| 0004287 | FreeCAD | Feature | public | 2020-03-12 09:27 | 2020-03-22 22:21 |
| Reporter | SarenT | Assigned To | |||
| Summary | 0004287: Alias field next to contents | ||||
| Description | Making parametric designs in FreeCAD is a useful feature. One challenge is to create aliases in the spread sheet. Often while working in other workbenches, I decide to create new values with aliases. Then I open the spreadsheet and I need to click a few times to get to alias setting (right click on cell, alias tab and select field). There is a short cut for alias setting: CTRL+SHIFT+A. However, for that I need to switch to Spreadsheet workbench from current workbench, which also costs some clicks. How about, we get an alias field right next to contents field (right above the spreadsheet cells and below the toolbars)? There is plenty of space there and 3 most important settings for cells are: content, unit and alias. The styles (colors, alignment and style) don't matter as much as the those. Units can be set by typing it with the numbers: eg: "2mm". Only inaccessible but important field is the "alias". ![]() | ||||
| Steps To Reproduce | Opening spreadsheet in any workbench is enough to see missing alias field. | ||||
| FreeCAD Information | OS: Ubuntu 18.04.4 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.4. Build type: Release Python version: 3.6.8 Qt version: 5.9.5 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/UnitedStates (en_US) But it is same in 19.04. | ||||
Here is the (positive) community feedback from the forums: https://forum.freecadweb.org/viewtopic.php?f=8&t=43957&sid=4c0e3413995dd135edd95f78ba74047a |
FreeCAD Pull Request 3154 |
https://github.com/FreeCAD/FreeCAD/commit/de1cc43b0b3d0384f878c7d11256ac0d0ae2d3c0 https://github.com/FreeCAD/FreeCAD/commit/c337cfeec2d0ea310b94696b4d0f38aac5dfecc3 https://github.com/FreeCAD/FreeCAD/commit/520b5cc0aad866d7dc940991dfcb3ac39a935919 |
| 2020-03-12 09:27 | SarenT | New Issue | |
| 2020-03-12 09:28 | SarenT | Note Added: 0014222 | |
| 2020-03-12 11:48 | Kunda1 | Note Added: 0014224 | |
| 2020-03-12 14:53 | wmayer | Status | new => closed |
| 2020-03-12 14:53 | wmayer | Resolution | open => fixed |
| 2020-03-12 14:53 | wmayer | Fixed in Version | => 0.19 |
| 2020-03-12 14:53 | wmayer | Note Added: 0014226 | |
| 2020-03-22 22:21 | TheMarkster | Changeset attached | => FreeCAD master 1ee2c4d8 |
| 2020-03-22 22:21 | guest | Note Added: 0014263 |
