| 0004260 | Path | Bug | public | 2020-02-03 09:40 | 2020-08-04 16:00 |
| Reporter | freman | Assigned To | sliptonic | ||
| Summary | 0004260: boundaryDressup causing tool crashes. | ||||
| Description | boundarydressup inserts spurious machine position which leads to non vertical cut paths across protected clamps space. This can damage clamps and likely destroy tools, possibly dangerously. https://forum.freecadweb.org/viewtopic.php?f=15&t=42820 | ||||
| Steps To Reproduce | I've detailed this once and bug reporter lost it. I won't start again. Refer to forum post. | ||||
| FreeCAD Information | OS: Fedora 31 (Thirty One) (LXDE/LXDE) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.19317 (Git) Build type: Release Branch: spiral-fix Hash: 2064410da473da178cf79cb8d80ef48952df00c5 Python version: 3.7.6 Qt version: 5.13.2 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/United Kingdom (en_GB) | ||||
PR to avoid possible tool crashes. https://github.com/FreeCAD/FreeCAD/pull/3009 |
@fremen FYI, it's also possible to reference PRs in github using
Which looks like this when it's interpreted by Mantisbt. FreeCAD Pull Request 3009 See https://www.freecadweb.org/wiki/Tracker#MantisBT_.3C.3D.3E_GitHub_Markup for more info. |
FreeCAD: master c944aafc 2020-02-08 15:10:50 J-Dunn Committer: GitHub Details Diff |
fix missing HorizFeed in boundaryDressup fix missing HorizFeed in boundaryDressup see bug 0004260 |
Affected Issues 0004260 |
| mod - src/Mod/Path/PathScripts/PathDressupPathBoundary.py | Diff File | ||
FreeCAD: master 5c67c40d 2020-08-04 15:40:13 Committer: GitHub Details Diff |
Merge pull request 0003751 from J-Dunn/master Path: prevent added paths creating tool crash: fixed 0004260 |
| 2020-02-03 09:40 | freman | New Issue | |
| 2020-02-04 16:16 | Kunda1 | Target Version | => 0.19 |
| 2020-02-05 21:43 | freman | Note Added: 0014142 | |
| 2020-02-07 18:22 | Kunda1 | Note Added: 0014143 | |
| 2020-02-07 18:24 | Kunda1 | Note Edited: 0014143 | |
| 2020-03-02 20:16 | Changeset attached | => FreeCAD master c944aafc | |
| 2020-08-04 16:00 | sliptonic | Changeset attached | => FreeCAD master 5c67c40d |
| 2020-08-04 16:00 | sliptonic | Note Added: 0014699 | |
| 2020-08-04 16:00 | sliptonic | Assigned To | => sliptonic |
| 2020-08-04 16:00 | sliptonic | Status | new => closed |
| 2020-08-04 16:00 | sliptonic | Resolution | open => fixed |
