| 0004254 | PartDesign | Bug | public | 2020-01-23 20:41 | 2020-03-24 15:51 |
| Reporter | Genues | Assigned To | wmayer | ||
| Summary | 0004254: Crash when canceling duplicate sketch in PartDesign | ||||
| Description | FreeCAD crash when canceling duplicate skecth in PartDesign. | ||||
| Steps To Reproduce | 1. Create new document. 2. Create new body and sketch in PartDesign. 3. Draw rectangle in sketch. 4. Close sketch. 5. Select sketch and press "Duplicate selection" in menu "Edit". 6. Press "Cancel". | ||||
| Additional Information | Forum Thread: https://forum.freecadweb.org/viewtopic.php?f=8&t=42676 | ||||
| Tags | 0.19, crash, duplicate, Part Design, Sketch | ||||
| FreeCAD Information | OS: Arch Linux (XFCE/xfce) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.19323 (Git) AppImage Build type: Release Branch: master Hash: 1b198453b8eb6aa2eaca4e4be4b49fee74e9de6e Python version: 3.8.1 Qt version: 5.12.5 Coin version: 4.0.0 OCC version: 7.4.0 Locale: Russian/Russia (ru_RU) | ||||
crash.log (5,105 bytes)
/tmp/.mount_freecaA4HX8r FreeCAD 0.19, Libs: 0.19R19323 (Git) © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2020 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## Loading Assembly 4 WorkBench. © Zoltan Hubert connect failed: Нет такого файла или каталога Program received signal SIGSEGV, Segmentation fault. #0 /usr/lib/libc.so.6(+0x3bfb0) [0x7f57c9af5fb0] #1 0x7f5796b1c7b8 in CmdPartDesignDuplicateSelection::activated(int) from /tmp/.mount_freecaA4HX8r/usr/lib/PartDesignGui.so+0x468 #2 0x7f57cc343851 in Gui::Command::invoke(int, Gui::Command::TriggerSource) from /tmp/.mount_freecaA4HX8r/usr/bin/../lib/libFreeCADGui.so+0x321 #3 0x7f57ca0357b8 in QMetaObject::activate(QObject*, int, int, void**) from /tmp/.mount_freecaA4HX8r/usr/bin/../lib/libQt5Core.so.5+0x780 #4 0x7f57ca84396e in QAction::triggered(bool) from /tmp/.mount_freecaA4HX8r/usr/bin/../lib/libQt5Widgets.so.5+0x32 #5 0x7f57ca845239 in QAction::activate(QAction::ActionEvent) from /tmp/.mount_freecaA4HX8r/usr/bin/../lib/libQt5Widgets.so.5+0xcb #6 /tmp/.mount_freecaA4HX8r/usr/bin/../lib/libQt5Widgets.so.5(+0x264252) [0x7f57ca938252] #7 /tmp/.mount_freecaA4HX8r/usr/bin/../lib/libQt5Widgets.so.5(+0x268e09) [0x7f57ca93ce09] #8 0x7f57ca93d59a in QMenu::mouseReleaseEvent(QMouseEvent*) from /tmp/.mount_freecaA4HX8r/usr/bin/../lib/libQt5Widgets.so.5+0xc6 #9 0x7f57ca873c3e in QWidget::event(QEvent*) from /tmp/.mount_freecaA4HX8r/usr/bin/../lib/libQt5Widgets.so.5+0xce #10 0x7f57ca93ece1 in QMenu::event(QEvent*) from /tmp/.mount_freecaA4HX8r/usr/bin/../lib/libQt5Widgets.so.5+0x2d1 #11 0x7f57ca84882a in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /tmp/.mount_freecaA4HX8r/usr/bin/../lib/libQt5Widgets.so.5+0xde #12 0x7f57ca84d095 in QApplication::notify(QObject*, QEvent*) from /tmp/.mount_freecaA4HX8r/usr/bin/../lib/libQt5Widgets.so.5+0x79d #13 0x7f57cc309ce9 in Gui::GUIApplication::notify(QObject*, QEvent*) from /tmp/.mount_freecaA4HX8r/usr/bin/../lib/libFreeCADGui.so+0x89 #14 0x7f57ca01f186 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /tmp/.mount_freecaA4HX8r/usr/bin/../lib/libQt5Core.so.5+0x88 #15 0x7f57ca84c53f in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool, bool) from /tmp/.mount_freecaA4HX8r/usr/bin/../lib/libQt5Widgets.so.5+0x283 #16 /tmp/.mount_freecaA4HX8r/usr/bin/../lib/libQt5Widgets.so.5(+0x1aefe4) [0x7f57ca882fe4] #17 /tmp/.mount_freecaA4HX8r/usr/bin/../lib/libQt5Widgets.so.5(+0x1b03a6) [0x7f57ca8843a6] #18 0x7f57ca84882a in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /tmp/.mount_freecaA4HX8r/usr/bin/../lib/libQt5Widgets.so.5+0xde #19 0x7f57ca84e3f1 in QApplication::notify(QObject*, QEvent*) from /tmp/.mount_freecaA4HX8r/usr/bin/../lib/libQt5Widgets.so.5+0x1af9 #20 0x7f57cc309ce9 in Gui::GUIApplication::notify(QObject*, QEvent*) from /tmp/.mount_freecaA4HX8r/usr/bin/../lib/libFreeCADGui.so+0x89 #21 0x7f57ca01f186 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /tmp/.mount_freecaA4HX8r/usr/bin/../lib/libQt5Core.so.5+0x88 #22 0x7f57ca3c540b in QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) from /tmp/.mount_freecaA4HX8r/usr/bin/../lib/libQt5Gui.so.5+0x6d3 #23 0x7f57ca3c5ff7 in QGuiApplicationPrivate::processWindowSystemEvent(QWindowSystemInterfacePrivate::WindowSystemEvent*) from /tmp/.mount_freecaA4HX8r/usr/bin/../lib/libQt5Gui.so.5+0x175 #24 0x7f57ca3b2dd4 in QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_freecaA4HX8r/usr/bin/../lib/libQt5Gui.so.5+0x64 #25 /tmp/.mount_freecaA4HX8r/usr/plugins/platforms/../../lib/libQt5XcbQpa.so.5(+0x5af0e) [0x7f57c5acdf0e] #26 /tmp/.mount_freecaA4HX8r/usr/bin/../lib/./libglib-2.0.so.0(g_main_context_dispatch+0x2e8) [0x7f57c70ab9d8] #27 /tmp/.mount_freecaA4HX8r/usr/bin/../lib/./libglib-2.0.so.0(+0x51c21) [0x7f57c70abc21] #28 /tmp/.mount_freecaA4HX8r/usr/bin/../lib/./libglib-2.0.so.0(g_main_context_iteration+0x2e) [0x7f57c70abcae] #29 0x7f57ca04e42b in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_freecaA4HX8r/usr/bin/../lib/libQt5Core.so.5+0x63 #30 0x7f57ca01bbc1 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_freecaA4HX8r/usr/bin/../lib/libQt5Core.so.5+0x187 #31 0x7f57ca01fa39 in QCoreApplication::exec() from /tmp/.mount_freecaA4HX8r/usr/bin/../lib/libQt5Core.so.5+0x105 #32 0x7f57cc2898d0 in Gui::Application::runApplication() from /tmp/.mount_freecaA4HX8r/usr/bin/../lib/libFreeCADGui.so+0x15b0 #33 /tmp/.mount_freecaA4HX8r/usr/bin/freecad(main+0x74d) [0x555fe13c87cd] #34 /usr/lib/libc.so.6(__libc_start_main+0xf3) [0x7f57c9ae1153] #35 /tmp/.mount_freecaA4HX8r/usr/bin/freecad(+0x451f) [0x555fe13c951f] |
Per the guidelines, please post this issue to the FreeCAD forums for the community to discuss. Many issues/bugs are addressed this way without needing to open tickets for them to track. Tracking bugs is decided by the community. Nevertheless, thanks for letting us know. In the futire please familiarize yourself with our tracker guidelines (yellow banner top of this page) |
@Kunda1 I don't know what I did wrong? I first created a topic on the forum and when I was advised to make a bug report I will do it. The link to the forum thread was published immediately when creating the bug report, and the link to bug report is published in the forum thread. |
@Genues : Please forget ! :) @Kunda1 probably goes too fast (everybody's prone to making mistake). You perfectly followed the reporting workflow and that's great. ;) BTW @Kunda1, you self-assigned the ticket. Is this correct ? |
@openBrain thank you ) |
Apologies, too many tabs open probably. Thanks for the ticket. I've unassigned myself. |
https://github.com/FreeCAD/FreeCAD/commit/107831e0a |
FreeCAD master 107831e0 |
| 2020-01-23 20:41 | Genues | New Issue | |
| 2020-01-23 20:41 | Genues | Tag Attached: 0.19 | |
| 2020-01-23 20:41 | Genues | Tag Attached: crash | |
| 2020-01-23 20:41 | Genues | Tag Attached: duplicate | |
| 2020-01-23 20:41 | Genues | Tag Attached: Part Design | |
| 2020-01-23 20:41 | Genues | Tag Attached: Sketch | |
| 2020-01-23 20:41 | Genues | File Added: crash.log | |
| 2020-01-24 11:37 | Kunda1 | Tag Attached: #post-to-forum | |
| 2020-01-24 11:39 | Kunda1 | Assigned To | => Kunda1 |
| 2020-01-24 11:39 | Kunda1 | Status | new => feedback |
| 2020-01-24 11:39 | Kunda1 | Note Added: 0014106 | |
| 2020-01-24 13:21 | Genues | Note Added: 0014107 | |
| 2020-01-24 13:21 | Genues | Status | feedback => assigned |
| 2020-01-24 18:01 | openBrain | Tag Detached: #post-to-forum | |
| 2020-01-24 18:03 | openBrain | Note Added: 0014109 | |
| 2020-01-25 19:25 | Genues | Note Added: 0014111 | |
| 2020-02-05 16:22 | Kunda1 | Status | assigned => confirmed |
| 2020-02-05 16:22 | Kunda1 | Note Added: 0014141 | |
| 2020-02-05 16:24 | Kunda1 | Additional Information Updated | |
| 2020-02-05 16:26 | Kunda1 | Severity | major => crash |
| 2020-02-05 16:26 | Kunda1 | Target Version | => 0.19 |
| 2020-03-24 14:16 | wmayer | Status | confirmed => closed |
| 2020-03-24 14:16 | wmayer | Resolution | open => fixed |
| 2020-03-24 14:16 | wmayer | Fixed in Version | => 0.19 |
| 2020-03-24 14:16 | wmayer | Note Added: 0014282 | |
| 2020-03-24 15:11 | Kunda1 | Note Added: 0014283 | |
| 2020-03-24 15:12 | Kunda1 | Note Edited: 0014283 | |
| 2020-03-24 15:51 | wmayer | Changeset attached | => FreeCAD master 107831e0 |
| 2020-03-24 15:51 | wmayer | Note Added: 0014284 | |
| 2020-03-24 15:51 | wmayer | Assigned To | Kunda1 => wmayer |
