| 0004178 | FreeCAD | Bug | public | 2019-10-27 01:53 | 2021-02-06 06:49 |
| Reporter | garya | Assigned To | |||
| Platform | PC | OS | FreeBSD | OS Version | 11.2-RELEASE-p4 |
| Summary | 0004178: Part Design auto-generated Body not placed under existing Part | ||||
| Description | A sketch which auto-creates a Body does not place it under the active Part. Instead, it is placed at the same level as the active part. It should be placed under the part. See forum topic | ||||
| Steps To Reproduce | Create a new document Part Design WB Create Part Create Sketch, select xy plane, click ok Close the sketcher task View the model tab The auto-generated Body is at the same level as the Part; it should be under it. | ||||
| Tags | Part Design | ||||
| FreeCAD Information | OS: FreeBSD 11.2-RELEASE-p4 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.0.18.2 Build type: Release Python version: 3.6.9 Qt version: 5.12.2 Coin version: 3.1.3 OCC version: 7.3.0 Locale: C/Default (C) | ||||
