLOCALPLACEMENT(#4206,#13574);
#13576= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#4220));
#13577= IFCPRODUCTDEFINITIONSHAPE($,$,(#13576));
#13578= IFCDISCRETEACCESSORY('1Td1iR002hRZ4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#13575,#13577,'P/430(?)');
#13579= IFCLOCALPLACEMENT(#30,#10);
#13580= IFCELEMENTASSEMBLY('1Td1iR002eBZ4rDp0rCJ4s',#5,'SLAB',$,$,#13579,$,'XX/130',.NOTDEFINED.,.REINFORCEMENT_UNIT.);
#13581= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(280.326416015604),$);
#13582= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -2.303'),$);
#13583= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -1.903'),$);
#13584= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('XX/130'),$);
#13585= IFCPROPERTYSET('1G0lvPN298uA45zQPLA241',#5,'Tekla Assembly','Assembly Properties',(#9686,#9687,#13581,#13582,#13583,#9691,#2857,#13584));
#13586= IFCQUANTITYLENGTH('Width',$,$,400.);
#13587= IFCELEMENTQUANTITY('3VcBo$zLbCygVjN4IC48bm',#5,'BaseQuantities',$,$,(#13586));
#13588= IFCCARTESIANPOINT((48349.9940185252,1479.99604226294,-2103.01017761231));
#13589= IFCAXIS2PLACEMENT3D(#13588,#9,#501);
#13590= IFCLOCALPLACEMENT(#13579,#13589);
#13591= IFCSURFACESTYLE('CONCRETE/C20/25',.POSITIVE.,(#51));
#13592= IFCPRESENTATIONSTYLEASSIGNMENT((#13591));
#13593= IFCCARTESIANPOINT((1460.,2.91038304567337E-011));
#13594= IFCCARTESIANPOINT((1460.,200.004577636719));
#13595= IFCCARTESIANPOINT((1.36424205265939E-012,200.004577636719));
#13596= IFCPOLYLINE((#54,#13593,#13594,#13595,#54,#54));
#13597= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'400*200',#13596);
#13598= IFCCARTESIANPOINT((0.,0.,-200.));
#13599= IFCAXIS2PLACEMENT3D(#13598,#9,#7);
#13600= IFCEXTRUDEDAREASOLID(#13597,#13599,#9,400.);
#13601= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#13600));
#13602= IFCSTYLEDITEM(#13600,(#13592),$);
#13603= IFCPRODUCTDEFINITIONSHAPE($,$,(#13601));
#13604= IFCSLAB('1Td1iR002eBp4rDp0rCJ4s',#5,'SLAB','400*200','400*200',#13590,#13603,'XX/130',.FLOOR.);
#13605= IFCSLABTYPE('0Fq27o_WnA4RPqppsz5PW8',#5,'400*200',$,$,$,$,$,$,.NOTDEFINED.);
#13606= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -2.303'),$);
#13607= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -1.903'),$);
#13608= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('XX/130'),$);
#13609= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('XX/130'),$);
#13610= IFCPROPERTYSINGLEVALUE('Phase',$,IFCINTEGER(81),$);
#13611= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('400*200'),$);
#13612= IFCPROPERTYSET('2hSnnAKyz9tOJkGSKzd4no',#5,'Tekla Common','Common Properties to Shared building elements',(#13606,#13607,#13608,#13609,#74,#75,#13610,#1194,#9722,#13611,#9724));
#13613= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(280.326416015604),$);
#13614= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(280.326416015604),$);
#13615= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(280.326416015625),$);
#13616= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(280.326416015604),$);
#13617= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.116802673339835),$);
#13618= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.116802673339835),$);
#13619= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.116802673339835),$);
#13620= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.292006683349588),$);
#13621= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(6.82068089045916),$);
#13622= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(1.91201702880854),$);
#13623= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.292006683349609),$);
#13624= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(200.004577636719),$);
#13625= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(400.),$);
#13626= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(1460.),$);
#13627= IFCPROPERTYSET('1a9B7IXV5BWAUL32oW6DpP',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#13613,#13614,#13615,#13616,#13617,#13618,#13619,#13620,#13621,#13622,#13623,#13624,#13625,#13626));
#13628= IFCQUANTITYVOLUME('NetVolume',$,$,0.116802673339835);
#13629= IFCQUANTITYAREA('NetArea',$,$,0.292006683349588);
#13630= IFCQUANTITYWEIGHT('NetWeight',$,$,280.326416015604);
#13631= IFCELEMENTQUANTITY('0rSswPsCj1Bv2QOz9wmZgu',#5,'BaseQuantities',$,$,(#13586,#13628,#13629,#13630));
#13632= IFCLOCALPLACEMENT(#30,#10);
#13633= IFCELEMENTASSEMBLY('1Td1iR002eAZ4rDp0rCJ4s',#5,'SLAB',$,$,#13632,$,'XX/115',.NOTDEFINED.,.REINFORCEMENT_UNIT.);
#13634= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(3465.58998046517),$);
#13635= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -1.503'),$);
#13636= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('XX/115'),$);
#13637= IFCPROPERTYSET('3fvDuIzvz4rPw7YN6$dhYe',#5,'Tekla Assembly','Assembly Properties',(#9686,#9687,#13634,#13582,#13635,#9691,#3342,#13636));
#13638= IFCQUANTITYLENGTH('Width',$,$,800.);
#13639= IFCELEMENTQUANTITY('2Z4VfXURvA9v0ttnsHXsel',#5,'BaseQuantities',$,$,(#13638));
#13640= IFCCARTESIANPOINT((47399.997070283,-200.004262912844,-1903.01055908203));
#13641= IFCAXIS2PLACEMENT3D(#13640,#9,#7);
#13642= IFCLOCALPLACEMENT(#13632,#13641);
#13643= IFCCARTESIANPOINT((949.996948242188,1.81898940354586E-012));
#13644= IFCCARTESIANPOINT((949.996948242188,1900.00061035156));
#13645= IFCCARTESIANPOINT((0.,1900.00061035156));
#13646= IFCPOLYLINE((#54,#13643,#13644,#13645,#54,#54));
#13647= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'800*950',#13646);
#13648= IFCCARTESIANPOINT((0.,0.,-400.));
#13649= IFCAXIS2PLACEMENT3D(#13648,#9,#7);
#13650= IFCEXTRUDEDAREASOLID(#13647,#13649,#9,800.);
#13651= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#13650));
#13652= IFCSTYLEDITEM(#13650,(#13592),$);
#13653= IFCPRODUCTDEFINITIONSHAPE($,$,(#13651));
#13654= IFCSLAB('1Td1iR002eAp4rDp0rCJ4s',#5,'SLAB','800*950','800*950',#13642,#13653,'XX/115',.FLOOR.);
#13655= IFCSLABTYPE('1OtPFZmy54Gvez3D3CHRIT',#5,'800*950',$,$,$,$,$,$,.NOTDEFINED.);
#13656= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -1.503'),$);
#13657= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('XX/115'),$);
#13658= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('XX/115'),$);
#13659= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('800*950'),$);
#13660= IFCPROPERTYSET('21$xQkyFH2$QZSERqF0hzE',#5,'Tekla Common','Common Properties to Shared building elements',(#13606,#13656,#13657,#13658,#74,#75,#13610,#1194,#9722,#13659,#9724));
#13661= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(3465.58998046517),$);
#13662= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(3465.58998046517),$);
#13663= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(3465.58998046517),$);
#13664= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(3465.58998046517),$);
#13665= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(1.44399582519382),$);
#13666= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(1.44399582519382),$);
#13667= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(1.44399582519382),$);
#13668= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(1.80499478149228),$);
#13669= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(2.35745881734051),$);
#13670= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(8.16998565673455),$);
#13671= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(1.80499478149228),$);
#13672= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(949.996948242188),$);
#13673= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(800.),$);
#13674= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(1900.00061035156),$);
#13675= IFCPROPERTYSET('2b8u_i$g95uPgGZNENinrO',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#13661,#13662,#13663,#13664,#13665,#13666,#13667,#13668,#13669,#13670,#13671,#13672,#13673,#13674));
#13676= IFCQUANTITYVOLUME('NetVolume',$,$,1.44399582519382);
#13677= IFCQUANTITYAREA('NetArea',$,$,1.80499478149228);
#13678= IFCQUANTITYWEIGHT('NetWeight',$,$,3465.58998046517);
#13679= IFCELEMENTQUANTITY('0tb3yqyCfA_PPgCKVYQtXR',#5,'BaseQuantities',$,$,(#13638,#13676,#13677,#13678));
#13680= IFCLOCALPLACEMENT(#30,#10);
#13681= IFCELEMENTASSEMBLY('1Td1iR001z6Z4rDp0rCJ4s',#5,'SLAB',$,$,#13680,$,'XX/126(?)',.NOTDEFINED.,.REINFORCEMENT_UNIT.);
#13682= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(293307.876453672),$);
#13683= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit position code',$,IFCLABEL('6>/N2-P1'),$);
#13684= IFCPROPERTYSET('1bSWN$L2n1vQNMR7tKLojO',#5,'Tekla Assembly','Assembly Properties',(#9686,#9687,#13682,#9689,#9690,#9691,#13683,#9693));
#13685= IFCQUANTITYLENGTH('Width',$,$,21600.000000033);
#13686= IFCELEMENTQUANTITY('2tOtOihoX2w9z2S44jGY5t',#5,'BaseQuantities',$,$,(#13685));
#13687= IFCCARTESIANPOINT((48615.0086654962,10799.9970465326,-1400.00038146973));
#13688= IFCAXIS2PLACEMENT3D(#13687,#501,#596);
#13689= IFCLOCALPLACEMENT(#13680,#13688);
#13690= IFCCARTESIANPOINT((599.99658203125,-5.82076609134674E-011));
#13691= IFCCARTESIANPOINT((599.99658203125,1889.99938964844));
#13692= IFCCARTESIANPOINT((589.996337890625,1900.00158691406));
#13693= IFCCARTESIANPOINT((399.999633789063,1900.00158691406));
#13694= IFCCARTESIANPOINT((399.999633789063,16959.9921875));
#13695= IFCCARTESIANPOINT((100.000846862793,16959.9921875));
#13696= IFCCARTESIANPOINT((100.000289916992,1900.00500488281));
#13697= IFCCARTESIANPOINT((-0.0182273052632809,1900.00378417969));
#13698= IFCPOLYLINE((#54,#13690,#13691,#13692,#13693,#13694,#13695,#13696,#13697,#54,#54));
#13699= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'21600*600',#13698);
#13700= IFCEXTRUDEDAREASOLID(#13699,#9709,#9,21600.);
#13701= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#13700));
#13702= IFCSTYLEDITEM(#13700,(#9702),$);
#13703= IFCPRODUCTDEFINITIONSHAPE($,$,(#13701));
#13704= IFCSLAB('1Td1iR001z6p4rDp0rCJ4s',#5,'SLAB','21600*600','21600*600',#13689,#13703,'XX/126(?)',.FLOOR.);
#13705= IFCSLABTYPE('3yDZqYz8HFZAgfNYuwvL2I',#5,'21600*600',$,$,$,$,$,$,.NOTDEFINED.);
#13706= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('21600*600'),$);
#13707= IFCPROPERTYSET('1TO6GpM0H8m92ksx0EjYq5',#5,'Tekla Common','Common Properties to Shared building elements',(#9716,#9717,#9718,#9719,#74,#75,#9720,#9721,#9722,#13706,#9724));
#13708= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(293307.876453672),$);
#13709= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(293307.876453672),$);
#13710= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(527536.617461027),$);
#13711= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(293307.876453672),$);
#13712= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(122.21161518903),$);
#13713= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(122.21161518903),$);
#13714= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(122.21161518903),$);
#13715= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(41.0400817401697),$);
#13716= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(2.62448190770163),$);
#13717= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(769.781215139047),$);
#13718= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(10.1762464788007),$);
#13719= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(600.014809336513),$);
#13720= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(21600.0000000904),$);
#13721= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(16959.9921876152),$);
#13722= IFCPROPERTYSET('2Unk6mZEP2jPh3Qjf0PRIi',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#13708,#13709,#13710,#13711,#13712,#13713,#13714,#13715,#13716,#13717,#13718,#13719,#13720,#13721));
#13723= IFCQUANTITYLENGTH('Width',$,$,21600.0000000904);
#13724= IFCQUANTITYVOLUME('NetVolume',$,$,122.21161518903);
#13725= IFCQUANTITYAREA('NetArea',$,$,41.0400817401697);
#13726= IFCQUANTITYWEIGHT('NetWeight',$,$,293307.876453672);
#13727= IFCELEMENTQUANTITY('20ejwaulb3Eueq97KCTcqi',#5,'BaseQuantities',$,$,(#13723,#13724,#13725,#13726));
#13728= IFCCARTESIANPOINT((46530.0091909279,-544.169499904543,-7141.));
#13729= IFCAXIS2PLACEMENT3D(#13728,#7,#501);
#13730= IFCLOCALPLACEMENT(#30,#13729);
#13731= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#13732= IFCEXTRUDEDAREASOLID(#13731,#8796,#9,6.);
#13733= IFCSTYLEDITEM(#13732,(#195),$);
#13734= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#8817);
#13735= IFCEXTRUDEDAREASOLID(#13734,#8820,#9,6.1);
#13736= IFCSTYLEDITEM(#13735,(#195),$);
#13737= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3875);
#13738= IFCEXTRUDEDAREASOLID(#13737,#8825,#9,7.92);
#13739= IFCSTYLEDITEM(#13738,(#558),$);
#13740= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#13741= IFCEXTRUDEDAREASOLID(#13740,#8830,#9,35.);
#13742= IFCSTYLEDITEM(#13741,(#558),$);
#13743= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#13744= IFCEXTRUDEDAREASOLID(#13743,#8835,#9,8.);
#13745= IFCSTYLEDITEM(#13744,(#558),$);
#13746= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#13747= IFCEXTRUDEDAREASOLID(#13746,#8840,#9,10.);
#13748= IFCSTYLEDITEM(#13747,(#558),$);
#13749= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#13732,#13735,#13738,#13741,#13744,#13747));
#13750= IFCREPRESENTATIONMAP(#10,#13749);
#13751= IFCMAPPEDITEM(#13750,#247);
#13752= IFCMAPPEDITEM(#13750,#8847);
#13753= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#13751,#13752));
#13754= IFCPRODUCTDEFINITIONSHAPE($,$,(#13753));
#13755= IFCMECHANICALFASTENER('1Td1iR001cq34rDp0rCJ4s',#5,'Bolt assembly',$,$,#13730,#13754,'ID5d9c1b1b-0000-66d0-3135-373035313136',12.,35.);
#13756= IFCCARTESIANPOINT((45089.9918822948,-544.169499904543,-7145.));
#13757= IFCAXIS2PLACEMENT3D(#13756,#7,#501);
#13758= IFCLOCALPLACEMENT(#30,#13757);
#13759= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#13760= IFCEXTRUDEDAREASOLID(#13759,#11276,#9,5.99999999999997);
#13761= IFCSTYLEDITEM(#13760,(#195),$);
#13762= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#13763= IFCEXTRUDEDAREASOLID(#13762,#11281,#9,6.1);
#13764= IFCSTYLEDITEM(#13763,(#195),$);
#13765= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3875);
#13766= IFCEXTRUDEDAREASOLID(#13765,#11286,#9,7.92);
#13767= IFCSTYLEDITEM(#13766,(#558),$);
#13768= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#13769= IFCEXTRUDEDAREASOLID(#13768,#11291,#9,35.);
#13770= IFCSTYLEDITEM(#13769,(#558),$);
#13771= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#13772= IFCEXTRUDEDAREASOLID(#13771,#11296,#9,8.);
#13773= IFCSTYLEDITEM(#13772,(#558),$);
#13774= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#13775= IFCEXTRUDEDAREASOLID(#13774,#11301,#9,10.);
#13776= IFCSTYLEDITEM(#13775,(#558),$);
#13777= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#13760,#13763,#13766,#13769,#13772,#13775));
#13778= IFCREPRESENTATIONMAP(#10,#13777);
#13779= IFCMAPPEDITEM(#13778,#247);
#13780= IFCMAPPEDITEM(#13778,#8847);
#13781= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#13779,#13780));
#13782= IFCPRODUCTDEFINITIONSHAPE($,$,(#13781));
#13783= IFCMECHANICALFASTENER('1Td1iR001cqp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#13758,#13782,'ID5d9c1b1b-0000-66d3-3135-373035313136',12.,35.);
#13784= IFCCARTESIANPOINT((44910.0091909279,-544.169499904543,-7141.));
#13785= IFCAXIS2PLACEMENT3D(#13784,#7,#501);
#13786= IFCLOCALPLACEMENT(#30,#13785);
#13787= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#13788= IFCEXTRUDEDAREASOLID(#13787,#8796,#9,6.);
#13789= IFCSTYLEDITEM(#13788,(#195),$);
#13790= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#8817);
#13791= IFCEXTRUDEDAREASOLID(#13790,#8820,#9,6.1);
#13792= IFCSTYLEDITEM(#13791,(#195),$);
#13793= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3875);
#13794= IFCEXTRUDEDAREASOLID(#13793,#8825,#9,7.92);
#13795= IFCSTYLEDITEM(#13794,(#558),$);
#13796= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#13797= IFCEXTRUDEDAREASOLID(#13796,#8830,#9,35.);
#13798= IFCSTYLEDITEM(#13797,(#558),$);
#13799= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#13800= IFCEXTRUDEDAREASOLID(#13799,#8835,#9,8.);
#13801= IFCSTYLEDITEM(#13800,(#558),$);
#13802= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#13803= IFCEXTRUDEDAREASOLID(#13802,#8840,#9,10.);
#13804= IFCSTYLEDITEM(#13803,(#558),$);
#13805= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#13788,#13791,#13794,#13797,#13800,#13803));
#13806= IFCREPRESENTATIONMAP(#10,#13805);
#13807= IFCMAPPEDITEM(#13806,#247);
#13808= IFCMAPPEDITEM(#13806,#8847);
#13809= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#13807,#13808));
#13810= IFCPRODUCTDEFINITIONSHAPE($,$,(#13809));
#13811= IFCMECHANICALFASTENER('1Td1iR001crZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#13786,#13810,'ID5d9c1b1b-0000-66d6-3135-373035313136',12.,35.);
#13812= IFCCARTESIANPOINT((44279.9918822948,-544.169499904543,-7145.));
#13813= IFCAXIS2PLACEMENT3D(#13812,#7,#501);
#13814= IFCLOCALPLACEMENT(#30,#13813);
#13815= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#13816= IFCEXTRUDEDAREASOLID(#13815,#11276,#9,5.99999999999997);
#13817= IFCSTYLEDITEM(#13816,(#195),$);
#13818= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#13819= IFCEXTRUDEDAREASOLID(#13818,#11281,#9,6.1);
#13820= IFCSTYLEDITEM(#13819,(#195),$);
#13821= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3875);
#13822= IFCEXTRUDEDAREASOLID(#13821,#11286,#9,7.92);
#13823= IFCSTYLEDITEM(#13822,(#558),$);
#13824= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#13825= IFCEXTRUDEDAREASOLID(#13824,#11291,#9,35.);
#13826= IFCSTYLEDITEM(#13825,(#558),$);
#13827= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#13828= IFCEXTRUDEDAREASOLID(#13827,#11296,#9,8.);
#13829= IFCSTYLEDITEM(#13828,(#558),$);
#13830= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#13831= IFCEXTRUDEDAREASOLID(#13830,#11301,#9,10.);
#13832= IFCSTYLEDITEM(#13831,(#558),$);
#13833= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#13816,#13819,#13822,#13825,#13828,#13831));
#13834= IFCREPRESENTATIONMAP(#10,#13833);
#13835= IFCMAPPEDITEM(#13834,#247);
#13836= IFCMAPPEDITEM(#13834,#8847);
#13837= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#13835,#13836));
#13838= IFCPRODUCTDEFINITIONSHAPE($,$,(#13837));
#13839= IFCMECHANICALFASTENER('1Td1iR001csJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#13814,#13838,'ID5d9c1b1b-0000-66d9-3135-373035313136',12.,35.);
#13840= IFCCARTESIANPOINT((44100.0091909279,-544.169499904543,-7141.));
#13841= IFCAXIS2PLACEMENT3D(#13840,#7,#501);
#13842= IFCLOCALPLACEMENT(#30,#13841);
#13843= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#13844= IFCEXTRUDEDAREASOLID(#13843,#8796,#9,6.);
#13845= IFCSTYLEDITEM(#13844,(#195),$);
#13846= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#8817);
#13847= IFCEXTRUDEDAREASOLID(#13846,#8820,#9,6.1);
#13848= IFCSTYLEDITEM(#13847,(#195),$);
#13849= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3875);
#13850= IFCEXTRUDEDAREASOLID(#13849,#8825,#9,7.92);
#13851= IFCSTYLEDITEM(#13850,(#558),$);
#13852= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#13853= IFCEXTRUDEDAREASOLID(#13852,#8830,#9,35.);
#13854= IFCSTYLEDITEM(#13853,(#558),$);
#13855= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#13856= IFCEXTRUDEDAREASOLID(#13855,#8835,#9,8.);
#13857= IFCSTYLEDITEM(#13856,(#558),$);
#13858= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#13859= IFCEXTRUDEDAREASOLID(#13858,#8840,#9,10.);
#13860= IFCSTYLEDITEM(#13859,(#558),$);
#13861= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#13844,#13847,#13850,#13853,#13856,#13859));
#13862= IFCREPRESENTATIONMAP(#10,#13861);
#13863= IFCMAPPEDITEM(#13862,#247);
#13864= IFCMAPPEDITEM(#13862,#8847);
#13865= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#13863,#13864));
#13866= IFCPRODUCTDEFINITIONSHAPE($,$,(#13865));
#13867= IFCMECHANICALFASTENER('1Td1iR001ct34rDp0rCJ4s',#5,'Bolt assembly',$,$,#13842,#13866,'ID5d9c1b1b-0000-66dc-3135-373035313136',12.,35.);
#13868= IFCCARTESIANPOINT((43469.9918822948,-544.169499904543,-7145.));
#13869= IFCAXIS2PLACEMENT3D(#13868,#7,#501);
#13870= IFCLOCALPLACEMENT(#30,#13869);
#13871= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#13872= IFCEXTRUDEDAREASOLID(#13871,#11276,#9,5.99999999999997);
#13873= IFCSTYLEDITEM(#13872,(#195),$);
#13874= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#13875= IFCEXTRUDEDAREASOLID(#13874,#11281,#9,6.1);
#13876= IFCSTYLEDITEM(#13875,(#195),$);
#13877= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3875);
#13878= IFCEXTRUDEDAREASOLID(#13877,#11286,#9,7.92);
#13879= IFCSTYLEDITEM(#13878,(#558),$);
#13880= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#13881= IFCEXTRUDEDAREASOLID(#13880,#11291,#9,35.);
#13882= IFCSTYLEDITEM(#13881,(#558),$);
#13883= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#13884= IFCEXTRUDEDAREASOLID(#13883,#11296,#9,8.);
#13885= IFCSTYLEDITEM(#13884,(#558),$);
#13886= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#13887= IFCEXTRUDEDAREASOLID(#13886,#11301,#9,10.);
#13888= IFCSTYLEDITEM(#13887,(#558),$);
#13889= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#13872,#13875,#13878,#13881,#13884,#13887));
#13890= IFCREPRESENTATIONMAP(#10,#13889);
#13891= IFCMAPPEDITEM(#13890,#247);
#13892= IFCMAPPEDITEM(#13890,#8847);
#13893= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#13891,#13892));
#13894= IFCPRODUCTDEFINITIONSHAPE($,$,(#13893));
#13895= IFCMECHANICALFASTENER('1Td1iR001ctp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#13870,#13894,'ID5d9c1b1b-0000-66df-3135-373035313136',12.,35.);
#13896= IFCCARTESIANPOINT((40860.0091909279,-544.169499904543,-7141.));
#13897= IFCAXIS2PLACEMENT3D(#13896,#7,#501);
#13898= IFCLOCALPLACEMENT(#30,#13897);
#13899= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#13900= IFCEXTRUDEDAREASOLID(#13899,#8796,#9,6.);
#13901= IFCSTYLEDITEM(#13900,(#195),$);
#13902= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#8817);
#13903= IFCEXTRUDEDAREASOLID(#13902,#8820,#9,6.1);
#13904= IFCSTYLEDITEM(#13903,(#195),$);
#13905= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3875);
#13906= IFCEXTRUDEDAREASOLID(#13905,#8825,#9,7.92);
#13907= IFCSTYLEDITEM(#13906,(#558),$);
#13908= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#13909= IFCEXTRUDEDAREASOLID(#13908,#8830,#9,35.);
#13910= IFCSTYLEDITEM(#13909,(#558),$);
#13911= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#13912= IFCEXTRUDEDAREASOLID(#13911,#8835,#9,8.);
#13913= IFCSTYLEDITEM(#13912,(#558),$);
#13914= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#13915= IFCEXTRUDEDAREASOLID(#13914,#8840,#9,10.);
#13916= IFCSTYLEDITEM(#13915,(#558),$);
#13917= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#13900,#13903,#13906,#13909,#13912,#13915));
#13918= IFCREPRESENTATIONMAP(#10,#13917);
#13919= IFCMAPPEDITEM(#13918,#247);
#13920= IFCMAPPEDITEM(#13918,#8847);
#13921= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#13919,#13920));
#13922= IFCPRODUCTDEFINITIONSHAPE($,$,(#13921));
#13923= IFCMECHANICALFASTENER('1Td1iR001cxZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#13898,#13922,'ID5d9c1b1b-0000-66ee-3135-373035313136',12.,35.);
#13924= IFCCARTESIANPOINT((40229.9918822948,-544.169499904543,-7145.));
#13925= IFCAXIS2PLACEMENT3D(#13924,#7,#501);
#13926= IFCLOCALPLACEMENT(#30,#13925);
#13927= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#13928= IFCEXTRUDEDAREASOLID(#13927,#11276,#9,5.99999999999997);
#13929= IFCSTYLEDITEM(#13928,(#195),$);
#13930= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#13931= IFCEXTRUDEDAREASOLID(#13930,#11281,#9,6.1);
#13932= IFCSTYLEDITEM(#13931,(#195),$);
#13933= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3875);
#13934= IFCEXTRUDEDAREASOLID(#13933,#11286,#9,7.92);
#13935= IFCSTYLEDITEM(#13934,(#558),$);
#13936= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#13937= IFCEXTRUDEDAREASOLID(#13936,#11291,#9,35.);
#13938= IFCSTYLEDITEM(#13937,(#558),$);
#13939= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#13940= IFCEXTRUDEDAREASOLID(#13939,#11296,#9,8.);
#13941= IFCSTYLEDITEM(#13940,(#558),$);
#13942= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#13943= IFCEXTRUDEDAREASOLID(#13942,#11301,#9,10.);
#13944= IFCSTYLEDITEM(#13943,(#558),$);
#13945= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#13928,#13931,#13934,#13937,#13940,#13943));
#13946= IFCREPRESENTATIONMAP(#10,#13945);
#13947= IFCMAPPEDITEM(#13946,#247);
#13948= IFCMAPPEDITEM(#13946,#8847);
#13949= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#13947,#13948));
#13950= IFCPRODUCTDEFINITIONSHAPE($,$,(#13949));
#13951= IFCMECHANICALFASTENER('1Td1iR001cyJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#13926,#13950,'ID5d9c1b1b-0000-66f1-3135-373035313136',12.,35.);
#13952= IFCCARTESIANPOINT((43290.0091909279,-544.169499904543,-7141.));
#13953= IFCAXIS2PLACEMENT3D(#13952,#7,#501);
#13954= IFCLOCALPLACEMENT(#30,#13953);
#13955= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#13956= IFCEXTRUDEDAREASOLID(#13955,#8796,#9,6.);
#13957= IFCSTYLEDITEM(#13956,(#195),$);
#13958= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#8817);
#13959= IFCEXTRUDEDAREASOLID(#13958,#8820,#9,6.1);
#13960= IFCSTYLEDITEM(#13959,(#195),$);
#13961= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3875);
#13962= IFCEXTRUDEDAREASOLID(#13961,#8825,#9,7.92);
#13963= IFCSTYLEDITEM(#13962,(#558),$);
#13964= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#13965= IFCEXTRUDEDAREASOLID(#13964,#8830,#9,35.);
#13966= IFCSTYLEDITEM(#13965,(#558),$);
#13967= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#13968= IFCEXTRUDEDAREASOLID(#13967,#8835,#9,8.);
#13969= IFCSTYLEDITEM(#13968,(#558),$);
#13970= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#13971= IFCEXTRUDEDAREASOLID(#13970,#8840,#9,10.);
#13972= IFCSTYLEDITEM(#13971,(#558),$);
#13973= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#13956,#13959,#13962,#13965,#13968,#13971));
#13974= IFCREPRESENTATIONMAP(#10,#13973);
#13975= IFCMAPPEDITEM(#13974,#247);
#13976= IFCMAPPEDITEM(#13974,#8847);
#13977= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#13975,#13976));
#13978= IFCPRODUCTDEFINITIONSHAPE($,$,(#13977));
#13979= IFCMECHANICALFASTENER('1Td1iR001cz34rDp0rCJ4s',#5,'Bolt assembly',$,$,#13954,#13978,'ID5d9c1b1b-0000-66f4-3135-373035313136',12.,35.);
#13980= IFCCARTESIANPOINT((41039.9918822948,-544.169499904543,-7145.));
#13981= IFCAXIS2PLACEMENT3D(#13980,#7,#501);
#13982= IFCLOCALPLACEMENT(#30,#13981);
#13983= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#13984= IFCEXTRUDEDAREASOLID(#13983,#11276,#9,5.99999999999997);
#13985= IFCSTYLEDITEM(#13984,(#195),$);
#13986= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#13987= IFCEXTRUDEDAREASOLID(#13986,#11281,#9,6.1);
#13988= IFCSTYLEDITEM(#13987,(#195),$);
#13989= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3875);
#13990= IFCEXTRUDEDAREASOLID(#13989,#11286,#9,7.92);
#13991= IFCSTYLEDITEM(#13990,(#558),$);
#13992= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#13993= IFCEXTRUDEDAREASOLID(#13992,#11291,#9,35.);
#13994= IFCSTYLEDITEM(#13993,(#558),$);
#13995= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#13996= IFCEXTRUDEDAREASOLID(#13995,#11296,#9,8.);
#13997= IFCSTYLEDITEM(#13996,(#558),$);
#13998= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#13999= IFCEXTRUDEDAREASOLID(#13998,#11301,#9,10.);
#14000= IFCSTYLEDITEM(#13999,(#558),$);
#14001= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#13984,#13987,#13990,#13993,#13996,#13999));
#14002= IFCREPRESENTATIONMAP(#10,#14001);
#14003= IFCMAPPEDITEM(#14002,#247);
#14004= IFCMAPPEDITEM(#14002,#8847);
#14005= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14003,#14004));
#14006= IFCPRODUCTDEFINITIONSHAPE($,$,(#14005));
#14007= IFCMECHANICALFASTENER('1Td1iR001czp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#13982,#14006,'ID5d9c1b1b-0000-66f7-3135-373035313136',12.,35.);
#14008= IFCCARTESIANPOINT((46610.,-459.171078953306,20104.9956931453));
#14009= IFCAXIS2PLACEMENT3D(#14008,#501,#596);
#14010= IFCLOCALPLACEMENT(#30,#14009);
#14011= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#14012= IFCCARTESIANPOINT((0.,1.89268046919314,0.));
#14013= IFCAXIS2PLACEMENT3D(#14012,#8,#7);
#14014= IFCEXTRUDEDAREASOLID(#14011,#14013,#9,16.1);
#14015= IFCSTYLEDITEM(#14014,(#195),$);
#14016= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#12699);
#14017= IFCEXTRUDEDAREASOLID(#14016,#12702,#9,10.);
#14018= IFCSTYLEDITEM(#14017,(#195),$);
#14019= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3875);
#14020= IFCEXTRUDEDAREASOLID(#14019,#12707,#9,7.92);
#14021= IFCSTYLEDITEM(#14020,(#558),$);
#14022= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#14023= IFCEXTRUDEDAREASOLID(#14022,#12712,#9,50.);
#14024= IFCSTYLEDITEM(#14023,(#558),$);
#14025= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#14026= IFCCARTESIANPOINT((0.,17.9926804691931,0.));
#14027= IFCAXIS2PLACEMENT3D(#14026,#8,#7);
#14028= IFCEXTRUDEDAREASOLID(#14025,#14027,#9,8.);
#14029= IFCSTYLEDITEM(#14028,(#558),$);
#14030= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#14031= IFCCARTESIANPOINT((0.,25.9926804691931,0.));
#14032= IFCAXIS2PLACEMENT3D(#14031,#8,#7);
#14033= IFCEXTRUDEDAREASOLID(#14030,#14032,#9,10.);
#14034= IFCSTYLEDITEM(#14033,(#558),$);
#14035= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14014,#14017,#14020,#14023,#14028,#14033));
#14036= IFCREPRESENTATIONMAP(#10,#14035);
#14037= IFCMAPPEDITEM(#14036,#247);
#14038= IFCMAPPEDITEM(#14036,#12729);
#14039= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14037,#14038));
#14040= IFCPRODUCTDEFINITIONSHAPE($,$,(#14039));
#14041= IFCMECHANICALFASTENER('1Td1iR001c_Z4rDp0rCJ4s',#5,'Bolt assembly',$,$,#14010,#14040,'ID5d9c1b1b-0000-66fa-3135-373035313136',12.,50.);
#14042= IFCCARTESIANPOINT((44990.,-459.171078953306,20104.9956931453));
#14043= IFCAXIS2PLACEMENT3D(#14042,#501,#596);
#14044= IFCLOCALPLACEMENT(#30,#14043);
#14045= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#14046= IFCEXTRUDEDAREASOLID(#14045,#14013,#9,16.1);
#14047= IFCSTYLEDITEM(#14046,(#195),$);
#14048= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#12699);
#14049= IFCEXTRUDEDAREASOLID(#14048,#12702,#9,10.);
#14050= IFCSTYLEDITEM(#14049,(#195),$);
#14051= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3875);
#14052= IFCEXTRUDEDAREASOLID(#14051,#12707,#9,7.92);
#14053= IFCSTYLEDITEM(#14052,(#558),$);
#14054= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#14055= IFCEXTRUDEDAREASOLID(#14054,#12712,#9,50.);
#14056= IFCSTYLEDITEM(#14055,(#558),$);
#14057= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#14058= IFCEXTRUDEDAREASOLID(#14057,#14027,#9,8.);
#14059= IFCSTYLEDITEM(#14058,(#558),$);
#14060= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#14061= IFCEXTRUDEDAREASOLID(#14060,#14032,#9,10.);
#14062= IFCSTYLEDITEM(#14061,(#558),$);
#14063= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14046,#14049,#14052,#14055,#14058,#14061));
#14064= IFCREPRESENTATIONMAP(#10,#14063);
#14065= IFCMAPPEDITEM(#14064,#247);
#14066= IFCMAPPEDITEM(#14064,#12729);
#14067= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14065,#14066));
#14068= IFCPRODUCTDEFINITIONSHAPE($,$,(#14067));
#14069= IFCMECHANICALFASTENER('1Td1iR001c$J4rDp0rCJ4s',#5,'Bolt assembly',$,$,#14044,#14068,'ID5d9c1b1b-0000-66fd-3135-373035313136',12.,50.);
#14070= IFCCARTESIANPOINT((44180.,-459.171078953306,20104.9956931453));
#14071= IFCAXIS2PLACEMENT3D(#14070,#501,#596);
#14072= IFCLOCALPLACEMENT(#30,#14071);
#14073= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#14074= IFCEXTRUDEDAREASOLID(#14073,#14013,#9,16.1);
#14075= IFCSTYLEDITEM(#14074,(#195),$);
#14076= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#12699);
#14077= IFCEXTRUDEDAREASOLID(#14076,#12702,#9,10.);
#14078= IFCSTYLEDITEM(#14077,(#195),$);
#14079= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3875);
#14080= IFCEXTRUDEDAREASOLID(#14079,#12707,#9,7.92);
#14081= IFCSTYLEDITEM(#14080,(#558),$);
#14082= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#14083= IFCEXTRUDEDAREASOLID(#14082,#12712,#9,50.);
#14084= IFCSTYLEDITEM(#14083,(#558),$);
#14085= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#14086= IFCEXTRUDEDAREASOLID(#14085,#14027,#9,8.);
#14087= IFCSTYLEDITEM(#14086,(#558),$);
#14088= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#14089= IFCEXTRUDEDAREASOLID(#14088,#14032,#9,10.);
#14090= IFCSTYLEDITEM(#14089,(#558),$);
#14091= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14074,#14077,#14080,#14083,#14086,#14089));
#14092= IFCREPRESENTATIONMAP(#10,#14091);
#14093= IFCMAPPEDITEM(#14092,#247);
#14094= IFCMAPPEDITEM(#14092,#12729);
#14095= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14093,#14094));
#14096= IFCPRODUCTDEFINITIONSHAPE($,$,(#14095));
#14097= IFCMECHANICALFASTENER('1Td1iR001d034rDp0rCJ4s',#5,'Bolt assembly',$,$,#14072,#14096,'ID5d9c1b1b-0000-6700-3135-373035313136',12.,50.);
#14098= IFCCARTESIANPOINT((43389.98,-459.171078953306,20104.9956931453));
#14099= IFCAXIS2PLACEMENT3D(#14098,#8,#596);
#14100= IFCLOCALPLACEMENT(#30,#14099);
#14101= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#14102= IFCCARTESIANPOINT((0.,2.08731953083189,0.));
#14103= IFCAXIS2PLACEMENT3D(#14102,#8,#7);
#14104= IFCEXTRUDEDAREASOLID(#14101,#14103,#9,16.);
#14105= IFCSTYLEDITEM(#14104,(#195),$);
#14106= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#12699);
#14107= IFCCARTESIANPOINT((0.,19.8800000000105,0.));
#14108= IFCAXIS2PLACEMENT3D(#14107,#8,#7);
#14109= IFCEXTRUDEDAREASOLID(#14106,#14108,#9,10.1);
#14110= IFCSTYLEDITEM(#14109,(#195),$);
#14111= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3875);
#14112= IFCCARTESIANPOINT((0.,-5.93268046916811,0.));
#14113= IFCAXIS2PLACEMENT3D(#14112,#8,#7);
#14114= IFCEXTRUDEDAREASOLID(#14111,#14113,#9,7.92);
#14115= IFCSTYLEDITEM(#14114,(#558),$);
#14116= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#14117= IFCCARTESIANPOINT((0.,1.98731953083189,0.));
#14118= IFCAXIS2PLACEMENT3D(#14117,#8,#7);
#14119= IFCEXTRUDEDAREASOLID(#14116,#14118,#9,50.);
#14120= IFCSTYLEDITEM(#14119,(#558),$);
#14121= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#14122= IFCCARTESIANPOINT((0.,29.9800000000105,0.));
#14123= IFCAXIS2PLACEMENT3D(#14122,#8,#7);
#14124= IFCEXTRUDEDAREASOLID(#14121,#14123,#9,8.);
#14125= IFCSTYLEDITEM(#14124,(#558),$);
#14126= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#14127= IFCCARTESIANPOINT((0.,37.9800000000105,0.));
#14128= IFCAXIS2PLACEMENT3D(#14127,#8,#7);
#14129= IFCEXTRUDEDAREASOLID(#14126,#14128,#9,10.);
#14130= IFCSTYLEDITEM(#14129,(#558),$);
#14131= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14104,#14109,#14114,#14119,#14124,#14129));
#14132= IFCREPRESENTATIONMAP(#10,#14131);
#14133= IFCMAPPEDITEM(#14132,#247);
#14134= IFCMAPPEDITEM(#14132,#12729);
#14135= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14133,#14134));
#14136= IFCPRODUCTDEFINITIONSHAPE($,$,(#14135));
#14137= IFCMECHANICALFASTENER('1Td1iR001d0p4rDp0rCJ4s',#5,'Bolt assembly',$,$,#14100,#14136,'ID5d9c1b1b-0000-6703-3135-373035313136',12.,50.);
#14138= IFCCARTESIANPOINT((40909.9926804692,-579.170000075344,4895.0000000002));
#14139= IFCAXIS2PLACEMENT3D(#14138,#8,#7);
#14140= IFCLOCALPLACEMENT(#30,#14139);
#14141= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#14142= IFCEXTRUDEDAREASOLID(#14141,#4752,#9,16.1);
#14143= IFCSTYLEDITEM(#14142,(#195),$);
#14144= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#14145= IFCEXTRUDEDAREASOLID(#14144,#4747,#9,16.000000000024);
#14146= IFCSTYLEDITEM(#14145,(#195),$);
#14147= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#14148= IFCEXTRUDEDAREASOLID(#14147,#4757,#9,6.5);
#14149= IFCSTYLEDITEM(#14148,(#191),$);
#14150= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#14151= IFCEXTRUDEDAREASOLID(#14150,#4762,#9,50.);
#14152= IFCSTYLEDITEM(#14151,(#191),$);
#14153= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#14154= IFCEXTRUDEDAREASOLID(#14153,#4767,#9,2.5);
#14155= IFCSTYLEDITEM(#14154,(#191),$);
#14156= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#14157= IFCEXTRUDEDAREASOLID(#14156,#4772,#9,10.);
#14158= IFCSTYLEDITEM(#14157,(#191),$);
#14159= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14142,#14145,#14148,#14151,#14154,#14157));
#14160= IFCREPRESENTATIONMAP(#10,#14159);
#14161= IFCMAPPEDITEM(#14160,#4776);
#14162= IFCMAPPEDITEM(#14160,#4781);
#14163= IFCMAPPEDITEM(#14160,#4784);
#14164= IFCMAPPEDITEM(#14160,#4787);
#14165= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14161,#14162,#14163,#14164));
#14166= IFCPRODUCTDEFINITIONSHAPE($,$,(#14165));
#14167= IFCMECHANICALFASTENER('1Td1iR001d1Z4rDp0rCJ4s',#5,'Bolt assembly',$,$,#14140,#14166,'ID5d9c1b1b-0000-6706-3135-373035313136',12.,50.);
#14168= IFCCARTESIANPOINT((40909.9926804692,-579.170000075344,10595.0000000002));
#14169= IFCAXIS2PLACEMENT3D(#14168,#8,#7);
#14170= IFCLOCALPLACEMENT(#30,#14169);
#14171= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#14172= IFCEXTRUDEDAREASOLID(#14171,#4752,#9,16.1);
#14173= IFCSTYLEDITEM(#14172,(#195),$);
#14174= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#14175= IFCEXTRUDEDAREASOLID(#14174,#4747,#9,16.0000000000234);
#14176= IFCSTYLEDITEM(#14175,(#195),$);
#14177= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#14178= IFCEXTRUDEDAREASOLID(#14177,#4757,#9,6.5);
#14179= IFCSTYLEDITEM(#14178,(#191),$);
#14180= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#14181= IFCEXTRUDEDAREASOLID(#14180,#4762,#9,50.);
#14182= IFCSTYLEDITEM(#14181,(#191),$);
#14183= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#14184= IFCEXTRUDEDAREASOLID(#14183,#4767,#9,2.5);
#14185= IFCSTYLEDITEM(#14184,(#191),$);
#14186= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#14187= IFCEXTRUDEDAREASOLID(#14186,#4772,#9,10.);
#14188= IFCSTYLEDITEM(#14187,(#191),$);
#14189= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14172,#14175,#14178,#14181,#14184,#14187));
#14190= IFCREPRESENTATIONMAP(#10,#14189);
#14191= IFCMAPPEDITEM(#14190,#4776);
#14192= IFCMAPPEDITEM(#14190,#4781);
#14193= IFCMAPPEDITEM(#14190,#4784);
#14194= IFCMAPPEDITEM(#14190,#4787);
#14195= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14191,#14192,#14193,#14194));
#14196= IFCPRODUCTDEFINITIONSHAPE($,$,(#14195));
#14197= IFCMECHANICALFASTENER('1Td1iR001d2J4rDp0rCJ4s',#5,'Bolt assembly',$,$,#14170,#14196,'ID5d9c1b1b-0000-6709-3135-373035313136',12.,50.);
#14198= IFCCARTESIANPOINT((40940.,-459.171078953306,20104.9956931453));
#14199= IFCAXIS2PLACEMENT3D(#14198,#501,#596);
#14200= IFCLOCALPLACEMENT(#30,#14199);
#14201= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#14202= IFCEXTRUDEDAREASOLID(#14201,#14013,#9,16.1);
#14203= IFCSTYLEDITEM(#14202,(#195),$);
#14204= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#12699);
#14205= IFCEXTRUDEDAREASOLID(#14204,#12702,#9,10.);
#14206= IFCSTYLEDITEM(#14205,(#195),$);
#14207= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3875);
#14208= IFCEXTRUDEDAREASOLID(#14207,#12707,#9,7.92);
#14209= IFCSTYLEDITEM(#14208,(#558),$);
#14210= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#14211= IFCEXTRUDEDAREASOLID(#14210,#12712,#9,50.);
#14212= IFCSTYLEDITEM(#14211,(#558),$);
#14213= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#14214= IFCEXTRUDEDAREASOLID(#14213,#14027,#9,8.);
#14215= IFCSTYLEDITEM(#14214,(#558),$);
#14216= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#14217= IFCEXTRUDEDAREASOLID(#14216,#14032,#9,10.);
#14218= IFCSTYLEDITEM(#14217,(#558),$);
#14219= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14202,#14205,#14208,#14211,#14214,#14217));
#14220= IFCREPRESENTATIONMAP(#10,#14219);
#14221= IFCMAPPEDITEM(#14220,#247);
#14222= IFCMAPPEDITEM(#14220,#12729);
#14223= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14221,#14222));
#14224= IFCPRODUCTDEFINITIONSHAPE($,$,(#14223));
#14225= IFCMECHANICALFASTENER('1Td1iR001d334rDp0rCJ4s',#5,'Bolt assembly',$,$,#14200,#14224,'ID5d9c1b1b-0000-670c-3135-373035313136',12.,50.);
#14226= IFCCARTESIANPOINT((40909.992680469,-579.170000065103,-1104.9999999998));
#14227= IFCAXIS2PLACEMENT3D(#14226,#8,#7);
#14228= IFCLOCALPLACEMENT(#30,#14227);
#14229= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#14230= IFCEXTRUDEDAREASOLID(#14229,#4752,#9,16.1);
#14231= IFCSTYLEDITEM(#14230,(#195),$);
#14232= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#14233= IFCCARTESIANPOINT((0.,-10.8957771389686,0.));
#14234= IFCAXIS2PLACEMENT3D(#14233,#8,#7);
#14235= IFCEXTRUDEDAREASOLID(#14232,#14234,#9,16.0000000000234);
#14236= IFCSTYLEDITEM(#14235,(#195),$);
#14237= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#14238= IFCCARTESIANPOINT((0.,-17.4957771389686,0.));
#14239= IFCAXIS2PLACEMENT3D(#14238,#8,#7);
#14240= IFCEXTRUDEDAREASOLID(#14237,#14239,#9,6.5);
#14241= IFCSTYLEDITEM(#14240,(#191),$);
#14242= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#14243= IFCCARTESIANPOINT((0.,-10.9957771389686,0.));
#14244= IFCAXIS2PLACEMENT3D(#14243,#8,#7);
#14245= IFCEXTRUDEDAREASOLID(#14242,#14244,#9,50.);
#14246= IFCSTYLEDITEM(#14245,(#191),$);
#14247= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#14248= IFCEXTRUDEDAREASOLID(#14247,#4767,#9,2.5);
#14249= IFCSTYLEDITEM(#14248,(#191),$);
#14250= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#14251= IFCEXTRUDEDAREASOLID(#14250,#4772,#9,10.);
#14252= IFCSTYLEDITEM(#14251,(#191),$);
#14253= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14230,#14235,#14240,#14245,#14248,#14251));
#14254= IFCREPRESENTATIONMAP(#10,#14253);
#14255= IFCMAPPEDITEM(#14254,#4784);
#14256= IFCMAPPEDITEM(#14254,#4787);
#14257= IFCMAPPEDITEM(#14254,#4776);
#14258= IFCMAPPEDITEM(#14254,#4781);
#14259= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14255,#14256,#14257,#14258));
#14260= IFCPRODUCTDEFINITIONSHAPE($,$,(#14259));
#14261= IFCMECHANICALFASTENER('1Td1iR001d3p4rDp0rCJ4s',#5,'Bolt assembly',$,$,#14228,#14260,'ID5d9c1b1b-0000-670f-3135-373035313136',12.,50.);
#14262= IFCCARTESIANPOINT((46509.9926804692,-581.666078953131,-7665.004));
#14263= IFCAXIS2PLACEMENT3D(#14262,#501,#185);
#14264= IFCLOCALPLACEMENT(#30,#14263);
#14265= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#14266= IFCEXTRUDEDAREASOLID(#14265,#2479,#9,15.1);
#14267= IFCSTYLEDITEM(#14266,(#195),$);
#14268= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14266));
#14269= IFCREPRESENTATIONMAP(#10,#14268);
#14270= IFCMAPPEDITEM(#14269,#247);
#14271= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14270));
#14272= IFCPRODUCTDEFINITIONSHAPE($,$,(#14271));
#14273= IFCMECHANICALFASTENER('1Td1iR001d4Z4rDp0rCJ4s',#5,'Bolt assembly',$,$,#14264,#14272,'ID5d9c1b1b-0000-6712-3135-373035313136',20.,15.);
#14274= IFCCARTESIANPOINT((46729.9926804692,-581.666078953131,-7665.004));
#14275= IFCAXIS2PLACEMENT3D(#14274,#8,#7);
#14276= IFCLOCALPLACEMENT(#30,#14275);
#14277= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#14278= IFCEXTRUDEDAREASOLID(#14277,#2479,#9,15.1);
#14279= IFCSTYLEDITEM(#14278,(#195),$);
#14280= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14278));
#14281= IFCREPRESENTATIONMAP(#10,#14280);
#14282= IFCMAPPEDITEM(#14281,#247);
#14283= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14282));
#14284= IFCPRODUCTDEFINITIONSHAPE($,$,(#14283));
#14285= IFCMECHANICALFASTENER('1Td1iR001d5J4rDp0rCJ4s',#5,'Bolt assembly',$,$,#14276,#14284,'ID5d9c1b1b-0000-6715-3135-373035313136',20.,15.);
#14286= IFCCARTESIANPOINT((46509.9926804692,-581.663078953131,-7680.004));
#14287= IFCAXIS2PLACEMENT3D(#14286,#8,#7);
#14288= IFCLOCALPLACEMENT(#30,#14287);
#14289= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,29.);
#14290= IFCEXTRUDEDAREASOLID(#14289,#9050,#9,20.100000000003);
#14291= IFCSTYLEDITEM(#14290,(#195),$);
#14292= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14290));
#14293= IFCREPRESENTATIONMAP(#10,#14292);
#14294= IFCMAPPEDITEM(#14293,#247);
#14295= IFCMAPPEDITEM(#14293,#9057);
#14296= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14294,#14295));
#14297= IFCPRODUCTDEFINITIONSHAPE($,$,(#14296));
#14298= IFCMECHANICALFASTENER('1Td1iR001d634rDp0rCJ4s',#5,'Bolt assembly',$,$,#14288,#14297,'ID5d9c1b1b-0000-6718-3135-373035313136',30.,20.);
#14299= IFCCARTESIANPOINT((44889.9926804692,-581.666078953131,-7665.004));
#14300= IFCAXIS2PLACEMENT3D(#14299,#501,#185);
#14301= IFCLOCALPLACEMENT(#30,#14300);
#14302= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#14303= IFCEXTRUDEDAREASOLID(#14302,#2479,#9,15.1);
#14304= IFCSTYLEDITEM(#14303,(#195),$);
#14305= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14303));
#14306= IFCREPRESENTATIONMAP(#10,#14305);
#14307= IFCMAPPEDITEM(#14306,#247);
#14308= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14307));
#14309= IFCPRODUCTDEFINITIONSHAPE($,$,(#14308));
#14310= IFCMECHANICALFASTENER('1Td1iR001d6p4rDp0rCJ4s',#5,'Bolt assembly',$,$,#14301,#14309,'ID5d9c1b1b-0000-671b-3135-373035313136',20.,15.);
#14311= IFCCARTESIANPOINT((45109.9926804692,-581.666078953131,-7665.004));
#14312= IFCAXIS2PLACEMENT3D(#14311,#8,#7);
#14313= IFCLOCALPLACEMENT(#30,#14312);
#14314= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#14315= IFCEXTRUDEDAREASOLID(#14314,#2479,#9,15.1);
#14316= IFCSTYLEDITEM(#14315,(#195),$);
#14317= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14315));
#14318= IFCREPRESENTATIONMAP(#10,#14317);
#14319= IFCMAPPEDITEM(#14318,#247);
#14320= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14319));
#14321= IFCPRODUCTDEFINITIONSHAPE($,$,(#14320));
#14322= IFCMECHANICALFASTENER('1Td1iR001d7Z4rDp0rCJ4s',#5,'Bolt assembly',$,$,#14313,#14321,'ID5d9c1b1b-0000-671e-3135-373035313136',20.,15.);
#14323= IFCCARTESIANPOINT((44889.9926804692,-581.663078953131,-7680.004));
#14324= IFCAXIS2PLACEMENT3D(#14323,#8,#7);
#14325= IFCLOCALPLACEMENT(#30,#14324);
#14326= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,29.);
#14327= IFCEXTRUDEDAREASOLID(#14326,#9050,#9,20.100000000003);
#14328= IFCSTYLEDITEM(#14327,(#195),$);
#14329= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14327));
#14330= IFCREPRESENTATIONMAP(#10,#14329);
#14331= IFCMAPPEDITEM(#14330,#247);
#14332= IFCMAPPEDITEM(#14330,#9057);
#14333= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14331,#14332));
#14334= IFCPRODUCTDEFINITIONSHAPE($,$,(#14333));
#14335= IFCMECHANICALFASTENER('1Td1iR001d8J4rDp0rCJ4s',#5,'Bolt assembly',$,$,#14325,#14334,'ID5d9c1b1b-0000-6721-3135-373035313136',30.,20.);
#14336= IFCCARTESIANPOINT((44079.9926804692,-581.666078953131,-7665.004));
#14337= IFCAXIS2PLACEMENT3D(#14336,#501,#185);
#14338= IFCLOCALPLACEMENT(#30,#14337);
#14339= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#14340= IFCEXTRUDEDAREASOLID(#14339,#2479,#9,15.1);
#14341= IFCSTYLEDITEM(#14340,(#195),$);
#14342= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14340));
#14343= IFCREPRESENTATIONMAP(#10,#14342);
#14344= IFCMAPPEDITEM(#14343,#247);
#14345= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14344));
#14346= IFCPRODUCTDEFINITIONSHAPE($,$,(#14345));
#14347= IFCMECHANICALFASTENER('1Td1iR001d934rDp0rCJ4s',#5,'Bolt assembly',$,$,#14338,#14346,'ID5d9c1b1b-0000-6724-3135-373035313136',20.,15.);
#14348= IFCCARTESIANPOINT((44299.9926804692,-581.666078953131,-7665.004));
#14349= IFCAXIS2PLACEMENT3D(#14348,#8,#7);
#14350= IFCLOCALPLACEMENT(#30,#14349);
#14351= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#14352= IFCEXTRUDEDAREASOLID(#14351,#2479,#9,15.1);
#14353= IFCSTYLEDITEM(#14352,(#195),$);
#14354= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14352));
#14355= IFCREPRESENTATIONMAP(#10,#14354);
#14356= IFCMAPPEDITEM(#14355,#247);
#14357= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14356));
#14358= IFCPRODUCTDEFINITIONSHAPE($,$,(#14357));
#14359= IFCMECHANICALFASTENER('1Td1iR001d9p4rDp0rCJ4s',#5,'Bolt assembly',$,$,#14350,#14358,'ID5d9c1b1b-0000-6727-3135-373035313136',20.,15.);
#14360= IFCCARTESIANPOINT((44079.9926804692,-581.663078953131,-7680.004));
#14361= IFCAXIS2PLACEMENT3D(#14360,#8,#7);
#14362= IFCLOCALPLACEMENT(#30,#14361);
#14363= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,29.);
#14364= IFCEXTRUDEDAREASOLID(#14363,#9050,#9,20.100000000003);
#14365= IFCSTYLEDITEM(#14364,(#195),$);
#14366= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14364));
#14367= IFCREPRESENTATIONMAP(#10,#14366);
#14368= IFCMAPPEDITEM(#14367,#247);
#14369= IFCMAPPEDITEM(#14367,#9057);
#14370= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14368,#14369));
#14371= IFCPRODUCTDEFINITIONSHAPE($,$,(#14370));
#14372= IFCMECHANICALFASTENER('1Td1iR001dAZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#14362,#14371,'ID5d9c1b1b-0000-672a-3135-373035313136',30.,20.);
#14373= IFCCARTESIANPOINT((43269.9926804692,-581.666078953131,-7665.004));
#14374= IFCAXIS2PLACEMENT3D(#14373,#501,#185);
#14375= IFCLOCALPLACEMENT(#30,#14374);
#14376= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#14377= IFCEXTRUDEDAREASOLID(#14376,#2479,#9,15.1);
#14378= IFCSTYLEDITEM(#14377,(#195),$);
#14379= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14377));
#14380= IFCREPRESENTATIONMAP(#10,#14379);
#14381= IFCMAPPEDITEM(#14380,#247);
#14382= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14381));
#14383= IFCPRODUCTDEFINITIONSHAPE($,$,(#14382));
#14384= IFCMECHANICALFASTENER('1Td1iR001dBJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#14375,#14383,'ID5d9c1b1b-0000-672d-3135-373035313136',20.,15.);
#14385= IFCCARTESIANPOINT((43489.9926804692,-581.666078953131,-7665.004));
#14386= IFCAXIS2PLACEMENT3D(#14385,#8,#7);
#14387= IFCLOCALPLACEMENT(#30,#14386);
#14388= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#14389= IFCEXTRUDEDAREASOLID(#14388,#2479,#9,15.1);
#14390= IFCSTYLEDITEM(#14389,(#195),$);
#14391= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14389));
#14392= IFCREPRESENTATIONMAP(#10,#14391);
#14393= IFCMAPPEDITEM(#14392,#247);
#14394= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14393));
#14395= IFCPRODUCTDEFINITIONSHAPE($,$,(#14394));
#14396= IFCMECHANICALFASTENER('1Td1iR001dC34rDp0rCJ4s',#5,'Bolt assembly',$,$,#14387,#14395,'ID5d9c1b1b-0000-6730-3135-373035313136',20.,15.);
#14397= IFCCARTESIANPOINT((43269.9926804692,-581.663078953131,-7680.004));
#14398= IFCAXIS2PLACEMENT3D(#14397,#8,#7);
#14399= IFCLOCALPLACEMENT(#30,#14398);
#14400= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,29.);
#14401= IFCEXTRUDEDAREASOLID(#14400,#9050,#9,20.100000000003);
#14402= IFCSTYLEDITEM(#14401,(#195),$);
#14403= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14401));
#14404= IFCREPRESENTATIONMAP(#10,#14403);
#14405= IFCMAPPEDITEM(#14404,#247);
#14406= IFCMAPPEDITEM(#14404,#9057);
#14407= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14405,#14406));
#14408= IFCPRODUCTDEFINITIONSHAPE($,$,(#14407));
#14409= IFCMECHANICALFASTENER('1Td1iR001dCp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#14399,#14408,'ID5d9c1b1b-0000-6733-3135-373035313136',30.,20.);
#14410= IFCCARTESIANPOINT((40839.9926804692,-581.666078953131,-7665.004));
#14411= IFCAXIS2PLACEMENT3D(#14410,#501,#185);
#14412= IFCLOCALPLACEMENT(#30,#14411);
#14413= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#14414= IFCEXTRUDEDAREASOLID(#14413,#2479,#9,15.1);
#14415= IFCSTYLEDITEM(#14414,(#195),$);
#14416= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14414));
#14417= IFCREPRESENTATIONMAP(#10,#14416);
#14418= IFCMAPPEDITEM(#14417,#247);
#14419= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14418));
#14420= IFCPRODUCTDEFINITIONSHAPE($,$,(#14419));
#14421= IFCMECHANICALFASTENER('1Td1iR001dDZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#14412,#14420,'ID5d9c1b1b-0000-6736-3135-373035313136',20.,15.);
#14422= IFCCARTESIANPOINT((41059.9926804692,-581.666078953131,-7665.004));
#14423= IFCAXIS2PLACEMENT3D(#14422,#8,#7);
#14424= IFCLOCALPLACEMENT(#30,#14423);
#14425= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#14426= IFCEXTRUDEDAREASOLID(#14425,#2479,#9,15.1);
#14427= IFCSTYLEDITEM(#14426,(#195),$);
#14428= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14426));
#14429= IFCREPRESENTATIONMAP(#10,#14428);
#14430= IFCMAPPEDITEM(#14429,#247);
#14431= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14430));
#14432= IFCPRODUCTDEFINITIONSHAPE($,$,(#14431));
#14433= IFCMECHANICALFASTENER('1Td1iR001dEJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#14424,#14432,'ID5d9c1b1b-0000-6739-3135-373035313136',20.,15.);
#14434= IFCCARTESIANPOINT((40839.9926804692,-581.663078953131,-7680.004));
#14435= IFCAXIS2PLACEMENT3D(#14434,#8,#7);
#14436= IFCLOCALPLACEMENT(#30,#14435);
#14437= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,29.);
#14438= IFCEXTRUDEDAREASOLID(#14437,#9050,#9,20.100000000003);
#14439= IFCSTYLEDITEM(#14438,(#195),$);
#14440= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14438));
#14441= IFCREPRESENTATIONMAP(#10,#14440);
#14442= IFCMAPPEDITEM(#14441,#247);
#14443= IFCMAPPEDITEM(#14441,#9057);
#14444= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14442,#14443));
#14445= IFCPRODUCTDEFINITIONSHAPE($,$,(#14444));
#14446= IFCMECHANICALFASTENER('1Td1iR001dF34rDp0rCJ4s',#5,'Bolt assembly',$,$,#14436,#14445,'ID5d9c1b1b-0000-673c-3135-373035313136',30.,20.);
#14447= IFCCARTESIANPOINT((32809.9926804692,-579.170000075344,4895.0000000002));
#14448= IFCAXIS2PLACEMENT3D(#14447,#8,#7);
#14449= IFCLOCALPLACEMENT(#30,#14448);
#14450= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#14451= IFCEXTRUDEDAREASOLID(#14450,#4747,#9,16.000000000024);
#14452= IFCSTYLEDITEM(#14451,(#195),$);
#14453= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#14454= IFCEXTRUDEDAREASOLID(#14453,#4752,#9,16.1);
#14455= IFCSTYLEDITEM(#14454,(#195),$);
#14456= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#14457= IFCEXTRUDEDAREASOLID(#14456,#4757,#9,6.5);
#14458= IFCSTYLEDITEM(#14457,(#191),$);
#14459= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#14460= IFCEXTRUDEDAREASOLID(#14459,#4762,#9,50.);
#14461= IFCSTYLEDITEM(#14460,(#191),$);
#14462= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#14463= IFCEXTRUDEDAREASOLID(#14462,#4767,#9,2.5);
#14464= IFCSTYLEDITEM(#14463,(#191),$);
#14465= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#14466= IFCEXTRUDEDAREASOLID(#14465,#4772,#9,10.);
#14467= IFCSTYLEDITEM(#14466,(#191),$);
#14468= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14451,#14454,#14457,#14460,#14463,#14466));
#14469= IFCREPRESENTATIONMAP(#10,#14468);
#14470= IFCMAPPEDITEM(#14469,#4776);
#14471= IFCMAPPEDITEM(#14469,#4781);
#14472= IFCMAPPEDITEM(#14469,#4784);
#14473= IFCMAPPEDITEM(#14469,#4787);
#14474= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14470,#14471,#14472,#14473));
#14475= IFCPRODUCTDEFINITIONSHAPE($,$,(#14474));
#14476= IFCMECHANICALFASTENER('1Td1iR001dHJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#14449,#14475,'ID5d9c1b1b-0000-6745-3135-373035313136',12.,50.);
#14477= IFCCARTESIANPOINT((32809.9926804692,-579.170000075344,10595.0000000002));
#14478= IFCAXIS2PLACEMENT3D(#14477,#8,#7);
#14479= IFCLOCALPLACEMENT(#30,#14478);
#14480= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#14481= IFCEXTRUDEDAREASOLID(#14480,#4747,#9,16.0000000000234);
#14482= IFCSTYLEDITEM(#14481,(#195),$);
#14483= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#14484= IFCEXTRUDEDAREASOLID(#14483,#4752,#9,16.1);
#14485= IFCSTYLEDITEM(#14484,(#195),$);
#14486= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#14487= IFCEXTRUDEDAREASOLID(#14486,#4757,#9,6.5);
#14488= IFCSTYLEDITEM(#14487,(#191),$);
#14489= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#14490= IFCEXTRUDEDAREASOLID(#14489,#4762,#9,50.);
#14491= IFCSTYLEDITEM(#14490,(#191),$);
#14492= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#14493= IFCEXTRUDEDAREASOLID(#14492,#4767,#9,2.5);
#14494= IFCSTYLEDITEM(#14493,(#191),$);
#14495= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#14496= IFCEXTRUDEDAREASOLID(#14495,#4772,#9,10.);
#14497= IFCSTYLEDITEM(#14496,(#191),$);
#14498= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14481,#14484,#14487,#14490,#14493,#14496));
#14499= IFCREPRESENTATIONMAP(#10,#14498);
#14500= IFCMAPPEDITEM(#14499,#4776);
#14501= IFCMAPPEDITEM(#14499,#4781);
#14502= IFCMAPPEDITEM(#14499,#4784);
#14503= IFCMAPPEDITEM(#14499,#4787);
#14504= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14500,#14501,#14502,#14503));
#14505= IFCPRODUCTDEFINITIONSHAPE($,$,(#14504));
#14506= IFCMECHANICALFASTENER('1Td1iR001dKJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#14479,#14505,'ID5d9c1b1b-0000-6751-3135-373035313136',12.,50.);
#14507= IFCCARTESIANPOINT((40050.0091909279,-544.169499904543,-7141.));
#14508= IFCAXIS2PLACEMENT3D(#14507,#7,#501);
#14509= IFCLOCALPLACEMENT(#30,#14508);
#14510= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#14511= IFCEXTRUDEDAREASOLID(#14510,#8796,#9,6.);
#14512= IFCSTYLEDITEM(#14511,(#195),$);
#14513= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#8817);
#14514= IFCEXTRUDEDAREASOLID(#14513,#8820,#9,6.1);
#14515= IFCSTYLEDITEM(#14514,(#195),$);
#14516= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3875);
#14517= IFCEXTRUDEDAREASOLID(#14516,#8825,#9,7.92);
#14518= IFCSTYLEDITEM(#14517,(#558),$);
#14519= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#14520= IFCEXTRUDEDAREASOLID(#14519,#8830,#9,35.);
#14521= IFCSTYLEDITEM(#14520,(#558),$);
#14522= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#14523= IFCEXTRUDEDAREASOLID(#14522,#8835,#9,8.);
#14524= IFCSTYLEDITEM(#14523,(#558),$);
#14525= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#14526= IFCEXTRUDEDAREASOLID(#14525,#8840,#9,10.);
#14527= IFCSTYLEDITEM(#14526,(#558),$);
#14528= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14511,#14514,#14517,#14520,#14523,#14526));
#14529= IFCREPRESENTATIONMAP(#10,#14528);
#14530= IFCMAPPEDITEM(#14529,#247);
#14531= IFCMAPPEDITEM(#14529,#8847);
#14532= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14530,#14531));
#14533= IFCPRODUCTDEFINITIONSHAPE($,$,(#14532));
#14534= IFCMECHANICALFASTENER('1Td1iR001dO34rDp0rCJ4s',#5,'Bolt assembly',$,$,#14509,#14533,'ID5d9c1b1b-0000-6760-3135-373035313136',12.,35.);
#14535= IFCCARTESIANPOINT((39419.9918822948,-544.169499904543,-7145.));
#14536= IFCAXIS2PLACEMENT3D(#14535,#7,#501);
#14537= IFCLOCALPLACEMENT(#30,#14536);
#14538= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#14539= IFCEXTRUDEDAREASOLID(#14538,#11276,#9,5.99999999999997);
#14540= IFCSTYLEDITEM(#14539,(#195),$);
#14541= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#14542= IFCEXTRUDEDAREASOLID(#14541,#11281,#9,6.1);
#14543= IFCSTYLEDITEM(#14542,(#195),$);
#14544= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3875);
#14545= IFCEXTRUDEDAREASOLID(#14544,#11286,#9,7.92);
#14546= IFCSTYLEDITEM(#14545,(#558),$);
#14547= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#14548= IFCEXTRUDEDAREASOLID(#14547,#11291,#9,35.);
#14549= IFCSTYLEDITEM(#14548,(#558),$);
#14550= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#14551= IFCEXTRUDEDAREASOLID(#14550,#11296,#9,8.);
#14552= IFCSTYLEDITEM(#14551,(#558),$);
#14553= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#14554= IFCEXTRUDEDAREASOLID(#14553,#11301,#9,10.);
#14555= IFCSTYLEDITEM(#14554,(#558),$);
#14556= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14539,#14542,#14545,#14548,#14551,#14554));
#14557= IFCREPRESENTATIONMAP(#10,#14556);
#14558= IFCMAPPEDITEM(#14557,#247);
#14559= IFCMAPPEDITEM(#14557,#8847);
#14560= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14558,#14559));
#14561= IFCPRODUCTDEFINITIONSHAPE($,$,(#14560));
#14562= IFCMECHANICALFASTENER('1Td1iR001dOp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#14537,#14561,'ID5d9c1b1b-0000-6763-3135-373035313136',12.,35.);
#14563= IFCCARTESIANPOINT((39240.0091909279,-544.169499904543,-7141.));
#14564= IFCAXIS2PLACEMENT3D(#14563,#7,#501);
#14565= IFCLOCALPLACEMENT(#30,#14564);
#14566= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#14567= IFCEXTRUDEDAREASOLID(#14566,#8796,#9,6.);
#14568= IFCSTYLEDITEM(#14567,(#195),$);
#14569= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#8817);
#14570= IFCEXTRUDEDAREASOLID(#14569,#8820,#9,6.1);
#14571= IFCSTYLEDITEM(#14570,(#195),$);
#14572= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3875);
#14573= IFCEXTRUDEDAREASOLID(#14572,#8825,#9,7.92);
#14574= IFCSTYLEDITEM(#14573,(#558),$);
#14575= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#14576= IFCEXTRUDEDAREASOLID(#14575,#8830,#9,35.);
#14577= IFCSTYLEDITEM(#14576,(#558),$);
#14578= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#14579= IFCEXTRUDEDAREASOLID(#14578,#8835,#9,8.);
#14580= IFCSTYLEDITEM(#14579,(#558),$);
#14581= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#14582= IFCEXTRUDEDAREASOLID(#14581,#8840,#9,10.);
#14583= IFCSTYLEDITEM(#14582,(#558),$);
#14584= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14567,#14570,#14573,#14576,#14579,#14582));
#14585= IFCREPRESENTATIONMAP(#10,#14584);
#14586= IFCMAPPEDITEM(#14585,#247);
#14587= IFCMAPPEDITEM(#14585,#8847);
#14588= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14586,#14587));
#14589= IFCPRODUCTDEFINITIONSHAPE($,$,(#14588));
#14590= IFCMECHANICALFASTENER('1Td1iR001dPZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#14565,#14589,'ID5d9c1b1b-0000-6766-3135-373035313136',12.,35.);
#14591= IFCCARTESIANPOINT((36989.9918822948,-544.169499904543,-7145.));
#14592= IFCAXIS2PLACEMENT3D(#14591,#7,#501);
#14593= IFCLOCALPLACEMENT(#30,#14592);
#14594= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#14595= IFCEXTRUDEDAREASOLID(#14594,#11276,#9,5.99999999999997);
#14596= IFCSTYLEDITEM(#14595,(#195),$);
#14597= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#14598= IFCEXTRUDEDAREASOLID(#14597,#11281,#9,6.1);
#14599= IFCSTYLEDITEM(#14598,(#195),$);
#14600= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3875);
#14601= IFCEXTRUDEDAREASOLID(#14600,#11286,#9,7.92);
#14602= IFCSTYLEDITEM(#14601,(#558),$);
#14603= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#14604= IFCEXTRUDEDAREASOLID(#14603,#11291,#9,35.);
#14605= IFCSTYLEDITEM(#14604,(#558),$);
#14606= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#14607= IFCEXTRUDEDAREASOLID(#14606,#11296,#9,8.);
#14608= IFCSTYLEDITEM(#14607,(#558),$);
#14609= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#14610= IFCEXTRUDEDAREASOLID(#14609,#11301,#9,10.);
#14611= IFCSTYLEDITEM(#14610,(#558),$);
#14612= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14595,#14598,#14601,#14604,#14607,#14610));
#14613= IFCREPRESENTATIONMAP(#10,#14612);
#14614= IFCMAPPEDITEM(#14613,#247);
#14615= IFCMAPPEDITEM(#14613,#8847);
#14616= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14614,#14615));
#14617= IFCPRODUCTDEFINITIONSHAPE($,$,(#14616));
#14618= IFCMECHANICALFASTENER('1Td1iR001dQJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#14593,#14617,'ID5d9c1b1b-0000-6769-3135-373035313136',12.,35.);
#14619= IFCCARTESIANPOINT((35239.9926804692,-579.170000075344,4895.0000000002));
#14620= IFCAXIS2PLACEMENT3D(#14619,#8,#7);
#14621= IFCLOCALPLACEMENT(#30,#14620);
#14622= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#14623= IFCEXTRUDEDAREASOLID(#14622,#4747,#9,16.000000000024);
#14624= IFCSTYLEDITEM(#14623,(#195),$);
#14625= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#14626= IFCEXTRUDEDAREASOLID(#14625,#4752,#9,16.1);
#14627= IFCSTYLEDITEM(#14626,(#195),$);
#14628= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#14629= IFCEXTRUDEDAREASOLID(#14628,#4757,#9,6.5);
#14630= IFCSTYLEDITEM(#14629,(#191),$);
#14631= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#14632= IFCEXTRUDEDAREASOLID(#14631,#4762,#9,50.);
#14633= IFCSTYLEDITEM(#14632,(#191),$);
#14634= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#14635= IFCEXTRUDEDAREASOLID(#14634,#4767,#9,2.5);
#14636= IFCSTYLEDITEM(#14635,(#191),$);
#14637= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#14638= IFCEXTRUDEDAREASOLID(#14637,#4772,#9,10.);
#14639= IFCSTYLEDITEM(#14638,(#191),$);
#14640= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14623,#14626,#14629,#14632,#14635,#14638));
#14641= IFCREPRESENTATIONMAP(#10,#14640);
#14642= IFCMAPPEDITEM(#14641,#4776);
#14643= IFCMAPPEDITEM(#14641,#4781);
#14644= IFCMAPPEDITEM(#14641,#4784);
#14645= IFCMAPPEDITEM(#14641,#4787);
#14646= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14642,#14643,#14644,#14645));
#14647= IFCPRODUCTDEFINITIONSHAPE($,$,(#14646));
#14648= IFCMECHANICALFASTENER('1Td1iR001dep4rDp0rCJ4s',#5,'Bolt assembly',$,$,#14621,#14647,'ID5d9c1b1b-0000-67a3-3135-373035313136',12.,50.);
#14649= IFCCARTESIANPOINT((36049.9926804692,-579.170000075344,4895.0000000002));
#14650= IFCAXIS2PLACEMENT3D(#14649,#8,#7);
#14651= IFCLOCALPLACEMENT(#30,#14650);
#14652= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#14653= IFCEXTRUDEDAREASOLID(#14652,#4747,#9,16.000000000024);
#14654= IFCSTYLEDITEM(#14653,(#195),$);
#14655= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#14656= IFCEXTRUDEDAREASOLID(#14655,#4752,#9,16.1);
#14657= IFCSTYLEDITEM(#14656,(#195),$);
#14658= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#14659= IFCEXTRUDEDAREASOLID(#14658,#4757,#9,6.5);
#14660= IFCSTYLEDITEM(#14659,(#191),$);
#14661= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#14662= IFCEXTRUDEDAREASOLID(#14661,#4762,#9,50.);
#14663= IFCSTYLEDITEM(#14662,(#191),$);
#14664= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#14665= IFCEXTRUDEDAREASOLID(#14664,#4767,#9,2.5);
#14666= IFCSTYLEDITEM(#14665,(#191),$);
#14667= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#14668= IFCEXTRUDEDAREASOLID(#14667,#4772,#9,10.);
#14669= IFCSTYLEDITEM(#14668,(#191),$);
#14670= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14653,#14656,#14659,#14662,#14665,#14668));
#14671= IFCREPRESENTATIONMAP(#10,#14670);
#14672= IFCMAPPEDITEM(#14671,#4776);
#14673= IFCMAPPEDITEM(#14671,#4781);
#14674= IFCMAPPEDITEM(#14671,#4784);
#14675= IFCMAPPEDITEM(#14671,#4787);
#14676= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14672,#14673,#14674,#14675));
#14677= IFCPRODUCTDEFINITIONSHAPE($,$,(#14676));
#14678= IFCMECHANICALFASTENER('1Td1iR001dfZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#14651,#14677,'ID5d9c1b1b-0000-67a6-3135-373035313136',12.,50.);
#14679= IFCCARTESIANPOINT((36859.9926804692,-579.170000075344,4895.0000000002));
#14680= IFCAXIS2PLACEMENT3D(#14679,#8,#7);
#14681= IFCLOCALPLACEMENT(#30,#14680);
#14682= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#14683= IFCEXTRUDEDAREASOLID(#14682,#4747,#9,16.000000000024);
#14684= IFCSTYLEDITEM(#14683,(#195),$);
#14685= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#14686= IFCEXTRUDEDAREASOLID(#14685,#4752,#9,16.1);
#14687= IFCSTYLEDITEM(#14686,(#195),$);
#14688= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#14689= IFCEXTRUDEDAREASOLID(#14688,#4757,#9,6.5);
#14690= IFCSTYLEDITEM(#14689,(#191),$);
#14691= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#14692= IFCEXTRUDEDAREASOLID(#14691,#4762,#9,50.);
#14693= IFCSTYLEDITEM(#14692,(#191),$);
#14694= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#14695= IFCEXTRUDEDAREASOLID(#14694,#4767,#9,2.5);
#14696= IFCSTYLEDITEM(#14695,(#191),$);
#14697= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#14698= IFCEXTRUDEDAREASOLID(#14697,#4772,#9,10.);
#14699= IFCSTYLEDITEM(#14698,(#191),$);
#14700= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14683,#14686,#14689,#14692,#14695,#14698));
#14701= IFCREPRESENTATIONMAP(#10,#14700);
#14702= IFCMAPPEDITEM(#14701,#4776);
#14703= IFCMAPPEDITEM(#14701,#4781);
#14704= IFCMAPPEDITEM(#14701,#4784);
#14705= IFCMAPPEDITEM(#14701,#4787);
#14706= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14702,#14703,#14704,#14705));
#14707= IFCPRODUCTDEFINITIONSHAPE($,$,(#14706));
#14708= IFCMECHANICALFASTENER('1Td1iR001dgJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#14681,#14707,'ID5d9c1b1b-0000-67a9-3135-373035313136',12.,50.);
#14709= IFCCARTESIANPOINT((39289.9926804692,-579.170000075344,4895.0000000002));
#14710= IFCAXIS2PLACEMENT3D(#14709,#8,#7);
#14711= IFCLOCALPLACEMENT(#30,#14710);
#14712= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#14713= IFCEXTRUDEDAREASOLID(#14712,#4747,#9,16.000000000024);
#14714= IFCSTYLEDITEM(#14713,(#195),$);
#14715= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#14716= IFCEXTRUDEDAREASOLID(#14715,#4752,#9,16.1);
#14717= IFCSTYLEDITEM(#14716,(#195),$);
#14718= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#14719= IFCEXTRUDEDAREASOLID(#14718,#4757,#9,6.5);
#14720= IFCSTYLEDITEM(#14719,(#191),$);
#14721= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#14722= IFCEXTRUDEDAREASOLID(#14721,#4762,#9,50.);
#14723= IFCSTYLEDITEM(#14722,(#191),$);
#14724= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#14725= IFCEXTRUDEDAREASOLID(#14724,#4767,#9,2.5);
#14726= IFCSTYLEDITEM(#14725,(#191),$);
#14727= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#14728= IFCEXTRUDEDAREASOLID(#14727,#4772,#9,10.);
#14729= IFCSTYLEDITEM(#14728,(#191),$);
#14730= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14713,#14716,#14719,#14722,#14725,#14728));
#14731= IFCREPRESENTATIONMAP(#10,#14730);
#14732= IFCMAPPEDITEM(#14731,#4776);
#14733= IFCMAPPEDITEM(#14731,#4781);
#14734= IFCMAPPEDITEM(#14731,#4784);
#14735= IFCMAPPEDITEM(#14731,#4787);
#14736= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14732,#14733,#14734,#14735));
#14737= IFCPRODUCTDEFINITIONSHAPE($,$,(#14736));
#14738= IFCMECHANICALFASTENER('1Td1iR001dh34rDp0rCJ4s',#5,'Bolt assembly',$,$,#14711,#14737,'ID5d9c1b1b-0000-67ac-3135-373035313136',12.,50.);
#14739= IFCCARTESIANPOINT((40099.9926804692,-579.170000075344,4895.0000000002));
#14740= IFCAXIS2PLACEMENT3D(#14739,#8,#7);
#14741= IFCLOCALPLACEMENT(#30,#14740);
#14742= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#14743= IFCEXTRUDEDAREASOLID(#14742,#4747,#9,16.000000000024);
#14744= IFCSTYLEDITEM(#14743,(#195),$);
#14745= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#14746= IFCEXTRUDEDAREASOLID(#14745,#4752,#9,16.1);
#14747= IFCSTYLEDITEM(#14746,(#195),$);
#14748= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#14749= IFCEXTRUDEDAREASOLID(#14748,#4757,#9,6.5);
#14750= IFCSTYLEDITEM(#14749,(#191),$);
#14751= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#14752= IFCEXTRUDEDAREASOLID(#14751,#4762,#9,50.);
#14753= IFCSTYLEDITEM(#14752,(#191),$);
#14754= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#14755= IFCEXTRUDEDAREASOLID(#14754,#4767,#9,2.5);
#14756= IFCSTYLEDITEM(#14755,(#191),$);
#14757= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#14758= IFCEXTRUDEDAREASOLID(#14757,#4772,#9,10.);
#14759= IFCSTYLEDITEM(#14758,(#191),$);
#14760= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14743,#14746,#14749,#14752,#14755,#14758));
#14761= IFCREPRESENTATIONMAP(#10,#14760);
#14762= IFCMAPPEDITEM(#14761,#4776);
#14763= IFCMAPPEDITEM(#14761,#4781);
#14764= IFCMAPPEDITEM(#14761,#4784);
#14765= IFCMAPPEDITEM(#14761,#4787);
#14766= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14762,#14763,#14764,#14765));
#14767= IFCPRODUCTDEFINITIONSHAPE($,$,(#14766));
#14768= IFCMECHANICALFASTENER('1Td1iR001dhp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#14741,#14767,'ID5d9c1b1b-0000-67af-3135-373035313136',12.,50.);
#14769= IFCCARTESIANPOINT((35239.9926804692,-579.170000075344,10595.0000000002));
#14770= IFCAXIS2PLACEMENT3D(#14769,#8,#7);
#14771= IFCLOCALPLACEMENT(#30,#14770);
#14772= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#14773= IFCEXTRUDEDAREASOLID(#14772,#4747,#9,16.0000000000234);
#14774= IFCSTYLEDITEM(#14773,(#195),$);
#14775= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#14776= IFCEXTRUDEDAREASOLID(#14775,#4752,#9,16.1);
#14777= IFCSTYLEDITEM(#14776,(#195),$);
#14778= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#14779= IFCEXTRUDEDAREASOLID(#14778,#4757,#9,6.5);
#14780= IFCSTYLEDITEM(#14779,(#191),$);
#14781= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#14782= IFCEXTRUDEDAREASOLID(#14781,#4762,#9,50.);
#14783= IFCSTYLEDITEM(#14782,(#191),$);
#14784= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#14785= IFCEXTRUDEDAREASOLID(#14784,#4767,#9,2.5);
#14786= IFCSTYLEDITEM(#14785,(#191),$);
#14787= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#14788= IFCEXTRUDEDAREASOLID(#14787,#4772,#9,10.);
#14789= IFCSTYLEDITEM(#14788,(#191),$);
#14790= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14773,#14776,#14779,#14782,#14785,#14788));
#14791= IFCREPRESENTATIONMAP(#10,#14790);
#14792= IFCMAPPEDITEM(#14791,#4776);
#14793= IFCMAPPEDITEM(#14791,#4781);
#14794= IFCMAPPEDITEM(#14791,#4784);
#14795= IFCMAPPEDITEM(#14791,#4787);
#14796= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14792,#14793,#14794,#14795));
#14797= IFCPRODUCTDEFINITIONSHAPE($,$,(#14796));
#14798= IFCMECHANICALFASTENER('1Td1iR001duZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#14771,#14797,'ID5d9c1b1b-0000-67e2-3135-373035313136',12.,50.);
#14799= IFCCARTESIANPOINT((36049.9926804692,-579.170000075344,10595.0000000002));
#14800= IFCAXIS2PLACEMENT3D(#14799,#8,#7);
#14801= IFCLOCALPLACEMENT(#30,#14800);
#14802= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#14803= IFCEXTRUDEDAREASOLID(#14802,#4747,#9,16.0000000000234);
#14804= IFCSTYLEDITEM(#14803,(#195),$);
#14805= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#14806= IFCEXTRUDEDAREASOLID(#14805,#4752,#9,16.1);
#14807= IFCSTYLEDITEM(#14806,(#195),$);
#14808= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#14809= IFCEXTRUDEDAREASOLID(#14808,#4757,#9,6.5);
#14810= IFCSTYLEDITEM(#14809,(#191),$);
#14811= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#14812= IFCEXTRUDEDAREASOLID(#14811,#4762,#9,50.);
#14813= IFCSTYLEDITEM(#14812,(#191),$);
#14814= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#14815= IFCEXTRUDEDAREASOLID(#14814,#4767,#9,2.5);
#14816= IFCSTYLEDITEM(#14815,(#191),$);
#14817= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#14818= IFCEXTRUDEDAREASOLID(#14817,#4772,#9,10.);
#14819= IFCSTYLEDITEM(#14818,(#191),$);
#14820= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14803,#14806,#14809,#14812,#14815,#14818));
#14821= IFCREPRESENTATIONMAP(#10,#14820);
#14822= IFCMAPPEDITEM(#14821,#4776);
#14823= IFCMAPPEDITEM(#14821,#4781);
#14824= IFCMAPPEDITEM(#14821,#4784);
#14825= IFCMAPPEDITEM(#14821,#4787);
#14826= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14822,#14823,#14824,#14825));
#14827= IFCPRODUCTDEFINITIONSHAPE($,$,(#14826));
#14828= IFCMECHANICALFASTENER('1Td1iR001dvJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#14801,#14827,'ID5d9c1b1b-0000-67e5-3135-373035313136',12.,50.);
#14829= IFCCARTESIANPOINT((36859.9926804692,-579.170000075344,10595.0000000002));
#14830= IFCAXIS2PLACEMENT3D(#14829,#8,#7);
#14831= IFCLOCALPLACEMENT(#30,#14830);
#14832= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#14833= IFCEXTRUDEDAREASOLID(#14832,#4747,#9,16.0000000000234);
#14834= IFCSTYLEDITEM(#14833,(#195),$);
#14835= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#14836= IFCEXTRUDEDAREASOLID(#14835,#4752,#9,16.1);
#14837= IFCSTYLEDITEM(#14836,(#195),$);
#14838= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#14839= IFCEXTRUDEDAREASOLID(#14838,#4757,#9,6.5);
#14840= IFCSTYLEDITEM(#14839,(#191),$);
#14841= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#14842= IFCEXTRUDEDAREASOLID(#14841,#4762,#9,50.);
#14843= IFCSTYLEDITEM(#14842,(#191),$);
#14844= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#14845= IFCEXTRUDEDAREASOLID(#14844,#4767,#9,2.5);
#14846= IFCSTYLEDITEM(#14845,(#191),$);
#14847= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#14848= IFCEXTRUDEDAREASOLID(#14847,#4772,#9,10.);
#14849= IFCSTYLEDITEM(#14848,(#191),$);
#14850= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14833,#14836,#14839,#14842,#14845,#14848));
#14851= IFCREPRESENTATIONMAP(#10,#14850);
#14852= IFCMAPPEDITEM(#14851,#4776);
#14853= IFCMAPPEDITEM(#14851,#4781);
#14854= IFCMAPPEDITEM(#14851,#4784);
#14855= IFCMAPPEDITEM(#14851,#4787);
#14856= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14852,#14853,#14854,#14855));
#14857= IFCPRODUCTDEFINITIONSHAPE($,$,(#14856));
#14858= IFCMECHANICALFASTENER('1Td1iR001dw34rDp0rCJ4s',#5,'Bolt assembly',$,$,#14831,#14857,'ID5d9c1b1b-0000-67e8-3135-373035313136',12.,50.);
#14859= IFCCARTESIANPOINT((39289.9926804692,-579.170000075344,10595.0000000002));
#14860= IFCAXIS2PLACEMENT3D(#14859,#8,#7);
#14861= IFCLOCALPLACEMENT(#30,#14860);
#14862= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#14863= IFCEXTRUDEDAREASOLID(#14862,#4747,#9,16.0000000000234);
#14864= IFCSTYLEDITEM(#14863,(#195),$);
#14865= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#14866= IFCEXTRUDEDAREASOLID(#14865,#4752,#9,16.1);
#14867= IFCSTYLEDITEM(#14866,(#195),$);
#14868= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#14869= IFCEXTRUDEDAREASOLID(#14868,#4757,#9,6.5);
#14870= IFCSTYLEDITEM(#14869,(#191),$);
#14871= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#14872= IFCEXTRUDEDAREASOLID(#14871,#4762,#9,50.);
#14873= IFCSTYLEDITEM(#14872,(#191),$);
#14874= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#14875= IFCEXTRUDEDAREASOLID(#14874,#4767,#9,2.5);
#14876= IFCSTYLEDITEM(#14875,(#191),$);
#14877= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#14878= IFCEXTRUDEDAREASOLID(#14877,#4772,#9,10.);
#14879= IFCSTYLEDITEM(#14878,(#191),$);
#14880= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14863,#14866,#14869,#14872,#14875,#14878));
#14881= IFCREPRESENTATIONMAP(#10,#14880);
#14882= IFCMAPPEDITEM(#14881,#4776);
#14883= IFCMAPPEDITEM(#14881,#4781);
#14884= IFCMAPPEDITEM(#14881,#4784);
#14885= IFCMAPPEDITEM(#14881,#4787);
#14886= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14882,#14883,#14884,#14885));
#14887= IFCPRODUCTDEFINITIONSHAPE($,$,(#14886));
#14888= IFCMECHANICALFASTENER('1Td1iR001dwp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#14861,#14887,'ID5d9c1b1b-0000-67eb-3135-373035313136',12.,50.);
#14889= IFCCARTESIANPOINT((40099.9926804692,-579.170000075344,10595.0000000002));
#14890= IFCAXIS2PLACEMENT3D(#14889,#8,#7);
#14891= IFCLOCALPLACEMENT(#30,#14890);
#14892= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#14893= IFCEXTRUDEDAREASOLID(#14892,#4747,#9,16.0000000000234);
#14894= IFCSTYLEDITEM(#14893,(#195),$);
#14895= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,7.);
#14896= IFCEXTRUDEDAREASOLID(#14895,#4752,#9,16.1);
#14897= IFCSTYLEDITEM(#14896,(#195),$);
#14898= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#4375);
#14899= IFCEXTRUDEDAREASOLID(#14898,#4757,#9,6.5);
#14900= IFCSTYLEDITEM(#14899,(#191),$);
#14901= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#14902= IFCEXTRUDEDAREASOLID(#14901,#4762,#9,50.);
#14903= IFCSTYLEDITEM(#14902,(#191),$);
#14904= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#14905= IFCEXTRUDEDAREASOLID(#14904,#4767,#9,2.5);
#14906= IFCSTYLEDITEM(#14905,(#191),$);
#14907= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#14908= IFCEXTRUDEDAREASOLID(#14907,#4772,#9,10.);
#14909= IFCSTYLEDITEM(#14908,(#191),$);
#14910= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14893,#14896,#14899,#14902,#14905,#14908));
#14911= IFCREPRESENTATIONMAP(#10,#14910);
#14912= IFCMAPPEDITEM(#14911,#4776);
#14913= IFCMAPPEDITEM(#14911,#4781);
#14914= IFCMAPPEDITEM(#14911,#4784);
#14915= IFCMAPPEDITEM(#14911,#4787);
#14916= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14912,#14913,#14914,#14915));
#14917= IFCPRODUCTDEFINITIONSHAPE($,$,(#14916));
#14918= IFCMECHANICALFASTENER('1Td1iR001dxZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#14891,#14917,'ID5d9c1b1b-0000-67ee-3135-373035313136',12.,50.);
#14919= IFCCARTESIANPOINT((39219.9926804692,-581.666078953131,-7665.004));
#14920= IFCAXIS2PLACEMENT3D(#14919,#501,#185);
#14921= IFCLOCALPLACEMENT(#30,#14920);
#14922= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#14923= IFCEXTRUDEDAREASOLID(#14922,#2479,#9,15.1);
#14924= IFCSTYLEDITEM(#14923,(#195),$);
#14925= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14923));
#14926= IFCREPRESENTATIONMAP(#10,#14925);
#14927= IFCMAPPEDITEM(#14926,#247);
#14928= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14927));
#14929= IFCPRODUCTDEFINITIONSHAPE($,$,(#14928));
#14930= IFCMECHANICALFASTENER('1Td1iR001eBp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#14921,#14929,'ID5d9c1b1b-0000-682f-3135-373035313136',20.,15.);
#14931= IFCCARTESIANPOINT((39439.9926804692,-581.666078953131,-7665.004));
#14932= IFCAXIS2PLACEMENT3D(#14931,#8,#7);
#14933= IFCLOCALPLACEMENT(#30,#14932);
#14934= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#14935= IFCEXTRUDEDAREASOLID(#14934,#2479,#9,15.1);
#14936= IFCSTYLEDITEM(#14935,(#195),$);
#14937= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14935));
#14938= IFCREPRESENTATIONMAP(#10,#14937);
#14939= IFCMAPPEDITEM(#14938,#247);
#14940= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14939));
#14941= IFCPRODUCTDEFINITIONSHAPE($,$,(#14940));
#14942= IFCMECHANICALFASTENER('1Td1iR001eCZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#14933,#14941,'ID5d9c1b1b-0000-6832-3135-373035313136',20.,15.);
#14943= IFCCARTESIANPOINT((39219.9926804692,-581.663078953131,-7680.004));
#14944= IFCAXIS2PLACEMENT3D(#14943,#8,#7);
#14945= IFCLOCALPLACEMENT(#30,#14944);
#14946= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,29.);
#14947= IFCEXTRUDEDAREASOLID(#14946,#9050,#9,20.100000000003);
#14948= IFCSTYLEDITEM(#14947,(#195),$);
#14949= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14947));
#14950= IFCREPRESENTATIONMAP(#10,#14949);
#14951= IFCMAPPEDITEM(#14950,#247);
#14952= IFCMAPPEDITEM(#14950,#9057);
#14953= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14951,#14952));
#14954= IFCPRODUCTDEFINITIONSHAPE($,$,(#14953));
#14955= IFCMECHANICALFASTENER('1Td1iR001eDJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#14945,#14954,'ID5d9c1b1b-0000-6835-3135-373035313136',30.,20.);
#14956= IFCCARTESIANPOINT((40029.9926804692,-581.666078953131,-7665.004));
#14957= IFCAXIS2PLACEMENT3D(#14956,#501,#185);
#14958= IFCLOCALPLACEMENT(#30,#14957);
#14959= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#14960= IFCEXTRUDEDAREASOLID(#14959,#2479,#9,15.1);
#14961= IFCSTYLEDITEM(#14960,(#195),$);
#14962= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14960));
#14963= IFCREPRESENTATIONMAP(#10,#14962);
#14964= IFCMAPPEDITEM(#14963,#247);
#14965= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14964));
#14966= IFCPRODUCTDEFINITIONSHAPE($,$,(#14965));
#14967= IFCMECHANICALFASTENER('1Td1iR001eE34rDp0rCJ4s',#5,'Bolt assembly',$,$,#14958,#14966,'ID5d9c1b1b-0000-6838-3135-373035313136',20.,15.);
#14968= IFCCARTESIANPOINT((39320.,-459.171078953306,20104.9956931453));
#14969= IFCAXIS2PLACEMENT3D(#14968,#501,#596);
#14970= IFCLOCALPLACEMENT(#30,#14969);
#14971= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#14972= IFCEXTRUDEDAREASOLID(#14971,#14013,#9,16.1);
#14973= IFCSTYLEDITEM(#14972,(#195),$);
#14974= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#12699);
#14975= IFCEXTRUDEDAREASOLID(#14974,#12702,#9,10.);
#14976= IFCSTYLEDITEM(#14975,(#195),$);
#14977= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3875);
#14978= IFCEXTRUDEDAREASOLID(#14977,#12707,#9,7.92);
#14979= IFCSTYLEDITEM(#14978,(#558),$);
#14980= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#14981= IFCEXTRUDEDAREASOLID(#14980,#12712,#9,50.);
#14982= IFCSTYLEDITEM(#14981,(#558),$);
#14983= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#14984= IFCEXTRUDEDAREASOLID(#14983,#14027,#9,8.);
#14985= IFCSTYLEDITEM(#14984,(#558),$);
#14986= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#14987= IFCEXTRUDEDAREASOLID(#14986,#14032,#9,10.);
#14988= IFCSTYLEDITEM(#14987,(#558),$);
#14989= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#14972,#14975,#14978,#14981,#14984,#14987));
#14990= IFCREPRESENTATIONMAP(#10,#14989);
#14991= IFCMAPPEDITEM(#14990,#247);
#14992= IFCMAPPEDITEM(#14990,#12729);
#14993= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#14991,#14992));
#14994= IFCPRODUCTDEFINITIONSHAPE($,$,(#14993));
#14995= IFCMECHANICALFASTENER('1Td1iR001eHp4rDp0rCJ4s',#5,'Bolt assembly',$,$,#14970,#14994,'ID5d9c1b1b-0000-6847-3135-373035313136',12.,50.);
#14996= IFCCARTESIANPOINT((40249.9926804692,-581.666078953131,-7665.004));
#14997= IFCAXIS2PLACEMENT3D(#14996,#8,#7);
#14998= IFCLOCALPLACEMENT(#30,#14997);
#14999= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,11.);
#15000= IFCEXTRUDEDAREASOLID(#14999,#2479,#9,15.1);
#15001= IFCSTYLEDITEM(#15000,(#195),$);
#15002= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15000));
#15003= IFCREPRESENTATIONMAP(#10,#15002);
#15004= IFCMAPPEDITEM(#15003,#247);
#15005= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#15004));
#15006= IFCPRODUCTDEFINITIONSHAPE($,$,(#15005));
#15007= IFCMECHANICALFASTENER('1Td1iR001eIZ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#14998,#15006,'ID5d9c1b1b-0000-684a-3135-373035313136',20.,15.);
#15008= IFCCARTESIANPOINT((40029.9926804692,-581.663078953131,-7680.004));
#15009= IFCAXIS2PLACEMENT3D(#15008,#8,#7);
#15010= IFCLOCALPLACEMENT(#30,#15009);
#15011= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,29.);
#15012= IFCEXTRUDEDAREASOLID(#15011,#9050,#9,20.100000000003);
#15013= IFCSTYLEDITEM(#15012,(#195),$);
#15014= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15012));
#15015= IFCREPRESENTATIONMAP(#10,#15014);
#15016= IFCMAPPEDITEM(#15015,#247);
#15017= IFCMAPPEDITEM(#15015,#9057);
#15018= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#15016,#15017));
#15019= IFCPRODUCTDEFINITIONSHAPE($,$,(#15018));
#15020= IFCMECHANICALFASTENER('1Td1iR001eJJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#15010,#15019,'ID5d9c1b1b-0000-684d-3135-373035313136',30.,20.);
#15021= IFCCARTESIANPOINT((40130.,-459.171078953306,20104.9956931453));
#15022= IFCAXIS2PLACEMENT3D(#15021,#501,#596);
#15023= IFCLOCALPLACEMENT(#30,#15022);
#15024= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.5);
#15025= IFCEXTRUDEDAREASOLID(#15024,#14013,#9,16.1);
#15026= IFCSTYLEDITEM(#15025,(#195),$);
#15027= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#12699);
#15028= IFCEXTRUDEDAREASOLID(#15027,#12702,#9,10.);
#15029= IFCSTYLEDITEM(#15028,(#195),$);
#15030= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3875);
#15031= IFCEXTRUDEDAREASOLID(#15030,#12707,#9,7.92);
#15032= IFCSTYLEDITEM(#15031,(#558),$);
#15033= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,6.);
#15034= IFCEXTRUDEDAREASOLID(#15033,#12712,#9,50.);
#15035= IFCSTYLEDITEM(#15034,(#558),$);
#15036= IFCCIRCLEPROFILEDEF(.AREA.,$,#197,12.);
#15037= IFCEXTRUDEDAREASOLID(#15036,#14027,#9,8.);
#15038= IFCSTYLEDITEM(#15037,(#558),$);
#15039= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,$,#3897);
#15040= IFCEXTRUDEDAREASOLID(#15039,#14032,#9,10.);
#15041= IFCSTYLEDITEM(#15040,(#558),$);
#15042= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15025,#15028,#15031,#15034,#15037,#15040));
#15043= IFCREPRESENTATIONMAP(#10,#15042);
#15044= IFCMAPPEDITEM(#15043,#247);
#15045= IFCMAPPEDITEM(#15043,#12729);
#15046= IFCSHAPEREPRESENTATION(#12,'Body','MappedRepresentation',(#15044,#15045));
#15047= IFCPRODUCTDEFINITIONSHAPE($,$,(#15046));
#15048= IFCMECHANICALFASTENER('1Td1iR001eMJ4rDp0rCJ4s',#5,'Bolt assembly',$,$,#15023,#15047,'ID5d9c1b1b-0000-6859-3135-373035313136',12.,50.);
#15049= IFCLOCALPLACEMENT(#30,#10);
#15050= IFCELEMENTASSEMBLY('1Td1iR001vLZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#15049,$,'B/194(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15051= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(40.8314418763888),$);
#15052= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('B/194(?)'),$);
#15053= IFCPROPERTYSET('3U2zfjzcfDTgRSqagEyNjx',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#15051,#8857,#8858,#890,#488,#15052));
#15054= IFCCARTESIANPOINT((46456.9918857521,-495.170126613528,-7145.));
#15055= IFCAXIS2PLACEMENT3D(#15054,#9,#501);
#15056= IFCLOCALPLACEMENT(#15049,#15055);
#15057= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8868));
#15058= IFCPRODUCTDEFINITIONSHAPE($,$,(#15057));
#15059= IFCDISCRETEACCESSORY('1Td1iR001jMZ4rDp0rCJ4s',#5,'DIKME','PLT6*78','PLT6*78',#15056,#15058,'P/474(?)');
#15060= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('B/194(?)'),$);
#15061= IFCPROPERTYSET('1gkKkNWRz8ogdfhRrALPOf',#5,'Tekla Common','Common Properties to Shared building elements',(#8873,#8874,#8875,#15060,#74,#75,#919,#4046,#78,#4047,#4048));
#15062= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(40.8314418763888),$);
#15063= IFCPROPERTYSET('3aXXi5OsfDwhS0D3O8YLIg',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#15062,#8879,#8880,#8881,#4054,#4055,#4056,#4057,#8882,#8883,#8884,#4061,#3965,#8885));
#15064= IFCCARTESIANPOINT((46570.0024756012,-572.169963574882,-7152.));
#15065= IFCAXIS2PLACEMENT3D(#15064,#501,#185);
#15066= IFCLOCALPLACEMENT(#15049,#15065);
#15067= IFCEXTRUDEDAREASOLID(#8895,#8897,#9,110.010591308601);
#15068= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15067));
#15069= IFCSTYLEDITEM(#15067,(#4077),$);
#15070= IFCPRODUCTDEFINITIONSHAPE($,$,(#15068));
#15071= IFCDISCRETEACCESSORY('1Td1iR001jNJ4rDp0rCJ4s',#5,'DIKME','PLT6*154','PLT6*154',#15066,#15070,'P/471(?)');
#15072= IFCPROPERTYSET('3ZUm7_SZj7ohpTyY1MiAa5',#5,'Tekla Common','Common Properties to Shared building elements',(#8903,#8904,#8905,#15060,#74,#75,#919,#4089,#78,#8906,#4048));
#15073= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(46.4331737632084),$);
#15074= IFCPROPERTYSET('1q5d3Y4MrC9gfRx0RS7Ssl',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#15062,#8908,#8909,#8910,#8911,#8912,#8913,#8914,#15073,#8916,#8917,#8918,#3965,#8919));
#15075= IFCQUANTITYLENGTH('Length',$,$,110.010591308601);
#15076= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0370513892187523);
#15077= IFCQUANTITYVOLUME('NetVolume',$,$,0.000101649786369147);
#15078= IFCQUANTITYWEIGHT('NetWeight',$,$,0.797950822997805);
#15079= IFCELEMENTQUANTITY('2VJaoXzmP2xOLm1XzsGVaE',#5,'BaseQuantities',$,$,(#15075,#15076,#15077,#15078));
#15080= IFCLOCALPLACEMENT(#30,#10);
#15081= IFCELEMENTASSEMBLY('1Td1iR001wdZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#15080,$,'ANK/11(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15082= IFCCARTESIANPOINT((45129.9927978221,-579.169652492433,-7197.));
#15083= IFCAXIS2PLACEMENT3D(#15082,#11319,#9);
#15084= IFCLOCALPLACEMENT(#15080,#15083);
#15085= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#11327));
#15086= IFCPRODUCTDEFINITIONSHAPE($,$,(#15085));
#15087= IFCDISCRETEACCESSORY('1Td1iR001jO34rDp0rCJ4s',#5,'DETAY','PL6*60','PL6*60',#15084,#15086,'P/395(?)');
#15088= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.270233840595995),$);
#15089= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.270233840595995),$);
#15090= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(3.44246930695536E-005),$);
#15091= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(3.44246930695536E-005),$);
#15092= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(3.44246930695536E-005),$);
#15093= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0134548844171871),$);
#15094= IFCPROPERTYSET('1mGTeZTpH2gxjD6eIIYO7C',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#11337,#15088,#11339,#15089,#15090,#15091,#15092,#11344,#11345,#15093,#11347,#8966,#4007,#11348));
#15095= IFCQUANTITYAREA('NetArea',$,$,0.0134548844171871);
#15096= IFCQUANTITYVOLUME('NetVolume',$,$,3.44246930695536E-005);
#15097= IFCQUANTITYVOLUME('GrossVolume',$,$,3.44246930695536E-005);
#15098= IFCELEMENTQUANTITY('1gW2iozYHEbf6tiEQ2GxkK',#5,'BaseQuantities',$,$,(#8970,#15095,#11351,#3971,#15096,#15097));
#15099= IFCCARTESIANPOINT((45147.9921874705,-495.170126613528,-7145.));
#15100= IFCAXIS2PLACEMENT3D(#15099,#9,#501);
#15101= IFCLOCALPLACEMENT(#15049,#15100);
#15102= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8868));
#15103= IFCPRODUCTDEFINITIONSHAPE($,$,(#15102));
#15104= IFCDISCRETEACCESSORY('1Td1iR001jOp4rDp0rCJ4s',#5,'DIKME','PLT6*78','PLT6*78',#15101,#15103,'P/474(?)');
#15105= IFCCARTESIANPOINT((45049.9985947024,-572.169963574882,-7158.));
#15106= IFCAXIS2PLACEMENT3D(#15105,#501,#7);
#15107= IFCLOCALPLACEMENT(#15049,#15106);
#15108= IFCEXTRUDEDAREASOLID(#8895,#11379,#9,94.9935913085938);
#15109= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15108));
#15110= IFCSTYLEDITEM(#15108,(#4077),$);
#15111= IFCPRODUCTDEFINITIONSHAPE($,$,(#15109));
#15112= IFCDISCRETEACCESSORY('1Td1iR001jPZ4rDp0rCJ4s',#5,'DIKME','PLT6*154','PLT6*154',#15107,#15111,'P/469(?)');
#15113= IFCPROPERTYSET('3m6QoBMZbAAB1Y9mZWstd6',#5,'Tekla Common','Common Properties to Shared building elements',(#8997,#8998,#11385,#15060,#74,#75,#919,#4089,#78,#8906,#4048));
#15114= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(46.7992863953795),$);
#15115= IFCPROPERTYSET('15ki20viTBtR34g0zs0zYm',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#15062,#11387,#11388,#11389,#11390,#11391,#11392,#11393,#15114,#11395,#11396,#8918,#3965,#11397));
#15116= IFCQUANTITYLENGTH('Length',$,$,94.9935913085938);
#15117= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.03224594921875);
#15118= IFCQUANTITYVOLUME('NetVolume',$,$,8.77740783691406E-005);
#15119= IFCQUANTITYWEIGHT('NetWeight',$,$,0.689026515197754);
#15120= IFCELEMENTQUANTITY('14d6M6zb1BzRkW5y44hmj$',#5,'BaseQuantities',$,$,(#15116,#15117,#15118,#15119));
#15121= IFCCARTESIANPOINT((45012.4916804684,-584.17000007709,-7164.));
#15122= IFCAXIS2PLACEMENT3D(#15121,#501,#7);
#15123= IFCLOCALPLACEMENT(#15080,#15122);
#15124= IFCEXTRUDEDAREASOLID(#8988,#11408,#9,117.501117353691);
#15125= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15124));
#15126= IFCSTYLEDITEM(#15124,(#4032),$);
#15127= IFCPRODUCTDEFINITIONSHAPE($,$,(#15125));
#15128= IFCDISCRETEACCESSORY('1Td1iR001jQJ4rDp0rCJ4s',#5,'DIKME','PLT6*150','PLT6*150',#15123,#15127,'P/470(?)');
#15129= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(46.3296536817758),$);
#15130= IFCPROPERTYSET('0eVXQGpHL7yfifXIiE34Ov',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#11337,#11417,#11418,#11419,#11420,#11421,#11422,#11423,#15129,#11425,#11426,#529,#3965,#11427));
#15131= IFCQUANTITYLENGTH('Length',$,$,117.501117353691);
#15132= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0384603486143517);
#15133= IFCQUANTITYVOLUME('NetVolume',$,$,0.000105751005618322);
#15134= IFCQUANTITYWEIGHT('NetWeight',$,$,0.830145394103829);
#15135= IFCELEMENTQUANTITY('2juXSiCEf48QRQK890mVy_',#5,'BaseQuantities',$,$,(#15131,#15132,#15133,#15134));
#15136= IFCLOCALPLACEMENT(#30,#10);
#15137= IFCELEMENTASSEMBLY('1Td1iR001vOZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#15136,$,'B/193(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15138= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(19.6195016803516),$);
#15139= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('B/193(?)'),$);
#15140= IFCPROPERTYSET('0OJzrNLuXE3xeOhdTFPDVl',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#15138,#8857,#8858,#890,#488,#15139));
#15141= IFCCARTESIANPOINT((44836.9918857521,-495.170126613528,-7145.));
#15142= IFCAXIS2PLACEMENT3D(#15141,#9,#501);
#15143= IFCLOCALPLACEMENT(#15136,#15142);
#15144= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8868));
#15145= IFCPRODUCTDEFINITIONSHAPE($,$,(#15144));
#15146= IFCDISCRETEACCESSORY('1Td1iR001jR34rDp0rCJ4s',#5,'DIKME','PLT6*78','PLT6*78',#15143,#15145,'P/474(?)');
#15147= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('B/193(?)'),$);
#15148= IFCPROPERTYSET('1_DkTznl13EAM7rczNkNZN',#5,'Tekla Common','Common Properties to Shared building elements',(#8873,#8874,#8875,#15147,#74,#75,#919,#4046,#78,#4047,#4048));
#15149= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(19.6195016803516),$);
#15150= IFCPROPERTYSET('1qt_m6RmL5hgCGhnbhkMDl',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#15149,#8879,#8880,#8881,#4054,#4055,#4056,#4057,#8882,#8883,#8884,#4061,#3965,#8885));
#15151= IFCCARTESIANPOINT((44950.0024756012,-572.169963574882,-7152.));
#15152= IFCAXIS2PLACEMENT3D(#15151,#501,#185);
#15153= IFCLOCALPLACEMENT(#15136,#15152);
#15154= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15067));
#15155= IFCPRODUCTDEFINITIONSHAPE($,$,(#15154));
#15156= IFCDISCRETEACCESSORY('1Td1iR001jRp4rDp0rCJ4s',#5,'DIKME','PLT6*154','PLT6*154',#15153,#15155,'P/471(?)');
#15157= IFCPROPERTYSET('3nrvOUPcvDzBJ3DPySMwNL',#5,'Tekla Common','Common Properties to Shared building elements',(#8903,#8904,#8905,#15147,#74,#75,#919,#4089,#78,#8906,#4048));
#15158= IFCPROPERTYSET('0$C0UF4_XDShMvABdxxCDs',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#15149,#8908,#8909,#8910,#8911,#8912,#8913,#8914,#15073,#8916,#8917,#8918,#3965,#8919));
#15159= IFCLOCALPLACEMENT(#30,#10);
#15160= IFCELEMENTASSEMBLY('1Td1iR001woZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#15159,$,'ANK/11(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15161= IFCCARTESIANPOINT((44319.9927978221,-579.169652492433,-7197.));
#15162= IFCAXIS2PLACEMENT3D(#15161,#11319,#9);
#15163= IFCLOCALPLACEMENT(#15159,#15162);
#15164= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#11327));
#15165= IFCPRODUCTDEFINITIONSHAPE($,$,(#15164));
#15166= IFCDISCRETEACCESSORY('1Td1iR001jSZ4rDp0rCJ4s',#5,'DETAY','PL6*60','PL6*60',#15163,#15165,'P/395(?)');
#15167= IFCCARTESIANPOINT((44337.9921874705,-495.170126613528,-7145.));
#15168= IFCAXIS2PLACEMENT3D(#15167,#9,#501);
#15169= IFCLOCALPLACEMENT(#15136,#15168);
#15170= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8868));
#15171= IFCPRODUCTDEFINITIONSHAPE($,$,(#15170));
#15172= IFCDISCRETEACCESSORY('1Td1iR001jTJ4rDp0rCJ4s',#5,'DIKME','PLT6*78','PLT6*78',#15169,#15171,'P/474(?)');
#15173= IFCCARTESIANPOINT((44239.9985947024,-572.169963574882,-7158.));
#15174= IFCAXIS2PLACEMENT3D(#15173,#501,#7);
#15175= IFCLOCALPLACEMENT(#15136,#15174);
#15176= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15108));
#15177= IFCPRODUCTDEFINITIONSHAPE($,$,(#15176));
#15178= IFCDISCRETEACCESSORY('1Td1iR001jU34rDp0rCJ4s',#5,'DIKME','PLT6*154','PLT6*154',#15175,#15177,'P/469(?)');
#15179= IFCPROPERTYSET('2gacNEoDzFQwe1FpqqP4dU',#5,'Tekla Common','Common Properties to Shared building elements',(#8997,#8998,#11385,#15147,#74,#75,#919,#4089,#78,#8906,#4048));
#15180= IFCPROPERTYSET('09JC3okZ96QOVHa9usYg0u',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#15149,#11387,#11388,#11389,#11390,#11391,#11392,#11393,#15114,#11395,#11396,#8918,#3965,#11397));
#15181= IFCCARTESIANPOINT((44202.4916804684,-584.17000007709,-7164.));
#15182= IFCAXIS2PLACEMENT3D(#15181,#501,#7);
#15183= IFCLOCALPLACEMENT(#15159,#15182);
#15184= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15124));
#15185= IFCPRODUCTDEFINITIONSHAPE($,$,(#15184));
#15186= IFCDISCRETEACCESSORY('1Td1iR001jUp4rDp0rCJ4s',#5,'DIKME','PLT6*150','PLT6*150',#15183,#15185,'P/470(?)');
#15187= IFCLOCALPLACEMENT(#30,#10);
#15188= IFCELEMENTASSEMBLY('1Td1iR001vRZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#15187,$,'B/193(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15189= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(19.6195174846319),$);
#15190= IFCPROPERTYSET('1ItJ7bqe93L89LNfU$pvWS',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#15189,#8857,#8858,#890,#488,#15139));
#15191= IFCCARTESIANPOINT((44026.9918857521,-495.170126613528,-7145.));
#15192= IFCAXIS2PLACEMENT3D(#15191,#9,#501);
#15193= IFCLOCALPLACEMENT(#15187,#15192);
#15194= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8868));
#15195= IFCPRODUCTDEFINITIONSHAPE($,$,(#15194));
#15196= IFCDISCRETEACCESSORY('1Td1iR001jVZ4rDp0rCJ4s',#5,'DIKME','PLT6*78','PLT6*78',#15193,#15195,'P/474(?)');
#15197= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(19.6195174846319),$);
#15198= IFCPROPERTYSET('1oSicv_HP4I9I2r$lPqFNV',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#15197,#8879,#8880,#8881,#4054,#4055,#4056,#4057,#8882,#8883,#8884,#4061,#3965,#8885));
#15199= IFCCARTESIANPOINT((44140.0024756012,-572.169963574882,-7152.));
#15200= IFCAXIS2PLACEMENT3D(#15199,#501,#185);
#15201= IFCLOCALPLACEMENT(#15187,#15200);
#15202= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15067));
#15203= IFCPRODUCTDEFINITIONSHAPE($,$,(#15202));
#15204= IFCDISCRETEACCESSORY('1Td1iR001jWJ4rDp0rCJ4s',#5,'DIKME','PLT6*154','PLT6*154',#15201,#15203,'P/471(?)');
#15205= IFCPROPERTYSET('3jZASHA7LD8xH2I16VUV9$',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#15197,#8908,#8909,#8910,#8911,#8912,#8913,#8914,#15073,#8916,#8917,#8918,#3965,#8919));
#15206= IFCLOCALPLACEMENT(#30,#10);
#15207= IFCELEMENTASSEMBLY('1Td1iR001wzZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#15206,$,'ANK/9(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15208= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(385.35705553208),$);
#15209= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('ANK/9(?)'),$);
#15210= IFCPROPERTYSET('1DNPv$Ch5FBQQDTHYxm7In',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#15208,#9101,#9102,#39,#488,#15209));
#15211= IFCCARTESIANPOINT((43509.9927978221,-579.169652492433,-7197.));
#15212= IFCAXIS2PLACEMENT3D(#15211,#11319,#9);
#15213= IFCLOCALPLACEMENT(#15206,#15212);
#15214= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#11327));
#15215= IFCPRODUCTDEFINITIONSHAPE($,$,(#15214));
#15216= IFCDISCRETEACCESSORY('1Td1iR001jX34rDp0rCJ4s',#5,'DETAY','PL6*60','PL6*60',#15213,#15215,'P/395(?)');
#15217= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('ANK/9(?)'),$);
#15218= IFCPROPERTYSET('2VMWHJis9Cgw5ZLa89K4AR',#5,'Tekla Common','Common Properties to Shared building elements',(#11332,#11333,#11334,#15217,#74,#75,#919,#77,#78,#3994,#921));
#15219= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(385.35705553208),$);
#15220= IFCPROPERTYSET('1KZGPesdnCoA8QtrRAorA$',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#15219,#15088,#11339,#15089,#15090,#15091,#15092,#11344,#11345,#15093,#11347,#8966,#4007,#11348));
#15221= IFCCARTESIANPOINT((43527.9921874705,-495.170126613528,-7145.));
#15222= IFCAXIS2PLACEMENT3D(#15221,#9,#501);
#15223= IFCLOCALPLACEMENT(#15187,#15222);
#15224= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8868));
#15225= IFCPRODUCTDEFINITIONSHAPE($,$,(#15224));
#15226= IFCDISCRETEACCESSORY('1Td1iR001jXp4rDp0rCJ4s',#5,'DIKME','PLT6*78','PLT6*78',#15223,#15225,'P/474(?)');
#15227= IFCCARTESIANPOINT((43429.9985947024,-572.169963574882,-7158.));
#15228= IFCAXIS2PLACEMENT3D(#15227,#501,#7);
#15229= IFCLOCALPLACEMENT(#15187,#15228);
#15230= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15108));
#15231= IFCPRODUCTDEFINITIONSHAPE($,$,(#15230));
#15232= IFCDISCRETEACCESSORY('1Td1iR001jYZ4rDp0rCJ4s',#5,'DIKME','PLT6*154','PLT6*154',#15229,#15231,'P/469(?)');
#15233= IFCPROPERTYSET('2ZXB3auvfBSuXmfPKUKdgk',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#15197,#11387,#11388,#11389,#11390,#11391,#11392,#11393,#15114,#11395,#11396,#8918,#3965,#11397));
#15234= IFCCARTESIANPOINT((43392.4916804684,-584.17000007709,-7164.));
#15235= IFCAXIS2PLACEMENT3D(#15234,#501,#7);
#15236= IFCLOCALPLACEMENT(#15206,#15235);
#15237= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15124));
#15238= IFCPRODUCTDEFINITIONSHAPE($,$,(#15237));
#15239= IFCDISCRETEACCESSORY('1Td1iR001jZJ4rDp0rCJ4s',#5,'DIKME','PLT6*150','PLT6*150',#15236,#15238,'P/470(?)');
#15240= IFCPROPERTYSET('1Sjs8TLff0Yuabz95gAfnb',#5,'Tekla Common','Common Properties to Shared building elements',(#11414,#8951,#11415,#15217,#74,#75,#919,#4046,#78,#9001,#4048));
#15241= IFCPROPERTYSET('2xrEtgikn8$RMj5Qj8IuJN',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#15219,#11417,#11418,#11419,#11420,#11421,#11422,#11423,#15129,#11425,#11426,#529,#3965,#11427));
#15242= IFCLOCALPLACEMENT(#30,#10);
#15243= IFCELEMENTASSEMBLY('1Td1iR001vaZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#15242,$,'B/193(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15244= IFCPROPERTYSET('3Y282068j0_OYPhazceGJd',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#15189,#8857,#8858,#890,#5873,#15139));
#15245= IFCCARTESIANPOINT((40786.9918857521,-495.170126613528,-7145.));
#15246= IFCAXIS2PLACEMENT3D(#15245,#9,#501);
#15247= IFCLOCALPLACEMENT(#15242,#15246);
#15248= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8868));
#15249= IFCPRODUCTDEFINITIONSHAPE($,$,(#15248));
#15250= IFCDISCRETEACCESSORY('1Td1iR001jj34rDp0rCJ4s',#5,'DIKME','PLT6*78','PLT6*78',#15247,#15249,'P/474(?)');
#15251= IFCCARTESIANPOINT((40900.0024756012,-572.169963574882,-7152.));
#15252= IFCAXIS2PLACEMENT3D(#15251,#501,#185);
#15253= IFCLOCALPLACEMENT(#15242,#15252);
#15254= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15067));
#15255= IFCPRODUCTDEFINITIONSHAPE($,$,(#15254));
#15256= IFCDISCRETEACCESSORY('1Td1iR001jjp4rDp0rCJ4s',#5,'DIKME','PLT6*154','PLT6*154',#15253,#15255,'P/471(?)');
#15257= IFCLOCALPLACEMENT(#30,#10);
#15258= IFCELEMENTASSEMBLY('1Td1iR001yu34rDp0rCJ4s',#5,'Steel Assembly',$,$,#15257,$,'ANK/11(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15259= IFCPROPERTYSET('3YuN9p4CTAO9DDfoDK7J4D',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#11313,#9101,#9102,#39,#5197,#11314));
#15260= IFCCARTESIANPOINT((40269.9927978221,-579.169652492433,-7197.));
#15261= IFCAXIS2PLACEMENT3D(#15260,#11319,#9);
#15262= IFCLOCALPLACEMENT(#15257,#15261);
#15263= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#11327));
#15264= IFCPRODUCTDEFINITIONSHAPE($,$,(#15263));
#15265= IFCDISCRETEACCESSORY('1Td1iR001jkZ4rDp0rCJ4s',#5,'DETAY','PL6*60','PL6*60',#15262,#15264,'P/395(?)');
#15266= IFCCARTESIANPOINT((40287.9921874705,-495.170126613528,-7145.));
#15267= IFCAXIS2PLACEMENT3D(#15266,#9,#501);
#15268= IFCLOCALPLACEMENT(#15242,#15267);
#15269= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8868));
#15270= IFCPRODUCTDEFINITIONSHAPE($,$,(#15269));
#15271= IFCDISCRETEACCESSORY('1Td1iR001jlJ4rDp0rCJ4s',#5,'DIKME','PLT6*78','PLT6*78',#15268,#15270,'P/474(?)');
#15272= IFCCARTESIANPOINT((40189.9985947024,-572.169963574882,-7158.));
#15273= IFCAXIS2PLACEMENT3D(#15272,#501,#7);
#15274= IFCLOCALPLACEMENT(#15242,#15273);
#15275= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15108));
#15276= IFCPRODUCTDEFINITIONSHAPE($,$,(#15275));
#15277= IFCDISCRETEACCESSORY('1Td1iR001jm34rDp0rCJ4s',#5,'DIKME','PLT6*154','PLT6*154',#15274,#15276,'P/469(?)');
#15278= IFCCARTESIANPOINT((40152.4916804684,-584.17000007709,-7164.));
#15279= IFCAXIS2PLACEMENT3D(#15278,#501,#7);
#15280= IFCLOCALPLACEMENT(#15257,#15279);
#15281= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15124));
#15282= IFCPRODUCTDEFINITIONSHAPE($,$,(#15281));
#15283= IFCDISCRETEACCESSORY('1Td1iR001jmp4rDp0rCJ4s',#5,'DIKME','PLT6*150','PLT6*150',#15280,#15282,'P/470(?)');
#15284= IFCCARTESIANPOINT((43239.9962754006,-579.169652492433,-7191.));
#15285= IFCAXIS2PLACEMENT3D(#15284,#8936,#9);
#15286= IFCLOCALPLACEMENT(#15206,#15285);
#15287= IFCCARTESIANPOINT((30.,127.496864316818));
#15288= IFCCARTESIANPOINT((-30.,127.496864316818));
#15289= IFCCARTESIANPOINT((-30.,97.4968643172979));
#15290= IFCPOLYLINE((#54,#3980,#15287,#15288,#15289,#54,#54));
#15291= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL6*60',#15290);
#15292= IFCEXTRUDEDAREASOLID(#15291,#3942,#9,6.);
#15293= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15292));
#15294= IFCSTYLEDITEM(#15292,(#53),$);
#15295= IFCPRODUCTDEFINITIONSHAPE($,$,(#15293));
#15296= IFCDISCRETEACCESSORY('1Td1iR001jnZ4rDp0rCJ4s',#5,'DETAY','PL6*60','PL6*60',#15286,#15295,'P/396(?)');
#15297= IFCPROPERTYSET('0J5HXnf0bDMwfdwSzUTWGP',#5,'Tekla Common','Common Properties to Shared building elements',(#8950,#8951,#8952,#15217,#74,#75,#919,#77,#78,#3994,#921));
#15298= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.291424603923018),$);
#15299= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(0.3603061385642),$);
#15300= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.291424603923018),$);
#15301= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(49.6586320117445),$);
#15302= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0144717471653816),$);
#15303= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.00764981185911252),$);
#15304= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(127.496864318542),$);
#15305= IFCPROPERTYSET('14CJ4z$9z0awgvMu5LBo1h',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#15219,#15298,#15299,#15300,#10776,#10777,#10778,#10779,#15301,#15302,#15303,#8966,#4007,#15304));
#15306= IFCQUANTITYAREA('NetArea',$,$,0.0144717471653816);
#15307= IFCQUANTITYAREA('GrossArea',$,$,0.00764981185911252);
#15308= IFCQUANTITYVOLUME('NetVolume',$,$,3.71241533659896E-005);
#15309= IFCQUANTITYVOLUME('GrossVolume',$,$,3.71241533659896E-005);
#15310= IFCELEMENTQUANTITY('2u$pqGEdT4oOUc_Fbgrikc',#5,'BaseQuantities',$,$,(#8970,#15306,#15307,#3971,#15308,#15309));
#15311= IFCLOCALPLACEMENT(#30,#10);
#15312= IFCELEMENTASSEMBLY('1Td1iR001vbZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#15311,$,'B/192(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15313= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(62.0433978763889),$);
#15314= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('B/192(?)'),$);
#15315= IFCPROPERTYSET('2ywHUD0MH4XvUR7GHB80Ww',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#15313,#8857,#8858,#890,#488,#15314));
#15316= IFCCARTESIANPOINT((43216.9918857521,-495.170126613528,-7145.));
#15317= IFCAXIS2PLACEMENT3D(#15316,#9,#501);
#15318= IFCLOCALPLACEMENT(#15311,#15317);
#15319= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8868));
#15320= IFCPRODUCTDEFINITIONSHAPE($,$,(#15319));
#15321= IFCDISCRETEACCESSORY('1Td1iR001joJ4rDp0rCJ4s',#5,'DIKME','PLT6*78','PLT6*78',#15318,#15320,'P/474(?)');
#15322= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('B/192(?)'),$);
#15323= IFCPROPERTYSET('0lS$AHoL1AbfSDNAfYoxrh',#5,'Tekla Common','Common Properties to Shared building elements',(#8873,#8874,#8875,#15322,#74,#75,#919,#4046,#78,#4047,#4048));
#15324= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(62.0433978763889),$);
#15325= IFCPROPERTYSET('3N5niVIcvEhuCbEo3g6YM3',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#15324,#8879,#8880,#8881,#4054,#4055,#4056,#4057,#8882,#8883,#8884,#4061,#3965,#8885));
#15326= IFCCARTESIANPOINT((43330.0024756012,-572.169963574882,-7152.));
#15327= IFCAXIS2PLACEMENT3D(#15326,#501,#185);
#15328= IFCLOCALPLACEMENT(#15311,#15327);
#15329= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15067));
#15330= IFCPRODUCTDEFINITIONSHAPE($,$,(#15329));
#15331= IFCDISCRETEACCESSORY('1Td1iR001jp34rDp0rCJ4s',#5,'DIKME','PLT6*154','PLT6*154',#15328,#15330,'P/471(?)');
#15332= IFCPROPERTYSET('2g0SpIqrv4sAbXOhqOkNiJ',#5,'Tekla Common','Common Properties to Shared building elements',(#8903,#8904,#8905,#15322,#74,#75,#919,#4089,#78,#8906,#4048));
#15333= IFCPROPERTYSET('2en4FUZ1DEW9AdL5zAyUAt',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#15324,#8908,#8909,#8910,#8911,#8912,#8913,#8914,#15073,#8916,#8917,#8918,#3965,#8919));
#15334= IFCCARTESIANPOINT((43367.4953927543,-584.17000007709,-7158.));
#15335= IFCAXIS2PLACEMENT3D(#15334,#501,#185);
#15336= IFCLOCALPLACEMENT(#15206,#15335);
#15337= IFCCARTESIANPOINT((127.499117353691,0.,0.));
#15338= IFCAXIS2PLACEMENT3D(#15337,#185,#501);
#15339= IFCEXTRUDEDAREASOLID(#8988,#15338,#9,127.499117353691);
#15340= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15339));
#15341= IFCSTYLEDITEM(#15339,(#4032),$);
#15342= IFCPRODUCTDEFINITIONSHAPE($,$,(#15340));
#15343= IFCDISCRETEACCESSORY('1Td1iR001jpp4rDp0rCJ4s',#5,'DIKME','PLT6*150','PLT6*150',#15336,#15342,'P/465(?)');
#15344= IFCPROPERTYSET('0yRJc3B7r42wVj2nI5ikcZ',#5,'Tekla Common','Common Properties to Shared building elements',(#8997,#8998,#8999,#15217,#74,#75,#919,#4046,#78,#9001,#4048));
#15345= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.900781264103827),$);
#15346= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(0.900781264103827),$);
#15347= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.900781264103827),$);
#15348= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.0191248676030536),$);
#15349= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(46.1596241743756),$);
#15350= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0415797246143516),$);
#15351= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.0415797246143516),$);
#15352= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(127.499117353691),$);
#15353= IFCPROPERTYSET('1zPruVGNb0tRyd$FeEY2Bi',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#15219,#15345,#15346,#15347,#10806,#10807,#10808,#15348,#15349,#15350,#15351,#529,#3965,#15352));
#15354= IFCQUANTITYLENGTH('Length',$,$,127.499117353691);
#15355= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.0415797246143516);
#15356= IFCQUANTITYVOLUME('NetVolume',$,$,0.000114749205618322);
#15357= IFCQUANTITYWEIGHT('NetWeight',$,$,0.900781264103827);
#15358= IFCELEMENTQUANTITY('3JwjnlBG15eObJMrfSNc1X',#5,'BaseQuantities',$,$,(#15354,#15355,#15356,#15357));
#15359= IFCLOCALPLACEMENT(#30,#10);
#15360= IFCELEMENTASSEMBLY('1Td1iR001x8Z4rDp0rCJ4s',#5,'Steel Assembly',$,$,#15359,$,'ANK/11(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15361= IFCCARTESIANPOINT((41079.9927978221,-579.169652492433,-7197.));
#15362= IFCAXIS2PLACEMENT3D(#15361,#11319,#9);
#15363= IFCLOCALPLACEMENT(#15359,#15362);
#15364= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#11327));
#15365= IFCPRODUCTDEFINITIONSHAPE($,$,(#15364));
#15366= IFCDISCRETEACCESSORY('1Td1iR001jqZ4rDp0rCJ4s',#5,'DETAY','PL6*60','PL6*60',#15363,#15365,'P/395(?)');
#15367= IFCCARTESIANPOINT((41097.9921874705,-495.170126613528,-7145.));
#15368= IFCAXIS2PLACEMENT3D(#15367,#9,#501);
#15369= IFCLOCALPLACEMENT(#15311,#15368);
#15370= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8868));
#15371= IFCPRODUCTDEFINITIONSHAPE($,$,(#15370));
#15372= IFCDISCRETEACCESSORY('1Td1iR001jrJ4rDp0rCJ4s',#5,'DIKME','PLT6*78','PLT6*78',#15369,#15371,'P/474(?)');
#15373= IFCCARTESIANPOINT((40999.9985947024,-572.169963574882,-7158.));
#15374= IFCAXIS2PLACEMENT3D(#15373,#501,#7);
#15375= IFCLOCALPLACEMENT(#15311,#15374);
#15376= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15108));
#15377= IFCPRODUCTDEFINITIONSHAPE($,$,(#15376));
#15378= IFCDISCRETEACCESSORY('1Td1iR001js34rDp0rCJ4s',#5,'DIKME','PLT6*154','PLT6*154',#15375,#15377,'P/469(?)');
#15379= IFCPROPERTYSET('2Gx4Q30tTDh9YWaF7l__hK',#5,'Tekla Common','Common Properties to Shared building elements',(#8997,#8998,#11385,#15322,#74,#75,#919,#4089,#78,#8906,#4048));
#15380= IFCPROPERTYSET('3jek0zFmLDjwIV1GCCAx3C',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#15324,#11387,#11388,#11389,#11390,#11391,#11392,#11393,#15114,#11395,#11396,#8918,#3965,#11397));
#15381= IFCCARTESIANPOINT((40962.4916804684,-584.17000007709,-7164.));
#15382= IFCAXIS2PLACEMENT3D(#15381,#501,#7);
#15383= IFCLOCALPLACEMENT(#15359,#15382);
#15384= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15124));
#15385= IFCPRODUCTDEFINITIONSHAPE($,$,(#15384));
#15386= IFCDISCRETEACCESSORY('1Td1iR001jsp4rDp0rCJ4s',#5,'DIKME','PLT6*150','PLT6*150',#15383,#15385,'P/470(?)');
#15387= IFCLOCALPLACEMENT(#30,#10);
#15388= IFCELEMENTASSEMBLY('1Td1iR001vd34rDp0rCJ4s',#5,'Steel Assembly',$,$,#15387,$,'C/8(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15389= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(226.343188939397),$);
#15390= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('C/8(?)'),$);
#15391= IFCPROPERTYSET('2SvzAyvmb0FOKfwnpggqjn',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#15389,#5749,#5750,#3925,#488,#15390));
#15392= IFCCARTESIANPOINT((46684.9926804732,-689.170276561898,4897.99565708869));
#15393= IFCDIRECTION((0.,1.71500000032868E-006,-0.999999999998529));
#15394= IFCAXIS2PLACEMENT3D(#15392,#15393,#185);
#15395= IFCLOCALPLACEMENT(#15387,#15394);
#15396= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12806));
#15397= IFCPRODUCTDEFINITIONSHAPE($,$,(#15396));
#15398= IFCDISCRETEACCESSORY('1Td1iR001jtZ4rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#15395,#15397,'P/418(?)');
#15399= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('C/8(?)'),$);
#15400= IFCPROPERTYSET('3F7xkExtv2IPE$Xa17I7Tn',#5,'Tekla Common','Common Properties to Shared building elements',(#2254,#2255,#12811,#15399,#74,#75,#919,#1194,#78,#12813,#5773));
#15401= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(226.343188939397),$);
#15402= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.0260004533391614),$);
#15403= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(19.157242563886),$);
#15404= IFCPROPERTYSET('2UPltF46n50O9EK_ixRmGn',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#15401,#12816,#12817,#12818,#12819,#12820,#12821,#15402,#15403,#12824,#12825,#12826,#94,#12827));
#15405= IFCQUANTITYAREA('NetArea',$,$,0.0625609821184744);
#15406= IFCQUANTITYAREA('GrossArea',$,$,0.0260008729564133);
#15407= IFCQUANTITYVOLUME('NetVolume',$,$,0.000416007253426425);
#15408= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000416007253426425);
#15409= IFCELEMENTQUANTITY('2Jf7aWIFHCCuzr8h5VQRTf',#5,'BaseQuantities',$,$,(#12795,#15405,#15406,#100,#15407,#15408));
#15410= IFCLOCALPLACEMENT(#30,#10);
#15411= IFCELEMENTASSEMBLY('1Td1iR001vhp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#15410,$,'C/10(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15412= IFCPROPERTYSET('1Vz4qZO5f3bhJHiY2lDQE2',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#12836,#4464,#4465,#3925,#488,#12837));
#15413= IFCCARTESIANPOINT((46684.9926804732,-689.170276561898,10597.9956570887));
#15414= IFCAXIS2PLACEMENT3D(#15413,#15393,#185);
#15415= IFCLOCALPLACEMENT(#15410,#15414);
#15416= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12806));
#15417= IFCPRODUCTDEFINITIONSHAPE($,$,(#15416));
#15418= IFCDISCRETEACCESSORY('1Td1iR001juJ4rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#15415,#15417,'P/418(?)');
#15419= IFCPROPERTYSET('1VFldcjb94ERnvEfoJlf97',#5,'Tekla Common','Common Properties to Shared building elements',(#2109,#2110,#12811,#12845,#74,#75,#919,#1194,#78,#12813,#5773));
#15420= IFCPROPERTYSET('1salJhk9zBhwJHHxidRMWb',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#12847,#12816,#12817,#12818,#12819,#12820,#12821,#15402,#15403,#12824,#12825,#12826,#94,#12827));
#15421= IFCQUANTITYAREA('NetArea',$,$,0.0625609821184753);
#15422= IFCQUANTITYAREA('GrossArea',$,$,0.0260008729564114);
#15423= IFCQUANTITYVOLUME('NetVolume',$,$,0.000416007253426461);
#15424= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000416007253426461);
#15425= IFCELEMENTQUANTITY('1KJAD28GX76xbiQ$GsgIb2',#5,'BaseQuantities',$,$,(#12795,#15421,#15422,#100,#15423,#15424));
#15426= IFCLOCALPLACEMENT(#30,#10);
#15427= IFCELEMENTASSEMBLY('1Td1iR001vgJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#15426,$,'C/14(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15428= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(179.432043378101),$);
#15429= IFCPROPERTYSET('19m51dPynC9vY8FGmOh4cg',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#15428,#9780,#12862,#3925,#488,#12863));
#15430= IFCCARTESIANPOINT((46684.9926804732,-689.170275313896,15797.9956570887));
#15431= IFCAXIS2PLACEMENT3D(#15430,#15393,#185);
#15432= IFCLOCALPLACEMENT(#15426,#15431);
#15433= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12872));
#15434= IFCPRODUCTDEFINITIONSHAPE($,$,(#15433));
#15435= IFCDISCRETEACCESSORY('1Td1iR001jv34rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#15432,#15434,'P/417(?)');
#15436= IFCPROPERTYSET('0Aqk$VdNDBAwb1WffFours',#5,'Tekla Common','Common Properties to Shared building elements',(#1901,#1902,#12877,#12878,#74,#75,#919,#1194,#78,#12813,#5773));
#15437= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(179.432043378101),$);
#15438= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(19.0414350914803),$);
#15439= IFCPROPERTYSET('1IytyQFhvD6BClAWkj2Oof',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#15437,#12881,#12882,#12883,#12884,#12885,#12886,#12887,#15438,#12889,#12890,#12826,#1097,#12891));
#15440= IFCQUANTITYAREA('NetArea',$,$,0.0684010660417466);
#15441= IFCQUANTITYAREA('GrossArea',$,$,0.0286009568797562);
#15442= IFCQUANTITYVOLUME('NetVolume',$,$,0.000457607924813051);
#15443= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000457607924813051);
#15444= IFCELEMENTQUANTITY('0C6ee972bDKeotFf54sMLS',#5,'BaseQuantities',$,$,(#12795,#15440,#15441,#100,#15442,#15443));
#15445= IFCLOCALPLACEMENT(#30,#10);
#15446= IFCELEMENTASSEMBLY('1Td1iR001ve34rDp0rCJ4s',#5,'Steel Assembly',$,$,#15445,$,'ANK/16(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15447= IFCPROPERTYSET('2Ozw2SAO17MOKkxq$STqjP',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#12900,#12901,#136,#39,#1615,#12902));
#15448= IFCCARTESIANPOINT((46680.,-355.163143608002,20200.001693145));
#15449= IFCAXIS2PLACEMENT3D(#15448,#501,#185);
#15450= IFCLOCALPLACEMENT(#15445,#15449);
#15451= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12917));
#15452= IFCPRODUCTDEFINITIONSHAPE($,$,(#15451));
#15453= IFCDISCRETEACCESSORY('1Td1iR001jvp4rDp0rCJ4s',#5,'DETAY','PL8*70','PL8*70',#15450,#15452,'P/389(?)');
#15454= IFCPROPERTYSET('1K22BFbXzB$9JeMUFN$kTv',#5,'Tekla Common','Common Properties to Shared building elements',(#12922,#12072,#12923,#12924,#74,#75,#919,#77,#78,#12925,#921));
#15455= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(37.1353761908911),$);
#15456= IFCPROPERTYSET('2c3GfkeCD2JRxwEylj6ocY',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#12927,#12928,#12929,#12930,#12931,#12932,#12933,#12934,#15455,#12936,#12937,#10678,#12938,#12939));
#15457= IFCQUANTITYAREA('NetArea',$,$,0.0242247056274833);
#15458= IFCQUANTITYVOLUME('NetVolume',$,$,8.30999999999943E-005);
#15459= IFCQUANTITYVOLUME('GrossVolume',$,$,8.30999999999943E-005);
#15460= IFCELEMENTQUANTITY('1T72YLex91EOXVHJcyOoOX',#5,'BaseQuantities',$,$,(#12941,#15457,#12943,#12944,#15458,#15459));
#15461= IFCCARTESIANPOINT((46530.,-355.163143608002,20200.001693145));
#15462= IFCAXIS2PLACEMENT3D(#15461,#8,#7);
#15463= IFCLOCALPLACEMENT(#15445,#15462);
#15464= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12917));
#15465= IFCPRODUCTDEFINITIONSHAPE($,$,(#15464));
#15466= IFCDISCRETEACCESSORY('1Td1iR001jwZ4rDp0rCJ4s',#5,'DETAY','PL8*70','PL8*70',#15463,#15465,'P/389(?)');
#15467= IFCCARTESIANPOINT((46680.,-224.165279838405,20125.001693145));
#15468= IFCAXIS2PLACEMENT3D(#15467,#9,#185);
#15469= IFCLOCALPLACEMENT(#15445,#15468);
#15470= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12960));
#15471= IFCPRODUCTDEFINITIONSHAPE($,$,(#15470));
#15472= IFCDISCRETEACCESSORY('1Td1iR001jxJ4rDp0rCJ4s',#5,'ANKRAJ','PLT10*150','PLT10*150',#15469,#15471,'P/337(?)');
#15473= IFCPROPERTYSET('31BHeFLKz9293Rw6hMYNzW',#5,'Tekla Common','Common Properties to Shared building elements',(#12922,#12072,#12965,#12924,#74,#75,#919,#12966,#78,#12967,#80));
#15474= IFCLOCALPLACEMENT(#30,#10);
#15475= IFCELEMENTASSEMBLY('1Td1iR001vjJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#15474,$,'C/8(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15476= IFCCARTESIANPOINT((45064.9926804732,-689.170276561898,4897.99565708869));
#15477= IFCAXIS2PLACEMENT3D(#15476,#15393,#185);
#15478= IFCLOCALPLACEMENT(#15474,#15477);
#15479= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12806));
#15480= IFCPRODUCTDEFINITIONSHAPE($,$,(#15479));
#15481= IFCDISCRETEACCESSORY('1Td1iR001jy34rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#15478,#15480,'P/418(?)');
#15482= IFCLOCALPLACEMENT(#30,#10);
#15483= IFCELEMENTASSEMBLY('1Td1iR001vo34rDp0rCJ4s',#5,'Steel Assembly',$,$,#15482,$,'C/10(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15484= IFCCARTESIANPOINT((45064.9926804732,-689.170276561898,10597.9956570887));
#15485= IFCAXIS2PLACEMENT3D(#15484,#15393,#185);
#15486= IFCLOCALPLACEMENT(#15482,#15485);
#15487= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12806));
#15488= IFCPRODUCTDEFINITIONSHAPE($,$,(#15487));
#15489= IFCDISCRETEACCESSORY('1Td1iR001jyp4rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#15486,#15488,'P/418(?)');
#15490= IFCLOCALPLACEMENT(#30,#10);
#15491= IFCELEMENTASSEMBLY('1Td1iR001vmZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#15490,$,'C/14(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15492= IFCCARTESIANPOINT((45064.9926804732,-689.170275313896,15797.9956570887));
#15493= IFCAXIS2PLACEMENT3D(#15492,#15393,#185);
#15494= IFCLOCALPLACEMENT(#15490,#15493);
#15495= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12872));
#15496= IFCPRODUCTDEFINITIONSHAPE($,$,(#15495));
#15497= IFCDISCRETEACCESSORY('1Td1iR001jzZ4rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#15494,#15496,'P/417(?)');
#15498= IFCLOCALPLACEMENT(#30,#10);
#15499= IFCELEMENTASSEMBLY('1Td1iR001vkJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#15498,$,'ANK/16(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15500= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(6.75889284307986),$);
#15501= IFCPROPERTYSET('2SnDJc$ZzF98fEBSktQhtV',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#15500,#12901,#136,#39,#1615,#12902));
#15502= IFCCARTESIANPOINT((45060.,-224.165279838405,20125.001693145));
#15503= IFCAXIS2PLACEMENT3D(#15502,#9,#185);
#15504= IFCLOCALPLACEMENT(#15498,#15503);
#15505= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12960));
#15506= IFCPRODUCTDEFINITIONSHAPE($,$,(#15505));
#15507= IFCDISCRETEACCESSORY('1Td1iR001j_Z4rDp0rCJ4s',#5,'ANKRAJ','PLT10*150','PLT10*150',#15504,#15506,'P/337(?)');
#15508= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(6.75889284307986),$);
#15509= IFCPROPERTYSET('2n8QEUpDD7shpY_82guF0v',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#15508,#12969,#12970,#12971,#12972,#12973,#12974,#12975,#12976,#12977,#12978,#529,#8277,#12939));
#15510= IFCLOCALPLACEMENT(#30,#10);
#15511= IFCELEMENTASSEMBLY('1Td1iR001vpZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#15510,$,'C/8(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15512= IFCCARTESIANPOINT((44254.9926804732,-689.170276561898,4897.99565708869));
#15513= IFCAXIS2PLACEMENT3D(#15512,#15393,#185);
#15514= IFCLOCALPLACEMENT(#15510,#15513);
#15515= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12806));
#15516= IFCPRODUCTDEFINITIONSHAPE($,$,(#15515));
#15517= IFCDISCRETEACCESSORY('1Td1iR001j$34rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#15514,#15516,'P/418(?)');
#15518= IFCLOCALPLACEMENT(#30,#10);
#15519= IFCELEMENTASSEMBLY('1Td1iR001vuJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#15518,$,'C/10(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15520= IFCCARTESIANPOINT((44254.9926804732,-689.170276561898,10597.9956570887));
#15521= IFCAXIS2PLACEMENT3D(#15520,#15393,#185);
#15522= IFCLOCALPLACEMENT(#15518,#15521);
#15523= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12806));
#15524= IFCPRODUCTDEFINITIONSHAPE($,$,(#15523));
#15525= IFCDISCRETEACCESSORY('1Td1iR001j$p4rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#15522,#15524,'P/418(?)');
#15526= IFCLOCALPLACEMENT(#30,#10);
#15527= IFCELEMENTASSEMBLY('1Td1iR001vsp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#15526,$,'C/14(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15528= IFCCARTESIANPOINT((44254.9926804732,-689.170275313896,15797.9956570887));
#15529= IFCAXIS2PLACEMENT3D(#15528,#15393,#185);
#15530= IFCLOCALPLACEMENT(#15526,#15529);
#15531= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12872));
#15532= IFCPRODUCTDEFINITIONSHAPE($,$,(#15531));
#15533= IFCDISCRETEACCESSORY('1Td1iR001k0Z4rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#15530,#15532,'P/417(?)');
#15534= IFCLOCALPLACEMENT(#30,#10);
#15535= IFCELEMENTASSEMBLY('1Td1iR001vqZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#15534,$,'ANK/16(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15536= IFCCARTESIANPOINT((44250.,-224.165279838405,20125.001693145));
#15537= IFCAXIS2PLACEMENT3D(#15536,#9,#185);
#15538= IFCLOCALPLACEMENT(#15534,#15537);
#15539= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12960));
#15540= IFCPRODUCTDEFINITIONSHAPE($,$,(#15539));
#15541= IFCDISCRETEACCESSORY('1Td1iR001k1Z4rDp0rCJ4s',#5,'ANKRAJ','PLT10*150','PLT10*150',#15538,#15540,'P/337(?)');
#15542= IFCLOCALPLACEMENT(#30,#10);
#15543= IFCELEMENTASSEMBLY('1Td1iR001vvp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#15542,$,'C/8(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15544= IFCCARTESIANPOINT((43444.9926804732,-689.170276561898,4897.99565708869));
#15545= IFCAXIS2PLACEMENT3D(#15544,#15393,#185);
#15546= IFCLOCALPLACEMENT(#15542,#15545);
#15547= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12806));
#15548= IFCPRODUCTDEFINITIONSHAPE($,$,(#15547));
#15549= IFCDISCRETEACCESSORY('1Td1iR001k234rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#15546,#15548,'P/418(?)');
#15550= IFCLOCALPLACEMENT(#30,#10);
#15551= IFCELEMENTASSEMBLY('1Td1iR001v_Z4rDp0rCJ4s',#5,'Steel Assembly',$,$,#15550,$,'C/10(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15552= IFCCARTESIANPOINT((43444.9926804732,-689.170276561898,10597.9956570887));
#15553= IFCAXIS2PLACEMENT3D(#15552,#15393,#185);
#15554= IFCLOCALPLACEMENT(#15550,#15553);
#15555= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12806));
#15556= IFCPRODUCTDEFINITIONSHAPE($,$,(#15555));
#15557= IFCDISCRETEACCESSORY('1Td1iR001k2p4rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#15554,#15556,'P/418(?)');
#15558= IFCLOCALPLACEMENT(#30,#10);
#15559= IFCELEMENTASSEMBLY('1Td1iR001vz34rDp0rCJ4s',#5,'Steel Assembly',$,$,#15558,$,'C/13(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15560= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('C/13(?)'),$);
#15561= IFCPROPERTYSET('2XGoVQsv90Vv05m96MQ_aH',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#15428,#9780,#12862,#3925,#488,#15560));
#15562= IFCCARTESIANPOINT((43444.9926804732,-689.170275313896,15797.9956570887));
#15563= IFCAXIS2PLACEMENT3D(#15562,#15393,#185);
#15564= IFCLOCALPLACEMENT(#15558,#15563);
#15565= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12872));
#15566= IFCPRODUCTDEFINITIONSHAPE($,$,(#15565));
#15567= IFCDISCRETEACCESSORY('1Td1iR001k3Z4rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#15564,#15566,'P/417(?)');
#15568= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('C/13(?)'),$);
#15569= IFCPROPERTYSET('0GwtL2Fy58XweenFbS5QnI',#5,'Tekla Common','Common Properties to Shared building elements',(#1901,#1902,#12877,#15568,#74,#75,#919,#1194,#78,#12813,#5773));
#15570= IFCLOCALPLACEMENT(#30,#10);
#15571= IFCELEMENTASSEMBLY('1Td1iR001vwp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#15570,$,'ANK/5(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15572= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('ANK/5(?)'),$);
#15573= IFCPROPERTYSET('3ZSIdAVjPAOAn7$ks2C8hU',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#15500,#12901,#136,#39,#1615,#15572));
#15574= IFCCARTESIANPOINT((43440.,-224.165279838405,20125.001693145));
#15575= IFCAXIS2PLACEMENT3D(#15574,#9,#185);
#15576= IFCLOCALPLACEMENT(#15570,#15575);
#15577= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12960));
#15578= IFCPRODUCTDEFINITIONSHAPE($,$,(#15577));
#15579= IFCDISCRETEACCESSORY('1Td1iR001k4Z4rDp0rCJ4s',#5,'ANKRAJ','PLT10*150','PLT10*150',#15576,#15578,'P/337(?)');
#15580= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('ANK/5(?)'),$);
#15581= IFCPROPERTYSET('25HqipIj96sAq_gpD_K9Gr',#5,'Tekla Common','Common Properties to Shared building elements',(#12922,#12072,#12965,#15580,#74,#75,#919,#12966,#78,#12967,#80));
#15582= IFCLOCALPLACEMENT(#30,#10);
#15583= IFCELEMENTASSEMBLY('1Td1iR001w034rDp0rCJ4s',#5,'Steel Assembly',$,$,#15582,$,'C/9(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15584= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('C/9(?)'),$);
#15585= IFCPROPERTYSET('1mzEaln419jOw0isCXw_JZ',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#15389,#5749,#5750,#3925,#488,#15584));
#15586= IFCCARTESIANPOINT((41014.9926804732,-689.170276561898,4897.99565708869));
#15587= IFCAXIS2PLACEMENT3D(#15586,#15393,#185);
#15588= IFCLOCALPLACEMENT(#15582,#15587);
#15589= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12806));
#15590= IFCPRODUCTDEFINITIONSHAPE($,$,(#15589));
#15591= IFCDISCRETEACCESSORY('1Td1iR001k534rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#15588,#15590,'P/421(?)');
#15592= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/421(?)'),$);
#15593= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('C/9(?)'),$);
#15594= IFCPROPERTYSET('1yMkVUDvvAmRMpYZHZZEEg',#5,'Tekla Common','Common Properties to Shared building elements',(#2254,#2255,#15592,#15593,#74,#75,#919,#1194,#78,#12813,#5773));
#15595= IFCLOCALPLACEMENT(#30,#10);
#15596= IFCELEMENTASSEMBLY('1Td1iR001w4p4rDp0rCJ4s',#5,'Steel Assembly',$,$,#15595,$,'C/11(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15597= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('C/11(?)'),$);
#15598= IFCPROPERTYSET('0LpIa43HHAuB_yMFHXH_Sp',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#12836,#4464,#4465,#3925,#488,#15597));
#15599= IFCCARTESIANPOINT((41014.9926804732,-689.170276561898,10597.9956570887));
#15600= IFCAXIS2PLACEMENT3D(#15599,#15393,#185);
#15601= IFCLOCALPLACEMENT(#15595,#15600);
#15602= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12806));
#15603= IFCPRODUCTDEFINITIONSHAPE($,$,(#15602));
#15604= IFCDISCRETEACCESSORY('1Td1iR001k5p4rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#15601,#15603,'P/421(?)');
#15605= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('C/11(?)'),$);
#15606= IFCPROPERTYSET('0cvf$tD1PCU8MPFHdUYgt2',#5,'Tekla Common','Common Properties to Shared building elements',(#2109,#2110,#15592,#15605,#74,#75,#919,#1194,#78,#12813,#5773));
#15607= IFCLOCALPLACEMENT(#30,#10);
#15608= IFCELEMENTASSEMBLY('1Td1iR001w3J4rDp0rCJ4s',#5,'Steel Assembly',$,$,#15607,$,'C/15(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15609= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('C/15(?)'),$);
#15610= IFCPROPERTYSET('3VMnJI8lz92RxB$RRMKxwP',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#15428,#9780,#12862,#3925,#488,#15609));
#15611= IFCCARTESIANPOINT((41014.9926804732,-689.170275313896,15797.9956570887));
#15612= IFCAXIS2PLACEMENT3D(#15611,#15393,#185);
#15613= IFCLOCALPLACEMENT(#15607,#15612);
#15614= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12872));
#15615= IFCPRODUCTDEFINITIONSHAPE($,$,(#15614));
#15616= IFCDISCRETEACCESSORY('1Td1iR001k6Z4rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#15613,#15615,'P/420(?)');
#15617= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/420(?)'),$);
#15618= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('C/15(?)'),$);
#15619= IFCPROPERTYSET('0hkcJDbTLCYw4WJHR0ro_m',#5,'Tekla Common','Common Properties to Shared building elements',(#1901,#1902,#15617,#15618,#74,#75,#919,#1194,#78,#12813,#5773));
#15620= IFCLOCALPLACEMENT(#30,#10);
#15621= IFCELEMENTASSEMBLY('1Td1iR001w134rDp0rCJ4s',#5,'Steel Assembly',$,$,#15620,$,'ANK/16(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15622= IFCPROPERTYSET('0YY0E$uH1ASOo9uxgVepgX',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#12900,#12901,#136,#39,#5947,#12902));
#15623= IFCCARTESIANPOINT((41010.,-355.163143608002,20200.001693145));
#15624= IFCAXIS2PLACEMENT3D(#15623,#501,#185);
#15625= IFCLOCALPLACEMENT(#15620,#15624);
#15626= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12917));
#15627= IFCPRODUCTDEFINITIONSHAPE($,$,(#15626));
#15628= IFCDISCRETEACCESSORY('1Td1iR001k7J4rDp0rCJ4s',#5,'DETAY','PL8*70','PL8*70',#15625,#15627,'P/389(?)');
#15629= IFCCARTESIANPOINT((40860.,-355.163143608002,20200.001693145));
#15630= IFCAXIS2PLACEMENT3D(#15629,#8,#7);
#15631= IFCLOCALPLACEMENT(#15620,#15630);
#15632= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12917));
#15633= IFCPRODUCTDEFINITIONSHAPE($,$,(#15632));
#15634= IFCDISCRETEACCESSORY('1Td1iR001k834rDp0rCJ4s',#5,'DETAY','PL8*70','PL8*70',#15631,#15633,'P/389(?)');
#15635= IFCCARTESIANPOINT((41010.,-224.165279838405,20125.001693145));
#15636= IFCAXIS2PLACEMENT3D(#15635,#9,#185);
#15637= IFCLOCALPLACEMENT(#15620,#15636);
#15638= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12960));
#15639= IFCPRODUCTDEFINITIONSHAPE($,$,(#15638));
#15640= IFCDISCRETEACCESSORY('1Td1iR001k8p4rDp0rCJ4s',#5,'ANKRAJ','PLT10*150','PLT10*150',#15637,#15639,'P/337(?)');
#15641= IFCLOCALPLACEMENT(#30,#10);
#15642= IFCELEMENTASSEMBLY('1Td1iR001w6Z4rDp0rCJ4s',#5,'Steel Assembly',$,$,#15641,$,'C/4(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15643= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(271.619659059399),$);
#15644= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('C/4(?)'),$);
#15645= IFCPROPERTYSET('3aKkRyGvL06REoOyZh_dg3',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#15643,#3923,#3924,#3925,#488,#15644));
#15646= IFCCARTESIANPOINT((46684.9926804732,-689.170276561901,-1102.00434291132));
#15647= IFCAXIS2PLACEMENT3D(#15646,#15393,#185);
#15648= IFCLOCALPLACEMENT(#15641,#15647);
#15649= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12806));
#15650= IFCPRODUCTDEFINITIONSHAPE($,$,(#15649));
#15651= IFCDISCRETEACCESSORY('1Td1iR001k9Z4rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#15648,#15650,'P/418(?)');
#15652= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('C/4(?)'),$);
#15653= IFCPROPERTYSET('2B6x1jXvjAEO6qN_MpcOc4',#5,'Tekla Common','Common Properties to Shared building elements',(#2392,#2393,#12811,#15652,#74,#75,#919,#1194,#78,#12813,#5773));
#15654= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(271.619659059399),$);
#15655= IFCPROPERTYSET('3UTHkUli53B8ykp07ekR1o',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#15654,#12816,#12817,#12818,#12819,#12820,#12821,#15402,#12823,#12824,#12825,#12826,#94,#12827));
#15656= IFCQUANTITYAREA('NetArea',$,$,0.0625609821184794);
#15657= IFCQUANTITYAREA('GrossArea',$,$,0.0260008729564107);
#15658= IFCQUANTITYVOLUME('NetVolume',$,$,0.00041600725342662);
#15659= IFCQUANTITYVOLUME('GrossVolume',$,$,0.00041600725342662);
#15660= IFCELEMENTQUANTITY('2E$LjLxND4TwaGMA66b4Yk',#5,'BaseQuantities',$,$,(#12795,#15656,#15657,#100,#15658,#15659));
#15661= IFCLOCALPLACEMENT(#30,#10);
#15662= IFCELEMENTASSEMBLY('1Td1iR001w8J4rDp0rCJ4s',#5,'Steel Assembly',$,$,#15661,$,'C/4(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15663= IFCCARTESIANPOINT((45064.9926804732,-689.170276561901,-1102.00434291132));
#15664= IFCAXIS2PLACEMENT3D(#15663,#15393,#185);
#15665= IFCLOCALPLACEMENT(#15661,#15664);
#15666= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12806));
#15667= IFCPRODUCTDEFINITIONSHAPE($,$,(#15666));
#15668= IFCDISCRETEACCESSORY('1Td1iR001kAJ4rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#15665,#15667,'P/418(?)');
#15669= IFCLOCALPLACEMENT(#30,#10);
#15670= IFCELEMENTASSEMBLY('1Td1iR001wA34rDp0rCJ4s',#5,'Steel Assembly',$,$,#15669,$,'C/4(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15671= IFCCARTESIANPOINT((44254.9926804732,-689.170276561901,-1102.00434291132));
#15672= IFCAXIS2PLACEMENT3D(#15671,#15393,#185);
#15673= IFCLOCALPLACEMENT(#15669,#15672);
#15674= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12806));
#15675= IFCPRODUCTDEFINITIONSHAPE($,$,(#15674));
#15676= IFCDISCRETEACCESSORY('1Td1iR001kB34rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#15673,#15675,'P/418(?)');
#15677= IFCLOCALPLACEMENT(#30,#10);
#15678= IFCELEMENTASSEMBLY('1Td1iR001wBp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#15677,$,'C/4(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15679= IFCCARTESIANPOINT((43444.9926804732,-689.170276561901,-1102.00434291132));
#15680= IFCAXIS2PLACEMENT3D(#15679,#15393,#185);
#15681= IFCLOCALPLACEMENT(#15677,#15680);
#15682= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12806));
#15683= IFCPRODUCTDEFINITIONSHAPE($,$,(#15682));
#15684= IFCDISCRETEACCESSORY('1Td1iR001kBp4rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#15681,#15683,'P/418(?)');
#15685= IFCLOCALPLACEMENT(#30,#10);
#15686= IFCELEMENTASSEMBLY('1Td1iR001wDZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#15685,$,'C/5(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15687= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('C/5(?)'),$);
#15688= IFCPROPERTYSET('3lfjzYMFT5NfDI0EX5rI54',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#15643,#3923,#3924,#3925,#488,#15687));
#15689= IFCCARTESIANPOINT((41014.9926804732,-689.170276561901,-1102.00434291132));
#15690= IFCAXIS2PLACEMENT3D(#15689,#15393,#185);
#15691= IFCLOCALPLACEMENT(#15685,#15690);
#15692= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12806));
#15693= IFCPRODUCTDEFINITIONSHAPE($,$,(#15692));
#15694= IFCDISCRETEACCESSORY('1Td1iR001kCZ4rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#15691,#15693,'P/421(?)');
#15695= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('C/5(?)'),$);
#15696= IFCPROPERTYSET('2EEdHJuZj6agk7wdLEBZEH',#5,'Tekla Common','Common Properties to Shared building elements',(#2392,#2393,#15592,#15695,#74,#75,#919,#1194,#78,#12813,#5773));
#15697= IFCLOCALPLACEMENT(#30,#10);
#15698= IFCELEMENTASSEMBLY('1Td1iR0021n34rDp0rCJ4s',#5,'Steel Assembly',$,$,#15697,$,'ANK/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15699= IFCPROPERTYSET('3Qlr7XSQHCMfcAVngwGT6N',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#9064,#9065,#9066,#39,#488,#41));
#15700= IFCCARTESIANPOINT((46509.9926804692,-531.666078953131,-7672.504));
#15701= IFCAXIS2PLACEMENT3D(#15700,#7,#501);
#15702= IFCLOCALPLACEMENT(#15697,#15701);
#15703= IFCEXTRUDEDAREASOLID(#8180,#8182,#9,100.);
#15704= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15703));
#15705= IFCSTYLEDITEM(#15703,(#53),$);
#15706= IFCPRODUCTDEFINITIONSHAPE($,$,(#15704));
#15707= IFCBEAM('1Td1iR001kSp4rDp0rCJ4s',#5,'ANKRAJ','PLT15*100','PLT15*100',#15702,#15706,'P/484(?)');
#15708= IFCQUANTITYLENGTH('Length',$,$,100.);
#15709= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.026);
#15710= IFCQUANTITYVOLUME('NetVolume',$,$,0.00015);
#15711= IFCQUANTITYWEIGHT('NetWeight',$,$,1.1775);
#15712= IFCELEMENTQUANTITY('3Jlh5lmwL4B9Yblowbkshv',#5,'BaseQuantities',$,$,(#15708,#15709,#15710,#15711));
#15713= IFCCARTESIANPOINT((46414.9926804696,-484.171109536622,-7530.00338648548));
#15714= IFCAXIS2PLACEMENT3D(#15713,#9107,#7);
#15715= IFCLOCALPLACEMENT(#11311,#15714);
#15716= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9115));
#15717= IFCPRODUCTDEFINITIONSHAPE($,$,(#15716));
#15718= IFCDISCRETEACCESSORY('1Td1iR001kTJ4rDp0rCJ4s',#5,'DETAY','PL10*150','PL10*150',#15715,#15717,'P/222(?)');
#15719= IFCPROPERTYSET('3FiK9LeHP6cw0t2HCyxWEU',#5,'Tekla Common','Common Properties to Shared building elements',(#9078,#9120,#8562,#11335,#74,#75,#919,#77,#78,#8263,#921));
#15720= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.113029194278983),$);
#15721= IFCPROPERTYSET('3ctq4JipTDau4awIsYCzCT',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#11337,#9469,#9124,#9470,#9471,#9472,#9473,#9129,#9130,#15720,#9132,#8276,#8277,#9135));
#15722= IFCQUANTITYLENGTH('Width',$,$,150.001007080111);
#15723= IFCQUANTITYAREA('NetArea',$,$,0.113029194278983);
#15724= IFCQUANTITYAREA('GrossArea',$,$,0.0615003650668348);
#15725= IFCQUANTITYVOLUME('NetVolume',$,$,0.000515003770256145);
#15726= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000515003770256145);
#15727= IFCELEMENTQUANTITY('3vKDARUWz64PtbNydjZgKM',#5,'BaseQuantities',$,$,(#15722,#15723,#15724,#8283,#15725,#15726));
#15728= IFCCARTESIANPOINT((46414.9926804696,-679.167109536622,-7530.00338648548));
#15729= IFCAXIS2PLACEMENT3D(#15728,#9144,#9145);
#15730= IFCLOCALPLACEMENT(#11311,#15729);
#15731= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8255));
#15732= IFCPRODUCTDEFINITIONSHAPE($,$,(#15731));
#15733= IFCDISCRETEACCESSORY('1Td1iR001kU34rDp0rCJ4s',#5,'DETAY','PL10*150','PL10*150',#15730,#15732,'P/240(?)');
#15734= IFCPROPERTYSET('1BRVIyPMDDq8wunQpbusCw',#5,'Tekla Common','Common Properties to Shared building elements',(#9078,#9120,#8261,#11335,#74,#75,#919,#77,#78,#8263,#921));
#15735= IFCPROPERTYSET('2hAa4CJCb4_BBGoZ02Hg$o',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#11337,#9152,#9153,#9154,#9155,#9156,#9157,#9158,#8273,#9191,#9160,#8276,#8277,#9161));
#15736= IFCQUANTITYLENGTH('Width',$,$,150.001007080079);
#15737= IFCQUANTITYAREA('NetArea',$,$,0.0404157363386676);
#15738= IFCQUANTITYAREA('GrossArea',$,$,0.0225007028997292);
#15739= IFCQUANTITYVOLUME('NetVolume',$,$,0.000175007148586694);
#15740= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000175007148586694);
#15741= IFCELEMENTQUANTITY('27XpT_DHnBevQ_LcxzYM15',#5,'BaseQuantities',$,$,(#15736,#15737,#15738,#8283,#15739,#15740));
#15742= IFCLOCALPLACEMENT(#30,#10);
#15743= IFCELEMENTASSEMBLY('1Td1iR0021nJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#15742,$,'ANK/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15744= IFCCARTESIANPOINT((46729.9926804692,-531.666078953131,-7672.504));
#15745= IFCAXIS2PLACEMENT3D(#15744,#185,#501);
#15746= IFCLOCALPLACEMENT(#15742,#15745);
#15747= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15703));
#15748= IFCPRODUCTDEFINITIONSHAPE($,$,(#15747));
#15749= IFCBEAM('1Td1iR001kUp4rDp0rCJ4s',#5,'ANKRAJ','PLT15*100','PLT15*100',#15746,#15748,'P/484(?)');
#15750= IFCCARTESIANPOINT((46824.9926804687,-679.167109536622,-7530.00338648548));
#15751= IFCAXIS2PLACEMENT3D(#15750,#9178,#9179);
#15752= IFCLOCALPLACEMENT(#11311,#15751);
#15753= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8255));
#15754= IFCPRODUCTDEFINITIONSHAPE($,$,(#15753));
#15755= IFCDISCRETEACCESSORY('1Td1iR001kVZ4rDp0rCJ4s',#5,'DETAY','PL10*150','PL10*150',#15752,#15754,'P/240(?)');
#15756= IFCQUANTITYAREA('NetArea',$,$,0.0404157363386675);
#15757= IFCQUANTITYVOLUME('NetVolume',$,$,0.000175007148586692);
#15758= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000175007148586692);
#15759= IFCELEMENTQUANTITY('16QGrleOLAFuDvHu6WF7LE',#5,'BaseQuantities',$,$,(#15736,#15756,#15738,#8283,#15757,#15758));
#15760= IFCCARTESIANPOINT((46619.9926804684,-589.170000077091,-1155.));
#15761= IFCAXIS2PLACEMENT3D(#15760,#501,#596);
#15762= IFCLOCALPLACEMENT(#11311,#15761);
#15763= IFCCARTESIANPOINT((70.,0.));
#15764= IFCCARTESIANPOINT((70.,195.003921508789));
#15765= IFCCARTESIANPOINT((0.0029211244545877,195.003921508789));
#15766= IFCPOLYLINE((#54,#15763,#15764,#15765,#54,#54));
#15767= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL115*70',#15766);
#15768= IFCCARTESIANPOINT((6349.99608038934,-57.4999999992433,-201.122921123963));
#15769= IFCAXIS2PLACEMENT3D(#15768,#8,#9);
#15770= IFCEXTRUDEDAREASOLID(#15767,#15769,#9,115.);
#15771= IFCBOOLEANRESULT(.DIFFERENCE.,#9819,#15770);
#15772= IFCCARTESIANPOINT((160.,0.));
#15773= IFCCARTESIANPOINT((160.,195.003921508789));
#15774= IFCCARTESIANPOINT((90.0029220581055,195.003921508789));
#15775= IFCPOLYLINE((#54,#15772,#15773,#15774,#54,#54));
#15776= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL120*160',#15775);
#15777= IFCCARTESIANPOINT((6349.99608038934,-59.9999999992433,-291.122921123963));
#15778= IFCAXIS2PLACEMENT3D(#15777,#8,#9);
#15779= IFCEXTRUDEDAREASOLID(#15776,#15778,#9,120.);
#15780= IFCBOOLEANRESULT(.DIFFERENCE.,#15771,#15779);
#15781= IFCPLANE(#9821);
#15782= IFCHALFSPACESOLID(#15781,.F.);
#15783= IFCBOOLEANRESULT(.DIFFERENCE.,#15780,#15782);
#15784= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#15783));
#15785= IFCPRODUCTDEFINITIONSHAPE($,$,(#15784));
#15786= IFCDISCRETEACCESSORY('1Td1iR001kY34rDp0rCJ4s',#5,'DIKME','T200-25-25-110','T200-25-25-110',#15762,#15785,'P/386(?)');
#15787= IFCPROPERTYSET('175Rs2Y2r9VA493syXOqMI',#5,'Tekla Common','Common Properties to Shared building elements',(#9078,#9829,#9830,#11335,#74,#75,#919,#4183,#78,#9831,#4048));
#15788= IFCPROPERTYSET('3M0ynsJZb1XvZJ_PZiWb4p',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#11337,#9833,#9834,#9835,#9836,#9837,#9838,#9839,#9840,#9841,#9842,#9843,#9844,#9845));
#15789= IFCLOCALPLACEMENT(#30,#10);
#15790= IFCELEMENTASSEMBLY('1Td1iR0021nZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#15789,$,'ANK/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15791= IFCCARTESIANPOINT((44889.9926804692,-531.666078953131,-7672.504));
#15792= IFCAXIS2PLACEMENT3D(#15791,#7,#501);
#15793= IFCLOCALPLACEMENT(#15789,#15792);
#15794= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15703));
#15795= IFCPRODUCTDEFINITIONSHAPE($,$,(#15794));
#15796= IFCBEAM('1Td1iR001kYp4rDp0rCJ4s',#5,'ANKRAJ','PLT15*100','PLT15*100',#15793,#15795,'P/484(?)');
#15797= IFCCARTESIANPOINT((44794.9926804696,-484.171109536622,-7530.00338648548));
#15798= IFCAXIS2PLACEMENT3D(#15797,#9107,#7);
#15799= IFCLOCALPLACEMENT(#15080,#15798);
#15800= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9115));
#15801= IFCPRODUCTDEFINITIONSHAPE($,$,(#15800));
#15802= IFCDISCRETEACCESSORY('1Td1iR001kZZ4rDp0rCJ4s',#5,'DETAY','PL10*150','PL10*150',#15799,#15801,'P/222(?)');
#15803= IFCCARTESIANPOINT((44794.9926804696,-679.167109536622,-7530.00338648548));
#15804= IFCAXIS2PLACEMENT3D(#15803,#9144,#9145);
#15805= IFCLOCALPLACEMENT(#15080,#15804);
#15806= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8255));
#15807= IFCPRODUCTDEFINITIONSHAPE($,$,(#15806));
#15808= IFCDISCRETEACCESSORY('1Td1iR001kaJ4rDp0rCJ4s',#5,'DETAY','PL10*150','PL10*150',#15805,#15807,'P/240(?)');
#15809= IFCLOCALPLACEMENT(#30,#10);
#15810= IFCELEMENTASSEMBLY('1Td1iR0021np4rDp0rCJ4s',#5,'Steel Assembly',$,$,#15809,$,'ANK/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15811= IFCCARTESIANPOINT((45109.9926804692,-531.666078953131,-7672.504));
#15812= IFCAXIS2PLACEMENT3D(#15811,#185,#501);
#15813= IFCLOCALPLACEMENT(#15809,#15812);
#15814= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15703));
#15815= IFCPRODUCTDEFINITIONSHAPE($,$,(#15814));
#15816= IFCBEAM('1Td1iR001kb34rDp0rCJ4s',#5,'ANKRAJ','PLT15*100','PLT15*100',#15813,#15815,'P/484(?)');
#15817= IFCCARTESIANPOINT((45204.9926804687,-679.167109536622,-7530.00338648548));
#15818= IFCAXIS2PLACEMENT3D(#15817,#9178,#9179);
#15819= IFCLOCALPLACEMENT(#15080,#15818);
#15820= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8255));
#15821= IFCPRODUCTDEFINITIONSHAPE($,$,(#15820));
#15822= IFCDISCRETEACCESSORY('1Td1iR001kbp4rDp0rCJ4s',#5,'DETAY','PL10*150','PL10*150',#15819,#15821,'P/240(?)');
#15823= IFCCARTESIANPOINT((44999.9926804684,-589.170000077091,-1155.));
#15824= IFCAXIS2PLACEMENT3D(#15823,#501,#596);
#15825= IFCLOCALPLACEMENT(#15080,#15824);
#15826= IFCBOOLEANRESULT(.DIFFERENCE.,#9819,#15770);
#15827= IFCBOOLEANRESULT(.DIFFERENCE.,#15826,#15779);
#15828= IFCPLANE(#9821);
#15829= IFCHALFSPACESOLID(#15828,.F.);
#15830= IFCBOOLEANRESULT(.DIFFERENCE.,#15827,#15829);
#15831= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#15830));
#15832= IFCPRODUCTDEFINITIONSHAPE($,$,(#15831));
#15833= IFCDISCRETEACCESSORY('1Td1iR001keJ4rDp0rCJ4s',#5,'DIKME','T200-25-25-110','T200-25-25-110',#15825,#15832,'P/386(?)');
#15834= IFCLOCALPLACEMENT(#30,#10);
#15835= IFCELEMENTASSEMBLY('1Td1iR0021o34rDp0rCJ4s',#5,'Steel Assembly',$,$,#15834,$,'ANK/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15836= IFCCARTESIANPOINT((44079.9926804692,-531.666078953131,-7672.504));
#15837= IFCAXIS2PLACEMENT3D(#15836,#7,#501);
#15838= IFCLOCALPLACEMENT(#15834,#15837);
#15839= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15703));
#15840= IFCPRODUCTDEFINITIONSHAPE($,$,(#15839));
#15841= IFCBEAM('1Td1iR001kf34rDp0rCJ4s',#5,'ANKRAJ','PLT15*100','PLT15*100',#15838,#15840,'P/484(?)');
#15842= IFCCARTESIANPOINT((43984.9926804696,-484.171109536622,-7530.00338648548));
#15843= IFCAXIS2PLACEMENT3D(#15842,#9107,#7);
#15844= IFCLOCALPLACEMENT(#15159,#15843);
#15845= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9115));
#15846= IFCPRODUCTDEFINITIONSHAPE($,$,(#15845));
#15847= IFCDISCRETEACCESSORY('1Td1iR001kfp4rDp0rCJ4s',#5,'DETAY','PL10*150','PL10*150',#15844,#15846,'P/222(?)');
#15848= IFCCARTESIANPOINT((43984.9926804696,-679.167109536622,-7530.00338648548));
#15849= IFCAXIS2PLACEMENT3D(#15848,#9144,#9145);
#15850= IFCLOCALPLACEMENT(#15159,#15849);
#15851= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8255));
#15852= IFCPRODUCTDEFINITIONSHAPE($,$,(#15851));
#15853= IFCDISCRETEACCESSORY('1Td1iR001kgZ4rDp0rCJ4s',#5,'DETAY','PL10*150','PL10*150',#15850,#15852,'P/240(?)');
#15854= IFCLOCALPLACEMENT(#30,#10);
#15855= IFCELEMENTASSEMBLY('1Td1iR0021oJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#15854,$,'ANK/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15856= IFCCARTESIANPOINT((44299.9926804692,-531.666078953131,-7672.504));
#15857= IFCAXIS2PLACEMENT3D(#15856,#185,#501);
#15858= IFCLOCALPLACEMENT(#15854,#15857);
#15859= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15703));
#15860= IFCPRODUCTDEFINITIONSHAPE($,$,(#15859));
#15861= IFCBEAM('1Td1iR001khJ4rDp0rCJ4s',#5,'ANKRAJ','PLT15*100','PLT15*100',#15858,#15860,'P/484(?)');
#15862= IFCCARTESIANPOINT((44394.9926804687,-679.167109536622,-7530.00338648548));
#15863= IFCAXIS2PLACEMENT3D(#15862,#9178,#9179);
#15864= IFCLOCALPLACEMENT(#15159,#15863);
#15865= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8255));
#15866= IFCPRODUCTDEFINITIONSHAPE($,$,(#15865));
#15867= IFCDISCRETEACCESSORY('1Td1iR001ki34rDp0rCJ4s',#5,'DETAY','PL10*150','PL10*150',#15864,#15866,'P/240(?)');
#15868= IFCCARTESIANPOINT((44189.9926804684,-589.170000077091,-1155.));
#15869= IFCAXIS2PLACEMENT3D(#15868,#501,#596);
#15870= IFCLOCALPLACEMENT(#15159,#15869);
#15871= IFCBOOLEANRESULT(.DIFFERENCE.,#9819,#15770);
#15872= IFCBOOLEANRESULT(.DIFFERENCE.,#15871,#15779);
#15873= IFCPLANE(#9821);
#15874= IFCHALFSPACESOLID(#15873,.F.);
#15875= IFCBOOLEANRESULT(.DIFFERENCE.,#15872,#15874);
#15876= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#15875));
#15877= IFCPRODUCTDEFINITIONSHAPE($,$,(#15876));
#15878= IFCDISCRETEACCESSORY('1Td1iR001kkZ4rDp0rCJ4s',#5,'DIKME','T200-25-25-110','T200-25-25-110',#15870,#15877,'P/386(?)');
#15879= IFCLOCALPLACEMENT(#30,#10);
#15880= IFCELEMENTASSEMBLY('1Td1iR0021oZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#15879,$,'ANK/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15881= IFCCARTESIANPOINT((43269.9926804692,-531.666078953131,-7672.504));
#15882= IFCAXIS2PLACEMENT3D(#15881,#7,#501);
#15883= IFCLOCALPLACEMENT(#15879,#15882);
#15884= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15703));
#15885= IFCPRODUCTDEFINITIONSHAPE($,$,(#15884));
#15886= IFCBEAM('1Td1iR001klJ4rDp0rCJ4s',#5,'ANKRAJ','PLT15*100','PLT15*100',#15883,#15885,'P/484(?)');
#15887= IFCCARTESIANPOINT((43174.9926804696,-484.171109536622,-7530.00338648548));
#15888= IFCAXIS2PLACEMENT3D(#15887,#9107,#7);
#15889= IFCLOCALPLACEMENT(#15206,#15888);
#15890= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9115));
#15891= IFCPRODUCTDEFINITIONSHAPE($,$,(#15890));
#15892= IFCDISCRETEACCESSORY('1Td1iR001km34rDp0rCJ4s',#5,'DETAY','PL10*150','PL10*150',#15889,#15891,'P/222(?)');
#15893= IFCPROPERTYSET('1fnDh7j8PB_APpf1jtyY8R',#5,'Tekla Common','Common Properties to Shared building elements',(#9078,#9120,#8562,#15217,#74,#75,#919,#77,#78,#8263,#921));
#15894= IFCPROPERTYSET('3TBHILZOX2WhoYJ0Obp8mr',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#15219,#9469,#9124,#9470,#9471,#9472,#9473,#9129,#9130,#15720,#9132,#8276,#8277,#9135));
#15895= IFCCARTESIANPOINT((43174.9926804696,-679.167109536622,-7530.00338648548));
#15896= IFCAXIS2PLACEMENT3D(#15895,#9144,#9145);
#15897= IFCLOCALPLACEMENT(#15206,#15896);
#15898= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8255));
#15899= IFCPRODUCTDEFINITIONSHAPE($,$,(#15898));
#15900= IFCDISCRETEACCESSORY('1Td1iR001kmp4rDp0rCJ4s',#5,'DETAY','PL10*150','PL10*150',#15897,#15899,'P/240(?)');
#15901= IFCPROPERTYSET('0FmTLfiJX3JuRNcZ3wWzYR',#5,'Tekla Common','Common Properties to Shared building elements',(#9078,#9120,#8261,#15217,#74,#75,#919,#77,#78,#8263,#921));
#15902= IFCPROPERTYSET('2JMAdyBMfAAQKv0FOJH8Hu',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#15219,#9152,#9153,#9154,#9155,#9156,#9157,#9158,#8273,#9191,#9160,#8276,#8277,#9161));
#15903= IFCLOCALPLACEMENT(#30,#10);
#15904= IFCELEMENTASSEMBLY('1Td1iR0021op4rDp0rCJ4s',#5,'Steel Assembly',$,$,#15903,$,'ANK/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15905= IFCCARTESIANPOINT((43489.9926804692,-531.666078953131,-7672.504));
#15906= IFCAXIS2PLACEMENT3D(#15905,#185,#501);
#15907= IFCLOCALPLACEMENT(#15903,#15906);
#15908= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15703));
#15909= IFCPRODUCTDEFINITIONSHAPE($,$,(#15908));
#15910= IFCBEAM('1Td1iR001knZ4rDp0rCJ4s',#5,'ANKRAJ','PLT15*100','PLT15*100',#15907,#15909,'P/484(?)');
#15911= IFCCARTESIANPOINT((43584.9926804687,-679.167109536622,-7530.00338648548));
#15912= IFCAXIS2PLACEMENT3D(#15911,#9178,#9179);
#15913= IFCLOCALPLACEMENT(#15206,#15912);
#15914= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8255));
#15915= IFCPRODUCTDEFINITIONSHAPE($,$,(#15914));
#15916= IFCDISCRETEACCESSORY('1Td1iR001koJ4rDp0rCJ4s',#5,'DETAY','PL10*150','PL10*150',#15913,#15915,'P/240(?)');
#15917= IFCCARTESIANPOINT((43379.9926804684,-589.170000077091,-1155.));
#15918= IFCAXIS2PLACEMENT3D(#15917,#501,#596);
#15919= IFCLOCALPLACEMENT(#15206,#15918);
#15920= IFCBOOLEANRESULT(.DIFFERENCE.,#9819,#15770);
#15921= IFCBOOLEANRESULT(.DIFFERENCE.,#15920,#15779);
#15922= IFCPLANE(#9821);
#15923= IFCHALFSPACESOLID(#15922,.F.);
#15924= IFCBOOLEANRESULT(.DIFFERENCE.,#15921,#15923);
#15925= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#15924));
#15926= IFCPRODUCTDEFINITIONSHAPE($,$,(#15925));
#15927= IFCDISCRETEACCESSORY('1Td1iR001kqp4rDp0rCJ4s',#5,'DIKME','T200-25-25-110','T200-25-25-110',#15919,#15926,'P/386(?)');
#15928= IFCPROPERTYSET('2XjpHeVYPC8xeRPFZKBlR1',#5,'Tekla Common','Common Properties to Shared building elements',(#9078,#9829,#9830,#15217,#74,#75,#919,#4183,#78,#9831,#4048));
#15929= IFCPROPERTYSET('13DI7Y69L9Jhm_TTzlBcBq',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#15219,#9833,#9834,#9835,#9836,#9837,#9838,#9839,#9840,#9841,#9842,#9843,#9844,#9845));
#15930= IFCLOCALPLACEMENT(#30,#10);
#15931= IFCELEMENTASSEMBLY('1Td1iR0021p34rDp0rCJ4s',#5,'Steel Assembly',$,$,#15930,$,'ANK/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15932= IFCPROPERTYSET('0H0eTlmqP4QwNGMzpIOWML',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#9064,#9065,#9066,#39,#5873,#41));
#15933= IFCCARTESIANPOINT((40839.9926804692,-531.666078953131,-7672.504));
#15934= IFCAXIS2PLACEMENT3D(#15933,#7,#501);
#15935= IFCLOCALPLACEMENT(#15930,#15934);
#15936= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15703));
#15937= IFCPRODUCTDEFINITIONSHAPE($,$,(#15936));
#15938= IFCBEAM('1Td1iR001krZ4rDp0rCJ4s',#5,'ANKRAJ','PLT15*100','PLT15*100',#15935,#15937,'P/484(?)');
#15939= IFCCARTESIANPOINT((40744.9926804696,-484.171109536622,-7530.00338648548));
#15940= IFCAXIS2PLACEMENT3D(#15939,#9107,#7);
#15941= IFCLOCALPLACEMENT(#15359,#15940);
#15942= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9115));
#15943= IFCPRODUCTDEFINITIONSHAPE($,$,(#15942));
#15944= IFCDISCRETEACCESSORY('1Td1iR001ksJ4rDp0rCJ4s',#5,'DETAY','PL10*150','PL10*150',#15941,#15943,'P/222(?)');
#15945= IFCCARTESIANPOINT((40744.9926804696,-679.167109536622,-7530.00338648548));
#15946= IFCAXIS2PLACEMENT3D(#15945,#9144,#9145);
#15947= IFCLOCALPLACEMENT(#15359,#15946);
#15948= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8255));
#15949= IFCPRODUCTDEFINITIONSHAPE($,$,(#15948));
#15950= IFCDISCRETEACCESSORY('1Td1iR001kt34rDp0rCJ4s',#5,'DETAY','PL10*150','PL10*150',#15947,#15949,'P/240(?)');
#15951= IFCLOCALPLACEMENT(#30,#10);
#15952= IFCELEMENTASSEMBLY('1Td1iR0021pJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#15951,$,'ANK/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15953= IFCCARTESIANPOINT((41059.9926804692,-531.666078953131,-7672.504));
#15954= IFCAXIS2PLACEMENT3D(#15953,#185,#501);
#15955= IFCLOCALPLACEMENT(#15951,#15954);
#15956= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15703));
#15957= IFCPRODUCTDEFINITIONSHAPE($,$,(#15956));
#15958= IFCBEAM('1Td1iR001ktp4rDp0rCJ4s',#5,'ANKRAJ','PLT15*100','PLT15*100',#15955,#15957,'P/484(?)');
#15959= IFCCARTESIANPOINT((41154.9926804687,-679.167109536622,-7530.00338648548));
#15960= IFCAXIS2PLACEMENT3D(#15959,#9178,#9179);
#15961= IFCLOCALPLACEMENT(#15359,#15960);
#15962= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8255));
#15963= IFCPRODUCTDEFINITIONSHAPE($,$,(#15962));
#15964= IFCDISCRETEACCESSORY('1Td1iR001kuZ4rDp0rCJ4s',#5,'DETAY','PL10*150','PL10*150',#15961,#15963,'P/240(?)');
#15965= IFCCARTESIANPOINT((40949.9926804684,-589.170000077091,-1155.));
#15966= IFCAXIS2PLACEMENT3D(#15965,#501,#596);
#15967= IFCLOCALPLACEMENT(#15359,#15966);
#15968= IFCBOOLEANRESULT(.DIFFERENCE.,#9819,#15770);
#15969= IFCBOOLEANRESULT(.DIFFERENCE.,#15968,#15779);
#15970= IFCPLANE(#9821);
#15971= IFCHALFSPACESOLID(#15970,.F.);
#15972= IFCBOOLEANRESULT(.DIFFERENCE.,#15969,#15971);
#15973= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#15972));
#15974= IFCPRODUCTDEFINITIONSHAPE($,$,(#15973));
#15975= IFCDISCRETEACCESSORY('1Td1iR001kx34rDp0rCJ4s',#5,'DIKME','T200-25-25-110','T200-25-25-110',#15967,#15974,'P/386(?)');
#15976= IFCCARTESIANPOINT((32432.9988530373,-664.132537913409,4873.99999999957));
#15977= IFCAXIS2PLACEMENT3D(#15976,#5347,#5202);
#15978= IFCLOCALPLACEMENT(#7681,#15977);
#15979= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5213));
#15980= IFCPRODUCTDEFINITIONSHAPE($,$,(#15979));
#15981= IFCDISCRETEACCESSORY('1Td1iR001lDZ4rDp0rCJ4s',#5,'DETAY','PL16*58','PL16*58',#15978,#15980,'P/428(?)');
#15982= IFCCARTESIANPOINT((32849.492680471,-474.168995337077,4874.));
#15983= IFCAXIS2PLACEMENT3D(#15982,#185,#596);
#15984= IFCLOCALPLACEMENT(#7681,#15983);
#15985= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5537));
#15986= IFCPRODUCTDEFINITIONSHAPE($,$,(#15985));
#15987= IFCDISCRETEACCESSORY('1Td1iR001lHJ4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#15984,#15986,'P/430(?)');
#15988= IFCPROPERTYSET('2ZdjQcH7H63Pns89dS5hAH',#5,'Tekla Common','Common Properties to Shared building elements',(#1318,#1319,#4225,#5219,#74,#75,#919,#77,#78,#920,#967));
#15989= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(21.4777104799946),$);
#15990= IFCPROPERTYSET('3Mc5sMTWn9JB$iGBJXa6_B',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#7692,#5543,#5544,#5545,#927,#928,#929,#5546,#15989,#5548,#5549,#5489,#94,#5550));
#15991= IFCQUANTITYLENGTH('Width',$,$,57.9999998234771);
#15992= IFCQUANTITYAREA('NetArea',$,$,0.0285137936071166);
#15993= IFCQUANTITYAREA('GrossArea',$,$,0.0110200584940326);
#15994= IFCQUANTITYVOLUME('NetVolume',$,$,0.000169120931171614);
#15995= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000169120931171614);
#15996= IFCELEMENTQUANTITY('1mTBh5XU9EzQylafRQZDQz',#5,'BaseQuantities',$,$,(#15991,#15992,#15993,#100,#15994,#15995));
#15997= IFCLOCALPLACEMENT(#30,#10);
#15998= IFCELEMENTASSEMBLY('1Td1iR001xC34rDp0rCJ4s',#5,'Steel Assembly',$,$,#15997,$,'B/193(?)',.NOTDEFINED.,.RIGID_FRAME.);
#15999= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(19.6196916099791),$);
#16000= IFCPROPERTYSET('3FJpH3_uf1Z8MHzyzJVOZg',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#15999,#8857,#8858,#890,#5197,#15139));
#16001= IFCCARTESIANPOINT((39976.9918857521,-495.170126613528,-7145.));
#16002= IFCAXIS2PLACEMENT3D(#16001,#9,#501);
#16003= IFCLOCALPLACEMENT(#15997,#16002);
#16004= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8868));
#16005= IFCPRODUCTDEFINITIONSHAPE($,$,(#16004));
#16006= IFCDISCRETEACCESSORY('1Td1iR001lWJ4rDp0rCJ4s',#5,'DIKME','PLT6*78','PLT6*78',#16003,#16005,'P/474(?)');
#16007= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(19.6196916099791),$);
#16008= IFCPROPERTYSET('0IiS_flQH9MAhTz6wacoCY',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#16007,#8879,#8880,#8881,#4054,#4055,#4056,#4057,#8882,#8883,#8884,#4061,#3965,#8885));
#16009= IFCCARTESIANPOINT((40090.0024756012,-572.169963574882,-7152.));
#16010= IFCAXIS2PLACEMENT3D(#16009,#501,#185);
#16011= IFCLOCALPLACEMENT(#15997,#16010);
#16012= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15067));
#16013= IFCPRODUCTDEFINITIONSHAPE($,$,(#16012));
#16014= IFCDISCRETEACCESSORY('1Td1iR001lWp4rDp0rCJ4s',#5,'DIKME','PLT6*154','PLT6*154',#16011,#16013,'P/471(?)');
#16015= IFCPROPERTYSET('1Gd9J9B2D3L9Nv94kR_G91',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#16007,#8908,#8909,#8910,#8911,#8912,#8913,#8914,#15073,#8916,#8917,#8918,#3965,#8919));
#16016= IFCLOCALPLACEMENT(#30,#10);
#16017= IFCELEMENTASSEMBLY('1Td1iR001yCJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#16016,$,'ANK/9(?)',.NOTDEFINED.,.RIGID_FRAME.);
#16018= IFCPROPERTYSET('02ratbUiT53ePpxXAeoePM',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#15208,#9101,#9102,#39,#5197,#15209));
#16019= IFCCARTESIANPOINT((39459.9927978221,-579.169652492433,-7197.));
#16020= IFCAXIS2PLACEMENT3D(#16019,#11319,#9);
#16021= IFCLOCALPLACEMENT(#16016,#16020);
#16022= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#11327));
#16023= IFCPRODUCTDEFINITIONSHAPE($,$,(#16022));
#16024= IFCDISCRETEACCESSORY('1Td1iR001lXZ4rDp0rCJ4s',#5,'DETAY','PL6*60','PL6*60',#16021,#16023,'P/395(?)');
#16025= IFCCARTESIANPOINT((39477.9921874705,-495.170126613528,-7145.));
#16026= IFCAXIS2PLACEMENT3D(#16025,#9,#501);
#16027= IFCLOCALPLACEMENT(#15997,#16026);
#16028= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8868));
#16029= IFCPRODUCTDEFINITIONSHAPE($,$,(#16028));
#16030= IFCDISCRETEACCESSORY('1Td1iR001lYJ4rDp0rCJ4s',#5,'DIKME','PLT6*78','PLT6*78',#16027,#16029,'P/474(?)');
#16031= IFCCARTESIANPOINT((39379.9985947024,-572.169963574882,-7158.));
#16032= IFCAXIS2PLACEMENT3D(#16031,#501,#7);
#16033= IFCLOCALPLACEMENT(#15997,#16032);
#16034= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15108));
#16035= IFCPRODUCTDEFINITIONSHAPE($,$,(#16034));
#16036= IFCDISCRETEACCESSORY('1Td1iR001lZ34rDp0rCJ4s',#5,'DIKME','PLT6*154','PLT6*154',#16033,#16035,'P/469(?)');
#16037= IFCPROPERTYSET('2KJ1CDF1v8hgXWEuCrbwtG',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#16007,#11387,#11388,#11389,#11390,#11391,#11392,#11393,#15114,#11395,#11396,#8918,#3965,#11397));
#16038= IFCCARTESIANPOINT((39342.4916804684,-584.17000007709,-7164.));
#16039= IFCAXIS2PLACEMENT3D(#16038,#501,#7);
#16040= IFCLOCALPLACEMENT(#16016,#16039);
#16041= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15124));
#16042= IFCPRODUCTDEFINITIONSHAPE($,$,(#16041));
#16043= IFCDISCRETEACCESSORY('1Td1iR001lZp4rDp0rCJ4s',#5,'DIKME','PLT6*150','PLT6*150',#16040,#16042,'P/470(?)');
#16044= IFCCARTESIANPOINT((39189.9962754006,-579.169652492433,-7191.));
#16045= IFCAXIS2PLACEMENT3D(#16044,#8936,#9);
#16046= IFCLOCALPLACEMENT(#16016,#16045);
#16047= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15292));
#16048= IFCPRODUCTDEFINITIONSHAPE($,$,(#16047));
#16049= IFCDISCRETEACCESSORY('1Td1iR001laZ4rDp0rCJ4s',#5,'DETAY','PL6*60','PL6*60',#16046,#16048,'P/396(?)');
#16050= IFCLOCALPLACEMENT(#30,#10);
#16051= IFCELEMENTASSEMBLY('1Td1iR001xD34rDp0rCJ4s',#5,'Steel Assembly',$,$,#16050,$,'B/192(?)',.NOTDEFINED.,.RIGID_FRAME.);
#16052= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(62.0432237509633),$);
#16053= IFCPROPERTYSET('35CMP_09n3qPStBXfaMgg_',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#16052,#8857,#8858,#890,#5197,#15314));
#16054= IFCCARTESIANPOINT((39166.9918857521,-495.170126613528,-7145.));
#16055= IFCAXIS2PLACEMENT3D(#16054,#9,#501);
#16056= IFCLOCALPLACEMENT(#16050,#16055);
#16057= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8868));
#16058= IFCPRODUCTDEFINITIONSHAPE($,$,(#16057));
#16059= IFCDISCRETEACCESSORY('1Td1iR001lbJ4rDp0rCJ4s',#5,'DIKME','PLT6*78','PLT6*78',#16056,#16058,'P/474(?)');
#16060= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(62.0432237509633),$);
#16061= IFCPROPERTYSET('30r4z0ICL32Bxxlzgdq_Zb',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#16060,#8879,#8880,#8881,#4054,#4055,#4056,#4057,#8882,#8883,#8884,#4061,#3965,#8885));
#16062= IFCCARTESIANPOINT((39280.0024756012,-572.169963574882,-7152.));
#16063= IFCAXIS2PLACEMENT3D(#16062,#501,#185);
#16064= IFCLOCALPLACEMENT(#16050,#16063);
#16065= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15067));
#16066= IFCPRODUCTDEFINITIONSHAPE($,$,(#16065));
#16067= IFCDISCRETEACCESSORY('1Td1iR001lc34rDp0rCJ4s',#5,'DIKME','PLT6*154','PLT6*154',#16064,#16066,'P/471(?)');
#16068= IFCPROPERTYSET('20BB9wP0fDhRJ2Dc1$ZskK',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#16060,#8908,#8909,#8910,#8911,#8912,#8913,#8914,#15073,#8916,#8917,#8918,#3965,#8919));
#16069= IFCCARTESIANPOINT((39317.4953927543,-584.17000007709,-7158.));
#16070= IFCAXIS2PLACEMENT3D(#16069,#501,#185);
#16071= IFCLOCALPLACEMENT(#16016,#16070);
#16072= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15339));
#16073= IFCPRODUCTDEFINITIONSHAPE($,$,(#16072));
#16074= IFCDISCRETEACCESSORY('1Td1iR001lcp4rDp0rCJ4s',#5,'DIKME','PLT6*150','PLT6*150',#16071,#16073,'P/465(?)');
#16075= IFCCARTESIANPOINT((37047.9921874705,-495.170126613528,-7145.));
#16076= IFCAXIS2PLACEMENT3D(#16075,#9,#501);
#16077= IFCLOCALPLACEMENT(#16050,#16076);
#16078= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8868));
#16079= IFCPRODUCTDEFINITIONSHAPE($,$,(#16078));
#16080= IFCDISCRETEACCESSORY('1Td1iR001leJ4rDp0rCJ4s',#5,'DIKME','PLT6*78','PLT6*78',#16077,#16079,'P/474(?)');
#16081= IFCCARTESIANPOINT((36949.9985947024,-572.169963574882,-7158.));
#16082= IFCAXIS2PLACEMENT3D(#16081,#501,#7);
#16083= IFCLOCALPLACEMENT(#16050,#16082);
#16084= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15108));
#16085= IFCPRODUCTDEFINITIONSHAPE($,$,(#16084));
#16086= IFCDISCRETEACCESSORY('1Td1iR001lf34rDp0rCJ4s',#5,'DIKME','PLT6*154','PLT6*154',#16083,#16085,'P/469(?)');
#16087= IFCPROPERTYSET('0zmj49UM5EhBexGpdAAbs6',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#16060,#11387,#11388,#11389,#11390,#11391,#11392,#11393,#15114,#11395,#11396,#8918,#3965,#11397));
#16088= IFCCARTESIANPOINT((35279.4926804679,-474.169997439216,4874.));
#16089= IFCAXIS2PLACEMENT3D(#16088,#185,#596);
#16090= IFCLOCALPLACEMENT(#7681,#16089);
#16091= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5567));
#16092= IFCPRODUCTDEFINITIONSHAPE($,$,(#16091));
#16093= IFCDISCRETEACCESSORY('1Td1iR001m3p4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#16090,#16092,'P/430(?)');
#16094= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(1.38410457914305),$);
#16095= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(21.4777233103612),$);
#16096= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(189.998979837231),$);
#16097= IFCPROPERTYSET('1wBzajvTn7iwIB2eb1rAJ6',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#7692,#5572,#16094,#5574,#927,#928,#929,#930,#16095,#5576,#974,#5577,#94,#16096));
#16098= IFCQUANTITYLENGTH('Width',$,$,58.0000004536059);
#16099= IFCQUANTITYAREA('NetArea',$,$,0.0285134938151639);
#16100= IFCQUANTITYAREA('GrossArea',$,$,0.0110199409167441);
#16101= IFCQUANTITYVOLUME('NetVolume',$,$,0.000169119052018008);
#16102= IFCQUANTITYVOLUME('GrossVolume',$,$,0.000169119052018008);
#16103= IFCELEMENTQUANTITY('16BWv6W6j2jvJS63XYwPfk',#5,'BaseQuantities',$,$,(#16098,#16099,#16100,#100,#16101,#16102));
#16104= IFCCARTESIANPOINT((36089.4926804679,-474.169997439216,4874.));
#16105= IFCAXIS2PLACEMENT3D(#16104,#185,#596);
#16106= IFCLOCALPLACEMENT(#7681,#16105);
#16107= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5567));
#16108= IFCPRODUCTDEFINITIONSHAPE($,$,(#16107));
#16109= IFCDISCRETEACCESSORY('1Td1iR001m7Z4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#16106,#16108,'P/430(?)');
#16110= IFCCARTESIANPOINT((36899.4926804679,-474.169997439216,4874.));
#16111= IFCAXIS2PLACEMENT3D(#16110,#185,#596);
#16112= IFCLOCALPLACEMENT(#7681,#16111);
#16113= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5567));
#16114= IFCPRODUCTDEFINITIONSHAPE($,$,(#16113));
#16115= IFCDISCRETEACCESSORY('1Td1iR001mBJ4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#16112,#16114,'P/430(?)');
#16116= IFCCARTESIANPOINT((39329.4926804679,-474.169997439216,4874.));
#16117= IFCAXIS2PLACEMENT3D(#16116,#185,#596);
#16118= IFCLOCALPLACEMENT(#7681,#16117);
#16119= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5567));
#16120= IFCPRODUCTDEFINITIONSHAPE($,$,(#16119));
#16121= IFCDISCRETEACCESSORY('1Td1iR001mF34rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#16118,#16120,'P/430(?)');
#16122= IFCCARTESIANPOINT((40139.4909530955,-474.168995337077,4874.));
#16123= IFCAXIS2PLACEMENT3D(#16122,#185,#596);
#16124= IFCLOCALPLACEMENT(#7681,#16123);
#16125= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5537));
#16126= IFCPRODUCTDEFINITIONSHAPE($,$,(#16125));
#16127= IFCDISCRETEACCESSORY('1Td1iR001mIp4rDp0rCJ4s',#5,'PLATE','PL16*58','PL16*58',#16124,#16126,'P/430(?)');
#16128= IFCLOCALPLACEMENT(#30,#10);
#16129= IFCELEMENTASSEMBLY('1Td1iR0021rZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#16128,$,'ANK/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#16130= IFCPROPERTYSET('0qJo$hk7P6Wvi2mdaIhKBf',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#9064,#9065,#9066,#39,#5197,#41));
#16131= IFCCARTESIANPOINT((39219.9926804692,-531.666078953131,-7672.504));
#16132= IFCAXIS2PLACEMENT3D(#16131,#7,#501);
#16133= IFCLOCALPLACEMENT(#16128,#16132);
#16134= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15703));
#16135= IFCPRODUCTDEFINITIONSHAPE($,$,(#16134));
#16136= IFCBEAM('1Td1iR001n3p4rDp0rCJ4s',#5,'ANKRAJ','PLT15*100','PLT15*100',#16133,#16135,'P/484(?)');
#16137= IFCCARTESIANPOINT((39124.9926804696,-484.171109536622,-7530.00338648548));
#16138= IFCAXIS2PLACEMENT3D(#16137,#9107,#7);
#16139= IFCLOCALPLACEMENT(#16016,#16138);
#16140= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9115));
#16141= IFCPRODUCTDEFINITIONSHAPE($,$,(#16140));
#16142= IFCDISCRETEACCESSORY('1Td1iR001n4Z4rDp0rCJ4s',#5,'DETAY','PL10*150','PL10*150',#16139,#16141,'P/222(?)');
#16143= IFCCARTESIANPOINT((39124.9926804696,-679.167109536622,-7530.00338648548));
#16144= IFCAXIS2PLACEMENT3D(#16143,#9144,#9145);
#16145= IFCLOCALPLACEMENT(#16016,#16144);
#16146= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8255));
#16147= IFCPRODUCTDEFINITIONSHAPE($,$,(#16146));
#16148= IFCDISCRETEACCESSORY('1Td1iR001n5J4rDp0rCJ4s',#5,'DETAY','PL10*150','PL10*150',#16145,#16147,'P/240(?)');
#16149= IFCLOCALPLACEMENT(#30,#10);
#16150= IFCELEMENTASSEMBLY('1Td1iR0021rp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#16149,$,'ANK/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#16151= IFCCARTESIANPOINT((39439.9926804692,-531.666078953131,-7672.504));
#16152= IFCAXIS2PLACEMENT3D(#16151,#185,#501);
#16153= IFCLOCALPLACEMENT(#16149,#16152);
#16154= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15703));
#16155= IFCPRODUCTDEFINITIONSHAPE($,$,(#16154));
#16156= IFCBEAM('1Td1iR001n634rDp0rCJ4s',#5,'ANKRAJ','PLT15*100','PLT15*100',#16153,#16155,'P/484(?)');
#16157= IFCCARTESIANPOINT((39534.9926804687,-679.167109536622,-7530.00338648548));
#16158= IFCAXIS2PLACEMENT3D(#16157,#9178,#9179);
#16159= IFCLOCALPLACEMENT(#16016,#16158);
#16160= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8255));
#16161= IFCPRODUCTDEFINITIONSHAPE($,$,(#16160));
#16162= IFCDISCRETEACCESSORY('1Td1iR001n6p4rDp0rCJ4s',#5,'DETAY','PL10*150','PL10*150',#16159,#16161,'P/240(?)');
#16163= IFCCARTESIANPOINT((39329.9926804684,-589.170000077091,-1155.));
#16164= IFCAXIS2PLACEMENT3D(#16163,#501,#596);
#16165= IFCLOCALPLACEMENT(#16016,#16164);
#16166= IFCBOOLEANRESULT(.DIFFERENCE.,#9819,#15770);
#16167= IFCBOOLEANRESULT(.DIFFERENCE.,#16166,#15779);
#16168= IFCPLANE(#9821);
#16169= IFCHALFSPACESOLID(#16168,.F.);
#16170= IFCBOOLEANRESULT(.DIFFERENCE.,#16167,#16169);
#16171= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#16170));
#16172= IFCPRODUCTDEFINITIONSHAPE($,$,(#16171));
#16173= IFCDISCRETEACCESSORY('1Td1iR001n9J4rDp0rCJ4s',#5,'DIKME','T200-25-25-110','T200-25-25-110',#16165,#16172,'P/386(?)');
#16174= IFCLOCALPLACEMENT(#30,#10);
#16175= IFCELEMENTASSEMBLY('1Td1iR0021s34rDp0rCJ4s',#5,'Steel Assembly',$,$,#16174,$,'ANK/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#16176= IFCCARTESIANPOINT((40029.9926804692,-531.666078953131,-7672.504));
#16177= IFCAXIS2PLACEMENT3D(#16176,#7,#501);
#16178= IFCLOCALPLACEMENT(#16174,#16177);
#16179= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15703));
#16180= IFCPRODUCTDEFINITIONSHAPE($,$,(#16179));
#16181= IFCBEAM('1Td1iR001nA34rDp0rCJ4s',#5,'ANKRAJ','PLT15*100','PLT15*100',#16178,#16180,'P/484(?)');
#16182= IFCCARTESIANPOINT((39934.9926804696,-484.171109536622,-7530.00338648548));
#16183= IFCAXIS2PLACEMENT3D(#16182,#9107,#7);
#16184= IFCLOCALPLACEMENT(#15257,#16183);
#16185= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9115));
#16186= IFCPRODUCTDEFINITIONSHAPE($,$,(#16185));
#16187= IFCDISCRETEACCESSORY('1Td1iR001nAp4rDp0rCJ4s',#5,'DETAY','PL10*150','PL10*150',#16184,#16186,'P/222(?)');
#16188= IFCCARTESIANPOINT((39934.9926804696,-679.167109536622,-7530.00338648548));
#16189= IFCAXIS2PLACEMENT3D(#16188,#9144,#9145);
#16190= IFCLOCALPLACEMENT(#15257,#16189);
#16191= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8255));
#16192= IFCPRODUCTDEFINITIONSHAPE($,$,(#16191));
#16193= IFCDISCRETEACCESSORY('1Td1iR001nBZ4rDp0rCJ4s',#5,'DETAY','PL10*150','PL10*150',#16190,#16192,'P/240(?)');
#16194= IFCLOCALPLACEMENT(#30,#10);
#16195= IFCELEMENTASSEMBLY('1Td1iR001z5p4rDp0rCJ4s',#5,'Steel Assembly',$,$,#16194,$,'C/4(?)',.NOTDEFINED.,.RIGID_FRAME.);
#16196= IFCPROPERTYSET('0LAG4bEwvDlv8qM66fJ0$S',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#15643,#3923,#3924,#3925,#5197,#15644));
#16197= IFCCARTESIANPOINT((39394.9926804732,-689.170276561901,-1102.00434291132));
#16198= IFCAXIS2PLACEMENT3D(#16197,#15393,#185);
#16199= IFCLOCALPLACEMENT(#16194,#16198);
#16200= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12806));
#16201= IFCPRODUCTDEFINITIONSHAPE($,$,(#16200));
#16202= IFCDISCRETEACCESSORY('1Td1iR001nFJ4rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#16199,#16201,'P/418(?)');
#16203= IFCLOCALPLACEMENT(#30,#10);
#16204= IFCELEMENTASSEMBLY('1Td1iR001z434rDp0rCJ4s',#5,'Steel Assembly',$,$,#16203,$,'C/4(?)',.NOTDEFINED.,.RIGID_FRAME.);
#16205= IFCPROPERTYSET('1mvlIsfsT2JPrbH9b$N_ex',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#15643,#3923,#3924,#3925,#5873,#15644));
#16206= IFCCARTESIANPOINT((40204.9926804732,-689.170276561901,-1102.00434291132));
#16207= IFCAXIS2PLACEMENT3D(#16206,#15393,#185);
#16208= IFCLOCALPLACEMENT(#16203,#16207);
#16209= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12806));
#16210= IFCPRODUCTDEFINITIONSHAPE($,$,(#16209));
#16211= IFCDISCRETEACCESSORY('1Td1iR001nG34rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#16208,#16210,'P/418(?)');
#16212= IFCLOCALPLACEMENT(#30,#10);
#16213= IFCELEMENTASSEMBLY('1Td1iR001yTp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#16212,$,'C/8(?)',.NOTDEFINED.,.RIGID_FRAME.);
#16214= IFCPROPERTYSET('25vu997Kn8k9EBPHBXJBnU',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#15389,#5749,#5750,#3925,#5197,#15390));
#16215= IFCCARTESIANPOINT((39394.9926804732,-689.170276561898,4897.99565708869));
#16216= IFCAXIS2PLACEMENT3D(#16215,#15393,#185);
#16217= IFCLOCALPLACEMENT(#16212,#16216);
#16218= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12806));
#16219= IFCPRODUCTDEFINITIONSHAPE($,$,(#16218));
#16220= IFCDISCRETEACCESSORY('1Td1iR001nJp4rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#16217,#16219,'P/418(?)');
#16221= IFCLOCALPLACEMENT(#30,#10);
#16222= IFCELEMENTASSEMBLY('1Td1iR001yVJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#16221,$,'C/8(?)',.NOTDEFINED.,.RIGID_FRAME.);
#16223= IFCPROPERTYSET('2H9BBHwYz78QOyXkWk0tZ9',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#15389,#5749,#5750,#3925,#5873,#15390));
#16224= IFCCARTESIANPOINT((40204.9926804732,-689.170276561898,4897.99565708869));
#16225= IFCAXIS2PLACEMENT3D(#16224,#15393,#185);
#16226= IFCLOCALPLACEMENT(#16221,#16225);
#16227= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12806));
#16228= IFCPRODUCTDEFINITIONSHAPE($,$,(#16227));
#16229= IFCDISCRETEACCESSORY('1Td1iR001nKZ4rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#16226,#16228,'P/418(?)');
#16230= IFCLOCALPLACEMENT(#30,#10);
#16231= IFCELEMENTASSEMBLY('1Td1iR001ycp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#16230,$,'C/10(?)',.NOTDEFINED.,.RIGID_FRAME.);
#16232= IFCPROPERTYSET('1XwRYkF6XC7gnVhzU1DBwm',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#12836,#4464,#4465,#3925,#5197,#12837));
#16233= IFCCARTESIANPOINT((39394.9926804732,-689.170276561898,10597.9956570887));
#16234= IFCAXIS2PLACEMENT3D(#16233,#15393,#185);
#16235= IFCLOCALPLACEMENT(#16230,#16234);
#16236= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12806));
#16237= IFCPRODUCTDEFINITIONSHAPE($,$,(#16236));
#16238= IFCDISCRETEACCESSORY('1Td1iR001nOJ4rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#16235,#16237,'P/418(?)');
#16239= IFCLOCALPLACEMENT(#30,#10);
#16240= IFCELEMENTASSEMBLY('1Td1iR001z2J4rDp0rCJ4s',#5,'Steel Assembly',$,$,#16239,$,'C/10(?)',.NOTDEFINED.,.RIGID_FRAME.);
#16241= IFCPROPERTYSET('18GptrqjP6hgBQCPOfMGiX',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#12836,#4464,#4465,#3925,#5873,#12837));
#16242= IFCCARTESIANPOINT((40204.9926804732,-689.170276561898,10597.9956570887));
#16243= IFCAXIS2PLACEMENT3D(#16242,#15393,#185);
#16244= IFCLOCALPLACEMENT(#16239,#16243);
#16245= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12806));
#16246= IFCPRODUCTDEFINITIONSHAPE($,$,(#16245));
#16247= IFCDISCRETEACCESSORY('1Td1iR001nP34rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#16244,#16246,'P/418(?)');
#16248= IFCLOCALPLACEMENT(#30,#10);
#16249= IFCELEMENTASSEMBLY('1Td1iR001yt34rDp0rCJ4s',#5,'Steel Assembly',$,$,#16248,$,'C/14(?)',.NOTDEFINED.,.RIGID_FRAME.);
#16250= IFCPROPERTYSET('2OHkbUkZv2MvDO3Dz$H7Sg',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#15428,#9780,#12862,#3925,#5197,#12863));
#16251= IFCCARTESIANPOINT((39394.9926804732,-689.170275313896,15797.9956570887));
#16252= IFCAXIS2PLACEMENT3D(#16251,#15393,#185);
#16253= IFCLOCALPLACEMENT(#16248,#16252);
#16254= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12872));
#16255= IFCPRODUCTDEFINITIONSHAPE($,$,(#16254));
#16256= IFCDISCRETEACCESSORY('1Td1iR001niZ4rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#16253,#16255,'P/417(?)');
#16257= IFCLOCALPLACEMENT(#30,#10);
#16258= IFCELEMENTASSEMBLY('1Td1iR001yqp4rDp0rCJ4s',#5,'Steel Assembly',$,$,#16257,$,'ANK/16(?)',.NOTDEFINED.,.RIGID_FRAME.);
#16259= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit position code',$,IFCLABEL('4/1-5/1/N2'),$);
#16260= IFCPROPERTYSET('2Go2EH8Aj0VAgE83GDAOFR',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#12900,#12901,#136,#39,#16259,#12902));
#16261= IFCCARTESIANPOINT((39390.,-355.163143608002,20200.001693145));
#16262= IFCAXIS2PLACEMENT3D(#16261,#501,#185);
#16263= IFCLOCALPLACEMENT(#16257,#16262);
#16264= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12917));
#16265= IFCPRODUCTDEFINITIONSHAPE($,$,(#16264));
#16266= IFCDISCRETEACCESSORY('1Td1iR001nn34rDp0rCJ4s',#5,'DETAY','PL8*70','PL8*70',#16263,#16265,'P/389(?)');
#16267= IFCCARTESIANPOINT((39240.,-355.163143608002,20200.001693145));
#16268= IFCAXIS2PLACEMENT3D(#16267,#8,#7);
#16269= IFCLOCALPLACEMENT(#16257,#16268);
#16270= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12917));
#16271= IFCPRODUCTDEFINITIONSHAPE($,$,(#16270));
#16272= IFCDISCRETEACCESSORY('1Td1iR001nnp4rDp0rCJ4s',#5,'DETAY','PL8*70','PL8*70',#16269,#16271,'P/389(?)');
#16273= IFCCARTESIANPOINT((39390.,-224.165279838405,20125.001693145));
#16274= IFCAXIS2PLACEMENT3D(#16273,#9,#185);
#16275= IFCLOCALPLACEMENT(#16257,#16274);
#16276= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12960));
#16277= IFCPRODUCTDEFINITIONSHAPE($,$,(#16276));
#16278= IFCDISCRETEACCESSORY('1Td1iR001noZ4rDp0rCJ4s',#5,'ANKRAJ','PLT10*150','PLT10*150',#16275,#16277,'P/337(?)');
#16279= IFCLOCALPLACEMENT(#30,#10);
#16280= IFCELEMENTASSEMBLY('1Td1iR001z0p4rDp0rCJ4s',#5,'Steel Assembly',$,$,#16279,$,'C/14(?)',.NOTDEFINED.,.RIGID_FRAME.);
#16281= IFCPROPERTYSET('1KkDFyIi55kRxX3MmXFOXy',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#15428,#9780,#12862,#3925,#5873,#12863));
#16282= IFCCARTESIANPOINT((40204.9926804732,-689.170275313896,15797.9956570887));
#16283= IFCAXIS2PLACEMENT3D(#16282,#15393,#185);
#16284= IFCLOCALPLACEMENT(#16279,#16283);
#16285= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12872));
#16286= IFCPRODUCTDEFINITIONSHAPE($,$,(#16285));
#16287= IFCDISCRETEACCESSORY('1Td1iR001npJ4rDp0rCJ4s',#5,'PLAKA','PL16*130','PL16*130',#16284,#16286,'P/417(?)');
#16288= IFCLOCALPLACEMENT(#30,#10);
#16289= IFCELEMENTASSEMBLY('1Td1iR0021sJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#16288,$,'ANK/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#16290= IFCCARTESIANPOINT((40249.9926804692,-531.666078953131,-7672.504));
#16291= IFCAXIS2PLACEMENT3D(#16290,#185,#501);
#16292= IFCLOCALPLACEMENT(#16288,#16291);
#16293= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15703));
#16294= IFCPRODUCTDEFINITIONSHAPE($,$,(#16293));
#16295= IFCBEAM('1Td1iR001nq34rDp0rCJ4s',#5,'ANKRAJ','PLT15*100','PLT15*100',#16292,#16294,'P/484(?)');
#16296= IFCCARTESIANPOINT((40344.9926804687,-679.167109536622,-7530.00338648548));
#16297= IFCAXIS2PLACEMENT3D(#16296,#9178,#9179);
#16298= IFCLOCALPLACEMENT(#15257,#16297);
#16299= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#8255));
#16300= IFCPRODUCTDEFINITIONSHAPE($,$,(#16299));
#16301= IFCDISCRETEACCESSORY('1Td1iR001nqp4rDp0rCJ4s',#5,'DETAY','PL10*150','PL10*150',#16298,#16300,'P/240(?)');
#16302= IFCLOCALPLACEMENT(#30,#10);
#16303= IFCELEMENTASSEMBLY('1Td1iR001y_Z4rDp0rCJ4s',#5,'Steel Assembly',$,$,#16302,$,'ANK/16(?)',.NOTDEFINED.,.RIGID_FRAME.);
#16304= IFCCARTESIANPOINT((40200.,-355.163143608002,20200.001693145));
#16305= IFCAXIS2PLACEMENT3D(#16304,#501,#185);
#16306= IFCLOCALPLACEMENT(#16302,#16305);
#16307= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12917));
#16308= IFCPRODUCTDEFINITIONSHAPE($,$,(#16307));
#16309= IFCDISCRETEACCESSORY('1Td1iR001nwp4rDp0rCJ4s',#5,'DETAY','PL8*70','PL8*70',#16306,#16308,'P/389(?)');
#16310= IFCCARTESIANPOINT((40050.,-355.163143608002,20200.001693145));
#16311= IFCAXIS2PLACEMENT3D(#16310,#8,#7);
#16312= IFCLOCALPLACEMENT(#16302,#16311);
#16313= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12917));
#16314= IFCPRODUCTDEFINITIONSHAPE($,$,(#16313));
#16315= IFCDISCRETEACCESSORY('1Td1iR001nxZ4rDp0rCJ4s',#5,'DETAY','PL8*70','PL8*70',#16312,#16314,'P/389(?)');
#16316= IFCCARTESIANPOINT((40200.,-224.165279838405,20125.001693145));
#16317= IFCAXIS2PLACEMENT3D(#16316,#9,#185);
#16318= IFCLOCALPLACEMENT(#16302,#16317);
#16319= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12960));
#16320= IFCPRODUCTDEFINITIONSHAPE($,$,(#16319));
#16321= IFCDISCRETEACCESSORY('1Td1iR001nyJ4rDp0rCJ4s',#5,'ANKRAJ','PLT10*150','PLT10*150',#16318,#16320,'P/337(?)');
#16322= IFCCARTESIANPOINT((40139.9926804684,-589.170000077091,-1155.));
#16323= IFCAXIS2PLACEMENT3D(#16322,#501,#596);
#16324= IFCLOCALPLACEMENT(#15257,#16323);
#16325= IFCBOOLEANRESULT(.DIFFERENCE.,#9819,#15770);
#16326= IFCBOOLEANRESULT(.DIFFERENCE.,#16325,#15779);
#16327= IFCPLANE(#9821);
#16328= IFCHALFSPACESOLID(#16327,.F.);
#16329= IFCBOOLEANRESULT(.DIFFERENCE.,#16326,#16328);
#16330= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#16329));
#16331= IFCPRODUCTDEFINITIONSHAPE($,$,(#16330));
#16332= IFCDISCRETEACCESSORY('1Td1iR001o3J4rDp0rCJ4s',#5,'DIKME','T200-25-25-110','T200-25-25-110',#16324,#16331,'P/386(?)');
#16333= IFCLOCALPLACEMENT(#30,#10);
#16334= IFCELEMENTASSEMBLY('1Td1iR001vJZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#16333,$,'B/164(?)',.NOTDEFINED.,.RIGID_FRAME.);
#16335= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(0.291424603923018),$);
#16336= IFCPROPERTYSET('2GqTeRrrH3KARJh0yvzt8F',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#16335,#8929,#8930,#4310,#488,#8931));
#16337= IFCQUANTITYLENGTH('Width',$,$,6.00000000034265);
#16338= IFCELEMENTQUANTITY('1MIDHAjGrDn9YUQQnx2IaK',#5,'BaseQuantities',$,$,(#16337));
#16339= IFCCARTESIANPOINT((46479.9962754006,-579.169652492433,-7191.));
#16340= IFCAXIS2PLACEMENT3D(#16339,#8936,#9);
#16341= IFCLOCALPLACEMENT(#16333,#16340);
#16342= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15292));
#16343= IFCPRODUCTDEFINITIONSHAPE($,$,(#16342));
#16344= IFCPLATE('1Td1iR001vJJ4rDp0rCJ4s',#5,'DETAY','PL6*60','PL6*60',#16341,#16343,'P/396(?)');
#16345= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(0.291424603923018),$);
#16346= IFCPROPERTYSET('2OB9y6CpXDChAUYDOw7jzY',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#16345,#15298,#15299,#15300,#10776,#10777,#10778,#10779,#15301,#15302,#15303,#8966,#4007,#15304));
#16347= IFCLOCALPLACEMENT(#30,#10);
#16348= IFCELEMENTASSEMBLY('1Td1iR001vKZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#16347,$,'DK/90(?)',.NOTDEFINED.,.RIGID_FRAME.);
#16349= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(0.900781264103827),$);
#16350= IFCPROPERTYSET('2WMtevn05Fjxn9KilnnAsO',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#16349,#8979,#8980,#3925,#488,#8981));
#16351= IFCCARTESIANPOINT((46607.4953927543,-584.17000007709,-7158.));
#16352= IFCAXIS2PLACEMENT3D(#16351,#501,#185);
#16353= IFCLOCALPLACEMENT(#16347,#16352);
#16354= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15339));
#16355= IFCPRODUCTDEFINITIONSHAPE($,$,(#16354));
#16356= IFCBEAM('1Td1iR001vKJ4rDp0rCJ4s',#5,'DIKME','PLT6*150','PLT6*150',#16353,#16355,'P/465(?)');
#16357= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(0.900781264103827),$);
#16358= IFCPROPERTYSET('3MVVMyss52F9vSzcye47q4',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#16357,#15345,#15346,#15347,#10806,#10807,#10808,#15348,#15349,#15350,#15351,#529,#3965,#15352));
#16359= IFCCARTESIANPOINT((45000.0005366125,-589.170000077491,-7145.));
#16360= IFCAXIS2PLACEMENT3D(#16359,#501,#7);
#16361= IFCLOCALPLACEMENT(#15049,#16360);
#16362= IFCCARTESIANPOINT((1619.99939650606,0.,0.));
#16363= IFCAXIS2PLACEMENT3D(#16362,#185,#501);
#16364= IFCEXTRUDEDAREASOLID(#4117,#16363,#9,1619.99939650606);
#16365= IFCCARTESIANPOINT((59.9842872258741,35.,100.));
#16366= IFCAXIS2PLACEMENT3D(#16365,#8,#596);
#16367= IFCEXTRUDEDAREASOLID(#11444,#16366,#9,10.);
#16368= IFCBOOLEANRESULT(.DIFFERENCE.,#16364,#16367);
#16369= IFCCARTESIANPOINT((144.984287225874,-45.,100.));
#16370= IFCAXIS2PLACEMENT3D(#16369,#8,#596);
#16371= IFCEXTRUDEDAREASOLID(#11454,#16370,#9,80.);
#16372= IFCBOOLEANRESULT(.DIFFERENCE.,#16368,#16371);
#16373= IFCCARTESIANPOINT((1559.98339601777,45.,100.));
#16374= IFCAXIS2PLACEMENT3D(#16373,#501,#596);
#16375= IFCEXTRUDEDAREASOLID(#4126,#16374,#9,10.);
#16376= IFCBOOLEANRESULT(.DIFFERENCE.,#16372,#16375);
#16377= IFCCARTESIANPOINT((1459.98639601778,35.,100.));
#16378= IFCAXIS2PLACEMENT3D(#16377,#501,#596);
#16379= IFCEXTRUDEDAREASOLID(#4137,#16378,#9,80.);
#16380= IFCBOOLEANRESULT(.DIFFERENCE.,#16376,#16379);
#16381= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#16380));
#16382= IFCSTYLEDITEM(#16364,(#4116),$);
#16383= IFCPRODUCTDEFINITIONSHAPE($,$,(#16381));
#16384= IFCBEAM('1Td1iR001vLJ4rDp0rCJ4s',#5,'KIRIS','RHS200*90*6','RHS200*90*6',#16361,#16383,'P/453(?)');
#16385= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/453(?)'),$);
#16386= IFCPROPERTYSET('0BcCfzCqz1Rgob9rtRHbYd',#5,'Tekla Common','Common Properties to Shared building elements',(#11471,#11472,#16385,#15060,#74,#75,#919,#4183,#78,#4184,#4185));
#16387= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(37.9631377809933),$);
#16388= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(42.423896195942),$);
#16389= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(37.9631377809933),$);
#16390= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.0048360685071329),$);
#16391= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.0054043179867442),$);
#16392= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.0048360685071329),$);
#16393= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.314449821758379),$);
#16394= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(22.0226481898291),$);
#16395= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.836048827532825),$);
#16396= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.932016148925121),$);
#16397= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(1585.01510928018),$);
#16398= IFCPROPERTYSET('0MFHRsOLDD1uGv0yu5fgP$',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#15062,#16387,#16388,#16389,#16390,#16391,#16392,#16393,#16394,#16395,#16396,#9843,#5657,#16397));
#16399= IFCQUANTITYLENGTH('Length',$,$,1585.01510928018);
#16400= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.836048827532825);
#16401= IFCQUANTITYVOLUME('NetVolume',$,$,0.0048360685071329);
#16402= IFCQUANTITYWEIGHT('NetWeight',$,$,37.9631377809933);
#16403= IFCELEMENTQUANTITY('3Nh$YKjJD1Whc1TcxRMsKz',#5,'BaseQuantities',$,$,(#16399,#16400,#16401,#16402));
#16404= IFCLOCALPLACEMENT(#30,#10);
#16405= IFCELEMENTASSEMBLY('1Td1iR001vMZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#16404,$,'B/164(?)',.NOTDEFINED.,.RIGID_FRAME.);
#16406= IFCCARTESIANPOINT((44859.9962754006,-579.169652492433,-7191.));
#16407= IFCAXIS2PLACEMENT3D(#16406,#8936,#9);
#16408= IFCLOCALPLACEMENT(#16404,#16407);
#16409= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15292));
#16410= IFCPRODUCTDEFINITIONSHAPE($,$,(#16409));
#16411= IFCPLATE('1Td1iR001vMJ4rDp0rCJ4s',#5,'DETAY','PL6*60','PL6*60',#16408,#16410,'P/396(?)');
#16412= IFCLOCALPLACEMENT(#30,#10);
#16413= IFCELEMENTASSEMBLY('1Td1iR001vNZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#16412,$,'DK/90(?)',.NOTDEFINED.,.RIGID_FRAME.);
#16414= IFCCARTESIANPOINT((44987.4953927543,-584.17000007709,-7158.));
#16415= IFCAXIS2PLACEMENT3D(#16414,#501,#185);
#16416= IFCLOCALPLACEMENT(#16412,#16415);
#16417= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15339));
#16418= IFCPRODUCTDEFINITIONSHAPE($,$,(#16417));
#16419= IFCBEAM('1Td1iR001vNJ4rDp0rCJ4s',#5,'DIKME','PLT6*150','PLT6*150',#16416,#16418,'P/465(?)');
#16420= IFCCARTESIANPOINT((44190.0005366162,-589.170000077491,-7145.));
#16421= IFCAXIS2PLACEMENT3D(#16420,#501,#7);
#16422= IFCLOCALPLACEMENT(#15136,#16421);
#16423= IFCCARTESIANPOINT((809.999396506057,0.,0.));
#16424= IFCAXIS2PLACEMENT3D(#16423,#185,#501);
#16425= IFCEXTRUDEDAREASOLID(#4117,#16424,#9,809.999396506057);
#16426= IFCBOOLEANRESULT(.DIFFERENCE.,#16425,#16367);
#16427= IFCBOOLEANRESULT(.DIFFERENCE.,#16426,#16371);
#16428= IFCCARTESIANPOINT((749.983999508077,45.,100.));
#16429= IFCAXIS2PLACEMENT3D(#16428,#501,#596);
#16430= IFCEXTRUDEDAREASOLID(#4126,#16429,#9,10.);
#16431= IFCBOOLEANRESULT(.DIFFERENCE.,#16427,#16430);
#16432= IFCCARTESIANPOINT((649.986999508081,35.,100.));
#16433= IFCAXIS2PLACEMENT3D(#16432,#501,#596);
#16434= IFCEXTRUDEDAREASOLID(#4137,#16433,#9,80.);
#16435= IFCBOOLEANRESULT(.DIFFERENCE.,#16431,#16434);
#16436= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#16435));
#16437= IFCSTYLEDITEM(#16425,(#4116),$);
#16438= IFCPRODUCTDEFINITIONSHAPE($,$,(#16436));
#16439= IFCBEAM('1Td1iR001vOJ4rDp0rCJ4s',#5,'KIRIS','RHS200*90*6','RHS200*90*6',#16422,#16438,'P/452(?)');
#16440= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/452(?)'),$);
#16441= IFCPROPERTYSET('2FsmTvu$X35RR8YOriOEEM',#5,'Tekla Common','Common Properties to Shared building elements',(#11471,#11472,#16440,#15147,#74,#75,#919,#4183,#78,#4184,#4185));
#16442= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(16.751197584956),$);
#16443= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(21.211940195942),$);
#16444= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(16.751197584956),$);
#16445= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.00213391052037656),$);
#16446= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.0027021579867442),$);
#16447= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.00213391052037656),$);
#16448= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.15244994245644),$);
#16449= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(22.1930707802669),$);
#16450= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.371760513657165),$);
#16451= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.467727489131307),$);
#16452= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(775.015712770488),$);
#16453= IFCPROPERTYSET('2qptEY16r6$AtOronefU2H',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#15149,#16442,#16443,#16444,#16445,#16446,#16447,#16448,#16449,#16450,#16451,#9843,#5657,#16452));
#16454= IFCQUANTITYLENGTH('Length',$,$,775.015712770488);
#16455= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.371760513657165);
#16456= IFCQUANTITYVOLUME('NetVolume',$,$,0.00213391052037656);
#16457= IFCQUANTITYWEIGHT('NetWeight',$,$,16.751197584956);
#16458= IFCELEMENTQUANTITY('2sdT52JOXAkQaFtNMkz53c',#5,'BaseQuantities',$,$,(#16454,#16455,#16456,#16457));
#16459= IFCLOCALPLACEMENT(#30,#10);
#16460= IFCELEMENTASSEMBLY('1Td1iR001vPZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#16459,$,'B/164(?)',.NOTDEFINED.,.RIGID_FRAME.);
#16461= IFCCARTESIANPOINT((44049.9962754006,-579.169652492433,-7191.));
#16462= IFCAXIS2PLACEMENT3D(#16461,#8936,#9);
#16463= IFCLOCALPLACEMENT(#16459,#16462);
#16464= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15292));
#16465= IFCPRODUCTDEFINITIONSHAPE($,$,(#16464));
#16466= IFCPLATE('1Td1iR001vPJ4rDp0rCJ4s',#5,'DETAY','PL6*60','PL6*60',#16463,#16465,'P/396(?)');
#16467= IFCLOCALPLACEMENT(#30,#10);
#16468= IFCELEMENTASSEMBLY('1Td1iR001vQZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#16467,$,'DK/90(?)',.NOTDEFINED.,.RIGID_FRAME.);
#16469= IFCCARTESIANPOINT((44177.4953927543,-584.17000007709,-7158.));
#16470= IFCAXIS2PLACEMENT3D(#16469,#501,#185);
#16471= IFCLOCALPLACEMENT(#16467,#16470);
#16472= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15339));
#16473= IFCPRODUCTDEFINITIONSHAPE($,$,(#16472));
#16474= IFCBEAM('1Td1iR001vQJ4rDp0rCJ4s',#5,'DIKME','PLT6*150','PLT6*150',#16471,#16473,'P/465(?)');
#16475= IFCCARTESIANPOINT((43380.0005366162,-589.170000077491,-7145.));
#16476= IFCAXIS2PLACEMENT3D(#16475,#501,#7);
#16477= IFCLOCALPLACEMENT(#15187,#16476);
#16478= IFCCARTESIANPOINT((59.9836837270777,35.,100.));
#16479= IFCAXIS2PLACEMENT3D(#16478,#8,#596);
#16480= IFCEXTRUDEDAREASOLID(#11444,#16479,#9,10.);
#16481= IFCBOOLEANRESULT(.DIFFERENCE.,#16425,#16480);
#16482= IFCCARTESIANPOINT((144.983683727078,-45.,100.));
#16483= IFCAXIS2PLACEMENT3D(#16482,#8,#596);
#16484= IFCEXTRUDEDAREASOLID(#11454,#16483,#9,80.);
#16485= IFCBOOLEANRESULT(.DIFFERENCE.,#16481,#16484);
#16486= IFCBOOLEANRESULT(.DIFFERENCE.,#16485,#16430);
#16487= IFCBOOLEANRESULT(.DIFFERENCE.,#16486,#16434);
#16488= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#16487));
#16489= IFCPRODUCTDEFINITIONSHAPE($,$,(#16488));
#16490= IFCBEAM('1Td1iR001vRJ4rDp0rCJ4s',#5,'KIRIS','RHS200*90*6','RHS200*90*6',#16477,#16489,'P/452(?)');
#16491= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(16.7512133892364),$);
#16492= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(16.7512133892364),$);
#16493= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.00213391253366068),$);
#16494= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.00213391253366068),$);
#16495= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.152450063156927),$);
#16496= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(22.1930704925023),$);
#16497= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.371760859582271),$);
#16498= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(775.016316272922),$);
#16499= IFCPROPERTYSET('0yXT_31_T2KfuAGPVtJ67D',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#15197,#16491,#16443,#16492,#16493,#16446,#16494,#16495,#16496,#16497,#16451,#9843,#5657,#16498));
#16500= IFCQUANTITYLENGTH('Length',$,$,775.016316272922);
#16501= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.371760859582271);
#16502= IFCQUANTITYVOLUME('NetVolume',$,$,0.00213391253366068);
#16503= IFCQUANTITYWEIGHT('NetWeight',$,$,16.7512133892364);
#16504= IFCELEMENTQUANTITY('2IdpK_3dbDL9rtZwod$U00',#5,'BaseQuantities',$,$,(#16500,#16501,#16502,#16503));
#16505= IFCLOCALPLACEMENT(#30,#10);
#16506= IFCELEMENTASSEMBLY('1Td1iR001vYZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#16505,$,'B/164(?)',.NOTDEFINED.,.RIGID_FRAME.);
#16507= IFCPROPERTYSET('0RbS7rSmb2VPLpjcZ$vxGI',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#16335,#8929,#8930,#4310,#5873,#8931));
#16508= IFCCARTESIANPOINT((40809.9962754006,-579.169652492433,-7191.));
#16509= IFCAXIS2PLACEMENT3D(#16508,#8936,#9);
#16510= IFCLOCALPLACEMENT(#16505,#16509);
#16511= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15292));
#16512= IFCPRODUCTDEFINITIONSHAPE($,$,(#16511));
#16513= IFCPLATE('1Td1iR001vYJ4rDp0rCJ4s',#5,'DETAY','PL6*60','PL6*60',#16510,#16512,'P/396(?)');
#16514= IFCLOCALPLACEMENT(#30,#10);
#16515= IFCELEMENTASSEMBLY('1Td1iR001vZZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#16514,$,'DK/90(?)',.NOTDEFINED.,.RIGID_FRAME.);
#16516= IFCPROPERTYSET('2qFcayQWb8CPLpHl4vL7ka',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#16349,#8979,#8980,#3925,#5873,#8981));
#16517= IFCCARTESIANPOINT((40937.4953927543,-584.17000007709,-7158.));
#16518= IFCAXIS2PLACEMENT3D(#16517,#501,#185);
#16519= IFCLOCALPLACEMENT(#16514,#16518);
#16520= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15339));
#16521= IFCPRODUCTDEFINITIONSHAPE($,$,(#16520));
#16522= IFCBEAM('1Td1iR001vZJ4rDp0rCJ4s',#5,'DIKME','PLT6*150','PLT6*150',#16519,#16521,'P/465(?)');
#16523= IFCCARTESIANPOINT((40140.0005366162,-589.170000077491,-7145.));
#16524= IFCAXIS2PLACEMENT3D(#16523,#501,#7);
#16525= IFCLOCALPLACEMENT(#15242,#16524);
#16526= IFCBOOLEANRESULT(.DIFFERENCE.,#16425,#16480);
#16527= IFCBOOLEANRESULT(.DIFFERENCE.,#16526,#16484);
#16528= IFCBOOLEANRESULT(.DIFFERENCE.,#16527,#16430);
#16529= IFCBOOLEANRESULT(.DIFFERENCE.,#16528,#16434);
#16530= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#16529));
#16531= IFCPRODUCTDEFINITIONSHAPE($,$,(#16530));
#16532= IFCBEAM('1Td1iR001vaJ4rDp0rCJ4s',#5,'KIRIS','RHS200*90*6','RHS200*90*6',#16525,#16531,'P/452(?)');
#16533= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(22.193070492507),$);
#16534= IFCPROPERTYSET('0nCJlkVJzA0eApKNlTorZ1',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#15197,#16491,#16443,#16492,#16493,#16446,#16494,#16495,#16533,#16497,#16451,#9843,#5657,#16498));
#16535= IFCQUANTITYLENGTH('Length',$,$,775.016316263216);
#16536= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.37176085957671);
#16537= IFCQUANTITYVOLUME('NetVolume',$,$,0.00213391253362831);
#16538= IFCQUANTITYWEIGHT('NetWeight',$,$,16.7512133889822);
#16539= IFCELEMENTQUANTITY('3ZpP6H7EP2MRJ2PjEilL_H',#5,'BaseQuantities',$,$,(#16535,#16536,#16537,#16538));
#16540= IFCCARTESIANPOINT((40950.0005366113,-589.170000077491,-7145.));
#16541= IFCAXIS2PLACEMENT3D(#16540,#501,#7);
#16542= IFCLOCALPLACEMENT(#15311,#16541);
#16543= IFCCARTESIANPOINT((2429.99939650606,0.,0.));
#16544= IFCAXIS2PLACEMENT3D(#16543,#185,#501);
#16545= IFCEXTRUDEDAREASOLID(#4117,#16544,#9,2429.99939650606);
#16546= IFCBOOLEANRESULT(.DIFFERENCE.,#16545,#16367);
#16547= IFCBOOLEANRESULT(.DIFFERENCE.,#16546,#16371);
#16548= IFCCARTESIANPOINT((2369.98339601778,45.,100.));
#16549= IFCAXIS2PLACEMENT3D(#16548,#501,#596);
#16550= IFCEXTRUDEDAREASOLID(#4126,#16549,#9,10.);
#16551= IFCBOOLEANRESULT(.DIFFERENCE.,#16547,#16550);
#16552= IFCCARTESIANPOINT((2269.98639601778,35.,100.));
#16553= IFCAXIS2PLACEMENT3D(#16552,#501,#596);
#16554= IFCEXTRUDEDAREASOLID(#4137,#16553,#9,80.);
#16555= IFCBOOLEANRESULT(.DIFFERENCE.,#16551,#16554);
#16556= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#16555));
#16557= IFCSTYLEDITEM(#16545,(#4116),$);
#16558= IFCPRODUCTDEFINITIONSHAPE($,$,(#16556));
#16559= IFCBEAM('1Td1iR001vbJ4rDp0rCJ4s',#5,'KIRIS','RHS200*90*6','RHS200*90*6',#16542,#16558,'P/451(?)');
#16560= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/451(?)'),$);
#16561= IFCPROPERTYSET('3IB4X$k$P649r_lFAO3X$e',#5,'Tekla Common','Common Properties to Shared building elements',(#11471,#11472,#16560,#15322,#74,#75,#919,#4183,#78,#4184,#4185));
#16562= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(59.1750937809934),$);
#16563= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(63.6358521959421),$);
#16564= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(59.1750937809934),$);
#16565= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.00753822850713291),$);
#16566= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.00810647798674421),$);
#16567= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.00753822850713291),$);
#16568= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.476449821758381),$);
#16569= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(21.9744051803142),$);
#16570= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(1.30033748732664),$);
#16571= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(1.39630480871894),$);
#16572= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(2395.01510928018),$);
#16573= IFCPROPERTYSET('1Lyucoa7jEiRPl_sE5IpJW',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#15324,#16562,#16563,#16564,#16565,#16566,#16567,#16568,#16569,#16570,#16571,#9843,#5657,#16572));
#16574= IFCQUANTITYLENGTH('Length',$,$,2395.01510928018);
#16575= IFCQUANTITYAREA('OuterSurfaceArea',$,$,1.30033748732664);
#16576= IFCQUANTITYVOLUME('NetVolume',$,$,0.00753822850713291);
#16577= IFCQUANTITYWEIGHT('NetWeight',$,$,59.1750937809934);
#16578= IFCELEMENTQUANTITY('0K9cN2CSn0uQUWGj3Ln7dS',#5,'BaseQuantities',$,$,(#16574,#16575,#16576,#16577));
#16579= IFCCARTESIANPOINT((46619.9926804692,-589.170000077483,10545.));
#16580= IFCAXIS2PLACEMENT3D(#16579,#501,#596);
#16581= IFCLOCALPLACEMENT(#15387,#16580);
#16582= IFCEXTRUDEDAREASOLID(#13030,#12990,#9,5700.);
#16583= IFCCARTESIANPOINT((5639.004,120.000000000102,-220.000000017202));
#16584= IFCAXIS2PLACEMENT3D(#16583,#7,#501);
#16585= IFCPLANE(#16584);
#16586= IFCHALFSPACESOLID(#16585,.F.);
#16587= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#16582,#16586);
#16588= IFCCARTESIANPOINT((45.0040000000008,-60.,-220.));
#16589= IFCAXIS2PLACEMENT3D(#16588,#185,#8);
#16590= IFCPLANE(#16589);
#16591= IFCHALFSPACESOLID(#16590,.F.);
#16592= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#16587,#16591);
#16593= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#16592));
#16594= IFCSTYLEDITEM(#16582,(#5245),$);
#16595= IFCPRODUCTDEFINITIONSHAPE($,$,(#16593));
#16596= IFCBEAM('1Td1iR001vcp4rDp0rCJ4s',#5,'DIKME','T200-16-20-110','T200-16-20-110',#16581,#16595,'P/315(?)');
#16597= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/315(?)'),$);
#16598= IFCPROPERTYSET('1SlNHc2e9B4uFa16N2soWF',#5,'Tekla Common','Common Properties to Shared building elements',(#2156,#9972,#16597,#15399,#74,#75,#919,#5256,#78,#13048,#4048));
#16599= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(223.077532),$);
#16600= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(227.3046),$);
#16601= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(223.077532),$);
#16602= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.02841752),$);
#16603= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.028956),$);
#16604= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.02841752),$);
#16605= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(15.592964333136),$);
#16606= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(3.47844),$);
#16607= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(3.54416),$);
#16608= IFCPROPERTYSET('0mgjXj9pj9FexQVXU6HYtr',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#15401,#16599,#16600,#16601,#16602,#16603,#16604,#13056,#16605,#16606,#16607,#9843,#9844,#13020));
#16609= IFCQUANTITYAREA('OuterSurfaceArea',$,$,3.47844);
#16610= IFCQUANTITYVOLUME('NetVolume',$,$,0.02841752);
#16611= IFCQUANTITYWEIGHT('NetWeight',$,$,223.077532);
#16612= IFCELEMENTQUANTITY('1CojL$BnPFSAaEX6izK12e',#5,'BaseQuantities',$,$,(#13022,#16609,#16610,#16611));
#16613= IFCCARTESIANPOINT((46605.,-229.17117837134,20199.9974118494));
#16614= IFCAXIS2PLACEMENT3D(#16613,#185,#596);
#16615= IFCLOCALPLACEMENT(#15445,#16614);
#16616= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#13077));
#16617= IFCPRODUCTDEFINITIONSHAPE($,$,(#16616));
#16618= IFCPLATE('1Td1iR001vdp4rDp0rCJ4s',#5,'ANKRAJ','PL10*250','PL10*250',#16615,#16617,'P/224(?)');
#16619= IFCPROPERTYSET('2xLOTnCtH4o9hj$$G_VC67',#5,'Tekla Common','Common Properties to Shared building elements',(#13083,#12072,#13084,#12924,#74,#75,#919,#12966,#78,#13085,#80));
#16620= IFCQUANTITYLENGTH('Width',$,$,250.006181261204);
#16621= IFCQUANTITYAREA('GrossArea',$,$,0.0675017864925488);
#16622= IFCELEMENTQUANTITY('0jIkQIS4L16eO2DKi8T5KO',#5,'BaseQuantities',$,$,(#16620,#13101,#16621,#8283,#13103,#13104));
#16623= IFCCARTESIANPOINT((46619.9926804692,-554.170000077484,20200.));
#16624= IFCAXIS2PLACEMENT3D(#16623,#501,#596);
#16625= IFCLOCALPLACEMENT(#15426,#16624);
#16626= IFCCARTESIANPOINT((49.9983068549809,64.9973097651819,-165.002921124353));
#16627= IFCAXIS2PLACEMENT3D(#16626,#501,#9);
#16628= IFCEXTRUDEDAREASOLID(#13119,#16627,#9,130.);
#16629= IFCBOOLEANRESULT(.DIFFERENCE.,#13112,#16628);
#16630= IFCCARTESIANPOINT((0.,-55.0000000000146,-138.780623036979));
#16631= IFCAXIS2PLACEMENT3D(#16630,#13124,#13126);
#16632= IFCPLANE(#16631);
#16633= IFCHALFSPACESOLID(#16632,.F.);
#16634= IFCBOOLEANRESULT(.DIFFERENCE.,#16629,#16633);
#16635= IFCCARTESIANPOINT((4394.004,60.0000000000873,-185.000000094612));
#16636= IFCAXIS2PLACEMENT3D(#16635,#7,#501);
#16637= IFCPLANE(#16636);
#16638= IFCHALFSPACESOLID(#16637,.F.);
#16639= IFCBOOLEANRESULT(.DIFFERENCE.,#16634,#16638);
#16640= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#16639));
#16641= IFCPRODUCTDEFINITIONSHAPE($,$,(#16640));
#16642= IFCBEAM('1Td1iR001vg34rDp0rCJ4s',#5,'DIKME','T270-16-16-110','T270-16-16-110',#16625,#16641,'P/319(?)');
#16643= IFCPROPERTYSET('2HtQYwG5D0N9lPEk4AWvxy',#5,'Tekla Common','Common Properties to Shared building elements',(#1598,#13141,#13142,#12878,#74,#75,#919,#13143,#78,#13144,#4048));
#16644= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(175.839821168319),$);
#16645= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(175.839821168319),$);
#16646= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00128002613798691),$);
#16647= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(16.7758435539524),$);
#16648= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(2.94986133047468),$);
#16649= IFCPROPERTYSET('1tPpOsukv28gtgUcKNAeP2',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#15437,#16644,#13147,#16645,#13149,#13150,#13151,#16646,#16647,#16648,#13155,#13156,#9844,#13157));
#16650= IFCQUANTITYAREA('OuterSurfaceArea',$,$,2.94986133047468);
#16651= IFCQUANTITYVOLUME('NetVolume',$,$,0.0223999772188941);
#16652= IFCQUANTITYWEIGHT('NetWeight',$,$,175.839821168319);
#16653= IFCELEMENTQUANTITY('1JiUm4tYX3M9ChkPOYmu6J',#5,'BaseQuantities',$,$,(#13159,#16650,#16651,#16652));
#16654= IFCCARTESIANPOINT((46619.9926804692,-589.170000077483,15745.));
#16655= IFCAXIS2PLACEMENT3D(#16654,#501,#596);
#16656= IFCLOCALPLACEMENT(#15410,#16655);
#16657= IFCCARTESIANPOINT((5139.004,120.000000000102,-220.000000017202));
#16658= IFCAXIS2PLACEMENT3D(#16657,#7,#501);
#16659= IFCPLANE(#16658);
#16660= IFCHALFSPACESOLID(#16659,.F.);
#16661= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#13033,#16660);
#16662= IFCPLANE(#16589);
#16663= IFCHALFSPACESOLID(#16662,.F.);
#16664= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#16661,#16663);
#16665= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#16664));
#16666= IFCPRODUCTDEFINITIONSHAPE($,$,(#16665));
#16667= IFCBEAM('1Td1iR001vhZ4rDp0rCJ4s',#5,'DIKME','T200-16-20-110','T200-16-20-110',#16656,#16666,'P/316(?)');
#16668= IFCPROPERTYSET('0TjOksIePBevX79DPZHPXq',#5,'Tekla Common','Common Properties to Shared building elements',(#2019,#12182,#13047,#12845,#74,#75,#919,#5256,#78,#13048,#4048));
#16669= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(203.138532),$);
#16670= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(203.138532),$);
#16671= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.02587752),$);
#16672= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.02587752),$);
#16673= IFCPROPERTYSET('2PgF8U6cj6F9zLF9JpKKoq',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#12847,#16669,#13051,#16670,#16671,#13054,#16672,#13056,#13057,#13058,#13059,#9843,#9844,#13060));
#16674= IFCQUANTITYVOLUME('NetVolume',$,$,0.02587752);
#16675= IFCQUANTITYWEIGHT('NetWeight',$,$,203.138532);
#16676= IFCELEMENTQUANTITY('0CVE7wVcr6yQgcmNe5lspY',#5,'BaseQuantities',$,$,(#13062,#13063,#16674,#16675));
#16677= IFCCARTESIANPOINT((44999.9926804692,-589.170000077483,10545.));
#16678= IFCAXIS2PLACEMENT3D(#16677,#501,#596);
#16679= IFCLOCALPLACEMENT(#15474,#16678);
#16680= IFCPLANE(#16584);
#16681= IFCHALFSPACESOLID(#16680,.F.);
#16682= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#16582,#16681);
#16683= IFCPLANE(#16589);
#16684= IFCHALFSPACESOLID(#16683,.F.);
#16685= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#16682,#16684);
#16686= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#16685));
#16687= IFCPRODUCTDEFINITIONSHAPE($,$,(#16686));
#16688= IFCBEAM('1Td1iR001vj34rDp0rCJ4s',#5,'DIKME','T200-16-20-110','T200-16-20-110',#16679,#16687,'P/315(?)');
#16689= IFCCARTESIANPOINT((44985.,-229.17117837134,20199.9974118494));
#16690= IFCAXIS2PLACEMENT3D(#16689,#185,#596);
#16691= IFCLOCALPLACEMENT(#15498,#16690);
#16692= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#13077));
#16693= IFCPRODUCTDEFINITIONSHAPE($,$,(#16692));
#16694= IFCPLATE('1Td1iR001vk34rDp0rCJ4s',#5,'ANKRAJ','PL10*250','PL10*250',#16691,#16693,'P/224(?)');
#16695= IFCPROPERTYSET('3c2vDcsT9BrgqRwNwb5OvX',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#15508,#13087,#13088,#13089,#13090,#13091,#13092,#13093,#13094,#13095,#13096,#13097,#8277,#13098));
#16696= IFCCARTESIANPOINT((44999.9926804692,-554.170000077483,20200.));
#16697= IFCAXIS2PLACEMENT3D(#16696,#501,#596);
#16698= IFCLOCALPLACEMENT(#15490,#16697);
#16699= IFCBOOLEANRESULT(.DIFFERENCE.,#13112,#16628);
#16700= IFCPLANE(#16631);
#16701= IFCHALFSPACESOLID(#16700,.F.);
#16702= IFCBOOLEANRESULT(.DIFFERENCE.,#16699,#16701);
#16703= IFCPLANE(#16636);
#16704= IFCHALFSPACESOLID(#16703,.F.);
#16705= IFCBOOLEANRESULT(.DIFFERENCE.,#16702,#16704);
#16706= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#16705));
#16707= IFCPRODUCTDEFINITIONSHAPE($,$,(#16706));
#16708= IFCBEAM('1Td1iR001vmJ4rDp0rCJ4s',#5,'DIKME','T270-16-16-110','T270-16-16-110',#16698,#16707,'P/319(?)');
#16709= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.00128002613798692),$);
#16710= IFCPROPERTYSET('30$RKbOzj8CAg4pfrapgau',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#15437,#16644,#13147,#16645,#13149,#13150,#13151,#16709,#16647,#16648,#13155,#13156,#9844,#13157));
#16711= IFCQUANTITYAREA('OuterSurfaceArea',$,$,2.94986133047468);
#16712= IFCQUANTITYVOLUME('NetVolume',$,$,0.0223999772188941);
#16713= IFCQUANTITYWEIGHT('NetWeight',$,$,175.839821168318);
#16714= IFCELEMENTQUANTITY('38kBrMaVrExO8rduuCxhLB',#5,'BaseQuantities',$,$,(#13159,#16711,#16712,#16713));
#16715= IFCCARTESIANPOINT((44999.9926804692,-589.170000077483,15745.));
#16716= IFCAXIS2PLACEMENT3D(#16715,#501,#596);
#16717= IFCLOCALPLACEMENT(#15482,#16716);
#16718= IFCPLANE(#16658);
#16719= IFCHALFSPACESOLID(#16718,.F.);
#16720= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#13033,#16719);
#16721= IFCPLANE(#16589);
#16722= IFCHALFSPACESOLID(#16721,.F.);
#16723= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#16720,#16722);
#16724= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#16723));
#16725= IFCPRODUCTDEFINITIONSHAPE($,$,(#16724));
#16726= IFCBEAM('1Td1iR001vnp4rDp0rCJ4s',#5,'DIKME','T200-16-20-110','T200-16-20-110',#16717,#16725,'P/316(?)');
#16727= IFCCARTESIANPOINT((44189.9926804692,-589.170000077483,10545.));
#16728= IFCAXIS2PLACEMENT3D(#16727,#501,#596);
#16729= IFCLOCALPLACEMENT(#15510,#16728);
#16730= IFCPLANE(#16584);
#16731= IFCHALFSPACESOLID(#16730,.F.);
#16732= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#16582,#16731);
#16733= IFCPLANE(#16589);
#16734= IFCHALFSPACESOLID(#16733,.F.);
#16735= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#16732,#16734);
#16736= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#16735));
#16737= IFCPRODUCTDEFINITIONSHAPE($,$,(#16736));
#16738= IFCBEAM('1Td1iR001vpJ4rDp0rCJ4s',#5,'DIKME','T200-16-20-110','T200-16-20-110',#16729,#16737,'P/315(?)');
#16739= IFCCARTESIANPOINT((44175.,-229.17117837134,20199.9974118494));
#16740= IFCAXIS2PLACEMENT3D(#16739,#185,#596);
#16741= IFCLOCALPLACEMENT(#15534,#16740);
#16742= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#13077));
#16743= IFCPRODUCTDEFINITIONSHAPE($,$,(#16742));
#16744= IFCPLATE('1Td1iR001vqJ4rDp0rCJ4s',#5,'ANKRAJ','PL10*250','PL10*250',#16741,#16743,'P/224(?)');
#16745= IFCCARTESIANPOINT((44189.9926804692,-554.170000077483,20200.));
#16746= IFCAXIS2PLACEMENT3D(#16745,#501,#596);
#16747= IFCLOCALPLACEMENT(#15526,#16746);
#16748= IFCBOOLEANRESULT(.DIFFERENCE.,#13112,#16628);
#16749= IFCPLANE(#16631);
#16750= IFCHALFSPACESOLID(#16749,.F.);
#16751= IFCBOOLEANRESULT(.DIFFERENCE.,#16748,#16750);
#16752= IFCPLANE(#16636);
#16753= IFCHALFSPACESOLID(#16752,.F.);
#16754= IFCBOOLEANRESULT(.DIFFERENCE.,#16751,#16753);
#16755= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#16754));
#16756= IFCPRODUCTDEFINITIONSHAPE($,$,(#16755));
#16757= IFCBEAM('1Td1iR001vsZ4rDp0rCJ4s',#5,'DIKME','T270-16-16-110','T270-16-16-110',#16747,#16756,'P/319(?)');
#16758= IFCCARTESIANPOINT((44189.9926804692,-589.170000077483,15745.));
#16759= IFCAXIS2PLACEMENT3D(#16758,#501,#596);
#16760= IFCLOCALPLACEMENT(#15518,#16759);
#16761= IFCPLANE(#16658);
#16762= IFCHALFSPACESOLID(#16761,.F.);
#16763= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#13033,#16762);
#16764= IFCPLANE(#16589);
#16765= IFCHALFSPACESOLID(#16764,.F.);
#16766= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#16763,#16765);
#16767= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#16766));
#16768= IFCPRODUCTDEFINITIONSHAPE($,$,(#16767));
#16769= IFCBEAM('1Td1iR001vu34rDp0rCJ4s',#5,'DIKME','T200-16-20-110','T200-16-20-110',#16760,#16768,'P/316(?)');
#16770= IFCCARTESIANPOINT((43379.9926804692,-589.170000077483,10545.));
#16771= IFCAXIS2PLACEMENT3D(#16770,#501,#596);
#16772= IFCLOCALPLACEMENT(#15542,#16771);
#16773= IFCPLANE(#16584);
#16774= IFCHALFSPACESOLID(#16773,.F.);
#16775= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#16582,#16774);
#16776= IFCPLANE(#16589);
#16777= IFCHALFSPACESOLID(#16776,.F.);
#16778= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#16775,#16777);
#16779= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#16778));
#16780= IFCPRODUCTDEFINITIONSHAPE($,$,(#16779));
#16781= IFCBEAM('1Td1iR001vvZ4rDp0rCJ4s',#5,'DIKME','T200-16-20-110','T200-16-20-110',#16772,#16780,'P/315(?)');
#16782= IFCCARTESIANPOINT((43365.,-229.17117837134,20199.9974118494));
#16783= IFCAXIS2PLACEMENT3D(#16782,#185,#596);
#16784= IFCLOCALPLACEMENT(#15570,#16783);
#16785= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#13077));
#16786= IFCPRODUCTDEFINITIONSHAPE($,$,(#16785));
#16787= IFCPLATE('1Td1iR001vwZ4rDp0rCJ4s',#5,'ANKRAJ','PL10*250','PL10*250',#16784,#16786,'P/221(?)');
#16788= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/221(?)'),$);
#16789= IFCPROPERTYSET('373KE9dY9F2xr424ui9t0A',#5,'Tekla Common','Common Properties to Shared building elements',(#13083,#12072,#16788,#15580,#74,#75,#919,#12966,#78,#13085,#80));
#16790= IFCCARTESIANPOINT((43379.9926804692,-554.170000077483,20200.));
#16791= IFCAXIS2PLACEMENT3D(#16790,#501,#596);
#16792= IFCLOCALPLACEMENT(#15558,#16791);
#16793= IFCBOOLEANRESULT(.DIFFERENCE.,#13112,#16628);
#16794= IFCPLANE(#16631);
#16795= IFCHALFSPACESOLID(#16794,.F.);
#16796= IFCBOOLEANRESULT(.DIFFERENCE.,#16793,#16795);
#16797= IFCPLANE(#16636);
#16798= IFCHALFSPACESOLID(#16797,.F.);
#16799= IFCBOOLEANRESULT(.DIFFERENCE.,#16796,#16798);
#16800= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#16799));
#16801= IFCPRODUCTDEFINITIONSHAPE($,$,(#16800));
#16802= IFCBEAM('1Td1iR001vyp4rDp0rCJ4s',#5,'DIKME','T270-16-16-110','T270-16-16-110',#16792,#16801,'P/318(?)');
#16803= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/318(?)'),$);
#16804= IFCPROPERTYSET('2EJNmF5FD5YwMzVByXbq49',#5,'Tekla Common','Common Properties to Shared building elements',(#1598,#13141,#16803,#15568,#74,#75,#919,#13143,#78,#13144,#4048));
#16805= IFCCARTESIANPOINT((43379.9926804692,-589.170000077483,15745.));
#16806= IFCAXIS2PLACEMENT3D(#16805,#501,#596);
#16807= IFCLOCALPLACEMENT(#15550,#16806);
#16808= IFCPLANE(#16658);
#16809= IFCHALFSPACESOLID(#16808,.F.);
#16810= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#13033,#16809);
#16811= IFCPLANE(#16589);
#16812= IFCHALFSPACESOLID(#16811,.F.);
#16813= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#16810,#16812);
#16814= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#16813));
#16815= IFCPRODUCTDEFINITIONSHAPE($,$,(#16814));
#16816= IFCBEAM('1Td1iR001v_J4rDp0rCJ4s',#5,'DIKME','T200-16-20-110','T200-16-20-110',#16807,#16815,'P/316(?)');
#16817= IFCCARTESIANPOINT((40949.9926804692,-589.170000077483,10545.));
#16818= IFCAXIS2PLACEMENT3D(#16817,#501,#596);
#16819= IFCLOCALPLACEMENT(#15582,#16818);
#16820= IFCPLANE(#16584);
#16821= IFCHALFSPACESOLID(#16820,.F.);
#16822= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#16582,#16821);
#16823= IFCPLANE(#16589);
#16824= IFCHALFSPACESOLID(#16823,.F.);
#16825= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#16822,#16824);
#16826= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#16825));
#16827= IFCPRODUCTDEFINITIONSHAPE($,$,(#16826));
#16828= IFCBEAM('1Td1iR001v$p4rDp0rCJ4s',#5,'DIKME','T200-16-20-110','T200-16-20-110',#16819,#16827,'P/315(?)');
#16829= IFCPROPERTYSET('3Tp0Xj9e14tvlJar2J5IgI',#5,'Tekla Common','Common Properties to Shared building elements',(#2156,#9972,#16597,#15593,#74,#75,#919,#5256,#78,#13048,#4048));
#16830= IFCCARTESIANPOINT((40935.,-229.17117837134,20199.9974118494));
#16831= IFCAXIS2PLACEMENT3D(#16830,#185,#596);
#16832= IFCLOCALPLACEMENT(#15620,#16831);
#16833= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#13077));
#16834= IFCPRODUCTDEFINITIONSHAPE($,$,(#16833));
#16835= IFCPLATE('1Td1iR001w0p4rDp0rCJ4s',#5,'ANKRAJ','PL10*250','PL10*250',#16832,#16834,'P/224(?)');
#16836= IFCCARTESIANPOINT((40949.9926804692,-554.170000077483,20200.));
#16837= IFCAXIS2PLACEMENT3D(#16836,#501,#596);
#16838= IFCLOCALPLACEMENT(#15607,#16837);
#16839= IFCBOOLEANRESULT(.DIFFERENCE.,#13112,#16628);
#16840= IFCPLANE(#16631);
#16841= IFCHALFSPACESOLID(#16840,.F.);
#16842= IFCBOOLEANRESULT(.DIFFERENCE.,#16839,#16841);
#16843= IFCPLANE(#16636);
#16844= IFCHALFSPACESOLID(#16843,.F.);
#16845= IFCBOOLEANRESULT(.DIFFERENCE.,#16842,#16844);
#16846= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#16845));
#16847= IFCPRODUCTDEFINITIONSHAPE($,$,(#16846));
#16848= IFCBEAM('1Td1iR001w334rDp0rCJ4s',#5,'DIKME','T270-16-16-110','T270-16-16-110',#16838,#16847,'P/319(?)');
#16849= IFCPROPERTYSET('3ZNqGYhyr6Y9gn8_YJz7ly',#5,'Tekla Common','Common Properties to Shared building elements',(#1598,#13141,#13142,#15618,#74,#75,#919,#13143,#78,#13144,#4048));
#16850= IFCCARTESIANPOINT((40949.9926804692,-589.170000077483,15745.));
#16851= IFCAXIS2PLACEMENT3D(#16850,#501,#596);
#16852= IFCLOCALPLACEMENT(#15595,#16851);
#16853= IFCPLANE(#16658);
#16854= IFCHALFSPACESOLID(#16853,.F.);
#16855= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#13033,#16854);
#16856= IFCPLANE(#16589);
#16857= IFCHALFSPACESOLID(#16856,.F.);
#16858= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#16855,#16857);
#16859= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#16858));
#16860= IFCPRODUCTDEFINITIONSHAPE($,$,(#16859));
#16861= IFCBEAM('1Td1iR001w4Z4rDp0rCJ4s',#5,'DIKME','T200-16-20-110','T200-16-20-110',#16852,#16860,'P/316(?)');
#16862= IFCPROPERTYSET('3g1FZgmP53Dx9c0yaao2F5',#5,'Tekla Common','Common Properties to Shared building elements',(#2019,#12182,#13047,#15605,#74,#75,#919,#5256,#78,#13048,#4048));
#16863= IFCCARTESIANPOINT((46619.9926804684,-589.170000077091,4845.));
#16864= IFCAXIS2PLACEMENT3D(#16863,#501,#596);
#16865= IFCLOCALPLACEMENT(#15641,#16864);
#16866= IFCCARTESIANPOINT((6000.,0.,0.));
#16867= IFCAXIS2PLACEMENT3D(#16866,#185,#501);
#16868= IFCEXTRUDEDAREASOLID(#12988,#16867,#9,6000.);
#16869= IFCCARTESIANPOINT((5939.004,60.0000000001019,-220.00000001713));
#16870= IFCAXIS2PLACEMENT3D(#16869,#7,#501);
#16871= IFCPLANE(#16870);
#16872= IFCHALFSPACESOLID(#16871,.F.);
#16873= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#16868,#16872);
#16874= IFCPLANE(#9821);
#16875= IFCHALFSPACESOLID(#16874,.F.);
#16876= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#16873,#16875);
#16877= IFCPLANE(#16870);
#16878= IFCHALFSPACESOLID(#16877,.F.);
#16879= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#16876,#16878);
#16880= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#16879));
#16881= IFCSTYLEDITEM(#16868,(#499),$);
#16882= IFCPRODUCTDEFINITIONSHAPE($,$,(#16880));
#16883= IFCBEAM('1Td1iR001w6J4rDp0rCJ4s',#5,'DIKME','T200-20-20-110','T200-20-20-110',#16865,#16882,'P/285(?)');
#16884= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('P/285(?)'),$);
#16885= IFCPROPERTYSET('3t1$ri9WDBFA4KC3db2oEv',#5,'Tekla Common','Common Properties to Shared building elements',(#510,#10036,#16884,#15652,#74,#75,#919,#515,#78,#13008,#4048));
#16886= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(268.35400212),$);
#16887= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(273.18),$);
#16888= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(268.35400212),$);
#16889= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.0341852232),$);
#16890= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.0348),$);
#16891= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.0341852232),$);
#16892= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(13.6606216081723),$);
#16893= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(3.66588248),$);
#16894= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(3.7316),$);
#16895= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(5894.004),$);
#16896= IFCPROPERTYSET('1ryd0zRV1ElhzKX5BhT4v0',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#15654,#16886,#16887,#16888,#16889,#16890,#16891,#13016,#16892,#16893,#16894,#9843,#9844,#16895));
#16897= IFCQUANTITYLENGTH('Length',$,$,5894.004);
#16898= IFCQUANTITYAREA('OuterSurfaceArea',$,$,3.66588248);
#16899= IFCQUANTITYVOLUME('NetVolume',$,$,0.0341852232);
#16900= IFCQUANTITYWEIGHT('NetWeight',$,$,268.35400212);
#16901= IFCELEMENTQUANTITY('3ViatmfG1CogrwqgIGCAaK',#5,'BaseQuantities',$,$,(#16897,#16898,#16899,#16900));
#16902= IFCCARTESIANPOINT((44999.9926804684,-589.170000077091,4845.));
#16903= IFCAXIS2PLACEMENT3D(#16902,#501,#596);
#16904= IFCLOCALPLACEMENT(#15661,#16903);
#16905= IFCPLANE(#16870);
#16906= IFCHALFSPACESOLID(#16905,.F.);
#16907= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#16868,#16906);
#16908= IFCPLANE(#9821);
#16909= IFCHALFSPACESOLID(#16908,.F.);
#16910= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#16907,#16909);
#16911= IFCPLANE(#16870);
#16912= IFCHALFSPACESOLID(#16911,.F.);
#16913= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#16910,#16912);
#16914= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#16913));
#16915= IFCPRODUCTDEFINITIONSHAPE($,$,(#16914));
#16916= IFCBEAM('1Td1iR001w834rDp0rCJ4s',#5,'DIKME','T200-20-20-110','T200-20-20-110',#16904,#16915,'P/285(?)');
#16917= IFCCARTESIANPOINT((44189.9926804684,-589.170000077091,4845.));
#16918= IFCAXIS2PLACEMENT3D(#16917,#501,#596);
#16919= IFCLOCALPLACEMENT(#15669,#16918);
#16920= IFCPLANE(#16870);
#16921= IFCHALFSPACESOLID(#16920,.F.);
#16922= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#16868,#16921);
#16923= IFCPLANE(#9821);
#16924= IFCHALFSPACESOLID(#16923,.F.);
#16925= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#16922,#16924);
#16926= IFCPLANE(#16870);
#16927= IFCHALFSPACESOLID(#16926,.F.);
#16928= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#16925,#16927);
#16929= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#16928));
#16930= IFCPRODUCTDEFINITIONSHAPE($,$,(#16929));
#16931= IFCBEAM('1Td1iR001w9p4rDp0rCJ4s',#5,'DIKME','T200-20-20-110','T200-20-20-110',#16919,#16930,'P/285(?)');
#16932= IFCCARTESIANPOINT((43379.9926804684,-589.170000077091,4845.));
#16933= IFCAXIS2PLACEMENT3D(#16932,#501,#596);
#16934= IFCLOCALPLACEMENT(#15677,#16933);
#16935= IFCPLANE(#16870);
#16936= IFCHALFSPACESOLID(#16935,.F.);
#16937= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#16868,#16936);
#16938= IFCPLANE(#9821);
#16939= IFCHALFSPACESOLID(#16938,.F.);
#16940= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#16937,#16939);
#16941= IFCPLANE(#16870);
#16942= IFCHALFSPACESOLID(#16941,.F.);
#16943= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#16940,#16942);
#16944= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#16943));
#16945= IFCPRODUCTDEFINITIONSHAPE($,$,(#16944));
#16946= IFCBEAM('1Td1iR001wBZ4rDp0rCJ4s',#5,'DIKME','T200-20-20-110','T200-20-20-110',#16934,#16945,'P/285(?)');
#16947= IFCCARTESIANPOINT((40949.9926804684,-589.170000077091,4845.));
#16948= IFCAXIS2PLACEMENT3D(#16947,#501,#596);
#16949= IFCLOCALPLACEMENT(#15685,#16948);
#16950= IFCPLANE(#16870);
#16951= IFCHALFSPACESOLID(#16950,.F.);
#16952= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#16868,#16951);
#16953= IFCPLANE(#9821);
#16954= IFCHALFSPACESOLID(#16953,.F.);
#16955= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#16952,#16954);
#16956= IFCPLANE(#16870);
#16957= IFCHALFSPACESOLID(#16956,.F.);
#16958= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#16955,#16957);
#16959= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#16958));
#16960= IFCPRODUCTDEFINITIONSHAPE($,$,(#16959));
#16961= IFCBEAM('1Td1iR001wDJ4rDp0rCJ4s',#5,'DIKME','T200-20-20-110','T200-20-20-110',#16949,#16960,'P/285(?)');
#16962= IFCPROPERTYSET('2Q4fLy1UP7hRlLbVvfcVPM',#5,'Tekla Common','Common Properties to Shared building elements',(#510,#10036,#16884,#15695,#74,#75,#919,#515,#78,#13008,#4048));
#16963= IFCLOCALPLACEMENT(#30,#10);
#16964= IFCELEMENTASSEMBLY('1Td1iR001wIZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#16963,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#16965= IFCPROPERTYSET('0bXswKLbz6twZP3Vj99DZ1',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#9228,#9229,#1775,#488,#1701));
#16966= IFCCARTESIANPOINT((46509.9926804692,-581.666086793292,-7661.00372056646));
#16967= IFCAXIS2PLACEMENT3D(#16966,#9232,#9233);
#16968= IFCLOCALPLACEMENT(#16963,#16967);
#16969= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9236));
#16970= IFCPRODUCTDEFINITIONSHAPE($,$,(#16969));
#16971= IFCBEAM('1Td1iR001wIJ4rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#16968,#16970,'XX/0(?)');
#16972= IFCQUANTITYLENGTH('Length',$,$,4.00000000138061);
#16973= IFCQUANTITYVOLUME('NetVolume',$,$,3.93300000135618E-006);
#16974= IFCELEMENTQUANTITY('0uKH3dHnjEbRuyjSDfTI2X',#5,'BaseQuantities',$,$,(#16972,#9247,#16973,#1754));
#16975= IFCLOCALPLACEMENT(#30,#10);
#16976= IFCELEMENTASSEMBLY('1Td1iR001wJZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#16975,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#16977= IFCPROPERTYSET('2csbupoz9FMP5f4qGmuHkL',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#9252,#4550,#137,#488,#1701));
#16978= IFCCARTESIANPOINT((46509.9926804692,-581.663086793291,-7700.00372056646));
#16979= IFCAXIS2PLACEMENT3D(#16978,#9255,#9256);
#16980= IFCLOCALPLACEMENT(#16975,#16979);
#16981= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#16982= IFCPRODUCTDEFINITIONSHAPE($,$,(#16981));
#16983= IFCBEAM('1Td1iR001wJJ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#16980,#16982,'XX/0(?)');
#16984= IFCLOCALPLACEMENT(#30,#10);
#16985= IFCELEMENTASSEMBLY('1Td1iR001wKZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#16984,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#16986= IFCPROPERTYSET('04bs7wM$DDy92PWzvNg85a',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#9273,#9274,#137,#488,#1701));
#16987= IFCCARTESIANPOINT((46509.9926804692,-581.666086793292,-7629.00372056646));
#16988= IFCAXIS2PLACEMENT3D(#16987,#9255,#9256);
#16989= IFCLOCALPLACEMENT(#16984,#16988);
#16990= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#16991= IFCPRODUCTDEFINITIONSHAPE($,$,(#16990));
#16992= IFCBEAM('1Td1iR001wKJ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#16989,#16991,'XX/0(?)');
#16993= IFCLOCALPLACEMENT(#30,#10);
#16994= IFCELEMENTASSEMBLY('1Td1iR001wLZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#16993,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#16995= IFCPROPERTYSET('3eFe3lk5jCTO0SC8o12EAW',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#9290,#9291,#137,#488,#1701));
#16996= IFCCARTESIANPOINT((46509.9926804692,-581.666086793292,-7645.00372056646));
#16997= IFCAXIS2PLACEMENT3D(#16996,#9255,#9256);
#16998= IFCLOCALPLACEMENT(#16993,#16997);
#16999= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17000= IFCPRODUCTDEFINITIONSHAPE($,$,(#16999));
#17001= IFCBEAM('1Td1iR001wLJ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#16998,#17000,'XX/0(?)');
#17002= IFCLOCALPLACEMENT(#30,#10);
#17003= IFCELEMENTASSEMBLY('1Td1iR001wMZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17002,$,'R/1(?)',.NOTDEFINED.,.RIGID_FRAME.);
#17004= IFCPROPERTYSET('3f7l_p$RXFHxLlehBEnqqT',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#9304,#9305,#137,#488,#8391));
#17005= IFCCARTESIANPOINT((46509.9926804692,-581.666103453154,-7615.0040758817));
#17006= IFCAXIS2PLACEMENT3D(#17005,#501,#596);
#17007= IFCLOCALPLACEMENT(#17002,#17006);
#17008= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9310));
#17009= IFCPRODUCTDEFINITIONSHAPE($,$,(#17008));
#17010= IFCBEAM('1Td1iR001wMJ4rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#17007,#17009,'P/487(?)');
#17011= IFCLOCALPLACEMENT(#30,#10);
#17012= IFCELEMENTASSEMBLY('1Td1iR001wNZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17011,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17013= IFCCARTESIANPOINT((46729.9926804692,-581.666086793292,-7661.00372056646));
#17014= IFCAXIS2PLACEMENT3D(#17013,#9232,#9233);
#17015= IFCLOCALPLACEMENT(#17011,#17014);
#17016= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9236));
#17017= IFCPRODUCTDEFINITIONSHAPE($,$,(#17016));
#17018= IFCBEAM('1Td1iR001wNJ4rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#17015,#17017,'XX/0(?)');
#17019= IFCLOCALPLACEMENT(#30,#10);
#17020= IFCELEMENTASSEMBLY('1Td1iR001wOZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17019,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17021= IFCCARTESIANPOINT((46729.9926804692,-581.663086793291,-7700.00372056646));
#17022= IFCAXIS2PLACEMENT3D(#17021,#9255,#9256);
#17023= IFCLOCALPLACEMENT(#17019,#17022);
#17024= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17025= IFCPRODUCTDEFINITIONSHAPE($,$,(#17024));
#17026= IFCBEAM('1Td1iR001wOJ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17023,#17025,'XX/0(?)');
#17027= IFCLOCALPLACEMENT(#30,#10);
#17028= IFCELEMENTASSEMBLY('1Td1iR001wPZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17027,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17029= IFCCARTESIANPOINT((46729.9926804692,-581.666086793292,-7629.00372056646));
#17030= IFCAXIS2PLACEMENT3D(#17029,#9255,#9256);
#17031= IFCLOCALPLACEMENT(#17027,#17030);
#17032= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17033= IFCPRODUCTDEFINITIONSHAPE($,$,(#17032));
#17034= IFCBEAM('1Td1iR001wPJ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17031,#17033,'XX/0(?)');
#17035= IFCLOCALPLACEMENT(#30,#10);
#17036= IFCELEMENTASSEMBLY('1Td1iR001wQZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17035,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17037= IFCCARTESIANPOINT((46729.9926804692,-581.666086793292,-7645.00372056646));
#17038= IFCAXIS2PLACEMENT3D(#17037,#9255,#9256);
#17039= IFCLOCALPLACEMENT(#17035,#17038);
#17040= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17041= IFCPRODUCTDEFINITIONSHAPE($,$,(#17040));
#17042= IFCBEAM('1Td1iR001wQJ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17039,#17041,'XX/0(?)');
#17043= IFCLOCALPLACEMENT(#30,#10);
#17044= IFCELEMENTASSEMBLY('1Td1iR001wRZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17043,$,'R/1(?)',.NOTDEFINED.,.RIGID_FRAME.);
#17045= IFCCARTESIANPOINT((46729.9926804692,-581.666103453154,-7615.0040758817));
#17046= IFCAXIS2PLACEMENT3D(#17045,#501,#596);
#17047= IFCLOCALPLACEMENT(#17043,#17046);
#17048= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9310));
#17049= IFCPRODUCTDEFINITIONSHAPE($,$,(#17048));
#17050= IFCBEAM('1Td1iR001wRJ4rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#17047,#17049,'P/487(?)');
#17051= IFCCARTESIANPOINT((46619.9926804692,-474.170105357636,-7690.00389468441));
#17052= IFCAXIS2PLACEMENT3D(#17051,#185,#501);
#17053= IFCLOCALPLACEMENT(#11311,#17052);
#17054= IFCEXTRUDEDAREASOLID(#9374,#8647,#9,214.996968697051);
#17055= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#17054));
#17056= IFCSTYLEDITEM(#17054,(#53),$);
#17057= IFCPRODUCTDEFINITIONSHAPE($,$,(#17055));
#17058= IFCBEAM('1Td1iR001wSJ4rDp0rCJ4s',#5,'ANKRAJ','PLT20*410','PLT20*410',#17053,#17057,'P/380(?)');
#17059= IFCPROPERTYSET('0p_ESMHTLE79cbyvHUjS6d',#5,'Tekla Common','Common Properties to Shared building elements',(#9381,#9382,#8655,#11335,#74,#75,#919,#1194,#78,#9383,#80));
#17060= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(13.8393548750315),$);
#17061= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(13.8393548750315),$);
#17062= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.00176297514331611),$);
#17063= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.00176297514331611),$);
#17064= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.00176297514331611),$);
#17065= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.201297393079469),$);
#17066= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.201297393079469),$);
#17067= IFCPROPERTYSET('1dtEE54WH3uQDAU58oi_Lz',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#11337,#17060,#9386,#17061,#17062,#17063,#17064,#9391,#9392,#17065,#17066,#9395,#5269,#9396));
#17068= IFCQUANTITYLENGTH('Length',$,$,214.996968697058);
#17069= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.201297393079469);
#17070= IFCQUANTITYVOLUME('NetVolume',$,$,0.00176297514331611);
#17071= IFCQUANTITYWEIGHT('NetWeight',$,$,13.8393548750315);
#17072= IFCELEMENTQUANTITY('23V9CHem9B$Pg5RHJYMswi',#5,'BaseQuantities',$,$,(#17068,#17069,#17070,#17071));
#17073= IFCLOCALPLACEMENT(#30,#10);
#17074= IFCELEMENTASSEMBLY('1Td1iR001wTZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17073,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17075= IFCCARTESIANPOINT((44889.9926804692,-581.666086793292,-7661.00372056646));
#17076= IFCAXIS2PLACEMENT3D(#17075,#9232,#9233);
#17077= IFCLOCALPLACEMENT(#17073,#17076);
#17078= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9236));
#17079= IFCPRODUCTDEFINITIONSHAPE($,$,(#17078));
#17080= IFCBEAM('1Td1iR001wTJ4rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#17077,#17079,'XX/0(?)');
#17081= IFCLOCALPLACEMENT(#30,#10);
#17082= IFCELEMENTASSEMBLY('1Td1iR001wUZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17081,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17083= IFCCARTESIANPOINT((44889.9926804692,-581.663086793291,-7700.00372056646));
#17084= IFCAXIS2PLACEMENT3D(#17083,#9255,#9256);
#17085= IFCLOCALPLACEMENT(#17081,#17084);
#17086= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17087= IFCPRODUCTDEFINITIONSHAPE($,$,(#17086));
#17088= IFCBEAM('1Td1iR001wUJ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17085,#17087,'XX/0(?)');
#17089= IFCLOCALPLACEMENT(#30,#10);
#17090= IFCELEMENTASSEMBLY('1Td1iR001wVZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17089,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17091= IFCCARTESIANPOINT((44889.9926804692,-581.666086793292,-7629.00372056646));
#17092= IFCAXIS2PLACEMENT3D(#17091,#9255,#9256);
#17093= IFCLOCALPLACEMENT(#17089,#17092);
#17094= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17095= IFCPRODUCTDEFINITIONSHAPE($,$,(#17094));
#17096= IFCBEAM('1Td1iR001wVJ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17093,#17095,'XX/0(?)');
#17097= IFCLOCALPLACEMENT(#30,#10);
#17098= IFCELEMENTASSEMBLY('1Td1iR001wWZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17097,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17099= IFCCARTESIANPOINT((44889.9926804692,-581.666086793292,-7645.00372056646));
#17100= IFCAXIS2PLACEMENT3D(#17099,#9255,#9256);
#17101= IFCLOCALPLACEMENT(#17097,#17100);
#17102= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17103= IFCPRODUCTDEFINITIONSHAPE($,$,(#17102));
#17104= IFCBEAM('1Td1iR001wWJ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17101,#17103,'XX/0(?)');
#17105= IFCLOCALPLACEMENT(#30,#10);
#17106= IFCELEMENTASSEMBLY('1Td1iR001wXZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17105,$,'R/1(?)',.NOTDEFINED.,.RIGID_FRAME.);
#17107= IFCCARTESIANPOINT((44889.9926804692,-581.666103453154,-7615.0040758817));
#17108= IFCAXIS2PLACEMENT3D(#17107,#501,#596);
#17109= IFCLOCALPLACEMENT(#17105,#17108);
#17110= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9310));
#17111= IFCPRODUCTDEFINITIONSHAPE($,$,(#17110));
#17112= IFCBEAM('1Td1iR001wXJ4rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#17109,#17111,'P/487(?)');
#17113= IFCLOCALPLACEMENT(#30,#10);
#17114= IFCELEMENTASSEMBLY('1Td1iR001wYZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17113,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17115= IFCCARTESIANPOINT((45109.9926804692,-581.666086793292,-7661.00372056646));
#17116= IFCAXIS2PLACEMENT3D(#17115,#9232,#9233);
#17117= IFCLOCALPLACEMENT(#17113,#17116);
#17118= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9236));
#17119= IFCPRODUCTDEFINITIONSHAPE($,$,(#17118));
#17120= IFCBEAM('1Td1iR001wYJ4rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#17117,#17119,'XX/0(?)');
#17121= IFCLOCALPLACEMENT(#30,#10);
#17122= IFCELEMENTASSEMBLY('1Td1iR001wZZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17121,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17123= IFCCARTESIANPOINT((45109.9926804692,-581.663086793291,-7700.00372056646));
#17124= IFCAXIS2PLACEMENT3D(#17123,#9255,#9256);
#17125= IFCLOCALPLACEMENT(#17121,#17124);
#17126= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17127= IFCPRODUCTDEFINITIONSHAPE($,$,(#17126));
#17128= IFCBEAM('1Td1iR001wZJ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17125,#17127,'XX/0(?)');
#17129= IFCLOCALPLACEMENT(#30,#10);
#17130= IFCELEMENTASSEMBLY('1Td1iR001waZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17129,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17131= IFCCARTESIANPOINT((45109.9926804692,-581.666086793292,-7629.00372056646));
#17132= IFCAXIS2PLACEMENT3D(#17131,#9255,#9256);
#17133= IFCLOCALPLACEMENT(#17129,#17132);
#17134= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17135= IFCPRODUCTDEFINITIONSHAPE($,$,(#17134));
#17136= IFCBEAM('1Td1iR001waJ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17133,#17135,'XX/0(?)');
#17137= IFCLOCALPLACEMENT(#30,#10);
#17138= IFCELEMENTASSEMBLY('1Td1iR001wbZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17137,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17139= IFCCARTESIANPOINT((45109.9926804692,-581.666086793292,-7645.00372056646));
#17140= IFCAXIS2PLACEMENT3D(#17139,#9255,#9256);
#17141= IFCLOCALPLACEMENT(#17137,#17140);
#17142= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17143= IFCPRODUCTDEFINITIONSHAPE($,$,(#17142));
#17144= IFCBEAM('1Td1iR001wbJ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17141,#17143,'XX/0(?)');
#17145= IFCLOCALPLACEMENT(#30,#10);
#17146= IFCELEMENTASSEMBLY('1Td1iR001wcZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17145,$,'R/1(?)',.NOTDEFINED.,.RIGID_FRAME.);
#17147= IFCCARTESIANPOINT((45109.9926804692,-581.666103453154,-7615.0040758817));
#17148= IFCAXIS2PLACEMENT3D(#17147,#501,#596);
#17149= IFCLOCALPLACEMENT(#17145,#17148);
#17150= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9310));
#17151= IFCPRODUCTDEFINITIONSHAPE($,$,(#17150));
#17152= IFCBEAM('1Td1iR001wcJ4rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#17149,#17151,'P/487(?)');
#17153= IFCCARTESIANPOINT((44999.9926804692,-474.170105357636,-7690.00389468441));
#17154= IFCAXIS2PLACEMENT3D(#17153,#185,#501);
#17155= IFCLOCALPLACEMENT(#15080,#17154);
#17156= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#17054));
#17157= IFCPRODUCTDEFINITIONSHAPE($,$,(#17156));
#17158= IFCBEAM('1Td1iR001wdJ4rDp0rCJ4s',#5,'ANKRAJ','PLT20*410','PLT20*410',#17155,#17157,'P/380(?)');
#17159= IFCLOCALPLACEMENT(#30,#10);
#17160= IFCELEMENTASSEMBLY('1Td1iR001weZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17159,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17161= IFCCARTESIANPOINT((44079.9926804692,-581.666086793292,-7661.00372056646));
#17162= IFCAXIS2PLACEMENT3D(#17161,#9232,#9233);
#17163= IFCLOCALPLACEMENT(#17159,#17162);
#17164= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9236));
#17165= IFCPRODUCTDEFINITIONSHAPE($,$,(#17164));
#17166= IFCBEAM('1Td1iR001weJ4rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#17163,#17165,'XX/0(?)');
#17167= IFCLOCALPLACEMENT(#30,#10);
#17168= IFCELEMENTASSEMBLY('1Td1iR001wfZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17167,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17169= IFCCARTESIANPOINT((44079.9926804692,-581.663086793291,-7700.00372056646));
#17170= IFCAXIS2PLACEMENT3D(#17169,#9255,#9256);
#17171= IFCLOCALPLACEMENT(#17167,#17170);
#17172= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17173= IFCPRODUCTDEFINITIONSHAPE($,$,(#17172));
#17174= IFCBEAM('1Td1iR001wfJ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17171,#17173,'XX/0(?)');
#17175= IFCLOCALPLACEMENT(#30,#10);
#17176= IFCELEMENTASSEMBLY('1Td1iR001wgZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17175,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17177= IFCCARTESIANPOINT((44079.9926804692,-581.666086793292,-7629.00372056646));
#17178= IFCAXIS2PLACEMENT3D(#17177,#9255,#9256);
#17179= IFCLOCALPLACEMENT(#17175,#17178);
#17180= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17181= IFCPRODUCTDEFINITIONSHAPE($,$,(#17180));
#17182= IFCBEAM('1Td1iR001wgJ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17179,#17181,'XX/0(?)');
#17183= IFCLOCALPLACEMENT(#30,#10);
#17184= IFCELEMENTASSEMBLY('1Td1iR001whZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17183,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17185= IFCCARTESIANPOINT((44079.9926804692,-581.666086793292,-7645.00372056646));
#17186= IFCAXIS2PLACEMENT3D(#17185,#9255,#9256);
#17187= IFCLOCALPLACEMENT(#17183,#17186);
#17188= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17189= IFCPRODUCTDEFINITIONSHAPE($,$,(#17188));
#17190= IFCBEAM('1Td1iR001whJ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17187,#17189,'XX/0(?)');
#17191= IFCLOCALPLACEMENT(#30,#10);
#17192= IFCELEMENTASSEMBLY('1Td1iR001wiZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17191,$,'R/1(?)',.NOTDEFINED.,.RIGID_FRAME.);
#17193= IFCCARTESIANPOINT((44079.9926804692,-581.666103453154,-7615.0040758817));
#17194= IFCAXIS2PLACEMENT3D(#17193,#501,#596);
#17195= IFCLOCALPLACEMENT(#17191,#17194);
#17196= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9310));
#17197= IFCPRODUCTDEFINITIONSHAPE($,$,(#17196));
#17198= IFCBEAM('1Td1iR001wiJ4rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#17195,#17197,'P/487(?)');
#17199= IFCLOCALPLACEMENT(#30,#10);
#17200= IFCELEMENTASSEMBLY('1Td1iR001wjZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17199,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17201= IFCCARTESIANPOINT((44299.9926804692,-581.666086793292,-7661.00372056646));
#17202= IFCAXIS2PLACEMENT3D(#17201,#9232,#9233);
#17203= IFCLOCALPLACEMENT(#17199,#17202);
#17204= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9236));
#17205= IFCPRODUCTDEFINITIONSHAPE($,$,(#17204));
#17206= IFCBEAM('1Td1iR001wjJ4rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#17203,#17205,'XX/0(?)');
#17207= IFCLOCALPLACEMENT(#30,#10);
#17208= IFCELEMENTASSEMBLY('1Td1iR001wkZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17207,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17209= IFCCARTESIANPOINT((44299.9926804692,-581.663086793291,-7700.00372056646));
#17210= IFCAXIS2PLACEMENT3D(#17209,#9255,#9256);
#17211= IFCLOCALPLACEMENT(#17207,#17210);
#17212= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17213= IFCPRODUCTDEFINITIONSHAPE($,$,(#17212));
#17214= IFCBEAM('1Td1iR001wkJ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17211,#17213,'XX/0(?)');
#17215= IFCLOCALPLACEMENT(#30,#10);
#17216= IFCELEMENTASSEMBLY('1Td1iR001wlZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17215,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17217= IFCCARTESIANPOINT((44299.9926804692,-581.666086793292,-7629.00372056646));
#17218= IFCAXIS2PLACEMENT3D(#17217,#9255,#9256);
#17219= IFCLOCALPLACEMENT(#17215,#17218);
#17220= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17221= IFCPRODUCTDEFINITIONSHAPE($,$,(#17220));
#17222= IFCBEAM('1Td1iR001wlJ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17219,#17221,'XX/0(?)');
#17223= IFCLOCALPLACEMENT(#30,#10);
#17224= IFCELEMENTASSEMBLY('1Td1iR001wmZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17223,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17225= IFCCARTESIANPOINT((44299.9926804692,-581.666086793292,-7645.00372056646));
#17226= IFCAXIS2PLACEMENT3D(#17225,#9255,#9256);
#17227= IFCLOCALPLACEMENT(#17223,#17226);
#17228= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17229= IFCPRODUCTDEFINITIONSHAPE($,$,(#17228));
#17230= IFCBEAM('1Td1iR001wmJ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17227,#17229,'XX/0(?)');
#17231= IFCLOCALPLACEMENT(#30,#10);
#17232= IFCELEMENTASSEMBLY('1Td1iR001wnZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17231,$,'R/1(?)',.NOTDEFINED.,.RIGID_FRAME.);
#17233= IFCCARTESIANPOINT((44299.9926804692,-581.666103453154,-7615.0040758817));
#17234= IFCAXIS2PLACEMENT3D(#17233,#501,#596);
#17235= IFCLOCALPLACEMENT(#17231,#17234);
#17236= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9310));
#17237= IFCPRODUCTDEFINITIONSHAPE($,$,(#17236));
#17238= IFCBEAM('1Td1iR001wnJ4rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#17235,#17237,'P/487(?)');
#17239= IFCCARTESIANPOINT((44189.9926804692,-474.170105357636,-7690.00389468441));
#17240= IFCAXIS2PLACEMENT3D(#17239,#185,#501);
#17241= IFCLOCALPLACEMENT(#15159,#17240);
#17242= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#17054));
#17243= IFCPRODUCTDEFINITIONSHAPE($,$,(#17242));
#17244= IFCBEAM('1Td1iR001woJ4rDp0rCJ4s',#5,'ANKRAJ','PLT20*410','PLT20*410',#17241,#17243,'P/380(?)');
#17245= IFCLOCALPLACEMENT(#30,#10);
#17246= IFCELEMENTASSEMBLY('1Td1iR001wpZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17245,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17247= IFCCARTESIANPOINT((43269.9926804692,-581.666086793292,-7661.00372056646));
#17248= IFCAXIS2PLACEMENT3D(#17247,#9232,#9233);
#17249= IFCLOCALPLACEMENT(#17245,#17248);
#17250= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9236));
#17251= IFCPRODUCTDEFINITIONSHAPE($,$,(#17250));
#17252= IFCBEAM('1Td1iR001wpJ4rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#17249,#17251,'XX/0(?)');
#17253= IFCLOCALPLACEMENT(#30,#10);
#17254= IFCELEMENTASSEMBLY('1Td1iR001wqZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17253,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17255= IFCCARTESIANPOINT((43269.9926804692,-581.663086793291,-7700.00372056646));
#17256= IFCAXIS2PLACEMENT3D(#17255,#9255,#9256);
#17257= IFCLOCALPLACEMENT(#17253,#17256);
#17258= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17259= IFCPRODUCTDEFINITIONSHAPE($,$,(#17258));
#17260= IFCBEAM('1Td1iR001wqJ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17257,#17259,'XX/0(?)');
#17261= IFCLOCALPLACEMENT(#30,#10);
#17262= IFCELEMENTASSEMBLY('1Td1iR001wrZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17261,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17263= IFCCARTESIANPOINT((43269.9926804692,-581.666086793292,-7629.00372056646));
#17264= IFCAXIS2PLACEMENT3D(#17263,#9255,#9256);
#17265= IFCLOCALPLACEMENT(#17261,#17264);
#17266= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17267= IFCPRODUCTDEFINITIONSHAPE($,$,(#17266));
#17268= IFCBEAM('1Td1iR001wrJ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17265,#17267,'XX/0(?)');
#17269= IFCLOCALPLACEMENT(#30,#10);
#17270= IFCELEMENTASSEMBLY('1Td1iR001wsZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17269,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17271= IFCCARTESIANPOINT((43269.9926804692,-581.666086793292,-7645.00372056646));
#17272= IFCAXIS2PLACEMENT3D(#17271,#9255,#9256);
#17273= IFCLOCALPLACEMENT(#17269,#17272);
#17274= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17275= IFCPRODUCTDEFINITIONSHAPE($,$,(#17274));
#17276= IFCBEAM('1Td1iR001wsJ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17273,#17275,'XX/0(?)');
#17277= IFCLOCALPLACEMENT(#30,#10);
#17278= IFCELEMENTASSEMBLY('1Td1iR001wtZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17277,$,'R/1(?)',.NOTDEFINED.,.RIGID_FRAME.);
#17279= IFCCARTESIANPOINT((43269.9926804692,-581.666103453154,-7615.0040758817));
#17280= IFCAXIS2PLACEMENT3D(#17279,#501,#596);
#17281= IFCLOCALPLACEMENT(#17277,#17280);
#17282= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9310));
#17283= IFCPRODUCTDEFINITIONSHAPE($,$,(#17282));
#17284= IFCBEAM('1Td1iR001wtJ4rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#17281,#17283,'P/487(?)');
#17285= IFCLOCALPLACEMENT(#30,#10);
#17286= IFCELEMENTASSEMBLY('1Td1iR001wuZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17285,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17287= IFCCARTESIANPOINT((43489.9926804692,-581.666086793292,-7661.00372056646));
#17288= IFCAXIS2PLACEMENT3D(#17287,#9232,#9233);
#17289= IFCLOCALPLACEMENT(#17285,#17288);
#17290= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9236));
#17291= IFCPRODUCTDEFINITIONSHAPE($,$,(#17290));
#17292= IFCBEAM('1Td1iR001wuJ4rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#17289,#17291,'XX/0(?)');
#17293= IFCLOCALPLACEMENT(#30,#10);
#17294= IFCELEMENTASSEMBLY('1Td1iR001wvZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17293,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17295= IFCCARTESIANPOINT((43489.9926804692,-581.663086793291,-7700.00372056646));
#17296= IFCAXIS2PLACEMENT3D(#17295,#9255,#9256);
#17297= IFCLOCALPLACEMENT(#17293,#17296);
#17298= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17299= IFCPRODUCTDEFINITIONSHAPE($,$,(#17298));
#17300= IFCBEAM('1Td1iR001wvJ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17297,#17299,'XX/0(?)');
#17301= IFCLOCALPLACEMENT(#30,#10);
#17302= IFCELEMENTASSEMBLY('1Td1iR001wwZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17301,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17303= IFCCARTESIANPOINT((43489.9926804692,-581.666086793292,-7629.00372056646));
#17304= IFCAXIS2PLACEMENT3D(#17303,#9255,#9256);
#17305= IFCLOCALPLACEMENT(#17301,#17304);
#17306= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17307= IFCPRODUCTDEFINITIONSHAPE($,$,(#17306));
#17308= IFCBEAM('1Td1iR001wwJ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17305,#17307,'XX/0(?)');
#17309= IFCLOCALPLACEMENT(#30,#10);
#17310= IFCELEMENTASSEMBLY('1Td1iR001wxZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17309,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17311= IFCCARTESIANPOINT((43489.9926804692,-581.666086793292,-7645.00372056646));
#17312= IFCAXIS2PLACEMENT3D(#17311,#9255,#9256);
#17313= IFCLOCALPLACEMENT(#17309,#17312);
#17314= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17315= IFCPRODUCTDEFINITIONSHAPE($,$,(#17314));
#17316= IFCBEAM('1Td1iR001wxJ4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17313,#17315,'XX/0(?)');
#17317= IFCLOCALPLACEMENT(#30,#10);
#17318= IFCELEMENTASSEMBLY('1Td1iR001wyZ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17317,$,'R/1(?)',.NOTDEFINED.,.RIGID_FRAME.);
#17319= IFCCARTESIANPOINT((43489.9926804692,-581.666103453154,-7615.0040758817));
#17320= IFCAXIS2PLACEMENT3D(#17319,#501,#596);
#17321= IFCLOCALPLACEMENT(#17317,#17320);
#17322= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9310));
#17323= IFCPRODUCTDEFINITIONSHAPE($,$,(#17322));
#17324= IFCBEAM('1Td1iR001wyJ4rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#17321,#17323,'P/487(?)');
#17325= IFCCARTESIANPOINT((43379.9926804692,-474.170105357636,-7690.00389468441));
#17326= IFCAXIS2PLACEMENT3D(#17325,#185,#501);
#17327= IFCLOCALPLACEMENT(#15206,#17326);
#17328= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#17054));
#17329= IFCPRODUCTDEFINITIONSHAPE($,$,(#17328));
#17330= IFCBEAM('1Td1iR001wzJ4rDp0rCJ4s',#5,'ANKRAJ','PLT20*410','PLT20*410',#17327,#17329,'P/380(?)');
#17331= IFCPROPERTYSET('0oabDQK314MBm1jG9fDg9l',#5,'Tekla Common','Common Properties to Shared building elements',(#9381,#9382,#8655,#15217,#74,#75,#919,#1194,#78,#9383,#80));
#17332= IFCPROPERTYSET('3ClEROlAL5lRsWtvo2boDe',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#15219,#17060,#9386,#17061,#17062,#17063,#17064,#9391,#9392,#17065,#17066,#9395,#5269,#9396));
#17333= IFCLOCALPLACEMENT(#30,#10);
#17334= IFCELEMENTASSEMBLY('1Td1iR001w_Z4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17333,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17335= IFCPROPERTYSET('1YMEW4pHXAruIqHZnw78oc',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#9228,#9229,#1775,#5873,#1701));
#17336= IFCCARTESIANPOINT((40839.9926804692,-581.666086793292,-7661.00372056646));
#17337= IFCAXIS2PLACEMENT3D(#17336,#9232,#9233);
#17338= IFCLOCALPLACEMENT(#17333,#17337);
#17339= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9236));
#17340= IFCPRODUCTDEFINITIONSHAPE($,$,(#17339));
#17341= IFCBEAM('1Td1iR001w_J4rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#17338,#17340,'XX/0(?)');
#17342= IFCLOCALPLACEMENT(#30,#10);
#17343= IFCELEMENTASSEMBLY('1Td1iR001w$Z4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17342,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17344= IFCPROPERTYSET('3k5993YnP5aeAm3YLOdZd7',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#9252,#4550,#137,#5873,#1701));
#17345= IFCCARTESIANPOINT((40839.9926804692,-581.663086793291,-7700.00372056646));
#17346= IFCAXIS2PLACEMENT3D(#17345,#9255,#9256);
#17347= IFCLOCALPLACEMENT(#17342,#17346);
#17348= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17349= IFCPRODUCTDEFINITIONSHAPE($,$,(#17348));
#17350= IFCBEAM('1Td1iR001w$J4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17347,#17349,'XX/0(?)');
#17351= IFCLOCALPLACEMENT(#30,#10);
#17352= IFCELEMENTASSEMBLY('1Td1iR001x0Z4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17351,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17353= IFCPROPERTYSET('2tS9n8szb05Ri2SGpiai9Q',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#9273,#9274,#137,#5873,#1701));
#17354= IFCCARTESIANPOINT((40839.9926804692,-581.666086793292,-7629.00372056646));
#17355= IFCAXIS2PLACEMENT3D(#17354,#9255,#9256);
#17356= IFCLOCALPLACEMENT(#17351,#17355);
#17357= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17358= IFCPRODUCTDEFINITIONSHAPE($,$,(#17357));
#17359= IFCBEAM('1Td1iR001x0J4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17356,#17358,'XX/0(?)');
#17360= IFCLOCALPLACEMENT(#30,#10);
#17361= IFCELEMENTASSEMBLY('1Td1iR001x1Z4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17360,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17362= IFCPROPERTYSET('1Mwtj$HXj7HQBQdQA7qSUp',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#9290,#9291,#137,#5873,#1701));
#17363= IFCCARTESIANPOINT((40839.9926804692,-581.666086793292,-7645.00372056646));
#17364= IFCAXIS2PLACEMENT3D(#17363,#9255,#9256);
#17365= IFCLOCALPLACEMENT(#17360,#17364);
#17366= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17367= IFCPRODUCTDEFINITIONSHAPE($,$,(#17366));
#17368= IFCBEAM('1Td1iR001x1J4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17365,#17367,'XX/0(?)');
#17369= IFCLOCALPLACEMENT(#30,#10);
#17370= IFCELEMENTASSEMBLY('1Td1iR001x2Z4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17369,$,'R/1(?)',.NOTDEFINED.,.RIGID_FRAME.);
#17371= IFCPROPERTYSET('19iC59p5j5UfY4uNzr_Xe6',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#9304,#9305,#137,#5873,#8391));
#17372= IFCCARTESIANPOINT((40839.9926804692,-581.666103453154,-7615.0040758817));
#17373= IFCAXIS2PLACEMENT3D(#17372,#501,#596);
#17374= IFCLOCALPLACEMENT(#17369,#17373);
#17375= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9310));
#17376= IFCPRODUCTDEFINITIONSHAPE($,$,(#17375));
#17377= IFCBEAM('1Td1iR001x2J4rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#17374,#17376,'P/487(?)');
#17378= IFCLOCALPLACEMENT(#30,#10);
#17379= IFCELEMENTASSEMBLY('1Td1iR001x3Z4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17378,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17380= IFCCARTESIANPOINT((41059.9926804692,-581.666086793292,-7661.00372056646));
#17381= IFCAXIS2PLACEMENT3D(#17380,#9232,#9233);
#17382= IFCLOCALPLACEMENT(#17378,#17381);
#17383= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9236));
#17384= IFCPRODUCTDEFINITIONSHAPE($,$,(#17383));
#17385= IFCBEAM('1Td1iR001x3J4rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#17382,#17384,'XX/0(?)');
#17386= IFCLOCALPLACEMENT(#30,#10);
#17387= IFCELEMENTASSEMBLY('1Td1iR001x4Z4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17386,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17388= IFCCARTESIANPOINT((41059.9926804692,-581.663086793291,-7700.00372056646));
#17389= IFCAXIS2PLACEMENT3D(#17388,#9255,#9256);
#17390= IFCLOCALPLACEMENT(#17386,#17389);
#17391= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17392= IFCPRODUCTDEFINITIONSHAPE($,$,(#17391));
#17393= IFCBEAM('1Td1iR001x4J4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17390,#17392,'XX/0(?)');
#17394= IFCLOCALPLACEMENT(#30,#10);
#17395= IFCELEMENTASSEMBLY('1Td1iR001x5Z4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17394,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17396= IFCCARTESIANPOINT((41059.9926804692,-581.666086793292,-7629.00372056646));
#17397= IFCAXIS2PLACEMENT3D(#17396,#9255,#9256);
#17398= IFCLOCALPLACEMENT(#17394,#17397);
#17399= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17400= IFCPRODUCTDEFINITIONSHAPE($,$,(#17399));
#17401= IFCBEAM('1Td1iR001x5J4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17398,#17400,'XX/0(?)');
#17402= IFCLOCALPLACEMENT(#30,#10);
#17403= IFCELEMENTASSEMBLY('1Td1iR001x6Z4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17402,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17404= IFCCARTESIANPOINT((41059.9926804692,-581.666086793292,-7645.00372056646));
#17405= IFCAXIS2PLACEMENT3D(#17404,#9255,#9256);
#17406= IFCLOCALPLACEMENT(#17402,#17405);
#17407= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17408= IFCPRODUCTDEFINITIONSHAPE($,$,(#17407));
#17409= IFCBEAM('1Td1iR001x6J4rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17406,#17408,'XX/0(?)');
#17410= IFCLOCALPLACEMENT(#30,#10);
#17411= IFCELEMENTASSEMBLY('1Td1iR001x7Z4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17410,$,'R/1(?)',.NOTDEFINED.,.RIGID_FRAME.);
#17412= IFCCARTESIANPOINT((41059.9926804692,-581.666103453154,-7615.0040758817));
#17413= IFCAXIS2PLACEMENT3D(#17412,#501,#596);
#17414= IFCLOCALPLACEMENT(#17410,#17413);
#17415= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9310));
#17416= IFCPRODUCTDEFINITIONSHAPE($,$,(#17415));
#17417= IFCBEAM('1Td1iR001x7J4rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#17414,#17416,'P/487(?)');
#17418= IFCCARTESIANPOINT((40949.9926804692,-474.170105357636,-7690.00389468441));
#17419= IFCAXIS2PLACEMENT3D(#17418,#185,#501);
#17420= IFCLOCALPLACEMENT(#15359,#17419);
#17421= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#17054));
#17422= IFCPRODUCTDEFINITIONSHAPE($,$,(#17421));
#17423= IFCBEAM('1Td1iR001x8J4rDp0rCJ4s',#5,'ANKRAJ','PLT20*410','PLT20*410',#17420,#17422,'P/380(?)');
#17424= IFCLOCALPLACEMENT(#30,#10);
#17425= IFCELEMENTASSEMBLY('1Td1iR001xA34rDp0rCJ4s',#5,'Steel Assembly',$,$,#17424,$,'B/164(?)',.NOTDEFINED.,.RIGID_FRAME.);
#17426= IFCPROPERTYSET('3g5FMTI6j3lghgPxahVHz4',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#16335,#8929,#8930,#4310,#5197,#8931));
#17427= IFCCARTESIANPOINT((39999.9962754006,-579.169652492433,-7191.));
#17428= IFCAXIS2PLACEMENT3D(#17427,#8936,#9);
#17429= IFCLOCALPLACEMENT(#17424,#17428);
#17430= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15292));
#17431= IFCPRODUCTDEFINITIONSHAPE($,$,(#17430));
#17432= IFCPLATE('1Td1iR001x9p4rDp0rCJ4s',#5,'DETAY','PL6*60','PL6*60',#17429,#17431,'P/396(?)');
#17433= IFCLOCALPLACEMENT(#30,#10);
#17434= IFCELEMENTASSEMBLY('1Td1iR001xB34rDp0rCJ4s',#5,'Steel Assembly',$,$,#17433,$,'DK/90(?)',.NOTDEFINED.,.RIGID_FRAME.);
#17435= IFCPROPERTYSET('3iJglWfRz6m8rnIeMTBw_e',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#16349,#8979,#8980,#3925,#5197,#8981));
#17436= IFCCARTESIANPOINT((40127.4953927543,-584.17000007709,-7158.));
#17437= IFCAXIS2PLACEMENT3D(#17436,#501,#185);
#17438= IFCLOCALPLACEMENT(#17433,#17437);
#17439= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#15339));
#17440= IFCPRODUCTDEFINITIONSHAPE($,$,(#17439));
#17441= IFCBEAM('1Td1iR001xAp4rDp0rCJ4s',#5,'DIKME','PLT6*150','PLT6*150',#17438,#17440,'P/465(?)');
#17442= IFCCARTESIANPOINT((39330.0005366162,-589.170000077491,-7145.));
#17443= IFCAXIS2PLACEMENT3D(#17442,#501,#7);
#17444= IFCLOCALPLACEMENT(#15997,#17443);
#17445= IFCCARTESIANPOINT((59.9764310781029,35.,99.9999999995998));
#17446= IFCAXIS2PLACEMENT3D(#17445,#8,#596);
#17447= IFCEXTRUDEDAREASOLID(#11444,#17446,#9,10.);
#17448= IFCBOOLEANRESULT(.DIFFERENCE.,#16425,#17447);
#17449= IFCCARTESIANPOINT((144.976431078103,-45.,99.9999999995998));
#17450= IFCAXIS2PLACEMENT3D(#17449,#8,#596);
#17451= IFCEXTRUDEDAREASOLID(#11454,#17450,#9,80.);
#17452= IFCBOOLEANRESULT(.DIFFERENCE.,#17448,#17451);
#17453= IFCCARTESIANPOINT((749.983396017771,45.,100.));
#17454= IFCAXIS2PLACEMENT3D(#17453,#501,#596);
#17455= IFCEXTRUDEDAREASOLID(#4126,#17454,#9,10.);
#17456= IFCBOOLEANRESULT(.DIFFERENCE.,#17452,#17455);
#17457= IFCCARTESIANPOINT((649.986396017775,35.,100.));
#17458= IFCAXIS2PLACEMENT3D(#17457,#501,#596);
#17459= IFCEXTRUDEDAREASOLID(#4137,#17458,#9,80.);
#17460= IFCBOOLEANRESULT(.DIFFERENCE.,#17456,#17459);
#17461= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#17460));
#17462= IFCPRODUCTDEFINITIONSHAPE($,$,(#17461));
#17463= IFCBEAM('1Td1iR001xBp4rDp0rCJ4s',#5,'KIRIS','RHS200*90*6','RHS200*90*6',#17444,#17462,'P/452(?)');
#17464= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(16.7513875145835),$);
#17465= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(16.7513875145835),$);
#17466= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.00213393471523357),$);
#17467= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.00213393471523357),$);
#17468= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.152451392987917),$);
#17469= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(22.1930673221468),$);
#17470= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.37176467085052),$);
#17471= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(200.0000000004),$);
#17472= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(775.022965427954),$);
#17473= IFCPROPERTYSET('2L1REPfnH9o8jspYhUOOJ0',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#16007,#17464,#16443,#17465,#17466,#16446,#17467,#17468,#17469,#17470,#16451,#17471,#5657,#17472));
#17474= IFCQUANTITYLENGTH('Length',$,$,775.022965427954);
#17475= IFCQUANTITYAREA('OuterSurfaceArea',$,$,0.371764670850521);
#17476= IFCQUANTITYVOLUME('NetVolume',$,$,0.00213393471523357);
#17477= IFCQUANTITYWEIGHT('NetWeight',$,$,16.7513875145835);
#17478= IFCELEMENTQUANTITY('3ugV5Z0ezDReHSCdRPyDDj',#5,'BaseQuantities',$,$,(#17474,#17475,#17476,#17477));
#17479= IFCCARTESIANPOINT((36900.0005366113,-589.170000077491,-7145.));
#17480= IFCAXIS2PLACEMENT3D(#17479,#501,#7);
#17481= IFCLOCALPLACEMENT(#16050,#17480);
#17482= IFCBOOLEANRESULT(.DIFFERENCE.,#16545,#16480);
#17483= IFCBOOLEANRESULT(.DIFFERENCE.,#17482,#16484);
#17484= IFCCARTESIANPOINT((2369.9761433688,45.,99.9999999995998));
#17485= IFCAXIS2PLACEMENT3D(#17484,#501,#596);
#17486= IFCEXTRUDEDAREASOLID(#4126,#17485,#9,10.);
#17487= IFCBOOLEANRESULT(.DIFFERENCE.,#17483,#17486);
#17488= IFCCARTESIANPOINT((2269.9791433688,35.,99.9999999995998));
#17489= IFCAXIS2PLACEMENT3D(#17488,#501,#596);
#17490= IFCEXTRUDEDAREASOLID(#4137,#17489,#9,80.);
#17491= IFCBOOLEANRESULT(.DIFFERENCE.,#17487,#17490);
#17492= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#17491));
#17493= IFCPRODUCTDEFINITIONSHAPE($,$,(#17492));
#17494= IFCBEAM('1Td1iR001xCp4rDp0rCJ4s',#5,'KIRIS','RHS200*90*6','RHS200*90*6',#17481,#17493,'P/451(?)');
#17495= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(59.1749196555677),$);
#17496= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(59.1749196555677),$);
#17497= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.476448491926386),$);
#17498= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(21.9744054343333),$);
#17499= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(1.30033367605554),$);
#17500= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(2395.0084601203),$);
#17501= IFCPROPERTYSET('1L1WX1BVT8w8Sg_8DO1yDD',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#16060,#17495,#16563,#17496,#16565,#16566,#16567,#17497,#17498,#17499,#16571,#17471,#5657,#17500));
#17502= IFCQUANTITYLENGTH('Length',$,$,2395.0084601203);
#17503= IFCQUANTITYAREA('OuterSurfaceArea',$,$,1.30033367605555);
#17504= IFCQUANTITYVOLUME('NetVolume',$,$,0.00753820632555003);
#17505= IFCQUANTITYWEIGHT('NetWeight',$,$,59.1749196555677);
#17506= IFCELEMENTQUANTITY('13W4A7wwL5u8nGU4B3nSKa',#5,'BaseQuantities',$,$,(#17502,#17503,#17504,#17505));
#17507= IFCCARTESIANPOINT((32424.9956594666,-569.169997411911,4845.));
#17508= IFCAXIS2PLACEMENT3D(#17507,#7505,#5239);
#17509= IFCLOCALPLACEMENT(#7681,#17508);
#17510= IFCBOOLEANRESULT(.DIFFERENCE.,#7508,#7517);
#17511= IFCBOOLEANRESULT(.DIFFERENCE.,#17510,#7525);
#17512= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#17511));
#17513= IFCPRODUCTDEFINITIONSHAPE($,$,(#17512));
#17514= IFCBEAM('1Td1iR001xJJ4rDp0rCJ4s',#5,'KIRIS','WB240-16-25*90-0','WB240-16-25*90-0',#17509,#17513,'P/252(?)');
#17515= IFCPROPERTYSET('159Ta40FnDbBZGVpicP$p7',#5,'Tekla Common','Common Properties to Shared building elements',(#7722,#1377,#5675,#5219,#74,#75,#919,#5643,#78,#5644,#4185));
#17516= IFCPROPERTYSET('0yu1nd54r9HwcsKli_llV9',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#7692,#7532,#7533,#7534,#7535,#7536,#7537,#7538,#7539,#7540,#7541,#5656,#5657,#7542));
#17517= IFCCARTESIANPOINT((32424.9985364744,-569.170194656646,10545.));
#17518= IFCAXIS2PLACEMENT3D(#17517,#501,#7);
#17519= IFCLOCALPLACEMENT(#6387,#17518);
#17520= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#5670));
#17521= IFCPRODUCTDEFINITIONSHAPE($,$,(#17520));
#17522= IFCBEAM('1Td1iR001xL34rDp0rCJ4s',#5,'KIRIS','WB240-16-25*90-0','WB240-16-25*90-0',#17519,#17521,'P/252(?)');
#17523= IFCPROPERTYSET('3XpfGwpnn9n8i83JcVzR1L',#5,'Tekla Common','Common Properties to Shared building elements',(#6417,#1267,#5675,#5219,#74,#75,#919,#5643,#78,#5644,#4185));
#17524= IFCLOCALPLACEMENT(#30,#10);
#17525= IFCELEMENTASSEMBLY('1Td1iR001y2J4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17524,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17526= IFCPROPERTYSET('0w9OUgcOv9aforbrn_5dYw',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#9228,#9229,#1775,#5197,#1701));
#17527= IFCCARTESIANPOINT((39219.9926804692,-581.666086793292,-7661.00372056646));
#17528= IFCAXIS2PLACEMENT3D(#17527,#9232,#9233);
#17529= IFCLOCALPLACEMENT(#17524,#17528);
#17530= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9236));
#17531= IFCPRODUCTDEFINITIONSHAPE($,$,(#17530));
#17532= IFCBEAM('1Td1iR001y234rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#17529,#17531,'XX/0(?)');
#17533= IFCLOCALPLACEMENT(#30,#10);
#17534= IFCELEMENTASSEMBLY('1Td1iR001y3J4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17533,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17535= IFCPROPERTYSET('3Nz54HbrH8HQn2TrhlWOwp',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#9252,#4550,#137,#5197,#1701));
#17536= IFCCARTESIANPOINT((39219.9926804692,-581.663086793291,-7700.00372056646));
#17537= IFCAXIS2PLACEMENT3D(#17536,#9255,#9256);
#17538= IFCLOCALPLACEMENT(#17533,#17537);
#17539= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17540= IFCPRODUCTDEFINITIONSHAPE($,$,(#17539));
#17541= IFCBEAM('1Td1iR001y334rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17538,#17540,'XX/0(?)');
#17542= IFCLOCALPLACEMENT(#30,#10);
#17543= IFCELEMENTASSEMBLY('1Td1iR001y4J4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17542,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17544= IFCPROPERTYSET('1Q7SnLdFXFpgO9ASqwimJZ',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#9273,#9274,#137,#5197,#1701));
#17545= IFCCARTESIANPOINT((39219.9926804692,-581.666086793292,-7629.00372056646));
#17546= IFCAXIS2PLACEMENT3D(#17545,#9255,#9256);
#17547= IFCLOCALPLACEMENT(#17542,#17546);
#17548= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17549= IFCPRODUCTDEFINITIONSHAPE($,$,(#17548));
#17550= IFCBEAM('1Td1iR001y434rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17547,#17549,'XX/0(?)');
#17551= IFCLOCALPLACEMENT(#30,#10);
#17552= IFCELEMENTASSEMBLY('1Td1iR001y5J4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17551,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17553= IFCPROPERTYSET('090iHb6ynBjfwL_PE8vB8E',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#9290,#9291,#137,#5197,#1701));
#17554= IFCCARTESIANPOINT((39219.9926804692,-581.666086793292,-7645.00372056646));
#17555= IFCAXIS2PLACEMENT3D(#17554,#9255,#9256);
#17556= IFCLOCALPLACEMENT(#17551,#17555);
#17557= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17558= IFCPRODUCTDEFINITIONSHAPE($,$,(#17557));
#17559= IFCBEAM('1Td1iR001y534rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17556,#17558,'XX/0(?)');
#17560= IFCLOCALPLACEMENT(#30,#10);
#17561= IFCELEMENTASSEMBLY('1Td1iR001y6J4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17560,$,'R/1(?)',.NOTDEFINED.,.RIGID_FRAME.);
#17562= IFCPROPERTYSET('1lKaD8Hj5AagaFD2q1DIhj',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#9304,#9305,#137,#5197,#8391));
#17563= IFCCARTESIANPOINT((39219.9926804692,-581.666103453154,-7615.0040758817));
#17564= IFCAXIS2PLACEMENT3D(#17563,#501,#596);
#17565= IFCLOCALPLACEMENT(#17560,#17564);
#17566= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9310));
#17567= IFCPRODUCTDEFINITIONSHAPE($,$,(#17566));
#17568= IFCBEAM('1Td1iR001y634rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#17565,#17567,'P/487(?)');
#17569= IFCLOCALPLACEMENT(#30,#10);
#17570= IFCELEMENTASSEMBLY('1Td1iR001y7J4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17569,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17571= IFCCARTESIANPOINT((39439.9926804692,-581.666086793292,-7661.00372056646));
#17572= IFCAXIS2PLACEMENT3D(#17571,#9232,#9233);
#17573= IFCLOCALPLACEMENT(#17569,#17572);
#17574= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9236));
#17575= IFCPRODUCTDEFINITIONSHAPE($,$,(#17574));
#17576= IFCBEAM('1Td1iR001y734rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#17573,#17575,'XX/0(?)');
#17577= IFCLOCALPLACEMENT(#30,#10);
#17578= IFCELEMENTASSEMBLY('1Td1iR001y8J4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17577,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17579= IFCCARTESIANPOINT((39439.9926804692,-581.663086793291,-7700.00372056646));
#17580= IFCAXIS2PLACEMENT3D(#17579,#9255,#9256);
#17581= IFCLOCALPLACEMENT(#17577,#17580);
#17582= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17583= IFCPRODUCTDEFINITIONSHAPE($,$,(#17582));
#17584= IFCBEAM('1Td1iR001y834rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17581,#17583,'XX/0(?)');
#17585= IFCLOCALPLACEMENT(#30,#10);
#17586= IFCELEMENTASSEMBLY('1Td1iR001y9J4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17585,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17587= IFCCARTESIANPOINT((39439.9926804692,-581.666086793292,-7629.00372056646));
#17588= IFCAXIS2PLACEMENT3D(#17587,#9255,#9256);
#17589= IFCLOCALPLACEMENT(#17585,#17588);
#17590= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17591= IFCPRODUCTDEFINITIONSHAPE($,$,(#17590));
#17592= IFCBEAM('1Td1iR001y934rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17589,#17591,'XX/0(?)');
#17593= IFCLOCALPLACEMENT(#30,#10);
#17594= IFCELEMENTASSEMBLY('1Td1iR001yAJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17593,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17595= IFCCARTESIANPOINT((39439.9926804692,-581.666086793292,-7645.00372056646));
#17596= IFCAXIS2PLACEMENT3D(#17595,#9255,#9256);
#17597= IFCLOCALPLACEMENT(#17593,#17596);
#17598= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17599= IFCPRODUCTDEFINITIONSHAPE($,$,(#17598));
#17600= IFCBEAM('1Td1iR001yA34rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17597,#17599,'XX/0(?)');
#17601= IFCLOCALPLACEMENT(#30,#10);
#17602= IFCELEMENTASSEMBLY('1Td1iR001yBJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17601,$,'R/1(?)',.NOTDEFINED.,.RIGID_FRAME.);
#17603= IFCCARTESIANPOINT((39439.9926804692,-581.666103453154,-7615.0040758817));
#17604= IFCAXIS2PLACEMENT3D(#17603,#501,#596);
#17605= IFCLOCALPLACEMENT(#17601,#17604);
#17606= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9310));
#17607= IFCPRODUCTDEFINITIONSHAPE($,$,(#17606));
#17608= IFCBEAM('1Td1iR001yB34rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#17605,#17607,'P/487(?)');
#17609= IFCCARTESIANPOINT((39329.9926804692,-474.170105357636,-7690.00389468441));
#17610= IFCAXIS2PLACEMENT3D(#17609,#185,#501);
#17611= IFCLOCALPLACEMENT(#16016,#17610);
#17612= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#17054));
#17613= IFCPRODUCTDEFINITIONSHAPE($,$,(#17612));
#17614= IFCBEAM('1Td1iR001yC34rDp0rCJ4s',#5,'ANKRAJ','PLT20*410','PLT20*410',#17611,#17613,'P/380(?)');
#17615= IFCLOCALPLACEMENT(#30,#10);
#17616= IFCELEMENTASSEMBLY('1Td1iR001yDJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17615,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17617= IFCCARTESIANPOINT((40029.9926804692,-581.666086793292,-7661.00372056646));
#17618= IFCAXIS2PLACEMENT3D(#17617,#9232,#9233);
#17619= IFCLOCALPLACEMENT(#17615,#17618);
#17620= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9236));
#17621= IFCPRODUCTDEFINITIONSHAPE($,$,(#17620));
#17622= IFCBEAM('1Td1iR001yD34rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#17619,#17621,'XX/0(?)');
#17623= IFCLOCALPLACEMENT(#30,#10);
#17624= IFCELEMENTASSEMBLY('1Td1iR001yEJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17623,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17625= IFCCARTESIANPOINT((40029.9926804692,-581.663086793291,-7700.00372056646));
#17626= IFCAXIS2PLACEMENT3D(#17625,#9255,#9256);
#17627= IFCLOCALPLACEMENT(#17623,#17626);
#17628= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17629= IFCPRODUCTDEFINITIONSHAPE($,$,(#17628));
#17630= IFCBEAM('1Td1iR001yE34rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17627,#17629,'XX/0(?)');
#17631= IFCLOCALPLACEMENT(#30,#10);
#17632= IFCELEMENTASSEMBLY('1Td1iR001yFJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17631,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17633= IFCCARTESIANPOINT((40029.9926804692,-581.666086793292,-7629.00372056646));
#17634= IFCAXIS2PLACEMENT3D(#17633,#9255,#9256);
#17635= IFCLOCALPLACEMENT(#17631,#17634);
#17636= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17637= IFCPRODUCTDEFINITIONSHAPE($,$,(#17636));
#17638= IFCBEAM('1Td1iR001yF34rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17635,#17637,'XX/0(?)');
#17639= IFCLOCALPLACEMENT(#30,#10);
#17640= IFCELEMENTASSEMBLY('1Td1iR001yGJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17639,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17641= IFCCARTESIANPOINT((40029.9926804692,-581.666086793292,-7645.00372056646));
#17642= IFCAXIS2PLACEMENT3D(#17641,#9255,#9256);
#17643= IFCLOCALPLACEMENT(#17639,#17642);
#17644= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17645= IFCPRODUCTDEFINITIONSHAPE($,$,(#17644));
#17646= IFCBEAM('1Td1iR001yG34rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17643,#17645,'XX/0(?)');
#17647= IFCLOCALPLACEMENT(#30,#10);
#17648= IFCELEMENTASSEMBLY('1Td1iR001yHJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17647,$,'R/1(?)',.NOTDEFINED.,.RIGID_FRAME.);
#17649= IFCCARTESIANPOINT((40029.9926804692,-581.666103453154,-7615.0040758817));
#17650= IFCAXIS2PLACEMENT3D(#17649,#501,#596);
#17651= IFCLOCALPLACEMENT(#17647,#17650);
#17652= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9310));
#17653= IFCPRODUCTDEFINITIONSHAPE($,$,(#17652));
#17654= IFCBEAM('1Td1iR001yH34rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#17651,#17653,'P/487(?)');
#17655= IFCLOCALPLACEMENT(#30,#10);
#17656= IFCELEMENTASSEMBLY('1Td1iR001yIJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17655,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17657= IFCCARTESIANPOINT((40249.9926804692,-581.666086793292,-7661.00372056646));
#17658= IFCAXIS2PLACEMENT3D(#17657,#9232,#9233);
#17659= IFCLOCALPLACEMENT(#17655,#17658);
#17660= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9236));
#17661= IFCPRODUCTDEFINITIONSHAPE($,$,(#17660));
#17662= IFCBEAM('1Td1iR001yI34rDp0rCJ4s',#5,'WASHER','EPD44*9.5','EPD44*9.5',#17659,#17661,'XX/0(?)');
#17663= IFCLOCALPLACEMENT(#30,#10);
#17664= IFCELEMENTASSEMBLY('1Td1iR001yJJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17663,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17665= IFCCARTESIANPOINT((40249.9926804692,-581.663086793291,-7700.00372056646));
#17666= IFCAXIS2PLACEMENT3D(#17665,#9255,#9256);
#17667= IFCLOCALPLACEMENT(#17663,#17666);
#17668= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17669= IFCPRODUCTDEFINITIONSHAPE($,$,(#17668));
#17670= IFCBEAM('1Td1iR001yJ34rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17667,#17669,'XX/0(?)');
#17671= IFCLOCALPLACEMENT(#30,#10);
#17672= IFCELEMENTASSEMBLY('1Td1iR001yKJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17671,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17673= IFCCARTESIANPOINT((40249.9926804692,-581.666086793292,-7629.00372056646));
#17674= IFCAXIS2PLACEMENT3D(#17673,#9255,#9256);
#17675= IFCLOCALPLACEMENT(#17671,#17674);
#17676= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17677= IFCPRODUCTDEFINITIONSHAPE($,$,(#17676));
#17678= IFCBEAM('1Td1iR001yK34rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17675,#17677,'XX/0(?)');
#17679= IFCLOCALPLACEMENT(#30,#10);
#17680= IFCELEMENTASSEMBLY('1Td1iR001yLJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17679,$,'XX/0(?)',.NOTDEFINED.,.NOTDEFINED.);
#17681= IFCCARTESIANPOINT((40249.9926804692,-581.666086793292,-7645.00372056646));
#17682= IFCAXIS2PLACEMENT3D(#17681,#9255,#9256);
#17683= IFCLOCALPLACEMENT(#17679,#17682);
#17684= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9259));
#17685= IFCPRODUCTDEFINITIONSHAPE($,$,(#17684));
#17686= IFCBEAM('1Td1iR001yL34rDp0rCJ4s',#5,'NUT','NUT_M20','NUT_M20',#17683,#17685,'XX/0(?)');
#17687= IFCLOCALPLACEMENT(#30,#10);
#17688= IFCELEMENTASSEMBLY('1Td1iR001yMJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17687,$,'R/1(?)',.NOTDEFINED.,.RIGID_FRAME.);
#17689= IFCCARTESIANPOINT((40249.9926804692,-581.666103453154,-7615.0040758817));
#17690= IFCAXIS2PLACEMENT3D(#17689,#501,#596);
#17691= IFCLOCALPLACEMENT(#17687,#17690);
#17692= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#9310));
#17693= IFCPRODUCTDEFINITIONSHAPE($,$,(#17692));
#17694= IFCBEAM('1Td1iR001yM34rDp0rCJ4s',#5,'ROD','ROD20','ROD20',#17691,#17693,'P/487(?)');
#17695= IFCCARTESIANPOINT((39329.9926804692,-589.170000077483,10545.));
#17696= IFCAXIS2PLACEMENT3D(#17695,#501,#596);
#17697= IFCLOCALPLACEMENT(#16212,#17696);
#17698= IFCPLANE(#16584);
#17699= IFCHALFSPACESOLID(#17698,.F.);
#17700= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#16582,#17699);
#17701= IFCPLANE(#16589);
#17702= IFCHALFSPACESOLID(#17701,.F.);
#17703= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#17700,#17702);
#17704= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#17703));
#17705= IFCPRODUCTDEFINITIONSHAPE($,$,(#17704));
#17706= IFCBEAM('1Td1iR001yTZ4rDp0rCJ4s',#5,'DIKME','T200-16-20-110','T200-16-20-110',#17697,#17705,'P/315(?)');
#17707= IFCCARTESIANPOINT((40139.9926804692,-589.170000077483,10545.));
#17708= IFCAXIS2PLACEMENT3D(#17707,#501,#596);
#17709= IFCLOCALPLACEMENT(#16221,#17708);
#17710= IFCPLANE(#16584);
#17711= IFCHALFSPACESOLID(#17710,.F.);
#17712= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#16582,#17711);
#17713= IFCPLANE(#16589);
#17714= IFCHALFSPACESOLID(#17713,.F.);
#17715= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#17712,#17714);
#17716= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#17715));
#17717= IFCPRODUCTDEFINITIONSHAPE($,$,(#17716));
#17718= IFCBEAM('1Td1iR001yV34rDp0rCJ4s',#5,'DIKME','T200-16-20-110','T200-16-20-110',#17709,#17717,'P/315(?)');
#17719= IFCCARTESIANPOINT((39329.9926804692,-589.170000077483,15745.));
#17720= IFCAXIS2PLACEMENT3D(#17719,#501,#596);
#17721= IFCLOCALPLACEMENT(#16230,#17720);
#17722= IFCPLANE(#16658);
#17723= IFCHALFSPACESOLID(#17722,.F.);
#17724= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#13033,#17723);
#17725= IFCPLANE(#16589);
#17726= IFCHALFSPACESOLID(#17725,.F.);
#17727= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#17724,#17726);
#17728= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#17727));
#17729= IFCPRODUCTDEFINITIONSHAPE($,$,(#17728));
#17730= IFCBEAM('1Td1iR001ycZ4rDp0rCJ4s',#5,'DIKME','T200-16-20-110','T200-16-20-110',#17721,#17729,'P/316(?)');
#17731= IFCCARTESIANPOINT((39315.,-229.17117837134,20199.9974118494));
#17732= IFCAXIS2PLACEMENT3D(#17731,#185,#596);
#17733= IFCLOCALPLACEMENT(#16257,#17732);
#17734= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#13077));
#17735= IFCPRODUCTDEFINITIONSHAPE($,$,(#17734));
#17736= IFCPLATE('1Td1iR001yqZ4rDp0rCJ4s',#5,'ANKRAJ','PL10*250','PL10*250',#17733,#17735,'P/224(?)');
#17737= IFCCARTESIANPOINT((39329.9926804692,-554.170000077483,20200.));
#17738= IFCAXIS2PLACEMENT3D(#17737,#501,#596);
#17739= IFCLOCALPLACEMENT(#16248,#17738);
#17740= IFCBOOLEANRESULT(.DIFFERENCE.,#13112,#16628);
#17741= IFCPLANE(#16631);
#17742= IFCHALFSPACESOLID(#17741,.F.);
#17743= IFCBOOLEANRESULT(.DIFFERENCE.,#17740,#17742);
#17744= IFCPLANE(#16636);
#17745= IFCHALFSPACESOLID(#17744,.F.);
#17746= IFCBOOLEANRESULT(.DIFFERENCE.,#17743,#17745);
#17747= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#17746));
#17748= IFCPRODUCTDEFINITIONSHAPE($,$,(#17747));
#17749= IFCBEAM('1Td1iR001ysp4rDp0rCJ4s',#5,'DIKME','T270-16-16-110','T270-16-16-110',#17739,#17748,'P/319(?)');
#17750= IFCCARTESIANPOINT((40139.9926804692,-474.170105357636,-7690.00389468441));
#17751= IFCAXIS2PLACEMENT3D(#17750,#185,#501);
#17752= IFCLOCALPLACEMENT(#15257,#17751);
#17753= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#17054));
#17754= IFCPRODUCTDEFINITIONSHAPE($,$,(#17753));
#17755= IFCBEAM('1Td1iR001ytp4rDp0rCJ4s',#5,'ANKRAJ','PLT20*410','PLT20*410',#17752,#17754,'P/380(?)');
#17756= IFCCARTESIANPOINT((40125.,-229.17117837134,20199.9974118494));
#17757= IFCAXIS2PLACEMENT3D(#17756,#185,#596);
#17758= IFCLOCALPLACEMENT(#16302,#17757);
#17759= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#13077));
#17760= IFCPRODUCTDEFINITIONSHAPE($,$,(#17759));
#17761= IFCPLATE('1Td1iR001y_J4rDp0rCJ4s',#5,'ANKRAJ','PL10*250','PL10*250',#17758,#17760,'P/224(?)');
#17762= IFCCARTESIANPOINT((40139.9926804692,-554.170000077483,20200.));
#17763= IFCAXIS2PLACEMENT3D(#17762,#501,#596);
#17764= IFCLOCALPLACEMENT(#16279,#17763);
#17765= IFCBOOLEANRESULT(.DIFFERENCE.,#13112,#16628);
#17766= IFCPLANE(#16631);
#17767= IFCHALFSPACESOLID(#17766,.F.);
#17768= IFCBOOLEANRESULT(.DIFFERENCE.,#17765,#17767);
#17769= IFCPLANE(#16636);
#17770= IFCHALFSPACESOLID(#17769,.F.);
#17771= IFCBOOLEANRESULT(.DIFFERENCE.,#17768,#17770);
#17772= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#17771));
#17773= IFCPRODUCTDEFINITIONSHAPE($,$,(#17772));
#17774= IFCBEAM('1Td1iR001z0Z4rDp0rCJ4s',#5,'DIKME','T270-16-16-110','T270-16-16-110',#17764,#17773,'P/319(?)');
#17775= IFCCARTESIANPOINT((40139.9926804692,-589.170000077483,15745.));
#17776= IFCAXIS2PLACEMENT3D(#17775,#501,#596);
#17777= IFCLOCALPLACEMENT(#16239,#17776);
#17778= IFCPLANE(#16658);
#17779= IFCHALFSPACESOLID(#17778,.F.);
#17780= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#13033,#17779);
#17781= IFCPLANE(#16589);
#17782= IFCHALFSPACESOLID(#17781,.F.);
#17783= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#17780,#17782);
#17784= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#17783));
#17785= IFCPRODUCTDEFINITIONSHAPE($,$,(#17784));
#17786= IFCBEAM('1Td1iR001z234rDp0rCJ4s',#5,'DIKME','T200-16-20-110','T200-16-20-110',#17777,#17785,'P/316(?)');
#17787= IFCCARTESIANPOINT((40139.9926804684,-589.170000077091,4845.));
#17788= IFCAXIS2PLACEMENT3D(#17787,#501,#596);
#17789= IFCLOCALPLACEMENT(#16203,#17788);
#17790= IFCPLANE(#16870);
#17791= IFCHALFSPACESOLID(#17790,.F.);
#17792= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#16868,#17791);
#17793= IFCPLANE(#9821);
#17794= IFCHALFSPACESOLID(#17793,.F.);
#17795= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#17792,#17794);
#17796= IFCPLANE(#16870);
#17797= IFCHALFSPACESOLID(#17796,.F.);
#17798= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#17795,#17797);
#17799= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#17798));
#17800= IFCPRODUCTDEFINITIONSHAPE($,$,(#17799));
#17801= IFCBEAM('1Td1iR001z3p4rDp0rCJ4s',#5,'DIKME','T200-20-20-110','T200-20-20-110',#17789,#17800,'P/285(?)');
#17802= IFCCARTESIANPOINT((39329.9926804684,-589.170000077091,4845.));
#17803= IFCAXIS2PLACEMENT3D(#17802,#501,#596);
#17804= IFCLOCALPLACEMENT(#16194,#17803);
#17805= IFCPLANE(#16870);
#17806= IFCHALFSPACESOLID(#17805,.F.);
#17807= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#16868,#17806);
#17808= IFCPLANE(#9821);
#17809= IFCHALFSPACESOLID(#17808,.F.);
#17810= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#17807,#17809);
#17811= IFCPLANE(#16870);
#17812= IFCHALFSPACESOLID(#17811,.F.);
#17813= IFCBOOLEANCLIPPINGRESULT(.DIFFERENCE.,#17810,#17812);
#17814= IFCSHAPEREPRESENTATION(#12,'Body','Clipping',(#17813));
#17815= IFCPRODUCTDEFINITIONSHAPE($,$,(#17814));
#17816= IFCBEAM('1Td1iR001z5Z4rDp0rCJ4s',#5,'DIKME','T200-20-20-110','T200-20-20-110',#17804,#17815,'P/285(?)');
#17817= IFCLOCALPLACEMENT(#30,#10);
#17818= IFCELEMENTASSEMBLY('1Td1iR0024634rDp0rCJ4s',#5,'Steel Assembly',$,$,#17817,$,'XX/122',.NOTDEFINED.,.NOTDEFINED.);
#17819= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' +20.200'),$);
#17820= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +20.220'),$);
#17821= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit name',$,IFCLABEL('GOMULU LEVHA'),$);
#17822= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('XX/122'),$);
#17823= IFCPROPERTYSET('2zCPNTEx1Dof7ZuIi5ezOh',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#17819,#17820,#17821,#1615,#17822));
#17824= IFCCARTESIANPOINT((40700.0085928583,-220.451620627083,20210.));
#17825= IFCAXIS2PLACEMENT3D(#17824,#9,#501);
#17826= IFCLOCALPLACEMENT(#17817,#17825);
#17827= IFCSURFACESTYLE('MISCELLANEOUS/Zero_weight',.POSITIVE.,(#4030));
#17828= IFCPRESENTATIONSTYLEASSIGNMENT((#17827));
#17829= IFCCARTESIANPOINT((179.554244995117,0.));
#17830= IFCCARTESIANPOINT((179.554244995117,500.));
#17831= IFCCARTESIANPOINT((-238.505218505859,500.));
#17832= IFCPOLYLINE((#54,#17829,#17830,#17831,#54,#54));
#17833= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL20*418',#17832);
#17834= IFCCARTESIANPOINT((0.,0.,-10.));
#17835= IFCAXIS2PLACEMENT3D(#17834,#9,#7);
#17836= IFCEXTRUDEDAREASOLID(#17833,#17835,#9,20.);
#17837= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#17836));
#17838= IFCSTYLEDITEM(#17836,(#17828),$);
#17839= IFCPRODUCTDEFINITIONSHAPE($,$,(#17837));
#17840= IFCPLATE('1Td1iR00246J4rDp0rCJ4s',#5,'GOMULU LEVHA','PL20*418','PL20*418',#17826,#17839,'XX/122');
#17841= IFCPLATETYPE('1ES5Jv3MP2yxD5T92P5xC8',#5,'PL20*418',$,$,$,$,$,$,.NOTDEFINED.);
#17842= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +20.200'),$);
#17843= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +20.220'),$);
#17844= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('XX/122'),$);
#17845= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('XX/122'),$);
#17846= IFCPROPERTYSINGLEVALUE('Phase',$,IFCINTEGER(4),$);
#17847= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PL20*418'),$);
#17848= IFCPROPERTYSINGLEVALUE('Name',$,IFCLABEL('GOMULU LEVHA'),$);
#17849= IFCPROPERTYSET('0nFma9L0HBFARhPSu3F4jS',#5,'Tekla Common','Common Properties to Shared building elements',(#17842,#17843,#17844,#17845,#74,#75,#17846,#4046,#1732,#17847,#17848));
#17850= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.00298806854248047),$);
#17851= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.00298806854248047),$);
#17852= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.00298806854248047),$);
#17853= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.149403427124023),$);
#17854= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.331838564130216),$);
#17855= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.209029731750488),$);
#17856= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(418.059463500977),$);
#17857= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(500.),$);
#17858= IFCPROPERTYSET('1wA_LIFaT2Iuiulr5VbFgm',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#17850,#17851,#17852,#17853,#1744,#17854,#17855,#17856,#1848,#17857));
#17859= IFCQUANTITYLENGTH('Width',$,$,418.059463500977);
#17860= IFCQUANTITYAREA('NetArea',$,$,0.331838564130216);
#17861= IFCQUANTITYAREA('GrossArea',$,$,0.209029731750488);
#17862= IFCQUANTITYAREA('CrossSectionArea',$,$,0.0004);
#17863= IFCQUANTITYVOLUME('NetVolume',$,$,0.00298806854248047);
#17864= IFCQUANTITYVOLUME('GrossVolume',$,$,0.00298806854248047);
#17865= IFCELEMENTQUANTITY('2Q98Z56ib8HuLbw8hazWvc',#5,'BaseQuantities',$,$,(#17859,#17860,#17861,#17862,#17863,#17864));
#17866= IFCLOCALPLACEMENT(#30,#10);
#17867= IFCELEMENTASSEMBLY('1Td1iR0024734rDp0rCJ4s',#5,'Steel Assembly',$,$,#17866,$,'XX/121',.NOTDEFINED.,.NOTDEFINED.);
#17868= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('XX/121'),$);
#17869= IFCPROPERTYSET('2GeDoz6QL9t8UfNeO06m6Q',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#17819,#17820,#17821,#16259,#17868));
#17870= IFCCARTESIANPOINT((39889.9965354691,-38.6553950296948,20210.));
#17871= IFCAXIS2PLACEMENT3D(#17870,#9,#501);
#17872= IFCLOCALPLACEMENT(#17866,#17871);
#17873= IFCCARTESIANPOINT((361.350463867188,0.));
#17874= IFCCARTESIANPOINT((361.350463867188,500.));
#17875= IFCCARTESIANPOINT((206.795379638672,500.));
#17876= IFCPOLYLINE((#54,#17873,#17874,#17875,#54,#54));
#17877= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL20*361',#17876);
#17878= IFCEXTRUDEDAREASOLID(#17877,#17835,#9,20.);
#17879= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#17878));
#17880= IFCSTYLEDITEM(#17878,(#17828),$);
#17881= IFCPRODUCTDEFINITIONSHAPE($,$,(#17879));
#17882= IFCPLATE('1Td1iR00247J4rDp0rCJ4s',#5,'GOMULU LEVHA','PL20*361','PL20*361',#17872,#17881,'XX/121');
#17883= IFCPLATETYPE('1lvHBjdS91Y9UwxtJs5V05',#5,'PL20*361',$,$,$,$,$,$,.NOTDEFINED.);
#17884= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('XX/121'),$);
#17885= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('XX/121'),$);
#17886= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PL20*361'),$);
#17887= IFCPROPERTYSET('2_2hxtFA98nwiWPZu3DxxB',#5,'Tekla Common','Common Properties to Shared building elements',(#17842,#17843,#17884,#17885,#74,#75,#17846,#4046,#1732,#17886,#17848));
#17888= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.00257952774047851),$);
#17889= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.00257952774047851),$);
#17890= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.00257952774047851),$);
#17891= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.128976387023926),$);
#17892= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.28909242517815),$);
#17893= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.180675231933594),$);
#17894= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(361.350463867188),$);
#17895= IFCPROPERTYSET('0UeXe5zL9BqfkFg9lUvsgc',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#17888,#17889,#17890,#17891,#1744,#17892,#17893,#17894,#1848,#17857));
#17896= IFCQUANTITYLENGTH('Width',$,$,361.350463867188);
#17897= IFCQUANTITYAREA('NetArea',$,$,0.28909242517815);
#17898= IFCQUANTITYAREA('GrossArea',$,$,0.180675231933594);
#17899= IFCQUANTITYVOLUME('NetVolume',$,$,0.00257952774047851);
#17900= IFCQUANTITYVOLUME('GrossVolume',$,$,0.00257952774047851);
#17901= IFCELEMENTQUANTITY('26AX4EOLn0KOiSZDWYJEYC',#5,'BaseQuantities',$,$,(#17896,#17897,#17898,#17862,#17899,#17900));
#17902= IFCLOCALPLACEMENT(#30,#10);
#17903= IFCELEMENTASSEMBLY('1Td1iR0024EJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17902,$,'XX/119',.NOTDEFINED.,.NOTDEFINED.);
#17904= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('XX/119'),$);
#17905= IFCPROPERTYSET('0SAIZXr4HEWuPdsOXivFgj',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#17819,#17820,#17821,#1615,#17904));
#17906= IFCCARTESIANPOINT((47948.9701537792,-152.484448480325,20209.9995230555));
#17907= IFCDIRECTION((0.707104737183595,-0.707108825183592,0.));
#17908= IFCAXIS2PLACEMENT3D(#17906,#9,#17907);
#17909= IFCLOCALPLACEMENT(#17902,#17908);
#17910= IFCCARTESIANPOINT((349.98303222988,2.48837750405073E-009));
#17911= IFCCARTESIANPOINT((600.002502448195,249.98109436439));
#17912= IFCCARTESIANPOINT((349.979919439138,500.002227785983));
#17913= IFCCARTESIANPOINT((-0.00751423426117981,499.995819092401));
#17914= IFCPOLYLINE((#54,#17910,#17911,#17912,#17913,#54,#54));
#17915= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL20*600',#17914);
#17916= IFCEXTRUDEDAREASOLID(#17915,#17835,#9,20.);
#17917= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#17916));
#17918= IFCSTYLEDITEM(#17916,(#17828),$);
#17919= IFCPRODUCTDEFINITIONSHAPE($,$,(#17917));
#17920= IFCPLATE('1Td1iR0024E34rDp0rCJ4s',#5,'GOMULU LEVHA','PL20*600','PL20*600',#17909,#17919,'XX/119');
#17921= IFCPLATETYPE('3FLQL_0QH7RO6wjSRE1Ow9',#5,'PL20*600',$,$,$,$,$,$,.NOTDEFINED.);
#17922= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('XX/119'),$);
#17923= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('XX/119'),$);
#17924= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PL20*600'),$);
#17925= IFCPROPERTYSET('2h_INCj9948eoW_IEszzWz',#5,'Tekla Common','Common Properties to Shared building elements',(#17842,#17843,#17922,#17923,#74,#75,#17846,#4046,#1732,#17924,#17848));
#17926= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.0047499561965412),$);
#17927= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.0047499561965412),$);
#17928= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.0047499561965412),$);
#17929= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.237497809826641),$);
#17930= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.513137707228804),$);
#17931= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.300004466297552),$);
#17932= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(600.006259238697),$);
#17933= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(500.002227773766),$);
#17934= IFCPROPERTYSET('0fAD90SITFLQGCuTFJHN0X',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#17926,#17927,#17928,#17929,#1744,#17930,#17931,#17932,#1848,#17933));
#17935= IFCQUANTITYLENGTH('Width',$,$,600.006259238697);
#17936= IFCQUANTITYAREA('NetArea',$,$,0.513137707228804);
#17937= IFCQUANTITYAREA('GrossArea',$,$,0.300004466297552);
#17938= IFCQUANTITYVOLUME('NetVolume',$,$,0.0047499561965412);
#17939= IFCQUANTITYVOLUME('GrossVolume',$,$,0.0047499561965412);
#17940= IFCELEMENTQUANTITY('2a9UF4bKTEZOpw2bht9o4H',#5,'BaseQuantities',$,$,(#17935,#17936,#17937,#17862,#17938,#17939));
#17941= IFCLOCALPLACEMENT(#30,#10);
#17942= IFCELEMENTASSEMBLY('1Td1iR001t334rDp0rCJ4s',#5,'Steel Assembly',$,$,#17941,$,'B/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#17943= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(0.65233499999999),$);
#17944= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' +20.050'),$);
#17945= IFCPROPERTYSET('24TBeBr0n0WgrZW8rvm2OG',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#17943,#17944,#136,#4310,#1615,#4251));
#17946= IFCQUANTITYLENGTH('Width',$,$,8.);
#17947= IFCELEMENTQUANTITY('11iIhgyMfCGAvq81n4AIWa',#5,'BaseQuantities',$,$,(#17946));
#17948= IFCCARTESIANPOINT((45060.,-355.163143608003,20200.001693145));
#17949= IFCAXIS2PLACEMENT3D(#17948,#501,#185);
#17950= IFCLOCALPLACEMENT(#17941,#17949);
#17951= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12917));
#17952= IFCPRODUCTDEFINITIONSHAPE($,$,(#17951));
#17953= IFCPLATE('1Td1iR002DUJ4rDp0rCJ4s',#5,'DETAY','PL8*70','PL8*70',#17950,#17952,'P/389(?)');
#17954= IFCPLATETYPE('1OCxV_KS1C2fe4BTQP684t',#5,'PL8*70',$,$,$,$,$,$,.NOTDEFINED.);
#17955= IFCPROPERTYSET('31Vj0$hePBbRp5ElW0Az0d',#5,'Tekla Common','Common Properties to Shared building elements',(#12922,#12072,#12923,#4268,#74,#75,#919,#77,#78,#12925,#921));
#17956= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(0.65233499999999),$);
#17957= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(0.65233499999999),$);
#17958= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(0.65233499999999),$);
#17959= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(8.30999999999987E-005),$);
#17960= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(8.30999999999987E-005),$);
#17961= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(8.30999999999987E-005),$);
#17962= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.0242247056274844),$);
#17963= IFCPROPERTYSET('2DiszsD355Zv5D3kS_7i34',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#17956,#17957,#12929,#17958,#17959,#17960,#17961,#12934,#12935,#17962,#12937,#10678,#12938,#12939));
#17964= IFCQUANTITYAREA('NetArea',$,$,0.0242247056274844);
#17965= IFCQUANTITYVOLUME('NetVolume',$,$,8.30999999999987E-005);
#17966= IFCQUANTITYVOLUME('GrossVolume',$,$,8.30999999999987E-005);
#17967= IFCELEMENTQUANTITY('32_7A$ECTBNwbtlUzKgyse',#5,'BaseQuantities',$,$,(#12941,#17964,#12943,#12944,#17965,#17966));
#17968= IFCLOCALPLACEMENT(#30,#10);
#17969= IFCELEMENTASSEMBLY('1Td1iR001t3J4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17968,$,'B/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#17970= IFCCARTESIANPOINT((44910.,-355.163143608003,20200.001693145));
#17971= IFCAXIS2PLACEMENT3D(#17970,#8,#7);
#17972= IFCLOCALPLACEMENT(#17968,#17971);
#17973= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12917));
#17974= IFCPRODUCTDEFINITIONSHAPE($,$,(#17973));
#17975= IFCPLATE('1Td1iR002DV34rDp0rCJ4s',#5,'DETAY','PL8*70','PL8*70',#17972,#17974,'P/389(?)');
#17976= IFCLOCALPLACEMENT(#30,#10);
#17977= IFCELEMENTASSEMBLY('1Td1iR001t3Z4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17976,$,'B/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#17978= IFCCARTESIANPOINT((44250.,-355.163143608003,20200.001693145));
#17979= IFCAXIS2PLACEMENT3D(#17978,#501,#185);
#17980= IFCLOCALPLACEMENT(#17976,#17979);
#17981= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12917));
#17982= IFCPRODUCTDEFINITIONSHAPE($,$,(#17981));
#17983= IFCPLATE('1Td1iR002DVp4rDp0rCJ4s',#5,'DETAY','PL8*70','PL8*70',#17980,#17982,'P/389(?)');
#17984= IFCLOCALPLACEMENT(#30,#10);
#17985= IFCELEMENTASSEMBLY('1Td1iR001t3p4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17984,$,'B/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#17986= IFCCARTESIANPOINT((44100.,-355.163143608003,20200.001693145));
#17987= IFCAXIS2PLACEMENT3D(#17986,#8,#7);
#17988= IFCLOCALPLACEMENT(#17984,#17987);
#17989= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12917));
#17990= IFCPRODUCTDEFINITIONSHAPE($,$,(#17989));
#17991= IFCPLATE('1Td1iR002DWZ4rDp0rCJ4s',#5,'DETAY','PL8*70','PL8*70',#17988,#17990,'P/389(?)');
#17992= IFCLOCALPLACEMENT(#30,#10);
#17993= IFCELEMENTASSEMBLY('1Td1iR001t4J4rDp0rCJ4s',#5,'Steel Assembly',$,$,#17992,$,'B/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#17994= IFCCARTESIANPOINT((43440.,-355.163143608003,20200.001693145));
#17995= IFCAXIS2PLACEMENT3D(#17994,#501,#185);
#17996= IFCLOCALPLACEMENT(#17992,#17995);
#17997= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12917));
#17998= IFCPRODUCTDEFINITIONSHAPE($,$,(#17997));
#17999= IFCPLATE('1Td1iR002DXJ4rDp0rCJ4s',#5,'DETAY','PL8*70','PL8*70',#17996,#17998,'P/389(?)');
#18000= IFCLOCALPLACEMENT(#30,#10);
#18001= IFCELEMENTASSEMBLY('1Td1iR001t434rDp0rCJ4s',#5,'Steel Assembly',$,$,#18000,$,'B/0(?)',.NOTDEFINED.,.RIGID_FRAME.);
#18002= IFCCARTESIANPOINT((43290.,-355.163143608003,20200.001693145));
#18003= IFCAXIS2PLACEMENT3D(#18002,#8,#7);
#18004= IFCLOCALPLACEMENT(#18000,#18003);
#18005= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#12917));
#18006= IFCPRODUCTDEFINITIONSHAPE($,$,(#18005));
#18007= IFCPLATE('1Td1iR002DY34rDp0rCJ4s',#5,'DETAY','PL8*70','PL8*70',#18004,#18006,'P/389(?)');
#18008= IFCLOCALPLACEMENT(#30,#10);
#18009= IFCELEMENTASSEMBLY('1Td1iR002DZJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#18008,$,'XX/120',.NOTDEFINED.,.NOTDEFINED.);
#18010= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('XX/120'),$);
#18011= IFCPROPERTYSET('2HU_p$9tv7PB0P_JzXAQ8p',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#17819,#17820,#17821,#1615,#18010));
#18012= IFCCARTESIANPOINT((43939.9963897909,299.976646980504,20210.));
#18013= IFCAXIS2PLACEMENT3D(#18012,#9,#501);
#18014= IFCLOCALPLACEMENT(#18008,#18013);
#18015= IFCCARTESIANPOINT((700.,0.));
#18016= IFCCARTESIANPOINT((700.,500.));
#18017= IFCCARTESIANPOINT((0.,500.));
#18018= IFCPOLYLINE((#54,#18015,#18016,#18017,#54,#54));
#18019= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL20*500',#18018);
#18020= IFCEXTRUDEDAREASOLID(#18019,#17835,#9,20.);
#18021= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#18020));
#18022= IFCSTYLEDITEM(#18020,(#17828),$);
#18023= IFCPRODUCTDEFINITIONSHAPE($,$,(#18021));
#18024= IFCPLATE('1Td1iR002DZZ4rDp0rCJ4s',#5,'GOMULU LEVHA','PL20*500','PL20*500',#18014,#18023,'XX/120');
#18025= IFCPLATETYPE('1OBhJvjW97avpn75ecNurw',#5,'PL20*500',$,$,$,$,$,$,.NOTDEFINED.);
#18026= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('XX/120'),$);
#18027= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('XX/120'),$);
#18028= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PL20*500'),$);
#18029= IFCPROPERTYSET('0qG35doPDFWwgVl6YbZQFX',#5,'Tekla Common','Common Properties to Shared building elements',(#17842,#17843,#18026,#18027,#74,#75,#17846,#4046,#1732,#18028,#17848));
#18030= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.007),$);
#18031= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.007),$);
#18032= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.007),$);
#18033= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.35),$);
#18034= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.748),$);
#18035= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.35),$);
#18036= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(500.),$);
#18037= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(700.),$);
#18038= IFCPROPERTYSET('1UNFsJLWTBdvuzHoT_dzPr',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#18030,#18031,#18032,#18033,#1744,#18034,#18035,#18036,#1848,#18037));
#18039= IFCQUANTITYLENGTH('Width',$,$,500.);
#18040= IFCQUANTITYAREA('NetArea',$,$,0.748);
#18041= IFCQUANTITYAREA('GrossArea',$,$,0.35);
#18042= IFCQUANTITYVOLUME('NetVolume',$,$,0.007);
#18043= IFCQUANTITYVOLUME('GrossVolume',$,$,0.007);
#18044= IFCELEMENTQUANTITY('3dAtBOFmL1PAXdxLjXuoti',#5,'BaseQuantities',$,$,(#18039,#18040,#18041,#17862,#18042,#18043));
#18045= IFCLOCALPLACEMENT(#30,#10);
#18046= IFCELEMENTASSEMBLY('1Td1iR002DaJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#18045,$,'XX/120',.NOTDEFINED.,.NOTDEFINED.);
#18047= IFCCARTESIANPOINT((43129.9963897909,299.976646980504,20210.));
#18048= IFCAXIS2PLACEMENT3D(#18047,#9,#501);
#18049= IFCLOCALPLACEMENT(#18045,#18048);
#18050= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#18020));
#18051= IFCPRODUCTDEFINITIONSHAPE($,$,(#18050));
#18052= IFCPLATE('1Td1iR002DaZ4rDp0rCJ4s',#5,'GOMULU LEVHA','PL20*500','PL20*500',#18049,#18051,'XX/120');
#18053= IFCLOCALPLACEMENT(#30,#10);
#18054= IFCELEMENTASSEMBLY('1Td1iR0025$p4rDp0rCJ4s',#5,'Steel Assembly',$,$,#18053,$,'XX/120',.NOTDEFINED.,.NOTDEFINED.);
#18055= IFCPROPERTYSET('14hy7OfgD8GPVsjiyH9vwl',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#17819,#17820,#17821,#3342,#18010));
#18056= IFCCARTESIANPOINT((48550.0023287627,4165.00561245356,20210.));
#18057= IFCAXIS2PLACEMENT3D(#18056,#9,#185);
#18058= IFCLOCALPLACEMENT(#18053,#18057);
#18059= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#18020));
#18060= IFCPRODUCTDEFINITIONSHAPE($,$,(#18059));
#18061= IFCPLATE('1Td1iR0025$Z4rDp0rCJ4s',#5,'GOMULU LEVHA','PL20*500','PL20*500',#18058,#18060,'XX/120');
#18062= IFCLOCALPLACEMENT(#30,#10);
#18063= IFCELEMENTASSEMBLY('1Td1iR00260p4rDp0rCJ4s',#5,'Steel Assembly',$,$,#18062,$,'XX/118',.NOTDEFINED.,.NOTDEFINED.);
#18064= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('XX/118'),$);
#18065= IFCPROPERTYSET('1ZjtL27TDDwvJM603_rwmp',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#17819,#17820,#17821,#3342,#18064));
#18066= IFCCARTESIANPOINT((48550.0085518295,1815.00457675126,20210.));
#18067= IFCAXIS2PLACEMENT3D(#18066,#9,#185);
#18068= IFCLOCALPLACEMENT(#18062,#18067);
#18069= IFCCARTESIANPOINT((700.000061035156,2.27328200708143E-009));
#18070= IFCCARTESIANPOINT((700.000000000116,65.2329864517869));
#18071= IFCCARTESIANPOINT((246.436798096605,500.00000000056));
#18072= IFCPOLYLINE((#54,#18069,#18070,#18071,#18017,#54,#54));
#18073= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL20*500',#18072);
#18074= IFCEXTRUDEDAREASOLID(#18073,#17835,#9,20.);
#18075= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#18074));
#18076= IFCSTYLEDITEM(#18074,(#17828),$);
#18077= IFCPRODUCTDEFINITIONSHAPE($,$,(#18075));
#18078= IFCPLATE('1Td1iR00260Z4rDp0rCJ4s',#5,'GOMULU LEVHA','PL20*500','PL20*500',#18068,#18077,'XX/118');
#18079= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('XX/118'),$);
#18080= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('XX/118'),$);
#18081= IFCPROPERTYSET('3tYfGIEjX1auDUoje8wNs3',#5,'Tekla Common','Common Properties to Shared building elements',(#17842,#17843,#18079,#18080,#74,#75,#17846,#4046,#1732,#18028,#17848));
#18082= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.00502805683421852),$);
#18083= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.00502805683421852),$);
#18084= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.00502805683421852),$);
#18085= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.251402841710926),$);
#18086= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.545604778557448),$);
#18087= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(0.350000030517669),$);
#18088= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(500.000000000131),$);
#18089= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(700.000061035156),$);
#18090= IFCPROPERTYSET('2wkyU2k_vBPApozky3PwFR',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#18082,#18083,#18084,#18085,#1744,#18086,#18087,#18088,#1848,#18089));
#18091= IFCQUANTITYLENGTH('Width',$,$,500.000000000131);
#18092= IFCQUANTITYAREA('NetArea',$,$,0.545604778557448);
#18093= IFCQUANTITYAREA('GrossArea',$,$,0.35000003051767);
#18094= IFCQUANTITYVOLUME('NetVolume',$,$,0.00502805683421852);
#18095= IFCQUANTITYVOLUME('GrossVolume',$,$,0.00502805683421852);
#18096= IFCELEMENTQUANTITY('3frF2Vs9DAgA$5KbkE0eOY',#5,'BaseQuantities',$,$,(#18091,#18092,#18093,#17862,#18094,#18095));
#18097= IFCLOCALPLACEMENT(#30,#10);
#18098= IFCELEMENTASSEMBLY('1Td1iR00261p4rDp0rCJ4s',#5,'Steel Assembly',$,$,#18097,$,'XX/117',.NOTDEFINED.,.NOTDEFINED.);
#18099= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('XX/117'),$);
#18100= IFCPROPERTYSET('2x3NaH5Mf6zfjcf0IjPJcw',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#17819,#17820,#17821,#1615,#18099));
#18101= IFCCARTESIANPOINT((46488.8761486427,299.97683215572,20210.));
#18102= IFCAXIS2PLACEMENT3D(#18101,#9,#185);
#18103= IFCLOCALPLACEMENT(#18097,#18102);
#18104= IFCCARTESIANPOINT((118.87491607666,0.));
#18105= IFCCARTESIANPOINT((118.87491607666,699.999938964844));
#18106= IFCCARTESIANPOINT((-381.125122070313,700.));
#18107= IFCCARTESIANPOINT((-381.125122070313,418.869812011719));
#18108= IFCPOLYLINE((#54,#18104,#18105,#18106,#18107,#54,#54));
#18109= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL20*500',#18108);
#18110= IFCEXTRUDEDAREASOLID(#18109,#17835,#9,20.);
#18111= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#18110));
#18112= IFCSTYLEDITEM(#18110,(#17828),$);
#18113= IFCPRODUCTDEFINITIONSHAPE($,$,(#18111));
#18114= IFCPLATE('1Td1iR00261Z4rDp0rCJ4s',#5,'GOMULU LEVHA','PL20*500','PL20*500',#18103,#18113,'XX/117');
#18115= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('XX/117'),$);
#18116= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('XX/117'),$);
#18117= IFCPROPERTYSET('055OhDV2v1XA28SGDBlRts',#5,'Tekla Common','Common Properties to Shared building elements',(#17842,#17843,#18115,#18116,#74,#75,#17846,#4046,#1732,#18028,#17848));
#18118= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.00540358214653646),$);
#18119= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.00540358214653646),$);
#18120= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.00540358214653646),$);
#18121= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.270179107326823),$);
#18122= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(0.583684538561559),$);
#18123= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(500.000038146973),$);
#18124= IFCPROPERTYSET('2hzm33XNrE3x10KvxgUCz1',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#1736,#1737,#1738,#1739,#18118,#18119,#18120,#18121,#1744,#18122,#18087,#18123,#1848,#18037));
#18125= IFCQUANTITYLENGTH('Width',$,$,500.000038146973);
#18126= IFCQUANTITYAREA('NetArea',$,$,0.583684538561559);
#18127= IFCQUANTITYAREA('GrossArea',$,$,0.350000026702881);
#18128= IFCQUANTITYVOLUME('NetVolume',$,$,0.00540358214653646);
#18129= IFCQUANTITYVOLUME('GrossVolume',$,$,0.00540358214653646);
#18130= IFCELEMENTQUANTITY('18ojVkzOr4SgUbAyAxX9Cz',#5,'BaseQuantities',$,$,(#18125,#18126,#18127,#17862,#18128,#18129));
#18131= IFCLOCALPLACEMENT(#30,#10);
#18132= IFCELEMENTASSEMBLY('1Td1iR0026mJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#18131,$,'XX/120',.NOTDEFINED.,.NOTDEFINED.);
#18133= IFCCARTESIANPOINT((44749.9963897909,299.976646980504,20210.));
#18134= IFCAXIS2PLACEMENT3D(#18133,#9,#501);
#18135= IFCLOCALPLACEMENT(#18131,#18134);
#18136= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#18020));
#18137= IFCPRODUCTDEFINITIONSHAPE($,$,(#18136));
#18138= IFCPLATE('1Td1iR0026mZ4rDp0rCJ4s',#5,'GOMULU LEVHA','PL20*500','PL20*500',#18135,#18137,'XX/120');
#18139= IFCLOCALPLACEMENT(#30,#10);
#18140= IFCELEMENTASSEMBLY('1Td1iR0026nJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#18139,$,'XX/120',.NOTDEFINED.,.NOTDEFINED.);
#18141= IFCLOCALPLACEMENT(#18139,#18013);
#18142= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#18020));
#18143= IFCPRODUCTDEFINITIONSHAPE($,$,(#18142));
#18144= IFCPLATE('1Td1iR0026nZ4rDp0rCJ4s',#5,'GOMULU LEVHA','PL20*500','PL20*500',#18141,#18143,'XX/120');
#18145= IFCLOCALPLACEMENT(#30,#10);
#18146= IFCELEMENTASSEMBLY('1Td1iR0026oJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#18145,$,'XX/120',.NOTDEFINED.,.NOTDEFINED.);
#18147= IFCLOCALPLACEMENT(#18145,#18048);
#18148= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#18020));
#18149= IFCPRODUCTDEFINITIONSHAPE($,$,(#18148));
#18150= IFCPLATE('1Td1iR0026oZ4rDp0rCJ4s',#5,'GOMULU LEVHA','PL20*500','PL20*500',#18147,#18149,'XX/120');
#18151= IFCLOCALPLACEMENT(#30,#10);
#18152= IFCELEMENTASSEMBLY('1Td1iR0026pJ4rDp0rCJ4s',#5,'Steel Assembly',$,$,#18151,$,'XX/120',.NOTDEFINED.,.NOTDEFINED.);
#18153= IFCPROPERTYSET('2mBV3ryE951OxfrxbqJkcU',#5,'Tekla Assembly','Assembly Properties',(#34,#35,#1697,#17819,#17820,#17821,#16259,#18010));
#18154= IFCCARTESIANPOINT((39079.9963897909,299.976646980504,20210.));
#18155= IFCAXIS2PLACEMENT3D(#18154,#9,#501);
#18156= IFCLOCALPLACEMENT(#18151,#18155);
#18157= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#18020));
#18158= IFCPRODUCTDEFINITIONSHAPE($,$,(#18157));
#18159= IFCPLATE('1Td1iR0026pZ4rDp0rCJ4s',#5,'GOMULU LEVHA','PL20*500','PL20*500',#18156,#18158,'XX/120');
#18160= IFCLOCALPLACEMENT(#30,#10);
#18161= IFCELEMENTASSEMBLY('1Td1iR0027EZ4rDp0rCJ4s',#5,'BA PARAPET',$,$,#18160,$,'XX/81',.NOTDEFINED.,.REINFORCEMENT_UNIT.);
#18162= IFCPROPERTYSINGLEVALUE('Cast unit vertical position code',$,IFCLABEL('+20.7>'),$);
#18163= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(2561.98262826366),$);
#18164= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' +20.700'),$);
#18165= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +21.400'),$);
#18166= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit name',$,IFCLABEL('BA PARAPET'),$);
#18167= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('XX/81'),$);
#18168= IFCPROPERTYSET('26SsCQUSv9Me65zuz$QxyU',#5,'Tekla Assembly','Assembly Properties',(#18162,#9687,#18163,#18164,#18165,#18166,#3342,#18167));
#18169= IFCQUANTITYLENGTH('Width',$,$,700.);
#18170= IFCELEMENTQUANTITY('11APwkoobCrgRaaZTzx$vn',#5,'BaseQuantities',$,$,(#18169));
#18171= IFCCARTESIANPOINT((41450.0173367234,499.979370117187,21050.));
#18172= IFCAXIS2PLACEMENT3D(#18171,#8,#7);
#18173= IFCLOCALPLACEMENT(#18160,#18172);
#18174= IFCRECTANGLEPROFILEDEF(.AREA.,'500*700',#197,700.,500.);
#18175= IFCCARTESIANPOINT((3049.97931936151,-3.63797880709171E-012,-5.04576752332703E-021));
#18176= IFCAXIS2PLACEMENT3D(#18175,#185,#501);
#18177= IFCEXTRUDEDAREASOLID(#18174,#18176,#9,3049.9793193615);
#18178= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#18177));
#18179= IFCSTYLEDITEM(#18177,(#13592),$);
#18180= IFCPRODUCTDEFINITIONSHAPE($,$,(#18178));
#18181= IFCBEAM('1Td1iR0027EJ4rDp0rCJ4s',#5,'BA PARAPET','500*700','500*700',#18173,#18180,'XX/81');
#18182= IFCBEAMTYPE('2RED8SCYjFRP6jCMVJnvM5',#5,'500*700',$,$,$,$,$,$,.NOTDEFINED.);
#18183= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' +20.700'),$);
#18184= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +21.400'),$);
#18185= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('XX/81'),$);
#18186= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('XX/81'),$);
#18187= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('500*700'),$);
#18188= IFCPROPERTYSINGLEVALUE('Name',$,IFCLABEL('BA PARAPET'),$);
#18189= IFCPROPERTYSET('1j9eYp5IjDkfKK6Zxc2LvY',#5,'Tekla Common','Common Properties to Shared building elements',(#18183,#18184,#18185,#18186,#74,#75,#13610,#77,#9722,#18187,#18188));
#18190= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(2561.98262826366),$);
#18191= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(2561.98262826366),$);
#18192= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(2561.98262828317),$);
#18193= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(2561.98262826366),$);
#18194= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(1.06749276177653),$);
#18195= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(1.06749276177653),$);
#18196= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(1.06749276177653),$);
#18197= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(1.52498965968075),$);
#18198= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(3.13036875347706),$);
#18199= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(8.01995036646761),$);
#18200= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(8.01995036646761),$);
#18201= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(500.000000003806),$);
#18202= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(700.),$);
#18203= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(3049.9793193615),$);
#18204= IFCPROPERTYSET('0hoGn6jvHDsQzSVFoLEX_w',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#18190,#18191,#18192,#18193,#18194,#18195,#18196,#18197,#18198,#18199,#18200,#18201,#18202,#18203));
#18205= IFCQUANTITYLENGTH('Length',$,$,3049.9793193615);
#18206= IFCQUANTITYAREA('OuterSurfaceArea',$,$,8.01995036646761);
#18207= IFCQUANTITYVOLUME('NetVolume',$,$,1.06749276177653);
#18208= IFCQUANTITYWEIGHT('NetWeight',$,$,2561.98262826366);
#18209= IFCELEMENTQUANTITY('1RqIGiDef8rgITazHMGZ1W',#5,'BaseQuantities',$,$,(#18205,#18206,#18207,#18208));
#18210= IFCLOCALPLACEMENT(#30,#10);
#18211= IFCELEMENTASSEMBLY('1Td1iR0027FZ4rDp0rCJ4s',#5,'DOSEME',$,$,#18210,$,'XX/89',.NOTDEFINED.,.REINFORCEMENT_UNIT.);
#18212= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(6770.50427674064),$);
#18213= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit name',$,IFCLABEL('DOSEME'),$);
#18214= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit position code',$,IFCLABEL('4/1-6/N2-M1'),$);
#18215= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('XX/89'),$);
#18216= IFCPROPERTYSET('0PrGeH87H7_QwVpBA4Z8Zr',#5,'Tekla Assembly','Assembly Properties',(#18162,#9687,#18212,#18164,#18165,#18213,#18214,#18215));
#18217= IFCCARTESIANPOINT((39550.,1700.,21050.));
#18218= IFCAXIS2PLACEMENT3D(#18217,#9,#501);
#18219= IFCLOCALPLACEMENT(#18210,#18218);
#18220= IFCCARTESIANPOINT((950.,-7.27595761418343E-012));
#18221= IFCCARTESIANPOINT((950.,-799.994384765625));
#18222= IFCCARTESIANPOINT((1450.02075195313,-799.994384765625));
#18223= IFCCARTESIANPOINT((1450.02075195313,-1.01877958513796E-007));
#18224= IFCCARTESIANPOINT((2149.9853515625,604.979797363281));
#18225= IFCCARTESIANPOINT((2150.,1205.01538085938));
#18226= IFCCARTESIANPOINT((1450.02062988281,1900.01733398438));
#18227= IFCCARTESIANPOINT((1.42996896101977E-007,1900.01733398438));
#18228= IFCPOLYLINE((#54,#18220,#18221,#18222,#18223,#18224,#18225,#18226,#18227,#54,#54));
#18229= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL700*2150',#18228);
#18230= IFCCARTESIANPOINT((0.,0.,-350.));
#18231= IFCAXIS2PLACEMENT3D(#18230,#9,#7);
#18232= IFCEXTRUDEDAREASOLID(#18229,#18231,#9,700.);
#18233= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#18232));
#18234= IFCSTYLEDITEM(#18232,(#13592),$);
#18235= IFCPRODUCTDEFINITIONSHAPE($,$,(#18233));
#18236= IFCSLAB('1Td1iR0027FJ4rDp0rCJ4s',#5,'DOSEME','PL700*2150','PL700*2150',#18219,#18235,'XX/89',.FLOOR.);
#18237= IFCSLABTYPE('37CmEUmhb0nh$ekN9r6nZ7',#5,'PL700*2150',$,$,$,$,$,$,.NOTDEFINED.);
#18238= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('XX/89'),$);
#18239= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('XX/89'),$);
#18240= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PL700*2150'),$);
#18241= IFCPROPERTYSINGLEVALUE('Name',$,IFCLABEL('DOSEME'),$);
#18242= IFCPROPERTYSET('339yyzPd17fxs$LEaU2DYR',#5,'Tekla Common','Common Properties to Shared building elements',(#18183,#18184,#18238,#18239,#74,#75,#13610,#77,#9722,#18240,#18241));
#18243= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(6770.50427674064),$);
#18244= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(6770.50427674064),$);
#18245= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(9752.44232786322),$);
#18246= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(6770.50427674064),$);
#18247= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(2.82104344864193),$);
#18248= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(2.82104344864193),$);
#18249= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(2.82104344864193),$);
#18250= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(4.03006206948848),$);
#18251= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(2.11185016114482),$);
#18252= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(14.2982905478664),$);
#18253= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(5.80502519515668),$);
#18254= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(2149.99999991232),$);
#18255= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(2700.01171878763),$);
#18256= IFCPROPERTYSET('357MezCCTA9PWKkfsZk1$N',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#18243,#18244,#18245,#18246,#18247,#18248,#18249,#18250,#18251,#18252,#18253,#18254,#18202,#18255));
#18257= IFCQUANTITYVOLUME('NetVolume',$,$,2.82104344864193);
#18258= IFCQUANTITYAREA('NetArea',$,$,4.03006206948848);
#18259= IFCQUANTITYWEIGHT('NetWeight',$,$,6770.50427674064);
#18260= IFCELEMENTQUANTITY('01LfWfgFnBQB8hX3JiTwfr',#5,'BaseQuantities',$,$,(#18169,#18257,#18258,#18259));
#18261= IFCLOCALPLACEMENT(#30,#10);
#18262= IFCELEMENTASSEMBLY('1Td1iR0027GZ4rDp0rCJ4s',#5,'BA PARAPET',$,$,#18261,$,'XX/82',.NOTDEFINED.,.REINFORCEMENT_UNIT.);
#18263= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(1554.00281118946),$);
#18264= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('XX/82'),$);
#18265= IFCPROPERTYSET('2Qop1RVXn2IxAuoGbJHwXN',#5,'Tekla Assembly','Assembly Properties',(#18162,#9687,#18263,#18164,#18165,#18166,#3342,#18264));
#18266= IFCCARTESIANPOINT((44599.9966533459,499.9793367011,21050.));
#18267= IFCAXIS2PLACEMENT3D(#18266,#8,#7);
#18268= IFCLOCALPLACEMENT(#18261,#18267);
#18269= IFCCARTESIANPOINT((1850.00334665412,0.,0.));
#18270= IFCAXIS2PLACEMENT3D(#18269,#185,#501);
#18271= IFCEXTRUDEDAREASOLID(#18174,#18270,#9,1850.00334665412);
#18272= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#18271));
#18273= IFCSTYLEDITEM(#18271,(#13592),$);
#18274= IFCPRODUCTDEFINITIONSHAPE($,$,(#18272));
#18275= IFCBEAM('1Td1iR0027GJ4rDp0rCJ4s',#5,'BA PARAPET','500*700','500*700',#18268,#18274,'XX/82');
#18276= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('XX/82'),$);
#18277= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('XX/82'),$);
#18278= IFCPROPERTYSET('05zEJQV1vDkv48jNop7rTf',#5,'Tekla Common','Common Properties to Shared building elements',(#18183,#18184,#18276,#18277,#74,#75,#13610,#77,#9722,#18187,#18188));
#18279= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(1554.00281118946),$);
#18280= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(1554.00281118946),$);
#18281= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(1554.00281118946),$);
#18282= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(1554.00281118946),$);
#18283= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(0.647501171328942),$);
#18284= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(0.647501171328942),$);
#18285= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(0.647501171328942),$);
#18286= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(0.92500167332706),$);
#18287= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(3.30759249272891),$);
#18288= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(5.14000803196989),$);
#18289= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(5.14000803196989),$);
#18290= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(1850.00334665412),$);
#18291= IFCPROPERTYSET('2tu0u3rb55F8bUhlmGjOQ1',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#18279,#18280,#18281,#18282,#18283,#18284,#18285,#18286,#18287,#18288,#18289,#18036,#18202,#18290));
#18292= IFCQUANTITYLENGTH('Length',$,$,1850.00334665412);
#18293= IFCQUANTITYAREA('OuterSurfaceArea',$,$,5.14000803196989);
#18294= IFCQUANTITYVOLUME('NetVolume',$,$,0.647501171328942);
#18295= IFCQUANTITYWEIGHT('NetWeight',$,$,1554.00281118946);
#18296= IFCELEMENTQUANTITY('34jCtBDDv8FRd6Dj75XJ$B',#5,'BaseQuantities',$,$,(#18292,#18293,#18294,#18295));
#18297= IFCLOCALPLACEMENT(#30,#10);
#18298= IFCELEMENTASSEMBLY('1Td1iR0027IZ4rDp0rCJ4s',#5,'DOSEME',$,$,#18297,$,'XX/91',.NOTDEFINED.,.REINFORCEMENT_UNIT.);
#18299= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(6862.87250632678),$);
#18300= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('XX/91'),$);
#18301= IFCPROPERTYSET('3CiRDS3Hz4YBPHXgTsGYZV',#5,'Tekla Assembly','Assembly Properties',(#18162,#9687,#18299,#18164,#18165,#18213,#3342,#18300));
#18302= IFCCARTESIANPOINT((46450.,1700.,21050.));
#18303= IFCAXIS2PLACEMENT3D(#18302,#9,#501);
#18304= IFCLOCALPLACEMENT(#18297,#18303);
#18305= IFCCARTESIANPOINT((1900.02075195313,0.));
#18306= IFCCARTESIANPOINT((1900.02075195313,2149.99633789063));
#18307= IFCCARTESIANPOINT((-0.00187988276593387,2150.));
#18308= IFCPOLYLINE((#54,#18305,#18306,#18307,#54,#54));
#18309= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL700*1900',#18308);
#18310= IFCEXTRUDEDAREASOLID(#18309,#18231,#9,700.);
#18311= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#18310));
#18312= IFCSTYLEDITEM(#18310,(#13592),$);
#18313= IFCPRODUCTDEFINITIONSHAPE($,$,(#18311));
#18314= IFCSLAB('1Td1iR0027IJ4rDp0rCJ4s',#5,'DOSEME','PL700*1900','PL700*1900',#18304,#18313,'XX/91',.FLOOR.);
#18315= IFCSLABTYPE('2SwXZsUZT1Ow4rMDFEYF3Y',#5,'PL700*1900',$,$,$,$,$,$,.NOTDEFINED.);
#18316= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('XX/91'),$);
#18317= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('XX/91'),$);
#18318= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PL700*1900'),$);
#18319= IFCPROPERTYSET('2Knud60yr97vo3T$IxAbjL',#5,'Tekla Common','Common Properties to Shared building elements',(#18183,#18184,#18316,#18317,#74,#75,#13610,#77,#9722,#18318,#18241));
#18320= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(6862.87250632678),$);
#18321= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(6862.87250632678),$);
#18322= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(6862.88704916418),$);
#18323= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(6862.87250632678),$);
#18324= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(2.85953021096949),$);
#18325= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(2.85953021096949),$);
#18326= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(2.85953021096949),$);
#18327= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(4.08504315852785),$);
#18328= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(2.01666490372297),$);
#18329= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(13.8401141222345),$);
#18330= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(4.08505181497868),$);
#18331= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(1900.02263183677),$);
#18332= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(2150.00166131159),$);
#18333= IFCPROPERTYSET('3JSoz_d$H5wPd3VwwCzTeG',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#18320,#18321,#18322,#18323,#18324,#18325,#18326,#18327,#18328,#18329,#18330,#18331,#18202,#18332));
#18334= IFCQUANTITYVOLUME('NetVolume',$,$,2.85953021096949);
#18335= IFCQUANTITYAREA('NetArea',$,$,4.08504315852785);
#18336= IFCQUANTITYWEIGHT('NetWeight',$,$,6862.87250632678);
#18337= IFCELEMENTQUANTITY('1S2AXs_OnEa8QB8IHgU1Df',#5,'BaseQuantities',$,$,(#18169,#18334,#18335,#18336));
#18338= IFCLOCALPLACEMENT(#30,#10);
#18339= IFCELEMENTASSEMBLY('1Td1iR0027WZ4rDp0rCJ4s',#5,'DOSEME',$,$,#18338,$,'XX/78',.NOTDEFINED.,.REINFORCEMENT_UNIT.);
#18340= IFCPROPERTYSINGLEVALUE('Cast unit vertical position code',$,IFCLABEL('+20.7'),$);
#18341= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(1322580.53958482),$);
#18342= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' +20.700'),$);
#18343= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit position code',$,IFCLABEL('<1/1-6/N2-P1'),$);
#18344= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('XX/78'),$);
#18345= IFCPROPERTYSET('0EqDpfDTvCrhYYo4pBetJL',#5,'Tekla Assembly','Assembly Properties',(#18340,#9687,#18341,#17819,#18342,#18213,#18343,#18344));
#18346= IFCELEMENTQUANTITY('3aYZxCnbT7gxvlwECyCaSO',#5,'BaseQuantities',$,$,(#18039));
#18347= IFCCARTESIANPOINT((-1886.4423933622,22049.9951716511,20450.));
#18348= IFCDIRECTION((0.290174911024165,-0.956973626079694,0.));
#18349= IFCAXIS2PLACEMENT3D(#18347,#9,#18348);
#18350= IFCLOCALPLACEMENT(#18338,#18349);
#18351= IFCCARTESIANPOINT((10292.8652342929,1.99725036509335E-008));
#18352= IFCCARTESIANPOINT((21541.070312319,-6498.6943359003));
#18353= IFCCARTESIANPOINT((36181.88281227,41785.5273437943));
#18354= IFCCARTESIANPOINT((14649.9814452635,48314.4648437571));
#18355= IFCPOLYLINE((#54,#18351,#18352,#18353,#18354,#54,#54));
#18356= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL500*22500',#18355);
#18357= IFCCARTESIANPOINT((0.,0.,-249.999999999996));
#18358= IFCAXIS2PLACEMENT3D(#18357,#9,#7);
#18359= IFCEXTRUDEDAREASOLID(#18356,#18358,#9,500.);
#18360= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#18359));
#18361= IFCSTYLEDITEM(#18359,(#13592),$);
#18362= IFCPRODUCTDEFINITIONSHAPE($,$,(#18360));
#18363= IFCSLAB('1Td1iR0027WJ4rDp0rCJ4s',#5,'DOSEME','PL500*22500','PL500*22500',#18350,#18362,'XX/78',.FLOOR.);
#18364= IFCSLABTYPE('3qESamx7XCAvvRLdkqhw7X',#5,'PL500*22500',$,$,$,$,$,$,.NOTDEFINED.);
#18365= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' +20.700'),$);
#18366= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('XX/78'),$);
#18367= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('XX/78'),$);
#18368= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PL500*22500'),$);
#18369= IFCPROPERTYSET('0ejLXOhrXE1uFzikgC3Wwb',#5,'Tekla Common','Common Properties to Shared building elements',(#17842,#18365,#18366,#18367,#74,#75,#13610,#77,#9722,#18368,#18241));
#18370= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(1322580.53958482),$);
#18371= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(1322580.53958482),$);
#18372= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(1363141.32583433),$);
#18373= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(1322580.53958482),$);
#18374= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(551.075224827008),$);
#18375= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(551.075224827008),$);
#18376= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(551.075224827008),$);
#18377= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(1102.15044965558),$);
#18378= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(1.72213598758139),$);
#18379= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(2277.66354369384),$);
#18380= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(1135.95110486195),$);
#18381= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(22499.9955859969),$);
#18382= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(500.),$);
#18383= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(50486.7256760226),$);
#18384= IFCPROPERTYSET('3xvrOJJwj9p8Ad0DwLj1Iv',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#18370,#18371,#18372,#18373,#18374,#18375,#18376,#18377,#18378,#18379,#18380,#18381,#18382,#18383));
#18385= IFCQUANTITYVOLUME('NetVolume',$,$,551.075224827008);
#18386= IFCQUANTITYAREA('NetArea',$,$,1102.15044965558);
#18387= IFCQUANTITYWEIGHT('NetWeight',$,$,1322580.53958482);
#18388= IFCELEMENTQUANTITY('2bqFGAbav6C9k4OZmARW0u',#5,'BaseQuantities',$,$,(#18039,#18385,#18386,#18387));
#18389= IFCLOCALPLACEMENT(#30,#10);
#18390= IFCELEMENTASSEMBLY('1Td1iR0027rZ4rDp0rCJ4s',#5,'DOSEME',$,$,#18389,$,'XX/77',.NOTDEFINED.,.REINFORCEMENT_UNIT.);
#18391= IFCPROPERTYSINGLEVALUE('Cast unit vertical position code',$,IFCLABEL('P1--7.55'),$);
#18392= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(77269.4164110219),$);
#18393= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -8.183'),$);
#18394= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -7.750'),$);
#18395= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit position code',$,IFCLABEL('1/1-6>/<1/1-N2'),$);
#18396= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('XX/77'),$);
#18397= IFCPROPERTYSET('3004S3UCnB$eqvAmJhFARi',#5,'Tekla Assembly','Assembly Properties',(#18391,#9687,#18392,#18393,#18394,#18213,#18395,#18396));
#18398= IFCQUANTITYLENGTH('Width',$,$,400.000000005789);
#18399= IFCELEMENTQUANTITY('3NkdDr0$nF6v7rpcZE1iA9',#5,'BaseQuantities',$,$,(#18398));
#18400= IFCCARTESIANPOINT((7350.0000000049,-412.002049911421,-7949.97747087726));
#18401= IFCDIRECTION((-2.83215758397371E-011,-0.0150092820057391,0.999887354382319));
#18402= IFCDIRECTION((1.06400000036698E-006,-0.999887354381753,-0.0150092820057306));
#18403= IFCAXIS2PLACEMENT3D(#18400,#18401,#18402);
#18404= IFCLOCALPLACEMENT(#18389,#18403);
#18405= IFCCARTESIANPOINT((2192.99609368826,-1.48975232150406E-009));
#18406= IFCCARTESIANPOINT((2193.04296867369,44008.4062499078));
#18407= IFCCARTESIANPOINT((0.0468165146183992,44008.4062499093));
#18408= IFCPOLYLINE((#54,#18405,#18406,#18407,#54,#54));
#18409= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL400*2193',#18408);
#18410= IFCEXTRUDEDAREASOLID(#18409,#13599,#9,400.);
#18411= IFCCARTESIANPOINT((1652.99621582031,0.));
#18412= IFCCARTESIANPOINT((1652.99621582031,1439.52416992188));
#18413= IFCCARTESIANPOINT((0.,1439.52416992188));
#18414= IFCPOLYLINE((#54,#18411,#18412,#18413,#54,#54));
#18415= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL438*1440',#18414);
#18416= IFCDIRECTION((-0.999887354381753,1.0638797203432E-006,-0.0150092820057391));
#18417= IFCDIRECTION((0.0150092820057306,-1.59981944451528E-008,-0.999887354382319));
#18418= IFCCARTESIANPOINT((2202.71171891064,2144.66407257394,235.63010307288));
#18419= IFCAXIS2PLACEMENT3D(#18418,#18417,#18416);
#18420= IFCEXTRUDEDAREASOLID(#18415,#18419,#9,438.);
#18421= IFCBOOLEANRESULT(.DIFFERENCE.,#18410,#18420);
#18422= IFCCARTESIANPOINT((1652.99621582031,1189.994140625));
#18423= IFCCARTESIANPOINT((0.,1189.994140625));
#18424= IFCPOLYLINE((#54,#18411,#18422,#18423,#54,#54));
#18425= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL438*1190',#18424);
#18426= IFCCARTESIANPOINT((2202.71626216937,6414.64407257153,235.630102951947));
#18427= IFCAXIS2PLACEMENT3D(#18426,#18417,#18416);
#18428= IFCEXTRUDEDAREASOLID(#18425,#18427,#9,438.);
#18429= IFCBOOLEANRESULT(.DIFFERENCE.,#18421,#18428);
#18430= IFCCARTESIANPOINT((2202.72269932681,12464.6040725681,235.630102780603));
#18431= IFCAXIS2PLACEMENT3D(#18430,#18417,#18416);
#18432= IFCEXTRUDEDAREASOLID(#18425,#18431,#9,438.);
#18433= IFCBOOLEANRESULT(.DIFFERENCE.,#18429,#18432);
#18434= IFCCARTESIANPOINT((2202.72910456425,18484.5640725647,235.630102610108));
#18435= IFCAXIS2PLACEMENT3D(#18434,#18417,#18416);
#18436= IFCEXTRUDEDAREASOLID(#18425,#18435,#9,438.);
#18437= IFCBOOLEANRESULT(.DIFFERENCE.,#18433,#18436);
#18438= IFCCARTESIANPOINT((2202.73343013921,22549.9540725624,235.630102494969));
#18439= IFCAXIS2PLACEMENT3D(#18438,#18417,#18416);
#18440= IFCEXTRUDEDAREASOLID(#18425,#18439,#9,438.);
#18441= IFCBOOLEANRESULT(.DIFFERENCE.,#18437,#18440);
#18442= IFCCARTESIANPOINT((2202.73988343753,28615.084072559,235.630102323196));
#18443= IFCAXIS2PLACEMENT3D(#18442,#18417,#18416);
#18444= IFCEXTRUDEDAREASOLID(#18425,#18443,#9,438.);
#18445= IFCBOOLEANRESULT(.DIFFERENCE.,#18441,#18444);
#18446= IFCCARTESIANPOINT((2202.74652249962,34854.8040725554,235.630102146476));
#18447= IFCAXIS2PLACEMENT3D(#18446,#18417,#18416);
#18448= IFCEXTRUDEDAREASOLID(#18425,#18447,#9,438.);
#18449= IFCBOOLEANRESULT(.DIFFERENCE.,#18445,#18448);
#18450= IFCCARTESIANPOINT((2202.74965051066,37794.6640725538,235.630102063215));
#18451= IFCAXIS2PLACEMENT3D(#18450,#18417,#18416);
#18452= IFCEXTRUDEDAREASOLID(#18425,#18451,#9,438.);
#18453= IFCBOOLEANRESULT(.DIFFERENCE.,#18449,#18452);
#18454= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#18453));
#18455= IFCSTYLEDITEM(#18410,(#13592),$);
#18456= IFCPRODUCTDEFINITIONSHAPE($,$,(#18454));
#18457= IFCSLAB('1Td1iR0027rJ4rDp0rCJ4s',#5,'DOSEME','PL400*2193','PL400*2193',#18404,#18456,'XX/77',.FLOOR.);
#18458= IFCSLABTYPE('1ICXsYVxDD7QRrjPHDNKoU',#5,'PL400*2193',$,$,$,$,$,$,.NOTDEFINED.);
#18459= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -8.183'),$);
#18460= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -7.750'),$);
#18461= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('XX/77'),$);
#18462= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('XX/77'),$);
#18463= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PL400*2193'),$);
#18464= IFCPROPERTYSET('3RizU_KUTDTO05IpFEw34j',#5,'Tekla Common','Common Properties to Shared building elements',(#18459,#18460,#18461,#18462,#74,#75,#13610,#77,#9722,#18463,#18241));
#18465= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(77269.4164110219),$);
#18466= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(77269.4164110219),$);
#18467= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(92649.8598576066),$);
#18468= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(77269.4164110219),$);
#18469= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(32.1955901712591),$);
#18470= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(38.6041057134647),$);
#18471= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(32.1955901712591),$);
#18472= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(2.69751071010444),$);
#18473= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(208.435078332252),$);
#18474= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(96.5102706850069),$);
#18475= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(2192.99615215768),$);
#18476= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(400.00000003482),$);
#18477= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(44008.4085829567),$);
#18478= IFCPROPERTYSET('0Z0parT4X6vv2ogCoFmYTO',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#18465,#18466,#18467,#18468,#18469,#18470,#18471,#1743,#18472,#18473,#18474,#18475,#18476,#18477));
#18479= IFCQUANTITYLENGTH('Width',$,$,400.00000003482);
#18480= IFCQUANTITYVOLUME('NetVolume',$,$,32.1955901712591);
#18481= IFCQUANTITYAREA('NetArea',$,$,0.);
#18482= IFCQUANTITYWEIGHT('NetWeight',$,$,77269.4164110219);
#18483= IFCELEMENTQUANTITY('0PsLGKiFXC4ujobvKh5mCK',#5,'BaseQuantities',$,$,(#18479,#18480,#18481,#18482));
#18484= IFCLOCALPLACEMENT(#30,#10);
#18485= IFCELEMENTASSEMBLY('1Td1iR0027u34rDp0rCJ4s',#5,'DOSEME',$,$,#18484,$,'XX/72(?)',.NOTDEFINED.,.REINFORCEMENT_UNIT.);
#18486= IFCPROPERTYSINGLEVALUE('Cast unit vertical position code',$,IFCLABEL('-7.55'),$);
#18487= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(588270.981257001),$);
#18488= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -7.800'),$);
#18489= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit top elevation',$,IFCLABEL(' -7.550'),$);
#18490= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit position code',$,IFCLABEL('1/1-6>/N2-P1'),$);
#18491= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('XX/72(?)'),$);
#18492= IFCPROPERTYSET('0XetfU4_X61RCJzuHUCLXl',#5,'Tekla Assembly','Assembly Properties',(#18486,#9687,#18487,#18488,#18489,#18213,#18490,#18491));
#18493= IFCQUANTITYLENGTH('Width',$,$,250.);
#18494= IFCELEMENTQUANTITY('1ra5mUAt12AONQRcsF0Gkj',#5,'BaseQuantities',$,$,(#18493));
#18495= IFCCARTESIANPOINT((7441.2944844517,22014.7186213421,-7675.));
#18496= IFCDIRECTION((-0.00523596400129087,-0.999986292246537,0.));
#18497= IFCAXIS2PLACEMENT3D(#18495,#9,#18496);
#18498= IFCLOCALPLACEMENT(#18484,#18497);
#18499= IFCCARTESIANPOINT((22430.0039060441,1.22076926345471E-007));
#18500= IFCCARTESIANPOINT((22199.5820310449,44007.199218948));
#18501= IFCCARTESIANPOINT((-230.422836302849,44007.1992188262));
#18502= IFCPOLYLINE((#54,#18499,#18500,#18501,#54,#54));
#18503= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'PL250*22430',#18502);
#18504= IFCCARTESIANPOINT((0.,0.,-125.));
#18505= IFCAXIS2PLACEMENT3D(#18504,#9,#7);
#18506= IFCEXTRUDEDAREASOLID(#18503,#18505,#9,250.);
#18507= IFCCARTESIANPOINT((1099.99853513575,1.20780896395445E-008));
#18508= IFCCARTESIANPOINT((1099.99853513576,300.001159680978));
#18509= IFCCARTESIANPOINT((2.91038304567337E-011,300.001159668915));
#18510= IFCPOLYLINE((#54,#18507,#18508,#18509,#54,#54));
#18511= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL255*300',#18510);
#18512= IFCCARTESIANPOINT((799.991896066495,42540.4603272556,127.5));
#18513= IFCAXIS2PLACEMENT3D(#18512,#596,#501);
#18514= IFCEXTRUDEDAREASOLID(#18511,#18513,#9,255.);
#18515= IFCBOOLEANRESULT(.DIFFERENCE.,#18506,#18514);
#18516= IFCCARTESIANPOINT((799.991896812335,38149.9955445408,127.500000000004));
#18517= IFCAXIS2PLACEMENT3D(#18516,#596,#501);
#18518= IFCEXTRUDEDAREASOLID(#18511,#18517,#9,255.);
#18519= IFCBOOLEANRESULT(.DIFFERENCE.,#18515,#18518);
#18520= IFCCARTESIANPOINT((799.991897118169,36349.5728760837,127.500000000011));
#18521= IFCAXIS2PLACEMENT3D(#18520,#596,#501);
#18522= IFCEXTRUDEDAREASOLID(#18511,#18521,#9,255.);
#18523= IFCBOOLEANRESULT(.DIFFERENCE.,#18519,#18522);
#18524= IFCCARTESIANPOINT((799.991897848482,32050.4090577244,127.500000000009));
#18525= IFCAXIS2PLACEMENT3D(#18524,#596,#501);
#18526= IFCEXTRUDEDAREASOLID(#18511,#18525,#9,255.);
#18527= IFCBOOLEANRESULT(.DIFFERENCE.,#18523,#18526);
#18528= IFCCARTESIANPOINT((799.991898196746,30000.2763062595,127.500000000011));
#18529= IFCAXIS2PLACEMENT3D(#18528,#596,#501);
#18530= IFCEXTRUDEDAREASOLID(#18511,#18529,#9,255.);
#18531= IFCBOOLEANRESULT(.DIFFERENCE.,#18527,#18530);
#18532= IFCCARTESIANPOINT((799.991898680928,27150.0031739353,127.500000000009));
#18533= IFCAXIS2PLACEMENT3D(#18532,#596,#501);
#18534= IFCEXTRUDEDAREASOLID(#18511,#18533,#9,255.);
#18535= IFCBOOLEANRESULT(.DIFFERENCE.,#18531,#18534);
#18536= IFCCARTESIANPOINT((799.991899275519,23649.8582154392,127.500000000009));
#18537= IFCAXIS2PLACEMENT3D(#18536,#596,#501);
#18538= IFCEXTRUDEDAREASOLID(#18511,#18537,#9,255.);
#18539= IFCBOOLEANRESULT(.DIFFERENCE.,#18535,#18538);
#18540= IFCCARTESIANPOINT((799.99189963223,21550.0046998142,127.500000000007));
#18541= IFCAXIS2PLACEMENT3D(#18540,#596,#501);
#18542= IFCEXTRUDEDAREASOLID(#18511,#18541,#9,255.);
#18543= IFCBOOLEANRESULT(.DIFFERENCE.,#18539,#18542);
#18544= IFCCARTESIANPOINT((799.991899988992,19449.861267197,127.500000000013));
#18545= IFCAXIS2PLACEMENT3D(#18544,#596,#501);
#18546= IFCEXTRUDEDAREASOLID(#18511,#18545,#9,255.);
#18547= IFCBOOLEANRESULT(.DIFFERENCE.,#18543,#18546);
#18548= IFCCARTESIANPOINT((799.99190065149,15549.8597413181,127.500000000005));
#18549= IFCAXIS2PLACEMENT3D(#18548,#596,#501);
#18550= IFCEXTRUDEDAREASOLID(#18511,#18549,#9,255.);
#18551= IFCBOOLEANRESULT(.DIFFERENCE.,#18547,#18550);
#18552= IFCCARTESIANPOINT((799.991901008201,13449.9985962986,127.500000000009));
#18553= IFCAXIS2PLACEMENT3D(#18552,#596,#501);
#18554= IFCEXTRUDEDAREASOLID(#18511,#18553,#9,255.);
#18555= IFCBOOLEANRESULT(.DIFFERENCE.,#18551,#18554);
#18556= IFCCARTESIANPOINT((799.991901364963,11349.8551636814,127.500000000004));
#18557= IFCAXIS2PLACEMENT3D(#18556,#596,#501);
#18558= IFCEXTRUDEDAREASOLID(#18511,#18557,#9,255.);
#18559= IFCBOOLEANRESULT(.DIFFERENCE.,#18555,#18558);
#18560= IFCCARTESIANPOINT((799.991902078415,7149.97265635717,127.500000000007));
#18561= IFCAXIS2PLACEMENT3D(#18560,#596,#501);
#18562= IFCEXTRUDEDAREASOLID(#18511,#18561,#9,255.);
#18563= IFCBOOLEANRESULT(.DIFFERENCE.,#18559,#18562);
#18564= IFCCARTESIANPOINT((600.006103517482,4.3121417547809E-010));
#18565= IFCCARTESIANPOINT((600.006103517006,300.000183105917));
#18566= IFCCARTESIANPOINT((-4.80213202536106E-010,300.000183105478));
#18567= IFCPOLYLINE((#54,#18564,#18565,#18566,#54,#54));
#18568= IFCARBITRARYCLOSEDPROFILEDEF(.AREA.,'BL255*300',#18567);
#18569= IFCCARTESIANPOINT((21630.0080383923,6299.96655638001,127.5));
#18570= IFCAXIS2PLACEMENT3D(#18569,#596,#8);
#18571= IFCEXTRUDEDAREASOLID(#18568,#18570,#9,255.);
#18572= IFCBOOLEANRESULT(.DIFFERENCE.,#18563,#18571);
#18573= IFCCARTESIANPOINT((21630.0080375683,11150.438052962,127.500000000004));
#18574= IFCAXIS2PLACEMENT3D(#18573,#596,#8);
#18575= IFCEXTRUDEDAREASOLID(#18568,#18574,#9,255.);
#18576= IFCBOOLEANRESULT(.DIFFERENCE.,#18572,#18575);
#18577= IFCCARTESIANPOINT((21630.0080373219,12600.862247298,127.500000000005));
#18578= IFCAXIS2PLACEMENT3D(#18577,#596,#8);
#18579= IFCEXTRUDEDAREASOLID(#18568,#18578,#9,255.);
#18580= IFCBOOLEANRESULT(.DIFFERENCE.,#18576,#18579);
#18581= IFCCARTESIANPOINT((21630.0080369651,14700.9980505206,127.500000000003));
#18582= IFCAXIS2PLACEMENT3D(#18581,#596,#8);
#18583= IFCEXTRUDEDAREASOLID(#18568,#18582,#9,255.);
#18584= IFCBOOLEANRESULT(.DIFFERENCE.,#18580,#18583);
#18585= IFCCARTESIANPOINT((21630.0080362263,19050.0352209308,127.500000000005));
#18586= IFCAXIS2PLACEMENT3D(#18585,#596,#8);
#18587= IFCEXTRUDEDAREASOLID(#18568,#18586,#9,255.);
#18588= IFCBOOLEANRESULT(.DIFFERENCE.,#18584,#18587);
#18589= IFCCARTESIANPOINT((21630.008036048,20100.0382726886,127.500000000003));
#18590= IFCAXIS2PLACEMENT3D(#18589,#596,#8);
#18591= IFCEXTRUDEDAREASOLID(#18568,#18590,#9,255.);
#18592= IFCBOOLEANRESULT(.DIFFERENCE.,#18588,#18591);
#18593= IFCCARTESIANPOINT((21630.0080354873,23400.3541296222,127.500000000003));
#18594= IFCAXIS2PLACEMENT3D(#18593,#596,#8);
#18595= IFCEXTRUDEDAREASOLID(#18568,#18594,#9,255.);
#18596= IFCBOOLEANRESULT(.DIFFERENCE.,#18592,#18595);
#18597= IFCCARTESIANPOINT((21630.0080349353,26650.1481359699,127.500000000005));
#18598= IFCAXIS2PLACEMENT3D(#18597,#596,#8);
#18599= IFCEXTRUDEDAREASOLID(#18568,#18598,#9,255.);
#18600= IFCBOOLEANRESULT(.DIFFERENCE.,#18596,#18599);
#18601= IFCCARTESIANPOINT((21630.0080345786,28750.0016515949,127.500000000003));
#18602= IFCAXIS2PLACEMENT3D(#18601,#596,#8);
#18603= IFCEXTRUDEDAREASOLID(#18568,#18602,#9,255.);
#18604= IFCBOOLEANRESULT(.DIFFERENCE.,#18600,#18603);
#18605= IFCCARTESIANPOINT((21630.0080342474,30699.7849767902,127.500000000003));
#18606= IFCAXIS2PLACEMENT3D(#18605,#596,#8);
#18607= IFCEXTRUDEDAREASOLID(#18568,#18606,#9,255.);
#18608= IFCBOOLEANRESULT(.DIFFERENCE.,#18604,#18607);
#18609= IFCCARTESIANPOINT((21630.0080334914,35149.7819250324,127.500000000004));
#18610= IFCAXIS2PLACEMENT3D(#18609,#596,#8);
#18611= IFCEXTRUDEDAREASOLID(#18568,#18610,#9,255.);
#18612= IFCBOOLEANRESULT(.DIFFERENCE.,#18608,#18611);
#18613= IFCCARTESIANPOINT((21630.0080331347,37249.6430700519,127.500000000005));
#18614= IFCAXIS2PLACEMENT3D(#18613,#596,#8);
#18615= IFCEXTRUDEDAREASOLID(#18568,#18614,#9,255.);
#18616= IFCBOOLEANRESULT(.DIFFERENCE.,#18612,#18615);
#18617= IFCCARTESIANPOINT((21630.0080323168,42064.6912878254,127.500000000007));
#18618= IFCAXIS2PLACEMENT3D(#18617,#596,#8);
#18619= IFCEXTRUDEDAREASOLID(#18568,#18618,#9,255.);
#18620= IFCBOOLEANRESULT(.DIFFERENCE.,#18616,#18619);
#18621= IFCSHAPEREPRESENTATION(#12,'Body','CSG',(#18620));
#18622= IFCSTYLEDITEM(#18506,(#13592),$);
#18623= IFCPRODUCTDEFINITIONSHAPE($,$,(#18621));
#18624= IFCSLAB('1Td1iR0027tp4rDp0rCJ4s',#5,'DOSEME','PL250*22430','PL250*22430',#18498,#18623,'XX/72(?)',.FLOOR.);
#18625= IFCSLABTYPE('18k0$r1P1EfeDzoIvzgaW_',#5,'PL250*22430',$,$,$,$,$,$,.NOTDEFINED.);
#18626= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -7.800'),$);
#18627= IFCPROPERTYSINGLEVALUE('Top elevation',$,IFCLABEL(' -7.550'),$);
#18628= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('XX/72(?)'),$);
#18629= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('XX/72(?)'),$);
#18630= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('PL250*22430'),$);
#18631= IFCPROPERTYSET('0gsrhIi61FEBY3YjopIvEF',#5,'Tekla Common','Common Properties to Shared building elements',(#18626,#18627,#18628,#18629,#74,#75,#13610,#77,#9722,#18630,#18241));
#18632= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(588270.981257001),$);
#18633= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(588270.981257001),$);
#18634= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(593829.528553221),$);
#18635= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(588270.981257001),$);
#18636= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(245.112908857084),$);
#18637= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(246.770417882654),$);
#18638= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(245.112908857084),$);
#18639= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(980.451635429534),$);
#18640= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(3.41521556760732),$);
#18641= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(2009.07221316054),$);
#18642= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(989.715880922034),$);
#18643= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(22429.6974062982),$);
#18644= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(250.),$);
#18645= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(44125.2444468611),$);
#18646= IFCPROPERTYSET('0UIzLkDvX1d9AMM_UiI0or',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#18632,#18633,#18634,#18635,#18636,#18637,#18638,#18639,#18640,#18641,#18642,#18643,#18644,#18645));
#18647= IFCQUANTITYVOLUME('NetVolume',$,$,245.112908857084);
#18648= IFCQUANTITYAREA('NetArea',$,$,980.451635429534);
#18649= IFCQUANTITYWEIGHT('NetWeight',$,$,588270.981257001);
#18650= IFCELEMENTQUANTITY('3A_GD2STfFPeNC_1IMWid_',#5,'BaseQuantities',$,$,(#18493,#18647,#18648,#18649));
#18651= IFCLOCALPLACEMENT(#30,#10);
#18652= IFCELEMENTASSEMBLY('1Td1iR00289J4rDp0rCJ4s',#5,'COLUMN',$,$,#18651,$,'XX/1',.NOTDEFINED.,.REINFORCEMENT_UNIT.);
#18653= IFCPROPERTYSINGLEVALUE('Cast unit vertical position code',$,IFCLABEL('-7.55-+20.7'),$);
#18654= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit weight',$,IFCMASSMEASURE(191988.587550882),$);
#18655= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit bottom elevation',$,IFCLABEL(' -7.550'),$);
#18656= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit name',$,IFCLABEL('COLUMN'),$);
#18657= IFCPROPERTYSINGLEVALUE('Assembly/Cast unit Mark',$,IFCLABEL('XX/1'),$);
#18658= IFCPROPERTYSET('0MrJmYZr5DQRvVCwDcgdJv',#5,'Tekla Assembly','Assembly Properties',(#18653,#9687,#18654,#18655,#18342,#18656,#3342,#18657));
#18659= IFCQUANTITYLENGTH('Width',$,$,1900.);
#18660= IFCELEMENTQUANTITY('3xwvCJ$7P2Wwb_3jgyYIcr',#5,'BaseQuantities',$,$,(#18659));
#18661= IFCCARTESIANPOINT((47400.,749.976150670642,-7550.));
#18662= IFCAXIS2PLACEMENT3D(#18661,#9,#7);
#18663= IFCLOCALPLACEMENT(#18651,#18662);
#18664= IFCCIRCLEPROFILEDEF(.AREA.,'D1900',#197,950.);
#18665= IFCCARTESIANPOINT((0.,0.,28250.));
#18666= IFCAXIS2PLACEMENT3D(#18665,#596,#185);
#18667= IFCEXTRUDEDAREASOLID(#18664,#18666,#9,28250.);
#18668= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#18667));
#18669= IFCSTYLEDITEM(#18667,(#13592),$);
#18670= IFCPRODUCTDEFINITIONSHAPE($,$,(#18668));
#18671= IFCCOLUMN('1Td1iR0028934rDp0rCJ4s',#5,'COLUMN','D1900','D1900',#18663,#18670,'XX/1');
#18672= IFCCOLUMNTYPE('18QXVh2sj77fHiEgiBmOKX',#5,'D1900',$,$,$,$,$,$,.NOTDEFINED.);
#18673= IFCPROPERTYSINGLEVALUE('Bottom elevation',$,IFCLABEL(' -7.550'),$);
#18674= IFCPROPERTYSINGLEVALUE('Part mark',$,IFCLABEL('XX/1'),$);
#18675= IFCPROPERTYSINGLEVALUE('Assembly mark',$,IFCLABEL('XX/1'),$);
#18676= IFCPROPERTYSINGLEVALUE('Profile',$,IFCLABEL('D1900'),$);
#18677= IFCPROPERTYSINGLEVALUE('Name',$,IFCLABEL('COLUMN'),$);
#18678= IFCPROPERTYSET('1VWPCYme5D58z$9a4SKM3I',#5,'Tekla Common','Common Properties to Shared building elements',(#18673,#18365,#18674,#18675,#74,#75,#13610,#1194,#9722,#18676,#18677));
#18679= IFCPROPERTYSINGLEVALUE('AssemblyWeight',$,IFCMASSMEASURE(191988.587550882),$);
#18680= IFCPROPERTYSINGLEVALUE('Net weight',$,IFCMASSMEASURE(191988.587550882),$);
#18681= IFCPROPERTYSINGLEVALUE('Gross weight',$,IFCMASSMEASURE(191988.587550882),$);
#18682= IFCPROPERTYSINGLEVALUE('Weight',$,IFCMASSMEASURE(191988.587550882),$);
#18683= IFCPROPERTYSINGLEVALUE('Net volume',$,IFCVOLUMEMEASURE(79.9952448128674),$);
#18684= IFCPROPERTYSINGLEVALUE('Gross volume',$,IFCVOLUMEMEASURE(79.9952448128674),$);
#18685= IFCPROPERTYSINGLEVALUE('Volume',$,IFCVOLUMEMEASURE(79.9952448128674),$);
#18686= IFCPROPERTYSINGLEVALUE('Gross footprint area',$,IFCAREAMEASURE(2.83169008187141),$);
#18687= IFCPROPERTYSINGLEVALUE('Area per tons',$,IFCAREAMEASURE(0.907527196269642),$);
#18688= IFCPROPERTYSINGLEVALUE('Net surface area',$,IFCAREAMEASURE(174.23486457582),$);
#18689= IFCPROPERTYSINGLEVALUE('Gross area',$,IFCAREAMEASURE(174.23486457582),$);
#18690= IFCPROPERTYSINGLEVALUE('Height',$,IFCLENGTHMEASURE(1900.),$);
#18691= IFCPROPERTYSINGLEVALUE('Width',$,IFCLENGTHMEASURE(1900.),$);
#18692= IFCPROPERTYSINGLEVALUE('Length',$,IFCLENGTHMEASURE(28250.),$);
#18693= IFCPROPERTYSET('3jtRxcPMP6uh7AdNUPGB1F',#5,'Tekla Quantity','Quantity Properties to Shared building elements',(#18679,#18680,#18681,#18682,#18683,#18684,#18685,#18686,#18687,#18688,#18689,#18690,#18691,#18692));
#18694= IFCQUANTITYLENGTH('Length',$,$,28250.);
#18695= IFCQUANTITYAREA('OuterSurfaceArea',$,$,174.23486457582);
#18696= IFCQUANTITYVOLUME('NetVolume',$,$,79.9952448128674);
#18697= IFCQUANTITYWEIGHT('NetWeight',$,$,191988.587550882);
#18698= IFCELEMENTQUANTITY('1wF9zdsPDFOQfiaPboyud2',#5,'BaseQuantities',$,$,(#18694,#18695,#18696,#18697));
#18699= IFCLOCALPLACEMENT(#30,#10);
#18700= IFCELEMENTASSEMBLY('1Td1iR0028AJ4rDp0rCJ4s',#5,'COLUMN',$,$,#18699,$,'XX/1',.NOTDEFINED.,.REINFORCEMENT_UNIT.);
#18701= IFCPROPERTYSET('3flGB0AUH5p8EkM4lETcKj',#5,'Tekla Assembly','Assembly Properties',(#18653,#9687,#18654,#18655,#18342,#18656,#18214,#18657));
#18702= IFCCARTESIANPOINT((40499.999999613,749.976150670642,-7550.));
#18703= IFCAXIS2PLACEMENT3D(#18702,#9,#7);
#18704= IFCLOCALPLACEMENT(#18699,#18703);
#18705= IFCSHAPEREPRESENTATION(#12,'Body','SweptSolid',(#18667));
#18706= IFCPRODUCTDEFINITIONSHAPE($,$,(#18705));
#18707= IFCCOLUMN('1Td1iR0028A34rDp0rCJ4s',#5,'COLUMN','D1900','D1900',#18704,#18706,'XX/1');
#18708= IFCRELAGGREGATES('08YvJH9FP6GAI7Qcx3hW7n',#5,$,$,#25,(#27));
#18709= IFCRELAGGREGATES('3o6Q6T0Y58pPtg227urskR',#5,$,$,#27,(#29));
#18710= IFCRELAGGREGATES('3ONxDAD21D08Jo2aMiQof4',#5,$,$,#29,(#31));
#18711= IFCRELAGGREGATES('1MUGbJ7TbF1wrg37FWHHHP',#5,$,$,#33,(#68));
#18712= IFCRELAGGREGATES('2eUsvvCEHAGgV4$7I$8Ico',#5,$,$,#106,(#118));
#18713= IFCRELAGGREGATES('0HIAgtu4LFDPgohp$Hv1Gk',#5,$,$,#134,(#12069,#12020,#11984,#11952,#4432,#157));
#18714= IFCRELAGGREGATES('2eic7vJbr8LAXwYI5p05Hy',#5,$,$,#484,(#508));
#18715= IFCRELAGGREGATES('1k_rR9Nnf3cwx17Ga$IW$P',#5,$,$,#538,(#546));
#18716= IFCRELAGGREGATES('3neGwbBXbDZRCNjwKDcHBl',#5,$,$,#886,(#5640,#5521,#5515,#5509,#5503,#5481,#5409,#5395,#5383,#5368,#5352,#4930,#964,#948,#913));
#18717= IFCRELAGGREGATES('2gIxxFUNz8Nf$LtHhoCI0o',#5,$,$,#985,(#1899,#1190,#1111,#1085,#1050,#1006));
#18718= IFCRELAGGREGATES('0H81a41wL9QxVp0kG1d1nW',#5,$,$,#1217,(#12675,#11943,#6567,#6561,#6555,#6549,#6543,#6485,#6451,#6445,#6438,#6431,#1241,#1235,#1226));
#18719= IFCRELAGGREGATES('0FFfheVdz8IuSX4xZeD8ht',#5,$,$,#1244,(#2108,#1293,#1282,#1275,#1265,#1254));
#18720= IFCRELAGGREGATES('1hY3TVnnv1AO6W7sSs9iqu',#5,$,$,#1306,(#12529,#12514,#12508,#12502,#12496,#12480,#11930,#7803,#7766,#7759,#7751,#7740,#1343,#1337,#1317));
#18721= IFCRELAGGREGATES('01UtHY6Eb42PwCU5KBR$O3',#5,$,$,#1357,(#2253,#1442,#1402,#1384,#1375,#1366));
#18722= IFCRELAGGREGATES('17mSsHL$f0VfX0L_D7pLAL',#5,$,$,#1451,(#12335,#11254,#1491,#1480,#1462));
#18723= IFCRELAGGREGATES('2NLEfLa653khu1LoDznhkd',#5,$,$,#1501,(#2391,#1573,#1537,#1528,#1519,#1510));
#18724= IFCRELAGGREGATES('0bqUcVPlH2MB5r1yewyxIv',#5,$,$,#1588,(#1597));
#18725= IFCRELAGGREGATES('3b5Jd$alD5Pga6yxCoWPHi',#5,$,$,#1602,(#1608));
#18726= IFCRELAGGREGATES('0sqSmBohr2XQ80IBuP40IM',#5,$,$,#1610,(#1635));
#18727= IFCRELAGGREGATES('1LXQISKzjFixSW_aq6Yatc',#5,$,$,#1664,(#1677));
#18728= IFCRELAGGREGATES('2TptPWAy15jwfvoViMm13B',#5,$,$,#1696,(#1726));
#18729= IFCRELAGGREGATES('1tEaO0D4H5HuOghEmgwI_a',#5,$,$,#1758,(#1766));
#18730= IFCRELAGGREGATES('3XXqCqwybFxu57kGhbzmRq',#5,$,$,#1772,(#1790));
#18731= IFCRELAGGREGATES('2DHQD1uaH02v2HETjaZgNT',#5,$,$,#1811,(#1833));
#18732= IFCRELAGGREGATES('0QW5k4Drn9kvJOJ5UNSGsd',#5,$,$,#1926,(#1936));
#18733= IFCRELAGGREGATES('03MGqnMLX2TQQri26mPcGh',#5,$,$,#1948,(#1956));
#18734= IFCRELAGGREGATES('3iTldnp2n9MOmtyjcD7Q6v',#5,$,$,#1964,(#1973));
#18735= IFCRELAGGREGATES('3EDq2eM3nFC9wtYHlNEcj2',#5,$,$,#1986,(#1996));
#18736= IFCRELAGGREGATES('2yHQWNF6f7Z86zDeHQUIen',#5,$,$,#2009,(#2018));
#18737= IFCRELAGGREGATES('2E0weswz53wgPJo84nKiuI',#5,$,$,#2023,(#2029));
#18738= IFCRELAGGREGATES('39owrWR9j53ujikKmC4OD0',#5,$,$,#2031,(#2040));
#18739= IFCRELAGGREGATES('0WtgPVrb51JPEE13qntCqM',#5,$,$,#2044,(#2051));
#18740= IFCRELAGGREGATES('1KA4z6MEbFVhQvoZybr98h',#5,$,$,#2053,(#2062));
#18741= IFCRELAGGREGATES('0TinIAOy56R8SdcfDYgxeV',#5,$,$,#2067,(#2073));
#18742= IFCRELAGGREGATES('05MMVUdzTEO92YPfs9iDH1',#5,$,$,#2075,(#2084));
#18743= IFCRELAGGREGATES('2NG3HvGrP1SBpMUNs4JNVn',#5,$,$,#2089,(#2098));
#18744= IFCRELAGGREGATES('06VFLsDFnCw9UV9sqsANdt',#5,$,$,#2114,(#2120));
#18745= IFCRELAGGREGATES('1vB4JG6$LB48yaJ4klQ0_I',#5,$,$,#2122,(#2128));
#18746= IFCRELAGGREGATES('1iQ5GfjbfDlwDEL7qNpjKP',#5,$,$,#2130,(#2136));
#18747= IFCRELAGGREGATES('3oJ2bA8mv0ThA_GQ_RsMr5',#5,$,$,#2138,(#2144));
#18748= IFCRELAGGREGATES('0qcYygXwr0w8CPimmTQC33',#5,$,$,#2146,(#2155));
#18749= IFCRELAGGREGATES('3ozR4QI$b1UxfNKf92nEMx',#5,$,$,#2160,(#2166));
#18750= IFCRELAGGREGATES('2$L4mSEpv11ApuJjcA_gbz',#5,$,$,#2168,(#2177));
#18751= IFCRELAGGREGATES('2THieOuynBlwj13M8LDPT0',#5,$,$,#2181,(#2188));
#18752= IFCRELAGGREGATES('1fnBAQ7A95whJStTmXzjBx',#5,$,$,#2190,(#2199));
#18753= IFCRELAGGREGATES('00I99FGRz489qNH_XnK8Rp',#5,$,$,#2204,(#2210));
#18754= IFCRELAGGREGATES('32ChUX3nbFiOQhBhMkDciH',#5,$,$,#2212,(#2221));
#18755= IFCRELAGGREGATES('2MCAWdRrz6Y9gd$Tfzxfw8',#5,$,$,#2230,(#2239));
#18756= IFCRELAGGREGATES('2G7BP0vKLDs8oKjM586hyM',#5,$,$,#2258,(#2264));
#18757= IFCRELAGGREGATES('1eRfEm6E14xxD_0cqvT0sg',#5,$,$,#2266,(#2272));
#18758= IFCRELAGGREGATES('3yjrkctfb6Hg07IdXb6d$x',#5,$,$,#2274,(#2280));
#18759= IFCRELAGGREGATES('2Mz23RDpf3nwUPbkQfjnyT',#5,$,$,#2291,(#2297));
#18760= IFCRELAGGREGATES('0ljKVu3s15i9CPQ9txPInr',#5,$,$,#2308,(#2317));
#18761= IFCRELAGGREGATES('2SSSQBsZrE4uFg0JgpSavZ',#5,$,$,#2321,(#2328));
#18762= IFCRELAGGREGATES('09mPG$ZdXASw6560sMBXXx',#5,$,$,#2330,(#2339));
#18763= IFCRELAGGREGATES('31KAWoA1XAgQlfSsKB6sRa',#5,$,$,#2344,(#2350));
#18764= IFCRELAGGREGATES('1IP2$mUQzAHO_qs2A5u_sb',#5,$,$,#2352,(#2361));
#18765= IFCRELAGGREGATES('0GjoDTIyPDdvYtRaJtGgf0',#5,$,$,#2369,(#2378));
#18766= IFCRELAGGREGATES('1gWMVqLif52ONfiburSyNY',#5,$,$,#2401,(#2407));
#18767= IFCRELAGGREGATES('2TDChdIrb2oRZMe6oTYThQ',#5,$,$,#2409,(#2415));
#18768= IFCRELAGGREGATES('0oC_$Lqiv2wPUuku9DAaM7',#5,$,$,#2417,(#2423));
#18769= IFCRELAGGREGATES('3uSvHruoLAE8wdQYrHKrip',#5,$,$,#2428,(#2434));
#18770= IFCRELAGGREGATES('3dglbav3TF$fNqhWQyVgja',#5,$,$,#2855,(#3380,#2999,#2945,#2922,#2898,#2870));
#18771= IFCRELAGGREGATES('0bS3K4PAP7Zhte8BwQkkqG',#5,$,$,#3014,(#3586,#3076,#3040,#3034,#3028,#3021));
#18772= IFCRELAGGREGATES('1TRhZGCpbBnfVg38c78zqj',#5,$,$,#3082,(#3789,#3146,#3110,#3102,#3096,#3089));
#18773= IFCRELAGGREGATES('1JumcJ2QT5exha_mcCd_1S',#5,$,$,#3154,(#3161));
#18774= IFCRELAGGREGATES('0DqW1EJwnAceGxTrkXKe86',#5,$,$,#3170,(#3176));
#18775= IFCRELAGGREGATES('0eZNNm24P4kOom0bRAyPL5',#5,$,$,#3182,(#3205));
#18776= IFCRELAGGREGATES('1lLDiPK$jFJgPY3anbHSUw',#5,$,$,#3232,(#3240));
#18777= IFCRELAGGREGATES('1FjtoY$YX14OQptniGSziG',#5,$,$,#3248,(#3254));
#18778= IFCRELAGGREGATES('1rpZPl0j5AHuZ8P3UxmhdE',#5,$,$,#3262,(#3273));
#18779= IFCRELAGGREGATES('1qEGgsY492FPlRK67QFZuI',#5,$,$,#3280,(#3290));
#18780= IFCRELAGGREGATES('2yqYG0bYvCgxaKRHlvEwNg',#5,$,$,#3298,(#3308));
#18781= IFCRELAGGREGATES('1ZbZK0SxzEe9FtpCJSSFQT',#5,$,$,#3314,(#3320));
#18782= IFCRELAGGREGATES('1n72xkY5b11eQVI6$ZTVAA',#5,$,$,#3325,(#3334));
#18783= IFCRELAGGREGATES('3Vm_ID7E96TxJvOUGrrWBy',#5,$,$,#3341,(#3351));
#18784= IFCRELAGGREGATES('15Eb3AuG5C38q5yAtjnVhS',#5,$,$,#3398,(#3407));
#18785= IFCRELAGGREGATES('0_9WYhnor3CfpZyXjMpFjj',#5,$,$,#3413,(#3419));
#18786= IFCRELAGGREGATES('2439G1CJ9FGR7SHZAgwtfL',#5,$,$,#3425,(#3433));
#18787= IFCRELAGGREGATES('3YLCMBRQXBHBpJZK4oiFbo',#5,$,$,#3439,(#3447));
#18788= IFCRELAGGREGATES('3$3k04AFb3_QDVHbswtx9V',#5,$,$,#3457,(#3464));
#18789= IFCRELAGGREGATES('14XwcHM$1Emu9_AW6TSzBV',#5,$,$,#3467,(#3473));
#18790= IFCRELAGGREGATES('3qdUUSuhT3qASAfb2AQEdW',#5,$,$,#3475,(#3484));
#18791= IFCRELAGGREGATES('3f$ApT43b3qOwVQyuldUdV',#5,$,$,#3487,(#3493));
#18792= IFCRELAGGREGATES('0395Asq7D0OBIYq9q8ks_j',#5,$,$,#3495,(#3501));
#18793= IFCRELAGGREGATES('2c8XCZSyvAaxrgbovHDe7w',#5,$,$,#3503,(#3510));
#18794= IFCRELAGGREGATES('1UA9xRxGrEOQ6RoUN$4nNq',#5,$,$,#3512,(#3520));
#18795= IFCRELAGGREGATES('0kfmFQrd9DsQxvWfa15Gie',#5,$,$,#3527,(#3536));
#18796= IFCRELAGGREGATES('0FflGfocrEBPTUOnf8mjdp',#5,$,$,#3541,(#3549));
#18797= IFCRELAGGREGATES('2aBHxGCwLEmvqPIWV11dkh',#5,$,$,#3554,(#3563));
#18798= IFCRELAGGREGATES('0li0COTcPDNgvpYcckzOXq',#5,$,$,#3569,(#3576));
#18799= IFCRELAGGREGATES('0Y5c4za6bFPOGWmaWKGL9Y',#5,$,$,#3593,(#3601));
#18800= IFCRELAGGREGATES('1rx2vpUEv2MPvfRUrPDwVo',#5,$,$,#3609,(#3615));
#18801= IFCRELAGGREGATES('2qp44Ag199lf3Y_UMao751',#5,$,$,#3621,(#3629));
#18802= IFCRELAGGREGATES('0c3OgYAC9BFAhP5ZoUwbXm',#5,$,$,#3635,(#3641));
#18803= IFCRELAGGREGATES('2oxvCnKZnFfB9yCD28MGNZ',#5,$,$,#3643,(#3650));
#18804= IFCRELAGGREGATES('2fyPuQuBX4JfZ7VGo$$mVI',#5,$,$,#3653,(#3659));
#18805= IFCRELAGGREGATES('2zz$eKmB58cAV4VQH7MbXP',#5,$,$,#3661,(#3670));
#18806= IFCRELAGGREGATES('0H7pn8rHbDTOKn8abP4TL7',#5,$,$,#3683,(#3689));
#18807= IFCRELAGGREGATES('2JjnbkX8r9kOLXdj76UQNl',#5,$,$,#3702,(#3708));
#18808= IFCRELAGGREGATES('3SNtH5XVL71RSOiKnxnMFV',#5,$,$,#3714,(#3721));
#18809= IFCRELAGGREGATES('0E78wRqUH5mOhtZZHbrGP7',#5,$,$,#3723,(#3729));
#18810= IFCRELAGGREGATES('0_h_idL61BVO2wdvr1KlT6',#5,$,$,#3731,(#3740));
#18811= IFCRELAGGREGATES('3IsmB62YT2_8$EEMEG734W',#5,$,$,#3745,(#3751));
#18812= IFCRELAGGREGATES('0wDHCZMqHCRgUnE45lu9w$',#5,$,$,#3756,(#3765));
#18813= IFCRELAGGREGATES('0rSVuimorEHgtDzeiR2CZG',#5,$,$,#3771,(#3778));
#18814= IFCRELAGGREGATES('3ni29HDxb4agbJfeUiom0K',#5,$,$,#3796,(#3804));
#18815= IFCRELAGGREGATES('09i6SJNYv37wSgUNmTToNz',#5,$,$,#3812,(#3818));
#18816= IFCRELAGGREGATES('01SrKDMB91ZuJrLpaFeDf6',#5,$,$,#3823,(#3831));
#18817= IFCRELAGGREGATES('0wesNxN5T2a84MupB7fJ64',#5,$,$,#3841,(#3847));
#18818= IFCRELAGGREGATES('1Q3B2CCOv3bA1zbwrmYOf1',#5,$,$,#3921,(#12109,#10035,#3990,#3947));
#18819= IFCRELAGGREGATES('3GaPdL4bb6c8oUG255OKlr',#5,$,$,#4017,(#4178,#4085,#4040));
#18820= IFCRELAGGREGATES('1SKtGHGXr3h8pRieq6jOe_',#5,$,$,#4207,(#13578,#13572,#13554,#13523,#13390,#13234,#12741,#11737,#11717,#11499,#4303,#4224));
#18821= IFCRELAGGREGATES('3bleygBx12SOGfh2qcsFPu',#5,$,$,#4249,(#13566,#13545,#13413,#13252,#12780,#10292,#10216,#4267));
#18822= IFCRELAGGREGATES('0hjgH2CSP9K8Db728C8jhC',#5,$,$,#4289,(#13560,#13534,#13402,#13243,#12761,#10528,#10501,#4296));
#18823= IFCRELAGGREGATES('130brzb5n4Fw1yAvpvWNhu',#5,$,$,#4306,(#4317));
#18824= IFCRELAGGREGATES('0ek1nSHpHEz8PkGiAnRdKc',#5,$,$,#4327,(#4333));
#18825= IFCRELAGGREGATES('3j4mMH9JT39RxrIo2ev$SZ',#5,$,$,#4462,(#12181,#12046,#4519));
#18826= IFCRELAGGREGATES('19kBkkzLP51gmtDujkWPdB',#5,$,$,#4548,(#4606));
#18827= IFCRELAGGREGATES('2mdFXoTeXEZgV0CpX4Nc4j',#5,$,$,#5195,(#5674,#5609,#5603,#5597,#5591,#5571,#5541,#5527,#5460,#5446,#5433,#5415,#5345,#5317,#5288,#5253,#5217));
#18828= IFCRELAGGREGATES('1l7kvP8s56x9PgxLey9Bb2',#5,$,$,#5747,(#12153,#9971,#5768));
#18829= IFCRELAGGREGATES('23Q4_y7K97UeyM4Njn5fpm',#5,$,$,#5871,(#6079,#5937,#5902,#5895,#5888,#5880));
#18830= IFCRELAGGREGATES('2y4S8yvo1EXf7zW7__dkd5',#5,$,$,#5945,(#5958));
#18831= IFCRELAGGREGATES('0QBWEmnaj9lwonPPuvR5yV',#5,$,$,#5978,(#5989));
#18832= IFCRELAGGREGATES('18ADN45JH9qPYBgY$M5xxg',#5,$,$,#5996,(#6005));
#18833= IFCRELAGGREGATES('2fMnDkvTHApOBX$3PO_GI0',#5,$,$,#6011,(#6019));
#18834= IFCRELAGGREGATES('3aAxC7v3fBCQ9$roQh2DcS',#5,$,$,#6026,(#6035));
#18835= IFCRELAGGREGATES('3dyvb1p2DFiP1vNatYAjws',#5,$,$,#6041,(#6050));
#18836= IFCRELAGGREGATES('0rzwIBklHCPvPjtkQveY3k',#5,$,$,#6100,(#6113));
#18837= IFCRELAGGREGATES('10lv0Qklv5kv04R4mNXZbd',#5,$,$,#6137,(#6145));
#18838= IFCRELAGGREGATES('1iMBFkEF1DFBgBShrbNvrh',#5,$,$,#6153,(#6161));
#18839= IFCRELAGGREGATES('0U8QVYPp14ORx8wMClg8YJ',#5,$,$,#6167,(#6175));
#18840= IFCRELAGGREGATES('3hCTEN5bn6791J7Fu8h60f',#5,$,$,#6186,(#6194));
#18841= IFCRELAGGREGATES('1vTAUbp$X13hY7t2_FgDb$',#5,$,$,#6207,(#6215));
#18842= IFCRELAGGREGATES('0cV0QB37LAyessdxLZRCS$',#5,$,$,#6388,(#17522,#6610,#6604,#6598,#6592,#6586,#6579,#6573,#6537,#6531,#6525,#6519,#6425,#6416,#6410,#6402,#6395));
#18843= IFCRELAGGREGATES('2Y8DP8ssbBk93v58VFm$6s',#5,$,$,#6454,(#6684,#6507,#6479,#6473,#6467,#6461));
#18844= IFCRELAGGREGATES('1pUOS2gVnD0AEPHXjxGKZx',#5,$,$,#6612,(#6619));
#18845= IFCRELAGGREGATES('1LieriOgL4nfJ5eCH$Qgsw',#5,$,$,#6621,(#6628));
#18846= IFCRELAGGREGATES('1bUzscOO5EoxYNYB_eM5if',#5,$,$,#6630,(#6639));
#18847= IFCRELAGGREGATES('3PlvLLO9nD$PetJJCf8dKk',#5,$,$,#6644,(#6652));
#18848= IFCRELAGGREGATES('09gsf$T9vCuvclnLn7LRBn',#5,$,$,#6654,(#6663));
#18849= IFCRELAGGREGATES('15K0yNjCj09P2gmcfa_dBl',#5,$,$,#6668,(#6677));
#18850= IFCRELAGGREGATES('02uGIn735EkvrEV_CHMB1e',#5,$,$,#6691,(#6698));
#18851= IFCRELAGGREGATES('3qja76Llf2K8Yk7xKxhh$t',#5,$,$,#6701,(#6709));
#18852= IFCRELAGGREGATES('3xHjqkNvz2nAW93$dbmnhw',#5,$,$,#6717,(#6725));
#18853= IFCRELAGGREGATES('0uvHqzIkjBVwnQVMm1d$Da',#5,$,$,#6730,(#6738));
#18854= IFCRELAGGREGATES('1FzoNMCvr848yO7TQt29BR',#5,$,$,#6744,(#6752));
#18855= IFCRELAGGREGATES('3JojBOHLr8aQh5ostz14iS',#5,$,$,#6757,(#6763));
#18856= IFCRELAGGREGATES('2Y8QK4Nwr5xx$phadHJS$0',#5,$,$,#6765,(#6773));
#18857= IFCRELAGGREGATES('1NX4UuU$vDW8Z1hnB9mW2E',#5,$,$,#6787,(#6794));
#18858= IFCRELAGGREGATES('2ZfTbMfvrCTAW6AK0Iz7RK',#5,$,$,#6801,(#6807));
#18859= IFCRELAGGREGATES('3kTArNJHbFmQho2SbEYO8i',#5,$,$,#6809,(#6815));
#18860= IFCRELAGGREGATES('0geHZP6nv5lfeNGY0Lbvh$',#5,$,$,#6817,(#6823));
#18861= IFCRELAGGREGATES('08BXnzXEbCHx_ceqFRbz4g',#5,$,$,#7137,(#7530,#7371,#7364,#7357,#7350,#7334,#7186,#7176,#7169,#7160,#7145));
#18862= IFCRELAGGREGATES('3GM_Ra_FP1Gg45JDCWMbt0',#5,$,$,#7188,(#7198));
#18863= IFCRELAGGREGATES('3xpcjagCDCYB$zb0uZETnj',#5,$,$,#7206,(#7217));
#18864= IFCRELAGGREGATES('1zxGZ78GL7NRL46Kq8qcYQ',#5,$,$,#7223,(#7231));
#18865= IFCRELAGGREGATES('3BTTy4p5jFRfU67jwJhK5l',#5,$,$,#7235,(#7244));
#18866= IFCRELAGGREGATES('1LJaNM9Kz18A7HV9A4LQ$0',#5,$,$,#7250,(#7437,#7323,#7280,#7273,#7266,#7258));
#18867= IFCRELAGGREGATES('1WUddQSX52tuk2ryB8TJ8B',#5,$,$,#7283,(#7289));
#18868= IFCRELAGGREGATES('1aDSYv92vAiR1upE$aBvqc',#5,$,$,#7373,(#7380));
#18869= IFCRELAGGREGATES('3zBD6Ew454FgxqZjYbYGSN',#5,$,$,#7382,(#7389));
#18870= IFCRELAGGREGATES('37nBGczfD9gwK6plcMhvYy',#5,$,$,#7391,(#7398));
#18871= IFCRELAGGREGATES('2lScsKk$v4Wuq$vs58Jiyx',#5,$,$,#7400,(#7406));
#18872= IFCRELAGGREGATES('3C9gavM5jAMgZTzVdymbon',#5,$,$,#7408,(#7415));
#18873= IFCRELAGGREGATES('3st3J4J914NxjzOEDc55Zd',#5,$,$,#7420,(#7427));
#18874= IFCRELAGGREGATES('3dZhVjQp9D4hKn9j79vI3$',#5,$,$,#7440,(#7447));
#18875= IFCRELAGGREGATES('2Zr_E7b0HENfRzlpxDxNJ2',#5,$,$,#7450,(#7456));
#18876= IFCRELAGGREGATES('08OWavS1n3ePgs3wGrwwk4',#5,$,$,#7458,(#7464));
#18877= IFCRELAGGREGATES('19kTQ9RL95SBNObWFmllbL',#5,$,$,#7466,(#7472));
#18878= IFCRELAGGREGATES('1PjvSQ8Sz9kwjbgdM4jJXf',#5,$,$,#7480,(#7486));
#18879= IFCRELAGGREGATES('3UvrkicLf5khmeF7f9gvdQ',#5,$,$,#7497,(#7503));
#18880= IFCRELAGGREGATES('0_lSb$VNn38x7EMCjVKNGI',#5,$,$,#7682,(#17514,#16127,#16121,#16115,#16109,#16093,#15987,#15981,#8034,#8027,#8020,#8007,#7731,#7721,#7714,#7705,#7690));
#18881= IFCRELAGGREGATES('2uIl3$TqDBivtVWcJRcMKF',#5,$,$,#7770,(#7916,#7838,#7796,#7789,#7783,#7777));
#18882= IFCRELAGGREGATES('1vSsRoH5H3Tw3H9Jpnf6N1',#5,$,$,#7844,(#7851));
#18883= IFCRELAGGREGATES('2wo05jSa54FxT5c5lUCoFD',#5,$,$,#7853,(#7860));
#18884= IFCRELAGGREGATES('1zQmjXcFz8MfYe4Yc0QkWM',#5,$,$,#7862,(#7871));
#18885= IFCRELAGGREGATES('3SRqM47oX7OuNd0R5YYlVA',#5,$,$,#7873,(#7881));
#18886= IFCRELAGGREGATES('0TXZBcWnrAxxh8EKRajVj1',#5,$,$,#7883,(#7892));
#18887= IFCRELAGGREGATES('2jD6Ei2lP34f$UrE1mZ2ez',#5,$,$,#7897,(#7906));
#18888= IFCRELAGGREGATES('1SHR9IF692XPMvpXV8G0xd',#5,$,$,#7926,(#7933));
#18889= IFCRELAGGREGATES('0c21WzZQLEPvpwckKKJTK$',#5,$,$,#7936,(#7944));
#18890= IFCRELAGGREGATES('3Cd7Z_LQP0eufU9rH6XFS3',#5,$,$,#7949,(#7957));
#18891= IFCRELAGGREGATES('2gUw_fTvLDigRQ3FC3TrLk',#5,$,$,#7962,(#7970));
#18892= IFCRELAGGREGATES('3YjgQksL57EQJZ8$tQ7bmL',#5,$,$,#7976,(#7984));
#18893= IFCRELAGGREGATES('3RBHCXWOfFbxOhjOzZu0JZ',#5,$,$,#7995,(#8001));
#18894= IFCRELAGGREGATES('3Acq9QWCT6i8OeKYqX3UqO',#5,$,$,#8067,(#8109));
#18895= IFCRELAGGREGATES('2LNn6gmm97Gv1flXbbjusA',#5,$,$,#8170,(#8187));
#18896= IFCRELAGGREGATES('2f83WJLgf42u3NAj6AkTJ4',#5,$,$,#8215,(#8225));
#18897= IFCRELAGGREGATES('2MGeuFAdP5pf9C$YTM0KY0',#5,$,$,#8234,(#13517,#13354,#11849,#10799,#10769,#8652,#8622,#8590,#8561,#8538,#8259));
#18898= IFCRELAGGREGATES('133wLAU0nFfA1C75H27lEp',#5,$,$,#8288,(#8302));
#18899= IFCRELAGGREGATES('3HuK5Pe2zDvRsXWFQLDsLs',#5,$,$,#8320,(#8335));
#18900= IFCRELAGGREGATES('0Oh7AbQqbBT9dMPpksYWSK',#5,$,$,#8348,(#8361));
#18901= IFCRELAGGREGATES('3D_ipN8U1CkB3tokMCm6IO',#5,$,$,#8370,(#8379));
#18902= IFCRELAGGREGATES('1pyMjddz1BJP9qpaSr$gGi',#5,$,$,#8388,(#8405));
#18903= IFCRELAGGREGATES('2EAvyaw754Jh_KqZ7ZrVur',#5,$,$,#8424,(#8430));
#18904= IFCRELAGGREGATES('04_ETukAb0s8WYLnHNoPbe',#5,$,$,#8440,(#8446));
#18905= IFCRELAGGREGATES('0gk0Mh7oP7$BYwrRPa7MTH',#5,$,$,#8454,(#8460));
#18906= IFCRELAGGREGATES('1YUhHYxGzD2ul30RVHz81l',#5,$,$,#8466,(#8472));
#18907= IFCRELAGGREGATES('0aXlKYhAH2QBPdBcEbuv7b',#5,$,$,#8477,(#8485));
#18908= IFCRELAGGREGATES('2RVS1gg3P5Qxr6oDPTvW52',#5,$,$,#8678,(#8717));
#18909= IFCRELAGGREGATES('1GN3szx3LFHQG1t4YqRLOm',#5,$,$,#8737,(#8743));
#18910= IFCRELAGGREGATES('2ZgpFFBFrEyPJ9aCUOb$o4',#5,$,$,#8748,(#8754));
#18911= IFCRELAGGREGATES('2_Ks2kA$j35geUP$uN6jR4',#5,$,$,#8760,(#8766));
#18912= IFCRELAGGREGATES('1uLFq6Rtv4wvl8cPianrjx',#5,$,$,#8770,(#8776));
#18913= IFCRELAGGREGATES('32B0uDx117SRyp9Q0$MMho',#5,$,$,#8781,(#8787));
#18914= IFCRELAGGREGATES('0L0Jg45Y15YPsES9lIsyJE',#5,$,$,#8855,(#11470,#11384,#11362,#8902,#8872));
#18915= IFCRELAGGREGATES('2XXUPmDJvFfuP8hJOeNDL9',#5,$,$,#8927,(#8948));
#18916= IFCRELAGGREGATES('3wbwcSiAv03eJhP_16Y6nk',#5,$,$,#8977,(#8995));
#18917= IFCRELAGGREGATES('0m1HDI8dr2QPsTMTBhMlW0',#5,$,$,#9063,(#9077));
#18918= IFCRELAGGREGATES('1InYee4ELCLAwtudvmgijN',#5,$,$,#9099,(#9828,#9379,#9184,#9150,#9119));
#18919= IFCRELAGGREGATES('1QJxBraHv5ugo$LJZYaDxS',#5,$,$,#9170,(#9176));
#18920= IFCRELAGGREGATES('1pfEy$LaT2PgjZUOmJ9d_R',#5,$,$,#9200,(#9213));
#18921= IFCRELAGGREGATES('36oAjXsvbAbhodQPT5tPiS',#5,$,$,#9227,(#9240));
#18922= IFCRELAGGREGATES('2opVluaAD6XxrsHAgG5POe',#5,$,$,#9251,(#9263));
#18923= IFCRELAGGREGATES('0Ld_f2pQ1B8QYvOMjN$2ZB',#5,$,$,#9272,(#9281));
#18924= IFCRELAGGREGATES('1Uf8OOTiPFbA0kWIrrB6Sw',#5,$,$,#9289,(#9298));
#18925= IFCRELAGGREGATES('3QEYGNR1L7zgUGelF29g0f',#5,$,$,#9303,(#9314));
#18926= IFCRELAGGREGATES('3fQ2R1tmvBiPTyH1DqrKec',#5,$,$,#9329,(#9335));
#18927= IFCRELAGGREGATES('0H2oCQECf9$By8aCftY2UH',#5,$,$,#9340,(#9346));
#18928= IFCRELAGGREGATES('1IKbFm2snFXxqhv0nEpnqn',#5,$,$,#9348,(#9354));
#18929= IFCRELAGGREGATES('3maj6fJBb4UAEiHg_B988e',#5,$,$,#9356,(#9362));
#18930= IFCRELAGGREGATES('2LKOpYv4rEqPkGbjaUrCc_',#5,$,$,#9364,(#9370));
#18931= IFCRELAGGREGATES('2ZiYZlTS5D0x6QN5hzuxJ5',#5,$,$,#9441,(#13181,#11183,#11160,#10945,#10834,#9674,#9512,#9500,#9486,#9467,#9452));
#18932= IFCRELAGGREGATES('1kq9bumCvD_OJ_o_gAZe5v',#5,$,$,#9521,(#9534));
#18933= IFCRELAGGREGATES('3cTnt6Sh19C9Mj66wOTA1x',#5,$,$,#9552,(#9558));
#18934= IFCRELAGGREGATES('2KJRpOvfH24uI6sKgQu2SR',#5,$,$,#9565,(#9571));
#18935= IFCRELAGGREGATES('02ofBZEE55JPrsnffovXDZ',#5,$,$,#9576,(#9582));
#18936= IFCRELAGGREGATES('0qtrHSTR9FyAtB1S5eNlhF',#5,$,$,#9586,(#9592));
#18937= IFCRELAGGREGATES('0LAxuQaPj4LRG5adF2zzTj',#5,$,$,#9597,(#9603));
#18938= IFCRELAGGREGATES('1wxJbZGhL62AIaXI8MWmLV',#5,$,$,#9608,(#9614));
#18939= IFCRELAGGREGATES('0re$Z059rDEfFJdVOSI$93',#5,$,$,#9622,(#9628));
#18940= IFCRELAGGREGATES('3H5Hqv0DX6oekLh8DQwJ4y',#5,$,$,#9634,(#9640));
#18941= IFCRELAGGREGATES('1z$EBXw8n1mv3sCz446_wd',#5,$,$,#9645,(#9651));
#18942= IFCRELAGGREGATES('2HHRQ1Agf4Th3MaC5p9_r6',#5,$,$,#9656,(#9662));
#18943= IFCRELAGGREGATES('2MnHOJNprBLeNOJPeVfNmA',#5,$,$,#9685,(#9714));
#18944= IFCRELAGGREGATES('3CDnhVWwD86uQAPzwzR6Gr',#5,$,$,#9778,(#9791));
#18945= IFCRELAGGREGATES('0FvqkS1zH279g7MoL6J3Ci',#5,$,$,#9853,(#9903));
#18946= IFCRELAGGREGATES('31xlShoPbBr9D2eVr$yrsu',#5,$,$,#10543,(#10553));
#18947= IFCRELAGGREGATES('3KQN2iz_z5cuXmQETy60u9',#5,$,$,#10562,(#10572));
#18948= IFCRELAGGREGATES('3CHdzc8brBbwjUrbh62E40',#5,$,$,#10574,(#10584));
#18949= IFCRELAGGREGATES('2W7oU0QVX1h8pZC5sI7G7B',#5,$,$,#10586,(#10596));
#18950= IFCRELAGGREGATES('0EdCZwE7LEDQGv4_e4N5N0',#5,$,$,#10598,(#10609));
#18951= IFCRELAGGREGATES('2j8Db6hhPAzQ8JLHGRHbMt',#5,$,$,#10611,(#10621));
#18952= IFCRELAGGREGATES('0XQB64INb6POq2wIO$0uJt',#5,$,$,#10651,(#11903,#10751,#10745,#10692,#10667));
#18953= IFCRELAGGREGATES('1LTAhi0HrFM8jC34JEQL$P',#5,$,$,#10883,(#10895));
#18954= IFCRELAGGREGATES('1S1LIZpsT6T9DXYjppLA70',#5,$,$,#10911,(#10925));
#18955= IFCRELAGGREGATES('1SySr4sWzCeBYKbwJj8HZF',#5,$,$,#10990,(#11796,#11144,#11129,#11012,#10999));
#18956= IFCRELAGGREGATES('2E7XM3Z4n4PulfHr_O9FOn',#5,$,$,#11029,(#11048));
#18957= IFCRELAGGREGATES('09355YR0b4Z9LLPpssR$GH',#5,$,$,#11065,(#11079));
#18958= IFCRELAGGREGATES('2_98Bounz5a8N5tppmw1RO',#5,$,$,#11312,(#17058,#15786,#15755,#15733,#15718,#11413,#11331));
#18959= IFCRELAGGREGATES('1UVzRZOy53HvL_z3TGcaIy',#5,$,$,#12791,(#13005,#12810));
#18960= IFCRELAGGREGATES('0Ad8eN7iTD3R2LuzB3WYl$',#5,$,$,#12835,(#13045,#12844));
#18961= IFCRELAGGREGATES('0PL_NnTMH0Eg1QQL2cUuCQ',#5,$,$,#12860,(#13139,#12876));
#18962= IFCRELAGGREGATES('3JDXYaMRLAAQVmByQafkqu',#5,$,$,#12899,(#13081,#12964,#12953,#12921));
#18963= IFCRELAGGREGATES('0Hl5eovHPDTAb3HpM6gWr6',#5,$,$,#13257,(#13311,#13263));
#18964= IFCRELAGGREGATES('0tHuvGHx9CcwUYtr_$ocaP',#5,$,$,#13265,(#13323,#13271));
#18965= IFCRELAGGREGATES('2G2iG__6vEzuZCrmMXSyAh',#5,$,$,#13273,(#13342,#13279));
#18966= IFCRELAGGREGATES('3nO5GTHVT06RN7N$gdwfHQ',#5,$,$,#13281,(#13329,#13299,#13293,#13287));
#18967= IFCRELAGGREGATES('3haEQ6k7z3BPuSjEtmiaAT',#5,$,$,#13420,(#13474,#13426));
#18968= IFCRELAGGREGATES('0H9dTB0iD8xhwFIQUd0u1u',#5,$,$,#13428,(#13486,#13434));
#18969= IFCRELAGGREGATES('345XDxWNf4e9sIgSX95NeU',#5,$,$,#13436,(#13505,#13442));
#18970= IFCRELAGGREGATES('2LqcawKb5A5fxAETsKkrVS',#5,$,$,#13444,(#13492,#13462,#13456,#13450));
#18971= IFCRELAGGREGATES('1joJZmecX88gHXeM$4CXY7',#5,$,$,#13580,(#13604));
#18972= IFCRELAGGREGATES('1uo5yMgNP62PYtCMUVDbyw',#5,$,$,#13633,(#13654));
#18973= IFCRELAGGREGATES('2HJ4aH4UfCCQzJA0ZIOmLF',#5,$,$,#13681,(#13704));
#18974= IFCRELAGGREGATES('1BatCQT$nCtOqEikFuVqXs',#5,$,$,#15050,(#16384,#15112,#15104,#15071,#15059));
#18975= IFCRELAGGREGATES('3g1vTjkvXBgxvPLAjNQYpC',#5,$,$,#15081,(#17158,#15833,#15822,#15808,#15802,#15128,#15087));
#18976= IFCRELAGGREGATES('1mAvrY5MjEQPohHBcw26mg',#5,$,$,#15137,(#16439,#15178,#15172,#15156,#15146));
#18977= IFCRELAGGREGATES('3vh4MKko5CQu$BCop2efV$',#5,$,$,#15160,(#17244,#15878,#15867,#15853,#15847,#15186,#15166));
#18978= IFCRELAGGREGATES('3mKo5NFzX3phge7E5$eSru',#5,$,$,#15188,(#16490,#15232,#15226,#15204,#15196));
#18979= IFCRELAGGREGATES('1AYnPQMPf5TQ0ifo5Jn5Lc',#5,$,$,#15207,(#17330,#15927,#15916,#15900,#15892,#15343,#15296,#15239,#15216));
#18980= IFCRELAGGREGATES('2t_BXHlnT7bRfnFxqmojAr',#5,$,$,#15243,(#16532,#15277,#15271,#15256,#15250));
#18981= IFCRELAGGREGATES('2EGlxuLzbAeQa9UMhdFD_Y',#5,$,$,#15258,(#17755,#16332,#16301,#16193,#16187,#15283,#15265));
#18982= IFCRELAGGREGATES('3FphrbnLb6xf_L3GTrwKYJ',#5,$,$,#15312,(#16559,#15378,#15372,#15331,#15321));
#18983= IFCRELAGGREGATES('3crNwuhYz6o9xpYIG1lgW1',#5,$,$,#15360,(#17423,#15975,#15964,#15950,#15944,#15386,#15366));
#18984= IFCRELAGGREGATES('0WRXqF_FfDFP28pu7KnjKc',#5,$,$,#15388,(#16596,#15398));
#18985= IFCRELAGGREGATES('2kgop4Y3v2JuADGq73JQkK',#5,$,$,#15411,(#16667,#15418));
#18986= IFCRELAGGREGATES('1f2DFIhwv7YQ$EgA7q0yGv',#5,$,$,#15427,(#16642,#15435));
#18987= IFCRELAGGREGATES('2W_tFYEXT3Dw3JVvHfpfnF',#5,$,$,#15446,(#16618,#15472,#15466,#15453));
#18988= IFCRELAGGREGATES('24y$Ytn7j9MO3tQVKD34bR',#5,$,$,#15475,(#16688,#15481));
#18989= IFCRELAGGREGATES('3V1trjR7D2sx$yKLTpl6Dn',#5,$,$,#15483,(#16726,#15489));
#18990= IFCRELAGGREGATES('2AMkOm_FPDQ9jCNG8S0qTK',#5,$,$,#15491,(#16708,#15497));
#18991= IFCRELAGGREGATES('1MyJxyCBj7m9DAHzgZ3IfL',#5,$,$,#15499,(#16694,#15507));
#18992= IFCRELAGGREGATES('2CbfivM0HDwwQVWpu2rTKN',#5,$,$,#15511,(#16738,#15517));
#18993= IFCRELAGGREGATES('14lWYHPMH64ghqfx6PNkDg',#5,$,$,#15519,(#16769,#15525));
#18994= IFCRELAGGREGATES('2EbP4Zq7L8T8a1aTqk5caA',#5,$,$,#15527,(#16757,#15533));
#18995= IFCRELAGGREGATES('0_WzJEmPL3UfgLHWIbV3K0',#5,$,$,#15535,(#16744,#15541));
#18996= IFCRELAGGREGATES('2jdG9aI4v7n9X$m45Xt5YZ',#5,$,$,#15543,(#16781,#15549));
#18997= IFCRELAGGREGATES('1i532V161DBOqwWF04ULUu',#5,$,$,#15551,(#16816,#15557));
#18998= IFCRELAGGREGATES('2bNow$aMP9gPkkT1NtoAyj',#5,$,$,#15559,(#16802,#15567));
#18999= IFCRELAGGREGATES('0yqsfXpSjAxQBw9VoLYDV2',#5,$,$,#15571,(#16787,#15579));
#19000= IFCRELAGGREGATES('2q4jRwNT14FRKldtbw33QN',#5,$,$,#15583,(#16828,#15591));
#19001= IFCRELAGGREGATES('01qi4zcyLDcxHad5lbzLtf',#5,$,$,#15596,(#16861,#15604));
#19002= IFCRELAGGREGATES('2f$LlT7jv30gquznv0rlNS',#5,$,$,#15608,(#16848,#15616));
#19003= IFCRELAGGREGATES('1qQXwdNi934emXlBaxMDFx',#5,$,$,#15621,(#16835,#15640,#15634,#15628));
#19004= IFCRELAGGREGATES('2el4bGYlvFhRg45Ekcw7qh',#5,$,$,#15642,(#16883,#15651));
#19005= IFCRELAGGREGATES('2g$ZoQ2_zEkByrLVNQVmWr',#5,$,$,#15662,(#16916,#15668));
#19006= IFCRELAGGREGATES('2mLsXYOjv5HPAtKvTwQbYL',#5,$,$,#15670,(#16931,#15676));
#19007= IFCRELAGGREGATES('3xigbGsLDFTALeBHNJwoFD',#5,$,$,#15678,(#16946,#15684));
#19008= IFCRELAGGREGATES('0iX2voTeLEExOko9MCLPqL',#5,$,$,#15686,(#16961,#15694));
#19009= IFCRELAGGREGATES('1x43DwuI954Q4AtI8CP7Ug',#5,$,$,#15698,(#15707));
#19010= IFCRELAGGREGATES('2U$CPmQ9rAQuk9AHyiwJme',#5,$,$,#15743,(#15749));
#19011= IFCRELAGGREGATES('3rVZUy85f8ngx7wn3l_Y5v',#5,$,$,#15790,(#15796));
#19012= IFCRELAGGREGATES('1$Qq9EoIj4DRb1uK0M6Umj',#5,$,$,#15810,(#15816));
#19013= IFCRELAGGREGATES('3oYapxMMLAfORIgzp72eVL',#5,$,$,#15835,(#15841));
#19014= IFCRELAGGREGATES('2CUBcnRwP9Mg1d_b6Xc0kS',#5,$,$,#15855,(#15861));
#19015= IFCRELAGGREGATES('3FNRKZZzDDNhSBuv7IBheI',#5,$,$,#15880,(#15886));
#19016= IFCRELAGGREGATES('0f9Us4_Or7uw5bX33ZBy3x',#5,$,$,#15904,(#15910));
#19017= IFCRELAGGREGATES('0P1jLjNJ19EOXLWeiP8BK4',#5,$,$,#15931,(#15938));
#19018= IFCRELAGGREGATES('2IDlfBaG96FuS7blY8nb4M',#5,$,$,#15952,(#15958));
#19019= IFCRELAGGREGATES('3_INZqJWTDZ8CEbSk7hlgI',#5,$,$,#15998,(#17463,#16036,#16030,#16014,#16006));
#19020= IFCRELAGGREGATES('0PPSM_Ad9FyQRS8JDfVNfX',#5,$,$,#16017,(#17614,#16173,#16162,#16148,#16142,#16074,#16049,#16043,#16024));
#19021= IFCRELAGGREGATES('3urZ9y7mXFfOp9$IF24TWO',#5,$,$,#16051,(#17494,#16086,#16080,#16067,#16059));
#19022= IFCRELAGGREGATES('3cQ8u6fVbDqQYSGArtbwvr',#5,$,$,#16129,(#16136));
#19023= IFCRELAGGREGATES('1OvEYG3XP3Uhi2fqkZ86$V',#5,$,$,#16150,(#16156));
#19024= IFCRELAGGREGATES('1in9VsyRbCOxBkEhHn5cyj',#5,$,$,#16175,(#16181));
#19025= IFCRELAGGREGATES('0mbTwupyDFNP7sTUOy64Bz',#5,$,$,#16195,(#17816,#16202));
#19026= IFCRELAGGREGATES('1xIiNQCSzFCgC3WkfyUyWF',#5,$,$,#16204,(#17801,#16211));
#19027= IFCRELAGGREGATES('2zzJtMQQHBzuRYtkw3yRPb',#5,$,$,#16213,(#17706,#16220));
#19028= IFCRELAGGREGATES('0sS1FS10L4jhFYP5ypIhgl',#5,$,$,#16222,(#17718,#16229));
#19029= IFCRELAGGREGATES('2sMSr12rLAkQpksFqrLjzB',#5,$,$,#16231,(#17730,#16238));
#19030= IFCRELAGGREGATES('2jR3ukO2L5CuXkHM3TnHFo',#5,$,$,#16240,(#17786,#16247));
#19031= IFCRELAGGREGATES('32Y374A15B6x$QWEtqACaS',#5,$,$,#16249,(#17749,#16256));
#19032= IFCRELAGGREGATES('1aR99n_Vf8G9HrzTyx9oeH',#5,$,$,#16258,(#17736,#16278,#16272,#16266));
#19033= IFCRELAGGREGATES('3yvNgvcUP1reChARsxRjhb',#5,$,$,#16280,(#17774,#16287));
#19034= IFCRELAGGREGATES('0VtroCrsXCkeNV71CyKP3Y',#5,$,$,#16289,(#16295));
#19035= IFCRELAGGREGATES('1FUyH$wyX6ZObxY4_I6R45',#5,$,$,#16303,(#17761,#16321,#16315,#16309));
#19036= IFCRELAGGREGATES('0K$qqiNur6jf5r1asmtbBc',#5,$,$,#16334,(#16344));
#19037= IFCRELAGGREGATES('2Lngij6RrEPOD9pzRaiVWN',#5,$,$,#16348,(#16356));
#19038= IFCRELAGGREGATES('3zXu9e3LT2Zesvzwn0mZZG',#5,$,$,#16405,(#16411));
#19039= IFCRELAGGREGATES('3yohpIF4fFfgHIvFUd7pET',#5,$,$,#16413,(#16419));
#19040= IFCRELAGGREGATES('2ZFlFEvcj5nuSwIgBdjyFA',#5,$,$,#16460,(#16466));
#19041= IFCRELAGGREGATES('0EySRXq_L3df1IrDeOsmGz',#5,$,$,#16468,(#16474));
#19042= IFCRELAGGREGATES('36AmzXDYXCegvGxDP2rhkq',#5,$,$,#16506,(#16513));
#19043= IFCRELAGGREGATES('2lwThHvHb2dwNsGSwAeQ_h',#5,$,$,#16515,(#16522));
#19044= IFCRELAGGREGATES('2Gi$wgKPX4qA4ApY2PueCE',#5,$,$,#16964,(#16971));
#19045= IFCRELAGGREGATES('3MxchjJQX76utgdn0JqxKX',#5,$,$,#16976,(#16983));
#19046= IFCRELAGGREGATES('2H9dbgHeT9dewIkxNOs5oj',#5,$,$,#16985,(#16992));
#19047= IFCRELAGGREGATES('1n6StQRlXD2xvScuuaSgbv',#5,$,$,#16994,(#17001));
#19048= IFCRELAGGREGATES('2$k3_a$w10mgubWScJSwhd',#5,$,$,#17003,(#17010));
#19049= IFCRELAGGREGATES('3X9oRjb1PBnhoovR81Z0DB',#5,$,$,#17012,(#17018));
#19050= IFCRELAGGREGATES('3D4DjFDFb32fAwFrdNsU57',#5,$,$,#17020,(#17026));
#19051= IFCRELAGGREGATES('23OaDZHKj3nOOCBOW9GD$c',#5,$,$,#17028,(#17034));
#19052= IFCRELAGGREGATES('1hwBY33eXAnPyLI1hzTEU2',#5,$,$,#17036,(#17042));
#19053= IFCRELAGGREGATES('2AUj05lkz4DffZfBfWeDKd',#5,$,$,#17044,(#17050));
#19054= IFCRELAGGREGATES('2UtjlHNQ12WfIquQnalra4',#5,$,$,#17074,(#17080));
#19055= IFCRELAGGREGATES('2W2GsLRODAbhOU4U4AJlls',#5,$,$,#17082,(#17088));
#19056= IFCRELAGGREGATES('1QAe5m029C99Ib8XwAdKk6',#5,$,$,#17090,(#17096));
#19057= IFCRELAGGREGATES('1Z7UJkukPBMPobWA$jIn2M',#5,$,$,#17098,(#17104));
#19058= IFCRELAGGREGATES('2aZ0nHkM53JwnSA3fA2lDZ',#5,$,$,#17106,(#17112));
#19059= IFCRELAGGREGATES('0Ta6YqArLElegHgK_S1LUz',#5,$,$,#17114,(#17120));
#19060= IFCRELAGGREGATES('1cKuMwuIzCzuSnzx1VGh8Y',#5,$,$,#17122,(#17128));
#19061= IFCRELAGGREGATES('3AWvf0P1n0DxzXSKniyXLU',#5,$,$,#17130,(#17136));
#19062= IFCRELAGGREGATES('1fLfHaYff6eOw8JSXI_T63',#5,$,$,#17138,(#17144));
#19063= IFCRELAGGREGATES('0So417Dhf6SPhNAZFrPWsG',#5,$,$,#17146,(#17152));
#19064= IFCRELAGGREGATES('0M9jTbHfT8CBdq$ll4a_L_',#5,$,$,#17160,(#17166));
#19065= IFCRELAGGREGATES('2RqAvIc9P31eSmVOnU2kh0',#5,$,$,#17168,(#17174));
#19066= IFCRELAGGREGATES('10Z_w04Yf27fz$dv15k$tu',#5,$,$,#17176,(#17182));
#19067= IFCRELAGGREGATES('2MoxMEG5547ANRdX2fft$a',#5,$,$,#17184,(#17190));
#19068= IFCRELAGGREGATES('1ulAx4IKbBBPl$B62zqL$r',#5,$,$,#17192,(#17198));
#19069= IFCRELAGGREGATES('1$pP_IwPX6egYAerKKtTop',#5,$,$,#17200,(#17206));
#19070= IFCRELAGGREGATES('3HpPzaHLLFKAfpW0qOHDJm',#5,$,$,#17208,(#17214));
#19071= IFCRELAGGREGATES('23yZ2oet13yg5YUEUA_nb4',#5,$,$,#17216,(#17222));
#19072= IFCRELAGGREGATES('1aA18pljHBQBfVmZ1VP6ZH',#5,$,$,#17224,(#17230));
#19073= IFCRELAGGREGATES('2APeOtvMrA7h_x7w4SflK0',#5,$,$,#17232,(#17238));
#19074= IFCRELAGGREGATES('0cQ_cwSzXEs8umPn_IBvka',#5,$,$,#17246,(#17252));
#19075= IFCRELAGGREGATES('2XHhbyXBfDJeW82RelKKUU',#5,$,$,#17254,(#17260));
#19076= IFCRELAGGREGATES('2TLl2hPIv7AghbNk23USe1',#5,$,$,#17262,(#17268));
#19077= IFCRELAGGREGATES('1ZOyd91I16YP7$$2YqnTSl',#5,$,$,#17270,(#17276));
#19078= IFCRELAGGREGATES('35a4osZuD8T9yGZ8CHgAGA',#5,$,$,#17278,(#17284));
#19079= IFCRELAGGREGATES('0EqlmPLID3Ou8FZ3HlUHDB',#5,$,$,#17286,(#17292));
#19080= IFCRELAGGREGATES('1Y8ZGPxq10KAI9vSPwZks0',#5,$,$,#17294,(#17300));
#19081= IFCRELAGGREGATES('3rIByPPaj0zhb94WA_3o6h',#5,$,$,#17302,(#17308));
#19082= IFCRELAGGREGATES('16MO7P7u93gg_WmR3ATpDk',#5,$,$,#17310,(#17316));
#19083= IFCRELAGGREGATES('32uQx3_Dz4ZgaSzaEHW2hr',#5,$,$,#17318,(#17324));
#19084= IFCRELAGGREGATES('0KGZ09aLX1mftWSJ2xV4CE',#5,$,$,#17334,(#17341));
#19085= IFCRELAGGREGATES('0fDBCtmWX0kxV1liXu7gam',#5,$,$,#17343,(#17350));
#19086= IFCRELAGGREGATES('3$vl6NVR1DcgbPf0Kpwcp$',#5,$,$,#17352,(#17359));
#19087= IFCRELAGGREGATES('1hesHZUCX91ubarSdDr8v9',#5,$,$,#17361,(#17368));
#19088= IFCRELAGGREGATES('1kODY9SzD7VPk4p4TLnl4$',#5,$,$,#17370,(#17377));
#19089= IFCRELAGGREGATES('08zGBvkhH3A96nLQmrXPZ3',#5,$,$,#17379,(#17385));
#19090= IFCRELAGGREGATES('2UpD$Hf0jAuPx525jie2ot',#5,$,$,#17387,(#17393));
#19091= IFCRELAGGREGATES('2oy4nYIhbDnhh4XZQ8mSjr',#5,$,$,#17395,(#17401));
#19092= IFCRELAGGREGATES('2k5ytSV4j8FRPTi4MSGU_5',#5,$,$,#17403,(#17409));
#19093= IFCRELAGGREGATES('1ra51fVvL2s81Hx$qsOzHA',#5,$,$,#17411,(#17417));
#19094= IFCRELAGGREGATES('1_vs01frn0dhDJJbzzImzu',#5,$,$,#17425,(#17432));
#19095= IFCRELAGGREGATES('1mUjI60Dr4cBQF95dZLaYt',#5,$,$,#17434,(#17441));
#19096= IFCRELAGGREGATES('0es2zXYkLAFQcGWgA3bZ1V',#5,$,$,#17525,(#17532));
#19097= IFCRELAGGREGATES('2XB8XZ4UzDLRu9bb9boA$e',#5,$,$,#17534,(#17541));
#19098= IFCRELAGGREGATES('2pB_qSzunDUAtETc8kMNaI',#5,$,$,#17543,(#17550));
#19099= IFCRELAGGREGATES('1aGycqbW9DdujQpLtHwK$P',#5,$,$,#17552,(#17559));
#19100= IFCRELAGGREGATES('0DhdqZhy5488tgo_RZJEsw',#5,$,$,#17561,(#17568));
#19101= IFCRELAGGREGATES('1$R6ajDcf0MQ5uFjqqE8iE',#5,$,$,#17570,(#17576));
#19102= IFCRELAGGREGATES('3YGhLoXdz9zxqDBhKoYkLR',#5,$,$,#17578,(#17584));
#19103= IFCRELAGGREGATES('1LH5fISRr7KR6PdIGWdqTR',#5,$,$,#17586,(#17592));
#19104= IFCRELAGGREGATES('1ASQUzITLFROmFmfYJnEK3',#5,$,$,#17594,(#17600));
#19105= IFCRELAGGREGATES('1dT$kfCY99PuyaB$GD51Jx',#5,$,$,#17602,(#17608));
#19106= IFCRELAGGREGATES('31Uh51Plv0yg4tM6I4toRx',#5,$,$,#17616,(#17622));
#19107= IFCRELAGGREGATES('0czH_UBoLDD8xZodeXEr40',#5,$,$,#17624,(#17630));
#19108= IFCRELAGGREGATES('3SeWUttJz9bvGtIyBzAji_',#5,$,$,#17632,(#17638));
#19109= IFCRELAGGREGATES('3$sTmrjsb30PR0ZPCh55b$',#5,$,$,#17640,(#17646));
#19110= IFCRELAGGREGATES('1$mLhPVdr6BRGgtX8njDM0',#5,$,$,#17648,(#17654));
#19111= IFCRELAGGREGATES('3sz2NviK16bP80VrgXpUOa',#5,$,$,#17656,(#17662));
#19112= IFCRELAGGREGATES('3o5$XPFfX6uvMwppSD5ug4',#5,$,$,#17664,(#17670));
#19113= IFCRELAGGREGATES('3k9PiKDbrDcf7NYVnR_L6H',#5,$,$,#17672,(#17678));
#19114= IFCRELAGGREGATES('1vd5UmXF5A98E5Lsjf_8yJ',#5,$,$,#17680,(#17686));
#19115= IFCRELAGGREGATES('1p2zlY4fn3RR86MrR_i9ot',#5,$,$,#17688,(#17694));
#19116= IFCRELAGGREGATES('2M6q2DSx59BgXr6tdkfMpS',#5,$,$,#17818,(#17840));
#19117= IFCRELAGGREGATES('0wwacQmavDBAuGMbWUeYlG',#5,$,$,#17867,(#17882));
#19118= IFCRELAGGREGATES('2y_m0Nd65Ck82vSRlb$ibi',#5,$,$,#17903,(#17920));
#19119= IFCRELAGGREGATES('0hSDZSS$1A1gJnfYXYswcA',#5,$,$,#17942,(#17953));
#19120= IFCRELAGGREGATES('1TPed6DSn24ROu8va95IQ6',#5,$,$,#17969,(#17975));
#19121= IFCRELAGGREGATES('3JhD2QMoz6hOx_kmTzTnBr',#5,$,$,#17977,(#17983));
#19122= IFCRELAGGREGATES('2MBr7V7AbE3goyQpYNd1M$',#5,$,$,#17985,(#17991));
#19123= IFCRELAGGREGATES('2HtiAlb8n4fflM2vDEk_C7',#5,$,$,#17993,(#17999));
#19124= IFCRELAGGREGATES('3n671ZVvn298r23M$HTPBm',#5,$,$,#18001,(#18007));
#19125= IFCRELAGGREGATES('1V$KaRP8n30uTe25DkZgOL',#5,$,$,#18009,(#18024));
#19126= IFCRELAGGREGATES('2mL4CSyM99CPbmA7CCfcl_',#5,$,$,#18046,(#18052));
#19127= IFCRELAGGREGATES('3qpE3gafn0nOHdDWdTRwNs',#5,$,$,#18054,(#18061));
#19128= IFCRELAGGREGATES('1RQenn1KT2M8QsichDIMJU',#5,$,$,#18063,(#18078));
#19129= IFCRELAGGREGATES('14Ijcs6hX3dvpLiUK8Nija',#5,$,$,#18098,(#18114));
#19130= IFCRELAGGREGATES('2OgqItFPDFVfXQY8rN8mX$',#5,$,$,#18132,(#18138));
#19131= IFCRELAGGREGATES('1PX9T7skz8MeNApWMyPn36',#5,$,$,#18140,(#18144));
#19132= IFCRELAGGREGATES('3Auiwyjo504hh$RRtaWK2n',#5,$,$,#18146,(#18150));
#19133= IFCRELAGGREGATES('0ZmMRQ0lT66favzzaMD5MU',#5,$,$,#18152,(#18159));
#19134= IFCRELAGGREGATES('0xYEriZx91tO5aScX084lV',#5,$,$,#18161,(#18181));
#19135= IFCRELAGGREGATES('1xLERVpafAreuhEl3v9kcF',#5,$,$,#18211,(#18236));
#19136= IFCRELAGGREGATES('1nlAY$ApP4Bxa45_mTY_3C',#5,$,$,#18262,(#18275));
#19137= IFCRELAGGREGATES('0eC4z$m3n2NRA5rMSpnsiJ',#5,$,$,#18298,(#18314));
#19138= IFCRELAGGREGATES('2Na7wWmQnCQBq6aK2FJr7r',#5,$,$,#18339,(#18363));
#19139= IFCRELAGGREGATES('3s5Gkm2Hj3P9$Dmj0XL6Ab',#5,$,$,#18390,(#18457));
#19140= IFCRELAGGREGATES('2$LcenYCLEuwiKiJOSU1pb',#5,$,$,#18485,(#18624));
#19141= IFCRELAGGREGATES('35fZ8ELXX8gxYxsb_LK4Wv',#5,$,$,#18652,(#18671));
#19142= IFCRELAGGREGATES('28wzTLH7DBJR$OlIu9KL2W',#5,$,$,#18700,(#18707));
#19143= IFCRELCONTAINEDINSPATIALSTRUCTURE('07J1N6xmfBRxE0qDqwnpA3',#5,$,$,(#18700,#18652,#18485,#18390,#18339,#18298,#18262,#18211,#18161,#18152,#18146,#18140,#18132,#18098,#18063,#18054,#18046,#18009,#18001,#17993,#17985,#17977,#17969,#17942,#17903,#17867,#17818,#17688,#17680,#17672,#17664,#17656,#17648,#17640,#17632,#17624,#17616,#17602,#17594,#17586,#17578,#17570,#17561,#17552,#17543,#17534,#17525,#17434,#17425,#17411,#17403,#17395,#17387,#17379,#17370,#17361,#17352,#17343,#17334,#17318,#17310,#17302,#17294,#17286,#17278,#17270,#17262,#17254,#17246,#17232,#17224,#17216,#17208,#17200,#17192,#17184,#17176,#17168,#17160,#17146,#17138,#17130,#17122,#17114,#17106,#17098,#17090,#17082,#17074,#17044,#17036,#17028,#17020,#17012,#17003,#16994,#16985,#16976,#16964,#16515,#16506,#16468,#16460,#16413,#16405,#16348,#16334,#16303,#16289,#16280,#16258,#16249,#16240,#16231,#16222,#16213,#16204,#16195,#16175,#16150,#16129,#16051,#16017,#15998,#15952,#15931,#15904,#15880,#15855,#15835,#15810,#15790,#15743,#15698,#15686,#15678,#15670,#15662,#15642,#15621,#15608,#15596,#15583,#15571,#15559,#15551,#15543,#15535,#15527,#15519,#15511,#15499,#15491,#15483,#15475,#15446,#15427,#15411,#15388,#15360,#15312,#15258,#15243,#15207,#15188,#15160,#15137,#15081,#15050,#15048,#15020,#15007,#14995,#14967,#14955,#14942,#14930,#14918,#14888,#14858,#14828,#14798,#14768,#14738,#14708,#14678,#14648,#14618,#14590,#14562,#14534,#14506,#14476,#14446,#14433,#14421,#14409,#14396,#14384,#14372,#14359,#14347,#14335,#14322,#14310,#14298,#14285,#14273,#14261,#14225,#14197,#14167,#14137,#14097,#14069,#14041,#14007,#13979,#13951,#13923,#13895,#13867,#13839,#13811,#13783,#13755,#13681,#13633,#13580,#13444,#13436,#13428,#13420,#13384,#13281,#13273,#13265,#13257,#13228,#12899,#12860,#12835,#12791,#12733,#12663,#12633,#12603,#12573,#12474,#12444,#12414,#12384,#12319,#12289,#12259,#12229,#11711,#11681,#11651,#11621,#11591,#11561,#11531,#11312,#11310,#11244,#11123,#11065,#11029,#10990,#10988,#10911,#10883,#10881,#10739,#10651,#10649,#10611,#10598,#10586,#10574,#10562,#10543,#10495,#10465,#10435,#10405,#10375,#10345,#10204,#10174,#10144,#10114,#10084,#9853,#9778,#9776,#9685,#9656,#9645,#9634,#9622,#9608,#9597,#9586,#9576,#9565,#9552,#9521,#9441,#9439,#9426,#9414,#9364,#9356,#9348,#9340,#9329,#9303,#9289,#9272,#9251,#9227,#9200,#9170,#9099,#9063,#9061,#9044,#9032,#8977,#8927,#8855,#8851,#8781,#8770,#8760,#8748,#8737,#8678,#8528,#8507,#8477,#8466,#8454,#8440,#8424,#8388,#8370,#8348,#8320,#8288,#8234,#8215,#8170,#8168,#8150,#8067,#8065,#7995,#7976,#7962,#7949,#7936,#7926,#7897,#7883,#7873,#7862,#7853,#7844,#7770,#7682,#7680,#7650,#7638,#7626,#7596,#7584,#7572,#7560,#7497,#7480,#7466,#7458,#7450,#7440,#7420,#7408,#7400,#7391,#7382,#7373,#7283,#7250,#7235,#7223,#7206,#7188,#7137,#7135,#7105,#7075,#7063,#7051,#7039,#7027,#7015,#7003,#6973,#6943,#6913,#6883,#6853,#6817,#6809,#6801,#6787,#6765,#6757,#6744,#6730,#6717,#6701,#6691,#6668,#6654,#6644,#6630,#6621,#6612,#6454,#6388,#6386,#6356,#6326,#6314,#6302,#6272,#6260,#6248,#6236,#6207,#6186,#6167,#6153,#6137,#6100,#6041,#6026,#6011,#5996,#5978,#5945,#5871,#5869,#5854,#5842,#5830,#5818,#5806,#5747,#5745,#5195,#5193,#5163,#5133,#5103,#5073,#5043,#5013,#4982,#4917,#4887,#4857,#4827,#4791,#4741,#4705,#4548,#4462,#4406,#4327,#4306,#4289,#4249,#4207,#4017,#3921,#3911,#3841,#3823,#3812,#3796,#3771,#3756,#3745,#3731,#3723,#3714,#3702,#3683,#3661,#3653,#3643,#3635,#3621,#3609,#3593,#3569,#3554,#3541,#3527,#3512,#3503,#3495,#3487,#3475,#3467,#3457,#3439,#3425,#3413,#3398,#3341,#3325,#3314,#3298,#3280,#3262,#3248,#3232,#3182,#3170,#3154,#3082,#3014,#2855,#2853,#2841,#2829,#2817,#2805,#2775,#2763,#2733,#2721,#2709,#2697,#2685,#2673,#2643,#2631,#2601,#2589,#2576,#2563,#2550,#2537,#2507,#2492,#2449,#2428,#2417,#2409,#2401,#2369,#2352,#2344,#2330,#2321,#2308,#2291,#2274,#2266,#2258,#2230,#2212,#2204,#2190,#2181,#2168,#2160,#2146,#2138,#2130,#2122,#2114,#2089,#2075,#2067,#2053,#2044,#2031,#2023,#2009,#1986,#1964,#1948,#1926,#1811,#1772,#1758,#1696,#1664,#1610,#1602,#1588,#1501,#1451,#1357,#1306,#1244,#1217,#985,#886,#884,#872,#860,#848,#836,#824,#812,#800,#788,#776,#764,#752,#740,#728,#716,#704,#692,#680,#666,#651,#633,#610,#594,#569,#538,#484,#482,#452,#422,#392,#362,#332,#302,#253,#134,#106,#33),#31);
#19144= IFCRELDEFINESBYPROPERTIES('049vaEZfn0ewW_O1Gtn0qQ',#5,$,$,(#33),#42);
#19145= IFCRELDEFINESBYPROPERTIES('3iTAdnHSf8yww6xX84LbNC',#5,$,$,(#33),#44);
#19146= IFCRELDEFINESBYPROPERTIES('010iDVXYH0zxAToS5sLHEq',#5,$,$,(#118,#68),#81);
#19147= IFCRELDEFINESBYPROPERTIES('0a5K3dgPX34uPLZulFr9bM',#5,$,$,(#68),#96);
#19148= IFCRELDEFINESBYPROPERTIES('3b8yoykND0WOiQdWSuMyDd',#5,$,$,(#68),#103);
#19149= IFCRELDEFINESBYPROPERTIES('3q8T2UUUP30xrDRXfDTTWt',#5,$,$,(#106),#108);
#19150= IFCRELDEFINESBYPROPERTIES('05tN1gfZ93vfy9EOkRayVi',#5,$,$,(#106),#110);
#19151= IFCRELDEFINESBYPROPERTIES('0UtVnJ6LvCaAQpNxIGBe00',#5,$,$,(#118),#126);
#19152= IFCRELDEFINESBYPROPERTIES('2DQP2Xq0DDA9kLE7GxNH0p',#5,$,$,(#118),#132);
#19153= IFCRELDEFINESBYPROPERTIES('2EwepLbxP2nfLtKn96D2Q_',#5,$,$,(#134),#140);
#19154= IFCRELDEFINESBYPROPERTIES('2pMNdLguf3TuLzYWDGq$PD',#5,$,$,(#134),#142);
#19155= IFCRELDEFINESBYPROPERTIES('3VZevwkcfAS9y6bfxN$lak',#5,$,$,(#157),#162);
#19156= IFCRELDEFINESBYPROPERTIES('3zNdVcNOD09RIj_HgDBF0u',#5,$,$,(#157),#177);
#19157= IFCRELDEFINESBYPROPERTIES('2whlvcb7bApOD$vxMB$Ar8',#5,$,$,(#157),#183);
#19158= IFCRELDEFINESBYPROPERTIES('1g3hcFWUTAGPVyT3G5dDd3',#5,$,$,(#482,#452,#422,#392,#362,#332,#302,#253),#271);
#19159= IFCRELDEFINESBYPROPERTIES('1Pajsl0Cn70RePyj3y$Mkg',#5,$,$,(#538,#484),#490);
#19160= IFCRELDEFINESBYPROPERTIES('078qBFL2XAahsKojzIix0$',#5,$,$,(#7995,#7926,#7497,#7440,#7235,#6817,#6809,#6801,#6787,#6765,#6757,#6691,#6207,#6100,#4327,#4306,#3653,#3643,#3467,#3457,#3170,#3154,#2160,#2146,#2023,#2009,#1602,#1588,#538,#484),#492);
#19161= IFCRELDEFINESBYPROPERTIES('3rRXnw2pnApxm1eL1EsM_M',#5,$,$,(#546,#508),#517);
#19162= IFCRELDEFINESBYPROPERTIES('1ihgxnkTz6CPDcO10O_ENl',#5,$,$,(#2155,#2018,#1597,#508),#531);
#19163= IFCRELDEFINESBYPROPERTIES('3ZOJayWqT0iBQsssFiqGM_',#5,$,$,(#2155,#2018,#1597,#508),#536);
#19164= IFCRELDEFINESBYPROPERTIES('2SNcrrkNP9lgA58BQP9MNn',#5,$,$,(#2166,#2029,#1608,#546),#548);
#19165= IFCRELDEFINESBYPROPERTIES('0sc6mfXMXBeROPeoZvMTm5',#5,$,$,(#2166,#2029,#1608,#546),#553);
#19166= IFCRELDEFINESBYPROPERTIES('0Co6eXojzCH8tm0ylqC1in',#5,$,$,(#2775,#2733,#2643,#2601,#2507,#2449,#836,#824,#764,#752,#692,#680,#594,#569),#581);
#19167= IFCRELDEFINESBYPROPERTIES('0SOgPLKHP1_viNezPYLiKr',#5,$,$,(#7584,#7560,#7039,#7015,#6260,#6236,#5830,#5806,#2841,#2817,#2709,#2685,#2576,#2550,#872,#848,#800,#776,#728,#704,#651,#610),#618);
#19168= IFCRELDEFINESBYPROPERTIES('2sRIG358bF5hwbQAlTTtyT',#5,$,$,(#7572,#7027,#6248,#5818,#2829,#2697,#2563,#860,#788,#716,#633),#638);
#19169= IFCRELDEFINESBYPROPERTIES('0LrlOYOTj2v938c1OrLBVE',#5,$,$,(#7596,#7051,#6272,#5842,#2853,#2721,#2589,#884,#812,#740,#666),#668);
#19170= IFCRELDEFINESBYPROPERTIES('0pfDAsShz9qhTYK9d5rJ7Z',#5,$,$,(#886),#892);
#19171= IFCRELDEFINESBYPROPERTIES('1bsM2MRfj25vbUQKHG9Vxl',#5,$,$,(#16051,#15998,#15312,#15243,#15188,#15137,#15050,#10990,#7682,#7137,#6388,#5195,#4289,#4249,#4207,#1451,#1306,#1217,#886),#894);
#19172= IFCRELDEFINESBYPROPERTIES('0HiQ7jACD9Nh98DnLG51Hf',#5,$,$,(#948,#913),#922);
#19173= IFCRELDEFINESBYPROPERTIES('2felrM_j9AefiIZP99$K3Z',#5,$,$,(#1235,#1226,#948,#913),#936);
#19174= IFCRELDEFINESBYPROPERTIES('3rE$F2zPnBhfY68l9ExKrx',#5,$,$,(#1235,#1226,#948,#913),#942);
#19175= IFCRELDEFINESBYPROPERTIES('2NEwgdnZTDTOA3$Oj9cmgS',#5,$,$,(#5521,#5515,#5509,#5503,#5481,#964),#968);
#19176= IFCRELDEFINESBYPROPERTIES('0ScLgnUOP2aRAX2MQbIMMz',#5,$,$,(#1241,#964),#977);
#19177= IFCRELDEFINESBYPROPERTIES('1feUts0vH7yvZTrLgvH6SY',#5,$,$,(#1241,#964),#983);
#19178= IFCRELDEFINESBYPROPERTIES('3NRgGO4Cr8tAEtT4DbFgXe',#5,$,$,(#985),#991);
#19179= IFCRELDEFINESBYPROPERTIES('0wc8Dqyq9439T4tknYFU4_',#5,$,$,(#7770,#7250,#6454,#5871,#3082,#3014,#2855,#1501,#1357,#1244,#985),#993);
#19180= IFCRELDEFINESBYPROPERTIES('16jghHb5XCsgLMcnUxoCL_',#5,$,$,(#5880,#1006),#1012);
#19181= IFCRELDEFINESBYPROPERTIES('3Fe9Nmf919Ug4o4L1U22uG',#5,$,$,(#1510,#1366,#1006),#1026);
#19182= IFCRELDEFINESBYPROPERTIES('3HGux3_Ib4gQZWejh6UtAj',#5,$,$,(#7777,#7258,#6461,#5880,#1510,#1366,#1254,#1006),#1032);
#19183= IFCRELDEFINESBYPROPERTIES('2Frf3Avmz0au5R0DNZXLx7',#5,$,$,(#5902,#5895,#5888,#2945,#2922,#2898,#1111,#1085,#1050),#1053);
#19184= IFCRELDEFINESBYPROPERTIES('1wDqt0jvT5GhM4yPcTw4ut',#5,$,$,(#1519,#1375,#1050),#1066);
#19185= IFCRELDEFINESBYPROPERTIES('2$oDMpDu5FggYcgm5wn1FX',#5,$,$,(#7783,#7266,#6467,#5888,#1519,#1375,#1265,#1050),#1072);
#19186= IFCRELDEFINESBYPROPERTIES('276VYpBFnEEwCVPRjPbVHS',#5,$,$,(#1085),#1099);
#19187= IFCRELDEFINESBYPROPERTIES('13CrAFO3XCaP_WsaucBeRv',#5,$,$,(#6473,#5895,#1275,#1085),#1105);
#19188= IFCRELDEFINESBYPROPERTIES('07Zc$G5T56QBkrF29Opgnl',#5,$,$,(#1111),#1118);
#19189= IFCRELDEFINESBYPROPERTIES('2N0YK3Sg50M8ivk7fN8VVO',#5,$,$,(#6479,#5902,#1282,#1111),#1123);
#19190= IFCRELDEFINESBYPROPERTIES('33whaPCQT99ACjB7cYW2WL',#5,$,$,(#5937,#2999,#1190),#1196);
#19191= IFCRELDEFINESBYPROPERTIES('3Ou2ScjOD6cBl7DgOripd3',#5,$,$,(#1442,#1190),#1210);
#19192= IFCRELDEFINESBYPROPERTIES('2b1Y6EX8n9kRqMBNu071Fn',#5,$,$,(#1190),#1215);
#19193= IFCRELDEFINESBYPROPERTIES('3v0EdUXAz1_PA$1dzJkFLu',#5,$,$,(#1217),#1220);
#19194= IFCRELDEFINESBYPROPERTIES('1lQVHRHXrFDAs4i2iAzHc5',#5,$,$,(#1235,#1226),#1229);
#19195= IFCRELDEFINESBYPROPERTIES('0wfIcow1D3DBbFMT3ScgJK',#5,$,$,(#6567,#6561,#6555,#6549,#6543,#1241),#1242);
#19196= IFCRELDEFINESBYPROPERTIES('29ZJVQBl13yfm2IqSwH9LU',#5,$,$,(#1244),#1248);
#19197= IFCRELDEFINESBYPROPERTIES('25ZZf4uwXFdeaRin4AGjCl',#5,$,$,(#6461,#1254),#1257);
#19198= IFCRELDEFINESBYPROPERTIES('2Q2XkqKiDBn9YdTgKanlYE',#5,$,$,(#1254),#1259);
#19199= IFCRELDEFINESBYPROPERTIES('1o$YXmebX5We9$EfZiC_OD',#5,$,$,(#6479,#6473,#6467,#3040,#3034,#3028,#1282,#1275,#1265),#1268);
#19200= IFCRELDEFINESBYPROPERTIES('2KDcxEIHr7_ewqBjl2z4LQ',#5,$,$,(#1265),#1269);
#19201= IFCRELDEFINESBYPROPERTIES('2Pte1Au6X6ivZrC2GfgsUD',#5,$,$,(#1275),#1276);
#19202= IFCRELDEFINESBYPROPERTIES('1f$5cESDr5Zgg5cW__rtHA',#5,$,$,(#1282),#1283);
#19203= IFCRELDEFINESBYPROPERTIES('0$kq2BaO1FcgM0EXNp4SY8',#5,$,$,(#6507,#3076,#1293),#1296);
#19204= IFCRELDEFINESBYPROPERTIES('0gjGoR7QL15xDDRpDjz_Cj',#5,$,$,(#1293),#1301);
#19205= IFCRELDEFINESBYPROPERTIES('3OXPBAjdP6$AGyIzWXX3zF',#5,$,$,(#1293),#1304);
#19206= IFCRELDEFINESBYPROPERTIES('1k4xWVE4jBpP4ZNMImXsCd',#5,$,$,(#1306),#1311);
#19207= IFCRELDEFINESBYPROPERTIES('0eAwgIZrL1NOW3o7J9ZlG3',#5,$,$,(#1337,#1317),#1321);
#19208= IFCRELDEFINESBYPROPERTIES('3TRIV9eFD6VQ9vJ6qWG3ST',#5,$,$,(#1337,#1317),#1325);
#19209= IFCRELDEFINESBYPROPERTIES('1gQI$N8jzCgvXZXSRabWfJ',#5,$,$,(#1337,#1317),#1331);
#19210= IFCRELDEFINESBYPROPERTIES('2HujUWkGr9ufHI$tLcPwLJ',#5,$,$,(#12514,#12508,#12502,#12496,#12480,#1343),#1344);
#19211= IFCRELDEFINESBYPROPERTIES('2E_nQ7xtz4yfFitqChZujb',#5,$,$,(#1343),#1349);
#19212= IFCRELDEFINESBYPROPERTIES('2B8efNGTvFgALQ33J2OHOz',#5,$,$,(#1343),#1355);
#19213= IFCRELDEFINESBYPROPERTIES('2IrycE$ozCtf3jTXX57VX8',#5,$,$,(#1357),#1360);
#19214= IFCRELDEFINESBYPROPERTIES('1ObccGvzL2zQ$CWzZ6O_ZX',#5,$,$,(#7777,#1366),#1369);
#19215= IFCRELDEFINESBYPROPERTIES('3weN9lggvECReC69YvAeGY',#5,$,$,(#7796,#7789,#7783,#3110,#3102,#3096,#1402,#1384,#1375),#1378);
#19216= IFCRELDEFINESBYPROPERTIES('2xZSLhepf2Vg_iBVS3eRjf',#5,$,$,(#1528,#1384),#1390);
#19217= IFCRELDEFINESBYPROPERTIES('18b7l0mRnDGO1mxvZXcKXc',#5,$,$,(#7789,#1384),#1396);
#19218= IFCRELDEFINESBYPROPERTIES('2_uoDDx0z5s9PadETd4rCx',#5,$,$,(#1537,#1402),#1403);
#19219= IFCRELDEFINESBYPROPERTIES('17Gjq8jBj1w8eaBUzgc7ZR',#5,$,$,(#7796,#1402),#1408);
#19220= IFCRELDEFINESBYPROPERTIES('2_tb1eD4P5lQY6cc835ajk',#5,$,$,(#7838,#3146,#1442),#1445);
#19221= IFCRELDEFINESBYPROPERTIES('0OlinLqiLE9xD1IOcYGk9T',#5,$,$,(#1442),#1449);
#19222= IFCRELDEFINESBYPROPERTIES('15SZe3Ilv0sRabUt2XmKqZ',#5,$,$,(#1451),#1456);
#19223= IFCRELDEFINESBYPROPERTIES('2Yvd5iExL8i80eJ7va303v',#5,$,$,(#1480,#1462),#1466);
#19224= IFCRELDEFINESBYPROPERTIES('1SvNErgDj5muv_lADSk8MF',#5,$,$,(#1480,#1462),#1469);
#19225= IFCRELDEFINESBYPROPERTIES('0WkVwjIsfAURoOnJnHHOsN',#5,$,$,(#1462),#1474);
#19226= IFCRELDEFINESBYPROPERTIES('0z$HnRC0L75RbF2LS_6hGf',#5,$,$,(#1480),#1485);
#19227= IFCRELDEFINESBYPROPERTIES('2MPz$yU6TBAeSeXFf0iWIA',#5,$,$,(#1491),#1492);
#19228= IFCRELDEFINESBYPROPERTIES('0wrnJ4H2r7j8AqmRwmMPlk',#5,$,$,(#1491),#1493);
#19229= IFCRELDEFINESBYPROPERTIES('1K$gwGB8vDsQotd2XsHkio',#5,$,$,(#1491),#1499);
#19230= IFCRELDEFINESBYPROPERTIES('2q50ELpNLC1foqiuF2uWax',#5,$,$,(#1501),#1504);
#19231= IFCRELDEFINESBYPROPERTIES('19VtzuRh16axFmy3QoY$eq',#5,$,$,(#7258,#1510),#1513);
#19232= IFCRELDEFINESBYPROPERTIES('0RWAWOrC1BHBisjg2OeAPM',#5,$,$,(#7280,#7273,#7266,#1537,#1528,#1519),#1522);
#19233= IFCRELDEFINESBYPROPERTIES('0RWcn6CAr9qx7SGdAUD8lp',#5,$,$,(#7273,#1528),#1531);
#19234= IFCRELDEFINESBYPROPERTIES('208j3Y1Iv0k9D5Djsz0WGY',#5,$,$,(#7280,#1537),#1539);
#19235= IFCRELDEFINESBYPROPERTIES('3OhQcuQ912TAqwcXCuMffz',#5,$,$,(#7323,#1573),#1576);
#19236= IFCRELDEFINESBYPROPERTIES('2iuSZyArfAwuyZFfGht5oI',#5,$,$,(#1573),#1582);
#19237= IFCRELDEFINESBYPROPERTIES('0WiO8ypiLFXxwjuKA1EIFg',#5,$,$,(#1573),#1586);
#19238= IFCRELDEFINESBYPROPERTIES('08fHtQwuv3fODqR4W9dqR2',#5,$,$,(#1602,#1588),#1591);
#19239= IFCRELDEFINESBYPROPERTIES('3trIpJ4dHEQgaihV5tkEE8',#5,$,$,(#1608,#1597),#1600);
#19240= IFCRELDEFINESBYPROPERTIES('3RkIEjwKrBjguj9BMQbWLr',#5,$,$,(#1610),#1617);
#19241= IFCRELDEFINESBYPROPERTIES('3QU9x48s5Em9zkDpml_Vy7',#5,$,$,(#2308,#2168,#2031,#1610),#1619);
#19242= IFCRELDEFINESBYPROPERTIES('0IeuVvXcj719HROEPCrpej',#5,$,$,(#5989,#5958,#3290,#3273,#1677,#1635),#1643);
#19243= IFCRELDEFINESBYPROPERTIES('2_xQoVtp57wgV6KBaYqv6W',#5,$,$,(#2317,#2177,#2040,#1635),#1657);
#19244= IFCRELDEFINESBYPROPERTIES('3ZU6ygroj25x8a0N0BOQMD',#5,$,$,(#2317,#2177,#2040,#1635),#1662);
#19245= IFCRELDEFINESBYPROPERTIES('0fwRgU8VLANecTT5Vb$$JI',#5,$,$,(#1664),#1666);
#19246= IFCRELDEFINESBYPROPERTIES('1jgnNvJJfFaQ$ruM1EelOc',#5,$,$,(#2321,#2181,#2044,#1664),#1668);
#19247= IFCRELDEFINESBYPROPERTIES('2eMCjtYb5A0u0_fxo7vTQO',#5,$,$,(#7860,#7389,#6628,#5989,#3721,#3510,#3273,#2328,#2188,#2051,#1677),#1689);
#19248= IFCRELDEFINESBYPROPERTIES('0sb2Xn05zEeOC76vuWxs47',#5,$,$,(#2328,#2188,#2051,#1677),#1694);
#19249= IFCRELDEFINESBYPROPERTIES('1gwtyTuL961ODf4GQ3NGPM',#5,$,$,(#1948,#1926,#1758,#1696),#1702);
#19250= IFCRELDEFINESBYPROPERTIES('1J5qkX0Gn7D9SDW_FyHeBa',#5,$,$,(#17680,#17672,#17664,#17640,#17632,#17624,#17594,#17586,#17578,#17552,#17543,#17534,#17403,#17395,#17387,#17361,#17352,#17343,#17310,#17302,#17294,#17270,#17262,#17254,#17224,#17216,#17208,#17184,#17176,#17168,#17138,#17130,#17122,#17098,#17090,#17082,#17036,#17028,#17020,#16994,#16985,#16976,#9356,#9348,#9340,#9289,#9272,#9251,#7949,#7936,#7873,#7862,#7458,#7450,#7400,#7391,#6717,#6701,#6644,#6630,#6153,#6137,#6011,#5996,#3812,#3796,#3745,#3731,#3609,#3593,#3541,#3527,#3413,#3398,#3314,#3298,#2409,#2401,#2344,#2330,#2266,#2258,#2204,#2190,#2122,#2114,#2067,#2053,#1948,#1926,#1758,#1696),#1704);
#19251= IFCRELDEFINESBYPROPERTIES('2yshPSQR91NgQ1Ag08quRC',#5,$,$,(#6161,#6145,#6019,#6005,#3419,#3407,#3320,#3308,#1956,#1936,#1766,#1726),#1735);
#19252= IFCRELDEFINESBYPROPERTIES('2GuaA4PeP509e$Py7X_$H0',#5,$,$,(#3751,#3740,#3549,#3536,#3419,#3407,#3320,#3308,#2350,#2339,#2210,#2199,#2073,#2062,#1766,#1726),#1750);
#19253= IFCRELDEFINESBYPROPERTIES('3u_pM3z29BQf2vNGk5OgKn',#5,$,$,(#2339,#2199,#2062,#1726),#1755);
#19254= IFCRELDEFINESBYPROPERTIES('1yBfXyrLf6K8FAcNJMd0ea',#5,$,$,(#2350,#2210,#2073,#1766),#1770);
#19255= IFCRELDEFINESBYPROPERTIES('0ns$0RGzj0ThUW_MaSl2Mc',#5,$,$,(#1964,#1772),#1776);
#19256= IFCRELDEFINESBYPROPERTIES('2Viqq7dAbAggCnY4tIT5ly',#5,$,$,(#17656,#17616,#17570,#17525,#17379,#17334,#17286,#17246,#17200,#17160,#17114,#17074,#17012,#16964,#9329,#9227,#7962,#7883,#7466,#7408,#6730,#6654,#6167,#6026,#3823,#3756,#3621,#3554,#3425,#3325,#2417,#2352,#2274,#2212,#2130,#2075,#1964,#1772),#1778);
#19257= IFCRELDEFINESBYPROPERTIES('1kY90TGUr2RPxGWaIVjWQM',#5,$,$,(#6175,#6035,#3433,#3334,#1973,#1790),#1796);
#19258= IFCRELDEFINESBYPROPERTIES('3_YEdf3bn3Te8ieiUXWd09',#5,$,$,(#2084,#1790),#1805);
#19259= IFCRELDEFINESBYPROPERTIES('1v6IBrVCP0q9kUisXONC06',#5,$,$,(#2084,#1790),#1809);
#19260= IFCRELDEFINESBYPROPERTIES('1oWCsWAiD7KeUyvDK_Y65Q',#5,$,$,(#1986,#1811),#1816);
#19261= IFCRELDEFINESBYPROPERTIES('0HwCIekQL0jPa9Hp7MSzzb',#5,$,$,(#18152,#18146,#18140,#18132,#18098,#18063,#18054,#18046,#18009,#17903,#17867,#17818,#17688,#17648,#17602,#17561,#17411,#17370,#17318,#17278,#17232,#17192,#17146,#17106,#17044,#17003,#9364,#9303,#7976,#7897,#7480,#7420,#7223,#6744,#6668,#6186,#6041,#3841,#3771,#3635,#3569,#3439,#3341,#2428,#2369,#2291,#2230,#2138,#2089,#1986,#1811),#1818);
#19262= IFCRELDEFINESBYPROPERTIES('0Fbkei$D95lBYrItNviafH',#5,$,$,(#6194,#6050,#3447,#3351,#1996,#1833),#1841);
#19263= IFCRELDEFINESBYPROPERTIES('2calubMj11FRqRn4qQTkot',#5,$,$,(#2098,#1833),#1850);
#19264= IFCRELDEFINESBYPROPERTIES('2H6GSloQX9Mf0Lv1vg04KW',#5,$,$,(#2098,#1833),#1854);
#19265= IFCRELDEFINESBYPROPERTIES('12HO$9_jLAahXIPnX1vpD7',#5,$,$,(#6079,#3380,#1899),#1905);
#19266= IFCRELDEFINESBYPROPERTIES('0wbYBNl3XCOQLAO6GFDhxH',#5,$,$,(#2253,#1899),#1918);
#19267= IFCRELDEFINESBYPROPERTIES('0vqnKBMB5DWQsJybKSdFCi',#5,$,$,(#2253,#2108,#1899),#1924);
#19268= IFCRELDEFINESBYPROPERTIES('2xEJ8qVDL2Ch3p33ifFx2f',#5,$,$,(#7871,#7398,#6639,#2407,#2264,#2120,#1936),#1943);
#19269= IFCRELDEFINESBYPROPERTIES('1FUxDXW890IBcfAS3ObSsH',#5,$,$,(#2407,#2264,#2120,#1936),#1946);
#19270= IFCRELDEFINESBYPROPERTIES('3$uzmKHkP9qfRITSYFFrT0',#5,$,$,(#2415,#2272,#2128,#1956),#1958);
#19271= IFCRELDEFINESBYPROPERTIES('2inL$9qWb58eJhlhwaNM4u',#5,$,$,(#2415,#2272,#2128,#1956),#1962);
#19272= IFCRELDEFINESBYPROPERTIES('2$tGSu4Qv1EOejlhshATqk',#5,$,$,(#7892,#7415,#6663,#6035,#3765,#3629,#3433,#2136,#1973),#1980);
#19273= IFCRELDEFINESBYPROPERTIES('0_cJQ4z3HC9hXTnjQwbnLL',#5,$,$,(#2136,#1973),#1984);
#19274= IFCRELDEFINESBYPROPERTIES('0IEM0vKrz3hwgBkurVtQOs',#5,$,$,(#2144,#1996),#2003);
#19275= IFCRELDEFINESBYPROPERTIES('28ln54R8bC98Cp1uA7CCN0',#5,$,$,(#2144,#1996),#2007);
#19276= IFCRELDEFINESBYPROPERTIES('3H0pdZsNH8DQAroAYXpzN5',#5,$,$,(#2023,#2009),#2012);
#19277= IFCRELDEFINESBYPROPERTIES('2VfCp9jAPF8hVoV8lV69sW',#5,$,$,(#2029,#2018),#2021);
#19278= IFCRELDEFINESBYPROPERTIES('0adjuFfOP7iPeIBoYYt_tR',#5,$,$,(#2031),#2034);
#19279= IFCRELDEFINESBYPROPERTIES('33p7fxrWv1kAMYjPDZIj1E',#5,$,$,(#6628,#6619,#3520,#3510,#2051,#2040),#2042);
#19280= IFCRELDEFINESBYPROPERTIES('0m4ATWNWrFfhcxxj0UqAGY',#5,$,$,(#2044),#2045);
#19281= IFCRELDEFINESBYPROPERTIES('30CMDUGg54A9_vVtGJHTFn',#5,$,$,(#2122,#2114,#2067,#2053),#2056);
#19282= IFCRELDEFINESBYPROPERTIES('16kapDS0nBVfArlf9ZfkRF',#5,$,$,(#6725,#6709,#6652,#6639,#3615,#3601,#3549,#3536,#2128,#2120,#2073,#2062),#2065);
#19283= IFCRELDEFINESBYPROPERTIES('3klut05BX8t8XwGG9u4_zN',#5,$,$,(#2130,#2075),#2078);
#19284= IFCRELDEFINESBYPROPERTIES('3CDe3Lq6r8$99a6d2KZrNl',#5,$,$,(#6738,#6663,#3629,#3563,#2136,#2084),#2087);
#19285= IFCRELDEFINESBYPROPERTIES('1iTEPAbfP0wg3VbJ$nd19_',#5,$,$,(#2138,#2089),#2092);
#19286= IFCRELDEFINESBYPROPERTIES('0yOOYaKXj2MRtqV88sbsFf',#5,$,$,(#6752,#6677,#3641,#3576,#2144,#2098),#2101);
#19287= IFCRELDEFINESBYPROPERTIES('0tBiijAtL8s9X8gbUc9brz',#5,$,$,(#6684,#3586,#2108),#2111);
#19288= IFCRELDEFINESBYPROPERTIES('0w_$4ok7T4$vVjFJJ$5OEC',#5,$,$,(#2108),#2112);
#19289= IFCRELDEFINESBYPROPERTIES('2TAA6I2sj7uBTxqu_B_ZKZ',#5,$,$,(#2160,#2146),#2149);
#19290= IFCRELDEFINESBYPROPERTIES('1LUCk32Av2dBcxGzpEHPzJ',#5,$,$,(#2166,#2155),#2158);
#19291= IFCRELDEFINESBYPROPERTIES('0uzye0KnH9nxlWBrNS_tMY',#5,$,$,(#2168),#2171);
#19292= IFCRELDEFINESBYPROPERTIES('1aqxVqITP1Ih1c3afBCnX3',#5,$,$,(#7860,#7851,#3729,#3721,#2188,#2177),#2179);
#19293= IFCRELDEFINESBYPROPERTIES('1B5JgSXXP2yfHGxAP_tQTu',#5,$,$,(#2181),#2182);
#19294= IFCRELDEFINESBYPROPERTIES('2v5fosvtP5eRzvCOklpChk',#5,$,$,(#2266,#2258,#2204,#2190),#2193);
#19295= IFCRELDEFINESBYPROPERTIES('3_GF$LzD9FM88x2l9exA_D',#5,$,$,(#7957,#7944,#7881,#7871,#3818,#3804,#3751,#3740,#2272,#2264,#2210,#2199),#2202);
#19296= IFCRELDEFINESBYPROPERTIES('2y3WC9eYL2MgExiY87QzUn',#5,$,$,(#2274,#2212),#2215);
#19297= IFCRELDEFINESBYPROPERTIES('1YQmKVNkj1AxWnDUe1r9Mu',#5,$,$,(#7970,#7892,#3831,#3765,#2280,#2221),#2224);
#19298= IFCRELDEFINESBYPROPERTIES('36VqLNMePBCPWcRPho_BoT',#5,$,$,(#2361,#2221),#2225);
#19299= IFCRELDEFINESBYPROPERTIES('2jUeJxAeL1vActqCrdKqe$',#5,$,$,(#2221),#2228);
#19300= IFCRELDEFINESBYPROPERTIES('3C8$lkkQ9DPOG09y9SGruy',#5,$,$,(#2291,#2230),#2233);
#19301= IFCRELDEFINESBYPROPERTIES('2bewv3OTjEa8nTBF8sILBW',#5,$,$,(#7984,#7906,#3847,#3778,#2297,#2239),#2242);
#19302= IFCRELDEFINESBYPROPERTIES('2gonYQEOn6hfovSupkgE9F',#5,$,$,(#2378,#2239),#2243);
#19303= IFCRELDEFINESBYPROPERTIES('20Gr4nNcz9her7$mzN7GBg',#5,$,$,(#2239),#2246);
#19304= IFCRELDEFINESBYPROPERTIES('21NNP_3D19xQvjPJNI7iYZ',#5,$,$,(#7916,#3789,#2253),#2256);
#19305= IFCRELDEFINESBYPROPERTIES('0bcF7XEE902xPQttlM$0MD',#5,$,$,(#2423,#2280),#2286);
#19306= IFCRELDEFINESBYPROPERTIES('2sagXJyivEyRbUPqKMYSqO',#5,$,$,(#2280),#2289);
#19307= IFCRELDEFINESBYPROPERTIES('1yngIk9gP4jh_7GOaj0Ikl',#5,$,$,(#2434,#2297),#2303);
#19308= IFCRELDEFINESBYPROPERTIES('0J$hjaJpb3HeRe5XMB8mjR',#5,$,$,(#2297),#2306);
#19309= IFCRELDEFINESBYPROPERTIES('1Eox9LquPDDvuQ6a8JNgjn',#5,$,$,(#2308),#2311);
#19310= IFCRELDEFINESBYPROPERTIES('125iQyEyn0iB75D1T61CqL',#5,$,$,(#7389,#7380,#2328,#2317),#2319);
#19311= IFCRELDEFINESBYPROPERTIES('0ZGhck0Qz3WwYiQWKMv2nF',#5,$,$,(#2321),#2322);
#19312= IFCRELDEFINESBYPROPERTIES('0_crC2bCr0svbYFCqgF6jo',#5,$,$,(#2409,#2401,#2344,#2330),#2333);
#19313= IFCRELDEFINESBYPROPERTIES('2MbgtdE519NfsbIpwfX1nC',#5,$,$,(#7464,#7456,#7406,#7398,#2415,#2407,#2350,#2339),#2342);
#19314= IFCRELDEFINESBYPROPERTIES('1l4a6atrH1h83PkrZT7uT0',#5,$,$,(#2417,#2352),#2355);
#19315= IFCRELDEFINESBYPROPERTIES('2hrixOO5v4a9Yn9cUJeWqI',#5,$,$,(#7472,#7415,#2423,#2361),#2364);
#19316= IFCRELDEFINESBYPROPERTIES('203eErF0v4OfeSYRrDdpwG',#5,$,$,(#2361),#2367);
#19317= IFCRELDEFINESBYPROPERTIES('3GixPCLNf9DuHdBY4E0d7f',#5,$,$,(#2428,#2369),#2372);
#19318= IFCRELDEFINESBYPROPERTIES('2j8roGtL5569euj2NXZgDy',#5,$,$,(#7486,#7427,#2434,#2378),#2381);
#19319= IFCRELDEFINESBYPROPERTIES('085w5L0wDAjhw0LruqWrir',#5,$,$,(#2378),#2384);
#19320= IFCRELDEFINESBYPROPERTIES('248_rqETX84BXhyp0GSg$4',#5,$,$,(#7437,#2391),#2394);
#19321= IFCRELDEFINESBYPROPERTIES('2$78tKt$nClRhpkthD06uV',#5,$,$,(#2391),#2396);
#19322= IFCRELDEFINESBYPROPERTIES('16bXu$P5v2QA_MFGNubtmz',#5,$,$,(#2391),#2399);
#19323= IFCRELDEFINESBYPROPERTIES('3OueRf7QX62wT8K5QJN1WA',#5,$,$,(#2423),#2426);
#19324= IFCRELDEFINESBYPROPERTIES('0WMUgQrYDF2gcWvFj8dZzi',#5,$,$,(#2434),#2437);
#19325= IFCRELDEFINESBYPROPERTIES('22qIui2Az0OQIWbOOqVFQ5',#5,$,$,(#2805,#2763,#2673,#2631,#2537,#2492),#2495);
#19326= IFCRELDEFINESBYPROPERTIES('3HrhJPIzTEL87dg$7wOM5p',#5,$,$,(#2855),#2858);
#19327= IFCRELDEFINESBYPROPERTIES('36Io9DSjr8Oee$LTKfdD19',#5,$,$,(#2870),#2872);
#19328= IFCRELDEFINESBYPROPERTIES('0ecGdZLBP7n93G5uoo5lJT',#5,$,$,(#3089,#3021,#2870),#2886);
#19329= IFCRELDEFINESBYPROPERTIES('2vXgQnuBj3sxpWbuKAMMUm',#5,$,$,(#3089,#3021,#2870),#2892);
#19330= IFCRELDEFINESBYPROPERTIES('2u$bpKJhfE9Rp25zhMi8Ee',#5,$,$,(#3096,#3028,#2898),#2905);
#19331= IFCRELDEFINESBYPROPERTIES('3iyQ42wjD5_gf8uFm4HHhB',#5,$,$,(#3096,#3028,#2898),#2910);
#19332= IFCRELDEFINESBYPROPERTIES('2iw1KQrFTA7B20$_D3e_Md',#5,$,$,(#3102,#3034,#2922),#2934);
#19333= IFCRELDEFINESBYPROPERTIES('2SywYbJbb6ev_Rp9lCCQ2H',#5,$,$,(#3034,#2922),#2939);
#19334= IFCRELDEFINESBYPROPERTIES('2AetzzbvTEzhxNBDgb77Z0',#5,$,$,(#3110,#3040,#2945),#2957);
#19335= IFCRELDEFINESBYPROPERTIES('1aGMjtS4v4zODbPVPEgOyf',#5,$,$,(#3040,#2945),#2962);
#19336= IFCRELDEFINESBYPROPERTIES('1E8I_qha5Ct8DJyl7p0c4u',#5,$,$,(#3076,#2999),#3007);
#19337= IFCRELDEFINESBYPROPERTIES('1FuonKtvXEmfwJORVyoGww',#5,$,$,(#2999),#3012);
#19338= IFCRELDEFINESBYPROPERTIES('2shFxV3l1AzA$$twWhA4mx',#5,$,$,(#3014),#3015);
#19339= IFCRELDEFINESBYPROPERTIES('2IiWQiJn9E6OIXM3xTIGwh',#5,$,$,(#3021),#3022);
#19340= IFCRELDEFINESBYPROPERTIES('22lKTJidT59w3uejXGcY_3',#5,$,$,(#3076),#3080);
#19341= IFCRELDEFINESBYPROPERTIES('0J2l3Jvoz1qBgNW4Ta9xRt',#5,$,$,(#3082),#3083);
#19342= IFCRELDEFINESBYPROPERTIES('3at1aokA1EyBwqgTpBg0Xo',#5,$,$,(#3089),#3090);
#19343= IFCRELDEFINESBYPROPERTIES('0fX2qL$2PAyAz$yYEUAOdL',#5,$,$,(#3102),#3104);
#19344= IFCRELDEFINESBYPROPERTIES('17bHqcKF55YvTfM2$bFZ3D',#5,$,$,(#3110),#3112);
#19345= IFCRELDEFINESBYPROPERTIES('0Z4F3RuGH0KOnuPNdc3TjD',#5,$,$,(#3146),#3148);
#19346= IFCRELDEFINESBYPROPERTIES('3DDlwjAgD1v9SiWmYHiiA3',#5,$,$,(#3146),#3152);
#19347= IFCRELDEFINESBYPROPERTIES('1BqSow7hX5xAOso2kLLPvi',#5,$,$,(#3170,#3154),#3155);
#19348= IFCRELDEFINESBYPROPERTIES('00TD0WLbnDwBvL5eHxvCXF',#5,$,$,(#3176,#3161),#3162);
#19349= IFCRELDEFINESBYPROPERTIES('0D8Y2q7d17Fh0eZphWMQld',#5,$,$,(#3659,#3650,#3473,#3464,#3176,#3161),#3164);
#19350= IFCRELDEFINESBYPROPERTIES('2o2gAY19X6V8wCf_DeFTLa',#5,$,$,(#3650,#3464,#3161),#3168);
#19351= IFCRELDEFINESBYPROPERTIES('3gKkuoTYH0qw05hqIG9BFq',#5,$,$,(#3659,#3473,#3176),#3180);
#19352= IFCRELDEFINESBYPROPERTIES('24XaJK8FfAxf6bR2pXmyvy',#5,$,$,(#3248,#3232,#3182),#3188);
#19353= IFCRELDEFINESBYPROPERTIES('0fpUtfIC16KAdeZwqjGi4n',#5,$,$,(#3661,#3475,#3182),#3190);
#19354= IFCRELDEFINESBYPROPERTIES('0rCTJdHbXA1fGZFLnOiUsP',#5,$,$,(#3254,#3240,#3205),#3209);
#19355= IFCRELDEFINESBYPROPERTIES('3IaQuSsZH7nxN9xSDPv3AA',#5,$,$,(#3484,#3205),#3224);
#19356= IFCRELDEFINESBYPROPERTIES('1lt6Tgepz4m8N411F5d8js',#5,$,$,(#3484,#3205),#3230);
#19357= IFCRELDEFINESBYPROPERTIES('3s91dS3KH3QA4IoOXOVrNH',#5,$,$,(#3702,#3683,#3495,#3487,#3248,#3232),#3234);
#19358= IFCRELDEFINESBYPROPERTIES('03vW2D_Vf1HhjFcqQThoTF',#5,$,$,(#3493,#3240),#3243);
#19359= IFCRELDEFINESBYPROPERTIES('0tZ5EGITz1BhmBhhunSXL3',#5,$,$,(#3493,#3240),#3246);
#19360= IFCRELDEFINESBYPROPERTIES('0pYJvAewP0BR9EEzDA3Q1d',#5,$,$,(#3501,#3254),#3256);
#19361= IFCRELDEFINESBYPROPERTIES('0r1BClATv0BfmiuhjWDp$N',#5,$,$,(#3501,#3254),#3260);
#19362= IFCRELDEFINESBYPROPERTIES('02Ioq6NCP9jhlu_V39Ev5N',#5,$,$,(#3280,#3262),#3263);
#19363= IFCRELDEFINESBYPROPERTIES('1wq2Xg8c9C89eK_H0q84z_',#5,$,$,(#3714,#3503,#3262),#3265);
#19364= IFCRELDEFINESBYPROPERTIES('3Av9ExRcLFrRN3phEbLvQ1',#5,$,$,(#3721,#3510,#3273),#3278);
#19365= IFCRELDEFINESBYPROPERTIES('0fIX$E7Lv9TPTKvAmlv31N',#5,$,$,(#3723,#3512,#3280),#3282);
#19366= IFCRELDEFINESBYPROPERTIES('272LkvQE51MP0Ed50rAyP9',#5,$,$,(#3729,#3520,#3290),#3291);
#19367= IFCRELDEFINESBYPROPERTIES('0R7mCNKtr8S89lPPlUKIOX',#5,$,$,(#3290),#3296);
#19368= IFCRELDEFINESBYPROPERTIES('1lXcNaz3j1XxhvKGTR1wB_',#5,$,$,(#3413,#3398,#3314,#3298),#3299);
#19369= IFCRELDEFINESBYPROPERTIES('24vVD1cnT0VPJfXH5gxnPP',#5,$,$,(#3308),#3312);
#19370= IFCRELDEFINESBYPROPERTIES('0PeGuTWuL1d8dtHLGwJuMo',#5,$,$,(#3320),#3323);
#19371= IFCRELDEFINESBYPROPERTIES('2HLjKRKJD9hRZKP$lrZ5Yw',#5,$,$,(#3425,#3325),#3326);
#19372= IFCRELDEFINESBYPROPERTIES('1U_3x9Dzv8oucYfnEE$KGm',#5,$,$,(#3334),#3335);
#19373= IFCRELDEFINESBYPROPERTIES('1ejKJMTD12chMnsHasltQM',#5,$,$,(#3334),#3339);
#19374= IFCRELDEFINESBYPROPERTIES('25bWVLF4D1ZwioDkeaXkDy',#5,$,$,(#3439,#3341),#3343);
#19375= IFCRELDEFINESBYPROPERTIES('0c3QmR7Cr1UPv61i$bzRyo',#5,$,$,(#3576,#3351),#3353);
#19376= IFCRELDEFINESBYPROPERTIES('2osy6RDTf7RvMI2bXdP8Ct',#5,$,$,(#3351),#3357);
#19377= IFCRELDEFINESBYPROPERTIES('1SuVg7Yxb0s8nwXiy4yN6d',#5,$,$,(#3789,#3586,#3380),#3390);
#19378= IFCRELDEFINESBYPROPERTIES('0cMVqLFOT3pBWDWtiiZ8Tr',#5,$,$,(#3380),#3396);
#19379= IFCRELDEFINESBYPROPERTIES('3x4u05uuzEiggtpj2BvNBe',#5,$,$,(#3407),#3411);
#19380= IFCRELDEFINESBYPROPERTIES('2awefpI0v5FhBRNraxnb4R',#5,$,$,(#3419),#3423);
#19381= IFCRELDEFINESBYPROPERTIES('2Y88Nx_a16nvtuEDH_T1Nj',#5,$,$,(#3433),#3437);
#19382= IFCRELDEFINESBYPROPERTIES('0zR17CqWr5b8rk4Duu6v9_',#5,$,$,(#3641,#3447),#3451);
#19383= IFCRELDEFINESBYPROPERTIES('0fAFWbDrz2mA6xlJ1Zakoh',#5,$,$,(#3641,#3447),#3455);
#19384= IFCRELDEFINESBYPROPERTIES('0Jx4SJ5pr8duF0XJ7UvSBe',#5,$,$,(#3467,#3457),#3458);
#19385= IFCRELDEFINESBYPROPERTIES('1verbAFaL55PG5KK54HBmr',#5,$,$,(#3473,#3464),#3465);
#19386= IFCRELDEFINESBYPROPERTIES('0Cu2jtblX3NxAZQjInxL4Y',#5,$,$,(#3495,#3487,#3475),#3478);
#19387= IFCRELDEFINESBYPROPERTIES('2nsFP2HcPFQ9s0BMai4OM8',#5,$,$,(#3501,#3493,#3484),#3485);
#19388= IFCRELDEFINESBYPROPERTIES('3C516S1cT9$BRYb0br$Yng',#5,$,$,(#3512,#3503),#3504);
#19389= IFCRELDEFINESBYPROPERTIES('2YWR72AOT9JunBCb2X5O5r',#5,$,$,(#3729,#3520),#3525);
#19390= IFCRELDEFINESBYPROPERTIES('3FkfuVZGL8Lwv53bNlP1up',#5,$,$,(#3609,#3593,#3541,#3527),#3528);
#19391= IFCRELDEFINESBYPROPERTIES('2XIOo6_C5C1hiaoLxcG$$f',#5,$,$,(#3536),#3539);
#19392= IFCRELDEFINESBYPROPERTIES('2TlkKCIwL7HwgHaRHVHye$',#5,$,$,(#3549),#3552);
#19393= IFCRELDEFINESBYPROPERTIES('1hqwW8Zb9B_v6Mr9fzMrNP',#5,$,$,(#3621,#3554),#3555);
#19394= IFCRELDEFINESBYPROPERTIES('3l9dTE$cr6O97dMuQV5mFn',#5,$,$,(#3563),#3564);
#19395= IFCRELDEFINESBYPROPERTIES('2f0bRKlFb4lALlrl44McuH',#5,$,$,(#3563),#3567);
#19396= IFCRELDEFINESBYPROPERTIES('2N5BkXflvDXfxop1Nzo42y',#5,$,$,(#3635,#3569),#3570);
#19397= IFCRELDEFINESBYPROPERTIES('1Ue3JpeVb4XP_uNE5Fqmla',#5,$,$,(#3576),#3579);
#19398= IFCRELDEFINESBYPROPERTIES('317JOIZNb31eIbjXPxq3c4',#5,$,$,(#3586),#3591);
#19399= IFCRELDEFINESBYPROPERTIES('0mcJs0aEDB68HWzeNujvNv',#5,$,$,(#3818,#3601),#3603);
#19400= IFCRELDEFINESBYPROPERTIES('3ssX6Vi4n4Lv3Sf4STRI27',#5,$,$,(#3601),#3607);
#19401= IFCRELDEFINESBYPROPERTIES('0_BVzp5mPB9Bcc3jU3cUJi',#5,$,$,(#3615),#3616);
#19402= IFCRELDEFINESBYPROPERTIES('19MBCPnsf7E8LYwb977i2T',#5,$,$,(#3615),#3619);
#19403= IFCRELDEFINESBYPROPERTIES('2tSsB4rYzCmuVQxWzSMPPp',#5,$,$,(#3629),#3633);
#19404= IFCRELDEFINESBYPROPERTIES('1gztSMrQnD_fIkJsXTNHq5',#5,$,$,(#3653,#3643),#3644);
#19405= IFCRELDEFINESBYPROPERTIES('23Irh1s7v1DwNsDu217TSD',#5,$,$,(#3659,#3650),#3651);
#19406= IFCRELDEFINESBYPROPERTIES('13IJZIipn1fxA5$ZFgEReC',#5,$,$,(#3702,#3683,#3661),#3664);
#19407= IFCRELDEFINESBYPROPERTIES('3vj7Q$n011KAr_daG_J6A$',#5,$,$,(#3708,#3689,#3670),#3671);
#19408= IFCRELDEFINESBYPROPERTIES('1xq4Pk7Qn7QumRJPTfpg7h',#5,$,$,(#3670),#3675);
#19409= IFCRELDEFINESBYPROPERTIES('3aH6jCwsj4vhndS8snJhxZ',#5,$,$,(#3670),#3681);
#19410= IFCRELDEFINESBYPROPERTIES('3aMwysGb5ALwU9W12v3X5e',#5,$,$,(#3689),#3694);
#19411= IFCRELDEFINESBYPROPERTIES('1D$bbTrQ98lf1aqtvnz_LQ',#5,$,$,(#3689),#3700);
#19412= IFCRELDEFINESBYPROPERTIES('3meHOxhG18aRb1K$jCzuM6',#5,$,$,(#3708),#3709);
#19413= IFCRELDEFINESBYPROPERTIES('1gLPRDRk90H85B7fUr1FVe',#5,$,$,(#3708),#3712);
#19414= IFCRELDEFINESBYPROPERTIES('1vX1c7pLHE39GeVLo1J3Wv',#5,$,$,(#3723,#3714),#3715);
#19415= IFCRELDEFINESBYPROPERTIES('1WWBB2yDb3Eg5$Ervpd5Z9',#5,$,$,(#3812,#3796,#3745,#3731),#3732);
#19416= IFCRELDEFINESBYPROPERTIES('1GcW10J_r5Zh0K7OrWo$q4',#5,$,$,(#3740),#3743);
#19417= IFCRELDEFINESBYPROPERTIES('3JmAH5yHn8XBrk0qBaSXLU',#5,$,$,(#3751),#3754);
#19418= IFCRELDEFINESBYPROPERTIES('2jEaYbTDLF5wDZLqbfsjOm',#5,$,$,(#3823,#3756),#3757);
#19419= IFCRELDEFINESBYPROPERTIES('3lkxRXyK91LBDa7awbgeYC',#5,$,$,(#3765),#3769);
#19420= IFCRELDEFINESBYPROPERTIES('2bR6bLPjP4ePgkPQOSc7KS',#5,$,$,(#3841,#3771),#3772);
#19421= IFCRELDEFINESBYPROPERTIES('1jrgDrxufD8wnt200gZnEP',#5,$,$,(#3778),#3779);
#19422= IFCRELDEFINESBYPROPERTIES('0SatokwnPBiuVAsvafX4DT',#5,$,$,(#3778),#3782);
#19423= IFCRELDEFINESBYPROPERTIES('2$5NcdQujFiwOO3uERiyBo',#5,$,$,(#3789),#3794);
#19424= IFCRELDEFINESBYPROPERTIES('1WYfRBcijCDPDfIMljA62G',#5,$,$,(#3804),#3806);
#19425= IFCRELDEFINESBYPROPERTIES('2NChZfP7b4vuAPHtS4TU2s',#5,$,$,(#3804),#3810);
#19426= IFCRELDEFINESBYPROPERTIES('1TUgjwqwb5u86zZVImuDQr',#5,$,$,(#3818),#3821);
#19427= IFCRELDEFINESBYPROPERTIES('2atEfBd01CHuHA3ng4EiyT',#5,$,$,(#3831),#3835);
#19428= IFCRELDEFINESBYPROPERTIES('2jdQus2XnElB8QS1IFIGfw',#5,$,$,(#3831),#3839);
#19429= IFCRELDEFINESBYPROPERTIES('0l5FTrwT9DGQSt9j129IpA',#5,$,$,(#3847),#3851);
#19430= IFCRELDEFINESBYPROPERTIES('3jMG$WPBz56veV4l5a60z4',#5,$,$,(#3847),#3854);
#19431= IFCRELDEFINESBYPROPERTIES('3cOUTTnV5EbB9epRe4fkyE',#5,$,$,(#14618,#14562,#14007,#13951,#13895,#13839,#13783,#11310,#11123,#10739,#3911),#3919);
#19432= IFCRELDEFINESBYPROPERTIES('10MIv9gh58P9a73YDNiXRx',#5,$,$,(#3921),#3928);
#19433= IFCRELDEFINESBYPROPERTIES('3KTXp$E496AOmTj7SL147Q',#5,$,$,(#3921),#3930);
#19434= IFCRELDEFINESBYPROPERTIES('25tit6cGr9Qfp7mzz3ufq_',#5,$,$,(#3947),#3952);
#19435= IFCRELDEFINESBYPROPERTIES('2q4$PcmkbDfQap8cOO8Voc',#5,$,$,(#3947),#3967);
#19436= IFCRELDEFINESBYPROPERTIES('1ZnS1pBtX0Ef2YEryaUG56',#5,$,$,(#3947),#3974);
#19437= IFCRELDEFINESBYPROPERTIES('0VI0QtMNL0dudUbXu7WoxH',#5,$,$,(#3990),#3995);
#19438= IFCRELDEFINESBYPROPERTIES('3FKdYto9v5uen_uPKQV0Oo',#5,$,$,(#3990),#4009);
#19439= IFCRELDEFINESBYPROPERTIES('0OWKKMy8H7YQ0jCK3Ouczd',#5,$,$,(#3990),#4015);
#19440= IFCRELDEFINESBYPROPERTIES('1pVFWvE6z4APgxW5jUPsgC',#5,$,$,(#4017),#4022);
#19441= IFCRELDEFINESBYPROPERTIES('1eosW8J_146P3MgFUZL8ID',#5,$,$,(#4017),#4024);
#19442= IFCRELDEFINESBYPROPERTIES('2Bv_sgrP59luJSVgPAqFiR',#5,$,$,(#4040),#4049);
#19443= IFCRELDEFINESBYPROPERTIES('2kAu5$o$b4i8TLC6pCl$bz',#5,$,$,(#4040),#4063);
#19444= IFCRELDEFINESBYPROPERTIES('1r5sJ4K9PBluQJc5DQWp$S',#5,$,$,(#4040),#4068);
#19445= IFCRELDEFINESBYPROPERTIES('1Yh$KOlZLCAwli1mbbkKz7',#5,$,$,(#4085),#4091);
#19446= IFCRELDEFINESBYPROPERTIES('38CH4q4_f9J801LkdMp2Cf',#5,$,$,(#4085),#4104);
#19447= IFCRELDEFINESBYPROPERTIES('2fNKuRKlPAe8cTVtWAjORL',#5,$,$,(#4085),#4109);
#19448= IFCRELDEFINESBYPROPERTIES('0RpvvobFj5UAFzyjkyCJYk',#5,$,$,(#4178),#4186);
#19449= IFCRELDEFINESBYPROPERTIES('3tM9X8vZr0wvZauoN4_Ikq',#5,$,$,(#4178),#4200);
#19450= IFCRELDEFINESBYPROPERTIES('19oNiHk$X1huuhx8AumDau',#5,$,$,(#4178),#4205);
#19451= IFCRELDEFINESBYPROPERTIES('3A3gXa30H5EAajXmAN$lmA',#5,$,$,(#4207),#4210);
#19452= IFCRELDEFINESBYPROPERTIES('2r28DeUdj2KAJpKVbRFad_',#5,$,$,(#13578,#13572,#13554,#13523,#13390,#13234,#12741,#4303,#4224),#4227);
#19453= IFCRELDEFINESBYPROPERTIES('2XiLmdMH564AEFRFZjY1HA',#5,$,$,(#4224),#4241);
#19454= IFCRELDEFINESBYPROPERTIES('2OclbSTqbCowFcfvoXuQRt',#5,$,$,(#4224),#4247);
#19455= IFCRELDEFINESBYPROPERTIES('1HgCB$xzT0V8wtoOBLa_JW',#5,$,$,(#4249),#4252);
#19456= IFCRELDEFINESBYPROPERTIES('17xjwmbTzD9RLSrPphVduC',#5,$,$,(#4267),#4269);
#19457= IFCRELDEFINESBYPROPERTIES('1y_emcamj0kAWKyW1ZKul0',#5,$,$,(#4296,#4267),#4282);
#19458= IFCRELDEFINESBYPROPERTIES('1xodH_v3D1dOliHF74uUPZ',#5,$,$,(#4303,#4296,#4267),#4287);
#19459= IFCRELDEFINESBYPROPERTIES('0PVET04YXCbADzkKTZfdjC',#5,$,$,(#4289),#4290);
#19460= IFCRELDEFINESBYPROPERTIES('02K1dF9YPEGuJdW2K1teHx',#5,$,$,(#4296),#4297);
#19461= IFCRELDEFINESBYPROPERTIES('29SruZlZP8kuiqjIb$JITw',#5,$,$,(#4303),#4304);
#19462= IFCRELDEFINESBYPROPERTIES('26Pxr9MZr8oQ_erMm7DS3k',#5,$,$,(#4327,#4306),#4311);
#19463= IFCRELDEFINESBYPROPERTIES('0n$EAxun19XhQmOuaSaAlo',#5,$,$,(#4333,#4317),#4318);
#19464= IFCRELDEFINESBYPROPERTIES('0XTT0Rhsn8WfPLD1moaV$$',#5,$,$,(#4333,#4317),#4321);
#19465= IFCRELDEFINESBYPROPERTIES('1t9fCAi759Gu3BXJAXgpwA',#5,$,$,(#4333,#4317),#4325);
#19466= IFCRELDEFINESBYPROPERTIES('0B6tEnIsX0$vmBt3q1JSxp',#5,$,$,(#4406),#4415);
#19467= IFCRELDEFINESBYPROPERTIES('1cyXHONYfAl81hUVVJ1ONN',#5,$,$,(#11952,#4432),#4439);
#19468= IFCRELDEFINESBYPROPERTIES('1h2nHZLRzFR94vWNQYT5v6',#5,$,$,(#4432),#4453);
#19469= IFCRELDEFINESBYPROPERTIES('2s21N_8Sr4HhTZH$pMd6tj',#5,$,$,(#4432),#4460);
#19470= IFCRELDEFINESBYPROPERTIES('3hUKYKw4r279U4Vblyj1vH',#5,$,$,(#4462),#4467);
#19471= IFCRELDEFINESBYPROPERTIES('1oHbglC8H6eBTJr_UtFDnr',#5,$,$,(#5747,#4462),#4469);
#19472= IFCRELDEFINESBYPROPERTIES('0_IJEb7MjD0xP2HUG1ZTGB',#5,$,$,(#4519),#4526);
#19473= IFCRELDEFINESBYPROPERTIES('2cNQI57SnBQQPbVKQvK$AQ',#5,$,$,(#4519),#4541);
#19474= IFCRELDEFINESBYPROPERTIES('18Fv33XH15nO_OQ3or$hg7',#5,$,$,(#4519),#4546);
#19475= IFCRELDEFINESBYPROPERTIES('2hRKbWYFrEkvtCW6_Mmsqs',#5,$,$,(#10586,#10574,#10562,#10543,#4548),#4552);
#19476= IFCRELDEFINESBYPROPERTIES('2EDahMyCbDMxBWKljO9CFp',#5,$,$,(#10611,#10598,#10586,#10574,#10562,#10543,#4548),#4554);
#19477= IFCRELDEFINESBYPROPERTIES('28J$UiOtTCwPySZAYM8A5r',#5,$,$,(#10621,#10609,#10596,#10584,#10572,#10553,#9213,#4606),#4614);
#19478= IFCRELDEFINESBYPROPERTIES('1NzZyKmeb38BG5Txp7TqYi',#5,$,$,(#4606),#4624);
#19479= IFCRELDEFINESBYPROPERTIES('3KkIAc4Mz7nhDR0YaHGBT0',#5,$,$,(#4606),#4631);
#19480= IFCRELDEFINESBYPROPERTIES('1__vGZxOzDSw0CL5L6DMWN',#5,$,$,(#8065,#7626,#7135,#6386,#6302,#5013,#4741,#4705),#4711);
#19481= IFCRELDEFINESBYPROPERTIES('02V8ywyQT0lhjhKSfhBE4G',#5,$,$,(#14918,#14888,#14858,#14828,#14798,#14768,#14738,#14708,#14678,#14648,#14506,#14476,#14261,#14197,#14167,#12663,#12633,#12603,#12573,#12474,#12444,#12414,#12384,#12319,#12289,#12259,#12229,#11711,#11681,#11651,#11621,#11591,#11561,#11531,#10495,#10465,#10435,#10405,#10375,#10345,#10204,#10174,#10144,#10114,#10084,#9776,#7003,#6973,#6943,#6913,#6883,#6853,#5745,#5193,#5163,#5133,#5103,#5073,#5043,#4917,#4887,#4857,#4827,#4791),#4797);
#19482= IFCRELDEFINESBYPROPERTIES('3Voxs7Enf3EPjIdToeAssw',#5,$,$,(#4930),#4933);
#19483= IFCRELDEFINESBYPROPERTIES('3D1x$BzDHBS8PVcnQwK1Pj',#5,$,$,(#11943,#4930),#4947);
#19484= IFCRELDEFINESBYPROPERTIES('2bd6_wDozFSOzuHQcA9or1',#5,$,$,(#11943,#4930),#4952);
#19485= IFCRELDEFINESBYPROPERTIES('2bjW7SCY53buygQ40gRPj4',#5,$,$,(#7680,#7105,#6356,#4982),#4983);
#19486= IFCRELDEFINESBYPROPERTIES('05CvGnEGX5KeO9Ejwld_9B',#5,$,$,(#5195),#5199);
#19487= IFCRELDEFINESBYPROPERTIES('1O_AGpjmP9JAU8v6hgNbYH',#5,$,$,(#5527,#5415,#5345,#5217),#5220);
#19488= IFCRELDEFINESBYPROPERTIES('3fhZO9c69CWB4Aj0XZegD_',#5,$,$,(#6425,#6395,#5345,#5217),#5231);
#19489= IFCRELDEFINESBYPROPERTIES('3Mx7DjlVDDcAr_T_kvWB1H',#5,$,$,(#6425,#6395,#5345,#5217),#5237);
#19490= IFCRELDEFINESBYPROPERTIES('2l_YYqgcv6zfp$g1m7D_2G',#5,$,$,(#5446,#5433,#5288,#5253),#5258);
#19491= IFCRELDEFINESBYPROPERTIES('0exDciJKrAGPEBePySXRt2',#5,$,$,(#6402,#5253),#5271);
#19492= IFCRELDEFINESBYPROPERTIES('24x74kJB57ww6Sc6HggvPh',#5,$,$,(#7705,#7160,#6402,#5253),#5276);
#19493= IFCRELDEFINESBYPROPERTIES('2Zz41SLT92gO7LgWWlMIQ9',#5,$,$,(#6410,#5288),#5299);
#19494= IFCRELDEFINESBYPROPERTIES('0vJc3wyLD5ufZoRKaEXg9r',#5,$,$,(#7714,#7169,#6410,#5288),#5304);
#19495= IFCRELDEFINESBYPROPERTIES('267Qdqwzb6LwZqiq5$ufGj',#5,$,$,(#5460,#5317),#5320);
#19496= IFCRELDEFINESBYPROPERTIES('1$zUNjsxv0bunhbUod7tqB',#5,$,$,(#6416,#5317),#5333);
#19497= IFCRELDEFINESBYPROPERTIES('1JSjopQxf7XwyoQvsvMpH6',#5,$,$,(#7721,#7176,#6416,#5317),#5339);
#19498= IFCRELDEFINESBYPROPERTIES('3aNjaK0NXD2QxJmbwSlwXJ',#5,$,$,(#5409,#5352),#5353);
#19499= IFCRELDEFINESBYPROPERTIES('31HUPtoRP6QvIFxUdq3xn9',#5,$,$,(#6485,#6431,#5409,#5352),#5355);
#19500= IFCRELDEFINESBYPROPERTIES('032Ya0PBz3qOmnly7zHX8O',#5,$,$,(#6485,#6431,#5409,#5352),#5359);
#19501= IFCRELDEFINESBYPROPERTIES('1kdjRffTn6zABlvkW8eKO5',#5,$,$,(#5383,#5368),#5369);
#19502= IFCRELDEFINESBYPROPERTIES('0THTVr6xb15QROwAHiqL6n',#5,$,$,(#6438,#5368),#5370);
#19503= IFCRELDEFINESBYPROPERTIES('3z52LYBT90fx_DbPS6kd_0',#5,$,$,(#7751,#7217,#6438,#5368),#5375);
#19504= IFCRELDEFINESBYPROPERTIES('0jQ_hQeW91NgO5PVBs3zhd',#5,$,$,(#6445,#5383),#5386);
#19505= IFCRELDEFINESBYPROPERTIES('0B5y5q03P1Yv2rSxydAIHd',#5,$,$,(#7759,#7231,#6445,#5383),#5389);
#19506= IFCRELDEFINESBYPROPERTIES('3bUpwE2sr0CPcg0CeLl3Y$',#5,$,$,(#5395),#5396);
#19507= IFCRELDEFINESBYPROPERTIES('3j0u16gN9CJBhVkApSdPtW',#5,$,$,(#6451,#5395),#5397);
#19508= IFCRELDEFINESBYPROPERTIES('2JQkeuo1j0ABSd79uJlDYl',#5,$,$,(#7766,#7244,#6451,#5395),#5403);
#19509= IFCRELDEFINESBYPROPERTIES('3$csxZoof5B9HSHtOvlcDH',#5,$,$,(#6573,#6519,#5527,#5415),#5419);
#19510= IFCRELDEFINESBYPROPERTIES('0cdJPd6Uz0Zuth$fBJaABA',#5,$,$,(#6573,#6519,#5527,#5415),#5425);
#19511= IFCRELDEFINESBYPROPERTIES('0rWBG45J5CrwSZOsu2MQx9',#5,$,$,(#6525,#5433),#5435);
#19512= IFCRELDEFINESBYPROPERTIES('27MPLXGIL2YezAWgq6KpJO',#5,$,$,(#8020,#7350,#6525,#5433),#5440);
#19513= IFCRELDEFINESBYPROPERTIES('2_8fETLUz2YP0u4pcl_0bi',#5,$,$,(#6531,#5446),#5451);
#19514= IFCRELDEFINESBYPROPERTIES('2z8wM7njT2IgHXeRpYUZsn',#5,$,$,(#8027,#7357,#6531,#5446),#5454);
#19515= IFCRELDEFINESBYPROPERTIES('0ZyDjZ2kjA2BcO9E9Sguhm',#5,$,$,(#6537,#5460),#5464);
#19516= IFCRELDEFINESBYPROPERTIES('1vw2c2OVvEH9CrnF1SDjiZ',#5,$,$,(#8034,#7364,#6537,#5460),#5467);
#19517= IFCRELDEFINESBYPROPERTIES('3iJPiOKzHCNPGwLhhKiEOG',#5,$,$,(#6567,#6561,#6555,#6549,#6543,#5521,#5515,#5509,#5503,#5481),#5491);
#19518= IFCRELDEFINESBYPROPERTIES('10VE3BSuP0rgxOsceLMa25',#5,$,$,(#6567,#6561,#6555,#6549,#6543,#5521,#5515,#5509,#5503,#5481),#5497);
#19519= IFCRELDEFINESBYPROPERTIES('3EmRgsgpT2ivKZQ$K6fWxn',#5,$,$,(#5609,#5603,#5597,#5591,#5571,#5541),#5542);
#19520= IFCRELDEFINESBYPROPERTIES('0PE9ZZPPjFqBFM3G_B_mqR',#5,$,$,(#6610,#6579,#5609,#5541),#5551);
#19521= IFCRELDEFINESBYPROPERTIES('0ZzysXw59FCxKoOwEpzd3K',#5,$,$,(#6610,#6579,#5609,#5541),#5557);
#19522= IFCRELDEFINESBYPROPERTIES('0$$qCspTfA8w_$pjf8nSsI',#5,$,$,(#6604,#6598,#6592,#6586,#5603,#5597,#5591,#5571),#5579);
#19523= IFCRELDEFINESBYPROPERTIES('0E4LOTwJL3xxjrT0MyVDgU',#5,$,$,(#6604,#6598,#6592,#6586,#5603,#5597,#5591,#5571),#5585);
#19524= IFCRELDEFINESBYPROPERTIES('2MqylGmVH0qOVJDdcb10p6',#5,$,$,(#5640),#5645);
#19525= IFCRELDEFINESBYPROPERTIES('0ljIHaFWX9Egxdz$B0qz60',#5,$,$,(#12675,#5640),#5659);
#19526= IFCRELDEFINESBYPROPERTIES('1Gk3qPEfL6z8s_$xjmkwue',#5,$,$,(#12675,#5640),#5664);
#19527= IFCRELDEFINESBYPROPERTIES('3Nmhjg4E52JuaP8WAXlPGZ',#5,$,$,(#5674),#5676);
#19528= IFCRELDEFINESBYPROPERTIES('1Qc0EzMUD9we8nwHdOL9MQ',#5,$,$,(#17522,#5674),#5688);
#19529= IFCRELDEFINESBYPROPERTIES('0ZpxgKw4vFufjwu1Wia6Gt',#5,$,$,(#17522,#5674),#5693);
#19530= IFCRELDEFINESBYPROPERTIES('2RYFKX8zrDHQ9L$mDr8sKi',#5,$,$,(#5747),#5752);
#19531= IFCRELDEFINESBYPROPERTIES('3xQc6Qm_TF$8cHstnhiyT_',#5,$,$,(#5768),#5774);
#19532= IFCRELDEFINESBYPROPERTIES('0ob8FrNjTBFBfehRSDXhmN',#5,$,$,(#5768),#5788);
#19533= IFCRELDEFINESBYPROPERTIES('3dfYUDcyHBEgHiGNBDAMV2',#5,$,$,(#5768),#5794);
#19534= IFCRELDEFINESBYPROPERTIES('2GG2NaTED2zvZ8owHBoeFq',#5,$,$,(#7650,#7638,#7075,#7063,#6326,#6314,#5869,#5854),#5857);
#19535= IFCRELDEFINESBYPROPERTIES('2RgYEDRKHAdhil3bMy7Imf',#5,$,$,(#5871),#5874);
#19536= IFCRELDEFINESBYPROPERTIES('0_PU7vngX3qxjQIi8x6lMe',#5,$,$,(#7777,#6461,#5880),#5882);
#19537= IFCRELDEFINESBYPROPERTIES('3IUrjYK1f8FgsLrfRwYHhk',#5,$,$,(#7783,#6467,#5888),#5889);
#19538= IFCRELDEFINESBYPROPERTIES('10XdX04Sn1XgNPFky5QAID',#5,$,$,(#6473,#5895),#5896);
#19539= IFCRELDEFINESBYPROPERTIES('0Pvz9q0HLBeP2leQyr9bIl',#5,$,$,(#6479,#5902),#5903);
#19540= IFCRELDEFINESBYPROPERTIES('2PslH8AuH52OiXxvKhpKhh',#5,$,$,(#5937),#5939);
#19541= IFCRELDEFINESBYPROPERTIES('1K2fKRxbzFUOJpGVQW4y1X',#5,$,$,(#5937),#5943);
#19542= IFCRELDEFINESBYPROPERTIES('14fqlLox1EIwk6$DIgRTwF',#5,$,$,(#5945),#5948);
#19543= IFCRELDEFINESBYPROPERTIES('2B36Etwq56mu8IV$sDolZ5',#5,$,$,(#7844,#7373,#6612,#5945),#5950);
#19544= IFCRELDEFINESBYPROPERTIES('2o5XLHQ9f96fUjXUw7Tuz2',#5,$,$,(#7851,#7380,#6619,#5958),#5971);
#19545= IFCRELDEFINESBYPROPERTIES('3tj2$mlPP5ExnWlEq9D$Qb',#5,$,$,(#7851,#7380,#6619,#5958),#5976);
#19546= IFCRELDEFINESBYPROPERTIES('1QYhvTYhf99uw8cS1h2$mQ',#5,$,$,(#5978),#5979);
#19547= IFCRELDEFINESBYPROPERTIES('0xrY_PLXPAy8GI_vjndwo$',#5,$,$,(#7853,#7382,#6621,#5978),#5981);
#19548= IFCRELDEFINESBYPROPERTIES('0NWafUEB51Ox2_Tr8W1cOa',#5,$,$,(#7860,#7389,#6628,#5989),#5994);
#19549= IFCRELDEFINESBYPROPERTIES('3CBhOYD2fB3vvUNUINC$_v',#5,$,$,(#6153,#6137,#6011,#5996),#5997);
#19550= IFCRELDEFINESBYPROPERTIES('0K8hJVRxv8EuiBJNKk$rHq',#5,$,$,(#6005),#6006);
#19551= IFCRELDEFINESBYPROPERTIES('0SzORkCgP2HezFfTanHixr',#5,$,$,(#6005),#6009);
#19552= IFCRELDEFINESBYPROPERTIES('0C9ZHqKLPAmfj31GZ1ul4e',#5,$,$,(#7881,#7406,#6652,#6019),#6020);
#19553= IFCRELDEFINESBYPROPERTIES('2y_EvWyZr5vuUu1IwxwU_Y',#5,$,$,(#7881,#7406,#6652,#6019),#6024);
#19554= IFCRELDEFINESBYPROPERTIES('3LlThHHnH9GAUmCa_EKy$v',#5,$,$,(#6167,#6026),#6027);
#19555= IFCRELDEFINESBYPROPERTIES('3DcaE$ZNT2C9zmqU_OKrdp',#5,$,$,(#6035),#6039);
#19556= IFCRELDEFINESBYPROPERTIES('13vJ5CiOb5nuLu5zG4_tjg',#5,$,$,(#6186,#6041),#6042);
#19557= IFCRELDEFINESBYPROPERTIES('0GaupQfkr4x8tU0__3D_z9',#5,$,$,(#7906,#7427,#6677,#6050),#6051);
#19558= IFCRELDEFINESBYPROPERTIES('1FEN7Mw351AOsq8zwITRUc',#5,$,$,(#6677,#6050),#6055);
#19559= IFCRELDEFINESBYPROPERTIES('3r7xkmcyD7Jg7tK184iGZX',#5,$,$,(#6079),#6092);
#19560= IFCRELDEFINESBYPROPERTIES('3DH49Pl8149h_cwfd$G8MI',#5,$,$,(#7437,#6079),#6098);
#19561= IFCRELDEFINESBYPROPERTIES('1TT97bHn5AYB6sC5cEJK_n',#5,$,$,(#6207,#6100),#6102);
#19562= IFCRELDEFINESBYPROPERTIES('1UTUGroTz7IPjyHaRzsOTm',#5,$,$,(#6215,#6113),#6116);
#19563= IFCRELDEFINESBYPROPERTIES('2rJhGYW_929g2IJ$g6AaCR',#5,$,$,(#7933,#7447,#6698,#6113),#6130);
#19564= IFCRELDEFINESBYPROPERTIES('2xrsccu61EOAR6mu6Dl9zM',#5,$,$,(#7933,#7447,#6698,#6113),#6135);
#19565= IFCRELDEFINESBYPROPERTIES('1EBmUhDNP9jPoZ6kzv1GuY',#5,$,$,(#7957,#7464,#6725,#6161,#6145),#6147);
#19566= IFCRELDEFINESBYPROPERTIES('2lljpQnHD0A93ayh0k17vX',#5,$,$,(#6145),#6151);
#19567= IFCRELDEFINESBYPROPERTIES('26k86Bb35CaAeCgw4StibZ',#5,$,$,(#6161),#6165);
#19568= IFCRELDEFINESBYPROPERTIES('0Xav2uIXjC1vEgxEqdnJ6z',#5,$,$,(#7970,#6738,#6175),#6181);
#19569= IFCRELDEFINESBYPROPERTIES('3MPnFmmXX7iP5fTGl$Mnow',#5,$,$,(#6175),#6184);
#19570= IFCRELDEFINESBYPROPERTIES('0V4FFhzjLBygwzaeY5Na24',#5,$,$,(#6752,#6194),#6201);
#19571= IFCRELDEFINESBYPROPERTIES('3GfZ2_4WDA$AM5jfIRl_P4',#5,$,$,(#6194),#6205);
#19572= IFCRELDEFINESBYPROPERTIES('2WL0fhcAz0RQ3kI4$M_pF5',#5,$,$,(#8001,#7503,#6763,#6215),#6219);
#19573= IFCRELDEFINESBYPROPERTIES('1eFgXVXpfBE9qj4APHHzk$',#5,$,$,(#8001,#7503,#6763,#6215),#6224);
#19574= IFCRELDEFINESBYPROPERTIES('0df03$BcTEP8sTf84gBKde',#5,$,$,(#6388),#6389);
#19575= IFCRELDEFINESBYPROPERTIES('2oD08sX1j5DgX6kqpDDmu7',#5,$,$,(#6573,#6519,#6425,#6395),#6396);
#19576= IFCRELDEFINESBYPROPERTIES('1Nu8n3Q6502gp$CV9mQOpA',#5,$,$,(#6531,#6525,#6410,#6402),#6404);
#19577= IFCRELDEFINESBYPROPERTIES('2s4fcyZerCwOUikAdEVcwd',#5,$,$,(#6537,#6416),#6419);
#19578= IFCRELDEFINESBYPROPERTIES('2B88xt$nD3aeUh_Ee5QB6y',#5,$,$,(#6485,#6431),#6432);
#19579= IFCRELDEFINESBYPROPERTIES('3BxWlx$Df9SR2Ea0ca6aNF',#5,$,$,(#6445,#6438),#6439);
#19580= IFCRELDEFINESBYPROPERTIES('0aJUzxnbH3rvvqmDMvYq3Z',#5,$,$,(#6451),#6452);
#19581= IFCRELDEFINESBYPROPERTIES('20B7Q16_T3JRZcVDA6dp5T',#5,$,$,(#6454),#6455);
#19582= IFCRELDEFINESBYPROPERTIES('2l_gqciHfE_Oqh2omNxfwR',#5,$,$,(#6507),#6509);
#19583= IFCRELDEFINESBYPROPERTIES('2llXCuCbnD3fPaufHm$nuO',#5,$,$,(#6507),#6513);
#19584= IFCRELDEFINESBYPROPERTIES('1hKwaWKVz7HxOReZou_i8a',#5,$,$,(#6610,#6604,#6598,#6592,#6586,#6579),#6580);
#19585= IFCRELDEFINESBYPROPERTIES('1FYJTD1Ub0YRWQokdry6lS',#5,$,$,(#6612),#6613);
#19586= IFCRELDEFINESBYPROPERTIES('0Z_XE5SQD2kuS3xAm08WKe',#5,$,$,(#6621),#6622);
#19587= IFCRELDEFINESBYPROPERTIES('0vlt5YgDj4VgcgtBuiM6iK',#5,$,$,(#6717,#6701,#6644,#6630),#6631);
#19588= IFCRELDEFINESBYPROPERTIES('1YlIu41erF$BzanUlURzUd',#5,$,$,(#7871,#7398,#6639),#6642);
#19589= IFCRELDEFINESBYPROPERTIES('2xTXdZtOn16PrKZGjlfEqL',#5,$,$,(#6730,#6654),#6655);
#19590= IFCRELDEFINESBYPROPERTIES('0vbRm9O9zC1QDEguDPR08P',#5,$,$,(#6663),#6666);
#19591= IFCRELDEFINESBYPROPERTIES('1DsqUBJDb2PwLszTAwdi1F',#5,$,$,(#6744,#6668),#6669);
#19592= IFCRELDEFINESBYPROPERTIES('28lXEVX$L74AEJ7BxSt1Xa',#5,$,$,(#6684),#6686);
#19593= IFCRELDEFINESBYPROPERTIES('2PJf$7daP1Xw81bF8wIBNr',#5,$,$,(#6684),#6689);
#19594= IFCRELDEFINESBYPROPERTIES('2r7cJM2YXFDfTJfGDHJ0xC',#5,$,$,(#6757,#6691),#6692);
#19595= IFCRELDEFINESBYPROPERTIES('2H0OGGapbDNPHibqpUI6LI',#5,$,$,(#6763,#6698),#6699);
#19596= IFCRELDEFINESBYPROPERTIES('2ViRi9PWb5tu0Rg2s4cAh9',#5,$,$,(#7944,#7456,#6709),#6711);
#19597= IFCRELDEFINESBYPROPERTIES('0pHBE0uC59GA6YfcRHAZTA',#5,$,$,(#7456,#6709),#6715);
#19598= IFCRELDEFINESBYPROPERTIES('1j4BK3OBn3EAWrqFKbsR2m',#5,$,$,(#7464,#6725),#6728);
#19599= IFCRELDEFINESBYPROPERTIES('29gAV0hZjDRRyoFIUXGPfQ',#5,$,$,(#6738),#6742);
#19600= IFCRELDEFINESBYPROPERTIES('1K8mxwGOb319pBaN147EHv',#5,$,$,(#6752),#6755);
#19601= IFCRELDEFINESBYPROPERTIES('0I_cYpiyP1XAvs30KPo0_R',#5,$,$,(#6817,#6809,#6801,#6765),#6767);
#19602= IFCRELDEFINESBYPROPERTIES('0P8ZDhJFrEAvtrM59Fmhb5',#5,$,$,(#6823,#6815,#6807,#6794,#6773),#6774);
#19603= IFCRELDEFINESBYPROPERTIES('1gVoTu1JH72PwkvtVFu2zT',#5,$,$,(#6773),#6779);
#19604= IFCRELDEFINESBYPROPERTIES('3_b05g1db1mgF9mCcYNcQu',#5,$,$,(#6773),#6785);
#19605= IFCRELDEFINESBYPROPERTIES('2iGFZuGFj6L8zVTPmh0ncH',#5,$,$,(#6787),#6788);
#19606= IFCRELDEFINESBYPROPERTIES('3ya8$_JST8SeVMGhmxkIGu',#5,$,$,(#6823,#6815,#6807,#6794),#6796);
#19607= IFCRELDEFINESBYPROPERTIES('0G3BX$qSL4IuXl0BQ_uZLe',#5,$,$,(#6823,#6815,#6807,#6794),#6799);
#19608= IFCRELDEFINESBYPROPERTIES('3ZRMYT$MPEQxVDiW_gJEHB',#5,$,$,(#7137),#7139);
#19609= IFCRELDEFINESBYPROPERTIES('1JERBLOeL4_h_EkmuhY3ZT',#5,$,$,(#7371,#7334,#7186,#7145),#7146);
#19610= IFCRELDEFINESBYPROPERTIES('1hhfcUZ2TDRAuXwu5kw3Yl',#5,$,$,(#7186,#7145),#7148);
#19611= IFCRELDEFINESBYPROPERTIES('0m0jispqzDt8TueXc5rBJf',#5,$,$,(#7186,#7145),#7154);
#19612= IFCRELDEFINESBYPROPERTIES('2sRJC1Lkn64Rofo0qBS3UW',#5,$,$,(#7357,#7350,#7169,#7160),#7162);
#19613= IFCRELDEFINESBYPROPERTIES('3sITO438f4eOvMa4yYJvR8',#5,$,$,(#7160),#7163);
#19614= IFCRELDEFINESBYPROPERTIES('03OSPTswfCVvb$dHWVpw$6',#5,$,$,(#7169),#7170);
#19615= IFCRELDEFINESBYPROPERTIES('0tF9cNKSz189VSXp5uWFJ6',#5,$,$,(#7364,#7176),#7179);
#19616= IFCRELDEFINESBYPROPERTIES('0gvs8D2LX6EONSVkG5Srk6',#5,$,$,(#7176),#7180);
#19617= IFCRELDEFINESBYPROPERTIES('1Vy$Jh75HCbB5WxG2ogOZZ',#5,$,$,(#7283,#7188),#7190);
#19618= IFCRELDEFINESBYPROPERTIES('2dkAEviU53eBP_GTWpAfDI',#5,$,$,(#7283,#7188),#7192);
#19619= IFCRELDEFINESBYPROPERTIES('2DbK0QqnHDKfdmMLjhxtOY',#5,$,$,(#7289,#7198),#7199);
#19620= IFCRELDEFINESBYPROPERTIES('21peTPrc93uxz6TXa7MKG9',#5,$,$,(#7289,#7198),#7201);
#19621= IFCRELDEFINESBYPROPERTIES('00xtmrCbj7afIYtuwAPfVT',#5,$,$,(#7289,#7198),#7204);
#19622= IFCRELDEFINESBYPROPERTIES('0QAPqwaKzDfArIkA3yF6_P',#5,$,$,(#7206),#7209);
#19623= IFCRELDEFINESBYPROPERTIES('1CX3hCqTL0UB5A2Yw34opv',#5,$,$,(#7206),#7211);
#19624= IFCRELDEFINESBYPROPERTIES('051aQ9PE55NBS7GMLAQ5aM',#5,$,$,(#7231,#7217),#7219);
#19625= IFCRELDEFINESBYPROPERTIES('1Z2Qu$d4nCEOAxFvM6_22g',#5,$,$,(#7217),#7221);
#19626= IFCRELDEFINESBYPROPERTIES('1C8gYB2iD0Fe43wJru9fkg',#5,$,$,(#7223),#7225);
#19627= IFCRELDEFINESBYPROPERTIES('3CfaRePUHAOQK_a2ndA49M',#5,$,$,(#7231),#7233);
#19628= IFCRELDEFINESBYPROPERTIES('37NRm5Yqb5JPpo$X4$$UWv',#5,$,$,(#7235),#7238);
#19629= IFCRELDEFINESBYPROPERTIES('2nZI77Fs53RB$NjEs5fRy2',#5,$,$,(#7244),#7246);
#19630= IFCRELDEFINESBYPROPERTIES('2ZpwX7yvPBiAPIo_0QekVU',#5,$,$,(#7244),#7248);
#19631= IFCRELDEFINESBYPROPERTIES('2pVxlzvAz5TxXlbmkQdLuZ',#5,$,$,(#7250),#7252);
#19632= IFCRELDEFINESBYPROPERTIES('3U3nI1q_T1yh1OLTZtPl5m',#5,$,$,(#7258),#7260);
#19633= IFCRELDEFINESBYPROPERTIES('0TGhyKVv9Eqwcvv9SauH1L',#5,$,$,(#7266),#7267);
#19634= IFCRELDEFINESBYPROPERTIES('36cPvA3n508eCLZ02nqzHr',#5,$,$,(#7273),#7274);
#19635= IFCRELDEFINESBYPROPERTIES('0xhnEg_697E8b$_EwgaPgW',#5,$,$,(#7280),#7281);
#19636= IFCRELDEFINESBYPROPERTIES('1LXqFwPXHFgBMjRNs_QloO',#5,$,$,(#7323),#7324);
#19637= IFCRELDEFINESBYPROPERTIES('2gKhCokBz51gwK8dJ3GoOd',#5,$,$,(#7323),#7328);
#19638= IFCRELDEFINESBYPROPERTIES('2SiB9pNMj2MhP5JE7fH3jl',#5,$,$,(#7371,#7334),#7338);
#19639= IFCRELDEFINESBYPROPERTIES('28wDEdeLL8QB8d57yItREV',#5,$,$,(#7371,#7334),#7344);
#19640= IFCRELDEFINESBYPROPERTIES('0FXDdAN4fACBBOzTSWXMDU',#5,$,$,(#7350),#7351);
#19641= IFCRELDEFINESBYPROPERTIES('28vbN1iPz8YQEUc$QBUpEZ',#5,$,$,(#7357),#7358);
#19642= IFCRELDEFINESBYPROPERTIES('211cHjNlP3lhES76x2kIc4',#5,$,$,(#7364),#7365);
#19643= IFCRELDEFINESBYPROPERTIES('016FP8Jir91P6flLWQkcL8',#5,$,$,(#7373),#7374);
#19644= IFCRELDEFINESBYPROPERTIES('3g_mbcQCDAQw6yR1kkMYOc',#5,$,$,(#7382),#7383);
#19645= IFCRELDEFINESBYPROPERTIES('2AZNwpHFX5F9KhUiWo9BUw',#5,$,$,(#7458,#7450,#7400,#7391),#7392);
#19646= IFCRELDEFINESBYPROPERTIES('00I4YiRUD2Rexj0VL0H$0o',#5,$,$,(#7466,#7408),#7409);
#19647= IFCRELDEFINESBYPROPERTIES('2TOzrhkhL20RrjxK_bh7Ki',#5,$,$,(#7415),#7418);
#19648= IFCRELDEFINESBYPROPERTIES('25kgb011P4f9hiN1Y_eNif',#5,$,$,(#7480,#7420),#7421);
#19649= IFCRELDEFINESBYPROPERTIES('2eUDsW2gH4BPioliyVxvZW',#5,$,$,(#7427),#7430);
#19650= IFCRELDEFINESBYPROPERTIES('0e2c6K9Kz3oAuHSZa1eXqo',#5,$,$,(#7437),#7438);
#19651= IFCRELDEFINESBYPROPERTIES('09VSq52EX2fOD$mDK7nvSV',#5,$,$,(#7497,#7440),#7441);
#19652= IFCRELDEFINESBYPROPERTIES('0IaTCHjh98XuXV5gia9_tG',#5,$,$,(#7503,#7447),#7448);
#19653= IFCRELDEFINESBYPROPERTIES('1nL6AUQNfEwga45U6mvI$L',#5,$,$,(#7472),#7475);
#19654= IFCRELDEFINESBYPROPERTIES('2MRlOSpGv9P9YVgtKHvMBI',#5,$,$,(#7472),#7478);
#19655= IFCRELDEFINESBYPROPERTIES('1iYhdy9Sz4uxtsdQnmBSNj',#5,$,$,(#7486),#7492);
#19656= IFCRELDEFINESBYPROPERTIES('0n_TIGU79B$fh95Hw$Nj4e',#5,$,$,(#7486),#7495);
#19657= IFCRELDEFINESBYPROPERTIES('1tIo8yJ455vxB5hCYsOpLp',#5,$,$,(#7530),#7531);
#19658= IFCRELDEFINESBYPROPERTIES('0hEgUR2EX2pBEOtT4QV7$p',#5,$,$,(#7530),#7543);
#19659= IFCRELDEFINESBYPROPERTIES('1mdgR2nR13VhpFC_390E7F',#5,$,$,(#17514,#7530),#7548);
#19660= IFCRELDEFINESBYPROPERTIES('0n4_vmYDj1MQeoVhJeFLcD',#5,$,$,(#7682),#7684);
#19661= IFCRELDEFINESBYPROPERTIES('2VDPYV8RX58f5WI7NAMwAE',#5,$,$,(#15981,#8007,#7731,#7690),#7691);
#19662= IFCRELDEFINESBYPROPERTIES('1vshVU2i5EvedQPjU8Xe_m',#5,$,$,(#7731,#7690),#7693);
#19663= IFCRELDEFINESBYPROPERTIES('2bDzzT5J10kuZSA_qx52Rr',#5,$,$,(#7690),#7699);
#19664= IFCRELDEFINESBYPROPERTIES('2tA0KSrin8ARw3Ziogg7xO',#5,$,$,(#8027,#8020,#7714,#7705),#7707);
#19665= IFCRELDEFINESBYPROPERTIES('32tUqccvD5_f1zxoLTosP_',#5,$,$,(#7705),#7708);
#19666= IFCRELDEFINESBYPROPERTIES('1XRcLnzWP2TxTYsPb0CGkV',#5,$,$,(#7714),#7715);
#19667= IFCRELDEFINESBYPROPERTIES('1OMUHf0qb13P94lQwOsOvw',#5,$,$,(#8034,#7721),#7724);
#19668= IFCRELDEFINESBYPROPERTIES('3p_jOl4uD49hIVa0uP8GtF',#5,$,$,(#7721),#7725);
#19669= IFCRELDEFINESBYPROPERTIES('3zXy2dC79Evwamc0U6ZM4S',#5,$,$,(#7731),#7734);
#19670= IFCRELDEFINESBYPROPERTIES('1cmJhl2N9BBQpigrMF$VG3',#5,$,$,(#7803,#7740),#7741);
#19671= IFCRELDEFINESBYPROPERTIES('0cmqZCVbPCvQFOdRD42LKT',#5,$,$,(#7803,#7740),#7742);
#19672= IFCRELDEFINESBYPROPERTIES('1VoPAOn9zCdgzPRFtkNCSk',#5,$,$,(#7740),#7745);
#19673= IFCRELDEFINESBYPROPERTIES('09XTwjifL1Nf8dROftwokN',#5,$,$,(#7759,#7751),#7752);
#19674= IFCRELDEFINESBYPROPERTIES('0vzjxkrbT9lQgro7uBPAmo',#5,$,$,(#7751),#7753);
#19675= IFCRELDEFINESBYPROPERTIES('3jPiMMT7508vuBsqn9$xwA',#5,$,$,(#7759),#7760);
#19676= IFCRELDEFINESBYPROPERTIES('2Y6cGjOAP4ER0pOmgeWW0r',#5,$,$,(#7766),#7767);
#19677= IFCRELDEFINESBYPROPERTIES('0DhKRBBj58UeCYla3SK5fe',#5,$,$,(#7766),#7768);
#19678= IFCRELDEFINESBYPROPERTIES('08Qn2YAAv3Efk0tAjtBPLS',#5,$,$,(#7770),#7771);
#19679= IFCRELDEFINESBYPROPERTIES('2PlOFvcYz0ROOgLp3L3cZf',#5,$,$,(#7789),#7790);
#19680= IFCRELDEFINESBYPROPERTIES('2r70E3q$HCdewdNYfbP3gm',#5,$,$,(#7796),#7797);
#19681= IFCRELDEFINESBYPROPERTIES('2PfymANmT2rPhbAv6KBSBk',#5,$,$,(#7803),#7804);
#19682= IFCRELDEFINESBYPROPERTIES('2u4k7dhir6sfobY2LVAW2C',#5,$,$,(#7838),#7839);
#19683= IFCRELDEFINESBYPROPERTIES('2QKO3U0xjChBaCTiEAebqo',#5,$,$,(#7838),#7842);
#19684= IFCRELDEFINESBYPROPERTIES('18XATP99HFGwwWf8OljU3x',#5,$,$,(#7844),#7845);
#19685= IFCRELDEFINESBYPROPERTIES('116l4f2817bfnWrDkuFRfq',#5,$,$,(#7853),#7854);
#19686= IFCRELDEFINESBYPROPERTIES('3ppQ83X7TBi9w0g1$TTVGy',#5,$,$,(#7949,#7936,#7873,#7862),#7863);
#19687= IFCRELDEFINESBYPROPERTIES('3h9T7Hn8X3PR0CO5whoEiu',#5,$,$,(#7962,#7883),#7884);
#19688= IFCRELDEFINESBYPROPERTIES('1IZ8tsHFr93uCmYqaBatca',#5,$,$,(#7892),#7895);
#19689= IFCRELDEFINESBYPROPERTIES('1VkUuobzP8bBBPmKW9XdSM',#5,$,$,(#7976,#7897),#7898);
#19690= IFCRELDEFINESBYPROPERTIES('34gTO90V99i8J71BJknnLf',#5,$,$,(#7906),#7909);
#19691= IFCRELDEFINESBYPROPERTIES('2_WAYXTm5BvO3Eo04Tzcuw',#5,$,$,(#7916),#7920);
#19692= IFCRELDEFINESBYPROPERTIES('2rwol7xS93QxLHcms7kQd$',#5,$,$,(#7916),#7924);
#19693= IFCRELDEFINESBYPROPERTIES('0Z8MqAprP0vvkAwogoabKJ',#5,$,$,(#7995,#7926),#7927);
#19694= IFCRELDEFINESBYPROPERTIES('0ByxvorTP5GB0vIhqnk2jj',#5,$,$,(#8001,#7933),#7934);
#19695= IFCRELDEFINESBYPROPERTIES('1tnxr6lGf7qAqjHHo_calF',#5,$,$,(#7944),#7947);
#19696= IFCRELDEFINESBYPROPERTIES('36lSqpSgj7qRmUPF1qyOYn',#5,$,$,(#7957),#7960);
#19697= IFCRELDEFINESBYPROPERTIES('0Q7TPlxIf5vwPcjzub800q',#5,$,$,(#7970),#7974);
#19698= IFCRELDEFINESBYPROPERTIES('2saLbSR7j6EgfVnnUuOkQu',#5,$,$,(#7984),#7990);
#19699= IFCRELDEFINESBYPROPERTIES('2UfG$neqL3VRpGB_0YY7V3',#5,$,$,(#7984),#7993);
#19700= IFCRELDEFINESBYPROPERTIES('2wEQ4pkHHF2gKZbk_1dGZg',#5,$,$,(#15981,#8007),#8008);
#19701= IFCRELDEFINESBYPROPERTIES('1W6YyiOvr2Q8a6Qfd$P$dK',#5,$,$,(#15981,#8007),#8014);
#19702= IFCRELDEFINESBYPROPERTIES('1BreASLnzDewFMiA6HaG7l',#5,$,$,(#8020),#8021);
#19703= IFCRELDEFINESBYPROPERTIES('1f3j_vDDbFi9$dy5cjONS2',#5,$,$,(#8027),#8028);
#19704= IFCRELDEFINESBYPROPERTIES('0lmnqYyvD1Mg5SrT7VoxCM',#5,$,$,(#8034),#8035);
#19705= IFCRELDEFINESBYPROPERTIES('0GRjJsLwH0bBcZpTij0T5m',#5,$,$,(#8067),#8071);
#19706= IFCRELDEFINESBYPROPERTIES('2q$dJKpVH5iQnP6AQBZzEJ',#5,$,$,(#8067),#8073);
#19707= IFCRELDEFINESBYPROPERTIES('0wt63WbEP2U9V4yPdj$Yt8',#5,$,$,(#8109),#8116);
#19708= IFCRELDEFINESBYPROPERTIES('3CTvSh$a9CHPXs3EPFxvK$',#5,$,$,(#8109),#8131);
#19709= IFCRELDEFINESBYPROPERTIES('3nbWHPWYv4WPAkretOP1bF',#5,$,$,(#8109),#8136);
#19710= IFCRELDEFINESBYPROPERTIES('3P5sUqStXET9L5NEK8AGx9',#5,$,$,(#15007,#14967,#14942,#14930,#14433,#14421,#14396,#14384,#14359,#14347,#14322,#14310,#14285,#14273,#9426,#9414,#9044,#9032,#8507,#8168,#8150),#8154);
#19711= IFCRELDEFINESBYPROPERTIES('3RsllaFN9BbfJRc9_goy9$',#5,$,$,(#8215,#8170),#8174);
#19712= IFCRELDEFINESBYPROPERTIES('34I8rcB7n6F9$3C44ibfb$',#5,$,$,(#8170),#8176);
#19713= IFCRELDEFINESBYPROPERTIES('3xV0VQlIH54xxbpMITwvQt',#5,$,$,(#8225,#8187),#8193);
#19714= IFCRELDEFINESBYPROPERTIES('1jQoIVk915IfpGTS2VRLhP',#5,$,$,(#8187),#8208);
#19715= IFCRELDEFINESBYPROPERTIES('2CZN3SoXPE28hJILp6oYXV',#5,$,$,(#8187),#8213);
#19716= IFCRELDEFINESBYPROPERTIES('2DC_1n1tz3xAX5h8$rosPz',#5,$,$,(#8215),#8217);
#19717= IFCRELDEFINESBYPROPERTIES('1TGGeoC8H0Jeb7s2obNPup',#5,$,$,(#8225),#8228);
#19718= IFCRELDEFINESBYPROPERTIES('2hRAkLOf59AO8X_b80LHav',#5,$,$,(#8225),#8232);
#19719= IFCRELDEFINESBYPROPERTIES('0xxECFMwH5weNPL3GLvVaS',#5,$,$,(#8234),#8238);
#19720= IFCRELDEFINESBYPROPERTIES('2j4XjC8DDELABUHq9ihYa6',#5,$,$,(#8234),#8240);
#19721= IFCRELDEFINESBYPROPERTIES('0jNOMQkxDAKOOGYXMFBwlq',#5,$,$,(#8622,#8590,#8259),#8264);
#19722= IFCRELDEFINESBYPROPERTIES('0_7kI$n1P2vRxIojR0xKWS',#5,$,$,(#8259),#8279);
#19723= IFCRELDEFINESBYPROPERTIES('3m6iy7QIjBrhPGHA4SKi_P',#5,$,$,(#8259),#8286);
#19724= IFCRELDEFINESBYPROPERTIES('3O8hKmRb53Dwt5mlVxeME_',#5,$,$,(#9608,#9552,#8737,#8424,#8288),#8291);
#19725= IFCRELDEFINESBYPROPERTIES('2vvKRcjorDAgn6md8MdPd$',#5,$,$,(#9608,#9552,#8737,#8424,#8288),#8293);
#19726= IFCRELDEFINESBYPROPERTIES('1OsvTSR1j4d8w8L0pFW4W5',#5,$,$,(#9614,#9558,#8743,#8430,#8302),#8305);
#19727= IFCRELDEFINESBYPROPERTIES('1UmYh_yqD0gxfv4w8TJIkA',#5,$,$,(#8743,#8302),#8314);
#19728= IFCRELDEFINESBYPROPERTIES('0IYV$dTQ93nQkz9zUjLdgN',#5,$,$,(#8302),#8318);
#19729= IFCRELDEFINESBYPROPERTIES('2Rhf6eDyv8I9glcowh7sKf',#5,$,$,(#9622,#9565,#8748,#8440,#8320),#8323);
#19730= IFCRELDEFINESBYPROPERTIES('0BliLI6tL4agpcAx1uJjhA',#5,$,$,(#8770,#8748,#8466,#8454,#8440,#8320),#8325);
#19731= IFCRELDEFINESBYPROPERTIES('198Q688HfDQQhjzvUNIDlD',#5,$,$,(#9628,#9571,#8754,#8446,#8335),#8338);
#19732= IFCRELDEFINESBYPROPERTIES('2eZXzmTXb09uQyB2Z11r7u',#5,$,$,(#9651,#9640,#9628,#9592,#9582,#8776,#8766,#8379,#8361,#8335),#8342);
#19733= IFCRELDEFINESBYPROPERTIES('3pGV8EO5f7mPYW9LLSdmT7',#5,$,$,(#8335),#8346);
#19734= IFCRELDEFINESBYPROPERTIES('0XUkIS9m1ABuGTxQaGdiyJ',#5,$,$,(#9634,#9576,#8760,#8454,#8348),#8351);
#19735= IFCRELDEFINESBYPROPERTIES('0957urr2L7JBIjSCTYem6T',#5,$,$,(#9645,#9634,#9622,#9586,#9576,#9565,#8760,#8370,#8348),#8353);
#19736= IFCRELDEFINESBYPROPERTIES('2d_oAIZlTBBuGTW9u07$LK',#5,$,$,(#9640,#9582,#8766,#8460,#8361),#8364);
#19737= IFCRELDEFINESBYPROPERTIES('1wwIGdqxj9AwxGQASba001',#5,$,$,(#8361),#8368);
#19738= IFCRELDEFINESBYPROPERTIES('0_8o3PTh97Ef4G371tqXJz',#5,$,$,(#9645,#9586,#8770,#8466,#8370),#8373);
#19739= IFCRELDEFINESBYPROPERTIES('32$DeBylLBsfgTSbVZc9sX',#5,$,$,(#9651,#9592,#8776,#8472,#8379),#8382);
#19740= IFCRELDEFINESBYPROPERTIES('3u9ZfRoyb0Jvs$NeeNbNPw',#5,$,$,(#8379),#8386);
#19741= IFCRELDEFINESBYPROPERTIES('1xtNOP8L98nh00yEey$IX0',#5,$,$,(#9656,#9597,#8781,#8477,#8388),#8392);
#19742= IFCRELDEFINESBYPROPERTIES('1aj2SPxb9FLBwQVFb9j33W',#5,$,$,(#8781,#8388),#8394);
#19743= IFCRELDEFINESBYPROPERTIES('1uCYsTtDL8q8SKyfZyI8Cu',#5,$,$,(#9662,#9603,#8787,#8485,#8405),#8410);
#19744= IFCRELDEFINESBYPROPERTIES('1whK0h6kT7OgSJeXusNYhU',#5,$,$,(#9603,#8787,#8405),#8418);
#19745= IFCRELDEFINESBYPROPERTIES('1xFAEnIj5D4wbEx_IYua4q',#5,$,$,(#8405),#8422);
#19746= IFCRELDEFINESBYPROPERTIES('2LICcEPpf0pRJNKc8eLO7F',#5,$,$,(#8430),#8434);
#19747= IFCRELDEFINESBYPROPERTIES('2XVMN7qq515Olm9v3BVRq4',#5,$,$,(#8430),#8438);
#19748= IFCRELDEFINESBYPROPERTIES('08o3eWCOHBPuPThfRkyfow',#5,$,$,(#9571,#8754,#8472,#8460,#8446),#8448);
#19749= IFCRELDEFINESBYPROPERTIES('205Pn85AzADBn_J03foY2y',#5,$,$,(#8446),#8452);
#19750= IFCRELDEFINESBYPROPERTIES('2f$0JeqQv2th6$KQTT6Lr8',#5,$,$,(#8460),#8464);
#19751= IFCRELDEFINESBYPROPERTIES('3cdg23MCrB3u1bKAvccA2a',#5,$,$,(#8472),#8475);
#19752= IFCRELDEFINESBYPROPERTIES('3nbQYpxU92sxxQPBR7aIPD',#5,$,$,(#9656,#9597,#8477),#8479);
#19753= IFCRELDEFINESBYPROPERTIES('2FtyBb4zn3iw1DKe74KcMn',#5,$,$,(#8485),#8492);
#19754= IFCRELDEFINESBYPROPERTIES('3YOscQu4XApua7t_hXyBi9',#5,$,$,(#8485),#8495);
#19755= IFCRELDEFINESBYPROPERTIES('3IRp6FVlXFxwYAx4ezg3iQ',#5,$,$,(#15020,#14955,#14446,#14409,#14372,#14335,#14298,#9439,#9061,#8528),#8532);
#19756= IFCRELDEFINESBYPROPERTIES('332DF$spL3UPipQKeVpU9B',#5,$,$,(#8538),#8539);
#19757= IFCRELDEFINESBYPROPERTIES('1NNbnC2_n8N9jFclv7F5Jp',#5,$,$,(#8538),#8540);
#19758= IFCRELDEFINESBYPROPERTIES('3Ed3cq0zr3IPXUa_gIcKwI',#5,$,$,(#8538),#8544);
#19759= IFCRELDEFINESBYPROPERTIES('39qU6DB8bA0wx_1nVPKz_8',#5,$,$,(#8561),#8563);
#19760= IFCRELDEFINESBYPROPERTIES('3xLLU77wXFpBQwx8xdDeuF',#5,$,$,(#8561),#8576);
#19761= IFCRELDEFINESBYPROPERTIES('2_ErxSjmv6WONA8Pb_HQ19',#5,$,$,(#8561),#8582);
#19762= IFCRELDEFINESBYPROPERTIES('3etEAeugzFPe1rnV56wK71',#5,$,$,(#8590),#8601);
#19763= IFCRELDEFINESBYPROPERTIES('22BhgqYy9EKwIcEbTnqONQ',#5,$,$,(#8590),#8607);
#19764= IFCRELDEFINESBYPROPERTIES('3eu6_6LwTAqhfEjvk8z54G',#5,$,$,(#8622),#8634);
#19765= IFCRELDEFINESBYPROPERTIES('1rBf7tb3L9iuqawd446VR8',#5,$,$,(#8622),#8640);
#19766= IFCRELDEFINESBYPROPERTIES('3EEnPgRrL1bfBKYKZUNNWG',#5,$,$,(#8652),#8657);
#19767= IFCRELDEFINESBYPROPERTIES('1nnnP2wDnCWugcZJzfxgEE',#5,$,$,(#8652),#8671);
#19768= IFCRELDEFINESBYPROPERTIES('12YvisrnL6Mv7R6LUYbug8',#5,$,$,(#8652),#8676);
#19769= IFCRELDEFINESBYPROPERTIES('1QGhU80ab9TQVoXugdOq$q',#5,$,$,(#9521,#8678),#8680);
#19770= IFCRELDEFINESBYPROPERTIES('0b0snxxLb0de_9crxeUNDO',#5,$,$,(#8678),#8682);
#19771= IFCRELDEFINESBYPROPERTIES('200$PT7YvC3wDongC4MsgZ',#5,$,$,(#9534,#8717),#8719);
#19772= IFCRELDEFINESBYPROPERTIES('0tykG8r6v1sBgKlFGufb00',#5,$,$,(#8717),#8729);
#19773= IFCRELDEFINESBYPROPERTIES('3XIfFndtnCk8EZrKPAJhmB',#5,$,$,(#8717),#8735);
#19774= IFCRELDEFINESBYPROPERTIES('178ZCsYcbAa8xXfDd_uHMZ',#5,$,$,(#8743),#8746);
#19775= IFCRELDEFINESBYPROPERTIES('3EfFAK5e95cRmW4Vn2uSTl',#5,$,$,(#8754),#8758);
#19776= IFCRELDEFINESBYPROPERTIES('2gxek3OWT4QfmNo3572z2r',#5,$,$,(#8766),#8768);
#19777= IFCRELDEFINESBYPROPERTIES('3HXvy2XRL3vPx3jzk8JLsX',#5,$,$,(#8776),#8779);
#19778= IFCRELDEFINESBYPROPERTIES('1HaLHVePL8J9ZBaU3HJZA8',#5,$,$,(#8787),#8790);
#19779= IFCRELDEFINESBYPROPERTIES('0tiGxfoMb6ke_2gYEAUbVI',#5,$,$,(#14590,#14534,#13979,#13923,#13867,#13811,#13755,#10988,#10881,#10649,#8851),#8853);
#19780= IFCRELDEFINESBYPROPERTIES('1dOenTnBz9t8XQ3Ro_RdIo',#5,$,$,(#8855),#8860);
#19781= IFCRELDEFINESBYPROPERTIES('3$PszRDS53lvD52xhr6mYk',#5,$,$,(#8855),#8862);
#19782= IFCRELDEFINESBYPROPERTIES('2nF2tTwRH5kxmjWpGvETSQ',#5,$,$,(#11362,#8872),#8877);
#19783= IFCRELDEFINESBYPROPERTIES('37VwjbqaDEnAula79pyKUr',#5,$,$,(#8872),#8886);
#19784= IFCRELDEFINESBYPROPERTIES('2BTGUjkKnBNOXcbGdo65Eg',#5,$,$,(#16080,#16059,#16030,#16006,#15372,#15321,#15271,#15250,#15226,#15196,#15172,#15146,#15104,#15059,#8872),#8891);
#19785= IFCRELDEFINESBYPROPERTIES('3ByzXpEXH9E8xwDu16KAZ6',#5,$,$,(#8902),#8907);
#19786= IFCRELDEFINESBYPROPERTIES('2yC7wU8OX5RgrzqnpMJGYj',#5,$,$,(#8902),#8920);
#19787= IFCRELDEFINESBYPROPERTIES('01tLM5UgT5Owv88ZxkQP31',#5,$,$,(#8902),#8925);
#19788= IFCRELDEFINESBYPROPERTIES('2W3sAXWq11A8SDdep4No4i',#5,$,$,(#8927),#8932);
#19789= IFCRELDEFINESBYPROPERTIES('323KjspXnA7vKBhgwkAGMw',#5,$,$,(#8927),#8934);
#19790= IFCRELDEFINESBYPROPERTIES('3$6UdzInTEC8QKk$XTWaDC',#5,$,$,(#17432,#16513,#16466,#16411,#16344,#8948),#8954);
#19791= IFCRELDEFINESBYPROPERTIES('3Vp43SPunCSPzJwRnoFs8_',#5,$,$,(#8948),#8969);
#19792= IFCRELDEFINESBYPROPERTIES('3ufbAn0nT9GxWGXE3I3bXc',#5,$,$,(#8948),#8975);
#19793= IFCRELDEFINESBYPROPERTIES('1f4jF7Ht13ORacBPywSzr3',#5,$,$,(#8977),#8982);
#19794= IFCRELDEFINESBYPROPERTIES('2wiIOjoyXBLwYqnx1S6v45',#5,$,$,(#17434,#16515,#16468,#16413,#16348,#11065,#8977),#8984);
#19795= IFCRELDEFINESBYPROPERTIES('2IvsfqXJb7uxRq3nTL0YSb',#5,$,$,(#17441,#16522,#16474,#16419,#16356,#8995),#9002);
#19796= IFCRELDEFINESBYPROPERTIES('0Tx9jsf9z2fuvWFwz1$3Rs',#5,$,$,(#8995),#9015);
#19797= IFCRELDEFINESBYPROPERTIES('11LMc2TEvDQ94C2XfyuKsG',#5,$,$,(#8995),#9020);
#19798= IFCRELDEFINESBYPROPERTIES('2ocQplWtX8Ufwh0qJAT4TM',#5,$,$,(#9170,#9063),#9067);
#19799= IFCRELDEFINESBYPROPERTIES('3_LfdgaoP7qvKMYEEADzM1',#5,$,$,(#16289,#16175,#16150,#16129,#15952,#15931,#15904,#15880,#15855,#15835,#15810,#15790,#15743,#15698,#9170,#9063),#9069);
#19800= IFCRELDEFINESBYPROPERTIES('353gNvsoL3AuyK_Kt$5R9G',#5,$,$,(#16295,#16181,#16156,#16136,#15958,#15938,#15910,#15886,#15861,#15841,#15816,#15796,#15749,#15707,#9176,#9077),#9080);
#19801= IFCRELDEFINESBYPROPERTIES('2PEVQ$At90EgG9QXFWRXWc',#5,$,$,(#16295,#16181,#16156,#16136,#15958,#15938,#15910,#15886,#15861,#15841,#15816,#15796,#15749,#15707,#9176,#9077),#9092);
#19802= IFCRELDEFINESBYPROPERTIES('1pGnORTQf5LP$sKPdiiYFk',#5,$,$,(#9176,#9077),#9097);
#19803= IFCRELDEFINESBYPROPERTIES('00TXZ9IV94ce$iK2NJJRHU',#5,$,$,(#9099),#9103);
#19804= IFCRELDEFINESBYPROPERTIES('3h3pxVjYXBcRy3Zr$dY8_l',#5,$,$,(#9099),#9105);
#19805= IFCRELDEFINESBYPROPERTIES('0wLAxu2nzCnPx_gINSIKUy',#5,$,$,(#9119),#9121);
#19806= IFCRELDEFINESBYPROPERTIES('1mC3jRdxP6_u5xFFIH92kJ',#5,$,$,(#9119),#9136);
#19807= IFCRELDEFINESBYPROPERTIES('1vS$lWXe5BRAI_0R8o1DlG',#5,$,$,(#9119),#9142);
#19808= IFCRELDEFINESBYPROPERTIES('2awcipy2rFd8VEwb8bEU_3',#5,$,$,(#9184,#9150),#9151);
#19809= IFCRELDEFINESBYPROPERTIES('01FZWuIWv5L9g8RCN6OuXf',#5,$,$,(#9150),#9162);
#19810= IFCRELDEFINESBYPROPERTIES('2zfYGkYUP97Re0w$0fP_bs',#5,$,$,(#9150),#9168);
#19811= IFCRELDEFINESBYPROPERTIES('32cV3NS1f0dB1VxAwV$Mbp',#5,$,$,(#9184),#9192);
#19812= IFCRELDEFINESBYPROPERTIES('3EvniBcmf3JRSH1f1eLQfD',#5,$,$,(#9184),#9198);
#19813= IFCRELDEFINESBYPROPERTIES('1SczdmME54dxgNqH_BPRYN',#5,$,$,(#9200),#9201);
#19814= IFCRELDEFINESBYPROPERTIES('3o40SPmGH6sxASSgM_rO18',#5,$,$,(#9200),#9203);
#19815= IFCRELDEFINESBYPROPERTIES('2ZWeR7W_H5jQ3tYDm9tE2r',#5,$,$,(#9213),#9219);
#19816= IFCRELDEFINESBYPROPERTIES('1Ttdg5j5T7B95D01owVb$J',#5,$,$,(#9213),#9225);
#19817= IFCRELDEFINESBYPROPERTIES('1kxT7saSb71gKMzVo9vJTJ',#5,$,$,(#9329,#9227),#9230);
#19818= IFCRELDEFINESBYPROPERTIES('2ZTHK2_JvD_grTXu8TluSg',#5,$,$,(#17662,#17622,#17576,#17532,#17385,#17341,#17292,#17252,#17206,#17166,#17120,#17080,#17018,#16971,#9335,#9240),#9243);
#19819= IFCRELDEFINESBYPROPERTIES('0WDKsotN9CNQ8b5sSMtTEZ',#5,$,$,(#17662,#17622,#17576,#17532,#17385,#17341,#17292,#17252,#17206,#17166,#17120,#17080,#17018,#16971,#9335,#9240),#9245);
#19820= IFCRELDEFINESBYPROPERTIES('12lY5dTm19Gu5Bmpnm8JeN',#5,$,$,(#9240),#9249);
#19821= IFCRELDEFINESBYPROPERTIES('2OH1gUjNbDiebIGrPzxpLV',#5,$,$,(#9340,#9251),#9253);
#19822= IFCRELDEFINESBYPROPERTIES('2r4YBTzFL4D8d0JlA6SQpb',#5,$,$,(#17670,#17630,#17584,#17541,#17393,#17350,#17300,#17260,#17214,#17174,#17128,#17088,#17026,#16983,#9346,#9263),#9265);
#19823= IFCRELDEFINESBYPROPERTIES('2eWeTi1v1EiwfffmqtmuD_',#5,$,$,(#17686,#17678,#17670,#17646,#17638,#17630,#17600,#17592,#17584,#17559,#17550,#17541,#17409,#17401,#17393,#17368,#17359,#17350,#17316,#17308,#17300,#17276,#17268,#17260,#17230,#17222,#17214,#17190,#17182,#17174,#17144,#17136,#17128,#17104,#17096,#17088,#17042,#17034,#17026,#17001,#16992,#16983,#9362,#9354,#9346,#9298,#9281,#9263),#9266);
#19824= IFCRELDEFINESBYPROPERTIES('2ivR0tstT5kPOO924UouBr',#5,$,$,(#17686,#17678,#17670,#17646,#17638,#17630,#17600,#17592,#17584,#17559,#17550,#17541,#17409,#17401,#17393,#17368,#17359,#17350,#17316,#17308,#17300,#17276,#17268,#17260,#17230,#17222,#17214,#17190,#17182,#17174,#17144,#17136,#17128,#17104,#17096,#17088,#17042,#17034,#17026,#17001,#16992,#16983,#9362,#9354,#9263),#9270);
#19825= IFCRELDEFINESBYPROPERTIES('3qUPKDhLDCLPEfw7Tcf24b',#5,$,$,(#9348,#9272),#9275);
#19826= IFCRELDEFINESBYPROPERTIES('2iidO$2dn0jxwZYHDsPyWs',#5,$,$,(#17678,#17638,#17592,#17550,#17401,#17359,#17308,#17268,#17222,#17182,#17136,#17096,#17034,#16992,#9354,#9281),#9284);
#19827= IFCRELDEFINESBYPROPERTIES('2Q$avqaC17peAeeyXEqWLo',#5,$,$,(#9346,#9298,#9281),#9287);
#19828= IFCRELDEFINESBYPROPERTIES('292kK77$nFFOBHQAOtb6gS',#5,$,$,(#9356,#9289),#9292);
#19829= IFCRELDEFINESBYPROPERTIES('3PUfmrXrL17wea0YAKVOGr',#5,$,$,(#17686,#17646,#17600,#17559,#17409,#17368,#17316,#17276,#17230,#17190,#17144,#17104,#17042,#17001,#9362,#9298),#9301);
#19830= IFCRELDEFINESBYPROPERTIES('0SAC87Pt96Ceu_c8xdbDnn',#5,$,$,(#9364,#9303),#9306);
#19831= IFCRELDEFINESBYPROPERTIES('2wp61JfLP9nO9f7qO3XxZc',#5,$,$,(#17694,#17654,#17608,#17568,#17417,#17377,#17324,#17284,#17238,#17198,#17152,#17112,#17050,#17010,#9370,#9314),#9317);
#19832= IFCRELDEFINESBYPROPERTIES('2nney$qhnDGAzcBFtLKF9E',#5,$,$,(#17694,#17654,#17608,#17568,#17417,#17377,#17324,#17284,#17238,#17198,#17152,#17112,#17050,#17010,#9370,#9314),#9323);
#19833= IFCRELDEFINESBYPROPERTIES('18yZUJ4iD9c8CVRr2UXk09',#5,$,$,(#17694,#17654,#17608,#17568,#17417,#17377,#17324,#17284,#17238,#17198,#17152,#17112,#17050,#17010,#9370,#9314),#9327);
#19834= IFCRELDEFINESBYPROPERTIES('0ZrJ_ubj5FYRR4dcug9htU',#5,$,$,(#9335),#9338);
#19835= IFCRELDEFINESBYPROPERTIES('29n8tWRIL62BU45xB7YJQB',#5,$,$,(#9379),#9384);
#19836= IFCRELDEFINESBYPROPERTIES('3_TJ_fYjHC5PmNyq$ouW5i',#5,$,$,(#9379),#9397);
#19837= IFCRELDEFINESBYPROPERTIES('2oPYJsU6LF68GrXsN0wY2p',#5,$,$,(#9379),#9402);
#19838= IFCRELDEFINESBYPROPERTIES('06KQzBNA59COofVmE5NAZb',#5,$,$,(#9441),#9444);
#19839= IFCRELDEFINESBYPROPERTIES('2fHSDO9qvCIAw4mChbY7Im',#5,$,$,(#9441),#9446);
#19840= IFCRELDEFINESBYPROPERTIES('3nIQxK17H8HP1pUzFztTTd',#5,$,$,(#9500,#9452),#9454);
#19841= IFCRELDEFINESBYPROPERTIES('1YSFh2bvz5l9_Grqya6LEl',#5,$,$,(#9452),#9456);
#19842= IFCRELDEFINESBYPROPERTIES('1DvLPAJnT1WgAgJokWHfdn',#5,$,$,(#9452),#9461);
#19843= IFCRELDEFINESBYPROPERTIES('0300KQpAv1hAcLUIJpFxWQ',#5,$,$,(#9467),#9468);
#19844= IFCRELDEFINESBYPROPERTIES('0rc4XOn6fDdASy18UhOZ66',#5,$,$,(#9467),#9474);
#19845= IFCRELDEFINESBYPROPERTIES('05LWQkSSD2ERj2WNnMMyPn',#5,$,$,(#9467),#9480);
#19846= IFCRELDEFINESBYPROPERTIES('1gcf2mgMz57wcqCj686Tcd',#5,$,$,(#9512,#9486),#9487);
#19847= IFCRELDEFINESBYPROPERTIES('3sAlfttU5EGgzclEViWdQR',#5,$,$,(#9486),#9488);
#19848= IFCRELDEFINESBYPROPERTIES('12$ozHHRP0$ubliS8OQA2D',#5,$,$,(#9486),#9494);
#19849= IFCRELDEFINESBYPROPERTIES('0iMArCdg5DXgq8RtNIFAiz',#5,$,$,(#9500),#9501);
#19850= IFCRELDEFINESBYPROPERTIES('0UCQljcu5CohPAaktTonZP',#5,$,$,(#9500),#9506);
#19851= IFCRELDEFINESBYPROPERTIES('0Y4i213wj7ew4wbHS4dkkK',#5,$,$,(#9512),#9513);
#19852= IFCRELDEFINESBYPROPERTIES('1m3o1XKEH9Z8Zt8czPhuLk',#5,$,$,(#9512),#9519);
#19853= IFCRELDEFINESBYPROPERTIES('253sQU0U9BShAVP49Qbb8Y',#5,$,$,(#9521),#9523);
#19854= IFCRELDEFINESBYPROPERTIES('11XrWaulDE1Q69v8Ij1MN5',#5,$,$,(#9534),#9544);
#19855= IFCRELDEFINESBYPROPERTIES('2hgfEXRiH0Mg4SQ1cmK_OA',#5,$,$,(#9534),#9550);
#19856= IFCRELDEFINESBYPROPERTIES('0DCXf7qkjDruxR_PYb8gyI',#5,$,$,(#9558),#9560);
#19857= IFCRELDEFINESBYPROPERTIES('02l_yAHtvDAhikbE54Cn2J',#5,$,$,(#9558),#9563);
#19858= IFCRELDEFINESBYPROPERTIES('0ozyKnqhr6QhqkfaNL37O$',#5,$,$,(#9571),#9574);
#19859= IFCRELDEFINESBYPROPERTIES('3IxpxCHgXBkRAW4X2Ppraw',#5,$,$,(#9582),#9584);
#19860= IFCRELDEFINESBYPROPERTIES('1YB12qJBL4CO9J_dA5eZPq',#5,$,$,(#9592),#9595);
#19861= IFCRELDEFINESBYPROPERTIES('3OayWZU3fEGg4NA9iHm1o$',#5,$,$,(#9603),#9606);
#19862= IFCRELDEFINESBYPROPERTIES('2eZYj1h3v3nPLgqrG2Cnsx',#5,$,$,(#9614),#9617);
#19863= IFCRELDEFINESBYPROPERTIES('0OVONEI8j3QQ_lq8ZRses$',#5,$,$,(#9614),#9620);
#19864= IFCRELDEFINESBYPROPERTIES('12tBqSBwrAXw3dpxrpprWb',#5,$,$,(#9628),#9632);
#19865= IFCRELDEFINESBYPROPERTIES('16omi8L_HBkP2w3Sx8lll_',#5,$,$,(#9640),#9643);
#19866= IFCRELDEFINESBYPROPERTIES('1foTvc3pz53hoblRjhWmpo',#5,$,$,(#9651),#9654);
#19867= IFCRELDEFINESBYPROPERTIES('0Zj1g5DsX0_Pqy_e8ctXoM',#5,$,$,(#9662),#9663);
#19868= IFCRELDEFINESBYPROPERTIES('1HXXYw0WzEsA0F1gjnvQBP',#5,$,$,(#9662),#9666);
#19869= IFCRELDEFINESBYPROPERTIES('0rRq0k3rz3HPCAw4uWTWwc',#5,$,$,(#9674),#9675);
#19870= IFCRELDEFINESBYPROPERTIES('3o7SNGEhb5fAqy2M8IWkXk',#5,$,$,(#9674),#9678);
#19871= IFCRELDEFINESBYPROPERTIES('2j5ZTiEHbFi8OJcTb3bqrV',#5,$,$,(#9674),#9683);
#19872= IFCRELDEFINESBYPROPERTIES('1rKj$N68H3KROWYH9rUyMh',#5,$,$,(#9685),#9694);
#19873= IFCRELDEFINESBYPROPERTIES('1ndiXFUJD9WBxnUR$0BnZr',#5,$,$,(#9685),#9696);
#19874= IFCRELDEFINESBYPROPERTIES('0jXq7CQ8jAwxWKYEt4Ns1D',#5,$,$,(#9714),#9725);
#19875= IFCRELDEFINESBYPROPERTIES('3kgujjWunF5hgEKdsbQd3y',#5,$,$,(#9714),#9740);
#19876= IFCRELDEFINESBYPROPERTIES('2byabEY0v28uKkMzd4XsFl',#5,$,$,(#9714),#9745);
#19877= IFCRELDEFINESBYPROPERTIES('2HMhP1gKzBPgEvElWVwWQc',#5,$,$,(#9778),#9783);
#19878= IFCRELDEFINESBYPROPERTIES('3KH$2IjhL70eyuTyXcVEse',#5,$,$,(#9778),#9785);
#19879= IFCRELDEFINESBYPROPERTIES('0FcgehKgnE9AeBFgu0bmAa',#5,$,$,(#9791),#9793);
#19880= IFCRELDEFINESBYPROPERTIES('3KBGruOmv8Hh5ISTbw7nwx',#5,$,$,(#9791),#9806);
#19881= IFCRELDEFINESBYPROPERTIES('0mfZzScXPCBxlA8Mp5ugMa',#5,$,$,(#12046,#9791),#9812);
#19882= IFCRELDEFINESBYPROPERTIES('1tC3XgkX57d9ev07PU9V1f',#5,$,$,(#9828),#9832);
#19883= IFCRELDEFINESBYPROPERTIES('0dZE1hLczDTg_$I_hwoFF7',#5,$,$,(#9828),#9846);
#19884= IFCRELDEFINESBYPROPERTIES('1eBdQhl5PDPOTaf2pLlTR8',#5,$,$,(#16332,#16173,#15975,#15927,#15878,#15833,#15786,#9828),#9851);
#19885= IFCRELDEFINESBYPROPERTIES('0WKAUnb3H9euEkTdsb0MSX',#5,$,$,(#9853),#9856);
#19886= IFCRELDEFINESBYPROPERTIES('2N16MrF8v52e_QyT8TdAmy',#5,$,$,(#9853),#9858);
#19887= IFCRELDEFINESBYPROPERTIES('3_rSFlYbvEKwMqlApiVREp',#5,$,$,(#9903),#9907);
#19888= IFCRELDEFINESBYPROPERTIES('26FleeUaHAwRUWFJN0KpvA',#5,$,$,(#9903),#9921);
#19889= IFCRELDEFINESBYPROPERTIES('0mWXIvQdr2JO1SWa2glgSx',#5,$,$,(#9903),#9926);
#19890= IFCRELDEFINESBYPROPERTIES('18ve3eCdP7r9iEo7o8uqfk',#5,$,$,(#9971),#9974);
#19891= IFCRELDEFINESBYPROPERTIES('2yTT3BMdfEIvPIKpz$EuIf',#5,$,$,(#9971),#9985);
#19892= IFCRELDEFINESBYPROPERTIES('2a77eKrRzCRPSbNPwmnXHS',#5,$,$,(#9971),#9990);
#19893= IFCRELDEFINESBYPROPERTIES('2zuwbSB5DBlRhQ7sDqvOr$',#5,$,$,(#10035),#10038);
#19894= IFCRELDEFINESBYPROPERTIES('22f_wirNj5PALTcLCwatOV',#5,$,$,(#10035),#10049);
#19895= IFCRELDEFINESBYPROPERTIES('32MehlLLD97BWXEOntLISg',#5,$,$,(#10035),#10054);
#19896= IFCRELDEFINESBYPROPERTIES('2FxBTnZdD4chXoMYPq$i8t',#5,$,$,(#10216),#10217);
#19897= IFCRELDEFINESBYPROPERTIES('0OvXJWHgX8K99tybOyRSLa',#5,$,$,(#10501,#10216),#10229);
#19898= IFCRELDEFINESBYPROPERTIES('2fqLqzqIX5c9revu$50QhB',#5,$,$,(#11717,#11499,#10501,#10216),#10234);
#19899= IFCRELDEFINESBYPROPERTIES('3SY2MOsQ1FKeIUyIWP0iOv',#5,$,$,(#10292),#10297);
#19900= IFCRELDEFINESBYPROPERTIES('0lKhezrdz09RjPu61IUu0b',#5,$,$,(#10292),#10310);
#19901= IFCRELDEFINESBYPROPERTIES('2LXZtnT5vD0eI0eaPjBTQV',#5,$,$,(#10292),#10315);
#19902= IFCRELDEFINESBYPROPERTIES('31C$_4obv8o9hsybrLhCrW',#5,$,$,(#10501),#10502);
#19903= IFCRELDEFINESBYPROPERTIES('0LwAyq8_P2SP43IWtnaEsJ',#5,$,$,(#10528),#10530);
#19904= IFCRELDEFINESBYPROPERTIES('246rGAaq1Fg8fM8AxMMSPC',#5,$,$,(#10528),#10536);
#19905= IFCRELDEFINESBYPROPERTIES('0b_AUiXjX7O8o2zQSAgtnz',#5,$,$,(#10528),#10541);
#19906= IFCRELDEFINESBYPROPERTIES('2PwusKbkfEyQ5iy420zb2n',#5,$,$,(#10621,#10609,#10596,#10584,#10572,#10553),#10554);
#19907= IFCRELDEFINESBYPROPERTIES('0eW111gub10B0f52y81I$B',#5,$,$,(#10621,#10609,#10596,#10584,#10572,#10553),#10560);
#19908= IFCRELDEFINESBYPROPERTIES('3uuksLhozDPAj97OWBFDA7',#5,$,$,(#10611,#10598),#10599);
#19909= IFCRELDEFINESBYPROPERTIES('0RneVM27D4LQCXP4VxWukU',#5,$,$,(#10651),#10654);
#19910= IFCRELDEFINESBYPROPERTIES('1lGaHkh0PBdBoqXadZiqeK',#5,$,$,(#10651),#10656);
#19911= IFCRELDEFINESBYPROPERTIES('1PP4r$2ObF399mGp7SEYf_',#5,$,$,(#10745,#10667),#10672);
#19912= IFCRELDEFINESBYPROPERTIES('1nmHNgL6DB3eVIi0qT$1uP',#5,$,$,(#10745,#10667),#10680);
#19913= IFCRELDEFINESBYPROPERTIES('3sNwhdg2D0yfJhZAh4qrKa',#5,$,$,(#10745,#10667),#10684);
#19914= IFCRELDEFINESBYPROPERTIES('0rMtWQX3HCzv2M2yOE4WFy',#5,$,$,(#10751,#10692),#10695);
#19915= IFCRELDEFINESBYPROPERTIES('0HQVYG7gz9XwpwyqhI$fJ1',#5,$,$,(#10692),#10706);
#19916= IFCRELDEFINESBYPROPERTIES('2HWbwRitbAQxcsjm7M_YRG',#5,$,$,(#10692),#10711);
#19917= IFCRELDEFINESBYPROPERTIES('2XRys_8W1Bjxr8p_g8bhIJ',#5,$,$,(#10751),#10753);
#19918= IFCRELDEFINESBYPROPERTIES('1m7qrT7eDEuOGaJod8INrV',#5,$,$,(#10751),#10756);
#19919= IFCRELDEFINESBYPROPERTIES('0iy1svek9CO9$gv5KULzsL',#5,$,$,(#10769),#10772);
#19920= IFCRELDEFINESBYPROPERTIES('3DoUjboRX4OQ4t5kWZ4E1V',#5,$,$,(#10769),#10784);
#19921= IFCRELDEFINESBYPROPERTIES('1wKAPFCiX1jPGurQX88WFe',#5,$,$,(#10769),#10789);
#19922= IFCRELDEFINESBYPROPERTIES('1ww2mAbUbDbxfbLz5b6eJS',#5,$,$,(#10799),#10802);
#19923= IFCRELDEFINESBYPROPERTIES('2MSSiSMnr5heK8LPi7h4$n',#5,$,$,(#10799),#10814);
#19924= IFCRELDEFINESBYPROPERTIES('15x7sKcgr1KeOQXgTbzw9c',#5,$,$,(#10799),#10819);
#19925= IFCRELDEFINESBYPROPERTIES('2RAzQNJmj2sg5kkMG$ECd9',#5,$,$,(#11160,#10834),#10835);
#19926= IFCRELDEFINESBYPROPERTIES('0RExu59NPApfqcLX8470yE',#5,$,$,(#10834),#10846);
#19927= IFCRELDEFINESBYPROPERTIES('1VVn3l779AFQzYfyi2BaKe',#5,$,$,(#10834),#10852);
#19928= IFCRELDEFINESBYPROPERTIES('14zWArr_nAjRP20eKK08KT',#5,$,$,(#10883),#10887);
#19929= IFCRELDEFINESBYPROPERTIES('0zugng5K11rPPkA$bXmtv2',#5,$,$,(#10883),#10889);
#19930= IFCRELDEFINESBYPROPERTIES('1mYOIdHVD5R8ihWMrgoORX',#5,$,$,(#10895),#10897);
#19931= IFCRELDEFINESBYPROPERTIES('1CsrszPu58e9fO302Ed60w',#5,$,$,(#10895),#10904);
#19932= IFCRELDEFINESBYPROPERTIES('1WDk7i7XDBbRQ4gXVgcN4q',#5,$,$,(#10895),#10909);
#19933= IFCRELDEFINESBYPROPERTIES('0G0h4zXTf8mBQbmlagYgZk',#5,$,$,(#10911),#10915);
#19934= IFCRELDEFINESBYPROPERTIES('27nNG4V817LOG2RIKo7_6W',#5,$,$,(#10911),#10917);
#19935= IFCRELDEFINESBYPROPERTIES('3Cag$RA8r1vfVqtfXdN8gf',#5,$,$,(#10925),#10926);
#19936= IFCRELDEFINESBYPROPERTIES('2FBzc$HELEJBG3xTOAx7mY',#5,$,$,(#10925),#10929);
#19937= IFCRELDEFINESBYPROPERTIES('12WVa5xEz3M9Cjb_G0z0jy',#5,$,$,(#10925),#10934);
#19938= IFCRELDEFINESBYPROPERTIES('3zb7117oL1Z8FEK7kFfB8c',#5,$,$,(#11183,#10945),#10946);
#19939= IFCRELDEFINESBYPROPERTIES('28PVxD5xrFkfSMqbr7daFU',#5,$,$,(#10945),#10955);
#19940= IFCRELDEFINESBYPROPERTIES('2_B$CObBT17Ol_0SUZ3JBR',#5,$,$,(#10945),#10960);
#19941= IFCRELDEFINESBYPROPERTIES('2hykRZ5yX3tOBVuDdX$AaL',#5,$,$,(#10990),#10993);
#19942= IFCRELDEFINESBYPROPERTIES('0Xz$8_LjD1hv1TPDATBcap',#5,$,$,(#11129,#10999),#11001);
#19943= IFCRELDEFINESBYPROPERTIES('0QS02Gt$rDZv2fwxV4L5lc',#5,$,$,(#10999),#11003);
#19944= IFCRELDEFINESBYPROPERTIES('1sTr$_kijBSw04aJsubb1b',#5,$,$,(#10999),#11006);
#19945= IFCRELDEFINESBYPROPERTIES('06eGa3$m19Ux3vtVVzFe14',#5,$,$,(#11144,#11012),#11013);
#19946= IFCRELDEFINESBYPROPERTIES('0hq7WhPm1Engyk7gT6ye7M',#5,$,$,(#11012),#11022);
#19947= IFCRELDEFINESBYPROPERTIES('0AkyPXfO15hwsHwwPgTWya',#5,$,$,(#11012),#11027);
#19948= IFCRELDEFINESBYPROPERTIES('1QGqp70_v7XAfjpSpiY3WM',#5,$,$,(#11029),#11033);
#19949= IFCRELDEFINESBYPROPERTIES('37Om$IbUT0KuEkLGWzWIKC',#5,$,$,(#11029),#11035);
#19950= IFCRELDEFINESBYPROPERTIES('0OriTekDj8fReXCXz$bBcc',#5,$,$,(#11048),#11049);
#19951= IFCRELDEFINESBYPROPERTIES('0gLH7dL7z3Ce9aTvWCNIVG',#5,$,$,(#11048),#11058);
#19952= IFCRELDEFINESBYPROPERTIES('2N11o4WlnFhR7arQKL8aBh',#5,$,$,(#11048),#11063);
#19953= IFCRELDEFINESBYPROPERTIES('31O1AUM257QhsGDmhiUTDo',#5,$,$,(#11065),#11069);
#19954= IFCRELDEFINESBYPROPERTIES('2V3R4W0OT0W9I$8qRAEDXw',#5,$,$,(#11079),#11080);
#19955= IFCRELDEFINESBYPROPERTIES('1rNPilRSf9MuwDAFPMJoiL',#5,$,$,(#11079),#11090);
#19956= IFCRELDEFINESBYPROPERTIES('31Kpci4qX24QuWntZiDJKq',#5,$,$,(#11079),#11095);
#19957= IFCRELDEFINESBYPROPERTIES('1WLQMMs1P4QAOtsZLikDse',#5,$,$,(#11129),#11135);
#19958= IFCRELDEFINESBYPROPERTIES('15ShSQ9494qO1Kwvddcu6t',#5,$,$,(#11129),#11138);
#19959= IFCRELDEFINESBYPROPERTIES('1C1A2is2f2seRilWMj8auK',#5,$,$,(#11144),#11145);
#19960= IFCRELDEFINESBYPROPERTIES('22XbNUY$P0iwqxKlwSvAaX',#5,$,$,(#11144),#11147);
#19961= IFCRELDEFINESBYPROPERTIES('2BgHsQHTD16gf6kvJ4pxtB',#5,$,$,(#11160),#11168);
#19962= IFCRELDEFINESBYPROPERTIES('3x2WJVThD6cfsc$7QmHfRy',#5,$,$,(#11160),#11173);
#19963= IFCRELDEFINESBYPROPERTIES('3BhYtv6Cz8HwaeybS9FzEj',#5,$,$,(#11183),#11192);
#19964= IFCRELDEFINESBYPROPERTIES('3jyeNHkLH8jRy6I$zWmZl2',#5,$,$,(#11183),#11197);
#19965= IFCRELDEFINESBYPROPERTIES('2GGeFVhf12$RhqNPsXJgtw',#5,$,$,(#11244),#11248);
#19966= IFCRELDEFINESBYPROPERTIES('37UGfCHt11hhEtcqK1ZuC4',#5,$,$,(#11254),#11255);
#19967= IFCRELDEFINESBYPROPERTIES('2mCe5UCqP9OBp_5aWkGTx8',#5,$,$,(#11254),#11265);
#19968= IFCRELDEFINESBYPROPERTIES('3Z23wg5y99Uu38JZhlTj9w',#5,$,$,(#11254),#11270);
#19969= IFCRELDEFINESBYPROPERTIES('3S0AWsT09BAfIpc1djVyjO',#5,$,$,(#15360,#15160,#15081,#11312),#11315);
#19970= IFCRELDEFINESBYPROPERTIES('3R$6XXAcf9og9mmkz9LF0d',#5,$,$,(#16017,#15360,#15258,#15207,#15160,#15081,#11312),#11317);
#19971= IFCRELDEFINESBYPROPERTIES('2BnSD6M89BRenONenDzX0j',#5,$,$,(#15366,#15265,#15166,#15087,#11331),#11336);
#19972= IFCRELDEFINESBYPROPERTIES('1v0tE1ltfANuapJxnMMmsW',#5,$,$,(#11331),#11349);
#19973= IFCRELDEFINESBYPROPERTIES('3CLknozRb5SBHfnXxn_NCm',#5,$,$,(#11331),#11354);
#19974= IFCRELDEFINESBYPROPERTIES('11IddKkNf0PQJIZZzpjUkR',#5,$,$,(#11362),#11369);
#19975= IFCRELDEFINESBYPROPERTIES('3BhBauchP3R8z8h_x7EHy3',#5,$,$,(#11362),#11374);
#19976= IFCRELDEFINESBYPROPERTIES('3CV80$qbn3uekEK63segXQ',#5,$,$,(#11384),#11386);
#19977= IFCRELDEFINESBYPROPERTIES('1Y9jozsa1DwP5skI5mOyGj',#5,$,$,(#11384),#11398);
#19978= IFCRELDEFINESBYPROPERTIES('1dGmEjw853jgjBeW7Ydn5T',#5,$,$,(#11384),#11403);
#19979= IFCRELDEFINESBYPROPERTIES('2m3fLP$Cv16vbw3TBaUAWl',#5,$,$,(#15386,#15283,#15186,#15128,#11413),#11416);
#19980= IFCRELDEFINESBYPROPERTIES('2A312PlP5AswQumM7pWG7c',#5,$,$,(#11413),#11428);
#19981= IFCRELDEFINESBYPROPERTIES('2QM5qsgH597gUXNgnpuJnC',#5,$,$,(#11413),#11433);
#19982= IFCRELDEFINESBYPROPERTIES('2Rm55NblP77hAg6sqASBc9',#5,$,$,(#11470),#11474);
#19983= IFCRELDEFINESBYPROPERTIES('2Ers$7EIr6CA7Z6XXe8qlu',#5,$,$,(#11470),#11488);
#19984= IFCRELDEFINESBYPROPERTIES('38tsB1GIT2XBX$UG7R0oTe',#5,$,$,(#11470),#11493);
#19985= IFCRELDEFINESBYPROPERTIES('30GKZQIxDE5ArxxIVVktUY',#5,$,$,(#11717,#11499),#11500);
#19986= IFCRELDEFINESBYPROPERTIES('0E9gRu$Hr0a9gs7xlQe964',#5,$,$,(#11717,#11499),#11501);
#19987= IFCRELDEFINESBYPROPERTIES('2adv2FOj51vOlP4rLGmC1g',#5,$,$,(#11737),#11739);
#19988= IFCRELDEFINESBYPROPERTIES('3hLzrRCNX7QOOzN4qXVLtV',#5,$,$,(#11737),#11752);
#19989= IFCRELDEFINESBYPROPERTIES('0ESQlxe3rCFxgEfultJb2V',#5,$,$,(#11737),#11757);
#19990= IFCRELDEFINESBYPROPERTIES('2svuF0Kez2guktgJ3YRj0o',#5,$,$,(#11796),#11798);
#19991= IFCRELDEFINESBYPROPERTIES('2OkNCJZgv5nxbu0lIyuCRr',#5,$,$,(#11796),#11811);
#19992= IFCRELDEFINESBYPROPERTIES('0pSYHBX$v45BhwxCDCkwJr',#5,$,$,(#11796),#11816);
#19993= IFCRELDEFINESBYPROPERTIES('238AaufBP6f990loxy1ukD',#5,$,$,(#11849),#11851);
#19994= IFCRELDEFINESBYPROPERTIES('2vZVUoPwnCfe9F7Kwh5Qip',#5,$,$,(#11849),#11865);
#19995= IFCRELDEFINESBYPROPERTIES('349eOY2nHB8e9WNwmOZ96f',#5,$,$,(#11849),#11870);
#19996= IFCRELDEFINESBYPROPERTIES('3jUC$4FWrAUBdLmpEqVTBv',#5,$,$,(#11903),#11905);
#19997= IFCRELDEFINESBYPROPERTIES('0HFMEn57b43eJWrA_7hPUC',#5,$,$,(#11903),#11919);
#19998= IFCRELDEFINESBYPROPERTIES('0n_gxTqqLB4vG9$vNREuT0',#5,$,$,(#11903),#11924);
#19999= IFCRELDEFINESBYPROPERTIES('1m9Kz4tQf0XvRwbHq3BORg',#5,$,$,(#11930),#11931);
#20000= IFCRELDEFINESBYPROPERTIES('2O7P6lITfDS84OOIEiTjHQ',#5,$,$,(#11930),#11932);
#20001= IFCRELDEFINESBYPROPERTIES('0odRLEjpDA5fTCrCC8jVzQ',#5,$,$,(#11930),#11937);
#20002= IFCRELDEFINESBYPROPERTIES('17q2ByhkHFdQXi$xUXZLub',#5,$,$,(#11943),#11944);
#20003= IFCRELDEFINESBYPROPERTIES('0yT1kvqQXEC8pnp7aqJRZL',#5,$,$,(#11952),#11963);
#20004= IFCRELDEFINESBYPROPERTIES('2XIJmAWsz3oe5VgjZN63d$',#5,$,$,(#11952),#11969);
#20005= IFCRELDEFINESBYPROPERTIES('0o2oubYLn4hO5842P6nAWg',#5,$,$,(#11984),#11986);
#20006= IFCRELDEFINESBYPROPERTIES('2kIGFe7Hb4KR4PsTeZhrFT',#5,$,$,(#11984),#11999);
#20007= IFCRELDEFINESBYPROPERTIES('0zTQUQmn158ukl6rbAecmC',#5,$,$,(#11984),#12005);
#20008= IFCRELDEFINESBYPROPERTIES('3WJbpJwY5D3xNbwIppHo4o',#5,$,$,(#12020),#12022);
#20009= IFCRELDEFINESBYPROPERTIES('2TgYE5klbDXvVUPfhUhOkz',#5,$,$,(#12020),#12034);
#20010= IFCRELDEFINESBYPROPERTIES('2YNOwnzSf7Cv0PByr9yeh5',#5,$,$,(#12020),#12040);
#20011= IFCRELDEFINESBYPROPERTIES('2m9p3lqsH9cvOK_D8$ghaS',#5,$,$,(#12046),#12047);
#20012= IFCRELDEFINESBYPROPERTIES('10y5WrYML9uhxahX9Dkpn6',#5,$,$,(#12046),#12048);
#20013= IFCRELDEFINESBYPROPERTIES('26Ko7dmaDE0vk6H3wRxFVo',#5,$,$,(#12069),#12076);
#20014= IFCRELDEFINESBYPROPERTIES('2W$xBeQGrFiurBVnhvyjVn',#5,$,$,(#12069),#12089);
#20015= IFCRELDEFINESBYPROPERTIES('1i3uCIheb8a8137b61z7_9',#5,$,$,(#12069),#12094);
#20016= IFCRELDEFINESBYPROPERTIES('20ok4moV51M8jRmGLNLY6j',#5,$,$,(#12109),#12114);
#20017= IFCRELDEFINESBYPROPERTIES('1V6WlV46r4oQpK21jhmhqL',#5,$,$,(#12109),#12127);
#20018= IFCRELDEFINESBYPROPERTIES('35nbUpIiH81OWHPTpIyFI3',#5,$,$,(#12109),#12132);
#20019= IFCRELDEFINESBYPROPERTIES('0PIMWkiQjDv9BEwh29KEq9',#5,$,$,(#12153),#12155);
#20020= IFCRELDEFINESBYPROPERTIES('2fRzJcD7DDxv0mJcsPnCCz',#5,$,$,(#12153),#12166);
#20021= IFCRELDEFINESBYPROPERTIES('0L3CdY1aL2JBzeYOBEyhxb',#5,$,$,(#12153),#12171);
#20022= IFCRELDEFINESBYPROPERTIES('1AVShcI2f7QvNhF9PmLL90',#5,$,$,(#12181),#12183);
#20023= IFCRELDEFINESBYPROPERTIES('2FqAF$Mw10sAAkTYuvt72W',#5,$,$,(#12181),#12194);
#20024= IFCRELDEFINESBYPROPERTIES('1wiE0UzdvBPxHUZvpaEYmB',#5,$,$,(#12181),#12199);
#20025= IFCRELDEFINESBYPROPERTIES('1VX0kzbrHDqAKSyuqxAJre',#5,$,$,(#12335),#12337);
#20026= IFCRELDEFINESBYPROPERTIES('1w3bbA7vP1CwArjU85xxWu',#5,$,$,(#12335),#12349);
#20027= IFCRELDEFINESBYPROPERTIES('0jlqKOfYL9yBFJ2AlK54Ph',#5,$,$,(#12335),#12354);
#20028= IFCRELDEFINESBYPROPERTIES('3sce6D7LH9xfEzKtlGEkbG',#5,$,$,(#12514,#12508,#12502,#12496,#12480),#12484);
#20029= IFCRELDEFINESBYPROPERTIES('2SJQ_pS6r0wu2pEnoOTnhk',#5,$,$,(#12514,#12508,#12502,#12496,#12480),#12490);
#20030= IFCRELDEFINESBYPROPERTIES('1XBwpCpN9DYva97wz8agra',#5,$,$,(#12529),#12531);
#20031= IFCRELDEFINESBYPROPERTIES('1ihpWo$_HAQwyV2Vog7mQh',#5,$,$,(#12529),#12538);
#20032= IFCRELDEFINESBYPROPERTIES('0a4swZe5P6UO8kDKLan6as',#5,$,$,(#12529),#12543);
#20033= IFCRELDEFINESBYPROPERTIES('2idGc_L8j2yBK0$jUZ5pLN',#5,$,$,(#12675),#12676);
#20034= IFCRELDEFINESBYPROPERTIES('3uXjDVv6n9b92rOoD2uPaN',#5,$,$,(#15048,#14995,#14225,#14137,#14097,#14069,#14041,#13384,#13228,#12733),#12735);
#20035= IFCRELDEFINESBYPROPERTIES('3oPVc$fYb6duEcF782hwzX',#5,$,$,(#13234,#12741),#12747);
#20036= IFCRELDEFINESBYPROPERTIES('1yYNzAHA11XgEYq76YQlUy',#5,$,$,(#12741),#12751);
#20037= IFCRELDEFINESBYPROPERTIES('1YK1nZnK9Ew9irdnn$IfxQ',#5,$,$,(#13560,#13534,#13402,#13243,#12761),#12762);
#20038= IFCRELDEFINESBYPROPERTIES('1wMeP9GCH4deP15nq3_bfn',#5,$,$,(#13243,#12761),#12768);
#20039= IFCRELDEFINESBYPROPERTIES('29n2P$GtzFyPnrGAl45eO_',#5,$,$,(#12761),#12774);
#20040= IFCRELDEFINESBYPROPERTIES('1QVA02Jfz8MP7xvhSvoxk9',#5,$,$,(#13566,#13545,#13413,#13252,#12780),#12781);
#20041= IFCRELDEFINESBYPROPERTIES('32_pLpfv94s88RV3xHMSXl',#5,$,$,(#13566,#13545,#13252,#12780),#12783);
#20042= IFCRELDEFINESBYPROPERTIES('2jkoSD8cn6AfXrnBoSvGPt',#5,$,$,(#12780),#12789);
#20043= IFCRELDEFINESBYPROPERTIES('18X6rxPs54NPXfkTlQ3GRM',#5,$,$,(#13420,#13257,#12791),#12794);
#20044= IFCRELDEFINESBYPROPERTIES('0r1TLKeTT0V8ICja93GtGY',#5,$,$,(#16280,#16249,#16240,#16231,#16222,#16213,#16204,#16195,#15686,#15678,#15670,#15662,#15642,#15608,#15596,#15583,#15559,#15551,#15543,#15527,#15519,#15511,#15491,#15483,#15475,#15427,#15411,#15388,#13436,#13428,#13420,#13273,#13265,#13257,#12860,#12835,#12791),#12796);
#20045= IFCRELDEFINESBYPROPERTIES('0f9nmL$zfEjgnXbUfKLeK6',#5,$,$,(#13426,#13263,#12810),#12814);
#20046= IFCRELDEFINESBYPROPERTIES('0ydK9mPi14g8Cn8Ktuij1f',#5,$,$,(#13426,#13263,#12810),#12828);
#20047= IFCRELDEFINESBYPROPERTIES('3b4SF0B$1DxQ__uQhsGyqY',#5,$,$,(#13426,#13263,#12810),#12833);
#20048= IFCRELDEFINESBYPROPERTIES('1BrLU0t9HEeR1rBautScEF',#5,$,$,(#13428,#13265,#12835),#12838);
#20049= IFCRELDEFINESBYPROPERTIES('0aY7ZoR$T04BYc8xgUlne$',#5,$,$,(#13434,#13271,#12844),#12846);
#20050= IFCRELDEFINESBYPROPERTIES('02Sy_tLg1BmeQIwQVnK$Wd',#5,$,$,(#13434,#13271,#12844),#12854);
#20051= IFCRELDEFINESBYPROPERTIES('06$6ySlB53xgPCKV1P2m0z',#5,$,$,(#13434,#13271,#12844),#12858);
#20052= IFCRELDEFINESBYPROPERTIES('3Eza0QMXf12frij4XVaMNd',#5,$,$,(#13436,#13273,#12860),#12864);
#20053= IFCRELDEFINESBYPROPERTIES('020kb9asHFt9DuTXdmRfXe',#5,$,$,(#13442,#13279,#12876),#12879);
#20054= IFCRELDEFINESBYPROPERTIES('0JmuymE5vCwRyeJ$Az1Qw5',#5,$,$,(#13442,#13279,#12876),#12892);
#20055= IFCRELDEFINESBYPROPERTIES('0CtiUKaVz9ieBXQfbvrvoM',#5,$,$,(#13442,#13279,#12876),#12897);
#20056= IFCRELDEFINESBYPROPERTIES('36QY1v4MP4N857KfiU8bZ1',#5,$,$,(#13444,#13281,#12899),#12903);
#20057= IFCRELDEFINESBYPROPERTIES('2tNQCAQavFrfQOtVr7aW$k',#5,$,$,(#16303,#16258,#15621,#15571,#15535,#15499,#15446,#13444,#13281,#12899),#12905);
#20058= IFCRELDEFINESBYPROPERTIES('0iHXGDTWH5J9MzI2U9Mab6',#5,$,$,(#13456,#13450,#13293,#13287,#12953,#12921),#12926);
#20059= IFCRELDEFINESBYPROPERTIES('1v3Pr6xyH3kA0Ui4FY$iGY',#5,$,$,(#13456,#13450,#13293,#13287,#12953,#12921),#12940);
#20060= IFCRELDEFINESBYPROPERTIES('3UFDzn04r62v7Ta2nNsuL_',#5,$,$,(#13456,#13450,#13293,#13287,#12953,#12921),#12947);
#20061= IFCRELDEFINESBYPROPERTIES('1sLBRPVW14iBhaBo2gvswb',#5,$,$,(#13462,#13299,#12964),#12968);
#20062= IFCRELDEFINESBYPROPERTIES('0adLZPS9D7ufUctUeLOXwM',#5,$,$,(#16321,#16278,#15640,#15472,#13462,#13299,#12964),#12979);
#20063= IFCRELDEFINESBYPROPERTIES('3CPCczSxrCegh_u_T5a1Nq',#5,$,$,(#16321,#16278,#15640,#15579,#15541,#15507,#15472,#13462,#13299,#12964),#12984);
#20064= IFCRELDEFINESBYPROPERTIES('2hqznLxTrD4OGBrVlHcpcx',#5,$,$,(#13474,#13311,#13005),#13009);
#20065= IFCRELDEFINESBYPROPERTIES('3HPSHDtvXDb9BEa8zA0RQ7',#5,$,$,(#13474,#13311,#13005),#13021);
#20066= IFCRELDEFINESBYPROPERTIES('0FHzL0wtr8MP$T5d5ajQ2n',#5,$,$,(#13474,#13311,#13005),#13026);
#20067= IFCRELDEFINESBYPROPERTIES('28kDWvB5T1Ie8APOoPrGrx',#5,$,$,(#13486,#13323,#13045),#13049);
#20068= IFCRELDEFINESBYPROPERTIES('0Os5ycD8nEW9z83AINxnjP',#5,$,$,(#13486,#13323,#13045),#13061);
#20069= IFCRELDEFINESBYPROPERTIES('0cf868ApDEZvnwCb_$z23T',#5,$,$,(#13486,#13323,#13045),#13066);
#20070= IFCRELDEFINESBYPROPERTIES('1bHYZ1ukz5fRG8BJF7W34K',#5,$,$,(#13492,#13329,#13081),#13086);
#20071= IFCRELDEFINESBYPROPERTIES('3XMxsn5B18IwkMsSslFRgh',#5,$,$,(#17761,#17736,#16835,#16618,#13492,#13329,#13081),#13099);
#20072= IFCRELDEFINESBYPROPERTIES('3w3$X1eVD3qAg56Oz2CYyB',#5,$,$,(#13492,#13329,#13081),#13105);
#20073= IFCRELDEFINESBYPROPERTIES('1V0gtwMMj6vusnwI6h2jxy',#5,$,$,(#13505,#13342,#13139),#13145);
#20074= IFCRELDEFINESBYPROPERTIES('2DD1fa8V16Th$zluxV3gJ7',#5,$,$,(#13505,#13342,#13139),#13158);
#20075= IFCRELDEFINESBYPROPERTIES('1ZMrmYPFX89PVNmiCYWe3v',#5,$,$,(#13505,#13342,#13139),#13163);
#20076= IFCRELDEFINESBYPROPERTIES('0kQSsd2H9Cgvcr8tW33dg_',#5,$,$,(#13181),#13184);
#20077= IFCRELDEFINESBYPROPERTIES('20FsG$hNf0Xet9j6$0i3Jl',#5,$,$,(#13181),#13195);
#20078= IFCRELDEFINESBYPROPERTIES('3SgRZ$tH1ASACLy4SR5pg5',#5,$,$,(#13517,#13354,#13181),#13200);
#20079= IFCRELDEFINESBYPROPERTIES('2AHf4SFGvBI9angbWqs2xF',#5,$,$,(#13234),#13237);
#20080= IFCRELDEFINESBYPROPERTIES('0GRVXXrq15cxoftisMLjxl',#5,$,$,(#13243),#13246);
#20081= IFCRELDEFINESBYPROPERTIES('3wDQlOlQPEdgJNcfbV2tQa',#5,$,$,(#13252),#13255);
#20082= IFCRELDEFINESBYPROPERTIES('0MIm1tdXj4DOKhTsl1YsrV',#5,$,$,(#13517,#13354),#13355);
#20083= IFCRELDEFINESBYPROPERTIES('0iloSmzTzDWxFj$5X4wjn4',#5,$,$,(#13517,#13354),#13356);
#20084= IFCRELDEFINESBYPROPERTIES('0LB0PKc4vCRQIH6Y9hFa6b',#5,$,$,(#13390),#13392);
#20085= IFCRELDEFINESBYPROPERTIES('01dtxwtLD5qhwViaUGLDmW',#5,$,$,(#13390),#13396);
#20086= IFCRELDEFINESBYPROPERTIES('0BmJxOqf9CnfMZVdMQPxpR',#5,$,$,(#13402),#13404);
#20087= IFCRELDEFINESBYPROPERTIES('1w9uJCCk14DOnm8JgKOoJO',#5,$,$,(#13402),#13407);
#20088= IFCRELDEFINESBYPROPERTIES('2KGkXyWf16oeI_cAIjphbd',#5,$,$,(#13413),#13414);
#20089= IFCRELDEFINESBYPROPERTIES('01QJxhocr6QAxrwgD5e1qo',#5,$,$,(#13413),#13418);
#20090= IFCRELDEFINESBYPROPERTIES('3aVQhndmH369PCHh5gsUZm',#5,$,$,(#13578,#13572,#13554,#13523),#13524);
#20091= IFCRELDEFINESBYPROPERTIES('3Dr9w0gcjC6xGA92yyMAXO',#5,$,$,(#13578,#13572,#13554,#13523),#13528);
#20092= IFCRELDEFINESBYPROPERTIES('2qXAijcmzBdeEZl$qgMPy7',#5,$,$,(#13560,#13534),#13536);
#20093= IFCRELDEFINESBYPROPERTIES('1d3L3$FSTBDfkepPqbXag0',#5,$,$,(#13560,#13534),#13539);
#20094= IFCRELDEFINESBYPROPERTIES('3sXeg6NBP6nxL3a14JRPqf',#5,$,$,(#13566,#13545),#13548);
#20095= IFCRELDEFINESBYPROPERTIES('3rbXWRfTn8rOs$kD1Y_wwu',#5,$,$,(#13580),#13585);
#20096= IFCRELDEFINESBYPROPERTIES('0ERLOeAeH93ghOOREzz0rq',#5,$,$,(#13580),#13587);
#20097= IFCRELDEFINESBYPROPERTIES('0CpHfJXz54XR4HhYYgYFEp',#5,$,$,(#13604),#13612);
#20098= IFCRELDEFINESBYPROPERTIES('0AnAebD0171utXadIUo7G5',#5,$,$,(#13604),#13627);
#20099= IFCRELDEFINESBYPROPERTIES('2B6h43u5P3sQ1zADmbKLlA',#5,$,$,(#13604),#13631);
#20100= IFCRELDEFINESBYPROPERTIES('3lSM5hA4jEFem0NP5wtSjh',#5,$,$,(#13633),#13637);
#20101= IFCRELDEFINESBYPROPERTIES('1ONRJ3NHbCNwt6b6mvmpFL',#5,$,$,(#13633),#13639);
#20102= IFCRELDEFINESBYPROPERTIES('2pi$TbLiz1bwCd08zImzGc',#5,$,$,(#13654),#13660);
#20103= IFCRELDEFINESBYPROPERTIES('3IA5rSnivDie3rEyRZ5L_2',#5,$,$,(#13654),#13675);
#20104= IFCRELDEFINESBYPROPERTIES('00WpbNFt93JA9X2ROhRt2t',#5,$,$,(#13654),#13679);
#20105= IFCRELDEFINESBYPROPERTIES('2jCGHRW$1Ek8NNGnVBh58Y',#5,$,$,(#13681),#13684);
#20106= IFCRELDEFINESBYPROPERTIES('1UR4GsNSb9GRmq2Aywwy9b',#5,$,$,(#13681),#13686);
#20107= IFCRELDEFINESBYPROPERTIES('0fukeXYUb7T8spTPY_dgju',#5,$,$,(#13704),#13707);
#20108= IFCRELDEFINESBYPROPERTIES('3bm60nJ2jC6uKtv7H$_$57',#5,$,$,(#13704),#13722);
#20109= IFCRELDEFINESBYPROPERTIES('0ZCSAU87z4XAUtE7lpulzy',#5,$,$,(#13704),#13727);
#20110= IFCRELDEFINESBYPROPERTIES('3A8HKN8z5FNRs5yd0fn3pe',#5,$,$,(#15050),#15053);
#20111= IFCRELDEFINESBYPROPERTIES('2aB6vjKnTD1x_Sb9YYlJ2D',#5,$,$,(#15104,#15059),#15061);
#20112= IFCRELDEFINESBYPROPERTIES('2b4PZfkFP5uP67zIYeinrq',#5,$,$,(#15104,#15059),#15063);
#20113= IFCRELDEFINESBYPROPERTIES('1G$XI5qZ59keV_q2isuG4N',#5,$,$,(#15071),#15072);
#20114= IFCRELDEFINESBYPROPERTIES('1IbR0mZxH0$e5IB$v_bRC6',#5,$,$,(#15071),#15074);
#20115= IFCRELDEFINESBYPROPERTIES('0H1$6yhDL90fMCMoUQ$Q7f',#5,$,$,(#16067,#16014,#15331,#15256,#15204,#15156,#15071),#15079);
#20116= IFCRELDEFINESBYPROPERTIES('3oW_gPIvDAOwbefoyc8VGU',#5,$,$,(#15366,#15265,#15166,#15087),#15094);
#20117= IFCRELDEFINESBYPROPERTIES('1Y$zjXQP97GA_08z4LgF6V',#5,$,$,(#16024,#15366,#15265,#15216,#15166,#15087),#15098);
#20118= IFCRELDEFINESBYPROPERTIES('0iATlDs7jCuRzChTJ4D$LO',#5,$,$,(#15112),#15113);
#20119= IFCRELDEFINESBYPROPERTIES('27mFxc7Jv85wzEnD7LV6y8',#5,$,$,(#15112),#15115);
#20120= IFCRELDEFINESBYPROPERTIES('2FAEKD6pf0zPQYeyYVJXpy',#5,$,$,(#16086,#16036,#15378,#15277,#15232,#15178,#15112),#15120);
#20121= IFCRELDEFINESBYPROPERTIES('0buFcoNkD6mflpdmehtBZV',#5,$,$,(#15386,#15283,#15186,#15128),#15130);
#20122= IFCRELDEFINESBYPROPERTIES('2AiFSqHm597x1RjoOsZuDs',#5,$,$,(#16043,#15386,#15283,#15239,#15186,#15128),#15135);
#20123= IFCRELDEFINESBYPROPERTIES('2TJGsJam10_eSLiOaoXj1O',#5,$,$,(#15137),#15140);
#20124= IFCRELDEFINESBYPROPERTIES('1NL$f3fm93pwI7nkPEtf0W',#5,$,$,(#16030,#16006,#15271,#15250,#15226,#15196,#15172,#15146),#15148);
#20125= IFCRELDEFINESBYPROPERTIES('01c4ALVf96Lh8fgYm5t9kr',#5,$,$,(#15172,#15146),#15150);
#20126= IFCRELDEFINESBYPROPERTIES('38HRsJxVvFQBTT7_t65rXj',#5,$,$,(#16014,#15256,#15204,#15156),#15157);
#20127= IFCRELDEFINESBYPROPERTIES('2rpcsMvWnFsRKmomxw6yBz',#5,$,$,(#15156),#15158);
#20128= IFCRELDEFINESBYPROPERTIES('2XcH9Y3Pr6afGpm9i5Zo$m',#5,$,$,(#16036,#15277,#15232,#15178),#15179);
#20129= IFCRELDEFINESBYPROPERTIES('1vbCYd4cD37uq5W29twMRv',#5,$,$,(#15178),#15180);
#20130= IFCRELDEFINESBYPROPERTIES('1LJwG03F50LRTtEONokD1L',#5,$,$,(#15188),#15190);
#20131= IFCRELDEFINESBYPROPERTIES('1OV1P9B190UxyIdCSxu_zs',#5,$,$,(#15271,#15250,#15226,#15196),#15198);
#20132= IFCRELDEFINESBYPROPERTIES('252CSFzEv0a8PN26c14SWg',#5,$,$,(#15256,#15204),#15205);
#20133= IFCRELDEFINESBYPROPERTIES('0lTw7VnCf1ORLpXRf4eOVR',#5,$,$,(#15207),#15210);
#20134= IFCRELDEFINESBYPROPERTIES('2qVSC_Gcz50PgBB7tLvcA2',#5,$,$,(#16024,#15216),#15218);
#20135= IFCRELDEFINESBYPROPERTIES('3KNhwOK1HEUunGGbgTMYEJ',#5,$,$,(#16024,#15216),#15220);
#20136= IFCRELDEFINESBYPROPERTIES('2_6fEj1WfBnfieaSmE2KnE',#5,$,$,(#15277,#15232),#15233);
#20137= IFCRELDEFINESBYPROPERTIES('1WxdJL1Db2sR_6b4ovw9Ar',#5,$,$,(#16043,#15239),#15240);
#20138= IFCRELDEFINESBYPROPERTIES('2mnC7GUWz8MAPFk$00BJHL',#5,$,$,(#16043,#15239),#15241);
#20139= IFCRELDEFINESBYPROPERTIES('2LxK0zom9A0exs3EL8Yhn6',#5,$,$,(#15243),#15244);
#20140= IFCRELDEFINESBYPROPERTIES('2N2BTJe0nFzOPztQot1Vhe',#5,$,$,(#15258),#15259);
#20141= IFCRELDEFINESBYPROPERTIES('3tpu21plj9veZxLlJsfAfW',#5,$,$,(#16049,#15296),#15297);
#20142= IFCRELDEFINESBYPROPERTIES('0Xf2u4l69BHhRRbaCAS3h9',#5,$,$,(#16049,#15296),#15305);
#20143= IFCRELDEFINESBYPROPERTIES('1csDqCSC95iP0DeQ8P8ypm',#5,$,$,(#17432,#16513,#16466,#16411,#16344,#16049,#15296),#15310);
#20144= IFCRELDEFINESBYPROPERTIES('0NeBZowlvEtwFhQknypboc',#5,$,$,(#15312),#15315);
#20145= IFCRELDEFINESBYPROPERTIES('1TKKyx7PzCnPdOYDe8wELB',#5,$,$,(#16080,#16059,#15372,#15321),#15323);
#20146= IFCRELDEFINESBYPROPERTIES('1UNGe$Lq1BTQj7zOb3uKGZ',#5,$,$,(#15372,#15321),#15325);
#20147= IFCRELDEFINESBYPROPERTIES('0Nca$ivcr45hsGyZ7wq3Wx',#5,$,$,(#16067,#15331),#15332);
#20148= IFCRELDEFINESBYPROPERTIES('0mXsk$et94KQCUiK0kx$ZR',#5,$,$,(#15331),#15333);
#20149= IFCRELDEFINESBYPROPERTIES('3Etn9dmW9098IxtbC3dMOx',#5,$,$,(#16074,#15343),#15344);
#20150= IFCRELDEFINESBYPROPERTIES('13SHa7SYDDVQBcbEe5d66B',#5,$,$,(#16074,#15343),#15353);
#20151= IFCRELDEFINESBYPROPERTIES('1HQs1bB6fFHxNhGpR$Gsmn',#5,$,$,(#17441,#16522,#16474,#16419,#16356,#16074,#15343),#15358);
#20152= IFCRELDEFINESBYPROPERTIES('3DxHKRliHDVvS8wIl6C2ra',#5,$,$,(#16086,#15378),#15379);
#20153= IFCRELDEFINESBYPROPERTIES('2zOd0s8M9Efv1_djU8ZlRR',#5,$,$,(#15378),#15380);
#20154= IFCRELDEFINESBYPROPERTIES('0X0K4m3xX86AKvAVvZrT3z',#5,$,$,(#15543,#15511,#15475,#15388),#15391);
#20155= IFCRELDEFINESBYPROPERTIES('2ZXXYhlOr7hu1ND1k7a1A_',#5,$,$,(#16229,#16220,#15549,#15517,#15481,#15398),#15400);
#20156= IFCRELDEFINESBYPROPERTIES('2IHEEQXwz3uuve3L5oHnlM',#5,$,$,(#16229,#16220,#15591,#15549,#15517,#15481,#15398),#15404);
#20157= IFCRELDEFINESBYPROPERTIES('14c8NsTeTECBX$_hJsMIu$',#5,$,$,(#16229,#16220,#15591,#15549,#15517,#15481,#15398),#15409);
#20158= IFCRELDEFINESBYPROPERTIES('3KTw8wnez1Q9cuvZW6Lh23',#5,$,$,(#15551,#15519,#15483,#15411),#15412);
#20159= IFCRELDEFINESBYPROPERTIES('0HP_igSP51B981$Ak27zlB',#5,$,$,(#16247,#16238,#15557,#15525,#15489,#15418),#15419);
#20160= IFCRELDEFINESBYPROPERTIES('0XtLC6kij7ghcEo3CCgJfo',#5,$,$,(#16247,#16238,#15604,#15557,#15525,#15489,#15418),#15420);
#20161= IFCRELDEFINESBYPROPERTIES('0FuB22cznA7fiwIsvfTsZN',#5,$,$,(#16247,#16238,#15604,#15557,#15525,#15489,#15418),#15425);
#20162= IFCRELDEFINESBYPROPERTIES('0KHqi2J0D9hQPN$JZ724iO',#5,$,$,(#15527,#15491,#15427),#15429);
#20163= IFCRELDEFINESBYPROPERTIES('3q9L4ouLL2$QixTEDUIajo',#5,$,$,(#16287,#16256,#15533,#15497,#15435),#15436);
#20164= IFCRELDEFINESBYPROPERTIES('0K_bXQ0gD7GO4ZLU6rE6mR',#5,$,$,(#16287,#16256,#15616,#15567,#15533,#15497,#15435),#15439);
#20165= IFCRELDEFINESBYPROPERTIES('2kLq$GoJ95$PE0h0fsNWVa',#5,$,$,(#16287,#16256,#15616,#15567,#15533,#15497,#15435),#15444);
#20166= IFCRELDEFINESBYPROPERTIES('2nu92yLu91aAK3fbVbmZPd',#5,$,$,(#15446),#15447);
#20167= IFCRELDEFINESBYPROPERTIES('23pm5Ze_PEHw5D0Vcz_j3f',#5,$,$,(#16315,#16309,#16272,#16266,#15634,#15628,#15466,#15453),#15454);
#20168= IFCRELDEFINESBYPROPERTIES('20G3la$o1DBBn1OAwSU8l0',#5,$,$,(#16315,#16309,#16272,#16266,#15634,#15628,#15466,#15453),#15456);
#20169= IFCRELDEFINESBYPROPERTIES('1ATPvvdLzApgmuNuwLGvSW',#5,$,$,(#16315,#16309,#16272,#16266,#15634,#15628,#15466,#15453),#15460);
#20170= IFCRELDEFINESBYPROPERTIES('0LyKuxfGD1kABVkFtnkmdv',#5,$,$,(#16321,#16278,#15640,#15541,#15507,#15472),#15473);
#20171= IFCRELDEFINESBYPROPERTIES('2n5P2HCtP5oxPjG2sj1qev',#5,$,$,(#15535,#15499),#15501);
#20172= IFCRELDEFINESBYPROPERTIES('3PqaJeihj8$OOU5Pe4gL1y',#5,$,$,(#15579,#15541,#15507),#15509);
#20173= IFCRELDEFINESBYPROPERTIES('2qtmWZupXCYwOYXiyx1iD6',#5,$,$,(#15559),#15561);
#20174= IFCRELDEFINESBYPROPERTIES('2VXsYPw1z3uBMh6Kd$yZDg',#5,$,$,(#15567),#15569);
#20175= IFCRELDEFINESBYPROPERTIES('1gb5ETvQPB3O2yKL_K0EE9',#5,$,$,(#15571),#15573);
#20176= IFCRELDEFINESBYPROPERTIES('2LvtfwFgHDPuSlcdMhfed6',#5,$,$,(#15579),#15581);
#20177= IFCRELDEFINESBYPROPERTIES('1dZGGPloD9jAOKCIsgk6dA',#5,$,$,(#15583),#15585);
#20178= IFCRELDEFINESBYPROPERTIES('2nxIX1nPnE$h77$WqLYFpB',#5,$,$,(#15591),#15594);
#20179= IFCRELDEFINESBYPROPERTIES('3ddDNndXn8lBIhfpBAqeRk',#5,$,$,(#15596),#15598);
#20180= IFCRELDEFINESBYPROPERTIES('3sjvNuiaHCYQqHn12tdq6M',#5,$,$,(#15604),#15606);
#20181= IFCRELDEFINESBYPROPERTIES('36x$bfaq51yAQ2BzNU7iSw',#5,$,$,(#15608),#15610);
#20182= IFCRELDEFINESBYPROPERTIES('2UY$6yC097kfeFizfHU1CO',#5,$,$,(#15616),#15619);
#20183= IFCRELDEFINESBYPROPERTIES('0FbJykiqn5_Q8WjeMOyF_u',#5,$,$,(#16303,#15621),#15622);
#20184= IFCRELDEFINESBYPROPERTIES('0H4nrC8R5ChvLBELMRhyAN',#5,$,$,(#15678,#15670,#15662,#15642),#15645);
#20185= IFCRELDEFINESBYPROPERTIES('2iRvRn6lHAPgVp4nsjr70O',#5,$,$,(#16211,#16202,#15684,#15676,#15668,#15651),#15653);
#20186= IFCRELDEFINESBYPROPERTIES('1vOURm2qnDegB03RYTsWvd',#5,$,$,(#16211,#16202,#15694,#15684,#15676,#15668,#15651),#15655);
#20187= IFCRELDEFINESBYPROPERTIES('3uF3KSsZ59qf0IXX1QP8cZ',#5,$,$,(#16211,#16202,#15694,#15684,#15676,#15668,#15651),#15660);
#20188= IFCRELDEFINESBYPROPERTIES('3kKzFYbAf5VO6g6KLKQ8iY',#5,$,$,(#15686),#15688);
#20189= IFCRELDEFINESBYPROPERTIES('20UI0CggX3BBaGrzrb_PKX',#5,$,$,(#15694),#15696);
#20190= IFCRELDEFINESBYPROPERTIES('2op1t3$wTEMxoGBdxDN1op',#5,$,$,(#15952,#15904,#15880,#15855,#15835,#15810,#15790,#15743,#15698),#15699);
#20191= IFCRELDEFINESBYPROPERTIES('3vm3niIjX3GuD$4ZARwS4G',#5,$,$,(#16295,#16181,#16156,#16136,#15958,#15938,#15910,#15886,#15861,#15841,#15816,#15796,#15749,#15707),#15712);
#20192= IFCRELDEFINESBYPROPERTIES('17HgOfaXP0IPdi57fkSp21',#5,$,$,(#16187,#15944,#15847,#15802,#15718),#15719);
#20193= IFCRELDEFINESBYPROPERTIES('0BPxm2fer27uAXEbwjuCNP',#5,$,$,(#16187,#15944,#15847,#15802,#15718),#15721);
#20194= IFCRELDEFINESBYPROPERTIES('1mltPhbhj76fCKC3ihnJlz',#5,$,$,(#16187,#16142,#15944,#15892,#15847,#15802,#15718),#15727);
#20195= IFCRELDEFINESBYPROPERTIES('3zBs9sdF9CU8bi6MZdtSlb',#5,$,$,(#16301,#16193,#15964,#15950,#15867,#15853,#15822,#15808,#15755,#15733),#15734);
#20196= IFCRELDEFINESBYPROPERTIES('09Qv8WYIb4cxYtbLq_x$kT',#5,$,$,(#16301,#16193,#15964,#15950,#15867,#15853,#15822,#15808,#15755,#15733),#15735);
#20197= IFCRELDEFINESBYPROPERTIES('2ttjVg42b7$hEpUq1rmvTK',#5,$,$,(#16193,#16148,#15950,#15900,#15853,#15808,#15733),#15741);
#20198= IFCRELDEFINESBYPROPERTIES('2yOyw94g5EbOJOnorRtp5V',#5,$,$,(#16301,#16162,#15964,#15916,#15867,#15822,#15755),#15759);
#20199= IFCRELDEFINESBYPROPERTIES('38ZAF0GLf5ZhPNFGQzOAEl',#5,$,$,(#16332,#15975,#15878,#15833,#15786),#15787);
#20200= IFCRELDEFINESBYPROPERTIES('15GxYG5hL8dRT1ZD$W34c5',#5,$,$,(#16332,#15975,#15878,#15833,#15786),#15788);
#20201= IFCRELDEFINESBYPROPERTIES('1qlN2peYv4ywfjjycNwd04',#5,$,$,(#16142,#15892),#15893);
#20202= IFCRELDEFINESBYPROPERTIES('1YE5cuRqvDcgRiyzMHSnYd',#5,$,$,(#16142,#15892),#15894);
#20203= IFCRELDEFINESBYPROPERTIES('11y3bKHcf9Q92geHWH4HPJ',#5,$,$,(#16162,#16148,#15916,#15900),#15901);
#20204= IFCRELDEFINESBYPROPERTIES('2wxvQxTrX0zBkSol2j0y2T',#5,$,$,(#16162,#16148,#15916,#15900),#15902);
#20205= IFCRELDEFINESBYPROPERTIES('1pBnSKl2r4xx3XYACTC4Rk',#5,$,$,(#16173,#15927),#15928);
#20206= IFCRELDEFINESBYPROPERTIES('1LwjFr0$rFKP0cRQ6FG2YL',#5,$,$,(#16173,#15927),#15929);
#20207= IFCRELDEFINESBYPROPERTIES('2LNMR$iBf9je1p$KRlh1eC',#5,$,$,(#16289,#15931),#15932);
#20208= IFCRELDEFINESBYPROPERTIES('0lopypE$fAShTWeU4v55$C',#5,$,$,(#16127,#16121,#16115,#16109,#16093,#15987),#15988);
#20209= IFCRELDEFINESBYPROPERTIES('1kt4yLxRH7zQd8qAJZKeUZ',#5,$,$,(#16127,#15987),#15990);
#20210= IFCRELDEFINESBYPROPERTIES('3OMqvPT$v1NAnpCjgC3MNJ',#5,$,$,(#16127,#15987),#15996);
#20211= IFCRELDEFINESBYPROPERTIES('17qzYaGsP36Ouyj0AkAoh6',#5,$,$,(#15998),#16000);
#20212= IFCRELDEFINESBYPROPERTIES('08zewD1zz1zv$X7BS1uvfu',#5,$,$,(#16030,#16006),#16008);
#20213= IFCRELDEFINESBYPROPERTIES('3IfOwv_X57f9ZJt2F7XGqv',#5,$,$,(#16014),#16015);
#20214= IFCRELDEFINESBYPROPERTIES('1BfFNjP_f7bQQjGH55q4Xo',#5,$,$,(#16017),#16018);
#20215= IFCRELDEFINESBYPROPERTIES('0Dx$vJHZrCvPgZPraWFYFZ',#5,$,$,(#16036),#16037);
#20216= IFCRELDEFINESBYPROPERTIES('0qKn$wP8LAzx6JZLV6l_Z0',#5,$,$,(#16051),#16053);
#20217= IFCRELDEFINESBYPROPERTIES('1ppzGKiQ96swL5WYEi6UPA',#5,$,$,(#16080,#16059),#16061);
#20218= IFCRELDEFINESBYPROPERTIES('3lNhaABzX1AwreAViXzUN8',#5,$,$,(#16067),#16068);
#20219= IFCRELDEFINESBYPROPERTIES('28ak7Dd6X8q8f869Y9Uer6',#5,$,$,(#16086),#16087);
#20220= IFCRELDEFINESBYPROPERTIES('06_9HQrWP5IhaYQGudbtkN',#5,$,$,(#16121,#16115,#16109,#16093),#16097);
#20221= IFCRELDEFINESBYPROPERTIES('1KCtYW4VHF2Rc1QJCsVw6M',#5,$,$,(#16121,#16115,#16109,#16093),#16103);
#20222= IFCRELDEFINESBYPROPERTIES('159GIJ8uH39uakvJOC4BX6',#5,$,$,(#16175,#16150,#16129),#16130);
#20223= IFCRELDEFINESBYPROPERTIES('0YnV4WOrj3QBtc03awnZgc',#5,$,$,(#16195),#16196);
#20224= IFCRELDEFINESBYPROPERTIES('0Qm$Sc6ObCShFEk7oC$Wzu',#5,$,$,(#16204),#16205);
#20225= IFCRELDEFINESBYPROPERTIES('0s$CPxaWvDaAEHF8Zm52w_',#5,$,$,(#16213),#16214);
#20226= IFCRELDEFINESBYPROPERTIES('1PJcq_kUH35PZ94_Ib5NFK',#5,$,$,(#16222),#16223);
#20227= IFCRELDEFINESBYPROPERTIES('2vtwfzHKj95AUK6YTRqsOT',#5,$,$,(#16231),#16232);
#20228= IFCRELDEFINESBYPROPERTIES('1O2KxJNuD3Ye5eQIxNQinL',#5,$,$,(#16240),#16241);
#20229= IFCRELDEFINESBYPROPERTIES('0sqmiwKa18K8t_n8OBz_Pi',#5,$,$,(#16249),#16250);
#20230= IFCRELDEFINESBYPROPERTIES('39EoRLGBTFqBvo8lCnfnG4',#5,$,$,(#16258),#16260);
#20231= IFCRELDEFINESBYPROPERTIES('3qeQHrCGr73fpr1c7rR6h4',#5,$,$,(#16280),#16281);
#20232= IFCRELDEFINESBYPROPERTIES('07gm7v5$r3bvJQsH59I18t',#5,$,$,(#16460,#16405,#16334),#16336);
#20233= IFCRELDEFINESBYPROPERTIES('0sp4Ve7gj7VuclnKftJmH$',#5,$,$,(#17425,#16506,#16460,#16405,#16334),#16338);
#20234= IFCRELDEFINESBYPROPERTIES('1swWirkbT8BepXC4qLgT1j',#5,$,$,(#17432,#16513,#16466,#16411,#16344),#16346);
#20235= IFCRELDEFINESBYPROPERTIES('27tEGBJIT9M8UzFwfcAbgh',#5,$,$,(#16468,#16413,#16348),#16350);
#20236= IFCRELDEFINESBYPROPERTIES('1iqU291IX05gBBUUCD7R8J',#5,$,$,(#17441,#16522,#16474,#16419,#16356),#16358);
#20237= IFCRELDEFINESBYPROPERTIES('2SqgqxngTA9ABsCK8g2UKR',#5,$,$,(#16384),#16386);
#20238= IFCRELDEFINESBYPROPERTIES('3TgGYmrH52EQKvsfSW5MeD',#5,$,$,(#16384),#16398);
#20239= IFCRELDEFINESBYPROPERTIES('3ke2P2nGrA9gNiv_P4fIEU',#5,$,$,(#16384),#16403);
#20240= IFCRELDEFINESBYPROPERTIES('1NXYDpJmXDTvGTjEElRAX_',#5,$,$,(#17463,#16532,#16490,#16439),#16441);
#20241= IFCRELDEFINESBYPROPERTIES('14BJ7geqTF4eQ8zcZbh4aK',#5,$,$,(#16439),#16453);
#20242= IFCRELDEFINESBYPROPERTIES('2uIHwtuVjBLhbiIruUBX08',#5,$,$,(#16439),#16458);
#20243= IFCRELDEFINESBYPROPERTIES('0KqpDjb9XFy8WacAhPYtc3',#5,$,$,(#16490),#16499);
#20244= IFCRELDEFINESBYPROPERTIES('2n7EYbehz30OjN30oumEEi',#5,$,$,(#16490),#16504);
#20245= IFCRELDEFINESBYPROPERTIES('16JzyuOTf62RRAWKWKEsl0',#5,$,$,(#16506),#16507);
#20246= IFCRELDEFINESBYPROPERTIES('123yJIfNjF1R1pCisEanAr',#5,$,$,(#16515),#16516);
#20247= IFCRELDEFINESBYPROPERTIES('0w2tBTEhD9iQdBUfdkyMnw',#5,$,$,(#16532),#16534);
#20248= IFCRELDEFINESBYPROPERTIES('1Vg1ZDqVT9eOZZSdiwN03M',#5,$,$,(#16532),#16539);
#20249= IFCRELDEFINESBYPROPERTIES('3zwMIySuD9CAvUk6Y5kudp',#5,$,$,(#17494,#16559),#16561);
#20250= IFCRELDEFINESBYPROPERTIES('3ar4pRUw5BDxgsgvnREG6k',#5,$,$,(#16559),#16573);
#20251= IFCRELDEFINESBYPROPERTIES('0tZMVHUIH7FBtNMZPwa1U9',#5,$,$,(#16559),#16578);
#20252= IFCRELDEFINESBYPROPERTIES('2rm8_srgf5BvYi7H_71PX4',#5,$,$,(#17718,#17706,#16781,#16738,#16688,#16596),#16598);
#20253= IFCRELDEFINESBYPROPERTIES('0iYqD5SST8UgDd1mT2xwhW',#5,$,$,(#17718,#17706,#16828,#16781,#16738,#16688,#16596),#16608);
#20254= IFCRELDEFINESBYPROPERTIES('0mI_7kH4vFMAy_GfJ49Yo$',#5,$,$,(#17718,#17706,#16828,#16781,#16738,#16688,#16596),#16612);
#20255= IFCRELDEFINESBYPROPERTIES('3MSEfPDV11qRuU4o1tVUv7',#5,$,$,(#17761,#17736,#16835,#16744,#16694,#16618),#16619);
#20256= IFCRELDEFINESBYPROPERTIES('2p3b77sU17TBW5cDwY01hy',#5,$,$,(#17761,#17736,#16835,#16787,#16744,#16694,#16618),#16622);
#20257= IFCRELDEFINESBYPROPERTIES('09Xk$FGJvDkgQWL3ioqHcH',#5,$,$,(#17774,#17749,#16757,#16708,#16642),#16643);
#20258= IFCRELDEFINESBYPROPERTIES('3JS$UFDq1DXf_NKPUSHWgj',#5,$,$,(#16642),#16649);
#20259= IFCRELDEFINESBYPROPERTIES('15aNLqS9j19xLaygUilj9_',#5,$,$,(#16642),#16653);
#20260= IFCRELDEFINESBYPROPERTIES('2cmMExw4L1yeksBw51wsBS',#5,$,$,(#17786,#17730,#16816,#16769,#16726,#16667),#16668);
#20261= IFCRELDEFINESBYPROPERTIES('3PvyR_FPf5z8WbN2AY6irM',#5,$,$,(#17786,#17730,#16861,#16816,#16769,#16726,#16667),#16673);
#20262= IFCRELDEFINESBYPROPERTIES('2tQWuGMC55yQzcqMZ2j$YN',#5,$,$,(#17786,#17730,#16861,#16816,#16769,#16726,#16667),#16676);
#20263= IFCRELDEFINESBYPROPERTIES('2M2BwXvLTDwe7HR4M_GMD2',#5,$,$,(#16787,#16744,#16694),#16695);
#20264= IFCRELDEFINESBYPROPERTIES('3N6XYJ2ffCTfTegijvZZpd',#5,$,$,(#17774,#17749,#16848,#16802,#16757,#16708),#16710);
#20265= IFCRELDEFINESBYPROPERTIES('3iM5ujChLEOwVwgPH7nfdA',#5,$,$,(#17774,#17749,#16848,#16802,#16757,#16708),#16714);
#20266= IFCRELDEFINESBYPROPERTIES('0sebBYnzXE2PtwMEIJ8l$7',#5,$,$,(#16787),#16789);
#20267= IFCRELDEFINESBYPROPERTIES('1ZvuLYUv1BqwRnXQkno5Qb',#5,$,$,(#16802),#16804);
#20268= IFCRELDEFINESBYPROPERTIES('3Cb82br5XDRAES1aZXg19d',#5,$,$,(#16828),#16829);
#20269= IFCRELDEFINESBYPROPERTIES('3_pUxmR8H2M8Qwxi7uxMWn',#5,$,$,(#16848),#16849);
#20270= IFCRELDEFINESBYPROPERTIES('0sD5udxfT49ORIo2hRabdG',#5,$,$,(#16861),#16862);
#20271= IFCRELDEFINESBYPROPERTIES('1QlMjy0iH3Ex1P4J2zdJDw',#5,$,$,(#17816,#17801,#16946,#16931,#16916,#16883),#16885);
#20272= IFCRELDEFINESBYPROPERTIES('3lvP93eFj6LBG6AdNn$JT4',#5,$,$,(#17816,#17801,#16961,#16946,#16931,#16916,#16883),#16896);
#20273= IFCRELDEFINESBYPROPERTIES('1cxHd9_uD2i8TxaBv3on2B',#5,$,$,(#17816,#17801,#16961,#16946,#16931,#16916,#16883),#16901);
#20274= IFCRELDEFINESBYPROPERTIES('2OgJEe14j8R8h2o0p12v$T',#5,$,$,(#16961),#16962);
#20275= IFCRELDEFINESBYPROPERTIES('1uYzgMyAbCB8lIEafCgTGR',#5,$,$,(#17379,#17286,#17246,#17200,#17160,#17114,#17074,#17012,#16964),#16965);
#20276= IFCRELDEFINESBYPROPERTIES('0J2hHg6Nv2e8r0YHJ_IIRh',#5,$,$,(#17662,#17622,#17576,#17532,#17385,#17341,#17292,#17252,#17206,#17166,#17120,#17080,#17018,#16971),#16974);
#20277= IFCRELDEFINESBYPROPERTIES('3j4gany951vObj2ksdz03r',#5,$,$,(#17387,#17294,#17254,#17208,#17168,#17122,#17082,#17020,#16976),#16977);
#20278= IFCRELDEFINESBYPROPERTIES('1ZLotZy4j62PeKMdexdgwD',#5,$,$,(#17395,#17302,#17262,#17216,#17176,#17130,#17090,#17028,#16985),#16986);
#20279= IFCRELDEFINESBYPROPERTIES('23x85be7n4dft23WaU19Pm',#5,$,$,(#17403,#17310,#17270,#17224,#17184,#17138,#17098,#17036,#16994),#16995);
#20280= IFCRELDEFINESBYPROPERTIES('0EaxjLGxf0ye$XFNv5OudM',#5,$,$,(#17411,#17318,#17278,#17232,#17192,#17146,#17106,#17044,#17003),#17004);
#20281= IFCRELDEFINESBYPROPERTIES('0PKc2jJYL9qR9CjSrO04WP',#5,$,$,(#17755,#17423,#17244,#17158,#17058),#17059);
#20282= IFCRELDEFINESBYPROPERTIES('2uEpxsizH61uoR7HTlyl3y',#5,$,$,(#17755,#17423,#17244,#17158,#17058),#17067);
#20283= IFCRELDEFINESBYPROPERTIES('1RJ393Ci9AhuehvyRt5Y3C',#5,$,$,(#17755,#17614,#17423,#17330,#17244,#17158,#17058),#17072);
#20284= IFCRELDEFINESBYPROPERTIES('1gp5eU68bFjRfMIsjyg4nu',#5,$,$,(#17614,#17330),#17331);
#20285= IFCRELDEFINESBYPROPERTIES('1wSQ3iGLT2B9II$5zEY331',#5,$,$,(#17614,#17330),#17332);
#20286= IFCRELDEFINESBYPROPERTIES('2k1jxeQWz7YvLucT_u$mFP',#5,$,$,(#17656,#17616,#17334),#17335);
#20287= IFCRELDEFINESBYPROPERTIES('3jMhWD1Kb39uUMGIrYGdsj',#5,$,$,(#17664,#17624,#17343),#17344);
#20288= IFCRELDEFINESBYPROPERTIES('2Yz7H6q9X7JAq50GL$rXmC',#5,$,$,(#17672,#17632,#17352),#17353);
#20289= IFCRELDEFINESBYPROPERTIES('2Pj5WK4EjBVxK1oGfN4Lig',#5,$,$,(#17680,#17640,#17361),#17362);
#20290= IFCRELDEFINESBYPROPERTIES('1XWlnj1dP3IuFOumyT6_Em',#5,$,$,(#17688,#17648,#17370),#17371);
#20291= IFCRELDEFINESBYPROPERTIES('2_59o6KOn7HhJFbD9drUzJ',#5,$,$,(#17425),#17426);
#20292= IFCRELDEFINESBYPROPERTIES('2f16CngKf2W9qhFqOwnueO',#5,$,$,(#17434),#17435);
#20293= IFCRELDEFINESBYPROPERTIES('3kiPwxqXb59gLrALCrvYeb',#5,$,$,(#17463),#17473);
#20294= IFCRELDEFINESBYPROPERTIES('3hpiAYZTXAux_4PPbDkSii',#5,$,$,(#17463),#17478);
#20295= IFCRELDEFINESBYPROPERTIES('2FfVVtwCzDDfqg09hNnd6k',#5,$,$,(#17494),#17501);
#20296= IFCRELDEFINESBYPROPERTIES('2hyj$y_nP5eP3Y7ohMz8lO',#5,$,$,(#17494),#17506);
#20297= IFCRELDEFINESBYPROPERTIES('1slQV3WafCkxfdtx0HnB9Q',#5,$,$,(#17514),#17515);
#20298= IFCRELDEFINESBYPROPERTIES('2w7hG6gfH4w8qVlvSjx8sM',#5,$,$,(#17514),#17516);
#20299= IFCRELDEFINESBYPROPERTIES('0ymz0R4cj6Rge01DqgRUbb',#5,$,$,(#17522),#17523);
#20300= IFCRELDEFINESBYPROPERTIES('3lZP5VR614BOJVNwfCELne',#5,$,$,(#17570,#17525),#17526);
#20301= IFCRELDEFINESBYPROPERTIES('2OG$L872L3Yvwou93Zg5BV',#5,$,$,(#17578,#17534),#17535);
#20302= IFCRELDEFINESBYPROPERTIES('0Sp1PDJyb4pv0V8Zcrw86N',#5,$,$,(#17586,#17543),#17544);
#20303= IFCRELDEFINESBYPROPERTIES('1Ob2pD0Z53ORi0JZtaY4uN',#5,$,$,(#17594,#17552),#17553);
#20304= IFCRELDEFINESBYPROPERTIES('0gefaimZH9xvjrAtPUpAwj',#5,$,$,(#17602,#17561),#17562);
#20305= IFCRELDEFINESBYPROPERTIES('0BQWIwe6rAweS8X4ZsYJuK',#5,$,$,(#17818),#17823);
#20306= IFCRELDEFINESBYPROPERTIES('1KI7xE03n7CxaDT1pIEvBi',#5,$,$,(#17840),#17849);
#20307= IFCRELDEFINESBYPROPERTIES('0KyPxces17wRxNHBAERxpN',#5,$,$,(#17840),#17858);
#20308= IFCRELDEFINESBYPROPERTIES('3T31DrgXnEixisGaxTXpSD',#5,$,$,(#17840),#17865);
#20309= IFCRELDEFINESBYPROPERTIES('2_ToLKEWj3z8Gqm8K5okOi',#5,$,$,(#17867),#17869);
#20310= IFCRELDEFINESBYPROPERTIES('1Q63Q_FVj67fDSqYh0e3bS',#5,$,$,(#17882),#17887);
#20311= IFCRELDEFINESBYPROPERTIES('35tqVA6jD1mex6IfOImoP_',#5,$,$,(#17882),#17895);
#20312= IFCRELDEFINESBYPROPERTIES('1IM_rj7aHDueqGHqSu6yHm',#5,$,$,(#17882),#17901);
#20313= IFCRELDEFINESBYPROPERTIES('2D5MXmuRXCQAtWRVbIZvqq',#5,$,$,(#17903),#17905);
#20314= IFCRELDEFINESBYPROPERTIES('1MFKBrKnXAQAEMsDtcaCq_',#5,$,$,(#17920),#17925);
#20315= IFCRELDEFINESBYPROPERTIES('2$6S3mWU95yuBIk8nRg_vN',#5,$,$,(#17920),#17934);
#20316= IFCRELDEFINESBYPROPERTIES('2P4Vvf6krCyejVCHOHLyfx',#5,$,$,(#17920),#17940);
#20317= IFCRELDEFINESBYPROPERTIES('0GhPkT3iz8pf0XNbiVXh96',#5,$,$,(#18001,#17993,#17985,#17977,#17969,#17942),#17945);
#20318= IFCRELDEFINESBYPROPERTIES('0g7QusSo9BywepRvIQSCCh',#5,$,$,(#18001,#17993,#17985,#17977,#17969,#17942),#17947);
#20319= IFCRELDEFINESBYPROPERTIES('3aRgZVW3rF9AabXhX9ZXEk',#5,$,$,(#18007,#17999,#17991,#17983,#17975,#17953),#17955);
#20320= IFCRELDEFINESBYPROPERTIES('1Wy8Akgl9CZgl89byVp7gM',#5,$,$,(#18007,#17999,#17991,#17983,#17975,#17953),#17963);
#20321= IFCRELDEFINESBYPROPERTIES('3OEZuL9VH9IeiYPGiwcAFS',#5,$,$,(#18007,#17999,#17991,#17983,#17975,#17953),#17967);
#20322= IFCRELDEFINESBYPROPERTIES('0EJIL9dGr2eP9RSa_h3cvv',#5,$,$,(#18146,#18140,#18132,#18046,#18009),#18011);
#20323= IFCRELDEFINESBYPROPERTIES('1UK67ZvGL02PJpK5ofv_tF',#5,$,$,(#18159,#18150,#18144,#18138,#18061,#18052,#18024),#18029);
#20324= IFCRELDEFINESBYPROPERTIES('1XjOvaoLLDVeD5MmDFfrUa',#5,$,$,(#18159,#18150,#18144,#18138,#18061,#18052,#18024),#18038);
#20325= IFCRELDEFINESBYPROPERTIES('2bDNmfObb3p8F2jo7d2pHm',#5,$,$,(#18159,#18150,#18144,#18138,#18061,#18052,#18024),#18044);
#20326= IFCRELDEFINESBYPROPERTIES('0A$DQ9Pp55LPCvK08Oq1DD',#5,$,$,(#18054),#18055);
#20327= IFCRELDEFINESBYPROPERTIES('0b4i03G4v39gfucSzFsuyP',#5,$,$,(#18063),#18065);
#20328= IFCRELDEFINESBYPROPERTIES('0pJsC0xirCTRb7CtbQc$gx',#5,$,$,(#18078),#18081);
#20329= IFCRELDEFINESBYPROPERTIES('0owaHu3mr1DhPQqotLhihn',#5,$,$,(#18078),#18090);
#20330= IFCRELDEFINESBYPROPERTIES('2PR2bCb1n8H9WQSpSH6AtG',#5,$,$,(#18078),#18096);
#20331= IFCRELDEFINESBYPROPERTIES('2AcPwi52bEiuYXXLZ2CqCr',#5,$,$,(#18098),#18100);
#20332= IFCRELDEFINESBYPROPERTIES('2slzsPLdv2yuBui5Owb5Hz',#5,$,$,(#18114),#18117);
#20333= IFCRELDEFINESBYPROPERTIES('2cET0Ylsb359xcCpIP9oK_',#5,$,$,(#18114),#18124);
#20334= IFCRELDEFINESBYPROPERTIES('3tVcOmMujCN9WTanitO5r6',#5,$,$,(#18114),#18130);
#20335= IFCRELDEFINESBYPROPERTIES('1J7VAWWnT2DPoVeaQs_Q$E',#5,$,$,(#18152),#18153);
#20336= IFCRELDEFINESBYPROPERTIES('36zsmzCVPFah_KnVEMqFuq',#5,$,$,(#18161),#18168);
#20337= IFCRELDEFINESBYPROPERTIES('3MGBM8v4X8svgDZbhBq$TW',#5,$,$,(#18298,#18262,#18211,#18161),#18170);
#20338= IFCRELDEFINESBYPROPERTIES('2iiv$9JcT2rf6rO9GnAigo',#5,$,$,(#18181),#18189);
#20339= IFCRELDEFINESBYPROPERTIES('0aygBEjcr0tv1EloOHxO2c',#5,$,$,(#18181),#18204);
#20340= IFCRELDEFINESBYPROPERTIES('38V4erN8D7oe6XBT2Id_Hh',#5,$,$,(#18181),#18209);
#20341= IFCRELDEFINESBYPROPERTIES('3aIOEmGSP3jh1jUiqG_AUB',#5,$,$,(#18211),#18216);
#20342= IFCRELDEFINESBYPROPERTIES('0yn_JUl65CJOkDsq6FQYih',#5,$,$,(#18236),#18242);
#20343= IFCRELDEFINESBYPROPERTIES('11o3nk$d5El8dNENkiMwVi',#5,$,$,(#18236),#18256);
#20344= IFCRELDEFINESBYPROPERTIES('3sFlkEucb3LQm_YRpAVWWC',#5,$,$,(#18236),#18260);
#20345= IFCRELDEFINESBYPROPERTIES('1dtNyuOzjDoh$umUwXRO2h',#5,$,$,(#18262),#18265);
#20346= IFCRELDEFINESBYPROPERTIES('3qvs0gIiHDJRuIQHRs0CQm',#5,$,$,(#18275),#18278);
#20347= IFCRELDEFINESBYPROPERTIES('0rVDulmXPBLe8UVE0SIyjs',#5,$,$,(#18275),#18291);
#20348= IFCRELDEFINESBYPROPERTIES('0Q9kMA6iH08xFHxrR_HYtL',#5,$,$,(#18275),#18296);
#20349= IFCRELDEFINESBYPROPERTIES('04uMaxjr52vACXwGwbWQXB',#5,$,$,(#18298),#18301);
#20350= IFCRELDEFINESBYPROPERTIES('1lZVs6MtHAdQ7hYNpFvMUC',#5,$,$,(#18314),#18319);
#20351= IFCRELDEFINESBYPROPERTIES('3Z1V3mAKfDn84f07ZgxDD5',#5,$,$,(#18314),#18333);
#20352= IFCRELDEFINESBYPROPERTIES('0PKNnLTVbA4RINs70RJ$FQ',#5,$,$,(#18314),#18337);
#20353= IFCRELDEFINESBYPROPERTIES('2CurR4HC96YvHVfRhP5wXO',#5,$,$,(#18339),#18345);
#20354= IFCRELDEFINESBYPROPERTIES('1an27Y$qHEfOzpFezqSrCH',#5,$,$,(#18339),#18346);
#20355= IFCRELDEFINESBYPROPERTIES('0g0TmSiwfCHur8e6Xwxv20',#5,$,$,(#18363),#18369);
#20356= IFCRELDEFINESBYPROPERTIES('3gSpfjagf3uPldSeP0YMwb',#5,$,$,(#18363),#18384);
#20357= IFCRELDEFINESBYPROPERTIES('1esgehekr1ahBC75IAFr1p',#5,$,$,(#18363),#18388);
#20358= IFCRELDEFINESBYPROPERTIES('3OfPUbtnL2swS8hHaY64R$',#5,$,$,(#18390),#18397);
#20359= IFCRELDEFINESBYPROPERTIES('2N8simke5EifIkEJBsAsUg',#5,$,$,(#18390),#18399);
#20360= IFCRELDEFINESBYPROPERTIES('2ZQEBL5b5APOFzDExs8TTR',#5,$,$,(#18457),#18464);
#20361= IFCRELDEFINESBYPROPERTIES('2z2$YDnp1F49aW4KRzCt_F',#5,$,$,(#18457),#18478);
#20362= IFCRELDEFINESBYPROPERTIES('3AGHKQjY1DYB6XjFOqgIkz',#5,$,$,(#18457),#18483);
#20363= IFCRELDEFINESBYPROPERTIES('2YLcjwlZ1BFBUqP5qVNkJV',#5,$,$,(#18485),#18492);
#20364= IFCRELDEFINESBYPROPERTIES('0f8ctY_UH2Vu0I27Krmjuo',#5,$,$,(#18485),#18494);
#20365= IFCRELDEFINESBYPROPERTIES('2WDTSmCkr5JwpybqvyuYoa',#5,$,$,(#18624),#18631);
#20366= IFCRELDEFINESBYPROPERTIES('3pI5PKCh56LPQAiXos2i67',#5,$,$,(#18624),#18646);
#20367= IFCRELDEFINESBYPROPERTIES('2faptuaFnC$eYuZBZFmiNl',#5,$,$,(#18624),#18650);
#20368= IFCRELDEFINESBYPROPERTIES('3cuoA0xdP71fU$ey_IfBLM',#5,$,$,(#18652),#18658);
#20369= IFCRELDEFINESBYPROPERTIES('0bv_9zppn0vBQyq6SdJkp4',#5,$,$,(#18700,#18652),#18660);
#20370= IFCRELDEFINESBYPROPERTIES('11H6oMYNnECOPDb2AAb$tE',#5,$,$,(#18707,#18671),#18678);
#20371= IFCRELDEFINESBYPROPERTIES('1MKYuaoPf1WvEybKMHloyw',#5,$,$,(#18707,#18671),#18693);
#20372= IFCRELDEFINESBYPROPERTIES('1fGmuk_2vA0P1rdPlO2lU0',#5,$,$,(#18707,#18671),#18698);
#20373= IFCRELDEFINESBYPROPERTIES('3xDOwT5Bj9T8v8nKrNbUzk',#5,$,$,(#18700),#18701);
#20374= IFCRELDEFINESBYTYPE('0isOQ_sq90uRqlSqp1c9rb',#5,$,$,(#118,#68),#69);
#20375= IFCRELDEFINESBYTYPE('3CWR$ffJbC8eBoHe8cVvaG',#5,$,$,(#16321,#16278,#15640,#15579,#15541,#15507,#15472,#13462,#13299,#12964,#12020,#11984,#9674,#9500,#9452,#8652,#8538,#8027,#8020,#7838,#7759,#7751,#7714,#7705,#7357,#7350,#7323,#7169,#7160,#6531,#6525,#6507,#6445,#6438,#6410,#6402,#5937,#5446,#5433,#5383,#5368,#5288,#5253,#3146,#3076,#2999,#1573,#1442,#1293,#1190,#157),#158);
#20376= IFCRELDEFINESBYTYPE('1AtgjNeNn82ek6EKIKn3hZ',#5,$,$,(#15048,#15020,#15007,#14995,#14967,#14955,#14942,#14930,#14918,#14888,#14858,#14828,#14798,#14768,#14738,#14708,#14678,#14648,#14618,#14590,#14562,#14534,#14506,#14476,#14446,#14433,#14421,#14409,#14396,#14384,#14372,#14359,#14347,#14335,#14322,#14310,#14298,#14285,#14273,#14261,#14225,#14197,#14167,#14137,#14097,#14069,#14041,#14007,#13979,#13951,#13923,#13895,#13867,#13839,#13811,#13783,#13755,#13384,#13228,#12733,#12663,#12633,#12603,#12573,#12474,#12444,#12414,#12384,#12319,#12289,#12259,#12229,#11711,#11681,#11651,#11621,#11591,#11561,#11531,#11310,#11244,#11123,#10988,#10881,#10739,#10649,#10495,#10465,#10435,#10405,#10375,#10345,#10204,#10174,#10144,#10114,#10084,#9776,#9439,#9426,#9414,#9061,#9044,#9032,#8851,#8528,#8507,#8168,#8150,#8065,#7680,#7650,#7638,#7626,#7596,#7584,#7572,#7560,#7135,#7105,#7075,#7063,#7051,#7039,#7027,#7015,#7003,#6973,#6943,#6913,#6883,#6853,#6386,#6356,#6326,#6314,#6302,#6272,#6260,#6248,#6236,#5869,#5854,#5842,#5830,#5818,#5806,#5745,#5193,#5163,#5133,#5103,#5073,#5043,#5013,#4982,#4917,#4887,#4857,#4827,#4791,#4741,#4705,#4406,#3911,#2853,#2841,#2829,#2817,#2805,#2775,#2763,#2733,#2721,#2709,#2697,#2685,#2673,#2643,#2631,#2601,#2589,#2576,#2563,#2550,#2537,#2507,#2492,#2449,#884,#872,#860,#848,#836,#824,#812,#800,#788,#776,#764,#752,#740,#728,#716,#704,#692,#680,#666,#651,#633,#610,#594,#569,#482,#452,#422,#392,#362,#332,#302,#253),#254);
#20377= IFCRELDEFINESBYTYPE('3zUlD7UK985QsXKxQpWSms',#5,$,$,(#3659,#3650,#3473,#3464,#3176,#3161,#2166,#2155,#2029,#2018,#1608,#1597,#546,#508),#509);
#20378= IFCRELDEFINESBYTYPE('0e9XMQ$15248uWw2vM1HXH',#5,$,$,(#16315,#16309,#16301,#16272,#16266,#16193,#16187,#16162,#16148,#16142,#16049,#16024,#15981,#15964,#15950,#15944,#15916,#15900,#15892,#15867,#15853,#15847,#15822,#15808,#15802,#15755,#15733,#15718,#15634,#15628,#15466,#15453,#15366,#15296,#15265,#15216,#15166,#15087,#13456,#13450,#13293,#13287,#12953,#12921,#11331,#11160,#10834,#10769,#9512,#9486,#9467,#9184,#9150,#9119,#8622,#8590,#8561,#8259,#8034,#8007,#7803,#7766,#7740,#7731,#7721,#7690,#7371,#7364,#7334,#7186,#7176,#7145,#6573,#6537,#6519,#6485,#6451,#6431,#6425,#6416,#6395,#5527,#5460,#5415,#5409,#5395,#5352,#5345,#5317,#5217,#3990,#1480,#1462,#1337,#1317,#1235,#1226,#948,#913),#914);
#20379= IFCRELDEFINESBYTYPE('27PSvnHtf8CfqCSGucu6oR',#5,$,$,(#16127,#16121,#16115,#16109,#16093,#15987,#13578,#13572,#13566,#13560,#13554,#13545,#13534,#13523,#13413,#13402,#13390,#13252,#13243,#13234,#12780,#12761,#12741,#12514,#12508,#12502,#12496,#12480,#7796,#7789,#7783,#7777,#7280,#7273,#7266,#7258,#6610,#6604,#6598,#6592,#6586,#6579,#6567,#6561,#6555,#6549,#6543,#6479,#6473,#6467,#6461,#5902,#5895,#5888,#5880,#5609,#5603,#5597,#5591,#5571,#5541,#5521,#5515,#5509,#5503,#5481,#4303,#4296,#4267,#4224,#3947,#3110,#3102,#3096,#3089,#3040,#3034,#3028,#3021,#2945,#2922,#2898,#2870,#1537,#1528,#1519,#1510,#1491,#1402,#1384,#1375,#1366,#1343,#1282,#1275,#1265,#1254,#1241,#1111,#1085,#1050,#1006,#964),#965);
#20380= IFCRELDEFINESBYTYPE('3mO8iumvTDwfQPGujqUOfH',#5,$,$,(#7860,#7851,#7389,#7380,#6628,#6619,#5989,#5958,#3729,#3721,#3520,#3510,#3290,#3273,#2328,#2317,#2188,#2177,#2051,#2040,#1677,#1635),#1636);
#20381= IFCRELDEFINESBYTYPE('2vdxQ7kWf4_APNBBABnzET',#5,$,$,(#17686,#17678,#17670,#17646,#17638,#17630,#17600,#17592,#17584,#17559,#17550,#17541,#17409,#17401,#17393,#17368,#17359,#17350,#17316,#17308,#17300,#17276,#17268,#17260,#17230,#17222,#17214,#17190,#17182,#17174,#17144,#17136,#17128,#17104,#17096,#17088,#17042,#17034,#17026,#17001,#16992,#16983,#9651,#9640,#9628,#9592,#9582,#9571,#9362,#9354,#9346,#9298,#9281,#9263,#8776,#8766,#8754,#8472,#8460,#8446,#8379,#8361,#8335,#7957,#7944,#7881,#7871,#7464,#7456,#7406,#7398,#6725,#6709,#6652,#6639,#6161,#6145,#6019,#6005,#3818,#3804,#3751,#3740,#3615,#3601,#3549,#3536,#3419,#3407,#3320,#3308,#2415,#2407,#2350,#2339,#2272,#2264,#2210,#2199,#2128,#2120,#2073,#2062,#1956,#1936,#1766,#1726),#1727);
#20382= IFCRELDEFINESBYTYPE('1vE8uQnCX3TAKO2EWmLxsN',#5,$,$,(#17662,#17622,#17576,#17532,#17385,#17341,#17292,#17252,#17206,#17166,#17120,#17080,#17018,#16971,#9614,#9558,#9335,#9240,#8743,#8430,#8302,#7970,#7892,#7472,#7415,#6738,#6663,#6175,#6035,#3831,#3765,#3629,#3563,#3433,#3334,#2423,#2361,#2280,#2221,#2136,#2084,#1973,#1790),#1791);
#20383= IFCRELDEFINESBYTYPE('0UaJahpgP1Hg2k$LU7zIVP',#5,$,$,(#17694,#17654,#17608,#17568,#17417,#17377,#17324,#17284,#17238,#17198,#17152,#17112,#17050,#17010,#9662,#9603,#9370,#9314,#8787,#8485,#8405,#7984,#7906,#7486,#7427,#6752,#6677,#6194,#6050,#3847,#3778,#3641,#3576,#3447,#3351,#2434,#2378,#2297,#2239,#2144,#2098,#1996,#1833),#1834);
#20384= IFCRELDEFINESBYTYPE('0tbbGo7gzFBuJhUSeQ0TmE',#5,$,$,(#7916,#7437,#6684,#6079,#3789,#3586,#3380,#2391,#2253,#2108,#1899),#1900);
#20385= IFCRELDEFINESBYTYPE('23yEFBKWLB4BuvcSF$5aBB',#5,$,$,(#7289,#7198,#6823,#6815,#6807,#6794,#6773,#4333,#4317,#3708,#3689,#3670,#3501,#3493,#3484,#3254,#3240,#3205),#3206);
#20386= IFCRELDEFINESBYTYPE('0KEvl61Lr0VPj5TiatgXEJ',#5,$,$,(#16332,#16173,#16086,#16080,#16074,#16067,#16059,#16043,#16036,#16030,#16014,#16006,#15975,#15927,#15878,#15833,#15786,#15386,#15378,#15372,#15343,#15331,#15321,#15283,#15277,#15271,#15256,#15250,#15239,#15232,#15226,#15204,#15196,#15186,#15178,#15172,#15156,#15146,#15128,#15112,#15104,#15071,#15059,#13517,#11413,#11384,#11362,#11183,#11144,#11129,#11012,#10999,#10945,#10799,#10751,#10745,#10692,#10667,#9828,#8902,#8872,#4085,#4040),#4041);
#20387= IFCRELDEFINESBYTYPE('3Hm7eXnM5AogggzoeicBOC',#5,$,$,(#17494,#17463,#16559,#16532,#16490,#16439,#16384,#11903,#11796,#11470,#4178),#4179);
#20388= IFCRELDEFINESBYTYPE('3WLoU51eT0Px8EZwTWDF6V',#5,$,$,(#11952,#11943,#11930,#11717,#11499,#11254,#10501,#10216,#4930,#4432),#4433);
#20389= IFCRELDEFINESBYTYPE('10ayGHLGjEYuf6dJJVsi8I',#5,$,$,(#11849,#10035,#9971,#4519),#4520);
#20390= IFCRELDEFINESBYTYPE('2aoNXDnn51sOfox8cIZE5P',#5,$,$,(#10621,#10609,#10596,#10584,#10572,#10553,#9534,#9213,#8717,#4606),#4607);
#20391= IFCRELDEFINESBYTYPE('2fAW6Z$fnFXxxkW40ZAPgG',#5,$,$,(#17522,#17514,#12675,#12529,#12335,#7530,#5674,#5640),#5641);
#20392= IFCRELDEFINESBYTYPE('0ebcw3R9HA2xM8749BLtyz',#5,$,$,(#16287,#16256,#16247,#16238,#16229,#16220,#16211,#16202,#15694,#15684,#15676,#15668,#15651,#15616,#15604,#15591,#15567,#15557,#15549,#15533,#15525,#15517,#15497,#15489,#15481,#15435,#15418,#15398,#13442,#13434,#13426,#13279,#13271,#13263,#12876,#12844,#12810,#12046,#5768),#5769);
#20393= IFCRELDEFINESBYTYPE('2W4HroxvX4Se70D0wqIY5q',#5,$,$,(#8001,#7933,#7503,#7447,#6763,#6698,#6215,#6113),#6114);
#20394= IFCRELDEFINESBYTYPE('0x7g_vuT1BLhKHhCiiv3Kw',#5,$,$,(#7231,#7217),#7218);
#20395= IFCRELDEFINESBYTYPE('3u7FxWd3fFxRlBB6FSU84a',#5,$,$,(#7244),#7245);
#20396= IFCRELDEFINESBYTYPE('0LRHOtuy1CuAB9qCiNr$hn',#5,$,$,(#8109),#8110);
#20397= IFCRELDEFINESBYTYPE('3m7yJF6$v11QjBLO2Sf090',#5,$,$,(#16295,#16181,#16156,#16136,#15958,#15938,#15910,#15886,#15861,#15841,#15816,#15796,#15749,#15707,#9176,#9077,#8225,#8187),#8188);
#20398= IFCRELDEFINESBYTYPE('3xhhkZSB1BoRlaT9AFvAd3',#5,$,$,(#17432,#16513,#16466,#16411,#16344,#11048,#8948),#8949);
#20399= IFCRELDEFINESBYTYPE('0QYvPfwMH9MQ2fOoMuwMth',#5,$,$,(#17441,#16522,#16474,#16419,#16356,#11079,#10925,#8995),#8996);
#20400= IFCRELDEFINESBYTYPE('3_ygVPrvf45v5whEhJTHtZ',#5,$,$,(#17755,#17614,#17423,#17330,#17244,#17158,#17058,#9379),#9380);
#20401= IFCRELDEFINESBYTYPE('02SF_r4ZH7fQNXa1Yy_GBj',#5,$,$,(#9714),#9715);
#20402= IFCRELDEFINESBYTYPE('1vIP71w918GuRbA1fjNblw',#5,$,$,(#9791),#9792);
#20403= IFCRELDEFINESBYTYPE('3NYl7a6GD2GfYJYefGC557',#5,$,$,(#9903),#9904);
#20404= IFCRELDEFINESBYTYPE('3GJNcfN6T8KeMiplgVfG4r',#5,$,$,(#11737,#10528,#10292),#10293);
#20405= IFCRELDEFINESBYTYPE('1Zz37_ivD7igkaCDB6moYT',#5,$,$,(#10895),#10896);
#20406= IFCRELDEFINESBYTYPE('1gm7uk$Xv8wBf9ihiVT5SX',#5,$,$,(#12069),#12070);
#20407= IFCRELDEFINESBYTYPE('2PHdaDV6T598GOGqY62fHx',#5,$,$,(#12181,#12153,#12109),#12110);
#20408= IFCRELDEFINESBYTYPE('22q_HyUSD4wPoQpq66SORU',#5,$,$,(#17816,#17801,#16961,#16946,#16931,#16916,#16883,#13474,#13311,#13005),#13006);
#20409= IFCRELDEFINESBYTYPE('3N1$w9bEf4wQSwkan$j99$',#5,$,$,(#17786,#17730,#17718,#17706,#16861,#16828,#16816,#16781,#16769,#16738,#16726,#16688,#16667,#16596,#13486,#13323,#13045),#13046);
#20410= IFCRELDEFINESBYTYPE('0$QyNrK3L6mBkw_5D56lpO',#5,$,$,(#17761,#17736,#16835,#16787,#16744,#16694,#16618,#13492,#13329,#13081),#13082);
#20411= IFCRELDEFINESBYTYPE('3JWTQMHYT7yeML5l5_MOjU',#5,$,$,(#17774,#17749,#16848,#16802,#16757,#16708,#16642,#13505,#13342,#13139),#13140);
#20412= IFCRELDEFINESBYTYPE('3522ZptlD3TQ1lunZjzT$K',#5,$,$,(#13354,#13181),#13182);
#20413= IFCRELDEFINESBYTYPE('0OPqFdtxLE28JA4z7UxaFe',#5,$,$,(#13604),#13605);
#20414= IFCRELDEFINESBYTYPE('3yyqyFTDz6Q93ncv96ZFiK',#5,$,$,(#13654),#13655);
#20415= IFCRELDEFINESBYTYPE('2nEzNrMWfEa8b64Ub3FbSU',#5,$,$,(#13704),#13705);
#20416= IFCRELDEFINESBYTYPE('1XHza9MxfBSwhTBFuhopbm',#5,$,$,(#17840),#17841);
#20417= IFCRELDEFINESBYTYPE('1K1acYkz99nwsup35ZF51V',#5,$,$,(#17882),#17883);
#20418= IFCRELDEFINESBYTYPE('1P4f8G8x15oec3kpOj7ktt',#5,$,$,(#17920),#17921);
#20419= IFCRELDEFINESBYTYPE('2Gm5zQGxf46ww4OODxjHV0',#5,$,$,(#18007,#17999,#17991,#17983,#17975,#17953),#17954);
#20420= IFCRELDEFINESBYTYPE('2MiJk1KZ16Q9dPiVFjNkrI',#5,$,$,(#18159,#18150,#18144,#18138,#18114,#18078,#18061,#18052,#18024),#18025);
#20421= IFCRELDEFINESBYTYPE('0vapRQjAXAC8Rrp_qLd4F4',#5,$,$,(#18275,#18181),#18182);
#20422= IFCRELDEFINESBYTYPE('3u23PzEpf7fPItDEXVtuzT',#5,$,$,(#18236),#18237);
#20423= IFCRELDEFINESBYTYPE('1Ki5SeN$f31QX7MFIUYHXh',#5,$,$,(#18314),#18315);
#20424= IFCRELDEFINESBYTYPE('0pnJWhKr900PGcIpd7B1RO',#5,$,$,(#18363),#18364);
#20425= IFCRELDEFINESBYTYPE('0PhnwwwjT2Iep38LWCCEOz',#5,$,$,(#18457),#18458);
#20426= IFCRELDEFINESBYTYPE('38hn8SxvfCBh4MlwwVAcwi',#5,$,$,(#18624),#18625);
#20427= IFCRELDEFINESBYTYPE('1DFLEpm3vDce6yOq5n9Tzp',#5,$,$,(#18707,#18671),#18672);
#20428= IFCRELASSOCIATESMATERIAL('3RXDFiKSnAuB$rnFyxO157',#5,$,$,(#18007,#17999,#17991,#17983,#17975,#17953,#17816,#17801,#17786,#17774,#17761,#17755,#17749,#17736,#17730,#17718,#17706,#17614,#17522,#17514,#17494,#17463,#17441,#17432,#17423,#17330,#17244,#17158,#17058,#16961,#16946,#16931,#16916,#16883,#16861,#16848,#16835,#16828,#16816,#16802,#16787,#16781,#16769,#16757,#16744,#16738,#16726,#16708,#16694,#16688,#16667,#16642,#16618,#16596,#16559,#16532,#16522,#16513,#16490,#16474,#16466,#16439,#16419,#16411,#16384,#16356,#16344,#16332,#16321,#16315,#16309,#16301,#16295,#16287,#16278,#16272,#16266,#16256,#16247,#16238,#16229,#16220,#16211,#16202,#16193,#16187,#16181,#16173,#16162,#16156,#16148,#16142,#16136,#16127,#16121,#16115,#16109,#16093,#16086,#16080,#16074,#16067,#16059,#16049,#16043,#16036,#16030,#16024,#16014,#16006,#15987,#15981,#15975,#15964,#15958,#15950,#15944,#15938,#15927,#15916,#15910,#15900,#15892,#15886,#15878,#15867,#15861,#15853,#15847,#15841,#15833,#15822,#15816,#15808,#15802,#15796,#15786,#15755,#15749,#15733,#15718,#15707,#15694,#15684,#15676,#15668,#15651,#15640,#15634,#15628,#15616,#15604,#15591,#15579,#15567,#15557,#15549,#15541,#15533,#15525,#15517,#15507,#15497,#15489,#15481,#15472,#15466,#15453,#15435,#15418,#15398,#15386,#15378,#15372,#15366,#15343,#15331,#15321,#15296,#15283,#15277,#15271,#15265,#15256,#15250,#15239,#15232,#15226,#15216,#15204,#15196,#15186,#15178,#15172,#15166,#15156,#15146,#15128,#15112,#15104,#15087,#15071,#15059,#13578,#13572,#13566,#13560,#13554,#13545,#13534,#13523,#13517,#13505,#13492,#13486,#13474,#13462,#13456,#13450,#13442,#13434,#13426,#13413,#13402,#13390,#13354,#13342,#13329,#13323,#13311,#13299,#13293,#13287,#13279,#13271,#13263,#13252,#13243,#13234,#13181,#13139,#13081,#13045,#13005,#12964,#12953,#12921,#12876,#12844,#12810,#12780,#12761,#12741,#12675,#12529,#12514,#12508,#12502,#12496,#12480,#12335,#12181,#12153,#12109,#12069,#12046,#12020,#11984,#11952,#11943,#11930,#11903,#11849,#11796,#11737,#11717,#11499,#11470,#11413,#11384,#11362,#11331,#11254,#11183,#11160,#11144,#11129,#11079,#11048,#11012,#10999,#10945,#10925,#10895,#10834,#10799,#10769,#10751,#10745,#10692,#10667,#10528,#10501,#10292,#10216,#10035,#9971,#9903,#9828,#9791,#9674,#9512,#9500,#9486,#9467,#9452,#9379,#9184,#9176,#9150,#9119,#9077,#8995,#8948,#8902,#8872,#8652,#8622,#8590,#8561,#8538,#8259,#8225,#8187,#8109,#8034,#8027,#8020,#8007,#8001,#7933,#7916,#7860,#7851,#7838,#7803,#7796,#7789,#7783,#7777,#7766,#7759,#7751,#7740,#7731,#7721,#7714,#7705,#7690,#7530,#7503,#7447,#7437,#7389,#7380,#7371,#7364,#7357,#7350,#7334,#7323,#7289,#7280,#7273,#7266,#7258,#7244,#7231,#7217,#7198,#7186,#7176,#7169,#7160,#7145,#6823,#6815,#6807,#6794,#6773,#6763,#6698,#6684,#6628,#6619,#6610,#6604,#6598,#6592,#6586,#6579,#6573,#6567,#6561,#6555,#6549,#6543,#6537,#6531,#6525,#6519,#6507,#6485,#6479,#6473,#6467,#6461,#6451,#6445,#6438,#6431,#6425,#6416,#6410,#6402,#6395,#6215,#6113,#6079,#5989,#5958,#5937,#5902,#5895,#5888,#5880,#5768,#5674,#5640,#5609,#5603,#5597,#5591,#5571,#5541,#5527,#5521,#5515,#5509,#5503,#5481,#5460,#5446,#5433,#5415,#5409,#5395,#5383,#5368,#5352,#5345,#5317,#5288,#5253,#5217,#4930,#4519,#4432,#4333,#4317,#4303,#4296,#4267,#4224,#4178,#4085,#4040,#3990,#3947,#3789,#3729,#3721,#3708,#3689,#3670,#3659,#3650,#3586,#3520,#3510,#3501,#3493,#3484,#3473,#3464,#3380,#3290,#3273,#3254,#3240,#3205,#3176,#3161,#3146,#3110,#3102,#3096,#3089,#3076,#3040,#3034,#3028,#3021,#2999,#2945,#2922,#2898,#2870,#2391,#2328,#2317,#2253,#2188,#2177,#2166,#2155,#2108,#2051,#2040,#2029,#2018,#1899,#1677,#1635,#1608,#1597,#1573,#1537,#1528,#1519,#1510,#1491,#1480,#1462,#1442,#1402,#1384,#1375,#1366,#1343,#1337,#1317,#1293,#1282,#1275,#1265,#1254,#1241,#1235,#1226,#1190,#1111,#1085,#1050,#1006,#964,#948,#913,#546,#508,#157,#118,#68),#104);
#20429= IFCRELASSOCIATESMATERIAL('2A7GgPo9D4EPcKZB_sWxOU',#5,$,$,(#14918,#14888,#14858,#14828,#14798,#14768,#14738,#14708,#14678,#14648,#14506,#14476,#14261,#14197,#14167,#12663,#12633,#12603,#12573,#12474,#12444,#12414,#12384,#12319,#12289,#12259,#12229,#11711,#11681,#11651,#11621,#11591,#11561,#11531,#10495,#10465,#10435,#10405,#10375,#10345,#10204,#10174,#10144,#10114,#10084,#9776,#7003,#6973,#6943,#6913,#6883,#6853,#5745,#5193,#5163,#5133,#5103,#5073,#5043,#4917,#4887,#4857,#4827,#4791,#2805,#2763,#2673,#2631,#2537,#2492,#482,#452,#422,#392,#362,#332,#302,#253),#272);
#20430= IFCRELASSOCIATESMATERIAL('1HqSJ_WlTCIOCWySHoGVZ$',#5,$,$,(#15048,#15020,#15007,#14995,#14967,#14955,#14942,#14930,#14618,#14590,#14562,#14534,#14446,#14433,#14421,#14409,#14396,#14384,#14372,#14359,#14347,#14335,#14322,#14310,#14298,#14285,#14273,#14225,#14137,#14097,#14069,#14041,#14007,#13979,#13951,#13923,#13895,#13867,#13839,#13811,#13783,#13755,#13384,#13228,#12733,#11310,#11244,#11123,#10988,#10881,#10739,#10649,#9439,#9426,#9414,#9061,#9044,#9032,#8851,#8528,#8507,#8168,#8150,#8065,#7680,#7650,#7638,#7626,#7596,#7584,#7572,#7560,#7135,#7105,#7075,#7063,#7051,#7039,#7027,#7015,#6386,#6356,#6326,#6314,#6302,#6272,#6260,#6248,#6236,#5869,#5854,#5842,#5830,#5818,#5806,#5013,#4982,#4741,#4705,#4406,#3911,#2853,#2841,#2829,#2817,#2775,#2733,#2721,#2709,#2697,#2685,#2643,#2601,#2589,#2576,#2563,#2550,#2507,#2449,#884,#872,#860,#848,#836,#824,#812,#800,#788,#776,#764,#752,#740,#728,#716,#704,#692,#680,#666,#651,#633,#610,#594,#569),#582);
#20431= IFCRELASSOCIATESMATERIAL('0WgR0$EAj0f9vYmsr5bTfn',#5,$,$,(#18159,#18150,#18144,#18138,#18114,#18078,#18061,#18052,#18024,#17920,#17882,#17840,#17686,#17678,#17670,#17662,#17646,#17638,#17630,#17622,#17600,#17592,#17584,#17576,#17559,#17550,#17541,#17532,#17409,#17401,#17393,#17385,#17368,#17359,#17350,#17341,#17316,#17308,#17300,#17292,#17276,#17268,#17260,#17252,#17230,#17222,#17214,#17206,#17190,#17182,#17174,#17166,#17144,#17136,#17128,#17120,#17104,#17096,#17088,#17080,#17042,#17034,#17026,#17018,#17001,#16992,#16983,#16971,#9651,#9640,#9628,#9614,#9592,#9582,#9571,#9558,#9362,#9354,#9346,#9335,#9298,#9281,#9263,#9240,#8776,#8766,#8754,#8743,#8472,#8460,#8446,#8430,#8379,#8361,#8335,#8302,#7970,#7957,#7944,#7892,#7881,#7871,#7472,#7464,#7456,#7415,#7406,#7398,#6738,#6725,#6709,#6663,#6652,#6639,#6175,#6161,#6145,#6035,#6019,#6005,#3831,#3818,#3804,#3765,#3751,#3740,#3629,#3615,#3601,#3563,#3549,#3536,#3433,#3419,#3407,#3334,#3320,#3308,#2423,#2415,#2407,#2361,#2350,#2339,#2280,#2272,#2264,#2221,#2210,#2199,#2136,#2128,#2120,#2084,#2073,#2062,#1973,#1956,#1936,#1790,#1766,#1726),#1756);
#20432= IFCRELASSOCIATESMATERIAL('1cIopX5Cj7MwXoQnSQM$46',#5,$,$,(#17694,#17654,#17608,#17568,#17417,#17377,#17324,#17284,#17238,#17198,#17152,#17112,#17050,#17010,#9662,#9603,#9370,#9314,#8787,#8485,#8405,#7984,#7906,#7486,#7427,#6752,#6677,#6194,#6050,#3847,#3778,#3641,#3576,#3447,#3351,#2434,#2378,#2297,#2239,#2144,#2098,#1996,#1833),#1855);
#20433= IFCRELASSOCIATESMATERIAL('2dGyQCHJH3Ufo7XozPrHNs',#5,$,$,(#10621,#10609,#10596,#10584,#10572,#10553,#9534,#9213,#8717,#4606),#4632);
#20434= IFCRELASSOCIATESMATERIAL('3nsrqfGAnBQAR1Kl6XV1lm',#5,$,$,(#18707,#18671,#18624,#18457,#18363,#18314,#18275,#18236,#18181,#13704,#13654,#13604,#9714),#9746);
#20435= IFCPRESENTATIONLAYERASSIGNMENT('ANKRAJ',$,(#17759,#17753,#17734,#17612,#17421,#17328,#17242,#17156,#17055,#16833,#16785,#16742,#16692,#16616,#16319,#16293,#16276,#16179,#16154,#16134,#15956,#15936,#15908,#15884,#15859,#15839,#15814,#15794,#15747,#15704,#15638,#15577,#15539,#15505,#15470,#13490,#13460,#13327,#13297,#13078,#12961,#12017,#11981,#9671,#9498,#9450,#9376,#9174,#9074,#8649,#8536,#8222,#8184,#8025,#8018,#7999,#7931,#7836,#7757,#7749,#7712,#7703,#7501,#7445,#7355,#7348,#7321,#7229,#7215,#7167,#7158,#6761,#6696,#6529,#6523,#6505,#6443,#6436,#6408,#6400,#6212,#6110,#5935,#5444,#5430,#5381,#5365,#5285,#5250,#3657,#3648,#3471,#3462,#3174,#3159,#3144,#3073,#2996,#2164,#2153,#2027,#2016,#1606,#1595,#1571,#1440,#1291,#1187,#543,#505,#154,#116,#65),$);
#20436= IFCPRESENTATIONLAYERASSIGNMENT('',$,(#15046,#15018,#15005,#14993,#14965,#14953,#14940,#14928,#14916,#14886,#14856,#14826,#14796,#14766,#14736,#14706,#14676,#14646,#14616,#14588,#14560,#14532,#14504,#14474,#14444,#14431,#14419,#14407,#14394,#14382,#14370,#14357,#14345,#14333,#14320,#14308,#14296,#14283,#14271,#14259,#14223,#14195,#14165,#14135,#14095,#14067,#14039,#14005,#13977,#13949,#13921,#13893,#13865,#13837,#13809,#13781,#13753,#13382,#13226,#12731,#12661,#12631,#12601,#12571,#12472,#12442,#12412,#12382,#12317,#12287,#12257,#12227,#11709,#11679,#11649,#11619,#11589,#11559,#11529,#11308,#11242,#11121,#10986,#10879,#10737,#10647,#10493,#10463,#10433,#10403,#10373,#10343,#10202,#10172,#10142,#10112,#10082,#9774,#9437,#9424,#9412,#9059,#9042,#9030,#8849,#8526,#8505,#8166,#8148,#8063,#7678,#7648,#7636,#7624,#7594,#7582,#7570,#7558,#7133,#7103,#7073,#7061,#7049,#7037,#7025,#7013,#7001,#6971,#6941,#6911,#6881,#6851,#6384,#6354,#6324,#6312,#6300,#6270,#6258,#6246,#6234,#5867,#5852,#5840,#5828,#5816,#5804,#5743,#5191,#5161,#5131,#5101,#5071,#5041,#5011,#4980,#4915,#4885,#4855,#4825,#4789,#4739,#4703,#4404,#3909,#2851,#2839,#2827,#2815,#2803,#2773,#2761,#2731,#2719,#2707,#2695,#2683,#2671,#2641,#2629,#2599,#2587,#2574,#2561,#2548,#2535,#2505,#2490,#2447,#882,#870,#858,#846,#834,#822,#810,#798,#786,#774,#762,#750,#738,#726,#714,#702,#690,#678,#664,#649,#631,#608,#592,#567,#480,#450,#420,#390,#360,#330,#300,#251),$);
#20437= IFCPRESENTATIONLAYERASSIGNMENT('DETAY',$,(#18005,#17997,#17989,#17981,#17973,#17951,#17430,#16511,#16464,#16409,#16342,#16313,#16307,#16299,#16270,#16264,#16191,#16185,#16160,#16146,#16140,#16047,#16022,#15979,#15962,#15948,#15942,#15914,#15898,#15890,#15865,#15851,#15845,#15820,#15806,#15800,#15753,#15731,#15716,#15632,#15626,#15464,#15451,#15364,#15293,#15263,#15214,#15164,#15085,#13454,#13448,#13291,#13285,#12951,#12918,#11328,#11157,#11045,#10831,#10766,#9510,#9484,#9465,#9182,#9148,#9116,#8945,#8619,#8588,#8558,#8256,#8032,#8005,#7801,#7764,#7738,#7729,#7719,#7688,#7369,#7362,#7332,#7287,#7242,#7196,#7184,#7174,#7143,#6571,#6535,#6517,#6483,#6449,#6429,#6423,#6414,#6393,#5525,#5458,#5413,#5407,#5393,#5350,#5343,#5314,#5214,#4331,#4315,#3987,#1478,#1460,#1335,#1315,#1233,#1224,#946,#910),$);
#20438= IFCPRESENTATIONLAYERASSIGNMENT('PLATE',$,(#16125,#16119,#16113,#16107,#16091,#15985,#13576,#13570,#13564,#13558,#13552,#13543,#13532,#13521,#13411,#13400,#13388,#13250,#13241,#13232,#12778,#12758,#12739,#12512,#12506,#12500,#12494,#12478,#7794,#7787,#7781,#7775,#7278,#7271,#7264,#7256,#6821,#6813,#6805,#6792,#6771,#6608,#6602,#6596,#6590,#6584,#6577,#6565,#6559,#6553,#6547,#6541,#6477,#6471,#6465,#6459,#5900,#5893,#5886,#5878,#5607,#5601,#5595,#5589,#5568,#5538,#5519,#5513,#5507,#5501,#5478,#4301,#4294,#4264,#4221,#3944,#3706,#3687,#3668,#3499,#3491,#3482,#3252,#3238,#3202,#3108,#3100,#3094,#3087,#3038,#3032,#3026,#3019,#2943,#2919,#2896,#2867,#1535,#1526,#1517,#1508,#1489,#1400,#1382,#1373,#1364,#1341,#1280,#1273,#1263,#1252,#1239,#1109,#1082,#1047,#1003,#961),$);
#20439= IFCPRESENTATIONLAYERASSIGNMENT('PUL',$,(#7858,#7849,#7387,#7378,#6626,#6617,#5986,#5955,#3727,#3719,#3517,#3508,#3287,#3270,#2326,#2315,#2186,#2175,#2049,#2038,#1674,#1632),$);
#20440= IFCPRESENTATIONLAYERASSIGNMENT('NUT',$,(#17684,#17676,#17668,#17644,#17636,#17628,#17598,#17590,#17582,#17557,#17548,#17539,#17407,#17399,#17391,#17366,#17357,#17348,#17314,#17306,#17298,#17274,#17266,#17258,#17228,#17220,#17212,#17188,#17180,#17172,#17142,#17134,#17126,#17102,#17094,#17086,#17040,#17032,#17024,#16999,#16990,#16981,#9649,#9638,#9626,#9590,#9580,#9569,#9360,#9352,#9344,#9296,#9279,#9260,#8774,#8764,#8752,#8470,#8458,#8444,#8377,#8358,#8332,#7954,#7941,#7878,#7868,#7462,#7454,#7404,#7396,#6722,#6706,#6649,#6636,#6158,#6142,#6016,#6002,#3816,#3801,#3749,#3737,#3613,#3598,#3546,#3533,#3417,#3404,#3318,#3305,#2413,#2405,#2348,#2337,#2270,#2262,#2208,#2197,#2126,#2118,#2071,#2060,#1953,#1933,#1763,#1723),$);
#20441= IFCPRESENTATIONLAYERASSIGNMENT('WASHER',$,(#17660,#17620,#17574,#17530,#17383,#17339,#17290,#17250,#17204,#17164,#17118,#17078,#17016,#16969,#9612,#9556,#9333,#9237,#8741,#8428,#8299,#7967,#7889,#7470,#7413,#6735,#6660,#6172,#6032,#3828,#3762,#3626,#3560,#3430,#3331,#2421,#2359,#2278,#2219,#2134,#2082,#1970,#1787),$);
#20442= IFCPRESENTATIONLAYERASSIGNMENT('ROD',$,(#17692,#17652,#17606,#17566,#17415,#17375,#17322,#17282,#17236,#17196,#17150,#17110,#17048,#17008,#9660,#9601,#9368,#9311,#8785,#8483,#8402,#7981,#7903,#7484,#7425,#6749,#6674,#6191,#6047,#3845,#3776,#3639,#3574,#3444,#3348,#2432,#2376,#2295,#2237,#2142,#2096,#1993,#1830),$);
#20443= IFCPRESENTATIONLAYERASSIGNMENT('ANCHOR',$,(#7914,#7435,#6682,#6076,#3787,#3584,#3377,#2389,#2251,#2106,#1896),$);
#20444= IFCPRESENTATIONLAYERASSIGNMENT('DIKME',$,(#17814,#17799,#17784,#17772,#17747,#17728,#17716,#17704,#17439,#16959,#16944,#16929,#16914,#16880,#16859,#16846,#16826,#16814,#16800,#16779,#16767,#16755,#16736,#16724,#16706,#16686,#16665,#16640,#16593,#16520,#16472,#16417,#16354,#16330,#16171,#16084,#16078,#16072,#16065,#16057,#16041,#16034,#16028,#16012,#16004,#15973,#15925,#15876,#15831,#15784,#15384,#15376,#15370,#15340,#15329,#15319,#15281,#15275,#15269,#15254,#15248,#15237,#15230,#15224,#15202,#15194,#15184,#15176,#15170,#15154,#15144,#15125,#15109,#15102,#15068,#15057,#13515,#13503,#13484,#13472,#13352,#13340,#13321,#13309,#13178,#13136,#13042,#13002,#12178,#12150,#12106,#11410,#11381,#11359,#11180,#11142,#11127,#11076,#11010,#10997,#10942,#10922,#10893,#10796,#10749,#10743,#10689,#10664,#9825,#8992,#8899,#8869,#8106,#4082,#4037),$);
#20445= IFCPRESENTATIONLAYERASSIGNMENT('KIRIS',$,(#17520,#17512,#17492,#17461,#16556,#16530,#16488,#16436,#16381,#12673,#12526,#12332,#11900,#11846,#11793,#11734,#11467,#10525,#10289,#10033,#9969,#9901,#7527,#5671,#5637,#4517,#4175),$);
#20446= IFCPRESENTATIONLAYERASSIGNMENT('Cap plate',$,(#11950,#11941,#11928,#11715,#11497,#11252,#10499,#10213,#4927,#4429),$);
#20447= IFCPRESENTATIONLAYERASSIGNMENT('GROUT',$,(#10619,#10607,#10594,#10582,#10570,#10551,#9532,#9211,#8714,#4603),$);
#20448= IFCPRESENTATIONLAYERASSIGNMENT('PLAKA',$,(#16285,#16254,#16245,#16236,#16227,#16218,#16209,#16200,#15692,#15682,#15674,#15666,#15649,#15614,#15602,#15589,#15565,#15555,#15547,#15531,#15523,#15515,#15495,#15487,#15479,#15433,#15416,#15396,#13440,#13432,#13424,#13277,#13269,#13261,#12873,#12842,#12807,#12044,#9789,#5765),$);
#20449= IFCPRESENTATIONLAYERASSIGNMENT('SLAB',$,(#13701,#13651,#13601,#9711),$);
#20450= IFCPRESENTATIONLAYERASSIGNMENT('BEAM',$,(#12066),$);
#20451= IFCPRESENTATIONLAYERASSIGNMENT('GOMULU LEVHA',$,(#18157,#18148,#18142,#18136,#18111,#18075,#18059,#18050,#18021,#17917,#17879,#17837),$);
#20452= IFCPRESENTATIONLAYERASSIGNMENT('BA PARAPET',$,(#18272,#18178),$);
#20453= IFCPRESENTATIONLAYERASSIGNMENT('DOSEME',$,(#18621,#18454,#18360,#18311,#18233),$);
#20454= IFCPRESENTATIONLAYERASSIGNMENT('COLUMN',$,(#18705,#18668),$);
ENDSEC;
END-ISO-10303-21;
@nikitron : thx for reporting. However, according guidelines (big yellow box on top of page), could you please first open a topic in the forum ? Think about adding valuable information, such as your full FC version info, an example file and/or a step-by-step process to reproduce. ;) As is, your ticket is basically unusable. :) |
example ifc file in comment about version FreeCAD-0.18.16131.3129ae4-WIN-x64-installer just downloaded. steps are - import button or drug-drop anyway error. |
for some reason this ticket is only visible if the user is logged in? |
found it set status to public. I just changed it. |
@nikitron is this still an issue ? |
@nikitron ping |
Closed. Bernd, please next time associate the commit to the ticket. Thanks |
| 2019-10-09 11:17 | nikitron | New Issue | |
| 2019-10-09 11:17 | nikitron | Tag Attached: Arch | |
| 2019-10-09 11:17 | nikitron | Tag Attached: IFC | |
| 2019-10-09 11:17 | nikitron | Tag Attached: import | |
| 2019-10-09 11:17 | nikitron | File Added: Угловая стойка к.А.ifc | |
| 2019-10-09 14:04 | openBrain | Note Added: 0013728 | |
| 2019-10-09 14:05 | openBrain | Tag Attached: #post-to-forum | |
| 2019-10-09 14:05 | openBrain | Tag Detached: Arch | |
| 2019-10-09 14:05 | openBrain | Status | new => feedback |
| 2019-10-09 14:05 | openBrain | Description Updated | |
| 2019-10-09 14:09 | nikitron | Note Added: 0013729 | |
| 2019-10-09 14:09 | nikitron | Status | feedback => new |
| 2019-10-10 17:04 | berndhahnebach | Note Added: 0013737 | |
| 2019-10-10 17:05 | berndhahnebach | View Status | private => public |
| 2019-10-10 17:05 | berndhahnebach | Note Added: 0013738 | |
| 2019-10-10 17:05 | berndhahnebach | Note Edited: 0013738 | |
| 2019-12-17 04:17 | Kunda1 | Status | new => feedback |
| 2019-12-17 04:17 | Kunda1 | Note Added: 0013925 | |
| 2019-12-29 13:35 | Kunda1 | Note Added: 0013952 | |
| 2020-01-06 16:22 | Kunda1 | Assigned To | => berndhahnebach |
| 2020-01-06 16:22 | Kunda1 | Status | feedback => closed |
| 2020-01-06 16:22 | Kunda1 | Resolution | open => fixed |
| 2020-01-06 16:22 | Kunda1 | Note Added: 0013998 | |
| 2020-01-06 16:22 | Kunda1 | Tag Detached: #post-to-forum | |
| 2020-01-06 16:22 | Kunda1 | Fixed in Version | => 0.19 |
