| 0004187 | Draft | Bug | public | 2019-11-06 11:35 | 2019-11-12 23:04 |
| Reporter | normen | Assigned To | carlopav | ||
| Summary | 0004187: Dwire editing breaks when Esc-ing out of edit session | ||||
| Description | System: MacOS 10.14.6 Versions: 0.18.3 and 0.19-pre (18589) When canceling a Dwire editing session with the Esc key or the "close" button Dwire editing breaks completely until FreeCAD is restarted. | ||||
| Steps To Reproduce | - Create new FreeCAD document - Create open Dwire with a few points - Finish editing Dwire - Double-click Dwire to edit again - Click on one point to move it (don't place it) - Press Esc to cancel edit - Double-click Dwire again to try editing again -> Dwires cannot be edited anymore until FreeCAD is restarted | ||||
| Additional Information | The reportView of 0.19-pre shows many "<class 'IndexError'>" messages when the mouse moves over the main view after this happens. | ||||
| FreeCAD Information | OS: macOS Mojave (10.14) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.18589 (Git) Build type: Release Branch: master Hash: 3500451a040989d00693eab85b2a7c13ce4dad67 Python version: 3.7.3 Qt version: 5.12.5 Coin version: 4.0.0a OCC version: 7.3.0 Locale: German/Germany (de_DE) | ||||
Thanks @normen for opening the ticket, I can reproduce it, I'll fix as soon as i can. |
Fixed with PR 2697 |
Wow that was fast :) Thanks, really exciting to see FreeCAD grow, great work. |
@normen : thanks for good report. However please notice that our guidelines (big yellow banner) ask to first open a forum topic co community can confirm and identify bug. ;) Just think about it for next reporting. :) |
Yeah, sorry, I'm a developer myself and I know how standard procedure makes things easier. However as this bug was easy to reproduce in a new document and it existed across multiple versions I just decided that it's real ;) |
@carlopav FYI, see the difference between remotely referencing a mantis ticket from github and remotely closing a mantis ticket from Github: https://freecadweb.org/wiki/tracker#GitHub_and_MantisBT In this scenario you only referenced it. Should we close this ticket manually ? |
Thanks @kunda, next time I'll do it right. I think we can close the ticket manually. :) |
| 2019-11-06 11:35 | normen | New Issue | |
| 2019-11-06 13:07 | carlopav | Assigned To | => carlopav |
| 2019-11-06 13:07 | carlopav | Status | new => assigned |
| 2019-11-06 13:08 | carlopav | Note Added: 0013799 | |
| 2019-11-06 20:06 | carlopav | Note Added: 0013800 | |
| 2019-11-06 20:08 | carlopav | Note Edited: 0013800 | |
| 2019-11-06 20:18 | normen | Note Added: 0013801 | |
| 2019-11-07 18:22 | openBrain | Note Added: 0013803 | |
| 2019-11-07 20:40 | normen | Note Added: 0013804 | |
| 2019-11-11 20:59 | yorik | Changeset attached | => FreeCAD master c9522a6e |
| 2019-11-12 22:42 | Kunda1 | Note Added: 0013822 | |
| 2019-11-12 23:04 | carlopav | Note Added: 0013823 | |
| 2019-11-12 23:04 | carlopav | Status | assigned => closed |
| 2019-11-12 23:04 | carlopav | Resolution | open => fixed |
| 2019-11-12 23:04 | carlopav | Fixed in Version | => 0.19 |
