| 0004285 | FreeCAD | Bug | public | 2020-03-10 14:31 | 2020-06-09 11:40 |
| Reporter | fc_tofu | Assigned To | wandererfan | ||
| Platform | x64 | OS | Windows 10 | OS Version | 10.0.17763.1039 |
| Summary | 0004285: PartWB Bevel/Chamfer command invert surface normal | ||||
| Description | PartWB, Bevel/Chamfer on 3D Offset solid (positive distance)/Thickness solid causes inverted surface normal. | ||||
| Steps To Reproduce | Reproduce 1: 1. Create a plane object. Copy and move apart for comparision. 2. use "3D offset" command on above planes to make solid("Fill offset"), one with positive offset, other use negative offset. (Here found another minor issue, "3D offset" command won't toggle off planes' visibility after generating new feature history.) 3. "Chamfer" command on abvove solids. 3.1 surface normal on positive offset solid is inverted, except chamfer area. 3.2 for comparison, surface normal on negative offset solid is correct. Reproduce 2: 1. Create cube 100mm * 100mm * 100mm. 2. Select top face, use Thickness command, 10mm thick 3. Select any edge 4. Chamfer(or Bevel) 5mm. Result: surface normal invert except Chamfer area. | ||||
| Additional Information | Solid from Extrude/Revolve/Loft/Sweep is not affected by this bug. Discussion: Forum thread | ||||
| Tags | Chamfer, Part | ||||
| FreeCAD Information | OS: Windows 10 (10.0) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.19858 (Git) Build type: Release Branch: master Hash: dbe292496b56147c081761084774f42bda56ea90 Python version: 3.7.3 Qt version: 5.12.5 Coin version: 4.0.0a OCC version: 7.3.0 Locale: Chinese/China (zh_CN) | ||||
Fix committed: https://github.com/FreeCAD/FreeCAD/commit/b7ba72bf8fc4024e02d8587e35856f3c1172f36b by @wandererfan |
FreeCAD: master 73f086f7 2020-06-07 15:25:18 Details Diff |
[Part]Fix 0004285 Bad Shape from Chamfer - chamfer was producing invalid shape as output. fix uses shapefix to correct invalid surface/face. |
Affected Issues 0004285 |
| mod - src/Mod/Part/App/FeatureChamfer.cpp | Diff File | ||
FreeCAD: master b7ba72bf 2020-06-07 19:41:52 Committer: GitHub Details Diff |
Merge pull request 0003579 from WandererFan/prefDirs [Part]Fix 0004285 Bad Shape from Chamfer |
| mod - src/Mod/TechDraw/Gui/DlgPrefsTechDrawGeneral.ui | Diff File | ||
| 2020-03-10 14:31 | fc_tofu | New Issue | |
| 2020-03-10 14:31 | fc_tofu | Tag Attached: Chamfer | |
| 2020-03-10 14:31 | fc_tofu | Tag Attached: Part | |
| 2020-03-10 14:31 | fc_tofu | File Added: fc019pre_bevel_on_3doffsetsolid.FCStd | |
| 2020-03-10 14:31 | fc_tofu | File Added: fc019pre_partwb_chamfer_on_thinkness.FCStd | |
| 2020-03-10 18:28 | openBrain | Status | new => confirmed |
| 2020-06-07 15:31 | wandererfan | Assigned To | => wandererfan |
| 2020-06-07 15:31 | wandererfan | Status | confirmed => assigned |
| 2020-06-07 22:49 | uwestoehr | Note Added: 0014515 | |
| 2020-06-07 22:50 | uwestoehr | Additional Information Updated | |
| 2020-06-09 11:40 | wandererfan | Changeset attached | => FreeCAD master b7ba72bf |
| 2020-06-09 11:40 | wandererfan | Changeset attached | => FreeCAD master 73f086f7 |
| 2020-06-09 11:40 | wandererfan | Note Added: 0014520 | |
| 2020-06-09 11:40 | wandererfan | Status | assigned => closed |
| 2020-06-09 11:40 | wandererfan | Resolution | open => fixed |
