| 0004278 | Draft | Bug | public | 2020-03-03 15:11 | 2021-03-30 20:13 |
| Reporter | fc_tofu | Assigned To | marioalexis | ||
| Platform | X64 | OS | Win10 | ||
| Summary | 0004278: Working Plane Proxy origin hijack nearby object | ||||
| Description | Working Plane Proxy's origin forces nearby object movement snapped to it. | ||||
| Steps To Reproduce | 1. DraftWB, turn off snap bar 2. create a Working Plane Proxy (WPP) object and a circle 3. move circle, the intentional destination is somewhere in WPP area, but not WPP origin 4. when cursor entering into WPP area, an "End Point" snap sign appear on cursor, and... 5. circle is snapped to the WPP origin. Document | ||||
| Additional Information | Forum post | ||||
| FreeCAD Information | OS: Windows 10 (10.0) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.19697 (Git) Build type: Release Branch: master Hash: 8832356802011bf5d70e9d6f0efa89c47bc70a91 Python version: 3.7.3 Qt version: 5.12.5 Coin version: 4.0.0a OCC version: 7.3.0 Locale: Chinese/China (zh_CN) | ||||
I can also confirm this occurs. A few notes: - The WPP will hijack pretty much all mouse movements where you need to select a point, such as when creating an object, not just the move tool. - It still occurs when there are more than one WPP. - The error's snapping does not occur when the snap button "nearest" is set. side note from something I discovered accidentally while looking into this: If you select Draft's "select working plane button", and don't create a working plane, DraftSelectPlane.handle appears to fire every single time you click from then onwards. Doing this again, causes DraftSelectPlane.handle to fire an additional time per click. I'm fairly certain this is totally unrelated, but I wanted to document it here anyway. |
Closed. @marioalexis I've added you as a developer here on the bugtracker. Thanks for all you contributions! |
FreeCAD: master 0efc7a3e 2021-02-09 21:00:36 Details Diff |
Draft: Fix snap to proxy WP and BuildingParts - fixes 0004278 |
Affected Issues 0004278 |
| mod - src/Mod/Draft/draftguitools/gui_snapper.py | Diff File | ||
FreeCAD: master 37ef8ee2 2021-03-30 11:16:14 Committer: GitHub Details Diff |
Merge pull request 0004410 from marioalexis84/draft-snap Draft: Fixes 0004278: Working Plane Proxy origin hijack nearby object |
| 2020-03-03 15:11 | fc_tofu | New Issue | |
| 2020-03-03 16:21 | fc_tofu | Description Updated | |
| 2020-03-08 04:00 | David_D | Note Added: 0014217 | |
| 2020-03-10 22:22 | Kunda1 | Status | new => confirmed |
| 2020-03-10 22:22 | Kunda1 | Target Version | => 0.19 |
| 2020-03-10 22:22 | Kunda1 | Tag Attached: #pending-forum | |
| 2021-03-30 11:30 | yorik | Changeset attached | => FreeCAD master 37ef8ee2 |
| 2021-03-30 11:30 | marioalexis | Changeset attached | => FreeCAD master 0efc7a3e |
| 2021-03-30 11:30 | marioalexis | Note Added: 0015586 | |
| 2021-03-30 20:13 | Kunda1 | Assigned To | => marioalexis |
| 2021-03-30 20:13 | Kunda1 | Status | confirmed => closed |
| 2021-03-30 20:13 | Kunda1 | Resolution | open => fixed |
| 2021-03-30 20:13 | Kunda1 | Fixed in Version | => 0.20 |
| 2021-03-30 20:13 | Kunda1 | Note Added: 0015587 | |
| 2021-03-30 20:13 | Kunda1 | Tag Detached: #pending-forum |
