| 0004199 | Path | Bug | public | 2019-11-21 02:27 | 2020-01-24 11:35 |
| Reporter | mlampert | Assigned To | mlampert | ||
| Summary | 0004199: Path.Length reports wrong length | ||||
| Description | Some experiments with Path.Length revealed that the calculation is incorrect. As it turns out the implementation relies on all coordinates set - any not set coordinates are filled with 0 which does not result in the correct length. | ||||
| Steps To Reproduce |
The result should be 2, but because the second command's X value gets reset to 0 it's length is calculated as 1.414 | ||||
| FreeCAD Information | affects all versions | ||||
@mlampert : according guidelines, could you please open a forum thread and crosslink it with this ticket (in both directions). Thx |
Forum thread: https://forum.freecadweb.org/viewtopic.php?f=15&t=42351 |
fix: https://github.com/FreeCAD/FreeCAD/pull/2909 |
Using https://www.freecadweb.org/wiki/Tracker#MantisBT_.3C.3D.3E_GitHub_Markup I can reference the PR via
Result: FreeCAD Pull Request 2909 |
https://github.com/FreeCAD/FreeCAD/commit/099d06a29c55d57ca4f8df84b75516f8ca8b4657 |
FreeCAD master 099d06a2 Edit: retroactively associated commit to mantis |
FreeCAD: master 099d06a2 2020-01-18 19:26:10 Committer: GitHub Details Diff |
Merge pull request #2909 from mlampert/bugfix/path-length Path: Fix Path.Length calculation. |
Affected Issues 0004199 |
| mod - src/Mod/Path/App/Command.cpp | Diff File | ||
| mod - src/Mod/Path/App/Command.h | Diff File | ||
| mod - src/Mod/Path/App/Path.cpp | Diff File | ||
| mod - src/Mod/Path/PathTests/TestPathCore.py | Diff File | ||
| 2019-11-21 02:27 | mlampert | New Issue | |
| 2019-11-22 16:41 | openBrain | Tag Attached: #post-to-forum | |
| 2019-11-22 16:42 | openBrain | Note Added: 0013828 | |
| 2019-11-26 20:38 | Kunda1 | Steps to Reproduce Updated | |
| 2020-01-11 12:48 | Kunda1 | Tag Detached: #post-to-forum | |
| 2020-01-11 12:49 | Kunda1 | Note Added: 0014048 | |
| 2020-01-11 12:49 | Kunda1 | Tag Attached: #pending-forum | |
| 2020-01-17 06:51 | mlampert | Assigned To | => mlampert |
| 2020-01-17 06:51 | mlampert | Status | new => assigned |
| 2020-01-17 06:57 | mlampert | Note Added: 0014092 | |
| 2020-01-17 11:47 | Kunda1 | Note Added: 0014093 | |
| 2020-01-17 11:48 | Kunda1 | Note Edited: 0014093 | |
| 2020-01-19 18:45 | mlampert | Status | assigned => closed |
| 2020-01-19 18:45 | mlampert | Resolution | open => fixed |
| 2020-01-19 18:45 | mlampert | Fixed in Version | => 0.19 |
| 2020-01-19 18:45 | mlampert | Note Added: 0014098 | |
| 2020-01-24 11:32 | Kunda1 | Note Added: 0014105 | |
| 2020-01-24 11:32 | Kunda1 | Changeset attached | => FreeCAD master 099d06a2 |
| 2020-01-24 11:33 | Kunda1 | Tag Detached: #pending-forum | |
| 2020-01-24 11:35 | Kunda1 | Note Edited: 0014105 |
