| 0004190 | FreeCAD | Bug | public | 2019-11-07 10:30 | 2019-11-11 10:50 |
| Reporter | cbalint | Assigned To | wmayer | ||
| Priority | none | Severity | major | Reproducibility | always |
| Platform | Linux | OS | Fedora | ||
| Summary | 0004190: FreeCAD fail to build with OCE (community eddition) AKA support older OCC versions | ||||
| Description | This [PR#2680](https://github.com/FreeCAD/FreeCAD/pull/2680) introduced a hederfile [Standard_Handle.hxx](https://github.com/FreeCAD/FreeCAD/blob/master/src/Mod/TechDraw/App/DrawDimHelper.h#L26) not available in OCE community edition. Unsure if it is intentional, is FreeCAD dropping OCE support. Error is obvious: ``` [ 35%] Building CXX object src/Mod/TechDraw/App/CMakeFiles/TechDraw.dir/AppTechDrawPy.cpp.o In file included from /home/cbalint/rpmbuild/BUILD/FreeCAD/src/Mod/TechDraw/App/AppTechDrawPy.cpp:73: /home/cbalint/rpmbuild/BUILD/FreeCAD/src/Mod/TechDraw/App/DrawDimHelper.h:26:10: fatal error: Standard_Handle.hxx: No such file or directory 26 | #include <Standard_Handle.hxx> | ^~~~~~~~~~~~~~~~~~~~~ ``` Standard_Handle.hxx is not part of community edition of OCE (never was). | ||||
| Steps To Reproduce | Using FreeCAD master as of 07Nov2010. | ||||
| Additional Information | ``` -- -- OpenCASCADE Community Edition has been found. -- Found OCC: /usr/lib64/oce-0.18/../../include/oce (found version "6.9.1") -- -- Found OCE/OpenCASCADE version: 6.9.1 -- -- OCE/OpenCASCADE include directory: /usr/lib64/oce-0.18/../../include/oce -- -- OCE/OpenCASCADE shared libraries directory: ``` ``` ============== Summary report ============== -- Build type: -- Python: [/usr/bin/python3] [.cpython-38-x86_64-linux-gnu] -- PCL: 1.9.1 -- pybind11: 2.4.3 -- Boost: 106900 -- XercesC: [/usr/lib64/libxerces-c.so] [/usr/include] -- ZLIB: 1.2.11 -- PyCXX: [/usr/include] -- OCC: 6.9.1 [TKFillet;TKMesh;TKernel;TKG2d;TKG3d;TKMath;TKIGES;TKSTL;TKShHealing;TKXSBase;TKBin;TKBool;TKBO;TKCDF;TKBRep;TKTopAlgo;TKGeomAlgo;TKGeomBase;TKOffset;TKPrim;TKSTEP;TKSTEPBase;TKSTEPAttr;TKHLR;TKFeat] -- SMESH: build internal -- MEDFile: [/usr/lib64/libmedC.so;/usr/lib64/libmed.so] [/usr/include/med] -- HDF5: 1.10.5 -- VTK: 8.2.0 -- NETGEN: 6.2-dev [-DNO_PARALLEL_THREADS;-DOCCGEOMETRY;-DNETGEN_VERSION=393728] [] [/usr/include/netgen-mesher/include;/usr/include/netgen-mesher] [nglib] [/usr/include/netgen-mesher/include;/usr/include/netgen-mesher] -- SWIG: 4.0.1 -- Eigen3 3.3.7 -- Qt5Core: 5.12.5 -- Qt5Network: 5.12.5 -- Qt5Xml: 5.12.5 -- Qt5XmlPatterns: 5.12.5 -- Qt5Widgets: 5.12.5 -- Qt5PrintSupport: 5.12.5 -- Qt5OpenGL: 5.12.5 -- Qt5Svg: 5.12.5 -- Qt5UiTools: 5.12.5 -- Qt5Concurrent: 5.12.5 -- Qt5WebKitWidgets: 5.212.0 -- Shiboken2: 5.12.5 [/usr/lib64/cmake/Shiboken2-5.12.5] [/usr/include/shiboken2;/usr/include/python3.8] -- PySide2: 5.12.5 [/usr/include/PySide2] -- PySide2Tools: [/usr/bin/pyside2-uic] [/usr/bin/pyside2-rcc] -- Freetype: 2.10.0 -- OpenGLU: /usr/lib64/libGLU.so [/usr/lib64/libGLU.so][/usr/include] -- Coin3D: [Coin] [/usr/include/Coin4] -- SPNAV: [/usr/lib64/libspnav.so] [/usr/include] -- Matplotlib: 3.1.1 -- Rift: not enabled (BUILD_VR) -- Doxygen: not found ================================================= Now run 'cmake --build /home/cbalint/rpmbuild/BUILD/FreeCAD/build' to build FreeCAD ================================================= ``` | ||||
| FreeCAD Information | FreeCAD master branch. | ||||
@cbalint : please create a new topic in our forum to discuss this issue (according guidelines in the big yellow box on top of the page). Especially compiling issues are generally not bugs and are fast & well handle by community without requiring any reporting/tracking here. ;) Thx. |
@openBrain, * Did so under forum's 'Install/Compile' topic. * Referenced this Issue number there. Thank you ! |
@cbalint : that's the right place (actually saw there are already good answers there). ;) Link to said thread Ticket will be closed as is in the coming days except if developers need it as a reminder. |
wmayer added a fix in FreeCAD master ac4e2301 |
Thanks to all! Closing. |
| 2019-11-07 10:30 | cbalint | New Issue | |
| 2019-11-08 17:45 | openBrain | Note Added: 0013805 | |
| 2019-11-08 17:45 | openBrain | Tag Attached: #post-to-forum | |
| 2019-11-08 17:46 | openBrain | Priority | normal => none |
| 2019-11-08 17:46 | openBrain | Status | new => feedback |
| 2019-11-08 17:58 | cbalint | Note Added: 0013807 | |
| 2019-11-08 17:58 | cbalint | Status | feedback => new |
| 2019-11-09 10:07 | openBrain | Note Added: 0013811 | |
| 2019-11-09 10:07 | openBrain | Tag Detached: #post-to-forum | |
| 2019-11-09 10:08 | openBrain | Tag Attached: #pending-forum | |
| 2019-11-09 10:08 | openBrain | Tag Attached: #tobeclosed | |
| 2019-11-11 10:40 | Kunda1 | Tag Detached: #tobeclosed | |
| 2019-11-11 10:40 | Kunda1 | Tag Detached: #pending-forum | |
| 2019-11-11 10:40 | Kunda1 | Note Added: 0013819 | |
| 2019-11-11 10:41 | Kunda1 | Changeset attached | => FreeCAD master ac4e2301 |
| 2019-11-11 10:49 | Kunda1 | Summary | FreeCAD fail to build with OCE (community eddition) => FreeCAD fail to build with OCE (community eddition) AKA support older OCC versions |
| 2019-11-11 10:50 | Kunda1 | Assigned To | => wmayer |
| 2019-11-11 10:50 | Kunda1 | Status | new => closed |
| 2019-11-11 10:50 | Kunda1 | Resolution | open => fixed |
| 2019-11-11 10:50 | Kunda1 | Fixed in Version | => 0.19 |
| 2019-11-11 10:50 | Kunda1 | Note Added: 0013820 |
