| 0004198 | TechDraw | Bug | public | 2019-11-20 17:24 | 2019-12-11 11:57 |
| Reporter | SpeakerToMeat | Assigned To | wandererfan | ||
| Summary | 0004198: Deleting a subsection's figure while creating the subsection causes a crash | ||||
| Description | Deleting the figure/object on a subsection on TechDraw while the subsection is being created causes the dialog to stick in a loop and eventually a crash in FC. I attach a log created during a test session. More on this forum post: https://forum.freecadweb.org/viewtopic.php?f=35&t=41042 | ||||
| Steps To Reproduce | * Create any part (a cube works) or load a file with any part you can select to add a view in TechDraw * Select the view in tech draw and start the creation of a section * If you don't have a section already showing on the page at this stage just hit a viewing direction to get one (if you have one this is not needed). * Select the object inside the view, and hit the delete key, to delete it. You get a warning at breaking the page. Accept the delete. * Now on the Section creation dialog Reset works, but Ok and Cancel do not, giving this error: Unhandled std::exception caught in GUIApplication::notify. The error message is: basic_string::_M_construct null not valid * The only way to exit this loop is to click on one of the view selectors again which will cause FC to crash. | ||||
| FreeCAD Information | OS: Debian GNU/Linux 10 (buster) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18. Build type: Release Python version: 2.7.16rc1 Qt version: 5.11.3 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/UnitedStates (en_US) | ||||
crash-log.txt (15,857 bytes)
Msg: FreeCAD 0.18, Libs: 0.18R © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## Log: Time = Wed Nov 20 13:18:34 2019 Log: AppDataSkipVendor = true Log: AppHomePath = /usr/lib/freecad/ Log: AppIcon = freecad Log: AppTempPath = /tmp/ Log: BinPath = /usr/lib/freecad/bin/ Log: BuildRepositoryURL = https://code.launchpad.net/~vcs-imports/freecad/trunk Log: BuildRevision = Log: BuildRevisionDate = 2019/03/02 14:33:57 Log: BuildVersionMajor = 0 Log: BuildVersionMinor = 18 Log: Console = 0 Log: CopyrightInfo = © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## Log: Debug = 0 Log: DocPath = /usr/lib/freecad/doc/ Log: ExeName = FreeCAD Log: ExeVendor = FreeCAD Log: ExeVersion = 0.18 Log: LoggingFile = 1 Log: LoggingFileName = crash-log.txt Log: MaintainerUrl = http://www.freecadweb.org/wiki/Main_Page Log: PATH = /home/lars/.pyenv/plugins/pyenv-virtualenv/shims:/home/lars/.pyenv/shims:/home/lars/.pyenv/bin:/home/lars/bin:/home/lars/.pyenv/plugins/pyenv-virtualenv/shims:/home/lars/.pyenv/shims:/home/lars/.pyenv/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games:/snap/bin:/home/lars/.dotnet/tools:/home/lars/DCP/digital_cinema_tools:/home/lars/workspace/DRG/KDM-Tools:/home/lars/Android/Sdk/tools:/home/lars/Android/Sdk/platform-tools:/home/lars/scripts Log: PYTHONPATH = Log: PythonSearchPath = :/usr/lib/python2.7:/usr/lib/python2.7/plat-x86_64-linux-gnu:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload Log: RunMode = Gui Log: SplashAlignment = Bottom|Left Log: SplashInfoColor = #c8c8c8 Log: SplashScreen = freecadsplash Log: SplashTextColor = #ffffff Log: StartWorkbench = StartWorkbench Log: SystemParameter = /home/lars/.FreeCAD/system.cfg Log: UserAppData = /home/lars/.FreeCAD/ Log: UserHomePath = /home/lars Log: UserParameter = /home/lars/.FreeCAD/user.cfg Log: Verbose = Log: Create Application Log: Run App init script Log: Init: starting App::FreeCADInit.py Log: Init: Searching for modules... Log: Init: Initializing /usr/share/freecad/Mod/Sketcher... done Log: Init: Initializing /usr/share/freecad/Mod/ReverseEngineering... done Log: Init: Initializing /usr/share/freecad/Mod/Show(Init.py not found)... ignore Log: Init: Initializing /usr/share/freecad/Mod/Image... done Log: Init: Initializing /usr/share/freecad/Mod/Surface... done Log: Init: Initializing /usr/share/freecad/Mod/PartDesign... done Log: Init: Initializing /usr/share/freecad/Mod/Measure... done Log: Init: Initializing /usr/share/freecad/Mod/Ship(Init.py not found)... ignore Log: Init: Initializing /usr/share/freecad/Mod/Web... done Log: Init: Initializing /usr/share/freecad/Mod/MeshPart... done Log: Init: Initializing /usr/share/freecad/Mod/OpenSCAD... done Log: Init: Initializing /usr/share/freecad/Mod/Fem... done Log: Init: Initializing /usr/share/freecad/Mod/Spreadsheet... done Log: Init: Initializing /usr/share/freecad/Mod/Start... done Log: Init: Initializing /usr/share/freecad/Mod/AddonManager... done Log: Init: Initializing /usr/share/freecad/Mod/Draft... done Log: Init: Initializing /usr/share/freecad/Mod/Test... done Log: Init: Initializing /usr/share/freecad/Mod/Import... done Log: Init: Initializing /usr/share/freecad/Mod/TechDraw... done Log: Init: Initializing /usr/share/freecad/Mod/Tux(Init.py not found)... ignore Log: Init: Initializing /usr/share/freecad/Mod/Complete... done Log: Init: Initializing /usr/share/freecad/Mod/Plot(Init.py not found)... ignore Log: Init: Initializing /usr/share/freecad/Mod/Material... done Log: Init: Initializing /usr/share/freecad/Mod/Mesh... done Log: Init: Initializing /usr/share/freecad/Mod/Raytracing... done Log: Init: Initializing /usr/share/freecad/Mod/Part... done Log: Init: Initializing /usr/share/freecad/Mod/Path... done Log: Init: Initializing /usr/share/freecad/Mod/Arch... done Log: Init: Initializing /usr/share/freecad/Mod/Robot... done Log: Init: Initializing /usr/share/freecad/Mod/Points... done Log: Init: Initializing /usr/share/freecad/Mod/Idf... done Log: Init: Initializing /usr/share/freecad/Mod/Inspection... done Log: Init: Initializing /usr/share/freecad/Mod/Drawing... done Log: Using /usr/share/freecad/Mod as module path! Log: System path after init: Log: /usr/lib/freecad/bin Log: /usr/share/freecad/Mod/Sketcher Log: /usr/share/freecad/Mod/ReverseEngineering Log: /usr/share/freecad/Mod/Show Log: /usr/share/freecad/Mod/Image Log: /usr/share/freecad/Mod/Surface Log: /usr/share/freecad/Mod/PartDesign Log: /usr/share/freecad/Mod/Measure Log: /usr/share/freecad/Mod/Ship Log: /usr/share/freecad/Mod/Web Log: /usr/share/freecad/Mod/MeshPart Log: /usr/share/freecad/Mod/OpenSCAD Log: /usr/share/freecad/Mod/Fem Log: /usr/share/freecad/Mod/Spreadsheet Log: /usr/share/freecad/Mod/Start Log: /usr/share/freecad/Mod/AddonManager Log: /usr/share/freecad/Mod/Draft Log: /usr/share/freecad/Mod/Test Log: /usr/share/freecad/Mod/Import Log: /usr/share/freecad/Mod/TechDraw Log: /usr/share/freecad/Mod/Tux Log: /usr/share/freecad/Mod/Complete Log: /usr/share/freecad/Mod/Plot Log: /usr/share/freecad/Mod/Material Log: /usr/share/freecad/Mod/Mesh Log: /usr/share/freecad/Mod/Raytracing Log: /usr/share/freecad/Mod/Part Log: /usr/share/freecad/Mod/Path Log: /usr/share/freecad/Mod/Arch Log: /usr/share/freecad/Mod/Robot Log: /usr/share/freecad/Mod/Points Log: /usr/share/freecad/Mod/Idf Log: /usr/share/freecad/Mod/Inspection Log: /usr/share/freecad/Mod/Drawing Log: /home/lars/.pyenv/plugins/pyenv-virtualenv/shims Log: /home/lars/.pyenv/shims Log: /home/lars/.pyenv/bin Log: /home/lars/bin Log: /home/lars/.pyenv/plugins/pyenv-virtualenv/shims Log: /home/lars/.pyenv/shims Log: /home/lars/.pyenv/bin Log: /usr/local/bin Log: /usr/bin Log: /bin Log: /usr/local/games Log: /usr/games Log: /snap/bin Log: /home/lars/.dotnet/tools Log: /home/lars/DCP/digital_cinema_tools Log: /home/lars/workspace/DRG/KDM-Tools Log: /home/lars/Android/Sdk/tools Log: /home/lars/Android/Sdk/platform-tools Log: /home/lars/scripts Log: Init: App::FreeCADInit.py done Log: Init: Creating Gui::Application and QApplication Log: Local server 'FreeCAD' started Log: OpenGL version is: 4.6 (4.6.0 NVIDIA 418.74) Log: Run Gui init script Log: Init: Running FreeCADGuiInit.py start script... Log: Init: Searching modules... Log: Init: Initializing /usr/share/freecad/Mod/Sketcher... done Log: Init: Initializing /usr/share/freecad/Mod/ReverseEngineering... done Log: Init: Initializing /usr/share/freecad/Mod/Show(InitGui.py not found)... ignore Log: Init: Initializing /usr/share/freecad/Mod/Image... done Log: Init: Initializing /usr/share/freecad/Mod/Surface... done Log: Init: Initializing /usr/share/freecad/Mod/PartDesign... done Log: Init: Initializing /usr/share/freecad/Mod/Measure(InitGui.py not found)... ignore Log: Init: Initializing /usr/share/freecad/Mod/Ship... done Log: Init: Initializing /usr/share/freecad/Mod/Web... done Log: Init: Initializing /usr/share/freecad/Mod/MeshPart... done Log: Init: Initializing /usr/share/freecad/Mod/OpenSCAD... done Log: Init: Initializing /usr/share/freecad/Mod/Fem... done Log: Init: Initializing /usr/share/freecad/Mod/Spreadsheet... done Log: Init: Initializing /usr/share/freecad/Mod/Start... done Log: Init: Initializing /usr/share/freecad/Mod/AddonManager... done Log: Init: Initializing /usr/share/freecad/Mod/Draft... done Log: Init: Initializing /usr/share/freecad/Mod/Test... done Log: Init: Initializing /usr/share/freecad/Mod/Import... done Log: Init: Initializing /usr/share/freecad/Mod/TechDraw... done Log: Init: Initializing /usr/share/freecad/Mod/Tux... done Log: Init: Initializing /usr/share/freecad/Mod/Complete... done Log: Init: Initializing /usr/share/freecad/Mod/Plot... done Log: Init: Initializing /usr/share/freecad/Mod/Material... done Log: Init: Initializing /usr/share/freecad/Mod/Mesh... done Log: Init: Initializing /usr/share/freecad/Mod/Raytracing... done Log: Init: Initializing /usr/share/freecad/Mod/Part... done Log: Init: Initializing /usr/share/freecad/Mod/Path... done Log: Init: Initializing /usr/share/freecad/Mod/Arch... done Log: Init: Initializing /usr/share/freecad/Mod/Robot... done Log: Init: Initializing /usr/share/freecad/Mod/Points... done Log: Init: Initializing /usr/share/freecad/Mod/Idf(InitGui.py not found)... ignore Log: Init: Initializing /usr/share/freecad/Mod/Inspection... done Log: Init: Initializing /usr/share/freecad/Mod/Drawing... done Log: Init: Loading FreeCAD GUI Log: Init: Running FreeCADGuiInit.py start script... done Log: Init: Activating default workbench StartWorkbench Log: Loading GUI of Web module... done Log: Loading GUI of Start module... done Log: Loading Start module... done Log: Init: Showing main window Log: Main window restored Log: Show main window Log: Toolbars restored Log: Couldn't connect to spacenav daemon Log: Init: Entering event loop Log: Init: Processing command line files Log: Module: Part Log: Loading Part module... done Log: Loading Sketcher module... done Log: Loading PartDesign module... done Log: Loading GUI of Part module... done Log: Loading GUI of Sketcher module... done Log: Loading GUI of PartDesign module... done Log: Loading Inspection module... done Log: Loading TechDraw module... done Log: Loading TechDrawGui module... done Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Msg: Rebuilding Views for: Page/Page Log: TIMING - View001 GO spent: 89.252 millisecs in HLRBRep_Algo & co Log: TIMING - View001 GO spent: 5.016 millisecs in hlrToShape and BuildCurves Log: TechDraw::GeometryObject::addGeomFromCompound edgeCompound is NULL Log: TIMING - View001 DVP spent: 0.064 millisecs in GO::extractGeometry Log: TIMING - View GO spent: 6.424 millisecs in HLRBRep_Algo & co Log: TIMING - View GO spent: 0.144 millisecs in hlrToShape and BuildCurves Log: TechDraw::GeometryObject::addGeomFromCompound edgeCompound is NULL Log: TIMING - View DVP spent: 0.266 millisecs in GO::extractGeometry Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: INFO - ViewProviderPage::getMDIViewPage has no m_mdiView! Log: TIMING - QGIVP::updateView - total 0.690 millisecs Log: INFO - QGIVD::draw - no parent to update Log: INFO - QGIVD::draw - no parent to update Log: INFO - QGIVD::draw - no parent to update Log: INFO - QGIVD::draw - no parent to update Log: INFO - QGIVD::draw - no parent to update Log: INFO - QGIVD::draw - no parent to update Log: INFO - QGIVD::draw - no parent to update Log: INFO - QGIVD::draw - no parent to update Log: INFO - QGIVD::draw - no parent to update Log: INFO - QGIVD::draw - no parent to update Log: INFO - QGIVD::draw - no parent to update Log: INFO - QGIVD::draw - no parent to update Log: INFO - QGIVD::draw - no parent to update Log: INFO - QGIVD::draw - no parent to update Log: INFO - QGIVD::draw - no parent to update Log: TIMING - QGIVP::updateView - total 4.575 millisecs Log: TIMING - QGIVP::updateView - total 5.137 millisecs Log: TIMING - QGIVP::updateView - total 4.871 millisecs Msg: Log: TIMING - View GO spent: 6.559 millisecs in HLRBRep_Algo & co Log: TIMING - View GO spent: 0.121 millisecs in hlrToShape and BuildCurves Log: TechDraw::GeometryObject::addGeomFromCompound edgeCompound is NULL Log: TIMING - View DVP spent: 0.074 millisecs in GO::extractGeometry Log: TIMING - QGIVP::updateView - total 5.172 millisecs Log: TIMING - Section GO spent: 4.427 millisecs in HLRBRep_Algo & co Log: TIMING - Section GO spent: 0.097 millisecs in hlrToShape and BuildCurves Log: TechDraw::GeometryObject::addGeomFromCompound edgeCompound is NULL Log: TIMING - Section DVP spent: 0.054 millisecs in GO::extractGeometry Log: TIMING - QGIVP::updateView - total 2.578 millisecs |
should be fixed by commit 85ba410276 |
closed |
FreeCAD master 85ba4102 Edit: manually associated this ticket to the commit. |
| 2019-11-20 17:24 | SpeakerToMeat | New Issue | |
| 2019-11-20 17:24 | SpeakerToMeat | File Added: crash-log.txt | |
| 2019-11-20 18:56 | chrisb | Project | FreeCAD => TechDraw |
| 2019-12-05 01:48 | wandererfan | Note Added: 0013862 | |
| 2019-12-05 01:49 | wandererfan | Status | new => resolved |
| 2019-12-05 01:49 | wandererfan | Resolution | open => fixed |
| 2019-12-05 01:49 | wandererfan | Fixed in Version | => 0.19 |
| 2019-12-05 01:49 | wandererfan | Description Updated | |
| 2019-12-05 01:49 | wandererfan | Steps to Reproduce Updated | |
| 2019-12-05 01:49 | wandererfan | FreeCAD Information | OS: Debian GNU/Linux 10 (buster) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18. Build type: Release Python version: 2.7.16rc1 Qt version: 5.11.3 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/UnitedStates (en_US) => OS: Debian GNU/Linux 10 (buster) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18. Build type: Release Python version: 2.7.16rc1 Qt version: 5.11.3 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/UnitedStates (en_US) |
| 2019-12-10 12:09 | wandererfan | Assigned To | => wandererfan |
| 2019-12-10 12:09 | wandererfan | Status | resolved => closed |
| 2019-12-10 12:09 | wandererfan | Note Added: 0013894 | |
| 2019-12-11 11:55 | Kunda1 | Note Added: 0013900 | |
| 2019-12-11 11:56 | Kunda1 | Changeset attached | => FreeCAD master 85ba4102 |
| 2019-12-11 11:57 | Kunda1 | Note Edited: 0013900 |
