| 0004263 | FreeCAD | Bug | public | 2020-02-10 09:40 | 2022-02-05 02:07 |
| Reporter | jylandry | Assigned To | |||
| Summary | 0004263: Problem with negative offset "Placement" when the preference are "Building US" units | ||||
| Description | https://forum.freecadweb.org/viewtopic.php?f=8&t=42766 When using "Placement" for an object and working with the unit in "Building US(ft-in/sqft/cuft)" You can't work with negative number. For example, «-1.5"» or «-1+1/2"» will translate to «-1/2» The same for «-13'6"» that will become «-12'6"» | ||||
| Steps To Reproduce | 1) Put your preference in "Building US(ft-in/sqft/cuft)" 2) Create an empty document with an object like a cube (or anything will do) 3) try to change the "placement" (Translation) -- any of X: Y: or Z: -- Enter «-1.5"» or «-1+1/2"» or «-13'6"» if you return in placement, the entry «-1.5"» should have been change to «-1/2"» the entry «-13'6"» shall have been change by «-12'6"» | ||||
| Tags | #pending-forum, #ready-for-migration, units | ||||
| FreeCAD Information | OS: Ubuntu 18.04.4 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.4. Build type: Release Python version: 3.6.8 Qt version: 5.9.5 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/UnitedStates (en_US) | ||||
| related to | 0003925 | confirmed | Expressions | Negative numbers with multiple units interpeted as expressions |
Could that be a duplicate of 0003925 ? |
I look at it. Some aspect of 0003925 might exhibit the same symptom. However, their is additional problem with the Building US unit related to the interpretation of the fraction. a) When you enter -10+1/8" and click OK on the "Placement box"... you get -9+7/8". This might be similar to 0003925. b) When you re-enter the "Placement Box", it does display -8+1/8". I don't think it is the same. |
if you look at the post https://forum.freecadweb.org/viewtopic.php?f=8&t=42766 I have documented several cases scenario... including one that is not flagged as a bug. |
Independently observed again in 0.19.22366 and discussed in thread : https://forum.freecadweb.org/viewtopic.php?p=429940#p429940 |
@openBrain since you've been tackling 'units' do you want to assign yourself to these tickets tagged as 'units' ? |
@Kunda1 : certainly not. This ticket implies dealing with lexers and parsers, that I'm not totally not capable. ;) |
This ticket has been migrated to GitHub as issue 6029. |
| 2020-02-10 09:40 | jylandry | New Issue | |
| 2020-02-10 11:00 | openBrain | Relationship added | related to 0003925 |
| 2020-02-10 11:00 | openBrain | Note Added: 0014144 | |
| 2020-02-11 02:16 | jylandry | Note Added: 0014149 | |
| 2020-02-11 02:17 | jylandry | Note Added: 0014150 | |
| 2020-02-20 21:29 | Kunda1 | Tag Attached: units | |
| 2020-02-20 21:30 | Kunda1 | Target Version | => 0.19 |
| 2020-02-20 21:30 | Kunda1 | Tag Attached: #pending-forum | |
| 2020-09-12 15:07 | pablito | Note Added: 0014744 | |
| 2022-01-23 00:02 | Kunda1 | Note Added: 0016249 | |
| 2022-01-25 15:34 | openBrain | Note Added: 0016295 | |
| 2022-02-05 02:07 | Kunda1 | Tag Attached: #ready-for-migration |
