| 0004226 | Part | Bug | public | 2019-12-15 20:19 | 2020-01-10 20:53 |
| Reporter | stanley82 | Assigned To | |||
| Priority | normal | Severity | major | Reproducibility | sometimes |
| Platform | Linux | OS | LinuxMint | OS Version | 18.3 |
| Summary | 0004226: Conflict window1 and window2 | ||||
| Description | In window1 I have parts A and B. In window2 I have parts X and Y. In all cases cubes. What I found was that I had Window1 part A active but under combo view (top left) I was still editing the size and position of window2 part X. I am new to Freecad so I was lost as things were changing that I had not changed. The work round was usually a couple of clicks on the cube that I wanted to edit to fix things. I am using Freecad 18 but I also have the Mint default 15 on my machine and I must say that getting 18 up and running was a snap thanks. Ian. | ||||
| Steps To Reproduce | Simply have proj1 and proj2 open at the same time and under Window select between proj1 and proj2. | ||||
| Tags | #post-to-forum | ||||
@stanley82 : thanks for reporting. However per our guidelines (big yellow box on top of the page), please open first a topic in our forum to discuss the issue, so it can be eventually confirmed & identified by the community. Thx |
What a mess this has turned out to be. My password seems to be invalid. I try to register again and it's asking to answer a question (looks to be the one greyed out) but that still does not work. Anyway I only got as far as ONC S1 tech drawing and I'm not a geek so I'm really lost with this. I've made a couple of simple snippets to demo the problem only it's no longer apparent so lets drop it for now. Regards Ian. |
@stanley82 sorry to hear you're acting trouble. best to open a thread first on the forum and get feedback from the community. Also we recommend testing on 0.19pre since it orders of magnitude ahead of 0.18.4 Closing this ticket now |
| 2019-12-15 20:19 | stanley82 | New Issue | |
| 2019-12-16 15:11 | openBrain | Tag Attached: #post-to-forum | |
| 2019-12-16 15:13 | openBrain | Status | new => feedback |
| 2019-12-16 15:13 | openBrain | Note Added: 0013912 | |
| 2019-12-16 20:19 | stanley82 | Note Added: 0013915 | |
| 2019-12-16 20:19 | stanley82 | Status | feedback => new |
| 2020-01-10 20:53 | Kunda1 | Status | new => closed |
| 2020-01-10 20:53 | Kunda1 | Resolution | open => unable to reproduce |
| 2020-01-10 20:53 | Kunda1 | Note Added: 0014039 |
