| 0004209 | FreeCAD | Bug | public | 2019-12-01 00:03 | 2020-06-14 15:53 |
| Priority | normal | Severity | crash | Reproducibility | sometimes |
| Summary | 0004209: Crash of FreeCAD 0.19 on undo | ||||
| Description | With a certain sketch deleting of geometric elements cannot be undone. See forum discussion. | ||||
| Tags | undo | ||||
| FreeCAD Information | OS: macOS High Sierra (10.13) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.18811 (Git) Build type: Release Branch: master Hash: b809867021deb37be1039dab37b9fe1cafab254e Python version: 3.7.3 Qt version: 5.12.5 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/Germany (en_DE) | ||||
Hi! I just ran in to this myself on FreeCAD 0.19.20900 on macOS 10.13. I see that Reproducibility is set to sometimes. Do you need a reproducer for this? I have found that creating a single slot in an empty sketch, deleting one of the four lines, and hitting command-z leads to a crash ("FreeCAD quit unexpectedly") every time. The sketch with the slot already created can also be loaded from a document instead. I can provide e.g. a screen recording, document files, or more detailed description if this would be of help. |
@Feuermurmel I am now with: OS: Ubuntu 18.04.4 LTS (MATE/mate) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.21505 (Git) Build type: Debug Branch: master Hash: 9801519409c992fb964490abdefc35ae79e0b473 Python version: 3.6.9 Qt version: 5.9.5 Coin version: 4.0.0a OCC version: 7.4.1.dev I have tried to reproduce this with the version above. In the meantime there have some fixes relating to undo. Could you please check if you can reproduce your issue with a current build? |
@abdullah I can still reproduce this with the newest version available at https://github.com/FreeCAD/FreeCAD/releases OS: macOS High Sierra (10.13) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.21329 (Git) Build type: Release Branch: master Hash: 2330eef823b32ac412d839031cc174353a76b013 Python version: 3.8.2 Qt version: 5.12.5 Coin version: 4.0.0 OCC version: 7.4.0 Locale: C/Default (C) |
Notes: To reproduce select this geometry and constraints (I generally select first the tangency constraint and then the geometry): https://forum.freecadweb.org/viewtopic.php?f=3&t=41326&start=20#p407935 A possible fix in here: https://github.com/FreeCAD/FreeCAD/pull/3610 (subject to review and approval by Wmayer due to the impact in App::Document and DocumentObject). |
| 2019-12-01 00:03 | chrisb | New Issue | |
| 2020-01-10 20:54 | Kunda1 | Status | new => confirmed |
| 2020-01-10 20:54 | Kunda1 | Target Version | => 0.19 |
| 2020-02-20 21:05 | Kunda1 | Tag Attached: undo | |
| 2020-05-04 07:28 | Feuermurmel | Note Added: 0014401 | |
| 2020-05-04 07:29 | Feuermurmel | Note Edited: 0014401 | |
| 2020-05-04 07:31 | Feuermurmel | Note Edited: 0014401 | |
| 2020-06-06 17:52 | abdullah | Note Added: 0014488 | |
| 2020-06-06 21:19 | Feuermurmel | Note Added: 0014489 | |
| 2020-06-13 15:36 | abdullah | Note Added: 0014532 | |
| 2020-06-13 15:36 | abdullah | Assigned To | => abdullah |
| 2020-06-13 15:36 | abdullah | Status | confirmed => assigned |
| 2020-06-14 15:53 | wmayer | Status | assigned => closed |
| 2020-06-14 15:53 | wmayer | Resolution | open => fixed |
| 2020-06-14 15:53 | wmayer | Fixed in Version | => 0.19 |
