| 0004230 | Part | Bug | public | 2019-12-21 17:41 | 2019-12-30 15:30 |
| Reporter | lutz_dd | Assigned To | |||
| Summary | 0004230: 2nd edit of Chamfer @ Part-WB crashes, while 1st edit reports "Illegal storage access!" in the ReportView | ||||
| Description | I'm getting pretty reliable a crash if a chamfer is edited a 2nd time in the current session while ignoring "... restart the application" in the ReportView. My setup is clean after fresh installation with the old directory App/Roaming/Freecad renamed. - My previous version FC 0.19.18760 from Nov/18th/2019 does not express this behavior @ win7 - According to https://forum.freecadweb.org/viewtopic.php?f=3&t=41849#p355440 latest checked functional version is 0.19.18846 - Latest version FC 0.19.18990 from Dec/18th/2019 is still having this issue @ Win7 | ||||
| Steps To Reproduce | Start FreeCad ... Edit/Preferences . . . change Language to "English" . . . The ReportView returns . . . "Failed to load UI file from ':/ui/preferences-dxf.ui'" File/New Change WB-Start -> WB-Part Part/Primitives/Cube Part/Chamfer... . . . Select Edge1 . . . Press OK Select the "Chamfer" in ComboView/Model-Tab RMB (RightMouseButton) over the "Chamfer" ... choose "Edit chamfer edges" . . . Press OK . . . The ReportView returns . . . Illegal storage access / <Exception> Illegal storage access! Please save your work under a new file name and restart the application! RMB (RightMouseButton) over the "Chamfer" ... choose "Edit chamfer edges" . . . Press OK . . . Crash | ||||
| Additional Information | see https://forum.freecadweb.org/viewtopic.php?f=3&t=41849 (reported OS: Win7Pro, Win8.1, Debian, macOS) | ||||
| Tags | #tobeclosed, Chamfer, fillet | ||||
| FreeCAD Information | OS: Windows 7 SP 1 (6.1) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.18990 (Git) Build type: Release Branch: master Hash: e499f384240196c415f207520bfbcb8df9d1b0d2 Python version: 3.7.3 Qt version: 5.12.5 Coin version: 4.0.0a OCC version: 7.3.0 Locale: German/Germany (de_DE) | ||||
The same bug is present if the Fillet tool is used instead, both with version 0.19.18990 and 0.19.19060, but not in 0.19.18842. OS: Windows 7 SP 1 (6.1) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.19060 (Git) Build type: Release Branch: master Hash: 72065b0d3960ec9b4aa90cce1a6e810e8bab68c4 Python version: 3.6.8 Qt version: 5.12.1 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/United States (en_US) OS: Windows 7 SP 1 (6.1) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.18842 (Git) Build type: Release Branch: master Hash: 2fa9369d4203f33c62afddfbe190bb4e089d1840 Python version: 3.6.8 Qt version: 5.12.1 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/United States (en_US) |
A PR has been submitted: FreeCAD Pull Request 2835 by github user rajendrasp |
This ticket is assigned to rajendrasp (doesn't have a mantis login). |
@Kunda1 thanks for the comments. I am getting used to the process with FreeCAD development. Will surely take a note to leave a comment on the issue page while working on an issue |
PR didn't reference this ticket correctly. so I'm manually associating it: PR merged in FreeCAD master 28d67eba |
@lutz_dd please test to see if fix indeed fixes the bug. |
| 2019-12-21 17:41 | lutz_dd | New Issue | |
| 2019-12-21 17:43 | lutz_dd | Tag Attached: 0.19 | |
| 2019-12-21 17:43 | lutz_dd | Tag Attached: Chamfer | |
| 2019-12-21 17:43 | lutz_dd | Tag Attached: Part | |
| 2019-12-21 17:43 | lutz_dd | Tag Attached: crash | |
| 2019-12-21 17:45 | lutz_dd | Additional Information Updated | |
| 2019-12-23 17:16 | openBrain | Tag Detached: Part | |
| 2019-12-23 17:16 | openBrain | Tag Detached: crash | |
| 2019-12-23 17:16 | openBrain | Tag Detached: 0.19 | |
| 2019-12-23 17:20 | openBrain | Status | new => acknowledged |
| 2019-12-25 21:36 | otoien | Note Added: 0013941 | |
| 2019-12-25 21:38 | otoien | Tag Attached: fillet | |
| 2019-12-28 13:01 | Kunda1 | Note Added: 0013946 | |
| 2019-12-28 13:09 | Kunda1 | Status | acknowledged => assigned |
| 2019-12-28 13:09 | Kunda1 | Note Added: 0013947 | |
| 2019-12-28 13:09 | Kunda1 | Target Version | => 0.19 |
| 2019-12-28 13:10 | Kunda1 | Tag Attached: #pending | |
| 2019-12-28 15:28 | rajendrasp79 | Note Added: 0013948 | |
| 2019-12-30 15:19 | Kunda1 | Note Added: 0013959 | |
| 2019-12-30 15:20 | Kunda1 | Note Edited: 0013959 | |
| 2019-12-30 15:20 | Kunda1 | Changeset attached | => FreeCAD master 28d67eba |
| 2019-12-30 15:21 | Kunda1 | Tag Detached: #pending | |
| 2019-12-30 15:21 | Kunda1 | Tag Attached: #tobeclosed | |
| 2019-12-30 15:23 | Kunda1 | Status | assigned => resolved |
| 2019-12-30 15:23 | Kunda1 | Resolution | open => fixed |
| 2019-12-30 15:23 | Kunda1 | Fixed in Version | => 0.19 |
| 2019-12-30 15:23 | Kunda1 | Note Added: 0013960 | |
| 2019-12-30 15:30 | wmayer | Status | resolved => closed |
