| 0004213 | TechDraw | Bug | public | 2019-12-05 16:46 | 2019-12-11 20:20 |
| Reporter | lathrom | Assigned To | wandererfan | ||
| OS | Windows 10 | ||||
| Summary | 0004213: No dimension text in tech draw | ||||
| Description | Dimensions have to be manually input and arbitrary property set to true for anything to show up. | ||||
| Steps To Reproduce | Any dimension created in tech draw does this | ||||
| Additional Information | Nothing crashes just doesn't work. | ||||
| FreeCAD Information | OS: Windows 10 (10.0) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.18637 (Git) Build type: Debug Branch: master Hash: e243c6e943dc78e7e8093c5c38a879e46b37d0c1 Python version: 3.6.8 Qt version: 5.12.1 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/United States (en_US) | ||||
Same as this? |
Are you using US Customary or US Construction unit schemas? |
@lathrom : please notice that according our guidelines (big yellow banner), you should always :
@lathrom please respond to above follow-up questions. thanks |
Yes I was using the customary, changed to the other and all works. |
Should be fixed by git commit c77c550033 |
closed |
c:FreeCAD:c77c550033: |
@wandererfan there is no c77c550033 Can you double check the commit hash? |
correct commit hash: 186d52ffd4 don't know where the other one came from |
At least as of Version: 0.19.18855, this is fixed |
FreeCAD master 186d52ff Edit: Manually associated commit to this PR (instead of through github) |
| 2019-12-05 16:46 | lathrom | New Issue | |
| 2019-12-06 01:06 | wandererfan | Note Added: 0013873 | |
| 2019-12-06 01:07 | wandererfan | Status | new => feedback |
| 2019-12-06 01:07 | wandererfan | Note Added: 0013874 | |
| 2019-12-06 11:09 | openBrain | Note Added: 0013879 | |
| 2019-12-09 14:04 | Kunda1 | Note Added: 0013884 | |
| 2019-12-09 14:23 | lathrom | Note Added: 0013886 | |
| 2019-12-09 14:23 | lathrom | Status | feedback => new |
| 2019-12-09 14:41 | wandererfan | Note Added: 0013887 | |
| 2019-12-09 14:42 | wandererfan | Status | new => resolved |
| 2019-12-09 14:42 | wandererfan | Resolution | open => fixed |
| 2019-12-09 14:42 | wandererfan | Fixed in Version | => 0.19 |
| 2019-12-10 12:08 | wandererfan | Assigned To | => wandererfan |
| 2019-12-10 12:08 | wandererfan | Status | resolved => closed |
| 2019-12-10 12:08 | wandererfan | Note Added: 0013893 | |
| 2019-12-11 11:51 | Kunda1 | Note Edited: 0013887 | |
| 2019-12-11 11:53 | Kunda1 | Note Edited: 0013887 | |
| 2019-12-11 11:53 | Kunda1 | Note Added: 0013898 | |
| 2019-12-11 11:54 | Kunda1 | Status | closed => feedback |
| 2019-12-11 11:54 | Kunda1 | Resolution | fixed => reopened |
| 2019-12-11 11:54 | Kunda1 | Note Added: 0013899 | |
| 2019-12-11 13:30 | wandererfan | Note Added: 0013901 | |
| 2019-12-11 14:15 | lathrom | Note Added: 0013902 | |
| 2019-12-11 14:15 | lathrom | Status | feedback => assigned |
| 2019-12-11 20:18 | Kunda1 | Note Added: 0013904 | |
| 2019-12-11 20:18 | Kunda1 | Changeset attached | => FreeCAD master 186d52ff |
| 2019-12-11 20:19 | Kunda1 | Note Edited: 0013904 | |
| 2019-12-11 20:20 | Kunda1 | Status | assigned => closed |
